[GRASS-SVN] r30524 - grass/trunk/swig/python/NumPtr/src
svn_grass at osgeo.org
Mon Mar 10 18:46:57 EDT 2008
Author: hamish
Date: 2008-03-10 18:46:57 -0400 (Mon, 10 Mar 2008)
New Revision: 30524
Removed:
grass/trunk/swig/python/NumPtr/src/NumPtr.py
grass/trunk/swig/python/NumPtr/src/NumPtr_wrap.c
remove files autogenerated by SWIG
Deleted: grass/trunk/swig/python/NumPtr/src/NumPtr.py
--- grass/trunk/swig/python/NumPtr/src/NumPtr.py 2008-03-10 15:02:59 UTC (rev 30523)
+++ grass/trunk/swig/python/NumPtr/src/NumPtr.py 2008-03-10 22:46:57 UTC (rev 30524)
@@ -1,81 +0,0 @@
-# This file was created automatically by SWIG.
-# Don't modify this file, modify the SWIG interface instead.
-# This file is compatible with both classic and new-style classes.
-import _NumPtr
-def _swig_setattr(self,class_type,name,value):
- if (name == "this"):
- if isinstance(value, class_type):
- self.__dict__[name] = value.this
- if hasattr(value,"thisown"): self.__dict__["thisown"] = value.thisown
- del value.thisown
- return
- method = class_type.__swig_setmethods__.get(name,None)
- if method: return method(self,value)
-def _swig_getattr(self,class_type,name):
- method = class_type.__swig_getmethods__.get(name,None)
- if method: return method(self)
- raise AttributeError,name
-import types
-try:
- _object = types.ObjectType
- _newclass = 1
-except AttributeError:
- class _object : pass
- _newclass = 0
-del types
-getpointer1 = _NumPtr.getpointer1
-getpointer2 = _NumPtr.getpointer2
-getpointer3 = _NumPtr.getpointer3
-getdpointer1 = _NumPtr.getdpointer1
-getdpointer2 = _NumPtr.getdpointer2
-getdpointer3 = _NumPtr.getdpointer3
-getfpointer1 = _NumPtr.getfpointer1
-getfpointer2 = _NumPtr.getfpointer2
-getfpointer3 = _NumPtr.getfpointer3
-getipointer1 = _NumPtr.getipointer1
-getipointer2 = _NumPtr.getipointer2
-getipointer3 = _NumPtr.getipointer3
-test1 = _NumPtr.test1
-test2 = _NumPtr.test2
-test3 = _NumPtr.test3
-testd1 = _NumPtr.testd1
-testd2 = _NumPtr.testd2
-testd3 = _NumPtr.testd3
-testf1 = _NumPtr.testf1
-testf2 = _NumPtr.testf2
-testf3 = _NumPtr.testf3
-testi1 = _NumPtr.testi1
-testi2 = _NumPtr.testi2
-testi3 = _NumPtr.testi3
Deleted: grass/trunk/swig/python/NumPtr/src/NumPtr_wrap.c
--- grass/trunk/swig/python/NumPtr/src/NumPtr_wrap.c 2008-03-10 15:02:59 UTC (rev 30523)
+++ grass/trunk/swig/python/NumPtr/src/NumPtr_wrap.c 2008-03-10 22:46:57 UTC (rev 30524)
@@ -1,1218 +0,0 @@
- * This file was automatically generated by SWIG (http://www.swig.org).
- * Version 1.3.21
- * This file is not intended to be easily readable and contains a number of
- * coding conventions designed to improve portability and efficiency. Do not make
- * changes to this file unless you know what you are doing--modify the SWIG
- * interface file instead.
-#define SWIGPYTHON
-#include "Python.h"
-/*************************************************************** -*- c -*-
- * python/precommon.swg
- * Rename all exported symbols from common.swg, to avoid symbol
- * clashes if multiple interpreters are included
-#define SWIG_TypeRegister SWIG_Python_TypeRegister
-#define SWIG_TypeCheck SWIG_Python_TypeCheck
-#define SWIG_TypeCast SWIG_Python_TypeCast
-#define SWIG_TypeDynamicCast SWIG_Python_TypeDynamicCast
-#define SWIG_TypeName SWIG_Python_TypeName
-#define SWIG_TypeQuery SWIG_Python_TypeQuery
-#define SWIG_TypeClientData SWIG_Python_TypeClientData
-#define SWIG_PackData SWIG_Python_PackData
-#define SWIG_UnpackData SWIG_Python_UnpackData
- * common.swg
- * This file contains generic SWIG runtime support for pointer
- * type checking as well as a few commonly used macros to control
- * external linkage.
- * Author : David Beazley (beazley at cs.uchicago.edu)
- * Copyright (c) 1999-2000, The University of Chicago
- * This file may be freely redistributed without license or fee provided
- * this copyright message remains intact.
