[GRASS-SVN] r31232 - grass/trunk/raster/r.slope.aspect
svn_grass at osgeo.org
Sat May 3 07:07:43 EDT 2008
Author: martinl
Date: 2008-05-03 07:07:43 -0400 (Sat, 03 May 2008)
New Revision: 31232
grass/trunk/raster/r.slope.aspect/main.c
grass/trunk/raster/r.slope.aspect/opennew.c
r.slope.aspect: message cleaning, i18n (sync'ed with develbr6)
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c 2008-05-03 11:04:06 UTC (rev 31231)
+++ grass/trunk/raster/r.slope.aspect/main.c 2008-05-03 11:07:43 UTC (rev 31232)
@@ -147,18 +147,13 @@
G_gisinit (argv[0]);
module = G_define_module();
- module->keywords = _("raster");
+ module->keywords = _("raster, terrain analysis");
module->description =
_("Generates raster map layers of slope, aspect, curvatures and "
"partial derivatives from a raster map layer of true elevation "
"values. Aspect is calculated counterclockwise from east.");
- parm.elevation = G_define_option() ;
- parm.elevation->key = "elevation" ;
- parm.elevation->type = TYPE_STRING ;
- parm.elevation->required = YES ;
- parm.elevation->gisprompt = "old,cell,raster" ;
- parm.elevation->description= _("Raster elevation file name");
+ parm.elevation = G_define_standard_option(G_OPT_R_ELEV) ;
parm.slope = G_define_option() ;
parm.slope->key = "slope" ;
@@ -166,7 +161,7 @@
parm.slope->required = NO ;
parm.slope->answer = NULL ;
parm.slope->gisprompt = "new,cell,raster" ;
- parm.slope->description= _("Output slope filename") ;
+ parm.slope->description= _("Name for output slope raster map") ;
parm.aspect = G_define_option() ;
parm.aspect->key = "aspect" ;
@@ -174,7 +169,7 @@
parm.aspect->required = NO ;
parm.aspect->answer = NULL ;
parm.aspect->gisprompt = "new,cell,raster" ;
- parm.aspect->description= _("Output aspect filename") ;
+ parm.aspect->description= _("Name for output aspect raster map") ;
parm.slope_fmt = G_define_option() ;
parm.slope_fmt->key = "format" ;
@@ -200,7 +195,7 @@
parm.pcurv->required = NO ;
parm.pcurv->answer = NULL ;
parm.pcurv->gisprompt = "new,cell,raster" ;
- parm.pcurv->description= _("Output profile curvature filename" );
+ parm.pcurv->description= _("Name for output profile curvature raster map" );
parm.pcurv->guisection = _("Advanced");
parm.tcurv = G_define_option() ;
@@ -209,7 +204,7 @@
parm.tcurv->required = NO ;
parm.tcurv->answer = NULL ;
parm.tcurv->gisprompt = "new,cell,raster" ;
- parm.tcurv->description= _("Output tangential curvature filename") ;
+ parm.tcurv->description= _("Name for output tangential curvature raster map") ;
parm.tcurv->guisection = _("Advanced");
parm.dx = G_define_option() ;
@@ -218,7 +213,7 @@
parm.dx->required = NO ;
parm.dx->answer = NULL ;
parm.dx->gisprompt = "new,cell,raster" ;
- parm.dx->description= _("Output first order partial derivative dx (E-W slope) filename") ;
+ parm.dx->description= _("Name for output first order partial derivative dx (E-W slope) raster map") ;
parm.dx->guisection = _("Advanced");
parm.dy = G_define_option() ;
@@ -227,7 +222,7 @@
parm.dy->required = NO ;
parm.dy->answer = NULL ;
parm.dy->gisprompt = "new,cell,raster" ;
- parm.dy->description= _("Output first order partial derivative dy (N-S slope) filename") ;
+ parm.dy->description= _("Name for output first order partial derivative dy (N-S slope) raster map") ;
parm.dy->guisection = _("Advanced");
parm.dxx = G_define_option() ;
@@ -236,7 +231,7 @@
parm.dxx->required = NO ;
parm.dxx->answer = NULL ;
parm.dxx->gisprompt = "new,cell,raster" ;
