[GRASS-SVN] r30570 - in grass/trunk/gui/wxpython: . gui_modules
Sat Mar 15 13:35:32 EDT 2008
Author: martinl
Date: 2008-03-15 13:35:32 -0400 (Sat, 15 Mar 2008)
New Revision: 30570
   grass/trunk/gui/wxpython/gui_modules/menudata.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: menudata changed to support i18N
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py	2008-03-15 14:13:10 UTC (rev 30569)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py	2008-03-15 17:35:32 UTC (rev 30570)
@@ -2,19 +2,19 @@
 MODULE:     menudata.py
 CLASSES:
-    * Data
+* Data
 PURPOSE:    Complex list for main menu entries for GRASS wxPython GUI.
 AUTHORS:    The GRASS Development Team
-            Michael Barton (Arizona State University)
-            Yann Chemin
-            Martin Landa <landa.martin gmail.com>
+Michael Barton (Arizona State University)
+Yann Chemin
+Martin Landa <landa.martin gmail.com>
 COPYRIGHT:  (C) 2007-2008 by the GRASS Development Team
-            This program is free software under the GNU General Public
-            License (>=v2). Read the file COPYING that comes with GRASS
-            for details.
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
@@ -25,529 +25,1537 @@
     Probably could be changed to XML or *.dtd file.'''
     def GetMenu(self):
         return [(
-          ("File", (
-              ("Workspace", (
-                 ("New workspace", "Create new workspace file (erase current workspace settings first)", "self.OnWorkspaceNew", ""),
-                 ("Open existing workspace", "Open existing workspace file", "self.OnWorkspaceOpen", ""),
-                 ("Load map layers", "Load map layers into layer tree", "self.OnWorkspaceLoad", ""),
-                 ("Save workspace", "Save current workspace to file", "self.OnWorkspaceSave", ""),
-                 ("Save workspace as", "Save current workspace as file", "self.OnWorkspaceSaveAs", ""),
-                 ("Close current workspace", "Close current workspace", "self.OnWorkspaceClose", ""),
-              ("Import raster map", (
-                 ("Multiple import formats using GDAL", "Import multiple formats using GDAL", "self.OnMenuCmd", "r.in.gdal"),
-                 ("Aggregate ASCII xyz import", "Import aggregate ASCII xyz data", "self.OnMenuCmd", "r.in.xyz"),
-                 ("ASCII grid import", "Import ASCII GRID (includes GRASS ASCII)", "self.OnMenuCmd", "r.in.ascii"),
-                 ("ASCII polygons and lines import", "Import Polygons and lines from ASCII file", "self.OnMenuCmd", "r.in.poly"),
-                 ("Binary import", "Import binary file (includes GTOPO30 format)", "self.OnMenuCmd", "r.in.bin"),
-                 ("ESRI ASCII grid import", "Import ESRI Arc/Info ASCII grid", "self.OnMenuCmd", "r.in.arc"),
-                 ("GRIDATB.FOR import", "Import GRIDATB.FOR map file (TOPMODEL)", "self.OnMenuCmd", "r.in.gridatb"),
-                 ("MAT-File (v.4) import", "Import MAT-File (v.4) array (Matlab or Octave)", "self.OnMenuCmd", "r.in.mat"),
-                 ("SPOT NDVI import", "Import SPOT vegetation NDVI data sets", "self.OnMenuCmd", "r.in.spotvgt"),
-                 ("SRTM HGT import", "Import SRTM hgt files", "self.OnMenuCmd", "r.in.srtm"),
-                 ("Terra ASTER HDF import", "Import Terra ASTER HDF files", "self.OnMenuCmd", "r.in.aster"),
-                 ("WMS import", "Import Web Mapping Server", "self.OnMenuCmd", "r.in.wms"),
-              ("Import vector map", (
-                 ("Multiple import formats using OGR", "Import multiple formats using OGR", "self.OnMenuCmd", "v.in.ogr"),
-                 ("ASCII points/GRASS ASCII vector import", "Import ASCII points file or GRASS ASCII vector file", "self.OnMenuCmd", "v.in.ascii"),
-                 ("Old GRASS vector import", "Import old GRASS vector format", "self.OnMenuCmd", "v.convert"),
-                 ("DXF import", "Import DXF file", "self.OnMenuCmd", "v.in.dxf"),
-                 ("ESRI e00 import", "Import ESRI e00 file", "self.OnMenuCmd", "v.in.e00"),
-                 ("Garmin GPS import", "Import Garmin GPS Waypoints/Routes/Tracks", "self.OnMenuCmd", "v.in.garmin"),
-                 ("GPSBabel GPS import", "Import GPS Waypoints/Routes/Tracks using GPSBabel", "self.OnMenuCmd", "v.in.gpsbabel"),
-                 ("GEOnet import", "Import GEOnet Name server country files (US-NGA GNS)", "self.OnMenuCmd", "v.in.gns"),
-                 ("Matlab and MapGen import", "Import Matlab and MapGen files", "self.OnMenuCmd", "v.in.mapgen"),
-              ("Import grid 3D volume", (
-                 ("ASCII 3D import", "Import ASCII 3D file", "self.OnMenuCmd", "r3.in.ascii"),
-                 ("Vis5D import", "Import Vis5D file", "self.OnMenuCmd", "r3.in.v5d"),
-              ("Import database table", (
-                 ("Multiple import formats using OGR", "Import multiple formats using OGR", "self.OnMenuCmd", "db.in.ogr"),
-              ("Export raster map", (
-                 ("Multiple export formats using GDAL", "Export multiple formats using GDAL", "self.OnMenuCmd", "r.out.gdal"),
-                 ("ASCII grid export", "Export ASCII grid (for GRASS, Surfer, Modflow, etc)", "self.OnMenuCmd", "r.out.ascii"),
-                 ("ASCII x,y,z export", "Export ASCII x,y,z values of cell centers", "self.OnMenuCmd", "r.out.xyz"),
-                 ("ESRI ASCII grid export", "Export ESRI Arc/Info ASCII grid", "self.OnMenuCmd", "r.out.arc"),
-                 ("GRIDATB.FOR export", "Export GRIDATB.FOR map file (TOPMODEL)", "self.OnMenuCmd", "r.out.gridatb"),
-                 ("MAT-File (v.4) export", "Export MAT-File (v.4) array (Matlab or Octave)", "self.OnMenuCmd", "r.out.mat"),
-                 ("Binary export", "Export binary file", "self.OnMenuCmd", "r.out.bin"),
-                 ("MPEG-1 export", "Export MPEG-1 animations", "self.OnMenuCmd", "r.out.mpeg"),
-                 ("PNG export", "Export PNG image (not georeferenced)", "self.OnMenuCmd", "r.out.png"),
-                 ("PPM export", "Export PPM image (24bit)", "self.OnMenuCmd", "r.out.ppm"),
-                 ("PPM from RGB export", "Export PPM image from red, green, blue raster maps", "self.OnMenuCmd", "r.out.ppm3"),
-                 ("POV-Ray export", "Export POVray height-field", "self.OnMenuCmd", "r.out.pov"),
-                 ("TIFF export", "Export TIFF image (8/24bit)", "self.OnMenuCmd", "r.out.tiff"),
-                 ("VRML export", "Export VRML file", "self.OnMenuCmd", "r.out.vrml"),
-                 ("VTK export", "Export VTK ASCII file", "self.OnMenuCmd", "r.out.vtk"),
-              ("Export vector map", (
-                 ("Multiple export formats using OGR", "Export multiple formats using OGR", "self.OnMenuCmd", "v.out.ogr"),
-                 ("ASCII points/GRASS ASCII vector export", "Import ASCII points file or GRASS ASCII vector file", "self.OnMenuCmd", "v.out.ascii"),
-                 ("DXF export", "Export DXF file", "self.OnMenuCmd", "v.out.dxf"),
-                 ("POV-Ray export", "Export POV-Ray format file", "self.OnMenuCmd", "v.out.pov"),
-                 ("SVG export", "Export SVG file", "self.OnMenuCmd", "v.out.svg"),
-                 ("VTK export", "Export VTK ASCII file", "self.OnMenuCmd", "v.out.vtk"),
-              ("Export grid 3D volume", (
-                 ("ASCII 3D export", "Export ASCII 3D file", "self.OnMenuCmd", "r3.out.ascii"),
-                 ("Vis5D export", "Export Vis5D file", "self.OnMenuCmd", "r3.out.v5d"),
-                 ("VTK export", "Export VTK ASCII file", "self.OnMenuCmd", "r3.out.vtk"),
-              ("Manage maps and volumes", (
-                ("Copy", "Copy maps within mapsets or between mapsets", "self.OnMenuCmd", "g.copy"),
-                ("List", "List maps by type", "self.OnMenuCmd", "list"),
-                ("List filtered", "List maps filtered by expressions and wildcards", "self.OnMenuCmd", "g.mlist"),
-                ("Rename", "Rename maps", "self.OnMenuCmd", "g.rename"),
-                ("Delete", "Delete maps", "self.OnMenuCmd", "g.remove"),
-                ("Delete filtered", "Delete maps using expressions and wildcards", "self.OnMenuCmd", "g.mremove"),
-              ("Map type conversions", (
-                ("Raster to vector", "Convert raster to vector map", "self.OnMenuCmd", "r.to.vect"),
-                ("Raster series to volume", "Convert raster map series to volume", "self.OnMenuCmd", "r.to.rast3"),
-                ("Raster 2.5D to volume", "Convert raster 2.5D map to volume", "self.OnMenuCmd", "r.to.rast3elev"),
-                ("Vector to raster", "Convert vector to raster map", "self.OnMenuCmd", "v.to.rast"),
-                ("Vector to volume", "Convert vector 3D points to volume voxels", "self.OnMenuCmd", "v.to.rast3"),
-                ("Sites to vector", "Convert sites (GRASS 5) to vector map", "self.OnMenuCmd", "v.in.sites"),
-                ("Volume to raster series", "Convert raster to vector map", "self.OnMenuCmd", "r3.to.rast"),
-              ("Georectify", "Georectify raster and vector maps", "self.OnGeorectify", ""),
-              ("NViz (requires TclTk)", "N-Dimensional visualization of maps and volumes", "self.OnMenuCmd", "nviz"),
-              ("Bearing/distance to coordinates", "Convert between bearing/distance and coordinates", "self.OnMenuCmd", "m.cogo"),
-              ("Postscript plot", "Create cartographic PostScript plot", "self.OnMenuCmd", "ps.map"),
-              ("E&xit", "Exit from wxgui.py", "self.OnCloseWindow", ""),
-          ("Config", (
-              ("Region", (
-                ("Display region", "Display region settings", "self.RunMenuCmd", "g.region -p"),
-                ("Set region", "Change region settings", "self.OnMenuCmd", "g.region"),
-              ("GRASS working environment", (
-                ("Mapset access", "Set/unset access to other mapsets in current location", "self.OnMapsets", ""),
-                ("Change working environment", "Change current working session to new mapset, location, or data directory", "self.OnMenuCmd", "g.mapset"),
-                ("User access", "Change access by other users to current mapset", "self.OnMenuCmd", "g.access"),
-                ("Show settings", "Show current GRASS environment settings", "self.RunMenuCmd", "g.gisenv"),
-                ("Change settings", "Change GRASS environment settings", "self.OnMenuCmd", "g.gisenv"),
-                ("Version", "Show current GRASS version", "self.RunMenuCmd", "g.version -c"),
-              ("Manage projections", (
-                ("Manage projections", "Show projection information and create projection files", "self.OnMenuCmd", "g.proj"),
-                ("Projection for current location", "Create/edit projection information for current location", "self.OnXTerm", "g.setproj"),
-                ("Convert coordinates", "Convert coordinates from one projection to another", "self.OnMenuCmd", "m.proj"),
-              ("Preferences", "User preferences (display font, etc.)", "self.OnPreferences", ""),
-          ("Raster", (
-              ("Develop map", (
-                ("Digitize raster (requires XTerm)", "Digitize new raster map", "self.OnXTerm", "r.digit"),
-                ("Compress/decompress", "Compress/decompress raster file", "self.OnMenuCmd", "r.compress"),
-                ("Boundaries", "Manage boundary definition", "self.OnMenuCmd", "r.region"),
-                ("Manage NULL values", "Manage NULL values", "self.OnMenuCmd", "r.null"),
-                ("Quantization", "Quantization for floating-point maps", "self.OnMenuCmd", "r.quant"),
-                ("Timestamp", "Manage timestamp for files", "self.OnMenuCmd", "r.timestamp"),
-                ("Resample using aggregate statistics", "Resample (change resolution) using aggregate statistics", "self.OnMenuCmd", "r.resamp.stats"),
-                ("Resample using multiple methods", "Resample (change resolution) using nearest neighbor, bilinear, or bicubic interpolation", "self.OnMenuCmd", "r.resamp.interp"),
-                ("Resample using nearest neighbor", "Resample (change resolution) using nearest neighbor interpolation", "self.OnMenuCmd", "r.resample"),
-                ("Resample using spline tension", "Resample (change resolution) using regularized spline tension", "self.OnMenuCmd", "r.resamp.rst"),
-                ("Support file maintenance", "Support file creation and maintenance", "self.OnMenuCmd", "r.support"),
-                ("Update map statistics", "Update map statistics", "self.OnMenuCmd", "r.support.stats"),
-                ("Reproject raster", "Reproject raster from other location", "self.OnMenuCmd", "r.proj"),
-                ("Tiling", "Generate tiling for other projection", "self.OnMenuCmd", "r.tileset"),
-              ("Manage map colors", (
-                ("Color tables", "Set colors to predefined color tables", "self.OnMenuCmd", "r.colors"),
-                ("Color rules", "Set colors interactively by entering color rules", "self.RulesCmd", "r.colors"),
-                ("Blend 2 color maps", "Blend 2 color maps to produce 3 RGB files", "self.OnMenuCmd", "r.blend"),
-                ("Create RGB", "Create color image from RGB files", "self.OnMenuCmd", "r.composite"),
-                ("RGB to HIS", "Create 3 RGB (red, green, blue) maps from 3 HIS (hue, intensity, saturation) maps", "self.OnMenuCmd", "r.his"),
-              ("Query by coordinates", "Query by coordinates", "self.OnMenuCmd", "r.what"),
-              ("Buffer rasters", "Create raster buffers around raster objects", "self.OnMenuCmd", "r.buffer"),
-              ("Closest points", "r.distance", "self.OnMenuCmd", "r.distance"),
-              ("MASK", "Develop raster mask", "self.OnMenuCmd", "r.mask"),
-              ("Map calculator", "Map calculator for map algebra", "self.DispMapCalculator", ""),
-              ("Neighborhood analysis", (
-                ("Moving window", "Moving window analysis of raster cells", "self.OnMenuCmd", "r.neighbors"),
-                ("Neighborhood points", "Analyze vector points in neighborhood of raster cells", "self.OnMenuCmd", "v.neighbors"),
-              ("Overlay maps", (
-                ("Cross product", "Cross product", "self.OnMenuCmd", "r.cross"),
-                ("Map series", "Function of map series (time series)", "self.OnMenuCmd", "r.series"),
-                ("Patch raster maps", "Patch maps", "self.OnMenuCmd", "r.patch"),
-                ("Statistical overlay", "Statistical calculations for cover map over base map", "self.OnMenuCmd", "r.statistics"),
-              ("Solar radiance and shadows", (
-                ("Solar irradiance and irradiation", "Solar irradiance and daily irradiation", "self.OnMenuCmd", "r.sun"),
-                ("Shadows map", "Shadows map for sun position or date/time", "self.OnMenuCmd", "r.sunmask"),
