[GRASS-SVN] r30478 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Mar 5 07:45:36 EST 2008
Author: martinl
Date: 2008-03-05 07:45:36 -0500 (Wed, 05 Mar 2008)
New Revision: 30478
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI (menuform) use wx.SpinCtrl for numeric types
fix setting default value(s)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-03-05 11:22:56 UTC (rev 30477)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-03-05 12:45:36 UTC (rev 30478)
@@ -936,7 +936,7 @@
else:
hSizer=wx.StaticBoxSizer ( box=txt, orient=wx.HORIZONTAL )
isDefault = {}
- for defval in p.get('value','').split(','):
+ for defval in p.get('default','').split(','):
isDefault[ defval ] = 'yes'
# for multi checkboxes, this is an array of all wx IDs
# for each individual checkbox
@@ -1004,15 +1004,24 @@
which_sizer.Add(item=txt, proportion=0,
flag=wx.RIGHT | wx.LEFT | wx.TOP | wx.EXPAND, border=5)
- txt3 = wx.TextCtrl(parent=which_panel, value = p.get('default',''),
- size = (STRING_ENTRY_WIDTH, ENTRY_HEIGHT))
+ if p.get('type','string') == 'string':
+ txt3 = wx.TextCtrl(parent=which_panel, value = p.get('default',''),
+ size = (STRING_ENTRY_WIDTH, ENTRY_HEIGHT))
+ txt3.Bind(wx.EVT_TEXT, self.OnSetValue)
+ else:
+ minValue = -1e9
+ maxValue = 1e9
+ txt3 = wx.SpinCtrl(parent=which_panel, value=p.get('default',''),
+ size = (STRING_ENTRY_WIDTH, ENTRY_HEIGHT),
+ min=minValue, max=maxValue)
+ txt3.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
if p.get('value','') != '':
txt3.SetValue(p['value']) # parameter previously set
which_sizer.Add(item=txt3, proportion=0, flag=wx.BOTTOM | wx.LEFT, border=5)
p['wxId'] = txt3.GetId()
- txt3.Bind(wx.EVT_TEXT, self.OnSetValue)
if p.get('type','string') == 'string' and p.get('gisprompt',False) == True:
txt = wx.StaticText(parent=which_panel, label = title + ':')