-#include <string.h>
-#if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
-# if defined(_MSC_VER) || defined(__GNUC__)
-# if defined(STATIC_LINKED)
-# define SWIGEXPORT(a) a
-# define SWIGIMPORT(a) extern a
-# else
-# define SWIGEXPORT(a) __declspec(dllexport) a
-# endif
-# else
-# if defined(__BORLANDC__)
-# define SWIGEXPORT(a) a _export
-# define SWIGIMPORT(a) a _export
-# else
-# endif
-# endif
-#else
-#endif
-#ifdef SWIG_GLOBAL
-# define SWIGRUNTIME(a) SWIGEXPORT(a)
-#else
-# define SWIGRUNTIME(a) static a
-#endif
-#ifdef __cplusplus
-extern "C" {
-#endif
-typedef void *(*swig_converter_func)(void *);
-typedef struct swig_type_info *(*swig_dycast_func)(void **);
-typedef struct swig_type_info {
- const char *name;
- swig_converter_func converter;
- const char *str;
- void *clientdata;
- swig_dycast_func dcast;
- struct swig_type_info *next;
- struct swig_type_info *prev;
-} swig_type_info;
-#ifdef SWIG_NOINCLUDE
-SWIGIMPORT(swig_type_info *) SWIG_TypeRegister(swig_type_info *);
-SWIGIMPORT(swig_type_info *) SWIG_TypeCheck(char *c, swig_type_info *);
-SWIGIMPORT(void *) SWIG_TypeCast(swig_type_info *, void *);
-SWIGIMPORT(swig_type_info *) SWIG_TypeDynamicCast(swig_type_info *, void **);
-SWIGIMPORT(const char *) SWIG_TypeName(const swig_type_info *);
-SWIGIMPORT(swig_type_info *) SWIG_TypeQuery(const char *);
-SWIGIMPORT(void) SWIG_TypeClientData(swig_type_info *, void *);
-SWIGIMPORT(char *) SWIG_PackData(char *, void *, int);
-SWIGIMPORT(char *) SWIG_UnpackData(char *, void *, int);
-#else
-static swig_type_info *swig_type_list = 0;
-/* Register a type mapping with the type-checking */
-SWIGRUNTIME(swig_type_info *)
-SWIG_TypeRegister(swig_type_info *ti) {
- swig_type_info *tc, *head, *ret, *next;
- /* Check to see if this type has already been registered */
- tc = swig_type_list;
- while (tc) {
- if (strcmp(tc->name, ti->name) == 0) {
- /* Already exists in the table. Just add additional types to the list */
- if (tc->clientdata) ti->clientdata = tc->clientdata;
- head = tc;
- next = tc->next;
- goto l1;
- tc = tc->prev;
- head = ti;
- next = 0;
- /* Place in list */
- ti->prev = swig_type_list;
- swig_type_list = ti;
- /* Build linked lists */
- l1:
- ret = head;
- tc = ti + 1;
- /* Patch up the rest of the links */
- while (tc->name) {
- head->next = tc;
- tc->prev = head;
- head = tc;
- tc++;
- if (next) next->prev = head;
- head->next = next;
- return ret;
-/* Check the typename */
-SWIG_TypeCheck(char *c, swig_type_info *ty) {
- swig_type_info *s;
- if (!ty) return 0; /* Void pointer */
- s = ty->next; /* First element always just a name */
- do {
- if (strcmp(s->name,c) == 0) {
- if (s == ty->next) return s;
- /* Move s to the top of the linked list */
- s->prev->next = s->next;
- if (s->next) {
- s->next->prev = s->prev;
- /* Insert s as second element in the list */
- s->next = ty->next;
- if (ty->next) ty->next->prev = s;
- ty->next = s;
- s->prev = ty;
- return s;
- s = s->next;
- } while (s && (s != ty->next));
- return 0;
-/* Cast a pointer up an inheritance hierarchy */
-SWIGRUNTIME(void *)
-SWIG_TypeCast(swig_type_info *ty, void *ptr) {
- if ((!ty) || (!ty->converter)) return ptr;
- return (*ty->converter)(ptr);
-/* Dynamic pointer casting. Down an inheritance hierarchy */
-SWIG_TypeDynamicCast(swig_type_info *ty, void **ptr) {
- swig_type_info *lastty = ty;
- if (!ty || !ty->dcast) return ty;
- while (ty && (ty->dcast)) {
- ty = (*ty->dcast)(ptr);
- if (ty) lastty = ty;
- return lastty;
-/* Return the name associated with this type */
-SWIGRUNTIME(const char *)
-SWIG_TypeName(const swig_type_info *ty) {
- return ty->name;
-/* Search for a swig_type_info structure */
