[GRASS-SVN] r30693 -
grass/branches/releasebranch_6_3/gui/wxpython/vdigit
svn_grass at osgeo.org
Sat Mar 22 10:50:12 EDT 2008
Author: martinl
Date: 2008-03-22 10:50:12 -0400 (Sat, 22 Mar 2008)
New Revision: 30693
Removed:
grass/branches/releasebranch_6_3/gui/wxpython/vdigit/grass6_wxvdigit.py
grass/branches/releasebranch_6_3/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
Build wrappers using SWIG (backported from trunk, r30684)
Deleted: grass/branches/releasebranch_6_3/gui/wxpython/vdigit/grass6_wxvdigit.py
--- grass/branches/releasebranch_6_3/gui/wxpython/vdigit/grass6_wxvdigit.py 2008-03-22 14:41:49 UTC (rev 30692)
+++ grass/branches/releasebranch_6_3/gui/wxpython/vdigit/grass6_wxvdigit.py 2008-03-22 14:50:12 UTC (rev 30693)
@@ -1,303 +0,0 @@
-# This file was automatically generated by SWIG (http://www.swig.org).
-# Version 1.3.33
-# Don't modify this file, modify the SWIG interface instead.
-# This file is compatible with both classic and new-style classes.
-import _grass6_wxvdigit
-import new
-new_instancemethod = new.instancemethod
-try:
- _swig_property = property
-except NameError:
- pass # Python < 2.2 doesn't have 'property'.
-def _swig_setattr_nondynamic(self,class_type,name,value,static=1):
- if (name == "thisown"): return self.this.own(value)
- if (name == "this"):
- if type(value).__name__ == 'PySwigObject':
- self.__dict__[name] = value
- return
- method = class_type.__swig_setmethods__.get(name,None)
- if method: return method(self,value)
- if (not static) or hasattr(self,name):
- else:
- raise AttributeError("You cannot add attributes to %s" % self)
-def _swig_setattr(self,class_type,name,value):
- return _swig_setattr_nondynamic(self,class_type,name,value,0)
-def _swig_getattr(self,class_type,name):
- if (name == "thisown"): return self.this.own()
- method = class_type.__swig_getmethods__.get(name,None)
- if method: return method(self)
- raise AttributeError,name
-def _swig_repr(self):
- try: strthis = "proxy of " + self.this.__repr__()
- except: strthis = ""
- return "<%s.%s; %s >" % (self.__class__.__module__, self.__class__.__name__, strthis,)
-import types
-try:
- _object = types.ObjectType
- _newclass = 1
-except AttributeError:
- class _object : pass
- _newclass = 0
-del types
-class PySwigIterator(_object):
- __swig_setmethods__ = {}
- __setattr__ = lambda self, name, value: _swig_setattr(self, PySwigIterator, name, value)
- __swig_getmethods__ = {}
- __getattr__ = lambda self, name: _swig_getattr(self, PySwigIterator, name)
- def __init__(self): raise AttributeError, "No constructor defined"
- __repr__ = _swig_repr
- __swig_destroy__ = _grass6_wxvdigit.delete_PySwigIterator
- __del__ = lambda self : None;
- def value(*args): return _grass6_wxvdigit.PySwigIterator_value(*args)
- def incr(*args): return _grass6_wxvdigit.PySwigIterator_incr(*args)
- def decr(*args): return _grass6_wxvdigit.PySwigIterator_decr(*args)
- def distance(*args): return _grass6_wxvdigit.PySwigIterator_distance(*args)
- def equal(*args): return _grass6_wxvdigit.PySwigIterator_equal(*args)
- def copy(*args): return _grass6_wxvdigit.PySwigIterator_copy(*args)
- def next(*args): return _grass6_wxvdigit.PySwigIterator_next(*args)
- def previous(*args): return _grass6_wxvdigit.PySwigIterator_previous(*args)
- def advance(*args): return _grass6_wxvdigit.PySwigIterator_advance(*args)
- def __eq__(*args): return _grass6_wxvdigit.PySwigIterator___eq__(*args)
- def __ne__(*args): return _grass6_wxvdigit.PySwigIterator___ne__(*args)
- def __iadd__(*args): return _grass6_wxvdigit.PySwigIterator___iadd__(*args)
- def __isub__(*args): return _grass6_wxvdigit.PySwigIterator___isub__(*args)
- def __add__(*args): return _grass6_wxvdigit.PySwigIterator___add__(*args)
- def __sub__(*args): return _grass6_wxvdigit.PySwigIterator___sub__(*args)
- def __iter__(self): return self
-PySwigIterator_swigregister = _grass6_wxvdigit.PySwigIterator_swigregister
-PySwigIterator_swigregister(PySwigIterator)
-class IntVector(_object):
- __setattr__ = lambda self, name, value: _swig_setattr(self, IntVector, name, value)
- __getattr__ = lambda self, name: _swig_getattr(self, IntVector, name)
- def iterator(*args): return _grass6_wxvdigit.IntVector_iterator(*args)
- def __iter__(self): return self.iterator()
- def __nonzero__(*args): return _grass6_wxvdigit.IntVector___nonzero__(*args)
- def __len__(*args): return _grass6_wxvdigit.IntVector___len__(*args)
- def pop(*args): return _grass6_wxvdigit.IntVector_pop(*args)
- def __getslice__(*args): return _grass6_wxvdigit.IntVector___getslice__(*args)
- def __setslice__(*args): return _grass6_wxvdigit.IntVector___setslice__(*args)
- def __delslice__(*args): return _grass6_wxvdigit.IntVector___delslice__(*args)
- def __delitem__(*args): return _grass6_wxvdigit.IntVector___delitem__(*args)
- def __getitem__(*args): return _grass6_wxvdigit.IntVector___getitem__(*args)
- def __setitem__(*args): return _grass6_wxvdigit.IntVector___setitem__(*args)
- def append(*args): return _grass6_wxvdigit.IntVector_append(*args)
- def empty(*args): return _grass6_wxvdigit.IntVector_empty(*args)
- def size(*args): return _grass6_wxvdigit.IntVector_size(*args)
- def clear(*args): return _grass6_wxvdigit.IntVector_clear(*args)
- def swap(*args): return _grass6_wxvdigit.IntVector_swap(*args)
- def get_allocator(*args): return _grass6_wxvdigit.IntVector_get_allocator(*args)
- def begin(*args): return _grass6_wxvdigit.IntVector_begin(*args)
- def end(*args): return _grass6_wxvdigit.IntVector_end(*args)
- def rbegin(*args): return _grass6_wxvdigit.IntVector_rbegin(*args)
- def rend(*args): return _grass6_wxvdigit.IntVector_rend(*args)
- def pop_back(*args): return _grass6_wxvdigit.IntVector_pop_back(*args)
- def erase(*args): return _grass6_wxvdigit.IntVector_erase(*args)
- def __init__(self, *args):
- this = _grass6_wxvdigit.new_IntVector(*args)
- try: self.this.append(this)
- except: self.this = this
- def push_back(*args): return _grass6_wxvdigit.IntVector_push_back(*args)
- def front(*args): return _grass6_wxvdigit.IntVector_front(*args)
- def back(*args): return _grass6_wxvdigit.IntVector_back(*args)
- def assign(*args): return _grass6_wxvdigit.IntVector_assign(*args)
- def resize(*args): return _grass6_wxvdigit.IntVector_resize(*args)
- def insert(*args): return _grass6_wxvdigit.IntVector_insert(*args)
- def reserve(*args): return _grass6_wxvdigit.IntVector_reserve(*args)
- def capacity(*args): return _grass6_wxvdigit.IntVector_capacity(*args)
- __swig_destroy__ = _grass6_wxvdigit.delete_IntVector
-IntVector_swigregister = _grass6_wxvdigit.IntVector_swigregister
-IntVector_swigregister(IntVector)
-class DoubleVector(_object):
- __setattr__ = lambda self, name, value: _swig_setattr(self, DoubleVector, name, value)
- __getattr__ = lambda self, name: _swig_getattr(self, DoubleVector, name)
- def iterator(*args): return _grass6_wxvdigit.DoubleVector_iterator(*args)
- def __nonzero__(*args): return _grass6_wxvdigit.DoubleVector___nonzero__(*args)
- def __len__(*args): return _grass6_wxvdigit.DoubleVector___len__(*args)
- def pop(*args): return _grass6_wxvdigit.DoubleVector_pop(*args)
- def __getslice__(*args): return _grass6_wxvdigit.DoubleVector___getslice__(*args)
- def __setslice__(*args): return _grass6_wxvdigit.DoubleVector___setslice__(*args)
- def __delslice__(*args): return _grass6_wxvdigit.DoubleVector___delslice__(*args)
- def __delitem__(*args): return _grass6_wxvdigit.DoubleVector___delitem__(*args)
- def __getitem__(*args): return _grass6_wxvdigit.DoubleVector___getitem__(*args)
- def __setitem__(*args): return _grass6_wxvdigit.DoubleVector___setitem__(*args)
- def append(*args): return _grass6_wxvdigit.DoubleVector_append(*args)
- def empty(*args): return _grass6_wxvdigit.DoubleVector_empty(*args)
- def size(*args): return _grass6_wxvdigit.DoubleVector_size(*args)
- def clear(*args): return _grass6_wxvdigit.DoubleVector_clear(*args)
- def swap(*args): return _grass6_wxvdigit.DoubleVector_swap(*args)
- def get_allocator(*args): return _grass6_wxvdigit.DoubleVector_get_allocator(*args)
- def begin(*args): return _grass6_wxvdigit.DoubleVector_begin(*args)
- def end(*args): return _grass6_wxvdigit.DoubleVector_end(*args)
- def rbegin(*args): return _grass6_wxvdigit.DoubleVector_rbegin(*args)
- def rend(*args): return _grass6_wxvdigit.DoubleVector_rend(*args)
- def pop_back(*args): return _grass6_wxvdigit.DoubleVector_pop_back(*args)
- def erase(*args): return _grass6_wxvdigit.DoubleVector_erase(*args)
- this = _grass6_wxvdigit.new_DoubleVector(*args)
- def push_back(*args): return _grass6_wxvdigit.DoubleVector_push_back(*args)
- def front(*args): return _grass6_wxvdigit.DoubleVector_front(*args)
- def back(*args): return _grass6_wxvdigit.DoubleVector_back(*args)
- def assign(*args): return _grass6_wxvdigit.DoubleVector_assign(*args)
- def resize(*args): return _grass6_wxvdigit.DoubleVector_resize(*args)
- def insert(*args): return _grass6_wxvdigit.DoubleVector_insert(*args)
- def reserve(*args): return _grass6_wxvdigit.DoubleVector_reserve(*args)
- def capacity(*args): return _grass6_wxvdigit.DoubleVector_capacity(*args)
- __swig_destroy__ = _grass6_wxvdigit.delete_DoubleVector
-DoubleVector_swigregister = _grass6_wxvdigit.DoubleVector_swigregister
-DoubleVector_swigregister(DoubleVector)
-class IntVecIntMap(_object):
- __setattr__ = lambda self, name, value: _swig_setattr(self, IntVecIntMap, name, value)
- __getattr__ = lambda self, name: _swig_getattr(self, IntVecIntMap, name)
- def iterator(*args): return _grass6_wxvdigit.IntVecIntMap_iterator(*args)
- def __nonzero__(*args): return _grass6_wxvdigit.IntVecIntMap___nonzero__(*args)
- def __len__(*args): return _grass6_wxvdigit.IntVecIntMap___len__(*args)
- def __getitem__(*args): return _grass6_wxvdigit.IntVecIntMap___getitem__(*args)
- def __delitem__(*args): return _grass6_wxvdigit.IntVecIntMap___delitem__(*args)
- def has_key(*args): return _grass6_wxvdigit.IntVecIntMap_has_key(*args)
- def keys(*args): return _grass6_wxvdigit.IntVecIntMap_keys(*args)
- def values(*args): return _grass6_wxvdigit.IntVecIntMap_values(*args)
- def items(*args): return _grass6_wxvdigit.IntVecIntMap_items(*args)
- def __contains__(*args): return _grass6_wxvdigit.IntVecIntMap___contains__(*args)
- def key_iterator(*args): return _grass6_wxvdigit.IntVecIntMap_key_iterator(*args)
- def value_iterator(*args): return _grass6_wxvdigit.IntVecIntMap_value_iterator(*args)
- def __iter__(self): return self.key_iterator()
- def iterkeys(self): return self.key_iterator()
- def itervalues(self): return self.value_iterator()
- def iteritems(self): return self.iterator()
- def __setitem__(*args): return _grass6_wxvdigit.IntVecIntMap___setitem__(*args)
- this = _grass6_wxvdigit.new_IntVecIntMap(*args)
- def empty(*args): return _grass6_wxvdigit.IntVecIntMap_empty(*args)
- def size(*args): return _grass6_wxvdigit.IntVecIntMap_size(*args)
- def clear(*args): return _grass6_wxvdigit.IntVecIntMap_clear(*args)
- def swap(*args): return _grass6_wxvdigit.IntVecIntMap_swap(*args)
- def get_allocator(*args): return _grass6_wxvdigit.IntVecIntMap_get_allocator(*args)
- def begin(*args): return _grass6_wxvdigit.IntVecIntMap_begin(*args)
- def end(*args): return _grass6_wxvdigit.IntVecIntMap_end(*args)
- def rbegin(*args): return _grass6_wxvdigit.IntVecIntMap_rbegin(*args)
- def rend(*args): return _grass6_wxvdigit.IntVecIntMap_rend(*args)
- def count(*args): return _grass6_wxvdigit.IntVecIntMap_count(*args)
- def erase(*args): return _grass6_wxvdigit.IntVecIntMap_erase(*args)
- def find(*args): return _grass6_wxvdigit.IntVecIntMap_find(*args)
- def lower_bound(*args): return _grass6_wxvdigit.IntVecIntMap_lower_bound(*args)
- def upper_bound(*args): return _grass6_wxvdigit.IntVecIntMap_upper_bound(*args)
- __swig_destroy__ = _grass6_wxvdigit.delete_IntVecIntMap
-IntVecIntMap_swigregister = _grass6_wxvdigit.IntVecIntMap_swigregister
-IntVecIntMap_swigregister(IntVecIntMap)
-class DisplayDriver(_object):
- __setattr__ = lambda self, name, value: _swig_setattr(self, DisplayDriver, name, value)
- __getattr__ = lambda self, name: _swig_getattr(self, DisplayDriver, name)
- this = _grass6_wxvdigit.new_DisplayDriver(*args)
- __swig_destroy__ = _grass6_wxvdigit.delete_DisplayDriver
- def DrawMap(*args): return _grass6_wxvdigit.DisplayDriver_DrawMap(*args)
- def SelectLinesByBox(*args): return _grass6_wxvdigit.DisplayDriver_SelectLinesByBox(*args)
- def SelectLineByPoint(*args): return _grass6_wxvdigit.DisplayDriver_SelectLineByPoint(*args)
- def GetSelected(*args): return _grass6_wxvdigit.DisplayDriver_GetSelected(*args)
- def SetSelected(*args): return _grass6_wxvdigit.DisplayDriver_SetSelected(*args)
- def GetSelectedVertex(*args): return _grass6_wxvdigit.DisplayDriver_GetSelectedVertex(*args)
- def CloseMap(*args): return _grass6_wxvdigit.DisplayDriver_CloseMap(*args)
- def OpenMap(*args): return _grass6_wxvdigit.DisplayDriver_OpenMap(*args)
- def ReloadMap(*args): return _grass6_wxvdigit.DisplayDriver_ReloadMap(*args)
- def SetDevice(*args): return _grass6_wxvdigit.DisplayDriver_SetDevice(*args)
- def GetMapBoundingBox(*args): return _grass6_wxvdigit.DisplayDriver_GetMapBoundingBox(*args)
- def SetRegion(*args): return _grass6_wxvdigit.DisplayDriver_SetRegion(*args)
- def UpdateSettings(*args): return _grass6_wxvdigit.DisplayDriver_UpdateSettings(*args)
-DisplayDriver_swigregister = _grass6_wxvdigit.DisplayDriver_swigregister
-DisplayDriver_swigregister(DisplayDriver)
-print_error = _grass6_wxvdigit.print_error
-GSQL_MAX = _grass6_wxvdigit.GSQL_MAX
-class Digit(_object):
- __setattr__ = lambda self, name, value: _swig_setattr(self, Digit, name, value)
- __getattr__ = lambda self, name: _swig_getattr(self, Digit, name)
- this = _grass6_wxvdigit.new_Digit(*args)
- def InitCats(*args): return _grass6_wxvdigit.Digit_InitCats(*args)
- def AddLine(*args): return _grass6_wxvdigit.Digit_AddLine(*args)
- def RewriteLine(*args): return _grass6_wxvdigit.Digit_RewriteLine(*args)
- def SplitLine(*args): return _grass6_wxvdigit.Digit_SplitLine(*args)
- def DeleteLines(*args): return _grass6_wxvdigit.Digit_DeleteLines(*args)
- def MoveLines(*args): return _grass6_wxvdigit.Digit_MoveLines(*args)
- def FlipLines(*args): return _grass6_wxvdigit.Digit_FlipLines(*args)
- def MergeLines(*args): return _grass6_wxvdigit.Digit_MergeLines(*args)
- def BreakLines(*args): return _grass6_wxvdigit.Digit_BreakLines(*args)
- def SnapLines(*args): return _grass6_wxvdigit.Digit_SnapLines(*args)
- def ConnectLines(*args): return _grass6_wxvdigit.Digit_ConnectLines(*args)
- def TypeConvLines(*args): return _grass6_wxvdigit.Digit_TypeConvLines(*args)
- def ZBulkLabeling(*args): return _grass6_wxvdigit.Digit_ZBulkLabeling(*args)
- def CopyLines(*args): return _grass6_wxvdigit.Digit_CopyLines(*args)
- def MoveVertex(*args): return _grass6_wxvdigit.Digit_MoveVertex(*args)
- def ModifyLineVertex(*args): return _grass6_wxvdigit.Digit_ModifyLineVertex(*args)
- def SelectLinesByQuery(*args): return _grass6_wxvdigit.Digit_SelectLinesByQuery(*args)
- def CopyCats(*args): return _grass6_wxvdigit.Digit_CopyCats(*args)
- def GetCategory(*args): return _grass6_wxvdigit.Digit_GetCategory(*args)
- def GetLineCats(*args): return _grass6_wxvdigit.Digit_GetLineCats(*args)
- def SetLineCats(*args): return _grass6_wxvdigit.Digit_SetLineCats(*args)
- def GetLayers(*args): return _grass6_wxvdigit.Digit_GetLayers(*args)
- __swig_destroy__ = _grass6_wxvdigit.delete_Digit
-Digit_swigregister = _grass6_wxvdigit.Digit_swigregister
-Digit_swigregister(Digit)
-GV_POINT = _grass6_wxvdigit.GV_POINT
-GV_LINE = _grass6_wxvdigit.GV_LINE
-GV_BOUNDARY = _grass6_wxvdigit.GV_BOUNDARY
-GV_CENTROID = _grass6_wxvdigit.GV_CENTROID
-GV_FACE = _grass6_wxvdigit.GV_FACE
-GV_KERNEL = _grass6_wxvdigit.GV_KERNEL
-GV_AREA = _grass6_wxvdigit.GV_AREA
-GV_VOLUME = _grass6_wxvdigit.GV_VOLUME
-GV_POINTS = _grass6_wxvdigit.GV_POINTS
-GV_LINES = _grass6_wxvdigit.GV_LINES
-PORT_DOUBLE_MAX = _grass6_wxvdigit.PORT_DOUBLE_MAX
-NO_SNAP = _grass6_wxvdigit.NO_SNAP
-SNAP = _grass6_wxvdigit.SNAP
-SNAPVERTEX = _grass6_wxvdigit.SNAPVERTEX
-QUERY_UNKNOWN = _grass6_wxvdigit.QUERY_UNKNOWN
-QUERY_LENGTH = _grass6_wxvdigit.QUERY_LENGTH
-QUERY_DANGLE = _grass6_wxvdigit.QUERY_DANGLE
Deleted: grass/branches/releasebranch_6_3/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
--- grass/branches/releasebranch_6_3/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp 2008-03-22 14:41:49 UTC (rev 30692)
+++ grass/branches/releasebranch_6_3/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp 2008-03-22 14:50:12 UTC (rev 30693)
@@ -1,12747 +0,0 @@
- * This file was automatically generated by SWIG (http://www.swig.org).
- * Version 1.3.33
- * This file is not intended to be easily readable and contains a number of
- * coding conventions designed to improve portability and efficiency. Do not make
- * changes to this file unless you know what you are doing--modify the SWIG
- * interface file instead.
-#define SWIGPYTHON
-#define SWIG_PYTHON_DIRECTOR_NO_VTABLE
-#ifdef __cplusplus
-template<typename T> class SwigValueWrapper {
- T *tt;
-public:
- SwigValueWrapper() : tt(0) { }
- SwigValueWrapper(const SwigValueWrapper<T>& rhs) : tt(new T(*rhs.tt)) { }
- SwigValueWrapper(const T& t) : tt(new T(t)) { }
- ~SwigValueWrapper() { delete tt; }
- SwigValueWrapper& operator=(const T& t) { delete tt; tt = new T(t); return *this; }
- operator T&() const { return *tt; }
- T *operator&() { return tt; }
-private:
- SwigValueWrapper& operator=(const SwigValueWrapper<T>& rhs);
-template <typename T> T SwigValueInit() {
- return T();
-#endif
- * This section contains generic SWIG labels for method/variable
- * declarations/attributes, and other compiler dependent labels.
-/* template workaround for compilers that cannot correctly implement the C++ standard */
-#ifndef SWIGTEMPLATEDISAMBIGUATOR
-# if defined(__SUNPRO_CC) && (__SUNPRO_CC <= 0x560)
-# define SWIGTEMPLATEDISAMBIGUATOR template
-# elif defined(__HP_aCC)
-/* Needed even with `aCC -AA' when `aCC -V' reports HP ANSI C++ B3910B A.03.55 */
-/* If we find a maximum version that requires this, the test would be __HP_aCC <= 35500 for A.03.55 */
-# else
-# endif
-#endif
-/* inline attribute */
-#ifndef SWIGINLINE
-# if defined(__cplusplus) || (defined(__GNUC__) && !defined(__STRICT_ANSI__))
-# define SWIGINLINE inline
-# else
-# endif
-#endif
-/* attribute recognised by some compilers to avoid 'unused' warnings */
-#ifndef SWIGUNUSED
-# if defined(__GNUC__)
-# if !(defined(__cplusplus)) || (__GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4))
-# define SWIGUNUSED __attribute__ ((__unused__))
-# else
-# endif
-# elif defined(__ICC)
-# else
-# endif
-#endif
-#ifndef SWIGUNUSEDPARM
-# ifdef __cplusplus
-# define SWIGUNUSEDPARM(p)
-# else
-# define SWIGUNUSEDPARM(p) p SWIGUNUSED
-# endif
-#endif
-/* internal SWIG method */
-#ifndef SWIGINTERN
-# define SWIGINTERN static SWIGUNUSED
-#endif
-/* internal inline SWIG method */
-#ifndef SWIGINTERNINLINE
-# define SWIGINTERNINLINE SWIGINTERN SWIGINLINE
-#endif
-/* exporting methods */
-#if (__GNUC__ >= 4) || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4)
-# ifndef GCC_HASCLASSVISIBILITY
-# define GCC_HASCLASSVISIBILITY
-# endif
-#endif
-#ifndef SWIGEXPORT
-# if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
-# if defined(STATIC_LINKED)
-# define SWIGEXPORT
-# else
-# define SWIGEXPORT __declspec(dllexport)
-# endif
-# else
-# if defined(__GNUC__) && defined(GCC_HASCLASSVISIBILITY)
-# define SWIGEXPORT __attribute__ ((visibility("default")))
-# else
-# endif
-# endif
-#endif
-/* calling conventions for Windows */
-#ifndef SWIGSTDCALL
-# define SWIGSTDCALL __stdcall
-# else
-# endif
-#endif
-/* Deal with Microsoft's attempt at deprecating C standard runtime functions */
-#if !defined(SWIG_NO_CRT_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_CRT_SECURE_NO_DEPRECATE)
-# define _CRT_SECURE_NO_DEPRECATE
-#endif
-/* Deal with Microsoft's attempt at deprecating methods in the standard C++ library */
-#if !defined(SWIG_NO_SCL_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_SCL_SECURE_NO_DEPRECATE)
-# define _SCL_SECURE_NO_DEPRECATE
-#endif
-/* Python.h has to appear first */
-#include <Python.h>
- * swigrun.swg
- * This file contains generic CAPI SWIG runtime support for pointer
- * type checking.
-/* This should only be incremented when either the layout of swig_type_info changes,
- or for whatever reason, the runtime changes incompatibly */
-#define SWIG_RUNTIME_VERSION "3"
-/* define SWIG_TYPE_TABLE_NAME as "SWIG_TYPE_TABLE" */
-#ifdef SWIG_TYPE_TABLE
-# define SWIG_QUOTE_STRING(x) #x
-# define SWIG_EXPAND_AND_QUOTE_STRING(x) SWIG_QUOTE_STRING(x)
-# define SWIG_TYPE_TABLE_NAME SWIG_EXPAND_AND_QUOTE_STRING(SWIG_TYPE_TABLE)
-#else
-#endif
- You can use the SWIGRUNTIME and SWIGRUNTIMEINLINE macros for
- creating a static or dynamic library from the swig runtime code.
- In 99.9% of the cases, swig just needs to declare them as 'static'.
- But only do this if is strictly necessary, ie, if you have problems
- with your compiler or so.
-#ifndef SWIGRUNTIME
-# define SWIGRUNTIME SWIGINTERN
-#endif
-#ifndef SWIGRUNTIMEINLINE
-# define SWIGRUNTIMEINLINE SWIGRUNTIME SWIGINLINE
-#endif
-/* Generic buffer size */
-#ifndef SWIG_BUFFER_SIZE
-# define SWIG_BUFFER_SIZE 1024
-#endif
-/* Flags for pointer conversions */
-#define SWIG_POINTER_DISOWN 0x1
-/* Flags for new pointer objects */
-#define SWIG_POINTER_OWN 0x1
- Flags/methods for returning states.
- The swig conversion methods, as ConvertPtr, return and integer
- that tells if the conversion was successful or not. And if not,
- an error code can be returned (see swigerrors.swg for the codes).
- Use the following macros/flags to set or process the returning
- states.
- In old swig versions, you usually write code as:
- if (SWIG_ConvertPtr(obj,vptr,ty.flags) != -1) {
- // success code
- } else {
- //fail code
- Now you can be more explicit as:
- int res = SWIG_ConvertPtr(obj,vptr,ty.flags);
- if (SWIG_IsOK(res)) {
- // success code
- } else {
- // fail code
- that seems to be the same, but now you can also do
- Type *ptr;
- int res = SWIG_ConvertPtr(obj,(void **)(&ptr),ty.flags);
- // success code
- if (SWIG_IsNewObj(res) {
- delete *ptr;
- } else {
- } else {
- // fail code
- I.e., now SWIG_ConvertPtr can return new objects and you can
- identify the case and take care of the deallocation. Of course that
- requires also to SWIG_ConvertPtr to return new result values, as
- int SWIG_ConvertPtr(obj, ptr,...) {
- if (<obj is ok>) {
- if (<need new object>) {
- *ptr = <ptr to new allocated object>;
- return SWIG_NEWOBJ;
- } else {
- *ptr = <ptr to old object>;
- return SWIG_OLDOBJ;
- } else {
- return SWIG_BADOBJ;
- Of course, returning the plain '0(success)/-1(fail)' still works, but you can be
- more explicit by returning SWIG_BADOBJ, SWIG_ERROR or any of the
- swig errors code.
- Finally, if the SWIG_CASTRANK_MODE is enabled, the result code
- allows to return the 'cast rank', for example, if you have this
- int food(double)
- int fooi(int);
- and you call
- food(1) // cast rank '1' (1 -> 1.0)
- fooi(1) // cast rank '0'
- just use the SWIG_AddCast()/SWIG_CheckState()
-#define SWIG_OK (0)
-#define SWIG_ERROR (-1)
-#define SWIG_IsOK(r) (r >= 0)
-#define SWIG_ArgError(r) ((r != SWIG_ERROR) ? r : SWIG_TypeError)
-/* The CastRankLimit says how many bits are used for the cast rank */
-#define SWIG_CASTRANKLIMIT (1 << 8)
-/* The NewMask denotes the object was created (using new/malloc) */
-#define SWIG_NEWOBJMASK (SWIG_CASTRANKLIMIT << 1)
-/* The TmpMask is for in/out typemaps that use temporal objects */
-#define SWIG_TMPOBJMASK (SWIG_NEWOBJMASK << 1)
-/* Simple returning values */
-#define SWIG_BADOBJ (SWIG_ERROR)
-#define SWIG_OLDOBJ (SWIG_OK)
-#define SWIG_NEWOBJ (SWIG_OK | SWIG_NEWOBJMASK)
-#define SWIG_TMPOBJ (SWIG_OK | SWIG_TMPOBJMASK)
-/* Check, add and del mask methods */
-#define SWIG_AddNewMask(r) (SWIG_IsOK(r) ? (r | SWIG_NEWOBJMASK) : r)
-#define SWIG_DelNewMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_NEWOBJMASK) : r)
-#define SWIG_IsNewObj(r) (SWIG_IsOK(r) && (r & SWIG_NEWOBJMASK))
-#define SWIG_AddTmpMask(r) (SWIG_IsOK(r) ? (r | SWIG_TMPOBJMASK) : r)
-#define SWIG_DelTmpMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_TMPOBJMASK) : r)
-#define SWIG_IsTmpObj(r) (SWIG_IsOK(r) && (r & SWIG_TMPOBJMASK))
-/* Cast-Rank Mode */
-#if defined(SWIG_CASTRANK_MODE)
-# ifndef SWIG_TypeRank
-# define SWIG_TypeRank unsigned long
-# endif
-# ifndef SWIG_MAXCASTRANK /* Default cast allowed */
-# define SWIG_MAXCASTRANK (2)
-# endif
-# define SWIG_CASTRANKMASK ((SWIG_CASTRANKLIMIT) -1)
-# define SWIG_CastRank(r) (r & SWIG_CASTRANKMASK)
-SWIGINTERNINLINE int SWIG_AddCast(int r) {
- return SWIG_IsOK(r) ? ((SWIG_CastRank(r) < SWIG_MAXCASTRANK) ? (r + 1) : SWIG_ERROR) : r;
-SWIGINTERNINLINE int SWIG_CheckState(int r) {
- return SWIG_IsOK(r) ? SWIG_CastRank(r) + 1 : 0;
-#else /* no cast-rank mode */
-# define SWIG_AddCast
-# define SWIG_CheckState(r) (SWIG_IsOK(r) ? 1 : 0)
-#endif
-#include <string.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-typedef void *(*swig_converter_func)(void *);
-typedef struct swig_type_info *(*swig_dycast_func)(void **);
-/* Structure to store inforomation on one type */
-typedef struct swig_type_info {
- const char *name; /* mangled name of this type */
- const char *str; /* human readable name of this type */
- swig_dycast_func dcast; /* dynamic cast function down a hierarchy */
- struct swig_cast_info *cast; /* linked list of types that can cast into this type */
- void *clientdata; /* language specific type data */
- int owndata; /* flag if the structure owns the clientdata */
-} swig_type_info;
-/* Structure to store a type and conversion function used for casting */
-typedef struct swig_cast_info {
- swig_type_info *type; /* pointer to type that is equivalent to this type */
- swig_converter_func converter; /* function to cast the void pointers */
- struct swig_cast_info *next; /* pointer to next cast in linked list */
- struct swig_cast_info *prev; /* pointer to the previous cast */
-} swig_cast_info;
-/* Structure used to store module information
- * Each module generates one structure like this, and the runtime collects
- * all of these structures and stores them in a circularly linked list.*/
-typedef struct swig_module_info {
- swig_type_info **types; /* Array of pointers to swig_type_info structures that are in this module */
- size_t size; /* Number of types in this module */
- struct swig_module_info *next; /* Pointer to next element in circularly linked list */
- swig_type_info **type_initial; /* Array of initially generated type structures */
- swig_cast_info **cast_initial; /* Array of initially generated casting structures */
- void *clientdata; /* Language specific module data */
-} swig_module_info;
- Compare two type names skipping the space characters, therefore
- "char*" == "char *" and "Class<int>" == "Class<int >", etc.
- Return 0 when the two name types are equivalent, as in
- strncmp, but skipping ' '.
-SWIGRUNTIME int
-SWIG_TypeNameComp(const char *f1, const char *l1,
- const char *f2, const char *l2) {
- for (;(f1 != l1) && (f2 != l2); ++f1, ++f2) {
- while ((*f1 == ' ') && (f1 != l1)) ++f1;
- while ((*f2 == ' ') && (f2 != l2)) ++f2;
- if (*f1 != *f2) return (*f1 > *f2) ? 1 : -1;
- return (int)((l1 - f1) - (l2 - f2));
- Check type equivalence in a name list like <name1>|<name2>|...