-              ("Terrain analysis", (
-                ("Cumulative movement costs", "Calculate cumulative movement costs between locales", "self.OnMenuCmd", "r.walk"),
-                ("Cost surface", "cost surface", "self.OnMenuCmd", "r.cost"),
-                ("Least cost route or flow", "Least cost route or flow", "self.OnMenuCmd", "r.drain"),
-                ("Shaded relief", "Shaded relief map", "self.OnMenuCmd", "r.shaded.relief"),
-                ("Slope and aspect", "Slope and aspect", "self.OnMenuCmd", "r.slope.aspect"),
-                ("Terrain parameters", "Terrain parameters", "self.OnMenuCmd", "r.param.scale"),
-                ("Textural features", "Textural features", "self.OnMenuCmd", "r.texture"),
-                ("Visibility", "Visibility and line of sight", "self.OnMenuCmd", "r.los"),
-              ("Transform features", (
-                ("Clump", "Clump small areas (statistics calculated by r.volume)", "self.OnMenuCmd", "r.clump"),
-                ("Grow", "Grow areas", "self.OnMenuCmd", "r.grow"),
-                ("Thin", "Thin linear features", "self.OnMenuCmd", "r.thin"),
-              ("Hydrologic modeling", (
-                ("Carve stream channels", "Carve stream channels into elevation map using vector streams map", "self.OnMenuCmd", "r.carve"),
-                ("Fill lake", "Fill lake from seed point to specified level", "self.OnMenuCmd", "r.lake"),
-                ("Depressionless map and flowlines", "Depressionless elevation map and flowline map", "self.OnMenuCmd", "r.fill.dir"),
-                ("Flow accumulation", "Flow accumulation for massive grids", "self.OnMenuCmd", "r.terraflow"),
-                ("Flow lines", "Generate flow lines for raster map", "self.OnMenuCmd", "r.flow"),
-                ("SIMWE Overland flow modeling", "SIMWE overland flow modeling", "self.OnMenuCmd", "r.sim.water"),
-                ("SIMWE Sediment flux modeling", "SIMWE sediment erosion, transport, deposition modeling", "self.OnMenuCmd", "r.sim.sediment"),
-                ("Topographic index map", "Topographic index map", "self.OnMenuCmd", "r.topidx"),
-                ("TOPMODEL simulation", "TOPMODEL simulation", "self.OnMenuCmd", "r.topmodel"),
-                ("Watershed subbasins", "Watershed subbasins", "self.OnMenuCmd", "r.basins.fill"),
-                ("Watershed analysis", "Watershed analysis", "self.OnMenuCmd", "r.watershed"),
-                ("Watershed basin creation", "Watershed basin creation", "self.OnMenuCmd", "r.water.outlet"),
-              ("Landscape structure modeling", (
-                ("Set up (requires XTerm)", "Set up sampling and analysis framework", "self.OnXTerm", "r.le.setup"),
-                ("Analyze landscape", "Analyze landscape characteristics", "self.OnMenuCmd", "r.le.pixel"),
-                ("Analyze patches", "Analyze landscape patch characteristics", "self.OnMenuCmd", "r.le.patch"),
-                ("Output", "Output landscape patch information", "self.OnMenuCmd", "r.le.trace"),
-              ("Landscape patch analysis", (
-                ("Set up sampling and analysis framework", "Configure and create patch map for analysis", "self.OnMenuCmd", "r.li.setup"),
-                ("Edge density", "Calculate edge density index using a 4 neighbour algorithm", "self.OnMenuCmd", "r.li.edgedensity"),
-                ("Contrast weighted edge density", "Calculate contrast weighted edge density index", "self.OnMenuCmd", "r.li.cwed"),
-                ("Patch area mean", "Calculate mean patch size index using a 4 neighbour algorithm", "self.OnMenuCmd", "r.li.mps"),
-                ("Patch area range", "Calculate range of patch area size", "self.OnMenuCmd", "r.li.padrange"),
-                ("Patch area Std Dev", "Calculate standard deviation of patch area", "self.OnMenuCmd", "r.li.padsd"),
-                ("Patch area Coeff Var", "Calculate coefficient of variation of patch area", "self.OnMenuCmd", "r.li.padcv"),
-                ("Patch density", "Calculate patch density index using a 4 neighbour algorithm", "self.OnMenuCmd", "r.li.patchdensity"),
-                ("Patch number", "Calculate patch number index using a 4 neighbour algorithm", "self.OnMenuCmd", "r.li.patchnum"),
-                ("Dominance's diversity", "Calculate Dominance's diversity index", "self.OnMenuCmd", "r.li.dominance"),
-                ("Shannon's diversity", "Calculate Shannon's diversity index", "self.OnMenuCmd", "r.li.shannon"),
-                ("Simpson's diversity", "Calculate Simpson's diversity index", "self.OnMenuCmd", "r.li.simpson"),
-                ("Richness", "Calculate richness index", "self.OnMenuCmd", "r.li.richness"),
-                ("Shape index", "Calculate shape index", "self.OnMenuCmd", "r.li.shape"),
-              ("Wildfire modeling", (
-                ("Rate of spread", "Generate rate of spread (ROS) maps", "self.OnMenuCmd", "r.ros"),
-                ("Least-cost spread paths", "Generate least-cost spread paths", "self.OnMenuCmd", "r.spreadpath"),
-                ("Anisotropic spread simulation", "Simulate anisotropic spread phenomena", "self.OnMenuCmd", "r.spread"),
-              ("Change category values and labels", (
-                ("Interactively edit category values", "Edit category values of individual cells for displayed raster map", "self.OnMenuCmd", "d.rast.edit"),
-                ("Reclassify by size", "Reclassify categories for areas of specified sizes", "self.OnMenuCmd", "r.reclass.area"),
-                ("Reclassify interactively", "Reclassify categories interactively by entering reclass rules", "self.RulesCmd", "r.reclass"),
-                ("Reclassify using rules file", "Reclassify categories by inputting reclass rules from a text file", "self.OnMenuCmd", "r.reclass"),
-                ("Recode interactively", "Recode categories interactively by entering recode rules (create new map)", "self.RulesCmd", "r.recode"),
-                ("Recode using rules file", "Recode categories by inputting recode rules from a text file (create new map)", "self.OnMenuCmd", "r.recode.file"),
-                ("Rescale", "Rescale categories (create new map)", "self.OnMenuCmd", "r.rescale"),
-                ("Rescale with histogram", "Rescale categories with equalized histogram (create new map)", "self.OnMenuCmd", "r.rescale.eq"),
-              ("Concentric circles", "Generate concentric circles around points", "self.OnMenuCmd", "r.circle"),
-              ("Generate random cells", (
-                ("Random cells", "Generate random cells", "self.OnMenuCmd", "r.random.cells"),
-                ("Random cells and vector points ", "Generate random cells and vector points from raster map", "self.OnMenuCmd", "r.random"),
-              ("Generate surfaces", (
-                ("Fractal surface", "Generate fractal surface", "self.OnMenuCmd", "r.surf.fractal"),
-                ("Gaussian kernel density surface", "Generate density surface using moving Gaussian kernel", "self.OnMenuCmd", "v.kernel"),
-                ("Gaussian deviates surface", "Generate gaussian deviates surface", "self.OnMenuCmd", "r.surf.gauss"),
-                ("Plane", "Generate plane", "self.OnMenuCmd", "r.plane"),
-                ("Random deviates surface", "Generate random deviates surface", "self.OnMenuCmd", "r.surf.random"),
-                ("Random surface with spatial dependence", "Generate random surface with spatial dependence", "self.OnMenuCmd", "r.random.surface"),
-              ("Generate contour lines", "Generate vector contour lines", "self.OnMenuCmd", "r.contour"),
-              ("Interpolate surfaces", (
-                ("Bilinear from raster points", "Bilinear interpolation from raster points", "self.OnMenuCmd", "r.bilinear"),
-                ("Bilinear and bicubic from vector points", "Bicubic and bilinear interpolation with Tykhonov regularization from vector points", "self.OnMenuCmd", "v.surf.bspline"),
-                ("IDW from raster points", "Inverse distance weighted interpolation from raster points", "self.OnMenuCmd", "r.surf.idw"),
-                ("IDW from vector points", "Inverse distance weighted interpolation from vector points", "self.OnMenuCmd", "v.surf.idw"),
-                ("Raster contours", "Interpolation from raster contour", "self.OnMenuCmd", "r.surf.contour"),
-                ("Regularized spline tension ", "Regularized spline tension interpolation from vector points or contours", "self.OnMenuCmd", "v.surf.rst"),
-                ("Fill NULL cells", "Fill NULL cells by interpolation using regularized spline tension", "self.OnMenuCmd", "r.fillnulls"),
-              ("Report and statistics", (
-                ("Basic raster information", "Report basic file information", "self.OnMenuCmd", "r.info"),
-                ("Manage category information", "Manage category labels and values", "self.OnMenuCmd", "r.category"),
-                ("General statistics", "General statistics", "self.OnMenuCmd", "r.stats"),
-                ("Range of category values", "Range of all category values", "self.OnMenuCmd", "r.describe"),
-                ("Sum cell category values", "Sum all cell category values", "self.OnMenuCmd", "r.sum"),
-                ("Sum area by map and category", "Sum area by map and category", "self.OnMenuCmd", "r.report"),
-                ("Statistics for clumped cells", "Summary statistics for clumped cells (work with r.clump)", "self.OnMenuCmd", "r.volume"),
-                ("Total corrected area", "Total surface area corrected for topography", "self.OnMenuCmd", "r.surf.area"),
-                ("Univariate raster statistics", "Calculate univariate statistics for raster categories", "self.OnMenuCmd", "r.univar"),
-                ("Sample transects", "Sample values along transects", "self.OnMenuCmd", "r.profile"),
-                ("Sample transects (bearing/distance)", "Sample values along transects (use azimuth, distance)", "self.OnMenuCmd", "r.transect"),
-                ("Covariance/correlation", "Covariance/correlation", "self.OnMenuCmd", "r.covar"),
-                ("Linear regression", "Linear regression between 2 maps", "self.OnMenuCmd", "r.regression.line"),
-                ("Mutual category occurrences", "Mutual category occurrences (coincidence)", "self.OnMenuCmd", "r.coin"),
-          ("Vector", (
-              ("Develop vector map", (
-                ("Create empty vector map", "Create new empty vector map", "self.OnMenuCmd", "v.edit tool=create"),
-#                ("Digitize vector map", "Digitize/edit vector map", "self.OnMenuCmd", "v.digit"),
-                ("Create/rebuild topology", "Create or rebuild topology of vector objects", "self.OnMenuCmd", "v.build"),
-                ("Clean vector map", "Clean vector objects", "self.OnMenuCmd", "v.clean"),
-                ("Generalization", "Smooth, simplify, displace, or generalize a vector map", "self.OnMenuCmd", "v.generalize"),
-                ("Convert object types", "Convert vector objects from one feature type to another", "self.OnMenuCmd", "v.type.sh"),
-                ("Add centroids", "Add centroids to closed boundaries to create areas", "self.OnMenuCmd", "v.centroids"),
-                ("Build polylines", "Build polylines from adjacent segments", "self.OnMenuCmd", "v.build.polylines"),
-                ("Split polylines", "Split polylines into points and segments", "self.OnMenuCmd", "v.segment"),
-                ("Parallel lines", "Create lines parallel to existing lines", "self.OnMenuCmd", "v.parallel"),
-                ("Dissolve boundaries", "Dissolve common boundaries of areas", "self.OnMenuCmd", "v.dissolve"),
-                ("Create 3D vector map over raster", "Create 3D objects by sampling raster with 2D vector", "self.OnMenuCmd", "v.drape"),
-                ("Extrude 3D vector map", "Extrude 3D objects from 2D vector", "self.OnMenuCmd", "v.extrude"),
-                ("Link to OGR", "Create new vector as link to external OGR layer", "self.OnMenuCmd", "v.external"),
-                ("Create labels", "Create text label file for vector features", "self.OnMenuCmd", "v.label"),
-                ("Reposition vector map", "Reposition (shift, rotate, skew) vector file in coordinate space", "self.OnMenuCmd", "v.transform"),
-                ("Reproject vector map", "Reproject vector from other location", "self.OnMenuCmd", "v.proj"),
-              ("Query with attributes", "Query vector objects by attribute values", "self.OnMenuCmd", "v.extract"),
-              ("Query with coordinate(s)", "Query vector objects by coordinate(s)", "self.OnMenuCmd", "v.what"),
-              ("Query with another vector map", "Query objects using objects from a second map", "self.OnMenuCmd", "v.select"),
-              ("Buffer vectors", "Create vector buffers around vector objects", "self.OnMenuCmd", "v.buffer"),
-              ("Lidar analysis", (
-                ("Detect edges", "Detect object edges in Lidar data", "self.OnMenuCmd", "v.lidar.edgedetection"),
-                ("Detect interiors", "Detect interiors of objects in Lidar data", "self.OnMenuCmd", "v.lidar.growing"),
-                ("Correct and reclassify objects", "Correct and reclassify objects detected in Lidar data", "self.OnMenuCmd", "v.lidar.correction"),
-              ("Linear referencing", (
-                ("Create LRS", "Create linear reference system", "self.OnMenuCmd", "v.lrs.create"),
-                ("Create stationing", "Create stationing from input lines, and linear reference system", "self.OnMenuCmd", "v.lrs.label"),
-                ("Create points/segments", "Create points/segments from input lines, linear reference system and positions read from stdin", "self.OnMenuCmd", "v.lrs.segment"),
-                ("Find line id and offset", "Find line id and real km+offset for given points in vector map using linear reference system", "self.OnMenuCmd", "v.lrs.where"),
-              ("Nearest features", "Locate nearest feature to points or centroids", "self.OnMenuCmd", "v.distance"),
-              ("Network analysis", (
-                ("Allocate subnets", "Allocate subnets for nearest centers", "self.OnMenuCmd", "v.net.alloc"),
-                ("Network maintenance", "Network maintenance", "self.OnMenuCmd", "v.net"),
-                ("Visibility network", "Create and maintain a visibility network", "self.OnMenuCmd", "v.net.visibility"),
-                ("Shortest route", "Calculate shortest route along network between 2 nodes", "self.OnMenuCmd", "v.net.path"),
-                ("Display shortest route (requires XTerm)", " Display shortest route along network between 2 nodes (visualization only)", "self.OnXTerm", "d.path"),
-                ("Split net", "Split net into bands between cost isolines", "self.OnMenuCmd", "v.net.iso"),
