[GRASS-SVN] r31270 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Tue May 6 16:47:19 EDT 2008
Author: martinl
Date: 2008-05-06 16:47:18 -0400 (Tue, 06 May 2008)
New Revision: 31270
Added:
grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
grass/branches/develbranch_6/locale/po/grasslibs_es.po
grass/branches/develbranch_6/locale/po/grasslibs_ru.po
grass/branches/develbranch_6/locale/po/grassmods_es.po
grass/branches/develbranch_6/locale/po/grassmods_ru.po
grass/branches/develbranch_6/locale/po/grasstcl_es.po
grass/branches/develbranch_6/locale/po/grasstcl_ru.po
grass/branches/develbranch_6/locale/po/grasswxpy_es.po
grasslibs_ru translation by Maxim Dubinin, grasswxpy_ru added and other files updated with current code (merged from trunk)
Modified: grass/branches/develbranch_6/locale/po/grasslibs_es.po
--- grass/branches/develbranch_6/locale/po/grasslibs_es.po 2008-05-06 19:11:33 UTC (rev 31269)
+++ grass/branches/develbranch_6/locale/po/grasslibs_es.po 2008-05-06 20:47:18 UTC (rev 31270)
@@ -14,7 +14,7 @@
msgstr ""
"Project-Id-Version: grasslibs_es\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-04-11 20:51+0200\n"
+"POT-Creation-Date: 2008-05-06 20:31+0200\n"
"PO-Revision-Date: 2008-04-12 00:37+0200\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -385,8 +385,10 @@
msgstr "Resolviendo sistemas no lineales (SOR) -- iteración %5i error %g\n"
#: ../lib/gpde/N_parse_options.c:59
-msgid "The type of solver which should solve the symmetric linear equation system"
-msgstr "El método que debería resolver el sistema de ecuaciones lineal simétrico"
+msgid ""
+"The type of solver which should solve the symmetric linear equation system"
+msgstr ""
+"El método que debería resolver el sistema de ecuaciones lineal simétrico"
#: ../lib/gpde/N_parse_options.c:71
msgid "The type of solver which should solve the linear equation system"
@@ -397,8 +399,10 @@
msgstr "Número máximo de iteraciones usado para resolver el sistema lineal"
#: ../lib/gpde/N_parse_options.c:89
-msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-msgstr "Error en los criterios de métodos iterativos (jacobi, sor, cg or bicgstab)"
+msgid ""
+"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgstr ""
+"Error en los criterios de métodos iterativos (jacobi, sor, cg or bicgstab)"
#: ../lib/gpde/N_parse_options.c:98
msgid ""
@@ -518,7 +522,8 @@
#: ../lib/gpde/N_solvers_krylov.c:198
#, fuzzy, c-format
msgid "Sparse PCG -- iteration %i error %g\n"
-msgstr "Método no lineal de gradientes conjugados (CG)-- iteración %i error %g\n"
+msgstr ""
+"Método no lineal de gradientes conjugados (CG)-- iteración %i error %g\n"
#: ../lib/gpde/N_solvers_krylov.c:200
#, c-format
@@ -533,7 +538,8 @@
#: ../lib/gpde/N_solvers_krylov.c:367
#, c-format
msgid "CG -- iteration %i error %g\n"
-msgstr "Método no lineal de gradientes conjugados (CG) -- iteración %5i error %g\n"
+msgstr ""
+"Método no lineal de gradientes conjugados (CG) -- iteración %5i error %g\n"
#: ../lib/gpde/N_solvers_krylov.c:530
#, c-format
@@ -545,17 +551,20 @@
#: ../lib/gpde/N_solvers_krylov.c:533
#, c-format
msgid "BiCGStab -- iteration %i error %g\n"
-msgstr "gradientes biconjugados estabilizados (BiCGStab)-- iteración %5i error %g\n"
+msgstr ""
+"gradientes biconjugados estabilizados (BiCGStab)-- iteración %5i error %g\n"
#: ../lib/db/dbmi_base/legal_dbname.c:24
#, c-format
msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-msgstr "Nombre de tabla de mapa <%s> no admitido. No puede contener '.' o 'NULO'.\n"
+msgstr ""
+"Nombre de tabla de mapa <%s> no admitido. No puede contener '.' o 'NULO'.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:30
#, c-format
msgid "Illegal table map name <%s>. Must start with a letter.\n"
-msgstr "Nombre de tabla de mapa <%s> no admitido. Debe empezar con una letra.\n"
+msgstr ""
+"Nombre de tabla de mapa <%s> no admitido. Debe empezar con una letra.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:36
#, c-format
@@ -723,7 +732,8 @@
#: ../lib/vector/diglib/plus_area.c:366
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr "Centroide inexistente %d registrado para el área (error en la biblioteca)"
+msgstr ""
+"Centroide inexistente %d registrado para el área (error en la biblioteca)"
#: ../lib/vector/diglib/plus_area.c:387
#, c-format
@@ -811,8 +821,8 @@
"Attempt to read line angle for the line which is not connected to the node: "
"node %d, line %d"
msgstr ""
-"Intento de leer el ángulo de la línea que no está conectada al nodo: "
-"nodo %d, línea %d"
+"Intento de leer el ángulo de la línea que no está conectada al nodo: nodo %"
+"d, línea %d"
#: ../lib/vector/Vlib/build.c:29 ../lib/vector/Vlib/open.c:34
#: ../lib/vector/Vlib/close.c:36 ../lib/vector/Vlib/read.c:27
@@ -949,7 +959,8 @@
msgstr "Mapa vectorial <%s> no encontrado"
#: ../lib/vector/Vlib/open.c:166
-msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
msgstr ""
"Un mapa que no está en el directorio de mapas actual no se puede abrir para "
"actualizar"
@@ -1090,7 +1101,8 @@
#: ../lib/vector/Vlib/legal_vname.c:66
#, c-format
-msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgid ""
+"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
msgstr ""
"El nombre <%s> del mapa vectorial no está permitido. Las palabras clave de "
"SQL no se puede usar como nombre de mapa vectorial."
@@ -1098,7 +1110,8 @@
#: ../lib/vector/Vlib/legal_vname.c:95 ../lib/vector/Vlib/legal_vname.c:97
#, c-format
msgid "Output vector map name <%s> is not valid map name"
-msgstr "El nombre del mapa vectorial de salida <%s> no es un nombre de mapa válido"
+msgstr ""
+"El nombre del mapa vectorial de salida <%s> no es un nombre de mapa válido"
#: ../lib/vector/Vlib/legal_vname.c:128 ../lib/vector/Vlib/legal_vname.c:130
#, c-format
@@ -1154,8 +1167,11 @@
#: ../lib/vector/Vlib/read.c:102
#, c-format
-msgid "Vect_read_line(): line %d is not reasonable (max line in vector map: %d)"
-msgstr "Vect_read_line(): la línea %d no es razonable (línea máxima en mapa vectorial: %d)"
+msgid ""
+"Vect_read_line(): line %d is not reasonable (max line in vector map: %d)"
+msgstr ""
+"Vect_read_line(): la línea %d no es razonable (línea máxima en mapa "
+"vectorial: %d)"
#: ../lib/vector/Vlib/dangles.c:169 ../lib/vector/Vlib/dangles.c:263
#: ../lib/vector/Vlib/dangles.c:274
@@ -1195,7 +1211,8 @@
#: ../lib/vector/Vlib/array.c:280
#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr "No se puede seleccionar el registro de la tabla <%s> (clave<%s, donde %s)"
+msgstr ""
+"No se puede seleccionar el registro de la tabla <%s> (clave<%s, donde %s)"
#: ../lib/vector/Vlib/break_lines.c:116
#, c-format
@@ -1245,7 +1262,8 @@
#: ../lib/vector/Vlib/cats.c:135
#, c-format
msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr "Demasiadas categorías (%d), no se puede establecer la categoría %d (capa %d)"
+msgstr ""
+"Demasiadas categorías (%d), no se puede establecer la categoría %d (capa %d)"
#: ../lib/vector/Vlib/cats.c:398
#, c-format
@@ -1404,7 +1422,8 @@
msgstr "No está soportada la construcción parcial para OGR"
#: ../lib/vector/Vlib/build_ogr.c:329
-msgid "Random read is not supported by OGR for this layer, cannot build support"
+msgid ""
+"Random read is not supported by OGR for this layer, cannot build support"
msgstr ""
"La lectura aleatoria no está soportada por OGR para esta capa, no se puede "
"construir el soporte"
@@ -1550,7 +1569,8 @@
#: ../lib/vector/Vlib/map.c:453
#, c-format
msgid "Unable to find table <%s> linked to vector map <%s>"
-msgstr "No se puede encontrar la tabla <%s> enlazada con el mapa vectorial <%s>"
+msgstr ""
+"No se puede encontrar la tabla <%s> enlazada con el mapa vectorial <%s>"
#: ../lib/vector/Vlib/map.c:467
@@ -1582,7 +1602,8 @@
#: ../lib/vector/Vlib/map.c:564 ../lib/vector/Vlib/map.c:653
#, c-format
msgid "Unable to add database link for vector map <%s>"
-msgstr "No se puede añadir el enlace a la base de datos para el mapa vectorial <%s>"
+msgstr ""
+"No se puede añadir el enlace a la base de datos para el mapa vectorial <%s>"
#: ../lib/vector/Vlib/read_nat.c:146
msgid "Attempt to read dead line"
@@ -1594,11 +1615,13 @@
#: ../lib/vector/Vlib/overlay.c:124
msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr "Superposición: el tipo de línea/contorno no está soportado por el operador Y"
+msgstr ""
+"Superposición: el tipo de línea/contorno no está soportado por el operador Y"
#: ../lib/vector/Vlib/overlay.c:127
msgid "Overlay: area x area types not supported by AND operator"
-msgstr "Superposición: los tipos de área x área no están soportados por el operador Y"
+msgstr ""
+"Superposición: los tipos de área x área no están soportados por el operador Y"
#: ../lib/vector/Vlib/read_ogr.c:165
@@ -1688,7 +1711,8 @@
#: ../lib/vector/Vlib/field.c:724
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr "Error: intento de actulizar un mapa que no es el directorio de mapas actual"
+msgstr ""
+"Error: intento de actulizar un mapa que no es el directorio de mapas actual"
#: ../lib/vector/Vlib/net.c:119
msgid "Building graph..."
@@ -1716,7 +1740,8 @@
#: ../lib/vector/Vlib/net.c:324
#, c-format
msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr "El tipo de datos de la columna <%s> no está soportado (debe ser numérico)"
+msgstr ""
+"El tipo de datos de la columna <%s> no está soportado (debe ser numérico)"
#: ../lib/vector/Vlib/net.c:213
msgid "Registering arcs..."
@@ -1841,7 +1866,7 @@
msgid "Unable to delete line %d from vector map <%s>"
msgstr "No se puede borrar la línea %d del mapa vectorial <%s>"
-#: ../lib/vector/vedit/select.c:196
+#: ../lib/vector/vedit/select.c:230
msgid "Unknown query tool"
msgstr "Herramienta de consulta desconocida"
@@ -1936,7 +1961,8 @@
#: ../lib/proj/convert.c:124
#, c-format
-msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgid ""
+"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
msgstr ""
"OGR no puede analizar la cadena de parámetros estilo PROJ.4: %s (El código "
"de error de OGR fue %d)"
@@ -1957,7 +1983,8 @@
#: ../lib/proj/convert.c:428
#, c-format
msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr "El datum <%s> no es reconocido por GRASS y no se han encontrado parámetos"
+msgstr ""
+"El datum <%s> no es reconocido por GRASS y no se han encontrado parámetos"
#: ../lib/proj/convert.c:445
#, c-format
@@ -2010,7 +2037,8 @@
#: ../lib/g3d/g3dparam.c:63
msgid "Precision used in the output file (default, max, or 0 to 52)"
-msgstr "La precisión usada en el archivo de salida (por defecto, máximo o de 0 a 52)"
+msgstr ""
+"La precisión usada en el archivo de salida (por defecto, máximo o de 0 a 52)"
#: ../lib/g3d/g3dparam.c:73
msgid "The compression method used in the output file"
@@ -2058,7 +2086,8 @@
#: ../lib/g3d/g3dopen.c:126
msgid "G3d_openCellOld: projection does not match window projection"
-msgstr "G3d_openCellOld: la proyección no coincide con la proyección de la ventana"
+msgstr ""
+"G3d_openCellOld: la proyección no coincide con la proyección de la ventana"
#: ../lib/g3d/g3dopen.c:130
msgid "G3d_openCellOld: zone does not match window zone"
@@ -2160,7 +2189,8 @@
#: ../lib/gis/legal_name.c:45
#, c-format
msgid "Illegal filename. Character <%c> not allowed.\n"
-msgstr "El nombre del archivo no es admitido. El carácter <%c> no está permitido.\n"
+msgstr ""
+"El nombre del archivo no es admitido. El carácter <%c> no está permitido.\n"
#: ../lib/gis/legal_name.c:75 ../lib/gis/legal_name.c:77
#, c-format
@@ -2302,7 +2332,8 @@
#: ../lib/gis/opencell.c:718
msgid "Can't write embedded null values for map open for random access"
-msgstr "No se puede escribir valores nulos en un mapa abierto por acceso aleatorio"
+msgstr ""
+"No se puede escribir valores nulos en un mapa abierto por acceso aleatorio"
#: ../lib/gis/opencell.c:936 ../lib/gis/opencell.c:991
#, c-format
@@ -2565,7 +2596,8 @@
#: ../lib/gis/range.c:365 ../lib/gis/range.c:416
#, c-format
msgid "can't write range file for [%s in %s]"
-msgstr "no es posible escribir el archivo conteniendo los rangos para [%s en %s]"
+msgstr ""
+"no es posible escribir el archivo conteniendo los rangos para [%s en %s]"
#: ../lib/gis/gisinit.c:55
#, c-format
@@ -2574,7 +2606,8 @@
#: ../lib/gis/gisinit.c:101
msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr "El sistema no está inicializado. El programador olvidó llamar a G_gisinit()."
+msgstr ""
+"El sistema no está inicializado. El programador olvidó llamar a G_gisinit()."
#: ../lib/gis/get_row.c:47 ../lib/gis/get_row.c:937
#, c-format
@@ -2665,7 +2698,8 @@
msgid ""
"G_set_window(): projection/zone differs from that of currently open raster "
"maps"
-msgstr "G_set_window(): la proyección/zona difiere en los archivos ráster abiertos"
+msgstr ""
+"G_set_window(): la proyección/zona difiere en los archivos ráster abiertos"
#: ../lib/gis/format.c:162
#, c-format
@@ -2685,7 +2719,8 @@
#: ../lib/gis/put_row.c:256
#, c-format
msgid "%s: map [%s] not open for random write - request ignored"
-msgstr "%s: el mapa [%s] no está abierto para escritura aleatoria - petición ignorada"
+msgstr ""
+"%s: el mapa [%s] no está abierto para escritura aleatoria - petición ignorada"
#: ../lib/gis/put_row.c:263
#, c-format
@@ -2866,7 +2901,8 @@
#: ../lib/gis/get_ellipse.c:409
#, c-format
msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "No se ha proporcionado información de la elipsoide en el archivo %s en <%s>"
+msgstr ""
+"No se ha proporcionado información de la elipsoide en el archivo %s en <%s>"
#: ../lib/gis/location.c:46
#, c-format
@@ -2887,7 +2923,8 @@
#: ../lib/gis/null_val.c:117
msgid "Please advise GRASS developers of this error.\n"
-msgstr "Por favor notifique a los desarrolladores de GRASS acerca de este error.\n"
+msgstr ""
+"Por favor notifique a los desarrolladores de GRASS acerca de este error.\n"
#: ../lib/gis/null_val.c:231
msgid "G_set_null_value: wrong data type!"
@@ -3753,7 +3790,8 @@
#: ../lib/gis/view.c:550
#, c-format
-msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgid ""
+" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
msgstr ""
" Sólo el %d%% de la ventana grabada en \"%s\" se superpone a la ventana "
"actual de GRASS."
@@ -3866,7 +3904,8 @@
#: ../lib/gis/histogram.c:60
#, c-format
msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "El histograma para [%s en %s] no ha sido encontrado (ejecute r.support)"
+msgstr ""
+"El histograma para [%s en %s] no ha sido encontrado (ejecute r.support)"
#: ../lib/gis/histogram.c:68
#, c-format
@@ -3883,32 +3922,34 @@
msgid "can't create histogram for [%s in %s]"
msgstr "El histograma para [%s en %s] no puede crearse"
-#: ../lib/imagery/fopen.c:28
+#: ../lib/imagery/fopen.c:24
#, c-format
msgid "Unable to create file [%s] of group [%s in %s]"
msgstr "No se puede crear archivo [%s] del grupo [%s en %s]"
-#: ../lib/imagery/fopen.c:46 ../lib/imagery/fopen.c:73
+#: ../lib/imagery/fopen.c:38 ../lib/imagery/fopen.c:61
#, c-format
msgid "Unable to open file [%s] of group [%s in %s]"
msgstr "No se puede abrir el archivo [%s] del grupo [%s en %s]"
-#: ../lib/imagery/fopen.c:62
+#: ../lib/imagery/fopen.c:53
#, c-format
msgid "Unable to find file [%s] of group [%s in %s]"
msgstr "No se puede encontrar el archivo [%s] del grupo [%s en %s]"
-#: ../lib/imagery/fopen.c:94
+#: ../lib/imagery/fopen.c:82
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "No se puede crear el archivo [%s] para el subgrupo [%s] del grupo [%s en %s]"
+msgstr ""
+"No se puede crear el archivo [%s] para el subgrupo [%s] del grupo [%s en %s]"
-#: ../lib/imagery/fopen.c:115 ../lib/imagery/fopen.c:145
+#: ../lib/imagery/fopen.c:103 ../lib/imagery/fopen.c:133
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "No se puede abrir el archivo [%s] para el subgrupo [%s] del grupo [%s en %s]"
+msgstr ""
+"No se puede abrir el archivo [%s] para el subgrupo [%s] del grupo [%s en %s]"
-#: ../lib/imagery/fopen.c:134
+#: ../lib/imagery/fopen.c:122
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
@@ -4113,7 +4154,8 @@
#: ../lib/symbol/read.c:252
#, c-format
-msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgid ""
+"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
msgstr ""
"Nombre de símbolo incorrecto: %s (debe ser: grupo/nombre o grupo/"
"nombre at mapset)"
@@ -4201,7 +4243,8 @@
#: ../lib/rst/interp_float/vinput2d.c:302
#, c-format
msgid "there are points outside specified 2D/3D region--ignored %d points"
-msgstr "Hay puntos fuera de la región 2D/3D especificada -- se ignoraron %d puntos"
+msgstr ""
+"Hay puntos fuera de la región 2D/3D especificada -- se ignoraron %d puntos"
#: ../lib/rst/interp_float/vinput2d.c:304
#, c-format
@@ -4239,4 +4282,3 @@
#: ../lib/rst/interp_float/input2d.c:72
msgid "Bitmap mask created"
msgstr "Creada máscara de mapa de bits"
Modified: grass/branches/develbranch_6/locale/po/grasslibs_ru.po
--- grass/branches/develbranch_6/locale/po/grasslibs_ru.po 2008-05-06 19:11:33 UTC (rev 31269)
+++ grass/branches/develbranch_6/locale/po/grasslibs_ru.po 2008-05-06 20:47:18 UTC (rev 31270)
@@ -1,17 +1,17 @@
# translation of grasslibs_ru.po to Russian
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2006, GRASS Development Team
-# Alex Shevlakov <sixote at yahoo.com>, 2002.
+# Alex Shevlakov <sixote at yahoo.com>, Maxim Dubinin <sim at gis-lab.info>.
msgid ""
msgstr ""
"Project-Id-Version: grasslibs_ru\n"
-"POT-Creation-Date: 2008-01-24 17:42+0100\n"
-"PO-Revision-Date: 2006-07-07 11:52+0200\n"
-"Last-Translator: Markus Neteler <neteler at itc.it>\n"
+"PO-Revision-Date: 2008-05-05 19:03-0600\n"
+"Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=KOI8-R\n"
+"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.9.1\n"
@@ -38,26 +38,32 @@
"\n"
"++ Running array unit tests ++"
msgstr ""
+"\n"
+"++ ÐдÑÑ ÑеÑÑÑ Ð¼Ð°ÑÑива ++"
#: ../lib/gpde/test/test_arrays.c:50
msgid "\t 1. testing 2d arrays"
-msgstr ""
+msgstr "\t 1. ÑеÑÑиÑование 2d маÑÑивов"
#: ../lib/gpde/test/test_arrays.c:53
msgid "\t 2. testing 3d arrays"
-msgstr ""
+msgstr "\t 2. ÑеÑÑиÑование 3d маÑÑивов"
#: ../lib/gpde/test/test_arrays.c:57
msgid ""
"\n"
"-- Array unit tests failure --"
msgstr ""
+"\n"
+"-- ТеÑÑ ÐµÐ´Ð¸Ð½Ð¸Ñ Ð¼Ð°ÑÑива не пÑойден --"
#: ../lib/gpde/test/test_arrays.c:59
msgid ""
"\n"
"-- Array unit tests finished successfully --"
msgstr ""
+"\n"
+"-- ТеÑÑ ÐµÐ´Ð¸Ð½Ð¸Ñ Ð¼Ð°ÑÑива ÑÑпеÑно пÑойден --"
#: ../lib/gpde/test/test_heat.c:33
msgid ""
@@ -210,10 +216,13 @@
msgstr ""
#: ../lib/gpde/test/test_assemble.c:42
+#, fuzzy
msgid ""
"\n"
"++ Running assembling unit tests ++"
msgstr ""
+"\n"
+"++ ÐдÑÑ ÑеÑÑÑ ÐµÐ´Ð¸Ð½Ð¸Ñ ÑбоÑки ++"
#: ../lib/gpde/test/test_assemble.c:44
msgid "\t 1. testing 2d assembling"
@@ -338,7 +347,7 @@
#: ../lib/gpde/N_arrays_io.c:55
#, fuzzy, c-format
msgid "Raster map <%s> not found"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/gpde/N_arrays_io.c:67
#, fuzzy, c-format
@@ -348,7 +357,7 @@
#: ../lib/gpde/N_arrays_io.c:96
#, fuzzy, c-format
msgid "Reading raster map <%s> into memory"
-msgstr " òÁÓÔÒÏ×ÁÑ ËÁÒÔÁ %s@%s ÐÕÓÔÁ"
+msgstr " РаÑÑÑÐ¾Ð²Ð°Ñ ÐºÐ°ÑÑа %s@%s пÑÑÑа"
#: ../lib/gpde/N_arrays_io.c:103
#, fuzzy
@@ -358,7 +367,7 @@
#: ../lib/gpde/N_arrays_io.c:149 ../lib/gpde/N_arrays_io.c:231
#, fuzzy
msgid "Unable to close input map"
-msgstr "îÅ ÍÏÇÕ ÏÔËÒÙÔØ [%s]"
+msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¾ÑкÑÑÑÑ [%s]"
#: ../lib/gpde/N_arrays_io.c:178
msgid "N_array_2d * array is empty"
@@ -378,7 +387,7 @@
#: ../lib/gpde/N_arrays_io.c:225
#, fuzzy, c-format
msgid "Unable to write rast row %i"
-msgstr "ËÁÒÔÁ [%s] - ÎÅ×ÏÚÍÏÖÎÏ ÚÁÐÉÓÁÔØ ÓÔÒÏËÕ %d"
+msgstr "каÑÑа [%s] - невозможно запиÑаÑÑ ÑÑÑÐ¾ÐºÑ %d"
#: ../lib/gpde/N_arrays_io.c:282
#, c-format
@@ -472,96 +481,98 @@
#, fuzzy, c-format
-msgstr " "
+msgstr "ÐепÑавилÑное Ð¸Ð¼Ñ ÑаблиÑÑ <%s>. Ðе должно ÑодеÑжаÑÑ '.' или 'NULL'"
#, fuzzy, c-format
-msgstr " "
+msgstr "ÐепÑавилÑное Ð¸Ð¼Ñ ÑаблиÑÑ <%s>. Ðолжно наÑинаÑÑÑÑ Ñ Ð±ÑквÑ"
#, fuzzy, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-msgstr " "
+msgstr "ÐепÑавилÑное Ð¸Ð¼Ñ ÑаблиÑÑ <%s>. Символ <%c> иÑполÑзоваÑÑ Ð½ÐµÐ»ÑзÑ"
#: ../lib/db/dbmi_client/column.c:106
#, fuzzy, c-format
msgid "Cannot describe table <%s>"
-msgstr " "
+msgstr "Ðевозможно опиÑаÑÑ ÑаблиÑÑ <%s>"
#: ../lib/driver/parse_ftcap.c:33
#, c-format
msgid "%s: Unable to read font definition file; use the default"
msgstr ""
+"%s: Ðевозможно пÑоÑиÑаÑÑ Ñайл опиÑÐ°Ð½Ð¸Ñ ÑÑиÑÑа; иÑполÑзÑеÑÑÑ Ð¾Ð¿Ð¸Ñание по "
+"ÑмолÑаниÑ"
#: ../lib/driver/parse_ftcap.c:39
#, c-format
msgid "%s: No font definition file"
-msgstr ""
+msgstr "%s: ÐÑÑÑÑÑÑвÑÐµÑ Ñайл опиÑÐ°Ð½Ð¸Ñ ÑÑиÑÑа"
#: ../lib/driver/command.c:517
#, c-format
msgid "Unknown command: %d last: %d"
-msgstr ""
+msgstr "ÐеизвеÑÑÐ½Ð°Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ð°: %d last: %d"
#: ../lib/driver/command.c:559
msgid "Monitor: get_command: Premature EOF"
-msgstr ""
+msgstr "Monitor: get_command: Premature EOF"
#: ../lib/driver/main.c:89
#, c-format
msgid "Graphics driver [%s] started"
-msgstr ""
+msgstr "ÐÑаÑиÑеÑкий дÑÐ°Ð¹Ð²ÐµÑ [%s] запÑÑен"
#: ../lib/raster/rem_io.c:43
#, fuzzy, c-format
msgid "ERROR %s from graphics driver.\n"
-msgstr "ïûéâëá %s ÇÒÁÆÉÞÅÓËÏÇÏ ÄÒÁÊ×ÅÒÁ.\n"
+msgstr "ÐШÐÐÐÐ %s гÑаÑиÑеÑкого дÑайвеÑа.\n"
#: ../lib/raster/rem_io.c:172
#, fuzzy, c-format
msgid "Unable to allocate memory\n"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ×ÙÄÅÌÉÔØ ÐÁÍÑÔØ\n"
+msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ\n"
#: ../lib/raster/rem_io.c:225
#, fuzzy, c-format
msgid "ERROR - eof from graphics monitor.\n"
-msgstr "ïûéâëá - eof from graphics monitor.\n"
+msgstr "ÐШÐÐÐÐ - eof from graphics monitor.\n"
#: ../lib/raster/rem_io.c:244
#, fuzzy, c-format
msgid "Warning - no response from graphics monitor <%s>.\n"
-msgstr "ðÒÅÄÕÐÒÅÖÄÅÎÉÅ - ÇÒÁÆÉÞÅÓËÉÊ ÄÉÓÐÌÅÊ <%s> ÎÅ ÏÔ×ÅÞÁÅÔ.\n"
+msgstr "ÐÑедÑпÑеждение - гÑаÑиÑеÑкий диÑплей <%s> не оÑвеÑаеÑ.\n"
#: ../lib/raster/rem_io.c:246
#, fuzzy, c-format
msgid "Check to see if the mouse is still active.\n"
-msgstr "ðÒÏ×ÅÒØÔÅ, ÒÁÂÏÔÁÅÔ ÌÉ ÍÙÛØ.\n"
+msgstr "ÐÑовеÑÑÑе, ÑабоÑÐ°ÐµÑ Ð»Ð¸ мÑÑÑ.\n"
#: ../lib/raster/rem_io.c:251
#, fuzzy, c-format
msgid "ERROR - no response from graphics monitor <%s>.\n"
-msgstr "ïûéâëá - ÇÒÁÆÉÞÅÓËÉÊ ÄÉÓÐÌÅÊ <%s> ÎÅ ÏÔ×ÅÞÁÅÔ.\n"
+msgstr "ÐШÐÐÐÐ - гÑаÑиÑеÑкий диÑплей <%s> не оÑвеÑаеÑ.\n"
#: ../lib/raster/io_sock.c:65
#, fuzzy
msgid "No graphics monitor has been selected for output."
-msgstr "îÅ ×ÙÂÒÁÎ ÇÒÁÆÉÞÅÓËÉÊ ÄÉÓÐÌÅÊ ÄÌÑ ×Ù×ÏÄÁ.\n"
+msgstr "Ðе вÑбÑан гÑаÑиÑеÑкий диÑплей Ð´Ð»Ñ Ð²Ñвода.\n"
#: ../lib/raster/io_sock.c:66
#, fuzzy
msgid "Please run \"d.mon\" to select a graphics monitor."
-msgstr "÷ÙÐÏÌÎÉÔÅ \"d.mon\" ÄÌÑ ×ÙÂÏÒÁ ÇÒÁÆÉÞÅÓËÏÇÏ ÄÉÓÐÌÅÑ.\n"
+msgstr "ÐÑполниÑе \"d.mon\" Ð´Ð»Ñ Ð²ÑбоÑа гÑаÑиÑеÑкого диÑплеÑ.\n"
#: ../lib/raster/io_sock.c:75
#, fuzzy, c-format
msgid "Failed to get socket name for monitor <%s>."
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÐÏÌÕÞÉÔØ ÓÏËÅÔ ÄÌÑ ÄÉÓÐÌÅÑ <%s>.\n"
+msgstr "Ðевозможно полÑÑиÑÑ ÑÐ¾ÐºÐµÑ Ð´Ð»Ñ Ð´Ð¸ÑÐ¿Ð»ÐµÑ <%s>.\n"
#: ../lib/raster/io_sock.c:85
#, fuzzy, c-format
msgid "No socket to connect to for monitor <%s>."
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÓÏÅÄÉÎÉÔØÓÑ ÞÅÒÅÚ ÓÏËÅÔ ÄÌÑ ÄÉÓÐÌÅÑ <%s>.\n"
+msgstr "Ðевозможно ÑоединиÑÑÑÑ ÑеÑез ÑÐ¾ÐºÐµÑ Ð´Ð»Ñ Ð´Ð¸ÑÐ¿Ð»ÐµÑ <%s>.\n"
#: ../lib/raster/io_sock.c:105
#, fuzzy
@@ -571,7 +582,7 @@
#: ../lib/raster/io_sock.c:106
#, fuzzy
msgid "Use d.mon to select a monitor"
#: ../lib/raster/io_sock.c:113
msgid "Trying to connect to something not a socket."
@@ -588,97 +599,146 @@
#: ../lib/raster/io_sock.c:121
#, fuzzy
msgid "Probably an error with the server."
-msgstr "÷ÒÅÍÑ ÄÌÑ ÕÓÔÁÎÏ×ËÉ ÓÏÅÄÉÎÅÎÉÑ ÚÁËÏÎÞÉÌÏÓØ. ÷ÅÒÏÑÔÎÁ ÏÛÉÂËÁ ÓÅÒ×ÅÒÁ.\n"
+msgstr "ÐÑÐµÐ¼Ñ Ð´Ð»Ñ ÑÑÑановки ÑÐ¾ÐµÐ´Ð¸Ð½ÐµÐ½Ð¸Ñ Ð·Ð°ÐºÐ¾Ð½ÑилоÑÑ. ÐеÑоÑÑна оÑибка ÑеÑвеÑа.\n"
#: ../lib/raster/io_sock.c:129
#, fuzzy
msgid "Connection failed."
-msgstr "îÅÔ ÐÏÄËÌÀÞÅÎÉÑ\n"
+msgstr "ÐÐµÑ Ð¿Ð¾Ð´ÐºÐ»ÑÑениÑ\n"
-#: ../lib/vector/diglib/plus_area.c:211 ../lib/vector/diglib/plus_area.c:648
-#: ../lib/vector/diglib/plus_area.c:654
+#: ../lib/vector/diglib/spindex.c:232
+#, fuzzy, c-format
+msgid "Unable to delete node %d from spatial index"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл %s в %s"
+#: ../lib/vector/diglib/spindex.c:268
+#, fuzzy, c-format
+msgid "Unable to delete line %d from spatial index"
+#: ../lib/vector/diglib/spindex.c:295
+msgid "Attempt to delete sidx for dead area"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:304
+#, fuzzy, c-format
+msgid "Unable to delete area %d from spatial index"
+#: ../lib/vector/diglib/spindex.c:336
+#, fuzzy, c-format
+msgid "Unable to delete isle %d from spatial index"
+#: ../lib/vector/diglib/plus_area.c:191 ../lib/vector/diglib/plus_area.c:615
+#: ../lib/vector/diglib/plus_area.c:621
#, c-format
-msgid "Line [%d] already has area/isle [%d] to left."
+msgid "Line %d already has area/isle %d to left"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:219
+#: ../lib/vector/diglib/plus_area.c:199
#, c-format
-msgid "Line [%d] already has area/isle [%d] to right."
+msgid "Line %d already has area/isle %d to right"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:302
+#: ../lib/vector/diglib/plus_area.c:278
msgid "Attempt to delete isle from dead area"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:316
+#: ../lib/vector/diglib/plus_area.c:292
#, c-format
-msgid "Attempt to delete not registered isle [%d] from area [%d]"
+msgid "Attempt to delete not registered isle %d from area %d"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:354
+#: ../lib/vector/diglib/plus_area.c:328
msgid "Attempt to delete dead area"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:392
+#: ../lib/vector/diglib/plus_area.c:366
#, c-format
-msgid "Dead centroid [%d] registered for area (bug in the library)."
+msgid "Dead centroid %d registered for area (bug in the vector library)"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:413
+#: ../lib/vector/diglib/plus_area.c:387
#, c-format
-msgid "Attempt to delete area [%d] info from dead isle [%d]"
+msgid "Attempt to delete area %d info from dead isle %d"
msgstr ""
-#: ../lib/vector/diglib/plus_area.c:741
+#: ../lib/vector/diglib/plus_area.c:704
#, c-format
-msgid "Attempt to delete isle [%d] info from dead area [%d]"
+msgid "Attempt to delete isle %d info from dead area %d"
msgstr ""
-#: ../lib/vector/diglib/plus.c:318
+#: ../lib/vector/diglib/plus.c:288
#, fuzzy
-msgid "Cannot read topo for nodes"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÐÒÏÞÅÓÔØ ÇÉÓÔÏÇÒÁÍÍÕ ÄÌÑ [%s × %s]"
+msgid "Unable read topology for nodes"
+msgstr "Ðевозможно пÑоÑеÑÑÑ Ð³Ð¸ÑÑогÑÐ°Ð¼Ð¼Ñ Ð´Ð»Ñ [%s в %s]"
-#: ../lib/vector/diglib/plus.c:324
+#: ../lib/vector/diglib/plus.c:294
#, fuzzy, c-format
-msgid "Cannot read topo for node [%d]"
+msgid "Unable to read topology for node %d"
-#: ../lib/vector/diglib/plus.c:329
+#: ../lib/vector/diglib/plus.c:299
#, fuzzy
-msgid "Cannot read topo for lines"
+msgid "Unable read topology for lines"
-#: ../lib/vector/diglib/plus.c:335
+#: ../lib/vector/diglib/plus.c:305
#, fuzzy, c-format
-msgid "Cannot read topo for line [%d]"
+msgid "Unable to read topology for line %d"
-#: ../lib/vector/diglib/plus.c:340
+#: ../lib/vector/diglib/plus.c:310
#, fuzzy
-msgid "Cannot read topo for areas"
+msgid "Unable to read topo for areas"
msgstr " "
-#: ../lib/vector/diglib/plus.c:346
+#: ../lib/vector/diglib/plus.c:316
#, fuzzy, c-format
-msgid "Cannot read topo for area [%d]"
+msgid "Unable read topology for area %d"
-#: ../lib/vector/diglib/plus.c:351
+#: ../lib/vector/diglib/plus.c:321
#, fuzzy
-msgid "Cannot read topo for isles"
-msgstr "îÅ ÍÏÇÕ ÏÔËÒÙÔØ ×ÒÅÍ. ÆÁÊÌ"
+msgid "Unable to read topology for isles"
+msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¾ÑкÑÑÑÑ Ð²Ñем. Ñайл"
-#: ../lib/vector/diglib/plus.c:357
+#: ../lib/vector/diglib/plus.c:327
#, fuzzy, c-format
-msgid "Cannot read topo for isle [%d]"
+msgid "Unable to read topology for isle %d"
-#: ../lib/vector/diglib/plus_node.c:244
+#: ../lib/vector/diglib/plus.c:352 ../lib/vector/diglib/plus.c:383
+#, fuzzy
+msgid "Unable to write head to plus file"
+#: ../lib/vector/diglib/plus.c:358
+#, fuzzy
+msgid "Unable to write nodes to plus file"
+msgstr "невозможно запиÑаÑÑ quant Ñайл!"
+#: ../lib/vector/diglib/plus.c:364
+#, fuzzy
+msgid "Unable to write lines to plus file"
+#: ../lib/vector/diglib/plus.c:370
+#, fuzzy
+msgid "Unable to write areas to plus file"
+#: ../lib/vector/diglib/plus.c:376
+#, fuzzy
+msgid "Unable to write isles to plus file"
+#: ../lib/vector/diglib/plus_node.c:220
#, c-format
msgid ""
-"node = [%d] line = [%d]"
+"node %d, line %d"
msgstr ""
@@ -691,7 +751,7 @@
#: ../lib/vector/Vlib/build.c:143
#, fuzzy, c-format
msgid "Building topology for vector map <%s>...\n"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/build.c:156
msgid "Topology was built\n"
@@ -783,7 +843,7 @@
#: ../lib/vector/Vlib/build.c:269
#, fuzzy
msgid "Error writing out topo file"
-msgstr "ïÛÉÂËÁ ÚÁÐÉÓÉ × ÆÁÊÌ Ó ÐÌÁ×ÁÀÝÅÊ ÔÏÞËÏÊ ÄÌÑ ËÁÒÔÙ %s"
+msgstr "ÐÑибка запиÑи в Ñайл Ñ Ð¿Ð»Ð°Ð²Ð°ÑÑей ÑоÑкой Ð´Ð»Ñ ÐºÐ°ÑÑÑ %s"
#: ../lib/vector/Vlib/build.c:405
#, fuzzy, c-format
@@ -793,7 +853,7 @@
#: ../lib/vector/Vlib/build.c:413
#, fuzzy
msgid "Error writing out spatial index file"
#: ../lib/vector/Vlib/intersect.c:127
msgid "3D not supported by Vect_segment_intersection()"
@@ -816,7 +876,7 @@
#: ../lib/vector/Vlib/legal_vname.c:110 ../lib/vector/Vlib/map.c:305
#, fuzzy, c-format
msgid "Vector map <%s> not found"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#, fuzzy
@@ -833,27 +893,27 @@
#: ../lib/vector/Vlib/open.c:271
#, fuzzy, c-format
msgid "Unable to open vector map <%s> on topology level %d"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/open.c:195
#, fuzzy
msgid "Unable to read head file"
#: ../lib/vector/Vlib/open.c:215
#, fuzzy, c-format
msgid "Unable to open topology file for vector map <%s>"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/open.c:238
#, fuzzy, c-format
msgid "Unable to open category index file for vector map <%s>"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/open.c:319 ../lib/vector/Vlib/open.c:530
#, fuzzy, c-format
msgid "Unable to open history file for vector map <%s>"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/open.c:496 ../lib/vector/Vlib/map.c:169
#: ../lib/vector/Vlib/map.c:293
@@ -865,7 +925,7 @@
#: ../lib/vector/Vlib/map.c:297
#, fuzzy, c-format
msgid "Vector map <%s> already exists and will be overwritten"
-msgstr "×ÅËÔÏÒ ."
+msgstr "векÑÐ¾Ñ ."
#: ../lib/vector/Vlib/open.c:507 ../lib/vector/Vlib/map.c:176
#, fuzzy, c-format
@@ -880,7 +940,7 @@
#: ../lib/vector/Vlib/open.c:576
#, fuzzy, c-format
msgid "Unable to stat file <%s>"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ ÆÁÊÌ %s × %s"
#: ../lib/vector/Vlib/open.c:683
msgid "Size of 'coor' file differs from value saved in topology file"
@@ -889,7 +949,7 @@
#: ../lib/vector/Vlib/open.c:694
#, fuzzy, c-format
msgid "Please rebuild topology for vector map <%s@%s>"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/snap.c:119 ../lib/vector/Vlib/snap.c:159
#: ../lib/vector/Vlib/break_polygons.c:191
@@ -933,23 +993,23 @@
#: ../lib/vector/Vlib/legal_vname.c:43
#, fuzzy, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/legal_vname.c:49
#, fuzzy, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/legal_vname.c:56
#, fuzzy, c-format
msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#, fuzzy, c-format
msgid ""
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#, fuzzy, c-format
@@ -985,17 +1045,17 @@
#: ../lib/vector/Vlib/cindex.c:457
#, fuzzy, c-format
msgid "Unable to open cidx file <%s> for write"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ %s ÄÌÑ ÚÁÐÉÓÉ"
+msgstr "Ðевозможно оÑкÑÑÑÑ %s Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи"
#: ../lib/vector/Vlib/cindex.c:465
#, fuzzy, c-format
msgid "Error writing out category index file <%s>"
#: ../lib/vector/Vlib/cindex.c:508
#, fuzzy, c-format
msgid "Unable to open category index file for vector map <%s@%s>"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/clean_nodes.c:52 ../lib/vector/Vlib/clean_nodes.c:216
msgid "Modifications"
@@ -1003,8 +1063,8 @@
#: ../lib/vector/Vlib/read.c:99
#, fuzzy
-msgid "Vector map is not opened"
-msgstr "×ÅËÔÏÒ "
+msgid "vector map is not opened"
+msgstr "векÑÐ¾Ñ "
#, c-format
@@ -1012,9 +1072,9 @@
msgstr ""
-#: ../lib/vector/Vlib/dangles.c:122 ../lib/vector/Vlib/dangles.c:211
-#: ../lib/vector/Vlib/dangles.c:219
-msgid "Removed dangles"
+#: ../lib/vector/Vlib/dangles.c:169 ../lib/vector/Vlib/dangles.c:263
+#: ../lib/vector/Vlib/dangles.c:274
+msgid "Removed dangles:"
msgstr ""
#: ../lib/vector/Vlib/array.c:97
@@ -1049,8 +1109,19 @@
#, fuzzy, c-format
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÓÏÚÄÁÔØ ÆÁÊÌ ÚÁÇÏÌÏ×ËÁ ÄÌÑ [%s × %s]"
+msgstr "Ðевозможно ÑоздаÑÑ Ñайл заголовка Ð´Ð»Ñ [%s в %s]"
+#: ../lib/vector/Vlib/break_lines.c:116
+#, c-format
+msgid "%s %5d"
+msgstr ""
+#: ../lib/vector/Vlib/break_lines.c:116 ../lib/vector/Vlib/break_lines.c:323
+#: ../lib/vector/Vlib/break_lines.c:341
+#, fuzzy
+msgid "Intersections:"
+msgstr "ÐÑÑÐ³Ð°Ñ Ð¿ÑоекÑиÑ"
#: ../lib/vector/Vlib/break_polygons.c:200
msgid "All points (vertices)"
msgstr ""
@@ -1077,12 +1148,12 @@
#: ../lib/vector/Vlib/poly.c:243
#, fuzzy
msgid "Unable to find point in polygon"
-msgstr "ÎÅ ÍÏÇÕ ÎÁÊÔÉ [%s] × [%s]"
+msgstr "не Ð¼Ð¾Ð³Ñ Ð½Ð°Ð¹Ñи [%s] в [%s]"
#: ../lib/vector/Vlib/poly.c:661
#, fuzzy
-msgid "Conditions failed"
+msgid "conditions failed"
#: ../lib/vector/Vlib/cats.c:46
msgid "Vect_new_cats_struct(): Out of memory"
@@ -1099,13 +1170,13 @@
msgstr ""
#: ../lib/vector/Vlib/sindex.c:97
-msgid "Not implemented"
+msgid "not implemented"
msgstr ""
#: ../lib/vector/Vlib/sindex.c:108
#, fuzzy, c-format
msgid "Unable to delete item %d from spatial index"
#: ../lib/vector/Vlib/sindex.c:127
msgid ""
@@ -1148,7 +1219,7 @@
#: ../lib/vector/Vlib/level_two.c:303 ../lib/vector/Vlib/level_two.c:322
#, fuzzy, c-format
msgid "Vector map <%s> is not open on level >= 2"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/graph.c:107 ../lib/vector/Vlib/net.c:380
msgid "GngFlatten error"
@@ -1190,7 +1261,7 @@
msgstr " "
#: ../lib/vector/Vlib/build_nat.c:526
-msgid "Primitives registered"
+msgid "primitives registered"
msgstr ""
#: ../lib/vector/Vlib/build_nat.c:536
@@ -1198,11 +1269,11 @@
msgstr ""
#: ../lib/vector/Vlib/build_nat.c:553
-msgid "Areas built"
+msgid "areas built"
msgstr ""
-msgid "Isles built"
+msgid "isles built"
msgstr ""
#: ../lib/vector/Vlib/build_nat.c:561
@@ -1230,7 +1301,7 @@
#: ../lib/vector/Vlib/build_ogr.c:257
#, fuzzy, c-format
msgid "Unable to calculate centroid for area %d"
#: ../lib/vector/Vlib/build_ogr.c:292 ../lib/vector/Vlib/read_ogr.c:112
#: ../lib/vector/Vlib/read_ogr.c:285
@@ -1248,8 +1319,9 @@
msgstr ""
#: ../lib/vector/Vlib/build_ogr.c:336
+#, fuzzy
msgid "Feature: "
-msgstr ""
+msgstr "Тип(Ñ) обÑекÑа(ов)"
#: ../lib/vector/Vlib/build_ogr.c:354
#, c-format
@@ -1261,8 +1333,9 @@
msgstr ""
#: ../lib/vector/Vlib/level.c:39
+#, fuzzy
msgid "Map structure was never initialized"
-msgstr ""
+msgstr "ÐекÑоÑÐ½Ð°Ñ ÑÑÑÑкÑÑÑа не инниÑиализиÑована"
#: ../lib/vector/Vlib/level.c:41
msgid "Map structure has been closed"
@@ -1275,18 +1348,18 @@
#: ../lib/vector/Vlib/area.c:131
#, fuzzy, c-format
msgid "Unable to read line %d"
#: ../lib/vector/Vlib/area.c:173 ../lib/vector/Vlib/area.c:205
#: ../lib/vector/Vlib/area.c:274 ../lib/vector/Vlib/area.c:307
#, fuzzy, c-format
msgid "Attempt to read topo for dead area (%d)"
#: ../lib/vector/Vlib/area.c:335
#, fuzzy, c-format
msgid "Attempt to read topo for dead isle (%d)"
#: ../lib/vector/Vlib/open_ogr.c:54
msgid "OGR format cannot be updated"
@@ -1300,12 +1373,12 @@
#: ../lib/vector/Vlib/open_ogr.c:84
#, fuzzy, c-format
msgid "Unable to open layer <%s>"
#: ../lib/vector/Vlib/open_ogr.c:128
#, fuzzy, c-format
msgid "Unable to open fidx file for vector map <%s@%s>"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/open_ogr.c:144
#, c-format
@@ -1329,16 +1402,16 @@
msgid "Area is composed of dead boundary"
msgstr ""
-#: ../lib/vector/Vlib/remove_duplicates.c:67
-#: ../lib/vector/Vlib/remove_duplicates.c:129
+#: ../lib/vector/Vlib/remove_duplicates.c:69
+#: ../lib/vector/Vlib/remove_duplicates.c:137
#, fuzzy
msgid "Duplicates"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ×ÏÓÔÏË"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле воÑÑок"
#: ../lib/vector/Vlib/map.c:55
#, fuzzy
-msgid "Input vector map is not open"
-msgstr "×ÅËÔÏÒ "
+msgid "input vector map is not open"
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/map.c:65 ../lib/vector/Vlib/map.c:78
#, fuzzy, c-format
@@ -1348,24 +1421,24 @@
#: ../lib/vector/Vlib/map.c:199 ../lib/vector/Vlib/map.c:308
#, fuzzy, c-format
msgid "Unable to copy vector map <%s> to <%s>"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ ÒÁÓÔÒÏ×ÕÀ ËÁÒÔÕ [%s × %s]"
+msgstr "невозможно оÑкÑÑÑÑ ÑаÑÑÑовÑÑ ÐºÐ°ÑÑÑ [%s в %s]"
#: ../lib/vector/Vlib/map.c:241 ../lib/vector/Vlib/map.c:355
#: ../lib/vector/Vlib/map.c:572 ../lib/vector/Vlib/map.c:665
#, fuzzy, c-format
msgid "Unable to copy table <%s>"
#: ../lib/vector/Vlib/map.c:253 ../lib/vector/Vlib/map.c:380
#: ../lib/vector/Vlib/map.c:582
#, fuzzy, c-format
msgid "Unable to create index for table <%s>, key <%s>"
#: ../lib/vector/Vlib/map.c:369 ../lib/vector/Vlib/map.c:462
#, fuzzy, c-format
msgid "Unable to delete table <%s>"
#: ../lib/vector/Vlib/map.c:417
#, fuzzy, c-format
@@ -1375,17 +1448,17 @@
#: ../lib/vector/Vlib/map.c:433
#, fuzzy, c-format
msgid "Unable to open header file for vector map <%s>"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#, fuzzy, c-format
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#, fuzzy, c-format
msgid "Table <%s> linked to vector map <%s> does not exist"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/map.c:481
#, fuzzy, c-format
@@ -1395,7 +1468,7 @@
#: ../lib/vector/Vlib/map.c:492
#, fuzzy, c-format
msgid "Unable to delete file '%s'"
#: ../lib/vector/Vlib/map.c:509
#, fuzzy, c-format
@@ -1410,17 +1483,17 @@
#, fuzzy, c-format
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#, fuzzy
#: ../lib/vector/Vlib/overlay.c:76
#, fuzzy
-msgid "Unknown operator"
-msgstr "îÅÉÚ×ÅÓÔÎÁÑ ÐÒÏÅËÃÉÑ"
+msgid "unknown operator"
+msgstr "неизвеÑÑÐ½Ð°Ñ Ð¾Ñибка"
@@ -1451,67 +1524,68 @@
#: ../lib/vector/Vlib/field.c:101
#, fuzzy
msgid "Unable to add database link"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/field.c:107 ../lib/vector/Vlib/field.c:153
#, fuzzy
msgid "Unable to write database links"
#: ../lib/vector/Vlib/field.c:221
#, fuzzy, c-format
msgid "Layer number %d or name <%s> already exists"
msgstr " "
-#: ../lib/vector/Vlib/field.c:285
+#: ../lib/vector/Vlib/field.c:290
+#, c-format
msgid ""
"Default driver / database set to:\n"
-"driver: dbf\n"
-"database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
+"driver: %s\n"
+"database: %s"
msgstr ""
-#: ../lib/vector/Vlib/field.c:295
+#: ../lib/vector/Vlib/field.c:297
#, fuzzy
msgid "Default driver is not set"
msgstr " "
-#: ../lib/vector/Vlib/field.c:297
+#: ../lib/vector/Vlib/field.c:299
#, fuzzy
msgid "Default database is not set"
msgstr " "
-#: ../lib/vector/Vlib/field.c:352
+#: ../lib/vector/Vlib/field.c:355
#, c-format
msgid "Requested dblink %d, maximum link number %d"
msgstr ""
-#: ../lib/vector/Vlib/field.c:487
+#: ../lib/vector/Vlib/field.c:490
#, fuzzy
msgid "Unable to open OGR DBMI driver"
-msgstr " "
+msgstr "Ðевозможно оÑкÑÑÑÑ Ð¿Ð°Ð¿ÐºÑ %s"
-#: ../lib/vector/Vlib/field.c:516
+#: ../lib/vector/Vlib/field.c:519
msgid ""
"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
"available in OGR DB table"
msgstr ""
-#: ../lib/vector/Vlib/field.c:557
+#: ../lib/vector/Vlib/field.c:560
#, c-format
msgid "Don't know how to read links for format %d"
msgstr ""
-#: ../lib/vector/Vlib/field.c:585
+#: ../lib/vector/Vlib/field.c:588
#, fuzzy, c-format
msgid "Error in rule on row %d in %s"
msgstr " "
-#: ../lib/vector/Vlib/field.c:636
+#: ../lib/vector/Vlib/field.c:639
#, fuzzy, c-format
msgid "Unable to open vector database definition file '%s'"
-msgstr "ÎÅ ÍÏÇÕ ÏÔËÒÙÔØ ÆÁÊÌ: %s"
+msgstr "не Ð¼Ð¾Ð³Ñ Ð¾ÑкÑÑÑÑ Ñайл ÑаблиÑÑ Ð´Ð°ÑÑмов: %s"
-#: ../lib/vector/Vlib/field.c:721
+#: ../lib/vector/Vlib/field.c:724
#, fuzzy
msgstr " ."
@@ -1523,7 +1597,7 @@
#: ../lib/vector/Vlib/net.c:155
#, fuzzy
msgid "Unable to build network graph"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/net.c:161
msgid "Forward costs column not specified"
@@ -1537,7 +1611,7 @@
#: ../lib/vector/Vlib/net.c:318
#, fuzzy, c-format
msgid "Column <%s> not found in table <%s>"
-msgstr " "
#: ../lib/vector/Vlib/net.c:187 ../lib/vector/Vlib/net.c:202
@@ -1590,12 +1664,14 @@
msgstr ""
#: ../lib/vector/Vlib/line.c:61
+#, fuzzy
msgid "Out of memory"
-msgstr ""
+msgstr "G_malloc: out of memory"
#: ../lib/vector/Vlib/line.c:205 ../lib/vector/Vlib/line.c:237
+#, fuzzy
msgid "Index out of range in"
-msgstr ""
+msgstr "Ð Ñд/колонка вне диапазона"
#: ../lib/vector/Vlib/line.c:522
msgid "Segment outside line, no segment created"
@@ -1604,7 +1680,7 @@
#: ../lib/vector/Vlib/header.c:100 ../lib/vector/Vlib/header.c:149
#, fuzzy, c-format
msgid "Unable to open header file of vector <%s>"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/vector/Vlib/header.c:156
#, c-format
@@ -1614,12 +1690,12 @@
#: ../lib/vector/Vlib/header.c:187
#, fuzzy, c-format
msgid "Unknown keyword %s in vector head"
+msgstr "ÐеизвеÑÑÐ½Ð°Ñ Ð¿ÑоекÑиÑ"
#: ../lib/vector/Vlib/header.c:533 ../lib/gis/proj3.c:66
#, fuzzy
msgid "Unknown projection"
#: ../lib/vector/Vlib/write.c:25 ../lib/vector/Vlib/write.c:29
#: ../lib/vector/Vlib/write.c:33
@@ -1635,7 +1711,7 @@
#: ../lib/vector/Vlib/write.c:107
#, fuzzy
msgid "Unable to write line (negative offset)"
#: ../lib/vector/Vlib/write.c:143
#, fuzzy
@@ -1645,7 +1721,7 @@
#: ../lib/vector/Vlib/write.c:154
#, fuzzy, c-format
msgid "Unable to rewrite line %d"
#: ../lib/vector/Vlib/write.c:201
#, fuzzy, c-format
@@ -1662,10 +1738,30 @@
msgstr " "
+#, fuzzy
+msgid "Unknown query tool"
+#: ../lib/vector/vedit/break.c:245
+#, fuzzy, c-format
+msgid "Unable to connect lines %d,%d"
+#: ../lib/vector/vedit/cats.c:65
+#, fuzzy, c-format
+msgid "Unable to set category %d for line %d"
+msgstr "векÑÐ¾Ñ "
+#: ../lib/vector/vedit/cats.c:74
+#, fuzzy, c-format
+msgid "Unable to delete layer/category %d/%d line %d"
+msgstr " "
#: ../lib/vask/V_support.c:58
#, fuzzy, c-format
msgid "Unable to open file %s"
#: ../lib/proj/get_proj.c:149
#, fuzzy, c-format
@@ -1688,7 +1784,7 @@
#: ../lib/proj/get_proj.c:325
#, fuzzy, c-format
msgid "Unable to initialize pj cause: %s"
#: ../lib/proj/get_proj.c:400
msgid "Input Projection Parameters"
@@ -1709,23 +1805,23 @@
#: ../lib/proj/datum.c:252
#, fuzzy
msgid "Unable to open temporary file"
#: ../lib/proj/datum.c:337 ../lib/gis/get_ell_name.c:46
#: ../lib/gis/get_datum_name.c:56 ../lib/gis/get_projname.c:51
#, fuzzy, c-format
msgid "Hit RETURN to cancel request\n"
-msgstr "îÁÖÍÉÔÅ RETURN ÄÌÑ ÏÔÍÅÎÙ\n"
+msgstr "ÐажмиÑе RETURN Ð´Ð»Ñ Ð¾ÑменÑ\n"
#: ../lib/proj/datum.c:408 ../lib/proj/datum.c:471
#, fuzzy, c-format
msgid "Unable to open datum table file <%s>"
#: ../lib/proj/datum.c:421 ../lib/proj/datum.c:485
#, fuzzy, c-format
msgid "Error in datum table file <%s>, line %d"
-msgstr "ÏÛÉÂËÁ × ÆÁÊÌÅ ÄÁÎÎÙÈ, ÓÔÒÏËÁ %d"
+msgstr "оÑибка в Ñайле ÑаблиÑÑ Ð´Ð°ÑÑмов, ÑÑÑока %d"
#: ../lib/proj/convert.c:107
msgid "Unable parse GRASS PROJ_INFO file"
@@ -1788,122 +1884,123 @@
msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
msgstr " "
-#: ../lib/proj/ellipse.c:114
+#: ../lib/proj/ellipse.c:113
msgid "No ellipsoid info given in file"
msgstr ""
-#: ../lib/proj/ellipse.c:212 ../lib/gis/get_ellipse.c:296
+#: ../lib/proj/ellipse.c:213 ../lib/gis/get_ellipse.c:296
#, fuzzy, c-format
msgid "Unable to open ellipsoid table file <%s>"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ ÆÁÊÌ ÔÁÂÌ. ÜÌÌÉÐÓÏÉÄÁ: %s"
+msgstr "невозможно оÑкÑÑÑÑ Ñайл ÑаблиÑÑ ÑллипÑоидов: %s"
#: ../lib/g3d/g3dparam.c:54
msgid "Data type used in the output file"
-msgstr ""
+msgstr "Тип даннÑÑ
иÑполÑзÑемÑй в вÑÑ
одном Ñайле"
msgstr ""
+"ТоÑноÑÑÑ Ð¸ÑполÑзÑÐµÐ¼Ð°Ñ Ð² вÑÑ
одном Ñайле (по ÑмолÑаниÑ, макÑималÑÐ½Ð°Ñ Ð¸Ð»Ð¸ 0-52"
-msgstr ""
+msgstr "ÐеÑод ÑжаÑÐ¸Ñ Ð¸ÑполÑзÑемÑй в вÑÑ
одном Ñайле"
#: ../lib/g3d/g3dparam.c:83
msgid "The dimensions of the tiles used in the output file"
-msgstr ""
+msgstr "РазмеÑÑ Ñайлов иÑполÑзÑмÑе в вÑÑ
одном Ñайле"
#: ../lib/g3d/g3dparam.c:118
msgid "G3d_getStandard3dParams: precision value invalid"
-msgstr ""
+msgstr "G3d_getStandard3dParams: непÑавилÑное знаÑение ÑоÑноÑÑи"
#: ../lib/g3d/g3dparam.c:146
msgid "G3d_getStandard3dParams: tile dimension value invalid"
-msgstr ""
+msgstr "G3d_getStandard3dParams: непÑавилÑнÑе ÑазмеÑÑ Ñайлов"
#: ../lib/g3d/g3dparam.c:171
#, fuzzy
msgid "Window replacing the default"
-msgstr "ÞÔÏÂÙ ÕÓÔÁÎÏ×ÉÔØ ÐÏ ÕÍÏÌÞÁÎÉÀ"
+msgstr "ÑÑÐ¾Ð±Ñ ÑÑÑановиÑÑ Ð¿Ð¾ ÑмолÑаниÑ"
#: ../lib/g3d/g3dopen.c:22
msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
-msgstr ""
+msgstr "G3d_openCellOldNoHeader: оÑибка в G3d_maskOpenOld"
#: ../lib/g3d/g3dopen.c:28
msgid "G3d_openCellOldNoHeader: error in G3d_malloc"
-msgstr ""
+msgstr "G3d_openCellOldNoHeader: оÑибка в G3d_malloc"
#: ../lib/g3d/g3dopen.c:46
msgid "G3d_openCellOldNoHeader: error in G_open_old"
-msgstr ""
+msgstr "G3d_openCellOldNoHeader: оÑибка в G_open_old"
#: ../lib/g3d/g3dopen.c:101
msgid "G3d_openCellOld: error in G3d_openCellOldNoHeader"
-msgstr ""
+msgstr "G3d_openCellOld: оÑибка в G3d_openCellOldNoHeader"
#: ../lib/g3d/g3dopen.c:106
msgid "G3d_openCellOld: can't rewind file"
-msgstr ""
+msgstr "G3d_openCellOld: не Ð¼Ð¾Ð³Ñ Ð¿ÐµÑемоÑаÑÑ Ñайл"
#: ../lib/g3d/g3dopen.c:119
msgid "G3d_openCellOld: error in G3d_readHeader"
-msgstr ""
+msgstr "G3d_openCellOld: оÑибка в G3d_readHeader"
-msgstr ""
+msgstr "G3d_openCellOld: пÑоекÑÐ¸Ñ Ð½Ðµ ÑооÑвеÑÑÑвÑÐµÑ Ð¿ÑоекÑии окна"
-msgstr ""
+msgstr "G3d_openCellOld: зона не ÑÐ¾Ð²Ð¿Ð°Ð´Ð°ÐµÑ Ð·Ð¾Ð½Ðµ окна"
#: ../lib/g3d/g3dopen.c:142 ../lib/g3d/g3dopen.c:159
msgid "G3d_openCellOld: can't read header"
-msgstr ""
+msgstr "G3d_openCellOld: невозможно пÑоÑиÑаÑÑ Ð·Ð°Ð³Ð¾Ð»Ð¾Ð²Ð¾Ðº"
#: ../lib/g3d/g3dopen.c:148
msgid "G3d_openCellOld: index does not fit into long"
-msgstr ""
+msgstr "G3d_openCellOld: Ð¸Ð½Ð´ÐµÐºÑ Ð½Ðµ помеÑаеÑÑÑ Ð² long"
#: ../lib/g3d/g3dopen.c:152
msgid "G3d_openCellOld: error in G3d_malloc"
-msgstr ""
+msgstr "G3d_openCellOld: оÑибка в G3d_malloc"
#: ../lib/g3d/g3dopen.c:179
msgid "G3d_openCellOld: error in G3d_fillHeader"
-msgstr ""
+msgstr "G3d_openCellOld: оÑибка в G3d_fillHeader"
#: ../lib/g3d/g3dopen.c:227
msgid "G3d_openCellNew: error in G3d_maskOpenOld"
-msgstr ""
+msgstr "G3d_openCellNew: оÑибка в G3d_maskOpenOld"
#: ../lib/g3d/g3dopen.c:236
msgid "G3d_openCellNew: error in G3d_malloc"
-msgstr ""
+msgstr "G3d_openCellNew: оÑибка в G3d_malloc"
#: ../lib/g3d/g3dopen.c:249
msgid "G3d_openCellNew: could not open file"
-msgstr ""
+msgstr "G3d_openCellNew: невозможно оÑкÑÑÑÑ Ñайл"
#: ../lib/g3d/g3dopen.c:291 ../lib/g3d/g3dopen.c:296
msgid "G3d_openCellNew: can't write header"
-msgstr ""
+msgstr "G3d_openCellNew: невозможно ÑоздаÑÑ Ð·Ð°Ð³Ð¾Ð»Ð¾Ð²Ð¾Ðº"
#: ../lib/g3d/g3dopen.c:319
msgid "G3d_openCellNew: error in G3d_fillHeader"
-msgstr ""
+msgstr "G3d_openCellNew: оÑибка в G3d_fillHeader"
#: ../lib/g3d/g3dhistory.c:46 ../lib/gis/history.c:134
#, fuzzy, c-format
msgid "can't get history information for [%s] in mapset [%s]"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÐÒÏÞÉÔÁÔØ ÉÓÔÏÒÉÀ ÄÌÑ [%s] × ÎÁÂ. ÄÁÎÎÙÈ [%s]"
+msgstr "невозможно пÑоÑиÑаÑÑ Ð¸ÑÑоÑÐ¸Ñ Ð´Ð»Ñ [%s] в набоÑе [%s]"
#: ../lib/gis/get_ell_name.c:33 ../lib/gis/get_datum_name.c:67
#: ../lib/gis/get_projname.c:39
#, fuzzy
msgid "Cannot open temp file"
+msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¾ÑкÑÑÑÑ Ð²ÑеменнÑй Ñайл"
#: ../lib/gis/get_ell_name.c:44
#, c-format
@@ -1911,11 +2008,13 @@
"\n"
"Please specify ellipsoid name\n"
msgstr ""
+"\n"
+"ÐожалÑйÑÑа, задайÑе Ð¸Ð¼Ñ ÑллипÑоида\n"
#: ../lib/gis/get_ell_name.c:45
#, fuzzy, c-format
msgid "Enter 'list' for the list of available ellipsoids\n"
-msgstr "÷×ÅÄÉÔÅ 'list' ÄÌÑ ×Ù×ÏÄÁ ÓÐÉÓËÁ ÜÌÌÉÐÓÏÉÄÏ×\n"
+msgstr "ÐведиÑе 'list' Ð´Ð»Ñ Ð²Ñвода ÑпиÑка ÑллипÑоидов\n"
#: ../lib/gis/get_ell_name.c:65
#, c-format
@@ -1923,55 +2022,57 @@
"\n"
"invalid ellipsoid\n"
msgstr ""
+"\n"
+"непÑавилÑнÑй ÑллипÑоид\n"
#: ../lib/gis/sample.c:81
#, fuzzy
msgid "Unknown interpolation type"
+msgstr "неизвеÑÑнÑй Ñип инÑеÑполÑÑии"
#: ../lib/gis/sample.c:467
msgid "\"no data\" label found; setting to zero"
-msgstr ""
+msgstr "найдена меÑка \"no data\"; ÑÑÑановлена в нолÑ"
#: ../lib/gis/sample.c:481
#, fuzzy
msgid "Problem reading raster map"
-msgstr "óÌÉÛËÏÍ ÍÎÏÇÏ ÒÁÓÔÒÏ×ÙÈ ÆÁÊÌÏ× ÏÔËÒÙÔÙ"
+msgstr "пÑоблема ÑÑÐµÐ½Ð¸Ñ ÑаÑÑÑого Ñайла"
#: ../lib/gis/put_cellhd.c:26
#, fuzzy, c-format
msgid "Unable to create header file for [%s]"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÓÏÚÄÁÔØ ÆÁÊÌ ÚÁÇÏÌÏ×ËÁ ÄÌÑ [%s]"
+msgstr "Ðевозможно ÑоздаÑÑ Ñайл заголовка Ð´Ð»Ñ [%s]"
#: ../lib/gis/legal_name.c:38
#, fuzzy, c-format
msgid "Illegal filename. Cannot be '.' or 'NULL'\n"
-msgstr "îÅÐÒÁ×ÉÌØÎÏ ÚÁÄÁÎÏ ÉÍÑ ÆÁÊÌÁ. îÅ ÍÏÖÅÔ ÂÙÔØ '.' ÉÌÉ 'NULL'\n"
+msgstr "ÐепÑавилÑно задано Ð¸Ð¼Ñ Ñайла. Ðе должно бÑÑÑ '.' или 'NULL'\n"
#, fuzzy, c-format
-msgstr "îÅÐÒÁ×ÉÌØÎÏ ÚÁÄÁÎÏ ÉÍÑ ÆÁÊÌÁ. ÚÎÁË <%c> ÎÅÄÏÐÕÓÔÉÍ."
+msgstr "ÐепÑавилÑно задано Ð¸Ð¼Ñ Ñайла. знак <%c> недопÑÑÑим."
#, fuzzy, c-format
msgid "Output name '%s' is not valid rast name."
-msgstr " ."
+msgstr "ÐÑÑ
одное Ð¸Ð¼Ñ '%s' - недопÑÑÑимое Ð¸Ð¼Ñ Ð´Ð»Ñ ÑаÑÑÑового Ñайла."
#: ../lib/gis/legal_name.c:88 ../lib/gis/legal_name.c:90
#, fuzzy, c-format
msgid "Cannot find input map '%s'"
-msgstr " "
+msgstr "Ðевозможно найÑи вÑ
однÑÑ ÐºÐ°ÑÑÑ '%s'"
#: ../lib/gis/legal_name.c:109 ../lib/gis/legal_name.c:111
#, fuzzy, c-format
msgid "Output map '%s' is used as input"
-msgstr " "
+msgstr "ÐÑÑ
Ð¾Ð´Ð½Ð°Ñ ÐºÐ°ÑÑа '%s' иÑполÑзована как вÑ
однаÑ"
#: ../lib/gis/debug.c:68
#, fuzzy, c-format
msgid "Cannot open debug file '%s'"
-msgstr " "
+msgstr "Ðевозможно оÑкÑÑÑÑ debug-Ñайл '%s'"
#: ../lib/gis/get_datum_name.c:53
#, c-format
@@ -1979,16 +2080,18 @@
"\n"
"Please specify datum name\n"
msgstr ""
+"\n"
+"ÐожалÑйÑÑа, ÑкажиÑе Ð¸Ð¼Ñ Ð´Ð°ÑÑма\n"
#: ../lib/gis/get_datum_name.c:54
#, fuzzy, c-format
msgid "Enter 'list' for the list of available datums\n"
-msgstr "÷×ÅÄÉÔÅ 'list' ÄÌÑ ×Ù×ÏÄÁ ÓÐÉÓËÁ datum\n"
+msgstr "ÐведиÑе 'list' Ð´Ð»Ñ Ð²Ñвода ÑпиÑка доÑÑÑпнÑÑ
даÑÑмов\n"
#: ../lib/gis/get_datum_name.c:55
#, c-format
msgid "or 'custom' if you wish to enter custom parameters\n"
-msgstr ""
+msgstr "или 'custom' еÑли нÑжно ввеÑÑи дÑÑгие паÑамеÑÑÑ\n"
#: ../lib/gis/get_datum_name.c:93
#, c-format
@@ -1996,68 +2099,72 @@
"\n"
"invalid datum\n"
msgstr ""
+"\n"
+"непÑавилÑнÑй даÑÑм\n"
#: ../lib/gis/datum.c:172
#, fuzzy, c-format
msgid "unable to open datum table file: %s"
#: ../lib/gis/datum.c:196
#, fuzzy, c-format
msgid "error in datum table file, line %d"
#: ../lib/gis/list.c:116
#, fuzzy, c-format
msgid "no %s files available in current mapset\n"
-msgstr " "
+msgstr "в ÑекÑÑем набоÑе ÑÐ°Ð¹Ð»Ñ %s недоÑÑÑпнÑ\n"
#: ../lib/gis/list.c:118
#, fuzzy, c-format
msgid "no %s files available in mapset <%s>\n"
-msgstr " "
+msgstr "в набоÑе <%s> ÑÐ°Ð¹Ð»Ñ %s недоÑÑÑпнÑ"
#: ../lib/gis/list.c:132
#, fuzzy, c-format
msgid "hit RETURN to continue -->"
-msgstr "ÎÁÖÍÉÔÅ RETURN ÄÌÑ ÐÒÏÄÏÌÖÅÎÉÑ -->"
+msgstr "нажмиÑе RETURN Ð´Ð»Ñ Ð¿ÑÐ¾Ð´Ð¾Ð»Ð¶ÐµÐ½Ð¸Ñ -->"
#: ../lib/gis/list.c:184
#, fuzzy, c-format
msgid "%s files available in mapset <%s>:\n"
-msgstr "%s ÆÁÊÌÏ× × ÎÁÂÏÒÅ ÄÁÎÎÙÈ %s:\n"
+msgstr "%s Ñайлов в набоÑе даннÑÑ
<%s>:\n"
#: ../lib/gis/list.c:258
#, fuzzy
msgid "G_list: Unknown element type"
+msgstr "G_list: ÐеизвеÑÑнÑй Ñип ÑлеменÑа"
#: ../lib/gis/proj2.c:49
#, fuzzy
msgid "Latitude-Longitude"
-msgstr "ûÉÒÏÔÁ - äÏÌÇÏÔÁ"
+msgstr "ШиÑоÑа-ÐолгоÑа"
#: ../lib/gis/proj2.c:51
#, fuzzy
msgid "Other Projection"
-msgstr "äÒÕÇÁÑ ÐÒÏÅËÃÉÑ"
#: ../lib/gis/opencell.c:185
#, fuzzy, c-format
msgid "unable to open raster map [%s in %s]"
#: ../lib/gis/opencell.c:269
#, fuzzy, c-format
msgid ""
"unable to open [%s] in [%s] since it is a reclass of [%s] in [%s] which does "
"not exist"
-msgstr " "
+msgstr ""
+"невозможно оÑкÑÑÑÑ [%s] в [%s] Ñак как он - пеÑеклаÑÑиÑикаÑÐ¸Ñ [%s] в [%s] "
+"коÑоÑÐ°Ñ Ð½Ðµ ÑÑÑеÑÑвÑеÑ"
#: ../lib/gis/opencell.c:292
#, fuzzy, c-format
msgid "[%s] in mapset [%s]-format field in header file invalid"
-msgstr "[%s] × ÎÁÂ. ÄÁÎÎÙÈ [%s]- ÆÏÒÍÁÔ ÐÏÌÑ × ÆÁÊÌÅ ÚÁÇÏÌÏ×ËÁ ÎÅ×ÅÒÅÎ"
+msgstr "[%s] в набоÑе [%s]-ÑоÑÐ¼Ð°Ñ Ð¿Ð¾Ð»Ñ Ð² Ñайле заголовка невеÑен"
#: ../lib/gis/opencell.c:301
#, fuzzy, c-format
@@ -2065,207 +2172,209 @@
"[%s] in mapset [%s] - in different projection than current region:\n"
" found map [%s] in: <%s>, should be <%s> "
msgstr ""
-" \n"
+"[%s] в набоÑе [%s] - в пÑоекÑии оÑлиÑной Ð¾Ñ Ð¿ÑоекÑии ÑекÑÑего Ñегиона:\n"
+" найдена каÑÑа [%s] в: <%s>, должно бÑÑÑ <%s> "
#: ../lib/gis/opencell.c:308
#, fuzzy, c-format
msgid "[%s] in mapset [%s] - in different zone [%d] than current region [%d]"
-msgstr " "
+msgstr "[%s] в набоÑе [%s] - в дÑÑгой зоне [%d] Ñем ÑекÑÑий Ñегион [%d]"
#: ../lib/gis/opencell.c:316
#, fuzzy, c-format
msgid "[%s] in [%s] - bytes per cell (%d) too large"
-msgstr "[%s] × [%s] - ÂÁÊÔ ÎÁ ËÌÅÔËÕ (%d) ÓÌÉÛËÏÍ ÍÎÏÇÏ"
+msgstr "[%s] в [%s] - Ð±Ð°Ð¹Ñ Ð½Ð° ÑÑÐµÐ¹ÐºÑ (%d) ÑлиÑком много"
#: ../lib/gis/opencell.c:625
#, fuzzy, c-format
msgid "opencell: %s - illegal file name"
-msgstr "opencell: %s - ÎÅÐÒÁ×ÉÌØÎÏÅ ÉÍÑ ÆÁÊÌÁ"
+msgstr "opencell: %s - непÑавилÑное Ð¸Ð¼Ñ Ñайла"
msgstr ""
+"Ðевозможно запиÑаÑÑ Ð½ÑлевÑе знаÑÐµÐ½Ð¸Ñ Ð´Ð»Ñ ÐºÐ°ÑÑÑ Ð¾ÑкÑÑÑой Ð´Ð»Ñ ÑлÑÑайного "
+"доÑÑÑпа"
#, fuzzy, c-format
msgid "unable to find [%s] in [%s]"
#: ../lib/gis/opencell.c:1043
#, fuzzy, c-format
msgid "unable to find [%s]"
-msgstr "ÎÅ ÍÏÇÕ ÎÁÊÔÉ [%s]"
+msgstr "не Ð¼Ð¾Ð³Ñ Ð½Ð°Ð¹Ñи [%s]"
#: ../lib/gis/opencell.c:1049
#, fuzzy, c-format
msgid "Unable to open %s"
#: ../lib/gis/opencell.c:1058
#, fuzzy, c-format
msgid "invalid type: field %s in file %s "
-msgstr "ÎÅ×ÅÒÎÙÊ ÔÉÐ: ÐÏÌÅ %s × ÆÁÊÌÅ %s "
+msgstr "невеÑнÑй Ñип: поле %s в Ñайле %s "
#: ../lib/gis/put_title.c:28
#, fuzzy, c-format
msgid "category information for [%s] in [%s] missing or invalid"
-msgstr "ËÁÔÅÇÏÒÉÉ ÄÌÑ [%s] × [%s] ÏÔÓÕÔÓÔ×ÕÀÔ ÉÌÉ ÚÁÄÁÎÙ ÎÅ×ÅÒÎÏ"
+msgstr "каÑегоÑии Ð´Ð»Ñ [%s] в [%s] оÑÑÑÑÑÑвÑÑÑ Ð¸Ð»Ð¸ Ð·Ð°Ð´Ð°Ð½Ñ Ð½ÐµÐ²ÐµÑно"
#: ../lib/gis/put_title.c:38
#, fuzzy, c-format
msgid "G_put_title - can't create a temp file"
-msgstr "G_put_title - ÎÅ ÍÏÇÕ ÓÏÚÄÁÔØ ×ÒÅÍ. ÆÁÊÌ"
+msgstr "G_put_title - не Ð¼Ð¾Ð³Ñ ÑоздаÑÑ Ð²Ñем. Ñайл"
#: ../lib/gis/put_title.c:58
#, fuzzy, c-format
msgid "category information for [%s] in [%s] invalid"
-msgstr "ËÁÔÅÇÏÒÉÉ ÄÌÑ [%s] × [%s] ÚÁÄÁÎÙ ÎÅ×ÅÒÎÏ"
+msgstr "каÑегоÑии Ð´Ð»Ñ [%s] в [%s] Ð·Ð°Ð´Ð°Ð½Ñ Ð½ÐµÐ²ÐµÑно"
#: ../lib/gis/put_title.c:66
#, fuzzy, c-format
msgid "G_put_title - can't reopen temp file"
-msgstr "G_put_title - ÎÅ ÍÏÇÕ ÚÁÎÏ×Ï ÏÔËÒÙÔØ ×ÒÅÍ. ÆÁÊÌ"
+msgstr "G_put_title - не Ð¼Ð¾Ð³Ñ Ð·Ð°Ð½Ð¾Ð²Ð¾ оÑкÑÑÑÑ Ð²Ñем. Ñайл"
#: ../lib/gis/put_title.c:75
#, fuzzy, c-format
msgid "can't write category information for [%s] in [%s]"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÚÁÐÉÓÁÔØ ËÁÔÅÇÏÒÉÉ ÄÌÑ [%s] × [%s]"
+msgstr "невозможно запиÑаÑÑ ÐºÐ°ÑегоÑии Ð´Ð»Ñ [%s] в [%s]"
#: ../lib/gis/quant_io.c:92
#, fuzzy, c-format
msgid "The floating data range for %s@%s is empty"
-msgstr "äÉÁÐÁÚÏÎ Ó ÐÌÁ×. ÔÏÞËÏÊ ÄÌÑ %s@%s ÐÕÓÔ"
+msgstr "Ðиапазон Ñ Ð¿Ð»Ð°Ð². ÑоÑкой Ð´Ð»Ñ %s@%s пÑÑÑ"
#: ../lib/gis/quant_io.c:101
#, fuzzy, c-format
msgid "The integer data range for %s@%s is empty"
-msgstr "äÉÁÐÁÚÏÎ ÃÅÌÙÈ ÞÉÓÅÌ ÄÌÑ %s@%s ÐÕÓÔ"
+msgstr "Ðиапазон ÑелÑÑ
ÑиÑел Ð´Ð»Ñ %s@%s пÑÑÑ"
#: ../lib/gis/quant_io.c:167
#, fuzzy, c-format
msgid "quantization file [%s] in mapset [%s] %s"
-msgstr "ÆÁÊÌ ÒÁÚÂÉÅÎÉÑ ÚÎÁÞÅÎÉÊ [%s] × ÎÁÂ. ÄÁÎÎÙÈ [%s] %s"
+msgstr "Ñайл ÑÐ°Ð·Ð±Ð¸ÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений [%s] в наб. даннÑÑ
[%s] %s"
#: ../lib/gis/system.c:90
msgid "Can not create a new process!"
-msgstr ""
+msgstr "Ðевозможно ÑоздаÑÑ Ð½Ð¾Ð²Ñй пÑоÑеÑÑ!"
#: ../lib/gis/myname.c:51
#, fuzzy
msgid "Unknown Location"
-msgstr "ïâìáóôø ÎÅÉÚ×ÅÓÔÎÁ"
+msgstr "ÐÐÐÐСТЬ неизвеÑÑна"
#: ../lib/gis/color_rules.c:115
msgid "syntax error"
-msgstr ""
+msgstr "ÑинÑакÑиÑеÑÐºÐ°Ñ Ð¾Ñибка"
#: ../lib/gis/color_rules.c:116
msgid "R/G/B not in range 0-255"
-msgstr ""
+msgstr "R/G/B вне диапазона 0-255"
#: ../lib/gis/color_rules.c:117
#, fuzzy
msgid "invalid color name"
-msgstr "îÅ×ÅÒÎÙÅ ËÏÏÒÄÉÎÁÔÙ"
+msgstr "ÐевеÑное Ð¸Ð¼Ñ ÑвеÑа"
#: ../lib/gis/color_rules.c:118
msgid "percentage not in range 0-100"
-msgstr ""
+msgstr "пÑоÑÐµÐ½Ñ Ð²Ð½Ðµ диапазона 0-100"
#: ../lib/gis/color_rules.c:119
msgid "invalid value"
-msgstr ""
+msgstr "невеÑное знаÑение"
#: ../lib/gis/color_rules.c:120
#, fuzzy
msgid "unknown error"
-#: ../lib/gis/color_rules.c:151
-#, c-format
-msgid "bad rule (%s): %s"
-msgstr ""
+#: ../lib/gis/color_rules.c:152
+#, fuzzy, c-format
+msgid "bad rule (%s): [%s]"
+msgstr "непÑавилÑное пÑавило (%s): %s"
#: ../lib/gis/spawn.c:77 ../lib/gis/spawn.c:110
#, fuzzy
msgid "Too many arguments"
-msgstr "óÌÉÛËÏÍ ÍÎÏÇÏ ÏÔËÒÙÔÙÈ ÆÁÊÌÏ×"
+msgstr "СлиÑком много оÑкÑÑÑÑÑ
Ñайлов"
-#: ../lib/gis/spawn.c:132 ../lib/gis/spawn.c:385
+#: ../lib/gis/spawn.c:132 ../lib/gis/spawn.c:408
#, fuzzy
msgid "Unable to create a new process"
-#: ../lib/gis/spawn.c:142 ../lib/gis/spawn.c:410
+#: ../lib/gis/spawn.c:142 ../lib/gis/spawn.c:232 ../lib/gis/spawn.c:433
#, fuzzy
msgid "Unable to execute command"
-#: ../lib/gis/spawn.c:237 ../lib/gis/spawn.c:245
+#: ../lib/gis/spawn.c:260 ../lib/gis/spawn.c:268
#, c-format
msgid "G_spawn: unable to restore signal %d"
-msgstr ""
+msgstr "G_spawn: невозможно воÑÑÑановиÑÑ Ñигнал %d"
-#: ../lib/gis/spawn.c:278
+#: ../lib/gis/spawn.c:301
#, c-format
msgid "G_spawn: unable to reset signal %d"
-msgstr ""
+msgstr "G_spawn: невозможно ÑбÑоÑиÑÑ Ñигнал %d"
-#: ../lib/gis/spawn.c:288
+#: ../lib/gis/spawn.c:311
#, c-format
msgid "G_spawn: unable to ignore signal %d"
-msgstr ""
+msgstr "G_spawn: невозможно игноÑиÑоваÑÑ Ñигнал %d"
-#: ../lib/gis/spawn.c:299
+#: ../lib/gis/spawn.c:322
#, c-format
msgid "G_spawn: unable to block signal %d"
-msgstr ""
+msgstr "G_spawn: невозможно заблокиÑоваÑÑ Ñигнал %d"
-#: ../lib/gis/spawn.c:308
+#: ../lib/gis/spawn.c:331
#, c-format
msgid "G_spawn: unable to unblock signal %d"
-msgstr ""
+msgstr "G_spawn: невозможно ÑазблокиÑоваÑÑ Ñигнал %d"
-#: ../lib/gis/spawn.c:334
+#: ../lib/gis/spawn.c:357
#, fuzzy, c-format
msgid "G_spawn: unable to open file %s"
msgstr " "
-#: ../lib/gis/spawn.c:340 ../lib/gis/spawn.c:350
+#: ../lib/gis/spawn.c:363 ../lib/gis/spawn.c:373
#, c-format
msgid "G_spawn: unable to duplicate descriptor %d to %d"
-msgstr ""
+msgstr "G_spawn: невозможно дÑблиÑоваÑÑ Ð´ÐµÑкÑипÑÐ¾Ñ %d to %d"
-#: ../lib/gis/spawn.c:402
+#: ../lib/gis/spawn.c:425
#, fuzzy, c-format
msgid "Unable to change directory to %s"
msgstr " "
-#: ../lib/gis/mapset.c:41
+#: ../lib/gis/mapset.c:39
#, fuzzy
msgid "MAPSET is not set"
-msgstr "îáâïò äáîîùè ÎÅ ÚÁÄÁÎ"
+msgstr "ÐÐÐÐРне задан"
-#: ../lib/gis/mapset.c:60 ../lib/gis/gisinit.c:58
+#: ../lib/gis/mapset.c:58 ../lib/gis/gisinit.c:58
#, fuzzy, c-format
msgid "MAPSET %s not found"
-msgstr "îáâïò äáîîùè %s ÎÅ ÎÁÊÄÅÎ"
+msgstr "ÐÐÐÐÐ %s не найден"
#: ../lib/gis/gishelp.c:49
#, fuzzy, c-format
msgid "one moment...\n"
-msgstr "ÏÄÉÎ ÍÏÍÅÎÔ...\n"
+msgstr "один моменÑ...\n"
#: ../lib/gis/gishelp.c:54
#, fuzzy, c-format
msgid "No help available for command [%s]\n"
-msgstr "ðÏÍÏÝØ ÄÌÑ ËÏÍÁÎÄÙ [%s] ÏÔÓÕÔÓÔ×ÕÅÔ\n"
+msgstr "ÐÐµÑ ÑпÑавки Ð´Ð»Ñ ÐºÐ¾Ð¼Ð°Ð½Ð´Ñ [%s]\n"
#: ../lib/gis/make_colr.c:41
#, fuzzy, c-format
msgid " The raster map %s@%s is empty"
#: ../lib/gis/make_colr.c:49
#, fuzzy, c-format
@@ -2273,7 +2382,10 @@
"\n"
"\n"
"Color table needed for file [%s] in mapset [%s].\n"
-msgstr " "
+msgstr ""
+"\n"
+"\n"
+"ÐеобÑ
одима ÑвеÑÐ¾Ð²Ð°Ñ Ð´Ð»Ñ Ñайла [%s] в набоÑе [%s].\n"
#: ../lib/gis/make_colr.c:52
#, c-format
@@ -2281,128 +2393,130 @@
"\n"
"Please identify the type desired:\n"
msgstr ""
+"\n"
+"ÐожалÑйÑÑа, опÑеделиÑе нÑжнÑй Ñип:\n"
#: ../lib/gis/make_colr.c:53
#, fuzzy, c-format
msgid " 1: Random colors\n"
-msgstr " 1: óÌÕÞÁÊÎÙÅ Ã×ÅÔÁ\n"
+msgstr " 1: СлÑÑайнÑе ÑвеÑа\n"
#: ../lib/gis/make_colr.c:54
#, fuzzy, c-format
msgid " 2: Red, green, and blue color ramps\n"
-msgstr " 2: ëÒÁÓÎ., ÚÅÌÅÎ., É ÓÉÎ. Ó ÒÁÚÂÉÅÎÉÅÍ\n"
+msgstr " 2: ÐÑаÑнаÑ, зеленаÑ, и ÑинÑÑ ÑвеÑÐ¾Ð²Ð°Ñ Ñкала\n"
#: ../lib/gis/make_colr.c:55
#, fuzzy, c-format
msgid " 3: Color wave\n"
-msgstr " 3: ã×ÅÔÏ×ÁÑ ÇÁÍÍÁ\n"
+msgstr " 3: ЦвеÑÐ¾Ð²Ð°Ñ Ð³Ð°Ð¼Ð¼Ð°\n"
#: ../lib/gis/make_colr.c:56
#, fuzzy, c-format
msgid " 4: Gray scale\n"
-msgstr " 4: ïÔÔÅÎËÉ ÓÅÒÏÇÏ\n"
+msgstr " 4: ÐÑÑенки ÑеÑого\n"
#: ../lib/gis/make_colr.c:57
#, fuzzy, c-format
msgid " 5: Aspect\n"
-msgstr " 5: áÓÐÅËÔ\n"
+msgstr " 5: ÐÑпекÑ\n"
#: ../lib/gis/make_colr.c:58
#, fuzzy, c-format
msgid " 6: Rainbow colors\n"
-msgstr " 6: òÁÄÕÇÁ\n"
+msgstr " 6: РадÑга\n"
#: ../lib/gis/make_colr.c:59
#, fuzzy, c-format
msgid " 7: Red through yellow to green\n"
-msgstr " 7: ïÔ ËÒÁÓÎ. ÞÅÒÅÚ ÖÅÌÔ. ÄÏ ÚÅÌÅÎ.\n"
+msgstr " 7: ÐÑ ÐºÑаÑного ÑеÑез желÑÑй до зеленого\n"
#: ../lib/gis/make_colr.c:60
#, fuzzy, c-format
msgid " 8: Green through yellow to red\n"
-msgstr " 8: ïÔ ÚÅÌÅÎ. ÞÅÒÅÚ ÖÅÌÔ. ÄÏ ËÒÁÓÎ.\n"
+msgstr " 8: ÐÑ Ð·ÐµÐ»ÐµÐ½Ð¾Ð³Ð¾ ÑеÑез желÑÑй до кÑаÑного\n"
#: ../lib/gis/make_colr.c:61
#, c-format
msgid "RETURN quit\n"
-msgstr ""
+msgstr "RETURN quit\n"
#: ../lib/gis/make_colr.c:82
#, fuzzy, c-format
msgid ""
"\n"
"%s invalid; Try again > "
-msgstr " "
+msgstr "%s невеÑен; ÐопÑобÑйÑе еÑе Ñаз > "
#: ../lib/gis/range.c:195
#, fuzzy, c-format
msgid "can't read f_range file for [%s in %s]"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÐÒÏÞÉÔÁÔØ f_range ÆÁÊÌ ÄÌÑ [%s × %s]"
+msgstr "невозможно пÑоÑиÑаÑÑ f_range Ñайл Ð´Ð»Ñ [%s в %s]"
#: ../lib/gis/range.c:312
#, fuzzy, c-format
msgid "can't read range file for [%s in %s]"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÐÒÏÞÉÔÁÔØ ÆÁÊÌ ÄÉÁÐÁÚÏÎÁ ÄÌÑ [%s × %s]"
+msgstr "невозможно пÑоÑиÑаÑÑ Ñайл диапазона Ð´Ð»Ñ [%s в %s]"
#, fuzzy, c-format
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÚÁÐÉÓÁÔØ ÆÁÊÌ ÄÉÁÐÁÚÏÎÁ ÄÌÑ [%s × %s]"
+msgstr "невозможно запиÑаÑÑ Ñайл диапазона Ð´Ð»Ñ [%s в %s]"
#, fuzzy, c-format
msgid "MAPSET %s - permission denied"
-msgstr "îáâïò äáîîùè %s - ÄÏÓÔÕÐ ÎÅ ÒÁÚÒÅÛÅÎ"
+msgstr "ÐÐÐÐÐ %s - доÑÑÑп запÑеÑен"
#, fuzzy
-msgstr "\aïûéâëá: óÉÓÔÅÍÁ ÎÅ ÂÙÌÁ ÉÎÉÃÉÁÌÉÚÉÒÏ×ÁÎÁ. úÁÂÙÌÉ G_gisinit()\n"
+msgstr "\aÐШÐÐÐÐ: СиÑÑема не иниÑиализиÑована. Ðе вÑполнен G_gisinit()\n"
-#: ../lib/gis/get_row.c:47 ../lib/gis/get_row.c:939
+#: ../lib/gis/get_row.c:47 ../lib/gis/get_row.c:937
#, fuzzy, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr "[%s × %s] - ÞÔÅÎÉÅ ÓÔÒÏËÉ %d ÚÁ ÐÒÅÄÅÌÁÍÉ ÒÅÇÉÏÎÁ"
+msgstr "[%s в %s] - ÑÑение ÑÑÑоки %d за пÑеделами Ñегиона"
#: ../lib/gis/get_row.c:315
#, c-format
msgid "cell_values_float: xdr_float failed for index %d"
-msgstr ""
+msgstr "cell_values_float: xdr_float завеÑÑен неÑдаÑно Ð´Ð»Ñ Ð¸Ð½Ð´ÐµÐºÑа %d"
#: ../lib/gis/get_row.c:359
-#, c-format
+#, fuzzy, c-format
msgid "cell_values_double: xdr_double failed for index %d"
-msgstr ""
+msgstr "cell_values_double: xdr_double завеÑÑен неÑдаÑно Ð´Ð»Ñ Ð¸Ð½Ð´ÐµÐºÑа %d."
#: ../lib/gis/get_row.c:504
#, fuzzy, c-format
msgid "Error reading compressed map <%s@%s>, row %d"
-msgstr " "
+msgstr "оÑибка ÑÑÐµÐ½Ð¸Ñ ÑжаÑой каÑÑÑ [%s] из набоÑа [%s], ÑÑд %d"
#: ../lib/gis/get_row.c:507
#, fuzzy, c-format
msgid "Error reading map <%s@%s>, row %d"
-msgstr " "
+msgstr "оÑибка ÑÑÐµÐ½Ð¸Ñ ÐºÐ°ÑÑÑ [%s] в набоÑе [%s], ÑÑд %d"
-#: ../lib/gis/get_row.c:919 ../lib/gis/get_row.c:925
+#: ../lib/gis/get_row.c:917 ../lib/gis/get_row.c:923
#, fuzzy, c-format
msgid "Error reading null row %d"
-msgstr " "
+msgstr "оÑибка ÑÑÐµÐ½Ð¸Ñ Ð½Ñлевого ÑÑда %d"
-#: ../lib/gis/get_row.c:1006
+#: ../lib/gis/get_row.c:1004
#, fuzzy
msgid "Unable to realloc buffer"
-msgstr "îÅ×ÏÚÍÏÖÎÏ realloc ÂÕÆÅÒ"
+msgstr "Ðевозможно realloc бÑÑеÑ"
#: ../lib/gis/get_projname.c:32
#, fuzzy, c-format
msgid "%s not found"
-msgstr "%s ÎÅ ÎÁÊÄÅÎ"
+msgstr "%s не найден"
#: ../lib/gis/get_projname.c:35
#, fuzzy, c-format
msgid "ERROR in reading %s"
-msgstr "ïÛÉÂËÁ ÞÔÅÎÉÑ %s"
+msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ %s"
#: ../lib/gis/get_projname.c:49
#, c-format
@@ -2411,11 +2525,14 @@
"\n"
"Please specify projection name\n"
msgstr ""
+"\n"
+"\n"
+"ÐожалÑйÑÑа, задайÑе название пÑоекÑии\n"
#: ../lib/gis/get_projname.c:50
#, fuzzy, c-format
msgid "Enter 'list' for the list of available projections\n"
-msgstr "÷×ÅÄÉÔÅ 'list' ÄÌÑ ÓÐÉÓËÁ ×ÏÚÍÏÖÎÙÈ ÐÒÏÅËÃÉÊ\n"
+msgstr "ÐведиÑе 'list' Ð´Ð»Ñ ÑпиÑка возможнÑÑ
пÑоекÑий\n"
#: ../lib/gis/get_projname.c:72
#, c-format
@@ -2423,38 +2540,41 @@
"\n"
"invalid projection\n"
msgstr ""
+"\n"
+"невеÑÐ½Ð°Ñ Ð¿ÑоекÑиÑ\n"
#: ../lib/gis/ask_cell.c:56 ../lib/gis/ask_cell.c:75 ../lib/gis/ask_cell.c:94
#: ../lib/gis/ask_cell.c:101
#, fuzzy
msgid "with titles"
-msgstr "Ó ÎÁÚ×ÁÎÉÑÍÉ"
+msgstr "Ñ Ð½Ð°Ð·Ð²Ð°Ð½Ð¸Ñми"
#: ../lib/gis/ask_cell.c:113
#, fuzzy
msgid "(no title)"
-msgstr "(ÂÅÚ ÎÁÚ×ÁÎÉÑ)"
+msgstr "(без названиÑ)"
#: ../lib/gis/ls.c:63
#, fuzzy, c-format
msgid "Unable to open directory %s"
-msgstr " "
#: ../lib/gis/set_window.c:82
msgid ""
"maps"
msgstr ""
+"G_set_window(): пÑоекÑиÑ/зона оÑлиÑаеÑÑÑ Ð¾Ñ ÑекÑÑиÑ
оÑкÑÑÑÑÑ
ÑаÑÑÑовÑÑ
каÑÑ"
#, fuzzy, c-format
msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr "ïÛÉÂËÁ ÞÔÅÎÉÑ ÓÖÁÔÏÇÏ ÆÁÊÌÁ [%s × %s]"
+msgstr "ÐÑибка ÑÑÐµÐ½Ð¸Ñ ÑжаÑого Ñайла [%s в %s]"
#: ../lib/gis/put_row.c:212
#, fuzzy, c-format
msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-msgstr " !"
+msgstr "G_put_map_row: %s не Ñелое! ÐÑполÑзÑйÑе G_put_[f/d]_raster_row()!"
#: ../lib/gis/put_row.c:249
#, fuzzy, c-format
@@ -2479,17 +2599,17 @@
#: ../lib/gis/put_row.c:308
#, fuzzy, c-format
msgid "map [%s] - unable to write row %d"
#: ../lib/gis/put_row.c:396
#, c-format
msgid "xdr_float failed for index %d of row %d"
-msgstr ""
+msgstr "xdr_float завеÑÑен неÑдаÑно Ð´Ð»Ñ Ð¸Ð½Ð´ÐµÐºÑа %d ÑÑда %d"
#: ../lib/gis/put_row.c:425
#, c-format
msgid "xdr_double failed for index %d of row %d"
-msgstr ""
+msgstr "xdr_double завеÑÑен неÑдаÑно Ð´Ð»Ñ Ð¸Ð½Ð´ÐµÐºÑа %d ÑÑда %d"
#: ../lib/gis/put_row.c:769
#, fuzzy, c-format
@@ -2499,20 +2619,21 @@
#: ../lib/gis/put_row.c:790 ../lib/gis/put_row.c:796
#, c-format
msgid "error writing null row %d"
-msgstr ""
+msgstr "оÑибка пÑи запиÑи нÑлевой ÑÑÑоки %d"
#: ../lib/gis/history.c:184
#, fuzzy, c-format
msgid "can't write history information for [%s]"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÚÁÐÉÓÁÔØ ÉÓÔÏÒÉÀ ÄÌÑ [%s]"
+msgstr "невозможно запиÑаÑÑ Ð¸ÑÑоÑÐ¸Ñ Ð´Ð»Ñ [%s]"
#: ../lib/gis/history.c:269
msgid "Not enough room in history file to record command line."
