[GRASS-SVN] r31206 - grass/branches/develbranch_6/raster/r.composite
svn_grass at osgeo.org
Fri May 2 11:02:57 EDT 2008
Author: martinl
Date: 2008-05-02 11:02:57 -0400 (Fri, 02 May 2008)
New Revision: 31206
grass/branches/develbranch_6/raster/r.composite/main.c
r.composite: message cosmetics
Modified: grass/branches/develbranch_6/raster/r.composite/main.c
--- grass/branches/develbranch_6/raster/r.composite/main.c 2008-05-02 12:52:08 UTC (rev 31205)
+++ grass/branches/develbranch_6/raster/r.composite/main.c 2008-05-02 15:02:57 UTC (rev 31206)
@@ -68,10 +68,10 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("raster");
- module->description =
- _("Combines red, green and blue map layers into "
- "a single composite map layer.");
+ module->keywords = _("raster, composite");
+ module->description =
+ _("Combines red, green and blue map layers into "
+ "a single composite raster map.");
for (i = 0; i < 3; i++)
@@ -120,11 +120,7 @@
opt->description= G_store(buff);
- opt_out = G_define_option();
- opt_out->key = "output";
- opt_out->type = TYPE_STRING;
- opt_out->required = YES;
- opt_out->gisprompt = "new,cell,raster";
+ opt_out = G_define_standard_option(G_OPT_R_OUTPUT);
opt_out->description= _("Name of raster map to contain results");
flg_d = G_define_flag();
@@ -204,6 +200,8 @@
/* Make color table */
make_color_cube(&out_colors);
+ G_message(_("Writing raster map <%s>..."), out_name);
for (atrow = 0; atrow < window.rows; atrow++)
G_percent(atrow, window.rows, 2);
@@ -218,7 +216,7 @@
b->array[1],
b->array[2],
nulls) < 0)
- G_fatal_error(_("Error reading '%s' map"), color_names[i]);
+ G_fatal_error(_("Error reading raster map <%s>"), color_names[i]);
if (dither)
@@ -272,7 +270,7 @@
if(G_put_raster_row(out_file, out_array, CELL_TYPE) < 0)
- G_fatal_error(_("G_put_raster_row failed (file system full?)"));
+ G_fatal_error(_("Failed writing raster map <%s>"), out_name);
G_percent(window.rows, window.rows, 5);
@@ -288,6 +286,7 @@
G_command_history(&history);
G_write_history(out_name, &history);
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
@@ -312,6 +311,8 @@
G_init_colors(colors);
+ G_message(_("Creating color table for output raster map..."));
for (b = 0; b < nb; b++)
G_percent(b, nb, 5);