-                ("Steiner tree", "Create Steiner tree for network and given terminals", "self.OnMenuCmd", "v.net.steiner"),
-                ("Traveling salesman analysis", "Calculate shortest route connecting given set of nodes (Traveling salesman analysis)", "self.OnMenuCmd", "v.net.salesman"),
-              ("Overlay vector maps", (
-                ("Overlay vector maps", "Boolean overlay of 2 vector maps", "self.OnMenuCmd", "v.overlay"),
-                ("Patch vector maps", "Patch/combine multiple maps (Boolean OR)", "self.OnMenuCmd", "v.patch"),
-              ("Change attributes", (
-                ("Manage or report categories", "Attach/delete, or report categories", "self.OnMenuCmd", "v.category"),
-                ("Reclassify objects interactively", "Reclassify vector objects interactively by entering SQL rules", "self.RulesCmd", "v.reclass"),
-                ("Reclassify objects using rules file", "Reclassify vector objects by inputting SQL rules from a text file", "self.OnMenuCmd", "v.reclass"),
-              ("Generate area for current region", "Generate area object for extent of current region", "self.OnMenuCmd", "v.in.region"),
-              ("Generate areas from points", (
-                  ("Convex hull", "Generate convex hull for point set", "self.OnMenuCmd", "v.hull"),
-                  ("Delaunay triangles", "Generate Delaunay triangles for point set", "self.OnMenuCmd", "v.delaunay"),
-                  ("Voronoi diagram/Thiessen polygons", "Generate Voronoi diagram/Thiessen polygons for point set", "self.OnMenuCmd", "v.voronoi"),
-              ("Generate grid", "Generate rectangular vector grid", "self.OnMenuCmd", "v.mkgrid"),
-              ("Generate points", (
-                  ("Generate from database", "Generate points from database with x/y coordinates", "self.OnMenuCmd", "v.in.db"),
-                  ("Generate points along lines", "Generate points along vector lines/boundaries", "self.OnMenuCmd", "v.to.points"),
-                  ("Generate random points", "Generate random points", "self.OnMenuCmd", "v.random"),
-                  ("Perturb points", "Random perturbations of point locations", "self.OnMenuCmd", "v.perturb"),
-              ("Remove outliers in point sets", "Remove outliers from vector point set", "self.OnMenuCmd", "v.outlier"),
-              ("Test/training point sets", "Partition points into test/training sets for k-fold cross validation", "self.OnMenuCmd", "v.kcv"),
-              ("Update area attributes from raster", "Update area attribute data from univariate statistics on raster map", "self.OnMenuCmd", "v.rast.stats"),
-              ("Update point attributes from areas", "Update point attribute data from vector area map", "self.OnMenuCmd", "v.what.vect"),
-              ("Update point attributes from raster", (
-                  ("Sample raster maps at point locations", "Sample raster maps at point locations", "self.OnMenuCmd", "v.what.rast"),
-                  ("Sample raster neighborhood around points", "Sample raster neighborhood around points", "self.OnMenuCmd", "v.sample"),
-              ("Reports and statistics", (
-                ("Basic vector information", "Basic vector information", "self.OnMenuCmd", "v.info"),
-                ("Report topology by category", "Report areas for vector attribute categories", "self.OnMenuCmd", "v.report"),
-                ("Upload or report topology", "Update database fields or create reports from vector topology", "self.OnMenuCmd", "v.to.db"),
-                ("Univariate attribute statistics", "Calculate univariate statistics for vector attributes", "self.OnMenuCmd", "v.univar"),
-                ("Quadrat indices", "Indices of point counts in quadrats", "self.OnMenuCmd", "v.qcount"),
-                ("Test normality", "Test normality of point distribution", "self.OnMenuCmd", "v.normal"),
-          ("Imagery", (
-              ("Develop images and groups", (
-                ("Create/edit group", "Create/edit imagery group", "self.OnMenuCmd", "i.group"),
-                ("Target group", "Target imagery group", "self.OnMenuCmd", "i.target"),
-                ("Mosaic images", "Mosaic up to 4 adjacent images", "self.OnMenuCmd", "i.image.mosaic"),
-              ("Manage image colors", (
-                ("Color balance for RGB", "Color balance and enhance color tables of multiband imagery for rgb display", "self.OnMenuCmd", "i.landsat.rgb"),
-                ("HIS to RGB", "Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)", "self.OnMenuCmd", "i.his.rgb"),
-                ("RGB to HIS", "Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)", "self.OnMenuCmd", "i.rgb.his"),
-              ("Rectify image or raster", "Rectifies raster using information in previously created POINTS file", "self.OnMenuCmd", "i.rectify"),
-              ("Ortho photo rectification (requires Xterm)", "Ortho Photo rectification", "self.OnXTerm", "i.ortho.photo"),
-              ("Brovey sharpening", "Brovey transformation and pan sharpening", "self.OnMenuCmd", "i.fusion.brovey"),
-              ("Classify image", (
-                ("Clustering input for unsupervised classification", "Clustering input for unsupervised classification", "self.OnMenuCmd", "i.cluster"),
-                ("Maximum likelihood classification (MLC)", "Maximum likelihood Classification", "self.OnMenuCmd", "i.maxlik"),
-                ("Sequential maximum a posteriori classification (SMAP)", "Sequential maximum a posteriori classification (SMAP)", "self.OnMenuCmd", "i.smap"),
-                ("Interactive input for supervised classification (requires Xterm)", "Interactive input for supervised classification", "self.OnXTerm", "i.class"),
-                ("Input for supervised MLC", "Non-interactive input for supervised classification (MLC)", "self.OnMenuCmd", "i.gensig"),
-                ("Input for supervised SMAP", "Non-interactive input for supervised classification (SMAP)", "self.OnMenuCmd", "i.gensigset"),
-              ("Filter image", (
-                ("Edge detection", "Zero edge crossing detection", "self.OnMenuCmd", "i.zc"),
-                ("Matrix/convolving filter", "User defined matrix/convolving filter", "self.OnMenuCmd", "r.mfilter"),
-              ("Histogram image", "Histogram image", "self.DispHistogram", ""),
-              ("Spectral response", "Spectral response", "self.OnMenuCmd", "i.spectral"),
-              ("Tasseled cap vegetation index", "Tasseled cap vegetation index", "self.OnMenuCmd", "i.tasscap"),
-              ("Transform image", (
-                ("Canonical correlation", "Canonical correlation (discriminant analysis)", "self.OnMenuCmd", "i.cca"),
-                ("Principal components", "Principal components analysis", "self.OnMenuCmd", "i.pca"),
-                ("Fast Fourier", "Fast Fourier Transform", "self.OnMenuCmd", "i.fft"),
-                ("Inverse Fast Fourier", "Inverse Fast Fourier Transform", "self.OnMenuCmd", "i.ifft"),
-                ("Bit pattern comparison ", "Bit pattern comparison for ID of low quality pixels", "self.OnMenuCmd", "r.bitpattern"),
-                ("Kappa analysis", "Kappa classification accuracy assessment", "self.OnMenuCmd", "r.kappa"),
-                ("OIF for LandSat TM", "Optimum index factor for LandSat TM", "self.OnMenuCmd", "i.oif"),
-          ("Volumes", (
-              ("Develop grid3D volumes", (
-                ("Manage 3d NULL values", "Manage NULL values for grid3D volume", "self.OnMenuCmd", "r3.null"),
-                ("Manage timestamp", "Manage timestamp for grid3D volume", "self.OnMenuCmd", "r3.timestamp"),
-              ("3D MASK", "Create 3D mask for grid3D operations", "self.OnMenuCmd", "r3.mask"),
-              ("3D map calculator", "Map calculator for volumetric map algebra", "self.Disp3DMapCalculator", ""),
-              ("Cross section", "Create 2D raster cross section from grid3d volume", "self.OnMenuCmd", "r3.cross.rast"),
-              ("Interpolate volume from points", "Interpolate volume from vector points using splines", "self.OnMenuCmd", "v.vol.rst"),
-              ("Report and Statistics", (
-                ("Basic volume information", "Report basic information about grid3D volume", "self.OnMenuCmd", "r3.info"),
-          ("Database", (
-              ("Database information", (
-                ("Describe table", "Describe table structure and attributes", "self.OnMenuCmd", "db.describe"),
-                ("List columns", "List columns for selected table", "self.OnMenuCmd", "db.columns"),
-                ("List drivers", "List available database drivers", "self.OnMenuCmd", "db.drivers"),
-                ("List tables", "List tables in database", "self.OnMenuCmd", "db.tables"),
-              ("Manage databases", (
-                ("Connect", "Connect to database", "self.OnMenuCmd", "db.connect"),
-                ("Login", "Login to database", "self.OnMenuCmd", "db.login"),
-                ("Copy table", "Copy attribute table", "self.OnMenuCmd", "db.copy"),
-                ("New table", "Create and connect new attribute table to vector map", "self.OnMenuCmd", "v.db.addtable"),
-                ("Remove table", "Remove existing attribute table for vector map", "self.OnMenuCmd", "db.login"),
-                ("Add columns", "Add columns to table", "self.OnMenuCmd", "v.db.addcol"),
-                ("Change values", "Change values in a column", "self.OnMenuCmd", "v.db.update"),
-                ("Rename column", "Rename a column", "self.OnMenuCmd", "v.db.renamecol"),
-                ("Test", "Test database", "self.OnMenuCmd", "db.test"),
-              ("Query", (
-                ("Query any table", "Query data in any table", "self.OnMenuCmd", "db.select"),
-                ("Query vector attribute table", "Query vector attribute data", "self.OnMenuCmd", "v.db.select"),
-                ("SQL statement", "Execute SQL statement", "self.OnMenuCmd", "db.execute"),
-              ("Vector<->database connections", (
-                ("Reconnect vector to database", "Reconnect vector map to attribute database", "self.OnMenuCmd", "v.db.reconnect.all"),
-                ("Set vector - database connection", "Set database connection for vector attributes", "self.OnMenuCmd", "v.db.connect"),
-          ("Help", (
-              ("GRASS GIS help", "GRASS GIS Reference Manual", "self.RunMenuCmd", "g.manual -i"),
-              ("GRASS GIS GUI help", "GUI-related Reference Manual", "self.RunMenuCmd", "g.manual wxGUI"),
-              ("About GRASS GIS", "About GRASS GIS", "self.OnAboutGRASS", ""),
+                (_("File"), (
+                        (_("Workspace"), (
+                                (_("New workspace"),
+                                 _("Create new workspace file (erase current workspace settings first)"),
+                                 "self.OnWorkspaceNew",
+                                (_("Open existing workspace"),
+                                 _("Open existing workspace file"),
+                                 "self.OnWorkspaceOpen",
+                                (_("Load map layers"),
+                                 _("Load map layers into layer tree"),
+                                 "self.OnWorkspaceLoad",
+                                (_("Save workspace"),
+                                 _("Save current workspace to file"),
+                                 "self.OnWorkspaceSave",
+                                (_("Save workspace as"),
+                                 _("Save current workspace as file"),
+                                 "self.OnWorkspaceSaveAs",
+                                (_("Close current workspace"),
+                                 _("Close current workspace file"),
+                                 "self.OnWorkspaceClose",
+                        (_("Import raster map"), (
+                                (_("Multiple import formats using GDAL"),
+                                 _("Import file in format supported by GDAL"),
+                                 "self.OnMenuCmd",
+                                 "r.in.gdal"),
+                                (_("Aggregate ASCII xyz import"),
+                                 _("Import aggregated ASCII xyz data"),
+                                 "self.OnMenuCmd",
+                                 "r.in.xyz"),
+                                (_("ASCII grid import"),
+                                 _("Import ASCII GRID (includes GRASS ASCII)"),
+                                 "self.OnMenuCmd",
+                                 "r.in.ascii"),
+                                (_("ASCII polygons and lines import"),
+                                 _("Import polygons and lines from ASCII file"),
+                                 "self.OnMenuCmd",
+                                 "r.in.poly"),
+                                (_("Binary file import"),
+                                 _("Import binary file (includes GTOPO30 format)"),
+                                 "self.OnMenuCmd",
+                                 "r.in.bin"),
+                                (_("ESRI ASCII grid import"),
+                                 _("Import ESRI Arc/Info ASCII grid"),
+                                 "self.OnMenuCmd",
+                                 "r.in.arc"),
+                                (_("GRIDATB.FOR import"),
+                                 _("Import GRIDATB.FOR map file (TOPMODEL)"),
+                                 "self.OnMenuCmd",
+                                 "r.in.gridatb"),
+                                (_("MAT-File (v.4) import"),
+                                 _("Import MAT-File (v.4) array (Matlab or Octave)"),
+                                 "self.OnMenuCmd",
+                                 "r.in.mat"),
+                                (_("SPOT NDVI import"),
+                                 _("Import SPOT vegetation NDVI data sets"),
+                                 "self.OnMenuCmd",
+                                 "r.in.spotvgt"),
+                                (_("SRTM HGT import"),
+                                 _("Import SRTM HGT files"),
+                                 "self.OnMenuCmd", "r.in.srtm"),
+                                (_("Terra ASTER HDF import"),
+                                 _("Import Terra ASTER HDF files"),
+                                 "self.OnMenuCmd",
+                                 "r.in.aster"),
+                                (_("WMS import"),
+                                 _("Import Web Mapping Server layer"),
+                                 "self.OnMenuCmd",
+                                 "r.in.wms"),
+                        (_("Import vector map"), (
+                                (_("Multiple import formats using OGR"),
