[GRASS-SVN] r30608 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Mar 17 17:26:09 EDT 2008
Author: martinl
Date: 2008-03-17 17:26:09 -0400 (Mon, 17 Mar 2008)
New Revision: 30608
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: recycle GUI dialogs in Layer Manager (for selected map layer)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-03-17 21:02:43 UTC (rev 30607)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-03-17 21:26:09 UTC (rev 30608)
@@ -796,10 +796,10 @@
def OnCancel(self, event):
"""Cancel button pressed"""
self.MakeModal(False)
- # update only propwin reference
- self.get_dcmd(dcmd=None, layer=self.layer, params=None,
- propwin=None)
- self.Destroy()
+ if self.get_dcmd:
+ self.Hide()
+ else:
+ self.Destroy()
def OnCloseWindow(self, event):
"""Close the main window"""
@@ -883,10 +883,12 @@
# are we running from command line?
### add 'command output' tab regardless standalone dialog
- # if standalone:
- self.goutput = goutput.GMConsole(parent=self, margin=False)
- self.outpage = self.notebook.AddPage(self.goutput, text=_("Command output") )
- self.outpageid = self.notebook.GetPageCount() - 1
+ if self.parent.get_dcmd is None:
+ self.goutput = goutput.GMConsole(parent=self, margin=False)
+ self.outpage = self.notebook.AddPage(self.goutput, text=_("Command output") )
+ self.outpageid = self.notebook.GetPageCount() - 1
+ else:
+ self.goutput = None
manual_tab = helpPanel( parent = self.notebook, grass_command = self.task.name)
if manual_tab.Ok:
@@ -1172,7 +1174,7 @@
# TODO: be less arbitrary with these 600
self.panelMinHeight = 100
- self.constrained_size = (min(600, maxsizes[0]) + 25, min(600, maxsizes[1]))
+ self.constrained_size = (min(600, maxsizes[0]) + 25, min(600, maxsizes[1]) + 25)
for section in sections:
tab[section].SetMinSize( (self.constrained_size[0], self.panelMinHeight) )
# tab[section].SetMinSize( constrained_size )
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-17 21:02:43 UTC (rev 30607)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-17 21:26:09 UTC (rev 30608)
@@ -15,7 +15,7 @@
Jachym Cepicky (Mendel University of Agriculture)
Martin Landa <landa.martin gmail.com>
-COPYRIGHT: (C) 2007 by the GRASS Development Team
+COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -591,13 +591,14 @@
def PropertiesDialog (self, layer, show=True):
"""Launch the properties dialog"""
if self.GetPyData(layer)[0].has_key('propwin') and \
self.GetPyData(layer)[0]['propwin'] is not None:
- # avoid duplicated GUI dialog for given map layer
+ # recycle GUI dialogs
if self.GetPyData(layer)[0]['propwin'].IsShown():
self.GetPyData(layer)[0]['propwin'].SetFocus()
- return
+ else:
+ self.GetPyData(layer)[0]['propwin'].Show()
+ return
completed = ''
params = self.GetPyData(layer)[1]