-msgstr ""
+msgstr "ÐедоÑÑаÑоÑно меÑÑа в Ñайле иÑÑоÑии Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи командной ÑÑÑоки"
#: ../lib/gis/history.c:291
msgid "Not enough room in history file for command line (truncated)."
msgstr ""
+"ÐедоÑÑаÑоÑно меÑÑа в Ñайле иÑÑоÑии Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи командной ÑÑÑоки (truncated)"
#: ../lib/gis/closecell.c:223
#, fuzzy, c-format
@@ -2524,7 +2645,7 @@
#: ../lib/gis/closecell.c:243
#, fuzzy, c-format
msgid "Error writing floating point format file for map %s"
#: ../lib/gis/closecell.c:289
#, fuzzy, c-format
@@ -2535,307 +2656,310 @@
#: ../lib/gis/closecell.c:343
msgid "unable to write quant file!"
-msgstr ""
#: ../lib/gis/closecell.c:391
msgid "unable to write f_format file for CELL maps"
-msgstr ""
+msgstr "невозможно запиÑаÑÑ Ñайл f_format Ð´Ð»Ñ CELL каÑÑ"
#: ../lib/gis/home.c:40
#, fuzzy
msgid "unable to determine user's home directory"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÕÓÔÁÎÏ×ÉÔØ ÄÏÍÁÛÎÉÊ ËÁÔÁÌÏÇ ÐÏÌØÚÏ×ÁÔÅÌÑ"
+msgstr "невозможно опÑеделиÑÑ Ð´Ð¾Ð¼Ð°Ñний каÑалог полÑзоваÑелÑ"
-#: ../lib/gis/error.c:315
+#: ../lib/gis/error.c:308
#, fuzzy
msgid "WARNING: "
-msgstr "ðòåäõðòåöäåîéå "
+msgstr "ÐÐ ÐÐУÐÐ ÐÐÐÐÐÐÐ: "
-#: ../lib/gis/error.c:316
+#: ../lib/gis/error.c:309
#, fuzzy
msgid "ERROR: "
-msgstr "ïûéâëá "
+msgstr "ÐШÐÐÐÐ: "
#: ../lib/gis/get_cellhd.c:74 ../lib/gis/get_cellhd.c:103
#, fuzzy, c-format
msgid "Unable to read header file for raster map <%s@%s>."
#: ../lib/gis/get_cellhd.c:76
#, fuzzy, c-format
msgid " It is a reclass of raster map <%s@%s> "
-msgstr "üÔÏ ÒÅËÌÁÓÓ ÏÔ [%s × %s]"
+msgstr "ÐÑо пеÑеклаÑÑиÑикаÑÐ¸Ñ [%s в %s]"
#: ../lib/gis/get_cellhd.c:79
#, fuzzy, c-format
msgid "which is missing."
-msgstr "ËÏÔÏÒÙÊ ÏÔÓÕÔÓÔ×ÕÅÔ"
+msgstr "коÑоÑÑй оÑÑÑÑÑÑвÑеÑ"
#: ../lib/gis/get_cellhd.c:81
#, fuzzy, c-format
msgid "whose header file can't be opened."
-msgstr "ÞÅÊ ÆÁÊÌ ÚÁÇÏÌÏ×ËÁ ÎÅ ÍÏÖÅÔ ÂÙÔØ ÏÔËÒÙÔ"
+msgstr "Ñей Ñайл заголовка не Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¾ÑкÑÑÑ"
#: ../lib/gis/get_cellhd.c:91
#, fuzzy, c-format
msgid "Unable to open header file for raster map <%s@%s>"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/gis/get_cellhd.c:107
#, fuzzy, c-format
msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-msgstr "üÔÏ ÒÅËÌÁÓÓ ÏÔ [%s × %s] ÞÅÊ ÆÁÊÌ ÚÁÇÏÌÏ×ËÁ ÉÍÅÅÔ ÎÅ×ÅÒÎÙÊ ÆÏÒÍÁÔ\n"
+msgstr ""
+"ÐÑо пеÑеклаÑÑиÑикаÑÐ¸Ñ [%s в %s] Ñей Ñайл заголовка Ð¸Ð¼ÐµÐµÑ Ð½ÐµÐ²ÐµÑнÑй ÑоÑмаÑ\n"
#: ../lib/gis/get_cellhd.c:111
#, fuzzy, c-format
msgid " Invalid format."
-msgstr "îÅ×ÅÒÎÙÊ ÆÏÒÍÁÔ\n"
+msgstr "ÐевеÑнÑй ÑоÑмаÑ\n"
#: ../lib/gis/cats.c:385
#, fuzzy, c-format
msgid "category support for [%s] in mapset [%s] %s"
-msgstr "ËÁÔÅÇÏÒÉÉ [%s] × ÎÁÂÏÒÅ ÄÁÎÎÙÈ [%s] %s"
+msgstr "каÑегоÑии [%s] в набоÑе [%s] %s"
#: ../lib/gis/cats.c:424
#, fuzzy, c-format
msgid "category support for vector map [%s] in mapset [%s] %s"
-msgstr "ËÁÔÅÇÏÒÉÉ ×ÅËÔÏÒÎÏÊ ËÁÒÔÙ[%s] × ÎÁÂÏÒÅ ÄÁÎÎÙÈ [%s] %s"
+msgstr "каÑегоÑии векÑоÑной каÑÑÑ [%s] в набоÑе [%s] %s"
#: ../lib/gis/get_ellipse.c:87
#, fuzzy, c-format
msgid "Unable to open file %s in <%s>"
#: ../lib/gis/get_ellipse.c:345
#, fuzzy, c-format
msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr " "
+msgstr "ÐевеÑнÑе линии %s в Ñайле ÑаблиÑÑ ÑллипÑоидов <%s>"
#: ../lib/gis/get_ellipse.c:346
#, fuzzy, c-format
msgid "Line%s of ellipsoid table file <%s> is invalid"
-msgstr "ìÉÎÉÑ "
+msgstr "ÐевеÑÐ½Ð°Ñ Ð»Ð¸Ð½Ð¸Ñ %s в Ñайле ÑаблиÑÑ ÑллипÑоидов <%s>"
#: ../lib/gis/get_ellipse.c:365 ../lib/gis/get_ellipse.c:391
#, fuzzy, c-format
msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "ÎÅ×ÅÒÎÏ ÚÁÄÁÎÏ ÐÏÌÅ a: %s × ÆÁÊÌÅ %s × %s"
+msgstr "невеÑно задано поле a: %s в Ñайле %s в %s"
#: ../lib/gis/get_ellipse.c:378
#, fuzzy, c-format
msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "ÎÅ×ÅÒÎÏ ÚÁÄÁÎ ÜÌÌÉÐÓÏÉÄ %s × ÆÁÊÌÅ %s × %s"
+msgstr "невеÑно задан ÑллипÑоид %s в Ñайле %s в %s"
#: ../lib/gis/get_ellipse.c:395
#, fuzzy, c-format
msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "ÎÅ×ÅÒÎÏ ÚÁÄÁÎÏ ÐÏÌÅ es: %s × ÆÁÊÌÅ %s × %s"
+msgstr "невеÑно задано поле es: %s в Ñайле %s в %s"
#, fuzzy, c-format
-msgstr "îÅÔ ÉÎÆÏÒÍÁÃÉÉ Ï ÜÌÌÉÐÓÏÉÄÅ × ÆÁÊÌÅ %s × %s"
+msgstr "ÐÐµÑ Ð¸Ð½ÑоÑмаÑии об ÑллипÑоиде в Ñайле %s в %s"
#, fuzzy, c-format
msgid "LOCATION << %s >> not available"
-msgstr " "
+msgstr "ÐблаÑÑÑ << %s >> недоÑÑÑпна"
#: ../lib/gis/null_val.c:94
#, fuzzy
msgid "EmbedGivenNulls: wrong data type!"
-msgstr "EmbedGivenNulls: ÎÅ×ÅÒÎÙÊ ÔÉÐ ÄÁÎÎÙÈ!"
+msgstr "EmbedGivenNulls: невеÑнÑй Ñип даннÑÑ
#: ../lib/gis/null_val.c:115
#, fuzzy
msgid "Null values have not been initialized. "
-msgstr "îÕÌÅ×ÙÅ ×ÅÌÉÞÉÎÙ ÎÅ ÂÙÌÉ ÉÎÉÃÉÁÌÉÚÉÒÏ×ÁÎÙ."
+msgstr "ÐÑлевÑе велиÑÐ¸Ð½Ñ Ð½Ðµ бÑли иниÑиализиÑованÑ."
#: ../lib/gis/null_val.c:116
#, fuzzy
msgid "G_gisinit() must be called first. "
-msgstr "óÎÁÞÁÌÁ ÎÕÖÎÏ ×ÙÚ×ÁÔØ G_gisinit(). "
+msgstr "СнаÑала нÑжно вÑзваÑÑ G_gisinit(). "
#, fuzzy
-msgstr "óÏÏÂÝÉÔÅ ÒÁÚÒÁÂÏÔÞÉËÁÍ GRASS ÏÂ ÜÔÏÊ ÏÛÉÂËÅ.\n"
+msgstr "СообÑиÑе ÑазÑабоÑÑикам GRASS об ÑÑой оÑибке.\n"
#, fuzzy
-msgstr "G_set_null_value: ÎÅ×ÅÒÎÙÊ ÔÉÐ ÄÁÎÎÙÈ!"
+msgstr "G_set_null_value: невеÑнÑй Ñип даннÑÑ
#: ../lib/gis/get_projinfo.c:36 ../lib/gis/get_projinfo.c:67
#, fuzzy, c-format
msgid "<%s> file not found for location <%s>"
-msgstr "æÁÊÌ %s ÎÅ ÎÁÊÄÅÎ ÄÌÑ ÏÂÌÁÓÔÉ %s\n"
+msgstr "Файл <%s> не найден Ð´Ð»Ñ Ð¾Ð±Ð»Ð°ÑÑи <%s>\n"
#: ../lib/gis/get_projinfo.c:43 ../lib/gis/get_projinfo.c:74
#, fuzzy, c-format
msgid "ERROR in reading <%s> file for location <%s>"
-msgstr "ïûéâëá ÞÔÅÎÉÑ ÆÁÊÌÁ %s ÄÌÑ ÏÂÌÁÓÔÉ %s\n"
+msgstr "ÐШÐÐÐÐ ÑÑÐµÐ½Ð¸Ñ Ñайла %s Ð´Ð»Ñ Ð¾Ð±Ð»Ð°ÑÑи %s\n"
-#: ../lib/gis/mapset_msc.c:49
+#: ../lib/gis/mapset_msc.c:63
#, fuzzy, c-format
-msgid "can't make mapset element %s (%s)"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÓÏÚÄÁÔØ ÜÌÅÍÅÎÔ ÎÁÂ. ÄÁÎÎÙÈ %s (%s)"
+msgid "Unable to make mapset element %s (%s)"
+msgstr "невозможно ÑоздаÑÑ ÑÐ»ÐµÐ¼ÐµÐ½Ñ Ð½Ð°Ð±Ð¾Ñа %s (%s)"
#: ../lib/gis/parser.c:345
msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
+msgstr "ÑÑÐ»Ð¾Ð²Ð¸Ñ WHERE SQL-запÑоÑа не Ð¸Ð¼ÐµÐµÑ ÐºÐ»ÑÑевого Ñлова 'where'"
#: ../lib/gis/parser.c:346
msgid "Example: income < 1000 and inhab >= 10000"
-msgstr ""
+msgstr "ÐÑимеÑ: income < 1000 and inhab >= 10000"
#: ../lib/gis/parser.c:354
msgid "Table name"
-msgstr ""
+msgstr "ÐÐ¼Ñ ÑаблиÑÑ"
#: ../lib/gis/parser.c:362
msgid "Driver name"
-msgstr ""
+msgstr "Ðазвание дÑайвеÑа"
#: ../lib/gis/parser.c:370
msgid "Database name"
-msgstr ""
+msgstr "Ðазвание Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
#: ../lib/gis/parser.c:378
#, fuzzy
msgid "Name of attribute column"
-msgstr "×ÅËÔÏÒ"
+msgstr "ÐÐ¼Ñ Ð¿Ð¾Ð»Ñ"
#: ../lib/gis/parser.c:386
#, fuzzy
msgid "Name of attribute column(s)"
-msgstr "×ÅËÔÏÒ"
+msgstr "ÐÐ¼Ñ Ð¿Ð¾Ð»Ñ(ей)"
#: ../lib/gis/parser.c:396
#, fuzzy
msgid "Name of input imagery group"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одной гÑÑÐ¿Ð¿Ñ Ð¸Ð·Ð¾Ð±Ñажений"
#: ../lib/gis/parser.c:406 ../lib/gis/parser.c:431
msgid "Name of input raster map"
-msgstr ""
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одной ÑаÑÑÑовой каÑÑÑ"
#: ../lib/gis/parser.c:415 ../lib/gis/parser.c:440
#, fuzzy
msgid "Name of input raster map(s)"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одной ÑаÑÑÑовой каÑÑ(Ñ)"
#: ../lib/gis/parser.c:423
msgid "Name for output raster map"
-msgstr ""
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
#: ../lib/gis/parser.c:448
msgid "Name of base raster map"
-msgstr ""
+msgstr "ÐÐ¼Ñ Ð±Ð°Ð·Ð¾Ð²Ð¾Ð¹ ÑаÑÑÑовой каÑÑÑ"
#: ../lib/gis/parser.c:456
msgid "Name of cover raster map"
-msgstr ""
+msgstr "ÐÐ¼Ñ Ð²ÐµÑÑ
ней ÑаÑÑÑовой каÑÑÑ"
#: ../lib/gis/parser.c:464
#, fuzzy
msgid "Name of elevation raster map"
-msgstr " "
+msgstr "ÐÐ¼Ñ ÑаÑÑÑовой каÑÑÑ ÑелÑеÑа"
#: ../lib/gis/parser.c:473
#, fuzzy
msgid "Name of elevation raster map(s)"
-msgstr " "
+msgstr "ÐÐ¼Ñ ÑаÑÑÑовÑÑ
(ой) каÑÑ(Ñ) ÑелÑеÑа"
#: ../lib/gis/parser.c:483 ../lib/gis/parser.c:508
#, fuzzy
msgid "Name of input raster3d map"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одной raster3d каÑÑÑ"
#: ../lib/gis/parser.c:492 ../lib/gis/parser.c:517
#, fuzzy
msgid "Name of input raster3d map(s)"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
однÑÑ
(ой) raster3d каÑÑ(Ñ)"
#: ../lib/gis/parser.c:500
#, fuzzy
msgid "Name for output raster3d map"
-msgstr "×ÅËÔÏÒ"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
#: ../lib/gis/parser.c:527 ../lib/gis/parser.c:552
#, fuzzy
msgid "Name of input vector map"
-msgstr "×ÅËÔÏÒ"
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одной векÑоÑной каÑÑÑ"
#: ../lib/gis/parser.c:536 ../lib/gis/parser.c:561
#, fuzzy
msgid "Name of input vector map(s)"
-msgstr "×ÅËÔÏÒ"
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
однÑÑ
(ой) векÑоÑнÑÑ
(ой) каÑÑ(Ñ)"
#: ../lib/gis/parser.c:544
#, fuzzy
msgid "Name for output vector map"
-msgstr "×ÅËÔÏÒ"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
#: ../lib/gis/parser.c:570
msgid "Type"
-msgstr ""
+msgstr "Тип"
#: ../lib/gis/parser.c:571
msgid "Feature type(s)"
-msgstr ""
#: ../lib/gis/parser.c:578
msgid "Layer number"
-msgstr ""
+msgstr "ÐÐ¾Ð¼ÐµÑ ÑлоÑ"
#: ../lib/gis/parser.c:579
msgid ""
"A single vector map can be connected to multiple database tables. This "
"number determines which table to use."
msgstr ""
+"ÐдинÑÑÐ²ÐµÐ½Ð½Ð°Ñ Ð²ÐµÐºÑоÑÐ½Ð°Ñ ÐºÐ°ÑÑа Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ Ð¿Ð¾Ð´ÐºÐ»ÑÑена к неÑколÑким ÑаблиÑами "
+"Ð±Ð°Ð·Ñ Ð´Ð°Ð½Ð½ÑÑ
. ÐÑо ÑиÑло опÑеделÑÐµÑ ÐºÐ°ÐºÑÑ ÑаблиÑÑ Ð¸ÑполÑзоваÑÑ."
#: ../lib/gis/parser.c:586
msgid "Category value"
-msgstr ""
+msgstr "ÐнаÑение каÑегоÑии"
#: ../lib/gis/parser.c:593
msgid "Category values"
-msgstr ""
+msgstr "ÐнаÑÐµÐ½Ð¸Ñ ÐºÐ°ÑегоÑий"
#: ../lib/gis/parser.c:594
msgid "Example: 1,3,7-9,13"
-msgstr ""
+msgstr "ÐÑимеÑ: 1,3,7-9,13"
#: ../lib/gis/parser.c:604
#, fuzzy
msgid "Name of input file"
-msgstr " "
+msgstr "ÐÐ¼Ñ Ð¸ÑÑ
одного Ñайла"
#: ../lib/gis/parser.c:612
#, fuzzy
msgid "Name for output file"
-msgstr "×ÅËÔÏÒ"
+msgstr "ÐÐ¼Ñ Ð²ÑÑ
одного Ñайла"
#: ../lib/gis/parser.c:620
msgid "Field separator"
-msgstr ""
+msgstr "РазделиÑÐµÐ»Ñ Ð¿Ð¾Ð»ÐµÐ¹"
#: ../lib/gis/parser.c:631
msgid "Color"
-msgstr ""
+msgstr "ЦвеÑ"
#: ../lib/gis/parser.c:632
msgid "Either a standard color name or R:G:B triplet"
-msgstr ""
+msgstr "Ðибо ÑÑандÑаÑное название ÑвеÑа, либо ÑÑÐ¸Ð¿Ð»ÐµÑ R:G:B"
#: ../lib/gis/parser.c:641
msgid "Background color"
-msgstr ""
+msgstr "Ð¦Ð²ÐµÑ Ñона"
#: ../lib/gis/parser.c:642
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
+msgstr "Ðибо ÑÑандаÑÑнÑй ÑÐ²ÐµÑ GRASS, либо ÑÑÐ¸Ð¿Ð»ÐµÑ R:G:B, либо \"none\""
#: ../lib/gis/parser.c:787
#, c-format
@@ -2853,7 +2977,7 @@
#: ../lib/gis/parser.c:949
#, fuzzy, c-format
msgid "Sorry <%s> is not a valid option\n"
-msgstr "éÚ×ÉÎÉÔÅ <%s> ÎÅ×ÏÚÍÏÖÎÁÑ ÏÐÃÉÑ\n"
+msgstr "ÐзвиниÑе, опÑÐ¸Ñ <%s> невеÑна\n"
#: ../lib/gis/parser.c:1060
#, c-format
@@ -2861,6 +2985,8 @@
"\n"
"Description:\n"
msgstr ""
+"\n"
+"ÐпиÑание:\n"
#: ../lib/gis/parser.c:1067
#, c-format
@@ -2868,6 +2994,8 @@
"\n"
"Keywords:\n"
msgstr ""
+"\n"
+"ÐлÑÑевÑе Ñлова:\n"
#: ../lib/gis/parser.c:1071
#, c-format
@@ -2876,6 +3004,9 @@
"Usage:\n"
msgstr ""
+"\n"
+"ÐÑполÑзование:\n"
#: ../lib/gis/parser.c:1143
#, c-format
@@ -2883,18 +3014,20 @@
"\n"
"Flags:\n"
msgstr ""
+"\n"
+"Флаги:\n"
-#: ../lib/gis/parser.c:1166 ../lib/gis/parser.c:1654 ../lib/gis/parser.c:1940
+#: ../lib/gis/parser.c:1166 ../lib/gis/parser.c:1654 ../lib/gis/parser.c:1941
msgid "Allow output files to overwrite existing files"
-msgstr ""
+msgstr "РазÑеÑиÑÑ Ð²ÑÑ
однÑм Ñайлам пеÑезапиÑÑваÑÑ ÑÑÑеÑÑвÑÑÑие ÑайлÑ"
#: ../lib/gis/parser.c:1168 ../lib/gis/parser.c:1658
msgid "Verbose module output"
-msgstr ""
+msgstr "ÐногоÑловное опиÑание ÑабоÑÑ Ð¼Ð¾Ð´ÑлÑ"
#: ../lib/gis/parser.c:1169 ../lib/gis/parser.c:1661
msgid "Quiet module output"
-msgstr ""
+msgstr "ÐÑаÑкое опиÑание ÑабоÑÑ Ð¼Ð¾Ð´ÑлÑ"
#: ../lib/gis/parser.c:1175
#, c-format
@@ -2902,202 +3035,216 @@
"\n"
"Parameters:\n"
msgstr ""
+"\n"
+"ÐаÑамеÑÑÑ:\n"
#: ../lib/gis/parser.c:1198
#, fuzzy, c-format
msgid " %*s default: %s\n"
-msgstr " %*s ÐÏ ÕÍÏÌÞÁÎÉÀ: %s\n"
+msgstr " %*s по ÑмолÑаниÑ: %s\n"
#: ../lib/gis/parser.c:1537
msgid "NAME"
-msgstr ""
+msgstr "ÐÐЯ"
#: ../lib/gis/parser.c:1550
msgid "KEYWORDS"
-msgstr ""
+msgstr "ÐÐЮЧÐ"
#: ../lib/gis/parser.c:1555
msgid "SYNOPSIS"
-msgstr ""
+msgstr "СинопÑиÑ"
#: ../lib/gis/parser.c:1629
msgid "Flags"
-msgstr ""
+msgstr "Флаги"
#: ../lib/gis/parser.c:1670
msgid "Parameters"
-msgstr ""
+msgstr "ÐаÑамеÑÑÑ"
#: ../lib/gis/parser.c:1711
#, fuzzy
msgid "Options"
-msgstr " ÏÐÃÉÉ: %s\n"
+msgstr "ÐпÑии"
#: ../lib/gis/parser.c:1717
#, fuzzy
msgid "Default"
-msgstr " ÐÏ ÕÍÏÌ.: %s\n"
+msgstr "Ðо ÑмолÑаниÑ"
-#: ../lib/gis/parser.c:1942
+#: ../lib/gis/parser.c:1943
msgid "Allow overwrite"
-msgstr ""
+msgstr "РазÑеÑиÑÑ Ð¿ÐµÑезапиÑÑ"
-#: ../lib/gis/parser.c:1950
+#: ../lib/gis/parser.c:1951
msgid "Run with minimal output messages"
-msgstr ""
+msgstr "ÐÑполнÑÑÑ Ñ Ð¼Ð¸Ð½Ð¸Ð¼Ð°Ð»ÑнÑм колиÑеÑÑвом ÑообÑений"
-#: ../lib/gis/parser.c:1952
+#: ../lib/gis/parser.c:1953
msgid "Run quietly"
+msgstr "ÐапÑÑкаÑÑ Ð±ÐµÐ· ÑообÑений"
+#: ../lib/gis/parser.c:1986
+msgid "Unable to spawn the 'wish' program"
msgstr ""
-#: ../lib/gis/parser.c:1985
+#: ../lib/gis/parser.c:2005
#, fuzzy
-msgid "Unable to spawn wish"
-#: ../lib/gis/parser.c:2004
-#, fuzzy
msgid "Unable to determine program name"
-#: ../lib/gis/parser.c:2059
+#: ../lib/gis/parser.c:2060
#, fuzzy, c-format
msgid " %*s options: "
-msgstr " %*s ÏÐÃÉÉ: "
+msgstr " %*s опÑии: "
-#: ../lib/gis/parser.c:2108 ../lib/gis/parser.c:2125
+#: ../lib/gis/parser.c:2109 ../lib/gis/parser.c:2126
#, fuzzy, c-format
msgid "Sorry, <%c> is not a valid flag\n"
-msgstr "éÚ×ÉÎÉÔÅ, <%c> ÎÅ×ÏÚÍÏÖÎÙÊ ÆÌÁÇ\n"
+msgstr "ÐзвиниÑе, Ñлаг <%c> невеÑен\n"
-#: ../lib/gis/parser.c:2180
+#: ../lib/gis/parser.c:2181
#, fuzzy, c-format
msgid "Sorry, <%s=> is ambiguous\n"
-msgstr "éÚ×ÉÎÉÔÅ, <%s=> ÎÅÏÄÎÏÚÎÁÞÎÙÊ ÐÁÒÁÍÅÔÒ\n"
+msgstr "ÐзвиниÑе, паÑамеÑÑ <%s=> неоднознаÑен\n"
-#: ../lib/gis/parser.c:2187
+#: ../lib/gis/parser.c:2188
#, fuzzy, c-format
msgid "Sorry, <%s> is not a valid parameter\n"
-msgstr "éÚ×ÉÎÉÔÅ, <%s> ÎÅ×ÏÚÍÏÖÎÙÊ ÐÁÒÁÍÅÔÒ\n"
+msgstr "ÐзвиниÑе, паÑамеÑÑ <%s> невеÑен\n"
-#: ../lib/gis/parser.c:2272
+#: ../lib/gis/parser.c:2273
#, fuzzy, c-format
msgid ""
"\n"
"ERROR: illegal range syntax for parameter <%s>\n"
-msgstr " "
+msgstr ""
+"\n"
+"ÐÑибка: невеÑнÑй ÑинÑакÑÐ¸Ñ Ð´Ð¸Ð°Ð¿Ð°Ð·Ð¾Ð½Ð° Ð´Ð»Ñ Ð¿Ð°ÑамеÑÑа <%s>\n"
-#: ../lib/gis/parser.c:2274
+#: ../lib/gis/parser.c:2275
#, fuzzy, c-format
msgid " Presented as: %s\n"
-msgstr " ðÒÅÄÓÔÁ×ÌÅÎÎÏÇÏ ËÁË: %s\n"
+msgstr " ÐÑедÑÑавленного как: %s\n"
-#: ../lib/gis/parser.c:2277
+#: ../lib/gis/parser.c:2278
#, fuzzy, c-format
msgid ""
"\n"
"ERROR: value <%s> out of range for parameter <%s>\n"
-msgstr " "
+msgstr ""
+"\n"
+"ÐÑибка: знаÑение <%s> вÑÑ
Ð¾Ð´Ð¸Ñ Ð·Ð° диапазон паÑамеÑÑа <%s>\n"
-#: ../lib/gis/parser.c:2279
+#: ../lib/gis/parser.c:2280
#, fuzzy, c-format
msgid " Legal range: %s\n"
-msgstr " ÷ÏÚÍÏÖÎÙÊ ÄÉÁÐÁÚÏÎ: %s\n"
+msgstr " ÐозможнÑй диапазон: %s\n"
-#: ../lib/gis/parser.c:2282
+#: ../lib/gis/parser.c:2283
#, fuzzy, c-format
msgid ""
"\n"
"ERROR: Missing value for parameter <%s>\n"
-msgstr " "
+msgstr ""
+"\n"
+"ÐÑибка: ÐÑÑÑÑвÑÐµÑ Ð·Ð½Ð°Ñение Ð´Ð»Ñ Ð¿Ð°ÑамеÑÑа <%s>\n"
-#: ../lib/gis/parser.c:2442
+#: ../lib/gis/parser.c:2443
#, fuzzy, c-format
msgid ""
"\n"
"ERROR: Required parameter <%s> not set:\n"
" (%s).\n"
msgstr ""
-" \n"
+"\n"
+"ÐÑибка: ТÑебÑемÑй паÑамеÑÑ <%s> не ÑÑÑановлен:\n"
+" (%s).\n"
-#: ../lib/gis/parser.c:2545
+#: ../lib/gis/parser.c:2546
#, fuzzy, c-format
msgid ""
"\n"
"ERROR: option <%s> must be provided in multiples of %d\n"
-msgstr " "
+msgstr ""
+"\n"
+"ÐÑибка: опÑÐ¸Ñ <%s> должна задаваÑÑÑÑ Ð² знаÑениÑÑ
%d\n"
-#: ../lib/gis/parser.c:2547
+#: ../lib/gis/parser.c:2548
#, fuzzy, c-format
msgid " You provided %d items:\n"
-msgstr " ÷Ù ÚÁÄÁÌÉ %d ÒÁÚ:\n"
+msgstr " ÐÑ Ð·Ð°Ð´Ð°Ð»Ð¸ %d Ñаз:\n"
-#: ../lib/gis/parser.c:2602
+#: ../lib/gis/parser.c:2603
#, fuzzy, c-format
msgid "ERROR: option <%s>: <%s> exists.\n"
-msgstr " "
+msgstr "ÐÑибка: опÑÐ¸Ñ <%s>: <%s> ÑÑÑеÑÑвÑеÑ.\n"
-#: ../lib/gis/parser.c:2649
+#: ../lib/gis/parser.c:2650
#, c-format
msgid ""
"\n"
"FLAG: Set the following flag?\n"
msgstr ""
+"\n"
+"Флаг: ÐадаÑÑ ÑледÑÑÑий Ñлаг?\n"
-#: ../lib/gis/parser.c:2663
+#: ../lib/gis/parser.c:2664
#, fuzzy, c-format
msgid ""
"\n"
"OPTION: %s\n"
-msgstr " "
+msgstr ""
+" \n"
+"ÐпÑиÑ: %s\n"
-#: ../lib/gis/parser.c:2664
+#: ../lib/gis/parser.c:2665
#, fuzzy, c-format
msgid " key: %s\n"
-msgstr " ËÌÀÞ: %s\n"
+msgstr " клÑÑ: %s\n"
-#: ../lib/gis/parser.c:2666
+#: ../lib/gis/parser.c:2667
#, fuzzy, c-format
msgid " format: %s\n"
-msgstr " ÆÏÒÍÁÔ: %s\n"
+msgstr " ÑоÑмаÑ: %s\n"
-#: ../lib/gis/parser.c:2668
+#: ../lib/gis/parser.c:2669
#, fuzzy, c-format
msgid " default: %s\n"
+msgstr " по ÑмолÑаниÑ: %s\n"
-#: ../lib/gis/parser.c:2669
+#: ../lib/gis/parser.c:2670
#, fuzzy, c-format
msgid "required: %s\n"
-msgstr "ÎÅÏÂÈ.: %s\n"
+msgstr "необÑ
одимо: %s\n"
-#: ../lib/gis/parser.c:2671
+#: ../lib/gis/parser.c:2672
#, fuzzy, c-format
msgid "multiple: %s\n"
-msgstr "ÍÎÏÖ.: %s\n"
+msgstr "множ.: %s\n"
-#: ../lib/gis/parser.c:2673
+#: ../lib/gis/parser.c:2674
#, fuzzy, c-format
msgid " options: %s\n"
+msgstr " опÑии: %s\n"
-#: ../lib/gis/parser.c:2688
+#: ../lib/gis/parser.c:2689
#, fuzzy, c-format
msgid "enter option > "
-msgstr "ÚÁÄÁÊÔÅ ÏÐÃÉÀ > "
+msgstr "введиÑе опÑÐ¸Ñ > "
-#: ../lib/gis/parser.c:2702 ../lib/gis/parser.c:2713
+#: ../lib/gis/parser.c:2703 ../lib/gis/parser.c:2714
#, fuzzy
msgid " Try again? "
-msgstr " ðÏÐÒÏÂÏ×ÁÔØ ÓÎÏ×Á? "
+msgstr " ÐопÑобоваÑÑ Ñнова? "
-#: ../lib/gis/parser.c:2711
+#: ../lib/gis/parser.c:2712
#, fuzzy, c-format
msgid "Sorry, %s is not accepted.\n"
-msgstr "éÚ×ÉÎÉÔÅ, %s ÎÅ ÐÒÉÅÍÌÅÍÏ.\n"
+msgstr "ÐзвиниÑе, %s недопÑÑÑимо.\n"
-#: ../lib/gis/parser.c:2722
+#: ../lib/gis/parser.c:2723
#, fuzzy, c-format
msgid ""
"\n"
@@ -3105,67 +3252,68 @@
" %s\n"
msgstr ""
"\n"
+"ÐÑ Ð²ÑбÑали:\n"
+" %s\n"
-#: ../lib/gis/parser.c:2723
+#: ../lib/gis/parser.c:2724
#, fuzzy
msgid "Is this correct? "
-msgstr "ðÒÁ×ÉÌØÎÏ?"
+msgstr "ÐÑавилÑно?"
-#: ../lib/gis/parser.c:2792
+#: ../lib/gis/parser.c:2793
#, fuzzy
msgid "to accept the default"
#: ../lib/gis/reclass.c:150
#, fuzzy, c-format
msgid "Too many reclass categories for [%s in %s]"
-msgstr "óÌÉÛËÏÍ ÍÎÏÇÏ ËÁÔÅÇÏÒÉÊ ÄÌÑ ÒÅËÌÁÓÓÉÆÉËÁÃÉÉ [%s × %s]"
+msgstr "СлиÑком много каÑегоÑий Ð´Ð»Ñ ÑеклаÑÑиÑикаÑии [%s в %s]"
#: ../lib/gis/reclass.c:153
#, fuzzy, c-format
msgid "Illegal reclass format in header file for [%s in %s]"
-msgstr "îÅÐÒÁ×ÉÌØÎÙÊ ÆÏÒÍÁÔ ÒÅËÌÁÓÓÉÆÉËÁÃÉÉ × ÆÁÊÌÅ ÚÁÇÏÌÏ×ËÁ ÄÌÑ [%s × %s]"
+msgstr "ÐепÑавилÑнÑй ÑоÑÐ¼Ð°Ñ ÑеклаÑÑиÑикаÑии в Ñайле заголовка Ð´Ð»Ñ [%s в %s]"
#: ../lib/gis/reclass.c:248
#, fuzzy
msgid "Illegal reclass request"
-msgstr "äÁÎÎÁÑ ÒÅËÌÁÓÓÉÆÉËÁÃÉÑ ÎÅ×ÏÚÍÏÖÎÁ"
+msgstr "ÐÐ°Ð½Ð½Ð°Ñ ÑеклаÑÑиÑикаÑÐ¸Ñ Ð½ÐµÐ²Ð¾Ð·Ð¼Ð¾Ð¶Ð½Ð°"
#: ../lib/gis/reclass.c:253
#, fuzzy
msgid "Illegal reclass type"
-msgstr "îÅÐÒÁ×ÉÌØÎÏ ÚÁÄÁÎ ÔÉÐ ÒÅËÌÁÓÓÉÆÉËÁÃÉÉ"
+msgstr "ÐепÑавилÑно задан Ñип ÑеклаÑÑиÑикаÑии"
#: ../lib/gis/reclass.c:260
#, fuzzy, c-format
msgid "Unable to create header file for [%s in %s]"
#: ../lib/gis/reclass.c:310
#, fuzzy, c-format
msgid "Unable to create dependency file in [%s in %s]"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÓÏÚÄÁÔØ ÓÏÐÕÔÓÔ×ÕÀÝÉÊ dependency ÆÁÊÌ ÄÌÑ [%s × %s]"
+msgstr "Ðевозможно ÑоздаÑÑ ÑопÑÑÑÑвÑÑÑий dependency Ñайл Ð´Ð»Ñ [%s в %s]"
#: ../lib/gis/quant_rw.c:208
#, fuzzy, c-format
msgid "Cannot write quant rules: map %s is integer"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÚÁÐÉÓÁÔØ ÐÒÁ×ÉÌÁ ÒÁÚÂÉÅÎÉÑ ÚÎÁÞÅÎÉÊ: ËÁÒÔÁ %s ÃÅÌÏÞÉÓÌÅÎÎÁÑ"
+msgstr "Ðевозможно запиÑаÑÑ Ð¿Ñавила ÑÐ°Ð·Ð±Ð¸ÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений: каÑÑа %s ÑелоÑиÑленнаÑ"
#: ../lib/gis/quant_rw.c:218
#, fuzzy, c-format
msgid "Cannot write quant rules for map %s"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÚÁÐÉÓÁÔØ ÐÒÁ×ÉÌÁ ÒÁÚÂÉÅÎÉÑ ÚÎÁÞÅÎÉÊ ÄÌÑ ËÁÒÔÙ %s"
+msgstr "Ðевозможно запиÑаÑÑ Ð¿Ñавила ÑÐ°Ð·Ð±Ð¸ÐµÐ½Ð¸Ñ Ð·Ð½Ð°Ñений Ð´Ð»Ñ ÐºÐ°ÑÑÑ %s"
#: ../lib/gis/raster_metadata.c:111
#, fuzzy, c-format
msgid "Can't read %s for [%s in %s]"
#: ../lib/gis/raster_metadata.c:143
#, fuzzy, c-format
msgid "Can't create %s metadata file for [%s in %s]"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÐÒÏÞÅÓÔØ ÆÁÊÌ ÚÁÇÏÌÏ×ËÁ ÄÌÑ [%s × %s]\n"
+msgstr "Ðевозможно пÑоÑеÑÑÑ Ñайл заголовка Ð´Ð»Ñ [%s в %s]\n"
#: ../lib/gis/timestamp.c:298
#, fuzzy, c-format
@@ -3175,7 +3323,7 @@
#: ../lib/gis/timestamp.c:308
#, fuzzy, c-format
msgid "Invalid timestamp specified for %s map %s in mapset %s"
-msgstr "úÁÄÁÎÁ ÎÅ×ÅÒÎÁÑ ×ÒÅÍÅÎÎÁÑ ÍÅÔËÁ ÄÌÑ %s ËÁÒÔÙ %s × ÎÁÂ. ÄÁÎÎÙÈ %s"
+msgstr "Ðадана невеÑÐ½Ð°Ñ Ð²ÑÐµÐ¼ÐµÐ½Ð½Ð°Ñ Ð¼ÐµÑка Ð´Ð»Ñ %s каÑÑÑ %s в наб. даннÑÑ
%s"
#: ../lib/gis/timestamp.c:332
#, fuzzy, c-format
@@ -3185,168 +3333,171 @@
#: ../lib/gis/timestamp.c:342
#, fuzzy, c-format
msgid "Invalid timestamp file for %s map %s in mapset %s"
-msgstr "îÅ×ÅÒÎÙÊ ÆÏÒÍÁÔ ÆÁÊÌÁ ×ÒÅÍÅÎÎÏÊ ÍÅÔËÉ ÄÌÑ %s ËÁÒÔÙ %s × ÎÁÂ. ÄÁÎÎÙÈ %s"
+msgstr "ÐевеÑнÑй ÑоÑÐ¼Ð°Ñ Ñайла вÑеменной меÑки Ð´Ð»Ñ %s каÑÑÑ %s в наб. даннÑÑ
%s"
#: ../lib/gis/adj_cellhd.c:47 ../lib/gis/adj_cellhd.c:196
#, fuzzy
msgid "Illegal n-s resolution value"
-msgstr "îÅ×ÅÒÎÏ ÚÁÄÁÎÏ ÒÁÚÒÅÛÅÎÉÅ n-s"
+msgstr "ÐевеÑно задано ÑазÑеÑение n-s"
#: ../lib/gis/adj_cellhd.c:52 ../lib/gis/adj_cellhd.c:203
#, fuzzy
msgid "Illegal row value"
-msgstr "îÅÐÒÁ×ÉÌØÎÁÑ ×ÅÌÉÞÉÎÁ ÓÔÒÏËÉ"
+msgstr "ÐепÑавилÑÐ½Ð°Ñ Ð²ÐµÐ»Ð¸Ñина ÑÑÑоки"
#: ../lib/gis/adj_cellhd.c:57 ../lib/gis/adj_cellhd.c:210
#, fuzzy
msgid "Illegal e-w resolution value"
-msgstr "îÅ×ÅÒÎÏ ÚÁÄÁÎÏ ÒÁÚÒÅÛÅÎÉÅ e-w"
+msgstr "ÐевеÑно задано ÑазÑеÑение e-w"
#: ../lib/gis/adj_cellhd.c:62 ../lib/gis/adj_cellhd.c:217
#, fuzzy
msgid "Illegal col value"
-msgstr "îÅÐÒÁ×ÉÌØÎÁÑ ×ÅÌÉÞÉÎÁ ÓÔÏÌÂÃÁ"
+msgstr "ÐепÑавилÑÐ½Ð°Ñ Ð²ÐµÐ»Ð¸Ñина ÑÑолбÑа"
#: ../lib/gis/adj_cellhd.c:81 ../lib/gis/adj_cellhd.c:248
#, c-format
msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
+msgstr "ÐÑпÑавление оÑибки окÑÑÐ³Ð»ÐµÐ½Ð¸Ñ Ð´Ð»Ñ ÑевеÑной гÑаниÑÑ (%g>%g)"
#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:251
#, fuzzy
msgid "Illegal latitude for North"
-msgstr "îÅÐÒÁ×ÉÌØÎÁÑ ÛÉÒÏÔÁ ÄÌÑ óÅ×ÅÒÁ"
+msgstr "ÐепÑавилÑÐ½Ð°Ñ ÑиÑоÑа Ð´Ð»Ñ Ð¡ÐµÐ²ÐµÑа"
#: ../lib/gis/adj_cellhd.c:89 ../lib/gis/adj_cellhd.c:256
#, c-format
msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
+msgstr "ÐÑпÑавление оÑибки окÑÑÐ³Ð»ÐµÐ½Ð¸Ñ Ð´Ð»Ñ Ñжной гÑаниÑÑ (%g>%g)"
#: ../lib/gis/adj_cellhd.c:92 ../lib/gis/adj_cellhd.c:259
#, fuzzy
msgid "Illegal latitude for South"
-msgstr "îÅÐÒÁ×ÉÌØÎÁÑ ÛÉÒÏÔÁ ÄÌÑ àÇÁ"
+msgstr "ÐепÑавилÑÐ½Ð°Ñ ÑиÑоÑа Ð´Ð»Ñ Ð®Ð³Ð°"
#: ../lib/gis/adj_cellhd.c:103 ../lib/gis/adj_cellhd.c:270
#, c-format
msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
+msgstr "ÐÑпÑавление оÑибки окÑÑÐ³Ð»ÐµÐ½Ð¸Ñ Ð´Ð»Ñ Ð·Ð°Ð¿Ð°Ð´Ð½Ð¾Ð¹ гÑаниÑÑ (%g>%g)"
#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:280
#, c-format
msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
+msgstr "ÐÑпÑавление оÑибки окÑÑÐ³Ð»ÐµÐ½Ð¸Ñ Ð´Ð»Ñ Ð²Ð¾ÑÑоÑной гÑаниÑÑ (%g>%g)"
#: ../lib/gis/adj_cellhd.c:127 ../lib/gis/adj_cellhd.c:294
#, fuzzy
msgid "North must be north of South"
-msgstr "óÅ×ÅÒ ÄÏÌÖÅÎ ÂÙÔØ Ë ÓÅ×ÅÒÕ ÏÔ àÇÁ"
+msgstr "Ð¡ÐµÐ²ÐµÑ Ð´Ð¾Ð»Ð¶ÐµÐ½ бÑÑÑ Ðº ÑевеÑÑ Ð¾Ñ Ð®Ð³Ð°"
#: ../lib/gis/adj_cellhd.c:129 ../lib/gis/adj_cellhd.c:296
#, fuzzy
msgid "North must be larger than South"
-msgstr "óÅ×ÅÒ ÄÏÌÖÅÎ ÂÙÔØ ÂÏÌØÛÅ àÇÁ"
+msgstr "Ð¡ÐµÐ²ÐµÑ Ð´Ð¾Ð»Ð¶ÐµÐ½ бÑÑÑ Ð±Ð¾Ð»ÑÑе Юга"
#: ../lib/gis/adj_cellhd.c:132 ../lib/gis/adj_cellhd.c:299
#, fuzzy
msgid "East must be larger than West"
-msgstr "÷ÏÓÔÏË ÄÏÌÖÅÎ ÂÙÔØ ÂÏÌØÛÅ úÁÐÁÄÁ"
+msgstr "ÐоÑÑок должен бÑÑÑ Ð±Ð¾Ð»ÑÑе Ðапада"
#: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:337
#, fuzzy
msgid "Invalid coordinates"
+msgstr "ÐевеÑнÑе кооÑдинаÑÑ"
#: ../lib/gis/adj_cellhd.c:198
msgid "Illegal n-s3 resolution value"
-msgstr ""
+msgstr "ÐепÑавилÑное ÑазÑеÑение n-s3"
#: ../lib/gis/adj_cellhd.c:205
msgid "Illegal row3 value"
-msgstr ""
+msgstr "ÐепÑавилÑное знаÑение row3"
#: ../lib/gis/adj_cellhd.c:212
msgid "Illegal e-w3 resolution value"
-msgstr ""
+msgstr "ÐепÑавилÑное ÑазÑеÑение e-w3"
#: ../lib/gis/adj_cellhd.c:219
msgid "Illegal col3 value"
-msgstr ""
+msgstr "ÐепÑавилÑное знаÑение col3"
#: ../lib/gis/adj_cellhd.c:224
msgid "Illegal t-b3 resolution value"
-msgstr ""
+msgstr "ÐепÑавилÑное ÑазÑеÑение t-b3"
#: ../lib/gis/adj_cellhd.c:229
msgid "Illegal depths value"
-msgstr ""
+msgstr "ÐепÑавилÑное знаÑение глÑбинÑ"
#: ../lib/gis/adj_cellhd.c:301
#, fuzzy
msgid "Top must be larger than Bottom"
+msgstr "ÐеÑÑ
должен бÑÑÑ Ð±Ð¾Ð»ÑÑе Ðиза"
#: ../lib/gis/rd_cellhd.c:136
#, fuzzy
msgid "duplicate projection field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÐÒÏÅËÃÉÉ"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле пÑоекÑии"
#: ../lib/gis/rd_cellhd.c:147
#, fuzzy
msgid "duplicate zone field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÚÏÎÙ"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле зонÑ"
#: ../lib/gis/rd_cellhd.c:157
#, fuzzy
msgid "projection field missing"
-msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ ÐÏÌÅ ÐÒÏÅËÃÉÉ"
+msgstr "оÑÑÑÑÑÑвÑÐµÑ Ð¿Ð¾Ð»Ðµ пÑоекÑии"
#: ../lib/gis/rd_cellhd.c:159
#, fuzzy
msgid "zone field missing"
-msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ ÐÏÌÅ ÚÏÎÙ"
+msgstr "оÑÑÑÑÑÑвÑÐµÑ Ð¿Ð¾Ð»Ðµ зонÑ"
#: ../lib/gis/rd_cellhd.c:181
#, fuzzy
msgid "duplicate north field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÓÅ×ÅÒ"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле ÑевеÑ"
#: ../lib/gis/rd_cellhd.c:190
#, fuzzy
msgid "duplicate south field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÀÇ"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле Ñг"
#: ../lib/gis/rd_cellhd.c:199
#, fuzzy
msgid "duplicate east field"
#: ../lib/gis/rd_cellhd.c:208
#, fuzzy
msgid "duplicate west field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÚÁÐÁÄ"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле запад"
#: ../lib/gis/rd_cellhd.c:217
+#, fuzzy
msgid "duplicate top field"
-msgstr ""
+msgstr "дÑблиÑÑÑÑееÑÑ Ð²ÐµÑÑ
нее поле"
#: ../lib/gis/rd_cellhd.c:226
+#, fuzzy
msgid "duplicate bottom field"
-msgstr ""
+msgstr "дÑблиÑÑÑÑееÑÑ Ð½Ð¸Ð¶Ð½ÐµÐµ поле"
#: ../lib/gis/rd_cellhd.c:235
#, fuzzy
msgid "duplicate e-w resolution field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÒÁÚÒÅÛÅÎÉÑ ×-Ú"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле ÑазÑеÑÐµÐ½Ð¸Ñ Ð²-з"
#: ../lib/gis/rd_cellhd.c:246
+#, fuzzy
msgid "duplicate 3D e-w resolution field"
-msgstr ""
+msgstr "дÑблиÑÑÑÑееÑÑ Ð¿Ð¾Ð»Ðµ 3D ÑазÑеÑÐµÐ½Ð¸Ñ Ð²Ð¾ÑÑок-запад "
#: ../lib/gis/rd_cellhd.c:257
#, fuzzy
msgid "duplicate n-s resolution field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÒÁÚÒÅÛÅÎÉÑ Ó-À"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле ÑазÑеÑÐµÐ½Ð¸Ñ Ñ-Ñ"
#: ../lib/gis/rd_cellhd.c:268
#, fuzzy
@@ -3354,184 +3505,191 @@
msgstr " "
#: ../lib/gis/rd_cellhd.c:279
+#, fuzzy
msgid "duplicate t-b resolution field"
-msgstr ""
+msgstr "дÑблиÑÑÑÑееÑÑ Ð¿Ð¾Ð»Ðµ ÑазÑеÑÐµÐ½Ð¸Ñ Ð²ÐµÑÑ
-низ"
#: ../lib/gis/rd_cellhd.c:290
#, fuzzy
msgid "duplicate rows field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÓÔÒÏË"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле ÑÑÑок"
#: ../lib/gis/rd_cellhd.c:301
+#, fuzzy
msgid "duplicate 3D rows field"
-msgstr ""
+msgstr "дÑблиÑÑÑÑее поле 3D ÑÑÑок"
#: ../lib/gis/rd_cellhd.c:312
#, fuzzy
msgid "duplicate cols field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÓÔÏÌÂÃÏ×"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле ÑÑолбÑов"
#: ../lib/gis/rd_cellhd.c:323
+#, fuzzy
msgid "duplicate 3D cols field"
-msgstr ""
+msgstr "дÑблиÑÑÑÑее поле 3D колонок"
#: ../lib/gis/rd_cellhd.c:334
msgid "duplicate depths field"
-msgstr ""
+msgstr "дÑблиÑÑÑÑееÑÑ Ð¿Ð¾Ð»Ðµ глÑбин"
#: ../lib/gis/rd_cellhd.c:345
#, fuzzy
msgid "duplicate format field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÆÏÒÍÁÔÁ"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле ÑоÑмаÑа"
#: ../lib/gis/rd_cellhd.c:354
#, fuzzy
msgid "duplicate compressed field"
-msgstr "Ä×ÁÖÄÙ ÚÁÄÁÎÏ ÐÏÌÅ ÓÖÁÔÉÑ"
+msgstr "Ð´Ð²Ð°Ð¶Ð´Ñ Ð·Ð°Ð´Ð°Ð½Ð¾ поле ÑжаÑиÑ"
#: ../lib/gis/rd_cellhd.c:365
#, fuzzy
msgid "north field missing"
-msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ ÐÏÌÅ ÓÅ×ÅÒ"
+msgstr "оÑÑÑÑÑÑвÑÐµÑ Ð¿Ð¾Ð»Ðµ ÑевеÑ"
#: ../lib/gis/rd_cellhd.c:367
#, fuzzy
msgid "south field missing"
-msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ ÐÏÌÅ ÀÇ"
+msgstr "оÑÑÑÑÑÑвÑÐµÑ Ð¿Ð¾Ð»Ðµ Ñг"
#: ../lib/gis/rd_cellhd.c:369
#, fuzzy
msgid "west field missing"
-msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ ÐÏÌÅ ÚÁÐÁÄ"
+msgstr "оÑÑÑÑÑÑвÑÐµÑ Ð¿Ð¾Ð»Ðµ запад"
#: ../lib/gis/rd_cellhd.c:371
#, fuzzy
msgid "east field missing"
-msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ ÐÏÌÅ ×ÏÓÔÏË"
+msgstr "оÑÑÑÑÑÑвÑÐµÑ Ð¿Ð¾Ð»Ðµ воÑÑок"
#: ../lib/gis/rd_cellhd.c:373
#, fuzzy
msgid "cols field missing"
-msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ ÐÏÌÅ ÓÔÏÌÂÃÏ×"
+msgstr "оÑÑÑÑÑÑвÑÐµÑ Ð¿Ð¾Ð»Ðµ ÑÑолбÑов"
#: ../lib/gis/rd_cellhd.c:375
#, fuzzy
msgid "rows field missing"
-msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ ÐÏÌÅ ÓÔÒÏË"
+msgstr "оÑÑÑÑÑÑвÑÐµÑ Ð¿Ð¾Ð»Ðµ ÑÑÑок"
#: ../lib/gis/rd_cellhd.c:386
#, fuzzy
msgid "ewres3 field missing"
-msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ"
+msgstr "оÑÑÑÑÑÑвÑеÑ"
#: ../lib/gis/rd_cellhd.c:388
#, fuzzy
msgid "nsres3 field missing"
#: ../lib/gis/rd_cellhd.c:390
#, fuzzy
msgid "cols3 field missing"
#: ../lib/gis/rd_cellhd.c:392
#, fuzzy
msgid "rows3 field missing"
#: ../lib/gis/rd_cellhd.c:448
#, fuzzy, c-format
msgid "line %d: <%s>"
-msgstr "ÓÔÒÏËÁ %d: <%s>"
+msgstr "ÑÑÑока %d: <%s>"
#: ../lib/gis/auto_mask.c:66
#, fuzzy
msgid "Unable to open automatic MASK file"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ Á×ÔÏÍÁÔÉÞÅÓËÉ MASK ÆÁÊÌ"
+msgstr "Ðевозможно оÑкÑÑÑÑ MASK Ñайл авÑомаÑиÑеÑки"
#: ../lib/gis/env.c:248
#, fuzzy
msgid "GISRC - variable not set"
-msgstr "GISRC - ÐÅÒÅÍÅÎÎÁÑ ÎÅ ÕÓÔÁÎÏ×ÌÅÎÁ"
+msgstr "GISRC - пеÑÐµÐ¼ÐµÐ½Ð½Ð°Ñ Ð½Ðµ ÑÑÑановлена"
#: ../lib/gis/env.c:279
#, fuzzy, c-format
msgid "G_getenv(): Variable %s not set"
#: ../lib/gis/env.c:305
#, fuzzy, c-format
msgid "%s not set"
-msgstr "%s ÎÅ ÕÓÔÁÎÏ×ÌÅÎ"
+msgstr "%s не ÑÑÑановлен"
#: ../lib/gis/done_msg.c:37
#, fuzzy, c-format
msgid "%s complete. %s"
-msgstr " "
+msgstr "%s завеÑÑен. %s"
#: ../lib/gis/get_window.c:69 ../lib/gis/get_window.c:88
#, fuzzy, c-format
msgid ""
"region for current mapset %s\n"
"run \"g.region\""
-msgstr " "
+msgstr ""
+"Ñегион Ð´Ð»Ñ ÑекÑÑего набоÑа %s\n"
+"вÑполниÑе \"g.region\""
#: ../lib/gis/get_window.c:124
#, fuzzy, c-format
msgid "default region %s"
-msgstr "ÒÅÇÉÏÎ ÐÏ ÕÍÏÌÞÁÎÉÀ %s"
+msgstr "Ñегион по ÑмолÑÐ°Ð½Ð¸Ñ %s"
#: ../lib/gis/get_window.c:146
#, fuzzy
msgid "is not set"
-msgstr "ÎÅ ÕÓÔÁÎÏ×ÌÅÎ"
+msgstr "не ÑÑÑановлен"
#: ../lib/gis/get_window.c:156
#, fuzzy, c-format
msgid ""
"is invalid\n"
"%s"
-msgstr " "
+msgstr ""
+"невеÑно\n"
+"%s"
#: ../lib/gis/mask_info.c:42
#, fuzzy, c-format
msgid "<%s> in mapset <%s>"
-msgstr "<%s> × ÎÁÂ. ÄÁÎÎÙÈ <%s>"
+msgstr "<%s> в набоÑе <%s>"
#: ../lib/gis/mask_info.c:45
#, fuzzy
msgid "none"
-msgstr "ÎÅÔ"
+msgstr "неÑ"
#: ../lib/gis/mask_info.c:48
#, fuzzy
msgid "not known"
-msgstr "ÎÅ ÉÚ×ÅÓÔÎÏ"
+msgstr "неизвеÑÑно"
#: ../lib/gis/color_read.c:123
#, fuzzy, c-format
msgid "color support for [%s] in mapset [%s] %s"
-msgstr "ÐÏÄÄÅÒÖËÁ Ã×ÅÔÁ ÄÌÑ [%s] × ÎÁÂÏÒÅ ÄÁÎÎÙÈ [%s] %s"
+msgstr "поддеÑжка ÑвеÑа Ð´Ð»Ñ [%s] в набоÑе [%s] %s"
#: ../lib/gis/view.c:180
#, fuzzy, c-format
msgid "Unable to open %s for writing"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ %s ÄÌÑ ÚÁÐÉÓÉ"
+msgstr "Ðевозможно оÑкÑÑÑÑ %s Ð´Ð»Ñ Ð·Ð°Ð¿Ð¸Ñи"
#: ../lib/gis/view.c:269 ../lib/gis/view.c:486
#, fuzzy, c-format
msgid "Unable to open %s for reading"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ %s ÄÌÑ ÞÔÅÎÉÑ"
+msgstr "Ðевозможно оÑкÑÑÑÑ %s Ð´Ð»Ñ ÑÑениÑ"
#: ../lib/gis/view.c:472
#, fuzzy, c-format
msgid "GRASS window when view was saved:\n"
-msgstr "ïËÎÏ GRASS × ÍÏÍÅÎÔ ÓÏÈÒÁÎÅÎÉÑ ËÏÍÐÏÚÉÃÉÉ:\n"
+msgstr "Ðкно GRASS в Ð¼Ð¾Ð¼ÐµÐ½Ñ ÑоÑ
ÑÐ°Ð½ÐµÐ½Ð¸Ñ ÐºÐ¾Ð¼Ð¿Ð¾Ð·Ð¸Ñии:\n"
#: ../lib/gis/view.c:547
#, fuzzy, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr " ïËÎÏ, ÓÏÈÒ. × \"%s\" ÐÏÌÎÏÓÔØÀ ÚÁ ÐÒÅÄÅÌÁÍÉ ÔÅËÕÝ. ÏËÎÁ GRASS."
+msgstr " Ðкно, ÑоÑ
Ñ. в \"%s\" полноÑÑÑÑ Ð·Ð° пÑеделами ÑекÑÑ. окна GRASS."
#: ../lib/gis/view.c:550
#, fuzzy, c-format
@@ -3542,47 +3700,47 @@
#: ../lib/gis/ask.c:339
#, fuzzy
msgid "to cancel request"
-msgstr "ÄÌÑ ÏÔÍÅÎÙ"
+msgstr "Ð´Ð»Ñ Ð¾ÑменÑ"
#: ../lib/gis/ask.c:395
#, fuzzy, c-format
msgid "Enter a new %s file name"
-msgstr "÷×ÅÄÉÔÅ ÎÏ×ÏÅ %s ÉÍÑ ÆÁÊÌÁ"
+msgstr "ÐведиÑе новое %s Ð¸Ð¼Ñ Ñайла"
#: ../lib/gis/ask.c:401
#, fuzzy, c-format
msgid "Enter the name of an existing %s file"
-msgstr "÷×ÅÄÉÔÅ ÉÍÑ ÓÕÝÅÓÔ×ÕÀÝÅÇÏ %s ÆÁÊÌÁ"
+msgstr "ÐведиÑе Ð¸Ð¼Ñ ÑÑÑеÑÑвÑÑÑего %s Ñайла"
#: ../lib/gis/ask.c:405
#, fuzzy, c-format
msgid "Enter %s file name"
-msgstr "÷×ÅÄÉÔÅ %s ÉÍÑ ÆÁÊÌÁ"
+msgstr "ÐведиÑе %s Ð¸Ð¼Ñ Ñайла"
#: ../lib/gis/ask.c:425
#, fuzzy, c-format
msgid "Enter 'list' for a list of existing %s files\n"
-msgstr "÷×ÅÄÉÔÅ 'list' ÄÌÑ ×Ù×ÏÄÁ ÓÐÉÓËÁ ÓÕÝÅÓÔ×ÕÀÝÉÈ %s ÆÁÊÌÏ×\n"
+msgstr "ÐведиÑе 'list' Ð´Ð»Ñ Ð²Ñвода ÑпиÑка ÑÑÑеÑÑвÑÑÑиÑ
%s Ñайлов\n"
#: ../lib/gis/ask.c:428
#, fuzzy, c-format
msgid "Enter 'list -f' for "
-msgstr "÷×ÅÄÉÔÅ 'list -f' ÄÌÑ"
+msgstr "ÐведиÑе 'list -f' длÑ"
#: ../lib/gis/ask.c:430
#, fuzzy, c-format
msgid "a list %s"
-msgstr "ÓÐÉÓËÁ %s"
+msgstr "ÑпиÑка %s"
#: ../lib/gis/ask.c:432
#, fuzzy, c-format
msgid "an extended list"
-msgstr "ÒÁÓÛÉÒÅÎÙÊ ÓÐÉÓÏË"
+msgstr "ÑаÑÑиÑенÑй ÑпиÑок"
#: ../lib/gis/ask.c:436
#, fuzzy, c-format
msgid "Hit RETURN %s\n"
-msgstr "îÁÖÍÉÔÅ RETURN %s\n"
+msgstr "ÐажмиÑе RETURN %s\n"
#: ../lib/gis/ask.c:458 ../lib/gis/ask.c:565 ../lib/gis/ask.c:587
#, fuzzy, c-format
@@ -3622,260 +3780,269 @@
#: ../lib/gis/ask.c:569
#, fuzzy
msgid "ask: can't happen"
-msgstr "ask: ÎÅ ÍÏÖÅÔ ÂÙÔØ"
+msgstr "ask: не Ð¼Ð¾Ð¶ÐµÑ Ð±ÑÑÑ"
#: ../lib/gis/alloc.c:42
msgid "G_malloc: out of memory"
-msgstr ""
#: ../lib/gis/alloc.c:75
msgid "G_calloc: out of memory"
-msgstr ""
+msgstr "G_calloc: out of memory"
#: ../lib/gis/alloc.c:111
msgid "G_realloc: out of memory"
-msgstr ""
+msgstr "G_realloc: out of memory"
#: ../lib/gis/histogram.c:60
#, fuzzy, c-format
msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "çÉÓÔÏÇÒÁÍÍÁ ÄÌÑ [%s × %s] ÏÔÓÕÔÓÔ×ÕÅÔ (×ÙÐÏÌÎÉÔÅ r.support)"
+msgstr "ÐиÑÑогÑамма Ð´Ð»Ñ [%s в %s] оÑÑÑÑÑÑвÑÐµÑ (вÑполниÑе r.support)"
#: ../lib/gis/histogram.c:68
#, fuzzy, c-format
msgid "Can't read histogram for [%s in %s]"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÐÒÏÞÅÓÔØ ÇÉÓÔÏÇÒÁÍÍÕ ÄÌÑ [%s × %s]"
+msgstr "Ðевозможно пÑоÑеÑÑÑ Ð³Ð¸ÑÑогÑÐ°Ð¼Ð¼Ñ Ð´Ð»Ñ [%s в %s]"
#: ../lib/gis/histogram.c:79 ../lib/gis/histogram.c:89
#, fuzzy, c-format
msgid "Invalid histogram file for [%s in %s]"
-msgstr "îÅ×ÅÒÎÙÊ ÆÏÒÍÁÔ ÆÁÊÌÁ ÇÉÓÔÏÇÒÁÍÍÙ [%s × %s]"
+msgstr "ÐевеÑнÑй ÑоÑÐ¼Ð°Ñ Ñайла гиÑÑогÑÐ°Ð¼Ð¼Ñ [%s в %s]"
#: ../lib/gis/histogram.c:370
#, fuzzy, c-format
msgid "can't create histogram for [%s in %s]"
-msgstr "ÎÅ×ÏÚÍÏÖÎÏ ÓÏÚÄÁÔØ ÇÉÓÔÏÇÒÁÍÍÕ ÄÌÑ [%s × %s]"
+msgstr "невозможно ÑоздаÑÑ Ð³Ð¸ÑÑогÑÐ°Ð¼Ð¼Ñ Ð´Ð»Ñ [%s в %s]"
-#: ../lib/imagery/fopen.c:28
+#: ../lib/imagery/fopen.c:24
#, fuzzy, c-format
msgid "Unable to create file [%s] of group [%s in %s]"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÓÏÚÄÁÔØ ÆÁÊÌ ÚÁÇÏÌÏ×ËÁ ÄÌÑ [%s × %s]"
+msgstr "Ðевозможно ÑоздаÑÑ Ñайл заголовка Ð´Ð»Ñ [%s в %s]"
-#: ../lib/imagery/fopen.c:46 ../lib/imagery/fopen.c:73
+#: ../lib/imagery/fopen.c:38 ../lib/imagery/fopen.c:61
#, fuzzy, c-format
msgid "Unable to open file [%s] of group [%s in %s]"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ ÆÁÊÌ %s × %s"
+msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл %s в %s"
-#: ../lib/imagery/fopen.c:62
+#: ../lib/imagery/fopen.c:53
#, fuzzy, c-format
msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr "ÎÅ ÍÏÇÕ ÎÁÊÔÉ [%s] × [%s]"
+msgstr "не Ð¼Ð¾Ð³Ñ Ð½Ð°Ð¹Ñи [%s] в [%s]"
-#: ../lib/imagery/fopen.c:94
+#: ../lib/imagery/fopen.c:82
#, fuzzy, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-#: ../lib/imagery/fopen.c:115 ../lib/imagery/fopen.c:145
+#: ../lib/imagery/fopen.c:103 ../lib/imagery/fopen.c:133
#, fuzzy, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-#: ../lib/imagery/fopen.c:134
+#: ../lib/imagery/fopen.c:122
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
+#: ../lib/imagery/target.c:42
+#, fuzzy, c-format
+msgid "Unable to read target file for group [%s]"
#: ../lib/gmath/la.c:63 ../lib/gmath/la.c:120
msgid "Matrix dimensions out of range"
-msgstr ""
+msgstr "РазмеÑÑ Ð¼Ð°ÑÑиÑÑ Ð²Ð½Ðµ диапазона"
#: ../lib/gmath/la.c:154
+#, fuzzy
msgid "Matrix is not initialised fully."
-msgstr ""
+msgstr "ÐаÑÑиÑа не полноÑÑÑÑ Ð¸Ð½Ð½Ð¸ÑиализиÑована."
#: ../lib/gmath/la.c:159
#, fuzzy
msgid "Unable to allocate space for matrix copy"
-msgstr "îÅ×ÏÚÍÏÖÎÏ ×ÙÄÅÌÉÔØ ÐÁÍÑÔØ\n"
+msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ\n"
#: ../lib/gmath/la.c:251
msgid "First scalar multiplier must be non-zero"
-msgstr ""
+msgstr "ÐеÑвÑй ÑкалÑÑнÑй множиÑÐµÐ»Ñ Ð´Ð¾Ð»Ð¶ÐµÐ½ бÑÑÑ Ð½Ðµ Ñавен нÑлÑ"
#: ../lib/gmath/la.c:257 ../lib/gmath/la.c:265 ../lib/gmath/la.c:326
msgid "One or both input matrices uninitialised"
-msgstr ""
+msgstr "Ðдна или обе маÑÑиÑÑ Ð½Ðµ инниÑиализиÑованÑ"
#: ../lib/gmath/la.c:270 ../lib/gmath/la.c:331
msgid "Matrix order does not match"
-msgstr ""
+msgstr "ÐоÑÑдок маÑÑиÑÑ Ð½Ðµ ÑовпадаеÑ"
#: ../lib/gmath/la.c:276
#, fuzzy
msgid "Unable to allocate space for matrix sum"
#: ../lib/gmath/la.c:336
#, fuzzy
msgid "Unable to allocate space for matrix product"
#: ../lib/gmath/la.c:448
msgid "Input: one or both data matrices uninitialised"
-msgstr ""
+msgstr "Ðвод: одна или обе маÑÑиÑÑ Ð½Ðµ инниÑиализиÑованÑ"
#: ../lib/gmath/la.c:453
msgid "Principal matrix is not properly dimensioned"
-msgstr ""
+msgstr "ÐÐ°Ð´Ð°Ð½Ñ Ð½ÐµÐ¿ÑавилÑнÑе ÑазмеÑÑ Ð³Ð»Ð°Ð²Ð½Ð¾Ð¹ маÑÑиÑÑ"
#: ../lib/gmath/la.c:458
msgid "Input: you must have at least one array to solve"
-msgstr ""
+msgstr "Ðвод: Ð´Ð»Ñ ÑеÑение необÑ
одимо не менÑÑе одного маÑÑива"
#: ../lib/gmath/la.c:464
msgid "Could not allocate space for solution matrix"
-msgstr ""
+msgstr "Ðевозможно найÑи меÑÑо Ð´Ð»Ñ Ð¼Ð°ÑÑиÑÑ ÑеÑениÑ"
#: ../lib/gmath/la.c:470 ../lib/gmath/la.c:478
msgid "Could not allocate space for working matrix"
-msgstr ""
+msgstr "Ðевозможно найÑи меÑÑо Ð´Ð»Ñ ÑабоÑей маÑÑиÑÑ"
#: ../lib/gmath/la.c:530
msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr ""
+msgstr "ÐаÑÑиÑа (или ÑÑбмаÑÑиÑа вÑÑождена). Ðевозможно найÑи ÑеÑение"
#: ../lib/gmath/la.c:534
msgid "Problem in LA routine."
-msgstr ""
+msgstr "ÐÑоблема в LA пÑоÑедÑÑе."
#: ../lib/gmath/la.c:541
msgid "Procedure not yet available for selected matrix type"
-msgstr ""
+msgstr "ÐÐ»Ñ Ð²ÑбÑанного Ñипа маÑÑиÑÑ Ð¿ÑоÑедÑÑа еÑе не доÑÑÑпна"
#: ../lib/gmath/la.c:575
msgid "Matrix is not square. Cannot determine inverse"
-msgstr ""
+msgstr "ÐаÑÑиÑа не пÑÑмоÑголÑнаÑ, невозможно найÑи обÑаÑнÑÑ Ð¼Ð°ÑÑиÑÑ."
#: ../lib/gmath/la.c:580
#, fuzzy
msgid "Unable to allocate space for matrix"
#: ../lib/gmath/la.c:597
msgid "Matrix is singular"
-msgstr ""
+msgstr "ÐаÑÑиÑа вÑÑождена."
#: ../lib/gmath/la.c:602
msgid "Problem in LA procedure."
-msgstr ""
#: ../lib/gmath/la.c:692
+#, fuzzy
msgid "Element array has not been allocated"
-msgstr ""
+msgstr "ÐаÑÑив ÑлеменÑов не Ñоздан"
#: ../lib/gmath/la.c:698
msgid "Specified element is outside array bounds"
-msgstr ""
+msgstr "УказаннÑй ÑÐ»ÐµÐ¼ÐµÐ½Ñ Ð²ÑÑ
Ð¾Ð´Ð¸Ñ Ð·Ð° гÑаниÑÑ Ð¼Ð°ÑÑива"
#: ../lib/gmath/la.c:754
msgid "Specified matrix column index is outside range"
-msgstr ""
+msgstr "УказаннÑй Ð¸Ð½Ð´ÐµÐºÑ ÐºÐ¾Ð»Ð¾Ð½ÐºÐ¸ маÑÑиÑÑ Ð½Ð°Ñ
одиÑÑÑ Ð²Ð½Ðµ диапазона"
#: ../lib/gmath/la.c:759 ../lib/gmath/la.c:801 ../lib/gmath/la.c:1125
#: ../lib/gmath/la.c:1178 ../lib/gmath/la.c:1252
msgid "Matrix is not initialised"
-msgstr ""
+msgstr "ÐаÑÑиÑа не инниÑиализиÑована"
#: ../lib/gmath/la.c:764 ../lib/gmath/la.c:806
+#, fuzzy
msgid "Could not allocate space for vector structure"
-msgstr ""
+msgstr "Ðевозможно найÑи меÑÑо Ð´Ð»Ñ Ð²ÐµÐºÑоÑной ÑÑÑÑкÑÑÑÑ"
#: ../lib/gmath/la.c:796
msgid "Specified matrix row index is outside range"
-msgstr ""
+msgstr "УказаннÑй Ð¸Ð½Ð´ÐµÐºÑ ÑÑда маÑÑиÑÑ Ð½Ð°Ñ
#: ../lib/gmath/la.c:837
msgid "Specified row index is outside range"
-msgstr ""
+msgstr "УказаннÑй Ð¸Ð½Ð´ÐµÐºÑ ÑÑда наÑ
#: ../lib/gmath/la.c:842
msgid "Specified column index is outside range"
-msgstr ""
+msgstr "УказаннÑй Ð¸Ð½Ð´ÐµÐºÑ ÐºÐ¾Ð»Ð¾Ð½ÐºÐ¸ наÑ
#: ../lib/gmath/la.c:862
#, fuzzy
msgid "Unknown vector type."
-msgstr "îÅÉÚ×ÅÓÔÎÁÑ ÐÒÏÅËÃÉÑ"
+msgstr "ÐеизвеÑÑÐ½Ð°Ñ Ð¿ÑоекÑиÑ"
#: ../lib/gmath/la.c:991
+#, fuzzy
msgid "Output vector is uninitialized"
-msgstr ""
+msgstr "ÐÑÑ
одной векÑÐ¾Ñ Ð½Ðµ инниÑиализиÑован"
#: ../lib/gmath/la.c:996
msgid "Vectors are not of the same type"
-msgstr ""
+msgstr "ÐекÑоÑÑ Ð¾ÑноÑÑÑÑÑ Ðº ÑазнÑм Ñипам"
#: ../lib/gmath/la.c:1001
msgid "Output vector is of incorrect type"
-msgstr ""
+msgstr "ÐÑÑ
одной векÑÐ¾Ñ Ð½ÐµÐ¿ÑавилÑного Ñипа"
#: ../lib/gmath/la.c:1006
msgid "Matrices not allowed"
-msgstr ""
+msgstr "ÐаÑÑиÑÑ Ð½Ðµ ÑазÑеÑенÑ"
#: ../lib/gmath/la.c:1013
msgid "Vectors have differing dimensions"
-msgstr ""
+msgstr "ÐекÑоÑÑ Ð¸Ð¼ÐµÑÑ ÑазнÑе ÑазмеÑÑ"
#: ../lib/gmath/la.c:1020
msgid "Output vector has incorrect dimension"
-msgstr ""
+msgstr "ÐÑÑ
одной векÑÐ¾Ñ Ð¸Ð¼ÐµÐµÑ Ð½ÐµÐ¿ÑавилÑнÑе ÑазмеÑÑ"
#: ../lib/gmath/la.c:1067
msgid "Vector dimensions out of range"
-msgstr ""
+msgstr "РазмеÑÑ Ð²ÐµÐºÑоÑа вне диапазона"
#: ../lib/gmath/la.c:1073
msgid "Row/column out of range"
-msgstr ""
+msgstr "Ð Ñд/колонка вне диапазона"
#: ../lib/gmath/la.c:1291
msgid "Vector structure is not initialised"
-msgstr ""
+msgstr "ÐекÑоÑÐ½Ð°Ñ ÑÑÑÑкÑÑÑа не инниÑиализиÑована"
#: ../lib/gmath/la.c:1413 ../lib/gmath/la.c:1421 ../lib/gmath/la.c:1426
msgid "Input format error"
-msgstr ""
+msgstr "ÐÑибка иÑÑ
одного ÑоÑмаÑа"
#: ../lib/gmath/del2g.c:51
msgid " taking FFT of image..."
-msgstr ""
+msgstr " полÑÑение FFT изобÑажениÑ..."
#: ../lib/gmath/del2g.c:58
msgid "Insufficent memory for allocation of gaussian"
-msgstr ""
+msgstr "Insufficent memory for allocation of gaussian"
#: ../lib/gmath/del2g.c:60
msgid " computing del**2 g..."
-msgstr ""
+msgstr " вÑÑиÑление del**2 g..."
#: ../lib/gmath/del2g.c:63
msgid " taking FFT of del**2 g..."
-msgstr ""
+msgstr " вÑÑиÑление FFT del**2 g..."
#: ../lib/gmath/del2g.c:67
msgid " multiplying transforms..."
-msgstr ""
+msgstr " Ñмножение ÑÑанÑÑоÑмаÑий..."
#: ../lib/gmath/del2g.c:70
msgid " taking inverse FFT..."
-msgstr ""
+msgstr " полÑÑение обÑаÑного FFT..."
#: ../lib/display/tran_colr.c:132 ../lib/display/tran_colr.c:134
#, fuzzy, c-format
msgid "[%s]: No such color"
-msgstr " "
+msgstr "[%s]: ÐеÑÑÑеÑÑвÑÑÑий ÑвеÑ"
#: ../lib/symbol/read.c:203
#, fuzzy, c-format
@@ -3997,7 +4164,7 @@
#: ../lib/rst/interp_float/input2d.c:49
#, fuzzy, c-format
msgid "Mask raster map <%s> not found"
-msgstr "×ÅËÔÏÒ "
+msgstr "векÑÐ¾Ñ "
#: ../lib/rst/interp_float/input2d.c:72
msgid "Bitmap mask created"
@@ -4005,15 +4172,15 @@
#, fuzzy
#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "îÅ×ÏÚÍÏÖÎÏ ÐÒÏÞÅÓÔØ ÆÁÊÌ ÚÁÇÏÌÏ×ËÁ ÄÌÑ [%s × %s]\n"
+#~ msgstr "Ðевозможно пÑоÑеÑÑÑ Ñайл заголовка Ð´Ð»Ñ [%s в %s]\n"
#, fuzzy
#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ ÆÁÊÌ ÚÁÇÏÌÏ×ËÁ ÄÌÑ [%s × %s]\n"
+#~ msgstr "Ðевозможно оÑкÑÑÑÑ Ñайл заголовка Ð´Ð»Ñ [%s в %s]\n"
#, fuzzy
#~ msgid "Cannot get field info"
-#~ msgstr "îÅ ÍÏÇÕ ÏÔËÒÙÔØ ×ÒÅÍ. ÆÁÊÌ"
+#~ msgstr "Ðе Ð¼Ð¾Ð³Ñ Ð¾ÑкÑÑÑÑ Ð²Ñем. Ñайл"
#, fuzzy
#~ msgid "Cannot open database"
@@ -4024,28 +4191,32 @@
#~ msgstr " "
#, fuzzy
+#~ msgid "Error opening raster map %s"
+#~ msgstr "СлиÑком много ÑаÑÑÑовÑÑ
Ñайлов оÑкÑÑÑÑ"
+#, fuzzy
#~ msgid "Output name '%s' is not valid vector name."
-#~ msgstr " ×ÅËÔÏÒ."
+#~ msgstr " векÑоÑ."
#, fuzzy
#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "×ÅËÔÏÒ "
+#~ msgstr "векÑÐ¾Ñ "
#, fuzzy
#~ msgid "Cannot open existing vector map <%s>"
#, fuzzy
#~ msgid "Cannot delete existing vector <%s>"
#, fuzzy
#~ msgid "Cannot open new vector %s"
#, fuzzy
#~ msgid "Cannot open history file for vector '%s'"
#, fuzzy
#~ msgid "Could not stat file '%s'"
@@ -4053,23 +4224,23 @@
#, fuzzy
#~ msgid "Can't open directory %s"
#, fuzzy
#~ msgid "Unable to allocate options"
-#~ msgstr "îÅ×ÏÚÍÏÖÎÏ ×ÙÄÅÌÉÔØ ÐÁÍÑÔØ\n"
+#~ msgstr "Ðевозможно вÑделиÑÑ Ð¿Ð°Ð¼ÑÑÑ\n"
#, fuzzy
#~ msgid "%s - ** illegal name **"
-#~ msgstr "%s - ** ÎÅ×ÏÚÍÏÖÎÏÅ ÉÍÑ **"
+#~ msgstr "%s - ** невозможное Ð¸Ð¼Ñ **"
#, fuzzy
#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "çÒÁÆÉÞÅÓËÉÊ ÄÉÓÐÌÅÊ <%s> ÎÅ ÓÕÝÅÓÔ×ÕÅÔ.\n"
+#~ msgstr "ÐÑаÑиÑеÑкий диÑплей <%s> не ÑÑÑеÑÑвÑеÑ.\n"
#, fuzzy
#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr "÷ÙÐÏÌÎÉÔÅ \"d.mon\" ÄÌÑ ×ÙÂÏÒÁ ÓÕÝÅÓÔ×ÕÀÝÅÇÏ ÄÉÓÐÌÅÑ.\n"
+#~ msgstr "ÐÑполниÑе \"d.mon\" Ð´Ð»Ñ Ð²ÑбоÑа ÑÑÑеÑÑвÑÑÑего диÑплеÑ.\n"
#, fuzzy
#~ msgid "Can't stat %s\n"
@@ -4077,7 +4248,7 @@
#, fuzzy
#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "ïÛÉÂËÁ - äÉÓÐÌÅÊ <%s> ÚÁÎÑÔ.\n"
+#~ msgstr "ÐÑибка - ÐиÑплей <%s> занÑÑ.\n"
#, fuzzy
#~ msgid "Error - Monitor <%s> is in use by %s.\n"
@@ -4085,27 +4256,27 @@
#, fuzzy
#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "ïÛÉÂËÁ - ÎÅ ÂÙÌÏ ÚÁËÏÎÞÅÎÏ ÚÁÐÉÒÁÎÉÅ (lock) ÄÌÑ ÄÉÓÐÌÅÑ <%s>.\n"
+#~ msgstr "ÐÑибка - не бÑло законÑено запиÑание (lock) Ð´Ð»Ñ Ð´Ð¸ÑÐ¿Ð»ÐµÑ <%s>.\n"
#, fuzzy
#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "ïÛÉÂËÁ - îÅÔ ËÁÎÁÌÁ (pipe) Ë ÇÒÁÆÉÞÅÓËÏÍÕ ÕÓÔÒÏÊÓÔ×Õ.\n"
+#~ msgstr "ÐÑибка - ÐÐµÑ ÐºÐ°Ð½Ð°Ð»Ð° (pipe) к гÑаÑиÑеÑÐºÐ¾Ð¼Ñ ÑÑÑÑойÑÑвÑ.\n"
#, fuzzy
#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "ïÛÉÂËÁ - çÒÁÆÉÞÅÓËÉÊ ÄÉÓÐÌÅÊ <%s> ÎÅ ×ËÌÀÞÅÎ!\n"
+#~ msgstr "ÐÑибка - ÐÑаÑиÑеÑкий диÑплей <%s> не вклÑÑен!\n"
#, fuzzy
#~ msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "÷ËÌÀÞÉÔÅ ÇÒÁÆÉÞÅÓËÉÊ ÄÉÓÐÌÅÊ <%s>.\n"
+#~ msgstr "ÐклÑÑиÑе гÑаÑиÑеÑкий диÑплей <%s>.\n"
#, fuzzy
#~ msgid "Not connected...\n"
-#~ msgstr "îÅÔ ÓÏÅÄÉÎÅÎÉÑ...\n"
+#~ msgstr "ÐÐµÑ ÑоединениÑ...\n"
#, fuzzy
#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr "îÅ×ÏÚÍÏÖÎÏ ÐÏÄËÌÀÞÉÔØ ÄÉÓÐÌÅÊ. åÝÅ ÏÄÎÁ ÐÏÐÙÔËÁ.\n"
+#~ msgstr "Ðевозможно подклÑÑиÑÑ Ð´Ð¸Ñплей. ÐÑе одна попÑÑка.\n"
#, fuzzy
#~ msgid "Decompressed data buffer %s"
@@ -4121,7 +4292,7 @@
#, fuzzy
#~ msgid "Mapset of open file %s"
-#~ msgstr "îÁÂÏÒ ÄÁÎÎÙÈ "
+#~ msgstr "ÐÐ°Ð±Ð¾Ñ Ð´Ð°Ð½Ð½ÑÑ
#, fuzzy
#~ msgid "Color file for [%s] not available"
@@ -4133,4 +4304,4 @@
#, fuzzy
#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "ïûéâëá: GISBASE ÎÅ ÕÓÔÁÎÏ×ÌÅÎ\n"
+#~ msgstr "ÐШÐÐÐÐ: GISBASE не ÑÑÑановлен\n"
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po 2008-05-06 19:11:33 UTC (rev 31269)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po 2008-05-06 20:47:18 UTC (rev 31270)
@@ -14,7 +14,7 @@
msgstr ""
"Project-Id-Version: grassmods_es\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-03-26 21:14+0100\n"
+"POT-Creation-Date: 2008-05-06 20:32+0200\n"
"PO-Revision-Date: 2008-01-11 19:44+0100\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -32,13 +32,13 @@
#: ../vector/v.db.connect/main.c:173 ../vector/v.db.connect/main.c:228
#: ../vector/v.edit/select.c:531 ../vector/v.out.svg/main.c:138
#: ../vector/v.out.ogr/main.c:304 ../vector/v.extract/main.c:224
-#: ../display/d.vect/main.c:471 ../display/d.thematic.area/main.c:207
+#: ../display/d.vect/main.c:480 ../display/d.thematic.area/main.c:207
#, c-format
msgid "Unable to start driver <%s>"
msgstr "No se puede iniciar el controlador <%s>"
#: ../db/base/execute.c:67 ../db/base/tables.c:50 ../db/base/select.c:69
-#: ../db/base/describe.c:56 ../display/d.vect/main.c:476
+#: ../db/base/describe.c:56 ../display/d.vect/main.c:485
#: ../display/d.thematic.area/main.c:212
#, c-format
msgid "Unable to open database <%s>"
@@ -186,7 +186,7 @@
msgid "For example: 'select * from rybniky where kapri = 'hodne'"
msgstr "Por ejemplo: 'select * from rybniky where kapri = 'hodne'"
-#: ../db/base/select.c:201 ../raster/r.distance/parse.c:50
+#: ../db/base/select.c:201 ../raster/r.distance/parse.c:47
#: ../raster/r.stats/main.c:108 ../raster/r.cats/main.c:70
#: ../vector/v.db.select/main.c:57
msgid "Output field separator"
@@ -229,7 +229,7 @@
msgstr "Muestra todas las columnas de una tabla dada."
#: ../db/base/describe.c:63 ../vector/v.db.connect/main.c:182
-#: ../vector/v.in.ascii/in.c:401 ../vector/v.patch/main.c:140
+#: ../vector/v.in.ascii/in.c:403 ../vector/v.patch/main.c:140
#: ../vector/v.patch/main.c:181 ../vector/v.out.svg/main.c:150
#: ../vector/v.out.ogr/main.c:313
#, c-format
@@ -1071,13 +1071,13 @@
#: ../raster3d/base/r3.info.main.c:123 ../raster/r.resamp.stats/main.c:302
#: ../raster/r.param.scale/interface.c:165 ../raster/r.surf.area/main.c:121
#: ../raster/r.resamp.interp/main.c:102 ../raster/r.coin/inter.c:40
-#: ../raster/r.coin/inter.c:44 ../raster/r.coin/cmd_parms.c:96
-#: ../raster/r.coin/cmd_parms.c:99 ../raster/r.distance/parse.c:78
-#: ../raster/r.distance/parse.c:85 ../raster/r.reclass/main.c:77
+#: ../raster/r.coin/inter.c:44 ../raster/r.coin/cmd_parms.c:79
+#: ../raster/r.coin/cmd_parms.c:82 ../raster/r.distance/parse.c:63
+#: ../raster/r.distance/parse.c:70 ../raster/r.reclass/main.c:77
#: ../raster/r.los/main.c:160 ../raster/r.los/main.c:166
#: ../raster/r.drain/main.c:155 ../raster/r.out.ascii/main.c:145
-#: ../raster/r.carve/main.c:173 ../raster/r.profile/main.c:142
-#: ../raster/r.texture/main.c:224 ../raster/r.basins.fill/main.c:92
+#: ../raster/r.carve/main.c:156 ../raster/r.profile/main.c:142
+#: ../raster/r.texture/main.c:212 ../raster/r.basins.fill/main.c:92
#: ../raster/r.basins.fill/main.c:104 ../raster/r.sum/main.c:64
#: ../raster/r.null/null.c:104 ../raster/r.average/main.c:71
#: ../raster/r.average/main.c:74 ../raster/r.out.gridatb/check_ready.c:13
@@ -1087,40 +1087,40 @@
#: ../raster/simwe/simlib/input.c:205 ../raster/simwe/simlib/input.c:211
#: ../raster/simwe/simlib/input.c:217 ../raster/simwe/simlib/input.c:224
#: ../raster/simwe/simlib/input.c:231 ../raster/simwe/simlib/input.c:238
-#: ../raster/simwe/simlib/input.c:245 ../raster/r.out.mat/main.c:94
+#: ../raster/simwe/simlib/input.c:245 ../raster/r.out.mat/main.c:85
#: ../raster/r.to.rast3elev/main.c:114 ../raster/r.to.rast3elev/main.c:129
#: ../raster/r.statistics/main.c:75 ../raster/r.statistics/main.c:81
-#: ../raster/r.info/main.c:116 ../raster/r.patch/main.c:115
+#: ../raster/r.info/main.c:116 ../raster/r.patch/main.c:101
#: ../raster/r.grow2/main.c:185 ../raster/r.surf.idw/main.c:108
#: ../raster/r.thin/io.c:97 ../raster/r.flow/io.c:65
#: ../raster/r.topidx/check_ready.c:12 ../raster/r.out.pov/main.c:171
-#: ../raster/r.covar/main.c:96 ../raster/r.out.arc/main.c:111
+#: ../raster/r.covar/main.c:81 ../raster/r.out.arc/main.c:111
#: ../raster/r.report/parse.c:247 ../raster/r.random/main.c:106
#: ../raster/r.random/main.c:111 ../raster/r.his/main.c:128
#: ../raster/r.his/main.c:169 ../raster/r.his/main.c:197
#: ../raster/r.bilinear/main.c:78 ../raster/r.kappa/stats.c:30
-#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:141
+#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:129
#: ../raster/r.median/main.c:73 ../raster/r.resamp.rst/main.c:400
#: ../raster/r.resamp.rst/main.c:426 ../raster/r.stats/main.c:263
-#: ../raster/r.slope.aspect/main.c:383 ../raster/r.colors/main.c:266
-#: ../raster/r.colors/main.c:352 ../raster/r.out.ppm/main.c:115
-#: ../raster/r.fill.dir/main.c:163 ../raster/r.mfilter.fp/main.c:124
-#: ../raster/r.cost/main.c:319 ../raster/r.out.vtk/main.c:47
+#: ../raster/r.slope.aspect/main.c:356 ../raster/r.colors/main.c:252
+#: ../raster/r.colors/main.c:338 ../raster/r.out.ppm/main.c:101
+#: ../raster/r.fill.dir/main.c:163 ../raster/r.mfilter.fp/main.c:110
+#: ../raster/r.cost/main.c:301 ../raster/r.out.vtk/main.c:47
#: ../raster/r.out.vtk/main.c:60 ../raster/r.support/modcolr/modcolr.c:43
#: ../raster/r.support/front/front.c:218 ../raster/r.out.bin/main.c:129
-#: ../raster/r.neighbors/main.c:180 ../raster/r.clump/main.c:88
-#: ../raster/r.to.vect/main.c:109 ../raster/r.region/main.c:161
+#: ../raster/r.neighbors/main.c:174 ../raster/r.clump/main.c:73
+#: ../raster/r.to.vect/main.c:96 ../raster/r.region/main.c:161
#: ../raster/r.region/main.c:218 ../raster/r.region/main.c:353
-#: ../raster/r.out.ppm3/main.c:117 ../raster/r.univar2/r.univar_main.c:148
+#: ../raster/r.out.ppm3/main.c:103 ../raster/r.univar2/r.univar_main.c:149
#: ../raster/r.watershed/ram/init_vars.c:341
-#: ../raster/r.watershed/seg/init_vars.c:371 ../raster/r.contour/main.c:156
-#: ../raster/r.cross/main.c:116 ../raster/r.cats/main.c:120
-#: ../raster/r.cats/main.c:140 ../raster/r.series/main.c:170
-#: ../raster/r.water.outlet/legal.c:23 ../raster/r.out.tiff/r.out.tiff.c:167
-#: ../raster/r.out.mpeg/main.c:222 ../raster/r.walk/main.c:523
-#: ../raster/r.walk/main.c:526 ../raster/r.mapcalc/map.c:380
-#: ../raster/r.recode/main.c:82 ../raster/r.mfilter/main.c:117
-#: ../raster/r.composite/main.c:162 ../raster/wildfire/r.ros/main.c:312
+#: ../raster/r.watershed/seg/init_vars.c:371 ../raster/r.contour/main.c:134
+#: ../raster/r.cross/main.c:99 ../raster/r.cats/main.c:120
+#: ../raster/r.cats/main.c:140 ../raster/r.series/main.c:156
+#: ../raster/r.water.outlet/legal.c:23 ../raster/r.out.tiff/r.out.tiff.c:151
+#: ../raster/r.out.mpeg/main.c:222 ../raster/r.walk/main.c:518
+#: ../raster/r.walk/main.c:521 ../raster/r.mapcalc/map.c:380
+#: ../raster/r.recode/main.c:82 ../raster/r.mfilter/main.c:103
+#: ../raster/r.composite/main.c:158 ../raster/wildfire/r.ros/main.c:312
#: ../raster/wildfire/r.ros/main.c:322 ../raster/wildfire/r.ros/main.c:326
#: ../raster/wildfire/r.ros/main.c:330 ../raster/wildfire/r.ros/main.c:334
#: ../raster/wildfire/r.ros/main.c:348 ../raster/wildfire/r.ros/main.c:352
@@ -1130,17 +1130,17 @@
#: ../raster/wildfire/r.spread/main.c:356
#: ../raster/wildfire/r.spread/main.c:363
#: ../raster/wildfire/r.spread/main.c:368
-#: ../raster/wildfire/r.spread/main.c:373 ../raster/r.resample/main.c:96
-#: ../raster/r.buffer/main.c:115 ../raster/r.support.stats/main.c:47
+#: ../raster/wildfire/r.spread/main.c:373 ../raster/r.resample/main.c:82
+#: ../raster/r.buffer/main.c:98 ../raster/r.support.stats/main.c:47
#: ../raster/r.bitpattern/main.c:101 ../vector/v.what.rast/main.c:132
-#: ../vector/v.extrude/main.c:178 ../vector/v.sample/main.c:157
+#: ../vector/v.extrude/main.c:178 ../vector/v.sample/main.c:152
#: ../vector/v.vol.rst/main.c:577 ../vector/v.drape/main.c:120
#: ../doc/raster/r.example/main.c:110 ../ps/ps.map/outl_io.c:72
#: ../imagery/i.his.rgb/openfiles.c:32 ../imagery/i.his.rgb/openfiles.c:37
-#: ../imagery/i.his.rgb/openfiles.c:42 ../imagery/i.group/main.c:181
-#: ../imagery/i.group/main.c:218 ../imagery/i.rgb.his/openfiles.c:15
+#: ../imagery/i.his.rgb/openfiles.c:42 ../imagery/i.group/main.c:195
+#: ../imagery/i.group/main.c:232 ../imagery/i.rgb.his/openfiles.c:15
#: ../imagery/i.rgb.his/openfiles.c:17 ../imagery/i.rgb.his/openfiles.c:19
-#: ../imagery/i.pca/main.c:122 ../imagery/i.class/main.c:108
+#: ../imagery/i.pca/main.c:122 ../imagery/i.class/main.c:124
#: ../imagery/i.gensig/parse.c:48 ../imagery/i.zc/main.c:110
#: ../imagery/i.fft/fftmain.c:120
#: ../imagery/i.ortho.photo/photo.2target/main.c:202
@@ -1505,28 +1505,29 @@
#: ../raster3d/r3.to.rast/main.c:183 ../raster/r.resamp.stats/main.c:346
#: ../raster/r.resamp.interp/main.c:147 ../raster/r.los/main.c:201
-#: ../raster/r.in.ascii/main.c:211 ../raster/r.carve/main.c:182
-#: ../raster/r.texture/main.c:303 ../raster/r.basins.fill/main.c:116
+#: ../raster/r.in.ascii/main.c:211 ../raster/r.carve/main.c:165
+#: ../raster/r.texture/main.c:291 ../raster/r.basins.fill/main.c:116
#: ../raster/r.null/null.c:312 ../raster/r.surf.idw2/main.c:111
-#: ../raster/r.patch/main.c:147 ../raster/r.grow2/main.c:207
+#: ../raster/r.patch/main.c:133 ../raster/r.grow2/main.c:207
#: ../raster/r.circle/dist.c:127 ../raster/r.surf.idw/main.c:147
#: ../raster/r.thin/io.c:176 ../raster/r.li/r.li.daemon/daemon.c:113
#: ../raster/r.flow/io.c:179 ../raster/r.flow/io.c:217
-#: ../raster/r.in.gdal/main.c:722 ../raster/r.in.gdal/main.c:727
-#: ../raster/r.in.gdal/main.c:743 ../raster/r.sunmask/main.c:437
+#: ../raster/r.in.gdal/main.c:723 ../raster/r.in.gdal/main.c:728
+#: ../raster/r.in.gdal/main.c:744 ../raster/r.sunmask/main.c:437
#: ../raster/r.bilinear/main.c:103 ../raster/r.surf.random/randsurf.c:29
#: ../raster/r.surf.random/randsurf.c:33 ../raster/r.in.xyz/main.c:468
-#: ../raster/r.clump/main.c:99 ../raster/r.in.mat/main.c:386
-#: ../raster/r.cross/main.c:137 ../raster/r.series/main.c:185
-#: ../raster/r.mapcalc/map3.c:600 ../raster/r.mapcalc/map.c:513
-#: ../raster/r.composite/main.c:200 ../raster/r.buffer/write_map.c:39
-#: ../raster/r.in.arc/main.c:151 ../raster/r.bitpattern/main.c:125
-#: ../vector/lidar/v.surf.bspline/main.c:284 ../vector/v.kernel/main.c:236
-#: ../vector/v.surf.idw/main.c:234 ../vector/v.neighbors/main.c:94
-#: ../vector/v.to.rast/vect2rast.c:120 ../vector/v.to.rast/vect2rast.c:124
-#: ../doc/raster/r.example/main.c:140 ../imagery/i.his.rgb/openfiles.c:16
-#: ../imagery/i.his.rgb/openfiles.c:18 ../imagery/i.his.rgb/openfiles.c:20
-#: ../imagery/i.smap/shapiro/opencell.c:31 ../imagery/i.pca/main.c:395
+#: ../raster/r.slope.aspect/opennew.c:19 ../raster/r.clump/main.c:84
+#: ../raster/r.in.mat/main.c:397 ../raster/r.cross/main.c:120
+#: ../raster/r.series/main.c:171 ../raster/r.mapcalc/map3.c:600
+#: ../raster/r.mapcalc/map.c:513 ../raster/r.composite/main.c:196
+#: ../raster/r.buffer/write_map.c:39 ../raster/r.in.arc/main.c:151
+#: ../raster/r.bitpattern/main.c:125 ../vector/lidar/v.surf.bspline/main.c:284
+#: ../vector/v.kernel/main.c:223 ../vector/v.surf.idw/main.c:234
+#: ../vector/v.neighbors/main.c:94 ../vector/v.to.rast/vect2rast.c:120
+#: ../vector/v.to.rast/vect2rast.c:124 ../doc/raster/r.example/main.c:140
+#: ../imagery/i.his.rgb/openfiles.c:16 ../imagery/i.his.rgb/openfiles.c:18
+#: ../imagery/i.his.rgb/openfiles.c:20 ../imagery/i.smap/shapiro/opencell.c:31
+#: ../imagery/i.pca/main.c:395
#, c-format
msgid "Unable to create raster map <%s>"
msgstr "No se puede crear el mapa ráster <%s>"
@@ -1588,7 +1589,8 @@
msgstr "ráster, análisis de estructura del paisaje"
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "prints a graph of the correlation between data layers (in pairs)"
+#, fuzzy
+msgid "Prints a graph of the correlation between data layers (in pairs)."
msgstr ""
"presenta un gráfico de la correlación entre dos capas de datos (en pares)"
@@ -1861,8 +1863,7 @@
#: ../display/d.what.rast/main.c:44 ../display/d.title/main.c:45
#: ../display/d.geodesic/main.c:45 ../display/d.text/main.c:67
#: ../display/d.font.freetype/main.c:58 ../display/d.info/main.c:33
-#: ../display/d.save/main.c:81 ../display/d.vect/main.c:126
-#: ../display/d.vect.chart/main.c:62 ../display/d.rast.arrow/arrow.c:112
+#: ../display/d.save/main.c:81 ../display/d.rast.arrow/arrow.c:112
#: ../display/d.menu/main.c:65 ../display/d.text.freetype/main.c:140
#: ../display/d.rast/main.c:52 ../display/d.extract/main.c:48
#: ../display/d.rgb/main.c:53 ../display/d.where/main.c:41
@@ -2661,48 +2662,47 @@
"Mezcla los componentes de color de dos mapas ráster en la proporción indicada"
#: ../locale/scriptstrings/r.blend_to_translate.c:2
-#: ../raster/r.describe/main.c:58 ../raster/r.rescale.eq/main.c:51
-#: ../raster/r.surf.area/main.c:89 ../raster/r.coin/cmd_parms.c:42
-#: ../raster/r.out.png/r.out.png.c:135 ../raster/r.distance/main.c:38
+#: ../raster/r.describe/main.c:55 ../raster/r.rescale.eq/main.c:46
+#: ../raster/r.surf.area/main.c:89 ../raster/r.coin/cmd_parms.c:39
+#: ../raster/r.out.png/r.out.png.c:128 ../raster/r.distance/main.c:38
#: ../raster/r.surf.fractal/interface.c:32 ../raster/r.reclass/main.c:48
#: ../raster/r.los/main.c:81 ../raster/r.drain/main.c:103
-#: ../raster/r.carve/main.c:76 ../raster/r.profile/main.c:53
+#: ../raster/r.carve/main.c:72 ../raster/r.profile/main.c:53
#: ../raster/r.texture/main.c:71 ../raster/r.basins.fill/main.c:51
#: ../raster/r.sum/main.c:47 ../raster/r.sun/main.c:175
#: ../raster/r.volume/main.c:56 ../raster/r.null/null.c:45
#: ../raster/r.average/main.c:51 ../raster/r.lake/main.c:156
#: ../raster/r.out.gridatb/main.c:46 ../raster/r.surf.idw2/main.c:60
#: ../raster/r.transect/main.c:53 ../raster/r.mode/main.c:48
-#: ../raster/r.info/main.c:68 ../raster/r.compress/main.c:63
-#: ../raster/r.patch/main.c:53 ../raster/r.le/r.le.setup/main.c:60
+#: ../raster/r.info/main.c:68 ../raster/r.compress/main.c:60
+#: ../raster/r.patch/main.c:52 ../raster/r.le/r.le.setup/main.c:60
#: ../raster/r.le/r.le.pixel/main.c:45 ../raster/r.le/r.le.trace/main.c:57
#: ../raster/r.le/r.le.patch/main.c:47 ../raster/r.digit/main.c:44
#: ../raster/r.grow2/main.c:127 ../raster/r.circle/dist.c:52
#: ../raster/r.surf.idw/main.c:68 ../raster/r.thin/main.c:54
#: ../raster/r.surf.contour/main.c:50 ../raster/r.topidx/main.c:37
-#: ../raster/r.out.pov/main.c:120 ../raster/r.covar/main.c:52
-#: ../raster/r.out.arc/main.c:58 ../raster/r.rescale/main.c:48
+#: ../raster/r.out.pov/main.c:120 ../raster/r.covar/main.c:49
+#: ../raster/r.out.arc/main.c:58 ../raster/r.rescale/main.c:43
#: ../raster/r.random/main.c:46 ../raster/r.sunmask/main.c:124
#: ../raster/r.his/main.c:64 ../raster/r.topmodel/main.c:56
#: ../raster/r.bilinear/main.c:41 ../raster/r.kappa/main.c:49
#: ../raster/r.median/main.c:44 ../raster/r.resamp.rst/main.c:155
#: ../raster/r.stats/main.c:87 ../raster/r.surf.random/main.c:41
-#: ../raster/r.slope.aspect/main.c:152 ../raster/r.surf.gauss/main.c:43
-#: ../raster/r.fill.dir/main.c:85 ../raster/r.timestamp/main.c:34
-#: ../raster/r.what/main.c:89 ../raster/r.random.surface/main.c:47
-#: ../raster/r.out.vtk/main.c:150 ../raster/r.out.bin/main.c:63
-#: ../raster/r.neighbors/main.c:103 ../raster/r.clump/main.c:50
-#: ../raster/r.what.color/main.c:89 ../raster/r.in.gridatb/main.c:43
-#: ../raster/r.random.cells/main.c:39 ../raster/r.to.vect/main.c:49
-#: ../raster/r.region/main.c:53 ../raster/r.out.ppm3/main.c:54
-#: ../raster/r.in.mat/main.c:93 ../raster/r.watershed/front/main.c:49
-#: ../raster/r.quant/main.c:41 ../raster/r.contour/main.c:90
-#: ../raster/r.cross/main.c:65 ../raster/r.cats/main.c:49
-#: ../raster/r.out.mpeg/main.c:395 ../raster/r.walk/main.c:172
-#: ../raster/r.recode/main.c:42 ../raster/r.composite/main.c:71
+#: ../raster/r.surf.gauss/main.c:43 ../raster/r.fill.dir/main.c:85
+#: ../raster/r.timestamp/main.c:34 ../raster/r.what/main.c:89
+#: ../raster/r.random.surface/main.c:47 ../raster/r.out.vtk/main.c:150
+#: ../raster/r.out.bin/main.c:63 ../raster/r.neighbors/main.c:102
+#: ../raster/r.clump/main.c:47 ../raster/r.what.color/main.c:89
+#: ../raster/r.in.gridatb/main.c:43 ../raster/r.random.cells/main.c:39
+#: ../raster/r.to.vect/main.c:49 ../raster/r.region/main.c:53
+#: ../raster/r.out.ppm3/main.c:53 ../raster/r.in.mat/main.c:88
+#: ../raster/r.watershed/front/main.c:49 ../raster/r.quant/main.c:41
+#: ../raster/r.contour/main.c:85 ../raster/r.cross/main.c:62
+#: ../raster/r.cats/main.c:49 ../raster/r.out.mpeg/main.c:395
+#: ../raster/r.walk/main.c:172 ../raster/r.recode/main.c:42
#: ../raster/r.gwflow/main.c:219 ../raster/wildfire/r.ros/main.c:212
#: ../raster/wildfire/r.spreadpath/main.c:71
-#: ../raster/wildfire/r.spread/main.c:102 ../raster/r.resample/main.c:53
+#: ../raster/wildfire/r.spread/main.c:102 ../raster/r.resample/main.c:52
#: ../raster/r.in.arc/main.c:58 ../raster/r.bitpattern/main.c:62
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:152
msgid "raster"
@@ -3011,8 +3011,8 @@
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
#: ../raster/r.out.ascii/main.c:60 ../raster/r.out.gdal/main.c:375
-#: ../raster/r.out.mat/main.c:61 ../raster/r.out.ppm/main.c:52
-#: ../raster/r.out.tiff/r.out.tiff.c:100
+#: ../raster/r.out.mat/main.c:59 ../raster/r.out.ppm/main.c:51
+#: ../raster/r.out.tiff/r.out.tiff.c:99
msgid "raster, export"
msgstr "ráster, exportar"
@@ -3141,7 +3141,7 @@
#: ../locale/scriptstrings/r.regression.line_to_translate.c:2
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
#: ../raster/r.statistics/main.c:41 ../raster/r.report/main.c:27
-#: ../raster/r.univar2/r.univar_main.c:74 ../raster/r.quantile/main.c:233
+#: ../raster/r.univar2/r.univar_main.c:75 ../raster/r.quantile/main.c:233
msgid "raster, statistics"
msgstr "ráster, estadísticas"
@@ -3322,8 +3322,8 @@
#: ../vector/v.out.ascii/out.c:43 ../vector/v.sample/main.c:86
#: ../vector/v.in.region/main.c:38 ../vector/v.info/main.c:63
#: ../vector/v.info/main.c:227 ../vector/v.patch/main.c:68
-#: ../vector/v.vol.rst/main.c:201 ../vector/v.mkgrid/main.c:62
-#: ../vector/v.clean/test/topocheck.c:40 ../vector/v.voronoi/dt_main.c:44
+#: ../vector/v.vol.rst/main.c:201 ../vector/v.mkgrid/main.c:61
+#: ../vector/v.clean/test/topocheck.c:40 ../vector/v.voronoi/dt_main.c:46
#: ../vector/v.voronoi/vo_main.c:107 ../vector/v.out.vtk/main.c:45
#: ../vector/v.select/main.c:129 ../vector/v.surf.rst/main.c:159
#: ../vector/v.buffer/main.c:245 ../vector/v.extract/main.c:73
@@ -3569,7 +3569,7 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
#: ../vector/lidar/v.outlier/main.c:68 ../vector/v.univar/main.c:60
-#: ../vector/v.qcount/main.c:68 ../vector/v.random/main.c:77
+#: ../vector/v.qcount/main.c:67 ../vector/v.random/main.c:77
#: ../vector/v.kcv/main.c:76 ../vector/v.normal/main.c:78
#: ../vector/v.class/main.c:45
msgid "vector, statistics"
@@ -3676,8 +3676,6 @@
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:3
-#: ../raster/r.out.mat/main.c:79 ../raster/r.in.mat/main.c:116
-#: ../raster/r.out.tiff/r.out.tiff.c:137
msgid "Verbose mode"
msgstr "Modo verboso"
@@ -3852,7 +3850,7 @@
msgstr "Continuar si la columna(s) en la que cargar ya existe"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../raster/r.univar2/r.univar_main.c:47
+#: ../raster/r.univar2/r.univar_main.c:48
#: ../raster/r.univar2/r3.univar_main.c:47 ../vector/v.univar/main.c:94
msgid "Calculate extended statistics"
msgstr "Calcular estadísticas ampliadas"
@@ -3870,7 +3868,7 @@
msgstr "Prefijo de columna para las nuevas columnas de atributos"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-#: ../raster/r.univar2/r.univar_main.c:39
+#: ../raster/r.univar2/r.univar_main.c:40
#: ../raster/r.univar2/r3.univar_main.c:39 ../vector/v.univar/main.c:86
msgid "Percentile to calculate (requires extended statistics flag)"
msgstr "Percentil a calcular (requiere la opción de estadísticas ampliadas)"
@@ -3929,123 +3927,79 @@
msgid "Column to be queried"
msgstr "Columna a consultar"
-#: ../raster/r.describe/main.c:60
+#: ../raster/r.describe/main.c:57
msgid "Prints terse list of category values found in a raster map layer."
msgstr ""
"Imprime una lista concisa de valores de categoría en una capa de mapa ráster."
