[GRASS-SVN] r30442 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Mon Mar 3 09:50:13 EST 2008
Author: martinl
Date: 2008-03-03 09:50:12 -0500 (Mon, 03 Mar 2008)
New Revision: 30442
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/vdigit/driver.cpp
grass/trunk/gui/wxpython/vdigit/driver.h
wxGUI: do not use g.region for zooming to selected vector layer if the layer is opened for editing (only for vdigit component)
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-03-03 11:53:21 UTC (rev 30441)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-03-03 14:50:12 UTC (rev 30442)
@@ -1245,6 +1245,14 @@
reg['center_easting'],
reg['center_northing'],
map.width, map.height)
+ def GetMapBoundingBox(self):
+ """Return bounding box of given vector map layer
+ @return (w,s,b,e,n,t)
+ return self.__display.GetMapBoundingBox()
def UpdateSettings(self):
"""Update display driver settings"""
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-03-03 11:53:21 UTC (rev 30441)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-03-03 14:50:12 UTC (rev 30442)
@@ -277,17 +277,14 @@
(' '.join(cmd), wait, self.returncode, self.cmdThread.isAlive()))
if rerr is not None and self.returncode != 0:
if rerr is False: # GUI dialog
- try:
- raise CmdError(cmd=self.cmd,
- message="%s '%s'%s%s%s %s%s" %
- (_("Execution failed:"),
- ' '.join(self.cmd),
- os.linesep, os.linesep,
- _("Details:"),
- os.linesep,
- self.PrintModuleOutput()))
- except CmdError, e:
- print e
+ raise CmdError(cmd=self.cmd,
+ message="%s '%s'%s%s%s %s%s" %
+ (_("Execution failed:"),
+ ' '.join(self.cmd),
+ os.linesep, os.linesep,
+ _("Details:"),
+ os.linesep,
+ self.PrintModuleOutput()))
elif rerr == sys.stderr: # redirect message to sys
stderr.write("Execution failed: '%s'" % (' '.join(self.cmd)))
stderr.write("%sDetails:%s%s" % (os.linesep,
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-03-03 11:53:21 UTC (rev 30441)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-03-03 14:50:12 UTC (rev 30442)
@@ -1941,7 +1941,12 @@
if layer.type in ('raster', 'rgb', 'his', 'shaded', 'arrow'):
self.Map.region = self.Map.GetRegion(rast="%s" % layer.name)
elif layer.type in ('vector', 'thememap', 'themechart'):
- self.Map.region = self.Map.GetRegion(vect="%s" % layer.name)
+ if self.parent.digit and layer.name == self.parent.digit.map and \
+ self.parent.digit.type == 'vdigit':
+ w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
+ self.Map.region = self.Map.GetRegion(n=n, s=s, w=w, e=e)
+ else:
+ self.Map.region = self.Map.GetRegion(vect="%s" % layer.name)
else:
return
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-03 11:53:21 UTC (rev 30441)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-03 14:50:12 UTC (rev 30442)
@@ -376,7 +376,8 @@
self.height = 480
return False
- def GetRegion(self, rast=None, vect=None):
+ def GetRegion(self, rast=None, vect=None,
+ n=None, s=None, e=None, w=None):
Get region settings
@@ -397,13 +398,33 @@
# do not update & shell style output
cmdList = ["g.region", "-u", "-g", "-p", "-c"]
+ if n:
+ cmdList.append('n=%s' % n)
+ if s:
+ cmdList.append('s=%s' % s)
+ if e:
+ cmdList.append('e=%s' % e)
+ if w:
+ cmdList.append('w=%s' % w)
if rast:
cmdList.append('rast=%s' % rast)
- elif vect:
+ if vect:
cmdList.append('vect=%s' % vect)
- cmdRegion = gcmd.Command(cmdList)
+ try:
+ cmdRegion = gcmd.Command(cmdList)
+ except gcmd.CmdError, e:
+ if rast:
+ e.message = _("Unable to zoom to raster map <%s>.") % rast + \
+ '%s%s' % (os.linesep, os.linesep) + e.message
+ elif vect:
+ e.message = _("Unable to zoom to vector map <%s>.") % vect + \
+ print e
+ return self.region
for reg in cmdRegion.ReadStdOutput():
key, val = reg.split("=", 1)
try:
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-03-03 11:53:21 UTC (rev 30441)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-03-03 14:50:12 UTC (rev 30442)
@@ -1109,6 +1109,33 @@
+ \brief Get bounding box of (opened) vector map layer
+ \return (w,s,b,e,n,t)
+std::vector<double> DisplayDriver::GetMapBoundingBox()
+ std::vector<double> region;
+ BOUND_BOX bbox;
+ if (!mapInfo) {
+ return region;
+ Vect_get_map_box(mapInfo, &bbox);
+ region.push_back(bbox.W);
+ region.push_back(bbox.S);
+ region.push_back(bbox.B);
+ region.push_back(bbox.E);
+ region.push_back(bbox.N);
+ region.push_back(bbox.T);
+ return region;
\brief Error messages handling
\param msg message
@@ -1122,3 +1149,4 @@
return 0;
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h 2008-03-03 11:53:21 UTC (rev 30441)
+++ grass/trunk/gui/wxpython/vdigit/driver.h 2008-03-03 14:50:12 UTC (rev 30442)
@@ -172,6 +172,9 @@
void ReloadMap();
void SetDevice(void *);
+ /* misc */
+ std::vector<double> GetMapBoundingBox();
/* set */
void SetRegion(double, double, double, double,
double, double,
