[GRASS-SVN] r31220 - in grass-addons/gipe: i.evapo.SENAY i.evapo.potrad
Sat May 3 05:29:28 EDT 2008
Author: ychemin
Date: 2008-05-03 05:29:28 -0400 (Sat, 03 May 2008)
New Revision: 31220
   grass-addons/gipe/i.evapo.SENAY/et_pot_day.c
   grass-addons/gipe/i.evapo.SENAY/main.c
   grass-addons/gipe/i.evapo.potrad/description.html
Updated i.evapo.SENAY with new code for generic longwave energy balance
Modified: grass-addons/gipe/i.evapo.SENAY/et_pot_day.c
--- grass-addons/gipe/i.evapo.SENAY/et_pot_day.c	2008-05-02 22:45:49 UTC (rev 31219)
+++ grass-addons/gipe/i.evapo.SENAY/et_pot_day.c	2008-05-03 09:29:28 UTC (rev 31220)
@@ -4,12 +4,12 @@
 // Average Diurnal Potential ET after Bastiaanssen (1995)
-double et_pot_day( double bbalb, double solar, double tempk, double tsw, double roh_w )
+double et_pot_day( double rnetd, double tempk, double roh_w )
 	double latent, result;
 	latent=(2.501-(0.002361*(tempk-273.15)))*1000000.0;
-	result = ((((1.0 - bbalb)*solar)-(110.0*tsw))*86400*1000.0)/(latent*roh_w);
+	result = (rnetd*86400*1000.0)/(latent*roh_w);
 	return result;
Modified: grass-addons/gipe/i.evapo.SENAY/main.c
--- grass-addons/gipe/i.evapo.SENAY/main.c	2008-05-02 22:45:49 UTC (rev 31219)
+++ grass-addons/gipe/i.evapo.SENAY/main.c	2008-05-03 09:29:28 UTC (rev 31220)
@@ -21,7 +21,9 @@
 double solar_day(double lat, double doy, double tsw );
 double solar_day_3d(double lat, double doy, double tsw, double slope, double aspect);
-double et_pot_day( double bbalb, double solar, double tempk, double tsw, double roh_w );
+double r_net_day( double bbalb, double solar, double tsw );
+double r_net_day_bandara98( double surface_albedo, double solar_day, double apparent_atm_emissivity, double surface_emissivity, double air_temperature );
+double et_pot_day( double rnetd, double tempk, double roh_w );
 double evapfr_senay( double t_hot, double t_cold, double tempk);
 int main(int argc, char *argv[])
@@ -34,11 +36,12 @@
 	struct GModule *module;
 	struct Option *input1, *input2, *input3, *input4;
 	struct Option *input5, *input6, *input7, *input8, *input9;
+	struct Option *input10, *input11, *input12;
 	struct Option *output1, *output2;
-	struct Flag *flag1, *flag2, *flag3;
+	struct Flag *flag2, *flag3;
 	struct History history; //metadata
+	struct Colors colors; //Color rules
 	/* FMEO Declarations*****************/
 	char *name;   // input raster name
@@ -47,18 +50,21 @@
 	int infd_albedo, infd_tempk, infd_dem;
 	int infd_lat, infd_doy, infd_tsw;
 	int infd_slope, infd_aspect;
+	int infd_tair, infd_e0;
 	int outfd1, outfd2;
-	char *albedo,*tempk,*dem,*lat,*doy,*tsw,*slope,*aspect;
-	double roh_w;
+	char *albedo,*tempk,*dem,*lat,*doy,*tsw;
+	char *slope,*aspect,*tair,*e0;
+	double roh_w, e_atm;
 	int i=0,j=0;
 	void *inrast_albedo, *inrast_tempk;
 	void *inrast_dem, *inrast_lat;
 	void *inrast_doy, *inrast_tsw;
 	void *inrast_slope, *inrast_aspect;
+	void *inrast_tair, *inrast_e0;
-	unsigned char *outrast1, *outrast2;
+	DCELL *outrast1, *outrast2;
 	RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
 	RASTER_MAP_TYPE data_type_albedo;
 	RASTER_MAP_TYPE data_type_tempk;
@@ -68,6 +74,8 @@
 	RASTER_MAP_TYPE data_type_tsw;
 	RASTER_MAP_TYPE data_type_slope;
 	RASTER_MAP_TYPE data_type_aspect;
+	RASTER_MAP_TYPE data_type_tair;
+	RASTER_MAP_TYPE data_type_e0;
 	/* Stats for Senay equation	*/
 	double t0dem_min=400.0,t0dem_max=200.0;
@@ -84,31 +92,37 @@
 	input1->key	   = _("albedo");
 	input1->description=_("Name of the Albedo map [0.0-1.0]");
 	input1->answer     =_("albedo");