-#: ../raster/r.describe/main.c:71 ../raster/r.stats/main.c:116
+#: ../raster/r.describe/main.c:68 ../raster/r.stats/main.c:116
msgid "String representing no data cell value"
msgstr "Cadena que representa el valor de celda sin datos"
-#: ../raster/r.describe/main.c:79
+#: ../raster/r.describe/main.c:76
msgid "Number of quantization steps"
msgstr "Número de pasos de cuantización"
-#: ../raster/r.describe/main.c:85
+#: ../raster/r.describe/main.c:82
msgid "Print the output one value per line"
msgstr "Imprimir la salida un valor por línea"
-#: ../raster/r.describe/main.c:89
+#: ../raster/r.describe/main.c:86
msgid "Only print the range of the data"
msgstr "Imprimir sólo el rango de los datos"
-#: ../raster/r.describe/main.c:93 ../raster/r.stats/main.c:164
+#: ../raster/r.describe/main.c:90 ../raster/r.stats/main.c:164
msgid "Suppress reporting of any NULLs"
msgstr "Suprimir informar de cualquier NULO"
-#: ../raster/r.describe/main.c:97
+#: ../raster/r.describe/main.c:94
msgid "Use the current region"
msgstr "Usar la región actual"
-#: ../raster/r.describe/main.c:101
+#: ../raster/r.describe/main.c:98
msgid "Read fp map as integer"
msgstr "Leer mapa fp como entero"
-#: ../raster/r.describe/main.c:106 ../raster/r.coin/cmd_parms.c:78
-#: ../raster/r.distance/parse.c:63 ../raster/r.carve/main.c:113
-#: ../raster/r.compress/main.c:82 ../raster/r.covar/main.c:66
-#: ../raster/r.colors/main.c:221 ../raster/r.out.ppm/main.c:68
-#: ../raster/r.neighbors/main.c:158 ../raster/r.clump/main.c:69
-#: ../raster/r.out.ppm3/main.c:86 ../raster/r.contour/main.c:133
-#: ../raster/r.cross/main.c:90 ../raster/r.series/main.c:125
-#: ../raster/r.buffer/main.c:89 ../imagery/i.smap/shapiro/parse.c:54
-#: ../imagery/i.maxlik/main.c:86
-msgid "Run quietly"
-msgstr "Ejecutar en modo silencioso"
-#: ../raster/r.describe/main.c:114 ../raster/r.rescale.eq/main.c:105
-#: ../raster/r.coin/cmd_parms.c:87 ../raster/r.out.png/r.out.png.c:145
-#: ../raster/r.distance/parse.c:71 ../raster/r.carve/main.c:123
-#: ../raster/r.texture/main.c:217 ../raster/r.compress/main.c:90
-#: ../raster/r.patch/main.c:86 ../raster/r.covar/main.c:74
-#: ../raster/r.rescale/main.c:101 ../raster/r.slope.aspect/main.c:319
-#: ../raster/r.colors/main.c:231 ../raster/r.random.surface/init.c:107
-#: ../raster/r.neighbors/main.c:276 ../raster/r.clump/main.c:78
-#: ../raster/r.to.vect/main.c:95 ../raster/r.out.ppm3/main.c:98
-#: ../raster/r.cross/main.c:97 ../raster/r.series/main.c:137
-#: ../raster/r.resample/main.c:89 ../raster/r.buffer/main.c:98
-#: ../vector/v.qcount/main.c:115 ../vector/v.mkgrid/main.c:122
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:319
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"La opción -q está suplantada y se eliminará en el futuro. Por favor, use '--"
-"quiet' en su lugar."
-#: ../raster/r.describe/main.c:125
+#: ../raster/r.describe/main.c:110
#, c-format
msgid "%s = %s -- must be greater than zero"
msgstr "%s = %s -- debe ser mayor que cero"
-#: ../raster/r.describe/main.c:137
+#: ../raster/r.describe/main.c:122
#, c-format
msgid "%s: [%s] not found"
msgstr "%s: [%s] no encontrado"
-#: ../raster/r.rescale.eq/main.c:53
+#: ../raster/r.rescale.eq/main.c:48
#, fuzzy
msgid ""
"Rescales histogram equalized the range of category values in a raster map "
"layer."
msgstr "Rescala el histograma ráster."
-#: ../raster/r.rescale.eq/main.c:63 ../raster/r.rescale/main.c:60
+#: ../raster/r.rescale.eq/main.c:58 ../raster/r.rescale/main.c:55
msgid "The name of the raster map to be rescaled"
msgstr "Nombre del mapa ráster a rescalar"
-#: ../raster/r.rescale.eq/main.c:70 ../raster/r.rescale/main.c:67
+#: ../raster/r.rescale.eq/main.c:65 ../raster/r.rescale/main.c:62
msgid "The input data range to be rescaled (default: full range of input map)"
msgstr ""
"Rango de datos de entrada a rescalar (por omisión: todo el rango del mapa de "
"entrada)"
-#: ../raster/r.rescale.eq/main.c:77 ../raster/r.rescale/main.c:74
+#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:69
msgid "The resulting raster map name"
msgstr "Nombre del mapa ráster resultante"
-#: ../raster/r.rescale.eq/main.c:84 ../raster/r.rescale/main.c:81
+#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:76
msgid "The output data range"
msgstr "Rango de datos de salida"
-#: ../raster/r.rescale.eq/main.c:91 ../raster/r.rescale/main.c:88
+#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:83
msgid "Title for new raster map"
msgstr "Título para el nuevo mapa ráster"
-#: ../raster/r.rescale.eq/main.c:96 ../raster/r.texture/main.c:108
-#: ../raster/r.patch/main.c:72 ../raster/r.grow2/main.c:165
-#: ../raster/r.report/parse.c:90 ../raster/r.kappa/main.c:82
-#: ../raster/r.slope.aspect/main.c:281 ../raster/r.mfilter.fp/main.c:89
-#: ../raster/r.mfilter/main.c:82 ../raster/r.resample/main.c:78
-#: ../raster/r.bitpattern/main.c:87 ../vector/v.perturb/main.c:116
-#: ../vector/v.sample/main.c:128 ../vector/v.kcv/main.c:104
-#: ../doc/raster/r.example/main.c:95 ../imagery/i.cluster/main.c:135
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
-msgid "Quiet"
-msgstr "Silencioso"
-#: ../raster/r.rescale.eq/main.c:149
+#: ../raster/r.rescale.eq/main.c:131
#, c-format
msgid "Rescale %s[%d,%d] to %s[%d,%d]"
msgstr "Rescalar %s[%d,%d] a %s[%d,%d]"
@@ -4061,14 +4015,15 @@
msgstr "ráster, remuestrear"
#: ../raster/r.resamp.stats/main.c:267
-msgid "Resamples raster map layers using aggregation."
+#, fuzzy
+msgid "Resamples raster map layers to a coarser grid using aggregation."
msgstr "Vuelve a muestrear capas de mapa ráster usando agregación."
#: ../raster/r.resamp.stats/main.c:277
msgid "Aggregation method"
msgstr "Método de agregación"
-#: ../raster/r.resamp.stats/main.c:283 ../raster/r.series/main.c:129
+#: ../raster/r.resamp.stats/main.c:283 ../raster/r.series/main.c:122
msgid "Propagate NULLs"
msgstr "Propagar NULOS"
@@ -4077,7 +4032,7 @@
msgid "Weight according to area (slower)"
msgstr "a"
-#: ../raster/r.resamp.stats/main.c:296 ../raster/r.series/main.c:150
+#: ../raster/r.resamp.stats/main.c:296 ../raster/r.series/main.c:136
#, c-format
msgid "Unknown method <%s>"
msgstr "Método <%s> desconocido"
@@ -4085,29 +4040,29 @@
#: ../raster/r.resamp.stats/main.c:335 ../raster/r.surf.area/main.c:124
#: ../raster/r.resamp.interp/main.c:137 ../raster/r.los/main.c:196
#: ../raster/r.los/main.c:207 ../raster/r.out.ascii/main.c:150
-#: ../raster/r.carve/main.c:176 ../raster/r.profile/main.c:144
-#: ../raster/r.texture/main.c:230 ../raster/r.sum/main.c:68
+#: ../raster/r.carve/main.c:159 ../raster/r.profile/main.c:144
+#: ../raster/r.texture/main.c:218 ../raster/r.sum/main.c:68
#: ../raster/r.null/null.c:307 ../raster/r.out.gdal/main.c:101
-#: ../raster/r.surf.idw2/read_cell.c:36 ../raster/r.out.mat/main.c:99
+#: ../raster/r.surf.idw2/read_cell.c:36 ../raster/r.out.mat/main.c:90
#: ../raster/r.to.rast3elev/main.c:161 ../raster/r.grow2/main.c:201
#: ../raster/r.surf.idw/main.c:135 ../raster/r.thin/io.c:102
-#: ../raster/r.out.pov/main.c:175 ../raster/r.covar/main.c:99
+#: ../raster/r.out.pov/main.c:175 ../raster/r.covar/main.c:84
#: ../raster/r.out.arc/main.c:115 ../raster/r.random/count.c:24
#: ../raster/r.random/count.c:29 ../raster/r.sunmask/main.c:435
#: ../raster/r.his/main.c:132 ../raster/r.his/main.c:158
#: ../raster/r.his/main.c:186 ../raster/r.bilinear/main.c:92
#: ../raster/r.resamp.rst/main.c:405 ../raster/r.resamp.rst/main.c:437
-#: ../raster/r.out.ppm/main.c:120 ../raster/r.cost/main.c:337
+#: ../raster/r.out.ppm/main.c:106 ../raster/r.cost/main.c:319
#: ../raster/r.out.vtk/main.c:224 ../raster/r.out.vtk/main.c:286
#: ../raster/r.out.vtk/main.c:314 ../raster/r.out.vtk/main.c:360
#: ../raster/r.support/front/front.c:221 ../raster/r.out.bin/main.c:133
-#: ../raster/r.clump/main.c:95 ../raster/r.to.vect/main.c:112
-#: ../raster/r.out.ppm3/main.c:121 ../raster/r.univar2/r.univar_main.c:153
-#: ../raster/r.contour/main.c:160 ../raster/r.cross/main.c:120
-#: ../raster/r.cats/main.c:143 ../raster/r.out.tiff/r.out.tiff.c:188
-#: ../raster/r.walk/main.c:545 ../raster/r.walk/main.c:548
-#: ../raster/r.walk/main.c:855 ../raster/r.mapcalc/map3.c:527
-#: ../raster/r.composite/main.c:166 ../raster/wildfire/r.ros/main.c:441
+#: ../raster/r.clump/main.c:80 ../raster/r.to.vect/main.c:99
+#: ../raster/r.out.ppm3/main.c:107 ../raster/r.univar2/r.univar_main.c:154
+#: ../raster/r.contour/main.c:138 ../raster/r.cross/main.c:103
+#: ../raster/r.cats/main.c:143 ../raster/r.out.tiff/r.out.tiff.c:172
+#: ../raster/r.walk/main.c:540 ../raster/r.walk/main.c:543
+#: ../raster/r.walk/main.c:850 ../raster/r.mapcalc/map3.c:527
+#: ../raster/r.composite/main.c:162 ../raster/wildfire/r.ros/main.c:441
#: ../raster/wildfire/r.ros/main.c:446 ../raster/wildfire/r.ros/main.c:451
#: ../raster/wildfire/r.ros/main.c:456 ../raster/wildfire/r.ros/main.c:461
#: ../raster/wildfire/r.ros/main.c:466 ../raster/wildfire/r.ros/main.c:471
@@ -4122,7 +4077,7 @@
#: ../raster/r.buffer/write_map.c:45 ../raster/r.bitpattern/main.c:108
#: ../raster/r.to.rast3/main.c:358 ../raster/r.quantile/main.c:287
#: ../vector/v.what.rast/main.c:135 ../vector/v.extrude/main.c:182
-#: ../vector/v.sample/main.c:160 ../vector/v.vol.rst/main.c:580
+#: ../vector/v.sample/main.c:155 ../vector/v.vol.rst/main.c:580
#: ../vector/v.to.rast/support.c:247 ../vector/v.to.rast/support.c:396
#: ../vector/v.drape/main.c:125 ../doc/raster/r.example/main.c:121
#: ../imagery/i.his.rgb/openfiles.c:34 ../imagery/i.his.rgb/openfiles.c:39
@@ -4139,7 +4094,7 @@
msgstr "No se puede abrir el mapa ráster <%s>"
#: ../raster/r.resamp.stats/main.c:378 ../raster/r.resamp.interp/main.c:337
-#: ../raster/r.colors/main.c:355
+#: ../raster/r.colors/main.c:341
#, c-format
msgid "Unable to read color table for %s"
msgstr "No se puede leer la tabla de color para %s"
@@ -4304,7 +4259,7 @@
msgstr "No realizar optimización de "
#: ../raster/r.proj.seg/main.c:212 ../raster/r.statistics/main.c:98
-#: ../raster/r.neighbors/main.c:214 ../raster/r.proj/main.c:200
+#: ../raster/r.neighbors/main.c:208 ../raster/r.proj/main.c:200
#, c-format
msgid "<%s=%s> unknown %s"
msgstr "<%s=%s> desconocido %s"
@@ -4341,12 +4296,12 @@
msgid "Mapset <%s> in input location <%s> - %s"
msgstr "Directorio de mapas <%s> en localización de entrada <%s> - %s"
-#: ../raster/r.proj.seg/main.c:248 ../raster/r.in.gdal/main.c:642
+#: ../raster/r.proj.seg/main.c:248 ../raster/r.in.gdal/main.c:643
#: ../raster/r.proj/main.c:236
msgid "permission denied"
msgstr "permiso denegado"
-#: ../raster/r.proj.seg/main.c:249 ../raster/r.in.gdal/main.c:643
+#: ../raster/r.proj.seg/main.c:249 ../raster/r.in.gdal/main.c:644
#: ../raster/r.proj/main.c:237
msgid "not found"
msgstr "no encontrado"
@@ -4449,9 +4404,9 @@
msgstr "Proyectando..."
#: ../raster/r.proj.seg/main.c:442 ../raster/r.los/main.c:372
-#: ../raster/r.texture/main.c:349 ../raster/r.texture/main.c:352
-#: ../raster/r.texture/main.c:358 ../raster/r.in.mat/main.c:439
-#: ../raster/r.buffer/write_map.c:81 ../raster/r.proj/main.c:430
+#: ../raster/r.texture/main.c:337 ../raster/r.texture/main.c:340
+#: ../raster/r.texture/main.c:346 ../raster/r.buffer/write_map.c:81
+#: ../raster/r.proj/main.c:430
#, c-format
msgid "Failed writing raster map <%s> row %d"
msgstr "No se puede escribir en el mapa ráster <%s> la fila %d"
@@ -4486,7 +4441,8 @@
msgstr "Error al buscar en el archivo de segmentos"
#: ../raster/r.resamp.interp/main.c:73
-msgid "Resamples raster map layers using interpolation."
+#, fuzzy
+msgid "Resamples raster map layers to a finer grid using interpolation."
msgstr "Remuestrea capas de mapas ráster usando interpolación."
#: ../raster/r.resamp.interp/main.c:82
@@ -4603,7 +4559,7 @@
msgid "Preparing report ..."
msgstr "Preparando informe..."
-#: ../raster/r.coin/cmd_parms.c:44
+#: ../raster/r.coin/cmd_parms.c:41
msgid ""
"Tabulates the mutual occurrence (coincidence) of categories for two raster "
"map layers."
@@ -4611,19 +4567,19 @@
"Tabula la ocurrencia mutua (coincidencia) de categorías de dos capas de mapa "
"ráster."
-#: ../raster/r.coin/cmd_parms.c:52
+#: ../raster/r.coin/cmd_parms.c:49
msgid "Name of first raster map"
msgstr "Nombre del primer mapa ráster"
-#: ../raster/r.coin/cmd_parms.c:59
+#: ../raster/r.coin/cmd_parms.c:56
msgid "Name of second raster map"
msgstr "Nombre del segundo mapa ráster"
-#: ../raster/r.coin/cmd_parms.c:65
+#: ../raster/r.coin/cmd_parms.c:62
msgid "Unit of measure"
msgstr "Unidad de medida"
-#: ../raster/r.coin/cmd_parms.c:66
+#: ../raster/r.coin/cmd_parms.c:63
msgid ""
"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
@@ -4632,7 +4588,7 @@
"de categoría [fila]), a(cres), h(ectáreas), k(ilómetros cuadrados), m(illas "
"cuadradas)"
-#: ../raster/r.coin/cmd_parms.c:73
+#: ../raster/r.coin/cmd_parms.c:70
msgid "Wide report, 132 columns (default: 80)"
msgstr "Informe amplio, 132 columnas (por omisión: 80)"
@@ -4657,13 +4613,13 @@
msgid "Unable to open tempfile"
msgstr "No se puede abrir el archivo temporal"
-#: ../raster/r.out.png/r.out.png.c:179 ../raster/r.out.ppm/main.c:109
-#: ../raster/r.out.ppm3/main.c:105
+#: ../raster/r.out.png/r.out.png.c:164 ../raster/r.out.ppm/main.c:95
+#: ../raster/r.out.ppm3/main.c:91
#, c-format
msgid "rows = %d, cols = %d"
msgstr "filas = %d, columnas = %d"
-#: ../raster/r.out.png/r.out.png.c:253
+#: ../raster/r.out.png/r.out.png.c:238
#, c-format
msgid "Converting %s..."
msgstr "Convirtiendo %s..."
@@ -4682,15 +4638,15 @@
msgid "Reading maps <%s,%s> while finding 0 distance ..."
msgstr "Leyendo mapas <%s,%s> mientras se encuentran distancias 0..."
-#: ../raster/r.distance/parse.c:41
+#: ../raster/r.distance/parse.c:38
msgid "Maps for computing inter-class distances"
msgstr "Mapas para procesar distancias entre clases"
-#: ../raster/r.distance/parse.c:54
+#: ../raster/r.distance/parse.c:51
msgid "Include category labels in the output"
msgstr "Incluir etiquetas de categoría en la salida"
-#: ../raster/r.distance/parse.c:58
+#: ../raster/r.distance/parse.c:55
msgid "Report zero distance if rasters are overlapping"
msgstr "Informar distancia cero si los ráster solapan"
@@ -4721,24 +4677,24 @@
#: ../raster/r.surf.fractal/interface.c:84 ../raster/r.reclass/main.c:80
#: ../raster/r.los/main.c:171 ../raster/r.in.ascii/main.c:208
-#: ../raster/r.texture/main.c:227 ../raster/r.average/main.c:77
+#: ../raster/r.texture/main.c:215 ../raster/r.average/main.c:77
#: ../raster/r.surf.idw2/main.c:84 ../raster/r.mode/main.c:95
#: ../raster/r.to.rast3elev/main.c:474 ../raster/r.surf.idw/main.c:112
#: ../raster/r.in.gdal/main.c:206 ../raster/r.random/main.c:136
#: ../raster/r.random/main.c:141 ../raster/r.median/main.c:75
#: ../raster/r.slope.aspect/opennew.c:11 ../raster/r.surf.gauss/main.c:74
-#: ../raster/r.cost/main.c:324 ../raster/r.neighbors/main.c:185
-#: ../raster/r.clump/main.c:91 ../raster/r.in.mat/main.c:352
+#: ../raster/r.cost/main.c:306 ../raster/r.neighbors/main.c:179
+#: ../raster/r.clump/main.c:76 ../raster/r.in.mat/main.c:356
#: ../raster/r.watershed/ram/init_vars.c:330
#: ../raster/r.watershed/shed/com_line.c:194
#: ../raster/r.watershed/shed/com_line.c:224
#: ../raster/r.watershed/seg/init_vars.c:360
-#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:531
+#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:526
#: ../raster/r.recode/main.c:85 ../raster/wildfire/r.spread/main.c:383
#: ../raster/wildfire/r.spread/main.c:395
-#: ../raster/wildfire/r.spread/main.c:408 ../raster/r.buffer/main.c:118
+#: ../raster/wildfire/r.spread/main.c:408 ../raster/r.buffer/main.c:101
#: ../raster/r.bitpattern/main.c:104 ../vector/v.to.rast3/main.c:68
-#: ../vector/v.edit/main.c:85 ../vector/v.kernel/main.c:232
+#: ../vector/v.edit/main.c:85 ../vector/v.kernel/main.c:219
#: ../vector/v.in.ogr/main.c:316 ../vector/v.surf.idw/main.c:121
#: ../vector/v.random/main.c:123 ../doc/raster/r.example/main.c:113
#: ../imagery/i.ifft/ifftmain.c:107 ../imagery/i.zc/main.c:118
@@ -4941,12 +4897,12 @@
#: ../raster/r.profile/read_rast.c:47 ../raster/r.profile/read_rast.c:73
#: ../raster/r.profile/read_rast.c:99 ../raster/r.out.gdal/main.c:236
#: ../raster/r.out.gdal/main.c:266 ../raster/r.out.gdal/main.c:296
-#: ../raster/r.patch/main.c:160 ../raster/r.patch/main.c:168
-#: ../raster/r.topidx/file_io.c:64 ../raster/r.out.ppm/main.c:187
-#: ../raster/r.cost/main.c:399 ../raster/r.cost/main.c:603
-#: ../raster/r.walk/main.c:700 ../raster/r.walk/main.c:758
-#: ../raster/r.walk/main.c:873 ../raster/r.walk/main.c:1413
-#: ../raster/r.walk/main.c:1448 ../raster/r.walk/main.c:1482
+#: ../raster/r.patch/main.c:146 ../raster/r.patch/main.c:154
+#: ../raster/r.topidx/file_io.c:64 ../raster/r.out.ppm/main.c:173
+#: ../raster/r.cost/main.c:381 ../raster/r.cost/main.c:585
+#: ../raster/r.walk/main.c:695 ../raster/r.walk/main.c:753
+#: ../raster/r.walk/main.c:868 ../raster/r.walk/main.c:1408
+#: ../raster/r.walk/main.c:1443 ../raster/r.walk/main.c:1477
#: ../raster/r.buffer/read_map.c:60 ../raster/r.buffer/write_map.c:65
#: ../raster/r.bitpattern/main.c:135 ../vector/v.what.rast/main.c:258
#: ../vector/v.what.rast/main.c:261 ../vector/v.to.rast/support.c:411
@@ -5005,8 +4961,8 @@
msgid "Too many start points"
msgstr "Demasiados puntos de inicio"
-#: ../raster/r.drain/main.c:215 ../raster/r.carve/main.c:167
-#: ../raster/r.cost/main.c:298 ../raster/r.region/main.c:230
+#: ../raster/r.drain/main.c:215 ../raster/r.carve/main.c:150
+#: ../raster/r.cost/main.c:280 ../raster/r.region/main.c:230
#: ../vector/v.db.connect/main.c:113 ../vector/v.perturb/main.c:153
#: ../vector/v.edit/main.c:138
#: ../vector/lidar/v.lidar.edgedetection/main.c:164
@@ -5020,16 +4976,16 @@
#: ../vector/v.segment/main.c:95 ../vector/v.db.select/main.c:91
#: ../vector/v.univar/main.c:109 ../vector/v.what.rast/main.c:116
#: ../vector/v.build.polylines/main.c:136 ../vector/v.net.iso/main.c:174
-#: ../vector/v.extrude/main.c:143 ../vector/v.kernel/main.c:192
-#: ../vector/v.sample/main.c:151 ../vector/v.generalize/main.c:300
-#: ../vector/v.info/main.c:96 ../vector/v.qcount/main.c:126
+#: ../vector/v.extrude/main.c:143 ../vector/v.kernel/main.c:179
+#: ../vector/v.sample/main.c:146 ../vector/v.generalize/main.c:300
+#: ../vector/v.info/main.c:96 ../vector/v.qcount/main.c:112
#: ../vector/v.out.pov/main.c:93 ../vector/v.transform/main.c:228
#: ../vector/v.convert/old2new.c:27 ../vector/v.overlay/main.c:184
-#: ../vector/v.net.path/main.c:126 ../vector/v.label.sa/labels.c:56
+#: ../vector/v.net.path/main.c:126 ../vector/v.label.sa/labels.c:55
#: ../vector/v.clean/main.c:226 ../vector/v.kcv/main.c:132
#: ../vector/v.net/main.c:139 ../vector/v.net/main.c:153
#: ../vector/v.out.dxf/main.c:67 ../vector/v.normal/main.c:128
-#: ../vector/v.voronoi/dt_main.c:75 ../vector/v.voronoi/vo_main.c:145
+#: ../vector/v.voronoi/dt_main.c:77 ../vector/v.voronoi/vo_main.c:145
#: ../vector/v.what/main.c:142 ../vector/v.hull/main.c:295
#: ../vector/v.out.svg/main.c:124 ../vector/v.to.db/parse.c:112
#: ../vector/v.select/main.c:180 ../vector/v.net.alloc/main.c:130
@@ -5044,7 +5000,7 @@
#: ../vector/v.lrs/v.lrs.where/main.c:131 ../vector/v.buffer/main.c:353
#: ../vector/v.extract/main.c:139 ../vector/v.class/main.c:95
#: ../doc/vector/v.example/main.c:61 ../display/d.what.vect/main.c:149
-#: ../display/d.vect/main.c:450 ../display/d.vect.chart/main.c:227
+#: ../display/d.vect/main.c:459 ../display/d.vect.chart/main.c:234
#: ../display/d.extract/main.c:96 ../display/d.zoom/main.c:259
#: ../display/d.extend/main.c:103 ../display/d.path/main.c:192
#: ../display/d.thematic.area/main.c:187 ../general/g.region/main.c:520
@@ -5185,7 +5141,7 @@
#: ../raster/r.resamp.rst/main.c:616 ../raster/r.resamp.rst/main.c:627
#: ../raster/r.resamp.rst/main.c:639 ../raster/r.resamp.rst/main.c:652
#: ../raster/r.resamp.rst/main.c:664 ../raster/r.resamp.rst/main.c:676
-#: ../raster/r.in.arc/main.c:113 ../vector/v.in.ascii/in.c:239
+#: ../raster/r.in.arc/main.c:113 ../vector/v.in.ascii/in.c:241
#: ../vector/v.surf.rst/main.c:590 ../vector/v.surf.rst/main.c:598
#: ../vector/v.surf.rst/main.c:606 ../vector/v.surf.rst/main.c:615
#: ../vector/v.surf.rst/main.c:623 ../vector/v.surf.rst/main.c:631
@@ -5215,7 +5171,7 @@
msgid "Can't get cell header"
msgstr "No se puede obtener la cabecera de celda"
-#: ../raster/r.in.ascii/main.c:197 ../raster/r.out.tiff/r.out.tiff.c:173
+#: ../raster/r.in.ascii/main.c:197 ../raster/r.out.tiff/r.out.tiff.c:157
#: ../raster/r.in.arc/main.c:131
msgid "Can't set window"
msgstr "No se puede establecer la ventana"
@@ -5292,7 +5248,7 @@
msgstr "Utilice -M o -s, no ambas"
#: ../raster/r.out.ascii/main.c:173 ../raster/r.profile/main.c:157
-#: ../raster/r.out.arc/main.c:133 ../raster/r.out.ppm3/main.c:147
+#: ../raster/r.out.arc/main.c:133 ../raster/r.out.ppm3/main.c:133
#: ../raster/r.cats/main.c:170 ../vector/v.out.ascii/out.c:137
#: ../vector/v.out.vtk/main.c:163 ../display/d.nviz/main.c:202
#: ../general/g.pnmcomp/main.c:262 ../general/g.pnmcomp/main.c:280
@@ -5310,8 +5266,8 @@
msgid "Read failed at row %d"
msgstr "La lectura falló en la fila %d"
-#: ../raster/r.carve/raster.c:12 ../raster/r.texture/main.c:258
-#: ../raster/r.out.tiff/r.out.tiff.c:286 ../imagery/i.zc/main.c:168
+#: ../raster/r.carve/raster.c:12 ../raster/r.texture/main.c:246
+#: ../raster/r.out.tiff/r.out.tiff.c:270 ../imagery/i.zc/main.c:168
msgid "Reading raster map..."
msgstr "Leyendo mapa ráster..."
@@ -5325,7 +5281,7 @@
"intentando dividir por cero...no hay una solución única para el sistema..."
"saltando..."
-#: ../raster/r.carve/main.c:77
+#: ../raster/r.carve/main.c:73
msgid ""
"Takes vector stream data, transforms it to raster and subtracts depth from "
"the output DEM."
@@ -5333,42 +5289,42 @@
"Toma datos de corriente vectorial, los transforma a ráster y resta la "
"profundidad del MDT de salida."
-#: ../raster/r.carve/main.c:82
+#: ../raster/r.carve/main.c:78
msgid "Name of input raster elevation map"
msgstr "Nombre de mapa ráster de entrada de elevación"
-#: ../raster/r.carve/main.c:86
+#: ../raster/r.carve/main.c:82
msgid "Name of vector input map containing stream(s)"
msgstr "Nombre del vectorial de entrada que contiene corriente(s)"
-#: ../raster/r.carve/main.c:93
+#: ../raster/r.carve/main.c:89
msgid "Name for output vector map for adjusted stream points"
msgstr "Nombre del mapa vectorial de salida para puntos de corriente ajustados"
-#: ../raster/r.carve/main.c:98
+#: ../raster/r.carve/main.c:94
msgid "Stream width (in meters). Default is raster cell width"
msgstr ""
"Anchura de corriente (en metros). Por defecto es la anchura de celda ráster."
-#: ../raster/r.carve/main.c:104
+#: ../raster/r.carve/main.c:100
msgid "Additional stream depth (in meters)"
msgstr "Profundidad de corriente adicional (en metros)"
-#: ../raster/r.carve/main.c:108
+#: ../raster/r.carve/main.c:104
msgid "No flat areas allowed in flow direction"
msgstr "No se admiten áreas llanas en la dirección de flujo"
-#: ../raster/r.carve/main.c:145
+#: ../raster/r.carve/main.c:128
#, c-format
msgid "Invalid width value '%s' - using default."
msgstr "Valor de anchura '%s' no válido - se usa el predeterminado."
-#: ../raster/r.carve/main.c:158
+#: ../raster/r.carve/main.c:141
#, c-format
msgid "Invalid depth value '%s' - using default."
msgstr "Valor de profundidad '%s' no válido - se usa el predeterminado."
-#: ../raster/r.carve/main.c:223
+#: ../raster/r.carve/main.c:206
msgid "lat/lon projection not supported at this time."
msgstr "Proyección latitud/longitud no soportada en este momento."
@@ -5523,84 +5479,84 @@
msgid "The distance between two samples (>= 1)"
msgstr "La distancia entre dos muestras (>= 1)"
-#: ../raster/r.texture/main.c:119
+#: ../raster/r.texture/main.c:115
msgid "Angular Second Moment"
msgstr "Momento segundo angular"
-#: ../raster/r.texture/main.c:120 ../raster/r.texture/main.c:125
-#: ../raster/r.texture/main.c:130 ../raster/r.texture/main.c:135
-#: ../raster/r.texture/main.c:140 ../raster/r.texture/main.c:145
-#: ../raster/r.texture/main.c:150 ../raster/r.texture/main.c:155
-#: ../raster/r.texture/main.c:160 ../raster/r.texture/main.c:165
-#: ../raster/r.texture/main.c:170 ../raster/r.texture/main.c:175
-#: ../raster/r.texture/main.c:180 ../raster/r.texture/main.c:185
+#: ../raster/r.texture/main.c:116 ../raster/r.texture/main.c:121
+#: ../raster/r.texture/main.c:126 ../raster/r.texture/main.c:131
+#: ../raster/r.texture/main.c:136 ../raster/r.texture/main.c:141
+#: ../raster/r.texture/main.c:146 ../raster/r.texture/main.c:151
+#: ../raster/r.texture/main.c:156 ../raster/r.texture/main.c:161
+#: ../raster/r.texture/main.c:166 ../raster/r.texture/main.c:171
+#: ../raster/r.texture/main.c:176 ../raster/r.texture/main.c:181
msgid "Features"
msgstr "Elementos"
-#: ../raster/r.texture/main.c:124
+#: ../raster/r.texture/main.c:120
msgid "Contrast"
msgstr "Contraste"
-#: ../raster/r.texture/main.c:129
+#: ../raster/r.texture/main.c:125
msgid "Correlation"
msgstr "Correlación"
-#: ../raster/r.texture/main.c:134
+#: ../raster/r.texture/main.c:130
msgid "Variance"
msgstr "Varianza"
-#: ../raster/r.texture/main.c:139
+#: ../raster/r.texture/main.c:135
msgid "Inverse Diff Moment"
msgstr "Momento diferencial inverso"
-#: ../raster/r.texture/main.c:144
+#: ../raster/r.texture/main.c:140
msgid "Sum Average"
msgstr "Media de la suma"
-#: ../raster/r.texture/main.c:149
+#: ../raster/r.texture/main.c:145
msgid "Sum Variance"
msgstr "Varianza de la suma"
-#: ../raster/r.texture/main.c:154
+#: ../raster/r.texture/main.c:150
msgid "Sum Entropy"
msgstr "Entropía de la suma"
-#: ../raster/r.texture/main.c:159
+#: ../raster/r.texture/main.c:155
msgid "Entropy"
msgstr "Entropía"
-#: ../raster/r.texture/main.c:164
+#: ../raster/r.texture/main.c:160
msgid "Difference Variance"
msgstr "Varianza de la diferencia"
-#: ../raster/r.texture/main.c:169
+#: ../raster/r.texture/main.c:165
msgid "Difference Entropy"
msgstr "Entropía de la diferencia"
-#: ../raster/r.texture/main.c:174
+#: ../raster/r.texture/main.c:170
msgid "Measure of Correlation-1"
msgstr "Medida de la correlación-1"
-#: ../raster/r.texture/main.c:179
+#: ../raster/r.texture/main.c:175
msgid "Measure of Correlation-2"
msgstr "Medida de la correlación-2"
-#: ../raster/r.texture/main.c:184
+#: ../raster/r.texture/main.c:180
msgid "Max Correlation Coeff"
msgstr "Coeficiente de correlación máximo"
-#: ../raster/r.texture/main.c:212
+#: ../raster/r.texture/main.c:207
msgid "Nothing to compute. Use at least one of the flags."
msgstr "Nada que procesar. Use al menos una de las opciones."
-#: ../raster/r.texture/main.c:236 ../raster/r.out.tiff/r.out.tiff.c:170
+#: ../raster/r.texture/main.c:224 ../raster/r.out.tiff/r.out.tiff.c:154
#: ../raster/r.bitpattern/main.c:114 ../imagery/i.rectify/main.c:173
#: ../imagery/i.rectify/main.c:177
#, c-format
msgid "Unable to read header of raster map <%s>"
msgstr "No se puede leer la cabecera del mapa ráster <%s>"
-#: ../raster/r.texture/main.c:361
+#: ../raster/r.texture/main.c:349
#, c-format
msgid "Calculated measure #%d (56 measures available)"
msgstr "Medida #%d calculada (56 medidas disponibles)"
@@ -5623,7 +5579,7 @@
"Demasiadas categorías (encontradas: %i, máximo: %i). Intente rescalar o "
"reclasificar el mapa"
-#: ../raster/r.texture/h_measure.c:675 ../raster/r.cost/main.c:597
+#: ../raster/r.texture/h_measure.c:675 ../raster/r.cost/main.c:579
#: ../imagery/i.smap/bouman/interp.c:71
msgid "Unable to allocate memory"
msgstr "No se puede asignar memoria"
@@ -5666,8 +5622,8 @@
msgid "Reverse sweep complete"
msgstr "Barrido hacia atrás completo"
-#: ../raster/r.basins.fill/main.c:162 ../raster/r.cross/main.c:188
-#: ../raster/r.resample/main.c:153 ../imagery/i.smap/shapiro/closefiles.c:14
+#: ../raster/r.basins.fill/main.c:162 ../raster/r.cross/main.c:171
+#: ../raster/r.resample/main.c:139 ../imagery/i.smap/shapiro/closefiles.c:14
#, c-format
msgid "Creating support files for <%s>..."
msgstr "Creando archivos de soporte para %s..."
@@ -5680,8 +5636,8 @@
msgid "Name of incidence or density file."
msgstr "Nombre del archivo de incidencia o de densidad."
-#: ../raster/r.sum/main.c:77 ../raster/r.walk/main.c:685
-#: ../raster/r.walk/main.c:746 ../raster/wildfire/r.spread/main.c:537
+#: ../raster/r.sum/main.c:77 ../raster/r.walk/main.c:680
+#: ../raster/r.walk/main.c:741 ../raster/wildfire/r.spread/main.c:537
#, c-format
msgid "Reading %s..."
msgstr "Leyendo %s..."
@@ -6354,8 +6310,8 @@
#: ../raster/r.out.gdal/main.c:380 ../raster/r.in.gdal/main.c:132
#: ../vector/v.to.db/parse.c:90 ../vector/v.to.db/parse.c:95
-#: ../vector/v.to.db/parse.c:100 ../imagery/i.group/main.c:74
-#: ../imagery/i.group/main.c:79 ../general/g.region/main.c:99
+#: ../vector/v.to.db/parse.c:100 ../imagery/i.group/main.c:75
+#: ../imagery/i.group/main.c:80 ../general/g.region/main.c:99
#: ../general/g.region/main.c:105 ../general/g.region/main.c:110
#: ../general/g.region/main.c:115 ../general/g.region/main.c:120
#: ../general/g.region/main.c:125 ../general/g.region/main.c:130
@@ -6486,9 +6442,9 @@
#: ../raster/r.in.bin/main.c:167 ../raster/r.in.bin/main.c:220
#: ../raster/r.resamp.rst/main.c:234 ../raster/r.resamp.rst/main.c:242
#: ../raster/r.resamp.rst/main.c:250 ../raster/r.resamp.rst/main.c:258
-#: ../raster/r.resamp.rst/main.c:266 ../raster/r.slope.aspect/main.c:188
-#: ../raster/r.slope.aspect/main.c:197 ../raster/r.slope.aspect/main.c:268
-#: ../raster/r.slope.aspect/main.c:276 ../raster/r.slope.aspect/main.c:286
+#: ../raster/r.resamp.rst/main.c:266 ../raster/r.slope.aspect/main.c:181
+#: ../raster/r.slope.aspect/main.c:190 ../raster/r.slope.aspect/main.c:261
+#: ../raster/r.slope.aspect/main.c:269 ../raster/r.slope.aspect/main.c:274
#: ../vector/lidar/v.lidar.edgedetection/main.c:87
#: ../vector/lidar/v.lidar.edgedetection/main.c:95
#: ../vector/lidar/v.lidar.edgedetection/main.c:103
@@ -6686,7 +6642,7 @@
msgid "Cannot get row"
msgstr "No se puede obtener la fila"
-#: ../raster/r.surf.idw2/read_cell.c:40 ../raster/r.series/main.c:172
+#: ../raster/r.surf.idw2/read_cell.c:40 ../raster/r.series/main.c:158
#, c-format
msgid "Reading raster map <%s>..."
msgstr "Leyendo el mapa ráster <%s>..."
@@ -7102,101 +7058,89 @@
msgid "You are not outputting any raster or vector points maps"
msgstr "No está produciendo ningún mapa ráster o vectorial de puntos"
-#: ../raster/r.out.mat/main.c:63
+#: ../raster/r.out.mat/main.c:61
msgid "Exports a GRASS raster to a binary MAT-File."
msgstr "Exporta un ráster de GRASS a un archivo MAT binario."
-#: ../raster/r.out.mat/main.c:74
+#: ../raster/r.out.mat/main.c:72
msgid "Name for the output binary MAT-File"
msgstr "Nombre para el archivo MAT binario de salida"
-#: ../raster/r.out.mat/main.c:106 ../raster/r.out.pov/main.c:183
+#: ../raster/r.out.mat/main.c:97 ../raster/r.out.pov/main.c:183
#, c-format
msgid "Unable to open output file <%s>"
msgstr "No se puede abrir el archivo de salida <%s>"
-#: ../raster/r.out.mat/main.c:128
+#: ../raster/r.out.mat/main.c:119
#, c-format
msgid "Exporting <%s>"
msgstr "Exportando <%s>"
-#: ../raster/r.out.mat/main.c:189 ../raster/r.cost/main.c:225
-#: ../raster/r.in.mat/main.c:378 ../raster/r.out.tiff/r.out.tiff.c:145
-#: ../raster/wildfire/r.ros/main.c:304 ../raster/wildfire/r.spread/main.c:248
-#: ../vector/v.kernel/main.c:171 ../display/d.vect/main.c:366
-#: ../display/d.mon/pgms/release.c:37
-msgid ""
-"The '-v' flag is superseded and will be removed in future. Please use '--"
-"verbose' instead."
-msgstr ""
-"La opción '-v' está suplantado y se eliminará en el futuro. Por favor use '--"
-"verbose' en su lugar."
-#: ../raster/r.out.mat/main.c:195
+#: ../raster/r.out.mat/main.c:178
msgid "Using the Current Region settings:"
msgstr "Usando la configuración de la región actual:"
-#: ../raster/r.out.mat/main.c:196
+#: ../raster/r.out.mat/main.c:179 ../raster/r.in.mat/main.c:382
#, c-format
msgid "northern edge=%f"
msgstr "borde Norte=%f"
-#: ../raster/r.out.mat/main.c:197
+#: ../raster/r.out.mat/main.c:180 ../raster/r.in.mat/main.c:383
#, c-format
msgid "southern edge=%f"
msgstr "borde Sur=%f"
-#: ../raster/r.out.mat/main.c:198
+#: ../raster/r.out.mat/main.c:181 ../raster/r.in.mat/main.c:384
#, c-format
msgid "eastern edge=%f"
msgstr "borde Este=%f"
-#: ../raster/r.out.mat/main.c:199
+#: ../raster/r.out.mat/main.c:182 ../raster/r.in.mat/main.c:385
#, c-format
msgid "western edge=%f"
msgstr "borde Oeste=%f"
-#: ../raster/r.out.mat/main.c:200
+#: ../raster/r.out.mat/main.c:183 ../raster/r.in.mat/main.c:386
#, c-format
msgid "nsres=%f"
msgstr "resolución N-S=%f"
-#: ../raster/r.out.mat/main.c:201
+#: ../raster/r.out.mat/main.c:184 ../raster/r.in.mat/main.c:387
#, c-format
msgid "ewres=%f"
msgstr "resolución E-W=%f"
-#: ../raster/r.out.mat/main.c:202
+#: ../raster/r.out.mat/main.c:185 ../raster/r.in.mat/main.c:388
#, c-format
msgid "rows=%d"
msgstr "filas=%d"
-#: ../raster/r.out.mat/main.c:203
+#: ../raster/r.out.mat/main.c:186 ../raster/r.in.mat/main.c:389
#, c-format
msgid "cols=%d"
msgstr "columnas=%d"
-#: ../raster/r.out.mat/main.c:269
+#: ../raster/r.out.mat/main.c:253
msgid "Exporting raster as integer values"
msgstr "Exportando ráster como valores enteros"
-#: ../raster/r.out.mat/main.c:274
+#: ../raster/r.out.mat/main.c:258
msgid "Exporting raster as floating point values"
msgstr "Exportando ráster como valores de coma flotante"
-#: ../raster/r.out.mat/main.c:279
+#: ../raster/r.out.mat/main.c:263
msgid "Exporting raster as double FP values"
msgstr "Exportando ráster como valores de coma flotante doble"
-#: ../raster/r.out.mat/main.c:319
+#: ../raster/r.out.mat/main.c:303
msgid "Reading in map ... "
msgstr "Leyendo en mapa ... "
-#: ../raster/r.out.mat/main.c:331
+#: ../raster/r.out.mat/main.c:315
msgid "Writing out map..."
msgstr "Escribiendo mapa..."
-#: ../raster/r.out.mat/main.c:385
+#: ../raster/r.out.mat/main.c:369
#, c-format
msgid "%ld bytes written to '%s'"
msgstr "%ld bytes escritos a '%s'"
@@ -7371,68 +7315,68 @@
msgid "Unable to read range file"
msgstr "No se puede leer el archivo de intervalo"
-#: ../raster/r.compress/main.c:65
+#: ../raster/r.compress/main.c:62
msgid "Compresses and decompresses raster maps."
msgstr "Comprime y descomprime mapas ráster."
-#: ../raster/r.compress/main.c:73 ../display/d.what.rast/main.c:75
+#: ../raster/r.compress/main.c:70 ../display/d.what.rast/main.c:75
msgid "Name of existing raster map(s)"
msgstr "Nombre de mapa(s) ráster existentes"
-#: ../raster/r.compress/main.c:77
+#: ../raster/r.compress/main.c:74
msgid "Uncompress the map"
msgstr "Descomprimir el mapa"
-#: ../raster/r.compress/main.c:119
+#: ../raster/r.compress/main.c:104
#, c-format
msgid "[%s] not found"
msgstr "[%s] no encontrado"
-#: ../raster/r.compress/main.c:125
+#: ../raster/r.compress/main.c:110
#, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
msgstr ""
"[%s] es un archivo de reclasificación del mapa <%s> en el directorio <%s> - "
"no se puede descomprimir"
-#: ../raster/r.compress/main.c:126
+#: ../raster/r.compress/main.c:111
#, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
msgstr ""
"no se puede comprimir"
-#: ../raster/r.compress/main.c:171
+#: ../raster/r.compress/main.c:156
#, c-format
msgid "DONE: uncompressed file is %lu bytes smaller"
msgstr "HECHO: el archivo descomprimido es %lu bytes más pequeño"
-#: ../raster/r.compress/main.c:172
+#: ../raster/r.compress/main.c:157
#, c-format
msgid "DONE: compressed file is %lu bytes smaller"
msgstr "HECHO: el archivo comprimido es %lu bytes más pequeño"
-#: ../raster/r.compress/main.c:176
+#: ../raster/r.compress/main.c:161
#, c-format
msgid "DONE: uncompressed file is %lu bytes bigger"
msgstr "HECHO: el archivo descomprimido es %lu bytes mayor"
-#: ../raster/r.compress/main.c:177
+#: ../raster/r.compress/main.c:162
#, c-format
msgid "DONE: compressed file is %lu bytes bigger"
msgstr "HECHO: el archivo comprimido es %lu bytes mayor"
-#: ../raster/r.compress/main.c:202
+#: ../raster/r.compress/main.c:187
#, c-format
msgid "[%s] already uncompressed"
msgstr "[%s] ya está descomprimido"
-#: ../raster/r.compress/main.c:207
+#: ../raster/r.compress/main.c:192
#, c-format
msgid "[%s] already compressed"
msgstr "[%s] ya está comprimido"
-#: ../raster/r.compress/main.c:211
+#: ../raster/r.compress/main.c:196
#, c-format
msgid ""
"\n"
@@ -7441,7 +7385,7 @@
"\n"
"%sCOMPRIMIR [%s]"
-#: ../raster/r.patch/main.c:55
+#: ../raster/r.patch/main.c:54
msgid ""
"Creates a composite raster map layer by using known category values from one "
"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
@@ -7450,31 +7394,32 @@
"de una (o más) capa(s) de mapa para rellenar áreas \"sin datos\" en otra "
"capa de mapa."
-#: ../raster/r.patch/main.c:62
+#: ../raster/r.patch/main.c:61
msgid "Name of raster maps to be patched together"
msgstr "Nombre de los mapas ráster a parchear juntos"
-#: ../raster/r.patch/main.c:65
+#: ../raster/r.patch/main.c:64
msgid "Name for resultant raster map"
msgstr "Nombre para el mapa ráster resultante"
-#: ../raster/r.patch/main.c:76
+#: ../raster/r.patch/main.c:70
msgid "Use zero (0) for transparency instead of NULL"
msgstr "Usar cero (0) para transparencia en vez de NULO"
-#: ../raster/r.patch/main.c:102
+#: ../raster/r.patch/main.c:88
msgid "The minimum number of input raster maps is two"
msgstr "El número mínimo de mapas ráster de entrada es dos"
-#: ../raster/r.patch/main.c:142
+#: ../raster/r.patch/main.c:128
msgid "One or more input raster maps not found"
msgstr "No se encuentran uno o más mapas de entrada"
-#: ../raster/r.patch/main.c:155 ../raster/r.series/main.c:196
+#: ../raster/r.patch/main.c:141 ../raster/r.slope.aspect/main.c:582
+#: ../raster/r.series/main.c:182
msgid "Percent complete..."
msgstr "Porcentaje completo..."
-#: ../raster/r.patch/main.c:185
+#: ../raster/r.patch/main.c:171
#, c-format
msgid "Creating support files for raster map <%s>"
msgstr "Creando archivos de soporte para el mapa ráster <%s>"
@@ -7618,6 +7563,14 @@
msgid "Value to write for \"grown\" cells"
msgstr "Valor a escribir para celdas \"incrementadas\""
+#: ../raster/r.grow2/main.c:165 ../raster/r.report/parse.c:90
+#: ../raster/r.bitpattern/main.c:87 ../vector/v.perturb/main.c:116
+#: ../vector/v.kcv/main.c:104 ../doc/raster/r.example/main.c:95
+#: ../imagery/i.cluster/main.c:135
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
+msgid "Quiet"
+msgstr "Silencioso"
#: ../raster/r.grow2/main.c:197
#, c-format
msgid "Unknown metric: [%s]."
@@ -8258,9 +8211,9 @@
#: ../vector/lidar/v.outlier/main.c:149 ../vector/lidar/v.outlier/main.c:153
#: ../vector/lidar/v.outlier/main.c:159
#: ../vector/lidar/v.surf.bspline/main.c:260 ../vector/v.generalize/main.c:312
-#: ../vector/v.mkgrid/main.c:196 ../vector/v.net.path/main.c:134
-#: ../vector/v.voronoi/dt_main.c:82 ../vector/v.voronoi/vo_main.c:152
-#: ../doc/vector/v.example/main.c:70
+#: ../vector/v.mkgrid/main.c:181 ../vector/v.net.path/main.c:134
+#: ../vector/v.voronoi/dt_main.c:92 ../vector/v.voronoi/dt_main.c:96
+#: ../vector/v.voronoi/vo_main.c:152 ../doc/vector/v.example/main.c:70
#, c-format
msgid "Unable to create vector map <%s>"
msgstr "No se puede crear el mapa vectorial <%s>"
@@ -8360,7 +8313,7 @@
msgid "Negative elevation values in input"
msgstr "Valores de elevación negativos en entrada"
-#: ../raster/r.covar/main.c:54
+#: ../raster/r.covar/main.c:51
msgid ""
"Outputs a covariance/correlation matrix for user-specified raster map layer"
"(s)."
@@ -8368,16 +8321,16 @@
"Produce una matriz de covarianza/correlación para la capa(s) de mapa ráster "
"especificada por el usuario."
-#: ../raster/r.covar/main.c:61
+#: ../raster/r.covar/main.c:58
msgid "Print correlation matrix"
msgstr "Imprimir matriz de correlación"
-#: ../raster/r.covar/main.c:105
+#: ../raster/r.covar/main.c:90
#, c-format
msgid "%s: complete ... "
msgstr "%s: completo ... "
-#: ../raster/r.covar/main.c:133
+#: ../raster/r.covar/main.c:118
msgid "No non-null values"
msgstr "Ningún valor no nulo"
@@ -8666,72 +8619,83 @@
msgid "Selected band (%d) does not exist"
msgstr "La banda seleccionada (%d) no existe"
-#: ../raster/r.in.gdal/main.c:515
+#: ../raster/r.in.gdal/main.c:516
#, c-format
msgid "Copying %d GCPS in points file for <%s>"
msgstr "Copiando %d GCP en archivo de puntos para <%s>"
-#: ../raster/r.in.gdal/main.c:520
+#: ../raster/r.in.gdal/main.c:521
msgid "GCPs have the following OpenGIS WKT Coordinate System:"
msgstr "Los GCP tiene el siguiente sistema de coordenadas WKT de OpenGIS"
-#: ../raster/r.in.gdal/main.c:529
+#: ../raster/r.in.gdal/main.c:530
msgid "Re-projecting GCPs table:"
msgstr "Reproyectado la tabla de los GCP:"
-#: ../raster/r.in.gdal/main.c:530
+#: ../raster/r.in.gdal/main.c:531
#, c-format
msgid "* Input projection for GCP table: %s"
msgstr "* Proyección de entrada para la tabla de GCP: %s"
-#: ../raster/r.in.gdal/main.c:532
+#: ../raster/r.in.gdal/main.c:533
#, c-format
msgid "* Output projection for GCP table: %s"
msgstr "* Proyección de salida para la tabla de GCP: %s"
-#: ../raster/r.in.gdal/main.c:551
+#: ../raster/r.in.gdal/main.c:552
#, c-format
msgid "Error in pj_do_proj (can't re-projection GCP %i)"
msgstr "Error en pj_do_proj (no se puede reproyectar GCP %i)"
-#: ../raster/r.in.gdal/main.c:615
+#: ../raster/r.in.gdal/main.c:616
msgid "Unable to translate projection key values of input GCPs"
msgstr ""
"No se pueden traducir los valores clave de la proyección de los GCP de "
"entrada"
-#: ../raster/r.in.gdal/main.c:631
+#: ../raster/r.in.gdal/main.c:632
msgid "Unable to get projection info of target location"
msgstr ""
"No se puede obtener información de la proyección de la localización de "
"destino"
-#: ../raster/r.in.gdal/main.c:633
+#: ../raster/r.in.gdal/main.c:634
msgid "Unable to get projection units of target location"
msgstr ""
"No se pueden obtener las unidades de la proyección de la localización de "
"destino"
-#: ../raster/r.in.gdal/main.c:635
+#: ../raster/r.in.gdal/main.c:636
msgid "Unable to get projection key values of target location"
msgstr ""
"No se pueden obtener los valores clave de la proyección de la localización "
"de destino"
-#: ../raster/r.in.gdal/main.c:639
+#: ../raster/r.in.gdal/main.c:640
#, c-format
msgid "Mapset <%s> in target location <%s> - "
msgstr "Directorio de mapas <%s> en la localización de destino <%s> - "
-#: ../raster/r.rescale/main.c:50
+#: ../raster/r.in.gdal/main.c:940
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (8bit, full range)"
+msgstr "Creando tabla de colores para <%s en %s>..."
+#: ../raster/r.in.gdal/main.c:953
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (16bit, image range)"
+#: ../raster/r.in.gdal/main.c:963
+#, fuzzy, c-format
+msgid "<%s> created"
+msgstr "Archivo %s creado"
+#: ../raster/r.rescale/main.c:45
msgid "Rescales the range of category values in a raster map layer."
msgstr "Rescala el rango de valores de categoría en una capa de mapa ráster."
-#: ../raster/r.rescale/main.c:93
-msgid "Quietly"
-msgstr "De forma silenciosa"
-#: ../raster/r.rescale/main.c:144
+#: ../raster/r.rescale/main.c:127
#, c-format
msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
msgstr "Rescala %s[%ld,%ld] a %s[%ld,%ld]"
@@ -9200,8 +9164,8 @@
msgstr "Respetar valores NULOS mientras se dibuja"
#: ../raster/r.his/main.c:143 ../raster/r.his/main.c:165
-#: ../raster/r.his/main.c:193 ../raster/r.out.ppm3/main.c:128
-#: ../raster/r.composite/main.c:174 ../display/d.rast.edit/cell.c:51
+#: ../raster/r.his/main.c:193 ../raster/r.out.ppm3/main.c:114
+#: ../raster/r.composite/main.c:170 ../display/d.rast.edit/cell.c:51
#: ../display/d.histogram/main.c:160 ../display/d.rast.num/number.c:281
#: ../display/d.legend/main.c:255 ../display/d.rast/display.c:22
#: ../display/d.rgb/main.c:110 ../display/d.his/main.c:152
@@ -9348,24 +9312,15 @@
msgid "132 columns (default: 80)"
msgstr "132 columnas (por omisión: 80)"
-#: ../raster/r.kappa/main.c:86
+#: ../raster/r.kappa/main.c:81
msgid "No header in the report"
msgstr "Ningún encabezamiento en el informe"
-#: ../raster/r.kappa/main.c:101 ../imagery/i.cca/main.c:116
+#: ../raster/r.kappa/main.c:96 ../imagery/i.cca/main.c:116
#, c-format
msgid "Illegal output file name <%s>"
msgstr "Nombre de archivo de salida <%s> no admitido"
-#: ../raster/r.kappa/main.c:113 ../raster/r.out.ppm/main.c:80
-#: ../raster/r.mfilter.fp/main.c:107 ../raster/r.mfilter/main.c:100
-msgid ""
-"quiet' instead"
-msgstr ""
-"La opción '-q' está suplantada y se eliminará en el futuro. Por favor, use "
-"'--quiet' en su lugar"
#: ../raster/r.kappa/prt_mat.c:39
#, c-format
msgid "Cannot open file <%s> to write cats and counts (error matrix)"
@@ -9589,9 +9544,8 @@
msgid "Cannot set region to back to the initial region !!!"
msgstr "¡No se puede establecer la región para volver a la región inicial!"
-#: ../raster/r.resamp.rst/main.c:528 ../raster/r.slope.aspect/main.c:609
-#: ../raster/r.resample/main.c:137 ../vector/v.surf.rst/main.c:566
-#: ../vector/v.surf.rst/main.c:712
+#: ../raster/r.resamp.rst/main.c:528 ../raster/r.resample/main.c:123
+#: ../vector/v.surf.rst/main.c:566 ../vector/v.surf.rst/main.c:712
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:609
msgid "Percent complete: "
msgstr "Porcentaje completado: "
@@ -9676,7 +9630,7 @@
msgid "nsteps must be greater than zero; using nsteps=255"
msgstr "nsteps debe ser mayor que cero; se usa nsteps=255"
-#: ../raster/r.stats/main.c:253 ../raster/r.series/main.c:160
+#: ../raster/r.stats/main.c:253 ../raster/r.series/main.c:146
msgid "Raster map not found"
msgstr "Mapa ráster no encontrado"
@@ -9791,8 +9745,8 @@
msgid "Filter range for z data (min,max)"
msgstr "Rango de filtrado para los datos Z (mínimo, máximo)"
-#: ../raster/r.in.xyz/main.c:220 ../raster/r.cost/main.c:198
-#: ../raster/r.walk/main.c:258
+#: ../raster/r.in.xyz/main.c:220 ../raster/r.cost/main.c:195
+#: ../raster/r.walk/main.c:255
msgid "Percent of map to keep in memory"
msgstr "Porcentaje de mapa a mantener en memoria"
@@ -9834,7 +9788,7 @@
msgid "Unable to calculate trimmed mean without the trim option specified!"
msgstr ""
-#: ../raster/r.in.xyz/main.c:441 ../raster/r.in.mat/main.c:138
+#: ../raster/r.in.xyz/main.c:441 ../raster/r.in.mat/main.c:125
#: ../raster/r.in.arc/main.c:123 ../vector/v.segment/main.c:89
#: ../vector/v.net.path/path.c:46 ../vector/v.lrs/v.lrs.segment/main.c:129
#: ../display/d.linegraph/linegraph.c:194
@@ -9912,7 +9866,12 @@
msgid "Range: min max\n"
msgstr "Rango: mínimo máximo\n"
-#: ../raster/r.slope.aspect/main.c:154
+#: ../raster/r.slope.aspect/main.c:150
+#, fuzzy
+msgid "raster, terrain analysis"
+msgstr "ráster, análisis de estructura del paisaje"
+#: ../raster/r.slope.aspect/main.c:152
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:154
msgid ""
"Generates raster map layers of slope, aspect, curvatures and partial "
@@ -9923,40 +9882,35 @@
"derivadas parciales a partir de una capa de mapa ráster de valores reales de "
"elevación. La orientación se calcula en sentido horario desde el Este."
-#: ../raster/r.slope.aspect/main.c:163
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:163
-msgid "Raster elevation file name"
-msgstr "Nombre del archivo de elevación ráster"
+#: ../raster/r.slope.aspect/main.c:164
+#, fuzzy
+msgid "Name for output slope raster map"
+msgstr "Nombre para el mapa ráster de salida"
-#: ../raster/r.slope.aspect/main.c:171
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:171
-msgid "Output slope filename"
-msgstr "Nombre de archivo de pendiente de salida"
+#: ../raster/r.slope.aspect/main.c:172
+#, fuzzy
+msgid "Name for output aspect raster map"
-#: ../raster/r.slope.aspect/main.c:179
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:179
-msgid "Output aspect filename"
-msgstr "Nombre de archivo de orientación de salida"
-#: ../raster/r.slope.aspect/main.c:187
+#: ../raster/r.slope.aspect/main.c:180
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:187
msgid "Format for reporting the slope"
msgstr "Formato para informar la pendiente"
-#: ../raster/r.slope.aspect/main.c:196
+#: ../raster/r.slope.aspect/main.c:189
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:196
msgid "Type of output aspect and slope maps"
msgstr "Tipo de mapas de orientación y pendiente"
-#: ../raster/r.slope.aspect/main.c:205
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:205
-msgid "Output profile curvature filename"
-msgstr "Nombre de archivo de curvatura de perfil de salida"
+#: ../raster/r.slope.aspect/main.c:198
+#, fuzzy
+msgid "Name for output profile curvature raster map"
+msgstr "Producir mapa ráster de curvatura de perfil"
-#: ../raster/r.slope.aspect/main.c:206 ../raster/r.slope.aspect/main.c:215
-#: ../raster/r.slope.aspect/main.c:224 ../raster/r.slope.aspect/main.c:233
-#: ../raster/r.slope.aspect/main.c:242 ../raster/r.slope.aspect/main.c:251
-#: ../raster/r.slope.aspect/main.c:260 ../vector/v.buffer/main.c:269
+#: ../raster/r.slope.aspect/main.c:199 ../raster/r.slope.aspect/main.c:208
+#: ../raster/r.slope.aspect/main.c:217 ../raster/r.slope.aspect/main.c:226
+#: ../raster/r.slope.aspect/main.c:235 ../raster/r.slope.aspect/main.c:244
+#: ../raster/r.slope.aspect/main.c:253 ../vector/v.buffer/main.c:269
#: ../vector/v.buffer/main.c:277 ../vector/v.buffer/main.c:284
#: ../vector/v.buffer/main.c:294 ../display/d.legend/main.c:107
#: ../display/d.legend/main.c:116 ../display/d.legend/main.c:124
@@ -9974,146 +9928,148 @@
msgid "Advanced"
msgstr "Avanzado"
-#: ../raster/r.slope.aspect/main.c:214
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:214
-msgid "Output tangential curvature filename"
-msgstr "Nombre de archivo de curvatura tangencial de salida"
+#: ../raster/r.slope.aspect/main.c:207
+#, fuzzy
+msgid "Name for output tangential curvature raster map"
+msgstr "Producir mapa ráster de curvatura tangencial"
-#: ../raster/r.slope.aspect/main.c:223
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:223
-msgid "Output first order partial derivative dx (E-W slope) filename"
+#: ../raster/r.slope.aspect/main.c:216
+#, fuzzy
+msgid ""
+"Name for output first order partial derivative dx (E-W slope) raster map"
msgstr ""
"Nombre de archivo de derivada dx (pendiente E-W) parcial de primer orden de "
"salida"
-#: ../raster/r.slope.aspect/main.c:232
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:232
-msgid "Output first order partial derivative dy (N-S slope) filename"
+#: ../raster/r.slope.aspect/main.c:225
+#, fuzzy
+msgid ""
+"Name for output first order partial derivative dy (N-S slope) raster map"
msgstr ""
"Nombre de archivo de derivada dy (pendiente N-S) parcial de primer orden de "
"salida"
-#: ../raster/r.slope.aspect/main.c:241
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:241
-msgid "Output second order partial derivative dxx filename"
+#: ../raster/r.slope.aspect/main.c:234
+#, fuzzy
+msgid "Name for output second order partial derivative dxx raster map"
msgstr "Nombre de archivo de derivada dxx parcial de segundo orden de salida"
-#: ../raster/r.slope.aspect/main.c:250
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:250
-msgid "Output second order partial derivative dyy filename"
+#: ../raster/r.slope.aspect/main.c:243
+#, fuzzy
+msgid "Name for output second order partial derivative dyy raster map"
msgstr "Nombre de archivo de derivada dyy parcial de segundo orden de salida"
-#: ../raster/r.slope.aspect/main.c:259
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:259
-msgid "Output second order partial derivative dxy filename"
+#: ../raster/r.slope.aspect/main.c:252
+#, fuzzy
+msgid "Name for output second order partial derivative dxy raster map"
msgstr "Nombre de archivo de derivada dxy parcial de segundo orden de salida"
-#: ../raster/r.slope.aspect/main.c:264
+#: ../raster/r.slope.aspect/main.c:257
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:264
msgid "Multiplicative factor to convert elevation units to meters"
msgstr "Factor de multiplicación para convertir unidades de elevación a metros"
-#: ../raster/r.slope.aspect/main.c:272
+#: ../raster/r.slope.aspect/main.c:265
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
msgid "Minimum slope val. (in percent) for which aspect is computed"
msgstr ""
"Valor de pendiente mínimo (en porcentaje) para el que se procesa la "
"orientación"
-#: ../raster/r.slope.aspect/main.c:285
+#: ../raster/r.slope.aspect/main.c:273
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
msgid "Do not align the current region to the elevation layer"
msgstr "No alinear la región actual con la capa de elevación"
-#: ../raster/r.slope.aspect/main.c:405
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:405
+#: ../raster/r.slope.aspect/main.c:327
+#, fuzzy, c-format
+msgid "%s=%s - must be a positive number"
+msgstr "%s = %s -- debe ser mayor que cero"
+#: ../raster/r.slope.aspect/main.c:333
+#, fuzzy, c-format
+msgid "%s=%s - must be a non-negative number"
+#: ../raster/r.slope.aspect/main.c:346
#, c-format
-msgid "wrong type: %s"
+msgid ""
+"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%"
+"s>, <%s>, <%s>, <%s> or <%s>"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:378
+#, fuzzy, c-format
+msgid "Wrong raster type: %s"
msgstr "tipo incorrecto: %s"
-#: ../raster/r.slope.aspect/main.c:1035 ../raster/r.clump/main.c:103
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1035
-msgid "Creating support files..."
-msgstr "Creando archivos de soporte..."
+#: ../raster/r.slope.aspect/main.c:407
+#, c-format
+msgid "Converting units to meters, factor=%.6f"
+msgstr ""
-#: ../raster/r.slope.aspect/main.c:1037
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1037
-#, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
+#: ../raster/r.slope.aspect/main.c:1011
+#, fuzzy, c-format
+msgid "Elevation products for mapset <%s> in <%s>"
msgstr "Productos de elevación para el directorio de mapas [%s] en [%s]"
-#: ../raster/r.slope.aspect/main.c:1055
+#: ../raster/r.slope.aspect/main.c:1029
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1055
#, c-format
msgid "Min computed aspect %.4f, max computed aspect %.4f"
msgstr "Orientación mínima procesada %.4f orientación máxima procesada %.4f"
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1108
-#, c-format
-msgid "ASPECT [%s] COMPLETE"
-msgstr "ORIENTACIÓN [%s] COMPLETA"
+#: ../raster/r.slope.aspect/main.c:1082
+#, fuzzy, c-format
+msgid "Aspect raster map <%s> complete"
+msgstr "No se encuentra el mapa ráster de base <%s>"
-#: ../raster/r.slope.aspect/main.c:1148
+#: ../raster/r.slope.aspect/main.c:1122
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1148
#, c-format
msgid "Min computed slope %.4f, max computed slope %.4f"
msgstr "Pendiente mínima procesada %.4f pendiente máxima procesada %.4f"
-#: ../raster/r.slope.aspect/main.c:1198
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1198
-#, c-format
-msgid "SLOPE [%s] COMPLETE"
-msgstr "PENDIENTE [%s] COMPLETA"
+#: ../raster/r.slope.aspect/main.c:1172
+#, fuzzy, c-format
+msgid "Slope raster map <%s> complete"
+msgstr "No se encuentra el mapa ráster de pendiente de entada <%s>"
-#: ../raster/r.slope.aspect/main.c:1267
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1267
-#, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
-msgstr "CURVA DE PERFIL [%s] COMPLETA"
+#: ../raster/r.slope.aspect/main.c:1241
+#, fuzzy, c-format
+msgid "Profile curve raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1294
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1294
-#, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
-msgstr "CURVA TANGENCIAL [%s] COMPLETA"
+#: ../raster/r.slope.aspect/main.c:1268
+#, fuzzy, c-format
+msgid "Tangential curve raster map <%s> complete"
+msgstr "No se puede crear el mapa ráster <%s>"
-#: ../raster/r.slope.aspect/main.c:1319
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1319
-#, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
-msgstr "PENDIENTE E-W [%s] COMPLETA"
+#: ../raster/r.slope.aspect/main.c:1293
+#, fuzzy, c-format
+msgid "E-W slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1344
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1344
-#, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
-msgstr "PENDIENTE N-S [%s] COMPLETA"
+#: ../raster/r.slope.aspect/main.c:1318
+#, fuzzy, c-format
+msgid "N-S slope raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1369
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1369
-#, c-format
-msgid "DXX [%s] COMPLETE"
-msgstr "DXX [%s] COMPLETO"
+#: ../raster/r.slope.aspect/main.c:1343
+#, fuzzy, c-format
+msgid "Dxx raster map <%s> complete"
+msgstr "Mapa ráster 3D <%s> no encontrado"
-#: ../raster/r.slope.aspect/main.c:1394
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1394
-#, c-format
-msgid "DYY [%s] COMPLETE"
-msgstr "DYY [%s] COMPLETO"
+#: ../raster/r.slope.aspect/main.c:1368
+#, fuzzy, c-format
+msgid "Dyy raster map <%s> complete"
-#: ../raster/r.slope.aspect/main.c:1419
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1419
-#, c-format
-msgid "DXY [%s] COMPLETE"
-msgstr "DXY [%s] COMPLETO"
+#: ../raster/r.slope.aspect/main.c:1393
+#, fuzzy, c-format
+msgid "Dxy raster map <%s> complete"
-#: ../raster/r.slope.aspect/opennew.c:19
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:19
-#, c-format
-msgid "Failed in attempt to open %s"
-msgstr "Fallo al intentar de abrir %s"
#: ../raster/r.surf.gauss/main.c:45
msgid ""
"GRASS module to produce a raster map layer of gaussian deviates whose mean "
@@ -10183,15 +10139,15 @@
#: ../raster/r.colors/main.c:172 ../raster/r.colors/main.c:185
#: ../raster/r.colors/main.c:202 ../raster/r.colors/main.c:207
-#: ../raster/r.colors/main.c:212 ../vector/v.label.sa/main.c:150
-#: ../vector/v.label.sa/main.c:159 ../vector/v.label.sa/main.c:166
-#: ../vector/v.label.sa/main.c:175 ../vector/v.label.sa/main.c:185
-#: ../vector/v.label.sa/main.c:194 ../vector/v.label.sa/main.c:201
+#: ../raster/r.colors/main.c:212 ../vector/v.label.sa/main.c:175
+#: ../vector/v.label.sa/main.c:184 ../vector/v.label.sa/main.c:191
+#: ../vector/v.label.sa/main.c:200 ../vector/v.label.sa/main.c:210
+#: ../vector/v.label.sa/main.c:219 ../vector/v.label.sa/main.c:226
#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
-#: ../vector/v.label/main.c:205 ../display/d.vect/main.c:206
-#: ../display/d.vect/main.c:214 ../display/d.vect/main.c:222
-#: ../display/d.vect/main.c:324 ../display/d.vect/main.c:330
+#: ../vector/v.label/main.c:205 ../display/d.vect/main.c:164
+#: ../display/d.vect/main.c:172 ../display/d.vect/main.c:180
+#: ../display/d.vect/main.c:332 ../display/d.vect/main.c:338
msgid "Colors"
msgstr "Colores"
@@ -10231,11 +10187,11 @@
msgid "Enter rules interactively"
msgstr "Introducir reglas de forma interactiva"
-#: ../raster/r.colors/main.c:252
+#: ../raster/r.colors/main.c:238
msgid "No map specified"
msgstr "Ningún mapa especificado"
-#: ../raster/r.colors/main.c:255
+#: ../raster/r.colors/main.c:241
msgid ""
"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
"specified!"
@@ -10243,7 +10199,7 @@
"¡Se debe especificar \"-i\" o \"-r\" o una de las opciones \"color\", "
"\"ráster\" o \"reglas\"!"
-#: ../raster/r.colors/main.c:258
+#: ../raster/r.colors/main.c:244
msgid ""
"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
"options"
@@ -10251,45 +10207,45 @@
"El modo interactivo es incompatible con las opciones \"color\", \"reglas\" y "
"\"raster\""
-#: ../raster/r.colors/main.c:261
+#: ../raster/r.colors/main.c:247
msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
msgstr ""
"Las opciones \"color\", \"rules\" y \"raster\" son excluyentes entre si"
-#: ../raster/r.colors/main.c:273
+#: ../raster/r.colors/main.c:259
#, c-format
msgid "%s - unable to remove color table"
msgstr "%s - no se puede eliminar la tabla de colores"
-#: ../raster/r.colors/main.c:275
+#: ../raster/r.colors/main.c:261
#, c-format
msgid "%s - color table not found"
msgstr "%s - tabla de colores no encontrada"
-#: ../raster/r.colors/main.c:306
+#: ../raster/r.colors/main.c:292
msgid "Can't make random color table for floating point map"
msgstr "No se puede tabla de colores aleatoria para mapas de coma flotante"
-#: ../raster/r.colors/main.c:312
+#: ../raster/r.colors/main.c:298
msgid "Can't make grey.eq color table for floating point map"
msgstr "No se puede hacer tabla de colores gris.eq para mapas de coma flotante"
-#: ../raster/r.colors/main.c:320
+#: ../raster/r.colors/main.c:306
msgid "Can't make logarithmic color table for floating point map"
msgstr ""
"No se puede hacer tabla de colores logarítmica para mapas de coma flotante"
-#: ../raster/r.colors/main.c:333
+#: ../raster/r.colors/main.c:319
#, c-format
msgid "%s - unknown color request"
msgstr "%s - solicitud de color desconocido"
-#: ../raster/r.colors/main.c:344
+#: ../raster/r.colors/main.c:330
#, c-format
msgid "Unable to load rules file %s"
msgstr "No se puede cargar el archivo de reglas %s"
-#: ../raster/r.colors/main.c:382
+#: ../raster/r.colors/main.c:368
#, c-format
msgid "Color table for <%s> set to %s"
msgstr "Tabla de colores para <%s> establecida a %s"
@@ -10354,7 +10310,7 @@
msgid "bad rule (%s): [%s]"
msgstr "regla incorrecta (%s): %s"
-#: ../raster/r.out.ppm/main.c:54
+#: ../raster/r.out.ppm/main.c:53
msgid ""
"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
"the currently defined region."
@@ -10362,24 +10318,24 @@
"Convierte un mapa ráster de GRASS en un archivo de imagen PPM a la "
"resolución de píxel de la región definida actualmente."
-#: ../raster/r.out.ppm/main.c:63
+#: ../raster/r.out.ppm/main.c:62
msgid "Name for new PPM file (use '-' for stdout)"
msgstr "Nombre para el nuevo archivo PPM. (usar '-' para stdout)"
-#: ../raster/r.out.ppm/main.c:72
+#: ../raster/r.out.ppm/main.c:66
msgid "Output greyscale instead of color"
msgstr "Salida en escala de grises en vez de color"
-#: ../raster/r.out.ppm/main.c:137
+#: ../raster/r.out.ppm/main.c:123
#, c-format
msgid "Unable to open file <%s> for write"
msgstr "No se puede abrir el archivo <%s> para escritura"
-#: ../raster/r.out.ppm/main.c:166
+#: ../raster/r.out.ppm/main.c:152
msgid "Converting..."
msgstr "Convirtiendo..."
-#: ../raster/r.out.ppm/main.c:248
+#: ../raster/r.out.ppm/main.c:234
#, c-format
msgid "File <%s> created"
@@ -10548,31 +10504,31 @@
msgid "Illegal filter file format"
msgstr "Formato de archivo de filtro no admitido"
-#: ../raster/r.mfilter.fp/main.c:56 ../raster/r.mfilter/main.c:49
+#: ../raster/r.mfilter.fp/main.c:54 ../raster/r.mfilter/main.c:47
msgid "raster, map algebra"
msgstr "ráster, álgebra de mapas"
-#: ../raster/r.mfilter.fp/main.c:57 ../raster/r.mfilter/main.c:50
+#: ../raster/r.mfilter.fp/main.c:55 ../raster/r.mfilter/main.c:48
msgid "Raster map matrix filter."
msgstr "Filtro de matrices de mapas ráster."
-#: ../raster/r.mfilter.fp/main.c:68 ../raster/r.mfilter/main.c:61
+#: ../raster/r.mfilter.fp/main.c:66 ../raster/r.mfilter/main.c:59
msgid "Name of filter file"
msgstr "Nombre del archivo de filtro"
-#: ../raster/r.mfilter.fp/main.c:76 ../raster/r.mfilter/main.c:69
+#: ../raster/r.mfilter.fp/main.c:74 ../raster/r.mfilter/main.c:67
msgid "Number of times to repeat the filter"
msgstr "Número de veces a repetir el filtro"
-#: ../raster/r.mfilter.fp/main.c:82 ../raster/r.mfilter/main.c:75
+#: ../raster/r.mfilter.fp/main.c:80 ../raster/r.mfilter/main.c:73
msgid "Output raster map title"
msgstr "Título de mapa ráster de salida"
-#: ../raster/r.mfilter.fp/main.c:99
+#: ../raster/r.mfilter.fp/main.c:92
msgid "Apply filter only to null data values"
msgstr "Aplicar filtro sólo a valores de datos nulos"
-#: ../raster/r.mfilter.fp/main.c:137 ../raster/r.mfilter/main.c:130
+#: ../raster/r.mfilter.fp/main.c:123 ../raster/r.mfilter/main.c:116
msgid "Raster map too small for the size of the filter"
msgstr "El mapa ráster es demasiado pequeño para el tamaño del filtro"
@@ -10604,17 +10560,17 @@
"%s: guardando capa de mapa ráster [%s].\n"
"Porcentaje hecho:"
-#: ../raster/r.random.surface/init.c:196
+#: ../raster/r.random.surface/init.c:183
#, c-format
msgid "Seed [%d] larger than maximum [%d]"
msgstr ""
-#: ../raster/r.random.surface/init.c:199 ../raster/r.random.surface/init.c:207
+#: ../raster/r.random.surface/init.c:186 ../raster/r.random.surface/init.c:194
#, fuzzy, c-format
msgid " seed is set to %d"
msgstr "a"
-#: ../raster/r.random.surface/init.c:203
+#: ../raster/r.random.surface/init.c:190
#, c-format
msgid "Seed [%d] smaller than minimum [%d]"
msgstr ""
@@ -10679,11 +10635,11 @@
msgid "%s higher above pointer wrong"
msgstr "%s más alto sobre el puntero incorrecto"
-#: ../raster/r.cost/main.c:123
+#: ../raster/r.cost/main.c:120
msgid "raster, cost surface, cumulative costs"
msgstr "ráster, superficie de coste, coste acumulado"
-#: ../raster/r.cost/main.c:125
+#: ../raster/r.cost/main.c:122
msgid ""
"Outputs a raster map layer showing the cumulative cost of moving between "
"different geographic locations on an input raster map layer whose cell "
@@ -10693,167 +10649,162 @@
"entre diferentes localizaciones geográficas en una capa de mapa ráster de "
"entrada cuyos valores de categoría de celdas representan coste."
-#: ../raster/r.cost/main.c:132
+#: ../raster/r.cost/main.c:129
msgid "Name of raster map containing grid cell cost information"
msgstr ""
"Nombre del mapa ráster que contiene información de coste de celdas de "
"cuadrícula"
-#: ../raster/r.cost/main.c:141 ../raster/r.walk/main.c:208
+#: ../raster/r.cost/main.c:138 ../raster/r.walk/main.c:208
msgid "Starting points vector map"
msgstr "Mapa vectorial de puntos inicial"
-#: ../raster/r.cost/main.c:148 ../raster/r.walk/main.c:215
+#: ../raster/r.cost/main.c:145 ../raster/r.walk/main.c:215
msgid "Stop points vector map"
msgstr "Mapa vectorial de puntos final"
-#: ../raster/r.cost/main.c:155
+#: ../raster/r.cost/main.c:152
msgid "Starting points raster map"
msgstr "Mapa ráster de puntos inicial"
-#: ../raster/r.cost/main.c:163 ../raster/r.walk/main.c:223
+#: ../raster/r.cost/main.c:160 ../raster/r.walk/main.c:223
msgid "The map E and N grid coordinates of a starting point (E,N)"
msgstr "Coordenadas de cuadrícula E y N del mapa de un punto de inicio (E,N)"
-#: ../raster/r.cost/main.c:171 ../raster/r.walk/main.c:231
+#: ../raster/r.cost/main.c:168 ../raster/r.walk/main.c:231
msgid "The map E and N grid coordinates of a stopping point (E,N)"
msgstr "Coordenadas de cuadrícula E y N del mapa de un punto de final (E,N)"
-#: ../raster/r.cost/main.c:180 ../raster/r.walk/main.c:240
+#: ../raster/r.cost/main.c:177 ../raster/r.walk/main.c:239
msgid "An optional maximum cumulative cost"
msgstr "Un valor de coste acumulativo máximo opcional"
-#: ../raster/r.cost/main.c:189 ../raster/r.walk/main.c:249
+#: ../raster/r.cost/main.c:186 ../raster/r.walk/main.c:247
msgid "Cost assigned to null cells. By default, null cells are excluded"
msgstr ""
"Coste asignado a celdas nulas. Por defecto, las celdas nulas son excluidas"
-#: ../raster/r.cost/main.c:203 ../raster/r.walk/main.c:301
+#: ../raster/r.cost/main.c:200 ../raster/r.walk/main.c:296
msgid "Use the 'Knight's move'; slower, but more accurate"
msgstr "Usar el 'Movimiento de caballero'; más lento, pero más preciso."
-#: ../raster/r.cost/main.c:207 ../raster/r.walk/main.c:305
+#: ../raster/r.cost/main.c:204 ../raster/r.walk/main.c:300
msgid "Keep null values in output map"
msgstr "Conservar valores nulos en el mapa de entrada"
-#: ../raster/r.cost/main.c:211 ../raster/r.walk/main.c:309
+#: ../raster/r.cost/main.c:208 ../raster/r.walk/main.c:304
msgid "Start with values in raster map"
msgstr "Comenzar con valores en mapa ráster"
-#: ../raster/r.cost/main.c:216 ../raster/wildfire/r.ros/main.c:291
-#: ../vector/v.kernel/main.c:156 ../display/d.vect/main.c:320
-msgid "Run verbosely"
-msgstr "Ejecutar con comentarios"
-#: ../raster/r.cost/main.c:237 ../raster/r.water.outlet/main.c:85
-#: ../raster/r.walk/main.c:324
+#: ../raster/r.cost/main.c:220 ../raster/r.water.outlet/main.c:85
+#: ../raster/r.walk/main.c:319
msgid "Unable to read current window parameters"
msgstr "No se pueden leer los parámetros de la ventana actual"
-#: ../raster/r.cost/main.c:270
+#: ../raster/r.cost/main.c:252
msgid "Must specify exactly one of start_points, start_rast or coordinate"
msgstr ""
"Se debe especificar exactamente uno de los siguientes parámetros: mapa "
"vectorial de puntos inicial (start_points), mapa ráster de puntos inicial "
"(start_rast) o coordenadas"
-#: ../raster/r.cost/main.c:275 ../raster/r.cost/main.c:525
-#: ../raster/r.cost/main.c:630
+#: ../raster/r.cost/main.c:257 ../raster/r.cost/main.c:507
+#: ../raster/r.cost/main.c:612
msgid "No start points"
msgstr "Ningún punto de inicio"
-#: ../raster/r.cost/main.c:282 ../raster/r.walk/main.c:351
+#: ../raster/r.cost/main.c:264 ../raster/r.walk/main.c:346
#, c-format
msgid "Inappropriate maximum cost: %d"
msgstr "Coste máximo inapropiado: %d"
-#: ../raster/r.cost/main.c:285 ../raster/r.walk/main.c:354
+#: ../raster/r.cost/main.c:267 ../raster/r.walk/main.c:349
#, c-format
msgid "Inappropriate percent memory: %d"
msgstr "Memoria porcentual inapropiada: %d"
-#: ../raster/r.cost/main.c:289 ../raster/r.walk/main.c:393
+#: ../raster/r.cost/main.c:271 ../raster/r.walk/main.c:388
msgid "Null cells excluded from cost evaluation."
msgstr "Celdas nulas excluidas de la evaluación de costes."
-#: ../raster/r.cost/main.c:293 ../raster/r.walk/main.c:397
+#: ../raster/r.cost/main.c:275 ../raster/r.walk/main.c:392
msgid "Input null cell will be retained into output map"
msgstr "Las celdas nulas de entrada se retendrán en el mapa de salida"
-#: ../raster/r.cost/main.c:303 ../raster/r.walk/main.c:495
+#: ../raster/r.cost/main.c:285 ../raster/r.walk/main.c:490
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
msgstr "Aviso: asignando coste negativo a celda nula. Celdas nulas excluidas."
-#: ../raster/r.cost/main.c:346
+#: ../raster/r.cost/main.c:328
msgid "Source map is: Integer cell type"
msgstr "El mapa de origen es: tipo de celda entero"
-#: ../raster/r.cost/main.c:349
+#: ../raster/r.cost/main.c:331
msgid "Source map is: Floating point (float) cell type"
msgstr "El mapa de origen es: tipo de celda de coma flotante (flotante)"
-#: ../raster/r.cost/main.c:352
+#: ../raster/r.cost/main.c:334
msgid "Source map is: Floating point (double) cell type"
msgstr "El mapa de origen es: tipo de celda de coma flotante (doble)"
-#: ../raster/r.cost/main.c:355 ../raster/r.walk/main.c:585
-#: ../raster/r.walk/main.c:602 ../raster/r.walk/main.c:639
+#: ../raster/r.cost/main.c:337 ../raster/r.walk/main.c:580
+#: ../raster/r.walk/main.c:597 ../raster/r.walk/main.c:634
#, c-format
msgid " %d rows, %d cols"
msgstr " %d filas, %d columnas"
-#: ../raster/r.cost/main.c:366 ../raster/r.walk/main.c:657
+#: ../raster/r.cost/main.c:348 ../raster/r.walk/main.c:652
msgid "Creating some temporary files..."
msgstr "Creando algunos archivos temporales..."
-#: ../raster/r.cost/main.c:387 ../raster/r.cost/main.c:599
+#: ../raster/r.cost/main.c:369 ../raster/r.cost/main.c:581
#, c-format
msgid "Reading %s"
msgstr "Leyendo %s"
-#: ../raster/r.cost/main.c:450 ../raster/r.walk/main.c:813
+#: ../raster/r.cost/main.c:432 ../raster/r.walk/main.c:808
msgid "Initializing output "
msgstr "Inicializando la salida "
-#: ../raster/r.cost/main.c:459 ../raster/r.walk/main.c:821
+#: ../raster/r.cost/main.c:441 ../raster/r.walk/main.c:816
msgid "Unable to allocate memory for segment fbuff == NULL"
msgstr "No se puede asigna memoria para el segmento fbuff == NULO"
-#: ../raster/r.cost/main.c:587
+#: ../raster/r.cost/main.c:569
#, c-format
msgid "can't open raster map [%s] needed for input coordinates"
msgstr ""
"no se puede abrir el mapa ráster [%s] necesario para las coordenadas de "
"entrada"
-#: ../raster/r.cost/main.c:645 ../raster/r.walk/main.c:913
+#: ../raster/r.cost/main.c:627 ../raster/r.walk/main.c:908
msgid "Specified starting location outside database window"
msgstr ""
"La localización de inicio especificada está fuera de la ventana de la base "
"de datos"
-#: ../raster/r.cost/main.c:660 ../raster/r.walk/main.c:930
+#: ../raster/r.cost/main.c:642 ../raster/r.walk/main.c:925
msgid "Finding cost path"
msgstr "Encontrando ruta de coste"
-#: ../raster/r.cost/main.c:885 ../raster/r.walk/main.c:1377
+#: ../raster/r.cost/main.c:867 ../raster/r.walk/main.c:1372
msgid "End of map!"
msgstr "¡Final del mapa!"
-#: ../raster/r.cost/main.c:889 ../raster/r.walk/main.c:1381
+#: ../raster/r.cost/main.c:871 ../raster/r.walk/main.c:1376
msgid "Error, ct == pres_cell"
msgstr "Error, ct == pres_cell"
-#: ../raster/r.cost/main.c:901
+#: ../raster/r.cost/main.c:883
#, c-format
msgid "Writing %s"
msgstr "Escribiendo %s"
-#: ../raster/r.cost/main.c:905 ../raster/r.walk/main.c:1399
+#: ../raster/r.cost/main.c:887 ../raster/r.walk/main.c:1394
msgid "Will copy input map null values into output map"
msgstr "Copiará los valores nulos del mapa de entrada en el mapa de salida"
-#: ../raster/r.cost/main.c:912 ../raster/r.walk/main.c:1406
+#: ../raster/r.cost/main.c:894 ../raster/r.walk/main.c:1401
msgid ""
"Integer cell type.\n"
"Writing..."
