[GRASS-SVN] r30594 - grass-addons/gipe/r.vic_soil
svn_grass at osgeo.org
Mon Mar 17 00:09:26 EDT 2008
Author: ychemin
Date: 2008-03-17 00:09:26 -0400 (Mon, 17 Mar 2008)
New Revision: 30594
grass-addons/gipe/r.vic_soil/main.c
updated r.vic_soil with elevation input map
Modified: grass-addons/gipe/r.vic_soil/main.c
--- grass-addons/gipe/r.vic_soil/main.c 2008-03-17 03:42:42 UTC (rev 30593)
+++ grass-addons/gipe/r.vic_soil/main.c 2008-03-17 04:09:26 UTC (rev 30594)
@@ -50,8 +50,6 @@
char *result1; //output raster name
//File Descriptors
int infd;
- //Raster pointer
- DCELL *inrast_elevation;
char *in;
int i=0,j=0;
@@ -61,8 +59,8 @@
double stepx,stepy;
double latitude, longitude;
- void *inrast;
- RASTER_MAP_TYPE data_type_inrast;
+ void *inrast_elevation;
+ RASTER_MAP_TYPE data_type_inrast_elevation;
FILE *f; // output ascii file
int process; // process grid cell switch
@@ -75,7 +73,7 @@
module = G_define_module();
module->keywords = _("VIC, hydrology, soil");
- module->description = _("creates a soil ascii file taking lat/long from a map");
+ module->description = _("creates a soil ascii file taking elevation and lat/long from an elevation map");
/* Define the different options */
input1 = G_define_standard_option(G_OPT_R_INPUT) ;
@@ -99,12 +97,12 @@
if (mapset == NULL) {
G_fatal_error(_("cell file [%s] not found"), in);
- data_type_inrast = G_raster_map_type(in,mapset);
+ data_type_inrast_elevation = G_raster_map_type(in,mapset);
if ( (infd = G_open_cell_old (in,mapset)) < 0)
G_fatal_error (_("Cannot open cell file [%s]"), in);
if (G_get_cellhd (in, mapset, &cellhd) < 0)
G_fatal_error (_("Cannot read file header of [%s])"), in);
- inrast = G_allocate_raster_buf(data_type_inrast);
+ inrast_elevation = G_allocate_raster_buf(data_type_inrast_elevation);
G_debug(3, "number of rows %d",cellhd.rows);
@@ -116,9 +114,6 @@
ymin=cellhd.south;
ymax=cellhd.north;
- /*Allocate input buffer*/
- inrast_elevation = G_allocate_d_raster_buf();
nrows = G_window_rows();
ncols = G_window_cols();
@@ -158,11 +153,11 @@
G_fatal_error(_("Unable to set up lat/long projection parameters"));
}//End of stolen from r.sun :P
- for (row = 0; row < nrows/100; row++)
+ for (row = 0; row < nrows; row++)
DCELL d_elevation;
G_percent(row,nrows,2);
- if(G_get_raster_row(infd,inrast,row,data_type_inrast)<0)
+ if(G_get_raster_row(infd,inrast_elevation,row,data_type_inrast_elevation)<0)
G_fatal_error(_("Could not read from <%s>"),in);
for (col=0; col < ncols; col++)
@@ -177,7 +172,7 @@
//Do nothing
/*Extract elevation data*/
- switch(data_type_inrast){
+ switch(data_type_inrast_elevation){
case CELL_TYPE:
d_elevation = (double) ((CELL *) inrast_elevation)[col];
break;
@@ -188,12 +183,13 @@
d_elevation = ((DCELL *) inrast_elevation)[col];
break;
+ printf("%7.2f\n",d_elevation);
/*Print to ascii file*/
fprintf(f,"%d\t%d\t%6.3f\t%7.3f\t%s\t%7.2f\t%s\n", process, grid_count, latitude, longitude, dummy_data1, d_elevation, dummy_data2);
grid_count=grid_count+1;
- G_free (inrast);
+ G_free (inrast_elevation);
G_close_cell (infd);
fclose(f);
exit(EXIT_SUCCESS);
