[GRASS-SVN] r30646 - in
grass/branches/releasebranch_6_3/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Wed Mar 19 10:18:50 EDT 2008
Author: martinl
Date: 2008-03-19 10:18:49 -0400 (Wed, 19 Mar 2008)
New Revision: 30646
grass/branches/releasebranch_6_3/gui/wxpython/README
grass/branches/releasebranch_6_3/gui/wxpython/gis_set.py
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/dbm.py
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/gcmd.py
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/globalvar.py
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/goutput.py
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/menuform.py
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/preferences.py
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/render.py
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/utils.py
grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/wxgui_utils.py
grass/branches/releasebranch_6_3/gui/wxpython/wxgui.py
wxGUI: synchronized with trunk (for RC6)
Modified: grass/branches/releasebranch_6_3/gui/wxpython/README
--- grass/branches/releasebranch_6_3/gui/wxpython/README 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/README 2008-03-19 14:18:49 UTC (rev 30646)
@@ -1,8 +1,10 @@
wxPython GRASS Graphical User Interface
-0 - REQUIREMENTS
+$Date$
+1 - REQUIREMENTS
GRASS GIS >= 6.3
Python >= 2.4
wxPython >= 2.8.1.1
@@ -36,19 +38,9 @@
python-wxgtk2.8 wx2.8-doc wx2.8-examples \
wx2.8-headers wx2.8-i18n
-1 - INSTALLATION
-Go to:
-$ cd gui/wxpython
-and run
-$ make
2 - STARTUP WITH GRASS INITIALIZATION
-If you want to run wxPython GUI automatically when you start
+If you want to launch wxPython GUI automatically when you start
GRASS, edit your .grassrc6 file to replace
GRASS_GUI: tcktk (or whatever you have here)
@@ -59,11 +51,11 @@
or easier start new GRASS session with -wxpython switch.
-$ grass -wxpython
+$ grass63 -wxpython
3 - STARTUP FROM GRASS TERMINAL
-Simply type
+Simply run
$ g.gui wxpython
@@ -71,11 +63,11 @@
You can also specify workspace file to load on startup.
-$ g.gui gui=wxpython workspace=myworkspace.grc
+$ g.gui gui=wxpython workspace=myworkspace.gxw
4 - CLI Display scripts
-Note: This section is out-dated.
+Note: This section is out-dated!
This is going to be replacement for command line tools like d.rast and
d.vect.
@@ -122,23 +114,24 @@
5 - DEBUGGING
-To enable GUI debugging messages on given level set GRASS_DEBUG_WX
-environment variables, e.g.
+To enable GUI debug messages on given level set GRASS_DEBUG_WX
+environment variable, e.g.
$ export GRASS_WX_DEBUG=3
6 - ICON THEMES
Currently two icon themes are available:
* original GRASS (based on TCL/TK GUI prototype)
- * Silk-based
+ * Silk-based (default)
User can change icon theme in Preferences dialog
('Config->Preferences').
7 - DIGITIZATION TOOL
-To enable digitization tool you need to compile 'vdigit'
+To enable digitizer you need to compile 'vdigit'
component. Note that you must configure GRASS with C++ (--with-cxx),
Python (--with-python) and wxWidgets (--with-wxwidgets) support.
@@ -150,10 +143,10 @@
$ sudo ln -s /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so /usr/local/lib/libgdi.so
-Make sure you set up LD_LIBRARY_PATH or noted '/usr/local/lib' in
-/etc/ld.so.conf.
+Then update LD_LIBRARY_PATH or add '/usr/local/lib' to /etc/ld.so.conf
+(in this case run 'sudo ldconfig').
-$ sudo ldconfig
+TODO: Don't use direct linking here.
Then you can compile the driver
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gis_set.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gis_set.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gis_set.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -28,16 +28,15 @@
### i18N
import gettext
+from gui_modules import globalvar
+globalvar.CheckForWx()
from gui_modules import utils
-utils.CheckForWx()
import wx
import wx.html
import wx.lib.rcsizer as rcs
import wx.lib.filebrowsebutton as filebrowse
-from gui_modules import globalvar
class GRASSStartup(wx.Frame):
"""GRASS start-up screen"""
def __init__(self, parent=None, id=wx.ID_ANY, style=wx.DEFAULT_FRAME_STYLE):
@@ -199,13 +198,23 @@
if location:
# list of locations
self.UpdateLocations(self.gisdbase)
- self.lblocations.SetSelection(self.listOfLocations.index(location))
+ try:
+ self.lblocations.SetSelection(self.listOfLocations.index(location))
+ except ValueError:
+ print >> sys.stderr, _("ERROR: Location <%s> not found in GISDBASE (%s)") % \
+ (location, self.gisdbase)
# list of mapsets
self.UpdateMapsets(os.path.join(self.gisdbase,location))
- mapset =self._getRCValue("MAPSET")
- if mapset:
- self.lbmapsets.SetSelection(self.listOfMapsets.index(mapset))
+ mapset = self._getRCValue("MAPSET")
+ if mapset:
+ try:
+ self.lbmapsets.SetSelection(self.listOfMapsets.index(mapset))
+ self.lbmapsets.Clear()
+ print >> sys.stderr, _("ERROR: Mapset <%s> not found") % \
+ (mapset)
# self.bstart.Enable(True)
def _do_layout(self):
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/dbm.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/dbm.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/dbm.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -41,6 +41,9 @@
import gettext
gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+import globalvar
import wx
import wx.lib.mixins.listctrl as listmix
