[GRASS-SVN] r30471 - in grass/trunk/gui/wxpython: gui_modules icons
svn_grass at osgeo.org
Tue Mar 4 17:32:54 EST 2008
Author: martinl
Date: 2008-03-04 17:32:53 -0500 (Tue, 04 Mar 2008)
New Revision: 30471
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/icons/icon.py
wxGUI (preferences) use internal dict for window ids, cosmetics in variable names, fix atm settings group
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-03-04 21:31:39 UTC (rev 30470)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-03-04 22:32:53 UTC (rev 30471)
@@ -526,8 +526,13 @@
win.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnDataItemActivated)
win.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnDataRightUp) #wxMSW
win.Bind(wx.EVT_RIGHT_UP, self.OnDataRightUp) #wxGTK
- win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataItemEdit)
- win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataItemEdit)
+ if UserSettings.Get(group='atm', key='leftDbClick', subkey='selection') == 0:
+ win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataItemEdit)
+ win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataItemEdit)
+ else:
+ win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataDrawSelected)
+ win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataDrawSelected)
listSizer.Add(item=win, proportion=1,
flag=wx.EXPAND | wx.ALL,
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-03-04 21:31:39 UTC (rev 30470)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-03-04 22:32:53 UTC (rev 30471)
@@ -61,7 +61,7 @@
# (os.linesep, err)
# which interface to use?
-if UserSettings.Get(group='advanced', key='digitInterface', subkey='value') == 'vedit' and GV_LINES is not None:
+if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit' and GV_LINES is not None:
print >> sys.stderr, "%sWARNING: Digitization tool uses v.edit interface. " \
"This can significantly slow down some operations especially for " \
"middle-large vector maps. "\
@@ -98,7 +98,7 @@
UserSettings.Set(group='vdigit', key='category', subkey='value', value=1)
if self.map:
- if UserSettings.Get(group='advanced', key='digitInterface', subkey='value') == 'vedit':
+ if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
categoryCmd = gcmd.Command(cmd=["v.category", "-g", "--q",
"input=%s" % self.map,
"option=report"])
@@ -153,7 +153,7 @@
'Data are probably corrupted, '
'try to run v.build for rebuilding the topology.') % map)
- if UserSettings.Get(group='advanced', key='digitInterface', subkey='value') != 'v.edit':
+ if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') != 'v.edit':
try:
self.digit.InitCats()
except:
@@ -1019,7 +1019,7 @@
return (snap, thresh)
-if UserSettings.Get(group='advanced', key='digitInterface', subkey='value') == 'vedit':
+if UserSettings.Get(group='advanced', key='digitInterface', subkey='type') == 'vedit':
class Digit(VEdit):
"""Default digit class"""
def __init__(self, mapwindow):
@@ -1122,7 +1122,7 @@
if map:
name, mapset = map.split('@')
try:
ret = self.__display.OpenMap(str(name), str(mapset), False)
else:
ret = self.__display.OpenMap(str(name), str(mapset), True)
@@ -2181,7 +2181,7 @@
cat not in cats[1][layer]:
catList.append(cat)
if catList != []:
vEditCmd = ['v.edit', '--q',
'map=%s' % self.map,
'layer=%d' % layer,
@@ -2200,7 +2200,7 @@
if self.line < 0:
wx.MessageBox(parent=self, message=_("Unable to update vector map."),
caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
# reload map (needed for v.edit)
self.parent.parent.digit.driver.ReloadMap()
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-03-04 21:31:39 UTC (rev 30470)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-03-04 22:32:53 UTC (rev 30471)
@@ -74,25 +74,33 @@
See Command class (command exits with EXIT_FAILURE,
G_fatal_error() is called)."""
- def __init__(self, cmd, message):
+ def __init__(self, cmd, message, parent=None):
self.cmd = cmd
- GException.__init__(self, message, title=_("Error in command execution %s" % self.cmd[0]))
+ GException.__init__(self, message,
+ title=_("Error in command execution %s" % self.cmd[0]),
+ parent=parent)
class SettingsError(GException):
"""Exception used for GRASS settings, see
gui_modules/preferences.py."""