- parm.dxx->description= _("Output second order partial derivative dxx filename") ;
+ parm.dxx->description= _("Name for output second order partial derivative dxx raster map") ;
parm.dxx->guisection = _("Advanced");
parm.dyy = G_define_option() ;
@@ -245,7 +240,7 @@
parm.dyy->required = NO ;
parm.dyy->answer = NULL ;
parm.dyy->gisprompt = "new,cell,raster" ;
- parm.dyy->description= _("Output second order partial derivative dyy filename") ;
+ parm.dyy->description= _("Name for output second order partial derivative dyy raster map") ;
parm.dyy->guisection = _("Advanced");
parm.dxy = G_define_option() ;
@@ -254,7 +249,7 @@
parm.dxy->required = NO ;
parm.dxy->answer = NULL ;
parm.dxy->gisprompt = "new,cell,raster" ;
- parm.dxy->description= _("Output second order partial derivative dxy filename") ;
+ parm.dxy->description= _("Name for output second order partial derivative dxy raster map") ;
parm.dxy->guisection = _("Advanced");
parm.zfactor = G_define_option();
@@ -329,18 +324,14 @@
if (sscanf (parm.zfactor->answer, "%lf", &zfactor) != 1 || zfactor <= 0.0)
- G_warning("%s=%s - must be a postive number", parm.zfactor->key,
- parm.zfactor->answer);
- G_usage();
- exit(EXIT_FAILURE);
+ G_fatal_error(_("%s=%s - must be a positive number"), parm.zfactor->key,
+ parm.zfactor->answer);
if (sscanf (parm.min_slp_allowed->answer, "%lf", &min_slp_allowed) != 1 || min_slp_allowed < 0.0)
- G_warning("%s=%s - must be a non-negative number", parm.min_slp_allowed->key,
- parm.min_slp_allowed->answer);
- G_usage();
+ G_fatal_error(_("%s=%s - must be a non-negative number"), parm.min_slp_allowed->key,
+ parm.min_slp_allowed->answer);
slope_fmt = parm.slope_fmt->answer;
@@ -352,13 +343,11 @@
&& dx_name == NULL && dy_name == NULL
&& dxx_name == NULL && dyy_name == NULL && dxy_name == NULL)
- G_warning("You must specify at least one of the parameters:"
- "\n<%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>.\n",
- parm.slope->key, parm.aspect->key, parm.pcurv->key,
- parm.tcurv->key, parm.dx->key, parm.dy->key,
- parm.dxx->key, parm.dyy->key, parm.dxy->key);
- G_usage();
+ G_fatal_error(_("You must specify at least one of the parameters: "
+ "<%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"),
+ parm.slope->key, parm.aspect->key, parm.pcurv->key,
+ parm.tcurv->key, parm.dx->key, parm.dy->key,
+ parm.dxx->key, parm.dyy->key, parm.dxy->key);
/* check elevation file existence */
@@ -386,7 +375,7 @@
else if(strcmp(parm.out_precision->answer, "default") == 0)
out_type = -1;
else
- G_fatal_error(_("wrong type: %s"), parm.out_precision->answer);
+ G_fatal_error(_("Wrong raster type: %s"), parm.out_precision->answer);
data_type = out_type;
if(data_type < 0) data_type = DCELL_TYPE;
@@ -415,7 +404,7 @@
/* give warning if location units are different from meters and zfactor=1*/
factor = G_database_units_to_meters_factor();
if (factor != 1.0)
- G_warning("Converting units to meters, factor=%.6f", factor);
+ G_warning(_("Converting units to meters, factor=%.6f"), factor);
G_begin_distance_calculations();
north = G_row_to_northing(0.5, &window);
@@ -590,7 +579,8 @@
else G_get_d_raster_row_nomask (elevation_fd, elev_cell[2],1);
- G_message (_("Percent complete: "));
+ G_verbose_message (_("Percent complete..."));
for (row = 2; row < nrows; row++)
/* if projection is Lat/Lon, recalculate V and H */
@@ -1016,10 +1006,10 @@
G_percent (row, nrows, 2);
G_close_cell (elevation_fd);
- G_message(_("Creating support files..."));
