[GRASS-SVN] r30731 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Tue Mar 25 13:35:40 EDT 2008
Author: martinl
Date: 2008-03-25 13:35:39 -0400 (Tue, 25 Mar 2008)
New Revision: 30731
grass/trunk/lib/vector/diglib/spindex.c
diglib: Doxygen strings updated for spindex.c
Modified: grass/trunk/lib/vector/diglib/spindex.c
--- grass/trunk/lib/vector/diglib/spindex.c 2008-03-25 16:50:06 UTC (rev 30730)
+++ grass/trunk/lib/vector/diglib/spindex.c 2008-03-25 17:35:39 UTC (rev 30731)
@@ -1,33 +1,31 @@
-* $Id$
-* MODULE: Vector library
-* AUTHOR(S): Original author CERL, probably Dave Gerdes.
-* Update to GRASS 5.7 Radim Blazek.
-* PURPOSE: Lower level functions for reading/writing/manipulating vectors.
-* COPYRIGHT: (C) 2001 by the GRASS Development Team
-* This program is free software under the GNU General Public
-* License (>=v2). Read the file COPYING that comes with GRASS
-* for details.
+ * \file spindex.c
+ * \brief Vector library - spatial index (lower level functions)
+ * Lower level functions for reading/writing/manipulating vectors.
+ * (C) 2001 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author CERL (probably Dave Gerdes), Radim Blazek
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
#include <grass/Vect.h>
+#include <grass/glocale.h>
-* dig_spindex_init ()
-* initit spatial index (nodes, lines, areas, isles)
-* returns 1 OK
-* 0 on error
+ \brief Initit spatial index (nodes, lines, areas, isles)
+ \param Plus pointer to Plus_head structure
+ \return 1 OK
+ \return 0 on error
int
dig_spidx_init ( struct Plus_head *Plus)
@@ -51,31 +49,54 @@
return 1;
+ \brief Free spatial index for nodes
void
dig_spidx_free_nodes ( struct Plus_head *Plus) {
RTreeDestroyNode ( Plus->Node_spidx );
Plus->Node_spidx = RTreeNewIndex();
+ \brief Free spatial index for lines
void
dig_spidx_free_lines ( struct Plus_head *Plus) {
RTreeDestroyNode ( Plus->Line_spidx );
Plus->Line_spidx = RTreeNewIndex();
+ \brief Free spatial index for areas
void
dig_spidx_free_areas ( struct Plus_head *Plus) {
RTreeDestroyNode ( Plus->Area_spidx );
Plus->Area_spidx = RTreeNewIndex();
+ \brief Free spatial index for isles
void
dig_spidx_free_isles ( struct Plus_head *Plus) {
RTreeDestroyNode ( Plus->Isle_spidx );
Plus->Isle_spidx = RTreeNewIndex();
-* dig_spidx_free ()
-* free spatial index (nodes, lines, areas, isles)
+ \brief Free spatial index (nodes, lines, areas, isles)
void
dig_spidx_free ( struct Plus_head *Plus)
@@ -86,13 +107,15 @@
dig_spidx_free_isles ( Plus );
-/************************* ADD NEW *********************************/
-* dig_spindex_add_node ()
-* add new node to spatial index
-* returns 1 OK
-* 0 on error
+ \brief Add new node to spatial index
+ \param node node id
+ \param x,y,z node coordinates
+ \return 1 OK
int
dig_spidx_add_node ( struct Plus_head *Plus, int node,
@@ -109,12 +132,14 @@
return 1;
-* dig_spindex_add_line ()
-* add new line to spatial index
-* returns 1 OK
-* 0 on error
+ \brief Add new line to spatial index
+ \param line line id
+ \param box bounding box
+ \return 0
int
dig_spidx_add_line ( struct Plus_head *Plus, int line, BOUND_BOX *box )
@@ -130,12 +155,14 @@
return 0;
-* dig_spindex_add_area ()
-* add new area to spatial index
-* returns 1 OK
-* 0 on error
+ \brief Add new area to spatial index
+ \param area area id
+ \return 0
int
dig_spidx_add_area ( struct Plus_head *Plus, int area, BOUND_BOX *box )
@@ -151,12 +178,14 @@
return 0;
-* dig_spindex_add_isle ()
-* add new island to spatial index
-* returns 1 OK
-* 0 on error
+ \brief Add new island to spatial index
+ \param isle isle id
+ \return 0
int
@@ -173,12 +202,15 @@
return 0;
-* dig_spindex_del_node ()
-* delete node from spatial index
-* returns 1 OK
-* 0 on error
+ \brief Delete node from spatial index
+ G_fatal_error() called on error.
