[GRASS-SVN] r30610 - in grass-addons/gipe: . r.out.vic_mask r.out.vic_veg
Tue Mar 18 01:01:49 EDT 2008
Author: ychemin
Date: 2008-03-18 01:01:49 -0400 (Tue, 18 Mar 2008)
New Revision: 30610
Added:
   grass-addons/gipe/r.out.vic_mask/
   grass-addons/gipe/r.out.vic_mask/Makefile
   grass-addons/gipe/r.out.vic_mask/description.html
   grass-addons/gipe/r.out.vic_mask/main.c
   grass-addons/gipe/r.out.vic_veg/main.c
Added r.out.vic_mask, watershed mask ascii file creation for VIC hydrological model
Added: grass-addons/gipe/r.out.vic_mask/Makefile
--- grass-addons/gipe/r.out.vic_mask/Makefile	                        (rev 0)
+++ grass-addons/gipe/r.out.vic_mask/Makefile	2008-03-18 05:01:49 UTC (rev 30610)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = r.out.vic_mask
+LIBES =  $(GPROJLIB) $(GISLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP)
+EXTRA_INC = $(PROJINC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/r.out.vic_mask/description.html
--- grass-addons/gipe/r.out.vic_mask/description.html	                        (rev 0)
+++ grass-addons/gipe/r.out.vic_mask/description.html	2008-03-18 05:01:49 UTC (rev 30610)
@@ -0,0 +1,22 @@
+<H2>DESCRIPTION</H2>
+<EM>r.out.vic_mask</EM> creates a VIC hydrological model watershed basin maskinput ascii file.
+This is an input to VIC (Variable Infiltration Capacity).
+<H2>NOTES</H2>
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin<BR>
+<p>
+<i>Last changed: $Date: 2007/06/09 22:19:55 $</i>
Added: grass-addons/gipe/r.out.vic_mask/main.c
--- grass-addons/gipe/r.out.vic_mask/main.c	                        (rev 0)
+++ grass-addons/gipe/r.out.vic_mask/main.c	2008-03-18 05:01:49 UTC (rev 30610)
@@ -0,0 +1,191 @@
+ * MODULE:       r.out.vic_mask
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Creates a VIC watershed mask input ascii file.
+ * 		 Not NULL() and not "0" data is made "1",
+ * 		 which is valid grid cell for VIC processing.
+ * 		 NULL() and 0 data are set to "0",
+ * 		 which tells VIC not to process it.
+ * COPYRIGHT:    (C) 2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+int veglib(char *filename);
+int main(int argc, char *argv[])
+	struct Cell_head cellhd; //region+header info
+	char *mapset; // mapset name
+	int nrows, ncols;
+	int row,col;
+	struct GModule *module;
+	struct Option *input1, *output1;
+	struct History history; //metadata
+	struct pj_info iproj;
+	struct pj_info oproj;
+	/* FMEO Declarations*****************/
+	char 	*name;		// input raster name
+	char 	*result1; 	//output raster name
+	//File Descriptors
+	int 	infd;
+	int 	i=0,j=0;
+	double xp, yp;
+	double xmin, ymin;
+	double xmax, ymax;
+	double stepx,stepy;
+	double latitude, longitude;
+	int not_ll=0;//if proj is not lat/long, it will be 1.
+	void 			*inrast;
+	RASTER_MAP_TYPE 	data_type_inrast;
+	FILE	*f; 		// output ascii file
+	int 	grid_count; 	// grid cell count
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	module->keywords = _("VIC, hydrology, mask");
+	module->description = _("creates a watershed mask ascii file \
+			from any binary map. \
+			NULL() and '0' will be switch off for VIC.");
+	/* Define the different options */
+	input1 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input1->key	   = _("input");
+	input1->description=_("Name of the binary input map");
+	output1 = G_define_option() ;
+	output1->key        =_("output");
+	output1->description=_("Name of the output vic watershed \
+				mask ascii file");
+	output1->answer     =_("vic_mask.asc");
+	if (G_parser(argc, argv))
+		exit (EXIT_FAILURE);
+	name		 	= input1->answer;
+	result1 	 	= output1->answer;
+	/* LOADING REQUIRED BINARY MAP			*/
+	mapset = G_find_cell2(name, "");
+	if (mapset == NULL) {
+		G_fatal_error(_("cell file [%s] not found"), name);
+	data_type_inrast = G_raster_map_type(name,mapset);
+	if ( (infd = G_open_cell_old (name,mapset)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"), name);
+	if (G_get_cellhd (name, mapset, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s])"), name);
+	inrast = G_allocate_raster_buf(data_type_inrast);
+	G_debug(3, "number of rows %d",cellhd.rows);
+	stepx=cellhd.ew_res;
+	stepy=cellhd.ns_res;
+	xmin=cellhd.west;
+	xmax=cellhd.east;
+	ymin=cellhd.south;
+	ymax=cellhd.north;
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	//Shamelessly stolen from r.sun !!!!