@@ -10861,12 +10812,12 @@
"Tipo de celda entero.\n"
"Escribiendo..."
-#: ../raster/r.cost/main.c:917 ../raster/r.cost/main.c:949
-#: ../raster/r.cost/main.c:981
+#: ../raster/r.cost/main.c:899 ../raster/r.cost/main.c:931
+#: ../raster/r.cost/main.c:963
msgid "Error getting input null cells"
msgstr "Error al obtener celdas nulas de entrada"
-#: ../raster/r.cost/main.c:944 ../raster/r.walk/main.c:1441
+#: ../raster/r.cost/main.c:926 ../raster/r.walk/main.c:1436
msgid ""
"Float cell type.\n"
"Writing..."
@@ -10874,7 +10825,7 @@
"Tipo de celda flotante.\n"
"Escribiendo..."
-#: ../raster/r.cost/main.c:976 ../raster/r.walk/main.c:1476
+#: ../raster/r.cost/main.c:958 ../raster/r.walk/main.c:1471
msgid ""
"Double cell type.\n"
"Writing..."
@@ -10882,22 +10833,22 @@
"Tipo de celda doble.\n"
"Escribiendo..."
-#: ../raster/r.cost/main.c:1008 ../raster/r.walk/main.c:1511
+#: ../raster/r.cost/main.c:990 ../raster/r.walk/main.c:1506
#, c-format
msgid "Peak cost value: %f"
msgstr "Valor de coste pico: %f"
-#: ../raster/r.cost/main.c:1051 ../raster/r.walk/main.c:1562
+#: ../raster/r.cost/main.c:1033 ../raster/r.walk/main.c:1557
#, c-format
msgid "Illegal x coordinate <%s>"
msgstr "Coordenada X no admitida <%s>"
-#: ../raster/r.cost/main.c:1053 ../raster/r.walk/main.c:1564
+#: ../raster/r.cost/main.c:1035 ../raster/r.walk/main.c:1559
#, c-format
msgid "Illegal y coordinate <%s>"
msgstr "Coordenada Y no admitida <%s>"
-#: ../raster/r.cost/main.c:1057 ../raster/r.walk/main.c:1568
+#: ../raster/r.cost/main.c:1039 ../raster/r.walk/main.c:1563
#, c-format
msgid "Warning, ignoring point outside window: %.4f,%.4f"
msgstr "Aviso, se ignoran los puntos fuera de la ventana: %.4f,%.4f"
@@ -11576,7 +11527,7 @@
msgid "Reading map"
msgstr "Leyendo mapa"
-#: ../raster/r.neighbors/main.c:105
+#: ../raster/r.neighbors/main.c:104
msgid ""
"Makes each cell category value a function of the category values assigned to "
"the cells around it, and stores new cell values in an output raster map "
@@ -11586,43 +11537,43 @@
"categoría asignados a las celdas a su alrededor y guarda los nuevos valores "
"de celda en una capa de mapa ráster de salida."
-#: ../raster/r.neighbors/main.c:128
+#: ../raster/r.neighbors/main.c:127
msgid "Neighborhood operation"
msgstr "Operación de vecindad"
-#: ../raster/r.neighbors/main.c:134
+#: ../raster/r.neighbors/main.c:133
msgid "Neighborhood size"
msgstr "Tamaño de vecindad"
-#: ../raster/r.neighbors/main.c:142
+#: ../raster/r.neighbors/main.c:141
msgid "Title of the output raster map"
msgstr "Título del mapa ráster de salida"
-#: ../raster/r.neighbors/main.c:149
+#: ../raster/r.neighbors/main.c:148
msgid "File containing weights"
msgstr "Archivo que contiene pesos"
-#: ../raster/r.neighbors/main.c:153
+#: ../raster/r.neighbors/main.c:152
msgid "Do not align output with the input"
msgstr "No alinear la salida con la entrada"
-#: ../raster/r.neighbors/main.c:162
+#: ../raster/r.neighbors/main.c:156
msgid "Use circular neighborhood"
msgstr "Usar vecindario circular"
-#: ../raster/r.neighbors/main.c:169
+#: ../raster/r.neighbors/main.c:163
msgid "Neighborhood size must be positive"
msgstr "El tamaño del vecindario debe ser positivo"
-#: ../raster/r.neighbors/main.c:171
+#: ../raster/r.neighbors/main.c:165
msgid "Neighborhood size must be odd"
msgstr "El tamaño del vecindario debe ser impar"
-#: ../raster/r.neighbors/main.c:175
+#: ../raster/r.neighbors/main.c:169
msgid "weight= and -c are mutually exclusive"
msgstr "weight= y -c son excluyentes mutuamente"
-#: ../raster/r.neighbors/main.c:203 ../raster/r.series/main.c:175
+#: ../raster/r.neighbors/main.c:197 ../raster/r.series/main.c:161
#: ../ps/ps.map/outl_io.c:77
#, c-format
msgid "Unable to open raster map <%s> in mapset <%s>"
@@ -11651,7 +11602,7 @@
msgid "Unable to properly write output raster map"
msgstr "No se puede escribir adecuadamente el mapa ráster de salida"
-#: ../raster/r.clump/main.c:52
+#: ../raster/r.clump/main.c:49
msgid ""
"Recategorizes data in a raster map layer by grouping cells that form "
"physically discrete areas into unique categories."
@@ -11659,11 +11610,16 @@
"Recategoriza datos en una capa de mapa ráster agrupando celdas que forman "
"áreas físicamente discretas en categorías únicas."
-#: ../raster/r.clump/main.c:64
+#: ../raster/r.clump/main.c:61
msgid "Title, in quotes"
msgstr "Título, entre comillas"
-#: ../raster/r.clump/main.c:121
+#: ../raster/r.clump/main.c:88
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1035
+msgid "Creating support files..."
+msgstr "Creando archivos de soporte..."
+#: ../raster/r.clump/main.c:106
#, c-format
msgid "%d clumps"
msgstr "%d grupos"
@@ -11768,15 +11724,11 @@
"No construir topología vectorial (usar con cuidado para exportación masiva "
"de puntos)"
-#: ../raster/r.to.vect/main.c:87
-msgid "Quiet - Do not show progress"
-msgstr "Silencioso - no muestra el progreso"
-#: ../raster/r.to.vect/main.c:105
+#: ../raster/r.to.vect/main.c:92
msgid "z flag is supported only for points"
msgstr "La opción z sólo está soportada para puntos"
-#: ../raster/r.to.vect/main.c:119
+#: ../raster/r.to.vect/main.c:106
msgid ""
"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
"table."
@@ -11784,20 +11736,20 @@
"El ráster no es CELL, se ignora la opción '-v', los valores ráster se "
"escribirán en la tabla."
-#: ../raster/r.to.vect/main.c:154 ../raster/r.contour/main.c:179
+#: ../raster/r.to.vect/main.c:141 ../raster/r.contour/main.c:157
#: ../vector/v.db.connect/main.c:178 ../vector/v.db.connect/main.c:270
#: ../vector/v.to.rast3/main.c:85 ../vector/v.edit/select.c:539
#: ../vector/lidar/v.surf.bspline/main.c:297 ../vector/v.distance/main.c:342
#: ../vector/v.distance/main.c:376 ../vector/v.reclass/main.c:117
-#: ../vector/v.in.ascii/in.c:310 ../vector/v.db.select/main.c:103
+#: ../vector/v.in.ascii/in.c:312 ../vector/v.db.select/main.c:103
#: ../vector/v.db.select/main.c:173 ../vector/v.what.rast/main.c:127
-#: ../vector/v.extrude/main.c:167 ../vector/v.sample/main.c:201
+#: ../vector/v.extrude/main.c:167 ../vector/v.sample/main.c:196
#: ../vector/v.patch/main.c:132 ../vector/v.patch/main.c:164
#: ../vector/v.patch/main.c:287 ../vector/v.patch/main.c:347
#: ../vector/v.surf.idw/read_sites.c:39 ../vector/v.vol.rst/user1.c:96
#: ../vector/v.vol.rst/main.c:561 ../vector/v.transform/trans_digit.c:58
-#: ../vector/v.mkgrid/main.c:207 ../vector/v.overlay/main.c:168
-#: ../vector/v.overlay/main.c:261 ../vector/v.label.sa/labels.c:79
+#: ../vector/v.mkgrid/main.c:192 ../vector/v.overlay/main.c:168
+#: ../vector/v.overlay/main.c:261 ../vector/v.label.sa/labels.c:78
#: ../vector/v.kcv/main.c:173 ../vector/v.normal/main.c:141
#: ../vector/v.out.svg/main.c:145 ../vector/v.to.db/update.c:32
#: ../vector/v.to.db/query.c:81 ../vector/v.label/main.c:277
@@ -11811,31 +11763,31 @@
msgid "Unable to open database <%s> by driver <%s>"
msgstr "No se puede abrir la base de datos <%s> por el controlador <%s>"
-#: ../raster/r.to.vect/main.c:189 ../raster/r.contour/main.c:188
+#: ../raster/r.to.vect/main.c:176 ../raster/r.contour/main.c:166
#: ../vector/lidar/lidarlib/raster.c:74 ../vector/lidar/lidarlib/raster.c:88
#: ../vector/lidar/lidarlib/raster.c:100 ../vector/lidar/lidarlib/raster.c:116
#: ../vector/lidar/lidarlib/raster.c:130 ../vector/lidar/lidarlib/raster.c:142
#: ../vector/lidar/lidarlib/raster.c:156 ../vector/lidar/lidarlib/raster.c:167
-#: ../vector/v.in.ascii/in.c:379 ../vector/v.mkgrid/main.c:220
+#: ../vector/v.in.ascii/in.c:381 ../vector/v.mkgrid/main.c:205
#: ../vector/v.lrs/v.lrs.create/main.c:309
#, c-format
msgid "Unable to create table: %s"
msgstr "No se puede crear la tabla: %s"
-#: ../raster/r.to.vect/main.c:192 ../vector/v.mkgrid/main.c:224
+#: ../raster/r.to.vect/main.c:179 ../vector/v.mkgrid/main.c:209
#: ../vector/v.overlay/main.c:427
msgid "Unable to create index"
msgstr "No se puede crear el índice"
-#: ../raster/r.to.vect/main.c:195 ../raster/r.contour/main.c:195
-#: ../vector/v.distance/main.c:759 ../vector/v.in.ascii/in.c:388
-#: ../vector/v.sample/main.c:216 ../vector/v.mkgrid/main.c:227
+#: ../raster/r.to.vect/main.c:182 ../raster/r.contour/main.c:173
+#: ../vector/v.distance/main.c:759 ../vector/v.in.ascii/in.c:390
+#: ../vector/v.sample/main.c:211 ../vector/v.mkgrid/main.c:212
#: ../vector/v.overlay/main.c:430
#, c-format
msgid "Unable to grant privileges on table <%s>"
msgstr "No se pueden otorgar privilegios sobre la tabla <%s>"
-#: ../raster/r.to.vect/main.c:258
+#: ../raster/r.to.vect/main.c:245
#, c-format
msgid "Unable to insert into table: %s"
msgstr "No se puede insertar en la tabla: %s"
@@ -11987,7 +11939,7 @@
msgid "Unable to update boundaries"
msgstr "No se pueden actualizar los contornos"
-#: ../raster/r.out.ppm3/main.c:56
+#: ../raster/r.out.ppm3/main.c:55
msgid ""
"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
"resolution of the CURRENTLY DEFINED REGION."
@@ -11995,20 +11947,20 @@
"Convierte 3 capas ráster de GRASS (R,G,B) a un archivo de imagen PPM a la "
"resolución de píxel de la REGIÓN ACTUALMENTE DEFINIDA."
-#: ../raster/r.out.ppm3/main.c:62 ../display/d.rgb/main.c:69
+#: ../raster/r.out.ppm3/main.c:61 ../display/d.rgb/main.c:69
#, c-format
msgid "Name of raster map to be used for <%s>"
msgstr "Nombre del mapa ráster a usar para <%s>"
-#: ../raster/r.out.ppm3/main.c:81
+#: ../raster/r.out.ppm3/main.c:80
msgid "Name for new PPM file. (use out=- for stdout)"
msgstr "Nombre para el nuevo archivo PPM. (usar out=- para stdout)"
-#: ../raster/r.out.ppm3/main.c:90
+#: ../raster/r.out.ppm3/main.c:84
msgid "Add comments to describe the region"
msgstr "Añadir comentarios para describir la región"
-#: ../raster/r.out.ppm3/main.c:176
+#: ../raster/r.out.ppm3/main.c:162
msgid "Converting ... "
msgstr "Convirtiendo ... "
@@ -12050,115 +12002,140 @@
msgid "Writing color file..."
msgstr "Escribiendo archivo de color..."
-#: ../raster/r.in.mat/main.c:95
+#: ../raster/r.in.mat/main.c:90
msgid "Imports a binary MAT-File(v4) to a GRASS raster."
msgstr "Importa un archivo binario MAT(v4) a un ráster de GRASS."
-#: ../raster/r.in.mat/main.c:104
+#: ../raster/r.in.mat/main.c:99
msgid "Name of an existing MAT-File(v4)"
msgstr "Nombre de un archivo MAT(v4) existente"
-#: ../raster/r.in.mat/main.c:111
+#: ../raster/r.in.mat/main.c:106
msgid "Name for the output raster map (override)"
msgstr "Nombre para el mapa ráster de salida (no tener en cuenta)"
-#: ../raster/r.in.mat/main.c:161
+#: ../raster/r.in.mat/main.c:148
msgid "Reading MAT-File..."
msgstr "Leyendo archivo MAT..."
-#: ../raster/r.in.mat/main.c:187
+#: ../raster/r.in.mat/main.c:174
msgid "Array contains no data"
msgstr "La matriz no contiene datos"
-#: ../raster/r.in.mat/main.c:192
+#: ../raster/r.in.mat/main.c:179
msgid "Array contains imaginary data"
msgstr "La matriz contiene datos imaginarios"
-#: ../raster/r.in.mat/main.c:198
+#: ../raster/r.in.mat/main.c:185
msgid "Invalid array name"
msgstr "Nombre de matriz no válido"
-#: ../raster/r.in.mat/main.c:217
+#: ../raster/r.in.mat/main.c:204
msgid "Invalid 'map_name' array"
msgstr "Cadena 'map_name' no válida"
-#: ../raster/r.in.mat/main.c:226
+#: ../raster/r.in.mat/main.c:213
msgid "Error reading 'map_name' array"
msgstr "Error al leer la cadena 'map_name'"
-#: ../raster/r.in.mat/main.c:236
+#: ../raster/r.in.mat/main.c:223
msgid "Invalid 'map_northern_edge' array"
msgstr "Cadena 'map_northen_edge' no válida"
-#: ../raster/r.in.mat/main.c:244
+#: ../raster/r.in.mat/main.c:231
msgid "Invalid 'map_southern_edge' array"
msgstr "Cadena 'map_southern_edge' no válida"
-#: ../raster/r.in.mat/main.c:252
+#: ../raster/r.in.mat/main.c:239
msgid "Invalid 'map_eastern_edge' array"
msgstr "Cadena 'map_eastern_edge' no válida"
-#: ../raster/r.in.mat/main.c:260
+#: ../raster/r.in.mat/main.c:247
msgid "Invalid 'map_western_edge' array"
msgstr "Cadena 'map_western_edge' no válida"
-#: ../raster/r.in.mat/main.c:268
+#: ../raster/r.in.mat/main.c:255
msgid "Invalid 'map_title' array"
msgstr "Cadena 'map_title' no válida"
-#: ../raster/r.in.mat/main.c:277
+#: ../raster/r.in.mat/main.c:264
msgid "Error reading 'map_title' array"
msgstr "Error al leer la cadena 'map_title'"
-#: ../raster/r.in.mat/main.c:290
+#: ../raster/r.in.mat/main.c:277
msgid "Invalid 'map_data' array"
msgstr "Cadena 'map_data' no válida"
-#: ../raster/r.in.mat/main.c:312 ../raster/r.in.mat/main.c:418
-#: ../raster/r.in.mat/main.c:495
+#: ../raster/r.in.mat/main.c:299 ../raster/r.in.mat/main.c:429
+#: ../raster/r.in.mat/main.c:508
msgid "Please contact the GRASS development team"
msgstr "Por favor, contacte con el equipo de desarrollo de GRASS"
-#: ../raster/r.in.mat/main.c:317
+#: ../raster/r.in.mat/main.c:304
#, c-format
msgid "Skipping unknown array '%s'"
msgstr "Saltando matriz desconocida '%s'"
-#: ../raster/r.in.mat/main.c:344
+#: ../raster/r.in.mat/main.c:331
#, c-format
msgid "No 'map_data' array found in <%s>"
msgstr "No se encontró ninguna cadena 'map_data' en <%s>"
-#: ../raster/r.in.mat/main.c:358
+#: ../raster/r.in.mat/main.c:338
+#, c-format
+msgid "Setting map name to <%s> which overrides <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:345
+#, fuzzy, c-format
+msgid "Setting map name to <%s>"
+msgstr "Configurando ventana de mapa"
+#: ../raster/r.in.mat/main.c:349
+#, fuzzy
+msgid "No 'map_name' array found; using <MatFile>"
+msgstr "No se encontró ninguna cadena 'map_data' en <%s>"
+#: ../raster/r.in.mat/main.c:362
msgid "Missing bound"
msgstr "Falta el contorno"
-#: ../raster/r.in.mat/main.c:362
+#: ../raster/r.in.mat/main.c:366
msgid "Using default bounds"
msgstr "Usando contornos predeterminados"
-#: ../raster/r.in.mat/main.c:389
+#: ../raster/r.in.mat/main.c:381
+#, c-format
+msgid "Map <%s> bounds set to:"
+msgstr ""
+#: ../raster/r.in.mat/main.c:400
msgid "Writing new raster map..."
msgstr "Escribiendo nuevo mapa ráster..."
-#: ../raster/r.univar2/r.univar_main.c:43
+#: ../raster/r.in.mat/main.c:450
+#, fuzzy, c-format
+msgid "Writing raster map, row %d"
+msgstr "Escribiendo mapa, fila %d"
+#: ../raster/r.univar2/r.univar_main.c:44
#: ../raster/r.univar2/r3.univar_main.c:43 ../vector/v.univar/main.c:90
msgid "Print the stats in shell script style"
msgstr "Imprimir las estadísticas en estilo de script de consola"
-#: ../raster/r.univar2/r.univar_main.c:76
+#: ../raster/r.univar2/r.univar_main.c:77
msgid ""
"Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
"Calcula estadísticas univariantes a partir de celdas no nulas de un mapa "
"ráster."
-#: ../raster/r.univar2/r.univar_main.c:120
+#: ../raster/r.univar2/r.univar_main.c:121
#, fuzzy, c-format
msgid "Raster <%s> type mismatch"
msgstr "El mapa ráster <%s> ya existe"
-#: ../raster/r.univar2/r.univar_main.c:198
+#: ../raster/r.univar2/r.univar_main.c:204
#, c-format
msgid "Reading row %d"
msgstr "Leyendo la fila %d"
@@ -13105,89 +13082,77 @@
msgid "Edge number out of range"
msgstr "Número de borde fuera de rango"
-#: ../raster/r.contour/main.c:91
+#: ../raster/r.contour/main.c:86
msgid ""
"Produces a vector map layer of specified contours from a raster map layer."
msgstr ""
"Produce una capa de mapa vectorial de contornos especificados a partir de "
"una capa de mapa ráster."
-#: ../raster/r.contour/main.c:103
+#: ../raster/r.contour/main.c:97
msgid "List of contour levels"
msgstr "Lista de niveles de contorno"
-#: ../raster/r.contour/main.c:109
+#: ../raster/r.contour/main.c:103
msgid "Minimum contour level"
msgstr "Nivel mínimo de contorno"
-#: ../raster/r.contour/main.c:115
+#: ../raster/r.contour/main.c:109
msgid "Maximum contour level"
msgstr "Nivel máximo de contorno"
-#: ../raster/r.contour/main.c:121
+#: ../raster/r.contour/main.c:115
msgid "Increment between contour levels"
msgstr "Incremento entre niveles de contorno"
-#: ../raster/r.contour/main.c:128
+#: ../raster/r.contour/main.c:122
msgid "Minimum number of points for a contour line (0 -> no limit)"
msgstr "Número mínimo de puntos para una línea de contorno (0 -> sin límite)"
-#: ../raster/r.contour/main.c:136
-msgid "Suppress single crossing error messages"
-msgstr "Suprime mensaje de error de cruzamiento simple"
-#: ../raster/r.contour/main.c:145
-msgid ""
-"The '-q' and '-n' flag is superseded and will be removed in future. Please "
-"use '--quiet' instead."
-msgstr ""
-"Las opciones '-q' y '-n' son suplantadas y serán eliminadas en el futuro. "
-"Por favor use '--quiet' en su lugar."
-#: ../raster/r.contour/main.c:150
+#: ../raster/r.contour/main.c:128
msgid "Neither \"levels\" nor \"step\" parameter specified."
msgstr "Parámetros \"niveles\" o \"paso\" no especificados."
-#: ../raster/r.contour/main.c:163
+#: ../raster/r.contour/main.c:141
msgid "Could not read range file"
msgstr "No se pudo leer el archivo de rango"
-#: ../raster/r.contour/main.c:192 ../vector/v.db.connect/main.c:274
+#: ../raster/r.contour/main.c:170 ../vector/v.db.connect/main.c:274
#: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.reclass/main.c:204
-#: ../vector/v.to.points/main.c:277 ../vector/v.sample/main.c:213
+#: ../vector/v.to.points/main.c:277 ../vector/v.sample/main.c:208
#: ../vector/v.in.ogr/main.c:718 ../vector/v.net.path/path.c:106
msgid "Cannot create index"
-#: ../raster/r.contour/main.c:211 ../vector/v.sample/main.c:278
+#: ../raster/r.contour/main.c:189 ../vector/v.sample/main.c:271
#: ../vector/v.kcv/main.c:245
#, c-format
msgid "Unable to insert row: %s"
msgstr "No se puede insertar la fila: %s"
-#: ../raster/r.contour/main.c:233
+#: ../raster/r.contour/main.c:211
msgid "Reading data: "
msgstr "Leyendo datos: "
-#: ../raster/r.contour/main.c:264
+#: ../raster/r.contour/main.c:242
#, c-format
msgid "Range of data: min = %f max = %f"
msgstr "Rango de datos: mínimo = %f máximo = %f"
-#: ../raster/r.contour/main.c:266
+#: ../raster/r.contour/main.c:244
msgid "Range of data: empty"
msgstr "Rango de datos: vacío"
-#: ../raster/r.contour/main.c:297 ../raster/r.contour/main.c:299
+#: ../raster/r.contour/main.c:275 ../raster/r.contour/main.c:277
msgid "This step value is not allowed."
msgstr "Este valor de paso no está permitido."
-#: ../raster/r.contour/main.c:328
+#: ../raster/r.contour/main.c:306
#, c-format
msgid "Range of levels: min = %f max = %f"
msgstr "Rango de niveles: mínimo =%f máximo = %f"
-#: ../raster/r.contour/main.c:357
+#: ../raster/r.contour/main.c:335
msgid "Displacing data: "
msgstr "Desplazando datos: "
@@ -13196,7 +13161,7 @@
msgid "%s: STEP 3 ... "
msgstr "%s: PASO 3 ... "
-#: ../raster/r.cross/main.c:67
+#: ../raster/r.cross/main.c:64
msgid ""
"Creates a cross product of the category values from multiple raster map "
"layers."
@@ -13204,30 +13169,30 @@
"Crea un producto cruzado de los valores de categoría a partir de múltiples "
"capas de mapa ráster."
-#: ../raster/r.cross/main.c:77
+#: ../raster/r.cross/main.c:74
#, c-format
msgid "Names of 2-%d input raster maps"
msgstr "Nombres de 2-%d mapas ráster de entrada"
-#: ../raster/r.cross/main.c:85
+#: ../raster/r.cross/main.c:82
msgid "Non-zero data only"
msgstr "Solamente datos distintos de cero"
-#: ../raster/r.cross/main.c:113
+#: ../raster/r.cross/main.c:96
#, c-format
msgid "More than %d files not allowed"
msgstr "No se permiten más de %d archivos"
-#: ../raster/r.cross/main.c:132
+#: ../raster/r.cross/main.c:115
msgid "Must specify 2 or more input maps"
msgstr "Se deben especificar 2 o más mapas de entrada"
-#: ../raster/r.cross/main.c:153
+#: ../raster/r.cross/main.c:136
#, c-format
msgid "%s: STEP 2 ..."
msgstr "%s: PASO 2 ..."
-#: ../raster/r.cross/main.c:199
+#: ../raster/r.cross/main.c:182
#, c-format
msgid "%ld categories"
msgstr "%ld categorías"
@@ -13315,11 +13280,11 @@
msgid "Reading <%s> in <%s>"
msgstr "Leyendo <%s> en <%s>"
-#: ../raster/r.series/main.c:105
+#: ../raster/r.series/main.c:103
msgid "raster, series"
msgstr "ráster, series"
-#: ../raster/r.series/main.c:107
+#: ../raster/r.series/main.c:105
msgid ""
"Makes each output cell value a function of the values assigned to the "
"corresponding cells in the input raster map layers."
@@ -13327,7 +13292,7 @@
"Hace cada valor de celda de salida una función de los valores asignados a "
"las celdas correspondientes en las capas de mapa ráster de entrada."
-#: ../raster/r.series/main.c:120
+#: ../raster/r.series/main.c:118
msgid "Aggregate operation"
msgstr "Agregar operación"
@@ -13336,7 +13301,7 @@
msgstr "Programa de creación de cuenca hidrográfica."
#: ../raster/r.water.outlet/main.c:61 ../raster/r.walk/main.c:201
-#: ../raster/r.composite/main.c:128
+#: ../raster/r.composite/main.c:124
msgid "Name of raster map to contain results"
msgstr "Nombre del mapa ráster que contendrá los resultados"
@@ -13380,7 +13345,7 @@
msgid "Unable to close new basin map layer"
msgstr "No se puede cerrar la capa del nuevo mapa de cuenca"
-#: ../raster/r.out.tiff/r.out.tiff.c:102
+#: ../raster/r.out.tiff/r.out.tiff.c:101
msgid ""
"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
"resolution of the currently defined region."
@@ -13388,27 +13353,27 @@
"Exporta un mapa ráster de GRASS a una imagen TIFF de 8/24 bits a la "
-#: ../raster/r.out.tiff/r.out.tiff.c:112
+#: ../raster/r.out.tiff/r.out.tiff.c:111
msgid "Name for new TIFF file"
msgstr "Nombre para el nuevo archivo TIFF"
-#: ../raster/r.out.tiff/r.out.tiff.c:119
+#: ../raster/r.out.tiff/r.out.tiff.c:118
msgid "TIFF file compression"
msgstr "Compresión del archivo TIFF"
-#: ../raster/r.out.tiff/r.out.tiff.c:124
+#: ../raster/r.out.tiff/r.out.tiff.c:123
msgid "TIFF Palette output (8bit instead of 24bit)."
msgstr "Salida de paleta TIFF (8bits en vez de 24 bits)."
-#: ../raster/r.out.tiff/r.out.tiff.c:128
+#: ../raster/r.out.tiff/r.out.tiff.c:127
msgid "Output TIFF world file"
msgstr "Producir archivo de referenciación TIFF"
-#: ../raster/r.out.tiff/r.out.tiff.c:132
+#: ../raster/r.out.tiff/r.out.tiff.c:131
msgid "Output Tiled TIFF"
msgstr "TIFF teselado de salida"
-#: ../raster/r.out.tiff/r.out.tiff.c:177
+#: ../raster/r.out.tiff/r.out.tiff.c:161
#, c-format
msgid ""
"Raster map <%s> in mapset <%s> is a floating point map. Decimal values will "
@@ -13417,7 +13382,7 @@
"El mapa ráster <%s> en el directorio de mapas <%s> es de coma flotante. ¡Los "
"valores decimales se redondearán a entero!"
-#: ../raster/r.out.tiff/r.out.tiff.c:183
+#: ../raster/r.out.tiff/r.out.tiff.c:167
msgid ""
"Color map for palette must have less than 256 colors for the available range "
"of data"
@@ -13425,24 +13390,24 @@
"El mapa de color para paleta debe tener menos de 256 colores para el rango "
"disponible de datos"
-#: ../raster/r.out.tiff/r.out.tiff.c:198
+#: ../raster/r.out.tiff/r.out.tiff.c:182
#, c-format
msgid "Unable to open TIFF file <%s>"
msgstr "No se puede abrir el archivo TIFF <%s>"
-#: ../raster/r.out.tiff/r.out.tiff.c:430
+#: ../raster/r.out.tiff/r.out.tiff.c:414
msgid "Writing TIFF World file"
msgstr "Escribiendo archivo TIFF World"
-#: ../raster/r.out.tiff/r.out.tiff.c:433
+#: ../raster/r.out.tiff/r.out.tiff.c:417
msgid "Got null file name"
msgstr "Se obtuvo un nombre de archivo nulo"
-#: ../raster/r.out.tiff/r.out.tiff.c:435
+#: ../raster/r.out.tiff/r.out.tiff.c:419
msgid "Got null region struct"
msgstr "Se obtuvo una estructura de región nula"
-#: ../raster/r.out.tiff/r.out.tiff.c:438
+#: ../raster/r.out.tiff/r.out.tiff.c:422
msgid "Unable to open TIFF world file for writing"
msgstr "No se puede abrir el archivo de referenciación TIFF para escritura"
@@ -13521,144 +13486,144 @@
msgid "Name of input raster map containing friction costs"
msgstr "Nombre del mapa ráster de entrada que contiene costes de fricción"
-#: ../raster/r.walk/main.c:267
+#: ../raster/r.walk/main.c:263
msgid "Number of the segment to create (segment library)"
msgstr "Número del segmento a crear (biblioteca de segmento)"
-#: ../raster/r.walk/main.c:277
+#: ../raster/r.walk/main.c:273
msgid "Coefficients for walking energy formula parameters a,b,c,d"
msgstr ""
"Coeficientes para los parámetros a,b,c,d de la fórmula de energía de "
"desplazamiento"
-#: ../raster/r.walk/main.c:286
+#: ../raster/r.walk/main.c:282
msgid "Lambda coefficients for combining walking energy and friction cost"
msgstr ""
"Coeficientes lambda para combinar energía de desplazamiento y coste de "
"fricción"
-#: ../raster/r.walk/main.c:296
+#: ../raster/r.walk/main.c:291
msgid "Slope factor determines travel energy cost per height step"
msgstr ""
"El factor de pendiente determina el coste energético del viaje por paso de "
"altura"
-#: ../raster/r.walk/main.c:359
+#: ../raster/r.walk/main.c:354
#, c-format
msgid "Missing required value: got %d instead of 4"
msgstr "Falta un valor requerido: se obtuvo %d en vez de 4"
-#: ../raster/r.walk/main.c:363
+#: ../raster/r.walk/main.c:358
#, c-format
msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
msgstr "Los costes de desplazamiento son a=%lf b=%lf c=%lf d=%lf"
-#: ../raster/r.walk/main.c:369 ../raster/r.walk/main.c:377
-#: ../raster/r.walk/main.c:384
+#: ../raster/r.walk/main.c:364 ../raster/r.walk/main.c:372
+#: ../raster/r.walk/main.c:379
#, c-format
msgid "Missing required value: %d"
msgstr "Falta un valore requerido: %d"
-#: ../raster/r.walk/main.c:372
+#: ../raster/r.walk/main.c:367
#, c-format
msgid "Lambda is %lf"
msgstr "Lambda es %lf"
-#: ../raster/r.walk/main.c:380
+#: ../raster/r.walk/main.c:375
#, c-format
msgid "Slope_factor is %lf"
msgstr "Factor de pendiente es %If"
-#: ../raster/r.walk/main.c:387
+#: ../raster/r.walk/main.c:382
#, c-format
msgid "Nseg is %d"
msgstr "Nseg es %d"
-#: ../raster/r.walk/main.c:409
+#: ../raster/r.walk/main.c:404
#, c-format
msgid "Unable to find starting vector <%s> "
msgstr "No se puede encontrar el vector de inicio <%s> "
-#: ../raster/r.walk/main.c:455
+#: ../raster/r.walk/main.c:450
#, c-format
msgid "Unable to find stop vector <%s>"
msgstr "No se puede encontrar el vector de fin <%s>"
-#: ../raster/r.walk/main.c:556 ../raster/r.walk/main.c:558
+#: ../raster/r.walk/main.c:551 ../raster/r.walk/main.c:553
#, c-format
msgid "Unable to read %s"
msgstr "No se puede leer %s"
-#: ../raster/r.walk/main.c:563
+#: ../raster/r.walk/main.c:558
msgid "Map with different projection"
msgstr "Mapa con diferente proyección"
-#: ../raster/r.walk/main.c:575
+#: ../raster/r.walk/main.c:570
msgid "DTM_Source map is: Integer cell type"
msgstr "Mapa DTM_Origen es: tipo de celda entero"
-#: ../raster/r.walk/main.c:578
+#: ../raster/r.walk/main.c:573
msgid "DTM_Source map is: Floating point (float) cell type"
msgstr "Mapa DTM_Origen es: tipo de celda coma flotante (flotante)"
-#: ../raster/r.walk/main.c:582
+#: ../raster/r.walk/main.c:577
msgid "DTM_Source map is: Floating point (double) cell type"
msgstr "Mapa DTM_Origen es: tipo de celda coma flotante (doble)"
-#: ../raster/r.walk/main.c:591
+#: ../raster/r.walk/main.c:586
msgid "COST_Source map is: Integer cell type"
msgstr "Mapa COST_Origen es: tipo de celda entero"
-#: ../raster/r.walk/main.c:595
+#: ../raster/r.walk/main.c:590
msgid "COST_Source map is: Floating point (float) cell type"
msgstr "Mapa COST_Origen es: tipo de celda coma flotante (flotante)"
-#: ../raster/r.walk/main.c:599
+#: ../raster/r.walk/main.c:594
msgid "COST_Source map is: Floating point (double) cell type"
msgstr "Mapa COST_Origen es: tipo de celda coma flotante (doble)"
-#: ../raster/r.walk/main.c:630
+#: ../raster/r.walk/main.c:625
msgid "Output map is: Integer cell type"
msgstr "El mapa de salida es: tipo de celda entero"
-#: ../raster/r.walk/main.c:633
+#: ../raster/r.walk/main.c:628
msgid "Output map is: Floating point (float) cell type"
msgstr "El mapa de salida es: tipo de celda de coma flotante"
-#: ../raster/r.walk/main.c:636
+#: ../raster/r.walk/main.c:631
msgid "Output map is: Floating point (double) cell type"
msgstr "El mapa de salida es: tipo de celda de coma flotante (doble)"
-#: ../raster/r.walk/main.c:641
+#: ../raster/r.walk/main.c:636
#, c-format
msgid " EW resolution %s (%lf)"
msgstr " Resolución EW %s (%lf)"
-#: ../raster/r.walk/main.c:643
+#: ../raster/r.walk/main.c:638
#, c-format
msgid " NS resolution %s (%lf)"
msgstr " Resolución NS %s (%lf)"
-#: ../raster/r.walk/main.c:850
+#: ../raster/r.walk/main.c:845
#, c-format
msgid "Raster output map <%s> not found (no start_points given)"
msgstr ""
"No se encuentra el mapa ráster de salida <%s> (no se indican puntos de "
"inicio)"
-#: ../raster/r.walk/main.c:865
+#: ../raster/r.walk/main.c:860
#, c-format
msgid "Memory allocation error on reading start points from raster map %s"
msgstr ""
"Error de asignación de memoria al leer los puntos de inicio del mapa ráster %"
"s"
-#: ../raster/r.walk/main.c:868
+#: ../raster/r.walk/main.c:863
#, c-format
msgid "Reading %s... "
msgstr "Leyendo %s... "
-#: ../raster/r.walk/main.c:1395
+#: ../raster/r.walk/main.c:1390
#, c-format
msgid "Writing output raster map %s... "
msgstr "Escribiendo mapa ráster de salida %s... "
@@ -13904,13 +13869,19 @@
msgid "%s is not a valid rule"
msgstr "%s no es una regla válida"
-#: ../raster/r.mfilter/main.c:92
+#: ../raster/r.mfilter/main.c:85
msgid "Apply filter only to zero data values"
msgstr "Aplicar filtro sólo a valores cero de datos"
+#: ../raster/r.composite/main.c:71
+#, fuzzy
+msgid "raster, composite"
+msgstr "ráster, importar"
#: ../raster/r.composite/main.c:73
+#, fuzzy
msgid ""
-"Combines red, green and blue map layers into a single composite map layer."
+"Combines red, green and blue map layers into a single composite raster map."
msgstr ""
"Combina capas de mapa roja, verde y azul en una sola capa de mapa compuesto."
@@ -13928,22 +13899,33 @@
msgid "Number of levels to be used for <%s>"
msgstr "Número de niveles a usar para <%s>"
-#: ../raster/r.composite/main.c:132
+#: ../raster/r.composite/main.c:128
msgid "Dither"
msgstr "Vacilar"
-#: ../raster/r.composite/main.c:136
+#: ../raster/r.composite/main.c:132
msgid "Use closest color"
msgstr "Usar el color más próximo"
-#: ../raster/r.composite/main.c:221
+#: ../raster/r.composite/main.c:203
+#, fuzzy, c-format
+msgid "Writing raster map <%s>..."
+msgstr "Escribiendo mapa ráster <%s> ..."
+#: ../raster/r.composite/main.c:219
+#, fuzzy, c-format
+msgid "Error reading raster map <%s>"
+msgstr "Error al leer el mapa ráster [%s]."
+#: ../raster/r.composite/main.c:273 ../doc/raster/r.example/main.c:179
#, c-format
-msgid "Error reading '%s' map"
-msgstr "Error al leer el mapa '%s'"
+msgid "Failed writing raster map <%s>"
+msgstr "Fallo al escribir el mapa ráster <%s>"
-#: ../raster/r.composite/main.c:275
-msgid "G_put_raster_row failed (file system full?)"
-msgstr "G_put_raster_row falló (¿sistema de archivos lleno?)"
+#: ../raster/r.composite/main.c:314
+#, fuzzy
+msgid "Creating color table for output raster map..."
+msgstr "Creando tabla de colores para <%s en %s>..."
#: ../raster/r.gwflow/main.c:64
#, fuzzy
@@ -14108,10 +14090,23 @@
msgstr ""
"Nombre del mapa ráster que contiene los resultados (varias capas nuevas)"
+#: ../raster/wildfire/r.ros/main.c:291 ../display/d.vect/main.c:327
+msgid "Run verbosely"
+msgstr "Ejecutar con comentarios"
#: ../raster/wildfire/r.ros/main.c:295
msgid "Also produce maximum SPOTTING distance"
msgstr ""
+#: ../raster/wildfire/r.ros/main.c:304 ../raster/wildfire/r.spread/main.c:248
+#: ../display/d.vect/main.c:375 ../display/d.mon/pgms/release.c:37
+msgid ""
+"The '-v' flag is superseded and will be removed in future. Please use '--"
+"verbose' instead."
+msgstr ""
+"La opción '-v' está suplantado y se eliminará en el futuro. Por favor use '--"
+"verbose' en su lugar."
#: ../raster/wildfire/r.ros/main.c:396 ../raster/wildfire/r.ros/main.c:399
#: ../raster/wildfire/r.ros/main.c:402 ../raster/wildfire/r.ros/main.c:408
#: ../raster/wildfire/r.spread/main.c:388
@@ -14286,19 +14281,19 @@
msgid "Reading inputs..."
msgstr "Leyendo entradas..."
-#: ../raster/r.resample/main.c:55
+#: ../raster/r.resample/main.c:54
msgid "GRASS raster map layer data resampling capability."
msgstr "Capacidad de remuestreo de datos de capa de mapa ráster de GRASS."
-#: ../raster/r.resample/main.c:64
+#: ../raster/r.resample/main.c:63
msgid "Name of an input layer"
msgstr "Nombre de una capa de entrada"
-#: ../raster/r.resample/main.c:71
+#: ../raster/r.resample/main.c:70
msgid "Name of an output layer"
msgstr "Nombre de una capa de salida"
-#: ../raster/r.resample/main.c:166
+#: ../raster/r.resample/main.c:152
msgid "Creating new cats file..."
msgstr "Creando nuevo archivo de categorías..."
@@ -14311,11 +14306,11 @@
msgid "Reading input raster map <%s>..."
msgstr "Leyendo mapa ráster de entrada <%s>..."
-#: ../raster/r.buffer/main.c:58
+#: ../raster/r.buffer/main.c:54
msgid "raster, buffer"
msgstr "ráster, buffer"
-#: ../raster/r.buffer/main.c:60
+#: ../raster/r.buffer/main.c:56
msgid ""
"Creates a raster map layer showing buffer zones surrounding cells that "
"contain non-NULL category values."
@@ -14323,23 +14318,23 @@
"Crea una capa de mapa ráster que muestra zonas de buffer que rodean celdas "
"que contienen valores de categoría no NULOS."
-#: ../raster/r.buffer/main.c:72
+#: ../raster/r.buffer/main.c:68
msgid "Distance zone(s)"
msgstr "Zona(s) de distancia"
-#: ../raster/r.buffer/main.c:79
+#: ../raster/r.buffer/main.c:75
msgid "Units of distance"
msgstr "Unidades de distancia"
-#: ../raster/r.buffer/main.c:84
+#: ../raster/r.buffer/main.c:80
msgid "Ignore zero (0) data cells instead of NULL cells"
msgstr "Ignorar celdas de datos cero (0) en vez de celdas NULAS"
-#: ../raster/r.buffer/main.c:137
+#: ../raster/r.buffer/main.c:120
msgid "Parse distances error"
msgstr "Error de distancias de análisis"
-#: ../raster/r.buffer/main.c:157
+#: ../raster/r.buffer/main.c:140
#, c-format
msgid "Pass %d (of %d)"
msgstr "Pase %d (de %d)"
@@ -14609,7 +14604,7 @@
msgstr "El mapa vectorial <%s> está conectado por:"
#: ../vector/v.db.connect/main.c:150 ../display/d.what.vect/what.c:366
-#: ../display/d.vect/main.c:466 ../display/d.thematic.area/main.c:203
+#: ../display/d.vect/main.c:475 ../display/d.thematic.area/main.c:203
#, c-format
msgid "Database connection not defined"
msgstr "Conexión a la base de datos no definida"
@@ -14625,7 +14620,7 @@
#: ../vector/v.db.connect/main.c:170 ../vector/v.edit/select.c:524
#: ../vector/v.distance/main.c:337 ../vector/v.distance/main.c:371
#: ../vector/v.db.select/main.c:97 ../vector/v.what.rast/main.c:122
-#: ../vector/v.extrude/main.c:162 ../vector/v.sample/main.c:166
+#: ../vector/v.extrude/main.c:162 ../vector/v.sample/main.c:161
#: ../vector/v.generalize/misc.c:158 ../vector/v.surf.idw/read_sites.c:35
#: ../vector/v.overlay/main.c:254 ../vector/v.to.rast/support.c:126
#: ../vector/v.to.rast/support.c:261 ../vector/v.to.rast/vect2rast.c:51
@@ -14699,7 +14694,7 @@
#: ../vector/v.to.rast3/main.c:81 ../vector/v.reclass/main.c:113
#: ../vector/v.univar/main.c:131 ../vector/v.vol.rst/user1.c:92
-#: ../vector/v.label.sa/labels.c:76 ../vector/v.label/main.c:273
+#: ../vector/v.label.sa/labels.c:75 ../vector/v.label/main.c:273
#: ../vector/v.buffer/main.c:371 ../vector/v.class/main.c:104
#: ../ps/ps.map/catval.c:47 ../ps/ps.map/catval.c:105
#: ../ps/ps.map/catval.c:166
@@ -14707,7 +14702,7 @@
msgstr "No se puede obtener información de la capa para el mapa vectorial"
#: ../vector/v.to.rast3/main.c:93 ../vector/lidar/v.surf.bspline/main.c:307
-#: ../vector/v.univar/main.c:147 ../vector/v.sample/main.c:181
+#: ../vector/v.univar/main.c:147 ../vector/v.sample/main.c:176
#: ../vector/v.surf.idw/read_sites.c:49 ../vector/v.normal/main.c:150
#: ../vector/v.buffer/main.c:383 ../vector/v.class/main.c:124
#: ../ps/ps.map/catval.c:64 ../ps/ps.map/catval.c:125
@@ -14717,7 +14712,7 @@
#: ../vector/v.to.rast3/main.c:97 ../vector/lidar/v.surf.bspline/main.c:304
#: ../vector/v.univar/main.c:145 ../vector/v.what.rast/main.c:151
-#: ../vector/v.sample/main.c:258 ../vector/v.surf.idw/read_sites.c:46
+#: ../vector/v.sample/main.c:251 ../vector/v.surf.idw/read_sites.c:46
#: ../vector/v.buffer/main.c:388 ../vector/v.class/main.c:121
msgid "Column type not supported"
msgstr "Tipo de columna no soportado"
@@ -15073,8 +15068,9 @@
#: ../vector/v.edit/args.c:155 ../vector/v.edit/args.c:158
#: ../vector/v.edit/args.c:171 ../vector/v.in.ogr/main.c:126
#: ../vector/v.in.ogr/main.c:139 ../vector/v.in.ogr/main.c:160
-#: ../display/d.vect/main.c:176 ../display/d.vect/main.c:179
-#: ../display/d.vect/main.c:337 ../display/d.thematic.area/main.c:106
+#: ../display/d.vect/main.c:146 ../display/d.vect/main.c:150
+#: ../display/d.vect/main.c:153 ../display/d.vect/main.c:156
+#: ../display/d.vect/main.c:346 ../display/d.thematic.area/main.c:106
msgid "Query"
msgstr "Consulta"
@@ -16500,22 +16496,22 @@
msgid "Please specify reasonable z column"
msgstr "Por favor, especifique una columna Z razonable"
-#: ../vector/v.in.ascii/in.c:247
+#: ../vector/v.in.ascii/in.c:249
#, c-format
msgid "Maximum input row length: %d"
msgstr "Longitud máxima de fila de entrada: %d"
-#: ../vector/v.in.ascii/in.c:248
+#: ../vector/v.in.ascii/in.c:250
#, c-format
msgid "Maximum number of columns: %d"
msgstr "Número máximo de columnas: %d"
-#: ../vector/v.in.ascii/in.c:249
+#: ../vector/v.in.ascii/in.c:251
#, c-format
msgid "Minimum number of columns: %d"
msgstr "Número mínimo de columnas: %d"
-#: ../vector/v.in.ascii/in.c:255
+#: ../vector/v.in.ascii/in.c:257
msgid ""
"x column number > minimum last column number\n"
"(incorrect field separator?)"
@@ -16523,7 +16519,7 @@
"número de la columna X >mínimo número de la última columna\n"
"(¿separador de campo incorrecto?)"
-#: ../vector/v.in.ascii/in.c:260
+#: ../vector/v.in.ascii/in.c:262
msgid ""
"y column number > minimum last column number\n"
@@ -16531,41 +16527,41 @@
"número de la columna Y >mínimo número de la última columna\n"
-#: ../vector/v.in.ascii/in.c:264
+#: ../vector/v.in.ascii/in.c:266
msgid ""
"z column number > minimum last column number (incorrect field separator?)"
msgstr ""
"Número de la columna Z >mínimo número de la última columna (¿separador de "
"campo incorrecto?)"
-#: ../vector/v.in.ascii/in.c:269
+#: ../vector/v.in.ascii/in.c:271
msgid ""
"cat column number > minimum last column number (incorrect field separator?)"
msgstr ""
"Número de la columna de categoría >mínimo número de la última columna "
-#: ../vector/v.in.ascii/in.c:275
+#: ../vector/v.in.ascii/in.c:277
msgid "x column is not of number type"
msgstr "la columna X no es de tipo numérico"
-#: ../vector/v.in.ascii/in.c:279
+#: ../vector/v.in.ascii/in.c:281
msgid "y column is not of number type"
msgstr "la columna Y no es de tipo numérico"
-#: ../vector/v.in.ascii/in.c:283
+#: ../vector/v.in.ascii/in.c:285
msgid "z column is not of number type"
msgstr "la columna Z no es de tipo numérico"
-#: ../vector/v.in.ascii/in.c:287
+#: ../vector/v.in.ascii/in.c:289
msgid "cat column is not of number type"
msgstr "la columna de categoría no es de tipo numérico"
-#: ../vector/v.in.ascii/in.c:329
+#: ../vector/v.in.ascii/in.c:331
msgid "Category column is not of integer type"
msgstr "La columna de categoría no es de tipo entero"
-#: ../vector/v.in.ascii/in.c:411
+#: ../vector/v.in.ascii/in.c:413
#, c-format
msgid ""
"Number of columns defined (%d) does not match number of columns (%d) in input"
@@ -16573,49 +16569,49 @@
"El número de columnas definidas (%d) no concuerda con el número de columnas "
"(%d) en la entrada"
-#: ../vector/v.in.ascii/in.c:438
+#: ../vector/v.in.ascii/in.c:440
#, c-format
msgid "Column number %d defined as double has only integer values"
msgstr "La columna número %d definida como doble sólo tiene valores enteros"
-#: ../vector/v.in.ascii/in.c:442
+#: ../vector/v.in.ascii/in.c:444
#, c-format
msgid "Column number %d defined as string has only integer values"
msgstr "La columna número %d definida como cadena sólo tiene valores enteros"
-#: ../vector/v.in.ascii/in.c:450
+#: ../vector/v.in.ascii/in.c:452
#, c-format
msgid "Column number %d defined as integer has double values"
msgstr "La columna número %d definida como entero tiene valores dobles"
-#: ../vector/v.in.ascii/in.c:454
+#: ../vector/v.in.ascii/in.c:456
#, c-format
msgid "Column number %d defined as string has double values"
msgstr "La columna número %d definida como cadena tiene valores dobles"
-#: ../vector/v.in.ascii/in.c:462
+#: ../vector/v.in.ascii/in.c:464
#, c-format
msgid "Column number %d defined as integer has string values"
msgstr "La columna número %d definida como entero tiene valores de cadena"
-#: ../vector/v.in.ascii/in.c:468
+#: ../vector/v.in.ascii/in.c:470
#, c-format
msgid "Column number %d defined as double has string values"
msgstr "La columna número %d definida como doble sólo tiene valores de cadena"
-#: ../vector/v.in.ascii/in.c:474
+#: ../vector/v.in.ascii/in.c:476
#, c-format
msgid "Length of column %d (%d) is less than maximum value length (%d)"
msgstr ""
"La longitud de la columna %d (%d) es menor que la longitud del valor máximo "
"(%d)"
-#: ../vector/v.in.ascii/in.c:495
+#: ../vector/v.in.ascii/in.c:497
#, c-format
msgid "Unable to create index for table <%s>, key <%s>"
msgstr "No se puede crear el índice para la tabla <%s>, clave <%s>"
-#: ../vector/v.in.ascii/in.c:513
+#: ../vector/v.in.ascii/in.c:515
msgid "Populating table..."
msgstr "Rellenando la tabla..."
@@ -16642,7 +16638,7 @@
msgid "Importing points..."
msgstr "Importando puntos..."
-#: ../vector/v.in.ascii/points.c:388 ../vector/v.mkgrid/main.c:263
+#: ../vector/v.in.ascii/points.c:388 ../vector/v.mkgrid/main.c:248
#, c-format
msgid "Unable to insert new record: %s"
msgstr "No se puede insertar el nuevo registro: %s"
@@ -16963,9 +16959,9 @@
msgid "More points (%d) of category %d, value set to 'NULL'"
msgstr "Más puntos (%d) de categoría %d, el valor se establece a 'NULO'"
-#: ../vector/v.what.rast/main.c:294 ../vector/v.sample/main.c:244
-#: ../vector/v.sample/main.c:252 ../vector/v.vol.rst/user1.c:157
-#: ../vector/v.label.sa/labels.c:165 ../vector/v.label/main.c:318
+#: ../vector/v.what.rast/main.c:294 ../vector/v.sample/main.c:237
+#: ../vector/v.sample/main.c:245 ../vector/v.vol.rst/user1.c:157
+#: ../vector/v.label.sa/labels.c:164 ../vector/v.label/main.c:318
#: ../vector/v.buffer/main.c:433 ../vector/v.buffer/main.c:442
#: ../vector/v.buffer/main.c:501 ../vector/v.buffer/main.c:510
#, c-format
@@ -17246,17 +17242,17 @@
msgstr ""
"Sólo calcular desviación estándar óptima y salir (no se escribe ningún mapa)"
-#: ../vector/v.kernel/main.c:207
+#: ../vector/v.kernel/main.c:194
#, c-format
msgid "Network input map <%s> not found"
msgstr "Mapa de red de entrada <%s> no encontrado"
-#: ../vector/v.kernel/main.c:227
+#: ../vector/v.kernel/main.c:214
#, c-format
msgid "%d points outside threshold"
msgstr "%d puntos fuera del umbral"
-#: ../vector/v.kernel/main.c:252
+#: ../vector/v.kernel/main.c:239
#, c-format
msgid ""
"Automatic choose of smoothing parameter (standard deviation), maximum "
@@ -17265,22 +17261,22 @@
"Elección automática de parámetro de suavizado (desviación estándar), el "
"máximo valor posible de desviación estándar se estableció a %f"
-#: ../vector/v.kernel/main.c:259
+#: ../vector/v.kernel/main.c:246
#, c-format
msgid "Using maximum distance between points: %f"
msgstr "Usando la distancia máxima entre puntos: %f"
-#: ../vector/v.kernel/main.c:271
+#: ../vector/v.kernel/main.c:258
#, c-format
msgid "Number of input points: %d."
msgstr "Número de puntos de entrada: %d."
-#: ../vector/v.kernel/main.c:272
+#: ../vector/v.kernel/main.c:259
#, c-format
msgid "%d distances read from the map."
msgstr "%d distancias leídas del mapa."
-#: ../vector/v.kernel/main.c:275
+#: ../vector/v.kernel/main.c:262
#, c-format
msgid ""
"Distances between all points are beyond %e (4 * standard deviation), unable "
@@ -17289,12 +17285,12 @@
"Las distancias entre todos los puntos están más allá de %e (4 * desviación "
"estándar). No se puede calcular el valor óptimo."
-#: ../vector/v.kernel/main.c:285
+#: ../vector/v.kernel/main.c:272
#, c-format
msgid "Optimal smoothing parameter (standard deviation): %f."
msgstr "Parámetro de suavizado óptimo (desviación estándar): %f."
-#: ../vector/v.kernel/main.c:307
+#: ../vector/v.kernel/main.c:294
#, c-format
msgid ""
"\n"
@@ -17303,7 +17299,7 @@
"\n"
"Escribiendo mapa vectorial de salida usando parámetro de suavizado=%f."
-#: ../vector/v.kernel/main.c:308 ../vector/v.kernel/main.c:372
+#: ../vector/v.kernel/main.c:295 ../vector/v.kernel/main.c:359
#, c-format
msgid ""
"\n"
@@ -17312,7 +17308,7 @@
"\n"
"Factor de normalización=%f."
-#: ../vector/v.kernel/main.c:371
+#: ../vector/v.kernel/main.c:358
#, c-format
msgid ""
"\n"
@@ -17321,11 +17317,11 @@
"\n"
"Escribiendo mapa ráster de salida usando parámetro de suavizado=%f."
-#: ../vector/v.kernel/main.c:379
+#: ../vector/v.kernel/main.c:366
msgid "Unable to read MASK"
msgstr "No se puede leer MASK"
-#: ../vector/v.kernel/main.c:403
+#: ../vector/v.kernel/main.c:390
#, c-format
msgid "Maximum value in output: %e."
msgstr "Valor máximo en la salida: %e."
@@ -17367,28 +17363,28 @@
msgid "Cubic convolution interpolation (default is nearest neighbor)"
msgstr "Interpolación de convolución cúbica (por omisión, vecino más próximo)"
-#: ../vector/v.sample/main.c:142
+#: ../vector/v.sample/main.c:137
msgid "Flags -b & -c are mutually exclusive. Choose only one."
msgstr "Las opciones -b y -c son excluyentes entre sí. Elija sólo una."
-#: ../vector/v.sample/main.c:178
+#: ../vector/v.sample/main.c:173
#, c-format
msgid "Column type <%s> not supported (must be integer or double precision)"
msgstr ""
"El tipo de columna <%s> no está soportado (debe ser entero o precisión doble)"
-#: ../vector/v.sample/main.c:183 ../vector/v.surf.idw/read_sites.c:51
+#: ../vector/v.sample/main.c:178 ../vector/v.surf.idw/read_sites.c:51
#: ../vector/v.normal/main.c:151 ../vector/v.to.db/report.c:165
#, c-format
msgid "%d records selected from table"
msgstr "%d registros seleccionados de la tabla"
-#: ../vector/v.sample/main.c:210 ../vector/v.patch/main.c:298
+#: ../vector/v.sample/main.c:205 ../vector/v.patch/main.c:298
#, c-format
msgid "Unable to create table <%s>"
msgstr "No se puede crear la tabla <%s>"
-#: ../vector/v.sample/main.c:219
+#: ../vector/v.sample/main.c:213
msgid "Checking vector points..."
msgstr "Comprobando puntos vectoriales..."
@@ -17988,7 +17984,7 @@
msgstr "Eliminar puentes:"
#: ../vector/v.in.ogr/main.c:907 ../vector/v.overlay/area_area.c:71
-#: ../vector/v.voronoi/dt_main.c:122 ../vector/v.buffer/main.c:624
+#: ../vector/v.voronoi/dt_main.c:137 ../vector/v.buffer/main.c:624
#: ../vector/v.buffer/main.c:699
msgid "Cannot calculate area centroid"
msgstr "Imposible calcular el centroide del área"
@@ -18403,39 +18399,39 @@
msgid "Cannot open %s"
msgstr "No se puede abrir %s"
-#: ../vector/v.qcount/main.c:69
+#: ../vector/v.qcount/main.c:68
#, fuzzy
msgid "Indices for quadrat counts of sites lists."
msgstr "lugares"
-#: ../vector/v.qcount/main.c:75
+#: ../vector/v.qcount/main.c:74
msgid "Vector of points defining sample points"
msgstr "Vectoria de puntos que define los puntos de muestra"
-#: ../vector/v.qcount/main.c:82
+#: ../vector/v.qcount/main.c:81
#, fuzzy
msgid "Output quadrant centres, number of points is written as category"
msgstr "Salida puntos"
-#: ../vector/v.qcount/main.c:89
+#: ../vector/v.qcount/main.c:88
#, fuzzy
msgid "Number of quadrats"
msgstr "Número de marcos"
-#: ../vector/v.qcount/main.c:96
+#: ../vector/v.qcount/main.c:95
msgid "Quadrat radius"
msgstr ""
-#: ../vector/v.qcount/main.c:101
+#: ../vector/v.qcount/main.c:100
msgid "Print results in shell script style"
msgstr "Imprimir resultados en estilo de script de consola"
-#: ../vector/v.qcount/main.c:132
+#: ../vector/v.qcount/main.c:118
#, fuzzy
msgid "Finding quadrats..."
msgstr "Imprimiendo ... "
-#: ../vector/v.qcount/main.c:137
+#: ../vector/v.qcount/main.c:123
#, fuzzy
msgid "Counting sites in quadrats..."
msgstr "lugares."
@@ -18669,60 +18665,56 @@
msgid "Writing out vector columns..."
msgstr "Escribiendo columnas del vectorial de salida..."
-#: ../vector/v.mkgrid/main.c:63
+#: ../vector/v.mkgrid/main.c:62
msgid "Creates a GRASS vector map of a user-defined grid."
msgstr ""
"Crea un mapa vectorial de GRASS de una cuadrícula definida por el usuario."
-#: ../vector/v.mkgrid/main.c:74
+#: ../vector/v.mkgrid/main.c:73
msgid "Number of rows and columns in grid"
msgstr "Número de filas y columnas en la cuadrícula"
-#: ../vector/v.mkgrid/main.c:83
+#: ../vector/v.mkgrid/main.c:82
msgid "Where to place the grid"
msgstr "Dónde colocar la cuadrícula"
-#: ../vector/v.mkgrid/main.c:84
+#: ../vector/v.mkgrid/main.c:83
msgid "region;current region;coor;use 'coor' and 'box' options"
msgstr "region;región actual;coor;usar las opciones 'coor' y 'box'"
-#: ../vector/v.mkgrid/main.c:93
+#: ../vector/v.mkgrid/main.c:92
msgid "Lower left easting and northing coordinates of map"
msgstr "Coordenadas inferior izquierda Este y Norte del mapa"
-#: ../vector/v.mkgrid/main.c:101
+#: ../vector/v.mkgrid/main.c:100
msgid "Width and height of boxes in grid"
msgstr "Anchura y altura de cuadros en la cuadrícula"
-#: ../vector/v.mkgrid/main.c:107
+#: ../vector/v.mkgrid/main.c:106
msgid "Angle of rotation (in degrees counter-clockwise)"
msgstr "Ángulo de rotación (en grados en el sentido de las agujas del reloj)"
-#: ../vector/v.mkgrid/main.c:113
-msgid "Quiet; No chatter"
-msgstr "En silencio; Sin comentarios"
-#: ../vector/v.mkgrid/main.c:165
+#: ../vector/v.mkgrid/main.c:150
msgid "'coor' option missing"
msgstr "Falta la opción 'coor'"
-#: ../vector/v.mkgrid/main.c:168
+#: ../vector/v.mkgrid/main.c:153
msgid "'box' option missing"
msgstr "Falta la opción 'box'"
-#: ../vector/v.mkgrid/main.c:171
+#: ../vector/v.mkgrid/main.c:156
msgid "Invalid easting"
msgstr "Este no válido"
-#: ../vector/v.mkgrid/main.c:173
+#: ../vector/v.mkgrid/main.c:158
msgid "Invalid northing"
msgstr "Norte no válido"
-#: ../vector/v.mkgrid/main.c:176 ../vector/v.mkgrid/main.c:178
+#: ../vector/v.mkgrid/main.c:161 ../vector/v.mkgrid/main.c:163
msgid "Invalid distance"
msgstr "Distancia no válida"
-#: ../vector/v.mkgrid/main.c:232
+#: ../vector/v.mkgrid/main.c:217
msgid "Creating centroids..."
msgstr "Creando centroides..."
@@ -19153,7 +19145,7 @@
msgid "Collecting input attributes..."
msgstr "Recogiendo atributos de entrada..."
-#: ../vector/v.overlay/main.c:269 ../vector/v.label.sa/labels.c:161
+#: ../vector/v.overlay/main.c:269 ../vector/v.label.sa/labels.c:160
#: ../vector/v.label/main.c:312
msgid "Unable to select attributes"
msgstr "No se pueden seleccionar los atributos"
@@ -19270,47 +19262,47 @@
msgid "%d destination(s) unreachable (including points out of threshold)"
msgstr "Destino(s) %d inalcanzable(s) (incluyendo puntos fuera del umbral)"
-#: ../vector/v.label.sa/labels.c:69
+#: ../vector/v.label.sa/labels.c:68
#, c-format
msgid "Cannot allocate %d bytes of memory"
msgstr "No se pueden asignar %d de memoria"
-#: ../vector/v.label.sa/labels.c:87 ../display/d.text.freetype/main.c:326
+#: ../vector/v.label.sa/labels.c:86 ../display/d.text.freetype/main.c:326
msgid "Unable to initialise FreeType"
msgstr "No se puede inicializar FreeType"
-#: ../vector/v.label.sa/labels.c:90
+#: ../vector/v.label.sa/labels.c:89
#, c-format
msgid "Unable to find font '%s'\n"
msgstr "No se puede encontrar la fuente '%s'\n"
-#: ../vector/v.label.sa/labels.c:92
+#: ../vector/v.label.sa/labels.c:91
#, c-format
msgid "Font '%s' is not a FreeType font\n"
msgstr "La fuente '%s' no es una fuente FreeType\n"
-#: ../vector/v.label.sa/labels.c:95
+#: ../vector/v.label.sa/labels.c:94
msgid "Font file format is not supported by FreeType"
msgstr "El formato de archivo de fuentes no está soportado por FreeType"
-#: ../vector/v.label.sa/labels.c:97
+#: ../vector/v.label.sa/labels.c:96
msgid "Font file can not be loaded"
msgstr "No se puede cargar el archivo de fuentes"
-#: ../vector/v.label.sa/labels.c:106
+#: ../vector/v.label.sa/labels.c:105
msgid "Unable to set font size"
msgstr "No se puede establecer el tamaño de fuente"
-#: ../vector/v.label.sa/labels.c:127
+#: ../vector/v.label.sa/labels.c:126
msgid "Cannot allocate more memory"
msgstr "No se puede asignar más memoria"
-#: ../vector/v.label.sa/labels.c:140 ../vector/v.label/main.c:291
+#: ../vector/v.label.sa/labels.c:139 ../vector/v.label/main.c:291
#: ../display/d.vect/plot1.c:285
msgid "Unable to read vector map"
msgstr "No se puede leer el mapa vectorial"
-#: ../vector/v.label.sa/labels.c:241
+#: ../vector/v.label.sa/labels.c:240
#, fuzzy, c-format
msgid "Cannot load glyph for '%c'"
msgstr "No se puede leer la cabecera del mapa para <%s>"
@@ -19323,76 +19315,76 @@
msgid "Create optimally placed labels for vector map(s)"
msgstr "Crear etiquetas situadas de forma óptima para el mapa(s) vectorial"
-#: ../vector/v.label.sa/main.c:105 ../vector/v.label/main.c:79
+#: ../vector/v.label.sa/main.c:130 ../vector/v.label/main.c:79
msgid "Name of attribute column to be used for labels"
msgstr "Nombre de columna de atributos a usar para etiquetas"
-#: ../vector/v.label.sa/main.c:109 ../vector/v.label/main.c:69
+#: ../vector/v.label.sa/main.c:134 ../vector/v.label/main.c:69
msgid "Name for new paint-label file"
msgstr "Nombre para el nuevo archivo de etiquetas de pintura"
-#: ../vector/v.label.sa/main.c:118
+#: ../vector/v.label.sa/main.c:143
#, fuzzy
msgid "Name of TrueType font (as listed in the fontcap)"
msgstr "Nombre de tipo de letra TrueType (tal como se lista en )"
-#: ../vector/v.label.sa/main.c:119 ../vector/v.label.sa/main.c:127
+#: ../vector/v.label.sa/main.c:144 ../vector/v.label.sa/main.c:152
#: ../vector/v.label/main.c:126 ../vector/v.label/main.c:133
#: ../vector/v.label/main.c:140 ../vector/v.label/main.c:148
#: ../vector/v.lrs/v.lrs.label/main.c:175
msgid "Font"
msgstr "Fuente"
-#: ../vector/v.label.sa/main.c:124 ../vector/v.label/main.c:130
+#: ../vector/v.label.sa/main.c:149 ../vector/v.label/main.c:130
#: ../vector/v.lrs/v.lrs.label/main.c:181
msgid "Label size (in map-units)"
msgstr "Tamaño de etiqueta (en unidades de mapa)"
-#: ../vector/v.label.sa/main.c:131
+#: ../vector/v.label.sa/main.c:156
msgid "Icon size of point features (in map-units)"
msgstr "Tamaño de icono para elementos punto (en unidades de mapa)"
-#: ../vector/v.label.sa/main.c:145 ../vector/v.label/main.c:151
+#: ../vector/v.label.sa/main.c:170 ../vector/v.label/main.c:151
#: ../vector/v.lrs/v.lrs.label/main.c:188 ../display/d.grid/main.c:84
msgid "Text color"
msgstr "Color de texto"
-#: ../vector/v.label.sa/main.c:154
+#: ../vector/v.label.sa/main.c:179
msgid "Hilight color for text"
msgstr "Color de resalte para texto"
-#: ../vector/v.label.sa/main.c:163 ../vector/v.label/main.c:180
+#: ../vector/v.label.sa/main.c:188 ../vector/v.label/main.c:180
msgid "Width of highlight coloring"
msgstr "Anchura de color resaltado"
-#: ../vector/v.label.sa/main.c:170 ../vector/v.label/main.c:187
+#: ../vector/v.label.sa/main.c:195 ../vector/v.label/main.c:187
#: ../vector/v.lrs/v.lrs.label/main.c:221 ../display/d.path/main.c:114
#: ../general/g.pnmcomp/main.c:356
msgid "Background color"
msgstr "Color de fondo"
-#: ../vector/v.label.sa/main.c:180 ../vector/v.label/main.c:200
+#: ../vector/v.label.sa/main.c:205 ../vector/v.label/main.c:200
msgid "Opaque to vector (only relevant if background color is selected)"
msgstr ""
"Opaco a vectorial (sólo relevante si está seleccionado el color de fondo)"
-#: ../vector/v.label.sa/main.c:189 ../vector/v.label/main.c:193
+#: ../vector/v.label.sa/main.c:214 ../vector/v.label/main.c:193
#: ../vector/v.lrs/v.lrs.label/main.c:229 ../display/d.grid/main.c:79
msgid "Border color"
msgstr "Color de límites"
-#: ../vector/v.label.sa/main.c:198
+#: ../vector/v.label.sa/main.c:223
msgid "Border width (only for ps.map output)"
msgstr "Anchura de límites (sólo para salida de mapa PS)"
-#: ../vector/v.label.sa/font.c:53
+#: ../vector/v.label.sa/font.c:55
#, c-format
msgid "%s: Unable to read font definition file; use the default"
msgstr ""
"%s: no se puede leer el archivo de definición de fuentes; se usa el "
"predeterminado"
-#: ../vector/v.label.sa/font.c:59
+#: ../vector/v.label.sa/font.c:61
#, c-format
msgid "%s: No font definition file"
msgstr "%s: ningún archivo de definición de fuentes"
@@ -19806,7 +19798,7 @@
msgid "Doing log transformation"
msgstr "Haciendo transformación del registro"
-#: ../vector/v.voronoi/dt_main.c:45
+#: ../vector/v.voronoi/dt_main.c:47
msgid ""
"Creates a Delaunay triangulation from an input vector map containing points "
"or centroids."
@@ -19814,14 +19806,19 @@
"Crea una triangulación de Delaunay a partir de un mapa vectorial de entrada "
"que contiene puntos o centroides."
-#: ../vector/v.voronoi/dt_main.c:53
+#: ../vector/v.voronoi/dt_main.c:55
msgid "Use only points in current region"
msgstr "Usar sólo puntos en la región actual"
-#: ../vector/v.voronoi/dt_main.c:58
+#: ../vector/v.voronoi/dt_main.c:60
msgid "Output triangulation as a graph (lines), not areas"
msgstr "Producir triangulación como un gráfo (líneas), no áreas"
+#: ../vector/v.voronoi/dt_main.c:144
+#, fuzzy
+msgid "Cannot calculate area centroid z coordinate"
+msgstr "Imposible calcular el centroide del área"
#: ../vector/v.voronoi/vo_main.c:108
msgid ""
"Creates a Voronoi diagram from an input vector map containing points or "
@@ -20481,7 +20478,7 @@
msgid "Reference position"
msgstr "Posición de referencia"
-#: ../vector/v.label/main.c:123 ../display/d.vect/main.c:268
+#: ../vector/v.label/main.c:123 ../display/d.vect/main.c:275
#: ../display/d.text.freetype/main.c:170 ../display/d.text.new/main.c:212
msgid "Font name"
msgstr "Nombre de fuente"
@@ -20506,7 +20503,7 @@
msgid "Highlight color for text"
msgstr "Color de texto resaltado"
-#: ../vector/v.label/main.c:232 ../imagery/i.class/main.c:85
+#: ../vector/v.label/main.c:232 ../imagery/i.class/main.c:87
#: ../imagery/i.points/main.c:79
#: ../imagery/i.ortho.photo/photo.2target/main.c:89
#: ../display/d.histogram/main.c:175 ../display/d.erase/main.c:57
@@ -20516,7 +20513,7 @@
#: ../display/d.what.rast/main.c:110 ../display/d.text/main.c:131
#: ../display/d.font.freetype/main.c:101 ../display/d.info/main.c:72
#: ../display/d.legend/main.c:271 ../display/d.graph/main.c:95
-#: ../display/d.vect/main.c:376 ../display/d.vect.chart/main.c:237
+#: ../display/d.vect/main.c:385 ../display/d.vect.chart/main.c:243
#: ../display/d.rast.arrow/arrow.c:246 ../display/d.menu/main.c:107
#: ../display/d.text.freetype/main.c:309 ../display/d.rast/main.c:114
#: ../display/d.extract/main.c:77 ../display/d.rgb/main.c:87
@@ -20681,7 +20678,7 @@
msgstr "No se está produciendo ningún mapa ráster ni vectorial"
#: ../vector/v.surf.rst/main.c:404 ../vector/v.extract/main.c:212
-#: ../display/d.vect/main.c:463
+#: ../display/d.vect/main.c:472
msgid "'layer' must be > 0 for 'where'."
msgstr "'layer' (capa) debe ser >0 para 'where' (donde)."
@@ -22152,11 +22149,6 @@
msgid "Unable to read file header of <%s>"
msgstr "No se puede leer la cabecera del archivo <%s>"
-#: ../doc/raster/r.example/main.c:179
-#, c-format
-msgid "Failed writing raster map <%s>"
-msgstr "Fallo al escribir el mapa ráster <%s>"
#: ../doc/vector/v.example/main.c:43
msgid "vector, keyword2, keyword3"
msgstr "vectorial, palabra clave 2, palabra clave 3"
@@ -22509,16 +22501,16 @@
msgstr "Las ventanas real e imaginaria original no coinciden."
#: ../imagery/i.ifft/ifftmain.c:53 ../imagery/i.gensigset/main.c:39
-#: ../imagery/i.his.rgb/h2rmain.c:44 ../imagery/i.group/main.c:49
+#: ../imagery/i.his.rgb/h2rmain.c:44 ../imagery/i.group/main.c:50
#: ../imagery/i.rgb.his/r2hmain.c:44 ../imagery/i.smap/shapiro/main.c:37
#: ../imagery/i.vpoints/main.c:53 ../imagery/i.pca/main.c:61
-#: ../imagery/i.class/main.c:50 ../imagery/i.rectify/main.c:55
+#: ../imagery/i.class/main.c:52 ../imagery/i.rectify/main.c:55
#: ../imagery/i.gensig/main.c:38 ../imagery/i.points/main.c:52
#: ../imagery/i.zc/main.c:56 ../imagery/i.fft/fftmain.c:73
#: ../imagery/i.cluster/main.c:57
#: ../imagery/i.ortho.photo/photo.2target/main.c:45
#: ../imagery/i.ortho.photo/menu/menu.c:42 ../imagery/i.maxlik/main.c:50
-#: ../imagery/i.cca/main.c:83 ../imagery/i.target/main.c:43
+#: ../imagery/i.cca/main.c:83 ../imagery/i.target/main.c:44
msgid "imagery"
msgstr "imaginería"
@@ -22653,104 +22645,115 @@
msgid "Unable to allocate the input row buffer"
msgstr "No se puede asignar el buffer de la fila de entrada"
-#: ../imagery/i.group/main.c:51
+#: ../imagery/i.group/main.c:52
msgid "Creates, edits, and lists groups and subgroups of imagery files."
msgstr "Crea, edita y lista grupos y subgrupos de archivos de imaginería."
-#: ../imagery/i.group/main.c:55 ../imagery/i.rectify/main.c:66
+#: ../imagery/i.group/main.c:56 ../imagery/i.rectify/main.c:66
#: ../imagery/i.ortho.photo/photo.2target/main.c:54
#: ../general/g.transform/main.c:245
msgid "Name of imagery group"
msgstr "Nombre de grupo imaginario"
-#: ../imagery/i.group/main.c:61
+#: ../imagery/i.group/main.c:62
msgid "Name of imagery sub-group"
msgstr "Nombre del subgrupo de imaginería"
-#: ../imagery/i.group/main.c:65
+#: ../imagery/i.group/main.c:66
#, fuzzy
msgid "Name of raster map(s) to include in group"
msgstr "Nombre del ráster(s) a incluir en el grupo"
-#: ../imagery/i.group/main.c:69
+#: ../imagery/i.group/main.c:70
msgid "Remove selected files from specified group"
msgstr "Eliminar archivos seleccionados del grupo especificado"
-#: ../imagery/i.group/main.c:73
+#: ../imagery/i.group/main.c:74
msgid "List files from specified (sub)group (fancy)"
msgstr "Lista archivos del (sub)grupo especificado (fancy)"
-#: ../imagery/i.group/main.c:78
+#: ../imagery/i.group/main.c:79
#, fuzzy
msgid "List files from specified (sub)group (shell script style)"
msgstr "Listar archivos de un (sub)grupo específico (simple)"
-#: ../imagery/i.group/main.c:98
+#: ../imagery/i.group/main.c:99
#, fuzzy
msgid "No input raster map(s) specified"
msgstr "Mapa(s) de entrada no especificado(s)."
-#: ../imagery/i.group/main.c:106 ../imagery/i.group/main.c:125
+#: ../imagery/i.group/main.c:110 ../imagery/i.class/main.c:100
+#: ../imagery/i.target/main.c:78
#, fuzzy
-msgid "Specified group does not exist"
+msgid "Group must exist in the current mapset"
+msgstr "%s ya es el directorio de mapas actual"
+#: ../imagery/i.group/main.c:120
+#, fuzzy
+msgid "Specified group does not exist in current mapset"
msgstr "El grupo especificado no existe... Saliendo."
-#: ../imagery/i.group/main.c:110
+#: ../imagery/i.group/main.c:124
#, fuzzy, c-format
msgid "Removing raster maps from subgroup <%s>..."
msgstr "Leyendo mapas ráster en el grupo <%s> ..."
-#: ../imagery/i.group/main.c:114
+#: ../imagery/i.group/main.c:128
#, fuzzy, c-format
msgid "Removing raster maps from group <%s>..."
-#: ../imagery/i.group/main.c:148
+#: ../imagery/i.group/main.c:139
+#, fuzzy
+msgid "Specified group does not exist"
+msgstr "El grupo especificado no existe... Saliendo."
+#: ../imagery/i.group/main.c:162
#, fuzzy, c-format
msgid "Group <%s> does not yet exist. Creating..."
msgstr "el grupo [%s] - no existe aún. Creándolo..."
-#: ../imagery/i.group/main.c:151 ../imagery/i.group/main.c:158
+#: ../imagery/i.group/main.c:165 ../imagery/i.group/main.c:172
#, fuzzy, c-format
msgid "Adding raster maps to group <%s>..."
-#: ../imagery/i.group/main.c:154
+#: ../imagery/i.group/main.c:168
#, fuzzy, c-format
msgid "Adding raster maps to subgroup <%s>..."
-#: ../imagery/i.group/main.c:183
+#: ../imagery/i.group/main.c:197
#, fuzzy, c-format
msgid "Adding raster map <%s> to group"
msgstr "Añadiendo mapa ráster [%s]"
-#: ../imagery/i.group/main.c:188
+#: ../imagery/i.group/main.c:202
#, fuzzy, c-format
msgid "Raster map <%s> exists in group. Skipping..."
msgstr "El mapa ráster [%s] existe en el grupo."
-#: ../imagery/i.group/main.c:221
+#: ../imagery/i.group/main.c:235
#, fuzzy, c-format
msgid "Adding raster map <%s> to subgroup"
-#: ../imagery/i.group/main.c:227
+#: ../imagery/i.group/main.c:241
#, fuzzy, c-format
msgid "Raster map <%s> exists in subgroup. Skipping..."
-#: ../imagery/i.group/main.c:273
+#: ../imagery/i.group/main.c:287
#, fuzzy, c-format
msgid "Removing raster map <%s> from group"
msgstr "No se encuentra el mapa ráster de elevación de entada <%s>"
-#: ../imagery/i.group/main.c:290 ../imagery/i.group/main.c:343
+#: ../imagery/i.group/main.c:304 ../imagery/i.group/main.c:357
#, fuzzy
msgid "No raster map removed"
msgstr "Ráster 3D a eliminar"
-#: ../imagery/i.group/main.c:326
+#: ../imagery/i.group/main.c:340
#, fuzzy, c-format
msgid "Removing raster map <%s> from subgroup"
msgstr "Borrando archivos del subgrupo"
@@ -22891,6 +22894,10 @@
msgid "Use maximum likelihood estimation (instead of smap)"
msgstr "Utilizar estimación máxima de probabilidad (en lugar de SMAP)"
+#: ../imagery/i.smap/shapiro/parse.c:54 ../imagery/i.maxlik/main.c:86
+msgid "Run quietly"
+msgstr "Ejecutar en modo silencioso"
#: ../imagery/i.smap/shapiro/parse.c:68
#, c-format
msgid "Group [%s] not found."
@@ -22912,7 +22919,7 @@
msgstr "El archuvo de firma [%s] no es válido."
#: ../imagery/i.vpoints/plot.c:62 ../imagery/i.vpoints/plot.c:145
-#: ../display/d.graph/do_graph.c:426 ../display/d.vect/main.c:443
+#: ../display/d.graph/do_graph.c:426 ../display/d.vect/main.c:452
msgid "Cannot read symbol, cannot display points"
msgstr "No se puede leer el símbolo, no se pueden mostrar los puntos"
@@ -23105,7 +23112,7 @@
msgid "Error reading raster map in function readbands."
msgstr "Error al leer mapa ráster en la función readbands."
-#: ../imagery/i.class/main.c:52
+#: ../imagery/i.class/main.c:54
msgid ""
"Generates spectral signatures for an image by allowing the user to outline "
"regions of interest."
@@ -23113,7 +23120,7 @@
"Genera firmas espectrales para una imagen permitiendo al usuario resaltar "
"regiones de interés."
-#: ../imagery/i.class/main.c:55
+#: ../imagery/i.class/main.c:57
msgid ""
"The resulting signature file can be used as input for i.maxlik or as a seed "
"signature file for i.cluster."
@@ -23121,51 +23128,51 @@
"El archivo de firmas resultante se puede usar como entrada para i.maxlik o "
"como un archivo de firma semilla para i.cluster."
-#: ../imagery/i.class/main.c:60
+#: ../imagery/i.class/main.c:62
msgid "Name of raster map to be displayed"
msgstr "Nombre del mapa ráster a visualizar"
-#: ../imagery/i.class/main.c:67 ../imagery/i.cca/main.c:92
+#: ../imagery/i.class/main.c:69 ../imagery/i.cca/main.c:92
msgid "Name of input imagery subgroup"
msgstr "Nombre del subgrupo de imaginería de entrada"
-#: ../imagery/i.class/main.c:72 ../imagery/i.cluster/main.c:77
+#: ../imagery/i.class/main.c:74 ../imagery/i.cluster/main.c:77
msgid "File to contain result signatures"
msgstr "Archivo para contener las firmas resultantes"
-#: ../imagery/i.class/main.c:77
+#: ../imagery/i.class/main.c:79
msgid "File containing input signatures (seed)"
msgstr "Archivo que contiene las firmas de entrada (seed)"
-#: ../imagery/i.class/main.c:89
+#: ../imagery/i.class/main.c:91
msgid "You have a mask set. Unset mask and run again"
msgstr "Tiene una máscara establecida. Quite la máscara y ejecute de nuevo"
-#: ../imagery/i.class/main.c:193
+#: ../imagery/i.class/main.c:209
#, c-format
msgid "** The following raster maps in subgroup [%s] do not exist:"
msgstr "** Los siguientes mapas ráster en el subgrupo [%s] no existen:"
-#: ../imagery/i.class/main.c:201
+#: ../imagery/i.class/main.c:217
#, c-format
msgid "Subgroup [%s] does not have any files"
msgstr "El subgrupo [%s] no tiene ningún archivo"
-#: ../imagery/i.class/main.c:202 ../imagery/i.class/main.c:205
+#: ../imagery/i.class/main.c:218 ../imagery/i.class/main.c:221
msgid "The subgroup must have at least 2 files to run"
msgstr "El subgrupo debe tener al menos dos archivos para ejecutarse"
-#: ../imagery/i.class/main.c:204 ../imagery/i.cluster/open_files.c:45
+#: ../imagery/i.class/main.c:220 ../imagery/i.cluster/open_files.c:45
#, c-format
msgid "Subgroup [%s] only has 1 file"
msgstr "El subgrupo [%s] sólo tiene un archivo"
-#: ../imagery/i.class/main.c:209
+#: ../imagery/i.class/main.c:225
msgid "Unable to read cell header for first band file"
msgstr ""
"No se puede leer la cabecera del ráster para el archivo de la primera banda"
-#: ../imagery/i.class/main.c:214
+#: ../imagery/i.class/main.c:230
msgid ""
"\n"
"RESULT SIGNATURE"
@@ -23173,12 +23180,12 @@
"\n"
"FIRMA RESULTANTE"
-#: ../imagery/i.class/main.c:217
+#: ../imagery/i.class/main.c:233
#, c-format
msgid "Unable to open output signature file '%s'"
msgstr "No se puede abrir el archivo de firmas de salida '%s'"
-#: ../imagery/i.class/main.c:223
+#: ../imagery/i.class/main.c:239
msgid ""
"\n"
"SEED SIGNATURES"
@@ -23186,17 +23193,17 @@
"\n"
"FIRMAS SEMILLA"
-#: ../imagery/i.class/main.c:227
+#: ../imagery/i.class/main.c:243
#, c-format
msgid "Unable to read signature file [%s]"
msgstr "No se puede leer el archivo de firmas [%s]"
-#: ../imagery/i.class/main.c:230
+#: ../imagery/i.class/main.c:246
#, c-format
msgid "** Unable to read signature file [%s] **"
msgstr "** No se puede leer el archivo de firmas [%s] **"
-#: ../imagery/i.class/main.c:237
+#: ../imagery/i.class/main.c:253
#, c-format
msgid "%s has too many signatures"
msgstr "%s tiene demasiadas firmas"
@@ -24230,38 +24237,38 @@
msgid "Transform completed.\n"
msgstr "Transformación finalizada.\n"
-#: ../imagery/i.target/main.c:45
+#: ../imagery/i.target/main.c:46
msgid "Targets an imagery group to a GRASS location and mapset."
msgstr ""
"Destina un grupo de imagen a una localización GRASS y un conjunto de mapas"
-#: ../imagery/i.target/main.c:54
+#: ../imagery/i.target/main.c:55
msgid "Name of imagery target location"
msgstr "Nombre de destino de la localización de imágenes"
-#: ../imagery/i.target/main.c:60
+#: ../imagery/i.target/main.c:61
msgid "Name of target mapset"
msgstr "Nombre de destino del conjunto de mapas"
-#: ../imagery/i.target/main.c:65
+#: ../imagery/i.target/main.c:66
msgid "Set current location and mapset as target for of imagery group"
msgstr ""
"Asignar la localización y el conjunto de mapas activo como destino del grupo "
"de imágenes"
-#: ../imagery/i.target/main.c:74 ../imagery/i.target/main.c:91
-#: ../imagery/i.target/main.c:99
+#: ../imagery/i.target/main.c:88 ../imagery/i.target/main.c:105
+#: ../imagery/i.target/main.c:113
#, c-format
msgid "Group <%s> targeted for location [%s], mapset [%s]"
msgstr ""
"El grupo <%s> se destinó a la localización [%s], conjunto de mapas [%s]"
-#: ../imagery/i.target/main.c:77
+#: ../imagery/i.target/main.c:91
#, c-format
msgid "Group <%s> has no target"
msgstr "El grupo <%s> no tiene destino"
-#: ../imagery/i.target/main.c:85
+#: ../imagery/i.target/main.c:99
msgid ""
"Use either the Current Mapset and Location Flag (-c)\n"
" OR\n"
@@ -24348,62 +24355,81 @@
msgstr "No se puede leer la fila ráster"
#: ../visualization/nviz/src/nviz_init.c:56
-msgid "visualization"
-msgstr "visualización"
+#, fuzzy
+msgid "raster, vector, visualization"
+msgstr "ráster, elevación, interpolación"
#: ../visualization/nviz/src/nviz_init.c:58
-msgid "nviz - Visualization and animation tool for GRASS data"
+#, fuzzy
+msgid "nviz - Visualization and animation tool for GRASS data."
msgstr "NVIZ - Herramienta de visualización y animación para datos de GRASS"
-#: ../visualization/nviz/src/nviz_init.c:66
-msgid "Raster file(s) for Elevation"
-msgstr "Archivo(s) ráster para elevación"
+#: ../visualization/nviz/src/nviz_init.c:63
+#, fuzzy
+msgid "Name of raster map(s) for Elevation"
+msgstr "Nombre del primer mapa ráster a mezclar"
-#: ../visualization/nviz/src/nviz_init.c:74
-msgid "Raster file(s) for Color"
-msgstr "Archivo(s) ráster para color"
+#: ../visualization/nviz/src/nviz_init.c:64
+#: ../visualization/nviz/src/nviz_init.c:73
+#: ../visualization/nviz/src/nviz_init.c:100
+#, fuzzy
+msgid "Raster"
+msgstr "ráster"
-#: ../visualization/nviz/src/nviz_init.c:82
-msgid "Vector lines/areas overlay file(s)"
+#: ../visualization/nviz/src/nviz_init.c:72
+#, fuzzy
+msgid "Name of raster map(s) for Color"
+msgstr "Nombre del mapa ráster"
+#: ../visualization/nviz/src/nviz_init.c:81
+#, fuzzy
+msgid "Name of vector lines/areas overlay map(s)"
msgstr "Las líneas/áreas vectoriales solapan el archivo(s)"
+#: ../visualization/nviz/src/nviz_init.c:82
+#: ../visualization/nviz/src/nviz_init.c:91
+#, fuzzy
+msgid "Vector"
+msgstr "vectorial"
#: ../visualization/nviz/src/nviz_init.c:90
-msgid "Vector points overlay file(s)"
+#, fuzzy
+msgid "Name of vector points overlay file(s)"
msgstr "Los puntos vectoriales solapan el archivo(s)"
-#: ../visualization/nviz/src/nviz_init.c:98
+#: ../visualization/nviz/src/nviz_init.c:99
msgid "Name of existing 3d raster map"
msgstr "Nombre de mapa ráster 3D existente"
-#: ../visualization/nviz/src/nviz_init.c:102
+#: ../visualization/nviz/src/nviz_init.c:104
msgid "Quickstart - Do not load any data"
msgstr "Inicio rápido - No cargar ningún dato"
-#: ../visualization/nviz/src/nviz_init.c:106
+#: ../visualization/nviz/src/nviz_init.c:108
msgid "Script kill option"
msgstr "Opción de matar el script"
-#: ../visualization/nviz/src/nviz_init.c:110
+#: ../visualization/nviz/src/nviz_init.c:112
msgid "Start in Demo mode"
msgstr "Empezar en modo Demo"
-#: ../visualization/nviz/src/nviz_init.c:114
+#: ../visualization/nviz/src/nviz_init.c:116
msgid "Output more comments (default=quiet)"
msgstr "Mostrar más comentarios (por omisión=silencio)"
-#: ../visualization/nviz/src/nviz_init.c:120
+#: ../visualization/nviz/src/nviz_init.c:122
msgid "Set alternative panel path"
msgstr "Establecer ruta de panel alternativa"
-#: ../visualization/nviz/src/nviz_init.c:126
+#: ../visualization/nviz/src/nviz_init.c:128
msgid "Execute script file at startup"
msgstr "Ejecutar archivo de comandos al inicio"
-#: ../visualization/nviz/src/nviz_init.c:132
+#: ../visualization/nviz/src/nviz_init.c:134
msgid "Load previosly saved state file"
msgstr "Cargar archivo de estado guardado previamente"
-#: ../visualization/nviz/src/nviz_init.c:280
+#: ../visualization/nviz/src/nviz_init.c:282
msgid "Number of elevation files does not match number of colors files"
msgstr ""
"El número de archivos de elevación no se ajusta al número de archivos de "
@@ -25158,7 +25184,8 @@
msgstr "Mostrar número de colores"
#: ../display/d.legend/main.c:86 ../display/d.graph/main.c:53
-#: ../display/d.barscale/main.c:55 ../display/d.grid/main.c:51
+#: ../display/d.vect.chart/main.c:62 ../display/d.barscale/main.c:55
+#: ../display/d.grid/main.c:51
msgid "display, cartography"
msgstr "mostrar, cartografía"
@@ -25440,119 +25467,125 @@
"\n"
"ERROR: el mapa vectorial - no se puede leer\n"
+#: ../display/d.vect/main.c:126
+#, fuzzy
+msgid "display, vector"
+msgstr "muestra, exporta"
#: ../display/d.vect/main.c:128
-msgid "Displays GRASS vector data in the active frame on the graphics monitor."
+#, fuzzy
+msgid "Displays vector data in the active frame on the graphics monitor."
msgstr "Muestra datos vectoriales de GRASS en el marco activo de la pantalla."
-#: ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:140
msgid "Display"
msgstr "Mostrar"
-#: ../display/d.vect/main.c:151 ../display/d.vect/main.c:230
-#: ../display/d.vect/main.c:238 ../display/d.vect/main.c:245
-#: ../display/d.vect/main.c:253 ../display/d.vect/main.c:261
-#: ../display/d.vect/main.c:267 ../display/d.vect/main.c:273
-#: ../display/d.vect/main.c:281
-msgid "Labels"
-msgstr "Etiquetas"
+#: ../display/d.vect/main.c:149 ../display/d.thematic.area/main.c:103
+msgid "Layer number. If -1, all layers are displayed."
+msgstr "Número de capa. Si es -1 se muestran todas las capas."
-#: ../display/d.vect/main.c:152
-msgid "Name of column to be displayed"
-msgstr "Nombre de la columna a mostrar"
-#: ../display/d.vect/main.c:159 ../display/d.vect/main.c:169
-msgid "Symbols"
-msgstr "Símbolos"
#: ../display/d.vect/main.c:163
-msgid "Point and centroid symbol"
-msgstr "Símbolo de punto y centroide"
+msgid "Line color"
+msgstr "Color de línea"
-#: ../display/d.vect/main.c:170
-msgid "Symbol size"
-msgstr "Tamaño de símbolo"
+#: ../display/d.vect/main.c:171
+msgid "Area fill color"
+msgstr "Color de relleno"
-#: ../display/d.vect/main.c:173 ../display/d.thematic.area/main.c:103
-msgid "Layer number. If -1, all layers are displayed."
-msgstr "Número de capa. Si es -1 se muestran todas las capas."
+#: ../display/d.vect/main.c:182
+msgid "Name of color definition column (for use with -a flag)"
+msgstr ""
+"Nombre de la columna de definición de color (para usar con la opción -a)"
-#: ../display/d.vect/main.c:185 ../display/d.vect/main.c:191
-#: ../display/d.vect/main.c:198
+#: ../display/d.vect/main.c:190 ../display/d.vect/main.c:196
+#: ../display/d.vect/main.c:203
msgid "Lines"
msgstr "Líneas"
-#: ../display/d.vect/main.c:186
+#: ../display/d.vect/main.c:191
msgid "Line width"
msgstr "Ancho de línea"
-#: ../display/d.vect/main.c:192
+#: ../display/d.vect/main.c:197
msgid "Name of column for line widths (these values will be scaled by wscale)"
msgstr ""
"Nombre de columna para anchuras de línea (estos valores se escalarán por "
"wscale)"
-#: ../display/d.vect/main.c:199
+#: ../display/d.vect/main.c:204
msgid "Scale factor for wcolumn"
msgstr "Factor de escala para columna de anchura (wcolumn)"
-#: ../display/d.vect/main.c:205
-msgid "Line color"
-msgstr "Color de línea"
+#: ../display/d.vect/main.c:212 ../display/d.vect/main.c:222
+msgid "Symbols"
+msgstr "Símbolos"
-#: ../display/d.vect/main.c:213
-msgid "Area fill color"
-msgstr "Color de relleno"
+#: ../display/d.vect/main.c:216
+msgid "Point and centroid symbol"
+msgstr "Símbolo de punto y centroide"
-#: ../display/d.vect/main.c:224
-msgid "Name of color definition column (for use with -a flag)"
-msgstr ""
-"Nombre de la columna de definición de color (para usar con la opción -a)"
+#: ../display/d.vect/main.c:223
+msgid "Symbol size"
+msgstr "Tamaño de símbolo"
-#: ../display/d.vect/main.c:231
+#: ../display/d.vect/main.c:231 ../display/d.vect/main.c:237
+#: ../display/d.vect/main.c:245 ../display/d.vect/main.c:252
+#: ../display/d.vect/main.c:260 ../display/d.vect/main.c:268
+#: ../display/d.vect/main.c:274 ../display/d.vect/main.c:280
+#: ../display/d.vect/main.c:288
+msgid "Labels"
+msgstr "Etiquetas"
+#: ../display/d.vect/main.c:232
+msgid "Name of column to be displayed"
+msgstr "Nombre de la columna a mostrar"
+#: ../display/d.vect/main.c:238
msgid "Layer for labels (default: the given layer number)"
msgstr "Capa para etiquetas (por omisión: el número de la capa dada)"
-#: ../display/d.vect/main.c:237
+#: ../display/d.vect/main.c:244
msgid "Label color"
msgstr "Color de etiqueta"
-#: ../display/d.vect/main.c:246
+#: ../display/d.vect/main.c:253
msgid "Label background color"
msgstr "Color de fondo de etiqueta"
-#: ../display/d.vect/main.c:254
+#: ../display/d.vect/main.c:261
msgid "Label border color"
msgstr "Color de borde de etiqueta"
-#: ../display/d.vect/main.c:262
+#: ../display/d.vect/main.c:269
msgid "Label size (pixels)"
msgstr "Tamaño de etiqueta (píxeles)"
-#: ../display/d.vect/main.c:276
+#: ../display/d.vect/main.c:283
msgid "Label horizontal justification"
msgstr "Justificación horizontal de etiqueta"
-#: ../display/d.vect/main.c:284
+#: ../display/d.vect/main.c:291
msgid "Label vertical justification"
msgstr "Justificación vertical de etiqueta"
-#: ../display/d.vect/main.c:290
+#: ../display/d.vect/main.c:297
msgid ""
"Minimum region size (average from height and width) when map is displayed"
msgstr ""
"Tamaño mínimo de región (media de altura y anchura) cuando se muestra el mapa"
-#: ../display/d.vect/main.c:298
+#: ../display/d.vect/main.c:305
msgid ""
"Maximum region size (average from height and width) when map is displayed"
msgstr ""
"Tamaño máximo de región (media de altura y anchura) cuando se muestra el mapa"
-#: ../display/d.vect/main.c:308 ../display/d.thematic.area/main.c:130
+#: ../display/d.vect/main.c:315 ../display/d.thematic.area/main.c:130
msgid "Rendering method for filled polygons"
msgstr "Método de renderizado para polígonos rellenos"
-#: ../display/d.vect/main.c:310 ../display/d.thematic.area/main.c:132
+#: ../display/d.vect/main.c:317 ../display/d.thematic.area/main.c:132
#, fuzzy
msgid ""
"g;use the libgis render functions (features: clipping);r;use the raster "
@@ -25568,11 +25601,11 @@
"visualización (funciones: clipping);l;usar las funciones de culling de la "
"biblioteca de visualización (funciones: culling, polilíneas)"
-#: ../display/d.vect/main.c:326
+#: ../display/d.vect/main.c:334
msgid "Get colors from map table column (of form RRR:GGG:BBB)"
msgstr "Tomar colores de columna de la tabla del mapa (en forma RRR:GGG:BBB)"
-#: ../display/d.vect/main.c:332
+#: ../display/d.vect/main.c:340
msgid ""
"Random colors according to category number (or layer number if 'layer=-1' is "
"given)"
@@ -25580,11 +25613,12 @@
"Colores aleatorios según el número de categoría (o número de capa si se da "
"'capa=-1')"
-#: ../display/d.vect/main.c:338
-msgid "Use values from 'cats' option as line ID"
+#: ../display/d.vect/main.c:347
+#, fuzzy
+msgid "Use values from 'cats' option as feature id"
msgstr "Usar valores de la opción 'cats' (categorías) como línea ID"
-#: ../display/d.vect/main.c:343 ../display/d.thematic.area/main.c:152
+#: ../display/d.vect/main.c:352 ../display/d.thematic.area/main.c:152
msgid ""
"Don't add to list of vectors and commands in monitor (it won't be drawn if "
"the monitor is refreshed)"
@@ -25592,15 +25626,15 @@
"No añadir a la lista de vectoriales y comandos en el monitor (no se "
"dibujarán si se refresca el monitor)"
-#: ../display/d.vect/main.c:386 ../display/d.paint.labels/main.c:99
+#: ../display/d.vect/main.c:395 ../display/d.paint.labels/main.c:99
msgid "Region size is lower than minreg, nothing displayed."
msgstr "El tamaño de la región es menor que minreg, no se muestra nada."