-SWIG_TypeQuery(const char *name) {
- swig_type_info *ty = swig_type_list;
- while (ty) {
- if (ty->str && (strcmp(name,ty->str) == 0)) return ty;
- if (ty->name && (strcmp(name,ty->name) == 0)) return ty;
- ty = ty->prev;
- return 0;
-/* Set the clientdata field for a type */
-SWIGRUNTIME(void)
-SWIG_TypeClientData(swig_type_info *ti, void *clientdata) {
- swig_type_info *tc, *equiv;
- if (ti->clientdata == clientdata) return;
- ti->clientdata = clientdata;
- equiv = ti->next;
- while (equiv) {
- if (!equiv->converter) {
- while (tc) {
- if ((strcmp(tc->name, equiv->name) == 0))
- SWIG_TypeClientData(tc,clientdata);
- tc = tc->prev;
- equiv = equiv->next;
-/* Pack binary data into a string */
-SWIGRUNTIME(char *)
-SWIG_PackData(char *c, void *ptr, int sz) {
- static char hex[17] = "0123456789abcdef";
- int i;
- unsigned char *u = (unsigned char *) ptr;
- register unsigned char uu;
- for (i = 0; i < sz; i++,u++) {
- uu = *u;
- *(c++) = hex[(uu & 0xf0) >> 4];
- *(c++) = hex[uu & 0xf];
- return c;
-/* Unpack binary data from a string */
-SWIG_UnpackData(char *c, void *ptr, int sz) {
- register unsigned char uu = 0;
- register int d;
- int i;
- for (i = 0; i < sz; i++, u++) {
- d = *(c++);
- if ((d >= '0') && (d <= '9'))
- uu = ((d - '0') << 4);
- else if ((d >= 'a') && (d <= 'f'))
- uu = ((d - ('a'-10)) << 4);
- d = *(c++);
- uu |= (d - '0');
- uu |= (d - ('a'-10));
- *u = uu;
- return c;
-#endif
-#ifdef __cplusplus
-#endif
- * python.swg
- * This file contains the runtime support for Python modules
- * and includes code for managing global variables and pointer
- * type checking.
-#ifdef __cplusplus
-extern "C" {
-#endif
-#define SWIG_PY_INT 1
-#define SWIG_PY_FLOAT 2
-#define SWIG_PY_STRING 3
-#define SWIG_PY_POINTER 4
-#define SWIG_PY_BINARY 5
-/* Flags for pointer conversion */
-#define SWIG_POINTER_EXCEPTION 0x1
-#define SWIG_POINTER_DISOWN 0x2
-/* Exception handling in wrappers */
-#define SWIG_fail goto fail
-/* Constant information structure */
-typedef struct swig_const_info {
- int type;
- char *name;
- long lvalue;
- double dvalue;
- void *pvalue;
- swig_type_info **ptype;
-} swig_const_info;
-/* Common SWIG API */
-#define SWIG_ConvertPtr(obj, pp, type, flags) \
- SWIG_Python_ConvertPtr(obj, pp, type, flags)
-#define SWIG_NewPointerObj(p, type, flags) \
- SWIG_Python_NewPointerObj(p, type, flags)
-#define SWIG_MustGetPtr(p, type, argnum, flags) \
- SWIG_Python_MustGetPtr(p, type, argnum, flags)
-/* Python-specific SWIG API */
-#define SWIG_newvarlink() \
- SWIG_Python_newvarlink()
-#define SWIG_addvarlink(p, name, get_attr, set_attr) \
- SWIG_Python_addvarlink(p, name, get_attr, set_attr)
-#define SWIG_ConvertPacked(obj, ptr, sz, ty, flags) \
- SWIG_Python_ConvertPacked(obj, ptr, sz, ty, flags)
-#define SWIG_NewPackedObj(ptr, sz, type) \
- SWIG_Python_NewPackedObj(ptr, sz, type)
-#define SWIG_InstallConstants(d, constants) \
- SWIG_Python_InstallConstants(d, constants)
-SWIGIMPORT(int) SWIG_Python_ConvertPtr(PyObject *, void **, swig_type_info *, int);
-SWIGIMPORT(PyObject *) SWIG_Python_NewPointerObj(void *, swig_type_info *,int own);
-SWIGIMPORT(void *) SWIG_Python_MustGetPtr(PyObject *, swig_type_info *, int, int);
-SWIGIMPORT(PyObject *) SWIG_Python_newvarlink(void);
-SWIGIMPORT(void) SWIG_Python_addvarlink(PyObject *, char *, PyObject *(*)(void), int (*)(PyObject *));
-SWIGIMPORT(int) SWIG_Python_ConvertPacked(PyObject *, void *, int sz, swig_type_info *, int);
-SWIGIMPORT(PyObject *) SWIG_Python_NewPackedObj(void *, int sz, swig_type_info *);
-SWIGIMPORT(void) SWIG_Python_InstallConstants(PyObject *d, swig_const_info constants[]);
-#else
- * global variable support code.
