[GRASS-SVN] r30653 - grass-addons/raster/r.sun_horizon/r.sun2
svn_grass at osgeo.org
Thu Mar 20 09:20:53 EDT 2008
Author: neteler
Date: 2008-03-20 09:20:53 -0400 (Thu, 20 Mar 2008)
New Revision: 30653
grass-addons/raster/r.sun_horizon/r.sun2/main.c
Thomas Huld <Thomas.Huld jrc.it>: bugfix: the code did not calculate the distance along the line of sight to the sun correctly, it calculated them in lat/lon distances, while the height difference was in meters! This was never correct in r.sun.
This is a workaround for lat/lon coordinates and it then REQUIRES that the elevation map is in meters. The rule is: - lat/lon coordinates: elevation in meters - Other coordinates: elevation in the same unit as the easting-northing coordinates.
Modified: grass-addons/raster/r.sun_horizon/r.sun2/main.c
--- grass-addons/raster/r.sun_horizon/r.sun2/main.c 2008-03-19 22:39:54 UTC (rev 30652)
+++ grass-addons/raster/r.sun_horizon/r.sun2/main.c 2008-03-20 13:20:53 UTC (rev 30653)
@@ -174,6 +174,30 @@
double cbh, cdh;
double TOLER;
+#define DEGREEINMETERS 111120.
+int ll_correction=0;
+double coslatsq;
+double distance(double x1, double x2, double y1, double y2)
+ if(ll_correction)
+ return DEGREEINMETERS*sqrt(coslatsq*(x1-x2)*(x1-x2)
+ +(y1-y2)*(y1-y2));
+ else
+ return sqrt((x1 - x2)*(x1 - x2) + (y1 - y2)*(y1 - y2));
int main(int argc, char *argv[])
double singleSlope;
@@ -710,6 +734,12 @@
/**********end of parser - ******************************/
+ if ((G_projection() == PROJECTION_LL))
+ ll_correction=1;
calculate(singleSlope, singleAspect, singleAlbedo,
singleLinke,gridGeom);
OUTGR();
@@ -1557,7 +1587,7 @@
dx = (double)i *gridGeom->stepx;
dy = (double)j *gridGeom->stepy;
- *length = DISTANCE1(gridGeom->xg0, dx, gridGeom->yg0, dy); /* dist from orig. grid point to the current grid point */
+ *length = distance(gridGeom->xg0, dx, gridGeom->yg0, dy); /* dist from orig. grid point to the current grid point */
sunVarGeom->zp = z[j][i];
@@ -1732,6 +1762,7 @@
double longitTime=0.;
double locTimeOffset;
double latitude, longitude;
+ double coslat;
struct SunGeometryConstDay sunGeom;
@@ -1885,6 +1916,11 @@
gridGeom.xp=xmin+gridGeom.xx0;
gridGeom.yp=ymin+gridGeom.yy0;
+ if(ll_correction)
+ coslat=cos(deg2rad*gridGeom.yp);
+ coslatsq = coslat*coslat;
func = NULL;