+                                 _("Import file in format supported by OGR (e.g. Shapefile)"),
+                                 "self.OnMenuCmd",
+                                 "v.in.ogr"),
+                                (_("ASCII points/GRASS ASCII vector import"),
+                                 _("Import ASCII points file or GRASS ASCII vector file"),
+                                 "self.OnMenuCmd",
+                                 "v.in.ascii"),
+                                (_("Old GRASS vector import"),
+                                 _("Import file in old GRASS vector format"),
+                                 "self.OnMenuCmd",
+                                 "v.convert"),
+                                (_("DXF import"),
+                                 _("Import DXF file"),
+                                 "self.OnMenuCmd",
+                                 "v.in.dxf"),
+                                (_("ESRI e00 import"),
+                                 _("Import ESRI e00 file"),
+                                 "self.OnMenuCmd",
+                                 "v.in.e00"),
+                                (_("Garmin GPS import"),
+                                 _("Import Garmin GPS Waypoints/Routes/Tracks"),
+                                 "self.OnMenuCmd",
+                                 "v.in.garmin"),
+                                (_("GPSBabel GPS import"),
+                                 _("Import GPS Waypoints/Routes/Tracks using GPSBabel"),
+                                 "self.OnMenuCmd",
+                                 "v.in.gpsbabel"),
+                                (_("GEOnet import"),
+                                 _("Import GEOnet Name server country files (US-NGA GNS)"),
+                                 "self.OnMenuCmd",
+                                 "v.in.gns"),
+                                (_("Matlab and MapGen import"),
+                                 _("Import Matlab and MapGen files"),
+                                 "self.OnMenuCmd",
+                                 "v.in.mapgen"),
+                        (_("Import grid 3D volume"), (
+                                (_("ASCII 3D import"),
+                                 _("Import ASCII Raster 3D file"),
+                                 "self.OnMenuCmd",
+                                 "r3.in.ascii"),
+                                (_("Vis5D import"),
+                                 _("Import Vis5D file"),
+                                 "self.OnMenuCmd",
+                                 "r3.in.v5d"),
+                        (_("Import database table"), (
+                                 _("Import database file in format supported by OGR"),
+                                 "self.OnMenuCmd",
+                                 "db.in.ogr"),
+                        (_("Export raster map"), (
+                                (_("Multiple export formats using GDAL"),
+                                 _("Export raster map to format supported by GDAL"),
+                                 "self.OnMenuCmd",
+                                 "r.out.gdal"),
+                                (_("ASCII grid export"),
+                                 _("Export ASCII grid (for GRASS, Surfer, Modflow, etc.)"),
+                                 "self.OnMenuCmd",
+                                 "r.out.ascii"),
+                                (_("ASCII x,y,z export"),
+                                 _("Export ASCII x,y,z values of cell centers"),
+                                 "self.OnMenuCmd",
+                                 "r.out.xyz"),
+                                (_("ESRI ASCII grid export"),
+                                 _("Export ESRI Arc/Info ASCII grid"),
+                                 "self.OnMenuCmd",
+                                 "r.out.arc"),
+                                (_("GRIDATB.FOR export"),
+                                 _("Export GRIDATB.FOR map file (TOPMODEL)"),
+                                 "self.OnMenuCmd",
+                                 "r.out.gridatb"),
+                                (_("MAT-File (v.4) export"),
+                                 _("Export MAT-File (v.4) array (Matlab or Octave)"),
+                                 "self.OnMenuCmd",
+                                 "r.out.mat"),
+                                (_("Binary export"),
+                                 _("Export binary file"),
+                                 "self.OnMenuCmd",
+                                 "r.out.bin"),
+                                (_("MPEG-1 export"),
+                                 _("Export MPEG-1 animations"),
+                                 "self.OnMenuCmd",
+                                 "r.out.mpeg"),
+                                (_("PNG export"),
+                                 _("Export PNG image (not georeferenced)"),
+                                 "self.OnMenuCmd",
+                                 "r.out.png"),
+                                (_("PPM export"),
+                                 _("Export PPM image (24bit)"),
+                                 "self.OnMenuCmd",
+                                 "r.out.ppm"),
+                                (_("PPM from RGB export"),
+                                 _("Export PPM image from red, green, blue raster maps"),
+                                 "self.OnMenuCmd",
+                                 "r.out.ppm3"),
+                                (_("POV-Ray export"),
+                                 _("Export POVray height-field"),
+                                 "self.OnMenuCmd",
+                                 "r.out.pov"),
+                                (_("TIFF export"),
+                                 _("Export TIFF image (8/24bit)"),
+                                 "self.OnMenuCmd",
+                                 "r.out.tiff"),
+                                (_("VRML export"),
+                                 _("Export VRML file"),
+                                 "self.OnMenuCmd",
+                                 "r.out.vrml"),
+                                (_("VTK export"),
+                                 _("Export VTK ASCII file"),
+                                 "self.OnMenuCmd",
+                                 "r.out.vtk"),
+                        (_("Export vector map"), (
+                                (_("Multiple export formats using OGR"),
+                                 _("Export vector map to format supported by OGR (e.g. Shapefile)"),
+                                 "self.OnMenuCmd",
+                                 "v.out.ogr"),
+                                (_("ASCII points/GRASS ASCII vector export"),
+                                 _("Export vector map into ASCII points file or GRASS ASCII vector file"),
+                                 "self.OnMenuCmd",
+                                 "v.out.ascii"),
+                                (_("DXF export"),
+                                 _("Export vector map into DXF file"),
+                                 "self.OnMenuCmd",
+                                 "v.out.dxf"),
+                                 _("Export vector map into POV-Ray format file"),
+                                 "self.OnMenuCmd",
+                                 "v.out.pov"),
+                                (_("SVG export"),
+                                 _("Export vector map into SVG file"),
+                                 "self.OnMenuCmd",
+                                 "v.out.svg"),
+                                (_("VTK export"),
+                                 _("Export vector map into VTK ASCII file"),
+                                 "self.OnMenuCmd",
+                                 "v.out.vtk"),
+                        (_("Export grid 3D volume"), (
+                                (_("ASCII 3D export"),
+                                 _("Export ASCII 3D file"),
+                                 "self.OnMenuCmd",
+                                 "r3.out.ascii"),
+                                (_("Vis5D export"),
+                                 _("Export Vis5D file"),
+                                 "self.OnMenuCmd",
+                                 "r3.out.v5d"),
+                                (_("VTK export"),
+                                 "self.OnMenuCmd",
+                                 "r3.out.vtk"),
+                        (_("Manage maps and volumes"), (
+                                (_("Copy"),
+                                 _("Copy maps (GIS elements) within mapsets or between mapsets"),
+                                 "self.OnMenuCmd",
+                                 "g.copy"),
+                                (_("List"),
+                                 _("List by type"),
+                                 "self.OnMenuCmd",
+                                 "g.list"),
+                                (_("List filtered"),
+                                 _("List maps (GIS elements) filtered by expressions and wildcards"),
+                                 "self.OnMenuCmd",
+                                 "g.mlist"),
+                                (_("Rename"),
+                                 _("Rename maps (GIS elements)"),
+                                 "self.OnMenuCmd",
+                                 "g.rename"),
+                                (_("Delete"),
+                                 _("Delete maps (GIS elements)"),
+                                 "self.OnMenuCmd",
+                                 "g.remove"),
+                                (_("Delete filtered"),
+                                 _("Delete maps (GIS elements) using expressions and wildcards"),
+                                 "self.OnMenuCmd",
+                                 "g.mremove"),
+                        (_("Map type conversions"), (
+                                (_("Raster to vector"),
+                                 _("Convert raster to vector map"),
+                                 "self.OnMenuCmd",
+                                 "r.to.vect"),
+                                (_("Raster series to volume"),
+                                 _("Convert raster map series to volume"),
+                                 "self.OnMenuCmd",
+                                 "r.to.rast3"),
+                                (_("Raster 2.5D to volume"),
+                                 _("Convert raster 2.5D map to volume"),
+                                 "self.OnMenuCmd",
+                                 "r.to.rast3elev"),
+                                (_("Vector to raster"),
+                                 _("Convert vector to raster map"),
+                                 "self.OnMenuCmd",
+                                 "v.to.rast"),
+                                (_("Vector to volume"),
+                                 _("Convert vector 3D points to volume voxels"),
+                                 "self.OnMenuCmd",
+                                 "v.to.rast3"),
+                                (_("Sites to vector"),
+                                 _("Convert sites (GRASS 5) to vector map"),
+                                 "self.OnMenuCmd",
+                                 "v.in.sites"),
+                                (_("Volume to raster series"),
+                                 _("Convert 3D raster to raster series map"),
+                                 "self.OnMenuCmd",
+                                 "r3.to.rast"),
+                        (_("Georectify"),
+                         _("Georectify raster and vector maps"),
+                         "self.OnGeorectify",
+                        (_("NVIZ (requires Tcl/Tk)"),
+                         _("N-Dimensional visualization of 2D and 3D raster/vector maps"),
+                         "self.OnMenuCmd",
+                         "nviz"),
+                        (_("Bearing/distance to coordinates"),
+                         _("Convert between bearing/distance and coordinates"),
+                         "self.OnMenuCmd",
+                         "m.cogo"),
+                        (_("Postscript plot"),
+                         _("Create cartographic PostScript plot"),
+                         "self.OnMenuCmd",
+                         "ps.map"),
+                        (_("E&xit"),
+                         _("Exit GUI"),
+                         "self.OnCloseWindow",
+                (_("Config"), (
+                        (_("Region"), (
+                                (_("Display region"),
+                                 _("Display region settings (bounding box and resolution)"),
+                                 "self.RunMenuCmd",
+                                 "g.region -p"),
+                                (_("Set region"),
+                                 _("Change region settings"),
+                                 "self.OnMenuCmd",
+                                 "g.region"),
+                        (_("GRASS working environment"), (
+                                (_("Mapset access"),
+                                 _("Set/unset access to other mapsets in current location"),
+                                 "self.OnMapsets",
+                                (_("Change working environment"),
+                                 _("Change current working session to new mapset, location, or data directory"),
+                                 "self.OnMenuCmd",
+                                 "g.mapset"),
+                                (_("User access"),
+                                 _("Change access by other users to current mapset"),
+                                 "self.OnMenuCmd",
+                                 "g.access"),
+                                (_("Show settings"),
+                                 _("Show current GRASS environment settings"),
+                                 "g.gisenv"),
+                                (_("Change settings"),
+                                 _("Change GRASS environment settings"),
+                                 "self.OnMenuCmd",
+                                 "g.gisenv"),
+                                (_("Version"),
+                                 _("Show current GRASS version"),
+                                 "g.version -c"),
+                        (_("Manage projections"), (
+                                 _("Show projection information and create projection files"),
+                                 "self.OnMenuCmd",
+                                 "g.proj"),
+                                (_("Projection for current location"),
