[GRASS-SVN] r30592 - in grass-addons/gipe: . i.latitude i.longitude r.vic_soil
Sun Mar 16 22:39:57 EDT 2008
Author: ychemin
Date: 2008-03-16 22:39:57 -0400 (Sun, 16 Mar 2008)
New Revision: 30592
Added:
   grass-addons/gipe/r.vic_soil/
   grass-addons/gipe/r.vic_soil/Makefile
   grass-addons/gipe/r.vic_soil/description.html
   grass-addons/gipe/r.vic_soil/main.c
   grass-addons/gipe/i.latitude/main.c
   grass-addons/gipe/i.longitude/main.c
updated some prog. style in i.longitude/i.latitude, added a VIC dummy soil file creator: r.vic_soil
Modified: grass-addons/gipe/i.latitude/main.c
--- grass-addons/gipe/i.latitude/main.c	2008-03-16 19:55:34 UTC (rev 30591)
+++ grass-addons/gipe/i.latitude/main.c	2008-03-17 02:39:57 UTC (rev 30592)
@@ -19,8 +19,6 @@
 #include <grass/gprojects.h>
 #include <grass/glocale.h>
 int main(int argc, char *argv[])
 	struct Cell_head cellhd; //region+header info
@@ -66,35 +64,26 @@
 	module->description = _("creates a longitude map");
 	/* Define the different options */
-	input1 = G_define_option() ;
+	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input1->key	   = _("input");
-	input1->type       = TYPE_STRING;
-	input1->required   = YES;
-	input1->gisprompt  =_("old,cell,raster") ;
 	input1->description=_("Name of the input map");
 	input1->answer     =_("input");
-	output1 = G_define_option() ;
+	output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
 	output1->key        =_("longitude");
-	output1->type       = TYPE_STRING;
-	output1->required   = YES;
-	output1->gisprompt  =_("new,cell,raster");
 	output1->description=_("Name of the output longitude layer");
 	output1->answer     =_("longitude");
 	flag1 = G_define_flag();
 	flag1->key = 'q';
 	flag1->description = _("Quiet");
 	if (G_parser(argc, argv))
 		exit (EXIT_FAILURE);
 	in	 	= input1->answer;
-	result1  = output1->answer;
-	verbose = (!flag1->answer);
+	result1  	= output1->answer;
+	verbose 	= (!flag1->answer);
 	mapset = G_find_cell2(in, "");
 	if (mapset == NULL) {
Modified: grass-addons/gipe/i.longitude/main.c
--- grass-addons/gipe/i.longitude/main.c	2008-03-16 19:55:34 UTC (rev 30591)
+++ grass-addons/gipe/i.longitude/main.c	2008-03-17 02:39:57 UTC (rev 30592)
@@ -66,22 +66,15 @@
 	flag1->key = 'q';
@@ -92,9 +85,8 @@
Added: grass-addons/gipe/r.vic_soil/Makefile
--- grass-addons/gipe/r.vic_soil/Makefile	                        (rev 0)
+++ grass-addons/gipe/r.vic_soil/Makefile	2008-03-17 02:39:57 UTC (rev 30592)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = r.vic_soil
+LIBES =  $(GPROJLIB) $(GISLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP)
+EXTRA_INC = $(PROJINC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/r.vic_soil/description.html
--- grass-addons/gipe/r.vic_soil/description.html	                        (rev 0)
+++ grass-addons/gipe/r.vic_soil/description.html	2008-03-17 02:39:57 UTC (rev 30592)
@@ -0,0 +1,22 @@
+<H2>DESCRIPTION</H2>
+<EM>r.vic_soil</EM> creates a VIC hydrological model soil input ascii file.
+This is an input to VIC (Variable Infiltration Capacity).
+<H2>NOTES</H2>
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin<BR>
+<p>
+<i>Last changed: $Date: 2007/06/09 22:19:55 $</i>
Added: grass-addons/gipe/r.vic_soil/main.c
--- grass-addons/gipe/r.vic_soil/main.c	                        (rev 0)
+++ grass-addons/gipe/r.vic_soil/main.c	2008-03-17 02:39:57 UTC (rev 30592)
@@ -0,0 +1,173 @@
+ * MODULE:       r.vic_soil
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Creates a VIC soil input file.
+ * 		 Filling only lat/long and add dummy data from VIC website.
+ * 		 Will add raster layer input as they become available later.
+ * 		 Like soil texture, etc...
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+	struct Cell_head cellhd; //region+header info
+	char *mapset; // mapset name
+	int nrows, ncols;
+	int row,col;
+	int verbose=1;
+	int not_ll=0;//if proj is not lat/long, it will be 1.
