[GRASS-SVN] r31264 - grass-addons/gipe/i.albedo
svn_grass at osgeo.org
Tue May 6 06:11:50 EDT 2008
Author: ychemin
Date: 2008-05-06 06:11:50 -0400 (Tue, 06 May 2008)
New Revision: 31264
grass-addons/gipe/i.albedo/main.c
Updated with less agressive stretching (for Modis)
Modified: grass-addons/gipe/i.albedo/main.c
--- grass-addons/gipe/i.albedo/main.c 2008-05-06 07:35:11 UTC (rev 31263)
+++ grass-addons/gipe/i.albedo/main.c 2008-05-06 10:11:50 UTC (rev 31264)
@@ -38,9 +38,9 @@
struct Option *input,*output;
struct Flag *flag1, *flag2, *flag3;
- struct Flag *flag4, *flag5;
+ struct Flag *flag4, *flag5, *flag6;
struct History history; //metadata
- struct Colors colors;
/* FMEO Declarations*****************/
char *name; //input raster name
@@ -111,8 +111,12 @@
flag5 = G_define_flag() ;
flag5->key =_('c');
- flag5->description =_("Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction. Will slow down the processing.");
+ flag5->description =_("Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction. Agressive mode (Landsat).");
+ flag6 = G_define_flag() ;
+ flag6->key =_('d');
+ flag6->description =_("Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction. Soft mode (Modis).");
/* FMEO init nfiles */
nfiles = 1;
@@ -188,7 +192,7 @@
for (i=0;i<100;i++){
histogram[i]=0;
- if(flag5->answer){
+ if(flag5->answer||flag6->answer){
DCELL de;
DCELL d[MAXFILES];
@@ -333,11 +337,20 @@
i_bottom3b = i;
- G_message("peak1 %d %d\n",peak1, i_peak1);
- G_message("bottom2b= %d %d\n",bottom2b, i_bottom2b);
- a=(0.36-0.05)/(i_bottom2b/100.0-i_peak1/100.0);
- b=0.05-a*(i_peak1/100.0);
- G_message("a= %f\tb= %f\n",a,b);
+ if(flag5->answer){
+ G_message("peak1 %d %d\n",peak1, i_peak1);
+ G_message("bottom2b= %d %d\n",bottom2b, i_bottom2b);
+ a=(0.36-0.05)/(i_bottom2b/100.0-i_peak1/100.0);
+ b=0.05-a*(i_peak1/100.0);
+ G_message("a= %f\tb= %f\n",a,b);
+ if(flag6->answer){
+ G_message("bottom1a %d %d\n",bottom1a, i_bottom1a);
+ a=(0.36-0.05)/(i_bottom2b/100.0-i_bottom1a/100.0);
+ b=0.05-a*(i_bottom1a/100.0);
}//END OF FLAG1
/* End of processing histogram*/
@@ -381,7 +394,7 @@
} else if (aster){
de = bb_alb_aster(d[1],d[2],d[3],d[4],d[5],d[6]);
// Post-Process Albedo
de = a*de+b;
@@ -390,9 +403,6 @@
if (G_put_raster_row (outfd, outrast, out_data_type) < 0)
G_fatal_error (_("Cannot write to <%s>"),result);
- /* Color table for albedo */
- G_init_colors(&colors);
- G_add_color_rule(0,0,0,0,1,255,255,255,&colors);
for (i=1;i<=nfiles;i++)
G_free (inrast[i]);