+                                 _("Create/edit projection information for current location"),
+                                 "self.OnXTerm",
+                                 "g.setproj"),
+                                (_("Convert coordinates"),
+                                 _("Convert coordinates from one projection to another"),
+                                 "self.OnMenuCmd",
+                                 "m.proj"),
+                        (_("Preferences"),
+                         _("User GUI preferences (display font, commands, digitizer, etc.)"),
+                         "self.OnPreferences",
+                (_("Raster"), (
+                        (_("Develop raster map"), (
+                                (_("Digitize raster (requires XTerm)"),
+                                 _("Digitize raster map"),
+                                 "self.OnXTerm",
+                                 "r.digit"),
+                                (_("Compress/decompress"),
+                                 _("Compress/decompress raster file"),
+                                 "self.OnMenuCmd",
+                                 "r.compress"),
+                                (_("Region boundaries"),
+                                 _("Manage region boundary definition"),
+                                 "self.OnMenuCmd",
+                                 "r.region"),
+                                (_("Manage NULL values"),
+                                 _("Manage NULL values"),
+                                 "self.OnMenuCmd",
+                                 "r.null"),
+                                (_("Quantization"),
+                                 _("Quantization for floating-point maps"),
+                                 "self.OnMenuCmd",
+                                 "r.quant"),
+                                (_("Timestamp"),
+                                 _("Manage timestamp for files"),
+                                 "self.OnMenuCmd",
+                                 "r.timestamp"),
+                                (_("Resample using aggregate statistics"),
+                                 _("Resample raster map (change resolution) using aggregate statistics"),
+                                 "self.OnMenuCmd",
+                                 "r.resamp.stats"),
+                                (_("Resample using multiple methods"),
+                                 _("Resample raster map (change resolution) using nearest neighbor, bilinear, or bicubic interpolation"),
+                                 "self.OnMenuCmd",
+                                 "r.resamp.interp"),
+                                (_("Resample using nearest neighbor"),
+                                 _("Resample raster map (change resolution) using nearest neighbor interpolation"),
+                                 "self.OnMenuCmd",
+                                 "r.resample"),
+                                (_("Resample using spline tension"),
+                                 _("Resample raster map (change resolution) using regularized spline tension"),
+                                 "self.OnMenuCmd",
+                                 "r.resamp.rst"),
+                                (_("Support file maintenance"),
+                                 _("Support raster map file creation and maintenance"),
+                                 "self.OnMenuCmd",
+                                 "r.support"),
+                                (_("Update map statistics"),
+                                 _("Update raster map statistics"),
+                                 "self.OnMenuCmd",
+                                 "r.support.stats"),
+                                (_("Reproject raster"),
+                                 _("Reproject raster map from other location"),
+                                 "self.OnMenuCmd",
+                                 "r.proj"),
+                                (_("Tiling"),
+                                 _("Generate tiling for other projection"),
+                                 "self.OnMenuCmd",
+                                 "r.tileset"),
+                        (_("Manage colors"), (
+                                (_("Color tables"),
+                                 _("Set colors to predefined color tables"),
+                                 "self.OnMenuCmd",
+                                 "r.colors"),
+                                (_("Color rules"),
+                                 _("Set colors interactively by entering color rules"),
+                                 "self.RulesCmd",
+                                 "r.colors"),
+                                (_("Blend 2 color rasters"),
+                                 _("Blend 2 color raster maps to produce 3 RGB files"),
+                                 "self.OnMenuCmd",
+                                 "r.blend"),
+                                (_("Create RGB"),
+                                 _("Create color image from RGB raster maps"),
+                                 "self.OnMenuCmd",
+                                 "r.composite"),
+                                (_("RGB to HIS"),
+                                 _("Create 3 RGB (red, green, blue) maps from 3 HIS (hue, intensity, saturation) maps"),
+                                 "self.OnMenuCmd",
+                                 "r.his"),
+                        (_("Query by coordinates"),
+                         _("Query raster map by coordinates"),
+                         "self.OnMenuCmd",
+                         "r.what"),
+                        (_("Buffer rasters"),
+                         _("Create raster buffers around raster objects"),
+                         "self.OnMenuCmd",
+                         "r.buffer"),
+                        (_("Closest points"),
+                         _("r.distance"),
+                         "self.OnMenuCmd",
+                         "r.distance"),
+                        (_("Mask"),
+                         _("Develop raster mask"),
+                         "self.OnMenuCmd",
+                         "r.mask"),
+                        (_("Map calculator"),
+                         _("Map calculator for raster map algebra"),
+                         "self.DispMapCalculator",
+                        (_("Neighborhood analysis"), (
+                                (_("Moving window"),
+                                 _("Moving window analysis of raster cells"),
+                                 "self.OnMenuCmd",
+                                 "r.neighbors"),
+                                (_("Neighborhood points"),
+                                 _("Analyze vector points in neighborhood of raster cells"),
+                                 "self.OnMenuCmd",
+                                 "v.neighbors"),
+                        (_("Overlay rasters"), (
+                                (_("Cross product"),
+                                 _("Create raster cross product"),
+                                 "self.OnMenuCmd",
+                                 "r.cross"),
+                                (_("Raster series"),
+                                 _("Function of raster map series (time series)"),
+                                 "self.OnMenuCmd",
+                                 "r.series"),
+                                (_("Patch raster maps"),
+                                 _("Patch several raster maps"),
+                                 "self.OnMenuCmd",
+                                 "r.patch"),
+                                (_("Statistical overlay"),
+                                 _("Statistical calculations for cover raster map over base raster map"),
+                                 "self.OnMenuCmd",
+                                 "r.statistics"),
+                        (_("Solar radiance and shadows"), (
+                                (_("Solar irradiance and irradiation"),
+                                 _("Solar irradiance and daily irradiation"),
+                                 "self.OnMenuCmd",
+                                 "r.sun"),
+                                (_("Shadows map"),
+                                 _("Shadows raster map for sun position or date/time"),
+                                 "self.OnMenuCmd",
+                                 "r.sunmask"),
+                        (_("Terrain analysis"), (
+                                (_("Cumulative movement costs"),
+                                 _("Calculate cumulative movement costs between locales"),
+                                 "self.OnMenuCmd",
+                                 "r.walk"),
+                                (_("Cost surface"),
+                                 _("Create raster map of cost surface"),
+                                 "self.OnMenuCmd",
+                                 "r.cost"),
+                                (_("Least cost route or flow"),
+                                 _("Create raster map of least cost route or flow"),
+                                 "self.OnMenuCmd",
+                                 "r.drain"),
+                                (_("Shaded relief"),
+                                 _("Shaded relief raster map"),
+                                 "self.OnMenuCmd",
+                                 "r.shaded.relief"),
+                                (_("Slope and aspect"),
+                                 _("Create raster map of slope and aspect"),
+                                 "self.OnMenuCmd",
+                                 "r.slope.aspect"),
+                                (_("Terrain parameters"),
+                                 _("Calculate terrain parameters"),
+                                 "self.OnMenuCmd",
+                                 "r.param.scale"),
+                                (_("Textural features"),
+                                 _("Textural features analysis"),
+                                 "self.OnMenuCmd",
+                                 "r.texture"),
+                                (_("Visibility"),
+                                 _("Visibility and line of sight"),
+                                 "self.OnMenuCmd",
+                                 "r.los"),
+                        (_("Transform features"), (
+                                (_("Clump"),
+                                 _("Clump small areas (statistics calculated by r.volume)"),
+                                 "self.OnMenuCmd",
+                                 "r.clump"),
+                                (_("Grow"),
+                                 _("Grow raster areas"),
+                                 "self.OnMenuCmd",
+                                 "r.grow"),
+                                (_("Thin"),
+                                 _("Thin linear features"),
+                                 "self.OnMenuCmd",
+                                 "r.thin"),
+                        (_("Hydrologic modeling"), (
+                                (_("Carve stream channels"),
+                                 _("Carve stream channels into elevation map using vector streams map"),
+                                 "self.OnMenuCmd",
+                                 "r.carve"),
+                                (_("Fill lake"),
+                                 _("Fill lake from seed point to specified level"),
+                                 "self.OnMenuCmd",
+                                 "r.lake"),
+                                (_("Depressionless map and flowlines"),
+                                 _("Depressionless elevation map and flowline map"),
+                                 "self.OnMenuCmd",
+                                 "r.fill.dir"),
+                                (_("Flow accumulation"),
+                                 _("Flow accumulation for massive grids"),
+                                 "self.OnMenuCmd",
+                                 "r.terraflow"),
+                                (_("Flow lines"),
+                                 _("Generate flow lines for raster map"),
+                                 "self.OnMenuCmd",
+                                 "r.flow"),
+                                (_("SIMWE Overland flow modeling"),
+                                 _("SIMWE overland flow modeling analysis"),
+                                 "self.OnMenuCmd",
+                                 "r.sim.water"),
+                                (_("SIMWE Sediment flux modeling"),
+                                 _("SIMWE sediment erosion, transport, deposition modeling"),
+                                 "self.OnMenuCmd",
+                                 "r.sim.sediment"),
+                                (_("Topographic index map"),
+                                 _("Create topographic index raster map"),
+                                 "self.OnMenuCmd",
+                                 "r.topidx"),
+                                (_("TOPMODEL simulation"),
+                                 _("TOPMODEL simulation analysis"),
+                                 "self.OnMenuCmd",
+                                 "r.topmodel"),
+                                (_("Watershed subbasins"),
+                                 _("Watershed subbasins modelling"),
+                                 "self.OnMenuCmd",
+                                 "r.basins.fill"),
+                                (_("Watershed analysis"),
+                                 _("Run watershed analysis"),
+                                 "self.OnMenuCmd",
+                                 "r.watershed"),
+                                (_("Watershed basin creation"),
+                                 _("Watershed basin creation"),
+                                 "self.OnMenuCmd",
+                                 "r.water.outlet"),
+                        (_("Landscape structure modeling"), (
+                                (_("Set up (requires XTerm)"),
+                                 _("Set up sampling and analysis framework"),
+                                 "self.OnXTerm",
+                                 "r.le.setup"),
+                                (_("Analyze landscape"),
+                                 _("Analyze landscape characteristics"),
+                                 "self.OnMenuCmd",
+                                 "r.le.pixel"),
+                                (_("Analyze patches"),
+                                 _("Analyze landscape patch characteristics"),
+                                 "self.OnMenuCmd",
+                                 "r.le.patch"),
