[GRASS-SVN] r30494 - in grass-addons/imagery: . i.landsat.toar
Fri Mar 7 12:05:37 EST 2008
Author: ejtizado
Date: 2008-03-07 12:05:37 -0500 (Fri, 07 Mar 2008)
New Revision: 30494
Added:
   grass-addons/imagery/i.landsat.toar/
   grass-addons/imagery/i.landsat.toar/description.html
   grass-addons/imagery/i.landsat.toar/landsat.c
   grass-addons/imagery/i.landsat.toar/landsat.h
   grass-addons/imagery/i.landsat.toar/landsat_set.c
   grass-addons/imagery/i.landsat.toar/main.c
Removed:
Move to imaginery/
Copied: grass-addons/imagery/i.landsat.toar (from rev 30401, grass-addons/i.landsat.toar)
Deleted: grass-addons/imagery/i.landsat.toar/description.html
--- grass-addons/i.landsat.toar/description.html	2008-02-29 15:19:34 UTC (rev 30401)
+++ grass-addons/imagery/i.landsat.toar/description.html	2008-03-07 17:05:37 UTC (rev 30494)
@@ -1,128 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>i.landsat.toar</EM> is to transform calibrated digital number of Landsat products to top-of-atmosphere radiance or top-of-atmosphere reflectance and temperature (band 6 of the sensors TM and ETM+). Optionally, to calculate a simplefied at-surface radiance or reflectance.
-<p>Usually, to do this the production date, the acquisition date, and the solar elevation is needed. Moreover, also is needed for Landsat-7 ETM+ the gain (high or low) of the nine bands.</p>
-<p>Optionally, the data can be read from header file (.met) for all Landsat MSS, TM and ETM+. However, if the solar elevation or the product creation date are given the values of metfile are overwriten. This is necessary when this data in metfile are incorrects or imprecisses.</p>
-<p><b>Attention</b>: Any null value or less than QCALmin in input raster is set to null in output raster and it is not included in the equations.</p>
-<H2>Uncorrected at-sensor values (method=uncorrected, default)</H2>
-<p>The standard geometric and radiometric correction results in a calibrated digital number (QCAL = DN) images. To further standardize the impact of illumination geometry, the QCAL images are converted first to at-sensor radiance and then to at-sensor reflectance. The thermal band is first converted from QCAL to at-sensor radiance, and then to effective at-sensor temperature in Kelvin degrees.</p>
-<p>Radiometric calibration convert QCAL to <b>at-sensor radiance</b>, a radiometric quantity measured in  W/(m²·sr·µm) with the equations:
-  <ul>
-  <li> gain = (Lmax - Lmin) / (QCALmax - QCALmin)</li>
-  <li> bias = Lmin - gain · QCALmin </li>
-  <li> radiance = gain · QCAL + bias </li>
-  </ul>
-where,
-<em>Lmax</em> and <em>Lmin</em> are the calibration constants, and
-<em>QCALmax</em> and <em>QCALmin</em> are the highest and the lowest points of the range of rescaled radiance in QCAL.
-</p>
-<p>Then, to calculate <b>at-sensor reflectance</b> the equations are:
-    <ul>
-    <li> sun_radiance = [Esun · sin(e)] / (PI · d^2)</li>
-    <li> reflectance = radiance / sun_radiance </li>
-  </ul>
-where,
-<em>d</em> is the earth-sun distance in astronomical units,
-<em>e</em> is the solar elevation angle, and
-<em>Esun</em> is the mean solar exoatmospheric irradiance in W/(m²·µm).
-</p>
-<H2>Corrected at-sensor values (method=corrected)</H2>
-<p>At-sensor reflectance values range from zero to one, whereas at-sensor radiance must be greater or equal to zero. However, since Lmin can be a negative number then the at-sensor values also it can be negative. To avoid these possible negative values and set the minimum possible values at-sentor to zero, this method correct the radiance to output a corrected at-sensor values with the equations:
-    <ul>
-    <li> radiance = (uncorrected radiance - Lmin) </li>
-  </ul>
-</p>
-<H2>Simplified at-surface values (method=simplified)</H2>
-<p>Atmospheric correction and reflectance calibration remove the path radiance, i.e. the stray light from the atmosphere, and the spectral effect of solar illumination. To output these simple <b>at-surface radiance</b> and <b>at-surface reflectance</b>, the equations are:
-    <ul>
-    <li> sun_radiance = [Esun · sin(e) · TAUz + Esky] / (PI · d^2) </li>
-    <li> rpath = Lmin - percent · sun_radiance </li>
-    <li> radiance = (at-sensor radiance - rpath) / TAUv </li>
-  </ul>
-where,
-<em>percent</em> is a value between 0.0 and 1.0 (usually 0.01),
-<em>Esky</em> is the diffuse sky irradiance,
-<em>TAUz</em> is the atmospheric transmittance along the path from the sun to the ground surface, and
-<em>TAUv</em> is the atmospheric transmittance along the path from the ground surface to the sensor.
-</p>
-<p>For this calculus, the values are TAUv = 1.0, Esky = 0. and TAUz = 1.0. When the method is simplified TAUz = sin(e) for all bands with maximum wave length less than 1., i.e. bands 4-6 MSS, 1-4 TM, and 1-4 ETM+.</p>
-<H2>NOTES</H2>
-<p>In verbose mode (flag -v), the program write basic data of satellite and the parameters used in
-transformations.</p>
-<p>Production date is not a exact value and it is necessary to apply correct calibration constants, which were changed in the dates:
-    <ul>
-    <li>Landsat-1 MSS: never </li>
-    <li>Landsat-2 MSS: July 16, 1975</li>
-    <li>Landsat-3 MSS: June 1, 1978</li>
-    <li>Landsat-4 MSS: August 26, 1982 and April 1, 1983</li>
-    <li>Landsat-4 TM:  August 1, 1983 and January 15, 1984</li>
-    <li>Landsat-5 MSS: April 6, 1984 and November 9, 1984</li>
-    <li>Landsat-5 TM:  May 4, 2003 and April, 2 2007</li>
-    <li>Landsat-7 ETM+: July 1, 2000</li>
-    </ul>
-</p>
-<H2>EXAMPLES</H2>
-<p>Transform digital numbers of Landsat-7 ETM+ in band rasters 203_30.1, 203_30.2
-[...] to uncorrected at-sensor reflectance in output files 203_30.toar.1,
-203_30.toar.2 [...] and at-sensor temperature in output files 293_39.toar.61 and 293_39.toar.62:</p>
-<div class="code"><pre>
-i.landsat.toar -7 band=203_30 met=p203r030_7x20010620.met
-</pre></div>
-<p>or</p>
-i.landsat.toar -7 band=203_30 product=2004-06-07 date=2001-06-20 solar=64.3242970 gain="HHHLHLHHL"
-</pre></div>
-<H2>REFERENCES</H2>
-<ol>
-    <li>G.h Chander and B. Markham: IEEE Transactions On Geoscience And Remote Sensing, vol. 41, no. 11, November 2003.</li>
-    <li>Chavez, P. S., jr. 1996. Image-based atmospheric corrections - Revisited and Improved. Photogrammetric Engineering and Remote Sensing 62 (9): 1025-1036.</li>
-    <li>Huang et al: At-Satellite Reflectance: A First Order Normalization Of Landsat 7 ETM+ Images. 2002.</li>
-    <li>R. Irish: <a href="http://ltpwww.gsfc.nasa.gov/IAS/handbook/handbook_toc.html">Landsat 7. Science Data Users Handbook. February 17, 2007.</a></li>
-    <li>B. L. Markham and J.L. Barker: Landsat MSS and TM Post-Calibration Dynamic Ranges, Exoatmospheric Reflectances and At-Satellite Temperatures. EOSAT Landsat Technical Notes, No. 1, 1986</li>
-    <li>M.S. Moran, R.D. Jackson, P.N. Slater and P.M. Teillet: Remote Sensing of Environment, vol. 41. 1992.</li>
-</ol>
-<H2>SEE ALSO</H2>
-<em>
-<A HREF="r.mapcalc.html">r.mapcalc</A><br>
-<A HREF="r.in.gdal.html">r.in.gdal</A><br>
-</em>
-<H2>AUTHOR</H2>
-E. Jorge Tizado  (ej.tizado unileon es)<br>
-Dept. Biodiversity and Environmental Management, University of León, Spain<BR>
-<p>
-<i>Last changed: $Date: 2007/07/07 00:00:00 $</i>
Copied: grass-addons/imagery/i.landsat.toar/description.html (from rev 30464, grass-addons/i.landsat.toar/description.html)
--- grass-addons/imagery/i.landsat.toar/description.html	                        (rev 0)
@@ -0,0 +1,139 @@
+<H2>DESCRIPTION</H2>
+<EM>i.landsat.toar</EM> is to transform calibrated digital number of Landsat products to top-of-atmosphere radiance or top-of-atmosphere reflectance and temperature (band 6 of the sensors TM and ETM+). Optionally, to calculate the at-surface radiance or reflectance with atmosferic correction (DOS method).
+<p>Usually, to do this the production date, the acquisition date, and the solar elevation is needed. Moreover, also is needed for Landsat-7 ETM+ the gain (high or low) of the nine bands.</p>
+<p>Optionally, the data can be read from header file (.met) for all Landsat MSS, TM and ETM+. However, if the solar elevation or the product creation date are given the values of metfile are overwriten. This is necessary when this data in metfile are incorrects or imprecisses.</p>
+<p><b>Attention</b>: Any null value or less than QCALmin in input raster is set to null in output raster and it is not included in the equations.</p>
+<H2>Uncorrected at-sensor values (method=uncorrected, default)</H2>
+<p>The standard geometric and radiometric correction results in a calibrated digital number (QCAL = DN) images. To further standardize the impact of illumination geometry, the QCAL images are converted first to at-sensor radiance and then to at-sensor reflectance. The thermal band is first converted from QCAL to at-sensor radiance, and then to effective at-sensor temperature in Kelvin degrees.</p>
+<p>Radiometric calibration convert QCAL to <b>at-sensor radiance</b>, a radiometric quantity measured in  W/(m²·sr·µm) with the equations:
+  <ul>
+  <li> gain = (Lmax - Lmin) / (QCALmax - QCALmin)</li>
+  <li> bias = Lmin - gain · QCALmin </li>
+  <li> radiance = gain · QCAL + bias </li>
+  </ul>
+where,
+<em>Lmax</em> and <em>Lmin</em> are the calibration constants, and
+<em>QCALmax</em> and <em>QCALmin</em> are the highest and the lowest points of the range of rescaled radiance in QCAL.
+</p>
+<p>Then, to calculate <b>at-sensor reflectance</b> the equations are:
+    <ul>
+    <li> sun_radiance = [Esun · sin(e)] / (PI · d^2)</li>
+    <li> reflectance = radiance / sun_radiance </li>
+  </ul>
+where,
+<em>d</em> is the earth-sun distance in astronomical units,
+<em>e</em> is the solar elevation angle, and
+<em>Esun</em> is the mean solar exoatmospheric irradiance in W/(m²·µm).
