[GRASS-SVN] r30631 - in grass/trunk/swig/python: . examples
Wed Mar 19 06:07:49 EDT 2008
Author: hamish
Date: 2008-03-19 06:07:48 -0400 (Wed, 19 Mar 2008)
New Revision: 30631
Added:
   grass/trunk/swig/python/examples/rasteraccess.py
   grass/trunk/swig/python/examples/vectoraccess.py
Removed:
   grass/trunk/swig/python/rasteraccess.py
   grass/trunk/swig/python/vectoraccess.py
move examples into own dir
Copied: grass/trunk/swig/python/examples/rasteraccess.py (from rev 30630, grass/trunk/swig/python/rasteraccess.py)
--- grass/trunk/swig/python/examples/rasteraccess.py	                        (rev 0)
+++ grass/trunk/swig/python/examples/rasteraccess.py	2008-03-19 10:07:48 UTC (rev 30631)
@@ -0,0 +1,28 @@
+#!/usr/bin/python
+# run within GRASS Spearfish session
+import os, sys
+import python_grass6 as g6lib
+if not os.environ.has_key("GISBASE"):
+    print "You must be in GRASS GIS to run this program."
+    sys.exit(1)
+input = 'elevation.dem'
+mapset = 'PERMANENT'
+g6lib.G_gisinit('')
+infd = g6lib.G_open_cell_old(input, mapset)
+cell = g6lib.G_allocate_cell_buf()
+rown=0
+while 1:
+    myrow = g6lib.G_get_map_row_nomask(infd, cell, rown)
+    print rown,myrow[0:10]
+    rown = rown+1
+    if rown==476:break
+g6lib.G_close_cell(infd)
+g6lib.G_free(cell)
Copied: grass/trunk/swig/python/examples/vectoraccess.py (from rev 30630, grass/trunk/swig/python/vectoraccess.py)
--- grass/trunk/swig/python/examples/vectoraccess.py	                        (rev 0)
+++ grass/trunk/swig/python/examples/vectoraccess.py	2008-03-19 10:07:48 UTC (rev 30631)
@@ -0,0 +1,47 @@
+#!/usr/bin/python
+import os, sys
+    sys.exit(1)
+if len(sys.argv)==2:
+  input = sys.argv[1]
+else:
+  input = raw_input("Vector Map Name? ")
+# initialize
+# define map structure
+map = g6lib.Map_info()
+# define open level (level 2: topology)
+g6lib.Vect_set_open_level (2)
+# open existing map
+g6lib.Vect_open_old(map, input, mapset)
+# query
+print 'Vect map: ', input
+print 'Vect is 3D: ', g6lib.Vect_is_3d (map)
+print 'Vect DB links: ', g6lib.Vect_get_num_dblinks(map)
+print 'Map Scale:  1:', g6lib.Vect_get_scale(map)
+# misleading:
+# print 'Number of lines:', g6lib.Vect_get_num_lines(map)
+print 'Number of points: ', g6lib.Vect_get_num_primitives(map,g6lib.GV_POINT)
+# confusing:
+#print 'Number of lines: ', g6lib.Vect_get_num_primitives(map,g6lib.GV_LINE)
+#print 'Number of areas:', g6lib.Vect_get_num_primitives(map,g6lib.GV_AREA)
+print 'Number of areas:', g6lib.Vect_get_num_areas(map)
+# close map
+g6lib.Vect_close(map)
+## end of the python script
Deleted: grass/trunk/swig/python/rasteraccess.py
--- grass/trunk/swig/python/rasteraccess.py	2008-03-19 07:13:13 UTC (rev 30630)
+++ grass/trunk/swig/python/rasteraccess.py	2008-03-19 10:07:48 UTC (rev 30631)
@@ -1,28 +0,0 @@
-#!/usr/bin/python
-# run within GRASS Spearfish session
-import os, sys
-import python_grass6 as g6lib
-if not os.environ.has_key("GISBASE"):
-    print "You must be in GRASS GIS to run this program."
-    sys.exit(1)
-input = 'elevation.dem'
-mapset = 'PERMANENT'
-g6lib.G_gisinit('')
-infd = g6lib.G_open_cell_old(input, mapset)
-cell = g6lib.G_allocate_cell_buf()
-rown=0
-while 1:
-    myrow = g6lib.G_get_map_row_nomask(infd, cell, rown)
-    print rown,myrow[0:10]
-    rown = rown+1
-    if rown==476:break
-g6lib.G_close_cell(infd)
-g6lib.G_free(cell)
Deleted: grass/trunk/swig/python/vectoraccess.py
--- grass/trunk/swig/python/vectoraccess.py	2008-03-19 07:13:13 UTC (rev 30630)
+++ grass/trunk/swig/python/vectoraccess.py	2008-03-19 10:07:48 UTC (rev 30631)
@@ -1,47 +0,0 @@
-#!/usr/bin/python
-import os, sys
-    sys.exit(1)
-if len(sys.argv)==2:
-  input = sys.argv[1]
-else:
-  input = raw_input("Vector Map Name? ")
-# initialize
-# define map structure
-map = g6lib.Map_info()
-# define open level (level 2: topology)
-g6lib.Vect_set_open_level (2)
-# open existing map
-g6lib.Vect_open_old(map, input, mapset)
-# query
-print 'Vect map: ', input
-print 'Vect is 3D: ', g6lib.Vect_is_3d (map)
-print 'Vect DB links: ', g6lib.Vect_get_num_dblinks(map)
-print 'Map Scale:  1:', g6lib.Vect_get_scale(map)
-# misleading:
-# print 'Number of lines:', g6lib.Vect_get_num_lines(map)
-print 'Number of points: ', g6lib.Vect_get_num_primitives(map,g6lib.GV_POINT)
-# confusing:
-#print 'Number of lines: ', g6lib.Vect_get_num_primitives(map,g6lib.GV_LINE)
-#print 'Number of areas:', g6lib.Vect_get_num_primitives(map,g6lib.GV_AREA)
-print 'Number of areas:', g6lib.Vect_get_num_areas(map)
-# close map
-g6lib.Vect_close(map)
-## end of the python script
