[GRASS-SVN] r30449 - grass/trunk/raster/r.out.gdal
Mon Mar 3 12:59:24 EST 2008
Author: epatton
Date: 2008-03-03 12:59:24 -0500 (Mon, 03 Mar 2008)
New Revision: 30449
   grass/trunk/raster/r.out.gdal/main.c
Improved warning message grammar
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c	2008-03-03 17:09:43 UTC (rev 30448)
+++ grass/trunk/raster/r.out.gdal/main.c	2008-03-03 17:59:24 UTC (rev 30449)
@@ -320,12 +320,12 @@
     if (n_nulls > 0) {
 	if (maptype == CELL_TYPE)
 	    G_warning(_("Input raster map constains cells with NULL-value (no-data). "
-			"For no-data values was used value %d. "
+			"The value %d was used to represent no-data values in the input map."
 			"You can specify nodata value by %s parameter."),
 		      (int) nodataval, nodatakey);
 	else
-			"For no-data values was used value %g. "
+			"The value %g was used to represent no-data values in the input map."
