[GRASS-SVN] r30783 - grass/trunk/gui/wxpython/gui_modules
Fri Mar 28 16:43:21 EDT 2008
Author: martinl
Date: 2008-03-28 16:43:21 -0400 (Fri, 28 Mar 2008)
New Revision: 30783
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
wxGUI: measuring log output fixed (use WriteLog() instead of AddText())
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-03-28 20:18:47 UTC (rev 30782)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-03-28 20:43:21 UTC (rev 30783)
@@ -98,22 +98,38 @@
         self.SetAutoLayout(True)
         self.SetSizer(boxsizer1)
-    def WriteCmdLog(self, line, pid=None):
-        """Write out line in selected style"""
+    def WriteLog(self, line, style=None):
+        """Generic method for writing log message in
+        given style
+        @param line text line
+        @param style text style (see GMStc)
+        @param stdout write to stdout or stderr
+        if not style:
+            style = self.cmd_output.StyleDefault
         self.cmd_output.GotoPos(self.cmd_output.GetEndStyled())
         p1 = self.cmd_output.GetCurrentPos()
-        if pid:
-            line = '(' + str(pid) + ') ' + line
         # fill space
         if len(line) < self.lineWidth:
             diff = 80 - len(line)
             line += diff * ' '
         self.cmd_output.AddText(line + '%s' % os.linesep)
         self.cmd_output.EnsureCaretVisible()
         p2 = self.cmd_output.GetCurrentPos()
         self.cmd_output.StartStyling(p1, 0xff)
-        self.cmd_output.SetStyling(p2 - p1, self.cmd_output.StyleCommand)
+        self.cmd_output.SetStyling(p2 - p1, style)
+    def WriteCmdLog(self, line, pid=None):
+        """Write out line in selected style"""
+        if pid:
+            line = '(' + str(pid) + ') ' + line
+        self.WriteLog(line, self.cmd_output.StyleCommand)
     def RunCmd(self, command):
         Run in GUI GRASS (or other) commands typed into
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-03-28 20:18:47 UTC (rev 30782)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-03-28 20:43:21 UTC (rev 30783)
@@ -452,8 +452,7 @@
         # Make new off screen bitmap: this bitmap will always have the
         # current drawing in it, so it can be used to save the image to
         # a file, or whatever.
-        self.buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1,self.Map.height))
-        #self.buffer = wx.EmptyBitmap(mwidth, mheight)
+        self.buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
         # get the image to be rendered
         self.img = self.GetImage()
@@ -461,7 +460,8 @@
         # update map display
         if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
             self.img = self.img.Scale(self.Map.width, self.Map.height)
-            self.UpdateMap()
+            if len(self.Map.GetListOfLayers()) > 0:
+                self.UpdateMap()
         # re-render image on idle
         self.resize = True
@@ -474,10 +474,9 @@
     def OnIdle(self, event):
-        Only re-render a compsite map image from GRASS during
+        Only re-render a composite map image from GRASS during
         idle time instead of multiple times during resizing.
         if self.resize:
             self.UpdateMap(render=True)
@@ -537,6 +536,11 @@
         start = time.clock()
+        self.resize = False
+        if len(self.Map.GetListOfLayers()) == 0:
+            return False
         if self.img is None:
             render = True
@@ -557,7 +561,6 @@
             self.Map.ChangeMapSize(self.GetClientSize())
             self.mapfile = self.Map.Render(force=True, mapWindow=self.parent)
             self.img = self.GetImage() # id=99
-            self.resize = False
         # clear pseudoDcs
@@ -613,8 +616,6 @@
                 self.Draw(self.pdc, img=self.textdict[id], drawid=id,
                           pdctype='text', coords=self.ovlcoords[id])
         # render region border (to self.pdcTmp)
@@ -2445,7 +2446,7 @@
     def OnDraw(self, event):
-        Redraw button clicked
+        Re-display current map composition
         self.MapWindow.UpdateMap(render=False)
@@ -2455,9 +2456,9 @@
     def OnRender(self, event):
-        Rerender button clicked
+        Re-render map composition (each map layer)
-        # redraw map composition
+        # detele tmp map layers (queries)
         qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)
         for layer in qlayer:
             self.Map.DeleteLayer(layer)
@@ -3044,21 +3045,20 @@
         # initiating output
         style = self.gismanager.goutput.cmd_output.StyleWarning
-        self.gismanager.goutput.cmd_output.write('Click and drag with left mouse button '
-                                                 'to measure.%s'
-                                                 'Double click with left button to clear.%s' % \
-                                                     (os.linesep, os.linesep), style)
+        self.gismanager.goutput.WriteLog(_('Click and drag with left mouse button '
+                                           'to measure.%s'
+                                           'Double click with left button to clear.%s') % \
+                                             (os.linesep, os.linesep), style)
         if self.projinfo['proj'] != 'xy':
             units = self.projinfo['units']
             style = self.gismanager.goutput.cmd_output.StyleCommand
-            self.gismanager.goutput.cmd_output.write('Measuring distance ('
-                                                     + units + '):%s' % os.linesep,
-                                                     style)
+            self.gismanager.goutput.WriteLog(_('Measuring distance ('
+                                               + units + '):'),
+                                             style)
         else:
-            self.gismanager.goutput.cmd_output.write('Measuring distance:%s' % os.linesep,
-                                                     style)
+            self.gismanager.goutput.WriteLog(_('Measuring distance:'),
+                                             style)
     def MeasureDist(self, beginpt, endpt):
         Calculate map distance from screen distance
@@ -3084,13 +3084,13 @@
             angle = angle+90
             if angle < 0: angle = 360+angle
-            mstring = 'segment = %s %s\ttotal distance = %s %s\tbearing = %d deg\n' \
+            mstring = 'segment = %s %s\ttotal distance = %s %s\tbearing = %d deg' \
                 % (strdist,dunits,strtotdist,tdunits,angle)
         else:
-            mstring = 'segment = %s %s\ttotal distance = %s %s\n' \
+            mstring = 'segment = %s %s\ttotal distance = %s %s' \
                 % (strdist,dunits,strtotdist,tdunits)
-        self.gismanager.goutput.cmd_output.AddText(mstring)
+        self.gismanager.goutput.WriteLog(mstring)
         return dist