- def __init__(self, message):
- GException.__init__(self, message, title=_("Preferences error"))
+ def __init__(self, message, parent=None):
+ title=_("Preferences error"),
+ parent=parent)
class DigitError(GException):
"""Exception raised during digitization session"""
- GException.__init__(self, message, title=_("Error in digitization tool"))
+ title=_("Error in digitization tool"),
+ parent=parent)
class DBMError(GException):
"""Exception raised for Attribute Table Manager"""
- GException.__init__(self, message, title=_("Error in Attribute Table Manager"))
+ title=_("Error in Attribute Table Manager"),
+ parent=parent)
class Popen(subprocess.Popen):
"""Subclass subprocess.Popen"""
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-03-04 21:31:39 UTC (rev 30470)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-03-04 22:32:53 UTC (rev 30471)
@@ -63,9 +63,9 @@
# advanced
'advanced' : {
- 'settingsFile' : { 'value' : 'gisdbase' }, # gisdbase, location, mapset
- 'digitInterface' : { 'value' : 'vdigit' }, # vedit, vdigit
- 'iconTheme' : { 'value' : 'silk' }, # grass, silk
+ 'settingsFile' : { 'type' : 'gisdbase' }, # gisdbase, location, mapset
+ 'digitInterface' : { 'type' : 'vdigit' }, # vedit, vdigit
+ 'iconTheme' : { 'type' : 'silk' }, # grass, silk
# Attribute Table Manager
@@ -136,8 +136,7 @@
self.internalSettings[group] = {}
for key in self.userSettings[group].keys():
self.internalSettings[group][key] = {}
- self.internalSettings[group][key]['subkey'] = None # subkey in userSettings dict
- self.internalSettings[group][key]['winId'] = None # widget ID
self.internalSettings['general']["mapsetPath"]['value'] = self.GetMapsetPath()
self.internalSettings['general']['mapsetPath']['choices'] = [_('Mapset search path'),
_('All available mapsets')]
@@ -235,7 +234,7 @@
if settings is None:
settings = self.userSettings
- loc = self.Get(group='advanced', key='settingsFile', subkey='value')
+ loc = self.Get(group='advanced', key='settingsFile', subkey='type')
gisdbase = grassenv.GetGRASSVariable("GISDBASE")
location_name = grassenv.GetGRASSVariable("LOCATION_NAME")
mapset_name = grassenv.GetGRASSVariable("MAPSET")
@@ -248,7 +247,7 @@
filePath = os.path.join(gisdbase, location_name, mapset_name, self.fileName)
if filePath is None:
- raise gcmd.SettingsError('Uknown file location.')
+ raise gcmd.SettingsError(_('Uknown settings file location.'))
try:
file = open(filePath, "w")
@@ -316,7 +315,7 @@
raise KeyError
settings[group][key][subkey] = value
except KeyError:
- raise gcmd.SettingsError(_("Unable to set '%s:%s:%s'") % (group, key, subkey))
+ raise gcmd.SettingsError(_("Unable to set '%s:%s:%s'") % (group, key, subkey),)
globalSettings = Settings()
@@ -334,6 +333,9 @@
# notebook
notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+ # dict for window ids
+ self.winId = {}
# create notebook pages
self.__CreateGeneralPage(notebook)
self.__CreateDisplayPage(notebook)
@@ -395,8 +397,7 @@
choices=self.settings.Get(group='general', key='mapsetPath', subkey='choices', internal=True),
name="GetSelection")
mapsetPath.SetSelection(self.settings.Get(group='general', key='mapsetPath', subkey='selection'))
- self.settings.Set(group='general', key='mapsetPath', subkey='winId', value=mapsetPath.GetId(), internal=True)
- self.settings.Set(group='general', key='mapsetPath', subkey='subkey', value='selection', internal=True)
+ self.winId['general:mapsetPath:selection'] = mapsetPath.GetId()
gridSizer.Add(item=mapsetPath,
flag=wx.ALIGN_RIGHT |
@@ -458,8 +459,7 @@
label=_("Overlay raster map layers"),
name='IsChecked')
rasterOverlay.SetValue(self.settings.Get(group='display', key='rasterOverlay', subkey='enabled'))
- self.settings.Set(group='display', key='rasterOverlay', subkey='winId', value=rasterOverlay.GetId(), internal=True)
- self.settings.Set(group='display', key='rasterOverlay', subkey='subkey', value='enabled', internal=True)
+ self.winId['display:rasterOverlay:enabled'] = rasterOverlay.GetId()
gridSizer.Add(item=rasterOverlay,
pos=(row, 0), span=(1, 2))
@@ -493,20 +493,21 @@
label = wx.StaticText(parent=panel, id=wx.ID_ANY, label="Color")
hlColor = csel.ColourSelect(parent=panel, id=wx.ID_ANY,
colour=self.settings.Get(group='atm', key='highlight', subkey='color'),
- size=(25, 25),
- name="GetValue")
+ size=(25, 25))
+ self.winId['atm:highlight:color'] = hlColor.GetId()
flexSizer.Add(label, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(self.hlColor, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ flexSizer.Add(hlColor, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width (in pixels)"))
- self.hlWidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(50, -1),
- initial=self.settings.Get(group='atm', key='highlight',subkey='width'),
- min=1, max=1e6)
+ hlWidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(50, -1),
+ initial=self.settings.Get(group='atm', key='highlight',subkey='width'),
+ min=1, max=1e6)
+ self.winId['atm:highlight:width'] = hlWidth.GetId()
- flexSizer.Add(self.hlWidth, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ flexSizer.Add(hlWidth, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
