[GRASS-SVN] r30816 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Mar 30 11:48:01 EDT 2008
Author: martinl
Date: 2008-03-30 11:48:00 -0400 (Sun, 30 Mar 2008)
New Revision: 30816
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI (mapdisplay): Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box. Related to trac #106.
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-03-30 14:48:26 UTC (rev 30815)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-03-30 15:48:00 UTC (rev 30816)
@@ -538,8 +538,8 @@
self.resize = False
- if len(self.Map.GetListOfLayers()) == 0:
- return False
+ # if len(self.Map.GetListOfLayers()) == 0:
+ # return False
if self.img is None:
render = True
@@ -616,20 +616,7 @@
self.Draw(self.pdc, img=self.textdict[id], drawid=id,
pdctype='text', coords=self.ovlcoords[id])
- # render region border (to self.pdcTmp)
- if hasattr(self, "regionCoords"):
- reg = self.Map.GetWindow()
- self.polypen = wx.Pen(colour='red', width=2, style=wx.SOLID)
- self.regionCoords = []
- self.regionCoords.append((reg['west'], reg['north']))
- self.regionCoords.append((reg['east'], reg['north']))
- self.regionCoords.append((reg['east'], reg['south']))
- self.regionCoords.append((reg['west'], reg['south']))
- # draw region extent
- self.DrawLines(pdc=self.pdcTmp, polycoords=self.regionCoords)
+ self.DrawCompRegionExtent()
# redraw pdcTmp if needed
if len(self.polycoords) > 0:
@@ -655,6 +642,49 @@
return True
+ def DrawCompRegionExtent(self):
+ """Draw computational region extent in the display
+ Display region is drawn as a blue box inside the computational region,
+ computational region inside a display region as a red box).
+ if hasattr(self, "regionCoords"):
+ compReg = self.Map.GetRegion()
+ dispReg = self.Map.GetCurrentRegion()
+ reg = None
+ if self.IsInRegion(dispReg, compReg):
+ self.polypen = wx.Pen(colour='blue', width=3, style=wx.SOLID)
+ reg = dispReg
+ else:
+ self.polypen = wx.Pen(colour='red', width=3, style=wx.SOLID)
+ reg = compReg
+ self.regionCoords = []
+ self.regionCoords.append((reg['w'], reg['n']))
+ self.regionCoords.append((reg['e'], reg['n']))
+ self.regionCoords.append((reg['e'], reg['s']))
+ self.regionCoords.append((reg['w'], reg['s']))
+ # draw region extent
+ self.DrawLines(pdc=self.pdcTmp, polycoords=self.regionCoords)
+ def IsInRegion(self, region, refRegion):
+ """Test if 'region' is inside of 'refRegion'
+ @param region input region
+ @param refRegion reference region (e.g. computational region)
+ @return True if region is inside of refRegion
+ @return False
+ if region['s'] >= refRegion['s'] and \
+ region['n'] <= refRegion['n'] and \
+ region['w'] >= refRegion['w'] and \
+ region['e'] <= refRegion['e']:
+ return True
+ return False
def EraseMap(self):
Erase the map display
@@ -2240,7 +2270,11 @@
self.showRegion.SetValue(False)
self.showRegion.Hide()
self.showRegion.SetToolTip(wx.ToolTip (_("Show/hide computational "
- "region extent (set with g.region)")))
+ "region extent (set with g.region). "
+ "Display region drawn as a blue box inside the "
+ "computational region, "
+ "computational region inside a display region "
+ "as a red box).")))
# map scale
self.mapScale = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
value="", style=wx.TE_PROCESS_ENTER,
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-30 14:48:26 UTC (rev 30815)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-03-30 15:48:00 UTC (rev 30816)
@@ -459,9 +459,13 @@
os.environ["GRASS_REGION"] = tmpreg
Debug.msg (3, "Map.GetRegion(): %s" % region)
return region
+ def GetCurrentRegion(self):
+ """Get current display region settings"""
+ return self.region
def SetRegion(self, windres=False):
Render string for GRASS_REGION env. variable, so that the images will be rendered