+                                (_("Output"),
+                                 _("Output landscape patch information"),
+                                 "self.OnMenuCmd",
+                                 "r.le.trace"),
+                        (_("Landscape patch analysis"), (
+                                (_("Set up sampling and analysis framework"),
+                                 _("Configure and create patch map for analysis"),
+                                 "self.OnMenuCmd",
+                                 "r.li.setup"),
+                                (_("Edge density"),
+                                 _("Calculate edge density index using a 4 neighbour algorithm"),
+                                 "self.OnMenuCmd",
+                                 "r.li.edgedensity"),
+                                (_("Contrast weighted edge density"),
+                                 _("Calculate contrast weighted edge density index"),
+                                 "self.OnMenuCmd",
+                                 "r.li.cwed"),
+                                (_("Patch area mean"),
+                                 _("Calculate mean patch size index using a 4 neighbour algorithm"),
+                                 "self.OnMenuCmd",
+                                 "r.li.mps"),
+                                (_("Patch area range"),
+                                 _("Calculate range of patch area size"),
+                                 "self.OnMenuCmd",
+                                 "r.li.padrange"),
+                                (_("Patch area Std Dev"),
+                                 _("Calculate standard deviation of patch area"),
+                                 "self.OnMenuCmd",
+                                 "r.li.padsd"),
+                                (_("Patch area Coeff Var"),
+                                 _("Calculate coefficient of variation of patch area"),
+                                 "self.OnMenuCmd",
+                                 "r.li.padcv"),
+                                (_("Patch density"),
+                                 _("Calculate patch density index using a 4 neighbour algorithm"),
+                                 "self.OnMenuCmd",
+                                 "r.li.patchdensity"),
+                                (_("Patch number"),
+                                 _("Calculate patch number index using a 4 neighbour algorithm"),
+                                 "self.OnMenuCmd",
+                                 "r.li.patchnum"),
+                                (_("Dominance's diversity"),
+                                 _("Calculate Dominance's diversity index"),
+                                 "self.OnMenuCmd",
+                                 "r.li.dominance"),
+                                (_("Shannon's diversity"),
+                                 _("Calculate Shannon's diversity index"),
+                                 "self.OnMenuCmd",
+                                 "r.li.shannon"),
+                                (_("Simpson's diversity"),
+                                 _("Calculate Simpson's diversity index"),
+                                 "self.OnMenuCmd",
+                                 "r.li.simpson"),
+                                (_("Richness"),
+                                 _("Calculate richness index"),
+                                 "self.OnMenuCmd",
+                                 "r.li.richness"),
+                                (_("Shape index"),
+                                 _("Calculate shape index"),
+                                 "self.OnMenuCmd",
+                                 "r.li.shape"),
+                        (_("Wildfire modeling"), (
+                                (_("Rate of spread"),
+                                 _("Generate rate of spread (ROS) maps"),
+                                 "self.OnMenuCmd",
+                                 "r.ros"),
+                                (_("Least-cost spread paths"),
+                                 _("Generate least-cost spread paths"),
+                                 "self.OnMenuCmd",
+                                 "r.spreadpath"),
+                                (_("Anisotropic spread simulation"),
+                                 _("Simulate anisotropic spread phenomena"),
+                                 "self.OnMenuCmd",
+                                 "r.spread"),
+                        (_("Change category values and labels"), (
+                                (_("Interactively edit category values"),
+                                 _("Edit category values of individual cells for displayed raster map"),
+                                 "self.OnMenuCmd",
+                                 "d.rast.edit"),
+                                (_("Reclassify by size"),
+                                 _("Reclassify raster categories for raster areas of specified sizes"),
+                                 "self.OnMenuCmd",
+                                 "r.reclass.area"),
+                                (_("Reclassify interactively"),
+                                 _("Reclassify raster categories interactively by entering reclass rules"),
+                                 "self.RulesCmd",
+                                 "r.reclass"),
+                                (_("Reclassify using rules file"),
+                                 _("Reclassify raster categories by inputting reclass rules from a text file"),
+                                 "self.OnMenuCmd",
+                                 "r.reclass"),
+                                (_("Recode interactively"),
+                                 _("Recode raster categories interactively by entering recode rules (create new raster map)"),
+                                 "self.RulesCmd",
+                                 "r.recode"),
+                                (_("Recode using rules file"),
+                                 _("Recode raster categories by inputting recode rules from a text file (create new map)"),
+                                 "self.OnMenuCmd",
+                                 "r.recode.file"),
+                                (_("Rescale"),
+                                 _("Rescale raster categories (create new raster map)"),
+                                 "self.OnMenuCmd",
+                                 "r.rescale"),
+                                (_("Rescale with histogram"),
+                                 _("Rescale raster categories with equalized histogram (create new raster map)"),
+                                 "self.OnMenuCmd",
+                                 "r.rescale.eq"),
+                        (_("Concentric circles"),
+                         _("Generate concentric circles around points"),
+                         "self.OnMenuCmd",
+                         "r.circle"),
+                        (_("Generate random cells"), (
+                                (_("Random cells"),
+                                 _("Generate random raster cells"),
+                                 "self.OnMenuCmd",
+                                 "r.random.cells"),
+                                (_("Random cells and vector points"),
+                                 _("Generate random raster cells and vector points from raster map"),
+                                 "self.OnMenuCmd",
+                                 "r.random"),
+                        (_("Generate surfaces"), (
+                                (_("Fractal surface"),
+                                 _("Generate fractal surface"),
+                                 "self.OnMenuCmd",
+                                 "r.surf.fractal"),
+                                (_("Gaussian kernel density surface"),
+                                 _("Generate density surface using moving Gaussian kernel"),
+                                 "self.OnMenuCmd",
+                                 "v.kernel"),
+                                (_("Gaussian deviates surface"),
+                                 _("Generate gaussian deviates surface"),
+                                 "self.OnMenuCmd",
+                                 "r.surf.gauss"),
+                                (_("Plane"),
+                                 _("Generate plane"),
+                                 "self.OnMenuCmd",
+                                 "r.plane"),
+                                (_("Random deviates surface"),
+                                 _("Generate random deviates surface"),
+                                 "self.OnMenuCmd",
+                                 "r.surf.random"),
+                                (_("Random surface with spatial dependence"),
+                                 _("Generate random surface with spatial dependence"),
+                                 "self.OnMenuCmd",
+                                 "r.random.surface"),
+                        (_("Generate contour lines"),
+                         _("Generate vector contour lines"),
+                         "self.OnMenuCmd",
+                         "r.contour"),
+                        (_("Interpolate surfaces"), (
+                                (_("Bilinear from raster points"),
+                                 _("Bilinear interpolation from raster points"),
+                                 "self.OnMenuCmd",
+                                 "r.bilinear"),
+                                (_("Bilinear and bicubic from vector points"),
+                                 _("Bicubic and bilinear interpolation with Tykhonov regularization from vector points"),
+                                 "self.OnMenuCmd",
+                                 "v.surf.bspline"),
+                                (_("IDW from raster points"),
+                                 _("Inverse distance weighted interpolation from raster points"),
+                                 "self.OnMenuCmd",
+                                 "r.surf.idw"),
+                                (_("IDW from vector points"),
+                                 _("Inverse distance weighted interpolation from vector points"),
+                                 "self.OnMenuCmd",
+                                 "v.surf.idw"),
+                                (_("Raster contours"),
+                                 _("Interpolation from raster contour"),
+                                 "self.OnMenuCmd",
+                                 "r.surf.contour"),
+                                (_("Regularized spline tension"),
+                                 _("Regularized spline tension interpolation from vector points or contours"),
+                                 "self.OnMenuCmd",
+                                 "v.surf.rst"),
+                                (_("Fill NULL cells"),
+                                 _("Fill NULL raster cells by interpolation using regularized spline tension"),
+                                 "self.OnMenuCmd",
+                                 "r.fillnulls"),
+                        (_("Report and statistics"), (
+                                (_("Basic raster metadata"),
+                                 _("Report basic raster map metadata"),
+                                 "self.OnMenuCmd",
+                                 "r.info"),
+                                (_("Manage category information"),
+                                 _("Manage raster categories labels and values"),
+                                 "self.OnMenuCmd",
+                                 "r.category"),
+                                (_("General statistics"),
+                                 _("General raster map statistics"),
+                                 "self.OnMenuCmd",
+                                 "r.stats"),
+                                (_("Range of category values"),
+                                 _("Range of all raster category values"),
+                                 "self.OnMenuCmd",
+                                 "r.describe"),
+                                (_("Sum category values"),
+                                 _("Sum all raster category values"),
+                                 "self.OnMenuCmd",
+                                 "r.sum"),
+                                (_("Sum area by raster map and category"),
+                                 _("Calculate sum of area by raster map and category"),
+                                 "self.OnMenuCmd",
+                                 "r.report"),
+                                (_("Statistics for clumped cells"),
+                                 _("Summary statistics for clumped raster map (work with r.clump)"),
+                                 "self.OnMenuCmd",
+                                 "r.volume"),
+                                (_("Total corrected area"),
+                                 _("Total surface area corrected for topography"),
+                                 "self.OnMenuCmd",
+                                 "r.surf.area"),
+                                (_("Univariate raster statistics"),
+                                 _("Calculate univariate statistics for raster categories"),
+                                 "self.OnMenuCmd",
+                                 "r.univar"),
+                                (_("Sample transects"),
+                                 _("Sample values along transects"),
+                                 "self.OnMenuCmd",
+                                 "r.profile"),
+                                (_("Sample transects (bearing/distance)"),
+                                 _("Sample values along transects (use azimuth, distance)"),
+                                 "self.OnMenuCmd",
+                                 "r.transect"),
+                                (_("Covariance/correlation"),
+                                 _("Covariance/correlation calculation"),
+                                 "self.OnMenuCmd",
+                                 "r.covar"),
+                                (_("Linear regression"),
+                                 _("Linear regression between 2 raster maps"),
+                                 "self.OnMenuCmd",
+                                 "r.regression.line"),
+                                (_("Mutual category occurrences"),
+                                 _("Mutual category occurrences (coincidence)"),
+                                 "self.OnMenuCmd",
+                                 "r.coin"),
+                (_("Vector"), (
+                        (_("Develop vector map"), (
+                                (_("Create new vector map"),