-typedef struct swig_globalvar {
- char *name; /* Name of global variable */
- PyObject *(*get_attr)(void); /* Return the current value */
- int (*set_attr)(PyObject *); /* Set the value */
- struct swig_globalvar *next;
-} swig_globalvar;
-typedef struct swig_varlinkobject {
- PyObject_HEAD
- swig_globalvar *vars;
-} swig_varlinkobject;
-static PyObject *
-swig_varlink_repr(swig_varlinkobject *v) {
- v = v;
- return PyString_FromString("<Global variables>");
-static int
-swig_varlink_print(swig_varlinkobject *v, FILE *fp, int flags) {
- swig_globalvar *var;
- flags = flags;
- fprintf(fp,"Global variables { ");
- for (var = v->vars; var; var=var->next) {
- fprintf(fp,"%s", var->name);
- if (var->next) fprintf(fp,", ");
- fprintf(fp," }\n");
- return 0;
-static PyObject *
-swig_varlink_getattr(swig_varlinkobject *v, char *n) {
- swig_globalvar *var = v->vars;
- while (var) {
- if (strcmp(var->name,n) == 0) {
- return (*var->get_attr)();
- var = var->next;
- PyErr_SetString(PyExc_NameError,"Unknown C global variable");
- return NULL;
-static int
-swig_varlink_setattr(swig_varlinkobject *v, char *n, PyObject *p) {
- while (var) {
- return (*var->set_attr)(p);
- var = var->next;
- return 1;
-statichere PyTypeObject varlinktype = {
- PyObject_HEAD_INIT(0)
- 0,
- (char *)"swigvarlink", /* Type name */
- sizeof(swig_varlinkobject), /* Basic size */
- 0, /* Itemsize */
- 0, /* Deallocator */
- (printfunc) swig_varlink_print, /* Print */
- (getattrfunc) swig_varlink_getattr, /* get attr */
- (setattrfunc) swig_varlink_setattr, /* Set attr */
- 0, /* tp_compare */
- (reprfunc) swig_varlink_repr, /* tp_repr */
- 0, /* tp_as_number */
- 0, /* tp_as_mapping*/
- 0, /* tp_hash */
-/* Create a variable linking object for use later */
-SWIGRUNTIME(PyObject *)
-SWIG_Python_newvarlink(void) {
- swig_varlinkobject *result = 0;
- result = PyMem_NEW(swig_varlinkobject,1);
- varlinktype.ob_type = &PyType_Type; /* Patch varlinktype into a PyType */
- result->ob_type = &varlinktype;
- result->vars = 0;
- result->ob_refcnt = 0;
- Py_XINCREF((PyObject *) result);
- return ((PyObject*) result);
-SWIGRUNTIME(void)
-SWIG_Python_addvarlink(PyObject *p, char *name, PyObject *(*get_attr)(void), int (*set_attr)(PyObject *p)) {
- swig_varlinkobject *v;
- swig_globalvar *gv;
- v= (swig_varlinkobject *) p;
- gv = (swig_globalvar *) malloc(sizeof(swig_globalvar));
- gv->name = (char *) malloc(strlen(name)+1);
- strcpy(gv->name,name);
- gv->get_attr = get_attr;
- gv->set_attr = set_attr;
- gv->next = v->vars;
- v->vars = gv;
-/* Convert a pointer value */
-SWIGRUNTIME(int)
-SWIG_Python_ConvertPtr(PyObject *obj, void **ptr, swig_type_info *ty, int flags) {
- swig_type_info *tc;
- char *c = 0;
- static PyObject *SWIG_this = 0;
- int newref = 0;
- PyObject *pyobj = 0;
- if (!obj) return 0;
- if (obj == Py_None) {
- *ptr = 0;
- return 0;
-#ifdef SWIG_COBJECT_TYPES
- if (!(PyCObject_Check(obj))) {
- if (!SWIG_this)
- SWIG_this = PyString_FromString("this");
- pyobj = obj;
- obj = PyObject_GetAttr(obj,SWIG_this);
- newref = 1;
- if (!obj) goto type_error;
- if (!PyCObject_Check(obj)) {
- Py_DECREF(obj);
- goto type_error;
- *ptr = PyCObject_AsVoidPtr(obj);
- c = (char *) PyCObject_GetDesc(obj);
- if (newref) Py_DECREF(obj);
- goto cobject;
-#else
- if (!(PyString_Check(obj))) {
- if (!SWIG_this)
- pyobj = obj;
- newref = 1;
- if (!PyString_Check(obj)) {
- Py_DECREF(obj);
- goto type_error;
- c = PyString_AsString(obj);
- /* Pointer values must start with leading underscore */
- if (*c != '_') {
- *ptr = (void *) 0;
- if (strcmp(c,"NULL") == 0) {
- if (newref) { Py_DECREF(obj); }
- return 0;
- } else {
- goto type_error;
- c++;
- c = SWIG_UnpackData(c,ptr,sizeof(void *));
-#endif
-cobject:
-#endif
- if (ty) {
- tc = SWIG_TypeCheck(c,ty);
