[GRASS-SVN] r30621 -
grass/branches/releasebranch_6_3/scripts/i.in.spotvgt
svn_grass at osgeo.org
Tue Mar 18 11:54:11 EDT 2008
Author: neteler
Date: 2008-03-18 11:54:11 -0400 (Tue, 18 Mar 2008)
New Revision: 30621
grass/branches/releasebranch_6_3/scripts/i.in.spotvgt/description.html
grass/branches/releasebranch_6_3/scripts/i.in.spotvgt/i.in.spotvgt
backported fixed from HEAD (trac #81)
Modified: grass/branches/releasebranch_6_3/scripts/i.in.spotvgt/description.html
--- grass/branches/releasebranch_6_3/scripts/i.in.spotvgt/description.html 2008-03-18 15:52:28 UTC (rev 30620)
+++ grass/branches/releasebranch_6_3/scripts/i.in.spotvgt/description.html 2008-03-18 15:54:11 UTC (rev 30621)
@@ -11,6 +11,9 @@
<h2>NOTES</h2>
+The SPOT VGT files are delivered in HDF4 (Hierarchical Data Format Release 4)
+format. It is required to have the GDAL libraries installed with HDF4 support.
<h3>Export of entire world SPOT VGT maps</h3>
When working with SPOT VGT with entire world extent, it is recommended
Modified: grass/branches/releasebranch_6_3/scripts/i.in.spotvgt/i.in.spotvgt
--- grass/branches/releasebranch_6_3/scripts/i.in.spotvgt/i.in.spotvgt 2008-03-18 15:52:28 UTC (rev 30620)
+++ grass/branches/releasebranch_6_3/scripts/i.in.spotvgt/i.in.spotvgt 2008-03-18 15:54:11 UTC (rev 30621)
@@ -12,10 +12,14 @@
# COPYRIGHT: (c) 2004,2007 GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
# REQUIREMENTS:
-# - gdal: http://gdal.org
+# - gdal: http://www.gdal.org
# Notes:
# * According to the faq (http://www.vgt.vito.be/faq/faq.html), SPOT vegetation
@@ -124,11 +128,7 @@
#echo $SOUTHCORNER
#echo $RESOLUTION
- echo -n "<VRTDataset rasterXSize=" >> $1
- echo -n "\"$XSIZE\"" >> $1
- echo -n " rasterYSize=" >> $1
- echo "\"$YSIZE\">" >> $1
+ echo "<VRTDataset rasterXSize=\"$XSIZE\" rasterYSize=\"$YSIZE\">" >> "$1"
echo " <SRS>GEOGCS["wgs84",DATUM["WGS_1984",SPHEROID["wgs84",6378137,298.257223563],TOWGS84[0.000,0.000,0.000]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]</SRS>" >> $1
echo " <GeoTransform>$WESTCORNER, $RESOLUTION, 0.0000000000000000e+00, $NORTHCORNER, 0.0000000000000e+00, -$RESOLUTION</GeoTransform>" >> $1
echo " <VRTRasterBand dataType=\"Byte\" band=\"1\">" >> $1
@@ -174,16 +174,16 @@
### create VRT header for NDVI
-PROJFILE=${SPOTDIR}/0001_LOG.TXT
-VRTFILE=$TMPFILE.vrt
+PROJFILE="${SPOTDIR}/0001_LOG.TXT"
+VRTFILE="$TMPFILE.vrt"
# first process the NDVI:
-rm -f $VRTFILE
-create_VRT_file $VRTFILE $GIS_OPT_FILE
+rm -f "$VRTFILE"
+create_VRT_file "$VRTFILE" "$GIS_OPT_FILE"
## let's import the NDVI map...
g.message "Importing SPOT VGT NDVI map..."
-r.in.gdal $VRTFILE output=$NAME
+r.in.gdal "$VRTFILE" output="$NAME"
if [ $? -eq 1 ] ; then
g.message -e "An error occurred. Stop."
exit 1
@@ -200,17 +200,19 @@
# Coefficient a = 0.004
# Coefficient b = -0.1
-#save region before zoom to SPOT image
-g.region save=spot_$PID 2>&1 >/dev/null
-g.region rast=$NAME 2>&1 >/dev/null
+# switch to a temporary region
+WIND_OVERRIDE=spot_$PID
+export WIND_OVERRIDE
+g.region -d --quiet
+g.region rast="$NAME" --quiet
g.message "Remapping digital numbers to NDVI..."
-r.mapcalc "${NAME}_$PID=0.004 * $NAME - 0.1"
-g.remove rast=$NAME 2>&1 >/dev/null
-g.rename rast=${NAME}_$PID,${NAME} >/dev/null
+r.mapcalc "${NAME}_$PID = 0.004 * $NAME - 0.1"
+g.remove rast="$NAME" --quiet
+g.rename rast="${NAME}_$PID","$NAME" --quiet
#apply color table:
-r.colors ${NAME} color=ndvi 2>&1 >/dev/null
+r.colors "$NAME" color=ndvi --quiet
# second, optionally process the SM quality map:
@@ -242,18 +244,18 @@
if [ $GIS_FLAG_A -eq 1 ] ; then
g.message "Importing SPOT VGT NDVI quality map..."
- rm -f $VRTFILE
- create_VRT_file $VRTFILE `echo ${GIS_OPT_FILE} | sed 's+NDV+SM+g'`
+ rm -f "$VRTFILE"
+ create_VRT_file "$VRTFILE" `echo ${GIS_OPT_FILE} | sed 's+NDV+SM+g'`
## let's import the SM quality map...
- r.in.gdal $VRTFILE output=$NAME.sm
+ r.in.gdal "$VRTFILE" output="$NAME.sm"
exit 1
fi
# some of the possible values:
-r.colors $NAME.sm col=rules << EOF
+r.colors "$NAME.sm" col=rules << EOF
8 50 50 50
11 70 70 70
12 90 90 90
@@ -272,20 +274,19 @@
g.message ""
g.message message="Filtering NDVI map by Status Map quality layer..."
r.mapcalc "${NAME}_filt=if($NAME.sm >= 248, $NAME, null() )"
- r.colors ${NAME}_filt color=ndvi 2>&1 >/dev/null
+ r.colors "${NAME}_filt" color=ndvi --quiet
g.message message="Filtered SPOT VEGETATION NDVI map <${NAME}_filt>."
fi
-# restore user settings:
-g.region region=spot_$PID 2>&1 >/dev/null
-g.remove region=spot_$PID 2>&1 >/dev/null
+# remove the temporary region
+g.remove region="spot_$PID" --quiet
#### clean up the mess
-rm -f $VRTFILE $TMPFILE
+rm -f "$VRTFILE" "$TMPFILE"
#### end
# write cmd history:
-r.support ${NAME} history="${CMDLINE}"
+r.support "$NAME" history="${CMDLINE}"
g.message "Done."