- Return 0 if not equal, 1 if equal
-SWIGRUNTIME int
-SWIG_TypeEquiv(const char *nb, const char *tb) {
- int equiv = 0;
- const char* te = tb + strlen(tb);
- const char* ne = nb;
- while (!equiv && *ne) {
- for (nb = ne; *ne; ++ne) {
- if (*ne == '|') break;
- equiv = (SWIG_TypeNameComp(nb, ne, tb, te) == 0) ? 1 : 0;
- if (*ne) ++ne;
- return equiv;
- Return 0 if equal, -1 if nb < tb, 1 if nb > tb
-SWIGRUNTIME int
-SWIG_TypeCompare(const char *nb, const char *tb) {
- int equiv = 0;
- if (*ne) ++ne;
- return equiv;
-/* think of this as a c++ template<> or a scheme macro */
-#define SWIG_TypeCheck_Template(comparison, ty) \
- if (ty) { \
- swig_cast_info *iter = ty->cast; \
- while (iter) { \
- if (comparison) { \
- if (iter == ty->cast) return iter; \
- /* Move iter to the top of the linked list */ \
- iter->prev->next = iter->next; \
- if (iter->next) \
- iter->next->prev = iter->prev; \
- iter->next = ty->cast; \
- iter->prev = 0; \
- if (ty->cast) ty->cast->prev = iter; \
- ty->cast = iter; \
- return iter; \
- iter = iter->next; \
- return 0
- Check the typename
-SWIGRUNTIME swig_cast_info *
-SWIG_TypeCheck(const char *c, swig_type_info *ty) {
- SWIG_TypeCheck_Template(strcmp(iter->type->name, c) == 0, ty);
-/* Same as previous function, except strcmp is replaced with a pointer comparison */
-SWIG_TypeCheckStruct(swig_type_info *from, swig_type_info *into) {
- SWIG_TypeCheck_Template(iter->type == from, into);
- Cast a pointer up an inheritance hierarchy
-SWIGRUNTIMEINLINE void *
-SWIG_TypeCast(swig_cast_info *ty, void *ptr) {
- return ((!ty) || (!ty->converter)) ? ptr : (*ty->converter)(ptr);
- Dynamic pointer casting. Down an inheritance hierarchy
-SWIGRUNTIME swig_type_info *
-SWIG_TypeDynamicCast(swig_type_info *ty, void **ptr) {
- swig_type_info *lastty = ty;
- if (!ty || !ty->dcast) return ty;
- while (ty && (ty->dcast)) {
- ty = (*ty->dcast)(ptr);
- if (ty) lastty = ty;
- return lastty;
- Return the name associated with this type
-SWIGRUNTIMEINLINE const char *
-SWIG_TypeName(const swig_type_info *ty) {
- return ty->name;
- Return the pretty name associated with this type,
- that is an unmangled type name in a form presentable to the user.
-SWIGRUNTIME const char *
-SWIG_TypePrettyName(const swig_type_info *type) {
- /* The "str" field contains the equivalent pretty names of the
- type, separated by vertical-bar characters. We choose
- to print the last name, as it is often (?) the most
- specific. */
- if (!type) return NULL;
- if (type->str != NULL) {
- const char *last_name = type->str;
- const char *s;
- for (s = type->str; *s; s++)
- if (*s == '|') last_name = s+1;
- return last_name;
- else
- return type->name;
- Set the clientdata field for a type
-SWIGRUNTIME void
-SWIG_TypeClientData(swig_type_info *ti, void *clientdata) {
- swig_cast_info *cast = ti->cast;
- /* if (ti->clientdata == clientdata) return; */
- ti->clientdata = clientdata;
- while (cast) {
- if (!cast->converter) {
- swig_type_info *tc = cast->type;
- if (!tc->clientdata) {
- SWIG_TypeClientData(tc, clientdata);
- cast = cast->next;
-SWIGRUNTIME void
-SWIG_TypeNewClientData(swig_type_info *ti, void *clientdata) {
- SWIG_TypeClientData(ti, clientdata);
- ti->owndata = 1;
- Search for a swig_type_info structure only by mangled name
- Search is a O(log #types)
- We start searching at module start, and finish searching when start == end.
- Note: if start == end at the beginning of the function, we go all the way around
- the circular list.
-SWIG_MangledTypeQueryModule(swig_module_info *start,
- swig_module_info *end,
- const char *name) {
- swig_module_info *iter = start;
- do {
- if (iter->size) {
- register size_t l = 0;
- register size_t r = iter->size - 1;
- do {
- /* since l+r >= 0, we can (>> 1) instead (/ 2) */
- register size_t i = (l + r) >> 1;
- const char *iname = iter->types[i]->name;
- if (iname) {
- register int compare = strcmp(name, iname);
- if (compare == 0) {
- return iter->types[i];
- } else if (compare < 0) {
- if (i) {
- r = i - 1;
- } else {
- break;
- } else if (compare > 0) {
- l = i + 1;
- } else {
- break; /* should never happen */
- } while (l <= r);
- } while (iter != end);
- return 0;
- Search for a swig_type_info structure for either a mangled name or a human readable name.
- It first searches the mangled names of the types, which is a O(log #types)
- If a type is not found it then searches the human readable names, which is O(#types).
-SWIG_TypeQueryModule(swig_module_info *start,
- /* STEP 1: Search the name field using binary search */
- swig_type_info *ret = SWIG_MangledTypeQueryModule(start, end, name);
- if (ret) {
- return ret;
- } else {
- /* STEP 2: If the type hasn't been found, do a complete search
- of the str field (the human readable name) */
- do {
- register size_t i = 0;
- for (; i < iter->size; ++i) {
- if (iter->types[i]->str && (SWIG_TypeEquiv(iter->types[i]->str, name)))
- /* neither found a match */
- return 0;
- Pack binary data into a string
-SWIGRUNTIME char *
-SWIG_PackData(char *c, void *ptr, size_t sz) {
- static const char hex[17] = "0123456789abcdef";
- register const unsigned char *u = (unsigned char *) ptr;
- register const unsigned char *eu = u + sz;
- for (; u != eu; ++u) {
- register unsigned char uu = *u;
- *(c++) = hex[(uu & 0xf0) >> 4];
- *(c++) = hex[uu & 0xf];
- return c;
- Unpack binary data from a string
-SWIG_UnpackData(const char *c, void *ptr, size_t sz) {
- register unsigned char *u = (unsigned char *) ptr;
- register char d = *(c++);
- register unsigned char uu;
- if ((d >= '0') && (d <= '9'))
- uu = ((d - '0') << 4);
- else if ((d >= 'a') && (d <= 'f'))
- uu = ((d - ('a'-10)) << 4);
- else
- return (char *) 0;
- d = *(c++);
- uu |= (d - '0');
- uu |= (d - ('a'-10));
- else
- *u = uu;
- return c;
- Pack 'void *' into a string buffer.
-SWIGRUNTIME char *
-SWIG_PackVoidPtr(char *buff, void *ptr, const char *name, size_t bsz) {
- char *r = buff;
- if ((2*sizeof(void *) + 2) > bsz) return 0;
- *(r++) = '_';
- r = SWIG_PackData(r,&ptr,sizeof(void *));
- if (strlen(name) + 1 > (bsz - (r - buff))) return 0;
- strcpy(r,name);
- return buff;
-SWIG_UnpackVoidPtr(const char *c, void **ptr, const char *name) {
- if (*c != '_') {
- if (strcmp(c,"NULL") == 0) {
- *ptr = (void *) 0;
- return name;
- } else {
- return 0;
- return SWIG_UnpackData(++c,ptr,sizeof(void *));
-SWIGRUNTIME char *
-SWIG_PackDataName(char *buff, void *ptr, size_t sz, const char *name, size_t bsz) {
- char *r = buff;
- size_t lname = (name ? strlen(name) : 0);
- if ((2*sz + 2 + lname) > bsz) return 0;
- *(r++) = '_';
- r = SWIG_PackData(r,ptr,sz);
- if (lname) {
- strncpy(r,name,lname+1);
- } else {
- *r = 0;
- return buff;
-SWIG_UnpackDataName(const char *c, void *ptr, size_t sz, const char *name) {
- if (*c != '_') {
- memset(ptr,0,sz);
- return name;
- } else {
- return 0;
- return SWIG_UnpackData(++c,ptr,sz);
-#ifdef __cplusplus
-#endif
-/* Errors in SWIG */
-#define SWIG_UnknownError -1
-#define SWIG_IOError -2
-#define SWIG_RuntimeError -3
-#define SWIG_IndexError -4
-#define SWIG_TypeError -5
-#define SWIG_DivisionByZero -6
-#define SWIG_OverflowError -7
-#define SWIG_SyntaxError -8
-#define SWIG_ValueError -9
-#define SWIG_SystemError -10
-#define SWIG_AttributeError -11
-#define SWIG_MemoryError -12
-#define SWIG_NullReferenceError -13
-/* Add PyOS_snprintf for old Pythons */
-#if PY_VERSION_HEX < 0x02020000
-# if defined(_MSC_VER) || defined(__BORLANDC__) || defined(_WATCOM)
-# define PyOS_snprintf _snprintf
-# else
-# define PyOS_snprintf snprintf
-# endif
-#endif
-/* A crude PyString_FromFormat implementation for old Pythons */
-#ifndef SWIG_PYBUFFER_SIZE
-# define SWIG_PYBUFFER_SIZE 1024
-#endif
-static PyObject *
-PyString_FromFormat(const char *fmt, ...) {
- va_list ap;
- char buf[SWIG_PYBUFFER_SIZE * 2];
- int res;
- va_start(ap, fmt);
- res = vsnprintf(buf, sizeof(buf), fmt, ap);
- va_end(ap);
- return (res < 0 || res >= (int)sizeof(buf)) ? 0 : PyString_FromString(buf);
-#endif
-/* Add PyObject_Del for old Pythons */
-#if PY_VERSION_HEX < 0x01060000
-# define PyObject_Del(op) PyMem_DEL((op))
-#endif
-#ifndef PyObject_DEL
-# define PyObject_DEL PyObject_Del
-#endif
-/* A crude PyExc_StopIteration exception for old Pythons */
-# ifndef PyExc_StopIteration
-# define PyExc_StopIteration PyExc_RuntimeError
-# endif
-# ifndef PyObject_GenericGetAttr
-# define PyObject_GenericGetAttr 0
-# endif
-#endif
-/* Py_NotImplemented is defined in 2.1 and up. */
-#if PY_VERSION_HEX < 0x02010000
-# ifndef Py_NotImplemented
-# define Py_NotImplemented PyExc_RuntimeError
-# endif
-#endif
-/* A crude PyString_AsStringAndSize implementation for old Pythons */
-# ifndef PyString_AsStringAndSize
-# define PyString_AsStringAndSize(obj, s, len) {*s = PyString_AsString(obj); *len = *s ? strlen(*s) : 0;}
-# endif
-#endif
-/* PySequence_Size for old Pythons */
-#if PY_VERSION_HEX < 0x02000000
-# ifndef PySequence_Size
-# define PySequence_Size PySequence_Length
-# endif
-#endif
-/* PyBool_FromLong for old Pythons */
-#if PY_VERSION_HEX < 0x02030000
-static
-PyObject *PyBool_FromLong(long ok)
- PyObject *result = ok ? Py_True : Py_False;
- Py_INCREF(result);
- return result;
-#endif
-/* Py_ssize_t for old Pythons */
-/* This code is as recommended by: */
-/* http://www.python.org/dev/peps/pep-0353/#conversion-guidelines */
-#if PY_VERSION_HEX < 0x02050000 && !defined(PY_SSIZE_T_MIN)
-typedef int Py_ssize_t;
-# define PY_SSIZE_T_MAX INT_MAX
-# define PY_SSIZE_T_MIN INT_MIN
-#endif
- * error manipulation
-SWIGRUNTIME PyObject*
-SWIG_Python_ErrorType(int code) {
- PyObject* type = 0;
- switch(code) {
- case SWIG_MemoryError:
- type = PyExc_MemoryError;
- break;
- case SWIG_IOError:
- type = PyExc_IOError;
- break;
- case SWIG_RuntimeError:
- type = PyExc_RuntimeError;
- break;
- case SWIG_IndexError:
- type = PyExc_IndexError;
- break;
- case SWIG_TypeError:
- type = PyExc_TypeError;
- break;
- case SWIG_DivisionByZero:
- type = PyExc_ZeroDivisionError;
- break;
- case SWIG_OverflowError:
- type = PyExc_OverflowError;
- break;
- case SWIG_SyntaxError:
- type = PyExc_SyntaxError;
- break;
- case SWIG_ValueError:
- type = PyExc_ValueError;
- break;
- case SWIG_SystemError:
- type = PyExc_SystemError;
- break;
- case SWIG_AttributeError:
- type = PyExc_AttributeError;
- break;
- default:
- return type;
-SWIGRUNTIME void
-SWIG_Python_AddErrorMsg(const char* mesg)
- PyObject *type = 0;
- PyObject *value = 0;
- PyObject *traceback = 0;
- if (PyErr_Occurred()) PyErr_Fetch(&type, &value, &traceback);
- if (value) {
- PyObject *old_str = PyObject_Str(value);
- PyErr_Clear();
- Py_XINCREF(type);
- PyErr_Format(type, "%s %s", PyString_AsString(old_str), mesg);
- Py_DECREF(old_str);
- Py_DECREF(value);
- } else {
- PyErr_Format(PyExc_RuntimeError, mesg);
-#if defined(SWIG_PYTHON_NO_THREADS)
-# if defined(SWIG_PYTHON_THREADS)
-# undef SWIG_PYTHON_THREADS
-# endif
-#endif
-#if defined(SWIG_PYTHON_THREADS) /* Threading support is enabled */
-# if !defined(SWIG_PYTHON_USE_GIL) && !defined(SWIG_PYTHON_NO_USE_GIL)
-# if (PY_VERSION_HEX >= 0x02030000) /* For 2.3 or later, use the PyGILState calls */
-# define SWIG_PYTHON_USE_GIL
-# endif
-# endif
-# if defined(SWIG_PYTHON_USE_GIL) /* Use PyGILState threads calls */
-# ifndef SWIG_PYTHON_INITIALIZE_THREADS
-# define SWIG_PYTHON_INITIALIZE_THREADS PyEval_InitThreads()
-# endif
-# ifdef __cplusplus /* C++ code */
- class SWIG_Python_Thread_Block {
- bool status;
- PyGILState_STATE state;
- public:
- void end() { if (status) { PyGILState_Release(state); status = false;} }
- SWIG_Python_Thread_Block() : status(true), state(PyGILState_Ensure()) {}
- ~SWIG_Python_Thread_Block() { end(); }
- class SWIG_Python_Thread_Allow {
- bool status;
- PyThreadState *save;
- public:
- void end() { if (status) { PyEval_RestoreThread(save); status = false; }}
- SWIG_Python_Thread_Allow() : status(true), save(PyEval_SaveThread()) {}
- ~SWIG_Python_Thread_Allow() { end(); }
-# define SWIG_PYTHON_THREAD_BEGIN_BLOCK SWIG_Python_Thread_Block _swig_thread_block
-# define SWIG_PYTHON_THREAD_END_BLOCK _swig_thread_block.end()
-# define SWIG_PYTHON_THREAD_BEGIN_ALLOW SWIG_Python_Thread_Allow _swig_thread_allow
-# define SWIG_PYTHON_THREAD_END_ALLOW _swig_thread_allow.end()
-# else /* C code */
-# define SWIG_PYTHON_THREAD_BEGIN_BLOCK PyGILState_STATE _swig_thread_block = PyGILState_Ensure()
-# define SWIG_PYTHON_THREAD_END_BLOCK PyGILState_Release(_swig_thread_block)
-# define SWIG_PYTHON_THREAD_BEGIN_ALLOW PyThreadState *_swig_thread_allow = PyEval_SaveThread()
-# define SWIG_PYTHON_THREAD_END_ALLOW PyEval_RestoreThread(_swig_thread_allow)
-# endif
-# else /* Old thread way, not implemented, user must provide it */
-# if !defined(SWIG_PYTHON_INITIALIZE_THREADS)
-# endif
-# if !defined(SWIG_PYTHON_THREAD_BEGIN_BLOCK)
-# endif
-# if !defined(SWIG_PYTHON_THREAD_END_BLOCK)
-# endif
-# if !defined(SWIG_PYTHON_THREAD_BEGIN_ALLOW)
-# endif
-# if !defined(SWIG_PYTHON_THREAD_END_ALLOW)
-# endif
-# endif
-#else /* No thread support */
-#endif
- * Python API portion that goes into the runtime
-#ifdef __cplusplus
-extern "C" {
-#if 0
-} /* cc-mode */
-#endif
-#endif
- * Constant declarations
-/* Constant Types */
-#define SWIG_PY_POINTER 4
-#define SWIG_PY_BINARY 5
-/* Constant information structure */
-typedef struct swig_const_info {
- int type;
- char *name;
- long lvalue;
- double dvalue;
- void *pvalue;
- swig_type_info **ptype;
-} swig_const_info;
-#ifdef __cplusplus
-#if 0
-{ /* cc-mode */
-#endif
-#endif
- * See the LICENSE file for information on copyright, usage and redistribution
- * of SWIG, and the README file for authors - http://www.swig.org/release.html.
- * pyrun.swg
- * This file contains the runtime support for Python modules
- * and includes code for managing global variables and pointer
- * type checking.
-/* Common SWIG API */
-/* for raw pointers */
-#define SWIG_Python_ConvertPtr(obj, pptr, type, flags) SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, 0)
-#define SWIG_ConvertPtr(obj, pptr, type, flags) SWIG_Python_ConvertPtr(obj, pptr, type, flags)
-#define SWIG_ConvertPtrAndOwn(obj,pptr,type,flags,own) SWIG_Python_ConvertPtrAndOwn(obj, pptr, type, flags, own)
-#define SWIG_NewPointerObj(ptr, type, flags) SWIG_Python_NewPointerObj(ptr, type, flags)
-#define SWIG_CheckImplicit(ty) SWIG_Python_CheckImplicit(ty)
-#define SWIG_AcquirePtr(ptr, src) SWIG_Python_AcquirePtr(ptr, src)
-#define swig_owntype int
-/* for raw packed data */
-#define SWIG_ConvertPacked(obj, ptr, sz, ty) SWIG_Python_ConvertPacked(obj, ptr, sz, ty)
-#define SWIG_NewPackedObj(ptr, sz, type) SWIG_Python_NewPackedObj(ptr, sz, type)
-/* for class or struct pointers */
-#define SWIG_ConvertInstance(obj, pptr, type, flags) SWIG_ConvertPtr(obj, pptr, type, flags)
-#define SWIG_NewInstanceObj(ptr, type, flags) SWIG_NewPointerObj(ptr, type, flags)
-/* for C or C++ function pointers */
-#define SWIG_ConvertFunctionPtr(obj, pptr, type) SWIG_Python_ConvertFunctionPtr(obj, pptr, type)
-#define SWIG_NewFunctionPtrObj(ptr, type) SWIG_Python_NewPointerObj(ptr, type, 0)
-/* for C++ member pointers, ie, member methods */
-#define SWIG_ConvertMember(obj, ptr, sz, ty) SWIG_Python_ConvertPacked(obj, ptr, sz, ty)
-#define SWIG_NewMemberObj(ptr, sz, type) SWIG_Python_NewPackedObj(ptr, sz, type)
-/* Runtime API */
-#define SWIG_GetModule(clientdata) SWIG_Python_GetModule()
-#define SWIG_SetModule(clientdata, pointer) SWIG_Python_SetModule(pointer)
-#define SWIG_NewClientData(obj) PySwigClientData_New(obj)
-#define SWIG_SetErrorObj SWIG_Python_SetErrorObj
-#define SWIG_SetErrorMsg SWIG_Python_SetErrorMsg
-#define SWIG_ErrorType(code) SWIG_Python_ErrorType(code)
-#define SWIG_Error(code, msg) SWIG_Python_SetErrorMsg(SWIG_ErrorType(code), msg)
-#define SWIG_fail goto fail
-/* Runtime API implementation */
-/* Error manipulation */
-SWIGINTERN void
-SWIG_Python_SetErrorObj(PyObject *errtype, PyObject *obj) {
- SWIG_PYTHON_THREAD_BEGIN_BLOCK;
- PyErr_SetObject(errtype, obj);
- Py_DECREF(obj);
- SWIG_PYTHON_THREAD_END_BLOCK;
-SWIGINTERN void
-SWIG_Python_SetErrorMsg(PyObject *errtype, const char *msg) {
- PyErr_SetString(errtype, (char *) msg);
-#define SWIG_Python_Raise(obj, type, desc) SWIG_Python_SetErrorObj(SWIG_Python_ExceptionType(desc), obj)
-/* Set a constant value */
-SWIGINTERN void
-SWIG_Python_SetConstant(PyObject *d, const char *name, PyObject *obj) {
- PyDict_SetItemString(d, (char*) name, obj);
- Py_DECREF(obj);
-/* Append a value to the result obj */
-SWIGINTERN PyObject*
-SWIG_Python_AppendOutput(PyObject* result, PyObject* obj) {
-#if !defined(SWIG_PYTHON_OUTPUT_TUPLE)
- if (!result) {
- result = obj;
- } else if (result == Py_None) {
- Py_DECREF(result);
- result = obj;
- } else {
- if (!PyList_Check(result)) {
- PyObject *o2 = result;
- result = PyList_New(1);
- PyList_SetItem(result, 0, o2);
- PyList_Append(result,obj);
- Py_DECREF(obj);
- return result;
-#else
- PyObject* o2;
- PyObject* o3;
- if (!result) {
- result = obj;
- result = obj;
- } else {
- if (!PyTuple_Check(result)) {
- o2 = result;
- result = PyTuple_New(1);
- PyTuple_SET_ITEM(result, 0, o2);
- o3 = PyTuple_New(1);
- PyTuple_SET_ITEM(o3, 0, obj);
- o2 = result;
- result = PySequence_Concat(o2, o3);
- Py_DECREF(o2);
- Py_DECREF(o3);
- return result;
-#endif
-/* Unpack the argument tuple */
-SWIGINTERN int
-SWIG_Python_UnpackTuple(PyObject *args, const char *name, Py_ssize_t min, Py_ssize_t max, PyObject **objs)
- if (!args) {
- if (!min && !max) {
- return 1;
- } else {
- PyErr_Format(PyExc_TypeError, "%s expected %s%d arguments, got none",
- name, (min == max ? "" : "at least "), (int)min);
- return 0;
- if (!PyTuple_Check(args)) {
- PyErr_SetString(PyExc_SystemError, "UnpackTuple() argument list is not a tuple");
- return 0;
- } else {
- register Py_ssize_t l = PyTuple_GET_SIZE(args);
- if (l < min) {
- PyErr_Format(PyExc_TypeError, "%s expected %s%d arguments, got %d",
- name, (min == max ? "" : "at least "), (int)min, (int)l);
- return 0;
- } else if (l > max) {
- name, (min == max ? "" : "at most "), (int)max, (int)l);
- return 0;
- } else {
- register int i;
- for (i = 0; i < l; ++i) {
- objs[i] = PyTuple_GET_ITEM(args, i);
- for (; l < max; ++l) {
- objs[l] = 0;
- return i + 1;
-/* A functor is a function object with one single object argument */
-#if PY_VERSION_HEX >= 0x02020000
-#define SWIG_Python_CallFunctor(functor, obj) PyObject_CallFunctionObjArgs(functor, obj, NULL);
-#else
-#define SWIG_Python_CallFunctor(functor, obj) PyObject_CallFunction(functor, "O", obj);
-#endif
- Helper for static pointer initialization for both C and C++ code, for example
- static PyObject *SWIG_STATIC_POINTER(MyVar) = NewSomething(...);
-#ifdef __cplusplus
-#define SWIG_STATIC_POINTER(var) var
-#else
-#define SWIG_STATIC_POINTER(var) var = 0; if (!var) var
-#endif
- * Pointer declarations
-#define SWIG_POINTER_NOSHADOW (SWIG_POINTER_OWN << 1)
-#define SWIG_POINTER_NEW (SWIG_POINTER_NOSHADOW | SWIG_POINTER_OWN)
-#define SWIG_POINTER_IMPLICIT_CONV (SWIG_POINTER_DISOWN << 1)
-#ifdef __cplusplus
-extern "C" {
-#if 0
-} /* cc-mode */
-#endif
-#endif
-/* How to access Py_None */
-#if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
-# ifndef SWIG_PYTHON_NO_BUILD_NONE
-# ifndef SWIG_PYTHON_BUILD_NONE
-# define SWIG_PYTHON_BUILD_NONE
-# endif
-# endif
-#endif
-#ifdef SWIG_PYTHON_BUILD_NONE
-# ifdef Py_None
-# undef Py_None
-# define Py_None SWIG_Py_None()
-# endif
-SWIGRUNTIMEINLINE PyObject *
-_SWIG_Py_None(void)
- PyObject *none = Py_BuildValue((char*)"");
- Py_DECREF(none);
- return none;
-SWIGRUNTIME PyObject *
-SWIG_Py_None(void)
- static PyObject *SWIG_STATIC_POINTER(none) = _SWIG_Py_None();
- return none;
-#endif
-/* The python void return value */
-SWIG_Py_Void(void)
- PyObject *none = Py_None;
- Py_INCREF(none);
- return none;
-/* PySwigClientData */
-typedef struct {
- PyObject *klass;
- PyObject *newraw;
- PyObject *newargs;
- PyObject *destroy;
- int delargs;
- int implicitconv;
-} PySwigClientData;
-SWIGRUNTIMEINLINE int
-SWIG_Python_CheckImplicit(swig_type_info *ty)
- PySwigClientData *data = (PySwigClientData *)ty->clientdata;
- return data ? data->implicitconv : 0;
-SWIG_Python_ExceptionType(swig_type_info *desc) {
- PySwigClientData *data = desc ? (PySwigClientData *) desc->clientdata : 0;
- PyObject *klass = data ? data->klass : 0;
- return (klass ? klass : PyExc_RuntimeError);
-SWIGRUNTIME PySwigClientData *
-PySwigClientData_New(PyObject* obj)
- if (!obj) {
- return 0;
- } else {
- PySwigClientData *data = (PySwigClientData *)malloc(sizeof(PySwigClientData));
- /* the klass element */
- data->klass = obj;
- Py_INCREF(data->klass);
- /* the newraw method and newargs arguments used to create a new raw instance */
- if (PyClass_Check(obj)) {
- data->newraw = 0;
- data->newargs = obj;
- Py_INCREF(obj);
- } else {
-#if (PY_VERSION_HEX < 0x02020000)
- data->newraw = 0;
-#else
- data->newraw = PyObject_GetAttrString(data->klass, (char *)"__new__");
-#endif
- if (data->newraw) {
- Py_INCREF(data->newraw);
- data->newargs = PyTuple_New(1);
- PyTuple_SetItem(data->newargs, 0, obj);
- } else {
- Py_INCREF(data->newargs);
- /* the destroy method, aka as the C++ delete method */
- data->destroy = PyObject_GetAttrString(data->klass, (char *)"__swig_destroy__");
- if (PyErr_Occurred()) {
- PyErr_Clear();
- data->destroy = 0;
- if (data->destroy) {
- int flags;
- Py_INCREF(data->destroy);
- flags = PyCFunction_GET_FLAGS(data->destroy);
-#ifdef METH_O
- data->delargs = !(flags & (METH_O));
-#else
- data->delargs = 0;
-#endif
- } else {
- data->implicitconv = 0;
- return data;
-SWIGRUNTIME void
-PySwigClientData_Del(PySwigClientData* data)
- Py_XDECREF(data->newraw);
- Py_XDECREF(data->newargs);
- Py_XDECREF(data->destroy);
-/* =============== PySwigObject =====================*/
-typedef struct {
- PyObject_HEAD
- void *ptr;
- swig_type_info *ty;
- int own;
- PyObject *next;
-} PySwigObject;
-PySwigObject_long(PySwigObject *v)
- return PyLong_FromVoidPtr(v->ptr);
-PySwigObject_format(const char* fmt, PySwigObject *v)
- PyObject *res = NULL;
- PyObject *args = PyTuple_New(1);
- if (args) {
- if (PyTuple_SetItem(args, 0, PySwigObject_long(v)) == 0) {
- PyObject *ofmt = PyString_FromString(fmt);
- if (ofmt) {
- res = PyString_Format(ofmt,args);
- Py_DECREF(ofmt);
- Py_DECREF(args);
- return res;
-PySwigObject_oct(PySwigObject *v)
- return PySwigObject_format("%o",v);
-PySwigObject_hex(PySwigObject *v)
- return PySwigObject_format("%x",v);
-#ifdef METH_NOARGS
-PySwigObject_repr(PySwigObject *v)
-#else
-PySwigObject_repr(PySwigObject *v, PyObject *args)
-#endif
- const char *name = SWIG_TypePrettyName(v->ty);
- PyObject *hex = PySwigObject_hex(v);
- PyObject *repr = PyString_FromFormat("<Swig Object of type '%s' at 0x%s>", name, PyString_AsString(hex));
- Py_DECREF(hex);
- if (v->next) {
-#ifdef METH_NOARGS
- PyObject *nrep = PySwigObject_repr((PySwigObject *)v->next);
-#else
- PyObject *nrep = PySwigObject_repr((PySwigObject *)v->next, args);
-#endif
- PyString_ConcatAndDel(&repr,nrep);
- return repr;
-SWIGRUNTIME int
-PySwigObject_print(PySwigObject *v, FILE *fp, int SWIGUNUSEDPARM(flags))
-#ifdef METH_NOARGS
- PyObject *repr = PySwigObject_repr(v);
-#else
- PyObject *repr = PySwigObject_repr(v, NULL);
-#endif
- if (repr) {
- fputs(PyString_AsString(repr), fp);
- Py_DECREF(repr);
- return 0;
- } else {
- return 1;
-PySwigObject_str(PySwigObject *v)
- char result[SWIG_BUFFER_SIZE];
- return SWIG_PackVoidPtr(result, v->ptr, v->ty->name, sizeof(result)) ?