import wx.lib.flatnotebook as FN
@@ -49,7 +52,6 @@
import sqlbuilder
import grassenv
import gcmd
-import globalvar
import utils
from debug import Debug as Debug
from preferences import globalSettings as UserSettings
@@ -2971,11 +2973,18 @@
# list of available layers & (table, database, driver)
for line in layerCommand.ReadStdOutput():
lineList = line.split(' ')
- self.layers[int(lineList[0])] = { "table" : lineList[1],
- "key" : lineList[2],
- "database" : lineList[3],
- "driver" : lineList[4] }
+ if '/' in lineList[0]:
+ lineList[0], layer_name = lineList[0].split('/')
+ else:
+ layer_name = None
+ self.layers[int(lineList[0])] = {
+ "name" : layer_name,
+ "table" : lineList[1],
+ "key" : lineList[2],
+ "database" : lineList[3],
+ "driver" : lineList[4]
if (len(self.layers.keys()) == 0):
return False
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/gcmd.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/gcmd.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -358,7 +358,8 @@
os.linesep, os.linesep,
_("Details:"),
os.linesep,
- self.PrintModuleOutput()))
+ self.cmdThread.rerr))
+# self.PrintModuleOutput()))
elif rerr == sys.stderr: # redirect message to sys
stderr.write("Execution failed: '%s'" % (' '.join(self.cmd)))
stderr.write("%sDetails:%s%s" % (os.linesep,
@@ -370,7 +371,6 @@
Debug.msg (3, "Command(): cmd='%s', wait=%s, returncode=?, alive=%s" % \
(' '.join(cmd), wait, self.cmdThread.isAlive()))
if message_format:
os.environ["GRASS_MESSAGE_FORMAT"] = message_format
else:
@@ -503,20 +503,23 @@
def run(self):
"""Run command"""
+ if len(self.cmd) == 0:
+ return
self.startTime = time.time()
# TODO: wx.Exectute/wx.Process (?)
- self.module = Popen(self.cmd,
- stdin=subprocess.PIPE,
- stdout=subprocess.PIPE,
- stderr=subprocess.PIPE)
+ try:
+ self.module = Popen(self.cmd,
+ stdin=subprocess.PIPE,
+ stdout=subprocess.PIPE,
+ stderr=subprocess.PIPE)
+ except OSError, e:
+ raise CmdError(self.cmd[0], str(e))
if self.stdin: # read stdin if requested ...
self.module.stdin.write(self.stdin)
self.module.stdin.close()
- if not self.module:
- return
# redirect standard outputs...
if self.stdout or self.stderr:
self.__redirect_stream()
@@ -571,7 +574,7 @@
# line = self.__read_all(self.module.stderr)
line = recv_some(self.module, e=0, stderr=1)
self.stderr.write(line)
# get the last output
if self.stdout:
# line = self.__read_all(self.module.stdout)
@@ -583,7 +586,7 @@
self.rerr = self.__parseString(line)
if hasattr(self.stderr, "gmstc"):
# -> GMConsole
if self._want_abort: # abort running process
@@ -609,6 +612,10 @@
err += line + '%s' % os.linesep
elif err != '' and 'GRASS_INFO_END' in line:
err += line
+ elif 'ERROR' in line:
+ err += line
+ elif err != '':
+ err += line
return err
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/globalvar.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/globalvar.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -93,3 +93,23 @@
"""@Toolbar icon size"""
toolbarSize = (24, 24)
+def CheckForWx():
+ """Try to import wx module and check its version"""
+ majorVersion = 2.8
+ minorVersion = 1.1
+ try:
+ import wx
+ version = wx.__version__
+ if float(version[:3]) < majorVersion:
+ raise ValueError('You are using wxPython version %s' % str(version))
+ if float(version[:3]) == 2.8 and \
+ float(version[4:]) < minorVersion:
+ except (ImportError, ValueError), e:
+ print >> sys.stderr, 'ERROR: ' + str(e) + \
+ '. wxPython >= %s.%s is required. Detailed information in README file.' % \
+ (str(majorVersion), str(minorVersion))
+ sys.exit(1)
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/goutput.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/goutput.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/goutput.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -322,6 +322,8 @@
def write(self, s):
s = s.replace('\n', os.linesep)
+ # remove/replace escape sequences '\b' or '\r' from stream
+ s = s.replace('\b', '').replace('\r', '%s' % os.linesep)
message = ''
for line in s.split(os.linesep):
if len(line) == 0:
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/menuform.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/menuform.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/menuform.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -52,13 +52,17 @@
import textwrap
import os
from os import system
+import time
+start = time.time()
### i18N
import gettext
-import utils
-utils.CheckForWx()
+import globalvar
import wx
import wx.lib.colourselect as csel
@@ -72,8 +76,9 @@
HandlerBase=xml.sax.handler.ContentHandler
from xml.sax import make_parser
+import utils
gisbase = os.getenv("GISBASE")
-import globalvar
if gisbase is None:
print >>sys.stderr, "We don't seem to be properly installed, or we are being run outside GRASS. Expect glitches."
gisbase = os.path.join(os.path.dirname( sys.argv[0] ), os.path.pardir)
@@ -477,6 +482,7 @@
wx.html.HtmlWindow.__init__(self, *args, **kwargs)
self.fspath = gisbase + "/docs/html/"
self.SetStandardFonts ( size = 10 )
self.SetBorders(10)
wx.InitAllImageHandlers()
@@ -485,10 +491,11 @@
if skip_description:
self.fillContentsFromFile ( self.fspath + grass_command + ".html",
skip_description=skip_description )
+ self.Ok = True
else:
- ### FIXME: calling self.LoadPage is too time costly (why?)
