[GRASS-SVN] r30560 - in grass/trunk: lib/vector/Vlib vector/v.clean
svn_grass at osgeo.org
Fri Mar 14 06:53:44 EDT 2008
Author: martinl
Date: 2008-03-14 06:53:44 -0400 (Fri, 14 Mar 2008)
New Revision: 30560
grass/trunk/lib/vector/Vlib/remove_duplicates.c
grass/trunk/vector/v.clean/main.c
v.clean+Vlib: rmdupl works also for face and kernel feature type
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c 2008-03-14 09:47:00 UTC (rev 30559)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c 2008-03-14 10:53:44 UTC (rev 30560)
@@ -62,9 +62,12 @@
* this line and check if some of them is identical. If someone is identical
* remove current line. (In each step just one line is deleted)
- /* TODO: 3D */
ndupl = 0;
- if ( msgout ) fprintf (msgout, "%s: %5d", _("Duplicates"), ndupl );
+ if ( msgout )
+ fprintf (msgout, "%s: %5d", _("Duplicates"), ndupl );
for ( i = 1; i <= nlines; i++ ){
if ( !Vect_line_alive ( Map, i ) ) continue;
@@ -89,8 +92,11 @@
/* Forward */
forw = 1;
for ( k = 0; k < APoints->n_points; k++ ){
- if ( APoints->x[k] != BPoints->x[k] || APoints->y[k] != BPoints->y[k] ) {
- forw = 0; break;
+ if ( APoints->x[k] != BPoints->x[k] ||
+ APoints->y[k] != BPoints->y[k] ||
+ (Vect_is_3d(Map) && APoints->z[k] != BPoints->z[k])) {
+ forw = 0;
+ break;
@@ -98,8 +104,10 @@
backw = 1;
if ( APoints->x[k] != BPoints->x[npoints - k - 1] ||
- APoints->y[k] != BPoints->y[npoints - k - 1] ) {
- backw = 0; break;
+ APoints->y[k] != BPoints->y[npoints - k - 1] ||
+ (Vect_is_3d(Map) && APoints->z[k] != BPoints->z[npoints - k - 1])) {
+ backw = 0;
+ break;
@@ -126,8 +134,8 @@
ndupl++;
if ( msgout ) {
- fprintf (stderr, "\r%s: %5d", _("Duplicates"), ndupl );
- fflush ( stderr );
+ fprintf (msgout, "\r%s: %5d", _("Duplicates"), ndupl );
+ fflush (msgout);
break; /* line was deleted -> take the next one */
@@ -135,7 +143,8 @@
nlines = Vect_get_num_lines (Map); /* For future when lines with cats will be rewritten */
G_debug (3, "nlines = %d\n", nlines );
- if ( msgout ) fprintf (stderr, "\n" );
+ if ( msgout )
+ fprintf (msgout, "\n");
return;
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c 2008-03-14 09:47:00 UTC (rev 30559)
+++ grass/trunk/vector/v.clean/main.c 2008-03-14 10:53:44 UTC (rev 30560)
@@ -47,7 +47,8 @@
in_opt = G_define_standard_option(G_OPT_V_INPUT);
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
type_opt = G_define_standard_option(G_OPT_V_TYPE);
+ type_opt->options = "point,line,boundary,centroid,area,face,kernel";
err_opt = G_define_standard_option(G_OPT_V_OUTPUT);
err_opt->key = "error";
err_opt->description = _("Name of output map where errors are written");
@@ -63,7 +64,7 @@
tool_opt->description = _("Cleaning tool");
tool_opt->descriptions =
_("break;break lines at each intersection;"
- "rmdupl;remove duplicate lines (pay attention to categories!);" /* works for points too? what about other features? see lib/vector/Vlib/remove_duplicates.c */
+ "rmdupl;remove duplicate geometry features (pay attention to categories!);"
"rmdangle;remove dangles, threshold ignored if < 0;"
"chdangle;change the type of boundary dangle to line, "
"threshold ignored if < 0, input line type is ignored;"
