[GRASS-SVN] r30696 - grass/trunk/vector/v.edit
Sat Mar 22 15:51:17 EDT 2008
Author: martinl
Date: 2008-03-22 15:51:17 -0400 (Sat, 22 Mar 2008)
New Revision: 30696
   grass/trunk/vector/v.edit/main.c
v.edit: cosmetics -- check for illegal map name first, don't print duplicated warning (from Vect_open_new)
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c	2008-03-22 19:46:32 UTC (rev 30695)
+++ grass/trunk/vector/v.edit/main.c	2008-03-22 19:51:17 UTC (rev 30696)
@@ -80,21 +80,19 @@
     if (action_mode == MODE_CREATE) {
 	int overwrite;
+	if (G_legal_filename(params.map -> answer) == -1) {
+	    G_fatal_error(_("<%s> is an illegal file name"),
+			  params.map -> answer);
 	overwrite = G_check_overwrite(argc, argv);
 	if (G_find_vector2(params.map -> answer, G_mapset()) ) {
-	    if (overwrite)
-		G_warning (_("Vector map <%s> already exists and will be overwritten"),
-			   params.map -> answer);
-	    else
+	    if (!overwrite)
 		G_fatal_error (_("Vector map <%s> already exists"),
-	if (G_legal_filename(params.map -> answer) == -1) {
-	    G_fatal_error(_("<%s> is an illegal file name"),
 	/* 3D vector maps? */
 	ret = Vect_open_new (&Map, params.map -> answer, WITHOUT_Z);
 	if (ret == -1) {