+	struct GModule *module;
+	struct Option *input1, *output1;
+	struct Flag *flag1;
+	struct History history; //metadata
+	struct pj_info iproj;
+	struct pj_info oproj;
+	/* FMEO Declarations*****************/
+	char 	*name;   	// input raster name
+	char 	*result1; 	//output raster name
+	//File Descriptors
+	int 	infd;
+	char 	*in;
+	int 	i=0,j=0;
+	double 	xp, yp;
+	double 	xmin, ymin;
+	double 	xmax, ymax;
+	double 	stepx,stepy;
+	double 	latitude, longitude;
+	void 			*inrast;
+	RASTER_MAP_TYPE 	data_type_inrast;
+	FILE	*f; 		// output ascii file
+	int 	process; 	// process grid cell switch
+	int 	grid_count; 	// grid cell count
+	char 	*dummy_data1; 	// dummy data part 1
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("VIC, hydrology, soil");
+	module->description = _("creates a soil ascii file taking lat/long from a map");
+	/* Define the different options */
+	input1->key	   = _("input");
+	input1->description=_("Name of the input map to take the lat/lon from");
+	input1->answer     =_("input");
+	output1 = G_define_option() ;
+	output1->key        =_("output");
+	output1->description=_("Name of the output vic soil ascii file");
+	output1->answer     =_("vic_soil");
+	if (G_parser(argc, argv))
+		exit (EXIT_FAILURE);
+	in	 	= input1->answer;
+	mapset = G_find_cell2(in, "");
+	if (mapset == NULL) {
+		G_fatal_error(_("cell file [%s] not found"), in);
+	data_type_inrast = G_raster_map_type(in,mapset);
+	if ( (infd = G_open_cell_old (in,mapset)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"), in);
+	if (G_get_cellhd (in, mapset, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s])"), in);
+	inrast = G_allocate_raster_buf(data_type_inrast);
+	G_debug(3, "number of rows %d",cellhd.rows);
+	stepx=cellhd.ew_res;
+	stepy=cellhd.ns_res;
+	xmin=cellhd.west;
+	xmax=cellhd.east;
+	ymin=cellhd.south;
+	ymax=cellhd.north;
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	/*Initialize grid cell process switch*/
+	f=fopen(result1,"w");
+	/*If =1 then process, if =0 then skip*/
+	process = 1;
+	/*Initialize grid cell count*/
+	grid_count = 1;
+	/*Initialize output file */
+	fprintf(f,"#RUN\tGRID\tLAT\tLNG\tINFILT\tDs\tDs_MAX\tWs\tC\tEXPT_1\tEXPT_2\tEXPT_3\tKsat_1\tKsat_2\tKsat_3\tPHI_1\tPHI_2\tPHI_3\tMOIST_1\tMOIST_2\tMOIST_3\tELEV\tDEPTH_1\tDEPTH_2\tDEPTH_3\tAVG_T\tDP\tBUBLE1\tBUBLE2\tBUBLE3\tQUARZ1\tQUARZ2\tQUARZ3\tBULKDN1\tBULKDN2\tBULKDN3\tPARTDN1\tPARTDN2\tPARTDN3\tOFF_GMT\tWcrFT1\tWcrFT2\tWcrFT3\tWpFT1\tWpFT2\tWpFT3\tZ0_SOIL\tZ0_SNOW\tPRCP\tRESM1\tRESM2\tRESM3\tFS_ACTV\tJULY_TAVG\n");
+	/*Initialize dummy data*/
+	dummy_data1 = "0.010\t1.e-4\t3.05\t0.93\t2\t4.0\t4.0\t4.0\t250.0\t250.0\t250.0\t-999\t-999\t-999\t0.4\t0.4\t0.4\t306.3\t0.1\t6.90\t2.000\t14.0\t4.0\t75.0\t75.0\t75.0\t0.24\t0.24\t0.24\t1306\t1367\t1367\t2650\t2650\t2650\t-6\t0.330\t0.330\t0.330\t0.133\t0.133\t0.133\t0.001\t0.010\t500\t0.02\t0.02\t0.02\t1\t18.665\n";
+	//Shamelessly stolen from r.sun !!!!
+	/* Set up parameters for projection to lat/long if necessary */
+	if ((G_projection() != PROJECTION_LL)) {
+		not_ll=1;
+		struct Key_Value *in_proj_info, *in_unit_info;
+		if ((in_proj_info = G_get_projinfo()) == NULL)
+			G_fatal_error(_("Can't get projection info of current location"));
+		if ((in_unit_info = G_get_projunits()) == NULL)
+			G_fatal_error(_("Can't get projection units of current location"));
+		if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+			G_fatal_error(_("Can't get projection key values of current location"));
+		G_free_key_value(in_proj_info);
+		G_free_key_value(in_unit_info);
+		/* Set output projection to latlong w/ same ellipsoid */
+		oproj.zone = 0;
+		oproj.meters = 1.;
+		sprintf(oproj.proj, "ll");
+		if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+			G_fatal_error(_("Unable to set up lat/long projection parameters"));
+	}//End of stolen from r.sun :P
+	for (row = 0; row < nrows/100; row++)
+		G_percent(row,nrows,2);
+		if(G_get_raster_row(infd,inrast,row,data_type_inrast)<0)
+			G_fatal_error(_("Could not read from <%s>"),in);
+		for (col=0; col < ncols; col++)
+			latitude = ymax - ( row * stepy );
+			longitude = xmin + ( col * stepx );
+			if(not_ll){
+				if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+				    G_fatal_error(_("Error in pj_do_proj"));
+			}else{
+				//Do nothing
+			fprintf(f,"%d\t%d\t%6.3f\t%7.3f\t%s\n", process, grid_count, latitude, longitude, dummy_data1);
+			grid_count=grid_count+1;
+	G_free (inrast);
+	G_close_cell (infd);
+	fclose(f);
+	exit(EXIT_SUCCESS);