+</p>
+<H2>Corrected at-sensor values (method=corrected)</H2>
+<p>At-sensor reflectance values range from zero to one, whereas at-sensor radiance must be greater or equal to zero. However, since Lmin can be a negative number then the at-sensor values also it can be negative. To avoid these possible negative values and set the minimum possible values at-sentor to zero, this method correct the radiance to output a corrected at-sensor values with the equations (not for thermal bands):
+    <ul>
+    <li> radiance = (uncorrected_radiance - Lmin) </li>
+  </ul>
+</p>
+<p><b>Note</b>: Other possibility to avoid negative values is set to zero this values (radiance and/or reflectance), but this option is ease with uncorrected method and r.mapcalc.</p>
+<H2>Simplified at-surface values (method=dos[1-4])</H2>
+<p>Atmospheric correction and reflectance calibration remove the path radiance, i.e. the stray light from the atmosphere, and the spectral effect of solar illumination. To output these simple <b>at-surface radiance</b> and <b>at-surface reflectance</b>, the equations are (not for thermal bands):
+    <ul>
+    <li> sun_radiance = TAUv · [Esun · sin(e) · TAUz + Esky] / (PI · d^2) </li>
+    <li> radiance_path = radiance_dark - percent · sun_radiance </li>
+    <li> radiance = (at-sensor_radiance - radiance_path) </li>
+  </ul>
+where,
+<em>percent</em> is a value between 0.0 and 1.0 (usually 0.01),
+<em>Esky</em> is the diffuse sky irradiance,
+<em>TAUz</em> is the atmospheric transmittance along the path from the sun to the ground surface, and
+<em>TAUv</em> is the atmospheric transmittance along the path from the ground surface to the sensor.
+<em>radiance_dark</em> is the at-sensor radiance calculated from the darkest object, i.e. DN with a least 'dark_parameter' (usually 1000) pixels for the entire image.</p>
+The values are,
+	<ul>
+	<li>DOS1: TAUv = 1.0, TAUz = 1.0 and Esky = 0.0</li>
+	<li>DOS2: TAUv = 1.0, Esky = 0.0, and TAUz = sin(e) for all bands with maximum wave length less than 1. (i.e. bands 4-6 MSS, 1-4 TM, and 1-4 ETM+) other bands TAUz = 1.0</li>
+	<li>DOS3: TAUv = exp[-t/cos(sat_zenith)], TAUz = exp[-t/sin(e)], Esky = rayleigh</li>
+	<li>DOS4: TAUv = exp[-t/cos(sat_zenith)], TAUz = exp[-t/sin(e)], Esky = PI · radiance_dark </li>
+	</ul>
+<p><b>Attention</b>: Output radiance remain untouched (i.e. no set to 0. when it is negative) then they are possible negative values. However, output reflectance is set to 0. when is obtained a negative value.</p>
+<H2>NOTES</H2>
+<p>In verbose mode (flag -v), the program write basic data of satellite and the parameters used in
+transformations.</p>
+<p>Production date is not a exact value and it is necessary to apply correct calibration constants, which were changed in the dates:
+    <ul>
+    <li>Landsat-1 MSS: never </li>
+    <li>Landsat-2 MSS: July 16, 1975</li>
+    <li>Landsat-3 MSS: June 1, 1978</li>
+    <li>Landsat-4 MSS: August 26, 1982 and April 1, 1983</li>
+    <li>Landsat-4 TM:  August 1, 1983 and January 15, 1984</li>
+    <li>Landsat-5 MSS: April 6, 1984 and November 9, 1984</li>
+    <li>Landsat-5 TM:  May 4, 2003 and April, 2 2007</li>
+    <li>Landsat-7 ETM+: July 1, 2000</li>
+    </ul>
+</p>
+<H2>EXAMPLES</H2>
+<p>Transform digital numbers of Landsat-7 ETM+ in band rasters 203_30.1, 203_30.2
+[...] to uncorrected at-sensor reflectance in output files 203_30.toar.1,
+203_30.toar.2 [...] and at-sensor temperature in output files 293_39.toar.61 and 293_39.toar.62:</p>
+<div class="code"><pre>
+i.landsat.toar -7 band=203_30 met=p203r030_7x20010620.met
+</pre></div>
+<p>or</p>
+i.landsat.toar -7 band=203_30 product=2004-06-07 date=2001-06-20 solar=64.3242970 gain="HHHLHLHHL"
+</pre></div>
+<H2>REFERENCES</H2>
+<ol>
+    <li>Chander G.H. and B. Markham: IEEE Transactions On Geoscience And Remote Sensing, vol. 41, no. 11, November 2003.</li>
+    <li>Chavez P.S., jr. 1996. Image-based atmospheric corrections - Revisited and Improved. Photogrammetric Engineering and Remote Sensing 62 (9): 1025-1036.</li>
+    <li>Huang et al: At-Satellite Reflectance: A First Order Normalization Of Landsat 7 ETM+ Images. 2002.</li>
+    <li>R. Irish: <a href="http://ltpwww.gsfc.nasa.gov/IAS/handbook/handbook_toc.html">Landsat 7. Science Data Users Handbook. February 17, 2007.</a></li>
+    <li>Markham B.L. and J.L. Barker: Landsat MSS and TM Post-Calibration Dynamic Ranges, Exoatmospheric Reflectances and At-Satellite Temperatures. EOSAT Landsat Technical Notes, No. 1, 1986</li>
+    <li>Moran M.S., R.D. Jackson, P.N. Slater and P.M. Teillet: Remote Sensing of Environment, vol. 41. 1992.</li>
+    <li> Song et al : Classification and Change Detection Using Landsat TM Data: When and How to Correct Atmospheric Effects?. Remote Sensing of Environment, vol. 75. 2001. </li>
+</ol>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="r.mapcalc.html">r.mapcalc</A><br>
+<A HREF="r.in.gdal.html">r.in.gdal</A><br>
+</em>
+<H2>AUTHOR</H2>
+E. Jorge Tizado  (ej.tizado unileon es)<br>
+Dept. Biodiversity and Environmental Management, University of León, Spain<BR>
+<p>
+<i>Last changed: $Date: 2008/02/10 00:00:00 $</i>
Deleted: grass-addons/imagery/i.landsat.toar/landsat.c
--- grass-addons/i.landsat.toar/landsat.c	2008-02-29 15:19:34 UTC (rev 30401)
+++ grass-addons/imagery/i.landsat.toar/landsat.c	2008-03-07 17:05:37 UTC (rev 30494)
@@ -1,96 +0,0 @@
-#include<stdio.h>
-#include<stdlib.h>
-#include<math.h>
-#include "landsat.h"
-#define PI   3.1415926535897932384626433832795
-#define R2D 57.295779513082320877
-#define D2R  0.017453292519943295769
- * PURPOSE: Calibrated Digital Number to at-satellite Radiance
-double lsat_qcal2rad(int qcal, band_data * band)
-    return (double)(((double)qcal) * band->gain + band->bias);
- * PURPOSE: Radiance of non-thermal band to at-satellite Reflectance
-double lsat_rad2ref(double rad, band_data * band)
-    return (double)(rad / band->K2);
- * PURPOSE: Radiance of thermal band to at-satellite Temperature
-double lsat_rad2temp(double rad, band_data * band)
-    return (double)(band->K2 / log((band->K1 / rad) + 1.0));
- * PURPOSE: Some band constants
- *      zenith = 90 - sun_elevation
- *      sin( sun_elevation ) = cos( sun_zenith )
- *      lsat : satellite data
- *         i : band number
- *    method : level of atmospheric correction
- *       aot : atmospheric optical thickness (usually 0.15)
- *   percent : percent of solar irradiance in path radiance
-void lsat_bandctes(lsat_data * lsat, int i, char method, double aot, double percent)
-    double a, b, rad_sun;
-    double TAUv, TAUz, Edown;
-    a = (double)(PI * lsat->dist_es * lsat->dist_es);
-    b = (double)(sin(D2R * lsat->sun_elev));
-    /** Radiance of the Sun */
-    if (method == SIMPLIFIED) {
-        TAUv = 1.;      /* TAUv  = at. transmittance surface-sensor */
-                        /* TAUz  = at. transmittance sun-surface    */
-        TAUz = (lsat->band[i].wavemax < 1.) ? b : 1.;
-        Edown = 0.;     /* Edown = diffuse sky spectral irradiance  */
-    else { /* UNCORRECTED or CORRECTED */
-        TAUv = 1.;
-        TAUz = 1.;
-        Edown   = 0.;
-    rad_sun = ((lsat->band[i].esun * b * TAUz + Edown) / a);
-    /** Radiance coefficients */
-    lsat->band[i].gain = ((lsat->band[i].lmax - lsat->band[i].lmin) /
-                          (lsat->band[i].qcalmax - lsat->band[i].qcalmin));
-    lsat->band[i].bias = (lsat->band[i].lmin -
-                          lsat->band[i].gain * lsat->band[i].qcalmin);
-    if (method == CORRECTED)
-        lsat->band[i].bias -= lsat->band[i].lmin;
-    else if (method == SIMPLIFIED)
-        lsat->band[i].gain /= TAUv;
-        lsat->band[i].bias -= (lsat->band[i].lmin - percent * rad_sun);
-        lsat->band[i].bias /= TAUv;
-    /** Reflectance coefficients, only NO thermal bands.
-        Same variables are utilized to thermal constants
-    if (lsat->band[i].thermal == 0)
-        lsat->band[i].K1 = 0.;
-        lsat->band[i].K2 = rad_sun;
Copied: grass-addons/imagery/i.landsat.toar/landsat.c (from rev 30464, grass-addons/i.landsat.toar/landsat.c)
--- grass-addons/imagery/i.landsat.toar/landsat.c	                        (rev 0)
@@ -0,0 +1,164 @@
+#include<stdio.h>
+#include<stdlib.h>
+#include<math.h>
+#include "landsat.h"
+#define PI   3.1415926535897932384626433832795
+#define R2D 57.295779513082320877
+#define D2R  0.017453292519943295769
+ * PURPOSE: Calibrated Digital Number to at-satellite Radiance
+double lsat_qcal2rad(double qcal, band_data * band)
+    return (double)(qcal * band->gain + band->bias);
+ * PURPOSE: Radiance of non-thermal band to at-satellite Reflectance
+double lsat_rad2ref(double rad, band_data * band)
+    return (double)(rad / band->K2);
+ * PURPOSE: Radiance of thermal band to at-satellite Temperature
+double lsat_rad2temp(double rad, band_data * band)
+    return (double)(band->K2 / log((band->K1 / rad) + 1.0));
+ * PURPOSE: Some band constants
+ *      zenith = 90 - sun_elevation
+ *      sin( sun_elevation ) = cos( sun_zenith )
+ *      lsat : satellite data
+ *         i : band number
+ *    method : level of atmospheric correction
+ *   percent : percent of solar irradiance in path radiance
+ *       dos : digital number of dark object for DOS
+#define abs(x)	(((x)>0)?(x):(-x))
+void lsat_bandctes(lsat_data * lsat, int i, char method,
+				   double percent, int dos, double sat_zenith, double rayleigh)
+    double pi_d2, sin_e, cos_v, rad_sun;
+	/* TAUv  = at. transmittance surface-sensor */
+	/* TAUz  = at. transmittance sun-surface    */
+	/* Edown = diffuse sky spectral irradiance  */
+	double TAUv, TAUz, Edown;
+	pi_d2 = (double)(PI * lsat->dist_es * lsat->dist_es);
+	sin_e = (double)(sin(D2R * lsat->sun_elev));
+	cos_v = (double)(cos(D2R * sat_zenith));
+	/** Global irradiance on the sensor.
+		Radiance to reflectance coefficient, only NO thermal bands.