- self.LoadPage(self.fspath + grass_command + ".html")
- self.Ok = True
+ ### FIXME: calling LoadPage() is strangely time-consuming (only first call)
+ # self.LoadPage(self.fspath + grass_command + ".html")
+ self.Ok = False
else:
self.SetPage( text )
self.Ok = True
@@ -791,7 +798,10 @@
def OnCancel(self, event):
"""Cancel button pressed"""
self.MakeModal(False)
- self.Destroy()
+ if self.get_dcmd:
+ self.Hide()
+ else:
+ self.Destroy()
def OnCloseWindow(self, event):
"""Close the main window"""
@@ -864,7 +874,8 @@
nbStyle = globalvar.FNPageStyle
self.notebook = FN.FlatNotebook( self, id=wx.ID_ANY, style=nbStyle)
self.notebook.SetTabAreaColour(globalvar.FNPageColor)
- self.notebook.Bind( FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChange )
+ self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChange)
tab = {}
tabsizer = {}
for section in sections:
@@ -875,18 +886,20 @@
# are we running from command line?
### add 'command output' tab regardless standalone dialog
- # if standalone:
- self.goutput = goutput.GMConsole(parent=self, margin=False)
- self.outpage = self.notebook.AddPage(self.goutput, text=_("Command output") )
- self.outpageid = self.notebook.GetPageCount() - 1
+ if self.parent.get_dcmd is None:
+ self.goutput = goutput.GMConsole(parent=self, margin=False)
+ self.outpage = self.notebook.AddPage(self.goutput, text=_("Command output") )
+ self.outpageid = self.notebook.GetPageCount() - 1
+ else:
+ self.goutput = None
- manual_tab = helpPanel( parent = self.notebook, grass_command = self.task.name)
- if manual_tab.Ok:
- manual_tabsizer = wx.BoxSizer(wx.VERTICAL)
- self.notebook.AddPage( manual_tab, text = _("Manual") )
+ self.manual_tab = helpPanel(parent = self.notebook, grass_command = self.task.name)
+ self.manual_tabsizer = wx.BoxSizer(wx.VERTICAL)
+ self.notebook.AddPage(self.manual_tab, text=_("Manual"))
+ self.manual_tab_id = self.notebook.GetPageCount() - 1
self.notebook.SetSelection(0)
- panelsizer.Add( self.notebook, 1, flag=wx.EXPAND )
+ panelsizer.Add(item=self.notebook, proportion=1, flag=wx.EXPAND )
# flags
@@ -983,8 +996,8 @@
else:
if len(valuelist) == 1: # -> textctrl
txt = wx.StaticText(parent=which_panel,
- label = "%s. %s=%s" (title, _('Valid range'),
- str(valuelist).strip("[]'") + ':'))
+ label = "%s. %s %s" % (title, _('Valid range'),
+ str(valuelist[0]) + ':'))
which_sizer.Add(item=txt, proportion=0,
flag=wx.ADJUST_MINSIZE | wx.TOP | wx.RIGHT | wx.LEFT, border=5)
@@ -1164,13 +1177,13 @@
# TODO: be less arbitrary with these 600
self.panelMinHeight = 100
- self.constrained_size = (min(600, maxsizes[0]) + 25, min(600, maxsizes[1]))
+ self.constrained_size = (min(600, maxsizes[0]) + 25, min(600, maxsizes[1]) + 25)
tab[section].SetMinSize( (self.constrained_size[0], self.panelMinHeight) )
# tab[section].SetMinSize( constrained_size )
- if manual_tab.Ok:
- manual_tab.SetMinSize( (self.constrained_size[0], self.panelMinHeight) )
+ if self.manual_tab.Ok:
+ self.manual_tab.SetMinSize( (self.constrained_size[0], self.panelMinHeight) )
# manual_tab.SetMinSize( constrained_size )
self.SetSizer( panelsizer )
@@ -1195,6 +1208,14 @@
event.Skip()
def OnPageChange(self, event):
+ if hasattr(self, "manual_tab_id") and \
+ event.GetSelection() == self.manual_tab_id:
+ # calling LoadPage() is strangely time-consuming (only first call)
+ # FIXME: move to helpPage.__init__()
+ if not self.manual_tab.Ok:
+ self.manual_tab.LoadPage(self.manual_tab.fspath + self.task.name + ".html")
+ self.manual_tab.Ok = True
self.Layout()
def OnColorChange( self, event ):
@@ -1314,6 +1335,7 @@
self.mf = mainFrame(parent=None, ID=wx.ID_ANY, task_description=self.grass_task)
self.mf.Show(True)
self.SetTopWindow(self.mf)
+ # print >> sys.stderr, time.time() - start
return True
class GUI:
@@ -1334,6 +1356,7 @@
* add key name for first parameter if not given
* change mapname to mapname at mapset
+ start = time.time()
dcmd_params = {}
if completed == None:
get_dcmd = None
@@ -1394,13 +1417,19 @@
self.mf = mainFrame(parent=self.parent, ID=wx.ID_ANY,
task_description=self.grass_task,
get_dcmd=get_dcmd, layer=layer)
+ if get_dcmd is not None:
+ # update only propwin reference
+ get_dcmd(dcmd=None, layer=layer, params=None,
+ propwin=self.mf)
if show:
self.mf.Show(show)
self.mf.MakeModal(modal)
else:
self.mf.OnApply(None)
return cmd
class StaticWrapText(wx.StaticText):
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/preferences.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/preferences.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/preferences.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -22,10 +22,14 @@
import os
import sys
import copy
+import stat
+if os.name in ('posix', 'mac'):
+ import pwd
import wx