- if (!tc) goto type_error;
- *ptr = SWIG_TypeCast(tc,(void*) *ptr);
- if ((pyobj) && (flags & SWIG_POINTER_DISOWN)) {
- PyObject *zero = PyInt_FromLong(0);
- PyObject_SetAttrString(pyobj,(char*)"thisown",zero);
- Py_DECREF(zero);
- return 0;
-type_error:
- if (flags & SWIG_POINTER_EXCEPTION) {
- if (ty && c) {
- char *temp = (char *) malloc(64+strlen(ty->name)+strlen(c));
- sprintf(temp,"Type error. Got %s, expected %s", c, ty->name);
- PyErr_SetString(PyExc_TypeError, temp);
- free((char *) temp);
- } else {
- PyErr_SetString(PyExc_TypeError,"Expected a pointer");
- return -1;
-/* Convert a pointer value, signal an exception on a type mismatch */
-SWIG_Python_MustGetPtr(PyObject *obj, swig_type_info *ty, int argnum, int flags) {
- void *result;
- SWIG_Python_ConvertPtr(obj, &result, ty, flags | SWIG_POINTER_EXCEPTION);
- return result;
-/* Convert a packed value value */
-SWIGRUNTIME(int)
-SWIG_Python_ConvertPacked(PyObject *obj, void *ptr, int sz, swig_type_info *ty, int flags) {
- char *c = 0;
- if ((!obj) || (!PyString_Check(obj))) goto type_error;
- if (*c != '_') goto type_error;
- c++;
- c = SWIG_UnpackData(c,ptr,sz);
- if (ty) {
- return 0;
-type_error:
- if (flags) {
- if (ty && c) {
- } else {
- return -1;
-/* Create a new pointer object */
-SWIG_Python_NewPointerObj(void *ptr, swig_type_info *type, int own) {
- PyObject *robj;
- if (!ptr) {
- Py_INCREF(Py_None);
- return Py_None;
- robj = PyCObject_FromVoidPtrAndDesc((void *) ptr, (char *) type->name, NULL);
-#else
- char result[1024];
- char *r = result;
- *(r++) = '_';
- r = SWIG_PackData(r,&ptr,sizeof(void *));
- strcpy(r,type->name);
- robj = PyString_FromString(result);
-#endif
- if (!robj || (robj == Py_None)) return robj;
- if (type->clientdata) {
- PyObject *inst;
- PyObject *args = Py_BuildValue((char*)"(O)", robj);
- Py_DECREF(robj);
- inst = PyObject_CallObject((PyObject *) type->clientdata, args);
- Py_DECREF(args);
- if (inst) {
- if (own) {
- PyObject *n = PyInt_FromLong(1);
- PyObject_SetAttrString(inst,(char*)"thisown",n);
- Py_DECREF(n);
- robj = inst;
- return robj;
-SWIG_Python_NewPackedObj(void *ptr, int sz, swig_type_info *type) {
- char *r = result;
- if ((2*sz + 1 + strlen(type->name)) > 1000) return 0;
- *(r++) = '_';
- r = SWIG_PackData(r,ptr,sz);
- return PyString_FromString(result);
-/* Install Constants */
-SWIGRUNTIME(void)
-SWIG_Python_InstallConstants(PyObject *d, swig_const_info constants[]) {
- int i;
- PyObject *obj;
- for (i = 0; constants[i].type; i++) {
- switch(constants[i].type) {
- case SWIG_PY_INT:
- obj = PyInt_FromLong(constants[i].lvalue);
- break;
- case SWIG_PY_FLOAT:
- obj = PyFloat_FromDouble(constants[i].dvalue);
- break;
- case SWIG_PY_STRING:
- obj = PyString_FromString((char *) constants[i].pvalue);
- break;
- case SWIG_PY_POINTER:
- obj = SWIG_NewPointerObj(constants[i].pvalue, *(constants[i]).ptype,0);
- break;
- case SWIG_PY_BINARY:
- obj = SWIG_NewPackedObj(constants[i].pvalue, constants[i].lvalue, *(constants[i].ptype));
- break;
- default:
- obj = 0;
- break;
- if (obj) {
- PyDict_SetItemString(d,constants[i].name,obj);
- Py_DECREF(obj);
-#endif
-/* Contract support */
-#define SWIG_contract_assert(expr, msg) if (!(expr)) { PyErr_SetString(PyExc_RuntimeError, (char *) msg ); goto fail; } else
-#ifdef __cplusplus
-#endif
-/* -------- TYPES TABLE (BEGIN) -------- */
-#define SWIGTYPE_p_float swig_types[0]
-#define SWIGTYPE_p_p_float swig_types[1]
-#define SWIGTYPE_p_p_p_float swig_types[2]
-#define SWIGTYPE_p_double swig_types[3]
-#define SWIGTYPE_p_p_double swig_types[4]
-#define SWIGTYPE_p_p_p_double swig_types[5]
-#define SWIGTYPE_p_int swig_types[6]
-#define SWIGTYPE_p_p_int swig_types[7]
-#define SWIGTYPE_p_p_p_int swig_types[8]
