[GRASS-SVN] r30713 - grass/trunk/general/g.mapset
Mon Mar 24 13:23:43 EDT 2008
Author: glynn
Date: 2008-03-24 13:23:43 -0400 (Mon, 24 Mar 2008)
New Revision: 30713
   grass/trunk/general/g.mapset/main.c
g.mapset -l patch from Martin Landa
Modified: grass/trunk/general/g.mapset/main.c
--- grass/trunk/general/g.mapset/main.c	2008-03-24 11:19:11 UTC (rev 30712)
+++ grass/trunk/general/g.mapset/main.c	2008-03-24 17:23:43 UTC (rev 30713)
@@ -32,7 +32,7 @@
     int    ret;
     struct GModule *module;
     struct Option *gisdbase_opt, *location_opt, *mapset_opt;
-    struct Flag *f_add;
+    struct Flag *f_add, *f_list;
     char   *gisdbase_old, *location_old, *mapset_old;
     char   *gisdbase_new, *location_new, *mapset_new;
     char   *gis_lock;
@@ -51,7 +51,7 @@
     mapset_opt = G_define_option() ;
     mapset_opt->key         = "mapset" ;
     mapset_opt->type        = TYPE_STRING ;
-    mapset_opt->required    = YES ;
+    mapset_opt->required    = NO ;
     mapset_opt->multiple    = NO ;
     mapset_opt->description = _("New MAPSET name") ;
@@ -74,9 +74,16 @@
     f_add->description = _("Create mapset if it doesn't exist");
     f_add->answer      = FALSE;
+    f_list = G_define_flag() ;
+    f_list->key         = 'l' ;
+    f_list->description = _("List available mapsets");
     if (G_parser(argc, argv))
     	exit(EXIT_FAILURE);
+    if (!mapset_opt->answer && !f_list->answer)
+	G_fatal_error (_("Either mapset= or -l must be used"));
     /* Store original values */
     gisdbase_old = G__getenv ("GISDBASE");
     location_old = G__getenv ("LOCATION_NAME");
@@ -96,6 +103,21 @@
     else
 	location_new = location_old;
+    if (f_list->answer) {
+	char **ms;
+	int nmapsets;
+	ms = G_available_mapsets();
+	for (nmapsets = 0; ms[nmapsets]; nmapsets++) {
+	    if (G__mapset_permissions2 (gisdbase_new, location_new,  ms[nmapsets]) > 0) {
+		fprintf(stdout, "%s ", ms[nmapsets]);
+	fprintf(stdout, "\n");
+	exit(EXIT_SUCCESS);
     mapset_new = mapset_opt->answer;
     G_asprintf ( &mapset_new_path, "%s/%s/%s", gisdbase_new, location_new,
 		mapset_new );