+		K1 and K2 variables are also utilized as thermal constants
+	if (lsat->band[i].thermal == 0)
+		switch( method )
+			case DOS2:
+				TAUv  = 1.;
+				TAUz  = (lsat->band[i].wavemax < 1.) ? sin_e : 1.;
+				Edown = 0.;
+				break;
+			case DOS2b:
+				TAUv  = (lsat->band[i].wavemax < 1.) ? cos_v : 1.;
+				Edown = 0.;
+				break;
+			case DOS3:
+				double t;
+				t = 2. / (lsat->band[i].wavemax + lsat->band[i].wavemin);
+				t = 0.008569 *t*t*t*t*(1+0.0113*t*t+0.000013*t*t*t*t);
+				TAUv  = exp( -t / cos_v );
+				TAUz  = exp( -t / sin_e );
+				Edown = rayleigh;
+				break;
+			case DOS4:
+				double Ro = (lsat->band[i].lmax - lsat->band[i].lmin) * (dos - lsat->band[i].qcalmin) /
+							(lsat->band[i].qcalmax - lsat->band[i].qcalmin) + lsat->band[i].lmin;
+				double tv, Tv = 1.;
+				double Tz = 1.;
+				double Lp = 0.;
+ 				do
+					TAUz = Tz;
+					TAUv = Tv;
+					Lp = Ro - percent * TAUv * (lsat->band[i].esun * sin_e * TAUz + PI * Lp) / pi_d2;
+					Tz = 1 - (4 * pi_d2 * Lp) / (lsat->band[i].esun * sin_e);
+					Tv = exp( sin_e * log( Tz ) / cos_v );
+// 					G_message("TAUv = %.5f (%.5f), TAUz = %.5f (%.5f) and Edown = %.5f\n", TAUv, Tv, TAUz, Tz, PI * Lp );
+// 				} while( abs(TAUv - Tv) > 0.0000001 || abs(TAUz - Tz) > 0.0000001);
+				} while( TAUv != Tv && TAUz != Tz);
+				TAUz  = (Tz < 1. ? Tz : 1.);
+				TAUv  = (Tv < 1. ? Tv : 1.);
+				Edown = (Lp < 0. ? 0. : PI * Lp);
+				break;
+			default: /* DOS1 and Without atmosferic-correction */
+				TAUv  = 1.;
+				TAUz  = 1.;
+				Edown = 0.;
+				break;
+		rad_sun = TAUv * (lsat->band[i].esun * sin_e * TAUz + Edown) / pi_d2;
+		G_message("... TAUv = %.5f, TAUz = %.5f, Edown = %.5f\n", TAUv, TAUz, Edown);
+		lsat->band[i].K1 = 0.;
+		lsat->band[i].K2 = rad_sun;
+	/** Digital number to radiance coefficients.
+		Whitout atmosferic calibration for thermal bands.
+	lsat->band[i].gain = ((lsat->band[i].lmax - lsat->band[i].lmin) /
+						  (lsat->band[i].qcalmax - lsat->band[i].qcalmin));
+	if (method == UNCORRECTED || lsat->band[i].thermal)
+		/* L = G * (DN - Qmin) + Lmin
+		-> bias = Lmin - G * Qmin	*/
+		lsat->band[i].bias = (lsat->band[i].lmin - lsat->band[i].gain * lsat->band[i].qcalmin);
+	else
+		if (method == CORRECTED)
+			/* L = G * (DN - Qmin) + Lmin - Lmin
+			-> bias = - G * Qmin */
+			lsat->band[i].bias = - (lsat->band[i].gain * lsat->band[i].qcalmin);
+			/* Another possibility is cut when rad < 0 */
+		else if (method > DOS )
+			/* L = Lsat - Lpath =
+			   G * DNsat + B - (G * dark + B - p * rad_sun) =
+			   G * DNsat - G * dark + p * rad_sun
+			-> bias = p * rad_sun - G * dark */
+			lsat->band[i].bias = percent * rad_sun - lsat->band[i].gain * dos;
Deleted: grass-addons/imagery/i.landsat.toar/landsat.h
--- grass-addons/i.landsat.toar/landsat.h	2008-02-29 15:19:34 UTC (rev 30401)
+++ grass-addons/imagery/i.landsat.toar/landsat.h	2008-03-07 17:05:37 UTC (rev 30494)
@@ -1,62 +0,0 @@
-#ifndef _LANDSAT_H
-#define _LANDSAT_H
-#define MAX_BANDS   9
-#define UNCORRECTED     0
-#define CORRECTED       1
-#define SIMPLIFIED      2
- * Landsat Structures
- * Lmax and Lmin in  W / (m² · sr · µm) -> Radiance
- * Esun in  W / (m² · µm)               -> Irradiance
-typedef struct
-    int number;			/* Band number                   */
-    int code;                   /* Band code                     */
-    double wavemax, wavemin;    /* Wavelength in µm              */
-    double lmax, lmin;		/* Spectral radiance             */
-    double qcalmax, qcalmin;	/* Quantized calibrated pixel    */
-    double esun;                /* Mean solar irradiance         */
-    char thermal;               /* Flag to thermal band          */
-    double gain, bias;          /* Gain and Bias of sensor       */
-    double K1, K2;              /* Thermal calibration constants,
-                                   or Rad2Ref constants          */
-} band_data;
-typedef struct
-    unsigned char number;       /* Landsat number                */
-    char creation[11];          /* Image production date         */
-    char date[11];              /* Image acquisition date        */
-    double dist_es;		/* Distance Earth-Sun            */
-    double sun_elev;		/* Solar elevation               */
-    char sensor[5];             /* Type of sensor: MSS, TM, ETM+ */
-    int bands;			/* Total number of bands         */
-    band_data band[MAX_BANDS];	/* Data for each band            */
-} lsat_data;
- * Landsat Equations Prototypes
-double lsat_qcal2rad(int, band_data *);
-double lsat_rad2ref(double, band_data *);
-double lsat_rad2temp(double, band_data *);
-void lsat_bandctes(lsat_data *, int, char, double, double);
-#endif
Copied: grass-addons/imagery/i.landsat.toar/landsat.h (from rev 30464, grass-addons/i.landsat.toar/landsat.h)
--- grass-addons/imagery/i.landsat.toar/landsat.h	                        (rev 0)
@@ -0,0 +1,66 @@
+#ifndef _LANDSAT_H
+#define _LANDSAT_H
+#define UNCORRECTED     0
+#define CORRECTED       1
+#define DOS      		10
+#define DOS1			12
+#define DOS2			14
+#define DOS2b			15
+#define DOS3			16
+#define DOS4			18
+ * Landsat Structures
+ * Lmax and Lmin in  W / (m² · sr · µm) -> Radiance
+ * Esun in  W / (m² · µm)               -> Irradiance
+#define MAX_BANDS   9
+typedef struct
+	int number;					/* Band number                   */
+	int code;					/* Band code                     */
+	double wavemax, wavemin;	/* Wavelength in µm              */
+	double lmax, lmin;			/* Spectral radiance             */
+	double qcalmax, qcalmin;	/* Quantized calibrated pixel    */
+	double esun;				/* Mean solar irradiance         */
+	char thermal;				/* Flag to thermal band          */
+	double gain, bias;			/* Gain and Bias of sensor       */
+	double K1, K2;				/* Thermal calibration constants,
+                                   or Rad2Ref constants          */
+} band_data;
+typedef struct
+	unsigned char number;		/* Landsat number                */
+	char creation[11];			/* Image production date         */
+	char date[11];				/* Image acquisition date        */
+	double dist_es;				/* Distance Earth-Sun            */
+	double sun_elev;			/* Solar elevation               */
+	char sensor[5];				/* Type of sensor: MSS, TM, ETM+ */
+	int bands;					/* Total number of bands         */
+	band_data band[MAX_BANDS];	/* Data for each band            */
+} lsat_data;
+ * Landsat Equations Prototypes
+double lsat_qcal2rad(double, band_data *);
+double lsat_rad2ref (double, band_data *);
+double lsat_rad2temp(double, band_data *);
+void lsat_bandctes(lsat_data *, int, char, double, int, double, double);
+#endif
Deleted: grass-addons/imagery/i.landsat.toar/landsat_set.c
--- grass-addons/i.landsat.toar/landsat_set.c	2008-02-29 15:19:34 UTC (rev 30401)
+++ grass-addons/imagery/i.landsat.toar/landsat_set.c	2008-03-07 17:05:37 UTC (rev 30494)
@@ -1,437 +0,0 @@
-#include<stdio.h>
-#include<stdlib.h>
-#include<string.h>
-#include <math.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include "local_proto.h"
-#include "earth_sun.h"
-void sensor_MSS(lsat_data * lsat)
-    int i;
-    int band[]    = { 1, 2, 3, 4 };
-    int code[]    = { 4, 5, 6, 7 };
-    double wmax[] = { 0.6, 0.7, 0.8, 1.1 };
-    double wmin[] = { 0.5, 0.6, 0.7, 0.8 };
-    strcpy(lsat->sensor, "MSS");
-    lsat->bands = 4;
-    for (i = 0; i < lsat->bands; i++) {
-        lsat->band[i].number = *(band + i);
-        lsat->band[i].code = *(code + i);
-        lsat->band[i].wavemax = *(wmax + i);
-        lsat->band[i].wavemin = *(wmin + i);
-        lsat->band[i].qcalmax = 255.;
-        lsat->band[i].qcalmin = 0.;
-        lsat->band[i].thermal = 0;
-    return;
-void sensor_TM(lsat_data * lsat)
-    int i;
-    int band[]    = { 1, 2, 3, 4, 5, 6, 7 };
-    double wmax[] = { 0.52, 0.60, 0.69, 0.90, 1.75, 12.50, 2.35 };
-    double wmin[] = { 0.45, 0.52, 0.63, 0.76, 1.55, 10.40, 2.08 };
-    strcpy(lsat->sensor, "TM");
-    lsat->bands = 7;
-        lsat->band[i].code = *(band + i);
-        lsat->band[i].thermal = (lsat->band[i].number == 6);
-    return;
-void sensor_ETM(lsat_data * lsat)
-    int i;
-    int band[]    = { 1, 2, 3, 4, 5, 6, 6, 7, 8 };
-    int code[]    = { 1, 2, 3, 4, 5, 61, 62, 7, 8 };
-    double wmax[] = { 0.515, 0.605, 0.690, 0.90, 1.75, 12.50, 2.35, 0.90 };
-    double wmin[] = { 0.450, 0.525, 0.630, 0.75, 1.55, 10.40, 2.09, 0.52 };
-    strcpy(lsat->sensor, "ETM+");
-    lsat->bands = 9;
-        lsat->band[i].qcalmin = 1.;
-    return;
- ** Before access to this function ...
- ** store previously
- ** >>> adquisition date,
- ** >>> creation date, and
- ** >>> sun_elev
- * PURPOSE:     Store values of Landsat-1 MSS
- *              July 23, 1972 to January 6, 1978
-void set_MSS1(lsat_data * lsat)
-    int i, j;
-    /** Brian L. Markham and John L. Barker.