-static swig_type_info *swig_types[10];
-/* -------- TYPES TABLE (END) -------- */
- @(target):= _NumPtr.so
-#define SWIG_init init_NumPtr
-#define SWIG_name "_NumPtr"
-#include "getpointer.h"
-#include "test.h"
-#ifdef __cplusplus
-extern "C" {
-#endif
-static PyObject *_wrap_getpointer1(PyObject *self, PyObject *args) {
- PyObject *resultobj;
- PyObject *arg1 = (PyObject *) 0 ;
- double *result;
- PyObject * obj0 = 0 ;
- if(!PyArg_ParseTuple(args,(char *)"O:getpointer1",&obj0)) goto fail;
- arg1 = obj0;
- result = (double *)getpointer1(arg1);
- resultobj = SWIG_NewPointerObj((void *) result, SWIGTYPE_p_double, 0);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getpointer2(PyObject *self, PyObject *args) {
- double **result;
- if(!PyArg_ParseTuple(args,(char *)"O:getpointer2",&obj0)) goto fail;
- arg1 = obj0;
- result = (double **)getpointer2(arg1);
- resultobj = SWIG_NewPointerObj((void *) result, SWIGTYPE_p_p_double, 0);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getpointer3(PyObject *self, PyObject *args) {
- double ***result;
- if(!PyArg_ParseTuple(args,(char *)"O:getpointer3",&obj0)) goto fail;
- arg1 = obj0;
- result = (double ***)getpointer3(arg1);
- resultobj = SWIG_NewPointerObj((void *) result, SWIGTYPE_p_p_p_double, 0);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getdpointer1(PyObject *self, PyObject *args) {
- double *result;
- if(!PyArg_ParseTuple(args,(char *)"O:getdpointer1",&obj0)) goto fail;
- arg1 = obj0;
- result = (double *)getdpointer1(arg1);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getdpointer2(PyObject *self, PyObject *args) {
- double **result;
- if(!PyArg_ParseTuple(args,(char *)"O:getdpointer2",&obj0)) goto fail;
- arg1 = obj0;
- result = (double **)getdpointer2(arg1);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getdpointer3(PyObject *self, PyObject *args) {
- double ***result;
- if(!PyArg_ParseTuple(args,(char *)"O:getdpointer3",&obj0)) goto fail;
- arg1 = obj0;
- result = (double ***)getdpointer3(arg1);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getfpointer1(PyObject *self, PyObject *args) {
- float *result;
- if(!PyArg_ParseTuple(args,(char *)"O:getfpointer1",&obj0)) goto fail;
- arg1 = obj0;
- result = (float *)getfpointer1(arg1);
- resultobj = SWIG_NewPointerObj((void *) result, SWIGTYPE_p_float, 0);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getfpointer2(PyObject *self, PyObject *args) {
- float **result;
- if(!PyArg_ParseTuple(args,(char *)"O:getfpointer2",&obj0)) goto fail;
- arg1 = obj0;
- result = (float **)getfpointer2(arg1);
- resultobj = SWIG_NewPointerObj((void *) result, SWIGTYPE_p_p_float, 0);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getfpointer3(PyObject *self, PyObject *args) {
- float ***result;
- if(!PyArg_ParseTuple(args,(char *)"O:getfpointer3",&obj0)) goto fail;
- arg1 = obj0;
- result = (float ***)getfpointer3(arg1);
- resultobj = SWIG_NewPointerObj((void *) result, SWIGTYPE_p_p_p_float, 0);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getipointer1(PyObject *self, PyObject *args) {
- int *result;
- if(!PyArg_ParseTuple(args,(char *)"O:getipointer1",&obj0)) goto fail;
- arg1 = obj0;
- result = (int *)getipointer1(arg1);
- resultobj = SWIG_NewPointerObj((void *) result, SWIGTYPE_p_int, 0);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getipointer2(PyObject *self, PyObject *args) {
- int **result;
- if(!PyArg_ParseTuple(args,(char *)"O:getipointer2",&obj0)) goto fail;
- arg1 = obj0;
- result = (int **)getipointer2(arg1);
- resultobj = SWIG_NewPointerObj((void *) result, SWIGTYPE_p_p_int, 0);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_getipointer3(PyObject *self, PyObject *args) {
- int ***result;
- if(!PyArg_ParseTuple(args,(char *)"O:getipointer3",&obj0)) goto fail;