+ G_debug(1, "Creating support files...");
- G_message(_("Elevation products for mapset [%s] in [%s]"),
- G_mapset(), G_location());
+ G_verbose_message(_("Elevation products for mapset <%s> in <%s>"),
+ G_mapset(), G_location());
if (aspect_fd >= 0)
@@ -1036,7 +1026,7 @@
G_read_raster_cats (aspect_name, G_mapset(), &cats);
G_set_raster_cats_title ("Aspect counterclockwise in degrees from east", &cats);
- G_message(_("Min computed aspect %.4f, max computed aspect %.4f"), min_asp, max_asp);
+ G_verbose_message(_("Min computed aspect %.4f, max computed aspect %.4f"), min_asp, max_asp);
/* the categries quant intervals are 1.0 long, plus
we are using reverse order so that the label looked up
for i-.5 is not the one defined for i-.5, i+.5 interval, but
@@ -1089,7 +1079,7 @@
hist.edlinecnt = 3;
G_write_history (aspect_name, &hist);
- G_message(_("ASPECT [%s] COMPLETE"), aspect_name);
+ G_message(_("Aspect raster map <%s> complete"), aspect_name);
if (slope_fd >= 0)
@@ -1129,7 +1119,7 @@
if(deg) G_set_raster_cats_title ("slope in degrees", &cats);
else if(perc) G_set_raster_cats_title ("percent slope", &cats);
- G_message(_("Min computed slope %.4f, max computed slope %.4f"), min_slp, max_slp);
+ G_verbose_message(_("Min computed slope %.4f, max computed slope %.4f"), min_slp, max_slp);
@@ -1179,7 +1169,7 @@
hist.edlinecnt = 3;
G_write_history (slope_name, &hist);
- G_message(_("SLOPE [%s] COMPLETE"), slope_name);
+ G_message(_("Slope raster map <%s> complete"), slope_name);
/* colortable for curvatures */
@@ -1248,7 +1238,7 @@
hist.edlinecnt = 3;
G_write_history (pcurv_name, &hist);
- G_message(_("PROFILE CURVE [%s] COMPLETE"), pcurv_name);
+ G_message(_("Profile curve raster map <%s> complete"), pcurv_name);
if (tcurv_fd >= 0)
@@ -1275,7 +1265,7 @@
hist.edlinecnt = 3;
G_write_history (tcurv_name, &hist);
- G_message(_("TANGENTIAL CURVE [%s] COMPLETE"), tcurv_name);
+ G_message(_("Tangential curve raster map <%s> complete"), tcurv_name);
if (dx_fd >= 0)
@@ -1300,7 +1290,7 @@
hist.edlinecnt = 3;
G_write_history (dx_name, &hist);
- G_message(_("E-W SLOPE [%s] COMPLETE"), dx_name);
+ G_message(_("E-W slope raster map <%s> complete"), dx_name);
if (dy_fd >= 0)
@@ -1325,7 +1315,7 @@
hist.edlinecnt = 3;
G_write_history (dy_name, &hist);
- G_message(_("N-S SLOPE [%s] COMPLETE"), dy_name);
+ G_message(_("N-S slope raster map <%s> complete"), dy_name);
if (dxx_fd >= 0)
@@ -1350,7 +1340,7 @@
hist.edlinecnt = 3;
G_write_history (dxx_name, &hist);
- G_message(_("DXX [%s] COMPLETE"), dxx_name);
+ G_message(_("Dxx raster map <%s> complete"), dxx_name);
if (dyy_fd >= 0)
@@ -1375,7 +1365,7 @@
hist.edlinecnt = 3;
G_write_history (dyy_name, &hist);
- G_message(_("DYY [%s] COMPLETE"), dyy_name);
+ G_message(_("Dyy raster map <%s> complete"), dyy_name);
if (dxy_fd >= 0)
@@ -1400,7 +1390,7 @@
hist.edlinecnt = 3;
G_write_history (dxy_name, &hist);
- G_message(_("DXY [%s] COMPLETE"), dxy_name);
+ G_message(_("Dxy raster map <%s> complete"), dxy_name);
exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.slope.aspect/opennew.c
--- grass/trunk/raster/r.slope.aspect/opennew.c 2008-05-03 11:04:06 UTC (rev 31231)
+++ grass/trunk/raster/r.slope.aspect/opennew.c 2008-05-03 11:07:43 UTC (rev 31232)
@@ -16,7 +16,7 @@
fd = G_open_raster_new (name, wr_type);
if (fd < 0)
- G_fatal_error (_("Failed in attempt to open %s"), name);
+ G_fatal_error (_("Unable to create raster map <%s>"), name);
return fd;