- PyString_FromString(result) : 0;
-SWIGRUNTIME int
-PySwigObject_compare(PySwigObject *v, PySwigObject *w)
- void *i = v->ptr;
- void *j = w->ptr;
- return (i < j) ? -1 : ((i > j) ? 1 : 0);
-SWIGRUNTIME PyTypeObject* _PySwigObject_type(void);
-PySwigObject_type(void) {
- static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigObject_type();
- return type;
-PySwigObject_Check(PyObject *op) {
- return ((op)->ob_type == PySwigObject_type())
- || (strcmp((op)->ob_type->tp_name,"PySwigObject") == 0);
-PySwigObject_New(void *ptr, swig_type_info *ty, int own);
-SWIGRUNTIME void
-PySwigObject_dealloc(PyObject *v)
- PySwigObject *sobj = (PySwigObject *) v;
- PyObject *next = sobj->next;
- if (sobj->own) {
- swig_type_info *ty = sobj->ty;
- PySwigClientData *data = ty ? (PySwigClientData *) ty->clientdata : 0;
- PyObject *destroy = data ? data->destroy : 0;
- if (destroy) {
- /* destroy is always a VARARGS method */
- PyObject *res;
- if (data->delargs) {
- /* we need to create a temporal object to carry the destroy operation */
- PyObject *tmp = PySwigObject_New(sobj->ptr, ty, 0);
- res = SWIG_Python_CallFunctor(destroy, tmp);
- Py_DECREF(tmp);
- } else {
- PyCFunction meth = PyCFunction_GET_FUNCTION(destroy);
- PyObject *mself = PyCFunction_GET_SELF(destroy);
- res = ((*meth)(mself, v));
- Py_XDECREF(res);
- } else {
- const char *name = SWIG_TypePrettyName(ty);
-#if !defined(SWIG_PYTHON_SILENT_MEMLEAK)
- printf("swig/python detected a memory leak of type '%s', no destructor found.\n", name);
-#endif
- Py_XDECREF(next);
- PyObject_DEL(v);
-PySwigObject_append(PyObject* v, PyObject* next)
-#ifndef METH_O
- PyObject *tmp = 0;
- if (!PyArg_ParseTuple(next,(char *)"O:append", &tmp)) return NULL;
- next = tmp;
-#endif
- if (!PySwigObject_Check(next)) {
- return NULL;
- sobj->next = next;
- Py_INCREF(next);
- return SWIG_Py_Void();
-#ifdef METH_NOARGS
-PySwigObject_next(PyObject* v)
-#else
-PySwigObject_next(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
-#endif
- if (sobj->next) {
- Py_INCREF(sobj->next);
- return sobj->next;
- } else {
-#ifdef METH_NOARGS
-PySwigObject_disown(PyObject *v)
-#else
-PySwigObject_disown(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
-#endif
- PySwigObject *sobj = (PySwigObject *)v;
- sobj->own = 0;
-#ifdef METH_NOARGS
-PySwigObject_acquire(PyObject *v)
-#else
-PySwigObject_acquire(PyObject* v, PyObject *SWIGUNUSEDPARM(args))
-#endif
- sobj->own = SWIG_POINTER_OWN;
-PySwigObject_own(PyObject *v, PyObject *args)
- PyObject *val = 0;
- if (!PyArg_ParseTuple(args,(char *)"|O:own",&val))
-#else
- if (!PyArg_UnpackTuple(args, (char *)"own", 0, 1, &val))
-#endif
- return NULL;
- else
- PyObject *obj = PyBool_FromLong(sobj->own);
- if (val) {
-#ifdef METH_NOARGS
- if (PyObject_IsTrue(val)) {
- PySwigObject_acquire(v);
- } else {
- PySwigObject_disown(v);
-#else
- PySwigObject_acquire(v,args);
- } else {
- PySwigObject_disown(v,args);
-#endif
- return obj;
-#ifdef METH_O
-static PyMethodDef
-swigobject_methods[] = {
- {(char *)"disown", (PyCFunction)PySwigObject_disown, METH_NOARGS, (char *)"releases ownership of the pointer"},
- {(char *)"acquire", (PyCFunction)PySwigObject_acquire, METH_NOARGS, (char *)"aquires ownership of the pointer"},
- {(char *)"own", (PyCFunction)PySwigObject_own, METH_VARARGS, (char *)"returns/sets ownership of the pointer"},
- {(char *)"append", (PyCFunction)PySwigObject_append, METH_O, (char *)"appends another 'this' object"},
- {(char *)"next", (PyCFunction)PySwigObject_next, METH_NOARGS, (char *)"returns the next 'this' object"},
- {(char *)"__repr__",(PyCFunction)PySwigObject_repr, METH_NOARGS, (char *)"returns object representation"},
- {0, 0, 0, 0}
-#else
-static PyMethodDef
- {(char *)"disown", (PyCFunction)PySwigObject_disown, METH_VARARGS, (char *)"releases ownership of the pointer"},
- {(char *)"acquire", (PyCFunction)PySwigObject_acquire, METH_VARARGS, (char *)"aquires ownership of the pointer"},
- {(char *)"append", (PyCFunction)PySwigObject_append, METH_VARARGS, (char *)"appends another 'this' object"},
- {(char *)"next", (PyCFunction)PySwigObject_next, METH_VARARGS, (char *)"returns the next 'this' object"},
- {(char *)"__repr__",(PyCFunction)PySwigObject_repr, METH_VARARGS, (char *)"returns object representation"},
- {0, 0, 0, 0}
-#endif
-SWIGINTERN PyObject *
-PySwigObject_getattr(PySwigObject *sobj,char *name)
- return Py_FindMethod(swigobject_methods, (PyObject *)sobj, name);
-#endif
-_PySwigObject_type(void) {
- static char swigobject_doc[] = "Swig object carries a C/C++ instance pointer";
- static PyNumberMethods PySwigObject_as_number = {
- (binaryfunc)0, /*nb_add*/
- (binaryfunc)0, /*nb_subtract*/
- (binaryfunc)0, /*nb_multiply*/
- (binaryfunc)0, /*nb_divide*/
- (binaryfunc)0, /*nb_remainder*/
- (binaryfunc)0, /*nb_divmod*/
- (ternaryfunc)0,/*nb_power*/
- (unaryfunc)0, /*nb_negative*/
- (unaryfunc)0, /*nb_positive*/
- (unaryfunc)0, /*nb_absolute*/
- (inquiry)0, /*nb_nonzero*/
- 0, /*nb_invert*/
- 0, /*nb_lshift*/
- 0, /*nb_rshift*/
- 0, /*nb_and*/
- 0, /*nb_xor*/
- 0, /*nb_or*/
- (coercion)0, /*nb_coerce*/
- (unaryfunc)PySwigObject_long, /*nb_int*/
- (unaryfunc)PySwigObject_long, /*nb_long*/
- (unaryfunc)0, /*nb_float*/
- (unaryfunc)PySwigObject_oct, /*nb_oct*/
- (unaryfunc)PySwigObject_hex, /*nb_hex*/
-#if PY_VERSION_HEX >= 0x02050000 /* 2.5.0 */
- 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_index */
-#elif PY_VERSION_HEX >= 0x02020000 /* 2.2.0 */
- 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_inplace_true_divide */
-#elif PY_VERSION_HEX >= 0x02000000 /* 2.0.0 */
- 0,0,0,0,0,0,0,0,0,0,0 /* nb_inplace_add -> nb_inplace_or */
-#endif
- static PyTypeObject pyswigobject_type;
- static int type_init = 0;
- if (!type_init) {
- const PyTypeObject tmp
- PyObject_HEAD_INIT(NULL)
- 0, /* ob_size */
- (char *)"PySwigObject", /* tp_name */
- sizeof(PySwigObject), /* tp_basicsize */
- 0, /* tp_itemsize */
- (destructor)PySwigObject_dealloc, /* tp_dealloc */
- (printfunc)PySwigObject_print, /* tp_print */
- (getattrfunc)PySwigObject_getattr, /* tp_getattr */
-#else
- (getattrfunc)0, /* tp_getattr */
-#endif
- (setattrfunc)0, /* tp_setattr */
- (cmpfunc)PySwigObject_compare, /* tp_compare */
- (reprfunc)PySwigObject_repr, /* tp_repr */
- &PySwigObject_as_number, /* tp_as_number */
- 0, /* tp_as_sequence */
- 0, /* tp_as_mapping */
- (hashfunc)0, /* tp_hash */
- (ternaryfunc)0, /* tp_call */
- (reprfunc)PySwigObject_str, /* tp_str */
- PyObject_GenericGetAttr, /* tp_getattro */
- 0, /* tp_setattro */
- 0, /* tp_as_buffer */
- Py_TPFLAGS_DEFAULT, /* tp_flags */
- swigobject_doc, /* tp_doc */
- 0, /* tp_traverse */
- 0, /* tp_clear */
- 0, /* tp_richcompare */
- 0, /* tp_weaklistoffset */
- 0, /* tp_iter */
- 0, /* tp_iternext */
- swigobject_methods, /* tp_methods */
- 0, /* tp_members */
- 0, /* tp_getset */
- 0, /* tp_base */
- 0, /* tp_dict */
- 0, /* tp_descr_get */
- 0, /* tp_descr_set */
- 0, /* tp_dictoffset */
- 0, /* tp_init */
- 0, /* tp_alloc */
- 0, /* tp_new */
- 0, /* tp_free */
- 0, /* tp_is_gc */
- 0, /* tp_bases */
- 0, /* tp_mro */
- 0, /* tp_cache */
- 0, /* tp_subclasses */
- 0, /* tp_weaklist */
-#endif
-#if PY_VERSION_HEX >= 0x02030000
- 0, /* tp_del */
-#endif
-#ifdef COUNT_ALLOCS
- 0,0,0,0 /* tp_alloc -> tp_next */
-#endif
- pyswigobject_type = tmp;
- pyswigobject_type.ob_type = &PyType_Type;
- type_init = 1;
- return &pyswigobject_type;
- PySwigObject *sobj = PyObject_NEW(PySwigObject, PySwigObject_type());
- if (sobj) {
- sobj->ptr = ptr;
- sobj->ty = ty;
- sobj->own = own;
- sobj->next = 0;
- return (PyObject *)sobj;
- * Implements a simple Swig Packed type, and use it instead of string
-typedef struct {
- PyObject_HEAD
- void *pack;
- size_t size;
-} PySwigPacked;
-SWIGRUNTIME int
-PySwigPacked_print(PySwigPacked *v, FILE *fp, int SWIGUNUSEDPARM(flags))
- fputs("<Swig Packed ", fp);
- if (SWIG_PackDataName(result, v->pack, v->size, 0, sizeof(result))) {
- fputs("at ", fp);
- fputs(result, fp);
- fputs(v->ty->name,fp);
- fputs(">", fp);
- return 0;
-PySwigPacked_repr(PySwigPacked *v)
- return PyString_FromFormat("<Swig Packed at %s%s>", result, v->ty->name);
- } else {
- return PyString_FromFormat("<Swig Packed %s>", v->ty->name);
-PySwigPacked_str(PySwigPacked *v)
- if (SWIG_PackDataName(result, v->pack, v->size, 0, sizeof(result))){
- return PyString_FromFormat("%s%s", result, v->ty->name);
- } else {
- return PyString_FromString(v->ty->name);
-SWIGRUNTIME int
-PySwigPacked_compare(PySwigPacked *v, PySwigPacked *w)
- size_t i = v->size;
- size_t j = w->size;
- int s = (i < j) ? -1 : ((i > j) ? 1 : 0);
- return s ? s : strncmp((char *)v->pack, (char *)w->pack, 2*v->size);
-SWIGRUNTIME PyTypeObject* _PySwigPacked_type(void);
-PySwigPacked_type(void) {
- static PyTypeObject *SWIG_STATIC_POINTER(type) = _PySwigPacked_type();
- return type;
-PySwigPacked_Check(PyObject *op) {
- return ((op)->ob_type == _PySwigPacked_type())
- || (strcmp((op)->ob_type->tp_name,"PySwigPacked") == 0);
-SWIGRUNTIME void
-PySwigPacked_dealloc(PyObject *v)
- if (PySwigPacked_Check(v)) {
- PySwigPacked *sobj = (PySwigPacked *) v;
- free(sobj->pack);
- PyObject_DEL(v);
-_PySwigPacked_type(void) {
- static char swigpacked_doc[] = "Swig object carries a C/C++ instance pointer";
- static PyTypeObject pyswigpacked_type;
- if (!type_init) {
- 0, /* ob_size */
- (char *)"PySwigPacked", /* tp_name */
- sizeof(PySwigPacked), /* tp_basicsize */
- (destructor)PySwigPacked_dealloc, /* tp_dealloc */
- (printfunc)PySwigPacked_print, /* tp_print */
- (cmpfunc)PySwigPacked_compare, /* tp_compare */
- (reprfunc)PySwigPacked_repr, /* tp_repr */
- 0, /* tp_as_number */
- (reprfunc)PySwigPacked_str, /* tp_str */
- swigpacked_doc, /* tp_doc */
- 0, /* tp_clear */
- 0, /* tp_iter */
- 0, /* tp_methods */
- 0, /* tp_base */
- 0, /* tp_dict */
- 0, /* tp_init */
- 0, /* tp_alloc */
- 0, /* tp_new */
- 0, /* tp_free */
- 0, /* tp_is_gc */
- 0, /* tp_bases */
- 0, /* tp_mro */
- 0, /* tp_cache */
-#endif
- 0, /* tp_del */
-#endif
-#endif
- pyswigpacked_type = tmp;
- pyswigpacked_type.ob_type = &PyType_Type;
- type_init = 1;
- return &pyswigpacked_type;
-PySwigPacked_New(void *ptr, size_t size, swig_type_info *ty)
- PySwigPacked *sobj = PyObject_NEW(PySwigPacked, PySwigPacked_type());
- if (sobj) {
- void *pack = malloc(size);
- if (pack) {
- memcpy(pack, ptr, size);
- sobj->pack = pack;
- sobj->ty = ty;
- sobj->size = size;
- } else {
- PyObject_DEL((PyObject *) sobj);
- sobj = 0;
- return (PyObject *) sobj;
-PySwigPacked_UnpackData(PyObject *obj, void *ptr, size_t size)
- if (PySwigPacked_Check(obj)) {
- PySwigPacked *sobj = (PySwigPacked *)obj;
- if (sobj->size != size) return 0;
- memcpy(ptr, sobj->pack, size);
- return sobj->ty;
- } else {
- return 0;
- * pointers/data manipulation
-_SWIG_This(void)
- return PyString_FromString("this");
-SWIG_This(void)
- static PyObject *SWIG_STATIC_POINTER(swig_this) = _SWIG_This();
- return swig_this;
-/* #define SWIG_PYTHON_SLOW_GETSET_THIS */
-SWIGRUNTIME PySwigObject *
-SWIG_Python_GetSwigThis(PyObject *pyobj)
- if (PySwigObject_Check(pyobj)) {
- return (PySwigObject *) pyobj;
- } else {
- PyObject *obj = 0;
-#if (!defined(SWIG_PYTHON_SLOW_GETSET_THIS) && (PY_VERSION_HEX >= 0x02030000))
- if (PyInstance_Check(pyobj)) {
- obj = _PyInstance_Lookup(pyobj, SWIG_This());
- } else {
- PyObject **dictptr = _PyObject_GetDictPtr(pyobj);
- if (dictptr != NULL) {
- PyObject *dict = *dictptr;
- obj = dict ? PyDict_GetItem(dict, SWIG_This()) : 0;
- } else {
-#ifdef PyWeakref_CheckProxy
- if (PyWeakref_CheckProxy(pyobj)) {
- PyObject *wobj = PyWeakref_GET_OBJECT(pyobj);
- return wobj ? SWIG_Python_GetSwigThis(wobj) : 0;
-#endif
- obj = PyObject_GetAttr(pyobj,SWIG_This());
- if (obj) {
- Py_DECREF(obj);
- } else {
- if (PyErr_Occurred()) PyErr_Clear();
- return 0;
-#else
- if (obj) {
- Py_DECREF(obj);
- } else {
- return 0;
-#endif
- if (obj && !PySwigObject_Check(obj)) {
- /* a PyObject is called 'this', try to get the 'real this'
- PySwigObject from it */
- return SWIG_Python_GetSwigThis(obj);
- return (PySwigObject *)obj;
-/* Acquire a pointer value */
-SWIGRUNTIME int
-SWIG_Python_AcquirePtr(PyObject *obj, int own) {
- if (own) {
- PySwigObject *sobj = SWIG_Python_GetSwigThis(obj);
- if (sobj) {
- int oldown = sobj->own;
- sobj->own = own;
- return oldown;
- return 0;
-/* Convert a pointer value */
-SWIGRUNTIME int
-SWIG_Python_ConvertPtrAndOwn(PyObject *obj, void **ptr, swig_type_info *ty, int flags, int *own) {
- if (!obj) return SWIG_ERROR;
- if (obj == Py_None) {
- if (ptr) *ptr = 0;
- return SWIG_OK;
- } else {
- while (sobj) {
- void *vptr = sobj->ptr;
- if (ty) {
- swig_type_info *to = sobj->ty;
- if (to == ty) {
- /* no type cast needed */
- if (ptr) *ptr = vptr;
- break;
- } else {
- swig_cast_info *tc = SWIG_TypeCheck(to->name,ty);
- if (!tc) {
- sobj = (PySwigObject *)sobj->next;
- } else {
- if (ptr) *ptr = SWIG_TypeCast(tc,vptr);
- break;
- } else {
- break;
- if (sobj) {
- if (own) *own = sobj->own;
- if (flags & SWIG_POINTER_DISOWN) {
- sobj->own = 0;
- return SWIG_OK;
- } else {
- int res = SWIG_ERROR;
- if (flags & SWIG_POINTER_IMPLICIT_CONV) {
- if (data && !data->implicitconv) {
- PyObject *klass = data->klass;
- if (klass) {
- PyObject *impconv;
- data->implicitconv = 1; /* avoid recursion and call 'explicit' constructors*/
- impconv = SWIG_Python_CallFunctor(klass, obj);
- PyErr_Clear();
- impconv = 0;
- if (impconv) {
- PySwigObject *iobj = SWIG_Python_GetSwigThis(impconv);
- if (iobj) {
- void *vptr;
- res = SWIG_Python_ConvertPtrAndOwn((PyObject*)iobj, &vptr, ty, 0, 0);
- if (ptr) {
- *ptr = vptr;
- /* transfer the ownership to 'ptr' */
- iobj->own = 0;
- res = SWIG_AddCast(res);
- res = SWIG_AddNewMask(res);
- } else {
- Py_DECREF(impconv);
- return res;
-/* Convert a function ptr value */
-SWIGRUNTIME int
-SWIG_Python_ConvertFunctionPtr(PyObject *obj, void **ptr, swig_type_info *ty) {
- if (!PyCFunction_Check(obj)) {
- return SWIG_ConvertPtr(obj, ptr, ty, 0);
- } else {
- void *vptr = 0;
- /* here we get the method pointer for callbacks */
- const char *doc = (((PyCFunctionObject *)obj) -> m_ml -> ml_doc);
- const char *desc = doc ? strstr(doc, "swig_ptr: ") : 0;
- if (desc) {
- desc = ty ? SWIG_UnpackVoidPtr(desc + 10, &vptr, ty->name) : 0;
- if (!desc) return SWIG_ERROR;
- if (ty) {
- swig_cast_info *tc = SWIG_TypeCheck(desc,ty);
- if (!tc) return SWIG_ERROR;
- *ptr = SWIG_TypeCast(tc,vptr);
- } else {
- *ptr = vptr;
- return SWIG_OK;
-/* Convert a packed value value */
-SWIGRUNTIME int
-SWIG_Python_ConvertPacked(PyObject *obj, void *ptr, size_t sz, swig_type_info *ty) {
- swig_type_info *to = PySwigPacked_UnpackData(obj, ptr, sz);
- if (!to) return SWIG_ERROR;
- if (ty) {
- if (to != ty) {
- /* check type cast? */
- return SWIG_OK;
- * Create a new pointer object
- Create a new instance object, whitout calling __init__, and set the
- 'this' attribute.
-SWIG_Python_NewShadowInstance(PySwigClientData *data, PyObject *swig_this)
-#if (PY_VERSION_HEX >= 0x02020000)
- PyObject *inst = 0;
- PyObject *newraw = data->newraw;
- if (newraw) {
- inst = PyObject_Call(newraw, data->newargs, NULL);
- if (inst) {
-#if !defined(SWIG_PYTHON_SLOW_GETSET_THIS)
- PyObject **dictptr = _PyObject_GetDictPtr(inst);
- if (dict == NULL) {
- dict = PyDict_New();
- *dictptr = dict;
- PyDict_SetItem(dict, SWIG_This(), swig_this);
-#else
- PyObject *key = SWIG_This();
- PyObject_SetAttr(inst, key, swig_this);
-#endif
- } else {
- PyObject *dict = PyDict_New();
- inst = PyInstance_NewRaw(data->newargs, dict);
- Py_DECREF(dict);
- return inst;
-#else
-#if (PY_VERSION_HEX >= 0x02010000)
- PyObject *inst;
- Py_DECREF(dict);
- return (PyObject *) inst;
-#else
- PyInstanceObject *inst = PyObject_NEW(PyInstanceObject, &PyInstance_Type);
- if (inst == NULL) {
- return NULL;
- inst->in_class = (PyClassObject *)data->newargs;
- Py_INCREF(inst->in_class);
- inst->in_dict = PyDict_New();
- if (inst->in_dict == NULL) {
- Py_DECREF(inst);
- return NULL;
-#ifdef Py_TPFLAGS_HAVE_WEAKREFS
- inst->in_weakreflist = NULL;
-#endif
-#ifdef Py_TPFLAGS_GC
- PyObject_GC_Init(inst);
-#endif
- PyDict_SetItem(inst->in_dict, SWIG_This(), swig_this);
-#endif
-#endif
-SWIGRUNTIME void
-SWIG_Python_SetSwigThis(PyObject *inst, PyObject *swig_this)
- PyObject *dict;
-#if (PY_VERSION_HEX >= 0x02020000) && !defined(SWIG_PYTHON_SLOW_GETSET_THIS)
- dict = *dictptr;
- *dictptr = dict;
- return;
-#endif
- dict = PyObject_GetAttrString(inst, (char*)"__dict__");
- Py_DECREF(dict);
-SWIG_Python_InitShadowInstance(PyObject *args) {
- PyObject *obj[2];
- if (!SWIG_Python_UnpackTuple(args,(char*)"swiginit", 2, 2, obj)) {
- return NULL;
- } else {
- PySwigObject *sthis = SWIG_Python_GetSwigThis(obj[0]);
- if (sthis) {
- PySwigObject_append((PyObject*) sthis, obj[1]);
- } else {
- SWIG_Python_SetSwigThis(obj[0], obj[1]);
-/* Create a new pointer object */
-SWIG_Python_NewPointerObj(void *ptr, swig_type_info *type, int flags) {
- if (!ptr) {
- } else {
- int own = (flags & SWIG_POINTER_OWN) ? SWIG_POINTER_OWN : 0;
- PyObject *robj = PySwigObject_New(ptr, type, own);
- PySwigClientData *clientdata = type ? (PySwigClientData *)(type->clientdata) : 0;
- if (clientdata && !(flags & SWIG_POINTER_NOSHADOW)) {
- PyObject *inst = SWIG_Python_NewShadowInstance(clientdata, robj);
- if (inst) {
- Py_DECREF(robj);
- robj = inst;
- return robj;
-/* Create a new packed object */
-SWIG_Python_NewPackedObj(void *ptr, size_t sz, swig_type_info *type) {
- return ptr ? PySwigPacked_New((void *) ptr, sz, type) : SWIG_Py_Void();
- * Get type list
-#ifdef SWIG_LINK_RUNTIME
-void *SWIG_ReturnGlobalTypeList(void *);
-#endif
-SWIGRUNTIME swig_module_info *
-SWIG_Python_GetModule(void) {
- static void *type_pointer = (void *)0;
- /* first check if module already created */
- if (!type_pointer) {
- type_pointer = SWIG_ReturnGlobalTypeList((void *)0);
-#else
- type_pointer = PyCObject_Import((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
- (char*)"type_pointer" SWIG_TYPE_TABLE_NAME);
- PyErr_Clear();
- type_pointer = (void *)0;
-#endif
- return (swig_module_info *) type_pointer;
-#if PY_MAJOR_VERSION < 2
-/* PyModule_AddObject function was introduced in Python 2.0. The following function
- is copied out of Python/modsupport.c in python version 2.3.4 */
-SWIGINTERN int
-PyModule_AddObject(PyObject *m, char *name, PyObject *o)
- PyObject *dict;
- if (!PyModule_Check(m)) {
- PyErr_SetString(PyExc_TypeError,
- "PyModule_AddObject() needs module as first arg");
- return SWIG_ERROR;
- if (!o) {
- "PyModule_AddObject() needs non-NULL value");
- dict = PyModule_GetDict(m);
- /* Internal error -- modules must have a dict! */
- PyErr_Format(PyExc_SystemError, "module '%s' has no __dict__",
- PyModule_GetName(m));
- if (PyDict_SetItemString(dict, name, o))
- Py_DECREF(o);
- return SWIG_OK;
-#endif
-SWIGRUNTIME void
-SWIG_Python_DestroyModule(void *vptr)
- swig_module_info *swig_module = (swig_module_info *) vptr;
- swig_type_info **types = swig_module->types;
- size_t i;
- for (i =0; i < swig_module->size; ++i) {
- swig_type_info *ty = types[i];
- if (ty->owndata) {
- PySwigClientData *data = (PySwigClientData *) ty->clientdata;
- if (data) PySwigClientData_Del(data);
- Py_DECREF(SWIG_This());
-SWIGRUNTIME void
-SWIG_Python_SetModule(swig_module_info *swig_module) {
- static PyMethodDef swig_empty_runtime_method_table[] = { {NULL, NULL, 0, NULL} };/* Sentinel */
- PyObject *module = Py_InitModule((char*)"swig_runtime_data" SWIG_RUNTIME_VERSION,
- swig_empty_runtime_method_table);
- PyObject *pointer = PyCObject_FromVoidPtr((void *) swig_module, SWIG_Python_DestroyModule);
- if (pointer && module) {
- PyModule_AddObject(module, (char*)"type_pointer" SWIG_TYPE_TABLE_NAME, pointer);
- } else {
- Py_XDECREF(pointer);
-/* The python cached type query */
-SWIG_Python_TypeCache(void) {
- static PyObject *SWIG_STATIC_POINTER(cache) = PyDict_New();
- return cache;
-SWIG_Python_TypeQuery(const char *type)
- PyObject *cache = SWIG_Python_TypeCache();
- PyObject *key = PyString_FromString(type);
- PyObject *obj = PyDict_GetItem(cache, key);
- swig_type_info *descriptor;
- if (obj) {
- descriptor = (swig_type_info *) PyCObject_AsVoidPtr(obj);
- } else {
- swig_module_info *swig_module = SWIG_Python_GetModule();
- descriptor = SWIG_TypeQueryModule(swig_module, swig_module, type);
- if (descriptor) {
- obj = PyCObject_FromVoidPtr(descriptor, NULL);
- PyDict_SetItem(cache, key, obj);
- Py_DECREF(obj);
- Py_DECREF(key);
- return descriptor;
- For backward compatibility only
-#define SWIG_POINTER_EXCEPTION 0
-#define SWIG_arg_fail(arg) SWIG_Python_ArgFail(arg)
-#define SWIG_MustGetPtr(p, type, argnum, flags) SWIG_Python_MustGetPtr(p, type, argnum, flags)
-SWIGRUNTIME int
-SWIG_Python_AddErrMesg(const char* mesg, int infront)
- PyErr_Fetch(&type, &value, &traceback);
- if (value) {
- Py_XINCREF(type);
- PyErr_Clear();
- if (infront) {
- PyErr_Format(type, "%s %s", mesg, PyString_AsString(old_str));
- } else {
- return 1;
- } else {
- return 0;
-SWIGRUNTIME int
-SWIG_Python_ArgFail(int argnum)
- /* add information about failing argument */
- char mesg[256];
- PyOS_snprintf(mesg, sizeof(mesg), "argument number %d:", argnum);
- return SWIG_Python_AddErrMesg(mesg, 1);
- } else {
- return 0;
-PySwigObject_GetDesc(PyObject *self)
- PySwigObject *v = (PySwigObject *)self;
- swig_type_info *ty = v ? v->ty : 0;
- return ty ? ty->str : (char*)"";
-SWIGRUNTIME void
-SWIG_Python_TypeError(const char *type, PyObject *obj)
- if (type) {
-#if defined(SWIG_COBJECT_TYPES)
- if (obj && PySwigObject_Check(obj)) {
- const char *otype = (const char *) PySwigObject_GetDesc(obj);
- if (otype) {
- PyErr_Format(PyExc_TypeError, "a '%s' is expected, 'PySwigObject(%s)' is received",
- type, otype);
- return;
- } else
-#endif
- const char *otype = (obj ? obj->ob_type->tp_name : 0);
- if (otype) {
- PyObject *str = PyObject_Str(obj);
- const char *cstr = str ? PyString_AsString(str) : 0;
- if (cstr) {
- PyErr_Format(PyExc_TypeError, "a '%s' is expected, '%s(%s)' is received",
- type, otype, cstr);
- } else {
- PyErr_Format(PyExc_TypeError, "a '%s' is expected, '%s' is received",
- type, otype);
- Py_XDECREF(str);
- return;
- PyErr_Format(PyExc_TypeError, "a '%s' is expected", type);
- } else {
- PyErr_Format(PyExc_TypeError, "unexpected type is received");
-/* Convert a pointer value, signal an exception on a type mismatch */
-SWIGRUNTIME void *
-SWIG_Python_MustGetPtr(PyObject *obj, swig_type_info *ty, int argnum, int flags) {
- void *result;
- if (SWIG_Python_ConvertPtr(obj, &result, ty, flags) == -1) {
- PyErr_Clear();
- if (flags & SWIG_POINTER_EXCEPTION) {
- SWIG_Python_TypeError(SWIG_TypePrettyName(ty), obj);
- SWIG_Python_ArgFail(argnum);
- return result;
-#ifdef __cplusplus
-#if 0
-{ /* cc-mode */
-#endif
-#endif
-#define SWIG_exception_fail(code, msg) do { SWIG_Error(code, msg); SWIG_fail; } while(0)
-#define SWIG_contract_assert(expr, msg) if (!(expr)) { SWIG_Error(SWIG_RuntimeError, msg); SWIG_fail; } else
- #define SWIG_exception(code, msg) do { SWIG_Error(code, msg); SWIG_fail;; } while(0)
-/* -------- TYPES TABLE (BEGIN) -------- */
-#define SWIGTYPE_p_Digit swig_types[0]
-#define SWIGTYPE_p_DisplayDriver swig_types[1]
-#define SWIGTYPE_p_allocator_type swig_types[2]
-#define SWIGTYPE_p_char swig_types[3]
-#define SWIGTYPE_p_difference_type swig_types[4]
-#define SWIGTYPE_p_key_type swig_types[5]
-#define SWIGTYPE_p_mapped_type swig_types[6]
-#define SWIGTYPE_p_p_PyObject swig_types[7]
-#define SWIGTYPE_p_size_type swig_types[8]
-#define SWIGTYPE_p_std__invalid_argument swig_types[9]
-#define SWIGTYPE_p_std__lessTint_t swig_types[10]
-#define SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t swig_types[11]
-#define SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type swig_types[12]
-#define SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t swig_types[13]
-#define SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type swig_types[14]
-#define SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t swig_types[15]
-#define SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t__allocator_type swig_types[16]
-#define SWIGTYPE_p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t swig_types[17]
-#define SWIGTYPE_p_swig__PySwigIterator swig_types[18]
-#define SWIGTYPE_p_value_type swig_types[19]
-static swig_type_info *swig_types[21];
-static swig_module_info swig_module = {swig_types, 20, 0, 0, 0, 0};
-#define SWIG_TypeQuery(name) SWIG_TypeQueryModule(&swig_module, &swig_module, name)
-#define SWIG_MangledTypeQuery(name) SWIG_MangledTypeQueryModule(&swig_module, &swig_module, name)
-/* -------- TYPES TABLE (END) -------- */
-#if (PY_VERSION_HEX <= 0x02000000)
-# if !defined(SWIG_PYTHON_CLASSIC)
-# error "This python version requires swig to be run with the '-classic' option"
-# endif
-#endif
- @(target):= _grass6_wxvdigit.so
-#define SWIG_init init_grass6_wxvdigit
-#define SWIG_name "_grass6_wxvdigit"
-#define SWIGVERSION 0x010333
-#define SWIG_VERSION SWIGVERSION
-#define SWIG_as_voidptr(a) const_cast< void * >(static_cast< const void * >(a))
-#define SWIG_as_voidptrptr(a) ((void)SWIG_as_voidptr(*a),reinterpret_cast< void** >(a))
-#include <stdexcept>
-namespace swig {
- class PyObject_ptr {
- protected:
- PyObject *_obj;
- public:
- PyObject_ptr() :_obj(0)
- PyObject_ptr(const PyObject_ptr& item) : _obj(item._obj)
- Py_XINCREF(_obj);
- PyObject_ptr(PyObject *obj, bool initial_ref = true) :_obj(obj)
- if (initial_ref) Py_XINCREF(_obj);
- PyObject_ptr & operator=(const PyObject_ptr& item)
- Py_XINCREF(item._obj);
- Py_XDECREF(_obj);
- _obj = item._obj;
- return *this;
- ~PyObject_ptr()
- Py_XDECREF(_obj);
- operator PyObject *() const
- return _obj;
- PyObject *operator->() const
- return _obj;
-namespace swig {
- struct PyObject_var : PyObject_ptr {
- PyObject_var(PyObject* obj = 0) : PyObject_ptr(obj, false) { }
- PyObject_var & operator = (PyObject* obj)
- Py_XDECREF(_obj);
- _obj = obj;
- return *this;
-#include <grass/gis.h>
-#include <grass/gisdefs.h>
-#include <grass/Vect.h>
-#include <grass/vect/dig_structs.h>
-#include "driver.h"
-#include "digit.h"
-#include <iostream>
-#if defined(__SUNPRO_CC) && defined(_RWSTD_VER)
-# define SWIG_STD_NOASSIGN_STL
-# define SWIG_STD_NOINSERT_TEMPLATE_STL
-# define SWIG_STD_NOITERATOR_TRAITS_STL
-#endif
-#if defined(__GNUC__)
-# if __GNUC__ == 2 && __GNUC_MINOR <= 96
-# define SWIG_STD_NOMODERN_STL
-# endif
-#endif
-#include <string>
-namespace swig {
- struct stop_iteration {
- struct PySwigIterator {
- private:
- PyObject_ptr _seq;
- protected:
- PySwigIterator(PyObject *seq) : _seq(seq)
- public:
- virtual ~PySwigIterator() {}
- // Access iterator method, required by Python
- virtual PyObject *value() const = 0;
- // Forward iterator method, required by Python
- virtual PySwigIterator *incr(size_t n = 1) = 0;
- // Backward iterator method, very common in C++, but not required in Python
- virtual PySwigIterator *decr(size_t n = 1)
- throw stop_iteration();
- // Random access iterator methods, but not required in Python
- virtual ptrdiff_t distance(const PySwigIterator &x) const
- throw std::invalid_argument("operation not supported");
- virtual bool equal (const PySwigIterator &x) const
- // C++ common/needed methods
- virtual PySwigIterator *copy() const = 0;
- PyObject *next()
- PyObject *obj = value();
- incr();
- return obj;
- PyObject *previous()
- decr();
- return value();
- PySwigIterator *advance(ptrdiff_t n)
- return (n > 0) ? incr(n) : decr(-n);
- bool operator == (const PySwigIterator& x) const
- return equal(x);
- bool operator != (const PySwigIterator& x) const
- return ! operator==(x);
- PySwigIterator& operator += (ptrdiff_t n)
- return *advance(n);
- PySwigIterator& operator -= (ptrdiff_t n)
- return *advance(-n);
- PySwigIterator* operator + (ptrdiff_t n) const
- return copy()->advance(n);
- PySwigIterator* operator - (ptrdiff_t n) const
- return copy()->advance(-n);
- ptrdiff_t operator - (const PySwigIterator& x) const
- return x.distance(*this);
- static swig_type_info* descriptor() {
- static int init = 0;
- static swig_type_info* desc = 0;
- if (!init) {
- desc = SWIG_TypeQuery("swig::PySwigIterator *");
- init = 1;
- return desc;
-SWIGINTERN int
-SWIG_AsVal_double (PyObject *obj, double *val)
- int res = SWIG_TypeError;
- if (PyFloat_Check(obj)) {
- if (val) *val = PyFloat_AsDouble(obj);
- return SWIG_OK;
- } else if (PyInt_Check(obj)) {
- if (val) *val = PyInt_AsLong(obj);
- return SWIG_OK;
- } else if (PyLong_Check(obj)) {
- double v = PyLong_AsDouble(obj);
- if (!PyErr_Occurred()) {
- if (val) *val = v;
- return SWIG_OK;
- } else {
- PyErr_Clear();
-#ifdef SWIG_PYTHON_CAST_MODE
- int dispatch = 0;
- double d = PyFloat_AsDouble(obj);
- if (val) *val = d;
- return SWIG_AddCast(SWIG_OK);
- } else {
- PyErr_Clear();
- if (!dispatch) {
- long v = PyLong_AsLong(obj);
- return SWIG_AddCast(SWIG_AddCast(SWIG_OK));
- } else {
- PyErr_Clear();
-#endif
- return res;
-#include <float.h>
-#include <math.h>
-SWIG_CanCastAsInteger(double *d, double min, double max) {
- double x = *d;
- if ((min <= x && x <= max)) {
- double fx = floor(x);
- double cx = ceil(x);
- double rd = ((x - fx) < 0.5) ? fx : cx; /* simple rint */
- if ((errno == EDOM) || (errno == ERANGE)) {
- errno = 0;
- } else {
- double summ, reps, diff;
- if (rd < x) {
- diff = x - rd;
- } else if (rd > x) {
- diff = rd - x;
- } else {
- return 1;
- summ = rd + x;
- reps = diff/summ;
- if (reps < 8*DBL_EPSILON) {
- *d = rd;
- return 1;
- return 0;
-SWIGINTERN int
-SWIG_AsVal_unsigned_SS_long (PyObject *obj, unsigned long *val)
- if (PyInt_Check(obj)) {
- long v = PyInt_AsLong(obj);
- if (v >= 0) {
- return SWIG_OK;
- } else {
- return SWIG_OverflowError;
- unsigned long v = PyLong_AsUnsignedLong(obj);
- return SWIG_OK;
- } else {
- PyErr_Clear();
- int dispatch = 0;
- } else {
- PyErr_Clear();
- if (!dispatch) {
- double d;
- int res = SWIG_AddCast(SWIG_AsVal_double (obj,&d));
- if (SWIG_IsOK(res) && SWIG_CanCastAsInteger(&d, 0, ULONG_MAX)) {
- if (val) *val = (unsigned long)(d);
- return res;
-#endif
- return SWIG_TypeError;
-SWIG_AsVal_size_t (PyObject * obj, size_t *val)
- unsigned long v;
- int res = SWIG_AsVal_unsigned_SS_long (obj, val ? &v : 0);
- if (SWIG_IsOK(res) && val) *val = static_cast< size_t >(v);
- return res;
- #define SWIG_From_long PyInt_FromLong
-SWIGINTERNINLINE PyObject *
-SWIG_From_ptrdiff_t (ptrdiff_t value)
- return SWIG_From_long (static_cast< long >(value));
-SWIGINTERNINLINE PyObject*
- SWIG_From_bool (bool value)
- return PyBool_FromLong(value ? 1 : 0);
-SWIGINTERN int
-SWIG_AsVal_long (PyObject *obj, long* val)
- return SWIG_OK;
- return SWIG_OK;
- } else {
- PyErr_Clear();
- int dispatch = 0;
- } else {
- PyErr_Clear();
- if (!dispatch) {
- double d;
- if (SWIG_IsOK(res) && SWIG_CanCastAsInteger(&d, LONG_MIN, LONG_MAX)) {
- if (val) *val = (long)(d);
- return res;
-#endif
-SWIG_AsVal_ptrdiff_t (PyObject * obj, ptrdiff_t *val)
- long v;
- int res = SWIG_AsVal_long (obj, val ? &v : 0);
- if (SWIG_IsOK(res) && val) *val = static_cast< ptrdiff_t >(v);
- return res;
-#include <algorithm>
-#include <vector>
-namespace swig {
- template <class Type>
- struct noconst_traits {
- typedef Type noconst_type;
- struct noconst_traits<const Type> {
- type categories
- struct pointer_category { };
- struct value_category { };
- General traits that provides type_name and type_info
- template <class Type> struct traits { };
- inline const char* type_name() {
- return traits<typename noconst_traits<Type >::noconst_type >::type_name();
- struct traits_info {
- static swig_type_info *type_query(std::string name) {
- name += " *";
- return SWIG_TypeQuery(name.c_str());
- static swig_type_info *type_info() {
- static swig_type_info *info = type_query(type_name<Type>());
- return info;
- inline swig_type_info *type_info() {
- return traits_info<Type>::type_info();
- Partial specialization for pointers
- template <class Type> struct traits <Type *> {
- typedef pointer_category category;
- static std::string make_ptr_name(const char* name) {
- std::string ptrname = name;
- ptrname += " *";
- return ptrname;
- static const char* type_name() {
- static std::string name = make_ptr_name(swig::type_name<Type>());
- return name.c_str();
- template <class Type, class Category>
- struct traits_as { };
- struct traits_check { };
-namespace swig {
- Traits that provides the from method
- template <class Type> struct traits_from_ptr {
- static PyObject *from(Type *val, int owner = 0) {
- return SWIG_NewPointerObj(val, type_info<Type>(), owner);
- template <class Type> struct traits_from {
- static PyObject *from(const Type& val) {
- return traits_from_ptr<Type>::from(new Type(val), 1);
- template <class Type> struct traits_from<Type *> {
- static PyObject *from(Type* val) {
- return traits_from_ptr<Type>::from(val, 0);
- template <class Type> struct traits_from<const Type *> {
- static PyObject *from(const Type* val) {
- return traits_from_ptr<Type>::from(const_cast<Type*>(val), 0);
- inline PyObject *from(const Type& val) {
- return traits_from<Type>::from(val);
- inline PyObject *from_ptr(Type* val, int owner) {
- return traits_from_ptr<Type>::from(val, owner);
- Traits that provides the asval/as/check method
- struct traits_asptr {
- static int asptr(PyObject *obj, Type **val) {
- Type *p;
- int res = (SWIG_ConvertPtr(obj, (void**)&p, type_info<Type>(), 0) == SWIG_OK) ? SWIG_OLDOBJ : 0;
- if (SWIG_IsOK(res)) {
- if (val) *val = p;
- return res;
- inline int asptr(PyObject *obj, Type **vptr) {
- return traits_asptr<Type>::asptr(obj, vptr);
- struct traits_asval {
- static int asval(PyObject *obj, Type *val) {
- if (val) {
- Type *p = 0;
- int res = traits_asptr<Type>::asptr(obj, &p);
- if (!SWIG_IsOK(res)) return res;
- if (p) {
- typedef typename noconst_traits<Type>::noconst_type noconst_type;
- *(const_cast<noconst_type*>(val)) = *p;
- if (SWIG_IsNewObj(res)){
- delete p;
- res = SWIG_DelNewMask(res);
- return res;
- } else {
- } else {
- return traits_asptr<Type>::asptr(obj, (Type **)(0));
- template <class Type> struct traits_asval<Type*> {
- static int asval(PyObject *obj, Type **val) {
- if (val) {
- noconst_type *p = 0;
- int res = traits_asptr<noconst_type>::asptr(obj, &p);
- *(const_cast<noconst_type**>(val)) = p;
- return res;
- } else {
- inline int asval(PyObject *obj, Type *val) {
- return traits_asval<Type>::asval(obj, val);
- struct traits_as<Type, value_category> {
- static Type as(PyObject *obj, bool throw_error) {
- Type v;
- int res = asval(obj, &v);
- if (!obj || !SWIG_IsOK(res)) {
- SWIG_Error(SWIG_TypeError, swig::type_name<Type>());
- if (throw_error) throw std::invalid_argument("bad type");
- return v;
- struct traits_as<Type, pointer_category> {
- Type *v = 0;
- int res = (obj ? traits_asptr<Type>::asptr(obj, &v) : SWIG_ERROR);
- if (SWIG_IsOK(res) && v) {
- if (SWIG_IsNewObj(res)) {
- Type r(*v);
- delete v;
- return r;
- } else {
- return *v;
- } else {
- // Uninitialized return value, no Type() constructor required.
- static Type *v_def = (Type*) malloc(sizeof(Type));
- memset(v_def,0,sizeof(Type));
- return *v_def;
- struct traits_as<Type*, pointer_category> {
- static Type* as(PyObject *obj, bool throw_error) {
- Type *v = 0;
- return v;
- } else {
- return 0;
- inline Type as(PyObject *obj, bool te = false) {
- return traits_as<Type, typename traits<Type>::category>::as(obj, te);
- struct traits_check<Type, value_category> {
- static bool check(PyObject *obj) {
- int res = obj ? asval(obj, (Type *)(0)) : SWIG_ERROR;
- return SWIG_IsOK(res) ? true : false;
- struct traits_check<Type, pointer_category> {
- int res = obj ? asptr(obj, (Type **)(0)) : SWIG_ERROR;
- inline bool check(PyObject *obj) {
- return traits_check<Type, typename traits<Type>::category>::check(obj);
-#include <functional>
-namespace std {
- template <>
- struct less <PyObject *>: public binary_function<PyObject *, PyObject *, bool>
- bool
- operator()(PyObject * v, PyObject *w) const
- bool res;
- res = PyObject_Compare(v, w) < 0;
- return res;
- template <>
- struct less <swig::PyObject_ptr>: public binary_function<swig::PyObject_ptr, swig::PyObject_ptr, bool>
- bool
- operator()(const swig::PyObject_ptr& v, const swig::PyObject_ptr& w) const
- return std::less<PyObject *>()(v, w);
- template <>
- struct less <swig::PyObject_var>: public binary_function<swig::PyObject_var, swig::PyObject_var, bool>
- bool
- operator()(const swig::PyObject_var& v, const swig::PyObject_var& w) const
-namespace swig {
- template <> struct traits<PyObject *> {
- typedef value_category category;
- static const char* type_name() { return "PyObject *"; }
- template <> struct traits_asval<PyObject * > {
- typedef PyObject * value_type;
- static int asval(PyObject *obj, value_type *val) {
- if (val) *val = obj;
- return SWIG_OK;
- template <>
- struct traits_check<PyObject *, value_category> {
- static bool check(PyObject *) {
- return true;
- template <> struct traits_from<PyObject *> {
- static PyObject *from(const value_type& val) {
- Py_XINCREF(val);
- return val;
-namespace swig {
- inline size_t
- check_index(ptrdiff_t i, size_t size, bool insert = false) {
- if ( i < 0 ) {
- if ((size_t) (-i) <= size)
- return (size_t) (i + size);
- } else if ( (size_t) i < size ) {
- return (size_t) i;
- } else if (insert && ((size_t) i == size)) {
- return size;
- throw std::out_of_range("index out of range");
- inline size_t
- slice_index(ptrdiff_t i, size_t size) {
- if ( i < 0 ) {
- if ((size_t) (-i) <= size) {
- } else {
- } else {
- return ( (size_t) i < size ) ? ((size_t) i) : size;
- template <class Sequence, class Difference>
- inline typename Sequence::iterator
- getpos(Sequence* self, Difference i) {
- typename Sequence::iterator pos = self->begin();
- std::advance(pos, check_index(i,self->size()));
- return pos;
- inline typename Sequence::const_iterator
- cgetpos(const Sequence* self, Difference i) {
- typename Sequence::const_iterator pos = self->begin();
- return pos;
- inline Sequence*
- getslice(const Sequence* self, Difference i, Difference j) {
- typename Sequence::size_type size = self->size();
- typename Sequence::size_type ii = swig::check_index(i, size);
- typename Sequence::size_type jj = swig::slice_index(j, size);
- if (jj > ii) {
- typename Sequence::const_iterator vb = self->begin();
- typename Sequence::const_iterator ve = self->begin();
- std::advance(vb,ii);
- std::advance(ve,jj);
- return new Sequence(vb, ve);
- } else {
- return new Sequence();
- template <class Sequence, class Difference, class InputSeq>
- inline void
- setslice(Sequence* self, Difference i, Difference j, const InputSeq& v) {
- typename Sequence::size_type ii = swig::check_index(i, size, true);
- if (jj < ii) jj = ii;
- size_t ssize = jj - ii;
- if (ssize <= v.size()) {
- typename Sequence::iterator sb = self->begin();
- typename InputSeq::const_iterator vmid = v.begin();
- std::advance(sb,ii);
- std::advance(vmid, jj - ii);
- self->insert(std::copy(v.begin(), vmid, sb), vmid, v.end());
- } else {
- typename Sequence::iterator se = self->begin();
- std::advance(se,jj);
- self->erase(sb,se);
- self->insert(sb, v.begin(), v.end());
- inline void
- delslice(Sequence* self, Difference i, Difference j) {
- if (jj > ii) {
-#if !defined(SWIG_STD_NOITERATOR_TRAITS_STL)
-#include <iterator>
-#else
-namespace std {
- template <class Iterator>
- struct iterator_traits {
- typedef ptrdiff_t difference_type;
- typedef typename Iterator::value_type value_type;
- template <class Iterator, class Category,class T, class Reference, class Pointer, class Distance>
- struct iterator_traits<__reverse_bi_iterator<Iterator,Category,T,Reference,Pointer,Distance> > {
- typedef Distance difference_type;
- typedef T value_type;
-#endif
- template <class T>
- struct iterator_traits<T*> {
- template<typename _InputIterator>
- inline typename iterator_traits<_InputIterator>::difference_type
- distance(_InputIterator __first, _InputIterator __last)
- typename iterator_traits<_InputIterator>::difference_type __n = 0;
- while (__first != __last) {
- ++__first; ++__n;
- return __n;
-#endif
-namespace swig {
- template<typename OutIterator>
- class PySwigIterator_T : public PySwigIterator
- public:
- typedef OutIterator out_iterator;
- typedef typename std::iterator_traits<out_iterator>::value_type value_type;
- typedef PySwigIterator_T<out_iterator> self_type;
- PySwigIterator_T(out_iterator curr, PyObject *seq)
- : PySwigIterator(seq), current(curr)
- const out_iterator& get_current() const
- return current;
- bool equal (const PySwigIterator &iter) const
- const self_type *iters = dynamic_cast<const self_type *>(&iter);
- if (iters) {
- return (current == iters->get_current());
- } else {
- throw std::invalid_argument("bad iterator type");
- ptrdiff_t distance(const PySwigIterator &iter) const
- if (iters) {
- return std::distance(current, iters->get_current());
- } else {
- protected:
- out_iterator current;
- template <class ValueType>
- struct from_oper
- typedef const ValueType& argument_type;
- typedef PyObject *result_type;
- result_type operator()(argument_type v) const
- return swig::from(v);
- template<typename OutIterator,
- typename ValueType = typename std::iterator_traits<OutIterator>::value_type,
- typename FromOper = from_oper<ValueType> >
- class PySwigIteratorOpen_T : public PySwigIterator_T<OutIterator>
- public:
- FromOper from;
- typedef ValueType value_type;
- typedef PySwigIterator_T<out_iterator> base;
- typedef PySwigIteratorOpen_T<OutIterator, ValueType, FromOper> self_type;
- PySwigIteratorOpen_T(out_iterator curr, PyObject *seq)
- : PySwigIterator_T<OutIterator>(curr, seq)
- PyObject *value() const {
- return from(static_cast<const value_type&>(*(base::current)));
- PySwigIterator *copy() const
- return new self_type(*this);
- PySwigIterator *incr(size_t n = 1)
- while (n--) {
- ++base::current;
- return this;
- PySwigIterator *decr(size_t n = 1)
- while (n--) {
- --base::current;
- return this;
- class PySwigIteratorClosed_T : public PySwigIterator_T<OutIterator>
- public:
- FromOper from;
- typedef PySwigIteratorClosed_T<OutIterator, ValueType, FromOper> self_type;
- PySwigIteratorClosed_T(out_iterator curr, out_iterator first, out_iterator last, PyObject *seq)
- : PySwigIterator_T<OutIterator>(curr, seq), begin(first), end(last)
- if (base::current == end) {
- } else {
- while (n--) {
- } else {
- ++base::current;
- return this;
- while (n--) {
- if (base::current == begin) {
- } else {
- --base::current;
- return this;
- private:
- out_iterator begin;
- out_iterator end;
- template<typename OutIter>
- inline PySwigIterator*
- make_output_iterator(const OutIter& current, const OutIter& begin,const OutIter& end, PyObject *seq = 0)
- return new PySwigIteratorClosed_T<OutIter>(current, begin, end, seq);
- make_output_iterator(const OutIter& current, PyObject *seq = 0)
- return new PySwigIteratorOpen_T<OutIter>(current, seq);
-namespace swig
- struct PySequence_Ref
- PySequence_Ref(PyObject* seq, int index)
- : _seq(seq), _index(index)
- operator T () const
- swig::PyObject_var item = PySequence_GetItem(_seq, _index);
- try {
- return swig::as<T>(item, true);
- } catch (std::exception& e) {
- char msg[1024];
- sprintf(msg, "in sequence element %d ", _index);
- SWIG_Error(SWIG_TypeError, swig::type_name<T>());
- SWIG_Python_AddErrorMsg(msg);
- SWIG_Python_AddErrorMsg(e.what());
- throw;
- PySequence_Ref& operator=(const T& v)
- PySequence_SetItem(_seq, _index, swig::from<T>(v));
- return *this;
- private:
- PyObject* _seq;
- int _index;
- struct PySequence_ArrowProxy
- PySequence_ArrowProxy(const T& x): m_value(x) {}
- const T* operator->() const { return &m_value; }
- operator const T*() const { return &m_value; }
- T m_value;
- template <class T, class Reference >
- struct PySequence_InputIterator
- typedef PySequence_InputIterator<T, Reference > self;
- typedef std::random_access_iterator_tag iterator_category;
- typedef Reference reference;
- typedef T* pointer;
- typedef int difference_type;
- PySequence_InputIterator()
- PySequence_InputIterator(PyObject* seq, int index)
- reference operator*() const
- return reference(_seq, _index);
- PySequence_ArrowProxy<T>
- operator->() const {
- return PySequence_ArrowProxy<T>(operator*());
- bool operator==(const self& ri) const
- return (_index == ri._index) && (_seq == ri._seq);
- bool operator!=(const self& ri) const
- return !(operator==(ri));
- self& operator ++ ()
- ++_index;
- return *this;
- self& operator -- ()
- --_index;
- return *this;
- self& operator += (difference_type n)
- _index += n;
- return *this;
- self operator +(difference_type n) const
- return self(_seq, _index + n);
- self& operator -= (difference_type n)
- _index -= n;
- return *this;
- self operator -(difference_type n) const
- return self(_seq, _index - n);
- difference_type operator - (const self& ri) const
- return _index - ri._index;
- bool operator < (const self& ri) const
- return _index < ri._index;
- reference
- operator[](difference_type n) const
- return reference(_seq, _index + n);
- private:
- PyObject* _seq;
- difference_type _index;
- struct PySequence_Cont
- typedef PySequence_Ref<T> reference;
- typedef const PySequence_Ref<T> const_reference;
- typedef int size_type;
- typedef const pointer const_pointer;
- typedef PySequence_InputIterator<T, reference> iterator;
- typedef PySequence_InputIterator<T, const_reference> const_iterator;
- PySequence_Cont(PyObject* seq) : _seq(0)
- if (!PySequence_Check(seq)) {
- throw std::invalid_argument("a sequence is expected");
- _seq = seq;
- Py_INCREF(_seq);
- ~PySequence_Cont()
- if (_seq) Py_DECREF(_seq);
- size_type size() const
- return static_cast<size_type>(PySequence_Size(_seq));
- bool empty() const
- return size() == 0;
- iterator begin()
- return iterator(_seq, 0);
- const_iterator begin() const
- return const_iterator(_seq, 0);
- iterator end()
- return iterator(_seq, size());
- const_iterator end() const
- return const_iterator(_seq, size());
- reference operator[](difference_type n)
- return reference(_seq, n);
- const_reference operator[](difference_type n) const
- return const_reference(_seq, n);
- bool check(bool set_err = true) const
- int s = size();
- for (int i = 0; i < s; ++i) {
- swig::PyObject_var item = PySequence_GetItem(_seq, i);
- if (!swig::check<value_type>(item)) {
- if (set_err) {
- char msg[1024];
- sprintf(msg, "in sequence element %d", i);
- SWIG_Error(SWIG_RuntimeError, msg);
- return false;
- return true;
- private:
- PyObject* _seq;
-#include <limits.h>
-#if !defined(SWIG_NO_LLONG_MAX)
-# if !defined(LLONG_MAX) && defined(__GNUC__) && defined (__LONG_LONG_MAX__)
-# define LLONG_MAX __LONG_LONG_MAX__
-# define LLONG_MIN (-LLONG_MAX - 1LL)
-# define ULLONG_MAX (LLONG_MAX * 2ULL + 1ULL)
-# endif
-#endif
-SWIGINTERN int
-SWIG_AsVal_int (PyObject * obj, int *val)
- long v;
- int res = SWIG_AsVal_long (obj, &v);
- if ((v < INT_MIN || v > INT_MAX)) {
- } else {
- if (val) *val = static_cast< int >(v);
- return res;
-SWIG_From_int (int value)
- return SWIG_From_long (value);
-namespace swig {
- template <> struct traits<int > {
- static const char* type_name() { return"int"; }
- template <> struct traits_asval<int > {
- typedef int value_type;
- return SWIG_AsVal_int (obj, val);
- template <> struct traits_from<int > {
- return SWIG_From_int (val);
-namespace swig {
- template <class PySeq, class Seq>
- inline void
- assign(const PySeq& pyseq, Seq* seq) {
-#ifdef SWIG_STD_NOASSIGN_STL
- typedef typename PySeq::value_type value_type;
- typename PySeq::const_iterator it = pyseq.begin();
- for (;it != pyseq.end(); ++it) {
- seq->insert(seq->end(),(value_type)(*it));
-#else
- seq->assign(pyseq.begin(), pyseq.end());
-#endif
- template <class Seq, class T = typename Seq::value_type >
- struct traits_asptr_stdseq {
- typedef Seq sequence;
- static int asptr(PyObject *obj, sequence **seq) {
- if (PySequence_Check(obj)) {
- try {
- PySequence_Cont<value_type> pyseq(obj);
- if (seq) {
- sequence *pseq = new sequence();
- assign(pyseq, pseq);
- *seq = pseq;
- return SWIG_NEWOBJ;
- } else {
- return pyseq.check() ? SWIG_OK : SWIG_ERROR;
- if (seq) {
- PyErr_SetString(PyExc_TypeError, e.what());
- } else {
- sequence *p;
- if (SWIG_ConvertPtr(obj,(void**)&p,
- swig::type_info<sequence>(),0) == SWIG_OK) {
- if (seq) *seq = p;
- return SWIG_OLDOBJ;
- struct traits_from_stdseq {
- typedef typename Seq::size_type size_type;
- typedef typename sequence::const_iterator const_iterator;
- static PyObject *from(const sequence& seq) {
- size_type size = seq.size();
- if (size <= (size_type)INT_MAX) {
- PyObject *obj = PyTuple_New((int)size);
- int i = 0;
- for (const_iterator it = seq.begin();
- it != seq.end(); ++it, ++i) {
- PyTuple_SetItem(obj,i,swig::from<value_type>(*it));
- return obj;
- } else {
- PyErr_SetString(PyExc_OverflowError,"sequence size not valid in python");
- return NULL;
- namespace swig {
- struct traits_asptr<std::vector<T> > {
- static int asptr(PyObject *obj, std::vector<T> **vec) {
- return traits_asptr_stdseq<std::vector<T> >::asptr(obj, vec);
- struct traits_from<std::vector<T> > {
- static PyObject *from(const std::vector<T>& vec) {
- return traits_from_stdseq<std::vector<T> >::from(vec);
- namespace swig {
- template <> struct traits<std::vector<int, std::allocator<int > > > {
- return "std::vector<" "int" "," "std::allocator<int >" " >";
-SWIGINTERN swig::PySwigIterator *std_vector_Sl_int_Sg__iterator(std::vector<int > *self,PyObject **PYTHON_SELF){
- return swig::make_output_iterator(self->begin(), self->begin(), self->end(), *PYTHON_SELF);
-SWIGINTERN bool std_vector_Sl_int_Sg____nonzero__(std::vector<int > const *self){
- return !(self->empty());
-SWIGINTERN std::vector<int >::size_type std_vector_Sl_int_Sg____len__(std::vector<int > const *self){
- return self->size();
-SWIG_From_unsigned_SS_long (unsigned long value)
- return (value > LONG_MAX) ?
- PyLong_FromUnsignedLong(value) : PyInt_FromLong(static_cast< long >(value));
-SWIG_From_size_t (size_t value)
- return SWIG_From_unsigned_SS_long (static_cast< unsigned long >(value));
-SWIGINTERN std::vector<int >::value_type std_vector_Sl_int_Sg__pop(std::vector<int > *self){
- if (self->size() == 0)
- throw std::out_of_range("pop from empty container");
- std::vector<int,std::allocator<int > >::value_type x = self->back();
- self->pop_back();
- return x;
-SWIGINTERN std::vector<int,std::allocator<int > > *std_vector_Sl_int_Sg____getslice__(std::vector<int > *self,std::vector<int >::difference_type i,std::vector<int >::difference_type j){
- return swig::getslice(self, i, j);
-SWIGINTERN void std_vector_Sl_int_Sg____setslice__(std::vector<int > *self,std::vector<int >::difference_type i,std::vector<int >::difference_type j,std::vector<int,std::allocator<int > > const &v){
- swig::setslice(self, i, j, v);
-SWIGINTERN void std_vector_Sl_int_Sg____delslice__(std::vector<int > *self,std::vector<int >::difference_type i,std::vector<int >::difference_type j){
- swig::delslice(self, i, j);
-SWIGINTERN void std_vector_Sl_int_Sg____delitem__(std::vector<int > *self,std::vector<int >::difference_type i){
- self->erase(swig::getpos(self,i));
-SWIGINTERN std::vector<int >::value_type const &std_vector_Sl_int_Sg____getitem__(std::vector<int > const *self,std::vector<int >::difference_type i){
- return *(swig::cgetpos(self, i));
-SWIGINTERN void std_vector_Sl_int_Sg____setitem__(std::vector<int > *self,std::vector<int >::difference_type i,std::vector<int >::value_type const &x){
- *(swig::getpos(self,i)) = x;
-SWIGINTERN void std_vector_Sl_int_Sg__append(std::vector<int > *self,std::vector<int >::value_type const &x){
- self->push_back(x);
- #define SWIG_From_double PyFloat_FromDouble
-namespace swig {
- template <> struct traits<double > {
- static const char* type_name() { return"double"; }
- template <> struct traits_asval<double > {
- typedef double value_type;
- return SWIG_AsVal_double (obj, val);
- template <> struct traits_from<double > {
- return SWIG_From_double (val);
- namespace swig {
- template <> struct traits<std::vector<double, std::allocator<double > > > {
- return "std::vector<" "double" "," "std::allocator<double >" " >";
-SWIGINTERN swig::PySwigIterator *std_vector_Sl_double_Sg__iterator(std::vector<double > *self,PyObject **PYTHON_SELF){
-SWIGINTERN bool std_vector_Sl_double_Sg____nonzero__(std::vector<double > const *self){
-SWIGINTERN std::vector<double >::size_type std_vector_Sl_double_Sg____len__(std::vector<double > const *self){
-SWIGINTERN std::vector<double >::value_type std_vector_Sl_double_Sg__pop(std::vector<double > *self){
- std::vector<double,std::allocator<double > >::value_type x = self->back();
- self->pop_back();
- return x;
-SWIGINTERN std::vector<double,std::allocator<double > > *std_vector_Sl_double_Sg____getslice__(std::vector<double > *self,std::vector<double >::difference_type i,std::vector<double >::difference_type j){
-SWIGINTERN void std_vector_Sl_double_Sg____setslice__(std::vector<double > *self,std::vector<double >::difference_type i,std::vector<double >::difference_type j,std::vector<double,std::allocator<double > > const &v){
-SWIGINTERN void std_vector_Sl_double_Sg____delslice__(std::vector<double > *self,std::vector<double >::difference_type i,std::vector<double >::difference_type j){
-SWIGINTERN void std_vector_Sl_double_Sg____delitem__(std::vector<double > *self,std::vector<double >::difference_type i){
-SWIGINTERN std::vector<double >::value_type const &std_vector_Sl_double_Sg____getitem__(std::vector<double > const *self,std::vector<double >::difference_type i){
-SWIGINTERN void std_vector_Sl_double_Sg____setitem__(std::vector<double > *self,std::vector<double >::difference_type i,std::vector<double >::value_type const &x){
-SWIGINTERN void std_vector_Sl_double_Sg__append(std::vector<double > *self,std::vector<double >::value_type const &x){
-#include <utility>
-#include <map>
- namespace swig {
- template <class T, class U >
- struct traits_asptr<std::pair<T,U> > {
- typedef std::pair<T,U> value_type;
- static int get_pair(PyObject* first, PyObject* second,
- std::pair<T,U> **val)
- if (val) {
- value_type *vp = (new std::pair<T,U>);
- T *pfirst = &(vp->first);
- int res1 = swig::asval((PyObject*)first, pfirst);
- if (!SWIG_IsOK(res1)) return res1;
- U *psecond = &(vp->second);
- int res2 = swig::asval((PyObject*)second, psecond);
- if (!SWIG_IsOK(res2)) return res2;
- *val = vp;
- return SWIG_AddNewMask(res1 > res2 ? res1 : res2);
- } else {
- T *pfirst = 0;
- U *psecond = 0;
- return res1 > res2 ? res1 : res2;
- static int asptr(PyObject *obj, std::pair<T,U> **val) {
- if (PyTuple_Check(obj)) {
- if (PyTuple_GET_SIZE(obj) == 2) {
- res = get_pair(PyTuple_GET_ITEM(obj,0),PyTuple_GET_ITEM(obj,1), val);
- } else if (PySequence_Check(obj)) {
- if (PySequence_Size(obj) == 2) {
- swig::PyObject_var first = PySequence_GetItem(obj,0);
- swig::PyObject_var second = PySequence_GetItem(obj,1);
- res = get_pair(first, second, val);
- } else {
- value_type *p;
- res = SWIG_ConvertPtr(obj,(void**)&p,swig::type_info<value_type>(),0);
- if (SWIG_IsOK(res) && val) *val = p;
- return res;
- struct traits_from<std::pair<T,U> > {
- static PyObject *from(const std::pair<T,U>& val) {
- PyObject* obj = PyTuple_New(2);
- PyTuple_SetItem(obj,0,swig::from(val.first));
- PyTuple_SetItem(obj,1,swig::from(val.second));
- return obj;
- namespace swig {
- template <> struct traits<std::pair< int, std::vector<int,std::allocator<int > > > > {
- return "std::pair<" "int" "," "std::vector<int,std::allocator<int > >" " >";
- namespace swig {
- template <class PySeq, class K, class T >
- inline void
- assign(const PySeq& pyseq, std::map<K,T > *map) {
- typedef typename std::map<K,T>::value_type value_type;
- map->insert(value_type(it->first, it->second));
- template <class K, class T>
- struct traits_asptr<std::map<K,T> > {
- typedef std::map<K,T> map_type;
- static int asptr(PyObject *obj, map_type **val) {
- if (PyDict_Check(obj)) {
- PyObject_var items = PyObject_CallMethod(obj,"items",NULL);
- res = traits_asptr_stdseq<std::map<K,T>, std::pair<K, T> >::asptr(items, val);
- } else {
- map_type *p;
- res = SWIG_ConvertPtr(obj,(void**)&p,swig::type_info<map_type>(),0);
- return res;
- template <class K, class T >
- struct traits_from<std::map<K,T> > {
- typedef typename map_type::const_iterator const_iterator;
- typedef typename map_type::size_type size_type;
- static PyObject *from(const map_type& map) {
- swig_type_info *desc = swig::type_info<map_type>();
- if (desc && desc->clientdata) {
- return SWIG_NewPointerObj(new map_type(map), desc, SWIG_POINTER_OWN);
- } else {
- size_type size = map.size();
- int pysize = (size <= (size_type) INT_MAX) ? (int) size : -1;
- if (pysize < 0) {
- SWIG_PYTHON_THREAD_BEGIN_BLOCK;
- "map size not valid in python");
- SWIG_PYTHON_THREAD_END_BLOCK;
- return NULL;
- PyObject *obj = PyDict_New();
- for (const_iterator i= map.begin(); i!= map.end(); ++i) {
- swig::PyObject_var key = swig::from(i->first);
- swig::PyObject_var val = swig::from(i->second);
- PyDict_SetItem(obj, key, val);
- return obj;
- struct from_key_oper
- return swig::from(v.first);
- struct from_value_oper
- return swig::from(v.second);
- template<class OutIterator, class FromOper, class ValueType = typename OutIterator::value_type>
- struct PyMapIterator_T : PySwigIteratorClosed_T<OutIterator, ValueType, FromOper>
- PyMapIterator_T(OutIterator curr, OutIterator first, OutIterator last, PyObject *seq)
- : PySwigIteratorClosed_T<OutIterator,ValueType,FromOper>(curr, first, last, seq)
- class FromOper = from_key_oper<typename OutIterator::value_type> >
- struct PyMapKeyIterator_T : PyMapIterator_T<OutIterator, FromOper>
- PyMapKeyIterator_T(OutIterator curr, OutIterator first, OutIterator last, PyObject *seq)
- : PyMapIterator_T<OutIterator, FromOper>(curr, first, last, seq)
- make_output_key_iterator(const OutIter& current, const OutIter& begin, const OutIter& end, PyObject *seq = 0)
- return new PyMapKeyIterator_T<OutIter>(current, begin, end, seq);
- class FromOper = from_value_oper<typename OutIterator::value_type> >
- struct PyMapValueIterator_T : PyMapIterator_T<OutIterator, FromOper>
- PyMapValueIterator_T(OutIterator curr, OutIterator first, OutIterator last, PyObject *seq)
- make_output_value_iterator(const OutIter& current, const OutIter& begin, const OutIter& end, PyObject *seq = 0)
- return new PyMapValueIterator_T<OutIter>(current, begin, end, seq);
- namespace swig {
- template <> struct traits<std::map<int, std::vector<int,std::allocator<int > >, std::less<int >, std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > > {
- return "std::map<" "int" "," "std::vector<int,std::allocator<int > >" "," "std::less<int >" "," "std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > >" " >";
-SWIGINTERN swig::PySwigIterator *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__iterator(std::map<int,std::vector<int > > *self,PyObject **PYTHON_SELF){
-SWIGINTERN bool std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____nonzero__(std::map<int,std::vector<int > > const *self){
-SWIGINTERN std::map<int,std::vector<int > >::size_type std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____len__(std::map<int,std::vector<int > > const *self){
-SWIGINTERN std::map<int,std::vector<int > >::mapped_type std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____getitem__(std::map<int,std::vector<int > > const *self,std::map<int,std::vector<int > >::key_type const &key){
- std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::const_iterator i = self->find(key);
- if (i != self->end())
- return i->second;
- else
- throw std::out_of_range("key not found");
-SWIGINTERN void std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____delitem__(std::map<int,std::vector<int > > *self,std::map<int,std::vector<int > >::key_type const &key){
- std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::iterator i = self->find(key);
- self->erase(i);
- else
-SWIGINTERN bool std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__has_key(std::map<int,std::vector<int > > const *self,std::map<int,std::vector<int > >::key_type const &key){
- return i != self->end();
-SWIGINTERN PyObject *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__keys(std::map<int,std::vector<int > > *self){
- std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::size_type size = self->size();
- int pysize = (size <= (std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::size_type) INT_MAX) ? (int) size : -1;
- if (pysize < 0) {
- return NULL;
- PyObject* keyList = PyList_New(pysize);
- std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >::const_iterator i = self->begin();
- for (int j = 0; j < pysize; ++i, ++j) {
- PyList_SET_ITEM(keyList, j, swig::from(i->first));
- return keyList;
-SWIGINTERN PyObject *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__values(std::map<int,std::vector<int > > *self){
- if (pysize < 0) {
- return NULL;
- PyObject* valList = PyList_New(pysize);
- PyList_SET_ITEM(valList, j, swig::from(i->second));
- return valList;
-SWIGINTERN PyObject *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__items(std::map<int,std::vector<int > > *self){
- if (pysize < 0) {
- return NULL;
- PyObject* itemList = PyList_New(pysize);
- PyList_SET_ITEM(itemList, j, swig::from(*i));
- return itemList;
-SWIGINTERN bool std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____contains__(std::map<int,std::vector<int > > *self,std::map<int,std::vector<int > >::key_type const &key){
- return self->find(key) != self->end();
-SWIGINTERN swig::PySwigIterator *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__key_iterator(std::map<int,std::vector<int > > *self,PyObject **PYTHON_SELF){
- return swig::make_output_key_iterator(self->begin(), self->begin(), self->end(), *PYTHON_SELF);
-SWIGINTERN swig::PySwigIterator *std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__value_iterator(std::map<int,std::vector<int > > *self,PyObject **PYTHON_SELF){
- return swig::make_output_value_iterator(self->begin(), self->begin(), self->end(), *PYTHON_SELF);
-SWIGINTERN void std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____setitem__(std::map<int,std::vector<int > > *self,std::map<int,std::vector<int > >::key_type const &key,std::map<int,std::vector<int > >::mapped_type const &x){
- (*self)[key] = x;
-SWIGINTERN int
-SWIG_AsVal_bool (PyObject *obj, bool *val)
- int r = PyObject_IsTrue(obj);
- if (r == -1)
- if (val) *val = r ? true : false;
- return SWIG_OK;
-SWIGINTERN swig_type_info*
-SWIG_pchar_descriptor(void)
- static swig_type_info* info = 0;
- if (!init) {
- info = SWIG_TypeQuery("_p_char");
- init = 1;
- return info;
-SWIGINTERN int
-SWIG_AsCharPtrAndSize(PyObject *obj, char** cptr, size_t* psize, int *alloc)
- if (PyString_Check(obj)) {
- char *cstr; Py_ssize_t len;
- PyString_AsStringAndSize(obj, &cstr, &len);
- if (cptr) {
- if (alloc) {
- In python the user should not be able to modify the inner
- string representation. To warranty that, if you define
- SWIG_PYTHON_SAFE_CSTRINGS, a new/copy of the python string
- buffer is always returned.