+import wx.lib.mixins.listctrl as listmix
from wx.lib.wordwrap import wordwrap
import gcmd
@@ -51,6 +55,7 @@
'general': {
'mapsetPath' : { 'selection' : 0 }, # current mapset search path
+ 'changeOpacityLevel' : { 'enabled' : False }, # show opacity level widget
# display
@@ -431,6 +436,31 @@
sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
+ # Layer Manager settings
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Layer Manager settings"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ gridSizer = wx.GridBagSizer (hgap=3, vgap=3)
+ gridSizer.AddGrowableCol(0)
+ # show opacily level
+ row = 0
+ changeOpacityLevel = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("Opacity level editable"),
+ name='IsChecked')
+ changeOpacityLevel.SetValue(self.settings.Get(group='general', key='changeOpacityLevel', subkey='enabled'))
+ self.winId['general:changeOpacityLevel:enabled'] = changeOpacityLevel.GetId()
+ gridSizer.Add(item=changeOpacityLevel,
+ pos=(row, 0), span=(1, 2))
+ sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+ border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
panel.SetSizer(border)
return panel
@@ -926,8 +956,9 @@
Controls setting options and displaying/hiding map overlay decorations
def __init__(self, parent, id, title=_('Set/unset access to mapsets in current location'),
- pos=wx.DefaultPosition, size=(-1, -1),
+ pos=wx.DefaultPosition, size=(350, 400),
style=wx.DEFAULT_DIALOG_STYLE|wx.RESIZE_BORDER):
wx.Dialog.__init__(self, parent, id, title, pos, size, style)
self.all_mapsets, self.accessible_mapsets = utils.ListOfMapsets()
@@ -942,9 +973,8 @@
sizer.Add(item=label, proportion=0,
flag=wx.ALL, border=5)
- self.mapsetlb = wx.CheckListBox(parent=self, id=wx.ID_ANY, pos=wx.DefaultPosition,
- size=(350,200), choices=self.all_mapsets)
- self.mapsetlb.Bind(wx.EVT_CHECKLISTBOX, self.OnCheckMapset)
+ self.mapsetlb = CheckListMapset(parent=self)
+ self.mapsetlb.LoadData(self.all_mapsets)
sizer.Add(item=self.mapsetlb, proportion=1,
@@ -952,10 +982,11 @@
# check all accessible mapsets
if globalSettings.Get(group='general', key='mapsetPath', subkey='selection') == 1:
for mset in self.all_mapsets:
- self.mapsetlb.Check(self.all_mapsets.index(mset), True)
+ self.mapsetlb.CheckItem(self.all_mapsets.index(mset), True)
else:
for mset in self.accessible_mapsets:
+ pass
# dialog buttons
line = wx.StaticLine(parent=self, id=wx.ID_ANY,
@@ -980,14 +1011,8 @@
self.SetSizer(sizer)
sizer.Fit(self)
- self.SetMinSize(self.GetBestSize())
+ self.SetMinSize(size)
- def OnCheckMapset(self, event):
- """Mapset checked/unchecked"""
- mapset = self.mapsetlb.GetString(event.GetSelection())
- if mapset == 'PERMANENT' or mapset == self.curr_mapset:
- self.mapsetlb.Check(event.GetSelection(), True)
def GetMapsets(self):
"""Get list of checked mapsets"""
ms = []
@@ -998,3 +1023,47 @@
i += 1
return ms
+class CheckListMapset(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
+ """List of mapset/owner/group"""
+ def __init__(self, parent, pos=wx.DefaultPosition,
+ log=None):
+ self.parent = parent
+ wx.ListCtrl.__init__(self, parent, wx.ID_ANY,
+ style=wx.LC_REPORT)
+ listmix.CheckListCtrlMixin.__init__(self)
+ self.log = log
+ # setup mixins
+ listmix.ListCtrlAutoWidthMixin.__init__(self)
+ def LoadData(self, mapsets):
+ """Load data into list"""
+ self.InsertColumn(0, _('Mapset'))
+ self.InsertColumn(1, _('Owner'))
+ self.InsertColumn(2, _('Group'))
+ locationPath = os.path.join(grassenv.GetGRASSVariable('GISDBASE'),
+ grassenv.GetGRASSVariable('LOCATION_NAME'))
+ for mapset in mapsets:
+ index = self.InsertStringItem(sys.maxint, mapset)
+ mapsetPath = os.path.join(locationPath,
+ mapset)
+ stat_info = os.stat(mapsetPath)
+ if os.name in ('posix', 'mac'):
+ self.SetStringItem(index, 1, "%s" % pwd.getpwuid(stat_info.st_uid)[0])
+ # FIXME: get group name
+ self.SetStringItem(index, 2, "%-8s" % stat_info.st_gid)
+ else:
+ # FIXME: no pwd under MS Windows (owner: 0, group: 0)
+ self.SetStringItem(index, 1, "%-8s" % stat_info.st_uid)
+ self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE)
+ self.SetColumnWidth(col=1, width=wx.LIST_AUTOSIZE)
+ def OnCheckItem(self, index, flag):
+ """Mapset checked/unchecked"""
+ mapset = self.parent.all_mapsets[index]
+ if mapset == 'PERMANENT' or mapset == self.parent.curr_mapset:
+ self.CheckItem(index, True)
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/render.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/render.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/render.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -83,6 +83,8 @@
@return name of file with rendered image or None
+ if len(self.cmdlist) == 0:
+ return
Debug.msg (3, "MapLayer.Render(): type=%s" % \
(self.type))
