[GRASS-SVN] r31197 - in grass/trunk/gui/wxpython: . gui_modules
Thu May 1 12:29:26 EDT 2008
Author: martinl
Date: 2008-05-01 12:29:26 -0400 (Thu, 01 May 2008)
New Revision: 31197
   grass/trunk/gui/wxpython/gui_modules/gcmd.py
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/gui_modules/menuform.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: OnRun/OnAbort command-related fixes (sync'ed with develbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py	2008-05-01 16:27:05 UTC (rev 31196)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py	2008-05-01 16:29:26 UTC (rev 31197)
@@ -494,6 +494,8 @@
         self.rerr   = ''
         self._want_abort = False
+        self.aborted = False
         self.startTime = None
         self.setDaemon(True)
@@ -502,7 +504,7 @@
         """Run command"""
         if len(self.cmd) == 0:
             return
         self.startTime = time.time()
         # TODO: wx.Exectute/wx.Process (?)
         try:
@@ -558,10 +560,11 @@
         while self.module.poll() is None:
             time.sleep(.1)
             if self._want_abort: # abort running process
+                self.module.kill()
+                self.aborted = True
                 if hasattr(self.stderr, "gmstc"):
-                    self.module.kill()
                     # -> GMConsole
-                    wx.PostEvent(self.stderr.gmstc.parent, ResultEvent(None))
+                    wx.PostEvent(self.stderr.gmstc.parent, ResultEvent(self))
                 return
             if self.stdout:
                 # line = self.__read_all(self.module.stdout)
@@ -587,10 +590,7 @@
             # -> GMConsole
-            if self._want_abort: # abort running process
-            else:
-                wx.PostEvent(self.stderr.gmstc.parent, ResultEvent(self))
     def abort(self):
         """Abort running process, used by main thread to signal an abort"""
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-05-01 16:27:05 UTC (rev 31196)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-05-01 16:29:26 UTC (rev 31197)
@@ -35,7 +35,7 @@
     Create and manage output console for commands entered on the
     GIS Manager command line.
-    def __init__(self, parent, id=wx.ID_ANY, margin=False,
+    def __init__(self, parent, id=wx.ID_ANY, margin=False, pageid=0,
                  pos=wx.DefaultPosition, size=wx.DefaultSize,
                  style=wx.TAB_TRAVERSAL | wx.FULL_REPAINT_ON_RESIZE):
         wx.Panel.__init__(self, parent, id, pos, size, style)
@@ -45,7 +45,8 @@
         self.parent          = parent # GMFrame
         self.cmdThreads      = {}     # cmdThread : cmdPID
         self.lineWidth       = 80
+        self.pageid          = pageid
         # progress bar
         self.console_progressbar = wx.Gauge(parent=self, id=wx.ID_ANY,
                                             range=100, pos=(110, 50), size=(-1, 25),
@@ -60,11 +61,13 @@
         ### sys.stdout = self.cmd_stdout
         self.cmd_stderr = GMStderr(self.cmd_output,
                                    self.console_progressbar,
-                                   self.parent.notebook)
+                                   self.parent.notebook,
+                                   pageid)
         if Debug.get_level() == 0:
             # don't redirect when debugging is enabled
             sys.stderr = self.cmd_stderr
         # buttons
         self.console_clear = wx.Button(parent=self, id=wx.ID_CLEAR)
         self.console_save  = wx.Button(parent=self, id=wx.ID_SAVE)
@@ -194,10 +197,11 @@
                                                        lcmd=cmdlist)
             else: # other GRASS commands (r|v|g|...)
-                if self.parent.notebook.GetSelection() != 1:
-                    # select 'Command output' tab
-                    self.parent.notebook.SetSelection(1)
+                if hasattr(self.parent, "curr_page"):
+                    # change notebook page only for Layer Manager
+                    if self.parent.notebook.GetSelection() != 1:
+                        self.parent.notebook.SetSelection(1)
                 # activate computational region (set with g.region)
                 # for all non-display commands.
                 tmpreg = os.getenv("GRASS_REGION")
@@ -224,9 +228,10 @@
         else:
             # Send any other command to the shell. Send output to
             # console output window
             print "$ " + ' '.join(cmdlist)
@@ -287,8 +292,10 @@
     def OnResult(self, event):
         """Show result status"""
-        if event.cmdThread is None:
+        if event.cmdThread.aborted:
             # Thread aborted (using our convention of None return)
+            self.WriteLog(_('Please note that the data are left in incosistent stage '
+                            'and can be corrupted'), self.cmd_output.StyleWarning)
             self.WriteCmdLog(_('Command aborted'),
                              pid=self.cmdThreads[event.cmdThread]['cmdPID'])
         else:
@@ -297,8 +304,14 @@
         self.console_progressbar.SetValue(0) # reset progress bar on '0%'
-        if hasattr(self.parent.parent, "btn_run"): # menuform.mainFrame
+        # updated command dialog
+        if hasattr(self.parent.parent, "btn_run"):
             dialog = self.parent.parent
+            if hasattr(self.parent.parent, "btn_abort"):
+                dialog.btn_abort.Enable(False)
             dialog.btn_run.Enable(True)
             if dialog.get_dcmd is None and \
                    dialog.closebox.IsChecked():
@@ -342,14 +355,17 @@
     Copyright: (c) 2005-2007 Jean-Michel Fauth
     Licence:   GPL
-    def __init__(self, gmstc, gmgauge, notebook):
+    def __init__(self, gmstc, gmgauge, notebook, pageid):
         self.gmstc    = gmstc
         self.gmgauge  = gmgauge
         self.notebook = notebook
     def write(self, s):
-        if self.notebook.GetSelection() != 1: # command output
-            self.notebook.SetSelection(1)
+        if self.pageid > -1:
+            # swith notebook page to 'command output'
+            if self.notebook.GetSelection() != self.pageid:
+                self.notebook.SetSelection(self.pageid)
         s = s.replace('\n', os.linesep)
         # remove/replace escape sequences '\b' or '\r' from stream
@@ -434,7 +450,7 @@
         wx.stc.StyledTextCtrl.__init__(self, parent, id)
         self.wrap = wrap
         # styles
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-05-01 16:27:05 UTC (rev 31196)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-05-01 16:29:26 UTC (rev 31197)
@@ -643,13 +643,13 @@
             self.btn_run.SetToolTipString(_("Run the command"))
             self.btn_run.SetDefault()
             # abort
-            btn_abort = wx.Button(parent=self.panel, id=wx.ID_STOP)
-            btn_abort.SetToolTipString(_("Abort the running command"))
+            self.btn_abort = wx.Button(parent=self.panel, id=wx.ID_STOP)
+            self.btn_abort.SetToolTipString(_("Abort the running command"))
             # copy
             btn_clipboard = wx.Button(parent=self.panel, id=wx.ID_COPY)
             btn_clipboard.SetToolTipString(_("Copy the current command string to the clipboard"))
-            btnsizer.Add(item=btn_abort, proportion=0,
+            btnsizer.Add(item=self.btn_abort, proportion=0,
                          flag=wx.ALL | wx.ALIGN_CENTER,
                          border=10)
@@ -662,7 +662,7 @@
                          border=10)
             self.btn_run.Bind(wx.EVT_BUTTON, self.OnRun)
-            btn_abort.Bind(wx.EVT_BUTTON, self.OnAbort)
+            self.btn_abort.Bind(wx.EVT_BUTTON, self.OnAbort)
             btn_clipboard.Bind(wx.EVT_BUTTON, self.OnCopy)
         guisizer.Add(item=btnsizer, proportion=0, flag=wx.ALIGN_CENTER)
@@ -741,6 +741,10 @@
         if cmd == [] or cmd == None:
             return
+        # change page if needed
+        if self.notebookpanel.notebook.GetSelection() != self.notebookpanel.goutput.pageid:
+            self.notebookpanel.notebook.SetSelection(self.notebookpanel.goutput.pageid)
         if cmd[0][0:2] != "d.":
             # Send any non-display command to parent window (probably wxgui.py)
             # put to parents
@@ -753,13 +757,10 @@
         else:
             gcmd.Command(cmd)
-        # if self.standalone:
-        # change page if needed
-        if self.notebookpanel.notebook.GetSelection() != self.notebookpanel.outpageid:
-            self.notebookpanel.notebook.SetSelection(self.notebookpanel.outpageid)
+        # update buttons status
+        self.btn_run.Enable(False)
+        self.btn_abort.Enable(True)
-        self.btn_run.Enable(False)
     def OnAbort(self, event):
         """Abort running command"""
         try:
@@ -767,6 +768,9 @@
         except IndexError:
             pass
+        self.btn_run.Enable(True)
+        self.btn_abort.Enable(False)
     def OnCopy(self, event):
         """Copy the command"""
         cmddata = wx.TextDataObject()
@@ -872,9 +876,9 @@
         # are we running from command line?
         ### add 'command output' tab regardless standalone dialog
         if self.parent.get_dcmd is None:
-            self.goutput = goutput.GMConsole(parent=self, margin=False)
+            self.goutput = goutput.GMConsole(parent=self, margin=False,
+                                             pageid=self.notebook.GetPageCount())
             self.outpage = self.notebook.AddPage(self.goutput, text=_("Command output") )
-            self.outpageid = self.notebook.GetPageCount() - 1
         else:
             self.goutput = None
@@ -883,7 +887,7 @@
         self.notebook.AddPage(self.manual_tab, text=_("Manual"))
         self.manual_tab_id = self.notebook.GetPageCount() - 1
-        self.notebook.SetSelection(0)
+        wx.CallAfter(self.notebook.SetSelection, 0)
         panelsizer.Add(item=self.notebook, proportion=1, flag=wx.EXPAND )
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-05-01 16:27:05 UTC (rev 31196)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-05-01 16:29:26 UTC (rev 31197)
@@ -48,9 +48,6 @@
 TREE_ITEM_HEIGHT = 25
-# define event for GRASS console (running GRASS command in separate thread)
-(UpdateGMConsoleEvent, EVT_UPDATE_GMCONSOLE) = wx.lib.newevent.NewEvent()
 class LayerTree(CT.CustomTreeCtrl):
     Creates layer tree structure
@@ -89,7 +86,8 @@
         # init associated map display
         self.mapdisplay = mapdisp.MapFrame(self,
-                                           id=wx.ID_ANY, pos=wx.DefaultPosition, size=(680, 520),
+                                           id=wx.ID_ANY, pos=wx.DefaultPosition,
+                                           size=globalvar.MAP_WINDOW_SIZE,
                                            style=wx.DEFAULT_FRAME_STYLE,
                                            tree=self, notebook=self.notebook,
                                            gismgr=self.gismgr, page=self.treepg,
@@ -1097,9 +1095,6 @@
         # item.SetHeight(TREE_ITEM_HEIGHT)
-    def setNotebookPage(self,pg):
-        self.parent.notebook.SetSelection(pg)
     def OnCloseWindow(self, event):
         pass
         # self.Map.Clean()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-05-01 16:27:05 UTC (rev 31196)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-05-01 16:29:26 UTC (rev 31197)
@@ -117,9 +117,8 @@
         self.encoding      = 'ISO-8859-1' # default encoding for display fonts
         self.workspaceFile = workspace    # workspace file
         self.menucmd       = {}           # menuId / cmd
-        self.georectifying = False        # says whether we're running the georectifier
-        self.gr            = ""           # ID of georectify instance
+        self.georectifying = None         # reference to GCP class or None
         # creating widgets
         # -> self.notebook, self.goutput, self.outpage
         self.notebook  = self.__createNoteBook()
@@ -294,7 +293,7 @@
         self.notebook.AddPage(self.gm_cb, text=_("Map layers for each display"))
         # create command output text area and add it to main notebook page
-        self.goutput = goutput.GMConsole(self)
+        self.goutput = goutput.GMConsole(self, pageid=1)
         self.outpage = self.notebook.AddPage(self.goutput, text=_("Command output"))
         # bingings
@@ -341,8 +340,7 @@
         Launch georectifier module
-        self.gr = georect.GeorectWizard(self)
-        self.georectifying = True
+        georect.GeorectWizard(self)
     def OnMapsets(self, event):
@@ -1425,9 +1423,6 @@
         # show map display
         self.curr_page.maptree.mapdisplay.Show()
-    def GetSelectedDisplay(self):
-        return self.notebook.GetSelection()
     def OnDeleteLayer(self, event):
         Delete selected map display layer in GIS Manager tree widget
