[GRASS-SVN] r30440 - grass/trunk/scripts/v.db.dropcol
svn_grass at osgeo.org
Mon Mar 3 06:52:56 EST 2008
Author: msieczka
Date: 2008-03-03 06:52:55 -0500 (Mon, 03 Mar 2008)
New Revision: 30440
grass/trunk/scripts/v.db.dropcol/v.db.dropcol
Remove whitespace. More standarization.
Modified: grass/trunk/scripts/v.db.dropcol/v.db.dropcol
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcol 2008-03-03 11:41:49 UTC (rev 30439)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcol 2008-03-03 11:52:55 UTC (rev 30440)
@@ -3,7 +3,7 @@
# MODULE: v.db.dropcolumn
-# AUTHOR(S): Markus Neteler
+# AUTHOR(S): Markus Neteler
# PURPOSE: interface to db.execute to drop a column from the
# attribute table connected to a given vector map
# - Based on v.db.addcol
@@ -97,7 +97,7 @@
exit 1
fi
-table=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | cut -f2 -d" "`
+table=`v.db.connect map=$GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | cut -f2 -d" "`
if [ -z "$table" ] ; then
g.message -e 'There is no table connected to the input vector map! Cannot delete any column.'
cleanup
@@ -115,7 +115,7 @@
exit 1
fi
-v.info --q -c $GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d'|' -f1,2 | grep "|${col}$" 2>&1 >/dev/null
+v.info --q -c map=$GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d'|' -f1,2 | grep "|${col}$" 2>&1 >/dev/null
if [ $? -ne 0 ] ; then
g.message -e "Column <$col> not found in table <$table>."
cleanup
@@ -125,7 +125,7 @@
if [ "$driver" = "sqlite" ] ; then
#echo "Using special trick for SQLite"
# http://www.sqlite.org/faq.html#q13
- v.info --q -c $table | cut -d'|' -f1,2 | grep -v "|${col}$" > $TMP.coldesc
+ v.info --q -c map=$table | cut -d'|' -f1,2 | grep -v "|${col}$" > $TMP.coldesc
# need to revert order:
cat $TMP.coldesc | cut -d'|' -f1 > $TMP.coltypes
cat $TMP.coldesc | cut -d'|' -f2 > $TMP.colnames
@@ -158,6 +158,6 @@
cleanup
# write cmd history:
-v.support ${GIS_OPT_MAP} cmdhist="${CMDLINE}"
+v.support map=${GIS_OPT_MAP} cmdhist="${CMDLINE}"
exit 0