@@ -143,7 +145,10 @@
if not self.name:
return ''
- return self.name.split('@')[1]
+ try:
+ return self.name.split('@')[1]
+ except IndexError:
+ return self.name
def GetCmd(self, string=False):
@@ -691,7 +696,7 @@
return self.mapfile
def AddLayer(self, type, command, name=None,
- l_active=True, l_hidden=False, l_opacity=1, l_render=False):
+ l_active=True, l_hidden=False, l_opacity=1.0, l_render=False):
Adds generic display command layer to list of layers
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/utils.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/utils.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/utils.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -127,25 +127,6 @@
return catstr.strip(',')
-def CheckForWx():
- """Try to import wx module and check its version"""
- majorVersion = 2.8
- minorVersion = 1.1
- try:
- import wx
- version = wx.__version__
- if float(version[:3]) < majorVersion:
- raise ValueError('You are using wxPython version %s' % str(version))
- if float(version[:3]) == 2.8 and \
- float(version[4:]) < minorVersion:
- except (ImportError, ValueError), e:
- print >> sys.stderr, 'ERROR: ' + str(e) + \
- '. wxPython >= %s.%s is required. Detailed information in README file.' % \
- (str(majorVersion), str(minorVersion))
- sys.exit(1)
def ListOfMapsets():
"""Get list of available/accessible mapsets
Modified: grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -5,10 +5,6 @@
* AbstractLayer
* Layer
* LayerTree
- * GMConsole
- * GMStdout
- * GMStrerr
- * GMStc
* LoadMapLayersDialog
PURPOSE: Utility classes for GRASS wxPython GUI. Main functions include tree control
@@ -19,7 +15,7 @@
Jachym Cepicky (Mendel University of Agriculture)
Martin Landa <landa.martin gmail.com>
-COPYRIGHT: (C) 2007 by the GRASS Development Team
+COPYRIGHT: (C) 2007-2008 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -50,6 +46,8 @@
except:
from compat import subprocess
+TREE_ITEM_HEIGHT = 25
# define event for GRASS console (running GRASS command in separate thread)
(UpdateGMConsoleEvent, EVT_UPDATE_GMCONSOLE) = wx.lib.newevent.NewEvent()
@@ -62,17 +60,18 @@
size=wx.DefaultSize, style=wx.SUNKEN_BORDER,
ctstyle=CT.TR_HAS_BUTTONS | CT.TR_HAS_VARIABLE_ROW_HEIGHT |
- CT.TR_HIDE_ROOT | CT.TR_ROW_LINES | CT.TR_FULL_ROW_HIGHLIGHT|
- CT.TR_EDIT_LABELS|CT.TR_MULTIPLE,
+ CT.TR_HIDE_ROOT | CT.TR_ROW_LINES | CT.TR_FULL_ROW_HIGHLIGHT |
+ CT.TR_EDIT_LABELS | CT.TR_SINGLE,
idx=None, gismgr=None, notebook=None, auimgr=None, showMapDisplay=True):
CT.CustomTreeCtrl.__init__(self, parent, id, pos, size, style, ctstyle)
### SetAutoLayout() causes that no vertical scrollbar is displayed
### when some layers are not visible in layer tree
- # self.SetAutoLayout(True)
+ self.SetAutoLayout(True)
self.SetGradientStyle(1)
self.EnableSelectionGradient(True)
- self.SetFirstGradientColour(wx.Colour(150, 150, 150))
+ self.SetFirstGradientColour(wx.Colour(100, 100, 100))
+ self.SetSecondGradientColour(wx.Colour(150, 150, 150))
self.Map = render.Map() # instance of render.Map to be associated with display
self.root = None # ID of layer tree root node
@@ -107,15 +106,15 @@
self.mapdisplay.Refresh()
self.mapdisplay.Update()
- self.root = self.AddRoot("Map Layers")
+ self.root = self.AddRoot(_("Map Layers"))
self.SetPyData(self.root, (None,None))
#create image list to use with layer tree
- il = wx.ImageList(16, 16, False)
+ il = wx.ImageList(16, 16, mask=False)
- trart = wx.ArtProvider.GetBitmap(wx.ART_FOLDER_OPEN, wx.ART_OTHER, (16,16))
+ trart = wx.ArtProvider.GetBitmap(wx.ART_FOLDER_OPEN, wx.ART_OTHER, (16, 16))
self.folder_open = il.Add(trart)
- trart = wx.ArtProvider.GetBitmap(wx.ART_FOLDER, wx.ART_OTHER, (16,16))
+ trart = wx.ArtProvider.GetBitmap(wx.ART_FOLDER, wx.ART_OTHER, (16, 16))
self.folder = il.Add(trart)
bmpsize = (16, 16)
@@ -161,8 +160,6 @@
trgif = Icons["addcmd"].GetBitmap(bmpsize)
self.cmd_icon = il.Add(trgif)
- checksize = il.GetSize(0)
- checkbmp = il.GetBitmap(0)
self.AssignImageList(il)
# use when groups implemented
@@ -177,7 +174,7 @@
self.Bind(wx.EVT_TREE_DELETE_ITEM, self.OnDeleteLayer)
self.Bind(wx.EVT_TREE_BEGIN_DRAG, self.OnBeginDrag)
self.Bind(wx.EVT_TREE_END_DRAG, self.OnEndDrag)
- self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnContextMenu)
+ self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnLayerContextMenu)
self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnChangeLayerName)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
# self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
@@ -194,9 +191,8 @@
"""Change layer name"""
Debug.msg (3, "LayerTree.OnChangeLayerName: name=%s" % event.GetLabel())
- def OnContextMenu (self, event):
- """Context Layer Menu"""
+ def OnLayerContextMenu (self, event):