+	/* Set up parameters for projection to lat/long if necessary */
+	if ((G_projection() != PROJECTION_LL)) {
+		not_ll=1;
+		struct Key_Value *in_proj_info, *in_unit_info;
+		if ((in_proj_info = G_get_projinfo()) == NULL)
+			G_fatal_error(_("Can't get projection info of current location"));
+		if ((in_unit_info = G_get_projunits()) == NULL)
+			G_fatal_error(_("Can't get projection units of current location"));
+		if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+			G_fatal_error(_("Can't get projection key values of current location"));
+		G_free_key_value(in_proj_info);
+		G_free_key_value(in_unit_info);
+		/* Set output projection to latlong w/ same ellipsoid */
+		oproj.zone = 0;
+		oproj.meters = 1.;
+		sprintf(oproj.proj, "ll");
+		if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+			G_fatal_error(_("Unable to set up lat/long projection parameters"));
+	}//End of stolen from r.sun :P
+	latitude = ymax;
+	longitude = xmin;
+	if(not_ll){
+		if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+			G_fatal_error(_("Error in pj_do_proj"));
+	}else{
+		//Do nothing
+	/*Initialize grid cell process switch*/
+	f=fopen(result1,"w");
+	/*Print to ascii file*/
+	/*NORTHWEST LATITUDE*/
+	fprintf(f,"%d\n", latitude);
+	/*NORTHWEST LONGITUDE*/
+	fprintf(f,"%d\n", longitude);
+	fprintf(f,"%d\n", nrows);
+	fprintf(f,"%d\n", ncols);
+	for (row = 0; row < nrows; row++){
+		CELL c;
+		G_percent(row,nrows,2);
+		if(G_get_raster_row(infd,inrast,row,data_type_inrast)<0)
+			G_fatal_error(_("Could not read from <%s>"),name);
+		for (col=0; col < ncols; col++){
+			/*Extract data*/
+			switch(data_type_inrast){
+				case CELL_TYPE:
+					c=  ((CELL *) inrast)[col];
+					break;
+				case FCELL_TYPE:
+					c= (int) ((FCELL *) inrast)[col];
+					break;
+				case DCELL_TYPE:
+					c= (int) ((DCELL *) inrast)[col];
+					break;
+			if(G_is_c_null_value(&c)){
+				c = 0;
+			/*Grid cell value in that grid cell*/
+			if(c==0){
+				fprintf(f,"%d ",c);
+			} else {
+				fprintf(f,"1 ");
+		fprintf(f,"\n");
+	G_free (inrast);
+	G_close_cell (infd);
+	fclose(f);
+	exit(EXIT_SUCCESS);
Modified: grass-addons/gipe/r.out.vic_veg/main.c
--- grass-addons/gipe/r.out.vic_veg/main.c	2008-03-17 22:24:39 UTC (rev 30609)
+++ grass-addons/gipe/r.out.vic_veg/main.c	2008-03-18 05:01:49 UTC (rev 30610)
@@ -22,6 +22,8 @@
@@ -32,7 +34,7 @@
 	int verbose=1;
-	struct Option *input1, *input2, *output1;
+	struct Option *input1, *input2, *output1, *output2;
 	struct Flag *flag1;
@@ -72,7 +74,8 @@
 	module->keywords = _("VIC, hydrology, soil");
-	module->description = _("creates a vegetation ascii file from land cover map. \
+	module->description = _("creates a vegetation ascii file \
+			from land cover map. \
 			Optionally LAI data from 12 LAI maps.");
@@ -90,13 +93,24 @@
 	output1->description=_("Name of the output vic soil ascii file");
 	output1->answer     =_("vic_soil.asc");
+	output2 = G_define_option() ;
+	output2->key        =_("veglib");
+	output2->required   = NO;
+	output2->description=_("Name of a standard vegetation library file");
+	output2->answer     =_("veglib");
 	landcover_name	 	= input1->answer;
+	/* STANDARD VEGLIB CREATION HERE 		*/
+	if(output2->answer)
+		veglib(output2->answer);
+	/* LOADING OPTIONAL LAI MONTHLY MAPS 		*/
 	if (input2->answer){
 		test = input2->answers;
 		for (ptr = test, nfiles = 0; *ptr != NULL; ptr++, nfiles++)
@@ -120,8 +134,8 @@
 			inrast_lai[i] = G_allocate_raster_buf(data_type_inrast_lai[i]);
+	/* LOADING REQUIRED LAND COVER MAP		*/
 	mapset = G_find_cell2(landcover_name, "");
 		G_fatal_error(_("cell file [%s] not found"), landcover_name);
