[GRASS-SVN] r30603 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Mar 17 11:28:21 EDT 2008
Author: martinl
Date: 2008-03-17 11:28:21 -0400 (Mon, 17 Mar 2008)
New Revision: 30603
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI (wxgui_utils): Hide wx.SpinCtrl (change map layer opacity level) in layer item by default. Can be activated from contextual menu. The opacity level is displayed in wx.StaticText widget if differs from 100%.
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-03-17 14:27:04 UTC (rev 30602)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-03-17 15:28:21 UTC (rev 30603)
@@ -51,6 +51,7 @@
'general': {
'mapsetPath' : { 'selection' : 0 }, # current mapset search path
+ 'changeOpacityLevel' : { 'enabled' : False }, # show opacity level widget
# display
@@ -431,6 +432,31 @@
sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
+ # Layer Manager settings
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Layer Manager settings"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ gridSizer = wx.GridBagSizer (hgap=3, vgap=3)
+ gridSizer.AddGrowableCol(0)
+ # show opacily level
+ row = 0
+ changeOpacityLevel = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("Opacity level editable"),
+ name='IsChecked')
+ changeOpacityLevel.SetValue(self.settings.Get(group='general', key='changeOpacityLevel', subkey='enabled'))
+ self.winId['general:changeOpacityLevel:enabled'] = changeOpacityLevel.GetId()
+ gridSizer.Add(item=changeOpacityLevel,
+ pos=(row, 0), span=(1, 2))
+ sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+ border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
panel.SetSizer(border)
return panel
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-17 14:27:04 UTC (rev 30602)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-17 15:28:21 UTC (rev 30603)
@@ -691,7 +691,7 @@
return self.mapfile
def AddLayer(self, type, command, name=None,
- l_active=True, l_hidden=False, l_opacity=1, l_render=False):
+ l_active=True, l_hidden=False, l_opacity=1.0, l_render=False):
Adds generic display command layer to list of layers
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-17 14:27:04 UTC (rev 30602)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-17 15:28:21 UTC (rev 30603)
@@ -5,10 +5,6 @@
* AbstractLayer
* Layer
* LayerTree
- * GMConsole
- * GMStdout
- * GMStrerr
- * GMStc
* LoadMapLayersDialog
PURPOSE: Utility classes for GRASS wxPython GUI. Main functions include tree control
@@ -69,10 +65,11 @@
### SetAutoLayout() causes that no vertical scrollbar is displayed
### when some layers are not visible in layer tree
- # self.SetAutoLayout(True)
+ self.SetAutoLayout(True)
self.SetGradientStyle(1)
self.EnableSelectionGradient(True)
- self.SetFirstGradientColour(wx.Colour(150, 150, 150))
+ self.SetFirstGradientColour(wx.Colour(100, 100, 100))
+ self.SetSecondGradientColour(wx.Colour(150, 150, 150))
self.Map = render.Map() # instance of render.Map to be associated with display
self.root = None # ID of layer tree root node
@@ -107,7 +104,7 @@
self.mapdisplay.Refresh()
self.mapdisplay.Update()
- self.root = self.AddRoot("Map Layers")
+ self.root = self.AddRoot(_("Map Layers"))
self.SetPyData(self.root, (None,None))
#create image list to use with layer tree
@@ -177,7 +174,7 @@
self.Bind(wx.EVT_TREE_DELETE_ITEM, self.OnDeleteLayer)
self.Bind(wx.EVT_TREE_BEGIN_DRAG, self.OnBeginDrag)
self.Bind(wx.EVT_TREE_END_DRAG, self.OnEndDrag)
- self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnContextMenu)