-#: ../display/d.vect/main.c:395 ../display/d.paint.labels/main.c:108
+#: ../display/d.vect/main.c:404 ../display/d.paint.labels/main.c:108
msgid "Region size is greater than maxreg, nothing displayed."
msgstr "La región es mayor que maxreg, no se muestra nada."
-#: ../display/d.vect/main.c:411
+#: ../display/d.vect/main.c:420
msgid ""
"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
"ignored!"
@@ -25608,41 +25642,41 @@
"Los modificadores '-c' y '-a' no se pueden usar juntos. ¡Se ignorará la "
"opción '-c'!"
-#: ../display/d.vect/main.c:425 ../display/d.vect/main.c:438
+#: ../display/d.vect/main.c:434 ../display/d.vect/main.c:447
#: ../display/d.thematic.area/main.c:271
#, c-format
msgid "Unknown color: [%s]"
msgstr "Color desconocido: [%s]"
-#: ../display/d.vect/main.c:490
+#: ../display/d.vect/main.c:499
msgid "'layer' must be > 0 for 'cats'."
msgstr "'layer' (capa) debe ser > 0 para 'cats' (categorías)."
-#: ../display/d.vect/main.c:494
+#: ../display/d.vect/main.c:503
#, c-format
msgid "%d errors in cat option"
msgstr "%d errores en la opción categoría"
-#: ../display/d.vect/main.c:614 ../display/d.thematic.area/main.c:322
+#: ../display/d.vect/main.c:623 ../display/d.thematic.area/main.c:322
msgid "Plotting ..."
msgstr "Imprimiendo ..."
-#: ../display/d.vect/main.c:623 ../display/d.thematic.area/main.c:330
+#: ../display/d.vect/main.c:632 ../display/d.thematic.area/main.c:330
msgid ""
"The bounding box of the map is outside the current region, nothing drawn."
msgstr ""
"Los limites del mapa están fuera de la región actual, no se muestra nada."
-#: ../display/d.vect/main.c:649
+#: ../display/d.vect/main.c:658
msgid "Cannot display areas, topology not available"
msgstr "No se pueden mostrar las superficies, topología no disponible"
-#: ../display/d.vect/main.c:654
+#: ../display/d.vect/main.c:663
msgid "Cannot display lines by id, topology not available"
msgstr ""
"No se pueden mostrar las líneas por ID, la topología no está disponible"
-#: ../display/d.vect/main.c:692
+#: ../display/d.vect/main.c:701
msgid "Cannot display topology, not available"
msgstr "No se puede mostrar la topología, no está disponible"
@@ -25676,9 +25710,9 @@
msgstr "Ningún atributo encontrado para la categoría %d: %s"
#: ../display/d.vect.chart/main.c:64
+#, fuzzy
msgid ""
-"Displays charts of GRASS vector data in the active frame on the graphics "
-"monitor"
+"Displays charts of vector data in the active frame on the graphics monitor."
msgstr ""
"Muestra gráficos de datos vectoriales de GRASS en el marco activo de la "
"pantalla"
@@ -25687,39 +25721,47 @@
msgid "Chart type"
msgstr "Tipo de gráfico"
-#: ../display/d.vect.chart/main.c:88
+#: ../display/d.vect.chart/main.c:82 ../display/d.vect.chart/main.c:96
+#: ../display/d.vect.chart/main.c:103 ../display/d.vect.chart/main.c:110
+#: ../display/d.vect.chart/main.c:118 ../display/d.vect.chart/main.c:127
+#: ../display/d.vect.chart/main.c:132
+#, fuzzy
+msgid "Chart properties"
+msgstr "Tipo de gráfico"
+#: ../display/d.vect.chart/main.c:89
msgid "Attribute columns containing data"
msgstr "Columnas de atributos que contienen datos"
-#: ../display/d.vect.chart/main.c:94
+#: ../display/d.vect.chart/main.c:95
msgid "Column used for pie chart size"
msgstr "Columna usada para tamaño de gráfico circular"
-#: ../display/d.vect.chart/main.c:100
+#: ../display/d.vect.chart/main.c:102
msgid "Size of chart (diameter for pie, total width for bar)"
msgstr "Tamaño de gráfico (diámetro para circular, anchura total para barras)"
-#: ../display/d.vect.chart/main.c:106
+#: ../display/d.vect.chart/main.c:109
msgid "Scale for size (to get size in pixels)"
msgstr "Escala para tamaño (para obtener tamaño en píxeles)"
-#: ../display/d.vect.chart/main.c:112
+#: ../display/d.vect.chart/main.c:116
msgid "Outline color"
msgstr "Color de contorno"
-#: ../display/d.vect.chart/main.c:120
+#: ../display/d.vect.chart/main.c:125
msgid "Colors used to fill charts"
msgstr "Colores usados para rellenar gráficos"
-#: ../display/d.vect.chart/main.c:125
+#: ../display/d.vect.chart/main.c:131
msgid "Center the bar chart around a data point"
msgstr "Centrar el gráfico de barras alrededor de un punto de datos"
-#: ../display/d.vect.chart/main.c:132
+#: ../display/d.vect.chart/main.c:139
msgid "Maximum value used for bar plot reference"
msgstr "Valor máximo usado para para referencia de trazado de barras"
-#: ../display/d.vect.chart/main.c:136 ../display/d.thematic.area/main.c:143
+#: ../display/d.vect.chart/main.c:143 ../display/d.thematic.area/main.c:143
msgid "Create legend information and send to stdout"
msgstr "Crear información de leyenda y enviar a stdout"
@@ -26964,6 +27006,118 @@
msgid "Error interpreting color %s"
msgstr "Error al leer el archivo de color para <%s>"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:163
+msgid "Raster elevation file name"
+msgstr "Nombre del archivo de elevación ráster"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:171
+msgid "Output slope filename"
+msgstr "Nombre de archivo de pendiente de salida"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:179
+msgid "Output aspect filename"
+msgstr "Nombre de archivo de orientación de salida"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:205
+msgid "Output profile curvature filename"
+msgstr "Nombre de archivo de curvatura de perfil de salida"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:214
+msgid "Output tangential curvature filename"
+msgstr "Nombre de archivo de curvatura tangencial de salida"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:223
+msgid "Output first order partial derivative dx (E-W slope) filename"
+msgstr ""
+"Nombre de archivo de derivada dx (pendiente E-W) parcial de primer orden de "
+"salida"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:232
+msgid "Output first order partial derivative dy (N-S slope) filename"
+msgstr ""
+"Nombre de archivo de derivada dy (pendiente N-S) parcial de primer orden de "
+"salida"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:241
+msgid "Output second order partial derivative dxx filename"
+msgstr "Nombre de archivo de derivada dxx parcial de segundo orden de salida"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:250
+msgid "Output second order partial derivative dyy filename"
+msgstr "Nombre de archivo de derivada dyy parcial de segundo orden de salida"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:259
+msgid "Output second order partial derivative dxy filename"
+msgstr "Nombre de archivo de derivada dxy parcial de segundo orden de salida"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:319
+msgid ""
+"The '-q' flag is superseded and will be removed in future. Please use '--"
+"quiet' instead."
+msgstr ""
+"La opción -q está suplantada y se eliminará en el futuro. Por favor, use '--"
+"quiet' en su lugar."
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:405
+#, c-format
+msgid "wrong type: %s"
+msgstr "tipo incorrecto: %s"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1037
+#, c-format
+msgid "Elevation products for mapset [%s] in [%s]"
+msgstr "Productos de elevación para el directorio de mapas [%s] en [%s]"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1108
+#, c-format
+msgid "ASPECT [%s] COMPLETE"
+msgstr "ORIENTACIÓN [%s] COMPLETA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1198
+#, c-format
+msgid "SLOPE [%s] COMPLETE"
+msgstr "PENDIENTE [%s] COMPLETA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1267
+#, c-format
+msgid "PROFILE CURVE [%s] COMPLETE"
+msgstr "CURVA DE PERFIL [%s] COMPLETA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1294
+#, c-format
+msgid "TANGENTIAL CURVE [%s] COMPLETE"
+msgstr "CURVA TANGENCIAL [%s] COMPLETA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1319
+#, c-format
+msgid "E-W SLOPE [%s] COMPLETE"
+msgstr "PENDIENTE E-W [%s] COMPLETA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1344
+#, c-format
+msgid "N-S SLOPE [%s] COMPLETE"
+msgstr "PENDIENTE N-S [%s] COMPLETA"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1369
+#, c-format
+msgid "DXX [%s] COMPLETE"
+msgstr "DXX [%s] COMPLETO"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1394
+#, c-format
+msgid "DYY [%s] COMPLETE"
+msgstr "DYY [%s] COMPLETO"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1419
+#, c-format
+msgid "DXY [%s] COMPLETE"
+msgstr "DXY [%s] COMPLETO"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:19
+#, c-format
+msgid "Failed in attempt to open %s"
+msgstr "Fallo al intentar de abrir %s"
#: ../general/g.gisenv/main.c:36 ../general/g.access/main.c:37
#: ../general/g.tempfile/main.c:35 ../general/g.pnmcomp/main.c:302
#: ../general/g.proj/main.c:54 ../general/g.transform/main.c:236
@@ -27446,20 +27600,35 @@
msgid "Name(s) of existing mapset(s) to add to search list"
msgstr "Nombre(s) de directorio(s) de mapas a añadir a la lista de búsqueda"
-#: ../general/g.mapsets/main_cmd.c:71
+#: ../general/g.mapsets/main_cmd.c:74
+#, fuzzy
+msgid "Name(s) of existing mapset(s) to remove from search list"
+msgstr "Nombre(s) de directorio(s) de mapas a añadir a la lista de búsqueda"
+#: ../general/g.mapsets/main_cmd.c:78
msgid "List all available mapsets"
msgstr "Listar todos los directorios de mapas disponibles"
-#: ../general/g.mapsets/main_cmd.c:75
+#: ../general/g.mapsets/main_cmd.c:82
msgid "Print current mapset search path"
msgstr "Imprimir la ruta de búsqueda del directorio de mapas actual"
-#: ../general/g.mapsets/main_cmd.c:97 ../general/g.mapsets/main_cmd.c:124
+#: ../general/g.mapsets/main_cmd.c:104 ../general/g.mapsets/main_cmd.c:131
#, fuzzy, c-format
msgid "Mapset <%s> not found"
msgstr "%s: no se encontró <%s>"
-#: ../general/g.mapsets/main_cmd.c:144
+#: ../general/g.mapsets/main_cmd.c:133
+#, fuzzy, c-format
+msgid "Mapset <%s> added to search path"
+msgstr "Directorio de mapas a listar (predeterminado: ruta de búsqueda actual)"
+#: ../general/g.mapsets/main_cmd.c:158
+#, c-format
+msgid "Mapset <%s> removed from search path"
+msgstr ""
+#: ../general/g.mapsets/main_cmd.c:181
msgid "Cannot open SEARCH_PATH for write"
msgstr "No se puede abrir SEARCH_PATH para escritura"
@@ -28120,7 +28289,48 @@
msgid "<%s> is now the default GUI"
msgstr ""
+#~ msgid "Quietly"
+#~ msgstr "De forma silenciosa"
#~ msgid ""
+#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
+#~ "quiet' instead"
+#~ msgstr ""
+#~ "La opción '-q' está suplantada y se eliminará en el futuro. Por favor, "
+#~ "use '--quiet' en su lugar"
+#~ msgid "Quiet - Do not show progress"
+#~ msgstr "Silencioso - no muestra el progreso"
+#~ msgid "Suppress single crossing error messages"
+#~ msgstr "Suprime mensaje de error de cruzamiento simple"
+#~ msgid ""
+#~ "The '-q' and '-n' flag is superseded and will be removed in future. "
+#~ "Please use '--quiet' instead."
+#~ msgstr ""
+#~ "Las opciones '-q' y '-n' son suplantadas y serán eliminadas en el futuro. "
+#~ "Por favor use '--quiet' en su lugar."
+#~ msgid "Error reading '%s' map"
+#~ msgstr "Error al leer el mapa '%s'"
+#~ msgid "G_put_raster_row failed (file system full?)"
+#~ msgstr "G_put_raster_row falló (¿sistema de archivos lleno?)"
+#~ msgid "Quiet; No chatter"
+#~ msgstr "En silencio; Sin comentarios"
+#~ msgid "visualization"
+#~ msgstr "visualización"
+#~ msgid "Raster file(s) for Elevation"
+#~ msgstr "Archivo(s) ráster para elevación"
+#~ msgid "Raster file(s) for Color"
+#~ msgstr "Archivo(s) ráster para color"
+#~ msgid ""
#~ "Not enough data columns. Incorrect delimiter or column number?\n"
#~ "[%s]"
#~ msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po 2008-05-06 19:11:33 UTC (rev 31269)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po 2008-05-06 20:47:18 UTC (rev 31270)
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grassmods_ru\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-01-24 17:42+0100\n"
+"POT-Creation-Date: 2008-05-06 20:32+0200\n"
"PO-Revision-Date: 2006-07-07 11:53+0200\n"
"Last-Translator: Markus Neteler <neteler at itc.it>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -17,17 +17,18 @@
#: ../db/base/execute.c:61 ../db/base/createdb.c:42 ../db/base/dropdb.c:42
#: ../db/base/tables.c:45 ../db/base/droptable.c:43 ../db/base/select.c:63
-#: ../db/base/columns.c:44 ../db/base/describe.c:49 ../db/base/databases.c:51
-#: ../vector/v.db.connect/main.c:171 ../vector/v.db.connect/main.c:226
-#: ../vector/v.edit/cmd/select.c:529 ../vector/v.out.svg/main.c:138
-#: ../vector/v.out.ogr/main.c:298 ../vector/v.extract/main.c:224
-#: ../display/d.vect/main.c:471
+#: ../db/base/columns.c:44 ../db/base/describe.c:51 ../db/base/databases.c:51
+#: ../vector/v.db.connect/main.c:173 ../vector/v.db.connect/main.c:228
+#: ../vector/v.edit/select.c:531 ../vector/v.out.svg/main.c:138
+#: ../vector/v.out.ogr/main.c:304 ../vector/v.extract/main.c:224
+#: ../display/d.vect/main.c:480 ../display/d.thematic.area/main.c:207
#, fuzzy, c-format
msgid "Unable to start driver <%s>"
msgstr " "
#: ../db/base/execute.c:67 ../db/base/tables.c:50 ../db/base/select.c:69
-#: ../db/base/describe.c:54 ../display/d.vect/main.c:476
+#: ../db/base/describe.c:56 ../display/d.vect/main.c:485
+#: ../display/d.thematic.area/main.c:212
#, fuzzy, c-format
msgid "Unable to open database <%s>"
msgstr " "
@@ -40,7 +41,7 @@
#: ../db/base/execute.c:108 ../db/base/createdb.c:71 ../db/base/copy.c:34
#: ../db/base/dropdb.c:71 ../db/base/tables.c:95 ../db/base/droptable.c:78
#: ../db/base/drivers.c:73 ../db/base/select.c:236 ../db/base/columns.c:91
-#: ../db/base/describe.c:124 ../db/base/databases.c:89 ../db/base/connect.c:41
+#: ../db/base/describe.c:126 ../db/base/databases.c:89 ../db/base/connect.c:44
#: ../db/db.login/main.c:42
msgid "database, SQL"
msgstr ""
@@ -175,7 +176,7 @@
msgid "For example: 'select * from rybniky where kapri = 'hodne'"
msgstr ""
-#: ../db/base/select.c:201 ../raster/r.distance/parse.c:50
+#: ../db/base/select.c:201 ../raster/r.distance/parse.c:47
#: ../raster/r.stats/main.c:108 ../raster/r.cats/main.c:70
#: ../vector/v.db.select/main.c:57
msgid "Output field separator"
@@ -219,23 +220,23 @@
msgid "List all columns for a given table."
msgstr ""
-#: ../db/base/describe.c:61 ../vector/v.db.connect/main.c:180
-#: ../vector/v.in.ascii/in.c:399 ../vector/v.patch/main.c:140
+#: ../db/base/describe.c:63 ../vector/v.db.connect/main.c:182
+#: ../vector/v.in.ascii/in.c:403 ../vector/v.patch/main.c:140
#: ../vector/v.patch/main.c:181 ../vector/v.out.svg/main.c:150
-#: ../vector/v.out.ogr/main.c:307
+#: ../vector/v.out.ogr/main.c:313
#, fuzzy, c-format
msgid "Unable to describe table <%s>"
msgstr " "
-#: ../db/base/describe.c:103
+#: ../db/base/describe.c:105
msgid "Print column names only instead of full column descriptions"
msgstr ""
-#: ../db/base/describe.c:108
+#: ../db/base/describe.c:110
msgid "Print table structure"
msgstr ""
-#: ../db/base/describe.c:125
+#: ../db/base/describe.c:127
msgid "Describes a table in detail."
msgstr ""
@@ -253,36 +254,57 @@
msgid "List all databases for a given driver and location."
msgstr ""
-#: ../db/base/connect.c:43
+#: ../db/base/connect.c:46
#, fuzzy
msgid "Prints/sets general DB connection for current mapset and exits."
msgstr "×ÅËÔÏÒ"
-#: ../db/base/connect.c:48
+#: ../db/base/connect.c:51
#, fuzzy
msgid "Print current connection parameters and exit"
msgstr "×ÅËÔÏÒ"
-#: ../db/base/connect.c:63
+#: ../db/base/connect.c:56
+#, fuzzy
+msgid "Check connection parameters, set if uninitialized, and exit"
+msgstr "×ÅËÔÏÒ"
+#: ../db/base/connect.c:71
msgid "Database schema"
msgstr ""
-#: ../db/base/connect.c:64
+#: ../db/base/connect.c:72
#, fuzzy
msgid ""
"Do not use this option if schemas are not supported by driver/database server"
msgstr " ."
-#: ../db/base/connect.c:73
+#: ../db/base/connect.c:81
#, fuzzy
msgid "Default group of database users to which select privilege is granted"
msgstr " ."
-#: ../db/base/connect.c:124
+#: ../db/base/connect.c:113
#, fuzzy
msgid "Database connection not defined. Run db.connect."
msgstr " "
+#: ../db/base/connect.c:133
+#, c-format
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+#: ../db/base/connect.c:139
+msgid "Default driver is not set"
+msgstr ""
+#: ../db/base/connect.c:142
+msgid "Default database is not set"
+msgstr ""
#: ../db/db.login/main.c:43
msgid "Sets user/password for driver/database."
msgstr ""
@@ -550,7 +572,7 @@
msgstr ""
#: ../raster3d/r3.out.ascii/main.c:100 ../raster/r.transect/main.c:84
-#: ../raster/r.what/main.c:113
+#: ../raster/r.what/main.c:114
msgid "Char string to represent no data cell"
msgstr ""
@@ -581,7 +603,7 @@
msgid "Error closing new ASCII file"
msgstr ""
-#: ../raster3d/r3.stats/main.c:565 ../raster/r.univar2/r3.univar_main.c:76
+#: ../raster3d/r3.stats/main.c:565 ../raster/r.univar2/r3.univar_main.c:78
#, fuzzy
msgid "raster3d, statistics"
msgstr " "
@@ -604,13 +626,13 @@
msgid "The number of subranges has to be equal or greater than 1"
msgstr ""
-#: ../raster3d/r3.stats/main.c:608 ../raster/r.univar2/r3.univar_main.c:102
+#: ../raster3d/r3.stats/main.c:608 ../raster/r.univar2/r3.univar_main.c:103
#, fuzzy, c-format
msgid "Requested g3d map <%s> not found"
msgstr " "
#: ../raster3d/r3.stats/main.c:615 ../raster3d/r3.gwflow/main.c:376
-#: ../raster/r.univar2/r3.univar_main.c:110
+#: ../raster/r.univar2/r3.univar_main.c:111
#, fuzzy, c-format
msgid "Error opening g3d map <%s>"
msgstr " "
@@ -820,12 +842,12 @@
#: ../raster3d/r3.out.v5d/main.c:197 ../raster3d/r3.to.rast/main.c:299
#: ../raster/r.li/r.li.daemon/list.c:43 ../raster/r.gwflow/main.c:376
-#: ../raster/r.to.rast3/main.c:228 ../vector/v.edit/cmd/a2b.c:191
+#: ../raster/r.to.rast3/main.c:228 ../vector/v.edit/a2b.c:191
#: ../vector/v.in.ascii/a2b.c:161 ../vector/v.generalize/smoothing.c:93
#: ../vector/v.generalize/smoothing.c:150
#: ../vector/v.generalize/smoothing.c:250
-#: ../vector/v.generalize/smoothing.c:368
-#: ../vector/v.generalize/smoothing.c:399
+#: ../vector/v.generalize/smoothing.c:373
+#: ../vector/v.generalize/smoothing.c:402
#: ../vector/v.generalize/simplification.c:33
#: ../vector/v.generalize/simplification.c:40
#: ../vector/v.generalize/simplification.c:306
@@ -1023,56 +1045,57 @@
#: ../raster3d/base/r3.info.main.c:123 ../raster/r.resamp.stats/main.c:302
#: ../raster/r.param.scale/interface.c:165 ../raster/r.surf.area/main.c:121
-#: ../raster/r.resamp.interp/main.c:102 ../raster/r.coin/cmd_parms.c:96
-#: ../raster/r.coin/cmd_parms.c:99 ../raster/r.distance/parse.c:78
-#: ../raster/r.distance/parse.c:85 ../raster/r.reclass/main.c:77
-#: ../raster/r.los/main.c:152 ../raster/r.los/main.c:158
+#: ../raster/r.resamp.interp/main.c:102 ../raster/r.coin/inter.c:40
+#: ../raster/r.coin/inter.c:44 ../raster/r.coin/cmd_parms.c:79
+#: ../raster/r.coin/cmd_parms.c:82 ../raster/r.distance/parse.c:63
+#: ../raster/r.distance/parse.c:70 ../raster/r.reclass/main.c:77
+#: ../raster/r.los/main.c:160 ../raster/r.los/main.c:166
#: ../raster/r.drain/main.c:155 ../raster/r.out.ascii/main.c:145
-#: ../raster/r.carve/main.c:173 ../raster/r.profile/main.c:142
-#: ../raster/r.texture/main.c:224 ../raster/r.basins.fill/main.c:92
+#: ../raster/r.carve/main.c:156 ../raster/r.profile/main.c:142
+#: ../raster/r.texture/main.c:212 ../raster/r.basins.fill/main.c:92
#: ../raster/r.basins.fill/main.c:104 ../raster/r.sum/main.c:64
#: ../raster/r.null/null.c:104 ../raster/r.average/main.c:71
#: ../raster/r.average/main.c:74 ../raster/r.out.gridatb/check_ready.c:13
#: ../raster/r.surf.idw2/read_cell.c:20 ../raster/r.transect/main.c:117
-#: ../raster/simwe/simlib/input.c:171 ../raster/simwe/simlib/input.c:176
-#: ../raster/simwe/simlib/input.c:181 ../raster/simwe/simlib/input.c:186
-#: ../raster/simwe/simlib/input.c:192 ../raster/simwe/simlib/input.c:198
-#: ../raster/simwe/simlib/input.c:205 ../raster/simwe/simlib/input.c:212
-#: ../raster/simwe/simlib/input.c:219 ../raster/simwe/simlib/input.c:226
-#: ../raster/simwe/simlib/input.c:233 ../raster/r.out.mat/main.c:94
+#: ../raster/simwe/simlib/input.c:177 ../raster/simwe/simlib/input.c:183
+#: ../raster/simwe/simlib/input.c:188 ../raster/simwe/simlib/input.c:197
+#: ../raster/simwe/simlib/input.c:205 ../raster/simwe/simlib/input.c:211
+#: ../raster/simwe/simlib/input.c:217 ../raster/simwe/simlib/input.c:224
+#: ../raster/simwe/simlib/input.c:231 ../raster/simwe/simlib/input.c:238
+#: ../raster/simwe/simlib/input.c:245 ../raster/r.out.mat/main.c:85
#: ../raster/r.to.rast3elev/main.c:114 ../raster/r.to.rast3elev/main.c:129
#: ../raster/r.statistics/main.c:75 ../raster/r.statistics/main.c:81
-#: ../raster/r.info/main.c:116 ../raster/r.patch/main.c:115
+#: ../raster/r.info/main.c:116 ../raster/r.patch/main.c:101
#: ../raster/r.grow2/main.c:185 ../raster/r.surf.idw/main.c:108
#: ../raster/r.thin/io.c:97 ../raster/r.flow/io.c:65
#: ../raster/r.topidx/check_ready.c:12 ../raster/r.out.pov/main.c:171
-#: ../raster/r.covar/main.c:96 ../raster/r.out.arc/main.c:110
-#: ../raster/r.report/parse.c:249 ../raster/r.random/main.c:106
+#: ../raster/r.covar/main.c:81 ../raster/r.out.arc/main.c:111
+#: ../raster/r.report/parse.c:247 ../raster/r.random/main.c:106
#: ../raster/r.random/main.c:111 ../raster/r.his/main.c:128
#: ../raster/r.his/main.c:169 ../raster/r.his/main.c:197
#: ../raster/r.bilinear/main.c:78 ../raster/r.kappa/stats.c:30
-#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:141
+#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:129
#: ../raster/r.median/main.c:73 ../raster/r.resamp.rst/main.c:400
#: ../raster/r.resamp.rst/main.c:426 ../raster/r.stats/main.c:263
-#: ../raster/r.slope.aspect/main.c:383 ../raster/r.colors/main.c:237
-#: ../raster/r.colors/main.c:323 ../raster/r.out.ppm/main.c:115
-#: ../raster/r.fill.dir/main.c:163 ../raster/r.mfilter.fp/main.c:124
-#: ../raster/r.cost/main.c:319 ../raster/r.out.vtk/main.c:47
+#: ../raster/r.slope.aspect/main.c:356 ../raster/r.colors/main.c:252
+#: ../raster/r.colors/main.c:338 ../raster/r.out.ppm/main.c:101
+#: ../raster/r.fill.dir/main.c:163 ../raster/r.mfilter.fp/main.c:110
+#: ../raster/r.cost/main.c:301 ../raster/r.out.vtk/main.c:47
#: ../raster/r.out.vtk/main.c:60 ../raster/r.support/modcolr/modcolr.c:43
#: ../raster/r.support/front/front.c:218 ../raster/r.out.bin/main.c:129
-#: ../raster/r.neighbors/main.c:180 ../raster/r.clump/main.c:88
-#: ../raster/r.to.vect/main.c:109 ../raster/r.region/main.c:161
+#: ../raster/r.neighbors/main.c:174 ../raster/r.clump/main.c:73
+#: ../raster/r.to.vect/main.c:96 ../raster/r.region/main.c:161
#: ../raster/r.region/main.c:218 ../raster/r.region/main.c:353
-#: ../raster/r.out.ppm3/main.c:117 ../raster/r.univar2/r.univar_main.c:93
+#: ../raster/r.out.ppm3/main.c:103 ../raster/r.univar2/r.univar_main.c:149
#: ../raster/r.watershed/ram/init_vars.c:341
-#: ../raster/r.watershed/seg/init_vars.c:371 ../raster/r.contour/main.c:156
-#: ../raster/r.cross/main.c:116 ../raster/r.cats/main.c:120
-#: ../raster/r.cats/main.c:140 ../raster/r.series/main.c:170
-#: ../raster/r.water.outlet/legal.c:23 ../raster/r.out.tiff/r.out.tiff.c:167
-#: ../raster/r.out.mpeg/main.c:222 ../raster/r.walk/main.c:523
-#: ../raster/r.walk/main.c:526 ../raster/r.mapcalc/map.c:380
-#: ../raster/r.recode/main.c:82 ../raster/r.mfilter/main.c:117
-#: ../raster/r.composite/main.c:162 ../raster/wildfire/r.ros/main.c:312
+#: ../raster/r.watershed/seg/init_vars.c:371 ../raster/r.contour/main.c:134
+#: ../raster/r.cross/main.c:99 ../raster/r.cats/main.c:120
+#: ../raster/r.cats/main.c:140 ../raster/r.series/main.c:156
+#: ../raster/r.water.outlet/legal.c:23 ../raster/r.out.tiff/r.out.tiff.c:151
+#: ../raster/r.out.mpeg/main.c:222 ../raster/r.walk/main.c:518
+#: ../raster/r.walk/main.c:521 ../raster/r.mapcalc/map.c:380
+#: ../raster/r.recode/main.c:82 ../raster/r.mfilter/main.c:103
+#: ../raster/r.composite/main.c:158 ../raster/wildfire/r.ros/main.c:312
#: ../raster/wildfire/r.ros/main.c:322 ../raster/wildfire/r.ros/main.c:326
#: ../raster/wildfire/r.ros/main.c:330 ../raster/wildfire/r.ros/main.c:334
#: ../raster/wildfire/r.ros/main.c:348 ../raster/wildfire/r.ros/main.c:352
@@ -1082,34 +1105,34 @@
#: ../raster/wildfire/r.spread/main.c:356
#: ../raster/wildfire/r.spread/main.c:363
#: ../raster/wildfire/r.spread/main.c:368
-#: ../raster/wildfire/r.spread/main.c:373 ../raster/r.resample/main.c:96
-#: ../raster/r.buffer/main.c:115 ../raster/r.support.stats/main.c:47
+#: ../raster/wildfire/r.spread/main.c:373 ../raster/r.resample/main.c:82
+#: ../raster/r.buffer/main.c:98 ../raster/r.support.stats/main.c:47
#: ../raster/r.bitpattern/main.c:101 ../vector/v.what.rast/main.c:132
-#: ../vector/v.extrude/main.c:178 ../vector/v.sample/main.c:157
+#: ../vector/v.extrude/main.c:178 ../vector/v.sample/main.c:152
#: ../vector/v.vol.rst/main.c:577 ../vector/v.drape/main.c:120
#: ../doc/raster/r.example/main.c:110 ../ps/ps.map/outl_io.c:72
#: ../imagery/i.his.rgb/openfiles.c:32 ../imagery/i.his.rgb/openfiles.c:37
-#: ../imagery/i.his.rgb/openfiles.c:42 ../imagery/i.group/main.c:181
-#: ../imagery/i.group/main.c:218 ../imagery/i.rgb.his/openfiles.c:15
+#: ../imagery/i.his.rgb/openfiles.c:42 ../imagery/i.group/main.c:195
+#: ../imagery/i.group/main.c:232 ../imagery/i.rgb.his/openfiles.c:15
#: ../imagery/i.rgb.his/openfiles.c:17 ../imagery/i.rgb.his/openfiles.c:19
-#: ../imagery/i.pca/main.c:122 ../imagery/i.class/main.c:108
+#: ../imagery/i.pca/main.c:122 ../imagery/i.class/main.c:124
#: ../imagery/i.gensig/parse.c:48 ../imagery/i.zc/main.c:110
#: ../imagery/i.fft/fftmain.c:120
#: ../imagery/i.ortho.photo/photo.2target/main.c:202
#: ../imagery/i.ortho.photo/photo.2target/main.c:236
#: ../visualization/xganim/main.c:342 ../display/d.histogram/main.c:157
#: ../display/d.profile/main.c:92 ../display/d.rast.num/number.c:150
-#: ../display/d.what.rast/main.c:150 ../display/d.title/main.c:105
-#: ../display/d.legend/main.c:252 ../display/d.rast.arrow/arrow.c:196
-#: ../display/d.rast.arrow/arrow.c:238 ../display/d.rast.arrow/arrow.c:374
-#: ../display/d.rast/main.c:111 ../display/d.rgb/main.c:100
-#: ../display/d.his/main.c:137 ../display/d.his/main.c:176
-#: ../display/d.his/main.c:204 ../display/d.zoom/main.c:218
-#: ../display/d.nviz/main.c:183 ../display/d.colortable/main.c:101
-#: ../display/d.extend/main.c:62
+#: ../display/d.what.rast/opencell.c:15 ../display/d.what.rast/main.c:150
+#: ../display/d.title/main.c:105 ../display/d.legend/main.c:252
+#: ../display/d.rast.arrow/arrow.c:196 ../display/d.rast.arrow/arrow.c:238
+#: ../display/d.rast.arrow/arrow.c:374 ../display/d.rast/main.c:111
+#: ../display/d.rgb/main.c:100 ../display/d.his/main.c:137
+#: ../display/d.his/main.c:176 ../display/d.his/main.c:204
+#: ../display/d.zoom/main.c:218 ../display/d.nviz/main.c:183
+#: ../display/d.colortable/main.c:101 ../display/d.extend/main.c:62
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:383
-#: ../general/g.region/cmd/main.c:449 ../general/g.region/cmd/main.c:813
-#: ../general/g.region/cmd/main.c:822
+#: ../general/g.region/main.c:451 ../general/g.region/main.c:815
+#: ../general/g.region/main.c:824
#, fuzzy, c-format
msgid "Raster map <%s> not found"
msgstr " "
@@ -1455,29 +1478,30 @@
msgstr " "
#: ../raster3d/r3.to.rast/main.c:183 ../raster/r.resamp.stats/main.c:346
-#: ../raster/r.resamp.interp/main.c:147 ../raster/r.los/main.c:193
-#: ../raster/r.in.ascii/main.c:210 ../raster/r.carve/main.c:182
-#: ../raster/r.texture/main.c:303 ../raster/r.basins.fill/main.c:116
+#: ../raster/r.resamp.interp/main.c:147 ../raster/r.los/main.c:201
+#: ../raster/r.in.ascii/main.c:211 ../raster/r.carve/main.c:165
+#: ../raster/r.texture/main.c:291 ../raster/r.basins.fill/main.c:116
#: ../raster/r.null/null.c:312 ../raster/r.surf.idw2/main.c:111
-#: ../raster/r.patch/main.c:147 ../raster/r.grow2/main.c:207
+#: ../raster/r.patch/main.c:133 ../raster/r.grow2/main.c:207
#: ../raster/r.circle/dist.c:127 ../raster/r.surf.idw/main.c:147
#: ../raster/r.thin/io.c:176 ../raster/r.li/r.li.daemon/daemon.c:113
#: ../raster/r.flow/io.c:179 ../raster/r.flow/io.c:217
-#: ../raster/r.in.gdal/main.c:722 ../raster/r.in.gdal/main.c:727
-#: ../raster/r.in.gdal/main.c:743 ../raster/r.sunmask/main.c:437
+#: ../raster/r.in.gdal/main.c:723 ../raster/r.in.gdal/main.c:728
+#: ../raster/r.in.gdal/main.c:744 ../raster/r.sunmask/main.c:437
#: ../raster/r.bilinear/main.c:103 ../raster/r.surf.random/randsurf.c:29
-#: ../raster/r.surf.random/randsurf.c:33 ../raster/r.in.xyz/main.c:465
-#: ../raster/r.clump/main.c:99 ../raster/r.in.mat/main.c:386
-#: ../raster/r.cross/main.c:137 ../raster/r.series/main.c:185
-#: ../raster/r.mapcalc/map3.c:598 ../raster/r.mapcalc/map.c:513
-#: ../raster/r.composite/main.c:200 ../raster/r.buffer/write_map.c:39
-#: ../raster/r.in.arc/main.c:151 ../raster/r.bitpattern/main.c:125
-#: ../vector/lidar/v.surf.bspline/main.c:284 ../vector/v.kernel/main.c:236
-#: ../vector/v.surf.idw/main.c:234 ../vector/v.neighbors/main.c:94
-#: ../vector/v.to.rast/vect2rast.c:120 ../vector/v.to.rast/vect2rast.c:124
-#: ../doc/raster/r.example/main.c:140 ../imagery/i.his.rgb/openfiles.c:16
-#: ../imagery/i.his.rgb/openfiles.c:18 ../imagery/i.his.rgb/openfiles.c:20
-#: ../imagery/i.smap/shapiro/opencell.c:31 ../imagery/i.pca/main.c:395
+#: ../raster/r.surf.random/randsurf.c:33 ../raster/r.in.xyz/main.c:468
+#: ../raster/r.slope.aspect/opennew.c:19 ../raster/r.clump/main.c:84
+#: ../raster/r.in.mat/main.c:397 ../raster/r.cross/main.c:120
+#: ../raster/r.series/main.c:171 ../raster/r.mapcalc/map3.c:600
+#: ../raster/r.mapcalc/map.c:513 ../raster/r.composite/main.c:196
+#: ../raster/r.buffer/write_map.c:39 ../raster/r.in.arc/main.c:151
+#: ../raster/r.bitpattern/main.c:125 ../vector/lidar/v.surf.bspline/main.c:284
+#: ../vector/v.kernel/main.c:223 ../vector/v.surf.idw/main.c:234
+#: ../vector/v.neighbors/main.c:94 ../vector/v.to.rast/vect2rast.c:120
+#: ../vector/v.to.rast/vect2rast.c:124 ../doc/raster/r.example/main.c:140
+#: ../imagery/i.his.rgb/openfiles.c:16 ../imagery/i.his.rgb/openfiles.c:18
+#: ../imagery/i.his.rgb/openfiles.c:20 ../imagery/i.smap/shapiro/opencell.c:31
+#: ../imagery/i.pca/main.c:395
#, fuzzy, c-format
msgid "Unable to create raster map <%s>"
msgstr " "
@@ -1538,7 +1562,7 @@
msgstr ""
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "prints a graph of the correlation between data layers (in pairs)"
+msgid "Prints a graph of the correlation between data layers (in pairs)."
msgstr ""
#: ../locale/scriptstrings/d.correlate_to_translate.c:2
@@ -1818,8 +1842,7 @@
#: ../display/d.what.rast/main.c:44 ../display/d.title/main.c:45
#: ../display/d.geodesic/main.c:45 ../display/d.text/main.c:67
#: ../display/d.font.freetype/main.c:58 ../display/d.info/main.c:33
-#: ../display/d.save/main.c:81 ../display/d.vect/main.c:126
-#: ../display/d.vect.chart/main.c:62 ../display/d.rast.arrow/arrow.c:112
+#: ../display/d.save/main.c:81 ../display/d.rast.arrow/arrow.c:112
#: ../display/d.menu/main.c:65 ../display/d.text.freetype/main.c:140
#: ../display/d.rast/main.c:52 ../display/d.extract/main.c:48
#: ../display/d.rgb/main.c:53 ../display/d.where/main.c:41
@@ -1827,7 +1850,7 @@
#: ../display/d.ask/main.c:35 ../display/d.his/main.c:65
#: ../display/d.zoom/main.c:56 ../display/d.rhumbline/main.c:43
#: ../display/d.nviz/main.c:68 ../display/d.mon/cmd/main.c:47
-#: ../display/d.frame/frame.c:60
+#: ../display/d.frame/frame.c:60 ../display/d.thematic.area/main.c:72
msgid "display"
msgstr ""
@@ -2240,7 +2263,7 @@
#: ../locale/scriptstrings/g.mlist_to_translate.c:2
#: ../locale/scriptstrings/g.mremove_to_translate.c:2
#: ../general/manage/cmd/rename.c:40 ../general/manage/cmd/copy.c:38
-#: ../general/manage/cmd/list.c:40 ../general/manage/cmd/remove.c:45
+#: ../general/manage/cmd/list.c:40 ../general/manage/cmd/remove.c:110
msgid "general, map management"
msgstr ""
@@ -2471,7 +2494,7 @@
#: ../locale/scriptstrings/i.oif_to_translate.c:9
#: ../locale/scriptstrings/r.regression.line_to_translate.c:3
-#: ../general/g.region/cmd/main.c:135
+#: ../general/g.region/main.c:134
msgid "Print in shell script style"
msgstr ""
@@ -2613,55 +2636,51 @@
msgstr ""
#: ../locale/scriptstrings/r.blend_to_translate.c:1
-msgid "Blends color components of two raster maps by a given ratio"
+msgid "Blends color components of two raster maps by a given ratio."
msgstr ""
#: ../locale/scriptstrings/r.blend_to_translate.c:2
-#: ../raster/r.describe/main.c:58 ../raster/r.rescale.eq/main.c:51
-#: ../raster/r.surf.area/main.c:89 ../raster/r.coin/cmd_parms.c:42
-#: ../raster/r.out.png/r.out.png.c:135 ../raster/r.distance/main.c:38
+#: ../raster/r.describe/main.c:55 ../raster/r.rescale.eq/main.c:46
+#: ../raster/r.surf.area/main.c:89 ../raster/r.coin/cmd_parms.c:39
+#: ../raster/r.out.png/r.out.png.c:128 ../raster/r.distance/main.c:38
#: ../raster/r.surf.fractal/interface.c:32 ../raster/r.reclass/main.c:48
-#: ../raster/r.los/main.c:78 ../raster/r.drain/main.c:103
-#: ../raster/r.carve/main.c:76 ../raster/r.profile/main.c:53
+#: ../raster/r.los/main.c:81 ../raster/r.drain/main.c:103
+#: ../raster/r.carve/main.c:72 ../raster/r.profile/main.c:53
#: ../raster/r.texture/main.c:71 ../raster/r.basins.fill/main.c:51
-#: ../raster/r.sum/main.c:47 ../raster/r.sun/main.c:153
+#: ../raster/r.sum/main.c:47 ../raster/r.sun/main.c:175
#: ../raster/r.volume/main.c:56 ../raster/r.null/null.c:45
#: ../raster/r.average/main.c:51 ../raster/r.lake/main.c:156
#: ../raster/r.out.gridatb/main.c:46 ../raster/r.surf.idw2/main.c:60
#: ../raster/r.transect/main.c:53 ../raster/r.mode/main.c:48
-#: ../raster/simwe/r.sim.sediment/main.c:94
-#: ../raster/simwe/r.sim.water/main.c:97 ../raster/r.info/main.c:68
-#: ../raster/r.compress/main.c:63 ../raster/r.patch/main.c:53
-#: ../raster/r.le/r.le.setup/main.c:60 ../raster/r.le/r.le.pixel/main.c:45
-#: ../raster/r.le/r.le.trace/main.c:57 ../raster/r.le/r.le.patch/main.c:47
-#: ../raster/r.digit/main.c:44 ../raster/r.grow2/main.c:127
-#: ../raster/r.circle/dist.c:52 ../raster/r.surf.idw/main.c:68
-#: ../raster/r.thin/main.c:54 ../raster/r.surf.contour/main.c:50
-#: ../raster/r.topidx/main.c:37 ../raster/r.out.pov/main.c:120
-#: ../raster/r.covar/main.c:52 ../raster/r.out.arc/main.c:58
-#: ../raster/r.rescale/main.c:48 ../raster/r.random/main.c:46
-#: ../raster/r.sunmask/main.c:124 ../raster/r.his/main.c:64
-#: ../raster/r.topmodel/main.c:56 ../raster/r.bilinear/main.c:41
-#: ../raster/r.kappa/main.c:49 ../raster/r.median/main.c:44
-#: ../raster/r.resamp.rst/main.c:155 ../raster/r.stats/main.c:87
-#: ../raster/r.surf.random/main.c:41 ../raster/r.slope.aspect/main.c:152
-#: ../raster/r.surf.gauss/main.c:43 ../raster/r.colors/main.c:125
-#: ../raster/r.fill.dir/main.c:85 ../raster/r.timestamp/main.c:34
-#: ../raster/r.what/main.c:88 ../raster/r.random.surface/main.c:47
-#: ../raster/r.out.vtk/main.c:150 ../raster/r.support/front/front.c:54
-#: ../raster/r.out.bin/main.c:63 ../raster/r.neighbors/main.c:103
-#: ../raster/r.clump/main.c:50 ../raster/r.what.color/main.c:89
+#: ../raster/r.info/main.c:68 ../raster/r.compress/main.c:60
+#: ../raster/r.patch/main.c:52 ../raster/r.le/r.le.setup/main.c:60
+#: ../raster/r.le/r.le.pixel/main.c:45 ../raster/r.le/r.le.trace/main.c:57
+#: ../raster/r.le/r.le.patch/main.c:47 ../raster/r.digit/main.c:44
+#: ../raster/r.grow2/main.c:127 ../raster/r.circle/dist.c:52
+#: ../raster/r.surf.idw/main.c:68 ../raster/r.thin/main.c:54
+#: ../raster/r.surf.contour/main.c:50 ../raster/r.topidx/main.c:37
+#: ../raster/r.out.pov/main.c:120 ../raster/r.covar/main.c:49
+#: ../raster/r.out.arc/main.c:58 ../raster/r.rescale/main.c:43
+#: ../raster/r.random/main.c:46 ../raster/r.sunmask/main.c:124
+#: ../raster/r.his/main.c:64 ../raster/r.topmodel/main.c:56
+#: ../raster/r.bilinear/main.c:41 ../raster/r.kappa/main.c:49
+#: ../raster/r.median/main.c:44 ../raster/r.resamp.rst/main.c:155
+#: ../raster/r.stats/main.c:87 ../raster/r.surf.random/main.c:41
+#: ../raster/r.surf.gauss/main.c:43 ../raster/r.fill.dir/main.c:85
+#: ../raster/r.timestamp/main.c:34 ../raster/r.what/main.c:89
+#: ../raster/r.random.surface/main.c:47 ../raster/r.out.vtk/main.c:150
+#: ../raster/r.out.bin/main.c:63 ../raster/r.neighbors/main.c:102
+#: ../raster/r.clump/main.c:47 ../raster/r.what.color/main.c:89
#: ../raster/r.in.gridatb/main.c:43 ../raster/r.random.cells/main.c:39
#: ../raster/r.to.vect/main.c:49 ../raster/r.region/main.c:53
-#: ../raster/r.out.ppm3/main.c:54 ../raster/r.in.mat/main.c:93
+#: ../raster/r.out.ppm3/main.c:53 ../raster/r.in.mat/main.c:88
#: ../raster/r.watershed/front/main.c:49 ../raster/r.quant/main.c:41
-#: ../raster/r.contour/main.c:90 ../raster/r.cross/main.c:65
+#: ../raster/r.contour/main.c:85 ../raster/r.cross/main.c:62
#: ../raster/r.cats/main.c:49 ../raster/r.out.mpeg/main.c:395
#: ../raster/r.walk/main.c:172 ../raster/r.recode/main.c:42
-#: ../raster/r.composite/main.c:71 ../raster/r.gwflow/main.c:219
-#: ../raster/wildfire/r.ros/main.c:212
+#: ../raster/r.gwflow/main.c:219 ../raster/wildfire/r.ros/main.c:212
#: ../raster/wildfire/r.spreadpath/main.c:71
-#: ../raster/wildfire/r.spread/main.c:102 ../raster/r.resample/main.c:53
+#: ../raster/wildfire/r.spread/main.c:102 ../raster/r.resample/main.c:52
#: ../raster/r.in.arc/main.c:58 ../raster/r.bitpattern/main.c:62
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:152
msgid "raster"
@@ -2678,7 +2697,7 @@
msgstr " "
#: ../locale/scriptstrings/r.blend_to_translate.c:5
-msgid "Base name for red, green, & blue output maps containing the blend"
+msgid "Base name for red, green and blue output maps containing the blend"
msgstr ""
#: ../locale/scriptstrings/r.blend_to_translate.c:6
@@ -2742,7 +2761,7 @@
msgstr "×ÅËÔÏÒ."
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../raster/r.in.bin/main.c:111 ../raster/r.in.gdal/main.c:78
+#: ../raster/r.in.bin/main.c:112 ../raster/r.in.gdal/main.c:78
#: ../raster/r.in.poly/main.c:28
#, fuzzy
msgid "raster, import"
@@ -2970,8 +2989,8 @@
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
#: ../raster/r.out.ascii/main.c:60 ../raster/r.out.gdal/main.c:375
-#: ../raster/r.out.mat/main.c:61 ../raster/r.out.ppm/main.c:52
-#: ../raster/r.out.tiff/r.out.tiff.c:100
+#: ../raster/r.out.mat/main.c:59 ../raster/r.out.ppm/main.c:51
+#: ../raster/r.out.tiff/r.out.tiff.c:99
msgid "raster, export"
msgstr ""
@@ -3095,19 +3114,23 @@
#: ../locale/scriptstrings/r.regression.line_to_translate.c:2
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
#: ../raster/r.statistics/main.c:41 ../raster/r.report/main.c:27
-#: ../raster/r.univar2/r.univar_main.c:77
+#: ../raster/r.univar2/r.univar_main.c:75 ../raster/r.quantile/main.c:233
msgid "raster, statistics"
msgstr ""
#: ../locale/scriptstrings/r.regression.line_to_translate.c:4
+msgid "Slower but accurate (applies to FP maps only)"
+msgstr ""
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
msgid "Map for x coefficient"
msgstr ""
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:6
msgid "Map for y coefficient"
msgstr ""
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:6
+#: ../locale/scriptstrings/r.regression.line_to_translate.c:7
msgid ""
"ASCII file for storing regression coefficients (output to screen if file not "
"specified)."
@@ -3276,12 +3299,11 @@
#: ../vector/v.out.ascii/out.c:43 ../vector/v.sample/main.c:86
#: ../vector/v.in.region/main.c:38 ../vector/v.info/main.c:63
#: ../vector/v.info/main.c:227 ../vector/v.patch/main.c:68
-#: ../vector/v.vol.rst/main.c:201 ../vector/v.mkgrid/main.c:62
-#: ../vector/v.category/main.c:66 ../vector/v.clean/test/topocheck.c:40
-#: ../vector/v.voronoi/dt_main.c:44 ../vector/v.voronoi/vo_main.c:107
-#: ../vector/v.out.vtk/main.c:45 ../vector/v.select/main.c:129
-#: ../vector/v.surf.rst/main.c:159 ../vector/v.buffer/main.c:245
-#: ../vector/v.extract/main.c:73
+#: ../vector/v.vol.rst/main.c:201 ../vector/v.mkgrid/main.c:61
+#: ../vector/v.clean/test/topocheck.c:40 ../vector/v.voronoi/dt_main.c:46
+#: ../vector/v.voronoi/vo_main.c:107 ../vector/v.out.vtk/main.c:45
+#: ../vector/v.select/main.c:129 ../vector/v.surf.rst/main.c:159
+#: ../vector/v.buffer/main.c:245 ../vector/v.extract/main.c:73
msgid "vector"
msgstr ""
@@ -3324,7 +3346,7 @@
msgstr ""
#: ../locale/scriptstrings/v.centroids_to_translate.c:8
-#: ../vector/v.category/main.c:103
+#: ../vector/v.category/main.c:104
msgid "Category increment"
msgstr ""
@@ -3480,7 +3502,8 @@
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
#, fuzzy
-msgid "Renames a column in a attribute table connected to a given vector map."
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
msgstr "×ÅËÔÏÒ"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
@@ -3531,8 +3554,9 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
#: ../vector/lidar/v.outlier/main.c:68 ../vector/v.univar/main.c:60
-#: ../vector/v.qcount/main.c:68 ../vector/v.random/main.c:77
+#: ../vector/v.qcount/main.c:67 ../vector/v.random/main.c:77
#: ../vector/v.kcv/main.c:76 ../vector/v.normal/main.c:78
+#: ../vector/v.class/main.c:45
msgid "vector, statistics"
msgstr ""
@@ -3637,8 +3661,6 @@
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:3
-#: ../raster/r.out.mat/main.c:79 ../raster/r.in.mat/main.c:116
-#: ../raster/r.out.tiff/r.out.tiff.c:137
#, fuzzy
msgid "Verbose mode"
msgstr "÷Ù×ÏÄ ÓÔÁÔÉÓÔÉËÉ ÎÁ ÜËÒÁÎ"
@@ -3818,8 +3840,8 @@
msgstr " "
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../raster/r.univar2/r.univar_main.c:45
-#: ../raster/r.univar2/r3.univar_main.c:46 ../vector/v.univar/main.c:94
+#: ../raster/r.univar2/r.univar_main.c:48
+#: ../raster/r.univar2/r3.univar_main.c:47 ../vector/v.univar/main.c:94
msgid "Calculate extended statistics"
msgstr ""
@@ -3839,8 +3861,8 @@
msgstr "×ÅËÔÏÒ"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-#: ../raster/r.univar2/r.univar_main.c:37
-#: ../raster/r.univar2/r3.univar_main.c:38 ../vector/v.univar/main.c:86
+#: ../raster/r.univar2/r.univar_main.c:40
+#: ../raster/r.univar2/r3.univar_main.c:39 ../vector/v.univar/main.c:86
msgid "Percentile to calculate (requires extended statistics flag)"
msgstr ""
@@ -3903,118 +3925,76 @@
msgid "Column to be queried"
msgstr ""
-#: ../raster/r.describe/main.c:60
+#: ../raster/r.describe/main.c:57
msgid "Prints terse list of category values found in a raster map layer."
msgstr ""
-#: ../raster/r.describe/main.c:71 ../raster/r.stats/main.c:116
+#: ../raster/r.describe/main.c:68 ../raster/r.stats/main.c:116
msgid "String representing no data cell value"
msgstr ""
-#: ../raster/r.describe/main.c:79
+#: ../raster/r.describe/main.c:76
#, fuzzy
msgid "Number of quantization steps"
msgstr " "
-#: ../raster/r.describe/main.c:85
+#: ../raster/r.describe/main.c:82
msgid "Print the output one value per line"
msgstr ""
-#: ../raster/r.describe/main.c:89
+#: ../raster/r.describe/main.c:86
msgid "Only print the range of the data"
msgstr ""
-#: ../raster/r.describe/main.c:93 ../raster/r.stats/main.c:164
+#: ../raster/r.describe/main.c:90 ../raster/r.stats/main.c:164
msgid "Suppress reporting of any NULLs"
msgstr ""
-#: ../raster/r.describe/main.c:97
+#: ../raster/r.describe/main.c:94
msgid "Use the current region"
msgstr ""
-#: ../raster/r.describe/main.c:101
+#: ../raster/r.describe/main.c:98
msgid "Read fp map as integer"
msgstr ""
-#: ../raster/r.describe/main.c:106 ../raster/r.coin/cmd_parms.c:78
-#: ../raster/r.distance/parse.c:63 ../raster/r.carve/main.c:113
-#: ../raster/r.compress/main.c:82 ../raster/r.covar/main.c:66
-#: ../raster/r.colors/main.c:192 ../raster/r.out.ppm/main.c:68
-#: ../raster/r.neighbors/main.c:158 ../raster/r.clump/main.c:69
-#: ../raster/r.out.ppm3/main.c:86 ../raster/r.contour/main.c:133
-#: ../raster/r.cross/main.c:90 ../raster/r.series/main.c:125
-#: ../raster/r.buffer/main.c:89 ../imagery/i.smap/shapiro/parse.c:54
-#: ../imagery/i.maxlik/main.c:86
-msgid "Run quietly"
-msgstr ""
-#: ../raster/r.describe/main.c:114 ../raster/r.rescale.eq/main.c:105
-#: ../raster/r.coin/cmd_parms.c:87 ../raster/r.out.png/r.out.png.c:145
-#: ../raster/r.distance/parse.c:71 ../raster/r.carve/main.c:123
-#: ../raster/r.texture/main.c:217 ../raster/r.compress/main.c:90
-#: ../raster/r.patch/main.c:86 ../raster/r.covar/main.c:74
-#: ../raster/r.rescale/main.c:101 ../raster/r.slope.aspect/main.c:319
-#: ../raster/r.colors/main.c:202 ../raster/r.random.surface/init.c:107
-#: ../raster/r.neighbors/main.c:276 ../raster/r.clump/main.c:78
-#: ../raster/r.to.vect/main.c:95 ../raster/r.out.ppm3/main.c:98
-#: ../raster/r.cross/main.c:97 ../raster/r.series/main.c:137
-#: ../raster/r.resample/main.c:89 ../raster/r.buffer/main.c:98
-#: ../vector/v.qcount/main.c:115 ../vector/v.mkgrid/main.c:122
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:319
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-#: ../raster/r.describe/main.c:125
+#: ../raster/r.describe/main.c:110
#, fuzzy, c-format
msgid "%s = %s -- must be greater than zero"
msgstr " "
-#: ../raster/r.describe/main.c:137
+#: ../raster/r.describe/main.c:122
#, fuzzy, c-format
msgid "%s: [%s] not found"
msgstr " "
-#: ../raster/r.rescale.eq/main.c:53
+#: ../raster/r.rescale.eq/main.c:48
msgid ""
"Rescales histogram equalized the range of category values in a raster map "
"layer."
msgstr ""
-#: ../raster/r.rescale.eq/main.c:63 ../raster/r.rescale/main.c:60
+#: ../raster/r.rescale.eq/main.c:58 ../raster/r.rescale/main.c:55
msgid "The name of the raster map to be rescaled"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:70 ../raster/r.rescale/main.c:67
+#: ../raster/r.rescale.eq/main.c:65 ../raster/r.rescale/main.c:62
msgid "The input data range to be rescaled (default: full range of input map)"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:77 ../raster/r.rescale/main.c:74
+#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:69
msgid "The resulting raster map name"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:84 ../raster/r.rescale/main.c:81
+#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:76
msgid "The output data range"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:91 ../raster/r.rescale/main.c:88
+#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:83
msgid "Title for new raster map"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:96 ../raster/r.texture/main.c:108
-#: ../raster/r.patch/main.c:72 ../raster/r.grow2/main.c:165
-#: ../raster/r.report/parse.c:90 ../raster/r.kappa/main.c:82
-#: ../raster/r.slope.aspect/main.c:281 ../raster/r.mfilter.fp/main.c:89
-#: ../raster/r.mfilter/main.c:82 ../raster/r.resample/main.c:78
-#: ../raster/r.bitpattern/main.c:87 ../vector/v.perturb/main.c:116
-#: ../vector/v.sample/main.c:128 ../vector/v.kcv/main.c:104
-#: ../doc/raster/r.example/main.c:95 ../imagery/i.cluster/main.c:135
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
-msgid "Quiet"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:149
+#: ../raster/r.rescale.eq/main.c:131
#, c-format
msgid "Rescale %s[%d,%d] to %s[%d,%d]"
msgstr ""
@@ -4030,14 +4010,15 @@
msgstr ""
#: ../raster/r.resamp.stats/main.c:267
-msgid "Resamples raster map layers using aggregation."
-msgstr ""
+#, fuzzy
+msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgstr "×ÅËÔÏÒ."
#: ../raster/r.resamp.stats/main.c:277
msgid "Aggregation method"
msgstr ""
-#: ../raster/r.resamp.stats/main.c:283 ../raster/r.series/main.c:129
+#: ../raster/r.resamp.stats/main.c:283 ../raster/r.series/main.c:122
msgid "Propagate NULLs"
msgstr ""
@@ -4045,37 +4026,37 @@
msgid "Weight according to area (slower)"
msgstr ""
-#: ../raster/r.resamp.stats/main.c:296 ../raster/r.series/main.c:150
+#: ../raster/r.resamp.stats/main.c:296 ../raster/r.series/main.c:136
#, fuzzy, c-format
msgid "Unknown method <%s>"
msgstr " "
#: ../raster/r.resamp.stats/main.c:335 ../raster/r.surf.area/main.c:124
-#: ../raster/r.resamp.interp/main.c:137 ../raster/r.los/main.c:188
-#: ../raster/r.los/main.c:199 ../raster/r.out.ascii/main.c:150
-#: ../raster/r.carve/main.c:176 ../raster/r.profile/main.c:144
-#: ../raster/r.texture/main.c:230 ../raster/r.sum/main.c:68
+#: ../raster/r.resamp.interp/main.c:137 ../raster/r.los/main.c:196
+#: ../raster/r.los/main.c:207 ../raster/r.out.ascii/main.c:150
+#: ../raster/r.carve/main.c:159 ../raster/r.profile/main.c:144
+#: ../raster/r.texture/main.c:218 ../raster/r.sum/main.c:68
#: ../raster/r.null/null.c:307 ../raster/r.out.gdal/main.c:101
-#: ../raster/r.surf.idw2/read_cell.c:36 ../raster/r.out.mat/main.c:99
+#: ../raster/r.surf.idw2/read_cell.c:36 ../raster/r.out.mat/main.c:90
#: ../raster/r.to.rast3elev/main.c:161 ../raster/r.grow2/main.c:201
#: ../raster/r.surf.idw/main.c:135 ../raster/r.thin/io.c:102
-#: ../raster/r.out.pov/main.c:175 ../raster/r.covar/main.c:99
-#: ../raster/r.out.arc/main.c:114 ../raster/r.random/count.c:24
+#: ../raster/r.out.pov/main.c:175 ../raster/r.covar/main.c:84
+#: ../raster/r.out.arc/main.c:115 ../raster/r.random/count.c:24
#: ../raster/r.random/count.c:29 ../raster/r.sunmask/main.c:435
#: ../raster/r.his/main.c:132 ../raster/r.his/main.c:158
#: ../raster/r.his/main.c:186 ../raster/r.bilinear/main.c:92
#: ../raster/r.resamp.rst/main.c:405 ../raster/r.resamp.rst/main.c:437
-#: ../raster/r.out.ppm/main.c:120 ../raster/r.cost/main.c:337
+#: ../raster/r.out.ppm/main.c:106 ../raster/r.cost/main.c:319
#: ../raster/r.out.vtk/main.c:224 ../raster/r.out.vtk/main.c:286
#: ../raster/r.out.vtk/main.c:314 ../raster/r.out.vtk/main.c:360
#: ../raster/r.support/front/front.c:221 ../raster/r.out.bin/main.c:133
-#: ../raster/r.clump/main.c:95 ../raster/r.to.vect/main.c:112
-#: ../raster/r.out.ppm3/main.c:121 ../raster/r.univar2/r.univar_main.c:98
-#: ../raster/r.contour/main.c:160 ../raster/r.cross/main.c:120
-#: ../raster/r.cats/main.c:143 ../raster/r.out.tiff/r.out.tiff.c:188
-#: ../raster/r.walk/main.c:545 ../raster/r.walk/main.c:548
-#: ../raster/r.walk/main.c:855 ../raster/r.mapcalc/map3.c:527
-#: ../raster/r.composite/main.c:166 ../raster/wildfire/r.ros/main.c:441
+#: ../raster/r.clump/main.c:80 ../raster/r.to.vect/main.c:99
+#: ../raster/r.out.ppm3/main.c:107 ../raster/r.univar2/r.univar_main.c:154
+#: ../raster/r.contour/main.c:138 ../raster/r.cross/main.c:103
+#: ../raster/r.cats/main.c:143 ../raster/r.out.tiff/r.out.tiff.c:172
+#: ../raster/r.walk/main.c:540 ../raster/r.walk/main.c:543
+#: ../raster/r.walk/main.c:850 ../raster/r.mapcalc/map3.c:527
+#: ../raster/r.composite/main.c:162 ../raster/wildfire/r.ros/main.c:441
#: ../raster/wildfire/r.ros/main.c:446 ../raster/wildfire/r.ros/main.c:451
#: ../raster/wildfire/r.ros/main.c:456 ../raster/wildfire/r.ros/main.c:461
#: ../raster/wildfire/r.ros/main.c:466 ../raster/wildfire/r.ros/main.c:471
@@ -4088,16 +4069,17 @@
#: ../raster/wildfire/r.spread/main.c:457
#: ../raster/wildfire/r.spread/main.c:525 ../raster/r.buffer/read_map.c:41
#: ../raster/r.buffer/write_map.c:45 ../raster/r.bitpattern/main.c:108
-#: ../raster/r.to.rast3/main.c:358 ../vector/v.what.rast/main.c:135
-#: ../vector/v.extrude/main.c:182 ../vector/v.sample/main.c:160
-#: ../vector/v.vol.rst/main.c:580 ../vector/v.to.rast/support.c:247
-#: ../vector/v.to.rast/support.c:396 ../vector/v.drape/main.c:125
-#: ../doc/raster/r.example/main.c:121 ../imagery/i.his.rgb/openfiles.c:34
-#: ../imagery/i.his.rgb/openfiles.c:39 ../imagery/i.his.rgb/openfiles.c:44
-#: ../imagery/i.smap/shapiro/opencell.c:16 ../imagery/i.pca/main.c:125
-#: ../imagery/i.gensig/opencell.c:12 ../visualization/xganim/main.c:346
-#: ../display/d.rast.edit/cell.c:90 ../display/d.profile/ExtractProf.c:95
-#: ../display/d.profile/What.c:30 ../display/d.rast.num/number.c:154
+#: ../raster/r.to.rast3/main.c:358 ../raster/r.quantile/main.c:287
+#: ../vector/v.what.rast/main.c:135 ../vector/v.extrude/main.c:182
+#: ../vector/v.sample/main.c:155 ../vector/v.vol.rst/main.c:580
+#: ../vector/v.to.rast/support.c:247 ../vector/v.to.rast/support.c:396
+#: ../vector/v.drape/main.c:125 ../doc/raster/r.example/main.c:121
+#: ../imagery/i.his.rgb/openfiles.c:34 ../imagery/i.his.rgb/openfiles.c:39
+#: ../imagery/i.his.rgb/openfiles.c:44 ../imagery/i.smap/shapiro/opencell.c:16
+#: ../imagery/i.pca/main.c:125 ../imagery/i.gensig/opencell.c:12
+#: ../visualization/xganim/main.c:346 ../display/d.rast.edit/cell.c:90
+#: ../display/d.profile/ExtractProf.c:95 ../display/d.profile/What.c:30
+#: ../display/d.rast.num/number.c:154 ../display/d.what.rast/opencell.c:26
#: ../display/d.rast.arrow/arrow.c:382 ../display/d.rast/display.c:80
#: ../display/d.rgb/main.c:104 ../display/d.his/main.c:141
#: ../display/d.his/main.c:166 ../display/d.nviz/main.c:185
@@ -4106,7 +4088,7 @@
msgstr " "
#: ../raster/r.resamp.stats/main.c:378 ../raster/r.resamp.interp/main.c:337
-#: ../raster/r.colors/main.c:326
+#: ../raster/r.colors/main.c:341
#, fuzzy, c-format
msgid "Unable to read color table for %s"
msgstr " "
@@ -4274,7 +4256,7 @@
msgstr ""
#: ../raster/r.proj.seg/main.c:212 ../raster/r.statistics/main.c:98
-#: ../raster/r.neighbors/main.c:214 ../raster/r.proj/main.c:200
+#: ../raster/r.neighbors/main.c:208 ../raster/r.proj/main.c:200
#, c-format
msgid "<%s=%s> unknown %s"
msgstr ""
@@ -4309,12 +4291,12 @@
msgid "Mapset <%s> in input location <%s> - %s"
msgstr "îÁÂÏÒ ÄÁÎÎÙÈ "
-#: ../raster/r.proj.seg/main.c:248 ../raster/r.in.gdal/main.c:642
+#: ../raster/r.proj.seg/main.c:248 ../raster/r.in.gdal/main.c:643
#: ../raster/r.proj/main.c:236
msgid "permission denied"
msgstr ""
-#: ../raster/r.proj.seg/main.c:249 ../raster/r.in.gdal/main.c:643
+#: ../raster/r.proj.seg/main.c:249 ../raster/r.in.gdal/main.c:644
#: ../raster/r.proj/main.c:237
#, fuzzy
msgid "not found"
@@ -4418,10 +4400,10 @@
msgid "Projecting..."
msgstr "×ÅËÔÏÒ."
-#: ../raster/r.proj.seg/main.c:442 ../raster/r.los/main.c:352
-#: ../raster/r.texture/main.c:349 ../raster/r.texture/main.c:352
-#: ../raster/r.texture/main.c:358 ../raster/r.in.mat/main.c:439
-#: ../raster/r.buffer/write_map.c:81 ../raster/r.proj/main.c:430
+#: ../raster/r.proj.seg/main.c:442 ../raster/r.los/main.c:372
+#: ../raster/r.texture/main.c:337 ../raster/r.texture/main.c:340
+#: ../raster/r.texture/main.c:346 ../raster/r.buffer/write_map.c:81
+#: ../raster/r.proj/main.c:430
#, fuzzy, c-format
msgid "Failed writing raster map <%s> row %d"
msgstr " "
@@ -4460,8 +4442,9 @@
msgstr " "
#: ../raster/r.resamp.interp/main.c:73
-msgid "Resamples raster map layers using interpolation."
-msgstr ""
+#, fuzzy
+msgid "Resamples raster map layers to a finer grid using interpolation."
+msgstr "×ÅËÔÏÒ."
#: ../raster/r.resamp.interp/main.c:82
msgid "Interpolation method"
@@ -4568,33 +4551,33 @@
msgid "Preparing report ..."
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.coin/cmd_parms.c:44
+#: ../raster/r.coin/cmd_parms.c:41
msgid ""
"Tabulates the mutual occurrence (coincidence) of categories for two raster "
"map layers."
msgstr ""
-#: ../raster/r.coin/cmd_parms.c:52
+#: ../raster/r.coin/cmd_parms.c:49
#, fuzzy
msgid "Name of first raster map"
msgstr " "
-#: ../raster/r.coin/cmd_parms.c:59
+#: ../raster/r.coin/cmd_parms.c:56
#, fuzzy
msgid "Name of second raster map"
msgstr " "
-#: ../raster/r.coin/cmd_parms.c:65
+#: ../raster/r.coin/cmd_parms.c:62
msgid "Unit of measure"
msgstr ""
-#: ../raster/r.coin/cmd_parms.c:66
+#: ../raster/r.coin/cmd_parms.c:63
msgid ""
"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
msgstr ""
-#: ../raster/r.coin/cmd_parms.c:73
+#: ../raster/r.coin/cmd_parms.c:70
msgid "Wide report, 132 columns (default: 80)"
msgstr ""
@@ -4622,13 +4605,13 @@
msgid "Unable to open tempfile"
msgstr " "
-#: ../raster/r.out.png/r.out.png.c:179 ../raster/r.out.ppm/main.c:109
-#: ../raster/r.out.ppm3/main.c:105
+#: ../raster/r.out.png/r.out.png.c:164 ../raster/r.out.ppm/main.c:95
+#: ../raster/r.out.ppm3/main.c:91
#, c-format
msgid "rows = %d, cols = %d"
msgstr ""
-#: ../raster/r.out.png/r.out.png.c:253
+#: ../raster/r.out.png/r.out.png.c:238
#, fuzzy, c-format
msgid "Converting %s..."
msgstr " ."
@@ -4647,15 +4630,15 @@
msgid "Reading maps <%s,%s> while finding 0 distance ..."
msgstr ""
-#: ../raster/r.distance/parse.c:41
+#: ../raster/r.distance/parse.c:38
msgid "Maps for computing inter-class distances"
msgstr ""
-#: ../raster/r.distance/parse.c:54
+#: ../raster/r.distance/parse.c:51
msgid "Include category labels in the output"
msgstr ""
-#: ../raster/r.distance/parse.c:58
+#: ../raster/r.distance/parse.c:55
msgid "Report zero distance if rasters are overlapping"
msgstr ""
@@ -4685,28 +4668,28 @@
msgstr ""
#: ../raster/r.surf.fractal/interface.c:84 ../raster/r.reclass/main.c:80
-#: ../raster/r.los/main.c:163 ../raster/r.in.ascii/main.c:207
-#: ../raster/r.texture/main.c:227 ../raster/r.average/main.c:77
+#: ../raster/r.los/main.c:171 ../raster/r.in.ascii/main.c:208
+#: ../raster/r.texture/main.c:215 ../raster/r.average/main.c:77
#: ../raster/r.surf.idw2/main.c:84 ../raster/r.mode/main.c:95
#: ../raster/r.to.rast3elev/main.c:474 ../raster/r.surf.idw/main.c:112
#: ../raster/r.in.gdal/main.c:206 ../raster/r.random/main.c:136
#: ../raster/r.random/main.c:141 ../raster/r.median/main.c:75
#: ../raster/r.slope.aspect/opennew.c:11 ../raster/r.surf.gauss/main.c:74
-#: ../raster/r.cost/main.c:324 ../raster/r.neighbors/main.c:185
-#: ../raster/r.clump/main.c:91 ../raster/r.in.mat/main.c:352
+#: ../raster/r.cost/main.c:306 ../raster/r.neighbors/main.c:179
+#: ../raster/r.clump/main.c:76 ../raster/r.in.mat/main.c:356
#: ../raster/r.watershed/ram/init_vars.c:330
#: ../raster/r.watershed/shed/com_line.c:194
#: ../raster/r.watershed/shed/com_line.c:224
#: ../raster/r.watershed/seg/init_vars.c:360
-#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:531
+#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:526
#: ../raster/r.recode/main.c:85 ../raster/wildfire/r.spread/main.c:383
#: ../raster/wildfire/r.spread/main.c:395
-#: ../raster/wildfire/r.spread/main.c:408 ../raster/r.buffer/main.c:118
+#: ../raster/wildfire/r.spread/main.c:408 ../raster/r.buffer/main.c:101
#: ../raster/r.bitpattern/main.c:104 ../vector/v.to.rast3/main.c:68
-#: ../vector/v.kernel/main.c:232 ../vector/v.in.ogr/main.c:316
-#: ../vector/v.surf.idw/main.c:121 ../vector/v.random/main.c:123
-#: ../doc/raster/r.example/main.c:113 ../imagery/i.ifft/ifftmain.c:107
-#: ../imagery/i.zc/main.c:118
+#: ../vector/v.edit/main.c:85 ../vector/v.kernel/main.c:219
+#: ../vector/v.in.ogr/main.c:316 ../vector/v.surf.idw/main.c:121
+#: ../vector/v.random/main.c:123 ../doc/raster/r.example/main.c:113
+#: ../imagery/i.ifft/ifftmain.c:107 ../imagery/i.zc/main.c:118
#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:11
#: ../general/manage/cmd/rename.c:87 ../general/manage/cmd/copy.c:92
#, fuzzy, c-format
@@ -4846,59 +4829,73 @@
msgid "Cannot create category file of <%s>"
msgstr " "
-#: ../raster/r.los/main.c:79
+#: ../raster/r.los/main.c:82
#, fuzzy
msgid "Line-of-sight raster analysis program."
msgstr "ìÉÎÉÑ."
-#: ../raster/r.los/main.c:93
+#: ../raster/r.los/main.c:96
msgid "Coordinate identifying the viewing position"
msgstr ""
-#: ../raster/r.los/main.c:98
+#: ../raster/r.los/main.c:101
#, fuzzy
msgid "Binary (1/0) raster map to use as a mask"
msgstr "éÍÑ ÒÁÓÔÒÏ×ÏÇÏ ÆÁÊÌÁ-ÍÁÓËÉ"
-#: ../raster/r.los/main.c:105
+#: ../raster/r.los/main.c:108
msgid "Viewing position height above the ground"
msgstr ""
-#: ../raster/r.los/main.c:113
+#: ../raster/r.los/main.c:116
#, fuzzy
msgid "Maximum distance from the viewing point (meters)"
msgstr " "
-#: ../raster/r.los/main.c:139
+#: ../raster/r.los/main.c:121
+msgid "Consider earth curvature (current ellipsoid)"
+msgstr ""
+#: ../raster/r.los/main.c:147
#, fuzzy
msgid "Lat/Long support is not (yet) implemented for this module."
msgstr " ."
-#: ../raster/r.los/main.c:145
+#: ../raster/r.los/main.c:153
#, fuzzy
msgid "Specified observer coordinate is outside current region bounds."
msgstr " ."
-#: ../raster/r.los/main.c:167 ../raster/r.los/main.c:172
+#: ../raster/r.los/main.c:175 ../raster/r.los/main.c:180
#: ../raster/r.resamp.rst/main.c:408 ../raster/r.resamp.rst/main.c:431
#, fuzzy, c-format
msgid "[%s]: Cannot read map header"
msgstr " "
-#: ../raster/r.los/main.c:201
+#: ../raster/r.los/main.c:209
msgid "Pattern map should be a binary 0/1 CELL map"
msgstr ""
-#: ../raster/r.los/main.c:241 ../raster/r.los/main.c:248
+#: ../raster/r.los/main.c:243
+msgid ""
+"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr ""
+#: ../raster/r.los/main.c:248
+#, fuzzy, c-format
+msgid "Using maximum distance from the viewing point (meters): %f"
+msgstr " "
+#: ../raster/r.los/main.c:261 ../raster/r.los/main.c:268
#: ../raster/r.profile/read_rast.c:47 ../raster/r.profile/read_rast.c:73
#: ../raster/r.profile/read_rast.c:99 ../raster/r.out.gdal/main.c:236
#: ../raster/r.out.gdal/main.c:266 ../raster/r.out.gdal/main.c:296
-#: ../raster/r.patch/main.c:160 ../raster/r.patch/main.c:168
-#: ../raster/r.topidx/file_io.c:64 ../raster/r.out.ppm/main.c:187
-#: ../raster/r.cost/main.c:399 ../raster/r.cost/main.c:603
-#: ../raster/r.walk/main.c:700 ../raster/r.walk/main.c:758
-#: ../raster/r.walk/main.c:873 ../raster/r.walk/main.c:1413
-#: ../raster/r.walk/main.c:1448 ../raster/r.walk/main.c:1482
+#: ../raster/r.patch/main.c:146 ../raster/r.patch/main.c:154
+#: ../raster/r.topidx/file_io.c:64 ../raster/r.out.ppm/main.c:173
+#: ../raster/r.cost/main.c:381 ../raster/r.cost/main.c:585
+#: ../raster/r.walk/main.c:695 ../raster/r.walk/main.c:753
+#: ../raster/r.walk/main.c:868 ../raster/r.walk/main.c:1408
+#: ../raster/r.walk/main.c:1443 ../raster/r.walk/main.c:1477
#: ../raster/r.buffer/read_map.c:60 ../raster/r.buffer/write_map.c:65
#: ../raster/r.bitpattern/main.c:135 ../vector/v.what.rast/main.c:258
#: ../vector/v.what.rast/main.c:261 ../vector/v.to.rast/support.c:411
@@ -4959,10 +4956,10 @@
msgid "Too many start points"
msgstr " "
-#: ../raster/r.drain/main.c:215 ../raster/r.carve/main.c:167
-#: ../raster/r.cost/main.c:298 ../raster/r.region/main.c:230
+#: ../raster/r.drain/main.c:215 ../raster/r.carve/main.c:150
+#: ../raster/r.cost/main.c:280 ../raster/r.region/main.c:230
#: ../vector/v.db.connect/main.c:113 ../vector/v.perturb/main.c:153
-#: ../vector/v.edit/cmd/main.c:124
+#: ../vector/v.edit/main.c:138
#: ../vector/lidar/v.lidar.edgedetection/main.c:164
#: ../vector/lidar/v.lidar.correction/main.c:138
#: ../vector/lidar/v.outlier/main.c:143
@@ -4974,33 +4971,34 @@
#: ../vector/v.segment/main.c:95 ../vector/v.db.select/main.c:91
#: ../vector/v.univar/main.c:109 ../vector/v.what.rast/main.c:116
#: ../vector/v.build.polylines/main.c:136 ../vector/v.net.iso/main.c:174
-#: ../vector/v.extrude/main.c:143 ../vector/v.kernel/main.c:192
-#: ../vector/v.sample/main.c:151 ../vector/v.generalize/main.c:300
-#: ../vector/v.info/main.c:96 ../vector/v.qcount/main.c:126
+#: ../vector/v.extrude/main.c:143 ../vector/v.kernel/main.c:179
+#: ../vector/v.sample/main.c:146 ../vector/v.generalize/main.c:300
+#: ../vector/v.info/main.c:96 ../vector/v.qcount/main.c:112
#: ../vector/v.out.pov/main.c:93 ../vector/v.transform/main.c:228
#: ../vector/v.convert/old2new.c:27 ../vector/v.overlay/main.c:184
-#: ../vector/v.net.path/main.c:126 ../vector/v.label.sa/labels.c:56
-#: ../vector/v.clean/main.c:225 ../vector/v.kcv/main.c:132
+#: ../vector/v.net.path/main.c:126 ../vector/v.label.sa/labels.c:55
+#: ../vector/v.clean/main.c:226 ../vector/v.kcv/main.c:132
#: ../vector/v.net/main.c:139 ../vector/v.net/main.c:153
#: ../vector/v.out.dxf/main.c:67 ../vector/v.normal/main.c:128
-#: ../vector/v.voronoi/dt_main.c:75 ../vector/v.voronoi/vo_main.c:145
-#: ../vector/v.what/main.c:142 ../vector/v.hull/main.c:253
+#: ../vector/v.voronoi/dt_main.c:77 ../vector/v.voronoi/vo_main.c:145
+#: ../vector/v.what/main.c:142 ../vector/v.hull/main.c:295
#: ../vector/v.out.svg/main.c:124 ../vector/v.to.db/parse.c:112
#: ../vector/v.select/main.c:180 ../vector/v.net.alloc/main.c:130
#: ../vector/v.label/main.c:265 ../vector/v.type/main.c:204
#: ../vector/v.surf.rst/main.c:513 ../vector/v.to.rast/vect2rast.c:37
-#: ../vector/v.drape/main.c:138 ../vector/v.out.ogr/main.c:196
+#: ../vector/v.drape/main.c:138 ../vector/v.out.ogr/main.c:202
#: ../vector/v.net.steiner/main.c:394 ../vector/v.lrs/v.lrs.label/main.c:272
#: ../vector/v.lrs/v.lrs.segment/main.c:135
#: ../vector/v.lrs/v.lrs.create/main.c:236
#: ../vector/v.lrs/v.lrs.create/main.c:244
#: ../vector/v.lrs/v.lrs.where/main.c:123
#: ../vector/v.lrs/v.lrs.where/main.c:131 ../vector/v.buffer/main.c:353
-#: ../vector/v.extract/main.c:139 ../doc/vector/v.example/main.c:61
-#: ../display/d.what.vect/main.c:149 ../display/d.vect/main.c:450
-#: ../display/d.vect.chart/main.c:227 ../display/d.extract/main.c:96
-#: ../display/d.zoom/main.c:259 ../display/d.extend/main.c:103
-#: ../display/d.path/main.c:192 ../general/g.region/cmd/main.c:518
+#: ../vector/v.extract/main.c:139 ../vector/v.class/main.c:95
+#: ../doc/vector/v.example/main.c:61 ../display/d.what.vect/main.c:149
+#: ../display/d.vect/main.c:459 ../display/d.vect.chart/main.c:234
+#: ../display/d.extract/main.c:96 ../display/d.zoom/main.c:259
+#: ../display/d.extend/main.c:103 ../display/d.path/main.c:192
+#: ../display/d.thematic.area/main.c:187 ../general/g.region/main.c:520
#, fuzzy, c-format
msgid "Vector map <%s> not found"
msgstr "×ÅËÔÏÒ "
@@ -5086,60 +5084,60 @@
msgid "\"%s\" field missing from header"
msgstr ""
-#: ../raster/r.in.ascii/main.c:67
+#: ../raster/r.in.ascii/main.c:68
#, fuzzy
msgid "raster, import, conversion"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.in.ascii/main.c:69
+#: ../raster/r.in.ascii/main.c:70
#, fuzzy
msgid "Converts ASCII raster file to binary raster map layer."
msgstr "×ÅËÔÏÒ."
-#: ../raster/r.in.ascii/main.c:73
+#: ../raster/r.in.ascii/main.c:74
#, fuzzy
msgid ""
"ASCII raster file to be imported. If not given reads from standard input"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.in.ascii/main.c:84 ../raster/r.in.bin/main.c:158
+#: ../raster/r.in.ascii/main.c:85 ../raster/r.in.bin/main.c:159
#: ../raster/r.in.gdal/main.c:112 ../raster/r.in.poly/main.c:42
#: ../raster/r.in.arc/main.c:85
msgid "Title for resultant raster map"
msgstr ""
-#: ../raster/r.in.ascii/main.c:91 ../raster/r.in.arc/main.c:92
+#: ../raster/r.in.ascii/main.c:92 ../raster/r.in.arc/main.c:92
msgid "Multiplier for ASCII data"
msgstr ""
-#: ../raster/r.in.ascii/main.c:99
+#: ../raster/r.in.ascii/main.c:100
msgid "String representing NULL value data cell"
msgstr ""
-#: ../raster/r.in.ascii/main.c:104
+#: ../raster/r.in.ascii/main.c:105
#, fuzzy
msgid "Integer values are imported"
msgstr " "
-#: ../raster/r.in.ascii/main.c:109
+#: ../raster/r.in.ascii/main.c:110
#, fuzzy
msgid "Floating point values are imported"
msgstr " "
-#: ../raster/r.in.ascii/main.c:114
+#: ../raster/r.in.ascii/main.c:115
#, fuzzy
msgid "Double floating point values are imported"
msgstr " "
-#: ../raster/r.in.ascii/main.c:119
+#: ../raster/r.in.ascii/main.c:120
msgid "SURFER (Golden Software) ASCII file will be imported"
msgstr ""
-#: ../raster/r.in.ascii/main.c:130 ../raster/r.in.ascii/main.c:160
+#: ../raster/r.in.ascii/main.c:131 ../raster/r.in.ascii/main.c:161
#: ../raster/r.resamp.rst/main.c:616 ../raster/r.resamp.rst/main.c:627
#: ../raster/r.resamp.rst/main.c:639 ../raster/r.resamp.rst/main.c:652
#: ../raster/r.resamp.rst/main.c:664 ../raster/r.resamp.rst/main.c:676
-#: ../raster/r.in.arc/main.c:113 ../vector/v.in.ascii/in.c:237
+#: ../raster/r.in.arc/main.c:113 ../vector/v.in.ascii/in.c:241
#: ../vector/v.surf.rst/main.c:590 ../vector/v.surf.rst/main.c:598
#: ../vector/v.surf.rst/main.c:606 ../vector/v.surf.rst/main.c:615
#: ../vector/v.surf.rst/main.c:623 ../vector/v.surf.rst/main.c:631
@@ -5151,45 +5149,45 @@
msgid "Unable to open temporary file <%s>"
msgstr " "
-#: ../raster/r.in.ascii/main.c:138
+#: ../raster/r.in.ascii/main.c:139
#, fuzzy, c-format
msgid "Wrong entry for multiplier: %s"
msgstr " "
-#: ../raster/r.in.ascii/main.c:163
+#: ../raster/r.in.ascii/main.c:164
msgid "Unable to read input from stdin"
msgstr ""
-#: ../raster/r.in.ascii/main.c:171
+#: ../raster/r.in.ascii/main.c:172
#, fuzzy, c-format
msgid "Unable to read input from <%s>"
msgstr " "
-#: ../raster/r.in.ascii/main.c:191 ../raster/r.in.arc/main.c:126
+#: ../raster/r.in.ascii/main.c:192 ../raster/r.in.arc/main.c:126
msgid "Can't get cell header"
msgstr ""
-#: ../raster/r.in.ascii/main.c:196 ../raster/r.out.tiff/r.out.tiff.c:173
+#: ../raster/r.in.ascii/main.c:197 ../raster/r.out.tiff/r.out.tiff.c:157
#: ../raster/r.in.arc/main.c:131
msgid "Can't set window"
msgstr ""
-#: ../raster/r.in.ascii/main.c:199 ../raster/r.in.arc/main.c:134
+#: ../raster/r.in.ascii/main.c:200 ../raster/r.in.arc/main.c:134
#, c-format
msgid "OOPS: rows changed from %d to %d"
msgstr ""
-#: ../raster/r.in.ascii/main.c:201 ../raster/r.in.arc/main.c:136
+#: ../raster/r.in.ascii/main.c:202 ../raster/r.in.arc/main.c:136
#, c-format
msgid "OOPS: cols changed from %d to %d"
msgstr ""
-#: ../raster/r.in.ascii/main.c:219 ../raster/r.in.arc/main.c:161
+#: ../raster/r.in.ascii/main.c:220 ../raster/r.in.arc/main.c:161
#, c-format
msgid "Data conversion failed at row %d, col %d"
msgstr ""
-#: ../raster/r.in.ascii/main.c:296
+#: ../raster/r.in.ascii/main.c:302
msgid "Unable to write to file"
msgstr ""
@@ -5245,7 +5243,7 @@
msgstr " "
#: ../raster/r.out.ascii/main.c:173 ../raster/r.profile/main.c:157
-#: ../raster/r.out.arc/main.c:132 ../raster/r.out.ppm3/main.c:147
+#: ../raster/r.out.arc/main.c:133 ../raster/r.out.ppm3/main.c:133
#: ../raster/r.cats/main.c:170 ../vector/v.out.ascii/out.c:137
#: ../vector/v.out.vtk/main.c:163 ../display/d.nviz/main.c:202
#: ../general/g.pnmcomp/main.c:262 ../general/g.pnmcomp/main.c:280
@@ -5263,8 +5261,8 @@
msgid "Read failed at row %d"
msgstr "þÔÅÎÉÅ %s ..."
-#: ../raster/r.carve/raster.c:12 ../raster/r.texture/main.c:258
-#: ../raster/r.out.tiff/r.out.tiff.c:286 ../imagery/i.zc/main.c:168
+#: ../raster/r.carve/raster.c:12 ../raster/r.texture/main.c:246
+#: ../raster/r.out.tiff/r.out.tiff.c:270 ../imagery/i.zc/main.c:168
#, fuzzy
msgid "Reading raster map..."
msgstr " ."
@@ -5278,51 +5276,51 @@
msgid "trying to divide by zero...no unique solution for system...skipping..."
msgstr ""
-#: ../raster/r.carve/main.c:77
+#: ../raster/r.carve/main.c:73
#, fuzzy
msgid ""
"Takes vector stream data, transforms it to raster and subtracts depth from "
"the output DEM."
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.carve/main.c:82
+#: ../raster/r.carve/main.c:78
msgid "Name of input raster elevation map"
msgstr ""
-#: ../raster/r.carve/main.c:86
+#: ../raster/r.carve/main.c:82
#, fuzzy
msgid "Name of vector input map containing stream(s)"
msgstr "×ÅËÔÏÒ "
-#: ../raster/r.carve/main.c:93
+#: ../raster/r.carve/main.c:89
#, fuzzy
msgid "Name for output vector map for adjusted stream points"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.carve/main.c:98
+#: ../raster/r.carve/main.c:94
#, fuzzy
msgid "Stream width (in meters). Default is raster cell width"
msgstr " "
-#: ../raster/r.carve/main.c:104
+#: ../raster/r.carve/main.c:100
msgid "Additional stream depth (in meters)"
msgstr ""
-#: ../raster/r.carve/main.c:108
+#: ../raster/r.carve/main.c:104
msgid "No flat areas allowed in flow direction"
msgstr ""
-#: ../raster/r.carve/main.c:145
+#: ../raster/r.carve/main.c:128
#, fuzzy, c-format
msgid "Invalid width value '%s' - using default."
msgstr " ."
-#: ../raster/r.carve/main.c:158
+#: ../raster/r.carve/main.c:141
#, fuzzy, c-format
msgid "Invalid depth value '%s' - using default."
msgstr " ."
-#: ../raster/r.carve/main.c:223
+#: ../raster/r.carve/main.c:206
msgid "lat/lon projection not supported at this time."
msgstr ""
@@ -5471,84 +5469,84 @@
msgid "The distance between two samples (>= 1)"
msgstr ""
-#: ../raster/r.texture/main.c:119
+#: ../raster/r.texture/main.c:115
msgid "Angular Second Moment"
msgstr ""
-#: ../raster/r.texture/main.c:120 ../raster/r.texture/main.c:125
-#: ../raster/r.texture/main.c:130 ../raster/r.texture/main.c:135
-#: ../raster/r.texture/main.c:140 ../raster/r.texture/main.c:145
-#: ../raster/r.texture/main.c:150 ../raster/r.texture/main.c:155
-#: ../raster/r.texture/main.c:160 ../raster/r.texture/main.c:165
-#: ../raster/r.texture/main.c:170 ../raster/r.texture/main.c:175
-#: ../raster/r.texture/main.c:180 ../raster/r.texture/main.c:185
+#: ../raster/r.texture/main.c:116 ../raster/r.texture/main.c:121
+#: ../raster/r.texture/main.c:126 ../raster/r.texture/main.c:131
+#: ../raster/r.texture/main.c:136 ../raster/r.texture/main.c:141
+#: ../raster/r.texture/main.c:146 ../raster/r.texture/main.c:151
+#: ../raster/r.texture/main.c:156 ../raster/r.texture/main.c:161
+#: ../raster/r.texture/main.c:166 ../raster/r.texture/main.c:171
+#: ../raster/r.texture/main.c:176 ../raster/r.texture/main.c:181
msgid "Features"
msgstr ""
-#: ../raster/r.texture/main.c:124
+#: ../raster/r.texture/main.c:120
msgid "Contrast"
msgstr ""
-#: ../raster/r.texture/main.c:129
+#: ../raster/r.texture/main.c:125
msgid "Correlation"
msgstr ""
-#: ../raster/r.texture/main.c:134
+#: ../raster/r.texture/main.c:130
msgid "Variance"
msgstr ""
-#: ../raster/r.texture/main.c:139
+#: ../raster/r.texture/main.c:135
msgid "Inverse Diff Moment"
msgstr ""
-#: ../raster/r.texture/main.c:144
+#: ../raster/r.texture/main.c:140
msgid "Sum Average"
msgstr ""
-#: ../raster/r.texture/main.c:149
+#: ../raster/r.texture/main.c:145
msgid "Sum Variance"
msgstr ""
-#: ../raster/r.texture/main.c:154
+#: ../raster/r.texture/main.c:150
msgid "Sum Entropy"
msgstr ""
-#: ../raster/r.texture/main.c:159
+#: ../raster/r.texture/main.c:155
msgid "Entropy"
msgstr ""
-#: ../raster/r.texture/main.c:164
+#: ../raster/r.texture/main.c:160
msgid "Difference Variance"
msgstr ""
-#: ../raster/r.texture/main.c:169
+#: ../raster/r.texture/main.c:165
msgid "Difference Entropy"
msgstr ""
-#: ../raster/r.texture/main.c:174
+#: ../raster/r.texture/main.c:170
msgid "Measure of Correlation-1"
msgstr ""
-#: ../raster/r.texture/main.c:179
+#: ../raster/r.texture/main.c:175
msgid "Measure of Correlation-2"
msgstr ""
-#: ../raster/r.texture/main.c:184
+#: ../raster/r.texture/main.c:180
msgid "Max Correlation Coeff"
msgstr ""
-#: ../raster/r.texture/main.c:212
+#: ../raster/r.texture/main.c:207
msgid "Nothing to compute. Use at least one of the flags."
msgstr ""
-#: ../raster/r.texture/main.c:236 ../raster/r.out.tiff/r.out.tiff.c:170
+#: ../raster/r.texture/main.c:224 ../raster/r.out.tiff/r.out.tiff.c:154
#: ../raster/r.bitpattern/main.c:114 ../imagery/i.rectify/main.c:173
#: ../imagery/i.rectify/main.c:177
#, fuzzy, c-format
msgid "Unable to read header of raster map <%s>"
msgstr " !"
-#: ../raster/r.texture/main.c:361
+#: ../raster/r.texture/main.c:349
#, c-format
msgid "Calculated measure #%d (56 measures available)"
msgstr ""
@@ -5567,7 +5565,7 @@
"map"
msgstr ""
-#: ../raster/r.texture/h_measure.c:675 ../raster/r.cost/main.c:597
+#: ../raster/r.texture/h_measure.c:675 ../raster/r.cost/main.c:579
#: ../imagery/i.smap/bouman/interp.c:71
msgid "Unable to allocate memory"
msgstr ""
@@ -5611,8 +5609,8 @@
msgid "Reverse sweep complete"
msgstr "úÁ×ÅÒÛÅÎÏ:"
-#: ../raster/r.basins.fill/main.c:162 ../raster/r.cross/main.c:188
-#: ../raster/r.resample/main.c:153 ../imagery/i.smap/shapiro/closefiles.c:14
+#: ../raster/r.basins.fill/main.c:162 ../raster/r.cross/main.c:171
+#: ../raster/r.resample/main.c:139 ../imagery/i.smap/shapiro/closefiles.c:14
#, fuzzy, c-format
msgid "Creating support files for <%s>..."
msgstr " ."
@@ -5625,17 +5623,17 @@
msgid "Name of incidence or density file."
msgstr ""
-#: ../raster/r.sum/main.c:77 ../raster/r.walk/main.c:685
-#: ../raster/r.walk/main.c:746 ../raster/wildfire/r.spread/main.c:537
+#: ../raster/r.sum/main.c:77 ../raster/r.walk/main.c:680
+#: ../raster/r.walk/main.c:741 ../raster/wildfire/r.spread/main.c:537
#, fuzzy, c-format
msgid "Reading %s..."
-#: ../raster/r.sun/main.c:154
+#: ../raster/r.sun/main.c:176
msgid "Solar irradiance and irradiation model."
msgstr ""
-#: ../raster/r.sun/main.c:156
+#: ../raster/r.sun/main.c:179
#, fuzzy
msgid ""
"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
@@ -5647,32 +5645,36 @@
"is optionally incorporated."
msgstr " ."