+                                 _("Create new empty vector map"),
+                                 "self.OnMenuCmd",
+                                 "v.edit tool=create"),
+                                #                                 (_("Digitize vector map"),
+                                #                                  _("Digitize/edit vector map"),
+                                #                                  "self.OnMenuCmd",
+                                #                                 "v.digit"),
+                                (_("Create/rebuild topology"),
+                                 _("Create or rebuild topology of vector objects"),
+                                 "self.OnMenuCmd",
+                                 "v.build"),
+                                (_("Clean vector map"),
+                                 _("Clean vector objects (topologically incorect)"),
+                                 "self.OnMenuCmd",
+                                 "v.clean"),
+                                (_("Generalization"),
+                                 _("Smooth, simplify, displace, or generalize a vector map"),
+                                 "self.OnMenuCmd",
+                                 "v.generalize"),
+                                (_("Convert object types"),
+                                 _("Convert vector objects from one feature type to another"),
+                                 "self.OnMenuCmd",
+                                 "v.type.sh"),
+                                (_("Add centroids"),
+                                 _("Add centroids to closed boundaries to create areas"),
+                                 "self.OnMenuCmd",
+                                 "v.centroids"),
+                                (_("Build polylines"),
+                                 _("Build polylines from adjacent segments"),
+                                 "self.OnMenuCmd",
+                                 "v.build.polylines"),
+                                (_("Split polylines"),
+                                 _("Split polylines into points and segments"),
+                                 "self.OnMenuCmd",
+                                 "v.segment"),
+                                (_("Parallel lines"),
+                                 _("Create lines parallel to existing lines"),
+                                 "self.OnMenuCmd",
+                                 "v.parallel"),
+                                (_("Dissolve boundaries"),
+                                 _("Dissolve common boundaries of areas"),
+                                 "self.OnMenuCmd",
+                                 "v.dissolve"),
+                                (_("Create 3D vector over raster"),
+                                 _("Create 3D objects by sampling raster map with 2D vector map"),
+                                 "self.OnMenuCmd",
+                                 "v.drape"),
+                                (_("Extrude 3D vector map"),
+                                 _("Extrude 3D objects from 2D vector map"),
+                                 "self.OnMenuCmd",
+                                 "v.extrude"),
+                                (_("Link to OGR"),
+                                 _("Create new vector map as link to external OGR layer"),
+                                 "self.OnMenuCmd",
+                                 "v.external"),
+                                (_("Create labels"),
+                                 _("Create text label file for vector features"),
+                                 "self.OnMenuCmd",
+                                 "v.label"),
+                                (_("Reposition vector map"),
+                                 _("Reposition (shift, rotate, skew) vector map in coordinate space"),
+                                 "self.OnMenuCmd",
+                                 "v.transform"),
+                                (_("Reproject vector map"),
+                                 _("Reproject vector map from other location"),
+                                 "self.OnMenuCmd",
+                                 "v.proj"),
+                        (_("Query with attributes"),
+                         _("Query vector objects by attribute values (create new vector map)"),
+                         "self.OnMenuCmd",
+                         "v.extract"),
+                        (_("Query with coordinate(s)"),
+                         _("Query vector objects by coordinate(s)"),
+                         "self.OnMenuCmd",
+                         "v.what"),
+                        (_("Query with another vector map"),
+                         _("Query objects using objects from a second vector map"),
+                         "self.OnMenuCmd",
+                         "v.select"),
+                        (_("Buffer vectors"),
+                         _("Create vector buffers around vector objects"),
+                         "self.OnMenuCmd",
+                         "v.buffer"),
+                        (_("Lidar analysis"), (
+                                (_("Detect edges"),
+                                 _("Detect object edges in Lidar data"),
+                                 "self.OnMenuCmd",
+                                 "v.lidar.edgedetection"),
+                                (_("Detect interiors"),
+                                 _("Detect interiors of objects in Lidar data"),
+                                 "self.OnMenuCmd",
+                                 "v.lidar.growing"),
+                                (_("Correct and reclassify objects"),
+                                 _("Correct and reclassify objects detected in Lidar data"),
+                                 "self.OnMenuCmd",
+                                 "v.lidar.correction"),
+                        (_("Linear referencing"), (
+                                (_("Create LRS"),
+                                 _("Create linear reference system"),
+                                 "self.OnMenuCmd",
+                                 "v.lrs.create"),
+                                (_("Create stationing"),
+                                 _("Create stationing from input lines, and linear reference system"),
+                                 "self.OnMenuCmd",
+                                 "v.lrs.label"),
+                                (_("Create points/segments"),
+                                 _("Create points/segments from input lines, linear reference system and positions read from stdin"),
+                                 "self.OnMenuCmd",
+                                 "v.lrs.segment"),
+                                (_("Find line id and offset"),
+                                 _("Find line id and real km+offset for given points in vector map using linear reference system"),
+                                 "self.OnMenuCmd",
+                                 "v.lrs.where"),
+                        (_("Nearest features"),
+                         _("Locate nearest feature to points or centroids"),
+                         "self.OnMenuCmd",
+                         "v.distance"),
+                        (_("Network analysis"), (
+                                (_("Allocate subnets"),
+                                 _("Allocate subnets for nearest centers"),
+                                 "self.OnMenuCmd",
+                                 "v.net.alloc"),
+                                (_("Network maintenance"),
+                                 _("Network maintenance support"),
+                                 "self.OnMenuCmd",
+                                 "v.net"),
+                                (_("Visibility network"),
+                                 _("Create and maintain a visibility network"),
+                                 "self.OnMenuCmd",
+                                 "v.net.visibility"),
+                                (_("Shortest path"),
+                                 _("Calculate shortest route along network between 2 nodes"),
+                                 "self.OnMenuCmd",
+                                 "v.net.path"),
+                                (_("Display shortest route (requires XTerm)"),
+                                 _("Display shortest route along network between 2 nodes (visualization only, requires XTerm))"),
+                                 "self.OnXTerm",
+                                 "d.path"),
+                                (_("Split net"),
+                                 _("Split net into bands between cost isolines"),
+                                 "self.OnMenuCmd",
+                                 "v.net.iso"),
+                                (_("Steiner tree"),
+                                 _("Create Steiner tree for network and given terminals"),
+                                 "self.OnMenuCmd",
+                                 "v.net.steiner"),
+                                (_("Traveling salesman analysis"),
+                                 _("Calculate shortest route connecting given set of nodes (Traveling salesman analysis)"),
+                                 "self.OnMenuCmd",
+                                 "v.net.salesman"),
+                        (_("Overlay vector maps"), (
+                                 _("Boolean overlay of 2 vector maps"),
+                                 "self.OnMenuCmd",
+                                 "v.overlay"),
+                                (_("Patch vector maps"),
+                                 _("Patch/combine multiple maps (boolean OR)"),
+                                 "self.OnMenuCmd",
+                                 "v.patch"),
+                        (_("Change attributes"), (
+                                (_("Manage or report categories"),
+                                 _("Attach/delete, or report vector categories"),
+                                 "self.OnMenuCmd",
+                                 "v.category"),
+                                (_("Reclassify objects interactively"),
+                                 _("Reclassify vector objects interactively by entering SQL rules"),
+                                 "self.RulesCmd",
+                                 "v.reclass"),
+                                (_("Reclassify objects using rules file"),
+                                 _("Reclassify vector objects by inputting SQL rules from a text file"),
+                                 "self.OnMenuCmd",
+                                 "v.reclass"),
+                        (_("Generate area for current region"),
+                         _("Generate area object for extent of current region"),
+                         "self.OnMenuCmd",
+                         "v.in.region"),
+                        (_("Generate areas from points"), (
+                                (_("Convex hull"),
+                                 _("Generate convex hull for point set"),
+                                 "self.OnMenuCmd",
+                                 "v.hull"),
+                                (_("Delaunay triangles"),
+                                 _("Generate Delaunay triangles for point set"),
+                                 "self.OnMenuCmd",
+                                 "v.delaunay"),
+                                (_("Voronoi diagram/Thiessen polygons"),
+                                 _("Generate Voronoi diagram/Thiessen polygons for point set"),
+                                 "self.OnMenuCmd",
+                                 "v.voronoi"),
+                        (_("Generate grid"),
+                         _("Generate rectangular vector grid"),
+                         "self.OnMenuCmd",
+                         "v.mkgrid"),
+                        (_("Generate points"), (
+                                (_("Generate from database"),
+                                 _("Generate vector points from database with x/y coordinates"),
+                                 "self.OnMenuCmd",
+                                 "v.in.db"),
+                                (_("Generate points along lines"),
+                                 _("Generate vector points along vector lines/boundaries"),
+                                 "self.OnMenuCmd",
+                                 "v.to.points"),
+                                (_("Generate random points"),
+                                 _("Generate random vector points"),
+                                 "self.OnMenuCmd",
+                                 "v.random"),
+                                (_("Perturb points"),
+                                 _("Random perturbations of point locations"),
+                                 "self.OnMenuCmd",
+                                 "v.perturb"),
+                        (_("Remove outliers in point sets"),
+                         _("Remove outliers from vector point set"),
+                         "self.OnMenuCmd",
+                         "v.outlier"),
+                        (_("Test/training point sets"),
+                         _("Partition points into test/training sets for k-fold cross validation"),
+                         "self.OnMenuCmd",
+                         "v.kcv"),
+                        (_("Update area attributes from raster"),
+                         _("Update area attribute data from univariate statistics on raster map"),
+                         "self.OnMenuCmd",
+                         "v.rast.stats"),
+                        (_("Update point attributes from areas"),
+                         _("Update point attribute data from vector area map"),
+                         "self.OnMenuCmd",
+                         "v.what.vect"),
+                        (_("Update point attributes from raster"), (
+                                (_("Sample raster maps at point locations"),
+                                 _("Update attribute based on sample raster maps at point locations"),
+                                 "self.OnMenuCmd",
+                                 "v.what.rast"),
+                                (_("Sample raster neighborhood around points"),
+                                 _("Update attributes based on sample raster neighborhood around points"),
+                                 "self.OnMenuCmd",
+                                 "v.sample"),
+                        (_("Reports and statistics"), (
+                                (_("Basic vector metadata"),
+                                 _("Rebort basic vector map metadata"),
+                                 "self.OnMenuCmd",
+                                 "v.info"),