+ self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnLayerContextMenu)
self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnChangeLayerName)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
# self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
@@ -194,9 +191,8 @@
"""Change layer name"""
Debug.msg (3, "LayerTree.OnChangeLayerName: name=%s" % event.GetLabel())
- def OnContextMenu (self, event):
- """Context Layer Menu"""
+ def OnLayerContextMenu (self, event):
+ """Contextual menu for item/layer"""
if not self.layer_selected:
event.Skip()
return
@@ -217,6 +213,7 @@
self.popupID5 = wx.NewId()
self.popupID6 = wx.NewId()
self.popupID7 = wx.NewId()
+ self.popupID8 = wx.NewId()
self.popupMenu = wx.Menu()
# general item
@@ -231,6 +228,13 @@
if ltype != "group" and \
ltype != "command": # properties
self.popupMenu.AppendSeparator()
+ self.popupMenu.Append(self.popupID8, text=_("Change opacity level"), kind=wx.ITEM_CHECK)
+ if self.FindWindowById(self.GetPyData(self.layer_selected)[0]['ctrl']).GetName() == 'spinCtrl':
+ checked = True
+ else:
+ checked = False
+ self.popupMenu.Check(self.popupID8, checked)
+ self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id=self.popupID8)
self.popupMenu.Append(self.popupID3, text=_("Properties"))
self.Bind(wx.EVT_MENU, self.OnPopupProperties, id=self.popupID3)
@@ -368,6 +372,34 @@
"""Popup properties dialog"""
self.PropertiesDialog(self.layer_selected)
+ def OnPopupOpacityLevel(self, event):
+ """Popup opacity level indicator"""
+ if not self.GetPyData(self.layer_selected)[0]['ctrl']:
+ return
+ win = self.FindWindowById(self.GetPyData(self.layer_selected)[0]['ctrl'])
+ type = win.GetName()
+ self.layer_selected.DeleteWindow()
+ opacity = self.GetPyData(self.layer_selected)[0]['maplayer'].GetOpacity()
+ if type == 'staticText':
+ ctrl = wx.SpinCtrl(self, id=wx.ID_ANY, value="", pos=(30, 50),
+ style=wx.SP_ARROW_KEYS, initial=100, min=0, max=100,
+ name='spinCtrl')
+ ctrl.SetValue(opacity)
+ self.Bind(wx.EVT_SPINCTRL, self.OnOpacity, ctrl)
+ else:
+ ctrl = wx.StaticText(self, id=wx.ID_ANY,
+ name='staticText')
+ if opacity < 100:
+ ctrl.SetLabel('(' + str(opacity) + '%)')
+ self.GetPyData(self.layer_selected)[0]['ctrl'] = ctrl.GetId()
+ self.layer_selected.SetWindow(ctrl)
+ self.Refresh()
def RenameLayer (self, event):
"""Rename layer"""
self.EditLabel(self.layer_selected)
@@ -378,6 +410,7 @@
Note: lcmd is given as a list
self.first = True
params = {} # no initial options parameters
@@ -397,15 +430,19 @@
elif ltype == 'group':
# group item
ctrl = None
- grouptext = 'Layer group:' + str(self.groupnode)
+ grouptext = _('Layer group:') + str(self.groupnode)
self.groupnode += 1
else:
# all other items (raster, vector, ...)
- ctrl = wx.SpinCtrl(self, id=wx.ID_ANY, value="", pos=(30, 50),
- style=wx.SP_ARROW_KEYS, initial=100, min=0, max=100)
- self.Bind(wx.EVT_SPINCTRL, self.OnOpacity, ctrl)
+ if UserSettings.Get(group='general', key='changeOpacityLevel', subkey='enabled'):
+ name='spinCtrl')
+ else:
# add layer to the layer tree
if self.layer_selected and self.layer_selected != self.GetRootItem():
if self.GetPyData(self.layer_selected)[0]['type'] != 'group':
@@ -442,43 +479,43 @@
# add text and icons for each layer ltype
if ltype == 'raster':
self.SetItemImage(layer, self.rast_icon)
- self.SetItemText(layer, 'raster (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('raster'), _('(double click to set properties)')))
elif ltype == 'rgb':
self.SetItemImage(layer, self.rgb_icon)
- self.SetItemText(layer, 'RGB (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('RGB'), _('(double click to set properties)')))
