[GRASS-SVN] r30614 - grass/trunk/raster/r.los
Tue Mar 18 05:34:08 EDT 2008
Author: neteler
Date: 2008-03-18 05:34:07 -0400 (Tue, 18 Mar 2008)
New Revision: 30614
   grass/trunk/raster/r.los/Makefile
   grass/trunk/raster/r.los/local_proto.h
   grass/trunk/raster/r.los/main.c
   grass/trunk/raster/r.los/make_list.c
   grass/trunk/raster/r.los/point.h
   grass/trunk/raster/r.los/pts_elim.c
   grass/trunk/raster/r.los/segment.c
Earth curvature support added
Modified: grass/trunk/raster/r.los/Makefile
--- grass/trunk/raster/r.los/Makefile	2008-03-18 07:04:22 UTC (rev 30613)
+++ grass/trunk/raster/r.los/Makefile	2008-03-18 09:34:07 UTC (rev 30614)
@@ -2,8 +2,8 @@
 PGM = r.los
-LIBES = $(SEGMENTLIB) $(GISLIB)
-DEPENDENCIES = $(SEGMENTDEP) $(GISDEP)
+LIBES = $(SEGMENTLIB) $(GPROJLIB) $(GISLIB)
+DEPENDENCIES = $(SEGMENTDEP) $(GPROJDEP) $(GISDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/raster/r.los/local_proto.h
--- grass/trunk/raster/r.los/local_proto.h	2008-03-18 07:04:22 UTC (rev 30613)
+++ grass/trunk/raster/r.los/local_proto.h	2008-03-18 09:34:07 UTC (rev 30614)
@@ -1,7 +1,7 @@
 /* color_rnge.c */
 double decide_color_range(double, double, double);
 /* newsegment.c */
-struct point *segment(int, int, int, double, double, int, int, int, int, SEGMENT *, SEGMENT *, SEGMENT *, int, int, int);
+struct point *segment(int, int, int, double, double, int, int, int, int, SEGMENT *, SEGMENT *, SEGMENT *, int, int, int, int, double);
 /* pts_elim.c */
 double find_orientation(int, int, int);
-double find_inclination(int, int, int, SEGMENT *, int, int);
+double find_inclination(int, int, int, SEGMENT *, int, int, int, double);
Modified: grass/trunk/raster/r.los/main.c
--- grass/trunk/raster/r.los/main.c	2008-03-18 07:04:22 UTC (rev 30613)
+++ grass/trunk/raster/r.los/main.c	2008-03-18 09:34:07 UTC (rev 30614)
@@ -35,6 +35,7 @@
 #include <grass/gis.h>
 #define MAIN
 #include <grass/segment.h>
+#include <grass/gprojects.h>
 #include <grass/glocale.h>
 #include "cmd_line.h"
 #include "point.h"
@@ -69,8 +70,10 @@
     struct point *heads[16], *SEARCH_PT;
     struct GModule *module;
     struct Option *opt1, *opt2, *opt3, *opt5, *opt6, *opt7;
+    struct Flag *curvature;
     struct History history;
     char title[128];
+    double aa, e2;
     G_gisinit(argv[0]);
@@ -109,9 +112,14 @@
     opt6->type = TYPE_DOUBLE;
     opt6->required = NO;
     opt6->answer = "10000";
-    opt6->options = "0-999999";
+    opt6->options = "0-5000000";  /* observer can be in a plane, too */
     opt6->description = _("Maximum distance from the viewing point (meters)");
+    /* http://mintaka.sdsu.edu/GF/explain/atmos_refr/horizon.html */
+    curvature = G_define_flag();
+    curvature->key = 'c';
+    curvature->description = _("Consider earth curvature (current ellipsoid)");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -227,6 +235,18 @@
 	close(patt_fd);
+   if (curvature->answer){
+      /* try to get the radius the standard GRASS way from the libs */
+      G_get_ellipsoid_parameters (&aa, &e2);
+      if (aa == 0) {
+          /* since there was a problem, take a hardcoded radius :( */
+          G_warning(_("Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"));
+          aa = 6370997.00;
+      G_debug(3, "radius: %f", aa);
+    G_message(_("Using maximum distance from the viewing point (meters): %f"), max_dist);
     /*      open, initialize and segment all files          */
     in_fd = open(in_name, 2);
     segment_init(&seg_in, in_fd, 4);
@@ -304,7 +324,7 @@
 					slope_1, slope_2, flip, sign_on_y,
 					sign_on_x, viewpt_elev, &seg_in,
 					&seg_out, &seg_patt, row_viewpt,
-					col_viewpt, patt_flag);
+					col_viewpt, patt_flag, curvature->answer, aa);
 	G_percent(segment_no, 16, 5);
     }	/*      end of for-loop over segments           */
Modified: grass/trunk/raster/r.los/make_list.c
--- grass/trunk/raster/r.los/make_list.c	2008-03-18 07:04:22 UTC (rev 30613)
+++ grass/trunk/raster/r.los/make_list.c	2008-03-18 09:34:07 UTC (rev 30614)
@@ -18,7 +18,8 @@
 struct point *make_list(struct point *head, int y, int x,
 			SEGMENT * seg_in_p, int viewpt_elev,
-			int quadrant, int row_viewpt, int col_viewpt)
+			int quadrant, int row_viewpt, int col_viewpt,
+			int docurv, double ellps_a)
     double del_x, del_y, dist, orientation, inclination;