+	input1->guisection = _("Required");
 	input2 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input2->key        =_("tempk");
 	input2->description=_("Name of the temperature map [Degree Kelvin]");
 	input2->answer     =_("tempk");
+	input2->guisection = _("Required");
 	input3 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input3->key        =_("dem");
 	input3->description=_("Name of the elevation map [m]");
 	input3->answer     =_("dem");
+	input3->guisection = _("Required");
 	input4 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input4->key        =_("lat");
 	input4->description=_("Name of the degree latitude map [dd.ddd]");
 	input4->answer     =_("lat");
+	input4->guisection = _("Required");
 	input5 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input5->key        =_("doy");
 	input5->description=_("Name of the Day of Year map [0.0-366.0]");
 	input5->answer     =_("doy");
+	input5->guisection = _("Required");
 	input6 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input6->key        =_("tsw");
 	input6->description=_("Name of the single-way transmissivity map [0.0-1.0]");
 	input6->answer     =_("tsw");
+	input6->guisection = _("Required");
 	input7 = G_define_option() ;
 	input7->key        =_("roh_w");
@@ -116,36 +130,61 @@
 	input7->required   = YES;
 	input7->gisprompt  =_("value, parameter");
 	input7->description=_("Value of the density of fresh water ~[1000-1020]");
-	input7->answer     =_("1010.0");
+	input7->answer     =_("1005.0");
+	input7->guisection = _("Required");
 	input8 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input8->key        =_("slope");
 	input8->required   = NO;
 	input8->description=_("Name of the Slope map ~[0-90]");
+	input8->guisection = _("Optional");
 	input9 = G_define_standard_option(G_OPT_R_INPUT) ;
 	input9->key        =_("aspect");
 	input9->required   = NO;
 	input9->description=_("Name of the Aspect map ~[0-360]");
+	input9->guisection = _("Optional");
+	input10 = G_define_option() ;
+	input10->key        =_("e_atm");
+	input10->type       = TYPE_DOUBLE;
+	input10->required   = NO;
+	input10->gisprompt  =_("value, parameter");
+	input10->description=_("Value of the apparent atmospheric emissivity (Bandara, 1998 used 0.845 for Sri Lanka)");
+	input10->answer     =_("0.845");
+	input10->guisection = _("Optional");
+	input11 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input11->key        =_("t_air");
+	input11->required   = NO;
+	input11->description=_("Name of the Air Temperature map [Kelvin], use with -b");
+	input11->guisection = _("Optional");
+	input12 = G_define_standard_option(G_OPT_R_INPUT) ;
+	input12->key        =_("e0");
+	input12->required   = NO;
+	input12->description=_("Name of the Surface Emissivity map [-], use with -b");
+	input12->guisection = _("Optional");
 	output1 = G_define_standard_option(G_OPT_R_OUTPUT) ;
 	output1->key        =_("eta");
 	output1->description=_("Name of the output Actual ET layer");
 	output1->answer     =_("eta");
+	output1->guisection = _("Required");
 	output2 = G_define_standard_option(G_OPT_R_OUTPUT) ;
 	output2->key        =_("evapfr");
 	output2->required   = NO;
 	output2->description=_("Name of the output evaporative fraction layer");
+	output2->guisection = _("Optional");
-	flag1 = G_define_flag();
-	flag1->key = 's';
-	flag1->description = _("Output evaporative fraction after Senay (2007)");
 	flag2 = G_define_flag();
 	flag2->key = 'd';
 	flag2->description = _("Slope/Aspect correction");
+	flag3 = G_define_flag();
