[GRASS-SVN] r30589 - grass/trunk/general/g.mapset
svn_grass at osgeo.org
Sun Mar 16 13:52:13 EDT 2008
Author: martinl
Date: 2008-03-16 13:52:13 -0400 (Sun, 16 Mar 2008)
New Revision: 30589
grass/trunk/general/g.mapset/main.c
g.mapset: cosmetics in module description / messages
Modified: grass/trunk/general/g.mapset/main.c
--- grass/trunk/general/g.mapset/main.c 2008-03-16 17:43:38 UTC (rev 30588)
+++ grass/trunk/general/g.mapset/main.c 2008-03-16 17:52:13 UTC (rev 30589)
@@ -45,8 +45,8 @@
G_gisinit (argv[0]);
module = G_define_module();
- module->keywords = _("general");
- module->description = _("Change current mapset");
+ module->keywords = _("general, settings");
+ module->description = _("Change current mapset.");
mapset_opt = G_define_option() ;
mapset_opt->key = "mapset" ;
@@ -102,7 +102,7 @@
/* TODO: this should be checked better (repeated '/' etc.) */
if ( strcmp(mapset_old_path, mapset_new_path) == 0 )
- G_fatal_error ( _("%s is already the current mapset"), mapset_new );
+ G_fatal_error ( _("<%s> is already the current mapset"), mapset_new );
/* Check if the mapset exists and user is owner */
G_debug ( 2, "check : %s", mapset_new_path );
@@ -110,7 +110,7 @@
ret = G__mapset_permissions2 ( gisdbase_new, location_new, mapset_new );
switch ( ret ) {
case 0:
- G_fatal_error ( _("You don't have permission to use this mapset.") );
+ G_fatal_error ( _("You don't have permission to use this mapset") );
break;
case -1:
if ( f_add->answer == TRUE ) {
@@ -127,7 +127,7 @@
/* Check if the mapset is in use */
gis_lock = getenv ( "GIS_LOCK" );
if ( !gis_lock )
- G_fatal_error ( _("Cannot read GIS_LOCK enviroment variable.") );
+ G_fatal_error ( _("Unable to read GIS_LOCK enviroment variable") );
G_asprintf ( &lock_prog, "%s/etc/lock", G_gisbase() );
@@ -141,11 +141,11 @@
/* Warning: the value returned by system() is not that returned by exit() in executed program
* e.g. exit(1) -> 256 (multiplied by 256) */
if ( ret != 0 )
- G_fatal_error ( _("%s is currently running GRASS in selected mapset or lock file cannot be checked."),
+ G_fatal_error ( _("%s is currently running GRASS in selected mapset or lock file cannot be checked"),
G_whoami());
/* Erase monitors */
- G_message ( _("Erasing monitors ..." ));
+ G_message ( _("Erasing monitors..." ));
while ((cap = R_parse_monitorcap(MON_NEXT,"")) != NULL) {
G__setenv("MONITOR",cap->name);
R__open_quiet();
@@ -161,7 +161,7 @@
/* Clean temporary directory */
sprintf(path, "%s/etc/clean_temp", G_gisbase());
- G_message ( _("Cleaning up temporary files ..." ));
+ G_message ( _("Cleaning up temporary files..." ));
G_spawn(path, "clean_temp", NULL);
/* Reset variables */
@@ -175,7 +175,7 @@
G_free( mapset_old_path );
- G_warning ( _("Your shell continues to use the history for the old mapset.") );
+ G_warning ( _("Your shell continues to use the history for the old mapset") );
if ( (shell=getenv("SHELL")) ) {
if ( strstr(shell,"bash") ) {
@@ -192,4 +192,3 @@
return (EXIT_SUCCESS);