+ """Contextual menu for item/layer"""
if not self.layer_selected:
event.Skip()
return
@@ -217,6 +213,7 @@
self.popupID5 = wx.NewId()
self.popupID6 = wx.NewId()
self.popupID7 = wx.NewId()
+ self.popupID8 = wx.NewId()
self.popupMenu = wx.Menu()
# general item
@@ -231,6 +228,13 @@
if ltype != "group" and \
ltype != "command": # properties
self.popupMenu.AppendSeparator()
+ self.popupMenu.Append(self.popupID8, text=_("Change opacity level"), kind=wx.ITEM_CHECK)
+ if self.FindWindowById(self.GetPyData(self.layer_selected)[0]['ctrl']).GetName() == 'spinCtrl':
+ checked = True
+ else:
+ checked = False
+ self.popupMenu.Check(self.popupID8, checked)
+ self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id=self.popupID8)
self.popupMenu.Append(self.popupID3, text=_("Properties"))
self.Bind(wx.EVT_MENU, self.OnPopupProperties, id=self.popupID3)
@@ -368,6 +372,35 @@
"""Popup properties dialog"""
self.PropertiesDialog(self.layer_selected)
+ def OnPopupOpacityLevel(self, event):
+ """Popup opacity level indicator"""
+ if not self.GetPyData(self.layer_selected)[0]['ctrl']:
+ return
+ win = self.FindWindowById(self.GetPyData(self.layer_selected)[0]['ctrl'])
+ type = win.GetName()
+ self.layer_selected.DeleteWindow()
+ opacity = self.GetPyData(self.layer_selected)[0]['maplayer'].GetOpacity()
+ if type == 'staticText':
+ ctrl = wx.SpinCtrl(self, id=wx.ID_ANY, value="",
+ style=wx.SP_ARROW_KEYS, initial=100, min=0, max=100,
+ name='spinCtrl')
+ ctrl.SetValue(opacity)
+ self.Bind(wx.EVT_SPINCTRL, self.OnOpacity, ctrl)
+ else:
+ ctrl = wx.StaticText(self, id=wx.ID_ANY,
+ name='staticText')
+ if opacity < 100:
+ ctrl.SetLabel(' (' + str(opacity) + '%)')
+ self.GetPyData(self.layer_selected)[0]['ctrl'] = ctrl.GetId()
+ self.layer_selected.SetWindow(ctrl)
+ self.RefreshSelected()
+ self.Refresh()
def RenameLayer (self, event):
"""Rename layer"""
self.EditLabel(self.layer_selected)
@@ -378,6 +411,7 @@
Note: lcmd is given as a list
self.first = True
params = {} # no initial options parameters
@@ -397,15 +431,19 @@
elif ltype == 'group':
# group item
ctrl = None
- grouptext = 'Layer group:' + str(self.groupnode)
+ grouptext = _('Layer group:') + str(self.groupnode)
self.groupnode += 1
else:
# all other items (raster, vector, ...)
- ctrl = wx.SpinCtrl(self, id=wx.ID_ANY, value="", pos=(30, 50),
- style=wx.SP_ARROW_KEYS, initial=100, min=0, max=100)
- self.Bind(wx.EVT_SPINCTRL, self.OnOpacity, ctrl)
+ if UserSettings.Get(group='general', key='changeOpacityLevel', subkey='enabled'):
+ name='spinCtrl')
+ else:
# add layer to the layer tree
if self.layer_selected and self.layer_selected != self.GetRootItem():
if self.GetPyData(self.layer_selected)[0]['type'] != 'group':
@@ -442,43 +480,43 @@
# add text and icons for each layer ltype
if ltype == 'raster':
self.SetItemImage(layer, self.rast_icon)
- self.SetItemText(layer, 'raster (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('raster'), _('(double click to set properties)')))
elif ltype == 'rgb':
self.SetItemImage(layer, self.rgb_icon)
- self.SetItemText(layer, 'RGB (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('RGB'), _('(double click to set properties)')))
elif ltype == 'his':
self.SetItemImage(layer, self.his_icon)
- self.SetItemText(layer, 'HIS (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('HIS'), _('(double click to set properties)')))
elif ltype == 'shaded':
self.SetItemImage(layer, self.shaded_icon)
- self.SetItemText(layer, 'Shaded relief (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('Shaded relief'), _('(double click to set properties)')))
elif ltype == 'rastnum':
self.SetItemImage(layer, self.rnum_icon)
- self.SetItemText(layer, 'raster cell numbers (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('raster cell numbers'), _('(double click to set properties)')))
elif ltype == 'rastarrow':
self.SetItemImage(layer, self.rarrow_icon)
- self.SetItemText(layer, 'raster flow arrows (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('raster flow arrows'), _('(double click to set properties)')))
elif ltype == 'vector':
self.SetItemImage(layer, self.vect_icon)
- self.SetItemText(layer, 'vector (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('vector'), _('(double click to set properties)')))
elif ltype == 'thememap':
self.SetItemImage(layer, self.theme_icon)
- self.SetItemText(layer, 'thematic map (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('thematic map'), _('(double click to set properties)')))
elif ltype == 'themechart':
self.SetItemImage(layer, self.chart_icon)
- self.SetItemText(layer, 'thematic charts (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('thematic charts'), _('(double click to set properties)')))