- The default behavior is just to return the pointer value,
- so, be careful.
-#if defined(SWIG_PYTHON_SAFE_CSTRINGS)
- if (*alloc != SWIG_OLDOBJ)
-#else
- if (*alloc == SWIG_NEWOBJ)
-#endif
- *cptr = reinterpret_cast< char* >(memcpy((new char[len + 1]), cstr, sizeof(char)*(len + 1)));
- *alloc = SWIG_NEWOBJ;
- else {
- *cptr = cstr;
- *alloc = SWIG_OLDOBJ;
- } else {
- *cptr = PyString_AsString(obj);
- if (psize) *psize = len + 1;
- return SWIG_OK;
- } else {
- swig_type_info* pchar_descriptor = SWIG_pchar_descriptor();
- if (pchar_descriptor) {
- void* vptr = 0;
- if (SWIG_ConvertPtr(obj, &vptr, pchar_descriptor, 0) == SWIG_OK) {
- if (cptr) *cptr = (char *) vptr;
- if (psize) *psize = vptr ? (strlen((char *)vptr) + 1) : 0;
- if (alloc) *alloc = SWIG_OLDOBJ;
- return SWIG_OK;
-#ifdef __cplusplus
-extern "C" {
-#endif
-SWIGINTERN PyObject *_wrap_delete_PySwigIterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *resultobj = 0;
- swig::PySwigIterator *arg1 = (swig::PySwigIterator *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- PyObject * obj0 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:delete_PySwigIterator",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_swig__PySwigIterator, SWIG_POINTER_DISOWN | 0 );
- if (!SWIG_IsOK(res1)) {
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_PySwigIterator" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- arg1 = reinterpret_cast< swig::PySwigIterator * >(argp1);
- delete arg1;
- resultobj = SWIG_Py_Void();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_value(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_value",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_swig__PySwigIterator, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_value" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- try {
- result = (PyObject *)((swig::PySwigIterator const *)arg1)->value();
- catch(swig::stop_iteration &_e) {
- (void)_e;
- SWIG_SetErrorObj(PyExc_StopIteration, SWIG_Py_Void());
- SWIG_fail;
- resultobj = result;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_incr__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- swig::PySwigIterator *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- PyObject * obj1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_incr",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_incr" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- ecode2 = SWIG_AsVal_size_t(obj1, &val2);
- if (!SWIG_IsOK(ecode2)) {
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator_incr" "', argument " "2"" of type '" "size_t""'");
- arg2 = static_cast< size_t >(val2);
- try {
- result = (swig::PySwigIterator *)(arg1)->incr(arg2);
- (void)_e;
- SWIG_fail;
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__PySwigIterator, 0 | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_incr__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_incr",&obj0)) SWIG_fail;
- try {
- result = (swig::PySwigIterator *)(arg1)->incr();
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_incr(PyObject *self, PyObject *args) {
- int argc;
- PyObject *argv[3];
- int ii;
- if (!PyTuple_Check(args)) SWIG_fail;
- argc = (int)PyObject_Length(args);
- for (ii = 0; (ii < argc) && (ii < 2); ii++) {
- argv[ii] = PyTuple_GET_ITEM(args,ii);
- if (argc == 1) {
- int _v;
- void *vptr = 0;
- int res = SWIG_ConvertPtr(argv[0], &vptr, SWIGTYPE_p_swig__PySwigIterator, 0);
- _v = SWIG_CheckState(res);
- if (_v) {
- return _wrap_PySwigIterator_incr__SWIG_1(self, args);
- if (argc == 2) {
- int _v;
- void *vptr = 0;
- if (_v) {
- int res = SWIG_AsVal_size_t(argv[1], NULL);
- if (_v) {
- return _wrap_PySwigIterator_incr__SWIG_0(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'PySwigIterator_incr'.\n Possible C/C++ prototypes are:\n"" incr(swig::PySwigIterator *,size_t)\n"" incr(swig::PySwigIterator *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_decr__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_decr",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_decr" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator_decr" "', argument " "2"" of type '" "size_t""'");
- try {
- result = (swig::PySwigIterator *)(arg1)->decr(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_decr__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_decr",&obj0)) SWIG_fail;
- try {
- result = (swig::PySwigIterator *)(arg1)->decr();
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_decr(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- void *vptr = 0;
- if (_v) {
- return _wrap_PySwigIterator_decr__SWIG_1(self, args);
- if (argc == 2) {
- int _v;
- void *vptr = 0;
- if (_v) {
- if (_v) {
- return _wrap_PySwigIterator_decr__SWIG_0(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'PySwigIterator_decr'.\n Possible C/C++ prototypes are:\n"" decr(swig::PySwigIterator *,size_t)\n"" decr(swig::PySwigIterator *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_distance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- swig::PySwigIterator *arg2 = 0 ;
- ptrdiff_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_distance",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_distance" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_swig__PySwigIterator, 0 | 0);
- if (!SWIG_IsOK(res2)) {
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator_distance" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator_distance" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- arg2 = reinterpret_cast< swig::PySwigIterator * >(argp2);
- try {
- result = ((swig::PySwigIterator const *)arg1)->distance((swig::PySwigIterator const &)*arg2);
- catch(std::invalid_argument &_e) {
- SWIG_Python_Raise(SWIG_NewPointerObj((new std::invalid_argument(static_cast< const std::invalid_argument& >(_e))),SWIGTYPE_p_std__invalid_argument,SWIG_POINTER_OWN), "std::invalid_argument", SWIGTYPE_p_std__invalid_argument); SWIG_fail;
- resultobj = SWIG_From_ptrdiff_t(static_cast< ptrdiff_t >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_equal(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_equal",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_equal" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator_equal" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator_equal" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- try {
- result = (bool)((swig::PySwigIterator const *)arg1)->equal((swig::PySwigIterator const &)*arg2);
- resultobj = SWIG_From_bool(static_cast< bool >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_copy(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_copy",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_copy" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- result = (swig::PySwigIterator *)((swig::PySwigIterator const *)arg1)->copy();
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__PySwigIterator, SWIG_POINTER_OWN | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_next(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_next",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_next" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- try {
- result = (PyObject *)(arg1)->next();
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_previous(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:PySwigIterator_previous",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_previous" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- try {
- result = (PyObject *)(arg1)->previous();
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator_advance(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator_advance",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator_advance" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- ecode2 = SWIG_AsVal_ptrdiff_t(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator_advance" "', argument " "2"" of type '" "ptrdiff_t""'");
- arg2 = static_cast< ptrdiff_t >(val2);
- try {
- result = (swig::PySwigIterator *)(arg1)->advance(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___eq__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___eq__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___eq__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator___eq__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator___eq__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- result = (bool)((swig::PySwigIterator const *)arg1)->operator ==((swig::PySwigIterator const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___ne__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___ne__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___ne__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator___ne__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator___ne__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- result = (bool)((swig::PySwigIterator const *)arg1)->operator !=((swig::PySwigIterator const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___iadd__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___iadd__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___iadd__" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___iadd__" "', argument " "2"" of type '" "ptrdiff_t""'");
- try {
- swig::PySwigIterator &_result_ref = (arg1)->operator +=(arg2);
- result = (swig::PySwigIterator *) &_result_ref;
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___isub__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___isub__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___isub__" "', argument " "1"" of type '" "swig::PySwigIterator *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___isub__" "', argument " "2"" of type '" "ptrdiff_t""'");
- try {
- swig::PySwigIterator &_result_ref = (arg1)->operator -=(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___add__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___add__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___add__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___add__" "', argument " "2"" of type '" "ptrdiff_t""'");
- try {
- result = (swig::PySwigIterator *)((swig::PySwigIterator const *)arg1)->operator +(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___sub____SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:PySwigIterator___sub__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "PySwigIterator___sub__" "', argument " "1"" of type '" "swig::PySwigIterator const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "PySwigIterator___sub__" "', argument " "2"" of type '" "ptrdiff_t""'");
- try {
- result = (swig::PySwigIterator *)((swig::PySwigIterator const *)arg1)->operator -(arg2);
- (void)_e;
- SWIG_fail;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___sub____SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- ptrdiff_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "PySwigIterator___sub__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "PySwigIterator___sub__" "', argument " "2"" of type '" "swig::PySwigIterator const &""'");
- result = ((swig::PySwigIterator const *)arg1)->operator -((swig::PySwigIterator const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_PySwigIterator___sub__(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 2) {
- int _v;
- void *vptr = 0;
- if (_v) {
- int res = SWIG_ConvertPtr(argv[1], 0, SWIGTYPE_p_swig__PySwigIterator, 0);
- if (_v) {
- return _wrap_PySwigIterator___sub____SWIG_1(self, args);
- if (argc == 2) {
- int _v;
- void *vptr = 0;
- if (_v) {
- int res = SWIG_AsVal_ptrdiff_t(argv[1], NULL);
- if (_v) {
- return _wrap_PySwigIterator___sub____SWIG_0(self, args);
-fail:
- Py_INCREF(Py_NotImplemented);
- return Py_NotImplemented;
-SWIGINTERN PyObject *PySwigIterator_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- if (!PyArg_ParseTuple(args,(char*)"O|swigregister", &obj)) return NULL;
- SWIG_TypeNewClientData(SWIGTYPE_p_swig__PySwigIterator, SWIG_NewClientData(obj));
- return SWIG_Py_Void();
-SWIGINTERN PyObject *_wrap_IntVector_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int > *arg1 = (std::vector<int > *) 0 ;
- PyObject **arg2 = (PyObject **) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- arg2 = &obj0;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_iterator",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_iterator" "', argument " "1"" of type '" "std::vector<int > *""'");
- arg1 = reinterpret_cast< std::vector<int > * >(argp1);
- result = (swig::PySwigIterator *)std_vector_Sl_int_Sg__iterator(arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector___nonzero__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector___nonzero__",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___nonzero__" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = (bool)std_vector_Sl_int_Sg____nonzero__((std::vector<int > const *)arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector___len__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::size_type result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector___len__",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___len__" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = std_vector_Sl_int_Sg____len__((std::vector<int > const *)arg1);
- resultobj = SWIG_From_size_t(static_cast< size_t >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_pop(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::value_type result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_pop",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_pop" "', argument " "1"" of type '" "std::vector<int > *""'");
- try {
- result = (std::vector<int >::value_type)std_vector_Sl_int_Sg__pop(arg1);
- catch(std::out_of_range &_e) {
- SWIG_exception_fail(SWIG_IndexError, (&_e)->what());
- resultobj = SWIG_From_int(static_cast< int >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector___getslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::difference_type arg2 ;
- std::vector<int >::difference_type arg3 ;
- std::vector<int,std::allocator<int > > *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- ptrdiff_t val3 ;
- int ecode3 = 0 ;
- PyObject * obj2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector___getslice__",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___getslice__" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___getslice__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
- arg2 = static_cast< std::vector<int >::difference_type >(val2);
- ecode3 = SWIG_AsVal_ptrdiff_t(obj2, &val3);
- if (!SWIG_IsOK(ecode3)) {
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector___getslice__" "', argument " "3"" of type '" "std::vector<int >::difference_type""'");
- arg3 = static_cast< std::vector<int >::difference_type >(val3);
- try {
- result = (std::vector<int,std::allocator<int > > *)std_vector_Sl_int_Sg____getslice__(arg1,arg2,arg3);
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, SWIG_POINTER_OWN | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector___setslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int,std::allocator<int > > *arg4 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- ptrdiff_t val3 ;
- int ecode3 = 0 ;
- int res4 = SWIG_OLDOBJ ;
- PyObject * obj3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOO:IntVector___setslice__",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___setslice__" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___setslice__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector___setslice__" "', argument " "3"" of type '" "std::vector<int >::difference_type""'");
- std::vector<int,std::allocator<int > > *ptr = (std::vector<int,std::allocator<int > > *)0;
- res4 = swig::asptr(obj3, &ptr);
- if (!SWIG_IsOK(res4)) {
- SWIG_exception_fail(SWIG_ArgError(res4), "in method '" "IntVector___setslice__" "', argument " "4"" of type '" "std::vector<int,std::allocator<int > > const &""'");
- if (!ptr) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "IntVector___setslice__" "', argument " "4"" of type '" "std::vector<int,std::allocator<int > > const &""'");
- arg4 = ptr;
- try {
- std_vector_Sl_int_Sg____setslice__(arg1,arg2,arg3,(std::vector<int,std::allocator<int > > const &)*arg4);
- SWIG_exception_fail(SWIG_ValueError, (&_e)->what());
- if (SWIG_IsNewObj(res4)) delete arg4;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector___delslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- ptrdiff_t val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector___delslice__",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___delslice__" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___delslice__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector___delslice__" "', argument " "3"" of type '" "std::vector<int >::difference_type""'");
- try {
- std_vector_Sl_int_Sg____delslice__(arg1,arg2,arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector___delitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVector___delitem__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___delitem__" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___delitem__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
- try {
- std_vector_Sl_int_Sg____delitem__(arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector___getitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::value_type *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVector___getitem__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___getitem__" "', argument " "1"" of type '" "std::vector<int > const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___getitem__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
- try {
- std::vector<int >::value_type const &_result_ref = std_vector_Sl_int_Sg____getitem__((std::vector<int > const *)arg1,arg2);
- result = (std::vector<int >::value_type *) &_result_ref;
- resultobj = SWIG_From_int(static_cast< int >(*result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector___setitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::value_type *arg3 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- std::vector<int >::value_type temp3 ;
- int val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector___setitem__",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector___setitem__" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector___setitem__" "', argument " "2"" of type '" "std::vector<int >::difference_type""'");
- ecode3 = SWIG_AsVal_int(obj2, &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector___setitem__" "', argument " "3"" of type '" "std::vector<int >::value_type""'");
- temp3 = static_cast< std::vector<int >::value_type >(val3);
- arg3 = &temp3;
- try {
- std_vector_Sl_int_Sg____setitem__(arg1,arg2,(int const &)*arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_append(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::value_type *arg2 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- std::vector<int >::value_type temp2 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_append",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_append" "', argument " "1"" of type '" "std::vector<int > *""'");
- ecode2 = SWIG_AsVal_int(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_append" "', argument " "2"" of type '" "std::vector<int >::value_type""'");
- temp2 = static_cast< std::vector<int >::value_type >(val2);
- arg2 = &temp2;
- std_vector_Sl_int_Sg__append(arg1,(int const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_IntVector__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int > *result = 0 ;
- if (!PyArg_ParseTuple(args,(char *)":new_IntVector")) SWIG_fail;
- result = (std::vector<int > *)new std::vector<int >();
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, SWIG_POINTER_NEW | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_IntVector__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int > *arg1 = 0 ;
- int res1 = SWIG_OLDOBJ ;
- if (!PyArg_ParseTuple(args,(char *)"O:new_IntVector",&obj0)) SWIG_fail;
- res1 = swig::asptr(obj0, &ptr);
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_IntVector" "', argument " "1"" of type '" "std::vector<int > const &""'");
- if (!ptr) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "new_IntVector" "', argument " "1"" of type '" "std::vector<int > const &""'");
- arg1 = ptr;
- result = (std::vector<int > *)new std::vector<int >((std::vector<int > const &)*arg1);
- if (SWIG_IsNewObj(res1)) delete arg1;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_empty(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_empty",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_empty" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = (bool)((std::vector<int > const *)arg1)->empty();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_size(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_size",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_size" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = ((std::vector<int > const *)arg1)->size();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_clear(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_clear",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_clear" "', argument " "1"" of type '" "std::vector<int > *""'");
- (arg1)->clear();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_swap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int > *arg2 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_swap",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_swap" "', argument " "1"" of type '" "std::vector<int > *""'");
- res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, 0 );
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "IntVector_swap" "', argument " "2"" of type '" "std::vector<int > &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "IntVector_swap" "', argument " "2"" of type '" "std::vector<int > &""'");
- arg2 = reinterpret_cast< std::vector<int > * >(argp2);
- (arg1)->swap(*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_get_allocator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- SwigValueWrapper< std::allocator<int > > result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_get_allocator",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_get_allocator" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = ((std::vector<int > const *)arg1)->get_allocator();
- resultobj = SWIG_NewPointerObj((new std::vector<int >::allocator_type(static_cast< const std::vector<int >::allocator_type& >(result))), SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t__allocator_type, SWIG_POINTER_OWN | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_begin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_begin",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_begin" "', argument " "1"" of type '" "std::vector<int > *""'");
- result = (arg1)->begin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<int >::iterator & >(result)),
- swig::PySwigIterator::descriptor(),SWIG_POINTER_OWN);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_begin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::const_iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_begin" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = ((std::vector<int > const *)arg1)->begin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<int >::const_iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_begin(PyObject *self, PyObject *args) {
- int argc;
- PyObject *argv[2];
- int ii;
- for (ii = 0; (ii < argc) && (ii < 1); ii++) {
- if (argc == 1) {
- int _v;
- int res = swig::asptr(argv[0], (std::vector<int,std::allocator<int > >**)(0));
- if (_v) {
- return _wrap_IntVector_begin__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVector_begin__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_begin'.\n Possible C/C++ prototypes are:\n"" begin(std::vector<int > *)\n"" begin(std::vector<int > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_end__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_end",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_end" "', argument " "1"" of type '" "std::vector<int > *""'");
- result = (arg1)->end();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_end__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_end" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = ((std::vector<int > const *)arg1)->end();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_end(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVector_end__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVector_end__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_end'.\n Possible C/C++ prototypes are:\n"" end(std::vector<int > *)\n"" end(std::vector<int > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_rbegin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::reverse_iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_rbegin",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_rbegin" "', argument " "1"" of type '" "std::vector<int > *""'");
- result = (arg1)->rbegin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<int >::reverse_iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_rbegin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::const_reverse_iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_rbegin" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = ((std::vector<int > const *)arg1)->rbegin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<int >::const_reverse_iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_rbegin(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVector_rbegin__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVector_rbegin__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_rbegin'.\n Possible C/C++ prototypes are:\n"" rbegin(std::vector<int > *)\n"" rbegin(std::vector<int > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_rend__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_rend",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_rend" "', argument " "1"" of type '" "std::vector<int > *""'");
- result = (arg1)->rend();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_rend__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_rend" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = ((std::vector<int > const *)arg1)->rend();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_rend(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVector_rend__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVector_rend__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_rend'.\n Possible C/C++ prototypes are:\n"" rend(std::vector<int > *)\n"" rend(std::vector<int > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_new_IntVector__SWIG_2(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::size_type arg1 ;
- size_t val1 ;
- int ecode1 = 0 ;
- ecode1 = SWIG_AsVal_size_t(obj0, &val1);
- if (!SWIG_IsOK(ecode1)) {
- SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "new_IntVector" "', argument " "1"" of type '" "std::vector<int >::size_type""'");
- arg1 = static_cast< std::vector<int >::size_type >(val1);
- result = (std::vector<int > *)new std::vector<int >(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_pop_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_pop_back",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_pop_back" "', argument " "1"" of type '" "std::vector<int > *""'");
- (arg1)->pop_back();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_resize__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::size_type arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_resize",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_resize" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_resize" "', argument " "2"" of type '" "std::vector<int >::size_type""'");
- arg2 = static_cast< std::vector<int >::size_type >(val2);
- (arg1)->resize(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_erase__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::iterator arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- swig::PySwigIterator *iter2 = 0 ;
- int res2 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_erase",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_erase" "', argument " "1"" of type '" "std::vector<int > *""'");
- res2 = SWIG_ConvertPtr(obj1, SWIG_as_voidptrptr(&iter2), swig::PySwigIterator::descriptor(), 0);
- if (!SWIG_IsOK(res2) || !iter2) {
- SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVector_erase" "', argument " "2"" of type '" "std::vector<int >::iterator""'");
- } else {
- swig::PySwigIterator_T<std::vector<int >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::vector<int >::iterator > *>(iter2);
- if (iter_t) {
- arg2 = iter_t->get_current();
- } else {
- result = (arg1)->erase(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_erase__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::iterator arg3 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- swig::PySwigIterator *iter3 = 0 ;
- int res3 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector_erase",&obj0,&obj1,&obj2)) SWIG_fail;
- } else {
- if (iter_t) {
- } else {
- res3 = SWIG_ConvertPtr(obj2, SWIG_as_voidptrptr(&iter3), swig::PySwigIterator::descriptor(), 0);
- if (!SWIG_IsOK(res3) || !iter3) {
- SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVector_erase" "', argument " "3"" of type '" "std::vector<int >::iterator""'");
- } else {
- swig::PySwigIterator_T<std::vector<int >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::vector<int >::iterator > *>(iter3);
- if (iter_t) {
- arg3 = iter_t->get_current();
- } else {
- result = (arg1)->erase(arg2,arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_erase(PyObject *self, PyObject *args) {
- int argc;
- PyObject *argv[4];
- int ii;
- for (ii = 0; (ii < argc) && (ii < 3); ii++) {
- if (argc == 2) {
- int _v;
- if (_v) {
- swig::PySwigIterator *iter = 0;
- int res = SWIG_ConvertPtr(argv[1], SWIG_as_voidptrptr(&iter), swig::PySwigIterator::descriptor(), 0);
- _v = (SWIG_IsOK(res) && iter && (dynamic_cast<swig::PySwigIterator_T<std::vector<int >::iterator > *>(iter) != 0));
- if (_v) {
- return _wrap_IntVector_erase__SWIG_0(self, args);
- if (argc == 3) {
- int _v;
- if (_v) {
- if (_v) {
- int res = SWIG_ConvertPtr(argv[2], SWIG_as_voidptrptr(&iter), swig::PySwigIterator::descriptor(), 0);
- if (_v) {
- return _wrap_IntVector_erase__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_erase'.\n Possible C/C++ prototypes are:\n"" erase(std::vector<int > *,std::vector<int >::iterator)\n"" erase(std::vector<int > *,std::vector<int >::iterator,std::vector<int >::iterator)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_new_IntVector__SWIG_3(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t val1 ;
- int ecode1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:new_IntVector",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "new_IntVector" "', argument " "2"" of type '" "std::vector<int >::value_type""'");
- arg2 = &temp2;
- result = (std::vector<int > *)new std::vector<int >(arg1,(std::vector<int >::value_type const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_IntVector(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 0) {
- return _wrap_new_IntVector__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- int res = SWIG_AsVal_size_t(argv[0], NULL);
- if (_v) {
- return _wrap_new_IntVector__SWIG_2(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_new_IntVector__SWIG_1(self, args);
- if (argc == 2) {
- int _v;
- if (_v) {
- int res = SWIG_AsVal_int(argv[1], NULL);
- if (_v) {
- return _wrap_new_IntVector__SWIG_3(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'new_IntVector'.\n Possible C/C++ prototypes are:\n"" std::vector<(int)>()\n"" std::vector<(int)>(std::vector<int > const &)\n"" std::vector<(int)>(std::vector<int >::size_type)\n"" std::vector<(int)>(std::vector<int >::size_type,std::vector<int >::value_type const &)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_push_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_push_back",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_push_back" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_push_back" "', argument " "2"" of type '" "std::vector<int >::value_type""'");
- arg2 = &temp2;
- (arg1)->push_back((std::vector<int >::value_type const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_front(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_front",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_front" "', argument " "1"" of type '" "std::vector<int > const *""'");
- std::vector<int >::value_type const &_result_ref = ((std::vector<int > const *)arg1)->front();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_back",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_back" "', argument " "1"" of type '" "std::vector<int > const *""'");
- std::vector<int >::value_type const &_result_ref = ((std::vector<int > const *)arg1)->back();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_assign(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- int val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector_assign",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_assign" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_assign" "', argument " "2"" of type '" "std::vector<int >::size_type""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector_assign" "', argument " "3"" of type '" "std::vector<int >::value_type""'");
- arg3 = &temp3;
- (arg1)->assign(arg2,(std::vector<int >::value_type const &)*arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_resize__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- int val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector_resize",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector_resize" "', argument " "3"" of type '" "std::vector<int >::value_type""'");
- arg3 = &temp3;
- (arg1)->resize(arg2,(std::vector<int >::value_type const &)*arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_resize(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 2) {
- int _v;
- if (_v) {
- if (_v) {
- return _wrap_IntVector_resize__SWIG_0(self, args);
- if (argc == 3) {
- int _v;
- if (_v) {
- if (_v) {
- int res = SWIG_AsVal_int(argv[2], NULL);
- if (_v) {
- return _wrap_IntVector_resize__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_resize'.\n Possible C/C++ prototypes are:\n"" resize(std::vector<int > *,std::vector<int >::size_type)\n"" resize(std::vector<int > *,std::vector<int >::size_type,std::vector<int >::value_type const &)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_insert__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- int val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:IntVector_insert",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_insert" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVector_insert" "', argument " "2"" of type '" "std::vector<int >::iterator""'");
- } else {
- if (iter_t) {
- } else {
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector_insert" "', argument " "3"" of type '" "std::vector<int >::value_type""'");
- arg3 = &temp3;
- result = (arg1)->insert(arg2,(std::vector<int >::value_type const &)*arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_insert__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int >::size_type arg3 ;
- std::vector<int >::value_type *arg4 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- size_t val3 ;
- int ecode3 = 0 ;
- std::vector<int >::value_type temp4 ;
- int val4 ;
- int ecode4 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOO:IntVector_insert",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
- } else {
- if (iter_t) {
- } else {
- ecode3 = SWIG_AsVal_size_t(obj2, &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "IntVector_insert" "', argument " "3"" of type '" "std::vector<int >::size_type""'");
- arg3 = static_cast< std::vector<int >::size_type >(val3);
- ecode4 = SWIG_AsVal_int(obj3, &val4);
- if (!SWIG_IsOK(ecode4)) {
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "IntVector_insert" "', argument " "4"" of type '" "std::vector<int >::value_type""'");
- temp4 = static_cast< std::vector<int >::value_type >(val4);
- arg4 = &temp4;
- (arg1)->insert(arg2,arg3,(std::vector<int >::value_type const &)*arg4);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_insert(PyObject *self, PyObject *args) {
- int argc;
- PyObject *argv[5];
- int ii;
- for (ii = 0; (ii < argc) && (ii < 4); ii++) {
- if (argc == 3) {
- int _v;
- if (_v) {
- if (_v) {
- if (_v) {
- return _wrap_IntVector_insert__SWIG_0(self, args);
- if (argc == 4) {
- int _v;
- if (_v) {
- if (_v) {
- int res = SWIG_AsVal_size_t(argv[2], NULL);
- if (_v) {
- int res = SWIG_AsVal_int(argv[3], NULL);
- if (_v) {
- return _wrap_IntVector_insert__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVector_insert'.\n Possible C/C++ prototypes are:\n"" insert(std::vector<int > *,std::vector<int >::iterator,std::vector<int >::value_type const &)\n"" insert(std::vector<int > *,std::vector<int >::iterator,std::vector<int >::size_type,std::vector<int >::value_type const &)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_reserve(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVector_reserve",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_reserve" "', argument " "1"" of type '" "std::vector<int > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVector_reserve" "', argument " "2"" of type '" "std::vector<int >::size_type""'");
- (arg1)->reserve(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVector_capacity(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVector_capacity",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVector_capacity" "', argument " "1"" of type '" "std::vector<int > const *""'");
- result = ((std::vector<int > const *)arg1)->capacity();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_delete_IntVector(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:delete_IntVector",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_IntVector" "', argument " "1"" of type '" "std::vector<int > *""'");
- delete arg1;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *IntVector_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_std__vectorTint_std__allocatorTint_t_t, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_DoubleVector_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double > *arg1 = (std::vector<double > *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- arg2 = &obj0;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_iterator",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_iterator" "', argument " "1"" of type '" "std::vector<double > *""'");
- arg1 = reinterpret_cast< std::vector<double > * >(argp1);
- result = (swig::PySwigIterator *)std_vector_Sl_double_Sg__iterator(arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector___nonzero__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector___nonzero__",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___nonzero__" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = (bool)std_vector_Sl_double_Sg____nonzero__((std::vector<double > const *)arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector___len__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::size_type result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector___len__",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___len__" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = std_vector_Sl_double_Sg____len__((std::vector<double > const *)arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_pop(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::value_type result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_pop",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_pop" "', argument " "1"" of type '" "std::vector<double > *""'");
- try {
- result = (std::vector<double >::value_type)std_vector_Sl_double_Sg__pop(arg1);
- resultobj = SWIG_From_double(static_cast< double >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector___getslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::difference_type arg2 ;
- std::vector<double >::difference_type arg3 ;
- std::vector<double,std::allocator<double > > *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- ptrdiff_t val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector___getslice__",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___getslice__" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___getslice__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
- arg2 = static_cast< std::vector<double >::difference_type >(val2);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector___getslice__" "', argument " "3"" of type '" "std::vector<double >::difference_type""'");
- arg3 = static_cast< std::vector<double >::difference_type >(val3);
- try {
- result = (std::vector<double,std::allocator<double > > *)std_vector_Sl_double_Sg____getslice__(arg1,arg2,arg3);
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, SWIG_POINTER_OWN | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector___setslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double,std::allocator<double > > *arg4 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- ptrdiff_t val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOO:DoubleVector___setslice__",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___setslice__" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___setslice__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector___setslice__" "', argument " "3"" of type '" "std::vector<double >::difference_type""'");
- std::vector<double,std::allocator<double > > *ptr = (std::vector<double,std::allocator<double > > *)0;
- SWIG_exception_fail(SWIG_ArgError(res4), "in method '" "DoubleVector___setslice__" "', argument " "4"" of type '" "std::vector<double,std::allocator<double > > const &""'");
- if (!ptr) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "DoubleVector___setslice__" "', argument " "4"" of type '" "std::vector<double,std::allocator<double > > const &""'");
- arg4 = ptr;
- try {
- std_vector_Sl_double_Sg____setslice__(arg1,arg2,arg3,(std::vector<double,std::allocator<double > > const &)*arg4);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector___delslice__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- ptrdiff_t val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector___delslice__",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___delslice__" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___delslice__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector___delslice__" "', argument " "3"" of type '" "std::vector<double >::difference_type""'");
- try {
- std_vector_Sl_double_Sg____delslice__(arg1,arg2,arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector___delitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector___delitem__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___delitem__" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___delitem__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
- try {
- std_vector_Sl_double_Sg____delitem__(arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector___getitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::value_type *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector___getitem__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___getitem__" "', argument " "1"" of type '" "std::vector<double > const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___getitem__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
- try {
- std::vector<double >::value_type const &_result_ref = std_vector_Sl_double_Sg____getitem__((std::vector<double > const *)arg1,arg2);
- result = (std::vector<double >::value_type *) &_result_ref;
- resultobj = SWIG_From_double(static_cast< double >(*result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector___setitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::value_type *arg3 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- ptrdiff_t val2 ;
- int ecode2 = 0 ;
- std::vector<double >::value_type temp3 ;
- double val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector___setitem__",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector___setitem__" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector___setitem__" "', argument " "2"" of type '" "std::vector<double >::difference_type""'");
- ecode3 = SWIG_AsVal_double(obj2, &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector___setitem__" "', argument " "3"" of type '" "std::vector<double >::value_type""'");
- temp3 = static_cast< std::vector<double >::value_type >(val3);
- arg3 = &temp3;
- try {
- std_vector_Sl_double_Sg____setitem__(arg1,arg2,(double const &)*arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_append(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *resultobj = 0;
- std::vector<double >::value_type *arg2 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- std::vector<double >::value_type temp2 ;
- double val2 ;
- int ecode2 = 0 ;
- PyObject * obj0 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_append",&obj0,&obj1)) SWIG_fail;
- if (!SWIG_IsOK(res1)) {
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_append" "', argument " "1"" of type '" "std::vector<double > *""'");
- ecode2 = SWIG_AsVal_double(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_append" "', argument " "2"" of type '" "std::vector<double >::value_type""'");
- temp2 = static_cast< std::vector<double >::value_type >(val2);
- arg2 = &temp2;
- std_vector_Sl_double_Sg__append(arg1,(double const &)*arg2);
- resultobj = SWIG_Py_Void();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_DoubleVector__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double > *result = 0 ;
- if (!PyArg_ParseTuple(args,(char *)":new_DoubleVector")) SWIG_fail;
- result = (std::vector<double > *)new std::vector<double >();
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, SWIG_POINTER_NEW | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_DoubleVector__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double > *arg1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:new_DoubleVector",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_DoubleVector" "', argument " "1"" of type '" "std::vector<double > const &""'");
- if (!ptr) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "new_DoubleVector" "', argument " "1"" of type '" "std::vector<double > const &""'");
- arg1 = ptr;
- result = (std::vector<double > *)new std::vector<double >((std::vector<double > const &)*arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_empty(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_empty",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_empty" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = (bool)((std::vector<double > const *)arg1)->empty();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_size(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_size",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_size" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = ((std::vector<double > const *)arg1)->size();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_clear(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_clear",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_clear" "', argument " "1"" of type '" "std::vector<double > *""'");
- (arg1)->clear();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_swap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double > *arg2 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- PyObject * obj1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_swap",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_swap" "', argument " "1"" of type '" "std::vector<double > *""'");
- res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, 0 );
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "DoubleVector_swap" "', argument " "2"" of type '" "std::vector<double > &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "DoubleVector_swap" "', argument " "2"" of type '" "std::vector<double > &""'");
- arg2 = reinterpret_cast< std::vector<double > * >(argp2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_get_allocator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- SwigValueWrapper< std::allocator<double > > result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_get_allocator",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_get_allocator" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = ((std::vector<double > const *)arg1)->get_allocator();
- resultobj = SWIG_NewPointerObj((new std::vector<double >::allocator_type(static_cast< const std::vector<double >::allocator_type& >(result))), SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type, SWIG_POINTER_OWN | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_begin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_begin",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_begin" "', argument " "1"" of type '" "std::vector<double > *""'");
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<double >::iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_begin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::const_iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_begin" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = ((std::vector<double > const *)arg1)->begin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<double >::const_iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_begin(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (!PyTuple_Check(args)) SWIG_fail;
- argc = (int)PyObject_Length(args);
- argv[ii] = PyTuple_GET_ITEM(args,ii);
- if (argc == 1) {
- int _v;
- int res = swig::asptr(argv[0], (std::vector<double,std::allocator<double > >**)(0));
- _v = SWIG_CheckState(res);
- if (_v) {
- return _wrap_DoubleVector_begin__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_DoubleVector_begin__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_begin'.\n Possible C/C++ prototypes are:\n"" begin(std::vector<double > *)\n"" begin(std::vector<double > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_end__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_end",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_end" "', argument " "1"" of type '" "std::vector<double > *""'");
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_end__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_end" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = ((std::vector<double > const *)arg1)->end();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_end(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_DoubleVector_end__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_DoubleVector_end__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_end'.\n Possible C/C++ prototypes are:\n"" end(std::vector<double > *)\n"" end(std::vector<double > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_rbegin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::reverse_iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_rbegin",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_rbegin" "', argument " "1"" of type '" "std::vector<double > *""'");
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<double >::reverse_iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_rbegin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::const_reverse_iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_rbegin" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = ((std::vector<double > const *)arg1)->rbegin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::vector<double >::const_reverse_iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_rbegin(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_DoubleVector_rbegin__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_DoubleVector_rbegin__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_rbegin'.\n Possible C/C++ prototypes are:\n"" rbegin(std::vector<double > *)\n"" rbegin(std::vector<double > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_rend__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_rend",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_rend" "', argument " "1"" of type '" "std::vector<double > *""'");
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_rend__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_rend" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = ((std::vector<double > const *)arg1)->rend();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_rend(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_DoubleVector_rend__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_DoubleVector_rend__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_rend'.\n Possible C/C++ prototypes are:\n"" rend(std::vector<double > *)\n"" rend(std::vector<double > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_new_DoubleVector__SWIG_2(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::size_type arg1 ;
- size_t val1 ;
- int ecode1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "new_DoubleVector" "', argument " "1"" of type '" "std::vector<double >::size_type""'");
- arg1 = static_cast< std::vector<double >::size_type >(val1);
- result = (std::vector<double > *)new std::vector<double >(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_pop_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_pop_back",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_pop_back" "', argument " "1"" of type '" "std::vector<double > *""'");
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_resize__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::size_type arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_resize",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_resize" "', argument " "1"" of type '" "std::vector<double > *""'");
- ecode2 = SWIG_AsVal_size_t(obj1, &val2);
- if (!SWIG_IsOK(ecode2)) {
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_resize" "', argument " "2"" of type '" "std::vector<double >::size_type""'");
- arg2 = static_cast< std::vector<double >::size_type >(val2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_erase__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::iterator arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_erase",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_erase" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "DoubleVector_erase" "', argument " "2"" of type '" "std::vector<double >::iterator""'");
- } else {
- swig::PySwigIterator_T<std::vector<double >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::vector<double >::iterator > *>(iter2);
- if (iter_t) {
- } else {
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_erase__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::iterator arg3 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- int res3 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector_erase",&obj0,&obj1,&obj2)) SWIG_fail;
- } else {
- if (iter_t) {
- } else {
- SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "DoubleVector_erase" "', argument " "3"" of type '" "std::vector<double >::iterator""'");
- } else {
- swig::PySwigIterator_T<std::vector<double >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::vector<double >::iterator > *>(iter3);
- if (iter_t) {
- } else {
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_erase(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 2) {
- int _v;
- if (_v) {
- _v = (SWIG_IsOK(res) && iter && (dynamic_cast<swig::PySwigIterator_T<std::vector<double >::iterator > *>(iter) != 0));
- if (_v) {
- return _wrap_DoubleVector_erase__SWIG_0(self, args);
- if (argc == 3) {
- int _v;
- if (_v) {
- if (_v) {
- if (_v) {
- return _wrap_DoubleVector_erase__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_erase'.\n Possible C/C++ prototypes are:\n"" erase(std::vector<double > *,std::vector<double >::iterator)\n"" erase(std::vector<double > *,std::vector<double >::iterator,std::vector<double >::iterator)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_new_DoubleVector__SWIG_3(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- size_t val1 ;
- int ecode1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:new_DoubleVector",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "new_DoubleVector" "', argument " "2"" of type '" "std::vector<double >::value_type""'");
- arg2 = &temp2;
- result = (std::vector<double > *)new std::vector<double >(arg1,(std::vector<double >::value_type const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_DoubleVector(PyObject *self, PyObject *args) {
- int argc;
- PyObject *argv[3];
- int ii;
- for (ii = 0; (ii < argc) && (ii < 2); ii++) {
- if (argc == 0) {
- return _wrap_new_DoubleVector__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_new_DoubleVector__SWIG_2(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_new_DoubleVector__SWIG_1(self, args);
- if (argc == 2) {
- int _v;
- if (_v) {
- int res = SWIG_AsVal_double(argv[1], NULL);
- if (_v) {
- return _wrap_new_DoubleVector__SWIG_3(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'new_DoubleVector'.\n Possible C/C++ prototypes are:\n"" std::vector<(double)>()\n"" std::vector<(double)>(std::vector<double > const &)\n"" std::vector<(double)>(std::vector<double >::size_type)\n"" std::vector<(double)>(std::vector<double >::size_type,std::vector<double >::value_type const &)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_push_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_push_back",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_push_back" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_push_back" "', argument " "2"" of type '" "std::vector<double >::value_type""'");
- arg2 = &temp2;
- (arg1)->push_back((std::vector<double >::value_type const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_front(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_front",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_front" "', argument " "1"" of type '" "std::vector<double > const *""'");
- std::vector<double >::value_type const &_result_ref = ((std::vector<double > const *)arg1)->front();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_back(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_back",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_back" "', argument " "1"" of type '" "std::vector<double > const *""'");
- std::vector<double >::value_type const &_result_ref = ((std::vector<double > const *)arg1)->back();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_assign(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector_assign",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_assign" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_assign" "', argument " "2"" of type '" "std::vector<double >::size_type""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector_assign" "', argument " "3"" of type '" "std::vector<double >::value_type""'");
- arg3 = &temp3;
- (arg1)->assign(arg2,(std::vector<double >::value_type const &)*arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_resize__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- PyObject * obj2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector_resize",&obj0,&obj1,&obj2)) SWIG_fail;
- if (!SWIG_IsOK(ecode3)) {
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector_resize" "', argument " "3"" of type '" "std::vector<double >::value_type""'");
- arg3 = &temp3;
- (arg1)->resize(arg2,(std::vector<double >::value_type const &)*arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_resize(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 2) {
- int _v;
- if (_v) {
- int res = SWIG_AsVal_size_t(argv[1], NULL);
- if (_v) {
- return _wrap_DoubleVector_resize__SWIG_0(self, args);
- if (argc == 3) {
- int _v;
- if (_v) {
- if (_v) {
- int res = SWIG_AsVal_double(argv[2], NULL);
- if (_v) {
- return _wrap_DoubleVector_resize__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_resize'.\n Possible C/C++ prototypes are:\n"" resize(std::vector<double > *,std::vector<double >::size_type)\n"" resize(std::vector<double > *,std::vector<double >::size_type,std::vector<double >::value_type const &)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_insert__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- double val3 ;
- int ecode3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:DoubleVector_insert",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_insert" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "DoubleVector_insert" "', argument " "2"" of type '" "std::vector<double >::iterator""'");
- } else {
- if (iter_t) {
- } else {
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector_insert" "', argument " "3"" of type '" "std::vector<double >::value_type""'");
- arg3 = &temp3;
- result = (arg1)->insert(arg2,(std::vector<double >::value_type const &)*arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_insert__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<double >::size_type arg3 ;
- std::vector<double >::value_type *arg4 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- size_t val3 ;
- int ecode3 = 0 ;
- std::vector<double >::value_type temp4 ;
- double val4 ;
- int ecode4 = 0 ;
- PyObject * obj3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOO:DoubleVector_insert",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
- } else {
- if (iter_t) {
- } else {
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DoubleVector_insert" "', argument " "3"" of type '" "std::vector<double >::size_type""'");
- arg3 = static_cast< std::vector<double >::size_type >(val3);
- ecode4 = SWIG_AsVal_double(obj3, &val4);
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DoubleVector_insert" "', argument " "4"" of type '" "std::vector<double >::value_type""'");
- temp4 = static_cast< std::vector<double >::value_type >(val4);
- arg4 = &temp4;
- (arg1)->insert(arg2,arg3,(std::vector<double >::value_type const &)*arg4);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_insert(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 3) {
- int _v;
- if (_v) {
- if (_v) {
- if (_v) {
- return _wrap_DoubleVector_insert__SWIG_0(self, args);
- if (argc == 4) {
- int _v;
- if (_v) {
- if (_v) {
- if (_v) {
- int res = SWIG_AsVal_double(argv[3], NULL);
- if (_v) {
- return _wrap_DoubleVector_insert__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'DoubleVector_insert'.\n Possible C/C++ prototypes are:\n"" insert(std::vector<double > *,std::vector<double >::iterator,std::vector<double >::value_type const &)\n"" insert(std::vector<double > *,std::vector<double >::iterator,std::vector<double >::size_type,std::vector<double >::value_type const &)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_reserve(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DoubleVector_reserve",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_reserve" "', argument " "1"" of type '" "std::vector<double > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DoubleVector_reserve" "', argument " "2"" of type '" "std::vector<double >::size_type""'");
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DoubleVector_capacity(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DoubleVector_capacity",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DoubleVector_capacity" "', argument " "1"" of type '" "std::vector<double > const *""'");
- result = ((std::vector<double > const *)arg1)->capacity();
- resultobj = SWIG_From_size_t(static_cast< size_t >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_delete_DoubleVector(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:delete_DoubleVector",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_DoubleVector" "', argument " "1"" of type '" "std::vector<double > *""'");
- delete arg1;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *DoubleVector_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- if (!PyArg_ParseTuple(args,(char*)"O|swigregister", &obj)) return NULL;
- SWIG_TypeNewClientData(SWIGTYPE_p_std__vectorTdouble_std__allocatorTdouble_t_t, SWIG_NewClientData(obj));
- return SWIG_Py_Void();
-SWIGINTERN PyObject *_wrap_new_IntVecIntMap__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::less<int > *arg1 = 0 ;
- std::map<int,std::vector<int > > *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:new_IntVecIntMap",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1, SWIGTYPE_p_std__lessTint_t, 0 | 0);
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_IntVecIntMap" "', argument " "1"" of type '" "std::less<int > const &""'");
- if (!argp1) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "new_IntVecIntMap" "', argument " "1"" of type '" "std::less<int > const &""'");
- arg1 = reinterpret_cast< std::less<int > * >(argp1);
- result = (std::map<int,std::vector<int > > *)new std::map<int,std::vector<int > >((std::less<int > const &)*arg1);
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, SWIG_POINTER_NEW | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > > *arg1 = (std::map<int,std::vector<int > > *) 0 ;
- PyObject **arg2 = (PyObject **) 0 ;
- swig::PySwigIterator *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- arg2 = &obj0;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_iterator",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_iterator" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- arg1 = reinterpret_cast< std::map<int,std::vector<int > > * >(argp1);
- result = (swig::PySwigIterator *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__iterator(arg1,arg2);
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__PySwigIterator, SWIG_POINTER_OWN | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap___nonzero__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap___nonzero__",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___nonzero__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- result = (bool)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____nonzero__((std::map<int,std::vector<int > > const *)arg1);
- resultobj = SWIG_From_bool(static_cast< bool >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap___len__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > >::size_type result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap___len__",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___len__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- result = std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____len__((std::map<int,std::vector<int > > const *)arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap___getitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > >::key_type *arg2 = 0 ;
- std::map<int,std::vector<int > >::mapped_type result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- std::map<int,std::vector<int > >::key_type temp2 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap___getitem__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___getitem__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- ecode2 = SWIG_AsVal_int(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap___getitem__" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- temp2 = static_cast< std::map<int,std::vector<int > >::key_type >(val2);
- arg2 = &temp2;
- try {
- result = std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____getitem__((std::map<int,std::vector<int > > const *)arg1,(int const &)*arg2);
- catch(std::out_of_range &_e) {
- SWIG_exception_fail(SWIG_IndexError, (&_e)->what());
- resultobj = swig::from(static_cast< std::vector<int,std::allocator<int > > >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap___delitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap___delitem__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___delitem__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap___delitem__" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- arg2 = &temp2;
- try {
- std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____delitem__(arg1,(int const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_has_key(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_has_key",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_has_key" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_has_key" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- arg2 = &temp2;
- result = (bool)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__has_key((std::map<int,std::vector<int > > const *)arg1,(int const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_keys(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_keys",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_keys" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- result = (PyObject *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__keys(arg1);
- resultobj = result;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_values(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_values",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_values" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- result = (PyObject *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__values(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_items(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_items",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_items" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- result = (PyObject *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__items(arg1);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap___contains__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap___contains__",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___contains__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap___contains__" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- arg2 = &temp2;
- result = (bool)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____contains__(arg1,(int const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_key_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- arg2 = &obj0;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_key_iterator",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_key_iterator" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- result = (swig::PySwigIterator *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__key_iterator(arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_value_iterator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- arg2 = &obj0;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_value_iterator",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_value_iterator" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- result = (swig::PySwigIterator *)std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg__value_iterator(arg1,arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap___setitem__(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > >::mapped_type *arg3 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- int res3 = SWIG_OLDOBJ ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:IntVecIntMap___setitem__",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap___setitem__" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap___setitem__" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- arg2 = &temp2;
- std::vector<int,std::allocator<int > > *ptr = (std::vector<int,std::allocator<int > > *)0;
- res3 = swig::asptr(obj2, &ptr);
- if (!SWIG_IsOK(res3)) {
- SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "IntVecIntMap___setitem__" "', argument " "3"" of type '" "std::map<int,std::vector<int > >::mapped_type const &""'");
- if (!ptr) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "IntVecIntMap___setitem__" "', argument " "3"" of type '" "std::map<int,std::vector<int > >::mapped_type const &""'");
- arg3 = ptr;
- try {
- std_map_Sl_int_Sc_std_vector_Sl_int_Sg__Sg____setitem__(arg1,(int const &)*arg2,(std::vector<int,std::allocator<int > > const &)*arg3);
- if (SWIG_IsNewObj(res3)) delete arg3;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_IntVecIntMap__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- if (!PyArg_ParseTuple(args,(char *)":new_IntVecIntMap")) SWIG_fail;
- result = (std::map<int,std::vector<int > > *)new std::map<int,std::vector<int > >();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_IntVecIntMap__SWIG_2(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int,std::allocator<int > > > *arg1 = 0 ;
- int res1 = SWIG_OLDOBJ ;
- std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > *ptr = (std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > *)0;
- res1 = swig::asptr(obj0, &ptr);
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_IntVecIntMap" "', argument " "1"" of type '" "std::map<int,std::vector<int,std::allocator<int > > > const &""'");
- if (!ptr) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "new_IntVecIntMap" "', argument " "1"" of type '" "std::map<int,std::vector<int,std::allocator<int > > > const &""'");
- arg1 = ptr;
- result = (std::map<int,std::vector<int > > *)new std::map<int,std::vector<int > >((std::map<int,std::vector<int,std::allocator<int > > > const &)*arg1);
- if (SWIG_IsNewObj(res1)) delete arg1;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_IntVecIntMap(PyObject *self, PyObject *args) {
- int argc;
- PyObject *argv[2];
- int ii;
- for (ii = 0; (ii < argc) && (ii < 1); ii++) {
- if (argc == 0) {
- return _wrap_new_IntVecIntMap__SWIG_1(self, args);
- if (argc == 1) {
- int _v;
- int res = SWIG_ConvertPtr(argv[0], 0, SWIGTYPE_p_std__lessTint_t, 0);
- if (_v) {
- return _wrap_new_IntVecIntMap__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- int res = swig::asptr(argv[0], (std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > >**)(0));
- if (_v) {
- return _wrap_new_IntVecIntMap__SWIG_2(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'new_IntVecIntMap'.\n Possible C/C++ prototypes are:\n"" std::map<(int,std::vector<(int)>)>(std::less<int > const &)\n"" std::map<(int,std::vector<(int)>)>()\n"" std::map<(int,std::vector<(int)>)>(std::map<int,std::vector<int,std::allocator<int > > > const &)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_empty(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_empty",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_empty" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- result = (bool)((std::map<int,std::vector<int > > const *)arg1)->empty();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_size(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_size",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_size" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- result = ((std::map<int,std::vector<int > > const *)arg1)->size();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_clear(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_clear",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_clear" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- (arg1)->clear();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_swap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int,std::allocator<int > > > *arg2 = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_swap",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_swap" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, 0 );
- if (!SWIG_IsOK(res2)) {
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "IntVecIntMap_swap" "', argument " "2"" of type '" "std::map<int,std::vector<int,std::allocator<int > > > &""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "IntVecIntMap_swap" "', argument " "2"" of type '" "std::map<int,std::vector<int,std::allocator<int > > > &""'");
- arg2 = reinterpret_cast< std::map<int,std::vector<int,std::allocator<int > > > * >(argp2);
- (arg1)->swap(*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_get_allocator(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- SwigValueWrapper< std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_get_allocator",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_get_allocator" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- result = ((std::map<int,std::vector<int > > const *)arg1)->get_allocator();
- resultobj = SWIG_NewPointerObj((new std::map<int,std::vector<int > >::allocator_type(static_cast< const std::map<int,std::vector<int > >::allocator_type& >(result))), SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type, SWIG_POINTER_OWN | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_begin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > >::iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_begin",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_begin" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- result = (arg1)->begin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::map<int,std::vector<int > >::iterator & >(result)),
- swig::PySwigIterator::descriptor(),SWIG_POINTER_OWN);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_begin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > >::const_iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_begin" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- result = ((std::map<int,std::vector<int > > const *)arg1)->begin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::map<int,std::vector<int > >::const_iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_begin(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVecIntMap_begin__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVecIntMap_begin__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_begin'.\n Possible C/C++ prototypes are:\n"" begin(std::map<int,std::vector<int > > *)\n"" begin(std::map<int,std::vector<int > > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_end__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_end",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_end" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- result = (arg1)->end();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_end__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_end" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- result = ((std::map<int,std::vector<int > > const *)arg1)->end();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_end(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVecIntMap_end__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVecIntMap_end__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_end'.\n Possible C/C++ prototypes are:\n"" end(std::map<int,std::vector<int > > *)\n"" end(std::map<int,std::vector<int > > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_rbegin__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > >::reverse_iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_rbegin",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_rbegin" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- result = (arg1)->rbegin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::map<int,std::vector<int > >::reverse_iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_rbegin__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > >::const_reverse_iterator result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_rbegin" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- result = ((std::map<int,std::vector<int > > const *)arg1)->rbegin();
- resultobj = SWIG_NewPointerObj(swig::make_output_iterator(static_cast< const std::map<int,std::vector<int > >::const_reverse_iterator & >(result)),
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_rbegin(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVecIntMap_rbegin__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVecIntMap_rbegin__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_rbegin'.\n Possible C/C++ prototypes are:\n"" rbegin(std::map<int,std::vector<int > > *)\n"" rbegin(std::map<int,std::vector<int > > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_rend__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:IntVecIntMap_rend",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_rend" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- result = (arg1)->rend();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_rend__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_rend" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- result = ((std::map<int,std::vector<int > > const *)arg1)->rend();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_rend(PyObject *self, PyObject *args) {
- int argc;
- int ii;
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVecIntMap_rend__SWIG_0(self, args);
- if (argc == 1) {
- int _v;
- if (_v) {
- return _wrap_IntVecIntMap_rend__SWIG_1(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_rend'.\n Possible C/C++ prototypes are:\n"" rend(std::map<int,std::vector<int > > *)\n"" rend(std::map<int,std::vector<int > > const *)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_erase__SWIG_0(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_erase",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_erase" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_erase" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- arg2 = &temp2;
- result = (arg1)->erase((std::map<int,std::vector<int > >::key_type const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_count(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_count",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_count" "', argument " "1"" of type '" "std::map<int,std::vector<int > > const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_count" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- arg2 = &temp2;
- result = ((std::map<int,std::vector<int > > const *)arg1)->count((std::map<int,std::vector<int > >::key_type const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_erase__SWIG_1(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > >::iterator arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- swig::PySwigIterator *iter2 = 0 ;
- int res2 ;
- res2 = SWIG_ConvertPtr(obj1, SWIG_as_voidptrptr(&iter2), swig::PySwigIterator::descriptor(), 0);
- if (!SWIG_IsOK(res2) || !iter2) {
- SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVecIntMap_erase" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::iterator""'");
- } else {
- swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *>(iter2);
- if (iter_t) {
- arg2 = iter_t->get_current();
- } else {
- (arg1)->erase(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_erase__SWIG_2(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::map<int,std::vector<int > >::iterator arg3 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- swig::PySwigIterator *iter3 = 0 ;
- int res3 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:IntVecIntMap_erase",&obj0,&obj1,&obj2)) SWIG_fail;
- } else {
- if (iter_t) {
- } else {
- res3 = SWIG_ConvertPtr(obj2, SWIG_as_voidptrptr(&iter3), swig::PySwigIterator::descriptor(), 0);
- if (!SWIG_IsOK(res3) || !iter3) {
- SWIG_exception_fail(SWIG_ArgError(SWIG_TypeError), "in method '" "IntVecIntMap_erase" "', argument " "3"" of type '" "std::map<int,std::vector<int > >::iterator""'");
- } else {
- swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *iter_t = dynamic_cast<swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *>(iter3);
- if (iter_t) {
- arg3 = iter_t->get_current();
- } else {
- (arg1)->erase(arg2,arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_erase(PyObject *self, PyObject *args) {
- int argc;
- PyObject *argv[4];
- int ii;
- for (ii = 0; (ii < argc) && (ii < 3); ii++) {
- if (argc == 2) {
- int _v;
- if (_v) {
- swig::PySwigIterator *iter = 0;
- int res = SWIG_ConvertPtr(argv[1], SWIG_as_voidptrptr(&iter), swig::PySwigIterator::descriptor(), 0);
- _v = (SWIG_IsOK(res) && iter && (dynamic_cast<swig::PySwigIterator_T<std::map<int,std::vector<int > >::iterator > *>(iter) != 0));
- if (_v) {
- return _wrap_IntVecIntMap_erase__SWIG_1(self, args);
- if (argc == 2) {
- int _v;
- if (_v) {
- int res = SWIG_AsVal_int(argv[1], NULL);
- if (_v) {
- return _wrap_IntVecIntMap_erase__SWIG_0(self, args);
- if (argc == 3) {
- int _v;
- if (_v) {
- if (_v) {
- int res = SWIG_ConvertPtr(argv[2], SWIG_as_voidptrptr(&iter), swig::PySwigIterator::descriptor(), 0);
- if (_v) {
- return _wrap_IntVecIntMap_erase__SWIG_2(self, args);
-fail:
- SWIG_SetErrorMsg(PyExc_NotImplementedError,"Wrong number of arguments for overloaded function 'IntVecIntMap_erase'.\n Possible C/C++ prototypes are:\n"" erase(std::map<int,std::vector<int > > *,std::map<int,std::vector<int > >::key_type const &)\n"" erase(std::map<int,std::vector<int > > *,std::map<int,std::vector<int > >::iterator)\n"" erase(std::map<int,std::vector<int > > *,std::map<int,std::vector<int > >::iterator,std::map<int,std::vector<int > >::iterator)\n");
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_find(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_find",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_find" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_find" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- arg2 = &temp2;
- result = (arg1)->find((std::map<int,std::vector<int > >::key_type const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_lower_bound(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_lower_bound",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_lower_bound" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_lower_bound" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- arg2 = &temp2;
- result = (arg1)->lower_bound((std::map<int,std::vector<int > >::key_type const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_IntVecIntMap_upper_bound(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:IntVecIntMap_upper_bound",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "IntVecIntMap_upper_bound" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "IntVecIntMap_upper_bound" "', argument " "2"" of type '" "std::map<int,std::vector<int > >::key_type""'");
- arg2 = &temp2;
- result = (arg1)->upper_bound((std::map<int,std::vector<int > >::key_type const &)*arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_delete_IntVecIntMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:delete_IntVecIntMap",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_IntVecIntMap" "', argument " "1"" of type '" "std::map<int,std::vector<int > > *""'");
- delete arg1;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *IntVecIntMap_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_new_DisplayDriver(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *arg1 = (void *) 0 ;
- DisplayDriver *result = 0 ;
- int res1 ;
- if (!PyArg_ParseTuple(args,(char *)"O:new_DisplayDriver",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0,SWIG_as_voidptrptr(&arg1), 0, 0);
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_DisplayDriver" "', argument " "1"" of type '" "void *""'");
- result = (DisplayDriver *)new DisplayDriver(arg1);
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_DisplayDriver, SWIG_POINTER_NEW | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_delete_DisplayDriver(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- DisplayDriver *arg1 = (DisplayDriver *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:delete_DisplayDriver",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_DisplayDriver, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_DisplayDriver" "', argument " "1"" of type '" "DisplayDriver *""'");
- arg1 = reinterpret_cast< DisplayDriver * >(argp1);
- delete arg1;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_DrawMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool arg2 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- bool val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DisplayDriver_DrawMap",&obj0,&obj1)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_DisplayDriver, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_DrawMap" "', argument " "1"" of type '" "DisplayDriver *""'");
- ecode2 = SWIG_AsVal_bool(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_DrawMap" "', argument " "2"" of type '" "bool""'");
- arg2 = static_cast< bool >(val2);
- result = (int)(arg1)->DrawMap(arg2);
- resultobj = SWIG_From_int(static_cast< int >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_SelectLinesByBox(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- double arg3 ;
- double arg4 ;
- double arg5 ;
- double arg6 ;
- double arg7 ;
- int arg8 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- double val5 ;
- int ecode5 = 0 ;
- double val6 ;
- int ecode6 = 0 ;
- double val7 ;
- int ecode7 = 0 ;
- int val8 ;
- int ecode8 = 0 ;
- PyObject * obj4 = 0 ;
- PyObject * obj5 = 0 ;
- PyObject * obj6 = 0 ;
- PyObject * obj7 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOOOO:DisplayDriver_SelectLinesByBox",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7)) SWIG_fail;
- if (!SWIG_IsOK(res1)) {
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "1"" of type '" "DisplayDriver *""'");
- ecode2 = SWIG_AsVal_double(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "2"" of type '" "double""'");
- arg2 = static_cast< double >(val2);
- ecode3 = SWIG_AsVal_double(obj2, &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "3"" of type '" "double""'");
- arg3 = static_cast< double >(val3);
- if (!SWIG_IsOK(ecode4)) {
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "4"" of type '" "double""'");
- arg4 = static_cast< double >(val4);
- ecode5 = SWIG_AsVal_double(obj4, &val5);
- if (!SWIG_IsOK(ecode5)) {
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "5"" of type '" "double""'");
- arg5 = static_cast< double >(val5);
- ecode6 = SWIG_AsVal_double(obj5, &val6);
- if (!SWIG_IsOK(ecode6)) {
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "6"" of type '" "double""'");
- arg6 = static_cast< double >(val6);
- ecode7 = SWIG_AsVal_double(obj6, &val7);
- if (!SWIG_IsOK(ecode7)) {
- SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "7"" of type '" "double""'");
- arg7 = static_cast< double >(val7);
- ecode8 = SWIG_AsVal_int(obj7, &val8);
- if (!SWIG_IsOK(ecode8)) {
- SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "DisplayDriver_SelectLinesByBox" "', argument " "8"" of type '" "int""'");
- arg8 = static_cast< int >(val8);
- result = (int)(arg1)->SelectLinesByBox(arg2,arg3,arg4,arg5,arg6,arg7,arg8);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_SelectLineByPoint(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *resultobj = 0;
- double arg2 ;
- double arg3 ;
- double arg4 ;
- double arg5 ;
- int arg6 ;
- int arg7 ;
- std::vector<double,std::allocator<double > > result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- double val5 ;
- int ecode5 = 0 ;
- int val6 ;
- int ecode6 = 0 ;
- int val7 ;
- int ecode7 = 0 ;
- PyObject * obj0 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOOO:DisplayDriver_SelectLineByPoint",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "1"" of type '" "DisplayDriver *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "2"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "3"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "4"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "5"" of type '" "double""'");
- ecode6 = SWIG_AsVal_int(obj5, &val6);
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "6"" of type '" "int""'");
- arg6 = static_cast< int >(val6);
- ecode7 = SWIG_AsVal_int(obj6, &val7);
- SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "DisplayDriver_SelectLineByPoint" "', argument " "7"" of type '" "int""'");
- arg7 = static_cast< int >(val7);
- result = (arg1)->SelectLineByPoint(arg2,arg3,arg4,arg5,arg6,arg7);
- resultobj = swig::from(static_cast< std::vector<double,std::allocator<double > > >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_GetSelected(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool arg2 ;
- std::vector<int,std::allocator<int > > result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- bool val2 ;
- int ecode2 = 0 ;
- PyObject * obj1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DisplayDriver_GetSelected",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_GetSelected" "', argument " "1"" of type '" "DisplayDriver *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_GetSelected" "', argument " "2"" of type '" "bool""'");
- result = (arg1)->GetSelected(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_SetSelected(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- std::vector<int,std::allocator<int > > arg2 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DisplayDriver_SetSelected",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SetSelected" "', argument " "1"" of type '" "DisplayDriver *""'");
- int res = swig::asptr(obj1, &ptr);
- if (!SWIG_IsOK(res) || !ptr) {
- SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "DisplayDriver_SetSelected" "', argument " "2"" of type '" "std::vector<int,std::allocator<int > >""'");
- arg2 = *ptr;
- if (SWIG_IsNewObj(res)) delete ptr;
- result = (int)(arg1)->SetSelected(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_GetSelectedVertex(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- double arg3 ;
- double arg4 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOO:DisplayDriver_GetSelectedVertex",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_GetSelectedVertex" "', argument " "1"" of type '" "DisplayDriver *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_GetSelectedVertex" "', argument " "2"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_GetSelectedVertex" "', argument " "3"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_GetSelectedVertex" "', argument " "4"" of type '" "double""'");
- result = (arg1)->GetSelectedVertex(arg2,arg3,arg4);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_CloseMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DisplayDriver_CloseMap",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_CloseMap" "', argument " "1"" of type '" "DisplayDriver *""'");
- result = (int)(arg1)->CloseMap();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_OpenMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- char *arg2 = (char *) 0 ;
- char *arg3 = (char *) 0 ;
- bool arg4 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- char *buf2 = 0 ;
- int alloc2 = 0 ;
- int res3 ;
- char *buf3 = 0 ;
- int alloc3 = 0 ;
- bool val4 ;
- int ecode4 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOO:DisplayDriver_OpenMap",&obj0,&obj1,&obj2,&obj3)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_OpenMap" "', argument " "1"" of type '" "DisplayDriver *""'");
- res2 = SWIG_AsCharPtrAndSize(obj1, &buf2, NULL, &alloc2);
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "DisplayDriver_OpenMap" "', argument " "2"" of type '" "char const *""'");
- arg2 = reinterpret_cast< char * >(buf2);
- res3 = SWIG_AsCharPtrAndSize(obj2, &buf3, NULL, &alloc3);
- SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "DisplayDriver_OpenMap" "', argument " "3"" of type '" "char const *""'");
- arg3 = reinterpret_cast< char * >(buf3);
- ecode4 = SWIG_AsVal_bool(obj3, &val4);
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_OpenMap" "', argument " "4"" of type '" "bool""'");
- arg4 = static_cast< bool >(val4);
- result = (int)(arg1)->OpenMap((char const *)arg2,(char const *)arg3,arg4);
- if (alloc2 == SWIG_NEWOBJ) delete[] buf2;
- if (alloc3 == SWIG_NEWOBJ) delete[] buf3;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_ReloadMap(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DisplayDriver_ReloadMap",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_ReloadMap" "', argument " "1"" of type '" "DisplayDriver *""'");
- (arg1)->ReloadMap();
- resultobj = SWIG_Py_Void();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_SetDevice(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *arg2 = (void *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:DisplayDriver_SetDevice",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SetDevice" "', argument " "1"" of type '" "DisplayDriver *""'");
- res2 = SWIG_ConvertPtr(obj1,SWIG_as_voidptrptr(&arg2), 0, 0);
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "DisplayDriver_SetDevice" "', argument " "2"" of type '" "void *""'");
- (arg1)->SetDevice(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_GetMapBoundingBox(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:DisplayDriver_GetMapBoundingBox",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_GetMapBoundingBox" "', argument " "1"" of type '" "DisplayDriver *""'");
- result = (arg1)->GetMapBoundingBox();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_SetRegion(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- double arg3 ;
- double arg4 ;
- double arg5 ;
- double arg6 ;
- double arg7 ;
- double arg8 ;
- double arg9 ;
- double arg10 ;
- double arg11 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- double val5 ;
- int ecode5 = 0 ;
- double val6 ;
- int ecode6 = 0 ;
- double val7 ;
- int ecode7 = 0 ;
- double val8 ;
- int ecode8 = 0 ;
- double val9 ;
- int ecode9 = 0 ;
- double val10 ;
- int ecode10 = 0 ;
- double val11 ;
- int ecode11 = 0 ;
- PyObject * obj8 = 0 ;
- PyObject * obj9 = 0 ;
- PyObject * obj10 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOOOO:DisplayDriver_SetRegion",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8,&obj9,&obj10)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_SetRegion" "', argument " "1"" of type '" "DisplayDriver *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_SetRegion" "', argument " "2"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_SetRegion" "', argument " "3"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_SetRegion" "', argument " "4"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "DisplayDriver_SetRegion" "', argument " "5"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "DisplayDriver_SetRegion" "', argument " "6"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "DisplayDriver_SetRegion" "', argument " "7"" of type '" "double""'");
- ecode8 = SWIG_AsVal_double(obj7, &val8);
- SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "DisplayDriver_SetRegion" "', argument " "8"" of type '" "double""'");
- arg8 = static_cast< double >(val8);
- ecode9 = SWIG_AsVal_double(obj8, &val9);
- if (!SWIG_IsOK(ecode9)) {
- SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "DisplayDriver_SetRegion" "', argument " "9"" of type '" "double""'");
- arg9 = static_cast< double >(val9);
- ecode10 = SWIG_AsVal_double(obj9, &val10);
- if (!SWIG_IsOK(ecode10)) {
- SWIG_exception_fail(SWIG_ArgError(ecode10), "in method '" "DisplayDriver_SetRegion" "', argument " "10"" of type '" "double""'");
- arg10 = static_cast< double >(val10);
- ecode11 = SWIG_AsVal_double(obj10, &val11);
- if (!SWIG_IsOK(ecode11)) {
- SWIG_exception_fail(SWIG_ArgError(ecode11), "in method '" "DisplayDriver_SetRegion" "', argument " "11"" of type '" "double""'");
- arg11 = static_cast< double >(val11);
- (arg1)->SetRegion(arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10,arg11);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_DisplayDriver_UpdateSettings(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- unsigned long arg2 ;
- bool arg3 ;
- unsigned long arg4 ;
- bool arg5 ;
- unsigned long arg6 ;
- bool arg7 ;
- unsigned long arg8 ;
- bool arg9 ;
- unsigned long arg10 ;
- bool arg11 ;
- unsigned long arg12 ;
- bool arg13 ;
- unsigned long arg14 ;
- bool arg15 ;
- unsigned long arg16 ;
- bool arg17 ;
- unsigned long arg18 ;
- bool arg19 ;
- unsigned long arg20 ;
- bool arg21 ;
- unsigned long arg22 ;
- bool arg23 ;
- unsigned long arg24 ;
- int arg25 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- unsigned long val2 ;
- int ecode2 = 0 ;
- bool val3 ;
- int ecode3 = 0 ;
- unsigned long val4 ;
- int ecode4 = 0 ;
- bool val5 ;
- int ecode5 = 0 ;
- unsigned long val6 ;
- int ecode6 = 0 ;
- bool val7 ;
- int ecode7 = 0 ;
- unsigned long val8 ;
- int ecode8 = 0 ;
- bool val9 ;
- int ecode9 = 0 ;
- unsigned long val10 ;
- int ecode10 = 0 ;
- bool val11 ;
- int ecode11 = 0 ;
- unsigned long val12 ;
- int ecode12 = 0 ;
- bool val13 ;
- int ecode13 = 0 ;
- unsigned long val14 ;
- int ecode14 = 0 ;
- bool val15 ;
- int ecode15 = 0 ;
- unsigned long val16 ;
- int ecode16 = 0 ;
- bool val17 ;
- int ecode17 = 0 ;
- unsigned long val18 ;
- int ecode18 = 0 ;
- bool val19 ;
- int ecode19 = 0 ;
- unsigned long val20 ;
- int ecode20 = 0 ;
- bool val21 ;
- int ecode21 = 0 ;
- unsigned long val22 ;
- int ecode22 = 0 ;
- bool val23 ;
- int ecode23 = 0 ;
- unsigned long val24 ;
- int ecode24 = 0 ;
- int val25 ;
- int ecode25 = 0 ;
- PyObject * obj11 = 0 ;
- PyObject * obj12 = 0 ;
- PyObject * obj13 = 0 ;
- PyObject * obj14 = 0 ;
- PyObject * obj15 = 0 ;
- PyObject * obj16 = 0 ;
- PyObject * obj17 = 0 ;
- PyObject * obj18 = 0 ;
- PyObject * obj19 = 0 ;
- PyObject * obj20 = 0 ;
- PyObject * obj21 = 0 ;
- PyObject * obj22 = 0 ;
- PyObject * obj23 = 0 ;
- PyObject * obj24 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOOOOOOOOOOOOOOOOOO:DisplayDriver_UpdateSettings",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8,&obj9,&obj10,&obj11,&obj12,&obj13,&obj14,&obj15,&obj16,&obj17,&obj18,&obj19,&obj20,&obj21,&obj22,&obj23,&obj24)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "DisplayDriver_UpdateSettings" "', argument " "1"" of type '" "DisplayDriver *""'");
- ecode2 = SWIG_AsVal_unsigned_SS_long(obj1, &val2);
- if (!SWIG_IsOK(ecode2)) {
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "DisplayDriver_UpdateSettings" "', argument " "2"" of type '" "unsigned long""'");
- arg2 = static_cast< unsigned long >(val2);
- ecode3 = SWIG_AsVal_bool(obj2, &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "DisplayDriver_UpdateSettings" "', argument " "3"" of type '" "bool""'");
- arg3 = static_cast< bool >(val3);
- ecode4 = SWIG_AsVal_unsigned_SS_long(obj3, &val4);
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "DisplayDriver_UpdateSettings" "', argument " "4"" of type '" "unsigned long""'");
- arg4 = static_cast< unsigned long >(val4);
- ecode5 = SWIG_AsVal_bool(obj4, &val5);
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "DisplayDriver_UpdateSettings" "', argument " "5"" of type '" "bool""'");
- arg5 = static_cast< bool >(val5);
- ecode6 = SWIG_AsVal_unsigned_SS_long(obj5, &val6);
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "DisplayDriver_UpdateSettings" "', argument " "6"" of type '" "unsigned long""'");
- arg6 = static_cast< unsigned long >(val6);
- ecode7 = SWIG_AsVal_bool(obj6, &val7);
- SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "DisplayDriver_UpdateSettings" "', argument " "7"" of type '" "bool""'");
- arg7 = static_cast< bool >(val7);
- ecode8 = SWIG_AsVal_unsigned_SS_long(obj7, &val8);
- SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "DisplayDriver_UpdateSettings" "', argument " "8"" of type '" "unsigned long""'");
- arg8 = static_cast< unsigned long >(val8);
- ecode9 = SWIG_AsVal_bool(obj8, &val9);
- SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "DisplayDriver_UpdateSettings" "', argument " "9"" of type '" "bool""'");
- arg9 = static_cast< bool >(val9);
- ecode10 = SWIG_AsVal_unsigned_SS_long(obj9, &val10);
- SWIG_exception_fail(SWIG_ArgError(ecode10), "in method '" "DisplayDriver_UpdateSettings" "', argument " "10"" of type '" "unsigned long""'");
- arg10 = static_cast< unsigned long >(val10);
- ecode11 = SWIG_AsVal_bool(obj10, &val11);
- SWIG_exception_fail(SWIG_ArgError(ecode11), "in method '" "DisplayDriver_UpdateSettings" "', argument " "11"" of type '" "bool""'");
- arg11 = static_cast< bool >(val11);
- ecode12 = SWIG_AsVal_unsigned_SS_long(obj11, &val12);
- if (!SWIG_IsOK(ecode12)) {
- SWIG_exception_fail(SWIG_ArgError(ecode12), "in method '" "DisplayDriver_UpdateSettings" "', argument " "12"" of type '" "unsigned long""'");
- arg12 = static_cast< unsigned long >(val12);
- ecode13 = SWIG_AsVal_bool(obj12, &val13);
- if (!SWIG_IsOK(ecode13)) {
- SWIG_exception_fail(SWIG_ArgError(ecode13), "in method '" "DisplayDriver_UpdateSettings" "', argument " "13"" of type '" "bool""'");
- arg13 = static_cast< bool >(val13);
- ecode14 = SWIG_AsVal_unsigned_SS_long(obj13, &val14);
- if (!SWIG_IsOK(ecode14)) {
- SWIG_exception_fail(SWIG_ArgError(ecode14), "in method '" "DisplayDriver_UpdateSettings" "', argument " "14"" of type '" "unsigned long""'");
- arg14 = static_cast< unsigned long >(val14);
- ecode15 = SWIG_AsVal_bool(obj14, &val15);
- if (!SWIG_IsOK(ecode15)) {
- SWIG_exception_fail(SWIG_ArgError(ecode15), "in method '" "DisplayDriver_UpdateSettings" "', argument " "15"" of type '" "bool""'");
- arg15 = static_cast< bool >(val15);
- ecode16 = SWIG_AsVal_unsigned_SS_long(obj15, &val16);
- if (!SWIG_IsOK(ecode16)) {
- SWIG_exception_fail(SWIG_ArgError(ecode16), "in method '" "DisplayDriver_UpdateSettings" "', argument " "16"" of type '" "unsigned long""'");
- arg16 = static_cast< unsigned long >(val16);
- ecode17 = SWIG_AsVal_bool(obj16, &val17);
- if (!SWIG_IsOK(ecode17)) {
- SWIG_exception_fail(SWIG_ArgError(ecode17), "in method '" "DisplayDriver_UpdateSettings" "', argument " "17"" of type '" "bool""'");
- arg17 = static_cast< bool >(val17);
- ecode18 = SWIG_AsVal_unsigned_SS_long(obj17, &val18);
- if (!SWIG_IsOK(ecode18)) {
- SWIG_exception_fail(SWIG_ArgError(ecode18), "in method '" "DisplayDriver_UpdateSettings" "', argument " "18"" of type '" "unsigned long""'");
- arg18 = static_cast< unsigned long >(val18);
- ecode19 = SWIG_AsVal_bool(obj18, &val19);
- if (!SWIG_IsOK(ecode19)) {
- SWIG_exception_fail(SWIG_ArgError(ecode19), "in method '" "DisplayDriver_UpdateSettings" "', argument " "19"" of type '" "bool""'");
- arg19 = static_cast< bool >(val19);
- ecode20 = SWIG_AsVal_unsigned_SS_long(obj19, &val20);
- if (!SWIG_IsOK(ecode20)) {
- SWIG_exception_fail(SWIG_ArgError(ecode20), "in method '" "DisplayDriver_UpdateSettings" "', argument " "20"" of type '" "unsigned long""'");
- arg20 = static_cast< unsigned long >(val20);
- ecode21 = SWIG_AsVal_bool(obj20, &val21);
- if (!SWIG_IsOK(ecode21)) {
- SWIG_exception_fail(SWIG_ArgError(ecode21), "in method '" "DisplayDriver_UpdateSettings" "', argument " "21"" of type '" "bool""'");
- arg21 = static_cast< bool >(val21);
- ecode22 = SWIG_AsVal_unsigned_SS_long(obj21, &val22);
- if (!SWIG_IsOK(ecode22)) {
- SWIG_exception_fail(SWIG_ArgError(ecode22), "in method '" "DisplayDriver_UpdateSettings" "', argument " "22"" of type '" "unsigned long""'");
- arg22 = static_cast< unsigned long >(val22);
- ecode23 = SWIG_AsVal_bool(obj22, &val23);
- if (!SWIG_IsOK(ecode23)) {
- SWIG_exception_fail(SWIG_ArgError(ecode23), "in method '" "DisplayDriver_UpdateSettings" "', argument " "23"" of type '" "bool""'");
- arg23 = static_cast< bool >(val23);
- ecode24 = SWIG_AsVal_unsigned_SS_long(obj23, &val24);
- if (!SWIG_IsOK(ecode24)) {
- SWIG_exception_fail(SWIG_ArgError(ecode24), "in method '" "DisplayDriver_UpdateSettings" "', argument " "24"" of type '" "unsigned long""'");
- arg24 = static_cast< unsigned long >(val24);
- ecode25 = SWIG_AsVal_int(obj24, &val25);
- if (!SWIG_IsOK(ecode25)) {
- SWIG_exception_fail(SWIG_ArgError(ecode25), "in method '" "DisplayDriver_UpdateSettings" "', argument " "25"" of type '" "int""'");
- arg25 = static_cast< int >(val25);
- (arg1)->UpdateSettings(arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10,arg11,arg12,arg13,arg14,arg15,arg16,arg17,arg18,arg19,arg20,arg21,arg22,arg23,arg24,arg25);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *DisplayDriver_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- SWIG_TypeNewClientData(SWIGTYPE_p_DisplayDriver, SWIG_NewClientData(obj));
-SWIGINTERN PyObject *_wrap_print_error(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- char *arg1 = (char *) 0 ;
- int arg2 ;
- int result;
- int res1 ;
- char *buf1 = 0 ;
- int alloc1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:print_error",&obj0,&obj1)) SWIG_fail;
- res1 = SWIG_AsCharPtrAndSize(obj0, &buf1, NULL, &alloc1);
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "print_error" "', argument " "1"" of type '" "char const *""'");
- arg1 = reinterpret_cast< char * >(buf1);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "print_error" "', argument " "2"" of type '" "int""'");
- arg2 = static_cast< int >(val2);
- result = (int)print_error((char const *)arg1,arg2);
- if (alloc1 == SWIG_NEWOBJ) delete[] buf1;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_new_Digit(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- Digit *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:new_Digit",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "new_Digit" "', argument " "1"" of type '" "DisplayDriver *""'");
- result = (Digit *)new Digit(arg1);
- resultobj = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_Digit, SWIG_POINTER_NEW | 0 );
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_InitCats(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- Digit *arg1 = (Digit *) 0 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:Digit_InitCats",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_Digit, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_InitCats" "', argument " "1"" of type '" "Digit *""'");
- arg1 = reinterpret_cast< Digit * >(argp1);
- result = (int)(arg1)->InitCats();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_AddLine(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int arg2 ;
- std::vector<double,std::allocator<double > > arg3 ;
- int arg4 ;
- int arg5 ;
- char *arg6 = (char *) 0 ;
- int arg7 ;
- double arg8 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- int val4 ;
- int ecode4 = 0 ;
- int val5 ;
- int ecode5 = 0 ;
- int res6 ;
- char *buf6 = 0 ;
- int alloc6 = 0 ;
- int val7 ;
- int ecode7 = 0 ;
- double val8 ;
- int ecode8 = 0 ;
- PyObject * obj2 = 0 ;
- PyObject * obj3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOOOO:Digit_AddLine",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_AddLine" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_AddLine" "', argument " "2"" of type '" "int""'");
- std::vector<double,std::allocator<double > > *ptr = (std::vector<double,std::allocator<double > > *)0;
- int res = swig::asptr(obj2, &ptr);
- SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_AddLine" "', argument " "3"" of type '" "std::vector<double,std::allocator<double > >""'");
- arg3 = *ptr;
- ecode4 = SWIG_AsVal_int(obj3, &val4);
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_AddLine" "', argument " "4"" of type '" "int""'");
- arg4 = static_cast< int >(val4);
- ecode5 = SWIG_AsVal_int(obj4, &val5);
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_AddLine" "', argument " "5"" of type '" "int""'");
- arg5 = static_cast< int >(val5);
- res6 = SWIG_AsCharPtrAndSize(obj5, &buf6, NULL, &alloc6);
- if (!SWIG_IsOK(res6)) {
- SWIG_exception_fail(SWIG_ArgError(res6), "in method '" "Digit_AddLine" "', argument " "6"" of type '" "char const *""'");
- arg6 = reinterpret_cast< char * >(buf6);
- SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_AddLine" "', argument " "7"" of type '" "int""'");
- SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "Digit_AddLine" "', argument " "8"" of type '" "double""'");
- result = (int)(arg1)->AddLine(arg2,arg3,arg4,arg5,(char const *)arg6,arg7,arg8);
- if (alloc6 == SWIG_NEWOBJ) delete[] buf6;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_RewriteLine(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int arg2 ;
- char *arg4 = (char *) 0 ;
- int arg5 ;
- double arg6 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- int res4 ;
- char *buf4 = 0 ;
- int alloc4 = 0 ;
- int val5 ;
- int ecode5 = 0 ;
- double val6 ;
- int ecode6 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOO:Digit_RewriteLine",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_RewriteLine" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_RewriteLine" "', argument " "2"" of type '" "int""'");
- SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_RewriteLine" "', argument " "3"" of type '" "std::vector<double,std::allocator<double > >""'");
- arg3 = *ptr;
- res4 = SWIG_AsCharPtrAndSize(obj3, &buf4, NULL, &alloc4);
- if (!SWIG_IsOK(res4)) {
- SWIG_exception_fail(SWIG_ArgError(res4), "in method '" "Digit_RewriteLine" "', argument " "4"" of type '" "char const *""'");
- arg4 = reinterpret_cast< char * >(buf4);
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_RewriteLine" "', argument " "5"" of type '" "int""'");
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_RewriteLine" "', argument " "6"" of type '" "double""'");
- result = (int)(arg1)->RewriteLine(arg2,arg3,(char const *)arg4,arg5,arg6);
- if (alloc4 == SWIG_NEWOBJ) delete[] buf4;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_SplitLine(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- double arg3 ;
- double arg4 ;
- double arg5 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- double val5 ;
- int ecode5 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOO:Digit_SplitLine",&obj0,&obj1,&obj2,&obj3,&obj4)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_SplitLine" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_SplitLine" "', argument " "2"" of type '" "double""'");
- if (!SWIG_IsOK(ecode3)) {
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_SplitLine" "', argument " "3"" of type '" "double""'");
- ecode4 = SWIG_AsVal_double(obj3, &val4);
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_SplitLine" "', argument " "4"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_SplitLine" "', argument " "5"" of type '" "double""'");
- result = (int)(arg1)->SplitLine(arg2,arg3,arg4,arg5);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_DeleteLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- bool arg2 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- bool val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:Digit_DeleteLines",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_DeleteLines" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_DeleteLines" "', argument " "2"" of type '" "bool""'");
- result = (int)(arg1)->DeleteLines(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_MoveLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- double arg3 ;
- double arg4 ;
- char *arg5 = (char *) 0 ;
- int arg6 ;
- double arg7 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- int res5 ;
- char *buf5 = 0 ;
- int alloc5 = 0 ;
- int val6 ;
- int ecode6 = 0 ;
- double val7 ;
- int ecode7 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOOO:Digit_MoveLines",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_MoveLines" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_MoveLines" "', argument " "2"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_MoveLines" "', argument " "3"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_MoveLines" "', argument " "4"" of type '" "double""'");
- res5 = SWIG_AsCharPtrAndSize(obj4, &buf5, NULL, &alloc5);
- if (!SWIG_IsOK(res5)) {
- SWIG_exception_fail(SWIG_ArgError(res5), "in method '" "Digit_MoveLines" "', argument " "5"" of type '" "char const *""'");
- arg5 = reinterpret_cast< char * >(buf5);
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_MoveLines" "', argument " "6"" of type '" "int""'");
- SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_MoveLines" "', argument " "7"" of type '" "double""'");
- result = (int)(arg1)->MoveLines(arg2,arg3,arg4,(char const *)arg5,arg6,arg7);
- if (alloc5 == SWIG_NEWOBJ) delete[] buf5;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_FlipLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:Digit_FlipLines",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_FlipLines" "', argument " "1"" of type '" "Digit *""'");
- result = (int)(arg1)->FlipLines();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_MergeLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:Digit_MergeLines",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_MergeLines" "', argument " "1"" of type '" "Digit *""'");
- result = (int)(arg1)->MergeLines();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_BreakLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:Digit_BreakLines",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_BreakLines" "', argument " "1"" of type '" "Digit *""'");
- result = (int)(arg1)->BreakLines();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_SnapLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:Digit_SnapLines",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_SnapLines" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_SnapLines" "', argument " "2"" of type '" "double""'");
- result = (int)(arg1)->SnapLines(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_ConnectLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:Digit_ConnectLines",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_ConnectLines" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_ConnectLines" "', argument " "2"" of type '" "double""'");
- result = (int)(arg1)->ConnectLines(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_TypeConvLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:Digit_TypeConvLines",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_TypeConvLines" "', argument " "1"" of type '" "Digit *""'");
- result = (int)(arg1)->TypeConvLines();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_ZBulkLabeling(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- double arg3 ;
- double arg4 ;
- double arg5 ;
- double arg6 ;
- double arg7 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- double val5 ;
- int ecode5 = 0 ;
- double val6 ;
- int ecode6 = 0 ;
- double val7 ;
- int ecode7 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOOO:Digit_ZBulkLabeling",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_ZBulkLabeling" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_ZBulkLabeling" "', argument " "2"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_ZBulkLabeling" "', argument " "3"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_ZBulkLabeling" "', argument " "4"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_ZBulkLabeling" "', argument " "5"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_ZBulkLabeling" "', argument " "6"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_ZBulkLabeling" "', argument " "7"" of type '" "double""'");
- result = (int)(arg1)->ZBulkLabeling(arg2,arg3,arg4,arg5,arg6,arg7);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_CopyLines(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res3 ;
- char *buf3 = 0 ;
- int alloc3 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:Digit_CopyLines",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_CopyLines" "', argument " "1"" of type '" "Digit *""'");
- std::vector<int,std::allocator<int > > *ptr = (std::vector<int,std::allocator<int > > *)0;
- SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_CopyLines" "', argument " "2"" of type '" "std::vector<int,std::allocator<int > >""'");
- arg2 = *ptr;
- if (!SWIG_IsOK(res3)) {
- SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "Digit_CopyLines" "', argument " "3"" of type '" "char const *""'");
- result = (int)(arg1)->CopyLines(arg2,(char const *)arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_MoveVertex(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- double arg3 ;
- double arg4 ;
- double arg5 ;
- double arg6 ;
- double arg7 ;
- char *arg8 = (char *) 0 ;
- int arg9 ;
- double arg10 ;
- double arg11 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- double val5 ;
- int ecode5 = 0 ;
- double val6 ;
- int ecode6 = 0 ;
- double val7 ;
- int ecode7 = 0 ;
- int res8 ;
- char *buf8 = 0 ;
- int alloc8 = 0 ;
- int val9 ;
- int ecode9 = 0 ;
- double val10 ;
- int ecode10 = 0 ;
- double val11 ;
- int ecode11 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOOOO:Digit_MoveVertex",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8,&obj9,&obj10)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_MoveVertex" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_MoveVertex" "', argument " "2"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_MoveVertex" "', argument " "3"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_MoveVertex" "', argument " "4"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_MoveVertex" "', argument " "5"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_MoveVertex" "', argument " "6"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_MoveVertex" "', argument " "7"" of type '" "double""'");
- res8 = SWIG_AsCharPtrAndSize(obj7, &buf8, NULL, &alloc8);
- if (!SWIG_IsOK(res8)) {
- SWIG_exception_fail(SWIG_ArgError(res8), "in method '" "Digit_MoveVertex" "', argument " "8"" of type '" "char const *""'");
- arg8 = reinterpret_cast< char * >(buf8);
- ecode9 = SWIG_AsVal_int(obj8, &val9);
- SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "Digit_MoveVertex" "', argument " "9"" of type '" "int""'");
- arg9 = static_cast< int >(val9);
- SWIG_exception_fail(SWIG_ArgError(ecode10), "in method '" "Digit_MoveVertex" "', argument " "10"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode11), "in method '" "Digit_MoveVertex" "', argument " "11"" of type '" "double""'");
- result = (int)(arg1)->MoveVertex(arg2,arg3,arg4,arg5,arg6,arg7,(char const *)arg8,arg9,arg10,arg11);
- if (alloc8 == SWIG_NEWOBJ) delete[] buf8;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_ModifyLineVertex(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int arg2 ;
- double arg3 ;
- double arg4 ;
- double arg5 ;
- double arg6 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- double val5 ;
- int ecode5 = 0 ;
- double val6 ;
- int ecode6 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOO:Digit_ModifyLineVertex",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_ModifyLineVertex" "', argument " "1"" of type '" "Digit *""'");
- ecode2 = SWIG_AsVal_int(obj1, &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_ModifyLineVertex" "', argument " "2"" of type '" "int""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_ModifyLineVertex" "', argument " "3"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_ModifyLineVertex" "', argument " "4"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_ModifyLineVertex" "', argument " "5"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_ModifyLineVertex" "', argument " "6"" of type '" "double""'");
- result = (int)(arg1)->ModifyLineVertex(arg2,arg3,arg4,arg5,arg6);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_SelectLinesByQuery(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- double arg2 ;
- double arg3 ;
- double arg4 ;
- double arg5 ;
- double arg6 ;
- double arg7 ;
- bool arg8 ;
- int arg9 ;
- int arg10 ;
- double arg11 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- double val5 ;
- int ecode5 = 0 ;
- double val6 ;
- int ecode6 = 0 ;
- double val7 ;
- int ecode7 = 0 ;
- bool val8 ;
- int ecode8 = 0 ;
- int val9 ;
- int ecode9 = 0 ;
- int val10 ;
- int ecode10 = 0 ;
- double val11 ;
- int ecode11 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOOOOOOOO:Digit_SelectLinesByQuery",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5,&obj6,&obj7,&obj8,&obj9,&obj10)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_SelectLinesByQuery" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_SelectLinesByQuery" "', argument " "2"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_SelectLinesByQuery" "', argument " "3"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "Digit_SelectLinesByQuery" "', argument " "4"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_SelectLinesByQuery" "', argument " "5"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_SelectLinesByQuery" "', argument " "6"" of type '" "double""'");