-        EOSAT Landsat Technical Notes, No. 1, 1986 */
-    /* Spectral radiances at detector */
-    double lmax[] = { 248., 200., 176., 153. };
-    double lmin[] = {   0.,   0.,   0.,   0. };
-    /* Solar exoatmospheric spectral irradiances */
-    double esun[] = { 1852., 1584., 1276., 904. };
-    lsat->number = 1;
-    sensor_MSS( lsat );
-    lsat->dist_es = earth_sun(lsat->date);
-        j = lsat->band[i].number - 1;
-        lsat->band[i].esun = *(esun + j);
-        lsat->band[i].lmax = *(lmax + j);
-        lsat->band[i].lmin = *(lmin + j);
-    return;
- * PURPOSE:     Store values of Landsat-2 MSS
- *              January 22, 1975 to February 25, 1982
-void set_MSS2(lsat_data * lsat)
-    int i, j;
-    double julian, *lmax, *lmin;
-    double Lmax[][4] = { { 210., 156., 140., 138. },    /* before      July 16, 1975 */
-                         { 263., 176., 152., 130. } };  /* on or after July 16, 1975 */
-    double Lmin[][4] = { {  10.,   7.,   7.,   5. },
-                         {   8.,   6.,   6.,   4. } };
-    double esun[] = { 1856., 1559., 1269., 906. };
-    julian = julian_char(lsat->creation);
-    if (julian < julian_char("1975-07-16")) i = 0;
-    else i = 1;
-    lmax = Lmax[i];
-    lmin = Lmin[i];
-    lsat->number = 2;
-    return;
- * PURPOSE:     Store values of Landsat-3 MSS
- *              March 5, 1978 to March 31, 1983
- *              tiene una banda 8 thermal
-void set_MSS3(lsat_data * lsat)
-    int i, j;
-    double Lmax[][4] = { { 220., 175., 145., 147. },   /* before      June 1, 1978 */
-                         { 259., 179., 149., 128. } }; /* on or after June 1, 1978 */
-    double Lmin[][4] = { {   4.,   3.,   3.,   1. },
-                         {   4.,   3.,   3.,   1. } };
-    double esun[] = { 1860., 1571., 1289., 910. };
-    if (julian < julian_char("1978-06-01")) i = 0;
-    else i = 1;
-    lmax = Lmax[i];
-    lmin = Lmin[i];
-    lsat->number = 3;
-    return;
- * PURPOSE:     Store values of Landsat-4 MSS/TM
- *              July 16, 1982 to June 15, 2001
-void set_MSS4(lsat_data * lsat)
-    int i, j;
-    double Lmax[][4] = { { 250., 180., 150., 133. },     /* before      August 26, 1982 */
-                         { 230., 180., 130., 133. },     /* between                     */
-                         { 238., 164., 142., 116. } };   /* on or after April 1, 1983   */
-    double Lmin[][4] = { {   2.,   4.,   4.,   3. },
-                         {   2.,   4.,   4.,   3. },
-                         {   4.,   4.,   5.,   4. } };
-    double esun[] = { 1851., 1593., 1260., 878. };
-    if (julian < julian_char("1982-08-26")) i = 0;
-    else if (julian < julian_char("1983-03-31")) i = 1;
-    else i = 2;
-    lmax = Lmax[i];
-    lmin = Lmin[i];
-    lsat->number = 4;
-    return;
-void set_TM4(lsat_data * lsat)
-    int i, j;
-    double Lmax[][7] = { { 158.42, 308.17, 234.63, 224.32, 32.42, 15.64,  17.00 },   /* before August 1983      */
-                         { 142.86, 291.25, 225.00, 214.29, 30.00, 12.40,  15.93 },   /* before January 15, 1984 */
-                         { 152.10, 296.80, 204.30, 206.20, 27.19, 15.60,  14.38 } }; /* after  Jaunary 15, 1984 */
-    double Lmin[][7] = { {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  2.00,  -0.15 },
-                         {   0.00,   0.00,   0.00,   0.00,  0.00,  4.84,   0.00 },
-                         {  -1.50,  -2.80,  -1.20,  -1.50, -0.37,  1.238, -0.15 } };
-    /** Gyanesh Chander and Brian Markham.
-        IEEE Transactions On Geoscience And Remote Sensing, Vol. 41, No. 11, November 2003 */
-    double esun[] = { 1957., 1825., 1557., 1033., 214.9, 0., 80.72 };
-    /* Thermal band calibration constants: K1 = 671.62   K2 = 1284.30 */
-    if (julian < julian_char("1983-08-01")) i = 0;
-    else if (julian < julian_char("1984-01-15")) i = 1;
-    else i = 2;
-    lmax = Lmax[i];
-    lmin = Lmin[i];
-    lsat->number = 4;
-    sensor_TM( lsat );
-        if (lsat->band[i].thermal ) {
-            lsat->band[i].K1 = 671.62;
-            lsat->band[i].K2 = 1284.30;
-    return;
- * PURPOSE:     Store values of Landsat-5 MSS/TM
- *              March 1, 1984 to today
-void set_MSS5(lsat_data * lsat)
-    int i, j;
-    double Lmax[][4] = { { 240., 170., 150., 127. },    /* before   April 6, 1984    */
-                         { 268., 179., 159., 123. },    /* betweeen                  */
-                         { 268., 179., 148., 123. } };  /* after    November 9, 1984 */
-    double Lmin[][4] = { {   4.,   3.,   4.,   2. },
-                         {   3.,   3.,   4.,   3. },
-                         {   3.,   3.,   5.,   3. } };
-    double esun[] = { 1849., 1595., 1253., 870. };
-    if (julian < julian_char("1984-04-06")) i = 0;
-    else if (julian < julian_char("1984-11-09")) i = 1;
-    else i = 2;
-    lmax = Lmax[i];
-    lmin = Lmin[i];
-    lsat->number = 5;
-    return;
-void set_TM5(lsat_data * lsat)
-    int i, j;
-    double Lmax[][7] = { { 152.10, 296.81, 204.30, 206.20, 27.19, 15.303,  14.38 },    /* on or before May 4, 2003 */
-                         { 193.00, 365.00, 264.00, 221.00, 30.20, 15.303,  16.50 },    /* after May 4, 2003 */
-                         { 169.00, 333.00, 264.00, 221.00, 30.20, 15.303,  16.50 } };  /* after April 2, 2007 */
-    double Lmin[][7] = { {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 },
-                         {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 },
-                         {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 } };
-    double esun[] = { 1957., 1826., 1554., 1036., 215.0, 0., 80.67 };
-    /* Thermal band calibration constants: K1 = 607.76   K2 = 1260.56 */
-    if (julian < julian_char("2003-05-04")) i = 0;
-    else if (julian < julian_char("2007-04-02")) i = 1;
-    else i = 2;
-    lmax = Lmax[i];
-    lmin = Lmin[i];
-    if ( i == 2 ) {
-        julian = julian_char(lsat->date); /* Yes, here acquisition date */
-        if (julian >= julian_char("1992-01-01")) {
-            lmax[0] = 193.0;
-            lmax[1] = 365.0;
-    lsat->number = 5;
-            lsat->band[i].K1 = 607.76;
-            lsat->band[i].K2 = 1260.56;
-    return;
- * PURPOSE:     Store values of Landsat-7 ETM+
- *              April 15, 1999 to today
-void set_ETM(lsat_data * lsat, char gain[])
-    int i, k, j;
-    /** Richard Irish.
-        Landsat 7. Science Data Users Handbook. Last update: February 17, 2007 */
-    /* - LOW GAIN - */
-    double LmaxL[][8] = { { 297.5, 303.4, 235.5, 235.0, 47.70, 17.04, 16.600, 244.0 },      /* before      July 1, 2000 */
-                          { 293.7, 300.9, 234.4, 241.1, 47.57, 17.04, 16.540, 243.1 } };    /* on or after July 1, 2000 */
-    double LminL[][8] = { {  -6.2,  -6.0,  -4.5,  -4.5,  -1.0,  0.0,  -0.35,   -5.0 },
-                          {  -6.2,  -6.4,  -5.0,  -5.1,  -1.0,  0.0,  -0.35,   -4.7 } };
-    /* - HIGH GAIN - */
-    double LmaxH[][8] = { { 194.3, 202.4, 158.6, 157.5, 31.76, 12.65, 10.932, 158.4 },
-                          { 191.6, 196.5, 152.9, 157.4, 31.06, 12.65, 10.800, 158.3 } };
-    double LminH[][8] = { {  -6.2,  -6.0,  -4.5,  -4.5, -1.0,   3.2,  -0.35,   -5.0 },
-                          {  -6.2,  -6.4,  -5.0,  -5.1, -1.0,   3.2,  -0.35,   -4.7 } };
-    double esun[] = { 1969., 1840., 1551., 1044., 225.7, 0., 82.07, 1368. };
-    /*  Thermal band calibration constants: K1 = 666.09   K2 = 1282.71 */
-    if (julian < julian_char("2000-07-01")) k = 0;
-    else k = 1;
-    lsat->number = 7;
-    sensor_ETM( lsat );
-        if (gain[i] == 'H' || gain[i] == 'h') {
-            lmax = LmaxH[k];
-            lmin = LminH[k];
-        else {
-            lmax = LmaxL[k];
-            lmin = LminL[k];
-            lsat->band[i].K1 = 666.09;
-            lsat->band[i].K2 = 1282.71;
-    return;
Copied: grass-addons/imagery/i.landsat.toar/landsat_set.c (from rev 30464, grass-addons/i.landsat.toar/landsat_set.c)
--- grass-addons/imagery/i.landsat.toar/landsat_set.c	                        (rev 0)
@@ -0,0 +1,443 @@
+#include<stdio.h>
+#include<stdlib.h>
+#include<string.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+#include "earth_sun.h"
+void sensor_MSS(lsat_data * lsat)
+	int i;
+	/* green, red, near infrared, near infrared */
+	int band[]    = { 1, 2, 3, 4 };
+	int code[]    = { 4, 5, 6, 7 };
+	double wmax[] = { 0.6, 0.7, 0.8, 1.1 };
+	double wmin[] = { 0.5, 0.6, 0.7, 0.8 };
+	/* 79-82, 79-82, 79-82, 79-82 */
+	strcpy(lsat->sensor, "MSS");
+	lsat->bands = 4;
+	for (i = 0; i < lsat->bands; i++) {
+		lsat->band[i].number = *(band + i);
+		lsat->band[i].code = *(code + i);
+		lsat->band[i].wavemax = *(wmax + i);
+		lsat->band[i].wavemin = *(wmin + i);
+		lsat->band[i].qcalmax = 255.;
+		lsat->band[i].qcalmin = 0.;
+		lsat->band[i].thermal = 0;
+	return;
+void sensor_TM(lsat_data * lsat)
+	int i;
+	/* blue, green red, near infrared, shortwave IR, thermal IR, shortwave IR */
+	int band[]    = { 1, 2, 3, 4, 5, 6, 7 };
+	double wmax[] = { 0.52, 0.60, 0.69, 0.90, 1.75, 12.50, 2.35 };
+	double wmin[] = { 0.45, 0.52, 0.63, 0.76, 1.55, 10.40, 2.08 };
+	/* 30, 30, 30, 30, 30, 120, 30 */
+	strcpy(lsat->sensor, "TM");
+	lsat->bands = 7;
+		lsat->band[i].code = *(band + i);
+		lsat->band[i].thermal = (lsat->band[i].number == 6 ? 1 : 0);
+	return;
+void sensor_ETM(lsat_data * lsat)
+	int i;
+	/* blue, green red, near infrared, shortwave IR, thermal IR, shortwave IR, panchromatic */
+	int band[]    = { 1, 2, 3, 4, 5, 6, 6, 7, 8 };
+	int code[]    = { 1, 2, 3, 4, 5, 61, 62, 7, 8 };
+	double wmax[] = { 0.515, 0.605, 0.690, 0.90, 1.75, 12.50, 2.35, 0.90 };
+	double wmin[] = { 0.450, 0.525, 0.630, 0.75, 1.55, 10.40, 2.09, 0.52 };
+	/* 30, 30, 30, 30, 30, 60, 30, 15 */
+	strcpy(lsat->sensor, "ETM+");
+	lsat->bands = 9;
+		lsat->band[i].qcalmin = 1.;
+	return;
+ ** Before access to this function ...