highlightSizer.Add(item=flexSizer,
proportion=0,
flag=wx.ALL | wx.EXPAND,
@@ -526,13 +527,13 @@
flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
flexSizer.AddGrowableCol(0)
- label = wx.StaticText(parent=panel, id=wx.ID_ANY, label="Left double click")
+ label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Left mouse double click"))
leftDbClick = wx.Choice(parent=panel, id=wx.ID_ANY,
choices=self.settings.Get(group='atm', key='leftDbClick', subkey='choices', internal=True),
leftDbClick.SetSelection(self.settings.Get(group='atm', key='leftDbClick', subkey='selection'))
- self.settings.Set(group='atm', key='leftDbClick', subkey='winId', value=leftDbClick.GetId(), internal=True)
- self.settings.Set(group='atm', key='leftDbClick', subkey='subkey', value='selection', internal=True)
+ self.winId['atm:leftDbClick:selection'] = leftDbClick.GetId()
flexSizer.Add(leftDbClick, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
@@ -575,9 +576,8 @@
settingsFile = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
choices=self.settings.Get(group='advanced', key='settingsFile', subkey='choices', internal=True),
name='GetStringSelection')
- settingsFile.SetStringSelection(self.settings.Get(group='advanced', key='settingsFile', subkey='value'))
- self.settings.Set(group='advanced', key='settingsFile', subkey='winId', value=settingsFile.GetId(), internal=True)
- self.settings.Set(group='advanced', key='settingsFile', subkey='subkey', value='value', internal=True)
+ settingsFile.SetStringSelection(self.settings.Get(group='advanced', key='settingsFile', subkey='type'))
+ self.winId['advanced:settingsFile:type'] = settingsFile.GetId()
gridSizer.Add(item=settingsFile,
@@ -596,9 +596,8 @@
iconTheme = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
choices=self.settings.Get(group='advanced', key='iconTheme', subkey='choices', internal=True),
name="GetStringSelection")
- iconTheme.SetStringSelection(self.settings.Get(group='advanced', key='iconTheme', subkey='value'))
- self.settings.Set(group='advanced', key='iconTheme', subkey='winId', value=iconTheme.GetId(), internal=True)
- self.settings.Set(group='advanced', key='iconTheme', subkey='subkey', value='value', internal=True)
+ iconTheme.SetStringSelection(self.settings.Get(group='advanced', key='iconTheme', subkey='type'))
+ self.winId['advanced:iconTheme:type'] = iconTheme.GetId()
gridSizer.Add(item=iconTheme,
@@ -627,9 +626,8 @@
digitInterface = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
choices=self.settings.Get(group='advanced', key='digitInterface', subkey='choices', internal=True),
- digitInterface.SetStringSelection(self.settings.Get(group='advanced', key='digitInterface', subkey='value'))
- self.settings.Set(group='advanced', key='digitInterface', subkey='winId', value=digitInterface.GetId(), internal=True)
- self.settings.Set(group='advanced', key='digitInterface', subkey='subkey', value='value', internal=True)
+ digitInterface.SetStringSelection(self.settings.Get(group='advanced', key='digitInterface', subkey='type'))
+ self.winId['advanced:digitInterface:type'] = digitInterface.GetId()
gridSizer.Add(item=digitInterface,
@@ -694,31 +692,29 @@
def OnApply(self, event):
"""Button 'Apply' clicked"""
self.__UpdateSettings()
+ self.Close()
def OnCancel(self, event):
"""Button 'Cancel' clicked"""
self.Close()
def __UpdateSettings(self):
"""Update user settings"""
- for group in self.settings.internalSettings.keys():
- for key in self.settings.internalSettings[group].keys():
- id = self.settings.internalSettings[group][key]['winId']
- subkey = self.settings.internalSettings[group][key]['subkey']
- if id is None or subkey is None:
- continue
- win = self.FindWindowById(id)
- if win.GetName() == 'GetValue':
- value = win.GetValue()
- elif win.GetName() == 'GetSelection':
- value = win.GetSelection()
- elif win.GetName() == 'IsChecked':
- value = win.IsChecked()
- elif win.GetName() == 'GetStringSelection':
- value = win.GetStringSelection()
- else:
- value = None
- self.settings.Set(group, key, subkey, value)
+ for item in self.winId.keys():
+ group, key, subkey = item.split(':')
+ id = self.winId[item]
+ win = self.FindWindowById(id)
+ if win.GetName() == 'GetValue':
+ value = win.GetValue()
+ elif win.GetName() == 'GetSelection':
+ value = win.GetSelection()
+ elif win.GetName() == 'IsChecked':
+ value = win.IsChecked()
+ elif win.GetName() == 'GetStringSelection':
+ value = win.GetStringSelection()
+ else:
+ self.settings.Set(group, key, subkey, value)
class SetDefaultFont(wx.Dialog):
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2008-03-04 21:31:39 UTC (rev 30470)
+++ grass/trunk/gui/wxpython/icons/icon.py 2008-03-04 22:32:53 UTC (rev 30471)
@@ -32,7 +32,7 @@
# iconpath = grassenv.GetGRASSVariable('GRASS_ICONPATH')
# if not iconpath:
# iconpath = os.getenv("GRASS_ICONPATH")
-iconTheme = UserSettings.Get(group='advanced', key='iconTheme', subkey='value')
+iconTheme = UserSettings.Get(group='advanced', key='iconTheme', subkey='type')
if iconTheme and iconTheme == 'silk':
iconpath = os.path.join(globalvar.ETCWXDIR, "icons", "silk")
else:
