[GRASS-SVN] r30533 - grass-addons/tutorials/grass_starter
svn_grass at osgeo.org
Wed Mar 12 01:31:04 EDT 2008
Author: ychemin
Date: 2008-03-12 01:31:04 -0400 (Wed, 12 Mar 2008)
New Revision: 30533
Added:
grass-addons/tutorials/grass_starter/grass_rs000.png
grass-addons/tutorials/grass_starter/grass_rs001.png
grass-addons/tutorials/grass_starter/grass_rs002.png
grass-addons/tutorials/grass_starter/grass_rs003.png
grass-addons/tutorials/grass_starter/grass_rs004.png
grass-addons/tutorials/grass_starter/grass_rs005.png
grass-addons/tutorials/grass_starter/grass_rs006.png
grass-addons/tutorials/grass_starter/grass_rs007.png
grass-addons/tutorials/grass_starter/grass_rs008.png
grass-addons/tutorials/grass_starter/grass_rs009.png
grass-addons/tutorials/grass_starter/grass_rs010.png
grass-addons/tutorials/grass_starter/grass_rs011.png
grass-addons/tutorials/grass_starter/grass_rs012.png
grass-addons/tutorials/grass_starter/nviz000.png
grass-addons/tutorials/grass_starter/nviz001.png
grass-addons/tutorials/grass_starter/nviz002.png
grass-addons/tutorials/grass_starter/nviz003.png
grass-addons/tutorials/grass_starter/nviz004.png
grass-addons/tutorials/grass_starter/nviz005.png
grass-addons/tutorials/grass_starter/nviz006.png
grass-addons/tutorials/grass_starter/nviz007.png
grass-addons/tutorials/grass_starter/nviz008.png
grass-addons/tutorials/grass_starter/nviz009.png
grass-addons/tutorials/grass_starter/nviz010.png
grass-addons/tutorials/grass_starter/nviz011.png
grass-addons/tutorials/grass_starter/nviz012.png
grass-addons/tutorials/grass_starter/article_GRASS.tex
Added remote sensing and NVIZ sections
Modified: grass-addons/tutorials/grass_starter/article_GRASS.tex
--- grass-addons/tutorials/grass_starter/article_GRASS.tex 2008-03-11 22:32:12 UTC (rev 30532)
+++ grass-addons/tutorials/grass_starter/article_GRASS.tex 2008-03-12 05:31:04 UTC (rev 30533)
@@ -354,10 +354,10 @@
\label{fig:grass020}
\end{figure}
-\subsection{HABITAT PRESERVATION MISSION}
+\subsection{Habitat Preservation Mission}
The pickled strumpet (Trollopensus bibulosa) has recently been added to the Endangered Species List, and the Fish and Wildlife Service is identifying likely habitat areas in the Spearfish area for protection from development. They have constructed the following habitat scoring system based on the species observed habitat preferences:
-\subsection{HABITAT SCORING SYSTEM (from Fish and Wildlife Service) }
+\subsection{Habitat Scoring System (from Fish and Wildlife Service) }
Map number Environmental conditions Score to be given
\begin{enumerate}
@@ -375,7 +375,7 @@
Use r.buffer (..=> Create buffers) and r.mapcalc (..=> Map calculator) to create an aggregate habitat score map of the entire area, summing all the partial scores as defined above. (hint: you have to convert all null values of buffer output maps into zero values)
When finished with numbers 1 to 10 above, sum all the maps in a map that you may call scoreindivsum. Then identify suitable habitat areas by converting to zeroes all cells with overall habitat scores below 9, and all cells within 100 meters of a road (hint: you have to make a new buffer map here, and remove its null values for calculations). Make a final scoring map that you may call scorefinal and change 0 values to NULL (..=>Manage null values) for next laboratory part.
-\subsection{PROCESSING THE SCORING MAPS}
+\subsection{Process Scoring Maps}
In the processing of number 1 and 2, please use the Map Calculator with an input following an 'if statement'. The structure goes this
way:
@@ -405,7 +405,7 @@
This Set of instructions shows how GRASS GIS does the reclassification work under scripting mode. This is useful when you need to reuse the same set of GIS manipulations/models several times on different or new datasets.
-\subsection{HABITAT SCORING SCRIPT}
+\subsection{Scoring Script}
Map number Environmental conditions Score to be given:
@@ -447,48 +447,48 @@
&& aspect != 0,3,0)"
\end{smallverbatim}
-% \textbf{
-% 6) western or eastern exposure (SW to NW or SE to NE): +1 point}
-% \begin{smallverbatim}
-% r.mapcalc score61="if(aspect<45.0 || aspect>314.0,1,0)"
-% r.mapcalc score62="if(aspect<225.0 && aspect>135.0,1,0)"
-% \end{smallverbatim}
-% \textbf{
-% 7) 1200-1400 meters elevation: +2 points}
-% r.mapcalc score7="if(elevation.10m<1400
-% && elevation.10m>1200,2,0)"
-% \textbf{
-% 8) 1400-1600 meters elevation: +4 points}
-% r.mapcalc score8="if(elevation.10m<1600
-% && elevation.10m>=1400,4,0)"
-% \textbf{
-% 9) over 1600 meters elevation: +2 points}
-% r.mapcalc score9="if(elevation.10m>=1600,2,0)"
+\textbf{
+6) western or eastern exposure (SW to NW or SE to NE): +1 point}
+\begin{smallverbatim}
+r.mapcalc score61="if(aspect<45.0 || aspect>314.0,1,0)"
+r.mapcalc score62="if(aspect<225.0 && aspect>135.0,1,0)"
+\end{smallverbatim}
-\subsection{FINALIZING THE SCORING MAP}
+\textbf{
+7) 1200-1400 meters elevation: +2 points}
+r.mapcalc score7="if(elevation.10m<1400
+ && elevation.10m>1200,2,0)"
+\textbf{
+8) 1400-1600 meters elevation: +4 points}
+r.mapcalc score8="if(elevation.10m<1600
+ && elevation.10m>=1400,4,0)"
+\textbf{
+9) over 1600 meters elevation: +2 points}
+r.mapcalc score9="if(elevation.10m>=1600,2,0)"
+\subsection{Finalizing}
r.buffer input=roads output=roads100
distances=100 units=meters --overwrite
r.null map=roads100 null=0
-r.mapcalc add="float(score1+score2+score3+
+r.mapcalc score_temp="float(score1+score2+score3+
score4+score5+score61+score62+score7+
score8+score9)"
-r.mapcalc clas="if(add>9,1,null())"
+r.mapcalc score_final="if(add>9,1,null())"
-r.mapcalc class="if(clas==1&&_br100==0,1,null())"
+r.mapcalc score_final_clean="if(clas==1&&_br100==0,1,null())"
\end{smallverbatim}
%\setkeys{Gin}{width=1\textwidth}
@@ -502,7 +502,7 @@
\label{fig:grass021}
\end{figure}
-\subsection{CLUMPING SUITABLE AREAS}
+\subsection{Clumping Suitable Areas}
WARNING: This part of the Laboratory involves the use of the command line (command prompt).
What is ``clumping''?
@@ -549,7 +549,7 @@
\label{fig:grass023}
\end{figure}
-\subsection{EXPORT RESULTS TO VECTOR}
+\subsection{Export Shapefile}
Since the users work in vector GIS, we are going to convert the results in vector format and export them from GRASS GIS to shapefile.
Vectorize the clumped map you just produced (\textbf{File/Map type conversion/raster to vector}) and check that you have effectively created a polygon vector map by displaying your vector using random colors.Fig.~\ref{fig:grass024}
@@ -598,11 +598,189 @@
\section{Remote sensing}
\label{remote_sensing}
+\subsection{Import}
+\label{Import}
Download from GLCF website a satellite image of Landsat 7 ETM+ covering your country, or area of interest.
-Unzip the .tif.gz images, then import in GRASS GIS using r.in.gdal (File / import raster / multiple formats using GDAL).
+Unzip the .tif.gz images, start GRASS GIS. On opening, click on ``georeferenced file`` button.
-Identify with band number corresponds to which spectrum band, especially Red and Near-InfraRed spectra.
+%\setkeys{Gin}{width=1\textwidth}
+\begin{figure}[htbp]
+ \centering
+ %name of your graphic, without the path AND in PNG (screnshots etc)/PDF (drawings) format:
+ \includegraphics[scale=0.35]{grass_rs000.png}
+ %caption of the figure
+ \caption{Start GRASS GIS}
+ %label of the figure, which has to correspond to \ref{}:
+ \label{fig:grass_rs000}
+\end{figure}
+On launching the module, type in ''landsat`` and load your landsat image into it.
+ \centering
+ \includegraphics[scale=0.35]{grass_rs001.png}
+ \caption{Set up the new Location name}
+ \label{fig:grass_rs001}
+\end{figure}
+Once setup from georeferenced file, launch GRASS GIS from this new Location called ''landsat''.
+Identify with band number corresponding to which spectrum band, especially Red and Near-InfraRed spectra.
+Once loaded, import in GRASS GIS using r.in.gdal (File / import raster / multiple formats using GDAL).
+ \centering
+ \includegraphics[scale=0.35]{grass_rs002.png}
+ \caption{import with r.in.gdal}
+ \label{fig:grass_rs002}
+\end{figure}
+Change the coloring of the bands according to this.
+ \centering
+ \includegraphics[scale=0.35]{grass_rs003.png}
+ \caption{Change Look-up Table (histogram stretched)}
+ \label{fig:grass_rs003}
+\end{figure}
+Load a RGB combination of band 4,3,2.
+ \centering
+ \includegraphics[scale=0.35]{grass_rs004.png}
+ \caption{Load a RGB band combination}
+ \label{fig:grass_rs004}
+\end{figure}
+Display the map (histogram stretched False Color Composite)
+ \centering
+ \includegraphics[scale=0.35]{grass_rs005.png}
+ \caption{Display the RGB FCC}
+ \label{fig:grass_rs005}
+\end{figure}
+ \centering
+ \includegraphics[scale=0.35]{grass_rs006.png}
+ \caption{Change Look-up Table (non-stretched)}
+ \label{fig:grass_rs006}
+\end{figure}
+ \centering
+ \includegraphics[scale=0.35]{grass_rs007.png}
+ \caption{Display the RGB FCC (no stretching)}
+ \label{fig:grass_rs007}
+\end{figure}
+\subsection{Classification}
+\label{classification}
+Create a group and subgroup with band 1-5.
+ \centering
+ \includegraphics[scale=0.35]{grass_rs008.png}
+ \caption{Create image group and subgroup}
+ \label{fig:grass_rs008}
+\end{figure}
+Create a signature file.
+ \centering
+ \includegraphics[scale=0.35]{grass_rs009.png}
+ \caption{Create initial class statistics signature file}
+ \label{fig:grass_rs009}
+\end{figure}
+See the convergence happening...
+ \centering
+ \includegraphics[scale=0.35]{grass_rs010.png}
+ \caption{Convergence of statistics}
+ \label{fig:grass_rs010}
+\end{figure}
+Run the Maximum Likelihood clustering classification.
+ \centering
+ \includegraphics[scale=0.35]{grass_rs011.png}
+ \label{fig:grass_rs011}
+\end{figure}
+Display the result of unsupervised classification
+ \centering
+ \includegraphics[scale=0.35]{grass_rs012.png}
+ \caption{Display classification result}
+ \label{fig:grass_rs012}
+\end{figure}
+\subsection{Map Algebra}
+\label{map_algebra}
Using r.mapcalc, calculate the difference vegetation index (dvi), the Normalized dvi (ndvi) and the soil-adjusted vegetation index (savi). Then calculate some uncorrected Albedo and the temperature.
\begin{enumerate}
@@ -616,7 +794,179 @@
Observe cities, roads, irrigation canals, rivers, wetlands, agricultural lands, forests and barren areas with each and all of these images, find out what defines best each land use.
\newpage
+\section{3D Visualization}
+\label{3D_visualization}
+The N-Visualization tool in GRASS GIS takes care of 3D display of GIS data. Identify the 3 N-VIZ buttons in the GRASS GIS GUI. Click on the Left Side button. This will launch NVIZ.
+ \centering
+ \includegraphics[scale=0.35]{nviz000.png}
+ \caption{Find out the 3 NVIZ buttons}
+ \label{fig:nviz000}
+\end{figure}
+ \centering
+ \includegraphics[scale=0.2]{nviz001.png}
+ \caption{NVIZ Display}
+ \label{fig:nviz001}
+\end{figure}
+Open the Panel and detach it.
+ \centering
+ \includegraphics[scale=0.35]{nviz002.png}
+ \caption{NVIZ panel detached}
+ \label{fig:nviz002}
+\end{figure}
+Load a Raster by clicking on Raster surfaces
+ \centering
+ \includegraphics[scale=0.2]{nviz003.png}
+ \caption{Load a raster}
+ \label{fig:nviz003}
+\end{figure}
+In the Surface Panel, click on the NEW button,select NEW MAP.
+ \centering
+ \includegraphics[scale=0.2]{nviz004.png}
+ \caption{Select New Map}
+ \label{fig:nviz004}
+\end{figure}
+This will load a mapset locator, select permanent, then in the coverage browser select elevation.10m.
+ \centering
+ \includegraphics[scale=0.2]{nviz005.png}
+ \caption{Select elevation.10m}
+ \label{fig:nviz005}
+\end{figure}
+Accept for each open dialog. The raster will be loaded.
+ \centering
+ \includegraphics[scale=0.2]{nviz006.png}
+ \caption{Load elevation.10m}
+ \label{fig:nviz006}
+\end{figure}
+Close the Surface Panel and Open the Vector Panel.
+ \centering
+ \includegraphics[scale=0.2]{nviz007.png}
+ \caption{Open Vector Panel}
+ \label{fig:nviz007}
+\end{figure}
+Select NEW. This will open the mapset browser again, choose PERMANENT, select streams coverage.
+ \centering
+ \includegraphics[scale=0.2]{nviz008.png}
+ \caption{Load Streams vector layer}
+ \label{fig:nviz008}
+\end{figure}
+Accept and click the button called DRAW CURRENT.
+ \centering
+ \includegraphics[scale=0.2]{nviz009.png}
+ \caption{Draw Streams Layer}
+ \label{fig:nviz009}
+\end{figure}
+Close the vector panel and open the color panel from the main panel.
+ \centering
+ \includegraphics[scale=0.2]{nviz010.png}
+ \caption{Open color panel}
+ \label{fig:nviz010}
+\end{figure}
+Select your color and CLOSE the color panel.
+ \centering
+ \includegraphics[scale=0.2]{nviz011.png}
+ \caption{Select your color}
+ \label{fig:nviz011}
+\end{figure}
+Drag the directional ball-point to the Upper-left, closer to the center. Increase Height exaggeration to 3.0.
+ \centering
+ \includegraphics[scale=0.2]{nviz012.png}
+ \caption{Change the z-exaggeration and camera settings}
+ \label{fig:nviz012}
+\end{figure}
+\newpage
\subsection{Appendix A: Overview of Grass GUI}
\label{appendixA}
Added: grass-addons/tutorials/grass_starter/grass_rs000.png
(Binary files differ)
Property changes on: grass-addons/tutorials/grass_starter/grass_rs000.png
___________________________________________________________________
+ application/octet-stream
Added: grass-addons/tutorials/grass_starter/grass_rs001.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs001.png
Added: grass-addons/tutorials/grass_starter/grass_rs002.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs002.png
Added: grass-addons/tutorials/grass_starter/grass_rs003.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs003.png
Added: grass-addons/tutorials/grass_starter/grass_rs004.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs004.png
Added: grass-addons/tutorials/grass_starter/grass_rs005.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs005.png
Added: grass-addons/tutorials/grass_starter/grass_rs006.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs006.png
Added: grass-addons/tutorials/grass_starter/grass_rs007.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs007.png
Added: grass-addons/tutorials/grass_starter/grass_rs008.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs008.png
Added: grass-addons/tutorials/grass_starter/grass_rs009.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs009.png
Added: grass-addons/tutorials/grass_starter/grass_rs010.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs010.png
Added: grass-addons/tutorials/grass_starter/grass_rs011.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs011.png
Added: grass-addons/tutorials/grass_starter/grass_rs012.png
Property changes on: grass-addons/tutorials/grass_starter/grass_rs012.png
Added: grass-addons/tutorials/grass_starter/nviz000.png
Property changes on: grass-addons/tutorials/grass_starter/nviz000.png
Added: grass-addons/tutorials/grass_starter/nviz001.png
Property changes on: grass-addons/tutorials/grass_starter/nviz001.png
Added: grass-addons/tutorials/grass_starter/nviz002.png
Property changes on: grass-addons/tutorials/grass_starter/nviz002.png
Added: grass-addons/tutorials/grass_starter/nviz003.png
Property changes on: grass-addons/tutorials/grass_starter/nviz003.png
Added: grass-addons/tutorials/grass_starter/nviz004.png
Property changes on: grass-addons/tutorials/grass_starter/nviz004.png
Added: grass-addons/tutorials/grass_starter/nviz005.png
Property changes on: grass-addons/tutorials/grass_starter/nviz005.png
Added: grass-addons/tutorials/grass_starter/nviz006.png
Property changes on: grass-addons/tutorials/grass_starter/nviz006.png
Added: grass-addons/tutorials/grass_starter/nviz007.png
Property changes on: grass-addons/tutorials/grass_starter/nviz007.png
Added: grass-addons/tutorials/grass_starter/nviz008.png
Property changes on: grass-addons/tutorials/grass_starter/nviz008.png
Added: grass-addons/tutorials/grass_starter/nviz009.png
Property changes on: grass-addons/tutorials/grass_starter/nviz009.png
Added: grass-addons/tutorials/grass_starter/nviz010.png
Property changes on: grass-addons/tutorials/grass_starter/nviz010.png
Added: grass-addons/tutorials/grass_starter/nviz011.png
Property changes on: grass-addons/tutorials/grass_starter/nviz011.png
Added: grass-addons/tutorials/grass_starter/nviz012.png
Property changes on: grass-addons/tutorials/grass_starter/nviz012.png