+ \return 0
int
dig_spidx_del_node ( struct Plus_head *Plus, int node )
@@ -196,17 +228,21 @@
ret = RTreeDeleteRect( &rect, node, &(Plus->Node_spidx) );
- if ( ret ) G_fatal_error ( "Cannot delete node %d from spatial index", node );
+ if ( ret )
+ G_fatal_error (_("Unable to delete node %d from spatial index"), node);
return 0;
-* dig_spindex_del_line ()
-* delete line from spatial index
-* returns 1 OK
-* 0 on error
+ \brief Delete line from spatial index
+ \return 0
int
dig_spidx_del_line ( struct Plus_head *Plus, int line )
@@ -228,17 +264,21 @@
G_debug(3, " ret = %d", ret );
- if ( ret ) G_fatal_error ( "Cannot delete line %d from spatial index", line );
+ if ( ret )
+ G_fatal_error (_("Unable to delete line %d from spatial index"), line );
return 0;
-* dig_spindex_del_area ()
-* delete area from spatial index
-* returns 1 OK
-* 0 on error
+ \brief Delete area from spatial index
+ \return 0
int
dig_spidx_del_area ( struct Plus_head *Plus, int area )
@@ -252,7 +292,7 @@
Area = Plus->Area[area];
if (Area == NULL) {
- G_fatal_error ("Attempt to delete sidx for dead area");
+ G_fatal_error (_("Attempt to delete sidx for dead area"));
rect.boundary[0] = Area->W; rect.boundary[1] = Area->S; rect.boundary[2] = Area->B;
@@ -260,17 +300,21 @@
ret = RTreeDeleteRect( &rect, area, &(Plus->Area_spidx) );
- if ( ret ) G_fatal_error ( "Cannot delete area %d from spatial index", area );
+ if ( ret )
+ G_fatal_error (_("Unable to delete area %d from spatial index"), area );
return 0;
-* dig_spindex_del_isle ()
-* delete isle from spatial index
-* returns 1 OK
-* 0 on error
+ \brief Delete isle from spatial index
+ \return 0
int
dig_spidx_del_isle ( struct Plus_head *Plus, int isle )
@@ -288,23 +332,28 @@
ret = RTreeDeleteRect( &rect, isle, &(Plus->Isle_spidx) );
- if ( ret ) G_fatal_error ( "Cannot delete isle %d from spatial index", isle );
+ if ( ret )
+ G_fatal_error (_("Unable to delete isle %d from spatial index"), isle );
return 0;
-/************************* SELECT BY BOX *********************************/
/* This function is called by RTreeSearch() to add selected node/line/area/isle to thelist */
static int _add_item(int id, struct ilist *list)
dig_list_add ( list, id );
return 1;
-* dig_select_nodes ()
-* select nodes by bbox
-* returns: number of selected nodes
-* -1 error
+ \brief Select nodes by bbox
+ \param list list of selected lines
+ \return number of selected nodes
+ \return -1 on error
int
dig_select_nodes ( struct Plus_head *Plus, BOUND_BOX *box, struct ilist *list )
@@ -329,12 +378,14 @@
return 0;
-* dig_find_node ()
-* find one node by coordinates
-* returns: number of node
-* 0 not found
+ \brief Find one node by coordinates
+ \param x,y,z coordinates
+ \return number of node
+ \return 0 not found
int
dig_find_node ( struct Plus_head *Plus, double x, double y, double z )
@@ -356,11 +407,14 @@
return node;
-* dig_select_lines ()
-* select lines by box
-* returns: number of selected lines
+ \brief Select lines by box
+ \return number of selected lines
int
dig_select_lines ( struct Plus_head *Plus, BOUND_BOX *box, struct ilist *list )
@@ -378,11 +432,14 @@
return ( list->n_values );
-* dig_select_areas ()
-* select areas by box
-* returns: number of selected areas
+ \brief Select areas by box
+ \return number of selected areas
int
dig_select_areas ( struct Plus_head *Plus, BOUND_BOX *box, struct ilist *list )
@@ -400,11 +457,14 @@
-* dig_select_isles ()
-* select isles by box
-* returns: number of selected isles
+ \brief Select isles by box
+ \return number of selected isles
int
dig_select_isles ( struct Plus_head *Plus, BOUND_BOX *box, struct ilist *list )
@@ -421,5 +481,3 @@