+	flag3->key = 'b';
+	flag3->description = _("Net Radiation Bandara (1998), generic Longwave calculation, need apparent atmospheric emissivity, Air temperature and surface emissivity inputs");
 	if (G_parser(argc, argv))
 		exit (EXIT_FAILURE);
@@ -159,6 +198,9 @@
 	roh_w	 	= atof(input7->answer);
 	slope	 	= input8->answer;
 	aspect	 	= input9->answer;
+	e_atm	 	= atof(input10->answer);
+	tair	 	= input11->answer;
+	e0	 	= input12->answer;
 	result1  = output1->answer;
 	result2  = output2->answer;
@@ -255,6 +297,32 @@
 		inrast_aspect = G_allocate_raster_buf(data_type_aspect);
+	if(flag3->answer){
+		mapset = G_find_cell2 (tair, "");
+		if (mapset == NULL) {
+			G_fatal_error(_("Cell file [%s] not found"), tair);
+		data_type_tair = G_raster_map_type(tair,mapset);
+		if ( (infd_tair = G_open_cell_old (tair,mapset)) < 0)
+			G_fatal_error(_("Cannot open cell file [%s]"), tair);
+		if (G_get_cellhd (tair, mapset, &cellhd) < 0)
+			G_fatal_error(_("Cannot read file header of [%s]"), tair);
+		inrast_tair = G_allocate_raster_buf(data_type_tair);
+		mapset = G_find_cell2 (e0, "");
+			G_fatal_error(_("Cell file [%s] not found"), e0);
+		data_type_e0 = G_raster_map_type(e0,mapset);
+		if ( (infd_e0 = G_open_cell_old (e0,mapset)) < 0)
+			G_fatal_error(_("Cannot open cell file [%s]"), e0);
+		if (G_get_cellhd (e0, mapset, &cellhd) < 0)
+			G_fatal_error(_("Cannot read file header of [%s]"), e0);
+		inrast_e0 = G_allocate_raster_buf(data_type_e0);
 	G_debug(3, "number of rows %d",cellhd.rows);
 	nrows = G_window_rows();
 	ncols = G_window_cols();
@@ -320,12 +388,9 @@
 					d_dem = (double) ((DCELL *) inrast_dem)[col];
 					break;
-			if(G_is_d_null_value(&d_albedo)){
+			if(G_is_d_null_value(&d_albedo)||G_is_d_null_value(&d_tempk)
+			||G_is_d_null_value(&d_dem)){
 				/* do nothing */
-			} else if(G_is_d_null_value(&d_tempk)){
-				/* do nothing */
-			} else if(G_is_d_null_value(&d_dem)){
-				/* do nothing */
 			} else {
 				d_t0dem = d_tempk + 0.00649*d_dem;
 				if(d_t0dem<0.0||d_albedo<0.001){
@@ -359,6 +424,8 @@
 		DCELL d_rnetd;
 		DCELL d_slope;
 		DCELL d_aspect;
+		DCELL d_tair;
+		DCELL d_e0;
 		DCELL d_etpotd;
 		DCELL d_evapfr;
 		G_percent(row,nrows,2);
@@ -379,6 +446,12 @@
 			if(G_get_raster_row(infd_aspect,inrast_aspect,row,data_type_aspect)<0)
 				G_fatal_error(_("Could not read from <%s>"),aspect);
+			if(G_get_raster_row(infd_tair,inrast_tair,row,data_type_tair)<0)
+				G_fatal_error(_("Could not read from <%s>"),tair);
+			if(G_get_raster_row(infd_e0,inrast_e0,row,data_type_e0)<0)
+				G_fatal_error(_("Could not read from <%s>"),e0);
 		/*process the data */
 		for (col=0; col < ncols; col++)
@@ -461,38 +534,40 @@
 						break;
-				((DCELL *) outrast1)[col] = -999.99;
+				switch(data_type_tair){
+					case CELL_TYPE:
+						d_tair = (double) ((CELL *) inrast_tair)[col];
+						break;
+					case FCELL_TYPE:
+						d_tair = (double) ((FCELL *) inrast_tair)[col];
+						break;
+					case DCELL_TYPE:
+						d_tair = (double) ((DCELL *) inrast_tair)[col];
+						break;
+				switch(data_type_e0){
+					case CELL_TYPE:
+						d_e0 = (double) ((CELL *) inrast_e0)[col];
+						break;
+					case FCELL_TYPE:
+						d_e0 = (double) ((FCELL *) inrast_e0)[col];
+						break;
+					case DCELL_TYPE:
+						d_e0 = (double) ((DCELL *) inrast_e0)[col];
+						break;
+			||d_tempk<10.0||G_is_d_null_value(&d_lat)||
+			G_is_d_null_value(&d_doy)||G_is_d_null_value(&d_tsw)||
+			((flag2->answer)&&G_is_d_null_value(&d_slope))||
