[GRASS-SVN] r30705 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sun Mar 23 13:51:57 EDT 2008
Author: martinl
Date: 2008-03-23 13:51:57 -0400 (Sun, 23 Mar 2008)
New Revision: 30705
grass/trunk/gui/wxpython/gui_modules/debug.py
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: minor cleaning in render (Map/MapFrame class) initialization
Modified: grass/trunk/gui/wxpython/gui_modules/debug.py
--- grass/trunk/gui/wxpython/gui_modules/debug.py 2008-03-23 17:23:11 UTC (rev 30704)
+++ grass/trunk/gui/wxpython/gui_modules/debug.py 2008-03-23 17:51:57 UTC (rev 30705)
@@ -52,6 +52,10 @@
if self.debuglevel > 0 and level > 0 and level <= self.debuglevel:
print >> sys.stderr, "GUI D%d/%d: %s" % (level, self.debuglevel, message)
+ def get_level(self):
+ """Return current GUI debug level"""
+ return self.debuglevel
# Debug instance
Debug = DebugMsg()
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-03-23 17:23:11 UTC (rev 30704)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-03-23 17:51:57 UTC (rev 30705)
@@ -58,7 +58,9 @@
self.cmd_stderr = GMStderr(self.cmd_output,
self.console_progressbar,
self.parent.notebook)
- sys.stderr = self.cmd_stderr
+ if Debug.get_level() == 0:
+ # don't redirect when debugging is enabled
+ sys.stderr = self.cmd_stderr
# buttons
self.console_clear = wx.Button(parent=self, id=wx.ID_CLEAR)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-03-23 17:23:11 UTC (rev 30704)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-03-23 17:51:57 UTC (rev 30705)
@@ -211,12 +211,10 @@
self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
self.hitradius = 10 # distance for selecting map decorations
- self.Map.SetRegion() # make sure that extents are updated at init
# OnSize called to make sure the buffer is initialized.
# This might result in OnSize getting called twice on some
# platforms at initialization, but little harm done.
- self.OnSize(None)
+ ### self.OnSize(None)
# create PseudoDC used for background map, map decorations like scales and legends
self.pdc = wx.PseudoDC()
@@ -2151,8 +2149,6 @@
georect -- is window used by georectifier
- Debug.msg (1, "MapFrame.__init__(): size=%d,%d" % (size[0], size[1]))
wx.Frame.__init__(self, parent, id, title, pos, size, style)
self.gismanager = gismgr # GIS Manager object
@@ -2240,21 +2236,21 @@
self.Bind(wx.EVT_TIMER, self.TimerOnRender)
self.onRenderTimer = wx.Timer(self)
- self.Map.SetRegion() # set region
self.StatusbarReposition() # reposition statusbar
- # Init map display
+ # Init map display (buffered DC & set default cursor)
- self.__InitDisplay() # initialize region values
- # initialize buffered DC & set default cursor
self.MapWindow = BufferedWindow(self, id=wx.ID_ANY, Map=self.Map, tree=self.tree, gismgr=self.gismanager)
self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
self.MapWindow.SetCursor(self.cursors["default"])
+ # initialize region values
+ self.__InitDisplay()
# Decoration overlays
self.ovlchk = self.MapWindow.ovlchk
@@ -2381,8 +2377,8 @@
Debug.msg(2, "MapFrame.__InitDisplay():")
self.Map.ChangeMapSize(self.GetClientSize())
- self.Map.GetRegion() # g.region -upg
- self.Map.SetRegion() # adjust region to match display window
+ self.Map.region = self.Map.GetRegion() # g.region -upgc
+ # self.Map.SetRegion() # adjust region to match display window
def OnFocus(self, event):
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-23 17:23:11 UTC (rev 30704)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-23 17:51:57 UTC (rev 30705)
@@ -21,6 +21,7 @@
import sys
import glob
import math
+# import time
try:
import subprocess
except:
@@ -220,6 +221,10 @@
# setting some initial env. variables
self.InitGisEnv() # g.gisenv
self.InitRegion()
+ # GRASS environment variable (for rendering)
os.environ["GRASS_TRANSPARENT"] = "TRUE"
os.environ["GRASS_BACKGROUNDCOLOR"] = "ffffff"
@@ -236,7 +241,8 @@
# setting region ('g.region -upg')
- self.region = self.GetRegion()
+ ### not needed here (MapFrame.OnSize())
+ # self.region = self.GetRegion()
# read WIND file
@@ -246,7 +252,8 @@
# setting resolution
- self.SetRegion()
+ # not needed here (MapFrame.OnSize())
+ # self.SetRegion()
def InitGisEnv(self):
@@ -608,6 +615,8 @@
@return name of file with rendered image or None
+ # startTime = time.time()
maps = []
masks =[]
opacities = []
@@ -696,6 +705,8 @@
Debug.msg (2, "Map.Render() force=%s file=%s" % (force, self.mapfile))
+ # print time.time() - startTime
return self.mapfile
def AddLayer(self, type, command, name=None,
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-03-23 17:23:11 UTC (rev 30704)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-03-23 17:51:57 UTC (rev 30705)
@@ -1013,7 +1013,7 @@
"""Create new layer tree, which will
create an associated map display frame
- Debug.msg(3, "GMFrame.NewDisplay(): idx=%d" % self.disp_idx)
+ Debug.msg(1, "GMFrame.NewDisplay(): idx=%d" % self.disp_idx)
# make a new page in the bookcontrol for the layer tree (on page 0 of the notebook)
self.pg_panel = wx.Panel(self.gm_cb, id=wx.ID_ANY, style= wx.EXPAND)