- arg1 = obj0;
- result = (int ***)getipointer3(arg1);
- resultobj = SWIG_NewPointerObj((void *) result, SWIGTYPE_p_p_p_int, 0);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_test1(PyObject *self, PyObject *args) {
- double *arg1 = (double *) 0 ;
- int arg2 ;
- if(!PyArg_ParseTuple(args,(char *)"Oi:test1",&obj0,&arg2)) goto fail;
- if ((SWIG_ConvertPtr(obj0,(void **) &arg1, SWIGTYPE_p_double,SWIG_POINTER_EXCEPTION | 0 )) == -1) SWIG_fail;
- test1(arg1,arg2);
- Py_INCREF(Py_None); resultobj = Py_None;
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_test2(PyObject *self, PyObject *args) {
- double **arg1 = (double **) 0 ;
- int arg2 ;
- int arg3 ;
- if(!PyArg_ParseTuple(args,(char *)"Oii:test2",&obj0,&arg2,&arg3)) goto fail;
- if ((SWIG_ConvertPtr(obj0,(void **) &arg1, SWIGTYPE_p_p_double,SWIG_POINTER_EXCEPTION | 0 )) == -1) SWIG_fail;
- test2(arg1,arg2,arg3);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_test3(PyObject *self, PyObject *args) {
- double ***arg1 = (double ***) 0 ;
- int arg2 ;
- int arg3 ;
- int arg4 ;
- if(!PyArg_ParseTuple(args,(char *)"Oiii:test3",&obj0,&arg2,&arg3,&arg4)) goto fail;
- if ((SWIG_ConvertPtr(obj0,(void **) &arg1, SWIGTYPE_p_p_p_double,SWIG_POINTER_EXCEPTION | 0 )) == -1) SWIG_fail;
- test3(arg1,arg2,arg3,arg4);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_testd1(PyObject *self, PyObject *args) {
- int arg2 ;
- if(!PyArg_ParseTuple(args,(char *)"Oi:testd1",&obj0,&arg2)) goto fail;
- testd1(arg1,arg2);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_testd2(PyObject *self, PyObject *args) {
- int arg2 ;
- int arg3 ;
- if(!PyArg_ParseTuple(args,(char *)"Oii:testd2",&obj0,&arg2,&arg3)) goto fail;
- testd2(arg1,arg2,arg3);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_testd3(PyObject *self, PyObject *args) {
- int arg2 ;
- int arg3 ;
- int arg4 ;
- if(!PyArg_ParseTuple(args,(char *)"Oiii:testd3",&obj0,&arg2,&arg3,&arg4)) goto fail;
- testd3(arg1,arg2,arg3,arg4);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_testf1(PyObject *self, PyObject *args) {
- float *arg1 = (float *) 0 ;
- int arg2 ;
- if(!PyArg_ParseTuple(args,(char *)"Oi:testf1",&obj0,&arg2)) goto fail;
- if ((SWIG_ConvertPtr(obj0,(void **) &arg1, SWIGTYPE_p_float,SWIG_POINTER_EXCEPTION | 0 )) == -1) SWIG_fail;
- testf1(arg1,arg2);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_testf2(PyObject *self, PyObject *args) {
- float **arg1 = (float **) 0 ;
- int arg2 ;
- int arg3 ;
- if(!PyArg_ParseTuple(args,(char *)"Oii:testf2",&obj0,&arg2,&arg3)) goto fail;
- if ((SWIG_ConvertPtr(obj0,(void **) &arg1, SWIGTYPE_p_p_float,SWIG_POINTER_EXCEPTION | 0 )) == -1) SWIG_fail;
- testf2(arg1,arg2,arg3);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_testf3(PyObject *self, PyObject *args) {
- float ***arg1 = (float ***) 0 ;
- int arg2 ;
- int arg3 ;
- int arg4 ;
- if(!PyArg_ParseTuple(args,(char *)"Oiii:testf3",&obj0,&arg2,&arg3,&arg4)) goto fail;
- if ((SWIG_ConvertPtr(obj0,(void **) &arg1, SWIGTYPE_p_p_p_float,SWIG_POINTER_EXCEPTION | 0 )) == -1) SWIG_fail;
- testf3(arg1,arg2,arg3,arg4);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_testi1(PyObject *self, PyObject *args) {
- int *arg1 = (int *) 0 ;
- int arg2 ;
- if(!PyArg_ParseTuple(args,(char *)"Oi:testi1",&obj0,&arg2)) goto fail;
- if ((SWIG_ConvertPtr(obj0,(void **) &arg1, SWIGTYPE_p_int,SWIG_POINTER_EXCEPTION | 0 )) == -1) SWIG_fail;
- testi1(arg1,arg2);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_testi2(PyObject *self, PyObject *args) {
- int **arg1 = (int **) 0 ;
- int arg2 ;
- int arg3 ;
- if(!PyArg_ParseTuple(args,(char *)"Oii:testi2",&obj0,&arg2,&arg3)) goto fail;
- if ((SWIG_ConvertPtr(obj0,(void **) &arg1, SWIGTYPE_p_p_int,SWIG_POINTER_EXCEPTION | 0 )) == -1) SWIG_fail;
