[GRASS-SVN] r30675 - grass/trunk/raster/r.in.xyz
svn_grass at osgeo.org
Fri Mar 21 07:31:16 EDT 2008
Author: neteler
Date: 2008-03-21 07:31:16 -0400 (Fri, 21 Mar 2008)
New Revision: 30675
grass/trunk/raster/r.in.xyz/local_proto.h
grass/trunk/raster/r.in.xyz/main.c
Ignore broken lines added
Modified: grass/trunk/raster/r.in.xyz/local_proto.h
--- grass/trunk/raster/r.in.xyz/local_proto.h 2008-03-21 10:51:35 UTC (rev 30674)
+++ grass/trunk/raster/r.in.xyz/local_proto.h 2008-03-21 11:31:16 UTC (rev 30675)
@@ -38,7 +38,7 @@
#define METHOD_TRIMMEAN 13
/* main.c */
-int scan_bounds(FILE*, int, int, int, char*, int);
+int scan_bounds(FILE*, int, int, int, char*, int, int);
/* support.c */
int blank_array(void *, int, int, RASTER_MAP_TYPE, int);
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c 2008-03-21 10:51:35 UTC (rev 30674)
+++ grass/trunk/raster/r.in.xyz/main.c 2008-03-21 11:31:16 UTC (rev 30675)
@@ -142,7 +142,7 @@
struct Option *input_opt, *output_opt, *delim_opt, *percent_opt, *type_opt;
struct Option *method_opt, *xcol_opt, *ycol_opt, *zcol_opt, *zrange_opt;
struct Option *trim_opt, *pth_opt;
- struct Flag *scan_flag, *shell_style;
+ struct Flag *scan_flag, *shell_style, *skipline;
G_gisinit(argv[0]);
@@ -244,6 +244,9 @@
shell_style->key = 'g';
shell_style->description = _("In scan mode, print using shell script style");
+ skipline = G_define_flag();
+ skipline->key = 'i';
+ skipline->description = _("Ignore broken lines");
if (G_parser(argc,argv))
exit(EXIT_FAILURE);
@@ -450,7 +453,7 @@
if( zrange_opt->answer )
G_warning(_("zrange will not be taken into account during scan"));
- scan_bounds(in_fp, xcol, ycol, zcol, fs, shell_style->answer);
+ scan_bounds(in_fp, xcol, ycol, zcol, fs, shell_style->answer, skipline->answer);
if(!from_stdin)
fclose(in_fp);
@@ -559,10 +562,19 @@
tokens = G_tokenize (buff, fs);
ntokens = G_number_of_tokens ( tokens );
- if((ntokens < 3) || (max_col > ntokens) )
- G_fatal_error(_("Not enough data columns. "
- "Incorrect delimiter or column number? "
- "Found the following character(s) in row %d:\n[%s]"), line, buff);
+ if((ntokens < 3) || (max_col > ntokens) ) {
+ if (skipline->answer) {
+ G_warning(_("Not enough data columns. "
+ "Incorrect delimiter or column number? "
+ "Found the following character(s) in row %d:\n[%s]"), line, buff);
+ G_warning(_("Line ignored as requested"));
+ continue; /* line is garbage */
+ } else {
+ G_fatal_error(_("Not enough data columns. "
/* too slow?
if ( G_projection() == PROJECTION_LL ) {
@@ -999,7 +1011,7 @@
-int scan_bounds(FILE* fp, int xcol, int ycol, int zcol, char *fs, int shell_style)
+int scan_bounds(FILE* fp, int xcol, int ycol, int zcol, char *fs, int shell_style, int skipline)
int line, first, max_col;
char buff[BUFFSIZE];
@@ -1027,9 +1039,19 @@
- "Incorrect delimiter or column number?\n[%s]"), buff);
+ if (skipline) {
+ } else {
/* too slow?