-#: ../raster/r.sun/main.c:185
+#: ../raster/r.sun/main.c:209
msgid "Name of the input elevation raster map [meters]"
msgstr ""
-#: ../raster/r.sun/main.c:186 ../raster/r.sun/main.c:194
-#: ../raster/r.sun/main.c:203 ../raster/r.sun/main.c:212
-#: ../raster/r.sun/main.c:220 ../raster/r.sun/main.c:231
-#: ../raster/r.sun/main.c:239 ../raster/r.sun/main.c:250
-#: ../raster/r.sun/main.c:257 ../raster/r.sun/main.c:268
-#: ../raster/r.sun/main.c:277 ../raster/simwe/r.sim.sediment/main.c:152
-#: ../raster/simwe/r.sim.sediment/main.c:160
+#: ../raster/r.sun/main.c:210 ../raster/r.sun/main.c:220
+#: ../raster/r.sun/main.c:231 ../raster/r.sun/main.c:241
+#: ../raster/r.sun/main.c:249 ../raster/r.sun/main.c:262
+#: ../raster/r.sun/main.c:270 ../raster/r.sun/main.c:282
+#: ../raster/r.sun/main.c:289 ../raster/r.sun/main.c:301
+#: ../raster/r.sun/main.c:310 ../raster/simwe/r.sim.sediment/main.c:163
#: ../raster/simwe/r.sim.sediment/main.c:168
-#: ../raster/simwe/r.sim.sediment/main.c:176
-#: ../raster/simwe/r.sim.sediment/main.c:185
-#: ../raster/simwe/r.sim.sediment/main.c:194
-#: ../raster/simwe/r.sim.sediment/main.c:202
-#: ../raster/simwe/r.sim.sediment/main.c:210
-#: ../raster/simwe/r.sim.sediment/main.c:219
-#: ../raster/simwe/r.sim.water/main.c:153
-#: ../raster/simwe/r.sim.water/main.c:161
-#: ../raster/simwe/r.sim.water/main.c:169
-#: ../raster/simwe/r.sim.water/main.c:177
-#: ../raster/simwe/r.sim.water/main.c:185
-#: ../raster/simwe/r.sim.water/main.c:193
-#: ../raster/simwe/r.sim.water/main.c:201
-#: ../raster/simwe/r.sim.water/main.c:210
+#: ../raster/simwe/r.sim.sediment/main.c:173
+#: ../raster/simwe/r.sim.sediment/main.c:178
+#: ../raster/simwe/r.sim.sediment/main.c:184
+#: ../raster/simwe/r.sim.sediment/main.c:190
+#: ../raster/simwe/r.sim.sediment/main.c:195
+#: ../raster/simwe/r.sim.sediment/main.c:201
+#: ../raster/simwe/r.sim.sediment/main.c:209
+#: ../raster/simwe/r.sim.sediment/main.c:216
+#: ../raster/simwe/r.sim.water/main.c:165
+#: ../raster/simwe/r.sim.water/main.c:170
+#: ../raster/simwe/r.sim.water/main.c:175
+#: ../raster/simwe/r.sim.water/main.c:181
+#: ../raster/simwe/r.sim.water/main.c:189
+#: ../raster/simwe/r.sim.water/main.c:195
+#: ../raster/simwe/r.sim.water/main.c:203
+#: ../raster/simwe/r.sim.water/main.c:209
+#: ../raster/simwe/r.sim.water/main.c:217
+#: ../raster/simwe/r.sim.water/main.c:223
+#: ../raster/simwe/r.sim.water/main.c:230
#: ../raster/r.watershed/front/main.c:54 ../raster/r.watershed/front/main.c:62
#: ../raster/r.watershed/front/main.c:70 ../raster/r.watershed/front/main.c:78
#: ../raster/r.watershed/front/main.c:86 ../raster/r.watershed/front/main.c:94
@@ -5680,68 +5682,68 @@
msgid "Input_options"
msgstr ""
-#: ../raster/r.sun/main.c:193
+#: ../raster/r.sun/main.c:219
#, fuzzy
msgid ""
"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
"[decimal degrees]"
msgstr "üËÓÐÏÚÉÃÉÑ üËÓÐÏÚÉÃÉÑ"
-#: ../raster/r.sun/main.c:202
+#: ../raster/r.sun/main.c:230
#, fuzzy
msgid ""
"Name of the input slope raster map (terrain slope or solar panel "
"inclination) [decimal degrees]"
msgstr "óËÌÏÎÙ óËÌÏÎÙ"
-#: ../raster/r.sun/main.c:211
+#: ../raster/r.sun/main.c:240
msgid ""
"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
msgstr ""
-#: ../raster/r.sun/main.c:222
+#: ../raster/r.sun/main.c:252
msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
msgstr ""
-#: ../raster/r.sun/main.c:230
+#: ../raster/r.sun/main.c:261
msgid "Name of the ground albedo coefficient input raster map [-]"
msgstr ""
-#: ../raster/r.sun/main.c:240
+#: ../raster/r.sun/main.c:272
msgid "A single value of the ground albedo coefficient [-]"
msgstr ""
-#: ../raster/r.sun/main.c:249
+#: ../raster/r.sun/main.c:281
msgid "Name of the latitudes input raster map [decimal degrees]"
msgstr ""
-#: ../raster/r.sun/main.c:258
+#: ../raster/r.sun/main.c:291
msgid "A single value of latitude [decimal degrees]"
msgstr ""
-#: ../raster/r.sun/main.c:267
+#: ../raster/r.sun/main.c:300
msgid "Name of real-sky beam radiation coefficient raster map [-]"
msgstr ""
-#: ../raster/r.sun/main.c:276
+#: ../raster/r.sun/main.c:309
msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
msgstr ""
-#: ../raster/r.sun/main.c:284
+#: ../raster/r.sun/main.c:318
msgid "Output incidence angle raster map (mode 1 only)"
msgstr ""
-#: ../raster/r.sun/main.c:285 ../raster/r.sun/main.c:294
-#: ../raster/r.sun/main.c:302 ../raster/r.sun/main.c:311
-#: ../raster/r.sun/main.c:320 ../raster/simwe/r.sim.sediment/main.c:227
-#: ../raster/simwe/r.sim.sediment/main.c:236
-#: ../raster/simwe/r.sim.sediment/main.c:244
-#: ../raster/simwe/r.sim.sediment/main.c:252
-#: ../raster/simwe/r.sim.sediment/main.c:260
-#: ../raster/simwe/r.sim.water/main.c:218
-#: ../raster/simwe/r.sim.water/main.c:226
-#: ../raster/simwe/r.sim.water/main.c:234
-#: ../raster/simwe/r.sim.water/main.c:242 ../raster/r.resamp.rst/main.c:194
+#: ../raster/r.sun/main.c:319 ../raster/r.sun/main.c:329
+#: ../raster/r.sun/main.c:338 ../raster/r.sun/main.c:348
+#: ../raster/r.sun/main.c:358 ../raster/simwe/r.sim.sediment/main.c:222
+#: ../raster/simwe/r.sim.sediment/main.c:229
+#: ../raster/simwe/r.sim.sediment/main.c:235
+#: ../raster/simwe/r.sim.sediment/main.c:241
+#: ../raster/simwe/r.sim.sediment/main.c:247
+#: ../raster/simwe/r.sim.water/main.c:236
+#: ../raster/simwe/r.sim.water/main.c:242
+#: ../raster/simwe/r.sim.water/main.c:248
+#: ../raster/simwe/r.sim.water/main.c:254 ../raster/r.resamp.rst/main.c:194
#: ../raster/r.resamp.rst/main.c:202 ../raster/r.resamp.rst/main.c:210
#: ../raster/r.resamp.rst/main.c:218 ../raster/r.resamp.rst/main.c:226
#: ../raster/r.resamp.rst/main.c:290 ../raster/r.watershed/front/main.c:110
@@ -5761,155 +5763,153 @@
msgid "Output_options"
msgstr ""
-#: ../raster/r.sun/main.c:293
+#: ../raster/r.sun/main.c:328
msgid ""
"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
"day-1] (mode 2)"
msgstr ""
-#: ../raster/r.sun/main.c:301
+#: ../raster/r.sun/main.c:337
msgid "Output insolation time raster map [h] (mode 2 only)"
msgstr ""
-#: ../raster/r.sun/main.c:310
+#: ../raster/r.sun/main.c:347
msgid ""
"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
"day-1] (mode 2)"
msgstr ""
-#: ../raster/r.sun/main.c:319
+#: ../raster/r.sun/main.c:357
msgid ""
"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
"map [Wh.m-2.day-1] (mode 2)"
msgstr ""
-#: ../raster/r.sun/main.c:326
+#: ../raster/r.sun/main.c:364
msgid "No. of day of the year (1-365)"
msgstr ""
-#: ../raster/r.sun/main.c:333
+#: ../raster/r.sun/main.c:372
msgid "Time step when computing all-day radiation sums [decimal hours]"
msgstr ""
-#: ../raster/r.sun/main.c:340
+#: ../raster/r.sun/main.c:380
msgid "Declination value (overriding the internally computed value) [radians]"
msgstr ""
-#: ../raster/r.sun/main.c:347
+#: ../raster/r.sun/main.c:388
msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
msgstr ""
-#: ../raster/r.sun/main.c:352
+#: ../raster/r.sun/main.c:392
msgid "Incorporate the shadowing effect of terrain"
msgstr ""
-#: ../raster/r.sun/main.c:374
+#: ../raster/r.sun/main.c:418
#, fuzzy
msgid "insol_time and incidout are incompatible options"
msgstr " "
-#: ../raster/r.sun/main.c:382
+#: ../raster/r.sun/main.c:426
#, fuzzy
msgid "time and insol_time are incompatible options"
msgstr " "
-#: ../raster/r.sun/main.c:383
+#: ../raster/r.sun/main.c:428
msgid ""
"Mode 1: instantaneous solar incidence angle & irradiance given a set local "
"time"
msgstr ""
-#: ../raster/r.sun/main.c:388
+#: ../raster/r.sun/main.c:433
msgid "incidout requires time parameter to be set"
msgstr ""
-#: ../raster/r.sun/main.c:389
+#: ../raster/r.sun/main.c:435
msgid "Mode 2: integrated daily irradiation for a given day of the year"
msgstr ""
-#: ../raster/r.sun/main.c:438
+#: ../raster/r.sun/main.c:485
msgid ""
"Can't get projection info of current location: please set latitude via 'lat' "
"or 'latin' option!"
msgstr ""
-#: ../raster/r.sun/main.c:441 ../display/d.where/main.c:92
-#: ../general/g.region/cmd/printwindow.c:248
-#: ../general/g.region/cmd/printwindow.c:498
+#: ../raster/r.sun/main.c:488 ../display/d.where/main.c:92
+#: ../general/g.region/printwindow.c:248 ../general/g.region/printwindow.c:498
msgid "Can't get projection units of current location"
msgstr ""
-#: ../raster/r.sun/main.c:445 ../ps/ps.map/do_geogrid.c:268
-#: ../display/d.where/main.c:95 ../display/d.grid/plot.c:266
-#: ../general/g.region/cmd/printwindow.c:252
-#: ../general/g.region/cmd/printwindow.c:502
+#: ../raster/r.sun/main.c:492 ../ps/ps.map/do_geogrid.c:268
+#: ../display/d.where/main.c:95 ../display/d.grid/plot.c:298
+#: ../general/g.region/printwindow.c:252 ../general/g.region/printwindow.c:502
msgid "Can't get projection key values of current location"
msgstr ""
-#: ../raster/r.sun/main.c:455 ../ps/ps.map/do_geogrid.c:274
+#: ../raster/r.sun/main.c:502 ../ps/ps.map/do_geogrid.c:274
#: ../display/d.where/main.c:103 ../display/d.where/main.c:130
-#: ../display/d.grid/plot.c:274 ../display/d.grid/plot.c:302
+#: ../display/d.grid/plot.c:306 ../display/d.grid/plot.c:334
msgid "Unable to set up lat/long projection parameters"
msgstr ""
-#: ../raster/r.sun/main.c:493
+#: ../raster/r.sun/main.c:540
#, fuzzy, c-format
msgid "elevin raster map <%s> not found"
msgstr " "
-#: ../raster/r.sun/main.c:496
+#: ../raster/r.sun/main.c:543
#, fuzzy, c-format
msgid "aspin raster map <%s> not found"
msgstr " "
-#: ../raster/r.sun/main.c:499
+#: ../raster/r.sun/main.c:546
#, fuzzy, c-format
msgid "slopein raster map <%s> not found"
msgstr " "
-#: ../raster/r.sun/main.c:512
+#: ../raster/r.sun/main.c:559
#, fuzzy, c-format
msgid "linkein raster map <%s> not found"
msgstr " "
-#: ../raster/r.sun/main.c:524
+#: ../raster/r.sun/main.c:571
#, fuzzy, c-format
msgid "albedo raster map <%s> not found"
msgstr " "
-#: ../raster/r.sun/main.c:536
+#: ../raster/r.sun/main.c:583
#, fuzzy, c-format
msgid "latin raster map <%s> not found"
msgstr " "
-#: ../raster/r.sun/main.c:548
+#: ../raster/r.sun/main.c:595
#, fuzzy, c-format
msgid "coefbh raster map <%s> not found"
msgstr " "
-#: ../raster/r.sun/main.c:560
+#: ../raster/r.sun/main.c:607
#, fuzzy, c-format
msgid "coefdh raster map <%s> not found"
msgstr " "
-#: ../raster/r.sun/main.c:699 ../raster/r.sun/main.c:706
-#: ../raster/r.sun/main.c:713 ../raster/r.sun/main.c:720
-#: ../raster/r.sun/main.c:727 ../raster/r.in.bin/main.c:460
+#: ../raster/r.sun/main.c:746 ../raster/r.sun/main.c:753
+#: ../raster/r.sun/main.c:760 ../raster/r.sun/main.c:767
+#: ../raster/r.sun/main.c:774 ../raster/r.in.bin/main.c:461
#, fuzzy, c-format
msgid "Unable to create raster map %s"
msgstr " "
-#: ../raster/r.sun/main.c:735
+#: ../raster/r.sun/main.c:782
#, c-format
msgid "rows changed from %d to %d"
msgstr ""
-#: ../raster/r.sun/main.c:738
+#: ../raster/r.sun/main.c:785
#, c-format
msgid "cols changed from %d to %d"
msgstr ""
-#: ../raster/r.sun/main.c:1301 ../ps/ps.map/do_geogrid.c:86
+#: ../raster/r.sun/main.c:1354 ../ps/ps.map/do_geogrid.c:86
#: ../ps/ps.map/do_geogrid.c:91 ../ps/ps.map/do_geogrid.c:115
#: ../ps/ps.map/do_geogrid.c:120 ../ps/ps.map/do_geogrid.c:189
#: ../ps/ps.map/do_geogrid.c:227 ../ps/ps.map/do_geogrid.c:303
@@ -5917,10 +5917,10 @@
#: ../ps/ps.map/do_geogrid.c:347 ../ps/ps.map/do_geogrid.c:399
#: ../ps/ps.map/do_geogrid.c:405 ../ps/ps.map/do_geogrid.c:409
#: ../ps/ps.map/do_geogrid.c:417 ../ps/ps.map/do_geogrid.c:421
-#: ../display/d.grid/plot.c:162 ../display/d.grid/plot.c:168
-#: ../display/d.grid/plot.c:214 ../display/d.grid/plot.c:220
-#: ../display/d.grid/plot.c:355 ../display/d.grid/plot.c:369
-#: ../display/d.grid/plot.c:384 ../display/d.grid/plot.c:399
+#: ../display/d.grid/plot.c:194 ../display/d.grid/plot.c:200
+#: ../display/d.grid/plot.c:246 ../display/d.grid/plot.c:252
+#: ../display/d.grid/plot.c:387 ../display/d.grid/plot.c:401
+#: ../display/d.grid/plot.c:416 ../display/d.grid/plot.c:431
msgid "Error in pj_do_proj"
msgstr ""
@@ -6223,15 +6223,17 @@
#: ../raster/r.out.gdal/main.c:322
#, c-format
msgid ""
-"Input raster map constains cells with NULL-value (no-data). For no-data "
-"values was used value %d. You can specify nodata value by %s parameter."
+"Input raster map constains cells with NULL-value (no-data). The value %d was "
+"used to represent no-data values in the input map.You can specify nodata "
+"value by %s parameter."
msgstr ""
#: ../raster/r.out.gdal/main.c:327
#, c-format
msgid ""
-"values was used value %g. You can specify nodata value by %s parameter."
+"Input raster map constains cells with NULL-value (no-data). The value %g was "
msgstr ""
#: ../raster/r.out.gdal/main.c:374
@@ -6241,12 +6243,12 @@
#: ../raster/r.out.gdal/main.c:380 ../raster/r.in.gdal/main.c:132
#: ../vector/v.to.db/parse.c:90 ../vector/v.to.db/parse.c:95
-#: ../vector/v.to.db/parse.c:100 ../imagery/i.group/main.c:74
-#: ../imagery/i.group/main.c:79 ../general/g.region/cmd/main.c:100
-#: ../general/g.region/cmd/main.c:106 ../general/g.region/cmd/main.c:111
-#: ../general/g.region/cmd/main.c:116 ../general/g.region/cmd/main.c:121
-#: ../general/g.region/cmd/main.c:126 ../general/g.region/cmd/main.c:131
-#: ../general/g.region/cmd/main.c:136
+#: ../vector/v.to.db/parse.c:100 ../imagery/i.group/main.c:75
+#: ../imagery/i.group/main.c:80 ../general/g.region/main.c:99
+#: ../general/g.region/main.c:105 ../general/g.region/main.c:110
+#: ../general/g.region/main.c:115 ../general/g.region/main.c:120
+#: ../general/g.region/main.c:125 ../general/g.region/main.c:130
+#: ../general/g.region/main.c:135
msgid "Print"
msgstr ""
@@ -6257,6 +6259,7 @@
#: ../raster/r.out.gdal/main.c:385 ../raster/r.out.gdal/main.c:421
#: ../raster/r.in.gdal/main.c:89 ../raster/r.in.gdal/main.c:93
+#: ../raster/r.colors/main.c:131 ../vector/v.in.ascii/in.c:57
#: ../vector/v.in.ogr/main.c:111 ../vector/v.in.ogr/main.c:115
msgid "Required"
msgstr ""
@@ -6307,75 +6310,75 @@
msgid "Driver <%s> does not support creating rasters"
msgstr ""
-#: ../raster/r.out.gdal/main.c:626
+#: ../raster/r.out.gdal/main.c:628
#, c-format
msgid "Exporting to GDAL data type: %s"
msgstr ""
-#: ../raster/r.out.gdal/main.c:642
+#: ../raster/r.out.gdal/main.c:644
#, fuzzy
msgid "Output file name not specified"
msgstr "×ÅËÔÏÒ."
-#: ../raster/r.out.gdal/main.c:648
+#: ../raster/r.out.gdal/main.c:650
#, fuzzy
msgid "Unable to create dataset using memory raster driver"
msgstr " "
-#: ../raster/r.out.gdal/main.c:657
+#: ../raster/r.out.gdal/main.c:659
#, fuzzy, c-format
msgid "Unable to create <%s> dataset using <%s> driver"
msgstr " "
-#: ../raster/r.out.gdal/main.c:671
+#: ../raster/r.out.gdal/main.c:673
#, fuzzy
msgid "Unable to set geo transform"
msgstr " "
-#: ../raster/r.out.gdal/main.c:678
+#: ../raster/r.out.gdal/main.c:680
#, fuzzy
msgid "Unable to set projection"
msgstr " "
-#: ../raster/r.out.gdal/main.c:687
+#: ../raster/r.out.gdal/main.c:689
#, fuzzy, c-format
msgid "Exporting raster map <%s> (band %d)..."
msgstr " "
-#: ../raster/r.out.gdal/main.c:694
+#: ../raster/r.out.gdal/main.c:696
#, fuzzy, c-format
msgid "Unable to export raster map <%s>"
msgstr " "
-#: ../raster/r.out.gdal/main.c:704
+#: ../raster/r.out.gdal/main.c:706
#, fuzzy, c-format
msgid "Unable to create raster map <%s> using driver <%s>"
msgstr " "
-#: ../raster/r.in.bin/main.c:113
+#: ../raster/r.in.bin/main.c:114
#, fuzzy
msgid "Import a binary raster file into a GRASS raster map layer."
msgstr "×ÅËÔÏÒ."
-#: ../raster/r.in.bin/main.c:119
+#: ../raster/r.in.bin/main.c:120
msgid "Import as Floating Point Data (default: Integer)"
msgstr ""
-#: ../raster/r.in.bin/main.c:124
+#: ../raster/r.in.bin/main.c:125
msgid "Import as Double Precision Data (default: Integer)"
msgstr ""
-#: ../raster/r.in.bin/main.c:129
+#: ../raster/r.in.bin/main.c:130
msgid "Signed data (high bit means negative value)"
msgstr ""
-#: ../raster/r.in.bin/main.c:130 ../raster/r.in.bin/main.c:136
-#: ../raster/r.in.bin/main.c:166 ../raster/r.in.bin/main.c:219
+#: ../raster/r.in.bin/main.c:131 ../raster/r.in.bin/main.c:137
+#: ../raster/r.in.bin/main.c:167 ../raster/r.in.bin/main.c:220
#: ../raster/r.resamp.rst/main.c:234 ../raster/r.resamp.rst/main.c:242
#: ../raster/r.resamp.rst/main.c:250 ../raster/r.resamp.rst/main.c:258
-#: ../raster/r.resamp.rst/main.c:266 ../raster/r.slope.aspect/main.c:188
-#: ../raster/r.slope.aspect/main.c:197 ../raster/r.slope.aspect/main.c:268
-#: ../raster/r.slope.aspect/main.c:276 ../raster/r.slope.aspect/main.c:286
+#: ../raster/r.resamp.rst/main.c:266 ../raster/r.slope.aspect/main.c:181
+#: ../raster/r.slope.aspect/main.c:190 ../raster/r.slope.aspect/main.c:261
+#: ../raster/r.slope.aspect/main.c:269 ../raster/r.slope.aspect/main.c:274
#: ../vector/lidar/v.lidar.edgedetection/main.c:87
#: ../vector/lidar/v.lidar.edgedetection/main.c:95
#: ../vector/lidar/v.lidar.edgedetection/main.c:103
@@ -6405,104 +6408,104 @@
msgid "Settings"
msgstr ""
-#: ../raster/r.in.bin/main.c:135
+#: ../raster/r.in.bin/main.c:136
msgid "Byte Swap the Data During Import"
msgstr ""
-#: ../raster/r.in.bin/main.c:141
+#: ../raster/r.in.bin/main.c:142
msgid "Get region info from GMT style header"
msgstr ""
-#: ../raster/r.in.bin/main.c:142 ../raster/r.in.bin/main.c:174
-#: ../raster/r.in.bin/main.c:182 ../raster/r.in.bin/main.c:190
-#: ../raster/r.in.bin/main.c:198 ../raster/r.in.bin/main.c:205
-#: ../raster/r.in.bin/main.c:212 ../general/g.region/cmd/main.c:142
-#: ../general/g.region/cmd/main.c:201 ../general/g.region/cmd/main.c:211
-#: ../general/g.region/cmd/main.c:221 ../general/g.region/cmd/main.c:231
-#: ../general/g.region/cmd/main.c:240 ../general/g.region/cmd/main.c:249
-#: ../general/g.region/cmd/main.c:334
+#: ../raster/r.in.bin/main.c:143 ../raster/r.in.bin/main.c:175
+#: ../raster/r.in.bin/main.c:183 ../raster/r.in.bin/main.c:191
+#: ../raster/r.in.bin/main.c:199 ../raster/r.in.bin/main.c:206
+#: ../raster/r.in.bin/main.c:213 ../general/g.region/main.c:141
+#: ../general/g.region/main.c:200 ../general/g.region/main.c:210
+#: ../general/g.region/main.c:220 ../general/g.region/main.c:230
+#: ../general/g.region/main.c:239 ../general/g.region/main.c:248
+#: ../general/g.region/main.c:324 ../general/g.region/main.c:335
msgid "Bounds"
msgstr ""
-#: ../raster/r.in.bin/main.c:148
+#: ../raster/r.in.bin/main.c:149
#, fuzzy
msgid "Binary raster file to be imported"
msgstr " "
-#: ../raster/r.in.bin/main.c:165
+#: ../raster/r.in.bin/main.c:166
msgid "Number of bytes per cell (1, 2, 4)"
msgstr ""
-#: ../raster/r.in.bin/main.c:173
+#: ../raster/r.in.bin/main.c:174
msgid "Northern limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.in.bin/main.c:181
+#: ../raster/r.in.bin/main.c:182
msgid "Southern limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.in.bin/main.c:189
+#: ../raster/r.in.bin/main.c:190
msgid "Eastern limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.in.bin/main.c:197
+#: ../raster/r.in.bin/main.c:198
msgid "Western limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.in.bin/main.c:204
+#: ../raster/r.in.bin/main.c:205
msgid "Number of rows"
msgstr ""
-#: ../raster/r.in.bin/main.c:211
+#: ../raster/r.in.bin/main.c:212
msgid "Number of columns"
msgstr ""
-#: ../raster/r.in.bin/main.c:218
+#: ../raster/r.in.bin/main.c:219
msgid "Set Value to NULL"
msgstr ""
-#: ../raster/r.in.bin/main.c:243
+#: ../raster/r.in.bin/main.c:244
msgid "Byte Swapping Turned On."
msgstr ""
-#: ../raster/r.in.bin/main.c:275
+#: ../raster/r.in.bin/main.c:276
msgid ""
"Missing parameters ...\n"
"Must provide at least[north= south= east= west=] OR [r=\tc=]"
msgstr ""
-#: ../raster/r.in.bin/main.c:281
+#: ../raster/r.in.bin/main.c:282
msgid "You have to provide all limits of geographic region (n,s,e,w)"
msgstr ""
-#: ../raster/r.in.bin/main.c:301
+#: ../raster/r.in.bin/main.c:302
#, c-format
msgid "Using N=%f S=%f E=%f W=%f"
msgstr ""
-#: ../raster/r.in.bin/main.c:319
+#: ../raster/r.in.bin/main.c:320
#, c-format
msgid "Using rows=%d cols=%d\n"
msgstr ""
-#: ../raster/r.in.bin/main.c:423 ../raster/r.in.bin/main.c:430
-#: ../raster/r.in.bin/main.c:439
+#: ../raster/r.in.bin/main.c:424 ../raster/r.in.bin/main.c:431
+#: ../raster/r.in.bin/main.c:440
msgid "Bytes do not match File size"
msgstr ""
-#: ../raster/r.in.bin/main.c:424 ../raster/r.in.bin/main.c:431
-#: ../raster/r.in.bin/main.c:440
+#: ../raster/r.in.bin/main.c:425 ../raster/r.in.bin/main.c:432
+#: ../raster/r.in.bin/main.c:441
#, c-format
msgid "File Size %d ... Total Bytes %d"
msgstr ""
-#: ../raster/r.in.bin/main.c:425 ../raster/r.in.bin/main.c:432
-#: ../raster/r.in.bin/main.c:441
+#: ../raster/r.in.bin/main.c:426 ../raster/r.in.bin/main.c:433
+#: ../raster/r.in.bin/main.c:442
#, c-format
msgid "Try bytes=%d or adjusting input parameters"
msgstr ""
-#: ../raster/r.in.bin/main.c:479
+#: ../raster/r.in.bin/main.c:480
#, c-format
msgid "Conversion failed at row %d"
msgstr ""
@@ -6568,7 +6571,7 @@
msgid "Cannot get row"
msgstr ""
-#: ../raster/r.surf.idw2/read_cell.c:40 ../raster/r.series/main.c:172
+#: ../raster/r.surf.idw2/read_cell.c:40 ../raster/r.series/main.c:158
#, fuzzy, c-format
msgid "Reading raster map <%s>..."
msgstr " ."
@@ -6629,151 +6632,166 @@
msgid "reading r.stats output"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:96
-#: ../raster/simwe/r.sim.water/main.c:99
+#: ../raster/simwe/r.sim.sediment/main.c:107
+#, fuzzy
+msgid "raster, sediment flow, erosion, deposition"
+msgstr " "
+#: ../raster/simwe/r.sim.sediment/main.c:109
msgid ""
-"Overland flow hydrologic model based on duality particle-field concept "
-"(SIMWE)"
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:151
-msgid "Name of the elevation raster map"
-msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:162
+#: ../raster/simwe/r.sim.water/main.c:164
+#, fuzzy
+msgid "Name of the elevation raster map [m]"
+msgstr "×ÅËÔÏÒ"
-#: ../raster/simwe/r.sim.sediment/main.c:159
+#: ../raster/simwe/r.sim.sediment/main.c:167
#, fuzzy
-msgid "Name of the water height raster map"
+msgid "Name of the water depth raster map [m]"
msgstr " "
-#: ../raster/simwe/r.sim.sediment/main.c:167
-msgid "Name of the x-derivatives raster map"
-msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:172
+#: ../raster/simwe/r.sim.water/main.c:169
+#, fuzzy
+msgid "Name of the x-derivatives raster map [m/m]"
+msgstr " "
-#: ../raster/simwe/r.sim.sediment/main.c:175
-msgid "Name of the y-derivatives raster map"
-msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:177
+#: ../raster/simwe/r.sim.water/main.c:174
+#, fuzzy
+msgid "Name of the y-derivatives raster map [m/m]"
+msgstr " "
-#: ../raster/simwe/r.sim.sediment/main.c:184
+#: ../raster/simwe/r.sim.sediment/main.c:183
#, fuzzy
-msgid "Name of the detachment capacity coefficient raster map"
+msgid "Name of the detachment capacity coefficient raster map [s/m]"
msgstr "×ÅËÔÏÒ"
-#: ../raster/simwe/r.sim.sediment/main.c:193
+#: ../raster/simwe/r.sim.sediment/main.c:189
#, fuzzy
-msgid "Name of the transport capacity coefficient raster map"
+msgid "Name of the transport capacity coefficient raster map [s]"
msgstr "×ÅËÔÏÒ"
-#: ../raster/simwe/r.sim.sediment/main.c:201
+#: ../raster/simwe/r.sim.sediment/main.c:194
#, fuzzy
-msgid "Name of the critical shear stress raster map"
+msgid "Name of the critical shear stress raster map [Pa]"
msgstr " "
-#: ../raster/simwe/r.sim.sediment/main.c:209
-#: ../raster/simwe/r.sim.water/main.c:200
+#: ../raster/simwe/r.sim.sediment/main.c:200
+#: ../raster/simwe/r.sim.water/main.c:208
msgid "Name of the Mannings n raster map"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:218
-#: ../raster/simwe/r.sim.water/main.c:209
+#: ../raster/simwe/r.sim.sediment/main.c:208
#, fuzzy
-msgid "Name of the vector points map with x,y locations"
+msgid "Name of the Mannings n value"
+msgstr " "
+#: ../raster/simwe/r.sim.sediment/main.c:215
+#: ../raster/simwe/r.sim.water/main.c:229
+#, fuzzy
+msgid "Name of the sampling locations vector points map"
msgstr "×ÅËÔÏÒ"
-#: ../raster/simwe/r.sim.sediment/main.c:226
+#: ../raster/simwe/r.sim.sediment/main.c:221
#, fuzzy
-msgid "Output transport capacity raster map"
+msgid "Output transport capacity raster map [kg/ms]"
msgstr "üËÓÐÏÚÉÃÉÑ"
-#: ../raster/simwe/r.sim.sediment/main.c:235
+#: ../raster/simwe/r.sim.sediment/main.c:228
#, fuzzy
-msgid "Output transp.limited erosion-deposition raster map"
+msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
msgstr "üËÓÐÏÚÉÃÉÑ"
-#: ../raster/simwe/r.sim.sediment/main.c:243
+#: ../raster/simwe/r.sim.sediment/main.c:234
#, fuzzy
-msgid "Output sediment concentration raster map"
+msgid "Output sediment concentration raster map [particle/m3]"
msgstr "üËÓÐÏÚÉÃÉÑ"
-#: ../raster/simwe/r.sim.sediment/main.c:251
+#: ../raster/simwe/r.sim.sediment/main.c:240
#, fuzzy
-msgid "Output sediment flux raster map"
+msgid "Output sediment flux raster map [kg/ms]"
msgstr "üËÓÐÏÚÉÃÉÑ"
-#: ../raster/simwe/r.sim.sediment/main.c:259
+#: ../raster/simwe/r.sim.sediment/main.c:246
#, fuzzy
-msgid "Output erosion-deposition raster map"
+msgid "Output erosion-deposition raster map [kg/m2s]"
msgstr "óËÌÏÎÙ"
-#: ../raster/simwe/r.sim.sediment/main.c:267
-#: ../raster/simwe/r.sim.water/main.c:249
+#: ../raster/simwe/r.sim.sediment/main.c:254
msgid "Number of walkers"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:268
-#: ../raster/simwe/r.sim.sediment/main.c:276
-#: ../raster/simwe/r.sim.sediment/main.c:284
-#: ../raster/simwe/r.sim.sediment/main.c:292
-#: ../raster/simwe/r.sim.sediment/main.c:300
-#: ../raster/simwe/r.sim.water/main.c:250
-#: ../raster/simwe/r.sim.water/main.c:258
-#: ../raster/simwe/r.sim.water/main.c:266
-#: ../raster/simwe/r.sim.water/main.c:274
-#: ../raster/simwe/r.sim.water/main.c:282
-#: ../raster/simwe/r.sim.water/main.c:290
-#: ../raster/simwe/r.sim.water/main.c:298
-#: ../raster/simwe/r.sim.water/main.c:306
+#: ../raster/simwe/r.sim.sediment/main.c:255
+#: ../raster/simwe/r.sim.sediment/main.c:263
+#: ../raster/simwe/r.sim.sediment/main.c:271
+#: ../raster/simwe/r.sim.sediment/main.c:279
+#: ../raster/simwe/r.sim.sediment/main.c:287
+#: ../raster/simwe/r.sim.water/main.c:262
+#: ../raster/simwe/r.sim.water/main.c:270
+#: ../raster/simwe/r.sim.water/main.c:278
+#: ../raster/simwe/r.sim.water/main.c:286
+#: ../raster/simwe/r.sim.water/main.c:294
+#: ../raster/simwe/r.sim.water/main.c:302
+#: ../raster/simwe/r.sim.water/main.c:310
+#: ../raster/simwe/r.sim.water/main.c:318
msgid "Parameters"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:275
-#: ../raster/simwe/r.sim.water/main.c:257
-msgid "Number of time iterations (sec.)"
+#: ../raster/simwe/r.sim.sediment/main.c:262
+#: ../raster/simwe/r.sim.water/main.c:269
+msgid "Time used for iterations [minutes]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:283
-#: ../raster/simwe/r.sim.water/main.c:265
-msgid "Time step for saving output maps (sec.)"
+#: ../raster/simwe/r.sim.sediment/main.c:270
+#: ../raster/simwe/r.sim.water/main.c:277
+msgid "Time interval for creating output maps [minutes]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:291
-#: ../raster/simwe/r.sim.water/main.c:273
+#: ../raster/simwe/r.sim.sediment/main.c:278
+#: ../raster/simwe/r.sim.water/main.c:285
msgid "Density of output walkers"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:299
-#: ../raster/simwe/r.sim.water/main.c:281
+#: ../raster/simwe/r.sim.sediment/main.c:286
+#: ../raster/simwe/r.sim.water/main.c:293
msgid "Water diffusion constant"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:304
-#: ../raster/simwe/r.sim.water/main.c:310
-msgid "Multiscale simulation"
+#: ../raster/simwe/r.sim.sediment/main.c:332
+#: ../raster/simwe/r.sim.water/main.c:441
+msgid "More than 100 files are going to be created !!!!!"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:308
-#: ../raster/simwe/r.sim.water/main.c:314
-msgid "Time-series (dynamic) output"
+#: ../raster/simwe/r.sim.sediment/main.c:338
+#: ../raster/simwe/r.sim.water/main.c:447
+#, c-format
+msgid "default nwalk=%d, rwalk=%f"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:342
-#: ../raster/simwe/r.sim.water/main.c:350
+#: ../raster/simwe/r.sim.sediment/main.c:346
+#: ../raster/simwe/r.sim.water/main.c:456
#, c-format
msgid "Using metric conversion factor %f, step=%f"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:350
+#: ../raster/simwe/r.sim.sediment/main.c:353
#, fuzzy
msgid "You are not outputing any raster or site files"
msgstr " ×ÅËÔÏÒ"
-#: ../raster/simwe/r.sim.sediment/main.c:354
-#: ../raster/simwe/r.sim.water/main.c:362 ../vector/v.surf.rst/main.c:654
+#: ../raster/simwe/r.sim.sediment/main.c:356
+#: ../raster/simwe/r.sim.water/main.c:466 ../vector/v.surf.rst/main.c:654
#: ../vector/v.surf.rst/main.c:708
msgid "Input failed"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:434
-#: ../raster/simwe/r.sim.water/main.c:423
+#: ../raster/simwe/r.sim.sediment/main.c:424
+#: ../raster/simwe/r.sim.water/main.c:517
#, fuzzy
msgid "Cannot write raster maps"
msgstr " "
@@ -6798,19 +6816,66 @@
msgid "Reading sites map (%s) ..."
msgstr " ."
-#: ../raster/simwe/simlib/input.c:168
-msgid "Running MAY 10 version"
+#: ../raster/simwe/simlib/input.c:406
+#, c-format
+msgid ""
+"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
+"to process"
msgstr ""
-#: ../raster/simwe/simlib/input.c:468
+#: ../raster/simwe/simlib/input.c:539
msgid "Zero value in Mannings n"
msgstr ""
-#: ../raster/simwe/simlib/input.c:522
+#: ../raster/simwe/simlib/input.c:586
msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
msgstr ""
-#: ../raster/simwe/simlib/input.c:602
+#: ../raster/simwe/simlib/input.c:607
+#, c-format
+msgid ""
+"Min elevation \t= %.2f m\n"
+"Max elevation \t= %.2f m\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:608
+#, c-format
+msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:609
+#, c-format
+msgid "Mean flow velocity \t= %f m/s\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:610
+#, c-format
+msgid "Mean Mannings \t= %f\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:614
+#, fuzzy, c-format
+msgid "Number of iterations \t= %d cells\n"
+msgstr " "
+#: ../raster/simwe/simlib/input.c:615
+#, c-format
+msgid "Time step \t= %.2f s\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:617
+#, c-format
+msgid ""
+"Sigmax \t= %f\n"
+"Max velocity \t= %f m/s\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:618
+#, c-format
+msgid "Time step used \t= %.2f s\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:668
#, fuzzy
msgid "Unable to write et file"
msgstr " "
@@ -6824,168 +6889,177 @@
msgid "Unable to write raster maps"
msgstr " "
-#: ../raster/simwe/r.sim.water/main.c:152
+#: ../raster/simwe/r.sim.water/main.c:112
#, fuzzy
-msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-msgstr "éÍÑ ÒÁÓÔÒÏ×ÏÇÏ ÆÁÊÌÁ-ÍÁÓËÉ"
+msgid "raster, flow, hydrology"
+msgstr "×ÅËÔÏÒ"
-#: ../raster/simwe/r.sim.water/main.c:160
-#, fuzzy
-msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-msgstr " "
+#: ../raster/simwe/r.sim.water/main.c:114
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:168
-#, fuzzy
-msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-msgstr " "
-#: ../raster/simwe/r.sim.water/main.c:176
+#: ../raster/simwe/r.sim.water/main.c:180
msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:184
+#: ../raster/simwe/r.sim.water/main.c:188
+msgid "Rainfall excess rate unique value [mm/hr]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:194
#, fuzzy
msgid "Name of the runoff infiltration rate raster map [mm/hr]"
msgstr " "
-#: ../raster/simwe/r.sim.water/main.c:192
-msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:202
+#, fuzzy
+msgid "Runoff infiltration rate unique value [mm/hr]"
+msgstr " "
-#: ../raster/simwe/r.sim.water/main.c:217
-msgid "Output water depth raster map"
+#: ../raster/simwe/r.sim.water/main.c:216
+msgid "Mannings n unique value"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:225
-msgid "Output water discharge raster map"
+#: ../raster/simwe/r.sim.water/main.c:222
+msgid "Name of the flow controls raster map (permeability ratio 0-1)"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:233
-msgid "Output simulation error raster map"
-msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:235
+#, fuzzy
+msgid "Output water depth raster map [m]"
+msgstr "üËÓÐÏÚÉÃÉÑ"
#: ../raster/simwe/r.sim.water/main.c:241
#, fuzzy
+msgid "Output water discharge raster map [m3/s]"
+msgstr " "
+#: ../raster/simwe/r.sim.water/main.c:247
+#, fuzzy
+msgid "Output simulation error raster map [m]"
+msgstr "óËÌÏÎÙ"
+#: ../raster/simwe/r.sim.water/main.c:253
+#, fuzzy
msgid "Name of the output walkers vector points map"
msgstr "×ÅËÔÏÒ"
-#: ../raster/simwe/r.sim.water/main.c:289
+#: ../raster/simwe/r.sim.water/main.c:261
+msgid "Number of walkers, default is twice the no. of cells"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:301
#, fuzzy
msgid ""
-"Threshold water depth (diffusion increases after this water depth is reached)"
+"Threshold water depth [m] (diffusion increases after this water depth is "
+"reached)"
msgstr " "
-#: ../raster/simwe/r.sim.water/main.c:297
+#: ../raster/simwe/r.sim.water/main.c:309
msgid "Diffusion increase constant"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:305
+#: ../raster/simwe/r.sim.water/main.c:317
#, fuzzy
msgid "Weighting factor for water flow velocity vector"
msgstr "×ÅËÔÏÒ"
-#: ../raster/simwe/r.sim.water/main.c:358
+#: ../raster/simwe/r.sim.water/main.c:326
+msgid "Time-series output"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:463
#, fuzzy
msgid "You are not outputting any raster or vector points maps"
msgstr " ×ÅËÔÏÒ"
-#: ../raster/r.out.mat/main.c:63
+#: ../raster/r.out.mat/main.c:61
msgid "Exports a GRASS raster to a binary MAT-File."
msgstr ""
-#: ../raster/r.out.mat/main.c:74
+#: ../raster/r.out.mat/main.c:72
msgid "Name for the output binary MAT-File"
msgstr ""
-#: ../raster/r.out.mat/main.c:106 ../raster/r.out.pov/main.c:183
+#: ../raster/r.out.mat/main.c:97 ../raster/r.out.pov/main.c:183
#, fuzzy, c-format
msgid "Unable to open output file <%s>"
msgstr " "
-#: ../raster/r.out.mat/main.c:128
+#: ../raster/r.out.mat/main.c:119
#, fuzzy, c-format
msgid "Exporting <%s>"
msgstr " "
-#: ../raster/r.out.mat/main.c:189 ../raster/r.cost/main.c:225
-#: ../raster/r.in.mat/main.c:378 ../raster/r.out.tiff/r.out.tiff.c:145
-#: ../raster/wildfire/r.ros/main.c:304 ../raster/wildfire/r.spread/main.c:248
-#: ../vector/v.kernel/main.c:171 ../display/d.vect/main.c:366
-#: ../display/d.mon/pgms/release.c:37
-msgid ""
-"The '-v' flag is superseded and will be removed in future. Please use '--"
-"verbose' instead."
-msgstr ""
-#: ../raster/r.out.mat/main.c:195
+#: ../raster/r.out.mat/main.c:178
msgid "Using the Current Region settings:"
msgstr ""
-#: ../raster/r.out.mat/main.c:196
+#: ../raster/r.out.mat/main.c:179 ../raster/r.in.mat/main.c:382
#, c-format
msgid "northern edge=%f"
msgstr ""
-#: ../raster/r.out.mat/main.c:197
+#: ../raster/r.out.mat/main.c:180 ../raster/r.in.mat/main.c:383
#, c-format
msgid "southern edge=%f"
msgstr ""
-#: ../raster/r.out.mat/main.c:198
+#: ../raster/r.out.mat/main.c:181 ../raster/r.in.mat/main.c:384
#, c-format
msgid "eastern edge=%f"
msgstr ""
-#: ../raster/r.out.mat/main.c:199
+#: ../raster/r.out.mat/main.c:182 ../raster/r.in.mat/main.c:385
#, c-format
msgid "western edge=%f"
msgstr ""
-#: ../raster/r.out.mat/main.c:200
+#: ../raster/r.out.mat/main.c:183 ../raster/r.in.mat/main.c:386
#, c-format
msgid "nsres=%f"
msgstr ""
-#: ../raster/r.out.mat/main.c:201
+#: ../raster/r.out.mat/main.c:184 ../raster/r.in.mat/main.c:387
#, c-format
msgid "ewres=%f"
msgstr ""
-#: ../raster/r.out.mat/main.c:202
+#: ../raster/r.out.mat/main.c:185 ../raster/r.in.mat/main.c:388
#, c-format
msgid "rows=%d"
msgstr ""
-#: ../raster/r.out.mat/main.c:203
+#: ../raster/r.out.mat/main.c:186 ../raster/r.in.mat/main.c:389
#, fuzzy, c-format
msgid "cols=%d"
msgstr " "
-#: ../raster/r.out.mat/main.c:269
+#: ../raster/r.out.mat/main.c:253
#, fuzzy
msgid "Exporting raster as integer values"
msgstr "óÇÌÁÖÉ×ÁÎÉÅ ÄÏÌÖÎÏ ÂÙÔØ ÐÏÌÏÖÉÔÅÌØÎÙÍ"
-#: ../raster/r.out.mat/main.c:274
+#: ../raster/r.out.mat/main.c:258
#, fuzzy
msgid "Exporting raster as floating point values"
msgstr " "
-#: ../raster/r.out.mat/main.c:279
+#: ../raster/r.out.mat/main.c:263
msgid "Exporting raster as double FP values"
msgstr ""
-#: ../raster/r.out.mat/main.c:319
+#: ../raster/r.out.mat/main.c:303
#, fuzzy
msgid "Reading in map ... "
-#: ../raster/r.out.mat/main.c:331
+#: ../raster/r.out.mat/main.c:315
#, fuzzy
msgid "Writing out map..."
msgstr " "
-#: ../raster/r.out.mat/main.c:385
+#: ../raster/r.out.mat/main.c:369
#, fuzzy, c-format
msgid "%ld bytes written to '%s'"
msgstr "×ÅËÔÏÒ"
@@ -7087,7 +7161,7 @@
msgid "This module currently only works for integer (CELL) maps"
msgstr ""
-#: ../raster/r.statistics/main.c:88 ../raster/r.report/parse.c:274
+#: ../raster/r.statistics/main.c:88 ../raster/r.report/parse.c:269
#: ../raster/r.support/front/front.c:224 ../raster/r.cats/main.c:148
#: ../raster/r.cats/main.c:204 ../raster/r.mapcalc/map3.c:195
#: ../raster/r.mapcalc/map.c:88 ../display/d.title/main.c:111
@@ -7167,107 +7241,108 @@
msgid "Unable to read range file"
msgstr " "
-#: ../raster/r.compress/main.c:65
+#: ../raster/r.compress/main.c:62
msgid "Compresses and decompresses raster maps."
msgstr ""
-#: ../raster/r.compress/main.c:73 ../display/d.what.rast/main.c:75
+#: ../raster/r.compress/main.c:70 ../display/d.what.rast/main.c:75
#, fuzzy
msgid "Name of existing raster map(s)"
msgstr " "
-#: ../raster/r.compress/main.c:77
+#: ../raster/r.compress/main.c:74
msgid "Uncompress the map"
msgstr ""
-#: ../raster/r.compress/main.c:119
+#: ../raster/r.compress/main.c:104
#, fuzzy, c-format
msgid "[%s] not found"
msgstr " "
-#: ../raster/r.compress/main.c:125
+#: ../raster/r.compress/main.c:110
#, fuzzy, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
msgstr " !"
-#: ../raster/r.compress/main.c:126
+#: ../raster/r.compress/main.c:111
#, fuzzy, c-format
msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
msgstr " !"
-#: ../raster/r.compress/main.c:171
+#: ../raster/r.compress/main.c:156
#, c-format
msgid "DONE: uncompressed file is %lu bytes smaller"
msgstr ""
-#: ../raster/r.compress/main.c:172
+#: ../raster/r.compress/main.c:157
#, c-format
msgid "DONE: compressed file is %lu bytes smaller"
msgstr ""
-#: ../raster/r.compress/main.c:176
+#: ../raster/r.compress/main.c:161
#, c-format
msgid "DONE: uncompressed file is %lu bytes bigger"
msgstr ""
-#: ../raster/r.compress/main.c:177
+#: ../raster/r.compress/main.c:162
#, c-format
msgid "DONE: compressed file is %lu bytes bigger"
msgstr ""
-#: ../raster/r.compress/main.c:202
+#: ../raster/r.compress/main.c:187
#, fuzzy, c-format
msgid "[%s] already uncompressed"
msgstr " "
-#: ../raster/r.compress/main.c:207
+#: ../raster/r.compress/main.c:192
#, fuzzy, c-format
msgid "[%s] already compressed"
msgstr " "
-#: ../raster/r.compress/main.c:211
+#: ../raster/r.compress/main.c:196
#, c-format
msgid ""
"\n"
"%sCOMPRESS [%s]"
msgstr ""
-#: ../raster/r.patch/main.c:55
+#: ../raster/r.patch/main.c:54
#, fuzzy
msgid ""
"Creates a composite raster map layer by using known category values from one "
"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
msgstr " ."
-#: ../raster/r.patch/main.c:62
+#: ../raster/r.patch/main.c:61
msgid "Name of raster maps to be patched together"
msgstr ""
-#: ../raster/r.patch/main.c:65
+#: ../raster/r.patch/main.c:64
#, fuzzy
msgid "Name for resultant raster map"
msgstr " "
-#: ../raster/r.patch/main.c:76
+#: ../raster/r.patch/main.c:70
msgid "Use zero (0) for transparency instead of NULL"
msgstr ""
-#: ../raster/r.patch/main.c:102
+#: ../raster/r.patch/main.c:88
#, fuzzy
msgid "The minimum number of input raster maps is two"
msgstr " ."
-#: ../raster/r.patch/main.c:142
+#: ../raster/r.patch/main.c:128
#, fuzzy
msgid "One or more input raster maps not found"
msgstr " "
-#: ../raster/r.patch/main.c:155 ../raster/r.series/main.c:196
+#: ../raster/r.patch/main.c:141 ../raster/r.slope.aspect/main.c:582
+#: ../raster/r.series/main.c:182
#, fuzzy
msgid "Percent complete..."
msgstr "úÁ×ÅÒÛÅÎÏ:"
-#: ../raster/r.patch/main.c:185
+#: ../raster/r.patch/main.c:171
#, fuzzy, c-format
msgid "Creating support files for raster map <%s>"
msgstr " "
@@ -7400,6 +7475,14 @@
msgid "Value to write for \"grown\" cells"
msgstr ""
+#: ../raster/r.grow2/main.c:165 ../raster/r.report/parse.c:90
+#: ../raster/r.bitpattern/main.c:87 ../vector/v.perturb/main.c:116
+#: ../vector/v.kcv/main.c:104 ../doc/raster/r.example/main.c:95
+#: ../imagery/i.cluster/main.c:135
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:281
+msgid "Quiet"
+msgstr ""
#: ../raster/r.grow2/main.c:197
#, fuzzy, c-format
msgid "Unknown metric: [%s]."
@@ -8017,16 +8100,15 @@
msgstr " "
#: ../raster/r.flow/io.c:182 ../vector/v.net.visibility/main.c:86
-#: ../vector/v.edit/cmd/main.c:85
-#: ../vector/lidar/v.lidar.edgedetection/main.c:169
+#: ../vector/v.edit/main.c:99 ../vector/lidar/v.lidar.edgedetection/main.c:169
#: ../vector/lidar/v.lidar.correction/main.c:147
#: ../vector/lidar/v.lidar.correction/main.c:153
#: ../vector/lidar/v.outlier/main.c:149 ../vector/lidar/v.outlier/main.c:153
#: ../vector/lidar/v.outlier/main.c:159
#: ../vector/lidar/v.surf.bspline/main.c:260 ../vector/v.generalize/main.c:312
-#: ../vector/v.mkgrid/main.c:196 ../vector/v.net.path/main.c:134
-#: ../vector/v.voronoi/dt_main.c:82 ../vector/v.voronoi/vo_main.c:152
-#: ../vector/v.hull/main.c:273 ../doc/vector/v.example/main.c:70
+#: ../vector/v.mkgrid/main.c:181 ../vector/v.net.path/main.c:134
+#: ../vector/v.voronoi/dt_main.c:92 ../vector/v.voronoi/dt_main.c:96
+#: ../vector/v.voronoi/vo_main.c:152 ../doc/vector/v.example/main.c:70
#, fuzzy, c-format
msgid "Unable to create vector map <%s>"
msgstr " "
@@ -8121,23 +8203,23 @@
msgid "Negative elevation values in input"
msgstr ""
-#: ../raster/r.covar/main.c:54
+#: ../raster/r.covar/main.c:51
#, fuzzy
msgid ""
"Outputs a covariance/correlation matrix for user-specified raster map layer"
"(s)."
msgstr " ."
-#: ../raster/r.covar/main.c:61
+#: ../raster/r.covar/main.c:58
msgid "Print correlation matrix"
msgstr ""
-#: ../raster/r.covar/main.c:105
+#: ../raster/r.covar/main.c:90
#, fuzzy, c-format
msgid "%s: complete ... "
msgstr " "
-#: ../raster/r.covar/main.c:133
+#: ../raster/r.covar/main.c:118
msgid "No non-null values"
msgstr ""
@@ -8259,7 +8341,7 @@
msgid "Only %d unit%s allowed"
msgstr " "
-#: ../raster/r.report/parse.c:265
+#: ../raster/r.report/parse.c:261
#, fuzzy, c-format
msgid "Unable to read fp range for raster map <%s>"
msgstr " !"
@@ -8411,69 +8493,80 @@
msgid "Selected band (%d) does not exist"
msgstr " "
-#: ../raster/r.in.gdal/main.c:515
+#: ../raster/r.in.gdal/main.c:516
#, fuzzy, c-format
msgid "Copying %d GCPS in points file for <%s>"
msgstr " ."
-#: ../raster/r.in.gdal/main.c:520
+#: ../raster/r.in.gdal/main.c:521
msgid "GCPs have the following OpenGIS WKT Coordinate System:"
msgstr ""
-#: ../raster/r.in.gdal/main.c:529
+#: ../raster/r.in.gdal/main.c:530
#, fuzzy
msgid "Re-projecting GCPs table:"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.in.gdal/main.c:530
+#: ../raster/r.in.gdal/main.c:531
#, c-format
msgid "* Input projection for GCP table: %s"
msgstr ""
-#: ../raster/r.in.gdal/main.c:532
+#: ../raster/r.in.gdal/main.c:533
#, c-format
msgid "* Output projection for GCP table: %s"
msgstr ""
-#: ../raster/r.in.gdal/main.c:551
+#: ../raster/r.in.gdal/main.c:552
#, c-format
msgid "Error in pj_do_proj (can't re-projection GCP %i)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:615
+#: ../raster/r.in.gdal/main.c:616
#, fuzzy
msgid "Unable to translate projection key values of input GCPs"
msgstr "òÁÊÏÎ"
-#: ../raster/r.in.gdal/main.c:631
+#: ../raster/r.in.gdal/main.c:632
#, fuzzy
msgid "Unable to get projection info of target location"
msgstr "òÁÊÏÎ"
-#: ../raster/r.in.gdal/main.c:633
+#: ../raster/r.in.gdal/main.c:634
#, fuzzy
msgid "Unable to get projection units of target location"
msgstr "òÁÊÏÎ"
-#: ../raster/r.in.gdal/main.c:635
+#: ../raster/r.in.gdal/main.c:636
#, fuzzy
msgid "Unable to get projection key values of target location"
msgstr "òÁÊÏÎ"
-#: ../raster/r.in.gdal/main.c:639
+#: ../raster/r.in.gdal/main.c:640
#, fuzzy, c-format
msgid "Mapset <%s> in target location <%s> - "
msgstr "îÁÂÏÒ ÄÁÎÎÙÈ "
-#: ../raster/r.rescale/main.c:50
+#: ../raster/r.in.gdal/main.c:940
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (8bit, full range)"
+msgstr " ."
+#: ../raster/r.in.gdal/main.c:953
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (16bit, image range)"
+msgstr " ."
+#: ../raster/r.in.gdal/main.c:963
+#, fuzzy, c-format
+msgid "<%s> created"
+msgstr "òÁÊÏÎ !"
+#: ../raster/r.rescale/main.c:45
msgid "Rescales the range of category values in a raster map layer."
msgstr ""
-#: ../raster/r.rescale/main.c:93
-msgid "Quietly"
-msgstr ""
-#: ../raster/r.rescale/main.c:144
+#: ../raster/r.rescale/main.c:127
#, c-format
msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
msgstr ""
@@ -8939,8 +9032,8 @@
msgstr ""
#: ../raster/r.his/main.c:143 ../raster/r.his/main.c:165
-#: ../raster/r.his/main.c:193 ../raster/r.out.ppm3/main.c:128
-#: ../raster/r.composite/main.c:174 ../display/d.rast.edit/cell.c:51
+#: ../raster/r.his/main.c:193 ../raster/r.out.ppm3/main.c:114
+#: ../raster/r.composite/main.c:170 ../display/d.rast.edit/cell.c:51
#: ../display/d.histogram/main.c:160 ../display/d.rast.num/number.c:281
#: ../display/d.legend/main.c:255 ../display/d.rast/display.c:22
#: ../display/d.rgb/main.c:110 ../display/d.his/main.c:152
@@ -9084,22 +9177,15 @@
msgid "132 columns (default: 80)"
msgstr ""
-#: ../raster/r.kappa/main.c:86
+#: ../raster/r.kappa/main.c:81
msgid "No header in the report"
msgstr ""
-#: ../raster/r.kappa/main.c:101 ../imagery/i.cca/main.c:116
+#: ../raster/r.kappa/main.c:96 ../imagery/i.cca/main.c:116
#, fuzzy, c-format
msgid "Illegal output file name <%s>"
msgstr " "
-#: ../raster/r.kappa/main.c:113 ../raster/r.out.ppm/main.c:80
-#: ../raster/r.mfilter.fp/main.c:107 ../raster/r.mfilter/main.c:100
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead"
-msgstr ""
#: ../raster/r.kappa/prt_mat.c:39
#, fuzzy, c-format
msgid "Cannot open file <%s> to write cats and counts (error matrix)"
@@ -9327,9 +9413,8 @@
msgid "Cannot set region to back to the initial region !!!"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:528 ../raster/r.slope.aspect/main.c:609
-#: ../raster/r.resample/main.c:137 ../vector/v.surf.rst/main.c:566
-#: ../vector/v.surf.rst/main.c:712
+#: ../raster/r.resamp.rst/main.c:528 ../raster/r.resample/main.c:123
+#: ../vector/v.surf.rst/main.c:566 ../vector/v.surf.rst/main.c:712
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:609
#, fuzzy
msgid "Percent complete: "
@@ -9418,7 +9503,7 @@
msgid "nsteps must be greater than zero; using nsteps=255"
msgstr ""
-#: ../raster/r.stats/main.c:253 ../raster/r.series/main.c:160
+#: ../raster/r.stats/main.c:253 ../raster/r.series/main.c:146
#, fuzzy
msgid "Raster map not found"
msgstr " "
@@ -9491,54 +9576,51 @@
msgid "Statistic to use for raster values"
msgstr ""
-#: ../raster/r.in.xyz/main.c:167 ../raster/r.in.xyz/main.c:176
-#: ../vector/v.out.ogr/main.c:111 ../vector/v.out.ogr/main.c:124
-#: ../vector/v.out.ogr/main.c:133 ../vector/v.out.ogr/main.c:142
-#, fuzzy
-msgid "Output"
-msgstr " "
+#: ../raster/r.in.xyz/main.c:167 ../raster/r.in.xyz/main.c:228
+#: ../raster/r.in.xyz/main.c:237
+msgid "Statistic"
+msgstr ""
#: ../raster/r.in.xyz/main.c:175 ../raster/r.in.arc/main.c:78
msgid "Storage type for resultant raster map"
msgstr ""
-#: ../raster/r.in.xyz/main.c:179 ../raster/r.in.xyz/main.c:188
-#: ../raster/r.in.xyz/main.c:197 ../raster/r.in.xyz/main.c:206
-#: ../raster/r.in.xyz/main.c:214 ../vector/v.edit/cmd/args.c:98
-#: ../vector/v.edit/cmd/args.c:211 ../vector/v.out.ogr/main.c:96
-#: ../vector/v.out.ogr/main.c:114
+#: ../raster/r.in.xyz/main.c:178 ../raster/r.in.xyz/main.c:187
+#: ../raster/r.in.xyz/main.c:196 ../raster/r.in.xyz/main.c:205
+#: ../vector/v.edit/args.c:100 ../vector/v.edit/args.c:213
+#: ../vector/v.out.ogr/main.c:98 ../vector/v.out.ogr/main.c:116
#, fuzzy
msgid "Input"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.in.xyz/main.c:187
+#: ../raster/r.in.xyz/main.c:186
#, fuzzy
msgid "Column number of x coordinates in input file (first column is 1)"
msgstr " "
-#: ../raster/r.in.xyz/main.c:196
+#: ../raster/r.in.xyz/main.c:195
msgid "Column number of y coordinates in input file"
msgstr ""
-#: ../raster/r.in.xyz/main.c:205
+#: ../raster/r.in.xyz/main.c:204
msgid "Column number of data values in input file"
msgstr ""
-#: ../raster/r.in.xyz/main.c:213
+#: ../raster/r.in.xyz/main.c:212
msgid "Filter range for z data (min,max)"
msgstr ""
-#: ../raster/r.in.xyz/main.c:222 ../raster/r.cost/main.c:198
-#: ../raster/r.walk/main.c:258
+#: ../raster/r.in.xyz/main.c:220 ../raster/r.cost/main.c:195
+#: ../raster/r.walk/main.c:255
msgid "Percent of map to keep in memory"
msgstr ""
-#: ../raster/r.in.xyz/main.c:229
+#: ../raster/r.in.xyz/main.c:227
#, fuzzy
msgid "pth percentile of the values"
msgstr "óËÌÏÎÙ"
-#: ../raster/r.in.xyz/main.c:237
+#: ../raster/r.in.xyz/main.c:236
msgid ""
"Discard <trim> percent of the smallest and <trim> percent of the largest "
"observations"
@@ -9552,19 +9634,23 @@
msgid "In scan mode, print using shell script style"
msgstr ""
-#: ../raster/r.in.xyz/main.c:269
+#: ../raster/r.in.xyz/main.c:249
+msgid "Ignore broken lines"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:272
msgid "Please specify a reasonable column number."
msgstr ""
-#: ../raster/r.in.xyz/main.c:364
+#: ../raster/r.in.xyz/main.c:367
msgid "Unable to calculate percentile without the pth option specified!"
msgstr ""
-#: ../raster/r.in.xyz/main.c:377
+#: ../raster/r.in.xyz/main.c:380
msgid "Unable to calculate trimmed mean without the trim option specified!"
msgstr ""
-#: ../raster/r.in.xyz/main.c:438 ../raster/r.in.mat/main.c:138
+#: ../raster/r.in.xyz/main.c:441 ../raster/r.in.mat/main.c:125
#: ../raster/r.in.arc/main.c:123 ../vector/v.segment/main.c:89
#: ../vector/v.net.path/path.c:46 ../vector/v.lrs/v.lrs.segment/main.c:129
#: ../display/d.linegraph/linegraph.c:194
@@ -9573,25 +9659,26 @@
msgid "Unable to open input file <%s>"
msgstr " ."
-#: ../raster/r.in.xyz/main.c:445
+#: ../raster/r.in.xyz/main.c:448
msgid ""
"If input is not from a file it is only possible to perform a single pass."
msgstr ""
-#: ../raster/r.in.xyz/main.c:451
+#: ../raster/r.in.xyz/main.c:454
msgid "zrange will not be taken into account during scan"
msgstr ""
-#: ../raster/r.in.xyz/main.c:487 ../raster/r.in.xyz/main.c:1017
+#: ../raster/r.in.xyz/main.c:490 ../raster/r.in.xyz/main.c:1029
msgid "Scanning data ..."
msgstr ""
-#: ../raster/r.in.xyz/main.c:494 ../raster/r.in.poly/poly2rast.c:42
+#: ../raster/r.in.xyz/main.c:497 ../raster/r.in.poly/poly2rast.c:42
#, c-format
msgid "Pass #%d (of %d) ..."
msgstr ""
-#: ../raster/r.in.xyz/main.c:563
+#: ../raster/r.in.xyz/main.c:567 ../raster/r.in.xyz/main.c:573
+#: ../raster/r.in.xyz/main.c:1044 ../raster/r.in.xyz/main.c:1050
#, fuzzy, c-format
msgid ""
"Not enough data columns. Incorrect delimiter or column number? Found the "
@@ -9599,48 +9686,50 @@
"[%s]"
msgstr " "
-#: ../raster/r.in.xyz/main.c:575 ../raster/r.in.xyz/main.c:1054
+#: ../raster/r.in.xyz/main.c:570 ../raster/r.in.xyz/main.c:1047
+msgid "Line ignored as requested"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:587 ../raster/r.in.xyz/main.c:1076
#, fuzzy, c-format
msgid "Bad y-coordinate line %d column %d. <%s>"
msgstr " "
-#: ../raster/r.in.xyz/main.c:581 ../raster/r.in.xyz/main.c:1042
+#: ../raster/r.in.xyz/main.c:593 ../raster/r.in.xyz/main.c:1064
#, fuzzy, c-format
msgid "Bad x-coordinate line %d column %d. <%s>"
msgstr " "
-#: ../raster/r.in.xyz/main.c:587 ../raster/r.in.xyz/main.c:1066
+#: ../raster/r.in.xyz/main.c:599 ../raster/r.in.xyz/main.c:1088
#, fuzzy, c-format
msgid "Bad z-coordinate line %d column %d. <%s>"
msgstr " "
-#: ../raster/r.in.xyz/main.c:660
+#: ../raster/r.in.xyz/main.c:672
msgid "Writing to map ..."
msgstr ""
-#: ../raster/r.in.xyz/main.c:951
+#: ../raster/r.in.xyz/main.c:963
#, c-format
msgid "Writing map, row %d"
msgstr ""
-#: ../raster/r.in.xyz/main.c:992
+#: ../raster/r.in.xyz/main.c:1004
#, c-format
msgid "%d points found in region."
msgstr ""
-#: ../raster/r.in.xyz/main.c:1031
-#, fuzzy, c-format
-msgid ""
-"Not enough data columns. Incorrect delimiter or column number?\n"
-"[%s]"
-msgstr " "
-#: ../raster/r.in.xyz/main.c:1083
+#: ../raster/r.in.xyz/main.c:1105
#, c-format
msgid "Range: min max\n"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:154
+#: ../raster/r.slope.aspect/main.c:150
+#, fuzzy
+msgid "raster, terrain analysis"
+msgstr " "
+#: ../raster/r.slope.aspect/main.c:152
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:154
#, fuzzy
msgid ""
@@ -9649,44 +9738,37 @@
"calculated counterclockwise from east."
msgstr "óËÌÏÎÙ üËÓÐÏÚÉÃÉÑ üËÓÐÏÚÉÃÉÑ ."
-#: ../raster/r.slope.aspect/main.c:163
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:163
-msgid "Raster elevation file name"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:171
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:171
+#: ../raster/r.slope.aspect/main.c:164
#, fuzzy
-msgid "Output slope filename"
-msgstr "óËÌÏÎÙ"
+msgid "Name for output slope raster map"
+msgstr "×ÅËÔÏÒ"
-#: ../raster/r.slope.aspect/main.c:179
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:179
+#: ../raster/r.slope.aspect/main.c:172
#, fuzzy
-msgid "Output aspect filename"
-msgstr "üËÓÐÏÚÉÃÉÑ"
+msgid "Name for output aspect raster map"
+msgstr "×ÅËÔÏÒ"
-#: ../raster/r.slope.aspect/main.c:187
+#: ../raster/r.slope.aspect/main.c:180
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:187
#, fuzzy
msgid "Format for reporting the slope"
msgstr "óËÌÏÎÙ"
-#: ../raster/r.slope.aspect/main.c:196
+#: ../raster/r.slope.aspect/main.c:189
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:196
#, fuzzy
msgid "Type of output aspect and slope maps"
msgstr "üËÓÐÏÚÉÃÉÑ óËÌÏÎÙ"
-#: ../raster/r.slope.aspect/main.c:205
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:205
-msgid "Output profile curvature filename"
-msgstr ""
+#: ../raster/r.slope.aspect/main.c:198
+#, fuzzy
+msgid "Name for output profile curvature raster map"
+msgstr "×ÅËÔÏÒ"
-#: ../raster/r.slope.aspect/main.c:206 ../raster/r.slope.aspect/main.c:215
-#: ../raster/r.slope.aspect/main.c:224 ../raster/r.slope.aspect/main.c:233
-#: ../raster/r.slope.aspect/main.c:242 ../raster/r.slope.aspect/main.c:251
-#: ../raster/r.slope.aspect/main.c:260 ../vector/v.buffer/main.c:269
+#: ../raster/r.slope.aspect/main.c:199 ../raster/r.slope.aspect/main.c:208
+#: ../raster/r.slope.aspect/main.c:217 ../raster/r.slope.aspect/main.c:226
+#: ../raster/r.slope.aspect/main.c:235 ../raster/r.slope.aspect/main.c:244
+#: ../raster/r.slope.aspect/main.c:253 ../vector/v.buffer/main.c:269
#: ../vector/v.buffer/main.c:277 ../vector/v.buffer/main.c:284
#: ../vector/v.buffer/main.c:294 ../display/d.legend/main.c:107
#: ../display/d.legend/main.c:116 ../display/d.legend/main.c:124
@@ -9704,144 +9786,143 @@
msgid "Advanced"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:214
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:214
-msgid "Output tangential curvature filename"
-msgstr ""
+#: ../raster/r.slope.aspect/main.c:207
+#, fuzzy
+msgid "Name for output tangential curvature raster map"
+msgstr "×ÅËÔÏÒ"
-#: ../raster/r.slope.aspect/main.c:223
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:223
+#: ../raster/r.slope.aspect/main.c:216
#, fuzzy
-msgid "Output first order partial derivative dx (E-W slope) filename"
+msgid ""
+"Name for output first order partial derivative dx (E-W slope) raster map"
msgstr "óËÌÏÎÙ"
-#: ../raster/r.slope.aspect/main.c:232
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:232
+#: ../raster/r.slope.aspect/main.c:225
#, fuzzy
-msgid "Output first order partial derivative dy (N-S slope) filename"
+msgid ""
+"Name for output first order partial derivative dy (N-S slope) raster map"
msgstr "óËÌÏÎÙ"
-#: ../raster/r.slope.aspect/main.c:241
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:241
-msgid "Output second order partial derivative dxx filename"
-msgstr ""
+#: ../raster/r.slope.aspect/main.c:234
+#, fuzzy
+msgid "Name for output second order partial derivative dxx raster map"
+msgstr "óËÌÏÎÙ"
-#: ../raster/r.slope.aspect/main.c:250
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:250
-msgid "Output second order partial derivative dyy filename"
-msgstr ""
+#: ../raster/r.slope.aspect/main.c:243
+#, fuzzy
+msgid "Name for output second order partial derivative dyy raster map"
+msgstr "óËÌÏÎÙ"
-#: ../raster/r.slope.aspect/main.c:259
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:259
-msgid "Output second order partial derivative dxy filename"
-msgstr ""
+#: ../raster/r.slope.aspect/main.c:252
+#, fuzzy
+msgid "Name for output second order partial derivative dxy raster map"
+msgstr "óËÌÏÎÙ"
-#: ../raster/r.slope.aspect/main.c:264
+#: ../raster/r.slope.aspect/main.c:257
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:264
msgid "Multiplicative factor to convert elevation units to meters"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:272
+#: ../raster/r.slope.aspect/main.c:265
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:272
#, fuzzy
msgid "Minimum slope val. (in percent) for which aspect is computed"
msgstr "óËÌÏÎÙ üËÓÐÏÚÉÃÉÑ "
-#: ../raster/r.slope.aspect/main.c:285
+#: ../raster/r.slope.aspect/main.c:273
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:285
msgid "Do not align the current region to the elevation layer"
msgstr ""
-#: ../raster/r.slope.aspect/main.c:405
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:405
+#: ../raster/r.slope.aspect/main.c:327
#, fuzzy, c-format
-msgid "wrong type: %s"
-msgstr " "
+msgid "%s=%s - must be a positive number"
+msgstr " "
-#: ../raster/r.slope.aspect/main.c:1035 ../raster/r.clump/main.c:103
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1035
-#, fuzzy
-msgid "Creating support files..."
+#: ../raster/r.slope.aspect/main.c:333
+#, fuzzy, c-format
+msgid "%s=%s - must be a non-negative number"
+msgstr " "
+#: ../raster/r.slope.aspect/main.c:346
+#, c-format
+msgid ""
+"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%"
+"s>, <%s>, <%s>, <%s> or <%s>"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:378
+#, fuzzy, c-format
+msgid "Wrong raster type: %s"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1037
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1037
+#: ../raster/r.slope.aspect/main.c:407
+#, c-format
+msgid "Converting units to meters, factor=%.6f"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1011
#, fuzzy, c-format
-msgid "Elevation products for mapset [%s] in [%s]"
+msgid "Elevation products for mapset <%s> in <%s>"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1055
+#: ../raster/r.slope.aspect/main.c:1029
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1055
#, fuzzy, c-format
msgid "Min computed aspect %.4f, max computed aspect %.4f"
-#: ../raster/r.slope.aspect/main.c:1108
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1108
+#: ../raster/r.slope.aspect/main.c:1082
#, fuzzy, c-format
-msgid "ASPECT [%s] COMPLETE"
+msgid "Aspect raster map <%s> complete"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1148
+#: ../raster/r.slope.aspect/main.c:1122
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1148
#, fuzzy, c-format
msgid "Min computed slope %.4f, max computed slope %.4f"
-#: ../raster/r.slope.aspect/main.c:1198
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1198
+#: ../raster/r.slope.aspect/main.c:1172
#, fuzzy, c-format
-msgid "SLOPE [%s] COMPLETE"
+msgid "Slope raster map <%s> complete"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1267
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1267
+#: ../raster/r.slope.aspect/main.c:1241
#, fuzzy, c-format
-msgid "PROFILE CURVE [%s] COMPLETE"
+msgid "Profile curve raster map <%s> complete"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1294
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1294
+#: ../raster/r.slope.aspect/main.c:1268
#, fuzzy, c-format
-msgid "TANGENTIAL CURVE [%s] COMPLETE"
+msgid "Tangential curve raster map <%s> complete"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1319
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1319
+#: ../raster/r.slope.aspect/main.c:1293
#, fuzzy, c-format
-msgid "E-W SLOPE [%s] COMPLETE"
+msgid "E-W slope raster map <%s> complete"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1344
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1344
+#: ../raster/r.slope.aspect/main.c:1318
#, fuzzy, c-format
-msgid "N-S SLOPE [%s] COMPLETE"
+msgid "N-S slope raster map <%s> complete"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1369
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1369
+#: ../raster/r.slope.aspect/main.c:1343
#, fuzzy, c-format
-msgid "DXX [%s] COMPLETE"
+msgid "Dxx raster map <%s> complete"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1394
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1394
+#: ../raster/r.slope.aspect/main.c:1368
#, fuzzy, c-format
-msgid "DYY [%s] COMPLETE"
+msgid "Dyy raster map <%s> complete"
msgstr " "
-#: ../raster/r.slope.aspect/main.c:1419
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1419
+#: ../raster/r.slope.aspect/main.c:1393
#, fuzzy, c-format
-msgid "DXY [%s] COMPLETE"
+msgid "Dxy raster map <%s> complete"
msgstr " "
-#: ../raster/r.slope.aspect/opennew.c:19
-#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:19
-#, fuzzy, c-format
-msgid "Failed in attempt to open %s"
-msgstr " "
#: ../raster/r.surf.gauss/main.c:45
msgid ""
"GRASS module to produce a raster map layer of gaussian deviates whose mean "
@@ -9869,107 +9950,149 @@
"Please try another."
msgstr " ."
+#: ../raster/r.colors/main.c:125
+#, fuzzy
+msgid "raster, color table"
+msgstr "×ÅËÔÏÒ"
#: ../raster/r.colors/main.c:127
#, fuzzy
msgid "Creates/modifies the color table associated with a raster map layer."
msgstr "×ÅËÔÏÒ."
-#: ../raster/r.colors/main.c:140
+#: ../raster/r.colors/main.c:141
msgid "Type of color table"
msgstr ""
-#: ../raster/r.colors/main.c:152
+#: ../raster/r.colors/main.c:143
+msgid ""
+"aspect;aspect oriented grey colors;aspectcolr;aspect oriented rainbow colors;"
+"bcyr;blue through cyan through yellow to red;bgyr;blue through green through "
+"yellow to red;byg;blue through yellow to green colors;byr;blue through "
+"yellow to red colors;curvature;for terrain curvatures (from v.surf.rst and r."
+"slope.aspect curvature colors);differences;differences oriented colors;"
+"elevation;maps percentage ranges of raster values to elevation color ramp;"
+"etopo2;rainbow color ramp for the ETOPO2 2-minute Worldwide Bathymetry/"
+"Topography dataset;evi;enhanced vegetative index colors;grey;grey scale;"
+"grey1.0;grey scale for raster values between 0.0-1.0;grey255;grey scale for "
+"raster values bewtween 0-255;grey.eq;histogram-equalized grey scale;grey.log;"
+"histogram logarithmic transformed grey scale;gyr;green through yellow to red "
+"colors;ndvi;Normalized Difference Vegetation Index colors;population;color "
+"table covering human population classification breaks;rainbow;rainbow color "
+"table;ramp;color ramp;random;random color table;rules;create new color table "
+"based on user-specified rules;ryb;red through yellow to blue colors;ryg;red "
+"through yellow to green colors;slope;r.slope.aspect-type slope colors for "
+"raster values 0-90;srtm;color palette for Shuttle Radar Topography Mission "
+"elevation values;terrain;global elevation color table covering -11000 to "
+"+8850m;wave;color wave;"
+msgstr ""
+#: ../raster/r.colors/main.c:172 ../raster/r.colors/main.c:185
+#: ../raster/r.colors/main.c:202 ../raster/r.colors/main.c:207
+#: ../raster/r.colors/main.c:212 ../vector/v.label.sa/main.c:175
+#: ../vector/v.label.sa/main.c:184 ../vector/v.label.sa/main.c:191
+#: ../vector/v.label.sa/main.c:200 ../vector/v.label.sa/main.c:210
+#: ../vector/v.label.sa/main.c:219 ../vector/v.label.sa/main.c:226
+#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
+#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
+#: ../vector/v.label/main.c:205 ../display/d.vect/main.c:164
+#: ../display/d.vect/main.c:172 ../display/d.vect/main.c:180
+#: ../display/d.vect/main.c:332 ../display/d.vect/main.c:338
+msgid "Colors"
+msgstr ""
+#: ../raster/r.colors/main.c:179
msgid "Raster map name from which to copy color table"
msgstr ""
-#: ../raster/r.colors/main.c:158
+#: ../raster/r.colors/main.c:184
#, fuzzy
msgid "Path to rules file"
msgstr " ."
-#: ../raster/r.colors/main.c:163
+#: ../raster/r.colors/main.c:189
#, fuzzy
msgid "Remove existing color table"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.colors/main.c:167
+#: ../raster/r.colors/main.c:193
msgid "Only write new color table if one doesn't already exist"
msgstr ""
-#: ../raster/r.colors/main.c:171
+#: ../raster/r.colors/main.c:197
msgid "List available rules then exit"
msgstr ""
-#: ../raster/r.colors/main.c:175
+#: ../raster/r.colors/main.c:201
#, fuzzy
msgid "Invert colors"
msgstr "ìÉÎÉÑ"
-#: ../raster/r.colors/main.c:179
+#: ../raster/r.colors/main.c:206
msgid "Logarithmic scaling"
msgstr ""
-#: ../raster/r.colors/main.c:183
+#: ../raster/r.colors/main.c:211
msgid "Histogram equalization"
msgstr ""
-#: ../raster/r.colors/main.c:187
+#: ../raster/r.colors/main.c:216
msgid "Enter rules interactively"
msgstr ""
-#: ../raster/r.colors/main.c:223
+#: ../raster/r.colors/main.c:238
msgid "No map specified"
msgstr ""
-#: ../raster/r.colors/main.c:226
+#: ../raster/r.colors/main.c:241
msgid ""
"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
"specified!"
msgstr ""
-#: ../raster/r.colors/main.c:229
+#: ../raster/r.colors/main.c:244
msgid ""
"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
"options"
msgstr ""
-#: ../raster/r.colors/main.c:232
+#: ../raster/r.colors/main.c:247
msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
msgstr ""
-#: ../raster/r.colors/main.c:244
+#: ../raster/r.colors/main.c:259
#, fuzzy, c-format
msgid "%s - unable to remove color table"
msgstr " "
-#: ../raster/r.colors/main.c:246
+#: ../raster/r.colors/main.c:261
#, fuzzy, c-format
msgid "%s - color table not found"
msgstr " "
-#: ../raster/r.colors/main.c:277
+#: ../raster/r.colors/main.c:292
msgid "Can't make random color table for floating point map"
msgstr ""
-#: ../raster/r.colors/main.c:283
+#: ../raster/r.colors/main.c:298
msgid "Can't make grey.eq color table for floating point map"
msgstr ""
-#: ../raster/r.colors/main.c:291
+#: ../raster/r.colors/main.c:306
msgid "Can't make logarithmic color table for floating point map"
msgstr ""
-#: ../raster/r.colors/main.c:304
+#: ../raster/r.colors/main.c:319
#, fuzzy, c-format
msgid "%s - unknown color request"
msgstr " "
-#: ../raster/r.colors/main.c:315
+#: ../raster/r.colors/main.c:330
#, fuzzy, c-format
msgid "Unable to load rules file %s"
msgstr " "
-#: ../raster/r.colors/main.c:353
+#: ../raster/r.colors/main.c:368
#, fuzzy, c-format
msgid "Color table for <%s> set to %s"
msgstr " "
@@ -10028,34 +10151,34 @@
#: ../raster/r.colors/rules.c:132
#, c-format
-msgid "bad rule (%s): %s"
+msgid "bad rule (%s): [%s]"
msgstr ""
-#: ../raster/r.out.ppm/main.c:54
+#: ../raster/r.out.ppm/main.c:53
msgid ""
"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
"the currently defined region."
msgstr ""
-#: ../raster/r.out.ppm/main.c:63
+#: ../raster/r.out.ppm/main.c:62
msgid "Name for new PPM file (use '-' for stdout)"
msgstr ""
-#: ../raster/r.out.ppm/main.c:72
+#: ../raster/r.out.ppm/main.c:66
msgid "Output greyscale instead of color"
msgstr ""
-#: ../raster/r.out.ppm/main.c:137
+#: ../raster/r.out.ppm/main.c:123
#, fuzzy, c-format
msgid "Unable to open file <%s> for write"
msgstr " "
-#: ../raster/r.out.ppm/main.c:166
+#: ../raster/r.out.ppm/main.c:152
#, fuzzy
msgid "Converting..."
msgstr "×ÅËÔÏÒ."
-#: ../raster/r.out.ppm/main.c:248
+#: ../raster/r.out.ppm/main.c:234
#, fuzzy, c-format
msgid "File <%s> created"
msgstr "òÁÊÏÎ !"
@@ -10132,41 +10255,41 @@
msgid "Invalid timestamp"
msgstr ""
-#: ../raster/r.what/main.c:90
+#: ../raster/r.what/main.c:91
msgid "Queries raster map layers on their category values and category labels."
msgstr ""
-#: ../raster/r.what/main.c:98
+#: ../raster/r.what/main.c:99
#, fuzzy
msgid "Name of existing raster map(s) to query"
msgstr " "
-#: ../raster/r.what/main.c:105
+#: ../raster/r.what/main.c:106
msgid "Size of point cache"
msgstr ""
-#: ../raster/r.what/main.c:121 ../vector/v.what/main.c:71
+#: ../raster/r.what/main.c:124 ../vector/v.what/main.c:71
msgid "Coordinates for query"
msgstr ""
-#: ../raster/r.what/main.c:125
+#: ../raster/r.what/main.c:128
#, fuzzy
msgid "Show the category label in the grid cell(s)"
msgstr " "
-#: ../raster/r.what/main.c:129
+#: ../raster/r.what/main.c:132
msgid "Turn on cache reporting"
msgstr ""
-#: ../raster/r.what/main.c:133 ../raster/r.out.bin/main.c:92
+#: ../raster/r.what/main.c:136 ../raster/r.out.bin/main.c:92
msgid "Output integer category values, not cell values"
msgstr ""
-#: ../raster/r.what/main.c:137
+#: ../raster/r.what/main.c:140
msgid "Output color values as RRR:GGG:BBB"
msgstr ""
-#: ../raster/r.what/main.c:173
+#: ../raster/r.what/main.c:188
#, c-format
msgid "%s: can only do up to %d raster maps, sorry\n"
msgstr ""
@@ -10227,34 +10350,34 @@
msgid "Illegal filter file format"
msgstr " "
-#: ../raster/r.mfilter.fp/main.c:56 ../raster/r.mfilter/main.c:49
+#: ../raster/r.mfilter.fp/main.c:54 ../raster/r.mfilter/main.c:47
#, fuzzy
msgid "raster, map algebra"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.mfilter.fp/main.c:57 ../raster/r.mfilter/main.c:50
+#: ../raster/r.mfilter.fp/main.c:55 ../raster/r.mfilter/main.c:48
#, fuzzy
msgid "Raster map matrix filter."
msgstr " "
-#: ../raster/r.mfilter.fp/main.c:68 ../raster/r.mfilter/main.c:61
+#: ../raster/r.mfilter.fp/main.c:66 ../raster/r.mfilter/main.c:59
#, fuzzy
msgid "Name of filter file"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.mfilter.fp/main.c:76 ../raster/r.mfilter/main.c:69
+#: ../raster/r.mfilter.fp/main.c:74 ../raster/r.mfilter/main.c:67
msgid "Number of times to repeat the filter"
msgstr ""
-#: ../raster/r.mfilter.fp/main.c:82 ../raster/r.mfilter/main.c:75
+#: ../raster/r.mfilter.fp/main.c:80 ../raster/r.mfilter/main.c:73
msgid "Output raster map title"
msgstr ""
-#: ../raster/r.mfilter.fp/main.c:99
+#: ../raster/r.mfilter.fp/main.c:92
msgid "Apply filter only to null data values"
msgstr ""
-#: ../raster/r.mfilter.fp/main.c:137 ../raster/r.mfilter/main.c:130
+#: ../raster/r.mfilter.fp/main.c:123 ../raster/r.mfilter/main.c:116
#, fuzzy
msgid "Raster map too small for the size of the filter"
msgstr "×ÅËÔÏÒ"
@@ -10287,17 +10410,17 @@
"Percent complete:"
msgstr ""
-#: ../raster/r.random.surface/init.c:196
+#: ../raster/r.random.surface/init.c:183
#, c-format
msgid "Seed [%d] larger than maximum [%d]"
msgstr ""
-#: ../raster/r.random.surface/init.c:199 ../raster/r.random.surface/init.c:207
+#: ../raster/r.random.surface/init.c:186 ../raster/r.random.surface/init.c:194
#, c-format
msgid " seed is set to %d"
msgstr ""
-#: ../raster/r.random.surface/init.c:203
+#: ../raster/r.random.surface/init.c:190
#, c-format
msgid "Seed [%d] smaller than minimum [%d]"
msgstr ""
@@ -10363,216 +10486,211 @@
msgid "%s higher above pointer wrong"
msgstr ""
-#: ../raster/r.cost/main.c:123
+#: ../raster/r.cost/main.c:120
msgid "raster, cost surface, cumulative costs"
msgstr ""
-#: ../raster/r.cost/main.c:125
+#: ../raster/r.cost/main.c:122
msgid ""
"Outputs a raster map layer showing the cumulative cost of moving between "
"different geographic locations on an input raster map layer whose cell "
"category values represent cost."
msgstr ""
-#: ../raster/r.cost/main.c:132
+#: ../raster/r.cost/main.c:129
msgid "Name of raster map containing grid cell cost information"
msgstr ""
-#: ../raster/r.cost/main.c:141 ../raster/r.walk/main.c:208
+#: ../raster/r.cost/main.c:138 ../raster/r.walk/main.c:208
#, fuzzy
msgid "Starting points vector map"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.cost/main.c:148 ../raster/r.walk/main.c:215
+#: ../raster/r.cost/main.c:145 ../raster/r.walk/main.c:215
#, fuzzy
msgid "Stop points vector map"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.cost/main.c:155
+#: ../raster/r.cost/main.c:152
msgid "Starting points raster map"
msgstr ""
-#: ../raster/r.cost/main.c:163 ../raster/r.walk/main.c:223
+#: ../raster/r.cost/main.c:160 ../raster/r.walk/main.c:223
msgid "The map E and N grid coordinates of a starting point (E,N)"
msgstr ""
-#: ../raster/r.cost/main.c:171 ../raster/r.walk/main.c:231
+#: ../raster/r.cost/main.c:168 ../raster/r.walk/main.c:231
msgid "The map E and N grid coordinates of a stopping point (E,N)"
msgstr ""
-#: ../raster/r.cost/main.c:180 ../raster/r.walk/main.c:240
+#: ../raster/r.cost/main.c:177 ../raster/r.walk/main.c:239
msgid "An optional maximum cumulative cost"
msgstr ""
-#: ../raster/r.cost/main.c:189 ../raster/r.walk/main.c:249
+#: ../raster/r.cost/main.c:186 ../raster/r.walk/main.c:247
#, fuzzy
msgid "Cost assigned to null cells. By default, null cells are excluded"
msgstr " "
-#: ../raster/r.cost/main.c:203 ../raster/r.walk/main.c:301
+#: ../raster/r.cost/main.c:200 ../raster/r.walk/main.c:296
#, fuzzy
msgid "Use the 'Knight's move'; slower, but more accurate"
msgstr " "
-#: ../raster/r.cost/main.c:207 ../raster/r.walk/main.c:305
+#: ../raster/r.cost/main.c:204 ../raster/r.walk/main.c:300
msgid "Keep null values in output map"
msgstr ""
-#: ../raster/r.cost/main.c:211 ../raster/r.walk/main.c:309
+#: ../raster/r.cost/main.c:208 ../raster/r.walk/main.c:304
msgid "Start with values in raster map"
msgstr ""
-#: ../raster/r.cost/main.c:216 ../raster/wildfire/r.ros/main.c:291
-#: ../vector/v.kernel/main.c:156 ../display/d.vect/main.c:320
-msgid "Run verbosely"
-msgstr ""
-#: ../raster/r.cost/main.c:237 ../raster/r.water.outlet/main.c:85
-#: ../raster/r.walk/main.c:324
+#: ../raster/r.cost/main.c:220 ../raster/r.water.outlet/main.c:85
+#: ../raster/r.walk/main.c:319
#, fuzzy
msgid "Unable to read current window parameters"
msgstr " "
-#: ../raster/r.cost/main.c:270
+#: ../raster/r.cost/main.c:252
msgid "Must specify exactly one of start_points, start_rast or coordinate"
msgstr ""
-#: ../raster/r.cost/main.c:275 ../raster/r.cost/main.c:525
-#: ../raster/r.cost/main.c:630
+#: ../raster/r.cost/main.c:257 ../raster/r.cost/main.c:507
+#: ../raster/r.cost/main.c:612
msgid "No start points"
msgstr ""
-#: ../raster/r.cost/main.c:282 ../raster/r.walk/main.c:351
+#: ../raster/r.cost/main.c:264 ../raster/r.walk/main.c:346
#, c-format
msgid "Inappropriate maximum cost: %d"
msgstr ""
-#: ../raster/r.cost/main.c:285 ../raster/r.walk/main.c:354
+#: ../raster/r.cost/main.c:267 ../raster/r.walk/main.c:349
#, c-format
msgid "Inappropriate percent memory: %d"
msgstr ""
-#: ../raster/r.cost/main.c:289 ../raster/r.walk/main.c:393
+#: ../raster/r.cost/main.c:271 ../raster/r.walk/main.c:388
msgid "Null cells excluded from cost evaluation."
msgstr ""
-#: ../raster/r.cost/main.c:293 ../raster/r.walk/main.c:397
+#: ../raster/r.cost/main.c:275 ../raster/r.walk/main.c:392
msgid "Input null cell will be retained into output map"
msgstr ""
-#: ../raster/r.cost/main.c:303 ../raster/r.walk/main.c:495
+#: ../raster/r.cost/main.c:285 ../raster/r.walk/main.c:490
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
msgstr ""
-#: ../raster/r.cost/main.c:346
+#: ../raster/r.cost/main.c:328
#, fuzzy
msgid "Source map is: Integer cell type"
msgstr " "
-#: ../raster/r.cost/main.c:349
+#: ../raster/r.cost/main.c:331
#, fuzzy
msgid "Source map is: Floating point (float) cell type"
msgstr " "
-#: ../raster/r.cost/main.c:352
+#: ../raster/r.cost/main.c:334
#, fuzzy
msgid "Source map is: Floating point (double) cell type"
msgstr " "
-#: ../raster/r.cost/main.c:355 ../raster/r.walk/main.c:585
-#: ../raster/r.walk/main.c:602 ../raster/r.walk/main.c:639
+#: ../raster/r.cost/main.c:337 ../raster/r.walk/main.c:580
+#: ../raster/r.walk/main.c:597 ../raster/r.walk/main.c:634
#, c-format
msgid " %d rows, %d cols"
msgstr ""
-#: ../raster/r.cost/main.c:366 ../raster/r.walk/main.c:657
+#: ../raster/r.cost/main.c:348 ../raster/r.walk/main.c:652
#, fuzzy
msgid "Creating some temporary files..."
msgstr " "
-#: ../raster/r.cost/main.c:387 ../raster/r.cost/main.c:599
+#: ../raster/r.cost/main.c:369 ../raster/r.cost/main.c:581
#, fuzzy, c-format
msgid "Reading %s"
msgstr "þÔÅÎÉÅ %s ..."
-#: ../raster/r.cost/main.c:450 ../raster/r.walk/main.c:813
+#: ../raster/r.cost/main.c:432 ../raster/r.walk/main.c:808
msgid "Initializing output "
msgstr ""
-#: ../raster/r.cost/main.c:459 ../raster/r.walk/main.c:821
+#: ../raster/r.cost/main.c:441 ../raster/r.walk/main.c:816
#, fuzzy
msgid "Unable to allocate memory for segment fbuff == NULL"
msgstr " "
-#: ../raster/r.cost/main.c:587
+#: ../raster/r.cost/main.c:569
#, fuzzy, c-format
msgid "can't open raster map [%s] needed for input coordinates"
msgstr " "
-#: ../raster/r.cost/main.c:645 ../raster/r.walk/main.c:913
+#: ../raster/r.cost/main.c:627 ../raster/r.walk/main.c:908
msgid "Specified starting location outside database window"
msgstr ""
-#: ../raster/r.cost/main.c:660 ../raster/r.walk/main.c:930
+#: ../raster/r.cost/main.c:642 ../raster/r.walk/main.c:925
msgid "Finding cost path"
msgstr ""
-#: ../raster/r.cost/main.c:885 ../raster/r.walk/main.c:1377
+#: ../raster/r.cost/main.c:867 ../raster/r.walk/main.c:1372
msgid "End of map!"
msgstr ""
-#: ../raster/r.cost/main.c:889 ../raster/r.walk/main.c:1381
+#: ../raster/r.cost/main.c:871 ../raster/r.walk/main.c:1376
msgid "Error, ct == pres_cell"
msgstr ""
-#: ../raster/r.cost/main.c:901
+#: ../raster/r.cost/main.c:883
#, fuzzy, c-format
msgid "Writing %s"
msgstr " "
-#: ../raster/r.cost/main.c:905 ../raster/r.walk/main.c:1399
+#: ../raster/r.cost/main.c:887 ../raster/r.walk/main.c:1394
msgid "Will copy input map null values into output map"
msgstr ""
-#: ../raster/r.cost/main.c:912 ../raster/r.walk/main.c:1406
+#: ../raster/r.cost/main.c:894 ../raster/r.walk/main.c:1401
msgid ""
"Integer cell type.\n"
"Writing..."
msgstr ""
-#: ../raster/r.cost/main.c:917 ../raster/r.cost/main.c:949
-#: ../raster/r.cost/main.c:981
+#: ../raster/r.cost/main.c:899 ../raster/r.cost/main.c:931
+#: ../raster/r.cost/main.c:963
msgid "Error getting input null cells"
msgstr ""
-#: ../raster/r.cost/main.c:944 ../raster/r.walk/main.c:1441
+#: ../raster/r.cost/main.c:926 ../raster/r.walk/main.c:1436
msgid ""
"Float cell type.\n"
"Writing..."
msgstr ""
-#: ../raster/r.cost/main.c:976 ../raster/r.walk/main.c:1476
+#: ../raster/r.cost/main.c:958 ../raster/r.walk/main.c:1471
msgid ""
"Double cell type.\n"
"Writing..."
msgstr ""
-#: ../raster/r.cost/main.c:1008 ../raster/r.walk/main.c:1511
+#: ../raster/r.cost/main.c:990 ../raster/r.walk/main.c:1506
#, c-format
msgid "Peak cost value: %f"
msgstr ""
-#: ../raster/r.cost/main.c:1051 ../raster/r.walk/main.c:1562
+#: ../raster/r.cost/main.c:1033 ../raster/r.walk/main.c:1557
#, fuzzy, c-format
msgid "Illegal x coordinate <%s>"
msgstr " "
-#: ../raster/r.cost/main.c:1053 ../raster/r.walk/main.c:1564
+#: ../raster/r.cost/main.c:1035 ../raster/r.walk/main.c:1559
#, fuzzy, c-format
msgid "Illegal y coordinate <%s>"
msgstr " "
-#: ../raster/r.cost/main.c:1057 ../raster/r.walk/main.c:1568
+#: ../raster/r.cost/main.c:1039 ../raster/r.walk/main.c:1563
#, c-format
msgid "Warning, ignoring point outside window: %.4f,%.4f"
msgstr ""
@@ -10920,6 +11038,11 @@
"Hit RETURN to continue -->"
msgstr ""
+#: ../raster/r.support/front/front.c:54
+#, fuzzy
+msgid "raster, metadata"
+msgstr "×ÅËÔÏÒ"
#: ../raster/r.support/front/front.c:55
msgid "Allows creation and/or modification of raster map layer support files."
msgstr ""
@@ -11054,7 +11177,7 @@
msgstr " "
#: ../raster/r.support/front/front.c:348 ../imagery/i.gensig/write_sig.c:20
-#: ../imagery/i.target/main.c:99 ../display/d.what.vect/main.c:172
+#: ../display/d.what.vect/main.c:172
msgid "Done."
msgstr ""
@@ -11220,52 +11343,52 @@
msgid "Reading map"
msgstr ""
-#: ../raster/r.neighbors/main.c:105
+#: ../raster/r.neighbors/main.c:104
msgid ""
"Makes each cell category value a function of the category values assigned to "
"the cells around it, and stores new cell values in an output raster map "
"layer."
msgstr ""
-#: ../raster/r.neighbors/main.c:128
+#: ../raster/r.neighbors/main.c:127
msgid "Neighborhood operation"
msgstr ""
-#: ../raster/r.neighbors/main.c:134
+#: ../raster/r.neighbors/main.c:133
msgid "Neighborhood size"
msgstr ""
-#: ../raster/r.neighbors/main.c:142
+#: ../raster/r.neighbors/main.c:141
msgid "Title of the output raster map"
msgstr ""
-#: ../raster/r.neighbors/main.c:149
+#: ../raster/r.neighbors/main.c:148
#, fuzzy
msgid "File containing weights"
msgstr " "
-#: ../raster/r.neighbors/main.c:153
+#: ../raster/r.neighbors/main.c:152
msgid "Do not align output with the input"
msgstr ""
-#: ../raster/r.neighbors/main.c:162
+#: ../raster/r.neighbors/main.c:156
msgid "Use circular neighborhood"
msgstr ""
-#: ../raster/r.neighbors/main.c:169
+#: ../raster/r.neighbors/main.c:163
msgid "Neighborhood size must be positive"
msgstr ""
-#: ../raster/r.neighbors/main.c:171
+#: ../raster/r.neighbors/main.c:165
msgid "Neighborhood size must be odd"
msgstr ""
-#: ../raster/r.neighbors/main.c:175
+#: ../raster/r.neighbors/main.c:169
#, fuzzy
msgid "weight= and -c are mutually exclusive"
msgstr " ."
-#: ../raster/r.neighbors/main.c:203 ../raster/r.series/main.c:175
+#: ../raster/r.neighbors/main.c:197 ../raster/r.series/main.c:161
#: ../ps/ps.map/outl_io.c:77
#, fuzzy, c-format
msgid "Unable to open raster map <%s> in mapset <%s>"
@@ -11296,17 +11419,23 @@
msgid "Unable to properly write output raster map"
msgstr " "
-#: ../raster/r.clump/main.c:52
+#: ../raster/r.clump/main.c:49
msgid ""
"Recategorizes data in a raster map layer by grouping cells that form "
"physically discrete areas into unique categories."
msgstr ""
-#: ../raster/r.clump/main.c:64
+#: ../raster/r.clump/main.c:61
msgid "Title, in quotes"
msgstr ""
-#: ../raster/r.clump/main.c:121
+#: ../raster/r.clump/main.c:88
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1035
+#, fuzzy
+msgid "Creating support files..."
