[GRASS-SVN] r30617 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Tue Mar 18 09:11:15 EDT 2008
Author: martinl
Date: 2008-03-18 09:11:15 -0400 (Tue, 18 Mar 2008)
New Revision: 30617
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: do not execute zero-length commands
some cosmetics in error messages (writing settings into workspace file)
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-03-18 12:26:55 UTC (rev 30616)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-03-18 13:11:15 UTC (rev 30617)
@@ -503,20 +503,23 @@
def run(self):
"""Run command"""
+ if len(self.cmd) == 0:
+ return
self.startTime = time.time()
# TODO: wx.Exectute/wx.Process (?)
- self.module = Popen(self.cmd,
- stdin=subprocess.PIPE,
- stdout=subprocess.PIPE,
- stderr=subprocess.PIPE)
+ try:
+ self.module = Popen(self.cmd,
+ stdin=subprocess.PIPE,
+ stdout=subprocess.PIPE,
+ stderr=subprocess.PIPE)
+ except OSError, e:
+ raise CmdError(self.cmd[0], str(e))
if self.stdin: # read stdin if requested ...
self.module.stdin.write(self.stdin)
self.module.stdin.close()
- if not self.module:
- return
# redirect standard outputs...
if self.stdout or self.stderr:
self.__redirect_stream()
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-18 12:26:55 UTC (rev 30616)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-18 13:11:15 UTC (rev 30617)
@@ -83,6 +83,8 @@
@return name of file with rendered image or None
+ if len(self.cmdlist) == 0:
+ return
Debug.msg (3, "MapLayer.Render(): type=%s" % \
(self.type))
@@ -143,7 +145,10 @@
if not self.name:
return ''
- return self.name.split('@')[1]
+ try:
+ return self.name.split('@')[1]
+ except IndexError:
+ return self.name
def GetCmd(self, string=False):
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-03-18 12:26:55 UTC (rev 30616)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-03-18 13:11:15 UTC (rev 30617)
@@ -750,10 +750,9 @@
try:
file = open(filename, "w")
except IOError:
- dlg = wx.MessageDialog(self, _("Unable to open workspace file <%s> for writing.") % filename,
- _("Error"), wx.OK | wx.ICON_ERROR)
- dlg.ShowModal()
- dlg.Destroy()
+ wx.MessageBox(parent=self,
+ message=_("Unable to open workspace file <%s> for writing.") % filename,
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
return False
try:
@@ -774,17 +773,16 @@
self.indent =- 4
file.write('%s</gxw>\n' % (' ' * self.indent))
del self.indent
- except:
- dlg = wx.MessageDialog(self, _("Writing current settings to workspace file failed."),
- dlg.ShowModal()
- dlg.Destroy()
+ except StandardError, e:
+ file.close()
+ wx.MessageBox(parent=self, message=_("Writing current settings to workspace file failed (%s)." % e),
return False
file.close()
return True
def OnWorkspaceClose(self, event=None):
"""Close file with workspace definition