elif ltype == 'grid':
self.SetItemImage(layer, self.grid_icon)
- self.SetItemText(layer, 'grid (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('grid'), _('(double click to set properties)')))
elif ltype == 'geodesic':
self.SetItemImage(layer, self.geodesic_icon)
- self.SetItemText(layer, 'geodesic line (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('geodesic line'), _('(double click to set properties)')))
elif ltype == 'rhumb':
self.SetItemImage(layer, self.rhumb_icon)
- self.SetItemText(layer, 'rhumbline (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('rhumbline'), _('(double click to set properties)')))
elif ltype == 'labels':
self.SetItemImage(layer, self.labels_icon)
- self.SetItemText(layer, 'vector labels (double click to set properties)')
+ self.SetItemText(layer, '%s %s' % (_('vector labels'), _('(double click to set properties)')))
elif ltype == 'command':
self.SetItemImage(layer, self.cmd_icon)
@@ -490,7 +528,11 @@
if ltype != 'group':
if lopacity:
opacity = lopacity
- ctrl.SetValue(int(lopacity * 100))
+ ctrl.SetValue(int(lopacity * 100))
+ else:
+ if opacity < 1.0:
+ ctrl.SetLabel(' (' + str(int(opacity * 100)) + '%)')
else:
opacity = 1.0
if lcmd and len(lcmd) > 1:
@@ -502,10 +544,15 @@
render = False
name = None
+ if ctrl:
+ ctrlId = ctrl.GetId()
+ else:
+ ctrlId = None
# add a data object to hold the layer's command (does not apply to generic command layers)
self.SetPyData(layer, ({'cmd': cmd,
'type' : ltype,
- 'ctrl' : ctrl,
+ 'ctrl' : ctrlId,
'maplayer' : None,
'prowin' : None},
None))
@@ -538,15 +585,25 @@
if checked is True:
self.mapdisplay.onRenderGauge.SetRange(len(self.Map.GetListOfLayers(l_active=True)))
+ # layer.SetHeight(TREE_ITEM_HEIGHT)
return layer
def PropertiesDialog (self, layer, show=True):
"""Launch the properties dialog"""
- global gmpath
+ if self.GetPyData(layer)[0].has_key('propwin') and \
+ self.GetPyData(layer)[0]['propwin'] is not None:
+ # recycle GUI dialogs
+ if self.GetPyData(layer)[0]['propwin'].IsShown():
+ self.GetPyData(layer)[0]['propwin'].SetFocus()
+ else:
+ self.GetPyData(layer)[0]['propwin'].Show()
+ return
completed = ''
params = self.GetPyData(layer)[1]
ltype = self.GetPyData(layer)[0]['type']
Debug.msg (3, "LayerTree.PropertiesDialog(): ltype=%s" % \
ltype)
@@ -684,7 +741,7 @@
def OnCmdChanged(self, event):
"""Change command string"""
- ctrl = event.GetEventObject()
+ ctrl = event.GetEventObject().GetId()
cmd = event.GetString()
layer = None
@@ -714,7 +771,7 @@
Debug.msg (3, "LayerTree.OnOpacity(): %s" % event.GetInt())
maplayer = None
vislayer = self.GetFirstVisibleItem()
@@ -742,6 +799,7 @@
self.mapdisplay.OnRender(None)
def OnChangeSel(self, event):
+ """Selection changed"""
oldlayer = event.GetOldItem()
layer = event.GetItem()
self.layer_selected = layer
@@ -789,6 +847,15 @@
Debug.msg (4, "LayerTree.RecreateItem(): layer=%s" % \
self.GetItemText(oldItem))
+ # fetch data (olditem)
+ text = self.GetItemText(oldItem)
+ image = self.GetItemImage(oldItem, 0)
+ if self.GetPyData(oldItem)[0]['ctrl']:
+ oldctrl = self.FindWindowById(self.GetPyData(oldItem)[0]['ctrl'])
+ else:
+ oldctrl = None
+ checked = self.IsItemChecked(oldItem)
# recreate spin/text control for layer
if self.GetPyData(oldItem)[0]['type'] == 'command':
newctrl = wx.TextCtrl(self, id=wx.ID_ANY, value='',
@@ -800,16 +867,21 @@
pass
newctrl.Bind(wx.EVT_TEXT_ENTER, self.OnCmdChanged)
newctrl.Bind(wx.EVT_TEXT, self.OnCmdChanged)
- elif self.GetPyData(oldItem)[0]['type'] == 'group':
+ elif self.GetPyData(oldItem)[0]['type'] == 'group' or oldctrl is None:
newctrl = None
else:
- newctrl = wx.SpinCtrl(self, id=wx.ID_ANY, value="", pos=(30, 50),
- style=wx.SP_ARROW_KEYS, min=0, max=100)
- try:
- newctrl.SetValue(self.GetPyData(oldItem)[0]['maplayer'].GetOpacity())
- except:
- newctrl.SetValue(100)
- self.Bind(wx.EVT_SPINCTRL, self.OnOpacity, newctrl)
+ opacity = self.GetPyData(oldItem)[0]['maplayer'].GetOpacity()
+ if oldctrl.GetName() == 'staticText':
+ newctrl = wx.StaticText(self, id=wx.ID_ANY,
+ if opacity < 100:
+ newctrl.SetLabel(' (' + str(opacity) + '%)')
+ else:
+ newctrl = wx.SpinCtrl(self, id=wx.ID_ANY, value="",
+ style=wx.SP_ARROW_KEYS, min=0, max=100,
+ name='spinCtrl')
+ newctrl.SetValue(opacity)
+ self.Bind(wx.EVT_SPINCTRL, self.OnOpacity, newctrl)
# decide where to put new layer and put it there
if not parent:
@@ -817,16 +889,11 @@
else:
flag = 0
- # fetch data
- text = self.GetItemText(oldItem)
- image = self.GetItemImage(oldItem, 0)
- wind = self.GetItemWindow(oldItem)
- checked = self.IsItemChecked(oldItem)
windval = None
data = None
else:
- windval = self.GetItemWindow(oldItem).GetValue()
+ windval = self.GetPyData(self.layer_selected)[0]['maplayer'].GetOpacity()
data = self.GetPyData(oldItem)