+ ** store previously
+ ** >>> adquisition date,
+ ** >>> creation date, and
+ ** >>> sun_elev
+ * PURPOSE:     Store values of Landsat-1 MSS
+ *              July 23, 1972 to January 6, 1978
+void set_MSS1(lsat_data * lsat)
+    int i, j;
+    /** Brian L. Markham and John L. Barker.
+        EOSAT Landsat Technical Notes, No. 1, 1986 */
+    /* Spectral radiances at detector */
+    double lmax[] = { 248., 200., 176., 153. };
+    double lmin[] = {   0.,   0.,   0.,   0. };
+    /* Solar exoatmospheric spectral irradiances */
+    double esun[] = { 1852., 1584., 1276., 904. };
+    lsat->number = 1;
+    sensor_MSS( lsat );
+    lsat->dist_es = earth_sun(lsat->date);
+        j = lsat->band[i].number - 1;
+        lsat->band[i].esun = *(esun + j);
+        lsat->band[i].lmax = *(lmax + j);
+        lsat->band[i].lmin = *(lmin + j);
+    return;
+ * PURPOSE:     Store values of Landsat-2 MSS
+ *              January 22, 1975 to February 25, 1982
+void set_MSS2(lsat_data * lsat)
+    int i, j;
+    double julian, *lmax, *lmin;
+    double Lmax[][4] = { { 210., 156., 140., 138. },    /* before      July 16, 1975 */
+                         { 263., 176., 152., 130. } };  /* on or after July 16, 1975 */
+    double Lmin[][4] = { {  10.,   7.,   7.,   5. },
+                         {   8.,   6.,   6.,   4. } };
+    double esun[] = { 1856., 1559., 1269., 906. };
+    julian = julian_char(lsat->creation);
+    if (julian < julian_char("1975-07-16")) i = 0;
+    else i = 1;
+    lmax = Lmax[i];
+    lmin = Lmin[i];
+    lsat->number = 2;
+    return;
+ * PURPOSE:     Store values of Landsat-3 MSS
+ *              March 5, 1978 to March 31, 1983
+ *              tiene una banda 8 thermal
+void set_MSS3(lsat_data * lsat)
+    int i, j;
+    double Lmax[][4] = { { 220., 175., 145., 147. },   /* before      June 1, 1978 */
+                         { 259., 179., 149., 128. } }; /* on or after June 1, 1978 */
+    double Lmin[][4] = { {   4.,   3.,   3.,   1. },
+                         {   4.,   3.,   3.,   1. } };
+    double esun[] = { 1860., 1571., 1289., 910. };
+    if (julian < julian_char("1978-06-01")) i = 0;
+    else i = 1;
+    lmax = Lmax[i];
+    lmin = Lmin[i];
+    lsat->number = 3;
+    return;
+ * PURPOSE:     Store values of Landsat-4 MSS/TM
+ *              July 16, 1982 to June 15, 2001
+void set_MSS4(lsat_data * lsat)
+    int i, j;
+    double Lmax[][4] = { { 250., 180., 150., 133. },     /* before      August 26, 1982 */
+                         { 230., 180., 130., 133. },     /* between                     */
+                         { 238., 164., 142., 116. } };   /* on or after April 1, 1983   */
+    double Lmin[][4] = { {   2.,   4.,   4.,   3. },
+                         {   2.,   4.,   4.,   3. },
+                         {   4.,   4.,   5.,   4. } };
+    double esun[] = { 1851., 1593., 1260., 878. };
+    if (julian < julian_char("1982-08-26")) i = 0;
+    else if (julian < julian_char("1983-03-31")) i = 1;
+    else i = 2;
+    lmax = Lmax[i];
+    lmin = Lmin[i];
+    lsat->number = 4;
+    return;
+void set_TM4(lsat_data * lsat)
+    int i, j;
+    double Lmax[][7] = { { 158.42, 308.17, 234.63, 224.32, 32.42, 15.64,  17.00 },   /* before August 1983      */
+                         { 142.86, 291.25, 225.00, 214.29, 30.00, 12.40,  15.93 },   /* before January 15, 1984 */
+                         { 152.10, 296.80, 204.30, 206.20, 27.19, 15.60,  14.38 } }; /* after  Jaunary 15, 1984 */
+    double Lmin[][7] = { {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  2.00,  -0.15 },
+                         {   0.00,   0.00,   0.00,   0.00,  0.00,  4.84,   0.00 },
+                         {  -1.50,  -2.80,  -1.20,  -1.50, -0.37,  1.238, -0.15 } };
+    /** Gyanesh Chander and Brian Markham.
+        IEEE Transactions On Geoscience And Remote Sensing, Vol. 41, No. 11, November 2003 */
+    double esun[] = { 1957., 1825., 1557., 1033., 214.9, 0., 80.72 };
+    /* Thermal band calibration constants: K1 = 671.62   K2 = 1284.30 */
+    if (julian < julian_char("1983-08-01")) i = 0;
+    else if (julian < julian_char("1984-01-15")) i = 1;
+    else i = 2;
+    lmax = Lmax[i];
+    lmin = Lmin[i];
+    lsat->number = 4;
+    sensor_TM( lsat );
+        if (lsat->band[i].thermal ) {
+            lsat->band[i].K1 = 671.62;
+            lsat->band[i].K2 = 1284.30;
+    return;
+ * PURPOSE:     Store values of Landsat-5 MSS/TM
+ *              March 1, 1984 to today
+void set_MSS5(lsat_data * lsat)
+    int i, j;
+    double Lmax[][4] = { { 240., 170., 150., 127. },    /* before   April 6, 1984    */
+                         { 268., 179., 159., 123. },    /* betweeen                  */
+                         { 268., 179., 148., 123. } };  /* after    November 9, 1984 */
+    double Lmin[][4] = { {   4.,   3.,   4.,   2. },
+                         {   3.,   3.,   4.,   3. },
+                         {   3.,   3.,   5.,   3. } };
+    double esun[] = { 1849., 1595., 1253., 870. };
+    if (julian < julian_char("1984-04-06")) i = 0;
+    else if (julian < julian_char("1984-11-09")) i = 1;
+    else i = 2;
+    lmax = Lmax[i];
+    lmin = Lmin[i];
+    lsat->number = 5;
+    return;
+void set_TM5(lsat_data * lsat)
+    int i, j;
+    double Lmax[][7] = { { 152.10, 296.81, 204.30, 206.20, 27.19, 15.303,  14.38 },    /* before May 4, 2003 */
+                         { 193.00, 365.00, 264.00, 221.00, 30.20, 15.303,  16.50 },    /* after May 4, 2003 */
+                         { 169.00, 333.00, 264.00, 221.00, 30.20, 15.303,  16.50 } };  /* after April 2, 2007 */
+    double Lmin[][7] = { {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 },
+                         {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 },
+                         {  -1.52,  -2.84,  -1.17,  -1.51, -0.37,  1.2378, -0.15 } };
+    double esun[] = { 1957., 1826., 1554., 1036., 215.0, 0., 80.67 };
+    /* Thermal band calibration constants: K1 = 607.76   K2 = 1260.56 */
+    if (julian < julian_char("2003-05-04")) i = 0;
+    else if (julian < julian_char("2007-04-02")) i = 1;
+    else i = 2;
+    lmax = Lmax[i];
+    lmin = Lmin[i];
+    if ( i == 2 ) { /* in Chander, Markham and Barsi 2007 */
+        julian = julian_char(lsat->date); /* Yes, here acquisition date */
+        if (julian >= julian_char("1992-01-01")) {
+            lmax[0] = 193.0;
+            lmax[1] = 365.0;
+    lsat->number = 5;
+            lsat->band[i].K1 = 607.76;
+            lsat->band[i].K2 = 1260.56;
+    return;
+ * PURPOSE:     Store values of Landsat-7 ETM+
+ *              April 15, 1999 to today
+void set_ETM(lsat_data * lsat, char gain[])
+    int i, k, j;
+    /** Richard Irish.