elif ltype == 'his':
self.SetItemImage(layer, self.his_icon)
- self.SetItemText(layer, 'HIS (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('HIS'), _('(double click to set properties)')))
elif ltype == 'shaded':
self.SetItemImage(layer, self.shaded_icon)
- self.SetItemText(layer, 'Shaded relief (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('Shaded relief'), _('(double click to set properties)')))
elif ltype == 'rastnum':
self.SetItemImage(layer, self.rnum_icon)
- self.SetItemText(layer, 'raster cell numbers (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('raster cell numbers'), _('(double click to set properties)')))
elif ltype == 'rastarrow':
self.SetItemImage(layer, self.rarrow_icon)
- self.SetItemText(layer, 'raster flow arrows (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('raster flow arrows'), _('(double click to set properties)')))
elif ltype == 'vector':
self.SetItemImage(layer, self.vect_icon)
- self.SetItemText(layer, 'vector (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('vector'), _('(double click to set properties)')))
elif ltype == 'thememap':
self.SetItemImage(layer, self.theme_icon)
- self.SetItemText(layer, 'thematic map (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('thematic map'), _('(double click to set properties)')))
elif ltype == 'themechart':
self.SetItemImage(layer, self.chart_icon)
- self.SetItemText(layer, 'thematic charts (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('thematic charts'), _('(double click to set properties)')))
elif ltype == 'grid':
self.SetItemImage(layer, self.grid_icon)
- self.SetItemText(layer, 'grid (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('grid'), _('(double click to set properties)')))
elif ltype == 'geodesic':
self.SetItemImage(layer, self.geodesic_icon)
- self.SetItemText(layer, 'geodesic line (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('geodesic line'), _('(double click to set properties)')))
elif ltype == 'rhumb':
self.SetItemImage(layer, self.rhumb_icon)
- self.SetItemText(layer, 'rhumbline (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('rhumbline'), _('(double click to set properties)')))
elif ltype == 'labels':
self.SetItemImage(layer, self.labels_icon)
- self.SetItemText(layer, 'vector labels (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('vector labels'), _('(double click to set properties)')))
elif ltype == 'command':
self.SetItemImage(layer, self.cmd_icon)
@@ -490,7 +527,11 @@
if ltype != 'group':
if lopacity:
opacity = lopacity
- ctrl.SetValue(int(lopacity * 100))
+ ctrl.SetValue(int(lopacity * 100))
+ else:
+ if opacity < 1.0:
+ ctrl.SetLabel('(' + str(int(opacity * 100)) + '%)')
else:
opacity = 1.0
if lcmd and len(lcmd) > 1:
@@ -502,10 +543,15 @@
render = False
name = None
+ if ctrl:
+ ctrlId = ctrl.GetId()
+ else:
+ ctrlId = None
# add a data object to hold the layer's command (does not apply to generic command layers)
self.SetPyData(layer, ({'cmd': cmd,
'type' : ltype,
- 'ctrl' : ctrl,
+ 'ctrl' : ctrlId,
'maplayer' : None,
'prowin' : None},
None))
@@ -684,7 +730,7 @@
def OnCmdChanged(self, event):
"""Change command string"""
- ctrl = event.GetEventObject()
+ ctrl = event.GetEventObject().GetId()
cmd = event.GetString()
layer = None
@@ -714,7 +760,7 @@
Debug.msg (3, "LayerTree.OnOpacity(): %s" % event.GetInt())
maplayer = None
vislayer = self.GetFirstVisibleItem()
@@ -789,6 +835,15 @@
Debug.msg (4, "LayerTree.RecreateItem(): layer=%s" % \
self.GetItemText(oldItem))