+                                (_("Report topology by category"),
+                                 _("Report areas for vector attribute categories"),
+                                 "self.OnMenuCmd",
+                                 "v.report"),
+                                (_("Upload or report topology"),
+                                 _("Update database fields or create reports from vector topology"),
+                                 "self.OnMenuCmd",
+                                 "v.to.db"),
+                                (_("Univariate attribute statistics"),
+                                 _("Calculate univariate statistics for vector attributes"),
+                                 "self.OnMenuCmd",
+                                 "v.univar"),
+                                (_("Quadrat indices"),
+                                 _("Indices of point counts in quadrats"),
+                                 "self.OnMenuCmd",
+                                 "v.qcount"),
+                                (_("Test normality"),
+                                 _("Test normality of point distribution"),
+                                 "self.OnMenuCmd",
+                                 "v.normal"),
+                (_("Imagery"), (
+                        (_("Develop images and groups"), (
+                                (_("Create/edit group"),
+                                 _("Create/edit imagery group"),
+                                 "self.OnMenuCmd",
+                                 "i.group"),
+                                (_("Target group"),
+                                 _("Define target imagery group"),
+                                 "self.OnMenuCmd",
+                                 "i.target"),
+                                (_("Mosaic images"),
+                                 _("Mosaic up to 4 adjacent images"),
+                                 "self.OnMenuCmd",
+                                 "i.image.mosaic"),
+                        (_("Manage image colors"), (
+                                (_("Color balance for RGB"),
+                                 _("Color balance and enhance color tables of multiband imagery for RGB display"),
+                                 "self.OnMenuCmd",
+                                 "i.landsat.rgb"),
+                                (_("HIS to RGB"),
+                                 _("Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"),
+                                 "self.OnMenuCmd",
+                                 "i.his.rgb"),
+                                (_("RGB to HIS"),
+                                 _("Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"),
+                                 "self.OnMenuCmd",
+                                 "i.rgb.his"),
+                        (_("Rectify image or raster"),
+                         _("Rectifies raster map using information in previously created POINTS file"),
+                         "self.OnMenuCmd",
+                         "i.rectify"),
+                        (_("Ortho photo rectification (requires Xterm)"),
+                         _("Ortho Photo rectification"),
+                         "self.OnXTerm",
+                         "i.ortho.photo"),
+                        (_("Brovey sharpening"),
+                         _("Brovey transformation and pan sharpening"),
+                         "self.OnMenuCmd",
+                         "i.fusion.brovey"),
+                        (_("Classify image"), (
+                                (_("Clustering input for unsupervised classification"),
+                                 _("Clustering input for unsupervised classification analysis"),
+                                 "self.OnMenuCmd",
+                                 "i.cluster"),
+                                (_("Maximum likelihood classification (MLC)"),
+                                 _("Maximum Likelihood Classification analysis"),
+                                 "self.OnMenuCmd",
+                                 "i.maxlik"),
+                                (_("Sequential maximum a posteriori classification (SMAP)"),
+                                 _("Sequential Maximum A Posteriori Classification (SMAP) analysis"),
+                                 "self.OnMenuCmd",
+                                 "i.smap"),
+                                (_("Interactive input for supervised classification (requires Xterm)"),
+                                 _("Interactive input for supervised classification"),
+                                 "self.OnXTerm",
+                                 "i.class"),
+                                (_("Input for supervised MLC"),
+                                 _("Non-interactive input for supervised classification (MLC)"),
+                                 "self.OnMenuCmd",
+                                 "i.gensig"),
+                                (_("Input for supervised SMAP"),
+                                 _("Non-interactive input for supervised classification (SMAP)"),
+                                 "self.OnMenuCmd",
+                                 "i.gensigset"),
+                        (_("Filter image"), (
+                                (_("Edge detection"),
+                                 _("Zero edge crossing detection"),
+                                 "self.OnMenuCmd",
+                                 "i.zc"),
+                                (_("Matrix/convolving filter"),
+                                 _("User defined matrix/convolving filter"),
+                                 "self.OnMenuCmd",
+                                 "r.mfilter"),
+                        (_("Histogram"),
+                         _("Generate histogram of image"),
+                         "self.DispHistogram",
+                        (_("Spectral response"),
+                         _("Calculate spectral response"),
+                         "self.OnMenuCmd",
+                         "i.spectral"),
+                        (_("Tasseled cap vegetation index"),
+                         _("Tasseled cap vegetation index analysis"),
+                         "self.OnMenuCmd",
+                         "i.tasscap"),
+                        (_("Transform image"), (
+                                (_("Canonical correlation"),
+                                 _("Canonical correlation (discriminant analysis)"),
+                                 "self.OnMenuCmd",
+                                 "i.cca"),
+                                (_("Principal components"),
+                                 _("Principal components analysis"),
+                                 "self.OnMenuCmd",
+                                 "i.pca"),
+                                (_("Fast Fourier"),
+                                 _("Fast Fourier Transform"),
+                                 "self.OnMenuCmd",
+                                 "i.fft"),
+                                (_("Inverse Fast Fourier"),
+                                 _("Inverse Fast Fourier Transform"),
+                                 "self.OnMenuCmd",
+                                 "i.ifft"),
+                                (_("Bit pattern comparison "),
+                                 _("Bit pattern comparison for ID of low quality pixels"),
+                                 "self.OnMenuCmd",
+                                 "r.bitpattern"),
+                                (_("Kappa analysis"),
+                                 _("Kappa classification accuracy assessment"),
+                                 "self.OnMenuCmd",
+                                 "r.kappa"),
+                                (_("OIF for LandSat TM"),
+                                 _("Optimum index factor for LandSat TM"),
+                                 "self.OnMenuCmd",
+                                 "i.oif"),
+                (_("Volumes"), (
+                        (_("Develop volumes"), (
+                                (_("Manage 3D NULL values"),
+                                 _("Manage NULL values for volume"),
+                                 "self.OnMenuCmd",
+                                 "r3.null"),
+                                (_("Manage timestamp"),
+                                 _("Manage timestamp for volume"),
+                                 "self.OnMenuCmd",
+                                 "r3.timestamp"),
+                        (_("3D Mask"),
+                         _("Create 3D mask for 3D raster operations"),
+                         "self.OnMenuCmd",
+                         "r3.mask"),
+                        (_("3D raster map calculator"),
+                         _("Map calculator for volumetric map algebra"),
+                         "self.Disp3DMapCalculator",
+                        (_("Cross section"),
+                         _("Create 2D raster cross section from volume"),
+                         "self.OnMenuCmd",
+                         "r3.cross.rast"),
+                        (_("Interpolate volume from points"),
+                         _("Interpolate volume from vector points using splines"),
+                         "self.OnMenuCmd",
+                         "v.vol.rst"),
+                        (_("Report and Statistics"), (
+                                (_("Basic volume metadata"),
+                                 _("Report basic volume metadata"),
+                                 "self.OnMenuCmd",
+                                 "r3.info"),
+                (_("Database"), (
+                        (_("Database information"), (
+                                (_("Describe table"),
+                                 _("Describe table structure and attributes"),
+                                 "self.OnMenuCmd",
+                                 "db.describe"),
+                                (_("List columns"),
+                                 _("List columns for selected table"),
+                                 "self.OnMenuCmd",
+                                 "db.columns"),
+                                (_("List drivers"),
+                                 _("List available database drivers"),
+                                 "self.OnMenuCmd",
+                                 "db.drivers"),
+                                (_("List tables"),
+                                 _("List tables in selected database"),
+                                 "self.OnMenuCmd",
+                                 "db.tables"),
+                        (_("Manage databases"), (
+                                (_("Connect"),
+                                 _("Connect to database"),
+                                 "self.OnMenuCmd",
+                                 "db.connect"),
+                                (_("Login"),
+                                 _("Login to database"),
+                                 "self.OnMenuCmd",
+                                 "db.login"),
+                                (_("Copy table"),
+                                 _("Copy attribute table"),
+                                 "self.OnMenuCmd",
+                                 "db.copy"),
+                                (_("New table"),
+                                 _("Create and connect new attribute table to vector map"),
+                                 "self.OnMenuCmd",
+                                 "v.db.addtable"),
+                                (_("Remove table"),
+                                 _("Remove existing attribute table for vector map"),
+                                 "self.OnMenuCmd",
+                                 "db.login"),
+                                (_("Add columns"),
+                                 _("Add columns to table"),
+                                 "self.OnMenuCmd",
+                                 "v.db.addcol"),
+                                (_("Change values"),
+                                 _("Change values in a column"),
+                                 "self.OnMenuCmd",
+                                 "v.db.update"),
+                                (_("Rename column"),
+                                 _("Rename a column"),
+                                 "self.OnMenuCmd",
+                                 "v.db.renamecol"),
+                                (_("Test"),
+                                 _("Test database"),
+                                 "self.OnMenuCmd",
+                                 "db.test"),
+                        (_("Query"), (
+                                (_("Query any table"),
+                                 _("Query data in any table"),
+                                 "self.OnMenuCmd",
+                                 "db.select"),
+                                (_("Query vector attribute data"),
+                                 _("Query vector attribute data"),
+                                 "self.OnMenuCmd",
+                                 "v.db.select"),
+                                (_("SQL statement"),
+                                 _("Execute SQL statement"),
+                                 "self.OnMenuCmd",
+                                 "db.execute"),
+                        (_("Vector database connections"), (
+                                (_("Reconnect vector to database"),
+                                 _("Reconnect vector map to attribute database"),
+                                 "self.OnMenuCmd",
+                                 "v.db.reconnect.all"),
+                                (_("Set vector map - database connection"),
+                                 _("Set database connection for vector attributes"),
+                                 "self.OnMenuCmd",
+                                 "v.db.connect"),
+                (_("Help"), (
+                        (_("GRASS GIS help"),
+                         _("GRASS GIS Reference Manual"),
+                         "g.manual -i"),
+                        (_("GRASS GIS GUI help"),
+                         _("GUI-related Reference Manual"),
+                         "g.manual wxGUI"),
+                        (_("About GRASS GIS"),
+                         _("About GRASS GIS"),
+                         "self.OnAboutGRASS",
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-03-15 14:13:10 UTC (rev 30569)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-03-15 17:35:32 UTC (rev 30570)
@@ -250,7 +250,7 @@
             return
         if len(gcmd) > 0:
-            helpString = gcmd + ' (' + help + ')'
+            helpString = gcmd + ' -- ' + help
         else:
             helpString = help
