[GRASS-SVN] r31200 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Thu May 1 17:32:45 EDT 2008
Author: martinl
Date: 2008-05-01 17:32:45 -0400 (Thu, 01 May 2008)
New Revision: 31200
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: MS Windows related fixes (spaces in database path)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-05-01 16:52:40 UTC (rev 31199)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-05-01 21:32:45 UTC (rev 31200)
@@ -3030,16 +3030,22 @@
# list of available layers & (table, database, driver)
for line in layerCommand.ReadStdOutput():
lineList = line.split(' ')
- if '/' in lineList[0]:
- lineList[0], layer_name = lineList[0].split('/')
+ layer = lineList[0]
+ if '/' in layer:
+ layer, layer_name = lineList[0].split('/')
else:
layer_name = None
- self.layers[int(lineList[0])] = {
+ # database can contain ' ' in it's path
+ if len(lineList) > 5:
+ database = ''.join(lineList[3:-1])
+ else:
+ database = lineList[3]
+ self.layers[int(layer)] = {
"name" : layer_name,
"table" : lineList[1],
"key" : lineList[2],
- "database" : lineList[3],
- "driver" : lineList[4]
+ "database" : database,
+ "driver" : lineList[-1]
if (len(self.layers.keys()) == 0):
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2008-05-01 16:52:40 UTC (rev 31199)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2008-05-01 21:32:45 UTC (rev 31200)
@@ -580,8 +580,11 @@
file = open(filename, "r")
fileStream = ''.join(file.readlines())
- p = re.compile( '(grass-gxw.dtd)')
+ p = re.compile('(grass-gxw.dtd)')
p.search(fileStream)
+ if subprocess.mswindows:
+ # FIXME mixing '\' and '/' causes error in p.sub
+ dtdFilename = dtdFilename.replace("\\", "/")
fileStream = p.sub(dtdFilename, fileStream)
# sax
