[GRASS-SVN] r30476 - grass/trunk/swig/python/examples
svn_grass at osgeo.org
Wed Mar 5 04:56:00 EST 2008
Author: hamish
Date: 2008-03-05 04:56:00 -0500 (Wed, 05 Mar 2008)
New Revision: 30476
grass/trunk/swig/python/examples/m.distance
use a flag to know if input is from stdin instead of trying to guess.
less problematic and it lets us demonstrate using parser flags.
Modified: grass/trunk/swig/python/examples/m.distance
--- grass/trunk/swig/python/examples/m.distance 2008-03-05 09:48:30 UTC (rev 30475)
+++ grass/trunk/swig/python/examples/m.distance 2008-03-05 09:56:00 UTC (rev 30476)
@@ -36,7 +36,12 @@
#% key_desc: x,y
#% description: Comma separated list of coordinate pairs
#%End
+#%Flag
+#% key: i
+#% description: Read coordinate pairs from stdin
+#%End
import sys
import os
@@ -71,12 +76,10 @@
# parser always creates at least an empty variable, and sys.argv is
# toast, so no way to check if option was given. So it hangs if
# --q was the only option given and there is no data from stdin.
- coord_ans = os.getenv("GIS_OPT_COORD")
- if coord_ans:
- # read from coord= command line option
- coords = coord_ans.split(',')
- else:
- # FIXME: this can hang if no input is given
+ coord_ans = os.getenv("GIS_OPT_COORD")
+ stdin_flag = bool(int(os.getenv("GIS_FLAG_I")))
+ if stdin_flag is True:
coords = []
# read line by line from stdin
while 1:
@@ -85,7 +88,11 @@
break
else:
coords += line.split(',')
+ else:
+ # read from coord= command line option
+ coords = coord_ans.split(',')
if len(coords) < 4:
print "A minimum of two input coordinate pairs are needed"
return