# create GenericTreeItem instance
@@ -859,11 +926,14 @@
# add layer at new position
self.SetPyData(newItem, self.GetPyData(oldItem))
- self.GetPyData(newItem)[0]['ctrl'] = newctrl
+ if newctrl:
+ self.GetPyData(newItem)[0]['ctrl'] = newctrl.GetId()
+ else:
+ self.GetPyData(newItem)[0]['ctrl'] = None
self.CheckItem(newItem, checked=checked)
- event.Skip()
+ # newItem.SetHeight(TREE_ITEM_HEIGHT)
return newItem
@@ -895,7 +965,11 @@
self.Expand(newItem)
# delete layer at original position
- self.Delete(old) # entry in render.Map layers list automatically deleted by OnDeleteLayer handler
+ try:
+ self.Delete(old) # entry in render.Map layers list automatically deleted by OnDeleteLayer handler
+ except AttributeError:
+ # FIXME being ugly (item.SetWindow(None))
+ pass
# reorder layers in render.Map to match new order after drag and drop
self.ReorderLayers()
@@ -910,14 +984,17 @@
"""Process layer data"""
# set layer text to map name
- mapname = utils.GetLayerNameFromCmd(dcmd)
- self.SetItemText(layer, mapname)
+ if dcmd:
+ mapname = utils.GetLayerNameFromCmd(dcmd)
+ self.SetItemText(layer, mapname)
# update layer data
- self.SetPyData(layer, (self.GetPyData(layer)[0], params))
- self.GetPyData(layer)[0]['cmd'] = dcmd
+ if params:
+ self.SetPyData(layer, (self.GetPyData(layer)[0], params))
+ if dcmd:
+ self.GetPyData(layer)[0]['cmd'] = dcmd
self.GetPyData(layer)[0]['propwin'] = propwin
# check layer as active
# self.CheckItem(layer, checked=True)
@@ -962,15 +1039,16 @@
type = self.GetPyData(item)[0]['type']
if type == 'command':
- if self.GetItemWindow(item).GetValue() != None:
- cmdlist = self.GetItemWindow(item).GetValue().split(' ')
+ win = self.FindWindowById(self.GetPyData(item)[0]['ctrl'])
+ if win.GetValue() != None:
+ cmdlist = win.GetValue().split(' ')
opac = 1.0
chk = self.IsItemChecked(item)
hidden = not self.IsVisible(item)
elif type != 'group':
if self.GetPyData(item)[0] is not None:
cmdlist = self.GetPyData(item)[0]['cmd']
- opac = float(self.GetItemWindow(item).GetValue())/100
+ opac = self.GetPyData(item)[0]['maplayer'].GetOpacity(float=True)
maplayer = self.Map.ChangeLayer(layer=self.GetPyData(item)[0]['maplayer'], type=type,
@@ -987,6 +1065,8 @@
if self.mapdisplay.autoRender.GetValue():
+ # item.SetHeight(TREE_ITEM_HEIGHT)
def setNotebookPage(self,pg):
self.parent.notebook.SetSelection(pg)
Modified: grass/branches/releasebranch_6_3/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_6_3/gui/wxpython/wxgui.py 2008-03-19 14:11:01 UTC (rev 30645)
+++ grass/branches/releasebranch_6_3/gui/wxpython/wxgui.py 2008-03-19 14:18:49 UTC (rev 30646)
@@ -52,8 +52,9 @@
gmpath = icons.__path__[0]
sys.path.append(gmpath)
-import gui_modules.utils as utils
-utils.CheckForWx()
+import gui_modules.globalvar as globalvar
import wx
import wx.aui
import wx.combo
@@ -67,6 +68,7 @@
except:
import compat.subprocess as subprocess
+import gui_modules.utils as utils
import gui_modules.preferences as preferences
import gui_modules.wxgui_utils as wxgui_utils
import gui_modules.mapdisp as mapdisp
@@ -80,7 +82,6 @@
import gui_modules.gcmd as gcmd
import gui_modules.georect as georect
import gui_modules.dbm as dbm
-import gui_modules.globalvar as globalvar
import gui_modules.workspace as workspace
import gui_modules.goutput as goutput
from gui_modules.debug import Debug as Debug
@@ -749,10 +750,9 @@
try:
file = open(filename, "w")
except IOError:
- dlg = wx.MessageDialog(self, _("Unable to open workspace file <%s> for writing.") % filename,
- _("Error"), wx.OK | wx.ICON_ERROR)
- dlg.ShowModal()
- dlg.Destroy()
+ wx.MessageBox(parent=self,
+ message=_("Unable to open workspace file <%s> for writing.") % filename,
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
return False
try:
@@ -773,17 +773,16 @@
self.indent =- 4
file.write('%s</gxw>\n' % (' ' * self.indent))
del self.indent
- except:
- dlg = wx.MessageDialog(self, _("Writing current settings to workspace file failed."),
- dlg.ShowModal()
- dlg.Destroy()
+ except StandardError, e:
+ file.close()
+ wx.MessageBox(parent=self, message=_("Writing current settings to workspace file failed (%s)." % e),
return False
file.close()
return True
def OnWorkspaceClose(self, event=None):
"""Close file with workspace definition
@@ -919,7 +918,6 @@
if not label:
toolbar.AddSeparator()
return
tool = toolbar.AddLabelTool(id=wx.ID_ANY, label=label, bitmap=icon, shortHelp=help)
self.Bind(wx.EVT_TOOL, handler, tool)
@@ -1233,7 +1231,7 @@
dlg = wx.MessageDialog (parent=self, message=message,
caption=_("Remove map layer"),
- style=wx.YES_NO | wx.NO_DEFAULT | wx.CANCEL | wx.ICON_QUESTION)
+ style=wx.YES_NO | wx.YES_DEFAULT | wx.CANCEL | wx.ICON_QUESTION)
if dlg.ShowModal() in [wx.ID_NO, wx.ID_CANCEL]:
dlg.Destroy()