     static struct point *PRESENT_PT;
@@ -38,7 +39,7 @@
     /* otherwise find orientation and inclination           */
     orientation = find_orientation(x, y, quadrant);
     inclination = find_inclination(x, y, viewpt_elev, seg_in_p,
-				   row_viewpt, col_viewpt);
+				   row_viewpt, col_viewpt, docurv, ellps_a);
     if (head == NULL) {		/*  first point ?           */
 	head = make_point(orientation, inclination, y, x);
Modified: grass/trunk/raster/r.los/point.h
--- grass/trunk/raster/r.los/point.h	2008-03-18 07:04:22 UTC (rev 30613)
+++ grass/trunk/raster/r.los/point.h	2008-03-18 09:34:07 UTC (rev 30614)
@@ -31,14 +31,14 @@
 /* delete.c */
 struct point *delete(struct point *, struct point *, SEGMENT *, int, int);
 /* make_list.c */
-struct point *make_list(struct point *, int, int, SEGMENT *, int, int, int, int);
+struct point *make_list(struct point *, int, int, SEGMENT *, int, int, int, int, int, double);
 /* mark_pts.c */
 int mark_visible_points(struct point *, SEGMENT *, int, int, double, double);
 /* pts_elim.c */
-struct point *hidden_point_elimination(struct point *, int, SEGMENT *, SEGMENT *, SEGMENT *, int, int, int, int, int, int);
+struct point *hidden_point_elimination(struct point *, int, SEGMENT *, SEGMENT *, SEGMENT *, int, int, int, int, int, int, int, double);
 /* segment.c */
-	int, int, int, int, SEGMENT *, SEGMENT *, SEGMENT *, int, int, int);
+	int, int, int, int, SEGMENT *, SEGMENT *, SEGMENT *, int, int, int, int, double);
 #endif
Modified: grass/trunk/raster/r.los/pts_elim.c
--- grass/trunk/raster/r.los/pts_elim.c	2008-03-18 07:04:22 UTC (rev 30613)
+++ grass/trunk/raster/r.los/pts_elim.c	2008-03-18 09:34:07 UTC (rev 30614)
@@ -11,6 +11,7 @@
 #include <math.h>
+#include <grass/glocale.h>
 #include "point.h"
 #include "radians.h"
 #include "local_proto.h"
@@ -42,7 +43,8 @@
 	struct point *head, int viewpt_elev,
 	SEGMENT *seg_in_p, SEGMENT *seg_out_p, SEGMENT *seg_patt_p,
 	int quadrant, int sign_on_y, int sign_on_x,
-	int row_viewpt, int col_viewpt, int patt_flag)
+	int row_viewpt, int col_viewpt, int patt_flag,
 	struct point *CHECKED_PT, *BLOCKING_PT;
@@ -92,11 +94,11 @@
 		inclination_neighbor_1 =
 		    find_inclination(neighbor_1_x,neighbor_1_y,viewpt_elev,
-		    seg_in_p,row_viewpt,col_viewpt);
+		    seg_in_p,row_viewpt,col_viewpt, docurv, ellps_a);
 		inclination_neighbor_2 =
 		    find_inclination(neighbor_2_x,neighbor_2_y,viewpt_elev,
 		/* check all points behind the blocking point		*/
@@ -278,11 +280,12 @@
 double
-find_inclination (int x, int y, int viewpt_elev, SEGMENT *seg_in_p, int row_viewpt, int col_viewpt)
+find_inclination (int x, int y, int viewpt_elev, SEGMENT *seg_in_p, int row_viewpt, int col_viewpt,
-	double del_x, del_y,dist,atan(),sqrt();
+	double del_x, del_y,dist;
 	int abs();
 	FCELL picked_pt_elev;
 	extern struct Cell_head window;
@@ -293,6 +296,10 @@
 	dist=sqrt(del_x * del_x + del_y * del_y)*window.ns_res;
 	segment_get(seg_in_p,&picked_pt_elev,row_viewpt-y,x+col_viewpt);
+	if (docurv)  /* decrease height of target point */
+	    picked_pt_elev = picked_pt_elev - ((dist*dist) / (2 * ellps_a));
 	return(atan((picked_pt_elev-viewpt_elev)/dist));
Modified: grass/trunk/raster/r.los/segment.c
--- grass/trunk/raster/r.los/segment.c	2008-03-18 07:04:22 UTC (rev 30613)
+++ grass/trunk/raster/r.los/segment.c	2008-03-18 09:34:07 UTC (rev 30614)
@@ -19,7 +19,7 @@
 		      int sign_on_y, int sign_on_x, int viewpt_elev,
 		      SEGMENT * seg_in_p, SEGMENT * seg_out_p,
 		      SEGMENT * seg_patt_p, int row_viewpt, int col_viewpt,
-		      int patt_flag)
+		      int patt_flag, int docurv, double ellps_a)
     int lower_limit_y, upper_limit_y, less, x, y,
 	x_actual, y_actual, x_flip, y_flip;
@@ -60,7 +60,7 @@
 	    /*      add chosen point to the point list              */
 	    head = make_list(head, y_actual, x_actual, seg_in_p,
-			     viewpt_elev, quadrant, row_viewpt, col_viewpt);
+			     viewpt_elev, quadrant, row_viewpt, col_viewpt, docurv, ellps_a);
     }	/* end of outer loop */
@@ -79,7 +79,7 @@
 	head = hidden_point_elimination(head, viewpt_elev,
 					seg_in_p, seg_out_p, seg_patt_p,
 					quadrant, sign_on_y, sign_on_x,
-					row_viewpt, col_viewpt, patt_flag);
+					row_viewpt, col_viewpt, patt_flag, docurv, ellps_a);
     return (head);