+        Landsat 7. Science Data Users Handbook. Last update: February 17, 2007 */
+    /* - LOW GAIN - */
+    double LmaxL[][8] = { { 297.5, 303.4, 235.5, 235.0, 47.70, 17.04, 16.600, 244.0 },      /* before      July 1, 2000 */
+                          { 293.7, 300.9, 234.4, 241.1, 47.57, 17.04, 16.540, 243.1 } };    /* on or after July 1, 2000 */
+    double LminL[][8] = { {  -6.2,  -6.0,  -4.5,  -4.5,  -1.0,  0.0,  -0.35,   -5.0 },
+                          {  -6.2,  -6.4,  -5.0,  -5.1,  -1.0,  0.0,  -0.35,   -4.7 } };
+    /* - HIGH GAIN - */
+    double LmaxH[][8] = { { 194.3, 202.4, 158.6, 157.5, 31.76, 12.65, 10.932, 158.4 },
+                          { 191.6, 196.5, 152.9, 157.4, 31.06, 12.65, 10.800, 158.3 } };
+    double LminH[][8] = { {  -6.2,  -6.0,  -4.5,  -4.5, -1.0,   3.2,  -0.35,   -5.0 },
+                          {  -6.2,  -6.4,  -5.0,  -5.1, -1.0,   3.2,  -0.35,   -4.7 } };
+    double esun[] = { 1969., 1840., 1551., 1044., 225.7, 0., 82.07, 1368. };
+    /*  Thermal band calibration constants: K1 = 666.09   K2 = 1282.71 */
+	if (julian < julian_char("2000-07-01")) k = 0;
+	else k = 1;
+	lsat->number = 7;
+	sensor_ETM( lsat );
+		if (gain[i] == 'H' || gain[i] == 'h') {
+			lmax = LmaxH[k];
+			lmin = LminH[k];
+		else {
+			lmax = LmaxL[k];
+			lmin = LminL[k];
+		if (lsat->band[i].thermal) {
+			lsat->band[i].K1 = 666.09;
+			lsat->band[i].K2 = 1282.71;
+    return;
Deleted: grass-addons/imagery/i.landsat.toar/main.c
--- grass-addons/i.landsat.toar/main.c	2008-02-29 15:19:34 UTC (rev 30401)
+++ grass-addons/imagery/i.landsat.toar/main.c	2008-03-07 17:05:37 UTC (rev 30494)
@@ -1,436 +0,0 @@
- * MODULE:       i.landsat.toar
- * AUTHOR(S):    E. Jorge Tizado - ej.tizado at unileon.es
- * PURPOSE:      Calculate TOA Radiance or Reflectance and Kinetic Temperature
- *               for Landsat 1/2/3/4/5 MS, 4/5 TM or 7 ETM+
- * COPYRIGHT:    (C) 2002, 2005 2008 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
-#include <stdio.h>
-#include <stdlib.h>
-int main(int argc, char *argv[])
-    struct History history;
-    struct GModule *module;
-    struct Cell_head cellhd, window;
-    char *mapset;
-    void *inrast, *outrast;
-    int infd, outfd;
-    void *ptr;
-    int nrows, ncols, row, col;
-    RASTER_MAP_TYPE in_data_type;
-    int verbose = 1;
-    struct Option *input, *metfn,
-                  *adate, *elev, *bgain, *pdate, *metho, * perc;
-    char *name;
-    char *met;
-    char *atcor;
-    struct Flag *sat1, *sat2, *sat3, *sat4, *sat5, *sat7, *msss,
-                *verbo, *frad;
-    char band_in[127], band_out[127];
-    int i, method, qcal;
-    double rad, ref, percent;
-    lsat_data lsat;
-    char command[300];
-    /* initialize GIS environment */
-    G_gisinit(argv[0]);
-    /* initialize module */
-    module = G_define_module();
-    module->description = _("Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+");
-    module->keywords = _("Top-Of-Atmosphere Radiance or Reflectance.\n Landsat-1 MSS, Landsat-2 MSS, Landsat-3 MSS, Landsat-4 MSS, Landsat-5 MSS,\n Landsat-4 TM, Landsat-5 TM,\n Landsat-7 ETM+");
-    /* It defines the different parameters */
-    input = G_define_option();
-    input->key = _("band_prefix");
-    input->type = TYPE_STRING;
-    input->required = YES;
-    input->gisprompt = _("input,cell,raster");
-    input->description = _("Base name of the landsat band rasters (.#)");
-    metfn = G_define_option();
-    metfn->key = _("metfile");
-    metfn->type = TYPE_STRING;
-    metfn->required = NO;
-    metfn->gisprompt = _(".met file");
-    metfn->description = _("Landsat ETM+ or TM5 header file (.met)");
-    adate = G_define_option();
-    adate->key = _("date");
-    adate->type = TYPE_STRING;
-    adate->required = NO;
-    adate->gisprompt = _("image acquisition date");
-    adate->description = _("Image acquisition date (yyyy-mm-dd)");
-    elev = G_define_option();
-    elev->key = _("solar");
-    elev->type = TYPE_DOUBLE;
-    elev->required = NO;
-    elev->gisprompt = _("solar elevation");
-    elev->description = _("Solar elevation in degrees");
-    bgain = G_define_option();
-    bgain->key = _("gain");
-    bgain->type = TYPE_STRING;
-    bgain->required = NO;
-    bgain->gisprompt = _("band gain");
-    bgain->description = _("Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)");
-    pdate = G_define_option();
-    pdate->key = _("product_date");
-    pdate->type = TYPE_STRING;
-    pdate->required = NO;
-    pdate->gisprompt = _("image production date");
-    pdate->description = _("Image creation date (yyyy-mm-dd)");
-    metho = G_define_option();
-    metho->key = _("method");
-    metho->type = TYPE_STRING;
-    metho->required = NO;
-    metho->options = "uncorrected,corrected,simplified";
-    metho->gisprompt = _("atmosferic correction methods");
-    metho->description = _("Atmosferic correction methods");
-    metho->answer = "uncorrected";
-    perc = G_define_option();
-    perc->key = _("percent");
-    perc->type = TYPE_DOUBLE;
-    perc->required = NO;
-    perc->gisprompt = _("percent of solar irradiance in path radiance");
-    perc->description = _("Percent of solar irradiance in path radiance");
-    perc->answer = "0.01";
-    /* It defines the different flags */
-    frad = G_define_flag();
-    frad->key = 'r';
-    frad->description = _("Output at-sensor radiance for all bands");
-    frad->answer = 0;
-    sat1 = G_define_flag();
-    sat1->key = '1';
-    sat1->description = _("Landsat-1 MSS");
-    sat1->answer = 0;
-    sat2 = G_define_flag();
-    sat2->key = '2';
-    sat2->description = _("Landsat-2 MSS");
-    sat2->answer = 0;
-    sat3 = G_define_flag();
-    sat3->key = '3';
-    sat3->description = _("Landsat-3 MSS");
-    sat3->answer = 0;
-    sat4 = G_define_flag();
-    sat4->key = '4';
-    sat4->description = _("Landsat-4 TM");
-    sat4->answer = 0;
-    sat5 = G_define_flag();
-    sat5->key = '5';
-    sat5->description = _("Landsat-5 TM");
-    sat5->answer = 0;
-    sat7 = G_define_flag();
-    sat7->key = '7';
-    sat7->description = _("Landsat-7 ETM+");
-    sat7->answer = 0;
-    msss = G_define_flag();
-    msss->key = 's';
-    msss->description = _("Modify sensor of Landsat-4/5 to MSS");
-    msss->answer = 0;
-    verbo = G_define_flag();
-    verbo->key = 'v';
-    verbo->description = _("Show parameters applied");
-    verbo->answer = 0;
-    /* options and afters parser */
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-     * ---------- START --------------------
-     * Stores options and flag to variables
-    met = metfn->answer;
-    name = input->answer;
-    atcor = metho->answer;
-    if (adate->answer != NULL) {
-        strncpy(lsat.date, adate->answer, 11);
-        lsat.date[10] = '\0';
-    else
-        lsat.date[0] = '\0';
-    if (pdate->answer != NULL) {
-        strncpy(lsat.creation, pdate->answer, 11);
-        lsat.creation[10] = '\0';
-    else
-        lsat.creation[0] = '\0';
-    lsat.sun_elev = elev->answer == NULL ? 0. : atof(elev->answer);
-    percent = atof(perc->answer);
-    if (met == NULL &&
-        (sat1->answer + sat2->answer + sat3->answer +
-         sat4->answer + sat5->answer + sat7->answer) != 1)
-        G_fatal_error(_("Select one and only one type of satellite"));
-    /* Data from MET file: only Landsat-7 ETM+ and Landsat-5 TM  */
-    if (met != NULL) {
-        if (sat7->answer) met_ETM(met, &lsat);
-        else              met_TM5(met, &lsat);
-        fprintf(stdout, "Landsat-%d %s with data set in met file [%s]\n",
-                lsat.number, lsat.sensor, met);
-        if (elev->answer != NULL)
-           lsat.sun_elev = atof(elev->answer);         /* Overwrite sun elevation of met file */
-    /* Data from date and solar elevation */
-    else if (adate->answer == NULL || elev->answer == NULL) {
-	G_fatal_error(_("Lacking date or solar elevation for this satellite"));
-    else {
-	if (sat7->answer) { /* Need gain */
-	    if (bgain->answer && strlen(bgain->answer) == 9) {
-		set_ETM(&lsat, bgain->answer);
-		fprintf(stdout, "Landsat 7 ETM+\n");
-	    else {
-		G_fatal_error(_("For Landsat-7 is necessary band gain with 9 (H/L) data"));
-	else { /* Not need gain */
-            if (sat5->answer) {
-                if (msss->answer) set_MSS5(&lsat);
-                else              set_TM5 (&lsat);
-                fprintf(stdout, "Landsat-5 %s\n", lsat.sensor);
-            else if (sat4->answer) {
-                if (msss->answer) set_MSS4(&lsat);
-                else              set_TM4 (&lsat);
-                fprintf(stdout, "Landsat-4 %s\n", lsat.sensor);
-            else if (sat3->answer) {
-                set_MSS3(&lsat);
-                fprintf(stdout, "Landsat-3 MSS\n");
-            else if (sat2->answer) {
-                set_MSS2(&lsat);
-                fprintf(stdout, "Landsat-2 MSS\n");
-            else if (sat1->answer) {
-                set_MSS1(&lsat);
-                fprintf(stdout, "Landsat-1 MSS\n");
-            else
-                G_fatal_error(_("Lacking satellite type"));
-    /* Set method and calculate band constants */
-    switch(atcor[0])
-        case 'c':
-            method = CORRECTED;
-            break;
-        case 's':
-            method = SIMPLIFIED;
-            break;
-        default:
-            method = UNCORRECTED;
-            break;
-    for (i = 0; i < lsat.bands; i++)
-        lsat_bandctes(&lsat, i, method, 0.0, percent);
-     * ---------- VERBOSE ------------------
-    if (verbo->answer) {
-	fprintf(stdout, " ACQUISITION DATE %s [production date %s]\n", lsat.date, lsat.creation);
-	fprintf(stdout, "   earth-sun distance    = %.8lf\n", lsat.dist_es);
-        fprintf(stdout, "   solar elevation angle = %.8lf\n", lsat.sun_elev);
-        fprintf(stdout, "   Method for at sensor values = %s\n",
-            (atcor[0]=='c' ? "corrected" : (atcor[0]=='s' ? "simplified" : "uncorrected")));
-        if (atcor[0] == 's')
-            fprintf(stdout, "   percent of solar irradiance in path radiance = %.4lf\n", percent);
-	for (i = 0; i < lsat.bands; i++) {
-	    fprintf(stdout, "-------------------\n");
-	    fprintf(stdout, " BAND %d %s (code %d)\n",
-                    lsat.band[i].number, (lsat.band[i].thermal ? "thermal " : ""),
-                    lsat.band[i].code);
-            fprintf(stdout, "   calibrated digital number (DN): %.1lf to %.1lf\n",
-                    lsat.band[i].qcalmin, lsat.band[i].qcalmax);
-            fprintf(stdout, "   calibration constants (L): %.3lf to %.3lf\n",