- SWIG_exception_fail(SWIG_ArgError(ecode7), "in method '" "Digit_SelectLinesByQuery" "', argument " "7"" of type '" "double""'");
- ecode8 = SWIG_AsVal_bool(obj7, &val8);
- SWIG_exception_fail(SWIG_ArgError(ecode8), "in method '" "Digit_SelectLinesByQuery" "', argument " "8"" of type '" "bool""'");
- arg8 = static_cast< bool >(val8);
- SWIG_exception_fail(SWIG_ArgError(ecode9), "in method '" "Digit_SelectLinesByQuery" "', argument " "9"" of type '" "int""'");
- ecode10 = SWIG_AsVal_int(obj9, &val10);
- SWIG_exception_fail(SWIG_ArgError(ecode10), "in method '" "Digit_SelectLinesByQuery" "', argument " "10"" of type '" "int""'");
- arg10 = static_cast< int >(val10);
- SWIG_exception_fail(SWIG_ArgError(ecode11), "in method '" "Digit_SelectLinesByQuery" "', argument " "11"" of type '" "double""'");
- result = (arg1)->SelectLinesByQuery(arg2,arg3,arg4,arg5,arg6,arg7,arg8,arg9,arg10,arg11);
- resultobj = swig::from(static_cast< std::vector<int,std::allocator<int > > >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_CopyCats(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- SwigValueWrapper< std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > > > arg2 ;
- std::vector<int,std::allocator<int > > arg3 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 ;
- int res2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:Digit_CopyCats",&obj0,&obj1,&obj2)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_CopyCats" "', argument " "1"" of type '" "Digit *""'");
- res2 = SWIG_ConvertPtr(obj1, &argp2, SWIGTYPE_p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t, 0 | 0);
- if (!SWIG_IsOK(res2)) {
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "Digit_CopyCats" "', argument " "2"" of type '" "std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > >""'");
- if (!argp2) {
- SWIG_exception_fail(SWIG_ValueError, "invalid null reference " "in method '" "Digit_CopyCats" "', argument " "2"" of type '" "std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > >""'");
- } else {
- std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > > * temp = reinterpret_cast< std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > > * >(argp2);
- arg2 = *temp;
- if (SWIG_IsNewObj(res2)) delete temp;
- SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_CopyCats" "', argument " "3"" of type '" "std::vector<int,std::allocator<int > >""'");
- arg3 = *ptr;
- result = (int)(arg1)->CopyCats(arg2,arg3);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_GetCategory(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int arg2 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:Digit_GetCategory",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_GetCategory" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_GetCategory" "', argument " "2"" of type '" "int""'");
- result = (int)(arg1)->GetCategory(arg2);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_GetLineCats(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int arg2 ;
- std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OO:Digit_GetLineCats",&obj0,&obj1)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_GetLineCats" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_GetLineCats" "', argument " "2"" of type '" "int""'");
- result = (arg1)->GetLineCats(arg2);
- resultobj = swig::from(static_cast< std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > >(result));
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_SetLineCats(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- int arg2 ;
- int arg3 ;
- std::vector<int,std::allocator<int > > arg4 ;
- bool arg5 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- int val3 ;
- int ecode3 = 0 ;
- bool val5 ;
- int ecode5 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOOOO:Digit_SetLineCats",&obj0,&obj1,&obj2,&obj3,&obj4)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_SetLineCats" "', argument " "1"" of type '" "Digit *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "Digit_SetLineCats" "', argument " "2"" of type '" "int""'");
- ecode3 = SWIG_AsVal_int(obj2, &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "Digit_SetLineCats" "', argument " "3"" of type '" "int""'");
- arg3 = static_cast< int >(val3);
- int res = swig::asptr(obj3, &ptr);
- SWIG_exception_fail(SWIG_ArgError((ptr ? res : SWIG_TypeError)), "in method '" "Digit_SetLineCats" "', argument " "4"" of type '" "std::vector<int,std::allocator<int > >""'");
- arg4 = *ptr;
- SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_SetLineCats" "', argument " "5"" of type '" "bool""'");
- result = (int)(arg1)->SetLineCats(arg2,arg3,arg4,arg5);
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_Digit_GetLayers(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:Digit_GetLayers",&obj0)) SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_GetLayers" "', argument " "1"" of type '" "Digit *""'");
- result = (arg1)->GetLayers();
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *_wrap_delete_Digit(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"O:delete_Digit",&obj0)) SWIG_fail;
- res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_Digit, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "delete_Digit" "', argument " "1"" of type '" "Digit *""'");
- delete arg1;
- return resultobj;
-fail:
- return NULL;
-SWIGINTERN PyObject *Digit_swigregister(PyObject *SWIGUNUSEDPARM(self), PyObject *args) {
- PyObject *obj;
- if (!PyArg_ParseTuple(args,(char*)"O|swigregister", &obj)) return NULL;
- SWIG_TypeNewClientData(SWIGTYPE_p_Digit, SWIG_NewClientData(obj));
- return SWIG_Py_Void();
-static PyMethodDef SwigMethods[] = {
- { (char *)"delete_PySwigIterator", _wrap_delete_PySwigIterator, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_value", _wrap_PySwigIterator_value, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_incr", _wrap_PySwigIterator_incr, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_decr", _wrap_PySwigIterator_decr, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_distance", _wrap_PySwigIterator_distance, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_equal", _wrap_PySwigIterator_equal, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_copy", _wrap_PySwigIterator_copy, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_next", _wrap_PySwigIterator_next, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_previous", _wrap_PySwigIterator_previous, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_advance", _wrap_PySwigIterator_advance, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___eq__", _wrap_PySwigIterator___eq__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___ne__", _wrap_PySwigIterator___ne__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___iadd__", _wrap_PySwigIterator___iadd__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___isub__", _wrap_PySwigIterator___isub__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___add__", _wrap_PySwigIterator___add__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator___sub__", _wrap_PySwigIterator___sub__, METH_VARARGS, NULL},
- { (char *)"PySwigIterator_swigregister", PySwigIterator_swigregister, METH_VARARGS, NULL},
- { (char *)"IntVector_iterator", _wrap_IntVector_iterator, METH_VARARGS, NULL},
- { (char *)"IntVector___nonzero__", _wrap_IntVector___nonzero__, METH_VARARGS, NULL},
- { (char *)"IntVector___len__", _wrap_IntVector___len__, METH_VARARGS, NULL},
- { (char *)"IntVector_pop", _wrap_IntVector_pop, METH_VARARGS, NULL},
- { (char *)"IntVector___getslice__", _wrap_IntVector___getslice__, METH_VARARGS, NULL},
- { (char *)"IntVector___setslice__", _wrap_IntVector___setslice__, METH_VARARGS, NULL},
- { (char *)"IntVector___delslice__", _wrap_IntVector___delslice__, METH_VARARGS, NULL},
- { (char *)"IntVector___delitem__", _wrap_IntVector___delitem__, METH_VARARGS, NULL},
- { (char *)"IntVector___getitem__", _wrap_IntVector___getitem__, METH_VARARGS, NULL},
- { (char *)"IntVector___setitem__", _wrap_IntVector___setitem__, METH_VARARGS, NULL},
- { (char *)"IntVector_append", _wrap_IntVector_append, METH_VARARGS, NULL},
- { (char *)"IntVector_empty", _wrap_IntVector_empty, METH_VARARGS, NULL},
- { (char *)"IntVector_size", _wrap_IntVector_size, METH_VARARGS, NULL},
- { (char *)"IntVector_clear", _wrap_IntVector_clear, METH_VARARGS, NULL},
- { (char *)"IntVector_swap", _wrap_IntVector_swap, METH_VARARGS, NULL},
- { (char *)"IntVector_get_allocator", _wrap_IntVector_get_allocator, METH_VARARGS, NULL},
- { (char *)"IntVector_begin", _wrap_IntVector_begin, METH_VARARGS, NULL},
- { (char *)"IntVector_end", _wrap_IntVector_end, METH_VARARGS, NULL},
- { (char *)"IntVector_rbegin", _wrap_IntVector_rbegin, METH_VARARGS, NULL},
- { (char *)"IntVector_rend", _wrap_IntVector_rend, METH_VARARGS, NULL},
- { (char *)"IntVector_pop_back", _wrap_IntVector_pop_back, METH_VARARGS, NULL},
- { (char *)"IntVector_erase", _wrap_IntVector_erase, METH_VARARGS, NULL},
- { (char *)"new_IntVector", _wrap_new_IntVector, METH_VARARGS, NULL},
- { (char *)"IntVector_push_back", _wrap_IntVector_push_back, METH_VARARGS, NULL},
- { (char *)"IntVector_front", _wrap_IntVector_front, METH_VARARGS, NULL},
- { (char *)"IntVector_back", _wrap_IntVector_back, METH_VARARGS, NULL},
- { (char *)"IntVector_assign", _wrap_IntVector_assign, METH_VARARGS, NULL},
- { (char *)"IntVector_resize", _wrap_IntVector_resize, METH_VARARGS, NULL},
- { (char *)"IntVector_insert", _wrap_IntVector_insert, METH_VARARGS, NULL},
- { (char *)"IntVector_reserve", _wrap_IntVector_reserve, METH_VARARGS, NULL},
- { (char *)"IntVector_capacity", _wrap_IntVector_capacity, METH_VARARGS, NULL},
- { (char *)"delete_IntVector", _wrap_delete_IntVector, METH_VARARGS, NULL},
- { (char *)"IntVector_swigregister", IntVector_swigregister, METH_VARARGS, NULL},
- { (char *)"DoubleVector_iterator", _wrap_DoubleVector_iterator, METH_VARARGS, NULL},
- { (char *)"DoubleVector___nonzero__", _wrap_DoubleVector___nonzero__, METH_VARARGS, NULL},
- { (char *)"DoubleVector___len__", _wrap_DoubleVector___len__, METH_VARARGS, NULL},
- { (char *)"DoubleVector_pop", _wrap_DoubleVector_pop, METH_VARARGS, NULL},
- { (char *)"DoubleVector___getslice__", _wrap_DoubleVector___getslice__, METH_VARARGS, NULL},
- { (char *)"DoubleVector___setslice__", _wrap_DoubleVector___setslice__, METH_VARARGS, NULL},
- { (char *)"DoubleVector___delslice__", _wrap_DoubleVector___delslice__, METH_VARARGS, NULL},
- { (char *)"DoubleVector___delitem__", _wrap_DoubleVector___delitem__, METH_VARARGS, NULL},
- { (char *)"DoubleVector___getitem__", _wrap_DoubleVector___getitem__, METH_VARARGS, NULL},
- { (char *)"DoubleVector___setitem__", _wrap_DoubleVector___setitem__, METH_VARARGS, NULL},
- { (char *)"DoubleVector_append", _wrap_DoubleVector_append, METH_VARARGS, NULL},
- { (char *)"DoubleVector_empty", _wrap_DoubleVector_empty, METH_VARARGS, NULL},
- { (char *)"DoubleVector_size", _wrap_DoubleVector_size, METH_VARARGS, NULL},
- { (char *)"DoubleVector_clear", _wrap_DoubleVector_clear, METH_VARARGS, NULL},
- { (char *)"DoubleVector_swap", _wrap_DoubleVector_swap, METH_VARARGS, NULL},
- { (char *)"DoubleVector_get_allocator", _wrap_DoubleVector_get_allocator, METH_VARARGS, NULL},
- { (char *)"DoubleVector_begin", _wrap_DoubleVector_begin, METH_VARARGS, NULL},
- { (char *)"DoubleVector_end", _wrap_DoubleVector_end, METH_VARARGS, NULL},
- { (char *)"DoubleVector_rbegin", _wrap_DoubleVector_rbegin, METH_VARARGS, NULL},
- { (char *)"DoubleVector_rend", _wrap_DoubleVector_rend, METH_VARARGS, NULL},
- { (char *)"DoubleVector_pop_back", _wrap_DoubleVector_pop_back, METH_VARARGS, NULL},
- { (char *)"DoubleVector_erase", _wrap_DoubleVector_erase, METH_VARARGS, NULL},
- { (char *)"new_DoubleVector", _wrap_new_DoubleVector, METH_VARARGS, NULL},
- { (char *)"DoubleVector_push_back", _wrap_DoubleVector_push_back, METH_VARARGS, NULL},
- { (char *)"DoubleVector_front", _wrap_DoubleVector_front, METH_VARARGS, NULL},
- { (char *)"DoubleVector_back", _wrap_DoubleVector_back, METH_VARARGS, NULL},
- { (char *)"DoubleVector_assign", _wrap_DoubleVector_assign, METH_VARARGS, NULL},
- { (char *)"DoubleVector_resize", _wrap_DoubleVector_resize, METH_VARARGS, NULL},
- { (char *)"DoubleVector_insert", _wrap_DoubleVector_insert, METH_VARARGS, NULL},
- { (char *)"DoubleVector_reserve", _wrap_DoubleVector_reserve, METH_VARARGS, NULL},
- { (char *)"DoubleVector_capacity", _wrap_DoubleVector_capacity, METH_VARARGS, NULL},
- { (char *)"delete_DoubleVector", _wrap_delete_DoubleVector, METH_VARARGS, NULL},
- { (char *)"DoubleVector_swigregister", DoubleVector_swigregister, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_iterator", _wrap_IntVecIntMap_iterator, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap___nonzero__", _wrap_IntVecIntMap___nonzero__, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap___len__", _wrap_IntVecIntMap___len__, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap___getitem__", _wrap_IntVecIntMap___getitem__, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap___delitem__", _wrap_IntVecIntMap___delitem__, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_has_key", _wrap_IntVecIntMap_has_key, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_keys", _wrap_IntVecIntMap_keys, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_values", _wrap_IntVecIntMap_values, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_items", _wrap_IntVecIntMap_items, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap___contains__", _wrap_IntVecIntMap___contains__, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_key_iterator", _wrap_IntVecIntMap_key_iterator, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_value_iterator", _wrap_IntVecIntMap_value_iterator, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap___setitem__", _wrap_IntVecIntMap___setitem__, METH_VARARGS, NULL},
- { (char *)"new_IntVecIntMap", _wrap_new_IntVecIntMap, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_empty", _wrap_IntVecIntMap_empty, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_size", _wrap_IntVecIntMap_size, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_clear", _wrap_IntVecIntMap_clear, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_swap", _wrap_IntVecIntMap_swap, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_get_allocator", _wrap_IntVecIntMap_get_allocator, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_begin", _wrap_IntVecIntMap_begin, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_end", _wrap_IntVecIntMap_end, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_rbegin", _wrap_IntVecIntMap_rbegin, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_rend", _wrap_IntVecIntMap_rend, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_count", _wrap_IntVecIntMap_count, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_erase", _wrap_IntVecIntMap_erase, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_find", _wrap_IntVecIntMap_find, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_lower_bound", _wrap_IntVecIntMap_lower_bound, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_upper_bound", _wrap_IntVecIntMap_upper_bound, METH_VARARGS, NULL},
- { (char *)"delete_IntVecIntMap", _wrap_delete_IntVecIntMap, METH_VARARGS, NULL},
- { (char *)"IntVecIntMap_swigregister", IntVecIntMap_swigregister, METH_VARARGS, NULL},
- { (char *)"new_DisplayDriver", _wrap_new_DisplayDriver, METH_VARARGS, NULL},
- { (char *)"delete_DisplayDriver", _wrap_delete_DisplayDriver, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_DrawMap", _wrap_DisplayDriver_DrawMap, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_SelectLinesByBox", _wrap_DisplayDriver_SelectLinesByBox, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_SelectLineByPoint", _wrap_DisplayDriver_SelectLineByPoint, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_GetSelected", _wrap_DisplayDriver_GetSelected, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_SetSelected", _wrap_DisplayDriver_SetSelected, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_GetSelectedVertex", _wrap_DisplayDriver_GetSelectedVertex, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_CloseMap", _wrap_DisplayDriver_CloseMap, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_OpenMap", _wrap_DisplayDriver_OpenMap, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_ReloadMap", _wrap_DisplayDriver_ReloadMap, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_SetDevice", _wrap_DisplayDriver_SetDevice, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_GetMapBoundingBox", _wrap_DisplayDriver_GetMapBoundingBox, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_SetRegion", _wrap_DisplayDriver_SetRegion, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_UpdateSettings", _wrap_DisplayDriver_UpdateSettings, METH_VARARGS, NULL},
- { (char *)"DisplayDriver_swigregister", DisplayDriver_swigregister, METH_VARARGS, NULL},
- { (char *)"print_error", _wrap_print_error, METH_VARARGS, NULL},
- { (char *)"new_Digit", _wrap_new_Digit, METH_VARARGS, NULL},
- { (char *)"Digit_InitCats", _wrap_Digit_InitCats, METH_VARARGS, NULL},
- { (char *)"Digit_AddLine", _wrap_Digit_AddLine, METH_VARARGS, NULL},
- { (char *)"Digit_RewriteLine", _wrap_Digit_RewriteLine, METH_VARARGS, NULL},
- { (char *)"Digit_SplitLine", _wrap_Digit_SplitLine, METH_VARARGS, NULL},
- { (char *)"Digit_DeleteLines", _wrap_Digit_DeleteLines, METH_VARARGS, NULL},
- { (char *)"Digit_MoveLines", _wrap_Digit_MoveLines, METH_VARARGS, NULL},
- { (char *)"Digit_FlipLines", _wrap_Digit_FlipLines, METH_VARARGS, NULL},
- { (char *)"Digit_MergeLines", _wrap_Digit_MergeLines, METH_VARARGS, NULL},
- { (char *)"Digit_BreakLines", _wrap_Digit_BreakLines, METH_VARARGS, NULL},
- { (char *)"Digit_SnapLines", _wrap_Digit_SnapLines, METH_VARARGS, NULL},
- { (char *)"Digit_ConnectLines", _wrap_Digit_ConnectLines, METH_VARARGS, NULL},
- { (char *)"Digit_TypeConvLines", _wrap_Digit_TypeConvLines, METH_VARARGS, NULL},
- { (char *)"Digit_ZBulkLabeling", _wrap_Digit_ZBulkLabeling, METH_VARARGS, NULL},
- { (char *)"Digit_CopyLines", _wrap_Digit_CopyLines, METH_VARARGS, NULL},
- { (char *)"Digit_MoveVertex", _wrap_Digit_MoveVertex, METH_VARARGS, NULL},
- { (char *)"Digit_ModifyLineVertex", _wrap_Digit_ModifyLineVertex, METH_VARARGS, NULL},
- { (char *)"Digit_SelectLinesByQuery", _wrap_Digit_SelectLinesByQuery, METH_VARARGS, NULL},
- { (char *)"Digit_CopyCats", _wrap_Digit_CopyCats, METH_VARARGS, NULL},
- { (char *)"Digit_GetCategory", _wrap_Digit_GetCategory, METH_VARARGS, NULL},
- { (char *)"Digit_GetLineCats", _wrap_Digit_GetLineCats, METH_VARARGS, NULL},
- { (char *)"Digit_SetLineCats", _wrap_Digit_SetLineCats, METH_VARARGS, NULL},
- { (char *)"Digit_GetLayers", _wrap_Digit_GetLayers, METH_VARARGS, NULL},
- { (char *)"delete_Digit", _wrap_delete_Digit, METH_VARARGS, NULL},
- { (char *)"Digit_swigregister", Digit_swigregister, METH_VARARGS, NULL},
- { NULL, NULL, 0, NULL }
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (BEGIN) -------- */
-static swig_type_info _swigt__p_Digit = {"_p_Digit", "Digit *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_DisplayDriver = {"_p_DisplayDriver", "DisplayDriver *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_allocator_type = {"_p_allocator_type", "allocator_type *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_char = {"_p_char", "char *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_difference_type = {"_p_difference_type", "difference_type *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_key_type = {"_p_key_type", "key_type *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_mapped_type = {"_p_mapped_type", "mapped_type *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_p_PyObject = {"_p_p_PyObject", "PyObject **", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_size_type = {"_p_size_type", "size_type *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__invalid_argument = {"_p_std__invalid_argument", "std::invalid_argument *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__lessTint_t = {"_p_std__lessTint_t", "std::less<int > *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t = {"_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t", "std::map<int,std::vector<int > > *|std::map<int,std::vector<int,std::allocator<int > >,std::less<int >,std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > > *|std::map<int,std::vector<int,std::allocator<int > > > *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type = {"_p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type", "std::map<int,std::vector<int > >::allocator_type *|std::allocator<std::pair<int const,std::vector<int,std::allocator<int > > > > *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t = {"_p_std__vectorTdouble_std__allocatorTdouble_t_t", "std::vector<double,std::allocator<double > > *|std::vector<double > *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type = {"_p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type", "std::vector<double >::allocator_type *|std::allocator<double > *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__vectorTint_std__allocatorTint_t_t = {"_p_std__vectorTint_std__allocatorTint_t_t", "std::vector<int,std::allocator<int > > *|std::vector<int > *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__vectorTint_std__allocatorTint_t_t__allocator_type = {"_p_std__vectorTint_std__allocatorTint_t_t__allocator_type", "std::vector<int >::allocator_type *|std::allocator<int > *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t = {"_p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t", "std::vector<std::vector<int,std::allocator<int > >,std::allocator<std::vector<int,std::allocator<int > > > > *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_swig__PySwigIterator = {"_p_swig__PySwigIterator", "swig::PySwigIterator *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_value_type = {"_p_value_type", "value_type *", 0, 0, (void*)0, 0};
-static swig_type_info *swig_type_initial[] = {
- &_swigt__p_Digit,
- &_swigt__p_DisplayDriver,
- &_swigt__p_allocator_type,
- &_swigt__p_char,
- &_swigt__p_difference_type,
- &_swigt__p_key_type,
- &_swigt__p_mapped_type,
- &_swigt__p_p_PyObject,
- &_swigt__p_size_type,
- &_swigt__p_std__invalid_argument,
- &_swigt__p_std__lessTint_t,
- &_swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t,
- &_swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type,
- &_swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t,
- &_swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type,
- &_swigt__p_std__vectorTint_std__allocatorTint_t_t,
- &_swigt__p_std__vectorTint_std__allocatorTint_t_t__allocator_type,
- &_swigt__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t,
- &_swigt__p_swig__PySwigIterator,
- &_swigt__p_value_type,
-static swig_cast_info _swigc__p_Digit[] = { {&_swigt__p_Digit, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_DisplayDriver[] = { {&_swigt__p_DisplayDriver, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_allocator_type[] = { {&_swigt__p_allocator_type, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_char[] = { {&_swigt__p_char, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_difference_type[] = { {&_swigt__p_difference_type, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_key_type[] = { {&_swigt__p_key_type, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_mapped_type[] = { {&_swigt__p_mapped_type, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_p_PyObject[] = { {&_swigt__p_p_PyObject, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_size_type[] = { {&_swigt__p_size_type, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__invalid_argument[] = { {&_swigt__p_std__invalid_argument, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__lessTint_t[] = { {&_swigt__p_std__lessTint_t, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t[] = { {&_swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type[] = { {&_swigt__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__vectorTdouble_std__allocatorTdouble_t_t[] = { {&_swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type[] = { {&_swigt__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__vectorTint_std__allocatorTint_t_t[] = { {&_swigt__p_std__vectorTint_std__allocatorTint_t_t, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__vectorTint_std__allocatorTint_t_t__allocator_type[] = { {&_swigt__p_std__vectorTint_std__allocatorTint_t_t__allocator_type, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t[] = { {&_swigt__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_swig__PySwigIterator[] = { {&_swigt__p_swig__PySwigIterator, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_value_type[] = { {&_swigt__p_value_type, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info *swig_cast_initial[] = {
- _swigc__p_Digit,
- _swigc__p_DisplayDriver,
- _swigc__p_allocator_type,
- _swigc__p_char,
- _swigc__p_difference_type,
- _swigc__p_key_type,
- _swigc__p_mapped_type,
- _swigc__p_p_PyObject,
- _swigc__p_size_type,
- _swigc__p_std__invalid_argument,
- _swigc__p_std__lessTint_t,
- _swigc__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t,
- _swigc__p_std__mapTint_std__vectorTint_std__allocatorTint_t_t_std__lessTint_t_std__allocatorTstd__pairTint_const_std__vectorTint_std__allocatorTint_t_t_t_t_t__allocator_type,
- _swigc__p_std__vectorTdouble_std__allocatorTdouble_t_t,
- _swigc__p_std__vectorTdouble_std__allocatorTdouble_t_t__allocator_type,
- _swigc__p_std__vectorTint_std__allocatorTint_t_t,
- _swigc__p_std__vectorTint_std__allocatorTint_t_t__allocator_type,
- _swigc__p_std__vectorTstd__vectorTint_std__allocatorTint_t_t_std__allocatorTstd__vectorTint_std__allocatorTint_t_t_t_t,
- _swigc__p_swig__PySwigIterator,
- _swigc__p_value_type,
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (END) -------- */
-static swig_const_info swig_const_table[] = {
-{0, 0, 0, 0.0, 0, 0}};
-#ifdef __cplusplus
-#endif
- * Type initialization:
- * This problem is tough by the requirement that no dynamic
- * memory is used. Also, since swig_type_info structures store pointers to
- * swig_cast_info structures and swig_cast_info structures store pointers back
- * to swig_type_info structures, we need some lookup code at initialization.
- * The idea is that swig generates all the structures that are needed.
- * The runtime then collects these partially filled structures.
- * The SWIG_InitializeModule function takes these initial arrays out of
- * swig_module, and does all the lookup, filling in the swig_module.types
- * array with the correct data and linking the correct swig_cast_info
- * structures together.
- * The generated swig_type_info structures are assigned staticly to an initial
- * array. We just loop through that array, and handle each type individually.
- * First we lookup if this type has been already loaded, and if so, use the
- * loaded structure instead of the generated one. Then we have to fill in the
- * cast linked list. The cast data is initially stored in something like a
- * two-dimensional array. Each row corresponds to a type (there are the same
- * number of rows as there are in the swig_type_initial array). Each entry in
- * a column is one of the swig_cast_info structures for that type.
- * The cast_initial array is actually an array of arrays, because each row has
- * a variable number of columns. So to actually build the cast linked list,
- * we find the array of casts associated with the type, and loop through it
- * adding the casts to the list. The one last trick we need to do is making
- * sure the type pointer in the swig_cast_info struct is correct.
- * First off, we lookup the cast->type name to see if it is already loaded.
- * There are three cases to handle:
- * 1) If the cast->type has already been loaded AND the type we are adding
- * casting info to has not been loaded (it is in this module), THEN we
- * replace the cast->type pointer with the type pointer that has already
- * been loaded.
- * 2) If BOTH types (the one we are adding casting info to, and the
- * cast->type) are loaded, THEN the cast info has already been loaded by
- * the previous module so we just ignore it.
- * 3) Finally, if cast->type has not already been loaded, then we add that
- * swig_cast_info to the linked list (because the cast->type) pointer will
- * be correct.
-#ifdef __cplusplus
-extern "C" {
-#if 0
-} /* c-mode */
-#endif
-#endif
-#if 0
-#define SWIGRUNTIME_DEBUG
-#endif
-SWIGRUNTIME void
-SWIG_InitializeModule(void *clientdata) {
- size_t i;
- swig_module_info *module_head, *iter;
- int found;
- clientdata = clientdata;
- /* check to see if the circular list has been setup, if not, set it up */
- if (swig_module.next==0) {
- /* Initialize the swig_module */
- swig_module.type_initial = swig_type_initial;
- swig_module.cast_initial = swig_cast_initial;
- swig_module.next = &swig_module;
- /* Try and load any already created modules */
- module_head = SWIG_GetModule(clientdata);
- if (!module_head) {
- /* This is the first module loaded for this interpreter */
- /* so set the swig module into the interpreter */
- SWIG_SetModule(clientdata, &swig_module);
- module_head = &swig_module;
- } else {
- /* the interpreter has loaded a SWIG module, but has it loaded this one? */
- found=0;
- iter=module_head;
- do {
- if (iter==&swig_module) {
- found=1;
- break;
- iter=iter->next;
- } while (iter!= module_head);
- /* if the is found in the list, then all is done and we may leave */
- if (found) return;
- /* otherwise we must add out module into the list */
- swig_module.next = module_head->next;
- module_head->next = &swig_module;
- /* Now work on filling in swig_module.types */
-#ifdef SWIGRUNTIME_DEBUG
- printf("SWIG_InitializeModule: size %d\n", swig_module.size);
-#endif
- for (i = 0; i < swig_module.size; ++i) {
- swig_type_info *type = 0;
- swig_type_info *ret;
- swig_cast_info *cast;
- printf("SWIG_InitializeModule: type %d %s\n", i, swig_module.type_initial[i]->name);
-#endif
- /* if there is another module already loaded */
- if (swig_module.next != &swig_module) {
- type = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, swig_module.type_initial[i]->name);
- if (type) {
- /* Overwrite clientdata field */
- printf("SWIG_InitializeModule: found type %s\n", type->name);
-#endif
- if (swig_module.type_initial[i]->clientdata) {
- type->clientdata = swig_module.type_initial[i]->clientdata;
- printf("SWIG_InitializeModule: found and overwrite type %s \n", type->name);
-#endif
- } else {
- type = swig_module.type_initial[i];
- /* Insert casting types */
- cast = swig_module.cast_initial[i];
- while (cast->type) {
- /* Don't need to add information already in the list */
- ret = 0;
- printf("SWIG_InitializeModule: look cast %s\n", cast->type->name);
-#endif
- ret = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, cast->type->name);
- if (ret) printf("SWIG_InitializeModule: found cast %s\n", ret->name);
-#endif
- if (ret) {
- if (type == swig_module.type_initial[i]) {
- printf("SWIG_InitializeModule: skip old type %s\n", ret->name);
-#endif
- cast->type = ret;
- ret = 0;
- } else {
- /* Check for casting already in the list */
- swig_cast_info *ocast = SWIG_TypeCheck(ret->name, type);
- if (ocast) printf("SWIG_InitializeModule: skip old cast %s\n", ret->name);
-#endif
- if (!ocast) ret = 0;
- if (!ret) {
- printf("SWIG_InitializeModule: adding cast %s\n", cast->type->name);
-#endif
- if (type->cast) {
- type->cast->prev = cast;
- cast->next = type->cast;
- type->cast = cast;
- cast++;
- /* Set entry in modules->types array equal to the type */
- swig_module.types[i] = type;
- swig_module.types[i] = 0;
- printf("**** SWIG_InitializeModule: Cast List ******\n");
- int j = 0;
- swig_cast_info *cast = swig_module.cast_initial[i];
- printf("SWIG_InitializeModule: cast type %s\n", cast->type->name);
- cast++;
- ++j;
- printf("---- Total casts: %d\n",j);
-#endif
-/* This function will propagate the clientdata field of type to
-* any new swig_type_info structures that have been added into the list
-* of equivalent types. It is like calling
-* SWIG_TypeClientData(type, clientdata) a second time.
-SWIGRUNTIME void
-SWIG_PropagateClientData(void) {
- size_t i;
- swig_cast_info *equiv;
- static int init_run = 0;
- if (init_run) return;
- init_run = 1;
- for (i = 0; i < swig_module.size; i++) {
- if (swig_module.types[i]->clientdata) {
- equiv = swig_module.types[i]->cast;
- while (equiv) {
- if (!equiv->converter) {
- if (equiv->type && !equiv->type->clientdata)
- SWIG_TypeClientData(equiv->type, swig_module.types[i]->clientdata);
- equiv = equiv->next;
-#ifdef __cplusplus
-#if 0
- /* c-mode */
-#endif
-#endif
-#ifdef __cplusplus
-extern "C" {
-#endif
- /* Python-specific SWIG API */
-#define SWIG_newvarlink() SWIG_Python_newvarlink()
-#define SWIG_addvarlink(p, name, get_attr, set_attr) SWIG_Python_addvarlink(p, name, get_attr, set_attr)
-#define SWIG_InstallConstants(d, constants) SWIG_Python_InstallConstants(d, constants)
- * global variable support code.
- typedef struct swig_globalvar {
- char *name; /* Name of global variable */
- PyObject *(*get_attr)(void); /* Return the current value */
- int (*set_attr)(PyObject *); /* Set the value */
- struct swig_globalvar *next;
- } swig_globalvar;
- typedef struct swig_varlinkobject {
- PyObject_HEAD
- swig_globalvar *vars;
- } swig_varlinkobject;
- SWIGINTERN PyObject *
- swig_varlink_repr(swig_varlinkobject *SWIGUNUSEDPARM(v)) {
- return PyString_FromString("<Swig global variables>");
- swig_varlink_str(swig_varlinkobject *v) {
- PyObject *str = PyString_FromString("(");
- swig_globalvar *var;
- for (var = v->vars; var; var=var->next) {
- PyString_ConcatAndDel(&str,PyString_FromString(var->name));
- if (var->next) PyString_ConcatAndDel(&str,PyString_FromString(", "));
- PyString_ConcatAndDel(&str,PyString_FromString(")"));
- return str;
- SWIGINTERN int
- swig_varlink_print(swig_varlinkobject *v, FILE *fp, int SWIGUNUSEDPARM(flags)) {
- PyObject *str = swig_varlink_str(v);
- fprintf(fp,"Swig global variables ");
- fprintf(fp,"%s\n", PyString_AsString(str));
- Py_DECREF(str);
- return 0;
- SWIGINTERN void
- swig_varlink_dealloc(swig_varlinkobject *v) {
- swig_globalvar *var = v->vars;
- while (var) {
- swig_globalvar *n = var->next;
- free(var->name);
- free(var);
- var = n;
- swig_varlink_getattr(swig_varlinkobject *v, char *n) {
- PyObject *res = NULL;
- while (var) {
- if (strcmp(var->name,n) == 0) {
- res = (*var->get_attr)();
- break;
- var = var->next;
- if (res == NULL && !PyErr_Occurred()) {
- PyErr_SetString(PyExc_NameError,"Unknown C global variable");
- return res;
- SWIGINTERN int
- swig_varlink_setattr(swig_varlinkobject *v, char *n, PyObject *p) {
- int res = 1;
- while (var) {
- res = (*var->set_attr)(p);
- break;
- var = var->next;
- if (res == 1 && !PyErr_Occurred()) {
- return res;
- SWIGINTERN PyTypeObject*
- swig_varlink_type(void) {
- static char varlink__doc__[] = "Swig var link object";
- static PyTypeObject varlink_type;
- static int type_init = 0;
- if (!type_init) {
- const PyTypeObject tmp
- PyObject_HEAD_INIT(NULL)
- 0, /* Number of items in variable part (ob_size) */
- (char *)"swigvarlink", /* Type name (tp_name) */
- sizeof(swig_varlinkobject), /* Basic size (tp_basicsize) */
- 0, /* Itemsize (tp_itemsize) */
- (destructor) swig_varlink_dealloc, /* Deallocator (tp_dealloc) */
- (printfunc) swig_varlink_print, /* Print (tp_print) */
- (getattrfunc) swig_varlink_getattr, /* get attr (tp_getattr) */
- (setattrfunc) swig_varlink_setattr, /* Set attr (tp_setattr) */
- 0, /* tp_compare */
- (reprfunc) swig_varlink_repr, /* tp_repr */
- 0, /* tp_as_number */
- 0, /* tp_as_sequence */
- 0, /* tp_as_mapping */
- 0, /* tp_hash */
- 0, /* tp_call */
- (reprfunc)swig_varlink_str, /* tp_str */
- 0, /* tp_getattro */
- 0, /* tp_setattro */
- 0, /* tp_as_buffer */
- 0, /* tp_flags */
- varlink__doc__, /* tp_doc */
- 0, /* tp_traverse */
- 0, /* tp_clear */
- 0, /* tp_richcompare */
- 0, /* tp_weaklistoffset */
-#if PY_VERSION_HEX >= 0x02020000
- 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, /* tp_iter -> tp_weaklist */
-#endif
-#if PY_VERSION_HEX >= 0x02030000
- 0, /* tp_del */
-#endif
-#ifdef COUNT_ALLOCS
- 0,0,0,0 /* tp_alloc -> tp_next */
-#endif
- varlink_type = tmp;
- varlink_type.ob_type = &PyType_Type;
- type_init = 1;
- return &varlink_type;
- /* Create a variable linking object for use later */
- SWIG_Python_newvarlink(void) {
- swig_varlinkobject *result = PyObject_NEW(swig_varlinkobject, swig_varlink_type());
- if (result) {
- result->vars = 0;
- return ((PyObject*) result);
- SWIGINTERN void
- SWIG_Python_addvarlink(PyObject *p, char *name, PyObject *(*get_attr)(void), int (*set_attr)(PyObject *p)) {
- swig_varlinkobject *v = (swig_varlinkobject *) p;
- swig_globalvar *gv = (swig_globalvar *) malloc(sizeof(swig_globalvar));
- if (gv) {
- size_t size = strlen(name)+1;
- gv->name = (char *)malloc(size);
- if (gv->name) {
- strncpy(gv->name,name,size);
- gv->get_attr = get_attr;
- gv->set_attr = set_attr;
- gv->next = v->vars;
- v->vars = gv;
- SWIG_globals(void) {
- static PyObject *_SWIG_globals = 0;
- if (!_SWIG_globals) _SWIG_globals = SWIG_newvarlink();
- return _SWIG_globals;
- * constants/methods manipulation
- /* Install Constants */
- SWIGINTERN void
- SWIG_Python_InstallConstants(PyObject *d, swig_const_info constants[]) {
- PyObject *obj = 0;
- size_t i;
- for (i = 0; constants[i].type; ++i) {
- switch(constants[i].type) {
- case SWIG_PY_POINTER:
- obj = SWIG_NewPointerObj(constants[i].pvalue, *(constants[i]).ptype,0);
- break;
- case SWIG_PY_BINARY:
- obj = SWIG_NewPackedObj(constants[i].pvalue, constants[i].lvalue, *(constants[i].ptype));
- break;
- default:
- obj = 0;
- break;
- if (obj) {
- PyDict_SetItemString(d, constants[i].name, obj);
- Py_DECREF(obj);
- /* Fix SwigMethods to carry the callback ptrs when needed */
- SWIGINTERN void
- SWIG_Python_FixMethods(PyMethodDef *methods,
- swig_const_info *const_table,
- swig_type_info **types,
- swig_type_info **types_initial) {
- size_t i;
- for (i = 0; methods[i].ml_name; ++i) {
- const char *c = methods[i].ml_doc;
- if (c && (c = strstr(c, "swig_ptr: "))) {
- int j;
- swig_const_info *ci = 0;
- const char *name = c + 10;
- for (j = 0; const_table[j].type; ++j) {
- if (strncmp(const_table[j].name, name,
- strlen(const_table[j].name)) == 0) {
- ci = &(const_table[j]);
- break;
- if (ci) {
- size_t shift = (ci->ptype) - types;
- swig_type_info *ty = types_initial[shift];
- size_t ldoc = (c - methods[i].ml_doc);
- size_t lptr = strlen(ty->name)+2*sizeof(void*)+2;
- char *ndoc = (char*)malloc(ldoc + lptr + 10);
- if (ndoc) {
- char *buff = ndoc;
- void *ptr = (ci->type == SWIG_PY_POINTER) ? ci->pvalue : 0;
- if (ptr) {
- strncpy(buff, methods[i].ml_doc, ldoc);
- buff += ldoc;
- strncpy(buff, "swig_ptr: ", 10);
- buff += 10;
- SWIG_PackVoidPtr(buff, ptr, ty->name, lptr);
- methods[i].ml_doc = ndoc;
-#ifdef __cplusplus
-#endif
- * Partial Init method
-#ifdef __cplusplus
-extern "C"
-#endif
-SWIGEXPORT void SWIG_init(void) {
- PyObject *m, *d;
- SWIG_Python_FixMethods(SwigMethods, swig_const_table, swig_types, swig_type_initial);
- m = Py_InitModule((char *) SWIG_name, SwigMethods);
- d = PyModule_GetDict(m);
- SWIG_InitializeModule(0);
- SWIG_InstallConstants(d,swig_const_table);
- SWIG_Python_SetConstant(d, "GSQL_MAX",SWIG_From_int(static_cast< int >(4000)));
- SWIG_Python_SetConstant(d, "GV_POINT",SWIG_From_int(static_cast< int >(0x01)));
- SWIG_Python_SetConstant(d, "GV_LINE",SWIG_From_int(static_cast< int >(0x02)));
- SWIG_Python_SetConstant(d, "GV_BOUNDARY",SWIG_From_int(static_cast< int >(0x04)));
- SWIG_Python_SetConstant(d, "GV_CENTROID",SWIG_From_int(static_cast< int >(0x08)));
- SWIG_Python_SetConstant(d, "GV_FACE",SWIG_From_int(static_cast< int >(0x10)));
- SWIG_Python_SetConstant(d, "GV_KERNEL",SWIG_From_int(static_cast< int >(0x20)));
- SWIG_Python_SetConstant(d, "GV_AREA",SWIG_From_int(static_cast< int >(0x40)));
- SWIG_Python_SetConstant(d, "GV_VOLUME",SWIG_From_int(static_cast< int >(0x80)));
- SWIG_Python_SetConstant(d, "GV_POINTS",SWIG_From_int(static_cast< int >((0x01|0x08))));
- SWIG_Python_SetConstant(d, "GV_LINES",SWIG_From_int(static_cast< int >((0x02|0x04))));
- SWIG_Python_SetConstant(d, "PORT_DOUBLE_MAX",SWIG_From_double(static_cast< double >(1.7976931348623157e+308)));
- SWIG_Python_SetConstant(d, "NO_SNAP",SWIG_From_int(static_cast< int >(0)));
- SWIG_Python_SetConstant(d, "SNAP",SWIG_From_int(static_cast< int >(1)));
- SWIG_Python_SetConstant(d, "SNAPVERTEX",SWIG_From_int(static_cast< int >(2)));
- SWIG_Python_SetConstant(d, "QUERY_UNKNOWN",SWIG_From_int(static_cast< int >(-1)));
- SWIG_Python_SetConstant(d, "QUERY_LENGTH",SWIG_From_int(static_cast< int >(0)));
- SWIG_Python_SetConstant(d, "QUERY_DANGLE",SWIG_From_int(static_cast< int >(1)));