- testi2(arg1,arg2,arg3);
- return resultobj;
- fail:
- return NULL;
-static PyObject *_wrap_testi3(PyObject *self, PyObject *args) {
- int ***arg1 = (int ***) 0 ;
- int arg2 ;
- int arg3 ;
- int arg4 ;
- if(!PyArg_ParseTuple(args,(char *)"Oiii:testi3",&obj0,&arg2,&arg3,&arg4)) goto fail;
- if ((SWIG_ConvertPtr(obj0,(void **) &arg1, SWIGTYPE_p_p_p_int,SWIG_POINTER_EXCEPTION | 0 )) == -1) SWIG_fail;
- testi3(arg1,arg2,arg3,arg4);
- return resultobj;
- fail:
- return NULL;
-static PyMethodDef SwigMethods[] = {
- { (char *)"getpointer1", _wrap_getpointer1, METH_VARARGS },
- { (char *)"getpointer2", _wrap_getpointer2, METH_VARARGS },
- { (char *)"getpointer3", _wrap_getpointer3, METH_VARARGS },
- { (char *)"getdpointer1", _wrap_getdpointer1, METH_VARARGS },
- { (char *)"getdpointer2", _wrap_getdpointer2, METH_VARARGS },
- { (char *)"getdpointer3", _wrap_getdpointer3, METH_VARARGS },
- { (char *)"getfpointer1", _wrap_getfpointer1, METH_VARARGS },
- { (char *)"getfpointer2", _wrap_getfpointer2, METH_VARARGS },
- { (char *)"getfpointer3", _wrap_getfpointer3, METH_VARARGS },
- { (char *)"getipointer1", _wrap_getipointer1, METH_VARARGS },
- { (char *)"getipointer2", _wrap_getipointer2, METH_VARARGS },
- { (char *)"getipointer3", _wrap_getipointer3, METH_VARARGS },
- { (char *)"test1", _wrap_test1, METH_VARARGS },
- { (char *)"test2", _wrap_test2, METH_VARARGS },
- { (char *)"test3", _wrap_test3, METH_VARARGS },
- { (char *)"testd1", _wrap_testd1, METH_VARARGS },
- { (char *)"testd2", _wrap_testd2, METH_VARARGS },
- { (char *)"testd3", _wrap_testd3, METH_VARARGS },
- { (char *)"testf1", _wrap_testf1, METH_VARARGS },
- { (char *)"testf2", _wrap_testf2, METH_VARARGS },
- { (char *)"testf3", _wrap_testf3, METH_VARARGS },
- { (char *)"testi1", _wrap_testi1, METH_VARARGS },
- { (char *)"testi2", _wrap_testi2, METH_VARARGS },
- { (char *)"testi3", _wrap_testi3, METH_VARARGS },
- { NULL, NULL }
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (BEGIN) -------- */
-static swig_type_info _swigt__p_float[] = {{"_p_float", 0, "float *", 0},{"_p_float"},{0}};
-static swig_type_info _swigt__p_p_float[] = {{"_p_p_float", 0, "float **", 0},{"_p_p_float"},{0}};
-static swig_type_info _swigt__p_p_p_float[] = {{"_p_p_p_float", 0, "float ***", 0},{"_p_p_p_float"},{0}};
-static swig_type_info _swigt__p_double[] = {{"_p_double", 0, "double *", 0},{"_p_double"},{0}};
-static swig_type_info _swigt__p_p_double[] = {{"_p_p_double", 0, "double **", 0},{"_p_p_double"},{0}};
-static swig_type_info _swigt__p_p_p_double[] = {{"_p_p_p_double", 0, "double ***", 0},{"_p_p_p_double"},{0}};
-static swig_type_info _swigt__p_int[] = {{"_p_int", 0, "int *", 0},{"_p_int"},{0}};
-static swig_type_info _swigt__p_p_int[] = {{"_p_p_int", 0, "int **", 0},{"_p_p_int"},{0}};
-static swig_type_info _swigt__p_p_p_int[] = {{"_p_p_p_int", 0, "int ***", 0},{"_p_p_p_int"},{0}};
-static swig_type_info *swig_types_initial[] = {
-_swigt__p_float,
-_swigt__p_p_float,
-_swigt__p_p_p_float,
-_swigt__p_double,
-_swigt__p_p_double,
-_swigt__p_p_p_double,
-_swigt__p_int,
-_swigt__p_p_int,
-_swigt__p_p_p_int,
-0
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (END) -------- */
-static swig_const_info swig_const_table[] = {
-{0}};
-#ifdef __cplusplus
-#endif
-#ifdef __cplusplus
-extern "C"
-#endif
-SWIGEXPORT(void) SWIG_init(void) {
- static PyObject *SWIG_globals = 0;
- static int typeinit = 0;
- PyObject *m, *d;
- int i;
- if (!SWIG_globals) SWIG_globals = SWIG_newvarlink();
- m = Py_InitModule((char *) SWIG_name, SwigMethods);
- d = PyModule_GetDict(m);
- if (!typeinit) {
- for (i = 0; swig_types_initial[i]; i++) {
- swig_types[i] = SWIG_TypeRegister(swig_types_initial[i]);
- typeinit = 1;
- SWIG_InstallConstants(d,swig_const_table);