+			((flag2->answer)&&G_is_d_null_value(&d_aspect))||
+			((flag3->answer)&&G_is_d_null_value(&d_tair))||
+			((flag3->answer)&&G_is_d_null_value(&d_e0))){
+				G_set_d_null_value(&outrast1[col],1);
 				if (result2)
-				((DCELL *) outrast2)[col] = -999.99;
-			}else if(G_is_d_null_value(&d_tempk)){
-				if (result2)
-			}else if(d_tempk<10.0){
-				if (result2)
-			}else if(G_is_d_null_value(&d_lat)){
-				if (result2)
-			}else if(G_is_d_null_value(&d_doy)){
-				if (result2)
-			}else if(G_is_d_null_value(&d_tsw)){
-				if (result2)
-			}else if((flag2->answer)&&G_is_d_null_value(&d_slope)){
-				if (result2)
-			}else if((flag2->answer)&&G_is_d_null_value(&d_aspect)){
-				if (result2)
+					G_set_d_null_value(&outrast2[col],1);
 			}else {
 				if(flag2->answer){
 					d_solar = solar_day_3d(d_lat,d_doy,d_tsw,d_slope,d_aspect);
@@ -501,11 +576,17 @@
 				d_evapfr = evapfr_senay( tempk_max, tempk_min, d_tempk);
 				if(result2){
-					((DCELL *) outrast2)[col] = d_evapfr;
+					outrast2[col] = d_evapfr;
-				d_etpotd = et_pot_day(d_albedo,d_solar,d_tempk,d_tsw,roh_w);
+					d_rnetd = r_net_day_bandara98(d_albedo,d_solar,e_atm,d_e0,d_tair);
+				} else {
+					d_rnetd = r_net_day(d_albedo,d_solar,d_tsw);
+				d_etpotd = et_pot_day(d_rnetd,d_tempk,roh_w);
+				d_etpotd *= d_tsw;
 				d = d_etpotd * d_evapfr;
-				((DCELL *) outrast1)[col] = d;
+				outrast1[col] = d;
 		if (G_put_raster_row (outfd1, outrast1, data_type_output) < 0)
@@ -529,9 +610,19 @@
 	G_close_cell (infd_doy);
 	G_close_cell (infd_tsw);
+	if (flag3->answer){
+		G_free (inrast_tair);
+		G_close_cell (infd_tair);
+		G_free (inrast_e0);
+		G_close_cell (infd_e0);
 	G_free (outrast1);
 	G_close_cell (outfd1);
 	if (result2){
+		/* Color table for evaporative fraction */
+		G_init_colors(&colors);
+		G_add_color_rule(0,0,0,0,1,255,255,255,&colors);
 		G_free (outrast2);
 		G_close_cell (outfd2);
 		G_short_history(result2, "raster", &history);
@@ -539,6 +630,9 @@
 		G_write_history(result2,&history);
+	/* Color table for evapotranspiration */
+	G_add_color_rule(0,0,0,0,10,255,255,255,&colors);
 	G_short_history(result1, "raster", &history);
 	G_command_history(&history);
 	G_write_history(result1,&history);
Modified: grass-addons/gipe/i.evapo.potrad/description.html
--- grass-addons/gipe/i.evapo.potrad/description.html	2008-05-02 22:45:49 UTC (rev 31219)
+++ grass-addons/gipe/i.evapo.potrad/description.html	2008-05-03 09:29:28 UTC (rev 31220)
@@ -2,12 +2,18 @@
 <EM>i.evapo.potrad</EM> Calculates the diurnal potential evapotranspiration after bastiaanssen (1995). This is converting all Net radiation from the diurnal period into ET.
 It takes input maps of Albedo, surface skin temperature, latitude, day of year, single-way transmissivity and takes input value of the density of fresh water.
 The "-r" flag permits output map of Diurnal net radiation to use in r.eb.eta.
+The "-b" flag permits a generic longwave balance calculation from surface emissivity, Air Temperature and a value of apparent atmospheric emissivity.
+The "-d" flag is a slope/aspect correction, not really tested, reports and tests are most welcome.
 <H2>NOTES</H2>
 <H2>TODO</H2>
+Slope/aspect correction to be screened and tested by somebody in the known.
 <H2>SEE ALSO</H2>
 <em>
@@ -19,8 +25,8 @@
 <H2>AUTHORS</H2>
-Yann Chemin, Asian Institute of Technology, Thailand<BR>
+Yann Chemin, International Rice Research Institute, The Philippines<BR>
 <p>
-<i>Last changed: $Date: 2006/10/12 11:58:15 $</i>
+<i>Last changed: $Date: 2008/05/02 11:58:15 $</i>
