[GRASS-SVN] r30606 - grass/trunk/gui/wxpython
svn_grass at osgeo.org
Mon Mar 17 16:59:44 EDT 2008
Author: martinl
Date: 2008-03-17 16:59:44 -0400 (Mon, 17 Mar 2008)
New Revision: 30606
grass/trunk/gui/wxpython/README
wxGUI: README updated
Modified: grass/trunk/gui/wxpython/README
--- grass/trunk/gui/wxpython/README 2008-03-17 19:26:03 UTC (rev 30605)
+++ grass/trunk/gui/wxpython/README 2008-03-17 20:59:44 UTC (rev 30606)
@@ -1,8 +1,10 @@
wxPython GRASS Graphical User Interface
-0 - REQUIREMENTS
+$Date$
+1 - REQUIREMENTS
GRASS GIS >= 6.3
Python >= 2.4
wxPython >= 2.8.1.1
@@ -36,19 +38,9 @@
python-wxgtk2.8 wx2.8-doc wx2.8-examples \
wx2.8-headers wx2.8-i18n
-1 - INSTALLATION
-Go to:
-$ cd gui/wxpython
-and run
-$ make
2 - STARTUP WITH GRASS INITIALIZATION
-If you want to run wxPython GUI automatically when you start
+If you want to launch wxPython GUI automatically when you start
GRASS, edit your .grassrc6 file to replace
GRASS_GUI: tcktk (or whatever you have here)
@@ -59,11 +51,11 @@
or easier start new GRASS session with -wxpython switch.
-$ grass -wxpython
+$ grass63 -wxpython
3 - STARTUP FROM GRASS TERMINAL
-Simply type
+Simply run
$ g.gui wxpython
@@ -71,11 +63,11 @@
You can also specify workspace file to load on startup.
-$ g.gui gui=wxpython workspace=myworkspace.grc
+$ g.gui gui=wxpython workspace=myworkspace.gxw
4 - CLI Display scripts
-Note: This section is out-dated.
+Note: This section is out-dated!
This is going to be replacement for command line tools like d.rast and
d.vect.
@@ -122,23 +114,24 @@
5 - DEBUGGING
-To enable GUI debugging messages on given level set GRASS_DEBUG_WX
-environment variables, e.g.
+To enable GUI debug messages on given level set GRASS_DEBUG_WX
+environment variable, e.g.
$ export GRASS_WX_DEBUG=3
6 - ICON THEMES
Currently two icon themes are available:
* original GRASS (based on TCL/TK GUI prototype)
- * Silk-based
+ * Silk-based (default)
User can change icon theme in Preferences dialog
('Config->Preferences').
7 - DIGITIZATION TOOL
-To enable digitization tool you need to compile 'vdigit'
+To enable digitizer you need to compile 'vdigit'
component. Note that you must configure GRASS with C++ (--with-cxx),
Python (--with-python) and wxWidgets (--with-wxwidgets) support.
@@ -150,10 +143,10 @@
$ sudo ln -s /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so /usr/local/lib/libgdi.so
-Make sure you set up LD_LIBRARY_PATH or noted '/usr/local/lib' in
-/etc/ld.so.conf.
+Then update LD_LIBRARY_PATH or add '/usr/local/lib' to /etc/ld.so.conf
+(in this case run 'sudo ldconfig').
-$ sudo ldconfig
+TODO: Don't use direct linking here.
Then you can compile the driver
