[GRASS-SVN] r30739 -
grass/branches/releasebranch_6_3/raster/r.resamp.interp
svn_grass at osgeo.org
Wed Mar 26 09:52:37 EDT 2008
Author: neteler
Date: 2008-03-26 09:52:37 -0400 (Wed, 26 Mar 2008)
New Revision: 30739
grass/branches/releasebranch_6_3/raster/r.resamp.interp/description.html
updated to trnk version
Modified: grass/branches/releasebranch_6_3/raster/r.resamp.interp/description.html
--- grass/branches/releasebranch_6_3/raster/r.resamp.interp/description.html 2008-03-26 13:51:34 UTC (rev 30738)
+++ grass/branches/releasebranch_6_3/raster/r.resamp.interp/description.html 2008-03-26 13:52:37 UTC (rev 30739)
@@ -1,8 +1,9 @@
<H2>DESCRIPTION</H2>
-<p>
-<EM>r.resamp.interp</EM> fills a grid cell (raster) matrix with interpolated values
-generated from a set of input layer data points. A choice of three
+<EM>r.resamp.interp</EM> resamples an input raster map by interpolating between
+the neighboring cells via a selectable resampling algorithm. All cells
+present in the neighborhood of the input raster cell must be non-null to
+generate a non-null cell in the output raster map. A choice of three
interpolation methods is available; each uses the weighted values of a different
number of adjacent cells in the input map to determine the value of each
cell in the output map as follows:
@@ -11,14 +12,18 @@
<li>bilinear (4 cells)</li>
<li>bicubic (16 cells)</li>
</ul>
+This module is intended for reinterpolation of continuous data
+to a different resolution rather than for interpolation from scattered data
+(use the <EM>v.surf.*</EM> modules for that purpose).
</p>
<P>
Note that for bilinear and bicubic interpolation,
cells of the output raster that cannot be bounded by the appropriate number
-of input cell centers are set to null. This could occur due to the input
-cells being outside the current region, being NULL or MASKed.
+of input cell centers are set to NULL (NULL propagation). This could occur
+due to the input cells being outside the current region, being NULL or MASKed.
</p>
<H2>NOTES</H2>