+ # fetch data (olditem)
+ text = self.GetItemText(oldItem)
+ image = self.GetItemImage(oldItem, 0)
+ if self.GetPyData(oldItem)[0]['ctrl']:
+ oldctrl = self.FindWindowById(self.GetPyData(oldItem)[0]['ctrl'])
+ else:
+ oldctrl = None
+ checked = self.IsItemChecked(oldItem)
# recreate spin/text control for layer
if self.GetPyData(oldItem)[0]['type'] == 'command':
newctrl = wx.TextCtrl(self, id=wx.ID_ANY, value='',
@@ -800,16 +855,21 @@
pass
newctrl.Bind(wx.EVT_TEXT_ENTER, self.OnCmdChanged)
newctrl.Bind(wx.EVT_TEXT, self.OnCmdChanged)
- elif self.GetPyData(oldItem)[0]['type'] == 'group':
+ elif self.GetPyData(oldItem)[0]['type'] == 'group' or oldctrl is None:
newctrl = None
else:
- newctrl = wx.SpinCtrl(self, id=wx.ID_ANY, value="", pos=(30, 50),
- style=wx.SP_ARROW_KEYS, min=0, max=100)
- try:
- newctrl.SetValue(self.GetPyData(oldItem)[0]['maplayer'].GetOpacity())
- except:
- newctrl.SetValue(100)
- self.Bind(wx.EVT_SPINCTRL, self.OnOpacity, newctrl)
+ opacity = self.GetPyData(oldItem)[0]['maplayer'].GetOpacity()
+ if oldctrl.GetName() == 'staticText':
+ newctrl = wx.StaticText(self, id=wx.ID_ANY,
+ if opacity < 100:
+ newctrl.SetLabel('(' + str(opacity) + '%)')
+ else:
+ newctrl = wx.SpinCtrl(self, id=wx.ID_ANY, value="", pos=(30, 50),
+ style=wx.SP_ARROW_KEYS, min=0, max=100,
+ name='spinCtrl')
+ newctrl.SetValue(opacity)
+ self.Bind(wx.EVT_SPINCTRL, self.OnOpacity, newctrl)
# decide where to put new layer and put it there
if not parent:
@@ -817,16 +877,11 @@
else:
flag = 0
- # fetch data
- text = self.GetItemText(oldItem)
- image = self.GetItemImage(oldItem, 0)
- wind = self.GetItemWindow(oldItem)
- checked = self.IsItemChecked(oldItem)
windval = None
data = None
else:
- windval = self.GetItemWindow(oldItem).GetValue()
+ windval = self.GetPyData(self.layer_selected)[0]['maplayer'].GetOpacity()
data = self.GetPyData(oldItem)
# create GenericTreeItem instance
@@ -859,8 +914,11 @@
# add layer at new position
self.SetPyData(newItem, self.GetPyData(oldItem))
- self.GetPyData(newItem)[0]['ctrl'] = newctrl
+ if newctrl:
+ self.GetPyData(newItem)[0]['ctrl'] = newctrl.GetId()
+ else:
+ self.GetPyData(newItem)[0]['ctrl'] = None
self.CheckItem(newItem, checked=checked)
event.Skip()
@@ -895,7 +953,11 @@
self.Expand(newItem)
# delete layer at original position
- self.Delete(old) # entry in render.Map layers list automatically deleted by OnDeleteLayer handler
+ try:
+ self.Delete(old) # entry in render.Map layers list automatically deleted by OnDeleteLayer handler
+ except AttributeError:
+ # FIXME being ugly (item.SetWindow(None))
+ pass
# reorder layers in render.Map to match new order after drag and drop
self.ReorderLayers()
@@ -962,15 +1024,16 @@
type = self.GetPyData(item)[0]['type']
if type == 'command':
- if self.GetItemWindow(item).GetValue() != None:
- cmdlist = self.GetItemWindow(item).GetValue().split(' ')
+ win = self.FindWindowById(self.GetPyData(item)[0]['ctrl'])
+ if win.GetValue() != None:
+ cmdlist = win.GetValue().split(' ')
opac = 1.0
chk = self.IsItemChecked(item)
hidden = not self.IsVisible(item)
elif type != 'group':
if self.GetPyData(item)[0] is not None:
cmdlist = self.GetPyData(item)[0]['cmd']
- opac = float(self.GetItemWindow(item).GetValue())/100
+ opac = self.GetPyData(item)[0]['maplayer'].GetOpacity(float=True)
maplayer = self.Map.ChangeLayer(layer=self.GetPyData(item)[0]['maplayer'], type=type,
@@ -987,6 +1050,8 @@
if self.mapdisplay.autoRender.GetValue():
self.mapdisplay.OnRender(None)
+ self.Refresh()
def setNotebookPage(self,pg):
self.parent.notebook.SetSelection(pg)