+msgstr " "
+#: ../raster/r.clump/main.c:106
#, c-format
msgid "%d clumps"
msgstr ""
@@ -11410,42 +11539,38 @@
msgid "Do not build vector topology (use with care for massive point export)"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.to.vect/main.c:87
-msgid "Quiet - Do not show progress"
-msgstr ""
-#: ../raster/r.to.vect/main.c:105
+#: ../raster/r.to.vect/main.c:92
#, fuzzy
msgid "z flag is supported only for points"
msgstr " "
-#: ../raster/r.to.vect/main.c:119
+#: ../raster/r.to.vect/main.c:106
#, fuzzy
msgid ""
"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
"table."
msgstr " ."
-#: ../raster/r.to.vect/main.c:154 ../raster/r.contour/main.c:179
-#: ../vector/v.db.connect/main.c:176 ../vector/v.db.connect/main.c:268
-#: ../vector/v.to.rast3/main.c:85 ../vector/v.edit/cmd/select.c:537
+#: ../raster/r.to.vect/main.c:141 ../raster/r.contour/main.c:157
+#: ../vector/v.db.connect/main.c:178 ../vector/v.db.connect/main.c:270
+#: ../vector/v.to.rast3/main.c:85 ../vector/v.edit/select.c:539
#: ../vector/lidar/v.surf.bspline/main.c:297 ../vector/v.distance/main.c:342
#: ../vector/v.distance/main.c:376 ../vector/v.reclass/main.c:117
-#: ../vector/v.in.ascii/in.c:308 ../vector/v.db.select/main.c:103
+#: ../vector/v.in.ascii/in.c:312 ../vector/v.db.select/main.c:103
#: ../vector/v.db.select/main.c:173 ../vector/v.what.rast/main.c:127
-#: ../vector/v.extrude/main.c:167 ../vector/v.sample/main.c:201
+#: ../vector/v.extrude/main.c:167 ../vector/v.sample/main.c:196
#: ../vector/v.patch/main.c:132 ../vector/v.patch/main.c:164
#: ../vector/v.patch/main.c:287 ../vector/v.patch/main.c:347
#: ../vector/v.surf.idw/read_sites.c:39 ../vector/v.vol.rst/user1.c:96
#: ../vector/v.vol.rst/main.c:561 ../vector/v.transform/trans_digit.c:58
-#: ../vector/v.mkgrid/main.c:207 ../vector/v.overlay/main.c:168
-#: ../vector/v.overlay/main.c:261 ../vector/v.label.sa/labels.c:79
+#: ../vector/v.mkgrid/main.c:192 ../vector/v.overlay/main.c:168
+#: ../vector/v.overlay/main.c:261 ../vector/v.label.sa/labels.c:78
#: ../vector/v.kcv/main.c:173 ../vector/v.normal/main.c:141
#: ../vector/v.out.svg/main.c:145 ../vector/v.to.db/update.c:32
#: ../vector/v.to.db/query.c:81 ../vector/v.label/main.c:277
#: ../vector/v.in.db/main.c:113 ../vector/v.to.rast/support.c:130
#: ../vector/v.to.rast/support.c:265 ../vector/v.to.rast/vect2rast.c:55
-#: ../vector/v.out.ogr/main.c:303 ../vector/v.lrs/v.lrs.create/main.c:273
+#: ../vector/v.out.ogr/main.c:309 ../vector/v.lrs/v.lrs.create/main.c:273
#: ../vector/v.lrs/v.lrs.create/main.c:281 ../vector/v.buffer/main.c:375
#: ../vector/v.extract/main.c:229 ../ps/ps.map/catval.c:52
#: ../ps/ps.map/catval.c:110 ../ps/ps.map/catval.c:171
@@ -11453,32 +11578,32 @@
msgid "Unable to open database <%s> by driver <%s>"
msgstr " "
-#: ../raster/r.to.vect/main.c:189 ../raster/r.contour/main.c:188
+#: ../raster/r.to.vect/main.c:176 ../raster/r.contour/main.c:166
#: ../vector/lidar/lidarlib/raster.c:74 ../vector/lidar/lidarlib/raster.c:88
#: ../vector/lidar/lidarlib/raster.c:100 ../vector/lidar/lidarlib/raster.c:116
#: ../vector/lidar/lidarlib/raster.c:130 ../vector/lidar/lidarlib/raster.c:142
#: ../vector/lidar/lidarlib/raster.c:156 ../vector/lidar/lidarlib/raster.c:167
-#: ../vector/v.in.ascii/in.c:377 ../vector/v.mkgrid/main.c:220
+#: ../vector/v.in.ascii/in.c:381 ../vector/v.mkgrid/main.c:205
#: ../vector/v.lrs/v.lrs.create/main.c:309
#, fuzzy, c-format
msgid "Unable to create table: %s"
msgstr " "
-#: ../raster/r.to.vect/main.c:192 ../vector/v.mkgrid/main.c:224
+#: ../raster/r.to.vect/main.c:179 ../vector/v.mkgrid/main.c:209
#: ../vector/v.overlay/main.c:427
#, fuzzy
msgid "Unable to create index"
msgstr " "
-#: ../raster/r.to.vect/main.c:195 ../raster/r.contour/main.c:195
-#: ../vector/v.distance/main.c:759 ../vector/v.in.ascii/in.c:386
-#: ../vector/v.sample/main.c:216 ../vector/v.mkgrid/main.c:227
+#: ../raster/r.to.vect/main.c:182 ../raster/r.contour/main.c:173
+#: ../vector/v.distance/main.c:759 ../vector/v.in.ascii/in.c:390
+#: ../vector/v.sample/main.c:211 ../vector/v.mkgrid/main.c:212
#: ../vector/v.overlay/main.c:430
#, fuzzy, c-format
msgid "Unable to grant privileges on table <%s>"
msgstr " "
-#: ../raster/r.to.vect/main.c:258
+#: ../raster/r.to.vect/main.c:245
#, fuzzy, c-format
msgid "Unable to insert into table: %s"
msgstr " "
@@ -11534,7 +11659,7 @@
msgid "Set from current region"
msgstr ""
-#: ../raster/r.region/main.c:69 ../general/g.region/cmd/main.c:89
+#: ../raster/r.region/main.c:69 ../general/g.region/main.c:88
msgid "Set from default region"
msgstr ""
@@ -11546,72 +11671,72 @@
msgid "Set region from named region"
msgstr ""
-#: ../raster/r.region/main.c:96 ../general/g.region/cmd/main.c:165
+#: ../raster/r.region/main.c:96 ../general/g.region/main.c:164
msgid "Set region to match this raster map"
msgstr ""
-#: ../raster/r.region/main.c:104 ../general/g.region/cmd/main.c:180
+#: ../raster/r.region/main.c:104 ../general/g.region/main.c:179
#, fuzzy
msgid "Set region to match this vector map"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.region/main.c:112 ../general/g.region/cmd/main.c:189
+#: ../raster/r.region/main.c:112 ../general/g.region/main.c:188
msgid "Set region to match this 3dview file"
msgstr ""
-#: ../raster/r.region/main.c:120 ../general/g.region/cmd/main.c:199
+#: ../raster/r.region/main.c:120 ../general/g.region/main.c:198
msgid "Value for the northern edge"
msgstr ""
-#: ../raster/r.region/main.c:128 ../general/g.region/cmd/main.c:209
+#: ../raster/r.region/main.c:128 ../general/g.region/main.c:208
msgid "Value for the southern edge"
msgstr ""
-#: ../raster/r.region/main.c:136 ../general/g.region/cmd/main.c:219
+#: ../raster/r.region/main.c:136 ../general/g.region/main.c:218
msgid "Value for the eastern edge"
msgstr ""
-#: ../raster/r.region/main.c:144 ../general/g.region/cmd/main.c:229
+#: ../raster/r.region/main.c:144 ../general/g.region/main.c:228
msgid "Value for the western edge"
msgstr ""
-#: ../raster/r.region/main.c:152 ../general/g.region/cmd/main.c:332
+#: ../raster/r.region/main.c:152
msgid "Raster map to align to"
msgstr ""
#: ../raster/r.region/main.c:163 ../raster/r.region/main.c:220
#: ../raster/r.region/main.c:355 ../display/d.title/main.c:108
-#: ../general/g.region/cmd/main.c:451 ../general/g.region/cmd/main.c:824
+#: ../general/g.region/main.c:453 ../general/g.region/main.c:826
#, fuzzy, c-format
msgid "Unable to read header of raster map <%s@%s>"
msgstr " !"
-#: ../raster/r.region/main.c:177 ../general/g.region/cmd/main.c:395
+#: ../raster/r.region/main.c:177 ../general/g.region/main.c:397
#, fuzzy, c-format
msgid "Region <%s> not found"
msgstr " "
-#: ../raster/r.region/main.c:179 ../general/g.region/cmd/main.c:397
+#: ../raster/r.region/main.c:179 ../general/g.region/main.c:399
#, fuzzy, c-format
msgid "Unable to read region <%s> in <%s>"
msgstr " "
-#: ../raster/r.region/main.c:190 ../general/g.region/cmd/main.c:409
+#: ../raster/r.region/main.c:190 ../general/g.region/main.c:411
#, fuzzy, c-format
msgid "3dview file <%s> not found"
msgstr " "
-#: ../raster/r.region/main.c:196 ../general/g.region/cmd/main.c:414
+#: ../raster/r.region/main.c:196 ../general/g.region/main.c:416
#, fuzzy, c-format
msgid "Unable to open 3dview file <%s> in <%s>"
msgstr " "
-#: ../raster/r.region/main.c:200 ../general/g.region/cmd/main.c:419
+#: ../raster/r.region/main.c:200 ../general/g.region/main.c:421
#, fuzzy, c-format
msgid "Unable to read 3dview file <%s> in <%s>"
msgstr " "
-#: ../raster/r.region/main.c:202 ../general/g.region/cmd/main.c:421
+#: ../raster/r.region/main.c:202 ../general/g.region/main.c:423
#, fuzzy, c-format
msgid "Old 3dview file. Region <%s> not found in <%s>"
msgstr " "
@@ -11621,7 +11746,7 @@
msgid "Unable to open vector map <%s> in <%s>"
msgstr "×ÅËÔÏÒ "
-#: ../raster/r.region/main.c:364 ../general/g.region/cmd/adjust.c:11
+#: ../raster/r.region/main.c:364 ../general/g.region/adjust.c:11
#, fuzzy, c-format
msgid "Invalid region: %s"
msgstr " "
@@ -11631,26 +11756,26 @@
msgid "Unable to update boundaries"
msgstr " "
-#: ../raster/r.out.ppm3/main.c:56
+#: ../raster/r.out.ppm3/main.c:55
msgid ""
"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
"resolution of the CURRENTLY DEFINED REGION."
msgstr ""
-#: ../raster/r.out.ppm3/main.c:62 ../display/d.rgb/main.c:69
+#: ../raster/r.out.ppm3/main.c:61 ../display/d.rgb/main.c:69
#, fuzzy, c-format
msgid "Name of raster map to be used for <%s>"
msgstr " "
-#: ../raster/r.out.ppm3/main.c:81
+#: ../raster/r.out.ppm3/main.c:80
msgid "Name for new PPM file. (use out=- for stdout)"
msgstr ""
-#: ../raster/r.out.ppm3/main.c:90
+#: ../raster/r.out.ppm3/main.c:84
msgid "Add comments to describe the region"
msgstr ""
-#: ../raster/r.out.ppm3/main.c:176
+#: ../raster/r.out.ppm3/main.c:162
#, fuzzy
msgid "Converting ... "
msgstr "×ÅËÔÏÒ."
@@ -11696,116 +11821,146 @@
msgid "Writing color file..."
msgstr " ."
-#: ../raster/r.in.mat/main.c:95
+#: ../raster/r.in.mat/main.c:90
#, fuzzy
msgid "Imports a binary MAT-File(v4) to a GRASS raster."
msgstr "×ÅËÔÏÒ."
-#: ../raster/r.in.mat/main.c:104
+#: ../raster/r.in.mat/main.c:99
msgid "Name of an existing MAT-File(v4)"
msgstr ""
-#: ../raster/r.in.mat/main.c:111
+#: ../raster/r.in.mat/main.c:106
msgid "Name for the output raster map (override)"
msgstr ""
-#: ../raster/r.in.mat/main.c:161
+#: ../raster/r.in.mat/main.c:148
#, fuzzy
msgid "Reading MAT-File..."
msgstr " ."
-#: ../raster/r.in.mat/main.c:187
+#: ../raster/r.in.mat/main.c:174
msgid "Array contains no data"
msgstr ""
-#: ../raster/r.in.mat/main.c:192
+#: ../raster/r.in.mat/main.c:179
msgid "Array contains imaginary data"
msgstr ""
-#: ../raster/r.in.mat/main.c:198
+#: ../raster/r.in.mat/main.c:185
msgid "Invalid array name"
msgstr ""
-#: ../raster/r.in.mat/main.c:217
+#: ../raster/r.in.mat/main.c:204
msgid "Invalid 'map_name' array"
msgstr ""
-#: ../raster/r.in.mat/main.c:226
+#: ../raster/r.in.mat/main.c:213
msgid "Error reading 'map_name' array"
msgstr ""
-#: ../raster/r.in.mat/main.c:236
+#: ../raster/r.in.mat/main.c:223
msgid "Invalid 'map_northern_edge' array"
msgstr ""
-#: ../raster/r.in.mat/main.c:244
+#: ../raster/r.in.mat/main.c:231
msgid "Invalid 'map_southern_edge' array"
msgstr ""
-#: ../raster/r.in.mat/main.c:252
+#: ../raster/r.in.mat/main.c:239
msgid "Invalid 'map_eastern_edge' array"
msgstr ""
-#: ../raster/r.in.mat/main.c:260
+#: ../raster/r.in.mat/main.c:247
msgid "Invalid 'map_western_edge' array"
msgstr ""
-#: ../raster/r.in.mat/main.c:268
+#: ../raster/r.in.mat/main.c:255
msgid "Invalid 'map_title' array"
msgstr ""
-#: ../raster/r.in.mat/main.c:277
+#: ../raster/r.in.mat/main.c:264
msgid "Error reading 'map_title' array"
msgstr ""
-#: ../raster/r.in.mat/main.c:290
+#: ../raster/r.in.mat/main.c:277
msgid "Invalid 'map_data' array"
msgstr ""
-#: ../raster/r.in.mat/main.c:312 ../raster/r.in.mat/main.c:418
-#: ../raster/r.in.mat/main.c:495
+#: ../raster/r.in.mat/main.c:299 ../raster/r.in.mat/main.c:429
+#: ../raster/r.in.mat/main.c:508
msgid "Please contact the GRASS development team"
msgstr ""
-#: ../raster/r.in.mat/main.c:317
+#: ../raster/r.in.mat/main.c:304
#, c-format
msgid "Skipping unknown array '%s'"
msgstr ""
-#: ../raster/r.in.mat/main.c:344
+#: ../raster/r.in.mat/main.c:331
#, fuzzy, c-format
msgid "No 'map_data' array found in <%s>"
msgstr " "
-#: ../raster/r.in.mat/main.c:358
+#: ../raster/r.in.mat/main.c:338
+#, c-format
+msgid "Setting map name to <%s> which overrides <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:345
+#, fuzzy, c-format
+msgid "Setting map name to <%s>"
+msgstr " "
+#: ../raster/r.in.mat/main.c:349
+#, fuzzy
+msgid "No 'map_name' array found; using <MatFile>"
+msgstr " "
+#: ../raster/r.in.mat/main.c:362
msgid "Missing bound"
msgstr ""
-#: ../raster/r.in.mat/main.c:362
+#: ../raster/r.in.mat/main.c:366
msgid "Using default bounds"
msgstr ""
-#: ../raster/r.in.mat/main.c:389
+#: ../raster/r.in.mat/main.c:381
+#, c-format
+msgid "Map <%s> bounds set to:"
+msgstr ""
+#: ../raster/r.in.mat/main.c:400
#, fuzzy
msgid "Writing new raster map..."
msgstr " "
-#: ../raster/r.univar2/r.univar_main.c:41
-#: ../raster/r.univar2/r3.univar_main.c:42 ../vector/v.univar/main.c:90
+#: ../raster/r.in.mat/main.c:450
+#, fuzzy, c-format
+msgid "Writing raster map, row %d"
+msgstr " "
+#: ../raster/r.univar2/r.univar_main.c:44
+#: ../raster/r.univar2/r3.univar_main.c:43 ../vector/v.univar/main.c:90
msgid "Print the stats in shell script style"
msgstr ""
-#: ../raster/r.univar2/r.univar_main.c:80
+#: ../raster/r.univar2/r.univar_main.c:77
msgid ""
"Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
-#: ../raster/r.univar2/r.univar_main.c:113
+#: ../raster/r.univar2/r.univar_main.c:121
#, fuzzy, c-format
+msgid "Raster <%s> type mismatch"
+msgstr "ïûéâëá "
+#: ../raster/r.univar2/r.univar_main.c:204
+#, fuzzy, c-format
msgid "Reading row %d"
-#: ../raster/r.univar2/r3.univar_main.c:79
+#: ../raster/r.univar2/r3.univar_main.c:80
#, fuzzy
msgid ""
"Calculates univariate statistics from the non-null 3d cells of a raster3d "
@@ -12662,88 +12817,78 @@
msgid "Edge number out of range"
msgstr ""
-#: ../raster/r.contour/main.c:91
+#: ../raster/r.contour/main.c:86
#, fuzzy
msgid ""
"Produces a vector map layer of specified contours from a raster map layer."
msgstr "×ÅËÔÏÒ."
-#: ../raster/r.contour/main.c:103
+#: ../raster/r.contour/main.c:97
msgid "List of contour levels"
msgstr ""
-#: ../raster/r.contour/main.c:109
+#: ../raster/r.contour/main.c:103
msgid "Minimum contour level"
msgstr ""
-#: ../raster/r.contour/main.c:115
+#: ../raster/r.contour/main.c:109
msgid "Maximum contour level"
msgstr ""
-#: ../raster/r.contour/main.c:121
+#: ../raster/r.contour/main.c:115
msgid "Increment between contour levels"
msgstr ""
-#: ../raster/r.contour/main.c:128
+#: ../raster/r.contour/main.c:122
msgid "Minimum number of points for a contour line (0 -> no limit)"
msgstr ""
-#: ../raster/r.contour/main.c:136
-msgid "Suppress single crossing error messages"
-msgstr ""
-#: ../raster/r.contour/main.c:145
-msgid ""
-"The '-q' and '-n' flag is superseded and will be removed in future. Please "
-"use '--quiet' instead."
-msgstr ""
-#: ../raster/r.contour/main.c:150
+#: ../raster/r.contour/main.c:128
msgid "Neither \"levels\" nor \"step\" parameter specified."
msgstr ""
-#: ../raster/r.contour/main.c:163
+#: ../raster/r.contour/main.c:141
msgid "Could not read range file"
msgstr ""
-#: ../raster/r.contour/main.c:192 ../vector/v.db.connect/main.c:272
+#: ../raster/r.contour/main.c:170 ../vector/v.db.connect/main.c:274
#: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.reclass/main.c:204
-#: ../vector/v.to.points/main.c:277 ../vector/v.sample/main.c:213
+#: ../vector/v.to.points/main.c:277 ../vector/v.sample/main.c:208
#: ../vector/v.in.ogr/main.c:718 ../vector/v.net.path/path.c:106
msgid "Cannot create index"
msgstr ""
-#: ../raster/r.contour/main.c:211 ../vector/v.sample/main.c:278
+#: ../raster/r.contour/main.c:189 ../vector/v.sample/main.c:271
#: ../vector/v.kcv/main.c:245
#, fuzzy, c-format
msgid "Unable to insert row: %s"
msgstr " "
-#: ../raster/r.contour/main.c:233
+#: ../raster/r.contour/main.c:211
#, fuzzy
msgid "Reading data: "
-#: ../raster/r.contour/main.c:264
+#: ../raster/r.contour/main.c:242
#, c-format
msgid "Range of data: min = %f max = %f"
msgstr ""
-#: ../raster/r.contour/main.c:266
+#: ../raster/r.contour/main.c:244
msgid "Range of data: empty"
msgstr ""
-#: ../raster/r.contour/main.c:297 ../raster/r.contour/main.c:299
+#: ../raster/r.contour/main.c:275 ../raster/r.contour/main.c:277
#, fuzzy
msgid "This step value is not allowed."
msgstr " "
-#: ../raster/r.contour/main.c:328
+#: ../raster/r.contour/main.c:306
#, c-format
msgid "Range of levels: min = %f max = %f"
msgstr ""
-#: ../raster/r.contour/main.c:357
+#: ../raster/r.contour/main.c:335
#, fuzzy
msgid "Displacing data: "
@@ -12753,36 +12898,36 @@
msgid "%s: STEP 3 ... "
msgstr ""
-#: ../raster/r.cross/main.c:67
+#: ../raster/r.cross/main.c:64
msgid ""
"Creates a cross product of the category values from multiple raster map "
"layers."
msgstr ""
-#: ../raster/r.cross/main.c:77
+#: ../raster/r.cross/main.c:74
#, c-format
msgid "Names of 2-%d input raster maps"
msgstr ""
-#: ../raster/r.cross/main.c:85
+#: ../raster/r.cross/main.c:82
msgid "Non-zero data only"
msgstr ""
-#: ../raster/r.cross/main.c:113
+#: ../raster/r.cross/main.c:96
#, fuzzy, c-format
msgid "More than %d files not allowed"
msgstr " "
-#: ../raster/r.cross/main.c:132
+#: ../raster/r.cross/main.c:115
msgid "Must specify 2 or more input maps"
msgstr ""
-#: ../raster/r.cross/main.c:153
+#: ../raster/r.cross/main.c:136
#, c-format
msgid "%s: STEP 2 ..."
msgstr ""
-#: ../raster/r.cross/main.c:199
+#: ../raster/r.cross/main.c:182
#, c-format
msgid "%ld categories"
msgstr ""
@@ -12869,18 +13014,18 @@
msgid "Reading <%s> in <%s>"
-#: ../raster/r.series/main.c:105
+#: ../raster/r.series/main.c:103
#, fuzzy
msgid "raster, series"
msgstr " "
-#: ../raster/r.series/main.c:107
+#: ../raster/r.series/main.c:105
msgid ""
"Makes each output cell value a function of the values assigned to the "
"corresponding cells in the input raster map layers."
msgstr ""
-#: ../raster/r.series/main.c:120
+#: ../raster/r.series/main.c:118
msgid "Aggregate operation"
msgstr ""
@@ -12889,7 +13034,7 @@
msgstr ""
#: ../raster/r.water.outlet/main.c:61 ../raster/r.walk/main.c:201
-#: ../raster/r.composite/main.c:128
+#: ../raster/r.composite/main.c:124
msgid "Name of raster map to contain results"
msgstr ""
@@ -12934,65 +13079,65 @@
msgid "Unable to close new basin map layer"
msgstr "üËÓÐÏÚÉÃÉÑ."
-#: ../raster/r.out.tiff/r.out.tiff.c:102
+#: ../raster/r.out.tiff/r.out.tiff.c:101
msgid ""
"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
"resolution of the currently defined region."
msgstr ""
-#: ../raster/r.out.tiff/r.out.tiff.c:112
+#: ../raster/r.out.tiff/r.out.tiff.c:111
#, fuzzy
msgid "Name for new TIFF file"
msgstr "×ÅËÔÏÒ"
-#: ../raster/r.out.tiff/r.out.tiff.c:119
+#: ../raster/r.out.tiff/r.out.tiff.c:118
msgid "TIFF file compression"
msgstr ""
-#: ../raster/r.out.tiff/r.out.tiff.c:124
+#: ../raster/r.out.tiff/r.out.tiff.c:123
msgid "TIFF Palette output (8bit instead of 24bit)."
msgstr ""
-#: ../raster/r.out.tiff/r.out.tiff.c:128
+#: ../raster/r.out.tiff/r.out.tiff.c:127
msgid "Output TIFF world file"
msgstr ""
-#: ../raster/r.out.tiff/r.out.tiff.c:132
+#: ../raster/r.out.tiff/r.out.tiff.c:131
msgid "Output Tiled TIFF"
msgstr ""
-#: ../raster/r.out.tiff/r.out.tiff.c:177
+#: ../raster/r.out.tiff/r.out.tiff.c:161
#, fuzzy, c-format
msgid ""
"Raster map <%s> in mapset <%s> is a floating point map. Decimal values will "
"be rounded to integer!"
msgstr " !"
-#: ../raster/r.out.tiff/r.out.tiff.c:183
+#: ../raster/r.out.tiff/r.out.tiff.c:167
msgid ""
"Color map for palette must have less than 256 colors for the available range "
"of data"
msgstr ""
-#: ../raster/r.out.tiff/r.out.tiff.c:198
+#: ../raster/r.out.tiff/r.out.tiff.c:182
#, fuzzy, c-format
msgid "Unable to open TIFF file <%s>"
msgstr " ."
-#: ../raster/r.out.tiff/r.out.tiff.c:430
+#: ../raster/r.out.tiff/r.out.tiff.c:414
#, fuzzy
msgid "Writing TIFF World file"
msgstr " ."
-#: ../raster/r.out.tiff/r.out.tiff.c:433
+#: ../raster/r.out.tiff/r.out.tiff.c:417
msgid "Got null file name"
msgstr ""
-#: ../raster/r.out.tiff/r.out.tiff.c:435
+#: ../raster/r.out.tiff/r.out.tiff.c:419
msgid "Got null region struct"
msgstr ""
-#: ../raster/r.out.tiff/r.out.tiff.c:438
+#: ../raster/r.out.tiff/r.out.tiff.c:422
#, fuzzy
msgid "Unable to open TIFF world file for writing"
msgstr " "
@@ -13066,144 +13211,144 @@
msgid "Name of input raster map containing friction costs"
msgstr ""
-#: ../raster/r.walk/main.c:267
+#: ../raster/r.walk/main.c:263
msgid "Number of the segment to create (segment library)"
msgstr ""
-#: ../raster/r.walk/main.c:277
+#: ../raster/r.walk/main.c:273
msgid "Coefficients for walking energy formula parameters a,b,c,d"
msgstr ""
-#: ../raster/r.walk/main.c:286
+#: ../raster/r.walk/main.c:282
msgid "Lambda coefficients for combining walking energy and friction cost"
msgstr ""
-#: ../raster/r.walk/main.c:296
+#: ../raster/r.walk/main.c:291
#, fuzzy
msgid "Slope factor determines travel energy cost per height step"
msgstr "óËÌÏÎÙ"
-#: ../raster/r.walk/main.c:359
+#: ../raster/r.walk/main.c:354
#, c-format
msgid "Missing required value: got %d instead of 4"
msgstr ""
-#: ../raster/r.walk/main.c:363
+#: ../raster/r.walk/main.c:358
#, fuzzy, c-format
msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
msgstr " "
-#: ../raster/r.walk/main.c:369 ../raster/r.walk/main.c:377
-#: ../raster/r.walk/main.c:384
+#: ../raster/r.walk/main.c:364 ../raster/r.walk/main.c:372
+#: ../raster/r.walk/main.c:379
#, c-format
msgid "Missing required value: %d"
msgstr ""
-#: ../raster/r.walk/main.c:372
+#: ../raster/r.walk/main.c:367
#, fuzzy, c-format
msgid "Lambda is %lf"
msgstr " "
-#: ../raster/r.walk/main.c:380
+#: ../raster/r.walk/main.c:375
#, fuzzy, c-format
msgid "Slope_factor is %lf"
msgstr "óËÌÏÎÙ "
-#: ../raster/r.walk/main.c:387
+#: ../raster/r.walk/main.c:382
#, fuzzy, c-format
msgid "Nseg is %d"
msgstr " "
-#: ../raster/r.walk/main.c:409
+#: ../raster/r.walk/main.c:404
#, fuzzy, c-format
msgid "Unable to find starting vector <%s> "
msgstr "×ÅËÔÏÒ "
-#: ../raster/r.walk/main.c:455
+#: ../raster/r.walk/main.c:450
#, fuzzy, c-format
msgid "Unable to find stop vector <%s>"
msgstr "×ÅËÔÏÒ "
-#: ../raster/r.walk/main.c:556 ../raster/r.walk/main.c:558
+#: ../raster/r.walk/main.c:551 ../raster/r.walk/main.c:553
#, fuzzy, c-format
msgid "Unable to read %s"
msgstr " "
-#: ../raster/r.walk/main.c:563
+#: ../raster/r.walk/main.c:558
msgid "Map with different projection"
msgstr ""
-#: ../raster/r.walk/main.c:575
+#: ../raster/r.walk/main.c:570
#, fuzzy
msgid "DTM_Source map is: Integer cell type"
msgstr " "
-#: ../raster/r.walk/main.c:578
+#: ../raster/r.walk/main.c:573
#, fuzzy
msgid "DTM_Source map is: Floating point (float) cell type"
msgstr " "
-#: ../raster/r.walk/main.c:582
+#: ../raster/r.walk/main.c:577
#, fuzzy
msgid "DTM_Source map is: Floating point (double) cell type"
msgstr " "
-#: ../raster/r.walk/main.c:591
+#: ../raster/r.walk/main.c:586
#, fuzzy
msgid "COST_Source map is: Integer cell type"
msgstr " "
-#: ../raster/r.walk/main.c:595
+#: ../raster/r.walk/main.c:590
#, fuzzy
msgid "COST_Source map is: Floating point (float) cell type"
msgstr " "
-#: ../raster/r.walk/main.c:599
+#: ../raster/r.walk/main.c:594
#, fuzzy
msgid "COST_Source map is: Floating point (double) cell type"
msgstr " "
-#: ../raster/r.walk/main.c:630
+#: ../raster/r.walk/main.c:625
#, fuzzy
msgid "Output map is: Integer cell type"
msgstr " "
-#: ../raster/r.walk/main.c:633
+#: ../raster/r.walk/main.c:628
#, fuzzy
msgid "Output map is: Floating point (float) cell type"
msgstr " "
-#: ../raster/r.walk/main.c:636
+#: ../raster/r.walk/main.c:631
#, fuzzy
msgid "Output map is: Floating point (double) cell type"
msgstr " "
-#: ../raster/r.walk/main.c:641
+#: ../raster/r.walk/main.c:636
#, fuzzy, c-format
msgid " EW resolution %s (%lf)"
msgstr " "
-#: ../raster/r.walk/main.c:643
+#: ../raster/r.walk/main.c:638
#, fuzzy, c-format
msgid " NS resolution %s (%lf)"
msgstr " "
-#: ../raster/r.walk/main.c:850
+#: ../raster/r.walk/main.c:845
#, fuzzy, c-format
msgid "Raster output map <%s> not found (no start_points given)"
msgstr " "
-#: ../raster/r.walk/main.c:865
+#: ../raster/r.walk/main.c:860
#, fuzzy, c-format
msgid "Memory allocation error on reading start points from raster map %s"
msgstr " "
-#: ../raster/r.walk/main.c:868
+#: ../raster/r.walk/main.c:863
#, fuzzy, c-format
msgid "Reading %s... "
msgstr " "
-#: ../raster/r.walk/main.c:1395
+#: ../raster/r.walk/main.c:1390
#, fuzzy, c-format
msgid "Writing output raster map %s... "
msgstr " "
@@ -13334,7 +13479,7 @@
msgid "Unable to close raster map <%s@%s>"
msgstr " "
-#: ../raster/r.mapcalc/map3.c:617
+#: ../raster/r.mapcalc/map3.c:619
#, fuzzy
msgid "Unable to close output raster map"
msgstr " "
@@ -13456,13 +13601,18 @@
msgid "%s is not a valid rule"
msgstr " "
-#: ../raster/r.mfilter/main.c:92
+#: ../raster/r.mfilter/main.c:85
msgid "Apply filter only to zero data values"
msgstr ""
+#: ../raster/r.composite/main.c:71
+#, fuzzy
+msgid "raster, composite"
+msgstr "×ÅËÔÏÒ"
#: ../raster/r.composite/main.c:73
msgid ""
-"Combines red, green and blue map layers into a single composite map layer."
+"Combines red, green and blue map layers into a single composite raster map."
msgstr ""
#: ../raster/r.composite/main.c:91
@@ -13479,23 +13629,34 @@
msgid "Number of levels to be used for <%s>"
msgstr " "
-#: ../raster/r.composite/main.c:132
+#: ../raster/r.composite/main.c:128
msgid "Dither"
msgstr ""
-#: ../raster/r.composite/main.c:136
+#: ../raster/r.composite/main.c:132
msgid "Use closest color"
msgstr ""
-#: ../raster/r.composite/main.c:221
+#: ../raster/r.composite/main.c:203
#, fuzzy, c-format
-msgid "Error reading '%s' map"
-msgstr " "
+msgid "Writing raster map <%s>..."
+msgstr " "
-#: ../raster/r.composite/main.c:275
-msgid "G_put_raster_row failed (file system full?)"
-msgstr ""
+#: ../raster/r.composite/main.c:219
+#, fuzzy, c-format
+msgid "Error reading raster map <%s>"
+msgstr " ."
+#: ../raster/r.composite/main.c:273 ../doc/raster/r.example/main.c:179
+#, fuzzy, c-format
+msgid "Failed writing raster map <%s>"
+msgstr " "
+#: ../raster/r.composite/main.c:314
+#, fuzzy
+msgid "Creating color table for output raster map..."
+msgstr " ."
#: ../raster/r.gwflow/main.c:64
msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
msgstr ""
@@ -13645,10 +13806,21 @@
msgid "Name of raster map to contain results (several new layers)"
msgstr ""
+#: ../raster/wildfire/r.ros/main.c:291 ../display/d.vect/main.c:327
+msgid "Run verbosely"
+msgstr ""
#: ../raster/wildfire/r.ros/main.c:295
msgid "Also produce maximum SPOTTING distance"
msgstr ""
+#: ../raster/wildfire/r.ros/main.c:304 ../raster/wildfire/r.spread/main.c:248
+#: ../display/d.vect/main.c:375 ../display/d.mon/pgms/release.c:37
+msgid ""
+"The '-v' flag is superseded and will be removed in future. Please use '--"
+"verbose' instead."
+msgstr ""
#: ../raster/wildfire/r.ros/main.c:396 ../raster/wildfire/r.ros/main.c:399
#: ../raster/wildfire/r.ros/main.c:402 ../raster/wildfire/r.ros/main.c:408
#: ../raster/wildfire/r.spread/main.c:388
@@ -13803,19 +13975,19 @@
msgid "Reading inputs..."
-#: ../raster/r.resample/main.c:55
+#: ../raster/r.resample/main.c:54
msgid "GRASS raster map layer data resampling capability."
msgstr ""
-#: ../raster/r.resample/main.c:64
+#: ../raster/r.resample/main.c:63
msgid "Name of an input layer"
msgstr ""
-#: ../raster/r.resample/main.c:71
+#: ../raster/r.resample/main.c:70
msgid "Name of an output layer"
msgstr ""
-#: ../raster/r.resample/main.c:166
+#: ../raster/r.resample/main.c:152
#, fuzzy
msgid "Creating new cats file..."
msgstr " ."
@@ -13830,34 +14002,34 @@
msgid "Reading input raster map <%s>..."
msgstr " ."
-#: ../raster/r.buffer/main.c:58
+#: ../raster/r.buffer/main.c:54
msgid "raster, buffer"
msgstr ""
-#: ../raster/r.buffer/main.c:60
+#: ../raster/r.buffer/main.c:56
msgid ""
"Creates a raster map layer showing buffer zones surrounding cells that "
"contain non-NULL category values."
msgstr ""
-#: ../raster/r.buffer/main.c:72
+#: ../raster/r.buffer/main.c:68
#, fuzzy
msgid "Distance zone(s)"
msgstr " "
-#: ../raster/r.buffer/main.c:79
+#: ../raster/r.buffer/main.c:75
msgid "Units of distance"
msgstr ""
-#: ../raster/r.buffer/main.c:84
+#: ../raster/r.buffer/main.c:80
msgid "Ignore zero (0) data cells instead of NULL cells"
msgstr ""
-#: ../raster/r.buffer/main.c:137
+#: ../raster/r.buffer/main.c:120
msgid "Parse distances error"
msgstr ""
-#: ../raster/r.buffer/main.c:157
+#: ../raster/r.buffer/main.c:140
#, c-format
msgid "Pass %d (of %d)"
msgstr ""
@@ -13986,6 +14158,49 @@
msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
msgstr ""
+#: ../raster/r.quantile/main.c:60
+msgid "Computing histogram"
+msgstr ""
+#: ../raster/r.quantile/main.c:96
+#, fuzzy
+msgid "Computing bins"
+msgstr " "
+#: ../raster/r.quantile/main.c:135
+#, fuzzy
+msgid "Binning data"
+msgstr "þÔÅÎÉÅ %s ..."
+#: ../raster/r.quantile/main.c:182
+#, fuzzy
+msgid "Sorting bins"
+msgstr " "
+#: ../raster/r.quantile/main.c:192
+#, fuzzy
+msgid "Computing quantiles"
+#: ../raster/r.quantile/main.c:235
+msgid "Compute quantiles using two passes."
+msgstr ""
+#: ../raster/r.quantile/main.c:243
+#, fuzzy
+msgid "Number of quantiles"
+msgstr " "
+#: ../raster/r.quantile/main.c:251
+#, fuzzy
+msgid "List of percentiles"
+msgstr " "
+#: ../raster/r.quantile/main.c:257
+#, fuzzy
+msgid "Number of bins to use"
+msgstr "üËÓÐÏÚÉÃÉÑ"
#: ../vector/v.net.visibility/main.c:46
#, fuzzy
msgid "vector, path, visibility"
@@ -14005,16 +14220,15 @@
msgstr ""
#: ../vector/v.net.visibility/main.c:81 ../vector/v.net.visibility/main.c:94
-#: ../vector/v.edit/cmd/main.c:138
+#: ../vector/v.edit/main.c:152
#: ../vector/lidar/v.lidar.edgedetection/main.c:174
#: ../vector/lidar/v.lidar.correction/main.c:142
#: ../vector/lidar/v.lidar.growing/main.c:125
#: ../vector/lidar/v.lidar.growing/main.c:128
#: ../vector/v.generalize/main.c:305 ../vector/v.net/main.c:159
-#: ../vector/v.hull/main.c:260 ../vector/v.support/main.c:126
-#: ../vector/v.surf.rst/main.c:517 ../vector/v.surf.rst/main.c:661
-#: ../vector/v.surf.rst/main.c:752 ../doc/vector/v.example/main.c:66
-#: ../display/d.what.vect/main.c:128
+#: ../vector/v.support/main.c:126 ../vector/v.surf.rst/main.c:517
+#: ../vector/v.surf.rst/main.c:661 ../vector/v.surf.rst/main.c:752
+#: ../doc/vector/v.example/main.c:66 ../display/d.what.vect/main.c:128
#, fuzzy, c-format
msgid "Unable to open vector map <%s>"
msgstr "×ÅËÔÏÒ "
@@ -14083,27 +14297,27 @@
msgid "Database connection for map <%s> is not defined in DB file"
msgstr " "
-#: ../vector/v.db.connect/main.c:144
+#: ../vector/v.db.connect/main.c:145
#, fuzzy, c-format
msgid "Vector map <%s> is connected by:"
msgstr "×ÅËÔÏÒ "
-#: ../vector/v.db.connect/main.c:148 ../display/d.what.vect/what.c:366
-#: ../display/d.vect/main.c:466
+#: ../vector/v.db.connect/main.c:150 ../display/d.what.vect/what.c:366
+#: ../display/d.vect/main.c:475 ../display/d.thematic.area/main.c:203
#, c-format
msgid "Database connection not defined"
msgstr ""
-#: ../vector/v.db.connect/main.c:159
+#: ../vector/v.db.connect/main.c:161
#, c-format
msgid ""
"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
msgstr ""
-#: ../vector/v.db.connect/main.c:168 ../vector/v.edit/cmd/select.c:522
+#: ../vector/v.db.connect/main.c:170 ../vector/v.edit/select.c:524
#: ../vector/v.distance/main.c:337 ../vector/v.distance/main.c:371
#: ../vector/v.db.select/main.c:97 ../vector/v.what.rast/main.c:122
-#: ../vector/v.extrude/main.c:162 ../vector/v.sample/main.c:166
+#: ../vector/v.extrude/main.c:162 ../vector/v.sample/main.c:161
#: ../vector/v.generalize/misc.c:158 ../vector/v.surf.idw/read_sites.c:35
#: ../vector/v.overlay/main.c:254 ../vector/v.to.rast/support.c:126
#: ../vector/v.to.rast/support.c:261 ../vector/v.to.rast/vect2rast.c:51
@@ -14112,45 +14326,45 @@
msgid "Database connection not defined for layer %d"
msgstr " "
-#: ../vector/v.db.connect/main.c:213
+#: ../vector/v.db.connect/main.c:215
#, c-format
msgid "Use -o to overwrite existing link for layer <%d>"
msgstr ""
-#: ../vector/v.db.connect/main.c:220 ../vector/v.db.connect/main.c:253
+#: ../vector/v.db.connect/main.c:222 ../vector/v.db.connect/main.c:255
#, fuzzy, c-format
msgid "Table <%s> does not exist in database <%s>"
msgstr " "
-#: ../vector/v.db.connect/main.c:230 ../vector/v.transform/trans_digit.c:92
+#: ../vector/v.db.connect/main.c:232 ../vector/v.transform/trans_digit.c:92
#: ../vector/v.in.db/main.c:131
#, fuzzy, c-format
msgid "Missing column <%s> in table <%s>"
msgstr " "
-#: ../vector/v.db.connect/main.c:235 ../vector/v.in.db/main.c:134
+#: ../vector/v.db.connect/main.c:237 ../vector/v.in.db/main.c:134
#, fuzzy
msgid "Data type of key column must be integer"
msgstr "ìÉÎÉÑ ."
-#: ../vector/v.db.connect/main.c:242 ../vector/v.db.connect/main.c:259
+#: ../vector/v.db.connect/main.c:244 ../vector/v.db.connect/main.c:261
#, fuzzy, c-format
msgid ""
"The table <%s> is now part of vector map <%s> and may be deleted or "
"overwritten by GRASS modules"
msgstr " ×ÅËÔÏÒ "
-#: ../vector/v.db.connect/main.c:275 ../vector/v.in.dxf/write_vect.c:209
+#: ../vector/v.db.connect/main.c:277 ../vector/v.in.dxf/write_vect.c:209
#: ../vector/v.in.ogr/main.c:721
#, fuzzy, c-format
msgid "Cannot grant privileges on table %s"
msgstr " "
-#: ../vector/v.db.connect/main.c:277
+#: ../vector/v.db.connect/main.c:279
msgid "Select privileges were granted on the table"
msgstr ""
-#: ../vector/v.db.connect/main.c:284
+#: ../vector/v.db.connect/main.c:286
msgid ""
"For defining a new connection you have to specify these parameters: driver, "
"database, table [, key [, layer]]"
@@ -14173,26 +14387,28 @@
#: ../vector/v.to.rast3/main.c:81 ../vector/v.reclass/main.c:113
#: ../vector/v.univar/main.c:131 ../vector/v.vol.rst/user1.c:92
-#: ../vector/v.label.sa/labels.c:76 ../vector/v.label/main.c:273
-#: ../vector/v.buffer/main.c:371 ../ps/ps.map/catval.c:47
-#: ../ps/ps.map/catval.c:105 ../ps/ps.map/catval.c:166
+#: ../vector/v.label.sa/labels.c:75 ../vector/v.label/main.c:273
+#: ../vector/v.buffer/main.c:371 ../vector/v.class/main.c:104
+#: ../ps/ps.map/catval.c:47 ../ps/ps.map/catval.c:105
+#: ../ps/ps.map/catval.c:166
#, fuzzy
msgid "Unable to get layer info for vector map"
msgstr "×ÅËÔÏÒ"
#: ../vector/v.to.rast3/main.c:93 ../vector/lidar/v.surf.bspline/main.c:307
-#: ../vector/v.univar/main.c:147 ../vector/v.sample/main.c:181
+#: ../vector/v.univar/main.c:147 ../vector/v.sample/main.c:176
#: ../vector/v.surf.idw/read_sites.c:49 ../vector/v.normal/main.c:150
-#: ../vector/v.buffer/main.c:383 ../ps/ps.map/catval.c:64
-#: ../ps/ps.map/catval.c:125 ../ps/ps.map/catval.c:187
+#: ../vector/v.buffer/main.c:383 ../vector/v.class/main.c:124
+#: ../ps/ps.map/catval.c:64 ../ps/ps.map/catval.c:125
+#: ../ps/ps.map/catval.c:187
#, fuzzy
msgid "Unable to select data from table"
msgstr " "
#: ../vector/v.to.rast3/main.c:97 ../vector/lidar/v.surf.bspline/main.c:304
#: ../vector/v.univar/main.c:145 ../vector/v.what.rast/main.c:151
-#: ../vector/v.sample/main.c:258 ../vector/v.surf.idw/read_sites.c:46
-#: ../vector/v.buffer/main.c:388
+#: ../vector/v.sample/main.c:251 ../vector/v.surf.idw/read_sites.c:46
+#: ../vector/v.buffer/main.c:388 ../vector/v.class/main.c:121
msgid "Column type not supported"
msgstr ""
@@ -14298,213 +14514,256 @@
msgid "normalsv: restoration of unitialized block"
msgstr ""
-#: ../vector/v.edit/cmd/max_distance.c:57
+#: ../vector/v.edit/select.c:75
#, c-format
-msgid "Threshold distance set to %g map units (based on 2D resolution)"
+msgid "Threshold value for coordinates is %.2f"
msgstr ""
-#: ../vector/v.edit/cmd/select.c:186
+#: ../vector/v.edit/select.c:170
#, fuzzy, c-format
+msgid "Threshold value for querying is %.2f"
+msgstr "×ÅËÔÏÒ."
+#: ../vector/v.edit/select.c:186
+#, fuzzy, c-format
msgid "%d of %d features selected from vector map <%s>"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/select.c:516
+#: ../vector/v.edit/select.c:518
msgid "Layer must be > 0 for 'where'"
msgstr ""
-#: ../vector/v.edit/cmd/snap.c:119 ../vector/v.edit/cmd/a2b.c:319
+#: ../vector/v.edit/snap.c:119 ../vector/v.edit/a2b.c:319
#, fuzzy, c-format
msgid "Unable to rewrite line %d"
msgstr " "
-#: ../vector/v.edit/cmd/a2b.c:84 ../vector/v.edit/cmd/a2b.c:122
-#: ../vector/v.edit/cmd/a2b.c:147
+#: ../vector/v.edit/a2b.c:84 ../vector/v.edit/a2b.c:122
+#: ../vector/v.edit/a2b.c:147
#, fuzzy, c-format
msgid "Error reading ASCII file: '%s'"
msgstr " ."
-#: ../vector/v.edit/cmd/a2b.c:136 ../vector/v.in.ascii/a2b.c:102
+#: ../vector/v.edit/a2b.c:136 ../vector/v.in.ascii/a2b.c:102
msgid "End of ASCII file reached before end of coordinates"
msgstr ""
-#: ../vector/v.edit/cmd/a2b.c:173
+#: ../vector/v.edit/a2b.c:173
msgid "End of ascii file reached before end of categories"
msgstr ""
-#: ../vector/v.edit/cmd/a2b.c:183
+#: ../vector/v.edit/a2b.c:183
#, fuzzy, c-format
msgid "Error reading categories: '%s'"
msgstr " ."
-#: ../vector/v.edit/cmd/a2b.c:231
+#: ../vector/v.edit/a2b.c:231
#, fuzzy, c-format
msgid "Unexpected data in vector head: '%s'"
msgstr "×ÅËÔÏÒ "
-#: ../vector/v.edit/cmd/a2b.c:261
+#: ../vector/v.edit/a2b.c:261
#, fuzzy, c-format
msgid "Unknown keyword '%s' in vector head"
msgstr " ×ÅËÔÏÒ."
-#: ../vector/v.edit/cmd/main.c:54
+#: ../vector/v.edit/main.c:54
#, fuzzy
msgid "vector, editing, geometry"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:55
+#: ../vector/v.edit/main.c:55
#, fuzzy
msgid ""
"Edits a vector map, allows adding, deleting and modifying selected vector "
"features."
msgstr "×ÅËÔÏÒ ×ÅËÔÏÒ."
-#: ../vector/v.edit/cmd/main.c:64
+#: ../vector/v.edit/main.c:64
#, fuzzy, c-format
msgid "Unable to get category list <%s>"
msgstr " "
-#: ../vector/v.edit/cmd/main.c:76 ../vector/v.in.ascii/in.c:195
+#: ../vector/v.edit/main.c:76 ../vector/v.in.ascii/in.c:197
#, fuzzy, c-format
msgid "Unable to open ASCII file <%s>"
msgstr " ."
-#: ../vector/v.edit/cmd/main.c:99 ../vector/v.build/main.c:77
+#: ../vector/v.edit/main.c:92 ../vector/v.in.ogr/main.c:323
+#, fuzzy, c-format
+msgid "Vector map <%s> already exists"
+msgstr "ïûéâëá "
+#: ../vector/v.edit/main.c:113 ../vector/v.build/main.c:77
#: ../vector/v.support/main.c:121 ../vector/v.neighbors/main.c:76
#, fuzzy, c-format
msgid "Vector map <%s> not found in the current mapset"
msgstr "×ÅËÔÏÒ "
-#: ../vector/v.edit/cmd/main.c:110 ../vector/v.kcv/main.c:137
+#: ../vector/v.edit/main.c:124 ../vector/v.kcv/main.c:137
#, fuzzy, c-format
msgid "Unable to open vector map <%s> at topological level %d"
msgstr "×ÅËÔÏÒ "
-#: ../vector/v.edit/cmd/main.c:130
+#: ../vector/v.edit/main.c:144
#, fuzzy, c-format
msgid ""
"Unable to open vector map <%s> as the backround map. It is given as vector "
"map to be edited."
msgstr "×ÅËÔÏÒ "
-#: ../vector/v.edit/cmd/main.c:141
+#: ../vector/v.edit/main.c:155
#, fuzzy, c-format
msgid "Background vector map <%s> registered"
msgstr "×ÅËÔÏÒ "
-#: ../vector/v.edit/cmd/main.c:179
+#: ../vector/v.edit/main.c:205
msgid "No features selected, nothing to edit"
msgstr ""
-#: ../vector/v.edit/cmd/main.c:187
+#: ../vector/v.edit/main.c:213
#, c-format
msgid ""
"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
"the vector map to 3D using e.g. %s."
msgstr ""
-#: ../vector/v.edit/cmd/main.c:223
+#: ../vector/v.edit/main.c:249
#, fuzzy, c-format
msgid "%d features added"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:234
+#: ../vector/v.edit/main.c:251 ../vector/v.edit/main.c:273
+#: ../vector/v.edit/main.c:282 ../vector/v.edit/main.c:312
+#: ../vector/v.edit/main.c:351
#, fuzzy, c-format
-msgid "%d lines closed"
+msgid "Threshold value for snapping is %.2f"
+msgstr "×ÅËÔÏÒ."
+#: ../vector/v.edit/main.c:261
+#, fuzzy, c-format
+msgid "%d boundaries closed"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:241
+#: ../vector/v.edit/main.c:268
#, fuzzy, c-format
msgid "%d features deleted"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:248
+#: ../vector/v.edit/main.c:277
#, fuzzy, c-format
msgid "%d features moved"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:258
+#: ../vector/v.edit/main.c:288
#, fuzzy, c-format
msgid "%d vertices moved"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:263
+#: ../vector/v.edit/main.c:293
#, fuzzy, c-format
msgid "%d vertices added"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:268
+#: ../vector/v.edit/main.c:298
#, fuzzy, c-format
msgid "%d vertices removed"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:279
+#: ../vector/v.edit/main.c:309
#, fuzzy, c-format
msgid "%d lines broken"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:284
+#: ../vector/v.edit/main.c:315
#, fuzzy, c-format
msgid "%d lines connected"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:288
+#: ../vector/v.edit/main.c:319
#, fuzzy, c-format
msgid "%d lines merged"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:297 ../vector/v.edit/cmd/main.c:302
+#: ../vector/v.edit/main.c:328 ../vector/v.edit/main.c:333
#, fuzzy, c-format
msgid "%d features modified"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:307
+#: ../vector/v.edit/main.c:338
#, c-format
msgid ""
"Multiple background maps were given. Selected features will be copied only "
"from vector map <%s>."
msgstr ""
-#: ../vector/v.edit/cmd/main.c:317
+#: ../vector/v.edit/main.c:348
#, fuzzy, c-format
msgid "%d features copied"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:324
+#: ../vector/v.edit/main.c:356
#, fuzzy, c-format
msgid "%d lines flipped"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:345
+#: ../vector/v.edit/main.c:377
#, fuzzy, c-format
msgid "%d lines labeled"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/main.c:349
+#: ../vector/v.edit/main.c:388
+#, fuzzy, c-format
+msgid "%d points converted to centroids"
+msgstr "×ÅËÔÏÒ"
+#: ../vector/v.edit/main.c:392
+#, fuzzy, c-format
+msgid "%d centroids converted to points"
+msgstr "×ÅËÔÏÒ"
+#: ../vector/v.edit/main.c:396
+#, fuzzy, c-format
+msgid "%d lines converted to boundaries"
+msgstr " "
+#: ../vector/v.edit/main.c:400
+#, c-format
+msgid "%d boundaries converted to lines"
+msgstr ""
+#: ../vector/v.edit/main.c:405
#, fuzzy
+msgid "No feature modified"
+msgstr "×ÅËÔÏÒ"
+#: ../vector/v.edit/main.c:410
+#, fuzzy
msgid "Operation not implemented"
msgstr " "
-#: ../vector/v.edit/cmd/args.c:37
+#: ../vector/v.edit/args.c:37
#, fuzzy
msgid "Name of vector map to edit"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/args.c:40 ../vector/v.edit/cmd/args.c:45
-#: ../vector/v.edit/cmd/args.c:121 ../vector/v.edit/cmd/args.c:126
-#: ../vector/v.edit/cmd/args.c:135 ../vector/v.edit/cmd/args.c:144
-#: ../vector/v.edit/cmd/args.c:153 ../vector/v.edit/cmd/args.c:156
-#: ../vector/v.edit/cmd/args.c:169 ../vector/v.in.ogr/main.c:126
+#: ../vector/v.edit/args.c:40 ../vector/v.edit/args.c:45
+#: ../vector/v.edit/args.c:123 ../vector/v.edit/args.c:128
+#: ../vector/v.edit/args.c:137 ../vector/v.edit/args.c:146
+#: ../vector/v.edit/args.c:155 ../vector/v.edit/args.c:158
+#: ../vector/v.edit/args.c:171 ../vector/v.in.ogr/main.c:126
#: ../vector/v.in.ogr/main.c:139 ../vector/v.in.ogr/main.c:160
-#: ../display/d.vect/main.c:176 ../display/d.vect/main.c:179
-#: ../display/d.vect/main.c:337
+#: ../display/d.vect/main.c:146 ../display/d.vect/main.c:150
+#: ../display/d.vect/main.c:153 ../display/d.vect/main.c:156
+#: ../display/d.vect/main.c:346 ../display/d.thematic.area/main.c:106
msgid "Query"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:52
+#: ../vector/v.edit/args.c:52
msgid "Tool"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:53
+#: ../vector/v.edit/args.c:53
msgid ""
"create;Create new (empty) vector map;add;Add new features to existing vector "
"map;delete;Delete selected features from vector map;move;Move selected "
@@ -14516,128 +14775,129 @@
"categories from selected vector features for defined layer;copy;Copy "
"selected features;snap;Snap vector features in given threshold;flip;Flip "
"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
-"labeling (automated assignment of z coordinate to vector lines)"
+"labeling (automated assignment of z coordinate to vector lines);chtype;"
+"Change feature type (point<->centroid, line<->boundary)"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:96
+#: ../vector/v.edit/args.c:98
#, fuzzy
msgid "ASCII file to be converted to binary vector map"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/args.c:97
+#: ../vector/v.edit/args.c:99
#, fuzzy
msgid "If not given (or \"-\") reads from standard input"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/args.c:106
+#: ../vector/v.edit/args.c:108
msgid "Difference in x,y direction for moving feature or vertex"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:113
-msgid "Threshold distance"
+#: ../vector/v.edit/args.c:115
+msgid "Threshold distance (coords,snap,query)"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:114
+#: ../vector/v.edit/args.c:116
#, fuzzy
msgid "'-1' for threshold based on the current resolution settings"
msgstr " "
-#: ../vector/v.edit/cmd/args.c:120
+#: ../vector/v.edit/args.c:122
msgid "ID values"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:134
+#: ../vector/v.edit/args.c:136
#, fuzzy
msgid "List of point coordinates"
msgstr " "
-#: ../vector/v.edit/cmd/args.c:143
+#: ../vector/v.edit/args.c:145
msgid "Bounding box for selecting features"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:152
+#: ../vector/v.edit/args.c:154
msgid "Polygon for selecting features"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:162
+#: ../vector/v.edit/args.c:164
msgid "Query tool"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:163
+#: ../vector/v.edit/args.c:165
msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:165
+#: ../vector/v.edit/args.c:167
msgid ""
"length;Select only lines or boudaries shorter/longer than threshold distance;"
"dangle;Select dangles shorter/longer than threshold distance"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:174
+#: ../vector/v.edit/args.c:176
#, fuzzy
-msgid "Name of background vector map(s) snap to"
+msgid "Name of background vector map(s)"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/args.c:180
+#: ../vector/v.edit/args.c:182
msgid ""
"Snap added or modified features in the given threshold to the nearest "
"existing feature"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:181
+#: ../vector/v.edit/args.c:183
msgid ""
"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
"vertex"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:190
+#: ../vector/v.edit/args.c:192
msgid "Starting value and step for z bulk-labeling"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:191
+#: ../vector/v.edit/args.c:193
msgid "Pair: value,step (e.g. 1100,10)"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:196 ../vector/v.extract/main.c:88
+#: ../vector/v.edit/args.c:198 ../vector/v.extract/main.c:88
msgid "Reverse selection"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:206
+#: ../vector/v.edit/args.c:208
msgid "Close added boundaries (using threshold distance)"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:210
+#: ../vector/v.edit/args.c:212
#, fuzzy
msgid "Do not expect header of input data"
msgstr " "
-#: ../vector/v.edit/cmd/args.c:215 ../vector/v.in.dxf/main.c:78
+#: ../vector/v.edit/args.c:217 ../vector/v.in.dxf/main.c:78
#: ../vector/v.random/main.c:113
#, fuzzy
msgid "Do not build topology"
msgstr " ×ÅËÔÏÒ"
-#: ../vector/v.edit/cmd/args.c:219
+#: ../vector/v.edit/args.c:221
msgid "Modify only first found feature in bounding box"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:241
+#: ../vector/v.edit/args.c:243
msgid "Polygon must have at least 3 coordinate pairs"
msgstr ""
-#: ../vector/v.edit/cmd/args.c:307
+#: ../vector/v.edit/args.c:305
#, fuzzy, c-format
msgid "Operation '%s' not implemented"
msgstr " "
-#: ../vector/v.edit/cmd/args.c:319
+#: ../vector/v.edit/args.c:317
#, fuzzy, c-format
msgid "At least one option from %s must be specified"
msgstr "×ÅËÔÏÒ."
-#: ../vector/v.edit/cmd/args.c:327 ../vector/v.edit/cmd/args.c:338
-#: ../vector/v.edit/cmd/args.c:349 ../vector/v.edit/cmd/args.c:357
-#: ../vector/v.edit/cmd/args.c:362
+#: ../vector/v.edit/args.c:325 ../vector/v.edit/args.c:336
+#: ../vector/v.edit/args.c:347 ../vector/v.edit/args.c:355
+#: ../vector/v.edit/args.c:360
#, c-format
msgid "Tool %s requires option %s"
msgstr ""
@@ -14682,6 +14942,7 @@
#: ../vector/v.in.dxf/write_vect.c:185 ../vector/v.in.ogr/main.c:707
#: ../vector/v.surf.rst/main.c:553 ../display/d.vect/plot1.c:203
#: ../display/d.vect/area.c:57 ../display/d.vect/attr.c:44
+#: ../display/d.thematic.area/plot1.c:198
#, fuzzy, c-format
msgid "Cannot open database %s by driver %s"
msgstr " "
@@ -15276,7 +15537,7 @@
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:291 ../display/d.vect/plot1.c:198
-#: ../display/d.vect/area.c:52
+#: ../display/d.vect/area.c:52 ../display/d.thematic.area/plot1.c:193
msgid "Cannot read field info"
msgstr ""
@@ -15515,7 +15776,8 @@
#: ../vector/v.distance/main.c:657
-msgid "More cats of to_layer"
+#, c-format
+msgid "More cats found in to_layer (area=%d)"
msgstr ""
#: ../vector/v.distance/main.c:755 ../vector/v.overlay/main.c:422
@@ -15751,211 +16013,212 @@
msgid "ASCII file to be imported, if not given reads from standard input"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.in.ascii/in.c:67
+#: ../vector/v.in.ascii/in.c:68
#, fuzzy
msgid "Input file format"
msgstr " "
-#: ../vector/v.in.ascii/in.c:78
+#: ../vector/v.in.ascii/in.c:79
msgid "Number of header lines to skip at top of input file (points mode)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:82 ../vector/v.in.ascii/in.c:94
-#: ../vector/v.in.ascii/in.c:105 ../vector/v.in.ascii/in.c:116
-#: ../vector/v.in.ascii/in.c:128
+#: ../vector/v.in.ascii/in.c:83 ../vector/v.in.ascii/in.c:95
+#: ../vector/v.in.ascii/in.c:106 ../vector/v.in.ascii/in.c:117
+#: ../vector/v.in.ascii/in.c:129 ../vector/v.in.ascii/in.c:154
#, fuzzy
msgid "Columns"
msgstr " "
-#: ../vector/v.in.ascii/in.c:83
+#: ../vector/v.in.ascii/in.c:84
msgid "Column definition in SQL style (points mode)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:84
+#: ../vector/v.in.ascii/in.c:85
msgid ""
"For example: 'x double precision, y double precision, cat int, name varchar"
"(10)'"
msgstr ""
-#: ../vector/v.in.ascii/in.c:97
+#: ../vector/v.in.ascii/in.c:98
#, fuzzy
msgid ""
"Number of column used as x coordinate (first column is 1) for points mode"
msgstr " "
-#: ../vector/v.in.ascii/in.c:108
+#: ../vector/v.in.ascii/in.c:109
#, fuzzy
msgid ""
"Number of column used as y coordinate (first column is 1) for points mode"
msgstr " "
-#: ../vector/v.in.ascii/in.c:118
+#: ../vector/v.in.ascii/in.c:119
#, fuzzy
msgid ""
"Number of column used as z coordinate (first column is 1) for points mode"
msgstr " "
-#: ../vector/v.in.ascii/in.c:120
+#: ../vector/v.in.ascii/in.c:121
msgid "If 0, z coordinate is not used"
msgstr ""
-#: ../vector/v.in.ascii/in.c:131
+#: ../vector/v.in.ascii/in.c:132
#, fuzzy
msgid "Number of column used as category (first column is 1) for points mode"
msgstr " "
-#: ../vector/v.in.ascii/in.c:134
+#: ../vector/v.in.ascii/in.c:135
#, fuzzy
msgid ""
"If 0, unique category is assigned to each row and written to new column 'cat'"
msgstr " ."
-#: ../vector/v.in.ascii/in.c:138
-msgid "Create 3D file"
-msgstr ""
+#: ../vector/v.in.ascii/in.c:139
+#, fuzzy
+msgid "Create 3D vector map"
+msgstr "×ÅËÔÏÒ"
-#: ../vector/v.in.ascii/in.c:143
+#: ../vector/v.in.ascii/in.c:144
#, fuzzy
-msgid "Create a new empty map and exit. Nothing is read from input"
+msgid "Create a new empty vector map and exit. Nothing is read from input"
msgstr "ÐÕÓÔ ."
-#: ../vector/v.in.ascii/in.c:148
+#: ../vector/v.in.ascii/in.c:149
msgid "Don't expect a header when reading in standard format"
msgstr ""
-#: ../vector/v.in.ascii/in.c:152
+#: ../vector/v.in.ascii/in.c:153
msgid "Do not create table in points mode"
msgstr ""
-#: ../vector/v.in.ascii/in.c:156
+#: ../vector/v.in.ascii/in.c:158
msgid "Do not build topology in points mode"
msgstr ""
-#: ../vector/v.in.ascii/in.c:161
+#: ../vector/v.in.ascii/in.c:163
msgid "Only import points falling within current region (points mode)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:175
+#: ../vector/v.in.ascii/in.c:177
msgid "Please specify reasonable number of lines to skip"
msgstr ""
-#: ../vector/v.in.ascii/in.c:178
+#: ../vector/v.in.ascii/in.c:180
msgid "Please specify z column"
msgstr ""
-#: ../vector/v.in.ascii/in.c:189
+#: ../vector/v.in.ascii/in.c:191
msgid "Please specify reasonable z column"
msgstr ""
-#: ../vector/v.in.ascii/in.c:245
+#: ../vector/v.in.ascii/in.c:249
#, c-format
msgid "Maximum input row length: %d"
msgstr ""
-#: ../vector/v.in.ascii/in.c:246
+#: ../vector/v.in.ascii/in.c:250
#, fuzzy, c-format
msgid "Maximum number of columns: %d"
msgstr " "
-#: ../vector/v.in.ascii/in.c:247
+#: ../vector/v.in.ascii/in.c:251
#, fuzzy, c-format
msgid "Minimum number of columns: %d"
msgstr " "
-#: ../vector/v.in.ascii/in.c:253
+#: ../vector/v.in.ascii/in.c:257
msgid ""
"x column number > minimum last column number\n"
"(incorrect field separator?)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:258
+#: ../vector/v.in.ascii/in.c:262
msgid ""
"y column number > minimum last column number\n"
msgstr ""
-#: ../vector/v.in.ascii/in.c:262
+#: ../vector/v.in.ascii/in.c:266
msgid ""
"z column number > minimum last column number (incorrect field separator?)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:267
+#: ../vector/v.in.ascii/in.c:271
msgid ""
"cat column number > minimum last column number (incorrect field separator?)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:273
+#: ../vector/v.in.ascii/in.c:277
#, fuzzy
msgid "x column is not of number type"
msgstr " "
-#: ../vector/v.in.ascii/in.c:277
+#: ../vector/v.in.ascii/in.c:281
#, fuzzy
msgid "y column is not of number type"
msgstr " "
-#: ../vector/v.in.ascii/in.c:281
+#: ../vector/v.in.ascii/in.c:285
#, fuzzy
msgid "z column is not of number type"
msgstr " "
-#: ../vector/v.in.ascii/in.c:285
+#: ../vector/v.in.ascii/in.c:289
#, fuzzy
msgid "cat column is not of number type"
msgstr " "
-#: ../vector/v.in.ascii/in.c:327
+#: ../vector/v.in.ascii/in.c:331
#, fuzzy
msgid "Category column is not of integer type"
msgstr " "
-#: ../vector/v.in.ascii/in.c:409
+#: ../vector/v.in.ascii/in.c:413
#, c-format
msgid ""
"Number of columns defined (%d) does not match number of columns (%d) in input"
msgstr ""
-#: ../vector/v.in.ascii/in.c:436
+#: ../vector/v.in.ascii/in.c:440
#, c-format
msgid "Column number %d defined as double has only integer values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:440
+#: ../vector/v.in.ascii/in.c:444
#, c-format
msgid "Column number %d defined as string has only integer values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:448
+#: ../vector/v.in.ascii/in.c:452
#, c-format
msgid "Column number %d defined as integer has double values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:452
+#: ../vector/v.in.ascii/in.c:456
#, c-format
msgid "Column number %d defined as string has double values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:460
+#: ../vector/v.in.ascii/in.c:464
#, c-format
msgid "Column number %d defined as integer has string values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:466
+#: ../vector/v.in.ascii/in.c:470
#, c-format
msgid "Column number %d defined as double has string values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:472
+#: ../vector/v.in.ascii/in.c:476
#, fuzzy, c-format
msgid "Length of column %d (%d) is less than maximum value length (%d)"
msgstr " "
-#: ../vector/v.in.ascii/in.c:493
+#: ../vector/v.in.ascii/in.c:497
#, fuzzy, c-format
msgid "Unable to create index for table <%s>, key <%s>"
msgstr " "
-#: ../vector/v.in.ascii/in.c:511
+#: ../vector/v.in.ascii/in.c:515
#, fuzzy
msgid "Populating table..."
@@ -15985,14 +16248,14 @@
msgid "Importing points..."
msgstr " "
-#: ../vector/v.in.ascii/points.c:388 ../vector/v.mkgrid/main.c:263
+#: ../vector/v.in.ascii/points.c:388 ../vector/v.mkgrid/main.c:248
#, fuzzy, c-format
msgid "Unable to insert new record: %s"
msgstr " "
#: ../vector/v.to.points/main.c:161 ../vector/v.segment/main.c:51
#: ../vector/v.split/main.c:40 ../vector/v.overlay/main.c:55
-#: ../vector/v.parallel/main.c:39 ../vector/v.hull/main.c:233
+#: ../vector/v.parallel/main.c:39 ../vector/v.hull/main.c:271
#: ../vector/v.type/main.c:46
#, fuzzy
msgid "vector, geometry"
@@ -16132,11 +16395,6 @@
"to stdout;cdump;write category index to stdout"
msgstr ""
-#: ../vector/v.build/main.c:150 ../vector/v.clean/main.c:366
-#, fuzzy
-msgid "Building topology for error vector map..."
-msgstr " ."
#: ../vector/v.segment/main.c:53
msgid "Creates points/segments from input vector lines and positions."
msgstr ""
@@ -16308,9 +16566,9 @@
msgid "More points (%d) of category %d, value set to 'NULL'"
msgstr ""
-#: ../vector/v.what.rast/main.c:294 ../vector/v.sample/main.c:244
-#: ../vector/v.sample/main.c:252 ../vector/v.vol.rst/user1.c:157
-#: ../vector/v.label.sa/labels.c:165 ../vector/v.label/main.c:318
+#: ../vector/v.what.rast/main.c:294 ../vector/v.sample/main.c:237
+#: ../vector/v.sample/main.c:245 ../vector/v.vol.rst/user1.c:157
+#: ../vector/v.label.sa/labels.c:164 ../vector/v.label/main.c:318
#: ../vector/v.buffer/main.c:433 ../vector/v.buffer/main.c:442
#: ../vector/v.buffer/main.c:501 ../vector/v.buffer/main.c:510
#, fuzzy, c-format
@@ -16502,12 +16760,12 @@
msgid "Extruding areas..."
msgstr "×ÅËÔÏÒ."
-#: ../vector/v.extrude/main.c:203 ../vector/v.out.svg/main.c:209
+#: ../vector/v.extrude/main.c:201 ../vector/v.out.svg/main.c:209
#, c-format
msgid "Skipping area %d without centroid"
msgstr ""
-#: ../vector/v.extrude/main.c:217
+#: ../vector/v.extrude/main.c:215
#, fuzzy, c-format
msgid "Cannot select attributes for area %d"
msgstr " "
@@ -16517,12 +16775,12 @@
msgid "Extruding basic vector objects..."
msgstr " "
-#: ../vector/v.extrude/main.c:287
+#: ../vector/v.extrude/main.c:285
#, c-format
msgid "Cannot select attributes for area #%d"
msgstr ""
-#: ../vector/v.extrude/main.c:305
+#: ../vector/v.extrude/main.c:303
#, c-format
msgid "Column <%s>: invalid data type"
msgstr ""
@@ -16591,77 +16849,77 @@
msgid "Only calculate optimal standard deviation and exit (no map is written)"
msgstr " "
-#: ../vector/v.kernel/main.c:207
+#: ../vector/v.kernel/main.c:194
#, fuzzy, c-format
msgid "Network input map <%s> not found"
msgstr "×ÅËÔÏÒ "
-#: ../vector/v.kernel/main.c:227
+#: ../vector/v.kernel/main.c:214
#, c-format
msgid "%d points outside threshold"
msgstr ""
-#: ../vector/v.kernel/main.c:252
+#: ../vector/v.kernel/main.c:239
#, fuzzy, c-format
msgid ""
"Automatic choose of smoothing parameter (standard deviation), maximum "
"possible value of standard deviation is was set to %f"
msgstr " "
-#: ../vector/v.kernel/main.c:259
+#: ../vector/v.kernel/main.c:246
#, c-format
msgid "Using maximum distance between points: %f"
msgstr ""
-#: ../vector/v.kernel/main.c:271
+#: ../vector/v.kernel/main.c:258
#, c-format
msgid "Number of input points: %d."
msgstr ""
-#: ../vector/v.kernel/main.c:272
+#: ../vector/v.kernel/main.c:259
#, c-format
msgid "%d distances read from the map."
msgstr ""
-#: ../vector/v.kernel/main.c:275
+#: ../vector/v.kernel/main.c:262
#, fuzzy, c-format
msgid ""
"Distances between all points are beyond %e (4 * standard deviation), unable "
"to calculate optimal value."
msgstr " ."
-#: ../vector/v.kernel/main.c:285
+#: ../vector/v.kernel/main.c:272
#, c-format
msgid "Optimal smoothing parameter (standard deviation): %f."
msgstr ""
-#: ../vector/v.kernel/main.c:307
+#: ../vector/v.kernel/main.c:294
#, fuzzy, c-format
msgid ""
"\n"
"Writing output vector map using smooth parameter=%f."
msgstr "×ÅËÔÏÒ."
-#: ../vector/v.kernel/main.c:308 ../vector/v.kernel/main.c:372
+#: ../vector/v.kernel/main.c:295 ../vector/v.kernel/main.c:359
#, c-format
msgid ""
"\n"
"Normalising factor=%f."
msgstr ""
-#: ../vector/v.kernel/main.c:371
+#: ../vector/v.kernel/main.c:358
#, c-format
msgid ""
"\n"
"Writing output raster map using smooth parameter=%f."
msgstr ""
-#: ../vector/v.kernel/main.c:379
+#: ../vector/v.kernel/main.c:366
#, fuzzy
msgid "Unable to read MASK"
msgstr " "
-#: ../vector/v.kernel/main.c:403
+#: ../vector/v.kernel/main.c:390
#, c-format
msgid "Maximum value in output: %e."
msgstr ""
@@ -16700,31 +16958,31 @@
#: ../vector/v.sample/main.c:123
#, fuzzy
-msgid "Cubic convolution interpolation [default is nearest neighbor]"
+msgid "Cubic convolution interpolation (default is nearest neighbor)"
msgstr " "
-#: ../vector/v.sample/main.c:142
+#: ../vector/v.sample/main.c:137
#, fuzzy
msgid "Flags -b & -c are mutually exclusive. Choose only one."
msgstr " ."
-#: ../vector/v.sample/main.c:178
+#: ../vector/v.sample/main.c:173
#, fuzzy, c-format
msgid "Column type <%s> not supported (must be integer or double precision)"
msgstr " "
-#: ../vector/v.sample/main.c:183 ../vector/v.surf.idw/read_sites.c:51
+#: ../vector/v.sample/main.c:178 ../vector/v.surf.idw/read_sites.c:51
#: ../vector/v.normal/main.c:151 ../vector/v.to.db/report.c:165
#, c-format
msgid "%d records selected from table"
msgstr ""
-#: ../vector/v.sample/main.c:210 ../vector/v.patch/main.c:298
+#: ../vector/v.sample/main.c:205 ../vector/v.patch/main.c:298
#, fuzzy, c-format
msgid "Unable to create table <%s>"
msgstr " "
-#: ../vector/v.sample/main.c:219
+#: ../vector/v.sample/main.c:213
#, fuzzy
msgid "Checking vector points..."
msgstr "×ÅËÔÏÒ."
@@ -16734,12 +16992,12 @@
msgid "Look ahead parameter must be odd"
msgstr ""
-#: ../vector/v.generalize/smoothing.c:455
+#: ../vector/v.generalize/smoothing.c:458
#, fuzzy
msgid "Unable to find the inverse matrix"
msgstr "×ÅËÔÏÒ "
-#: ../vector/v.generalize/smoothing.c:462
+#: ../vector/v.generalize/smoothing.c:465
#, fuzzy
msgid "Unable to calculate the output vectors"
msgstr " "
@@ -17183,11 +17441,6 @@
msgid "Vector map <%s> already exists and will be overwritten"
msgstr "×ÅËÔÏÒ ."
-#: ../vector/v.in.ogr/main.c:323
-#, fuzzy, c-format
-msgid "Vector map <%s> already exists"
-msgstr "ïûéâëá "
#: ../vector/v.in.ogr/main.c:362
msgid "Select either the current region flag or the spatial option, not both"
msgstr ""
@@ -17311,9 +17564,9 @@
msgid "Remove bridges:"
msgstr ""
-#: ../vector/v.in.ogr/main.c:907 ../vector/v.category/main.c:235
-#: ../vector/v.overlay/area_area.c:71 ../vector/v.voronoi/dt_main.c:122
-#: ../vector/v.buffer/main.c:624 ../vector/v.buffer/main.c:699
+#: ../vector/v.in.ogr/main.c:907 ../vector/v.overlay/area_area.c:71
+#: ../vector/v.voronoi/dt_main.c:137 ../vector/v.buffer/main.c:624
+#: ../vector/v.buffer/main.c:699
msgid "Cannot calculate area centroid"
msgstr ""
@@ -17730,37 +17983,37 @@
msgid "Cannot open %s"
msgstr "îÅ×ÏÚÍÏÖÎÏ ÏÔËÒÙÔØ %s"
-#: ../vector/v.qcount/main.c:69
+#: ../vector/v.qcount/main.c:68
msgid "Indices for quadrat counts of sites lists."
msgstr ""
-#: ../vector/v.qcount/main.c:75
+#: ../vector/v.qcount/main.c:74
#, fuzzy
msgid "Vector of points defining sample points"
msgstr " "
-#: ../vector/v.qcount/main.c:82
+#: ../vector/v.qcount/main.c:81
msgid "Output quadrant centres, number of points is written as category"
msgstr ""
-#: ../vector/v.qcount/main.c:89
+#: ../vector/v.qcount/main.c:88
msgid "Number of quadrats"
msgstr ""
-#: ../vector/v.qcount/main.c:96
+#: ../vector/v.qcount/main.c:95
msgid "Quadrat radius"
msgstr ""
-#: ../vector/v.qcount/main.c:101
+#: ../vector/v.qcount/main.c:100
msgid "Print results in shell script style"
msgstr ""
-#: ../vector/v.qcount/main.c:132
+#: ../vector/v.qcount/main.c:118
#, fuzzy
msgid "Finding quadrats..."
-#: ../vector/v.qcount/main.c:137
+#: ../vector/v.qcount/main.c:123
#, fuzzy
msgid "Counting sites in quadrats..."
@@ -17771,7 +18024,7 @@
msgstr ""
#: ../vector/v.out.pov/main.c:197 ../vector/v.out.dxf/main.c:192
-#: ../vector/v.out.ogr/main.c:589
+#: ../vector/v.out.ogr/main.c:595
#, fuzzy, c-format
msgid "%d features written"
msgstr "×ÅËÔÏÒ"
@@ -17978,81 +18231,82 @@
msgid "Writing out vector columns..."
msgstr " "
-#: ../vector/v.mkgrid/main.c:63
+#: ../vector/v.mkgrid/main.c:62
#, fuzzy
msgid "Creates a GRASS vector map of a user-defined grid."
msgstr "×ÅËÔÏÒ."
-#: ../vector/v.mkgrid/main.c:74
+#: ../vector/v.mkgrid/main.c:73
#, fuzzy
msgid "Number of rows and columns in grid"
msgstr " "
-#: ../vector/v.mkgrid/main.c:83
+#: ../vector/v.mkgrid/main.c:82
msgid "Where to place the grid"
msgstr ""
-#: ../vector/v.mkgrid/main.c:84
+#: ../vector/v.mkgrid/main.c:83
msgid "region;current region;coor;use 'coor' and 'box' options"
msgstr ""
-#: ../vector/v.mkgrid/main.c:93
+#: ../vector/v.mkgrid/main.c:92
#, fuzzy
msgid "Lower left easting and northing coordinates of map"
msgstr " "
-#: ../vector/v.mkgrid/main.c:101
+#: ../vector/v.mkgrid/main.c:100
msgid "Width and height of boxes in grid"
msgstr ""
-#: ../vector/v.mkgrid/main.c:107
+#: ../vector/v.mkgrid/main.c:106
msgid "Angle of rotation (in degrees counter-clockwise)"
msgstr ""
-#: ../vector/v.mkgrid/main.c:113
-msgid "Quiet; No chatter"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:165
+#: ../vector/v.mkgrid/main.c:150
#, fuzzy
msgid "'coor' option missing"
msgstr "ÏÔÓÕÔÓÔ×ÕÅÔ"
-#: ../vector/v.mkgrid/main.c:168
+#: ../vector/v.mkgrid/main.c:153
#, fuzzy
msgid "'box' option missing"
-#: ../vector/v.mkgrid/main.c:171
+#: ../vector/v.mkgrid/main.c:156
#, fuzzy
msgid "Invalid easting"
msgstr " "
-#: ../vector/v.mkgrid/main.c:173
+#: ../vector/v.mkgrid/main.c:158
#, fuzzy
msgid "Invalid northing"
msgstr " "
-#: ../vector/v.mkgrid/main.c:176 ../vector/v.mkgrid/main.c:178
+#: ../vector/v.mkgrid/main.c:161 ../vector/v.mkgrid/main.c:163
#, fuzzy
msgid "Invalid distance"
msgstr " "
-#: ../vector/v.mkgrid/main.c:232
+#: ../vector/v.mkgrid/main.c:217
#, fuzzy
msgid "Creating centroids..."
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.category/main.c:68
+#: ../vector/v.category/main.c:67
+#, fuzzy
+msgid "vector, category"
+msgstr "×ÅËÔÏÒ"
+#: ../vector/v.category/main.c:69
msgid "Attach, delete or report vector categories to map geometry."
msgstr ""
-#: ../vector/v.category/main.c:82
+#: ../vector/v.category/main.c:83
#, fuzzy
msgid "Action to be done"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.category/main.c:83
+#: ../vector/v.category/main.c:84
msgid ""
"add;add a new category;del;delete category;chlayer;change layer number (e.g. "
"layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat "
@@ -18061,43 +18315,61 @@
"in the same layer are separated by '/'"
msgstr ""
-#: ../vector/v.category/main.c:107
+#: ../vector/v.category/main.c:108
+msgid "Feature id(s)"
+msgstr ""
+#: ../vector/v.category/main.c:109
+msgid "By default all ids are processed"
+msgstr ""
+#: ../vector/v.category/main.c:114
msgid "Shell script style, currently only for report"
msgstr ""
-#: ../vector/v.category/main.c:108
+#: ../vector/v.category/main.c:115
msgid "Format: layer type count min max"
msgstr ""
-#: ../vector/v.category/main.c:126
+#: ../vector/v.category/main.c:133
msgid ""
"Database connection and attribute tables for concerned layers are not changed"
msgstr ""
-#: ../vector/v.category/main.c:177
+#: ../vector/v.category/main.c:156
+#, c-format
+msgid "%d errors in id option"
+msgstr ""
+#: ../vector/v.category/main.c:173
msgid "Too many layers for this operation"
msgstr ""
-#: ../vector/v.category/main.c:180
+#: ../vector/v.category/main.c:176
msgid "2 layers must be specified"
msgstr ""
-#: ../vector/v.category/main.c:184
+#: ../vector/v.category/main.c:180
#, fuzzy
msgid "Output vector wasn't entered"
msgstr "×ÅËÔÏÒ."
-#: ../vector/v.category/main.c:246
+#: ../vector/v.category/main.c:234
+#, fuzzy
+msgid "Unable to calculate area centroid"
+msgstr " "
+#: ../vector/v.category/main.c:245
#, fuzzy, c-format
msgid "%d new centroids placed in output map"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.category/main.c:389
+#: ../vector/v.category/main.c:398
#, fuzzy
-msgid "Layer / table"
+msgid "Layer/table"
msgstr " "
-#: ../vector/v.category/main.c:393
+#: ../vector/v.category/main.c:402
#, fuzzy
msgid "Layer"
msgstr " "
@@ -18452,7 +18724,7 @@
msgid "Collecting input attributes..."
msgstr " "
-#: ../vector/v.overlay/main.c:269 ../vector/v.label.sa/labels.c:161
+#: ../vector/v.overlay/main.c:269 ../vector/v.label.sa/labels.c:160
#: ../vector/v.label/main.c:312
#, fuzzy
msgid "Unable to select attributes"
@@ -18464,7 +18736,7 @@
msgstr " "
#: ../vector/v.overlay/main.c:330 ../vector/v.out.svg/main.c:359
-#: ../vector/v.out.ogr/main.c:637 ../vector/v.lrs/v.lrs.label/main.c:328
+#: ../vector/v.out.ogr/main.c:643 ../vector/v.lrs/v.lrs.label/main.c:328
#, fuzzy
msgid "Unable to fetch data from table"
msgstr " "
@@ -18564,50 +18836,51 @@
msgid "%d destination(s) unreachable (including points out of threshold)"
msgstr ""
-#: ../vector/v.label.sa/labels.c:69
+#: ../vector/v.label.sa/labels.c:68
#, c-format
msgid "Cannot allocate %d bytes of memory"
msgstr ""
-#: ../vector/v.label.sa/labels.c:87 ../display/d.text.freetype/main.c:326
+#: ../vector/v.label.sa/labels.c:86 ../display/d.text.freetype/main.c:326
msgid "Unable to initialise FreeType"
msgstr ""
-#: ../vector/v.label.sa/labels.c:90
+#: ../vector/v.label.sa/labels.c:89
#, fuzzy, c-format
msgid "Unable to find font '%s'\n"
msgstr " "
-#: ../vector/v.label.sa/labels.c:92
+#: ../vector/v.label.sa/labels.c:91
#, c-format
msgid "Font '%s' is not a FreeType font\n"
msgstr ""
-#: ../vector/v.label.sa/labels.c:95
+#: ../vector/v.label.sa/labels.c:94
msgid "Font file format is not supported by FreeType"
msgstr ""
-#: ../vector/v.label.sa/labels.c:97
+#: ../vector/v.label.sa/labels.c:96
#, fuzzy
msgid "Font file can not be loaded"
msgstr " "
-#: ../vector/v.label.sa/labels.c:106
+#: ../vector/v.label.sa/labels.c:105
#, fuzzy
msgid "Unable to set font size"
msgstr "ìÉÎÉÑ."
-#: ../vector/v.label.sa/labels.c:127
+#: ../vector/v.label.sa/labels.c:126
#, fuzzy
msgid "Cannot allocate more memory"
msgstr " "
-#: ../vector/v.label.sa/labels.c:140 ../vector/v.label/main.c:291
+#: ../vector/v.label.sa/labels.c:139 ../vector/v.label/main.c:291
+#: ../display/d.vect/plot1.c:285
#, fuzzy
msgid "Unable to read vector map"
msgstr " "
-#: ../vector/v.label.sa/labels.c:241
+#: ../vector/v.label.sa/labels.c:240
#, fuzzy, c-format
msgid "Cannot load glyph for '%c'"
msgstr " "
@@ -18620,85 +18893,73 @@
msgid "Create optimally placed labels for vector map(s)"
msgstr ""
-#: ../vector/v.label.sa/main.c:105 ../vector/v.label/main.c:79
+#: ../vector/v.label.sa/main.c:130 ../vector/v.label/main.c:79
msgid "Name of attribute column to be used for labels"
msgstr ""
-#: ../vector/v.label.sa/main.c:109 ../vector/v.label/main.c:69
+#: ../vector/v.label.sa/main.c:134 ../vector/v.label/main.c:69
msgid "Name for new paint-label file"
msgstr ""
-#: ../vector/v.label.sa/main.c:118
+#: ../vector/v.label.sa/main.c:143
msgid "Name of TrueType font (as listed in the fontcap)"
msgstr ""
-#: ../vector/v.label.sa/main.c:119 ../vector/v.label.sa/main.c:127
+#: ../vector/v.label.sa/main.c:144 ../vector/v.label.sa/main.c:152
#: ../vector/v.label/main.c:126 ../vector/v.label/main.c:133
#: ../vector/v.label/main.c:140 ../vector/v.label/main.c:148
#: ../vector/v.lrs/v.lrs.label/main.c:175
msgid "Font"
msgstr ""
-#: ../vector/v.label.sa/main.c:124 ../vector/v.label/main.c:130
+#: ../vector/v.label.sa/main.c:149 ../vector/v.label/main.c:130
#: ../vector/v.lrs/v.lrs.label/main.c:181
msgid "Label size (in map-units)"
msgstr ""
-#: ../vector/v.label.sa/main.c:131
+#: ../vector/v.label.sa/main.c:156
msgid "Icon size of point features (in map-units)"
msgstr ""
-#: ../vector/v.label.sa/main.c:145 ../vector/v.label/main.c:151
+#: ../vector/v.label.sa/main.c:170 ../vector/v.label/main.c:151
#: ../vector/v.lrs/v.lrs.label/main.c:188 ../display/d.grid/main.c:84
msgid "Text color"
msgstr ""
-#: ../vector/v.label.sa/main.c:150 ../vector/v.label.sa/main.c:159
-#: ../vector/v.label.sa/main.c:166 ../vector/v.label.sa/main.c:175
-#: ../vector/v.label.sa/main.c:185 ../vector/v.label.sa/main.c:194
-#: ../vector/v.label.sa/main.c:201 ../vector/v.label/main.c:152
-#: ../vector/v.label/main.c:176 ../vector/v.label/main.c:189
-#: ../vector/v.label/main.c:195 ../vector/v.label/main.c:205
-#: ../display/d.vect/main.c:206 ../display/d.vect/main.c:214
-#: ../display/d.vect/main.c:222 ../display/d.vect/main.c:324
-#: ../display/d.vect/main.c:330
-msgid "Colors"
-msgstr ""
-#: ../vector/v.label.sa/main.c:154
+#: ../vector/v.label.sa/main.c:179
msgid "Hilight color for text"
msgstr ""
-#: ../vector/v.label.sa/main.c:163 ../vector/v.label/main.c:180
+#: ../vector/v.label.sa/main.c:188 ../vector/v.label/main.c:180
msgid "Width of highlight coloring"
msgstr ""
-#: ../vector/v.label.sa/main.c:170 ../vector/v.label/main.c:187
+#: ../vector/v.label.sa/main.c:195 ../vector/v.label/main.c:187
#: ../vector/v.lrs/v.lrs.label/main.c:221 ../display/d.path/main.c:114
#: ../general/g.pnmcomp/main.c:356
msgid "Background color"
msgstr ""
-#: ../vector/v.label.sa/main.c:180 ../vector/v.label/main.c:200
+#: ../vector/v.label.sa/main.c:205 ../vector/v.label/main.c:200
#, fuzzy
msgid "Opaque to vector (only relevant if background color is selected)"
msgstr "×ÅËÔÏÒ "
-#: ../vector/v.label.sa/main.c:189 ../vector/v.label/main.c:193
+#: ../vector/v.label.sa/main.c:214 ../vector/v.label/main.c:193
#: ../vector/v.lrs/v.lrs.label/main.c:229 ../display/d.grid/main.c:79
msgid "Border color"
msgstr ""
-#: ../vector/v.label.sa/main.c:198
+#: ../vector/v.label.sa/main.c:223
msgid "Border width (only for ps.map output)"
msgstr ""
-#: ../vector/v.label.sa/font.c:53
+#: ../vector/v.label.sa/font.c:55
#, fuzzy, c-format
msgid "%s: Unable to read font definition file; use the default"
msgstr " "
-#: ../vector/v.label.sa/font.c:59
+#: ../vector/v.label.sa/font.c:61
#, fuzzy, c-format
msgid "%s: No font definition file"
msgstr " "
@@ -18708,198 +18969,203 @@
msgid "Toolset for cleaning topology of vector map."
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.clean/main.c:53
+#: ../vector/v.clean/main.c:54
#, fuzzy
msgid "Name of output map where errors are written"
msgstr " "
-#: ../vector/v.clean/main.c:63
+#: ../vector/v.clean/main.c:64
msgid "Cleaning tool"
msgstr ""
-#: ../vector/v.clean/main.c:65
+#: ../vector/v.clean/main.c:66
msgid ""
-"break;break lines at each intersection;rmdupl;remove duplicate lines (pay "
-"attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;"
-"chdangle;change the type of boundary dangle to line, threshold ignored if < "
-"0, input line type is ignored;rmbridge;remove bridges connecting area and "
-"island or 2 islands;chbridge;change the type of bridges connecting area and "
-"island or 2 islands from boundary to line;snap;snap lines to vertex in "
-"threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;"
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different;prune;remove vertices "
-"in threshold from lines and boundaries, boundary is pruned only if topology "
-"is not damaged (new intersection, changed attachement of centroid), first "
-"and last segment of the boundary is never changed;rmarea;remove small areas, "
-"the longest boundary with adjacent area is removed;rmline;remove all lines "
-"or boundaries of zero length, threshold is ignored;rmsa;remove small angles "
-"between lines at nodes"
+"break;break lines at each intersection;rmdupl;remove duplicate geometry "
+"features (pay attention to categories!);rmdangle;remove dangles, threshold "
+"ignored if < 0;chdangle;change the type of boundary dangle to line, "
+"threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges "
+"connecting area and island or 2 islands;chbridge;change the type of bridges "
+"connecting area and island or 2 islands from boundary to line;snap;snap "
+"lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' "
+"option ignored);bpol;break (topologically clean) polygons (imported from non "
+"topological format, like ShapeFile). Boundaries are broken on each point "
+"shared between 2 and more polygons where angles of segments are different;"
+"prune;remove vertices in threshold from lines and boundaries, boundary is "
+"pruned only if topology is not damaged (new intersection, changed "
+"attachement of centroid), first and last segment of the boundary is never "
+"changed;rmarea;remove small areas, the longest boundary with adjacent area "
+"is removed;rmline;remove all lines or boundaries of zero length, threshold "
+"is ignored;rmsa;remove small angles between lines at nodes"
msgstr ""
-#: ../vector/v.clean/main.c:92
+#: ../vector/v.clean/main.c:93
msgid ""
"Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
msgstr ""
-#: ../vector/v.clean/main.c:97
+#: ../vector/v.clean/main.c:98
#, fuzzy
msgid "Don't build topology for the output vector"
msgstr " ×ÅËÔÏÒ"
-#: ../vector/v.clean/main.c:115
+#: ../vector/v.clean/main.c:116
msgid "You must select at least one tool"
msgstr ""
-#: ../vector/v.clean/main.c:150
+#: ../vector/v.clean/main.c:151
msgid "Tool doesn't exist"
msgstr ""
-#: ../vector/v.clean/main.c:167
+#: ../vector/v.clean/main.c:168
#, c-format
msgid "Threshold for tool %d may not be > 0, set to 0"
msgstr ""
-#: ../vector/v.clean/main.c:175
+#: ../vector/v.clean/main.c:176
msgid "Tool: Threshold"
msgstr ""
-#: ../vector/v.clean/main.c:180
+#: ../vector/v.clean/main.c:181
msgid "Break"
msgstr ""
-#: ../vector/v.clean/main.c:183
+#: ../vector/v.clean/main.c:184
#, fuzzy
msgid "Remove duplicates"
msgstr " "
-#: ../vector/v.clean/main.c:186
+#: ../vector/v.clean/main.c:187
msgid "Remove dangles"
msgstr ""
-#: ../vector/v.clean/main.c:189
+#: ../vector/v.clean/main.c:190
msgid "Change type of boundary dangles"
msgstr ""
-#: ../vector/v.clean/main.c:192
+#: ../vector/v.clean/main.c:193
msgid "Remove bridges"
msgstr ""
-#: ../vector/v.clean/main.c:195
+#: ../vector/v.clean/main.c:196
msgid "Change type of boundary bridges"
msgstr ""
-#: ../vector/v.clean/main.c:198
+#: ../vector/v.clean/main.c:199
#, fuzzy
msgid "Snap vertices"
msgstr " ."
-#: ../vector/v.clean/main.c:201
+#: ../vector/v.clean/main.c:202
msgid "Remove duplicate area centroids"
msgstr ""
-#: ../vector/v.clean/main.c:204
+#: ../vector/v.clean/main.c:205
msgid "Break polygons"
msgstr ""
-#: ../vector/v.clean/main.c:207
+#: ../vector/v.clean/main.c:208
msgid "Prune"
msgstr ""
-#: ../vector/v.clean/main.c:210
+#: ../vector/v.clean/main.c:211
msgid "Remove small areas"
msgstr ""
-#: ../vector/v.clean/main.c:213
+#: ../vector/v.clean/main.c:214
msgid "Remove small angles at nodes"
msgstr ""
-#: ../vector/v.clean/main.c:216
+#: ../vector/v.clean/main.c:217
msgid "Remove all lines or boundaries of zero length"
msgstr ""
-#: ../vector/v.clean/main.c:256
+#: ../vector/v.clean/main.c:257
#, fuzzy
msgid "Copying vector lines..."
msgstr "×ÅËÔÏÒ."
-#: ../vector/v.clean/main.c:280 ../vector/v.clean/main.c:288
+#: ../vector/v.clean/main.c:281 ../vector/v.clean/main.c:289
#, fuzzy
msgid "Rebuilding parts of topology..."
msgstr " ."
-#: ../vector/v.clean/main.c:296
+#: ../vector/v.clean/main.c:297
msgid "Tool: Break lines at intersections"
msgstr ""
-#: ../vector/v.clean/main.c:300
+#: ../vector/v.clean/main.c:301
msgid "Tool: Remove duplicates"
msgstr ""
-#: ../vector/v.clean/main.c:304
+#: ../vector/v.clean/main.c:305
msgid "Tool: Remove dangles"
msgstr ""
-#: ../vector/v.clean/main.c:308
+#: ../vector/v.clean/main.c:309
msgid "Tool: Change type of boundary dangles"
msgstr ""
-#: ../vector/v.clean/main.c:312
+#: ../vector/v.clean/main.c:313
msgid "Tool: Remove bridges"
msgstr ""
-#: ../vector/v.clean/main.c:316
+#: ../vector/v.clean/main.c:317
msgid "Tool: Change type of boundary bridges"
msgstr ""
-#: ../vector/v.clean/main.c:320
+#: ../vector/v.clean/main.c:321
msgid "Tool: Remove duplicate area centroids"
msgstr ""
-#: ../vector/v.clean/main.c:324
+#: ../vector/v.clean/main.c:325
msgid "Tool: Snap line to vertex in threshold"
msgstr ""
-#: ../vector/v.clean/main.c:328
+#: ../vector/v.clean/main.c:329
msgid "Tool: Break polygons"
msgstr ""
-#: ../vector/v.clean/main.c:332
+#: ../vector/v.clean/main.c:333
msgid "Tool: Prune lines/boundaries"
msgstr ""
-#: ../vector/v.clean/main.c:336
+#: ../vector/v.clean/main.c:337
msgid "Tool: Remove small areas"
msgstr ""
-#: ../vector/v.clean/main.c:338
+#: ../vector/v.clean/main.c:339
#, c-format
msgid "%d areas of total size %g removed"
msgstr ""
-#: ../vector/v.clean/main.c:341
+#: ../vector/v.clean/main.c:342
msgid "Tool: Remove small angles at nodes"
msgstr ""
-#: ../vector/v.clean/main.c:343
+#: ../vector/v.clean/main.c:344
#, c-format
msgid "%d modifications done"
msgstr ""
-#: ../vector/v.clean/main.c:346
+#: ../vector/v.clean/main.c:347
msgid "Tool: Remove all lines and boundaries of zero length"
msgstr ""
-#: ../vector/v.clean/main.c:348
+#: ../vector/v.clean/main.c:349
#, fuzzy, c-format
msgid "%d lines / boundaries removed"
msgstr " "
-#: ../vector/v.clean/main.c:356
+#: ../vector/v.clean/main.c:357
#, fuzzy
msgid "Rebuilding topology for output vector map..."
msgstr " ."
+#: ../vector/v.clean/main.c:367
+#, fuzzy
+msgid "Building topology for error vector map..."