-                    lsat.band[i].lmin, lsat.band[i].lmax);
-            fprintf(stdout, "   at-%s radiance = %.5lf · DN + %.5lf\n",
-                    (atcor[0] == 's' ? "surface" : "sensor"),
-                    lsat.band[i].gain, lsat.band[i].bias);
-	    if (lsat.band[i].thermal)
-		fprintf(stdout, "   at-%s temperature = %.3lf / log[(%.3lf / radiance) + 1.0]\n",
-                        lsat.band[i].K2, lsat.band[i].K1);
-	    else {
-                fprintf(stdout, "   mean solar exoatmospheric irradiance (ESUN): %.3lf\n",
-                        lsat.band[i].esun);
-		fprintf(stdout, "   at-%s reflectance = radiance / %.5lf\n",
-                        lsat.band[i].K2);
-	fflush(stdout);
-     * ---------- CALCULUS -----------------
-    G_get_window(&window);
-	snprintf(band_in, 127, "%s.%d", name, lsat.band[i].code);
-	snprintf(band_out, 127, "%s.toar.%d", name, lsat.band[i].code);
-	mapset = G_find_cell2(band_in, "");
-	if (mapset == NULL) {
-	    G_warning(_("raster file [%s] not found"), band_in);
-	    continue; }
-	if (G_legal_filename(band_out) < 0)
-	    G_fatal_error(_("[%s] is an illegal name"), band_out);
-	in_data_type = G_raster_map_type(band_in, mapset);
-	if ((infd = G_open_cell_old(band_in, mapset)) < 0)
-	    G_fatal_error(_("Cannot open cell file [%s]"), band_in);
-	if (G_get_cellhd(band_in, mapset, &cellhd) < 0)
-	    G_fatal_error(_("Cannot read file header of [%s]"), band_in);
-	/* set same size as original band raster */
-	if (G_set_window(&cellhd) < 0)
-	    G_fatal_error(_("Unable to set region"));
-	/* Allocate input and output buffer */
-	inrast = G_allocate_raster_buf(in_data_type);
-	outrast = G_allocate_raster_buf(DCELL_TYPE);
-	/* controlling, if we can write the raster */
-	if ((outfd = G_open_raster_new(band_out, DCELL_TYPE)) < 0)
-	    G_fatal_error(_("Could not open <%s>"), band_out);
-        G_message("%s of %s to %s",
-                  (frad->answer ? "Radiance" : "Reflectance"),
-                  band_in, band_out);
-        nrows = G_window_rows();
-        ncols = G_window_cols();
-	for (row = 0; row < nrows; row++)
-	    if (verbose)
-		G_percent(row, nrows, 2);
-            if (G_get_raster_row(infd, inrast, row, in_data_type) < 0)
-		G_fatal_error(_("Could not read from <%s>"), band_in);
-	    for (col = 0; col < ncols; col++)
-                switch(in_data_type)
-                        case CELL_TYPE:
-                                ptr = (void *)((CELL *)inrast + col);
-                                qcal = (int)((CELL *) inrast)[col];
-                                break;
-                        case FCELL_TYPE:
-                                ptr = (void *)((FCELL *)inrast + col);
-                                qcal = (int)((FCELL *) inrast)[col];
-                                break;
-                        case DCELL_TYPE:
-                                ptr = (void *)((DCELL *)inrast + col);
-                                qcal = (int)((DCELL *) inrast)[col];
-                                break;
-                if (G_is_null_value(ptr, in_data_type) ||
-                    qcal < lsat.band[i].qcalmin)
-                    G_set_d_null_value((DCELL *)outrast + col, 1);
-                else
-                    rad = lsat_qcal2rad(qcal, &lsat.band[i]);
-                    if (frad->answer)
-                        ref = rad;
-                    else
-                            ref = lsat_rad2temp(rad, &lsat.band[i]);
-                        else
-                            ref = lsat_rad2ref(rad, &lsat.band[i]);
-                    ((DCELL *) outrast)[col] = ref;
-	    if (G_put_raster_row(outfd, outrast, DCELL_TYPE) < 0)
-		G_fatal_error(_("Cannot write to <%s>"), band_out);
-	G_free(inrast);
-        G_close_cell(infd);
-	G_free(outrast);
-	G_close_cell(outfd);
-        sprintf(command, "r.colors map=%s color=grey", band_out);
-        system(command);
-	G_short_history(band_out, "raster", &history);
-	G_command_history(&history);
-	G_write_history(band_out, &history);
-    G_set_window(&window);
-    exit(EXIT_SUCCESS);
Copied: grass-addons/imagery/i.landsat.toar/main.c (from rev 30464, grass-addons/i.landsat.toar/main.c)
--- grass-addons/imagery/i.landsat.toar/main.c	                        (rev 0)
@@ -0,0 +1,577 @@
+ * MODULE:       i.landsat.toar
+ * AUTHOR(S):    E. Jorge Tizado - ej.tizado at unileon.es
+ * PURPOSE:      Calculate TOA Radiance or Reflectance and Kinetic Temperature
+ *               for Landsat 1/2/3/4/5 MS, 4/5 TM or 7 ETM+
+ * COPYRIGHT:    (C) 2002, 2005 2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdio.h>
+#include <stdlib.h>
+int main(int argc, char *argv[])
+	struct History history;
+	struct GModule *module;
+	struct Cell_head cellhd, window;
+	char *mapset;
+	void *inrast, *outrast;
+	int infd, outfd;
+	void *ptr;
+	int nrows, ncols, row, col;
+	RASTER_MAP_TYPE in_data_type;
+	int verbose = 1;
+	struct Option *input, *metfn,
+				*adate, *pdate, *elev, *bgain, *metho, *perc, *dark,
+				*satz, *atmo;
+	char *name, *met;
+	struct Flag *sat1, *sat2, *sat3, *sat4, *sat5, *sat7, *msss,
+				*verbo, *frad;
+	lsat_data lsat;
+	char band_in[127], band_out[127];
+	int i, j, q, method, pixel, dn_dark[MAX_BANDS], dn_mode[MAX_BANDS];
+	double qcal, rad, ref, percent, ref_mode, sat_zenith, rayleigh;
+	unsigned long hist[256], h_max;
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);
+    /* initialize module */
+    module = G_define_module();
+    module->description = _("Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+");
+    module->keywords = _("Top-Of-Atmosphere Radiance or Reflectance.\n Landsat-1 MSS, Landsat-2 MSS, Landsat-3 MSS, Landsat-4 MSS, Landsat-5 MSS,\n Landsat-4 TM, Landsat-5 TM,\n Landsat-7 ETM+");
+    /* It defines the different parameters */
+    input = G_define_option();
+    input->key         = _("band_prefix");
+    input->type        = TYPE_STRING;
+    input->required    = YES;
+    input->gisprompt   = _("input,cell,raster");
+    input->description = _("Base name of the landsat band rasters (.#)");
+    metfn = G_define_option();
+    metfn->key         = _("metfile");
+    metfn->type        = TYPE_STRING;
+    metfn->required    = NO;
+    metfn->gisprompt   = _(".met file");
+    metfn->description = _("Landsat ETM+ or TM5 header file (.met)");
+    adate = G_define_option();
+    adate->key         = _("date");
+    adate->type        = TYPE_STRING;
+    adate->required    = NO;
+    adate->gisprompt   = _("image acquisition date");
+    adate->description = _("Image acquisition date (yyyy-mm-dd)");
+    elev = G_define_option();
+    elev->key         = _("solar_elevation");
+    elev->type        = TYPE_DOUBLE;
+    elev->required    = NO;
+    elev->gisprompt   = _("solar elevation");
+    elev->description = _("Solar elevation in degrees");
+    bgain = G_define_option();
+    bgain->key         = _("gain");
+    bgain->type        = TYPE_STRING;
+    bgain->required    = NO;
+    bgain->gisprompt   = _("band gain");
+    bgain->description = _("Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)");
+    pdate = G_define_option();
+    pdate->key         = _("product_date");
+    pdate->type        = TYPE_STRING;
+    pdate->required    = NO;
+    pdate->gisprompt   = _("image production date");
+    pdate->description = _("Image creation date (yyyy-mm-dd)");
+    metho = G_define_option();
+    metho->key         = _("method");
+    metho->type        = TYPE_STRING;
+    metho->required    = NO;
+    metho->options     = "uncorrected,corrected,dos1,dos2,dos2b,dos3,dos4";
+    metho->gisprompt   = _("atmosferic correction method");
+    metho->description = _("Atmosferic correction method");
+    metho->answer      = "uncorrected";
+	perc = G_define_option();
+	perc->key         = _("percent");
+	perc->type        = TYPE_DOUBLE;
+	perc->required    = NO;
+	perc->gisprompt   = _("percent of solar radiance in path radiance");
+	perc->description = _("Percent of solar radiance in path radiance");
+	perc->answer      = "0.01";
+	dark = G_define_option();
+	dark->key         = _("pixel");
+	dark->type        = TYPE_INTEGER;
+	dark->required    = NO;
+	dark->gisprompt   = _("pixels to dark object");
+	dark->description = _("Minimum pixels to consider digital number as dark object");
+	dark->answer      = "1000";
+	satz = G_define_option();
+	satz->key         = _("sat_zenith");
+	satz->type        = TYPE_DOUBLE;
+	satz->required    = NO;
+	satz->gisprompt   = _("satellite zenith");
+	satz->description = _("Satellite zenith in degrees");
+	satz->answer      = "8.2000";
+	atmo = G_define_option();
+	atmo->key         = _("rayleigh");
+	atmo->type        = TYPE_DOUBLE;
+	atmo->required    = NO;
+	atmo->gisprompt   = _("Rayleigh atmosphere");
+	atmo->description = _("Rayleigh atmosphere");
+	atmo->answer      = "0.0";
+	/* It defines the different flags */
+    frad = G_define_flag();
+    frad->key         = 'r';
+    frad->description = _("Output at-sensor radiance for all bands");
+	frad->answer      = 0;
+    sat1 = G_define_flag();
+	sat1->key         = '1';
+    sat1->description = _("Landsat-1 MSS");
+	sat1->answer      = 0;
+    sat2 = G_define_flag();
+	sat2->key         = '2';
+    sat2->description = _("Landsat-2 MSS");
+	sat2->answer      = 0;
+    sat3 = G_define_flag();
+	sat3->key         = '3';
+    sat3->description = _("Landsat-3 MSS");
+	sat3->answer      = 0;
+    sat4 = G_define_flag();
+	sat4->key         = '4';
+    sat4->description = _("Landsat-4 TM");
+	sat4->answer      = 0;
+    sat5 = G_define_flag();
+	sat5->key         = '5';
+    sat5->description = _("Landsat-5 TM");
+	sat5->answer      = 0;
+    sat7 = G_define_flag();
+	sat7->key         = '7';
+    sat7->description = _("Landsat-7 ETM+");
+	sat7->answer      = 0;
+    msss = G_define_flag();
+	msss->key         = 's';
+    msss->description = _("Set sensor of Landsat-4/5 to MSS");
+	msss->answer      = 0;
+    verbo = G_define_flag();
+	verbo->key         = 'v';
+    verbo->description = _("Show parameters applied");
+    verbo->answer      = 0;
+    /* options and afters parser */
+    if (G_parser(argc, argv))
+		exit(EXIT_FAILURE);
+     * ---------- START --------------------
+     * Stores options and flag to variables
+	met = metfn->answer;
+	name = input->answer;
+	if (adate->answer != NULL) {
+		G_strncpy(lsat.date, adate->answer, 11);
+		lsat.date[10] = '\0';
+	else
+		lsat.date[0] = '\0';
+	if (pdate->answer != NULL) {
+		G_strncpy(lsat.creation, pdate->answer, 11);
+		lsat.creation[10] = '\0';
+	else
