[GRASS-SVN] r30491 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Mar 6 16:20:42 EST 2008
Author: martinl
Date: 2008-03-06 16:20:42 -0500 (Thu, 06 Mar 2008)
New Revision: 30491
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI (menuform) typo (wxgui_utils) fixing run command(command string with parameters)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-03-06 17:11:23 UTC (rev 30490)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-03-06 21:20:42 UTC (rev 30491)
@@ -772,7 +772,7 @@
"""Abort running command"""
try:
self.goutput.GetListOfCmdThreads()[0].abort()
- except KeyError:
+ except IndexError:
pass
def OnCopy(self, event):
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-06 17:11:23 UTC (rev 30490)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-06 21:20:42 UTC (rev 30491)
@@ -1114,12 +1114,22 @@
except:
curr_disp = None
+ if len(self.GetListOfCmdThreads()) > 0:
+ # only one running command enabled (per GMConsole instance)
+ busy = wx.BusyInfo(message=_("Unable to run the command, another command is running..."),
+ parent=self)
+ wx.Yield()
+ time.sleep(3)
+ busy.Destroy()
+ return
# command given as a string ?
try:
cmdlist = command.strip().split(' ')
except:
cmdlist = command
+ # print cmdlist[0], globalvar.grassCmd['all']
if cmdlist[0] in globalvar.grassCmd['all']:
# send GRASS command without arguments to GUI command interface
# except display commands (they are handled differently)
@@ -1152,34 +1162,34 @@
# select 'Command output' tab
self.parent.notebook.SetSelection(1)
- # activate computational region (set with g.region)
- # for all non-display commands.
- tmpreg = os.getenv("GRASS_REGION")
- os.unsetenv("GRASS_REGION")
- if len(cmdlist) == 1:
- # process GRASS command without argument
- menuform.GUI().ParseCommand(cmdlist, parentframe=self)
- else:
- # process GRASS command with argument
- self.cmdPID = len(self.cmdThreads)+1
- self.WriteCmdLog('%s' % ' '.join(cmdlist), pid=self.cmdPID)
- grassCmd = gcmd.Command(cmdlist, wait=False,
- stdout=self.cmd_stdout,
- stderr=self.cmd_stderr)
- self.cmdThreads.append(grassCmd.cmdThread)
- # deactivate computational region and return to display settings
- if tmpreg:
- os.environ["GRASS_REGION"] = tmpreg
+ # activate computational region (set with g.region)
+ # for all non-display commands.
+ tmpreg = os.getenv("GRASS_REGION")
+ os.unsetenv("GRASS_REGION")
+ print cmdlist
+ if len(cmdlist) == 1:
+ # process GRASS command without argument
+ menuform.GUI().ParseCommand(cmdlist, parentframe=self)
+ else:
+ # process GRASS command with argument
+ self.cmdPID = len(self.cmdThreads)+1
+ print self.cmdPID
+ self.WriteCmdLog('%s' % ' '.join(cmdlist), pid=self.cmdPID)
+ grassCmd = gcmd.Command(cmdlist, wait=False,
+ stdout=self.cmd_stdout,
+ stderr=self.cmd_stderr)
+ self.cmdThreads.append(grassCmd.cmdThread)
return grassCmd
+ # deactivate computational region and return to display settings
+ if tmpreg:
+ os.environ["GRASS_REGION"] = tmpreg
else:
# Send any other command to the shell. Send output to
# console output window
+ print cmdlist
if self.parent.notebook.GetSelection() != 1:
