[GRASS-SVN] r31218 - grass-addons/raster/r.inund.fluv
svn_grass at osgeo.org
Fri May 2 18:13:29 EDT 2008
Author: neteler
Date: 2008-05-02 18:13:29 -0400 (Fri, 02 May 2008)
New Revision: 31218
Added:
grass-addons/raster/r.inund.fluv/Makefile
new Makefile added
Added: grass-addons/raster/r.inund.fluv/Makefile
--- grass-addons/raster/r.inund.fluv/Makefile (rev 0)
+++ grass-addons/raster/r.inund.fluv/Makefile 2008-05-02 22:13:29 UTC (rev 31218)
@@ -0,0 +1,29 @@
+MODULE_TOPDIR = ../..
+PGM = r.inund.fluv
+include $(MODULE_TOPDIR)/include/Make/Module.make
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: DIR $(ETC)/fortran_code/$(PGM) html
+DIR:
+ mkdir -p $(ETC)/fortran_code/
+$(ETC)/fortran_code/$(PGM): $(OBJ)
+ gfortran -O1 -o find_main_channel find_main_channel.f90
+ gfortran -O1 -o clean_inundation clean_inundation.f90
+ gfortran -O1 -o 2d_path 2d_path.f90
+ gfortran -O1 -o correction_from_path correction_from_path.f90
+ $(INSTALL) find_main_channel$(EXE) $(ETC)/fortran_code
+ $(INSTALL) clean_inundation$(EXE) $(ETC)/fortran_code
+ $(INSTALL) 2d_path$(EXE) $(ETC)/fortran_code
+ $(INSTALL) correction_from_path$(EXE) $(ETC)/fortran_code
+ $(INSTALL) $(PGM) $(SCRIPT)
+html:
+ $(MKDIR) $(GISBASE)/docs/html
+ $(INSTALL_DATA) $(PGM).html $(GISBASE)/docs/html/
+clean:
+ -rm -f find_main_channel$(EXE) clean_inundation$(EXE) 2d_path$(EXE) correction_from_path$(EXE) dati.mod dd.mod
Property changes on: grass-addons/raster/r.inund.fluv/Makefile
___________________________________________________________________
+ native