+		lsat.creation[0] = '\0';
+	lsat.sun_elev = elev->answer == NULL ? 0. : atof(elev->answer);
+	percent       = atof(perc->answer);
+	pixel         = atoi(dark->answer);
+	sat_zenith    = atof(satz->answer);
+	rayleigh      = atof(atmo->answer);
+	if (met == NULL &&
+		(sat1->answer + sat2->answer + sat3->answer +
+		 sat4->answer + sat5->answer + sat7->answer) != 1)
+		G_fatal_error(_("Select one and only one type of satellite"));
+    /* Data from MET file: only Landsat-7 ETM+ and Landsat-5 TM  */
+	if (met != NULL) {
+		if (sat7->answer) met_ETM(met, &lsat); else met_TM5(met, &lsat);
+		G_message("Landsat-%d %s with data set in met file [%s]", lsat.number, lsat.sensor, met);
+		if (elev->answer != NULL)
+			lsat.sun_elev = atof(elev->answer);         /* Overwrite solar elevation of met file */
+	/* Data from date and solar elevation */
+	else if (adate->answer == NULL || elev->answer == NULL) {
+		G_fatal_error(_("Lacking date or solar elevation for this satellite"));
+    else {
+		if (sat7->answer) { /* Need gain */
+	    	if (bgain->answer != NULL && strlen(bgain->answer) == 9) {
+				set_ETM(&lsat, bgain->answer);
+				G_message("Landsat 7 ETM+");
+	    	else {
+				G_fatal_error(_("For Landsat-7 is necessary band gain with 9 (H/L) data"));
+		else { /* Not need gain */
+			if (sat5->answer) {
+				if (msss->answer) set_MSS5(&lsat); else set_TM5 (&lsat);
+				G_message("Landsat-5 %s", lsat.sensor);
+			else if (sat4->answer) {
+				if (msss->answer) set_MSS4(&lsat); else set_TM4 (&lsat);
+				G_message("Landsat-4 %s", lsat.sensor);
+			else if (sat3->answer) {
+				set_MSS3(&lsat);
+				G_message("Landsat-3 MSS");
+			else if (sat2->answer) {
+				set_MSS2(&lsat);
+				G_message("Landsat-2 MSS");
+			else if (sat1->answer) {
+				set_MSS1(&lsat);
+				G_message("Landsat-1 MSS");
+			else {
+				G_fatal_error(_("Lacking satellite type"));
+	* ------------ PREPARATION --------------
+	if (G_strcasecmp(metho->answer, "corrected") == 0)	method = CORRECTED;
+	else if (G_strcasecmp(metho->answer, "dos1") == 0)	method = DOS1;
+	else if (G_strcasecmp(metho->answer, "dos2") == 0)	method = DOS2;
+	else if (G_strcasecmp(metho->answer, "dos2b") == 0)	method = DOS2b;
+	else if (G_strcasecmp(metho->answer, "dos3") == 0)	method = DOS3;
+	else if (G_strcasecmp(metho->answer, "dos4") == 0)	method = DOS4;
+	else method = UNCORRECTED;
+// 	if (metho->answer[3] == 'r') 		method = CORRECTED;
+// 	else if (metho->answer[3] == '1')	method = DOS1;
+// 	else if (metho->answer[3] == '2')	method = (metho->answer[4] == '\0') ? DOS2 : DOS2b;
+// 	else if (metho->answer[3] == '3')	method = DOS3;
+// 	else if (metho->answer[3] == '4')	method = DOS4;
+// 	else method = UNCORRECTED;
+	for (i = 0; i < lsat.bands; i++)
+		dn_mode[i] = 0;
+		dn_dark[i] = (int)lsat.band[i].qcalmin;
+		/* Calculate dark pixel */
+		if (method > DOS && !lsat.band[i].thermal)
+			for (j = 0; j < 256; j++) hist[j] = 0L;
+			snprintf(band_in, 127, "%s.%d", name, lsat.band[i].code);
+			mapset = G_find_cell2(band_in, "");
+			if (mapset == NULL) {
+				G_warning(_("Raster file [%s] not found"), band_in);
+				continue;
+			if ((infd = G_open_cell_old(band_in, mapset)) < 0)
+				G_fatal_error(_("Cannot open cell file [%s]"), band_in);
+			if (G_get_cellhd(band_in, mapset, &cellhd) < 0)
+				G_fatal_error(_("Cannot read file header of [%s]"), band_in);
+			if (G_set_window(&cellhd) < 0)
+				G_fatal_error(_("Unable to set region"));
+			in_data_type = G_raster_map_type(band_in, mapset);
+			inrast = G_allocate_raster_buf(in_data_type);
+			nrows = G_window_rows();
+			ncols = G_window_cols();
+			G_message("Calculating dark pixel of [%s] ... ", band_in);
+			for (row = 0; row < nrows; row++)
+				G_get_raster_row(infd, inrast, row, in_data_type);
+				for (col = 0; col < ncols; col++)
+					switch(in_data_type)
+						case CELL_TYPE:
+							ptr = (void *)((CELL *)inrast + col);
+							q = (int)*((CELL *)ptr);
+							break;
+						case FCELL_TYPE:
+							ptr = (void *)((FCELL *)inrast + col);
+							q = (int)*((FCELL *)ptr);
+							break;
+						case DCELL_TYPE:
+							ptr = (void *)((DCELL *)inrast + col);
+							q = (int)*((DCELL *)ptr);
+							break;
+					if (!G_is_null_value(ptr, in_data_type) &&
+						q >= lsat.band[i].qcalmin && q < 256)
+						hist[q]++;
+			/* DN of dark object */
+			for (j = lsat.band[i].qcalmin; j < 256; j++)
+				if (hist[j] >= pixel)
+					dn_dark[i] = j;
+					break;
+			/* Mode of DN */
+			h_max = 0L;
+			for (j= lsat.band[i].qcalmin; j < 241; j++) /* Exclude ptentially saturated < 240 */
+// 				printf("%d-%ld\n", j, hist[j]);
+				if (hist[j] > h_max)
+					h_max = hist[j];
+					dn_mode[i] = j;
+			G_message("... DN = %.2d [%d] : mode %.2d [%d]",
+						dn_dark[i], hist[dn_dark[i]],
+						dn_mode[i], hist[dn_mode[i]],
+						hist[255] > hist[dn_mode[i]] ? ", excluding DN > 241" : "");
+			G_free(inrast);
+			G_close_cell(infd);
+		/* Calculate transformation constants */
+		lsat_bandctes(&lsat, i, method, percent, dn_dark[i], sat_zenith, rayleigh);
+	 * ------------ VERBOSE ------------------
+	if (verbo->answer)
+		fprintf(stdout, " ACQUISITION DATE %s [production date %s]\n", lsat.date, lsat.creation);
+		fprintf(stdout, "   earth-sun distance    = %.8lf\n", lsat.dist_es);
+		fprintf(stdout, "   solar elevation angle = %.8lf\n", lsat.sun_elev);
+		fprintf(stdout, "   Method of calculus = %s\n",
+				(method==CORRECTED ? "CORRECTED"
+								   : (method == UNCORRECTED ? "UNCORRECTED" : metho->answer)));
+		if (method > DOS) {
+			fprintf(stdout, "   percent of solar irradiance in path radiance = %.4lf\n", percent);
+			fprintf(stdout, "-------------------\n");
+			fprintf(stdout, " BAND %d %s (code %d)\n",
+					lsat.band[i].number, (lsat.band[i].thermal ? "thermal " : ""),
+					lsat.band[i].code);
+			fprintf(stdout, "   calibrated digital number (DN): %.1lf to %.1lf\n",
+					lsat.band[i].qcalmin, lsat.band[i].qcalmax);
+			fprintf(stdout, "   calibration constants (L): %.3lf to %.3lf\n",
+					lsat.band[i].lmin, lsat.band[i].lmax);
+			fprintf(stdout, "   at-%s radiance = %.5lf · DN + %.5lf\n",
+					(method > DOS ? "surface" : "sensor"),
+					lsat.band[i].gain, lsat.band[i].bias);
+			if (lsat.band[i].thermal) {
+				fprintf(stdout, "   at-sensor temperature = %.3lf / log[(%.3lf / radiance) + 1.0]\n",
+						lsat.band[i].K2, lsat.band[i].K1);
+			else {
+				fprintf(stdout, "   mean solar exoatmospheric irradiance (ESUN): %.3lf\n",
+						lsat.band[i].esun);
+				fprintf(stdout, "   at-%s reflectance = radiance / %.5lf\n",
+						lsat.band[i].K2);
+					fprintf(stdout, "   the darkness DN with a least %d pixels is %d\n", pixel, dn_dark[i] );
+					fprintf(stdout, "   the mode of DN is %d\n", dn_mode[i] );
+		fflush(stdout);
+	 * ------------ CALCULUS -----------------
+		snprintf(band_out, 127, "%s.toar.%d", name, lsat.band[i].code);
+	    	G_warning(_("raster file [%s] not found"), band_in);
+	    	continue; }
+		/* set same size as original band raster */
+		/* controlling, if we can write the raster */
+		if (G_legal_filename(band_out) < 0)
+	    	G_fatal_error(_("[%s] is an illegal name"), band_out);
+		if ((outfd = G_open_raster_new(band_out, DCELL_TYPE)) < 0)
+			G_fatal_error(_("Could not open <%s>"), band_out);
+		/* Allocate input and output buffer */
+		outrast = G_allocate_raster_buf(DCELL_TYPE);
+		G_message("%s of %s to %s",
+				  (frad->answer ? "Radiance"
+			                    : (lsat.band[i].thermal) ? "Temperature" : "Reflectance"),
+				   band_in, band_out);
+			if (verbose)
+				G_percent(row, nrows, 2);
+					case CELL_TYPE:
+							qcal = (double)((CELL *) inrast)[col];
+							break;
+					case FCELL_TYPE:
+							qcal = (double)((FCELL *) inrast)[col];
+							break;
+					case DCELL_TYPE:
+							qcal = (double)((DCELL *) inrast)[col];
+							break;
+				if (G_is_null_value(ptr, in_data_type) ||
+					qcal < lsat.band[i].qcalmin)
+					G_set_d_null_value((DCELL *)outrast + col, 1);
+				else
+					rad = lsat_qcal2rad(qcal, &lsat.band[i]);
+					if (frad->answer)
+						ref = rad;
+					else
+							ref = lsat_rad2temp(rad, &lsat.band[i]);
+						else
+							ref = lsat_rad2ref(rad, &lsat.band[i]);
+							if (ref < 0. && method > DOS) ref = 0.;
+					((DCELL *) outrast)[col] = ref;
+			if (G_put_raster_row(outfd, outrast, DCELL_TYPE) < 0)
+				G_fatal_error(_("Cannot write to <%s>"), band_out);
+		ref_mode = 0.;
+			ref_mode = lsat_qcal2rad(dn_mode[i], &lsat.band[i]);
+			ref_mode = lsat_rad2ref(ref_mode, &lsat.band[i]);
+		G_free(inrast);
+		G_free(outrast);
+		G_close_cell(outfd);
+		char command[300];
+		sprintf(command, "r.colors map=%s color=grey", band_out);
+		system(command);
+		G_short_history(band_out, "raster", &history);
+		sprintf(history.edhist[0], " %s of Landsat-%d %s (method %s)", lsat.band[i].thermal ? "Temperature": "Reflectance",
+				lsat.number, lsat.sensor, metho->answer);
+		sprintf(history.edhist[1], "----------------------------------------------------------------");
+		sprintf(history.edhist[2], " Acquisition date ...................... %s", lsat.date);
+		sprintf(history.edhist[3], " Production date ....................... %s\n", lsat.creation);
+		sprintf(history.edhist[4], " Earth-sun distance (d) ................ %.8lf", lsat.dist_es);
+		sprintf(history.edhist[5], " Digital number (DN) range ............. %.0lf to %.0lf", lsat.band[i].qcalmin, lsat.band[i].qcalmax);
+		sprintf(history.edhist[6], " Calibration constants (Lmin to Lmax) .. %+.3lf to %+.3lf", lsat.band[i].lmin, lsat.band[i].lmax);
+		sprintf(history.edhist[7], " DN to Radiance (gain and bias) ........ %+.5lf and %+.5lf", lsat.band[i].gain, lsat.band[i].bias);
+			sprintf(history.edhist[8], " Temperature (K1 and K2) ............... %.3lf and %.3lf", lsat.band[i].K1, lsat.band[i].K2);
+            history.edlinecnt = 9;
+		} else {
+			sprintf(history.edhist[8], " Mean solar irradiance (ESUN) .......... %.3lf", lsat.band[i].esun);
+			sprintf(history.edhist[9], " Reflectance = Radiance divided by ..... %.5lf", lsat.band[i].K2);
+	        history.edlinecnt = 10;
+				sprintf(history.edhist[10], "");
+				sprintf(history.edhist[11], " Dark object (%4d pixels) DN = ........ %d", pixel, dn_dark[i]);
+				sprintf(history.edhist[12], " Mode in reflectance histogram ......... %.5lf", ref_mode);
+				history.edlinecnt = 13;
+		sprintf (history.edhist[history.edlinecnt], "-----------------------------------------------------------------");
+		history.edlinecnt++;
+		G_command_history(&history);
+		G_write_history(band_out, &history);
+	exit(EXIT_SUCCESS);