+msgstr " ."
#: ../vector/v.clean/rmdac.c:39
#, c-format
msgid "Duplicate area centroids: %5d"
@@ -19093,22 +19359,27 @@
msgid "Doing log transformation"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.voronoi/dt_main.c:45
+#: ../vector/v.voronoi/dt_main.c:47
#, fuzzy
msgid ""
"Creates a Delaunay triangulation from an input vector map containing points "
"or centroids."
msgstr "×ÅËÔÏÒ."
-#: ../vector/v.voronoi/dt_main.c:53
+#: ../vector/v.voronoi/dt_main.c:55
#, fuzzy
msgid "Use only points in current region"
msgstr " "
-#: ../vector/v.voronoi/dt_main.c:58
+#: ../vector/v.voronoi/dt_main.c:60
msgid "Output triangulation as a graph (lines), not areas"
msgstr ""
+#: ../vector/v.voronoi/dt_main.c:144
+#, fuzzy
+msgid "Cannot calculate area centroid z coordinate"
+msgstr " "
#: ../vector/v.voronoi/vo_main.c:108
#, fuzzy
msgid ""
@@ -19298,31 +19569,41 @@
msgid "Unknown input format, skipping: '%s'"
msgstr " "
-#: ../vector/v.hull/main.c:234
+#: ../vector/v.hull/main.c:272
msgid "Uses a GRASS vector points map to produce a convex hull vector map."
msgstr ""
-#: ../vector/v.hull/main.c:237
+#: ../vector/v.hull/main.c:275
#, fuzzy
msgid "Name of input vector points map"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.hull/main.c:240
+#: ../vector/v.hull/main.c:278
#, fuzzy
msgid "Name of output vector area map"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.hull/main.c:244
+#: ../vector/v.hull/main.c:282
#, fuzzy
msgid "Use all vector points (do not limit to current region)"
msgstr "×ÅËÔÏÒ ."
-#: ../vector/v.hull/main.c:266
+#: ../vector/v.hull/main.c:286
+msgid "Create a 'flat' 2D hull even if the input is 3D points"
+msgstr ""
+#: ../vector/v.hull/main.c:302 ../vector/v.hull/main.c:327
+#: ../vector/v.hull/main.c:331
#, fuzzy, c-format
+msgid "Cannot open vector map <%s>"
+msgstr "×ÅËÔÏÒ."
+#: ../vector/v.hull/main.c:308
+#, fuzzy, c-format
msgid "Error loading vector points map <%s>"
msgstr "×ÅËÔÏÒ."
-#: ../vector/v.hull/main.c:269
+#: ../vector/v.hull/main.c:311
msgid "Convex hull calculation requires at least three points"
msgstr ""
@@ -19700,7 +19981,7 @@
#: ../vector/v.label/main.c:91 ../vector/v.label/main.c:96
#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
-#: ../general/g.region/cmd/main.c:147 ../general/g.region/cmd/main.c:344
+#: ../general/g.region/main.c:146 ../general/g.region/main.c:346
msgid "Effects"
msgstr ""
@@ -19725,7 +20006,7 @@
msgid "Reference position"
msgstr ""
-#: ../vector/v.label/main.c:123 ../display/d.vect/main.c:268
+#: ../vector/v.label/main.c:123 ../display/d.vect/main.c:275
#: ../display/d.text.freetype/main.c:170 ../display/d.text.new/main.c:212
msgid "Font name"
msgstr ""
@@ -19751,7 +20032,7 @@
msgid "Highlight color for text"
msgstr ""
-#: ../vector/v.label/main.c:232 ../imagery/i.class/main.c:85
+#: ../vector/v.label/main.c:232 ../imagery/i.class/main.c:87
#: ../imagery/i.points/main.c:79
#: ../imagery/i.ortho.photo/photo.2target/main.c:89
#: ../display/d.histogram/main.c:175 ../display/d.erase/main.c:57
@@ -19759,9 +20040,9 @@
#: ../display/d.what.vect/main.c:160 ../display/d.font/main.c:81
#: ../display/d.rast.num/number.c:129 ../display/d.linegraph/linegraph.c:256
#: ../display/d.what.rast/main.c:110 ../display/d.text/main.c:131
-#: ../display/d.font.freetype/main.c:101 ../display/d.info/main.c:68
+#: ../display/d.font.freetype/main.c:101 ../display/d.info/main.c:72
#: ../display/d.legend/main.c:271 ../display/d.graph/main.c:95
-#: ../display/d.vect/main.c:376 ../display/d.vect.chart/main.c:237
+#: ../display/d.vect/main.c:385 ../display/d.vect.chart/main.c:243
#: ../display/d.rast.arrow/arrow.c:246 ../display/d.menu/main.c:107
#: ../display/d.text.freetype/main.c:309 ../display/d.rast/main.c:114
#: ../display/d.extract/main.c:77 ../display/d.rgb/main.c:87
@@ -19769,11 +20050,11 @@
#: ../display/d.barscale/main.c:136 ../display/d.text.new/main.c:285
#: ../display/d.his/main.c:117 ../display/d.zoom/main.c:162
#: ../display/d.zoom/main.c:311 ../display/d.zoom/redraw.c:45
-#: ../display/d.grid/main.c:165 ../display/d.nviz/main.c:247
+#: ../display/d.grid/main.c:181 ../display/d.nviz/main.c:247
#: ../display/d.extend/main.c:42 ../display/d.frame/select.c:36
#: ../display/d.frame/frame.c:130 ../display/d.frame/frame.c:189
#: ../display/d.frame/frame.c:230 ../display/d.frame/list.c:24
-#: ../display/d.path/main.c:158
+#: ../display/d.path/main.c:158 ../display/d.thematic.area/main.c:314
msgid "No graphics device selected"
msgstr ""
@@ -19924,7 +20205,7 @@
msgstr " ×ÅËÔÏÒ"
#: ../vector/v.surf.rst/main.c:404 ../vector/v.extract/main.c:212
-#: ../display/d.vect/main.c:463
+#: ../display/d.vect/main.c:472
msgid "'layer' must be > 0 for 'where'."
msgstr ""
@@ -20290,167 +20571,172 @@
"map <%s>. "
msgstr ""
-#: ../vector/v.out.ogr/main.c:87
+#: ../vector/v.out.ogr/main.c:88
#, fuzzy
msgid "Converts to one of the supported OGR vector formats."
msgstr "×ÅËÔÏÒ."
-#: ../vector/v.out.ogr/main.c:94
+#: ../vector/v.out.ogr/main.c:96
#, fuzzy
msgid "Feature type. Combination of types is not supported by all formats."
msgstr " ."
-#: ../vector/v.out.ogr/main.c:102
+#: ../vector/v.out.ogr/main.c:104
#, fuzzy
msgid "OGR output datasource name"
msgstr "óËÌÏÎÙ"
-#: ../vector/v.out.ogr/main.c:103
+#: ../vector/v.out.ogr/main.c:105
msgid "For example: ESRI Shapefile: filename or directory for storage"
msgstr ""
-#: ../vector/v.out.ogr/main.c:109
+#: ../vector/v.out.ogr/main.c:111
#, fuzzy
msgid "OGR layer name. If not specified, input name is used."
msgstr " "
-#: ../vector/v.out.ogr/main.c:110
+#: ../vector/v.out.ogr/main.c:112
#, fuzzy
msgid "For example: ESRI Shapefile: shapefile name"
msgstr " "
-#: ../vector/v.out.ogr/main.c:123
+#: ../vector/v.out.ogr/main.c:113 ../vector/v.out.ogr/main.c:126
+#: ../vector/v.out.ogr/main.c:136 ../vector/v.out.ogr/main.c:146
+msgid "Creation"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:125
msgid "OGR format"
msgstr ""
-#: ../vector/v.out.ogr/main.c:132
+#: ../vector/v.out.ogr/main.c:135
msgid "OGR dataset creation option (format specific, NAME=VALUE)"
msgstr ""
-#: ../vector/v.out.ogr/main.c:141
+#: ../vector/v.out.ogr/main.c:145
msgid "OGR layer creation option (format specific, NAME=VALUE)"
msgstr ""
-#: ../vector/v.out.ogr/main.c:146
+#: ../vector/v.out.ogr/main.c:150
#, fuzzy
msgid ""
"Export features with category (labeled) only. Otherwise all features are "
"exported"
msgstr " "
-#: ../vector/v.out.ogr/main.c:151
+#: ../vector/v.out.ogr/main.c:155
msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
msgstr ""
-#: ../vector/v.out.ogr/main.c:156
+#: ../vector/v.out.ogr/main.c:160
msgid "Export lines as polygons"
msgstr ""
-#: ../vector/v.out.ogr/main.c:183
+#: ../vector/v.out.ogr/main.c:189
#, fuzzy
msgid "The combination of types is not supported by all formats."
msgstr " ."
-#: ../vector/v.out.ogr/main.c:230
+#: ../vector/v.out.ogr/main.c:236
#, fuzzy, c-format
msgid "OGR driver <%s> not found"
msgstr " "
-#: ../vector/v.out.ogr/main.c:246
+#: ../vector/v.out.ogr/main.c:252
#, fuzzy, c-format
msgid "Unable to open OGR data source '%s'"
msgstr " "
-#: ../vector/v.out.ogr/main.c:265 ../vector/v.out.ogr/main.c:272
+#: ../vector/v.out.ogr/main.c:271 ../vector/v.out.ogr/main.c:278
#, c-format
msgid ""
"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
"'lco') to export in 3D rather than 2D (default)"
msgstr ""
-#: ../vector/v.out.ogr/main.c:281
+#: ../vector/v.out.ogr/main.c:287
#, fuzzy
msgid "Unable to create OGR layer"
msgstr " "
-#: ../vector/v.out.ogr/main.c:290
+#: ../vector/v.out.ogr/main.c:296
msgid "No attribute table found -> using only category numbers as attributes"
msgstr ""
-#: ../vector/v.out.ogr/main.c:344
+#: ../vector/v.out.ogr/main.c:350
#, fuzzy, c-format
msgid "Key column '%s' not found"
msgstr " "
-#: ../vector/v.out.ogr/main.c:356
+#: ../vector/v.out.ogr/main.c:362
#, fuzzy, c-format
msgid ""
"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
msgstr " ."
-#: ../vector/v.out.ogr/main.c:360
+#: ../vector/v.out.ogr/main.c:366
#, fuzzy, c-format
msgid ""
"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
msgstr "ìÉÎÉÑ ."
-#: ../vector/v.out.ogr/main.c:364
+#: ../vector/v.out.ogr/main.c:370
#, fuzzy, c-format
msgid ""
"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
"parameter."
msgstr " ."
-#: ../vector/v.out.ogr/main.c:368
+#: ../vector/v.out.ogr/main.c:374
#, fuzzy, c-format
msgid ""
"%d centroid(s) found, but not requested to be exported. Verify 'type' "
"parameter."
msgstr " ."
-#: ../vector/v.out.ogr/main.c:372
+#: ../vector/v.out.ogr/main.c:378
#, fuzzy, c-format
msgid ""
"%d areas found, but not requested to be exported. Verify 'type' parameter."
msgstr "ìÉÎÉÑ ."
-#: ../vector/v.out.ogr/main.c:376
+#: ../vector/v.out.ogr/main.c:382
#, fuzzy, c-format
msgid ""
"%d faces found, but not requested to be exported. Verify 'type' parameter."
msgstr "ìÉÎÉÑ ."
-#: ../vector/v.out.ogr/main.c:383
+#: ../vector/v.out.ogr/main.c:389
#, fuzzy, c-format
msgid "Exporting %i points/lines..."
msgstr " "
-#: ../vector/v.out.ogr/main.c:458
+#: ../vector/v.out.ogr/main.c:464
#, c-format
msgid "Exporting %i areas (may take some time)..."
msgstr ""
-#: ../vector/v.out.ogr/main.c:523
+#: ../vector/v.out.ogr/main.c:529
#, c-format
msgid "Exporting %i faces (may take some time) ..."
msgstr ""
-#: ../vector/v.out.ogr/main.c:590
+#: ../vector/v.out.ogr/main.c:596
#, fuzzy, c-format
msgid "%d features without category written"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.out.ogr/main.c:591
+#: ../vector/v.out.ogr/main.c:597
#, fuzzy, c-format
msgid "%d features without attributes written"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.out.ogr/main.c:592
+#: ../vector/v.out.ogr/main.c:598
#, fuzzy, c-format
msgid "%d features found without category skip"
msgstr "×ÅËÔÏÒ"
-#: ../vector/v.out.ogr/main.c:635
+#: ../vector/v.out.ogr/main.c:641
#, c-format
msgid "Cannot select attributes for cat = %d"
msgstr ""
@@ -21245,6 +21531,80 @@
msgid "Removing duplicate centroids..."
msgstr " "
+#: ../vector/v.class/main.c:47
+msgid "Classifies attribute data, e.g. for thematic mapping"
+msgstr ""
+#: ../vector/v.class/main.c:58
+msgid "Column name or expression"
+msgstr ""
+#: ../vector/v.class/main.c:68
+msgid "Algorithm to use for classification"
+msgstr ""
+#: ../vector/v.class/main.c:69
+msgid ""
+"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
+"(normal distribution);dis;discontinuities"
+msgstr ""
+#: ../vector/v.class/main.c:80
+#, fuzzy
+msgid "Number of classes to define"
+msgstr " "
+#: ../vector/v.class/main.c:85
+msgid "Print only class breaks (without min and max)"
+msgstr ""
+#: ../vector/v.class/main.c:167
+#, c-format
+msgid "%s: Error in classification algorithm"
+msgstr ""
+#: ../vector/v.class/main.c:194
+#, c-format
+msgid ""
+"\n"
+"Classification of %s into %i classes\n"
+msgstr ""
+#: ../vector/v.class/main.c:196
+#, c-format
+msgid "Using algorithm: *** %s ***\n"
+msgstr ""
+#: ../vector/v.class/main.c:197
+#, fuzzy, c-format
+msgid "Mean: %f\tStandard deviation = %f\n"
+msgstr " "
+#: ../vector/v.class/main.c:201
+#, c-format
+msgid "Last chi2 = %f\n"
+msgstr ""
+#: ../vector/v.class/main.c:203
+#, c-format
+msgid "Stdev multiplied by %.4f to define step\n"
+msgstr ""
+#: ../vector/v.class/main.c:205
+#, c-format
+msgid ""
+"%15s%15s%15s\n"
+"\n"
+msgstr ""
+#: ../vector/v.class/main.c:217
+#, c-format
+msgid ""
+"\n"
+"Note: Minimum of first class is including\n"
+"\n"
+msgstr ""
#: ../doc/raster/r.example/main.c:84
msgid "raster, keyword2, keyword3"
msgstr ""
@@ -21258,11 +21618,6 @@
msgid "Unable to read file header of <%s>"
msgstr " "
-#: ../doc/raster/r.example/main.c:179
-#, fuzzy, c-format
-msgid "Failed writing raster map <%s>"
-msgstr " "
#: ../doc/vector/v.example/main.c:43
msgid "vector, keyword2, keyword3"
msgstr ""
@@ -21601,16 +21956,16 @@
msgstr ""
#: ../imagery/i.ifft/ifftmain.c:53 ../imagery/i.gensigset/main.c:39
-#: ../imagery/i.his.rgb/h2rmain.c:44 ../imagery/i.group/main.c:49
+#: ../imagery/i.his.rgb/h2rmain.c:44 ../imagery/i.group/main.c:50
#: ../imagery/i.rgb.his/r2hmain.c:44 ../imagery/i.smap/shapiro/main.c:37
#: ../imagery/i.vpoints/main.c:53 ../imagery/i.pca/main.c:61
-#: ../imagery/i.class/main.c:50 ../imagery/i.rectify/main.c:55
+#: ../imagery/i.class/main.c:52 ../imagery/i.rectify/main.c:55
#: ../imagery/i.gensig/main.c:38 ../imagery/i.points/main.c:52
#: ../imagery/i.zc/main.c:56 ../imagery/i.fft/fftmain.c:73
#: ../imagery/i.cluster/main.c:57
#: ../imagery/i.ortho.photo/photo.2target/main.c:45
#: ../imagery/i.ortho.photo/menu/menu.c:42 ../imagery/i.maxlik/main.c:50
-#: ../imagery/i.cca/main.c:83 ../imagery/i.target/main.c:43
+#: ../imagery/i.cca/main.c:83 ../imagery/i.target/main.c:44
msgid "imagery"
msgstr ""
@@ -21748,103 +22103,114 @@
msgid "Unable to allocate the input row buffer"
msgstr " "
-#: ../imagery/i.group/main.c:51
+#: ../imagery/i.group/main.c:52
msgid "Creates, edits, and lists groups and subgroups of imagery files."
msgstr ""
-#: ../imagery/i.group/main.c:55 ../imagery/i.rectify/main.c:66
+#: ../imagery/i.group/main.c:56 ../imagery/i.rectify/main.c:66
#: ../imagery/i.ortho.photo/photo.2target/main.c:54
#: ../general/g.transform/main.c:245
msgid "Name of imagery group"
msgstr ""
-#: ../imagery/i.group/main.c:61
+#: ../imagery/i.group/main.c:62
msgid "Name of imagery sub-group"
msgstr ""
-#: ../imagery/i.group/main.c:65
+#: ../imagery/i.group/main.c:66
#, fuzzy
msgid "Name of raster map(s) to include in group"
msgstr " "
-#: ../imagery/i.group/main.c:69
+#: ../imagery/i.group/main.c:70
msgid "Remove selected files from specified group"
msgstr ""
-#: ../imagery/i.group/main.c:73
+#: ../imagery/i.group/main.c:74
msgid "List files from specified (sub)group (fancy)"
msgstr ""
-#: ../imagery/i.group/main.c:78
+#: ../imagery/i.group/main.c:79
msgid "List files from specified (sub)group (shell script style)"
msgstr ""
-#: ../imagery/i.group/main.c:98
+#: ../imagery/i.group/main.c:99
#, fuzzy
msgid "No input raster map(s) specified"
msgstr " ."
-#: ../imagery/i.group/main.c:106 ../imagery/i.group/main.c:125
+#: ../imagery/i.group/main.c:110 ../imagery/i.class/main.c:100
+#: ../imagery/i.target/main.c:78
#, fuzzy
-msgid "Specified group does not exist"
+msgid "Group must exist in the current mapset"
+msgstr "ïûéâëá "
+#: ../imagery/i.group/main.c:120
+#, fuzzy
+msgid "Specified group does not exist in current mapset"
msgstr " "
-#: ../imagery/i.group/main.c:110
+#: ../imagery/i.group/main.c:124
#, fuzzy, c-format
msgid "Removing raster maps from subgroup <%s>..."
msgstr " ."
-#: ../imagery/i.group/main.c:114
+#: ../imagery/i.group/main.c:128
#, fuzzy, c-format
msgid "Removing raster maps from group <%s>..."
msgstr " ."
-#: ../imagery/i.group/main.c:148
+#: ../imagery/i.group/main.c:139
+#, fuzzy
+msgid "Specified group does not exist"
+msgstr " "
+#: ../imagery/i.group/main.c:162
#, fuzzy, c-format
msgid "Group <%s> does not yet exist. Creating..."
msgstr " ."
-#: ../imagery/i.group/main.c:151 ../imagery/i.group/main.c:158
+#: ../imagery/i.group/main.c:165 ../imagery/i.group/main.c:172
#, fuzzy, c-format
msgid "Adding raster maps to group <%s>..."
msgstr " ."
-#: ../imagery/i.group/main.c:154
+#: ../imagery/i.group/main.c:168
#, fuzzy, c-format
msgid "Adding raster maps to subgroup <%s>..."
msgstr " ."
-#: ../imagery/i.group/main.c:183
+#: ../imagery/i.group/main.c:197
#, fuzzy, c-format
msgid "Adding raster map <%s> to group"
msgstr " "
-#: ../imagery/i.group/main.c:188
+#: ../imagery/i.group/main.c:202
#, fuzzy, c-format
msgid "Raster map <%s> exists in group. Skipping..."
msgstr " ."
-#: ../imagery/i.group/main.c:221
+#: ../imagery/i.group/main.c:235
#, fuzzy, c-format
msgid "Adding raster map <%s> to subgroup"
msgstr " "
-#: ../imagery/i.group/main.c:227
+#: ../imagery/i.group/main.c:241
#, fuzzy, c-format
msgid "Raster map <%s> exists in subgroup. Skipping..."
msgstr " ."
-#: ../imagery/i.group/main.c:273
+#: ../imagery/i.group/main.c:287
#, fuzzy, c-format
msgid "Removing raster map <%s> from group"
msgstr " "
-#: ../imagery/i.group/main.c:290 ../imagery/i.group/main.c:343
+#: ../imagery/i.group/main.c:304 ../imagery/i.group/main.c:357
#, fuzzy
msgid "No raster map removed"
msgstr "×ÅËÔÏÒ"
-#: ../imagery/i.group/main.c:326
+#: ../imagery/i.group/main.c:340
#, fuzzy, c-format
msgid "Removing raster map <%s> from subgroup"
msgstr " "
@@ -21981,6 +22347,10 @@
msgid "Use maximum likelihood estimation (instead of smap)"
msgstr ""
+#: ../imagery/i.smap/shapiro/parse.c:54 ../imagery/i.maxlik/main.c:86
+msgid "Run quietly"
+msgstr ""
#: ../imagery/i.smap/shapiro/parse.c:68
#, fuzzy, c-format
msgid "Group [%s] not found."
@@ -22002,7 +22372,7 @@
msgstr " ."
#: ../imagery/i.vpoints/plot.c:62 ../imagery/i.vpoints/plot.c:145
-#: ../display/d.graph/do_graph.c:426 ../display/d.vect/main.c:443
+#: ../display/d.graph/do_graph.c:426 ../display/d.vect/main.c:452
msgid "Cannot read symbol, cannot display points"
msgstr ""
@@ -22192,95 +22562,95 @@
msgid "Error reading raster map in function readbands."
msgstr ""
-#: ../imagery/i.class/main.c:52
+#: ../imagery/i.class/main.c:54
msgid ""
"Generates spectral signatures for an image by allowing the user to outline "
"regions of interest."
msgstr ""
-#: ../imagery/i.class/main.c:55
+#: ../imagery/i.class/main.c:57
msgid ""
"The resulting signature file can be used as input for i.maxlik or as a seed "
"signature file for i.cluster."
msgstr ""
-#: ../imagery/i.class/main.c:60
+#: ../imagery/i.class/main.c:62
#, fuzzy
msgid "Name of raster map to be displayed"
msgstr "üËÓÐÏÚÉÃÉÑ"
-#: ../imagery/i.class/main.c:67 ../imagery/i.cca/main.c:92
+#: ../imagery/i.class/main.c:69 ../imagery/i.cca/main.c:92
#, fuzzy
msgid "Name of input imagery subgroup"
msgstr "×ÅËÔÏÒ"
-#: ../imagery/i.class/main.c:72 ../imagery/i.cluster/main.c:77
+#: ../imagery/i.class/main.c:74 ../imagery/i.cluster/main.c:77
#, fuzzy
msgid "File to contain result signatures"
msgstr " "
-#: ../imagery/i.class/main.c:77
+#: ../imagery/i.class/main.c:79
#, fuzzy
msgid "File containing input signatures (seed)"
msgstr "îÁÂÏÒ ÄÁÎÎÙÈ ×ÅËÔÏÒ"
-#: ../imagery/i.class/main.c:89
+#: ../imagery/i.class/main.c:91
msgid "You have a mask set. Unset mask and run again"
msgstr ""
-#: ../imagery/i.class/main.c:193
+#: ../imagery/i.class/main.c:209
#, fuzzy, c-format
msgid "** The following raster maps in subgroup [%s] do not exist:"
msgstr " :"
-#: ../imagery/i.class/main.c:201
+#: ../imagery/i.class/main.c:217
#, fuzzy, c-format
msgid "Subgroup [%s] does not have any files"
msgstr " "
-#: ../imagery/i.class/main.c:202 ../imagery/i.class/main.c:205
+#: ../imagery/i.class/main.c:218 ../imagery/i.class/main.c:221
#, fuzzy
msgid "The subgroup must have at least 2 files to run"
msgstr " "
-#: ../imagery/i.class/main.c:204 ../imagery/i.cluster/open_files.c:45
+#: ../imagery/i.class/main.c:220 ../imagery/i.cluster/open_files.c:45
#, fuzzy, c-format
msgid "Subgroup [%s] only has 1 file"
msgstr " "
-#: ../imagery/i.class/main.c:209
+#: ../imagery/i.class/main.c:225
#, fuzzy
msgid "Unable to read cell header for first band file"
msgstr " !"
-#: ../imagery/i.class/main.c:214
+#: ../imagery/i.class/main.c:230
msgid ""
"\n"
"RESULT SIGNATURE"
msgstr ""
-#: ../imagery/i.class/main.c:217
+#: ../imagery/i.class/main.c:233
#, fuzzy, c-format
msgid "Unable to open output signature file '%s'"
msgstr " "
-#: ../imagery/i.class/main.c:223
+#: ../imagery/i.class/main.c:239
msgid ""
"\n"
"SEED SIGNATURES"
msgstr ""
-#: ../imagery/i.class/main.c:227
+#: ../imagery/i.class/main.c:243
#, fuzzy, c-format
msgid "Unable to read signature file [%s]"
msgstr " "
-#: ../imagery/i.class/main.c:230
+#: ../imagery/i.class/main.c:246
#, fuzzy, c-format
msgid "** Unable to read signature file [%s] **"
msgstr " "
-#: ../imagery/i.class/main.c:237
+#: ../imagery/i.class/main.c:253
#, fuzzy, c-format
msgid "%s has too many signatures"
msgstr " ."
@@ -23249,34 +23619,34 @@
msgid "Transform completed.\n"
msgstr ""
-#: ../imagery/i.target/main.c:45
+#: ../imagery/i.target/main.c:46
msgid "Targets an imagery group to a GRASS location and mapset."
msgstr ""
-#: ../imagery/i.target/main.c:53
+#: ../imagery/i.target/main.c:55
msgid "Name of imagery target location"
msgstr ""
-#: ../imagery/i.target/main.c:59
+#: ../imagery/i.target/main.c:61
msgid "Name of target mapset"
msgstr ""
-#: ../imagery/i.target/main.c:64
+#: ../imagery/i.target/main.c:66
msgid "Set current location and mapset as target for of imagery group"
msgstr ""
-#: ../imagery/i.target/main.c:73 ../imagery/i.target/main.c:90
-#: ../imagery/i.target/main.c:95
+#: ../imagery/i.target/main.c:88 ../imagery/i.target/main.c:105
+#: ../imagery/i.target/main.c:113
#, fuzzy, c-format
msgid "Group <%s> targeted for location [%s], mapset [%s]"
msgstr " "
-#: ../imagery/i.target/main.c:76
+#: ../imagery/i.target/main.c:91
#, fuzzy, c-format
msgid "Group <%s> has no target"
msgstr " "
-#: ../imagery/i.target/main.c:84
+#: ../imagery/i.target/main.c:99
#, fuzzy
msgid ""
"Use either the Current Mapset and Location Flag (-c)\n"
@@ -23374,70 +23744,84 @@
msgstr " "
#: ../visualization/nviz/src/nviz_init.c:56
-msgid "visualization"
-msgstr ""
+#, fuzzy
+msgid "raster, vector, visualization"
+msgstr " "
#: ../visualization/nviz/src/nviz_init.c:58
-msgid "nviz - Visualization and animation tool for GRASS data"
+msgid "nviz - Visualization and animation tool for GRASS data."
msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:66
+#: ../visualization/nviz/src/nviz_init.c:63
#, fuzzy
-msgid "Raster file(s) for Elevation"
+msgid "Name of raster map(s) for Elevation"
msgstr " "
-#: ../visualization/nviz/src/nviz_init.c:74
+#: ../visualization/nviz/src/nviz_init.c:64
+#: ../visualization/nviz/src/nviz_init.c:73
+#: ../visualization/nviz/src/nviz_init.c:100
+msgid "Raster"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:72
#, fuzzy
-msgid "Raster file(s) for Color"
+msgid "Name of raster map(s) for Color"
msgstr " "
+#: ../visualization/nviz/src/nviz_init.c:81
+#, fuzzy
+msgid "Name of vector lines/areas overlay map(s)"
+msgstr " "
#: ../visualization/nviz/src/nviz_init.c:82
-msgid "Vector lines/areas overlay file(s)"
+#: ../visualization/nviz/src/nviz_init.c:91
+msgid "Vector"
msgstr ""
#: ../visualization/nviz/src/nviz_init.c:90
-msgid "Vector points overlay file(s)"
-msgstr ""
+#, fuzzy
+msgid "Name of vector points overlay file(s)"
+msgstr "×ÅËÔÏÒ"
-#: ../visualization/nviz/src/nviz_init.c:98
+#: ../visualization/nviz/src/nviz_init.c:99
#, fuzzy
msgid "Name of existing 3d raster map"
msgstr "×ÅËÔÏÒ"
-#: ../visualization/nviz/src/nviz_init.c:102
+#: ../visualization/nviz/src/nviz_init.c:104
msgid "Quickstart - Do not load any data"
msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:106
+#: ../visualization/nviz/src/nviz_init.c:108
msgid "Script kill option"
msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:110
+#: ../visualization/nviz/src/nviz_init.c:112
msgid "Start in Demo mode"
msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:114
+#: ../visualization/nviz/src/nviz_init.c:116
msgid "Output more comments (default=quiet)"
msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:120
+#: ../visualization/nviz/src/nviz_init.c:122
msgid "Set alternative panel path"
msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:126
+#: ../visualization/nviz/src/nviz_init.c:128
msgid "Execute script file at startup"
msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:132
+#: ../visualization/nviz/src/nviz_init.c:134
msgid "Load previosly saved state file"
msgstr ""
-#: ../visualization/nviz/src/nviz_init.c:280
+#: ../visualization/nviz/src/nviz_init.c:282
msgid "Number of elevation files does not match number of colors files"
msgstr ""
#: ../display/d.rast.edit/cell.c:35 ../display/d.rast.num/number.c:173
-#: ../display/d.info/main.c:108 ../display/d.rast.arrow/arrow.c:258
+#: ../display/d.info/main.c:112 ../display/d.rast.arrow/arrow.c:258
#: ../display/d.paint.labels/main.c:127 ../display/d.barscale/main.c:158
msgid "Setting map window"
msgstr ""
@@ -23853,29 +24237,31 @@
msgstr ""
#: ../display/d.rast.num/number.c:163 ../display/d.text/main.c:151
-#: ../display/d.info/main.c:100 ../display/d.legend/main.c:274
-#: ../display/d.graph/main.c:116 ../display/d.rast.arrow/arrow.c:249
-#: ../display/d.text.freetype/main.c:315 ../display/d.paint.labels/main.c:121
-#: ../display/d.barscale/main.c:139 ../display/d.text.new/main.c:299
+#: ../display/d.info/main.c:104 ../display/d.info/main.c:129
+#: ../display/d.legend/main.c:274 ../display/d.graph/main.c:116
+#: ../display/d.rast.arrow/arrow.c:249 ../display/d.text.freetype/main.c:315
+#: ../display/d.paint.labels/main.c:121 ../display/d.barscale/main.c:139
+#: ../display/d.text.new/main.c:299
msgid "No current window"
msgstr ""
#: ../display/d.rast.num/number.c:166 ../display/d.text/main.c:154
-#: ../display/d.info/main.c:102 ../display/d.legend/main.c:277
-#: ../display/d.graph/main.c:119 ../display/d.rast.arrow/arrow.c:252
-#: ../display/d.text.freetype/main.c:317 ../display/d.paint.labels/main.c:124
-#: ../display/d.barscale/main.c:142 ../display/d.text.new/main.c:302
+#: ../display/d.info/main.c:106 ../display/d.info/main.c:131
+#: ../display/d.legend/main.c:277 ../display/d.graph/main.c:119
+#: ../display/d.rast.arrow/arrow.c:252 ../display/d.text.freetype/main.c:317
+#: ../display/d.paint.labels/main.c:124 ../display/d.barscale/main.c:142
+#: ../display/d.text.new/main.c:302
msgid "Current window not available"
msgstr ""
-#: ../display/d.rast.num/number.c:181 ../display/d.info/main.c:110
+#: ../display/d.rast.num/number.c:181 ../display/d.info/main.c:114
#: ../display/d.graph/main.c:122 ../display/d.rast.arrow/arrow.c:265
#: ../display/d.paint.labels/main.c:134 ../display/d.barscale/main.c:165
msgid "Getting screen window"
msgstr ""
#: ../display/d.rast.num/number.c:183 ../display/d.what.rast/main.c:131
-#: ../display/d.info/main.c:112 ../display/d.rast.arrow/arrow.c:267
+#: ../display/d.info/main.c:116 ../display/d.rast.arrow/arrow.c:267
#: ../display/d.paint.labels/main.c:136 ../display/d.barscale/main.c:167
msgid "Error in calculating conversions"
msgstr ""
@@ -24093,7 +24479,7 @@
#: ../display/d.text/main.c:146 ../display/d.graph/do_graph.c:112
#: ../display/d.graph/do_graph.c:404 ../display/d.graph/do_graph.c:419
#: ../display/d.graph/main.c:102 ../display/d.text.freetype/main.c:879
-#: ../display/d.paint.labels/color.c:57
+#: ../display/d.paint.labels/color.c:68
#, fuzzy, c-format
msgid "[%s]: No such color"
msgstr " "
@@ -24132,11 +24518,18 @@
msgstr ""
#: ../display/d.info/main.c:55
+msgid ""
+"Display screen rectangle coordinates and resolution (west, east, north, "
+"south, ewres, nsres)"
+msgstr ""
+#: ../display/d.info/main.c:59
msgid "Display number of colors"
msgstr ""
#: ../display/d.legend/main.c:86 ../display/d.graph/main.c:53
-#: ../display/d.barscale/main.c:55 ../display/d.grid/main.c:51
+#: ../display/d.vect.chart/main.c:62 ../display/d.barscale/main.c:55
+#: ../display/d.grid/main.c:51
msgid "display, cartography"
msgstr ""
@@ -24339,10 +24732,12 @@
msgstr "×ÅËÔÏÒ"
#: ../display/d.vect/plot1.c:210 ../display/d.vect/area.c:65
+#: ../display/d.thematic.area/plot1.c:206
msgid "Color definition column not specified."
msgstr ""
#: ../display/d.vect/plot1.c:220 ../display/d.vect/area.c:75
+#: ../display/d.thematic.area/plot1.c:216
#, fuzzy, c-format
msgid ""
"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
@@ -24351,159 +24746,169 @@
#: ../display/d.vect/plot1.c:224 ../display/d.vect/plot1.c:249
#: ../display/d.vect/area.c:80 ../display/d.vect/area.c:105
+#: ../display/d.thematic.area/plot1.c:221
+#: ../display/d.thematic.area/plot1.c:248
+#: ../display/d.thematic.area/main.c:230
#, fuzzy, c-format
msgid "Cannot select data (%s) from table"
msgstr " "
#: ../display/d.vect/plot1.c:236 ../display/d.vect/area.c:92
+#: ../display/d.thematic.area/plot1.c:233
#, fuzzy
msgid "Line width column not specified."
msgstr "ìÉÎÉÑ."
#: ../display/d.vect/plot1.c:246 ../display/d.vect/area.c:102
+#: ../display/d.thematic.area/plot1.c:244
#, fuzzy, c-format
msgid "Line width column (%s) not a number."
msgstr "ìÉÎÉÑ ."
-#: ../display/d.vect/plot1.c:285 ../display/d.vect/topo.c:38
+#: ../display/d.vect/plot1.c:353 ../display/d.thematic.area/plot1.c:362
#, fuzzy, c-format
msgid ""
-"\n"
-"ERROR: vector map - can't read\n"
-msgstr "×ÅËÔÏÒ"
-#: ../display/d.vect/plot1.c:350
-#, fuzzy, c-format
-msgid ""
"Error in color definition column (%s), element %d with cat %d: colorstring [%"
"s]"
msgstr " "
-#: ../display/d.vect/plot1.c:356
+#: ../display/d.vect/plot1.c:359 ../display/d.thematic.area/plot1.c:370
#, fuzzy, c-format
msgid "Error in color definition column (%s), element %d with cat %d"
msgstr " "
-#: ../display/d.vect/plot1.c:418 ../display/d.vect/area.c:295
+#: ../display/d.vect/plot1.c:421 ../display/d.vect/area.c:295
+#: ../display/d.thematic.area/plot1.c:437
#, fuzzy, c-format
msgid ""
"Error in line width column (%s), element %d with cat %d: line width [%d]"
msgstr " "
+#: ../display/d.vect/topo.c:38 ../display/d.thematic.area/plot1.c:289
+#, fuzzy, c-format
+msgid ""
+"\n"
+"ERROR: vector map - can't read\n"
+msgstr "×ÅËÔÏÒ"
+#: ../display/d.vect/main.c:126
+msgid "display, vector"
+msgstr ""
#: ../display/d.vect/main.c:128
#, fuzzy
-msgid "Displays GRASS vector data in the active frame on the graphics monitor."
+msgid "Displays vector data in the active frame on the graphics monitor."
msgstr "×ÅËÔÏÒ."
-#: ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:140
msgid "Display"
msgstr ""
-#: ../display/d.vect/main.c:151 ../display/d.vect/main.c:230
-#: ../display/d.vect/main.c:238 ../display/d.vect/main.c:245
-#: ../display/d.vect/main.c:253 ../display/d.vect/main.c:261
-#: ../display/d.vect/main.c:267 ../display/d.vect/main.c:273
-#: ../display/d.vect/main.c:281
-msgid "Labels"
-msgstr ""
+#: ../display/d.vect/main.c:149 ../display/d.thematic.area/main.c:103
+#, fuzzy
+msgid "Layer number. If -1, all layers are displayed."
+msgstr " ."
-#: ../display/d.vect/main.c:152
-msgid "Name of column to be displayed"
-msgstr ""
+#: ../display/d.vect/main.c:163
+#, fuzzy
+msgid "Line color"
+msgstr "ìÉÎÉÑ"
-#: ../display/d.vect/main.c:159 ../display/d.vect/main.c:169
-msgid "Symbols"
+#: ../display/d.vect/main.c:171
+msgid "Area fill color"
msgstr ""
-#: ../display/d.vect/main.c:163
-msgid "Point and centroid symbol"
+#: ../display/d.vect/main.c:182
+msgid "Name of color definition column (for use with -a flag)"
msgstr ""
-#: ../display/d.vect/main.c:170
-msgid "Symbol size"
-msgstr ""
-#: ../display/d.vect/main.c:173
-#, fuzzy
-msgid "Layer number. If -1, all layers are displayed."
-msgstr " ."
-#: ../display/d.vect/main.c:185 ../display/d.vect/main.c:191
-#: ../display/d.vect/main.c:198
+#: ../display/d.vect/main.c:190 ../display/d.vect/main.c:196
+#: ../display/d.vect/main.c:203
msgid "Lines"
msgstr ""
-#: ../display/d.vect/main.c:186
+#: ../display/d.vect/main.c:191
#, fuzzy
msgid "Line width"
msgstr "ìÉÎÉÑ"
-#: ../display/d.vect/main.c:192
+#: ../display/d.vect/main.c:197
msgid "Name of column for line widths (these values will be scaled by wscale)"
msgstr ""
-#: ../display/d.vect/main.c:199
+#: ../display/d.vect/main.c:204
msgid "Scale factor for wcolumn"
msgstr ""
-#: ../display/d.vect/main.c:205
-#, fuzzy
-msgid "Line color"
-msgstr "ìÉÎÉÑ"
+#: ../display/d.vect/main.c:212 ../display/d.vect/main.c:222
+msgid "Symbols"
+msgstr ""
-#: ../display/d.vect/main.c:213
-msgid "Area fill color"
+#: ../display/d.vect/main.c:216
+msgid "Point and centroid symbol"
msgstr ""
-#: ../display/d.vect/main.c:224
-msgid "Name of color definition column (for use with -a flag)"
+#: ../display/d.vect/main.c:223
+msgid "Symbol size"
msgstr ""
-#: ../display/d.vect/main.c:231
+#: ../display/d.vect/main.c:231 ../display/d.vect/main.c:237
+#: ../display/d.vect/main.c:245 ../display/d.vect/main.c:252
+#: ../display/d.vect/main.c:260 ../display/d.vect/main.c:268
+#: ../display/d.vect/main.c:274 ../display/d.vect/main.c:280
+#: ../display/d.vect/main.c:288
+msgid "Labels"
+msgstr ""
+#: ../display/d.vect/main.c:232
+msgid "Name of column to be displayed"
+msgstr ""
+#: ../display/d.vect/main.c:238
msgid "Layer for labels (default: the given layer number)"
msgstr ""
-#: ../display/d.vect/main.c:237
+#: ../display/d.vect/main.c:244
msgid "Label color"
msgstr ""
-#: ../display/d.vect/main.c:246
+#: ../display/d.vect/main.c:253
msgid "Label background color"
msgstr ""
-#: ../display/d.vect/main.c:254
+#: ../display/d.vect/main.c:261
msgid "Label border color"
msgstr ""
-#: ../display/d.vect/main.c:262
+#: ../display/d.vect/main.c:269
msgid "Label size (pixels)"
msgstr ""
-#: ../display/d.vect/main.c:276
+#: ../display/d.vect/main.c:283
msgid "Label horizontal justification"
msgstr ""
-#: ../display/d.vect/main.c:284
+#: ../display/d.vect/main.c:291
msgid "Label vertical justification"
msgstr ""
-#: ../display/d.vect/main.c:290
+#: ../display/d.vect/main.c:297
#, fuzzy
msgid ""
"Minimum region size (average from height and width) when map is displayed"
msgstr " "
-#: ../display/d.vect/main.c:298
+#: ../display/d.vect/main.c:305
#, fuzzy
msgid ""
"Maximum region size (average from height and width) when map is displayed"
msgstr " "
-#: ../display/d.vect/main.c:308
+#: ../display/d.vect/main.c:315 ../display/d.thematic.area/main.c:130
msgid "Rendering method for filled polygons"
msgstr ""
-#: ../display/d.vect/main.c:310
+#: ../display/d.vect/main.c:317 ../display/d.thematic.area/main.c:132
msgid ""
"g;use the libgis render functions (features: clipping);r;use the raster "
"graphics library functions (features: polylines);d;use the display library "
@@ -24512,77 +24917,78 @@
"(features: culling, polylines)"
msgstr ""
-#: ../display/d.vect/main.c:326
+#: ../display/d.vect/main.c:334
msgid "Get colors from map table column (of form RRR:GGG:BBB)"
msgstr ""
-#: ../display/d.vect/main.c:332
+#: ../display/d.vect/main.c:340
#, fuzzy
msgid ""
"Random colors according to category number (or layer number if 'layer=-1' is "
"given)"
msgstr " "
-#: ../display/d.vect/main.c:338
-msgid "Use values from 'cats' option as line ID"
+#: ../display/d.vect/main.c:347
+msgid "Use values from 'cats' option as feature id"
msgstr ""
-#: ../display/d.vect/main.c:343
+#: ../display/d.vect/main.c:352 ../display/d.thematic.area/main.c:152
#, fuzzy
msgid ""
"Don't add to list of vectors and commands in monitor (it won't be drawn if "
"the monitor is refreshed)"
msgstr " "
-#: ../display/d.vect/main.c:386 ../display/d.paint.labels/main.c:99
+#: ../display/d.vect/main.c:395 ../display/d.paint.labels/main.c:99
#, fuzzy
msgid "Region size is lower than minreg, nothing displayed."
msgstr " ."
-#: ../display/d.vect/main.c:395 ../display/d.paint.labels/main.c:108
+#: ../display/d.vect/main.c:404 ../display/d.paint.labels/main.c:108
#, fuzzy
msgid "Region size is greater than maxreg, nothing displayed."
msgstr " ."
-#: ../display/d.vect/main.c:411
+#: ../display/d.vect/main.c:420
msgid ""
"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
"ignored!"
msgstr ""
-#: ../display/d.vect/main.c:425 ../display/d.vect/main.c:438
+#: ../display/d.vect/main.c:434 ../display/d.vect/main.c:447
+#: ../display/d.thematic.area/main.c:271
#, fuzzy, c-format
msgid "Unknown color: [%s]"
msgstr " "
-#: ../display/d.vect/main.c:490
+#: ../display/d.vect/main.c:499
msgid "'layer' must be > 0 for 'cats'."
msgstr ""
-#: ../display/d.vect/main.c:494
+#: ../display/d.vect/main.c:503
#, c-format
msgid "%d errors in cat option"
msgstr ""
-#: ../display/d.vect/main.c:614
+#: ../display/d.vect/main.c:623 ../display/d.thematic.area/main.c:322
msgid "Plotting ..."
msgstr ""
-#: ../display/d.vect/main.c:623
+#: ../display/d.vect/main.c:632 ../display/d.thematic.area/main.c:330
#, fuzzy
msgid ""
"The bounding box of the map is outside the current region, nothing drawn."
msgstr "×ÅËÔÏÒ "
-#: ../display/d.vect/main.c:647
+#: ../display/d.vect/main.c:658
msgid "Cannot display areas, topology not available"
msgstr ""
-#: ../display/d.vect/main.c:652
+#: ../display/d.vect/main.c:663
msgid "Cannot display lines by id, topology not available"
msgstr ""
-#: ../display/d.vect/main.c:690
+#: ../display/d.vect/main.c:701
msgid "Cannot display topology, not available"
msgstr ""
@@ -24614,47 +25020,53 @@
#: ../display/d.vect.chart/main.c:64
#, fuzzy
msgid ""
-"Displays charts of GRASS vector data in the active frame on the graphics "
-"monitor"
+"Displays charts of vector data in the active frame on the graphics monitor."
msgstr "×ÅËÔÏÒ"
#: ../display/d.vect.chart/main.c:81
msgid "Chart type"
msgstr ""
-#: ../display/d.vect.chart/main.c:88
+#: ../display/d.vect.chart/main.c:82 ../display/d.vect.chart/main.c:96
+#: ../display/d.vect.chart/main.c:103 ../display/d.vect.chart/main.c:110
+#: ../display/d.vect.chart/main.c:118 ../display/d.vect.chart/main.c:127
+#: ../display/d.vect.chart/main.c:132
+msgid "Chart properties"
+msgstr ""
+#: ../display/d.vect.chart/main.c:89
msgid "Attribute columns containing data"
msgstr ""
-#: ../display/d.vect.chart/main.c:94
+#: ../display/d.vect.chart/main.c:95
msgid "Column used for pie chart size"
msgstr ""
-#: ../display/d.vect.chart/main.c:100
+#: ../display/d.vect.chart/main.c:102
msgid "Size of chart (diameter for pie, total width for bar)"
msgstr ""
-#: ../display/d.vect.chart/main.c:106
+#: ../display/d.vect.chart/main.c:109
msgid "Scale for size (to get size in pixels)"
msgstr ""
-#: ../display/d.vect.chart/main.c:112
+#: ../display/d.vect.chart/main.c:116
msgid "Outline color"
msgstr ""
-#: ../display/d.vect.chart/main.c:120
+#: ../display/d.vect.chart/main.c:125
msgid "Colors used to fill charts"
msgstr ""
-#: ../display/d.vect.chart/main.c:125
+#: ../display/d.vect.chart/main.c:131
msgid "Center the bar chart around a data point"
msgstr ""
-#: ../display/d.vect.chart/main.c:132
+#: ../display/d.vect.chart/main.c:139
msgid "Maximum value used for bar plot reference"
msgstr ""
-#: ../display/d.vect.chart/main.c:136
+#: ../display/d.vect.chart/main.c:143 ../display/d.thematic.area/main.c:143
msgid "Create legend information and send to stdout"
msgstr ""
@@ -25011,8 +25423,8 @@
msgid "Please specify a lat/long ellipsoid with -l or -w"
msgstr ""
-#: ../display/d.where/main.c:89 ../general/g.region/cmd/printwindow.c:244
-#: ../general/g.region/cmd/printwindow.c:494
+#: ../display/d.where/main.c:89 ../general/g.region/printwindow.c:244
+#: ../general/g.region/printwindow.c:494
msgid "Can't get projection info of current location"
msgstr ""
@@ -25293,29 +25705,29 @@
msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
msgstr ""
-#: ../display/d.grid/plot.c:289
+#: ../display/d.grid/plot.c:321
msgid ""
"WGS84 grid output not possible as this location does not contain\n"
"datum transformation parameters. Try running g.setproj."
msgstr ""
-#: ../display/d.grid/plot.c:457
+#: ../display/d.grid/plot.c:489
msgid "Error in pj_do_proj1"
msgstr ""
-#: ../display/d.grid/plot.c:463
+#: ../display/d.grid/plot.c:495
msgid "Error in pj_do_proj2"
msgstr ""
-#: ../display/d.grid/plot.c:467
+#: ../display/d.grid/plot.c:499
msgid "Error in pj_do_proj3"
msgstr ""
-#: ../display/d.grid/plot.c:475
+#: ../display/d.grid/plot.c:507
msgid "Error in pj_do_proj5"
msgstr ""
-#: ../display/d.grid/plot.c:479
+#: ../display/d.grid/plot.c:511
msgid "Error in pj_do_proj6"
msgstr ""
@@ -25355,52 +25767,69 @@
msgstr ""
#: ../display/d.grid/main.c:106
+msgid "Draw '+' marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:110
+msgid "Draw fiducial marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:114
msgid "Disable grid drawing"
msgstr ""
-#: ../display/d.grid/main.c:110
+#: ../display/d.grid/main.c:118
msgid "Disable border drawing"
msgstr ""
-#: ../display/d.grid/main.c:114
+#: ../display/d.grid/main.c:122
msgid "Disable text drawing"
msgstr ""
-#: ../display/d.grid/main.c:124
+#: ../display/d.grid/main.c:132
#, fuzzy
msgid "Both grid and border drawing are disabled"
msgstr " "
-#: ../display/d.grid/main.c:128
+#: ../display/d.grid/main.c:136
#, fuzzy
msgid "Geo-Grid option is not available for LL projection"
msgstr " "
-#: ../display/d.grid/main.c:130
+#: ../display/d.grid/main.c:138
#, fuzzy
msgid "Geo-Grid option is not available for XY projection"
msgstr " "
-#: ../display/d.grid/main.c:141
+#: ../display/d.grid/main.c:147
+msgid "Chose a single mark style"
+msgstr ""
+#: ../display/d.grid/main.c:157
#, fuzzy, c-format
msgid "Invalid geo-grid size <%s>"
msgstr " "
-#: ../display/d.grid/main.c:144
+#: ../display/d.grid/main.c:160
#, fuzzy, c-format
msgid "Invalid grid size <%s>"
msgstr " "
-#: ../display/d.grid/main.c:151
+#: ../display/d.grid/main.c:167
#, fuzzy, c-format
msgid "Illegal east coordinate <%s>"
msgstr " "
-#: ../display/d.grid/main.c:159
+#: ../display/d.grid/main.c:175
#, fuzzy, c-format
msgid "Illegal north coordinate <%s>"
msgstr " "
+#: ../display/d.grid/fiducial.c:49
+#, fuzzy
+msgid "Reading symbol"
+msgstr "þÔÅÎÉÅ %s ..."
#: ../display/d.nviz/main.c:69
msgid "Creates fly-through script to run in NVIZ."
msgstr ""
@@ -25803,14 +26232,186 @@
msgid "Monitor: XGetWMName: bad result"
msgstr ""
+#: ../display/d.thematic.area/main.c:74
+#, fuzzy
+msgid ""
+"Displays a thematic vector area map in the activeframe on the graphics "
+"monitor."
+msgstr "×ÅËÔÏÒ."
+#: ../display/d.thematic.area/main.c:84
+msgid "Data to be classified: column name or expression"
+msgstr ""
+#: ../display/d.thematic.area/main.c:91
+msgid "Class breaks, without minimum and maximum"
+msgstr ""
+#: ../display/d.thematic.area/main.c:98
+msgid "Colors (one more than class breaks)."
+msgstr ""
+#: ../display/d.thematic.area/main.c:112 ../display/d.thematic.area/main.c:120
+#, fuzzy
+msgid "Boundaries"
+msgstr "×ÅËÔÏÒ"
+#: ../display/d.thematic.area/main.c:113
+#, fuzzy
+msgid "Boundary width"
+msgstr "ìÉÎÉÑ"
+#: ../display/d.thematic.area/main.c:119
+msgid "Boundary color"
+msgstr ""
+#: ../display/d.thematic.area/main.c:147
+msgid "Do not draw map, only output the legend"
+msgstr ""
+#: ../display/d.thematic.area/main.c:194
+#, fuzzy, c-format
+msgid "%s: You must build topology on vector map. Run v.build."
+msgstr " ×ÅËÔÏÒ"
+#: ../display/d.thematic.area/main.c:201
+msgid "'layer' must be > 0"
+msgstr ""
+#: ../display/d.thematic.area/main.c:226
+#, fuzzy, c-format
+msgid "Data (%s) not numeric. Column must be numeric."
+msgstr "ìÉÎÉÑ ."
+#: ../display/d.thematic.area/main.c:296
+#, c-format
+msgid ""
+"Not enough colors or error in color specifications.\n"
+"Need %i colors."
+msgstr ""
+#: ../display/d.thematic.area/main.c:301
+#, fuzzy, c-format
+msgid "Error interpreting color %s"
+msgstr " ."
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:163
+msgid "Raster elevation file name"
+msgstr ""
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:171
+#, fuzzy
+msgid "Output slope filename"
+msgstr "óËÌÏÎÙ"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:179
+#, fuzzy
+msgid "Output aspect filename"
+msgstr "üËÓÐÏÚÉÃÉÑ"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:205
+msgid "Output profile curvature filename"
+msgstr ""
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:214
+msgid "Output tangential curvature filename"
+msgstr ""
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:223
+#, fuzzy
+msgid "Output first order partial derivative dx (E-W slope) filename"
+msgstr "óËÌÏÎÙ"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:232
+#, fuzzy
+msgid "Output first order partial derivative dy (N-S slope) filename"
+msgstr "óËÌÏÎÙ"
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:241
+msgid "Output second order partial derivative dxx filename"
+msgstr ""
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:250
+msgid "Output second order partial derivative dyy filename"
+msgstr ""
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:259
+msgid "Output second order partial derivative dxy filename"
+msgstr ""
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:319
+msgid ""
+"The '-q' flag is superseded and will be removed in future. Please use '--"
+"quiet' instead."
+msgstr ""
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:405
+#, fuzzy, c-format
+msgid "wrong type: %s"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1037
+#, fuzzy, c-format
+msgid "Elevation products for mapset [%s] in [%s]"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1108
+#, fuzzy, c-format
+msgid "ASPECT [%s] COMPLETE"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1198
+#, fuzzy, c-format
+msgid "SLOPE [%s] COMPLETE"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1267
+#, fuzzy, c-format
+msgid "PROFILE CURVE [%s] COMPLETE"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1294
+#, fuzzy, c-format
+msgid "TANGENTIAL CURVE [%s] COMPLETE"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1319
+#, fuzzy, c-format
+msgid "E-W SLOPE [%s] COMPLETE"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1344
+#, fuzzy, c-format
+msgid "N-S SLOPE [%s] COMPLETE"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1369
+#, fuzzy, c-format
+msgid "DXX [%s] COMPLETE"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1394
+#, fuzzy, c-format
+msgid "DYY [%s] COMPLETE"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:1419
+#, fuzzy, c-format
+msgid "DXY [%s] COMPLETE"
+msgstr " "
+#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:19
+#, fuzzy, c-format
+msgid "Failed in attempt to open %s"
+msgstr " "
#: ../general/g.gisenv/main.c:36 ../general/g.access/main.c:37
#: ../general/g.tempfile/main.c:35 ../general/g.pnmcomp/main.c:302
#: ../general/g.proj/main.c:54 ../general/g.transform/main.c:236
-#: ../general/g.mapsets/main_cmd.c:52 ../general/g.findetc/main.c:27
-#: ../general/g.ask/main.c:39 ../general/g.findfile/main.c:33
-#: ../general/g.filename/main.c:38 ../general/g.region/cmd/main.c:80
-#: ../general/g.message/main.c:32 ../general/g.version/main.c:33
-#: ../general/g.mapset/main.c:48
+#: ../general/g.findetc/main.c:27 ../general/g.ask/main.c:39
+#: ../general/g.findfile/main.c:33 ../general/g.filename/main.c:38
+#: ../general/g.region/main.c:79 ../general/g.message/main.c:32
+#: ../general/g.version/main.c:33
msgid "general"
msgstr ""
@@ -25925,36 +26526,36 @@
msgid "Verbose listing (also list map titles)"
msgstr ""
-#: ../general/manage/cmd/remove.c:47
+#: ../general/manage/cmd/remove.c:41
+#, c-format
+msgid "[%s@%s] is a base map for [%s]. Remove forced."
+msgstr ""
+#: ../general/manage/cmd/remove.c:45
+#, c-format
+msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
+msgstr ""
+#: ../general/manage/cmd/remove.c:70 ../general/manage/cmd/remove.c:86
+#, c-format
+msgid "Removing information about reclassed map from [%s@%s] failed"
+msgstr ""
+#: ../general/manage/cmd/remove.c:112
#, fuzzy
msgid "Removes data base element files from the user's current mapset."
msgstr " ."
-#: ../general/manage/cmd/remove.c:52
+#: ../general/manage/cmd/remove.c:117
#, fuzzy
msgid "Force remove"
msgstr "×ÅËÔÏÒ"
-#: ../general/manage/cmd/remove.c:66
+#: ../general/manage/cmd/remove.c:131
#, fuzzy, c-format
msgid "%s file(s) to be removed"
msgstr " "
-#: ../general/manage/cmd/remove.c:89
-#, c-format
-msgid "[%s@%s] is a base map for [%s]. Remove forced."
-msgstr ""
-#: ../general/manage/cmd/remove.c:94
-#, c-format
-msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
-msgstr ""
-#: ../general/manage/cmd/remove.c:116 ../general/manage/cmd/remove.c:133
-#, c-format
-msgid "Removing information about reclassed map from [%s@%s] failed"
-msgstr ""
#: ../general/g.pnmcomp/main.c:38
#, fuzzy, c-format
msgid "Invalid color: %s"
@@ -26238,33 +26839,58 @@
msgid "Display summary information"
msgstr ""
-#: ../general/g.mapsets/main_cmd.c:54
+#: ../general/g.mapsets/main_cmd.c:49 ../general/g.mapset/main.c:48
#, fuzzy
+msgid "general, settings"
+msgstr "×ÅËÔÏÒ"
+#: ../general/g.mapsets/main_cmd.c:51
+#, fuzzy
msgid ""
"Modifies the user's current mapset search path, affecting the user's access "
"to data existing under the other GRASS mapsets in the current location."
msgstr " ."
-#: ../general/g.mapsets/main_cmd.c:63
+#: ../general/g.mapsets/main_cmd.c:60
#, fuzzy
msgid "Name(s) of existing mapset(s)"
msgstr " "
-#: ../general/g.mapsets/main_cmd.c:70
+#: ../general/g.mapsets/main_cmd.c:67
#, fuzzy
msgid "Name(s) of existing mapset(s) to add to search list"
msgstr " "
#: ../general/g.mapsets/main_cmd.c:74
+#, fuzzy
+msgid "Name(s) of existing mapset(s) to remove from search list"
+msgstr " "
+#: ../general/g.mapsets/main_cmd.c:78
msgid "List all available mapsets"
msgstr ""
-#: ../general/g.mapsets/main_cmd.c:78
+#: ../general/g.mapsets/main_cmd.c:82
#, fuzzy
msgid "Print current mapset search path"
msgstr " "
+#: ../general/g.mapsets/main_cmd.c:104 ../general/g.mapsets/main_cmd.c:131
+#, fuzzy, c-format
+msgid "Mapset <%s> not found"
+msgstr " "
+#: ../general/g.mapsets/main_cmd.c:133
+#, c-format
+msgid "Mapset <%s> added to search path"
+msgstr ""
#: ../general/g.mapsets/main_cmd.c:158
+#, c-format
+msgid "Mapset <%s> removed from search path"
+msgstr ""
+#: ../general/g.mapsets/main_cmd.c:181
msgid "Cannot open SEARCH_PATH for write"
msgstr ""
@@ -26291,206 +26917,205 @@
msgid "Name of a mapset (default: current)"
msgstr ""
-#: ../general/g.region/cmd/main.c:82
+#: ../general/g.region/main.c:81
msgid "Manages the boundary definitions for the geographic region."
msgstr ""
-#: ../general/g.region/cmd/main.c:90 ../general/g.region/cmd/main.c:95
-#: ../general/g.region/cmd/main.c:159 ../general/g.region/cmd/main.c:166
-#: ../general/g.region/cmd/main.c:174 ../general/g.region/cmd/main.c:181
-#: ../general/g.region/cmd/main.c:191
+#: ../general/g.region/main.c:89 ../general/g.region/main.c:94
+#: ../general/g.region/main.c:158 ../general/g.region/main.c:165
+#: ../general/g.region/main.c:173 ../general/g.region/main.c:180
+#: ../general/g.region/main.c:190
msgid "Existing"
msgstr ""
-#: ../general/g.region/cmd/main.c:94
+#: ../general/g.region/main.c:93
msgid "Save as default region"
msgstr ""
-#: ../general/g.region/cmd/main.c:99
+#: ../general/g.region/main.c:98
msgid "Print the current region"
msgstr ""
-#: ../general/g.region/cmd/main.c:104
-msgid "Print the current region in lat/long on current ellipsoid/datum"
+#: ../general/g.region/main.c:103
+msgid "Print the current region in lat/long using the current ellipsoid/datum"
msgstr ""
-#: ../general/g.region/cmd/main.c:110
+#: ../general/g.region/main.c:109
msgid "Print the current region extent"
msgstr ""
-#: ../general/g.region/cmd/main.c:115
+#: ../general/g.region/main.c:114
msgid "Print the current region map center coordinates"
msgstr ""
-#: ../general/g.region/cmd/main.c:120
+#: ../general/g.region/main.c:119
msgid "Print region resolution in meters (geodesic)"
msgstr ""
-#: ../general/g.region/cmd/main.c:125
+#: ../general/g.region/main.c:124
msgid "Print also 3D settings"
msgstr ""
-#: ../general/g.region/cmd/main.c:130
+#: ../general/g.region/main.c:129
msgid "Print the maximum bounding box in lat/long on WGS84"
msgstr ""
-#: ../general/g.region/cmd/main.c:140
+#: ../general/g.region/main.c:139
msgid ""
"Align region to resolution (default = align to bounds, works only for 2D "
"resolution)"
msgstr ""
-#: ../general/g.region/cmd/main.c:146
+#: ../general/g.region/main.c:145
msgid "Do not update the current region"
msgstr ""
-#: ../general/g.region/cmd/main.c:157
+#: ../general/g.region/main.c:156
msgid "Set current region from named region"
msgstr ""
-#: ../general/g.region/cmd/main.c:172
+#: ../general/g.region/main.c:171
msgid "Set region to match this 3D raster map (both 2D and 3D values)"
msgstr ""
-#: ../general/g.region/cmd/main.c:239
+#: ../general/g.region/main.c:238
msgid "Value for the top edge"
msgstr ""
-#: ../general/g.region/cmd/main.c:248
+#: ../general/g.region/main.c:247
msgid "Value for the bottom edge"
msgstr ""
-#: ../general/g.region/cmd/main.c:257
+#: ../general/g.region/main.c:256
msgid "Number of rows in the new region"
msgstr ""
-#: ../general/g.region/cmd/main.c:258 ../general/g.region/cmd/main.c:267
-#: ../general/g.region/cmd/main.c:276 ../general/g.region/cmd/main.c:285
-#: ../general/g.region/cmd/main.c:295 ../general/g.region/cmd/main.c:305
-#: ../general/g.region/cmd/main.c:314 ../general/g.region/cmd/main.c:324
+#: ../general/g.region/main.c:257 ../general/g.region/main.c:266
+#: ../general/g.region/main.c:275 ../general/g.region/main.c:284
+#: ../general/g.region/main.c:294 ../general/g.region/main.c:304
+#: ../general/g.region/main.c:313
msgid "Resolution"
msgstr ""
-#: ../general/g.region/cmd/main.c:266
+#: ../general/g.region/main.c:265
msgid "Number of columns in the new region"
msgstr ""
-#: ../general/g.region/cmd/main.c:275
+#: ../general/g.region/main.c:274
msgid "Grid resolution 2D (both north-south and east-west)"
msgstr ""
-#: ../general/g.region/cmd/main.c:284
+#: ../general/g.region/main.c:283
msgid "3D grid resolution (north-south, east-west and top-bottom)"
msgstr ""
-#: ../general/g.region/cmd/main.c:293
+#: ../general/g.region/main.c:292
msgid "North-south grid resolution 2D"
msgstr ""
-#: ../general/g.region/cmd/main.c:303
+#: ../general/g.region/main.c:302
msgid "East-west grid resolution 2D"
msgstr ""
-#: ../general/g.region/cmd/main.c:313
+#: ../general/g.region/main.c:312
msgid "Top-bottom grid resolution 3D"
msgstr ""
-#: ../general/g.region/cmd/main.c:322
-msgid "Raster map to zoom into"
+#: ../general/g.region/main.c:322
+msgid "Shrink region until it meets non-NULL data from this raster map"
msgstr ""
-#: ../general/g.region/cmd/main.c:342
-msgid "Save the current region to region definition file"
+#: ../general/g.region/main.c:333
+msgid "Adjust region cells to cleanly align with this raster map"
msgstr ""
-#: ../general/g.region/cmd/main.c:477
+#: ../general/g.region/main.c:344
+msgid "Save current region settings in named region file"
+msgstr ""
+#: ../general/g.region/main.c:479
#, fuzzy, c-format
msgid "3D raster map <%s> not found"
msgstr " "
-#: ../general/g.region/cmd/main.c:480
+#: ../general/g.region/main.c:482
#, fuzzy, c-format
msgid "Unable to read header of 3D raster map <%s@%s>"
msgstr " !"
-#: ../general/g.region/cmd/main.c:524
+#: ../general/g.region/main.c:526
#, fuzzy, c-format
msgid "Unable to open vector map <%s@%s>"
msgstr "×ÅËÔÏÒ "
-#: ../general/g.region/cmd/main.c:827
+#: ../general/g.region/main.c:829
#, fuzzy, c-format
msgid "Raster map <%s@%s>: %s"
msgstr " "
-#: ../general/g.region/cmd/main.c:834
+#: ../general/g.region/main.c:836
#, fuzzy, c-format
msgid "<%s> is an illegal region name"
msgstr " "
-#: ../general/g.region/cmd/main.c:838
+#: ../general/g.region/main.c:840
#, fuzzy, c-format
msgid "Unable to set region <%s>"
msgstr " "
-#: ../general/g.region/cmd/main.c:845
+#: ../general/g.region/main.c:847
msgid "Unable to update current region"
msgstr ""
-#: ../general/g.region/cmd/main.c:853
+#: ../general/g.region/main.c:855
msgid "Unable to change default region. The current mapset is not <PERMANENT>."
msgstr ""
-#: ../general/g.region/cmd/main.c:870
+#: ../general/g.region/main.c:872
#, fuzzy, c-format
msgid "Invalid input <%s=%s>"
msgstr " "
-#: ../general/g.region/cmd/main.c:887
+#: ../general/g.region/main.c:889
msgid "format"
msgstr ""
-#: ../general/g.region/cmd/printwindow.c:263
-#: ../general/g.region/cmd/printwindow.c:523
+#: ../general/g.region/printwindow.c:263 ../general/g.region/printwindow.c:523
msgid "Unable to update lat/long projection parameters"
msgstr ""
-#: ../general/g.region/cmd/printwindow.c:282
-#: ../general/g.region/cmd/printwindow.c:291
-#: ../general/g.region/cmd/printwindow.c:300
-#: ../general/g.region/cmd/printwindow.c:309
-#: ../general/g.region/cmd/printwindow.c:553
-#: ../general/g.region/cmd/printwindow.c:562
-#: ../general/g.region/cmd/printwindow.c:571
-#: ../general/g.region/cmd/printwindow.c:580
+#: ../general/g.region/printwindow.c:282 ../general/g.region/printwindow.c:291
+#: ../general/g.region/printwindow.c:300 ../general/g.region/printwindow.c:309
+#: ../general/g.region/printwindow.c:553 ../general/g.region/printwindow.c:562
+#: ../general/g.region/printwindow.c:571 ../general/g.region/printwindow.c:580
msgid "Error in pj_do_proj (projection of input coordinate pair)"
msgstr ""
-#: ../general/g.region/cmd/printwindow.c:406
+#: ../general/g.region/printwindow.c:406
msgid "You are already in lat/long. Use -p flag instead."
msgstr ""
-#: ../general/g.region/cmd/printwindow.c:408
+#: ../general/g.region/printwindow.c:408
msgid "You are in xy location (no projection possible, use -p flag instead)."
msgstr ""
-#: ../general/g.region/cmd/printwindow.c:512
+#: ../general/g.region/printwindow.c:512
msgid ""
"WGS84 output not possible as this location does not contain datum "
"transformation parameters. Try running g.setproj."
msgstr ""
-#: ../general/g.region/cmd/printwindow.c:662
+#: ../general/g.region/printwindow.c:662
#, fuzzy
msgid "No LatLong information for XY-Projection"
msgstr " "
-#: ../general/g.region/cmd/zoom.c:23
+#: ../general/g.region/zoom.c:23
#, fuzzy, c-format
msgid "Unable to open raster map <%s> in <%s>"
msgstr " "
-#: ../general/g.region/cmd/zoom.c:36
+#: ../general/g.region/zoom.c:36
#, fuzzy, c-format
msgid "Could not read from <%s>"
msgstr " "
@@ -26762,7 +27387,7 @@
#: ../general/g.mapset/main.c:49
#, fuzzy
-msgid "Change current mapset"
+msgid "Change current mapset."
msgstr " "
#: ../general/g.mapset/main.c:56
@@ -26782,60 +27407,132 @@
msgid "Create mapset if it doesn't exist"
msgstr " "
-#: ../general/g.mapset/main.c:105
+#: ../general/g.mapset/main.c:79
+msgid "List available mapsets"
+msgstr ""
+#: ../general/g.mapset/main.c:85
+#, fuzzy
+msgid "Either mapset= or -l must be used"
+msgstr "×ÅËÔÏÒ."
+#: ../general/g.mapset/main.c:131
#, fuzzy, c-format
-msgid "%s is already the current mapset"
+msgid "<%s> is already the current mapset"
msgstr "ïûéâëá "
-#: ../general/g.mapset/main.c:113
-msgid "You don't have permission to use this mapset."
+#: ../general/g.mapset/main.c:139
+msgid "You don't have permission to use this mapset"
msgstr ""
-#: ../general/g.mapset/main.c:121
+#: ../general/g.mapset/main.c:147
msgid "The mapset does not exist. Use -c flag to create it."
msgstr ""
-#: ../general/g.mapset/main.c:130
+#: ../general/g.mapset/main.c:156
#, fuzzy
-msgid "Cannot read GIS_LOCK enviroment variable."
+msgid "Unable to read GIS_LOCK enviroment variable"
msgstr " "
-#: ../general/g.mapset/main.c:144
+#: ../general/g.mapset/main.c:170
#, c-format
msgid ""
"%s is currently running GRASS in selected mapset or lock file cannot be "
-"checked."
+"checked"
msgstr ""
-#: ../general/g.mapset/main.c:148
+#: ../general/g.mapset/main.c:174
#, fuzzy
-msgid "Erasing monitors ..."
+msgid "Erasing monitors..."
msgstr "×ÅËÔÏÒ"
-#: ../general/g.mapset/main.c:164
+#: ../general/g.mapset/main.c:190
#, fuzzy
-msgid "Cleaning up temporary files ..."
+msgid "Cleaning up temporary files..."
msgstr " "
-#: ../general/g.mapset/main.c:178
-msgid "Your shell continues to use the history for the old mapset."
+#: ../general/g.mapset/main.c:204
+msgid "Your shell continues to use the history for the old mapset"
msgstr ""
-#: ../general/g.mapset/main.c:182
+#: ../general/g.mapset/main.c:208
#, c-format
msgid ""
"You can switch the history by commands:\n"
"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
msgstr ""
-#: ../general/g.mapset/main.c:186
+#: ../general/g.mapset/main.c:212
#, c-format
msgid ""
"history -S; history -L %s/.history; setenv histfile=%s/.history"
msgstr ""
+#: ../general/g.gui/main.c:35
#, fuzzy
+msgid "general, gui"
+msgstr "×ÅËÔÏÒ"
+#: ../general/g.gui/main.c:37
+msgid "Launches a GRASS graphical user interface (GUI) session."
+msgstr ""
+#: ../general/g.gui/main.c:43
+msgid "GUI type"
+msgstr ""
+#: ../general/g.gui/main.c:44
+msgid ""
+"tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - "
+"Display Manager (d.m);wxpython;wxPython based next generation GUI"
+msgstr ""
+#: ../general/g.gui/main.c:59
+#, fuzzy
+msgid "Name of workspace file"
+msgstr "×ÅËÔÏÒ"
+#: ../general/g.gui/main.c:63
+msgid "Update default GUI setting"
+msgstr ""
+#: ../general/g.gui/main.c:71
+#, c-format
+msgid "<%s> is now the default GUI"
+msgstr ""
+#, fuzzy
+#~ msgid "Name of the vector points map with x,y locations"
+#~ msgstr "×ÅËÔÏÒ"
+#, fuzzy
+#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+#~ msgstr "éÍÑ ÒÁÓÔÒÏ×ÏÇÏ ÆÁÊÌÁ-ÍÁÓËÉ"
+#, fuzzy
+#~ msgid "Output"
+#~ msgstr " "
+#, fuzzy
+#~ msgid ""
+#~ "Not enough data columns. Incorrect delimiter or column number?\n"
+#~ "[%s]"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Error reading '%s' map"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Raster file(s) for Elevation"
+#~ msgstr " "
+#, fuzzy
+#~ msgid "Raster file(s) for Color"
+#~ msgstr " "
+#, fuzzy
#~ msgid "Could not open input file <%s>."
#~ msgstr " ."
@@ -27418,10 +28115,6 @@
#~ msgstr " "
#, fuzzy
-#~ msgid "Close boundaries"
-#~ msgstr "×ÅËÔÏÒ"
-#, fuzzy
#~ msgid "Cannot copy line %d, editing terminated"
#~ msgstr " "
@@ -27594,10 +28287,6 @@
#~ msgstr " "
#, fuzzy
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "×ÅËÔÏÒ."
-#, fuzzy
#~ msgid "Cannot drop table: %s"
#~ msgstr " "
@@ -27763,10 +28452,6 @@
#~ msgstr " ."
#, fuzzy
-#~ msgid "Illegal map name <%s>"
-#~ msgstr " "
-#, fuzzy
#~ msgid "Filtering [%s] in [%s]"
#~ msgstr " "
@@ -28335,10 +29020,6 @@
#~ msgstr " "
#, fuzzy
-#~ msgid "Raster <%s> not found"
-#~ msgstr " "
-#, fuzzy
#~ msgid "Could not open raster <%s>"
#~ msgstr " "
Modified: grass/branches/develbranch_6/locale/po/grasstcl_es.po
--- grass/branches/develbranch_6/locale/po/grasstcl_es.po 2008-05-06 19:11:33 UTC (rev 31269)
+++ grass/branches/develbranch_6/locale/po/grasstcl_es.po 2008-05-06 20:47:18 UTC (rev 31270)
@@ -11,7 +11,7 @@
msgstr ""
"Project-Id-Version: grasstcl_es\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-03-26 21:14+0100\n"
+"POT-Creation-Date: 2008-05-06 20:32+0200\n"
"PO-Revision-Date: 2008-03-06 17:59+0100\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -295,7 +295,8 @@
msgstr "Cancelar"
#: ../lib/gis/gui.tcl:11 ../lib/gis/gui.tcl:15 ../lib/gis/gui.tcl:19
-#: ../lib/gis/gui.tcl:310 ../gui/tcltk/gis.m/runandoutput.tcl:258
+#: ../lib/gis/gui.tcl:310 ../gui/tcltk/gis.m/runandoutput.tcl:259
+#: ../gui/tcltk/gis.m/runandoutput.tcl:265
#: ../gui/tcltk/gis.m/grassabout.tcl:94 ../gui/tcltk/gis.m/gmlib.tcl:137
msgid "Error"
msgstr "Error"
@@ -338,7 +339,7 @@
#: ../gui/tcltk/gis.m/animate.tcl:484 ../gui/tcltk/gis.m/dnviz.tcl:208
#: ../gui/tcltk/gis.m/dnviz.tcl:212 ../gui/tcltk/gis.m/gridline.tcl:162
#: ../gui/tcltk/gis.m/gridline.tcl:214 ../gui/tcltk/gis.m/gridline.tcl:241
-#: ../gui/tcltk/gis.m/legend.tcl:189 ../gui/tcltk/gis.m/legend.tcl:192
+#: ../gui/tcltk/gis.m/legend.tcl:219 ../gui/tcltk/gis.m/legend.tcl:222
#: ../gui/tcltk/gis.m/raster.tcl:192 ../gui/tcltk/gis.m/raster.tcl:196
#: ../gui/tcltk/gis.m/chart.tcl:184 ../gui/tcltk/gis.m/chart.tcl:188
#: ../gui/tcltk/gis.m/vector.tcl:330 ../gui/tcltk/gis.m/vector.tcl:334
@@ -790,7 +791,7 @@
#: ../gui/tcltk/gis.m/frames.tcl:275 ../gui/tcltk/gis.m/animate.tcl:91
#: ../gui/tcltk/gis.m/mapprint.tcl:194 ../gui/tcltk/gis.m/mapprint.tcl:201
#: ../gui/tcltk/gis.m/gridline.tcl:99 ../gui/tcltk/gis.m/gridline.tcl:406
-#: ../gui/tcltk/gis.m/legend.tcl:95 ../gui/tcltk/gis.m/legend.tcl:476
+#: ../gui/tcltk/gis.m/legend.tcl:95 ../gui/tcltk/gis.m/legend.tcl:506
#: ../gui/tcltk/gis.m/raster.tcl:86 ../gui/tcltk/gis.m/raster.tcl:463
#: ../gui/tcltk/gis.m/chart.tcl:89 ../gui/tcltk/gis.m/chart.tcl:441
#: ../gui/tcltk/gis.m/vector.tcl:194 ../gui/tcltk/gis.m/vector.tcl:819
@@ -841,7 +842,7 @@
#: ../gui/tcltk/gis.m/thematic.tcl:223 ../gui/tcltk/gis.m/labels.tcl:118
#: ../gui/tcltk/gis.m/rastarrows.tcl:147 ../gui/tcltk/gis.m/rastnums.tcl:146
-#: ../gui/tcltk/gis.m/gridline.tcl:147 ../gui/tcltk/gis.m/legend.tcl:172
+#: ../gui/tcltk/gis.m/gridline.tcl:147 ../gui/tcltk/gis.m/legend.tcl:200
#: ../gui/tcltk/gis.m/raster.tcl:168 ../gui/tcltk/gis.m/chart.tcl:166
#: ../gui/tcltk/gis.m/vector.tcl:306 ../gui/tcltk/gis.m/cmd.tcl:105
#: ../gui/tcltk/gis.m/barscale.tcl:160 ../gui/tcltk/gis.m/rgbhis.tcl:143
@@ -851,7 +852,7 @@
#: ../gui/tcltk/gis.m/thematic.tcl:227 ../gui/tcltk/gis.m/labels.tcl:122
#: ../gui/tcltk/gis.m/rastarrows.tcl:151 ../gui/tcltk/gis.m/rastnums.tcl:150
-#: ../gui/tcltk/gis.m/gridline.tcl:151 ../gui/tcltk/gis.m/legend.tcl:176
+#: ../gui/tcltk/gis.m/gridline.tcl:151 ../gui/tcltk/gis.m/legend.tcl:204
#: ../gui/tcltk/gis.m/raster.tcl:172 ../gui/tcltk/gis.m/chart.tcl:170
#: ../gui/tcltk/gis.m/cmd.tcl:109 ../gui/tcltk/gis.m/barscale.tcl:164
#: ../gui/tcltk/gis.m/rgbhis.tcl:147 ../gui/tcltk/gis.m/dtext.tcl:170
@@ -1275,6 +1276,10 @@
msgid "Output - GIS.m"
msgstr "Salida - GIS.m"
+#: ../gui/tcltk/gis.m/runandoutput.tcl:266
+msgid "This module requires X11 support, but no xmons were found"
+msgstr ""
#: ../gui/tcltk/gis.m/maptool.tcl:41 ../gui/tcltk/gis.m/georecttool.tcl:40
msgid "Display active layers"
msgstr "Visualizar capas activas"
@@ -1345,7 +1350,7 @@
"visualización"
#: ../gui/tcltk/gis.m/maptool.tcl:228 ../gui/tcltk/gis.m/gmmenu.tcl:615
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1857 ../gui/tcltk/d.m/menu.tcl:554
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1859 ../gui/tcltk/d.m/menu.tcl:554
msgid "Query"
msgstr "Consultas"
@@ -1440,7 +1445,7 @@
msgstr " fuente de valores de celda "
#: ../gui/tcltk/gis.m/rastnums.tcl:180 ../gui/tcltk/gis.m/gridline.tcl:187
-#: ../gui/tcltk/gis.m/legend.tcl:234 ../gui/tcltk/gis.m/barscale.tcl:204
+#: ../gui/tcltk/gis.m/legend.tcl:264 ../gui/tcltk/gis.m/barscale.tcl:204
#: ../gui/tcltk/gis.m/maptext.tcl:180 ../gui/tcltk/gis.m/dtext.tcl:226
#: ../gui/tcltk/gis.m/histogram.tcl:177
msgid "select font for text"
@@ -1686,7 +1691,17 @@
msgid "Layers loaded"
msgstr "Capas cargadas"
-#: ../gui/tcltk/gis.m/gmtree.tcl:1171
+#: ../gui/tcltk/gis.m/gmtree.tcl:1166
+#, fuzzy
+msgid "Selected raster layer is empty"
+msgstr "Añandir capa ráster"
+#: ../gui/tcltk/gis.m/gmtree.tcl:1177
+#, fuzzy
+msgid "Selected vector layer is empty"
+msgstr "Añadir capa vectorial"
+#: ../gui/tcltk/gis.m/gmtree.tcl:1183
msgid "You can digitize raster or vector maps only"
msgstr "Sólo se pueden digitalizar mapas ráster o vectoriales"
@@ -3477,116 +3492,116 @@
msgid "legend for %s"
msgstr "leyenda para %s"
-#: ../gui/tcltk/gis.m/legend.tcl:165
+#: ../gui/tcltk/gis.m/legend.tcl:193
msgid "Display legend for raster map using cat values and labels"
msgstr ""
"Mostrar leyenda para mapa ráster usando valores de categorÃas y etiquetas"
-#: ../gui/tcltk/gis.m/legend.tcl:182
+#: ../gui/tcltk/gis.m/legend.tcl:210
msgid "Raster map: "
msgstr "Mapa ráster: "
-#: ../gui/tcltk/gis.m/legend.tcl:199
+#: ../gui/tcltk/gis.m/legend.tcl:229
#, tcl-format
msgid "Legend placement and size as 0-100% of display"
msgstr "Posición y tamaño de la leyenda como 0-100% of de la visualización"
-#: ../gui/tcltk/gis.m/legend.tcl:205
+#: ../gui/tcltk/gis.m/legend.tcl:235
#, tcl-format
msgid " x,y of lower left corner (in % from display top left)"
msgstr ""
" X,Y de la esquina inferior izquierda (en % f desde superior izquierda de "
"la visualización)"
-#: ../gui/tcltk/gis.m/legend.tcl:208 ../gui/tcltk/gis.m/barscale.tcl:191
+#: ../gui/tcltk/gis.m/legend.tcl:238 ../gui/tcltk/gis.m/barscale.tcl:191
#: ../gui/tcltk/gis.m/maptext.tcl:150 ../gui/tcltk/gis.m/dtext.tcl:197
msgid "place with mouse"
msgstr "situar con ratón"
-#: ../gui/tcltk/gis.m/legend.tcl:216
+#: ../gui/tcltk/gis.m/legend.tcl:246
msgid " legend height "
msgstr " altura de la leyenda "
-#: ../gui/tcltk/gis.m/legend.tcl:218
+#: ../gui/tcltk/gis.m/legend.tcl:248
#, tcl-format
msgid "Legend height (% of display)"
msgstr "Altura de la leyenda (% o de la visualización)"
-#: ../gui/tcltk/gis.m/legend.tcl:219
+#: ../gui/tcltk/gis.m/legend.tcl:249
msgid "% width"
msgstr "% anchura"
-#: ../gui/tcltk/gis.m/legend.tcl:221
+#: ../gui/tcltk/gis.m/legend.tcl:251
#, tcl-format
msgid "Legend width (% of display)"
msgstr "Anchura de la leyenda (% of de la visualización)"
-#: ../gui/tcltk/gis.m/legend.tcl:228
+#: ../gui/tcltk/gis.m/legend.tcl:258
msgid "Legend appearance: text color"
msgstr "Apariencia de la leyenda: color de texto"
-#: ../gui/tcltk/gis.m/legend.tcl:232
+#: ../gui/tcltk/gis.m/legend.tcl:262
msgid " legend text font "
msgstr " fuente de texto de la leyenda "
-#: ../gui/tcltk/gis.m/legend.tcl:243
+#: ../gui/tcltk/gis.m/legend.tcl:273
msgid "do not display labels"
msgstr "no mostrar etiquetas"
-#: ../gui/tcltk/gis.m/legend.tcl:245
+#: ../gui/tcltk/gis.m/legend.tcl:275
msgid "do not display values"
msgstr "no mostrar valores"
-#: ../gui/tcltk/gis.m/legend.tcl:252
+#: ../gui/tcltk/gis.m/legend.tcl:282
msgid " number of lines (0=display all):"
msgstr " número de lÃneas (0=mostrar todas):"
-#: ../gui/tcltk/gis.m/legend.tcl:254
+#: ../gui/tcltk/gis.m/legend.tcl:284
msgid "Lines to display"
msgstr "LÃneas a visualizar"
-#: ../gui/tcltk/gis.m/legend.tcl:256
+#: ../gui/tcltk/gis.m/legend.tcl:286
msgid "invert legend"
msgstr "invertir leyenda"
-#: ../gui/tcltk/gis.m/legend.tcl:263
+#: ../gui/tcltk/gis.m/legend.tcl:293
msgid " interval between categories (integer maps)"
msgstr " intervalo entre categorÃas (mapas enteros)"
-#: ../gui/tcltk/gis.m/legend.tcl:265
+#: ../gui/tcltk/gis.m/legend.tcl:295
msgid "Thinning interval"
msgstr "Intervalo de adelgazamiento"
-#: ../gui/tcltk/gis.m/legend.tcl:272
+#: ../gui/tcltk/gis.m/legend.tcl:302
msgid "draw smooth gradient (fp maps)"
msgstr "Dibujar gradiente suavizado (fp mapas)"
-#: ../gui/tcltk/gis.m/legend.tcl:274
+#: ../gui/tcltk/gis.m/legend.tcl:304
msgid "with maximum of"
msgstr "con máximo de "
-#: ../gui/tcltk/gis.m/legend.tcl:276
+#: ../gui/tcltk/gis.m/legend.tcl:306
msgid "Maximum lines to display for gradient"
msgstr "Máximo de lÃneas a mostrar para gradiente"
-#: ../gui/tcltk/gis.m/legend.tcl:277 ../gui/tcltk/gis.m/chart.tcl:196
+#: ../gui/tcltk/gis.m/legend.tcl:307 ../gui/tcltk/gis.m/chart.tcl:196
#: ../gui/tcltk/d.m/chart.tcl:108 ../gui/tcltk/d.m/vector.tcl:229
msgid "lines"
msgstr "lÃneas"
-#: ../gui/tcltk/gis.m/legend.tcl:283
+#: ../gui/tcltk/gis.m/legend.tcl:313
msgid "Display legend for subset of raster values"
msgstr "Mostrar leyenda para subconjunto de valores ráster"
-#: ../gui/tcltk/gis.m/legend.tcl:290
+#: ../gui/tcltk/gis.m/legend.tcl:320
msgid "skip categories with no labels"
msgstr "ignorar categorÃas sin etiquetas"
-#: ../gui/tcltk/gis.m/legend.tcl:297
+#: ../gui/tcltk/gis.m/legend.tcl:327
msgid " legend for only these categories "
msgstr " leyenda sólo para estas categorÃas "
-#: ../gui/tcltk/gis.m/legend.tcl:304
+#: ../gui/tcltk/gis.m/legend.tcl:334
msgid " legend for only this range of values"
msgstr " leyenda sólo para este rango de valores"
@@ -3685,6 +3700,10 @@
msgid " color"
msgstr " color "
+#: ../gui/tcltk/gis.m/maplabels.tcl:326
+msgid "Could not open labels file "
+msgstr ""
#: ../gui/tcltk/gis.m/raster.tcl:127
msgid "Raster drape map"
msgstr "Mapa de cobertura ráster"
@@ -4039,8 +4058,8 @@
msgid "Maximum zoom-in reached"
msgstr "Máximo aumento de zum alcanzado"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:593 ../gui/tcltk/gis.m/mapcanvas.tcl:1136
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1217 ../gui/tcltk/gis.m/georect.tcl:1576
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:593 ../gui/tcltk/gis.m/mapcanvas.tcl:1219
+#: ../gui/tcltk/gis.m/georect.tcl:1576
msgid "Error setting region"
msgstr "Error al establecer la región"
@@ -4048,11 +4067,11 @@
msgid "please wait..."
msgstr "por favor espere..."
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:760 ../gui/tcltk/gis.m/mapcanvas.tcl:1811
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:760 ../gui/tcltk/gis.m/mapcanvas.tcl:1813
msgid "You have to select map layer first"
msgstr "Tiene que seleccionar la capa del mapa primero"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:761 ../gui/tcltk/gis.m/mapcanvas.tcl:1812
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:761 ../gui/tcltk/gis.m/mapcanvas.tcl:1814
msgid "No map layer selected"
msgstr "Ninguna capa de mapa seleccionada"
@@ -4082,43 +4101,48 @@
msgid "Display: rows=%d cols=%d N-S res=%g E-W res=%g"
msgstr "Mostrar: filas=%d columnas=%d resolución N-S=%g resolución E-W=%g"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1182
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1136
+#, fuzzy
+msgid "Error setting region (Problem with g.region?)"
+msgstr "Error al leer la resolución actual con g.region"
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1182 ../gui/tcltk/gis.m/mapcanvas.tcl:1187
msgid "Error reading current resolution with g.region"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1242 ../gui/tcltk/gis.m/georect.tcl:2018
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1244 ../gui/tcltk/gis.m/georect.tcl:2018
msgid "Drag or click mouse to zoom"
msgstr "Arrastrar o clic de ratón para hacer zum"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1244 ../gui/tcltk/gis.m/georect.tcl:2020
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1246 ../gui/tcltk/gis.m/georect.tcl:2020
msgid "Drag or click mouse to unzoom"
msgstr "Arrastrar o clic de ratón para deshacer zum"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1479 ../gui/tcltk/gis.m/georect.tcl:2218
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1481 ../gui/tcltk/gis.m/georect.tcl:2218
msgid "Drag with mouse to pan"
msgstr "Arrastrar con el ratón para panorámica"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1606
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1608
msgid "Measurement"
msgstr "Medida"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1625
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1627
msgid "Draw measure line with mouse"
msgstr "Dibujar lÃnea de medida con el ratón"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1782
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1784
msgid "Click to query feature"
msgstr "Hacer clic para consultar elemento"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1850
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1852
msgid "This layer type does not support queries"
msgstr "Este tipo de capa no soporta consultas"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1851
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1853
msgid "Query not supported"
msgstr "Consulta no soportada"
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1858
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1860
msgid "You must select a map to query\n"
msgstr "Se debe seleccionar un mapa a consultar\n"
Modified: grass/branches/develbranch_6/locale/po/grasstcl_ru.po
--- grass/branches/develbranch_6/locale/po/grasstcl_ru.po 2008-05-06 19:11:33 UTC (rev 31269)
+++ grass/branches/develbranch_6/locale/po/grasstcl_ru.po 2008-05-06 20:47:18 UTC (rev 31270)
@@ -6,7 +6,7 @@
msgstr ""
"Project-Id-Version: grasstcl_ru\n"
-"POT-Creation-Date: 2008-01-24 17:42+0100\n"
"PO-Revision-Date: 2006-07-07 11:53+0200\n"
"Last-Translator: Markus Neteler <neteler at itc.it>\n"
"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -36,8 +36,9 @@
msgstr ""
#: ../vector/v.digit/settings.tcl:160 ../lib/init/epsg_option.tcl:311
-#: ../gui/tcltk/gis.m/gm.tcl:430 ../gui/tcltk/gis.m/animate.tcl:536
-#: ../gui/tcltk/gis.m/dnviz.tcl:228 ../gui/tcltk/gis.m/rules.tcl:170
+#: ../lib/init/file_option.tcl:263 ../gui/tcltk/gis.m/gm.tcl:430
+#: ../gui/tcltk/gis.m/animate.tcl:536 ../gui/tcltk/gis.m/dnviz.tcl:228
+#: ../gui/tcltk/gis.m/rules.tcl:170
msgid "OK"
msgstr ""
@@ -212,11 +213,11 @@
msgid "Pan"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:194 ../gui/tcltk/gis.m/maptool.tcl:196
+#: ../vector/v.digit/toolbox.tcl:194
msgid "Zoom to default region"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:207 ../gui/tcltk/gis.m/maptool.tcl:187
+#: ../vector/v.digit/toolbox.tcl:207
msgid "Zoom to saved region"
msgstr ""
@@ -282,20 +283,22 @@
#: ../lib/gtcltk/select.tcl:209 ../lib/init/epsg_option.tcl:167
#: ../lib/init/epsg_option.tcl:314 ../lib/init/file_option.tcl:114
-#: ../gui/tcltk/gis.m/gm.tcl:433 ../gui/tcltk/gis.m/animate.tcl:538
-#: ../gui/tcltk/gis.m/dnviz.tcl:230 ../gui/tcltk/gis.m/mapcanvas.tcl:855
-#: ../gui/tcltk/gis.m/georect.tcl:700 ../gui/tcltk/gis.m/rules.tcl:172
+#: ../lib/init/file_option.tcl:266 ../gui/tcltk/gis.m/gm.tcl:433
+#: ../gui/tcltk/gis.m/animate.tcl:538 ../gui/tcltk/gis.m/dnviz.tcl:230
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:855 ../gui/tcltk/gis.m/georect.tcl:700
+#: ../gui/tcltk/gis.m/rules.tcl:172
#, fuzzy
msgid "Cancel"
msgstr "ïÔÍÅÎÉÔØ"
-#: ../gui/tcltk/gis.m/grassabout.tcl:94 ../gui/tcltk/gis.m/gmlib.tcl:131
+#: ../gui/tcltk/gis.m/grassabout.tcl:94 ../gui/tcltk/gis.m/gmlib.tcl:137
msgid "Error"
msgstr ""
-#: ../lib/gis/gui.tcl:229 ../gui/tcltk/gis.m/gmlib.tcl:113
+#: ../lib/gis/gui.tcl:229 ../gui/tcltk/gis.m/gmlib.tcl:119
msgid "Save File"
msgstr ""
@@ -333,7 +336,7 @@
@@ -467,11 +470,13 @@
msgstr ""
#: ../lib/init/epsg_option.tcl:236 ../lib/init/epsg_option.tcl:263
+#: ../lib/init/file_option.tcl:185 ../lib/init/file_option.tcl:212
#, fuzzy
msgid "Error creating location!"
msgstr "ðòåäõðòåöäåîéå"
#: ../lib/init/epsg_option.tcl:237 ../lib/init/epsg_option.tcl:264
+#: ../lib/init/file_option.tcl:186 ../lib/init/file_option.tcl:213
#, tcl-format
msgid ""
"g.proj returned the following message:\n"
@@ -479,21 +484,23 @@
msgstr ""
#: ../lib/init/epsg_option.tcl:244 ../lib/init/epsg_option.tcl:268
+#: ../lib/init/file_option.tcl:193 ../lib/init/file_option.tcl:217
msgid "Informational output from g.proj"
msgstr ""
#: ../lib/init/epsg_option.tcl:245 ../lib/init/epsg_option.tcl:269
+#: ../lib/init/file_option.tcl:194 ../lib/init/file_option.tcl:218
#, tcl-format
msgid ""
"g.proj returned the following informational message:\n"
"%s"
msgstr ""
-#: ../lib/init/epsg_option.tcl:288
+#: ../lib/init/epsg_option.tcl:288 ../lib/init/file_option.tcl:240
msgid "Select datum transformation parameters:"
msgstr ""
-#: ../lib/init/epsg_option.tcl:292
+#: ../lib/init/epsg_option.tcl:292 ../lib/init/file_option.tcl:244
msgid ""
"Continue without specifying parameters - if used when creating a location, "
"other GRASS modules will use the \"default\" (likely non-optimum) parameters "
@@ -753,20 +760,6 @@
"valid georeferenced file"
msgstr ""
-#: ../lib/init/file_option.tcl:184
-#, fuzzy
-msgid "WARNING: Error creating new location"
-msgstr "ðòåäõðòåöäåîéå"
-#: ../lib/init/file_option.tcl:185
-#, tcl-format
-msgid ""
-"Error creating new location from georeferenced file. g.proj returned "
-"following message:\n"
-"\n"
-"%s"
-msgstr ""
#: ../gui/tcltk/gis.m/thematic.tcl:107 ../gui/tcltk/gis.m/thematic.tcl:607
#: ../gui/tcltk/gis.m/thematic.tcl:680 ../gui/tcltk/gis.m/labels.tcl:78
#: ../gui/tcltk/gis.m/labels.tcl:279 ../gui/tcltk/gis.m/rastarrows.tcl:83
@@ -775,7 +768,7 @@
@@ -825,7 +818,7 @@
@@ -835,7 +828,7 @@
@@ -1261,6 +1254,10 @@
msgstr ""
+msgstr ""
msgstr ""
@@ -1305,24 +1302,33 @@
#: ../gui/tcltk/gis.m/maptool.tcl:184
#, fuzzy
-msgid "Zoom to selected map"
+msgid "Zoom display to selected map"
msgstr "×ÅËÔÏÒ"
+#: ../gui/tcltk/gis.m/maptool.tcl:187
+#, fuzzy
+msgid "Zoom display to saved region"
+msgstr "×ÅËÔÏÒ "
#: ../gui/tcltk/gis.m/maptool.tcl:190
#, fuzzy
-msgid "Save display geometry to named region"
+msgid "Save display extents to named region"
msgstr "×ÅËÔÏÒ "
#: ../gui/tcltk/gis.m/maptool.tcl:193
-msgid "Zoom to current region (set with g.region)"
+msgid "Zoom display to computational region (set with g.region)"
msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:196
+msgid "Zoom display to default region"
+msgstr ""
#: ../gui/tcltk/gis.m/maptool.tcl:199
-msgid "Set current region (WIND file) to match display"
+msgid "Set computational region extents to match display"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1829 ../gui/tcltk/d.m/menu.tcl:554
msgid "Query"
msgstr ""
@@ -1420,7 +1426,7 @@
msgstr "×ÅËÔÏÒ"
@@ -1663,8 +1669,17 @@
msgstr ""
+msgstr ""
#, fuzzy
+msgstr "×ÅËÔÏÒ"
+#, fuzzy
msgstr "×ÅËÔÏÒ"
@@ -2556,7 +2571,7 @@
#: ../gui/tcltk/gis.m/gmmenu.tcl:400
#, fuzzy
-msgid "Report category information"
+msgid "Manage category information"
msgstr "×ÅËÔÏÒ"
#: ../gui/tcltk/gis.m/gmmenu.tcl:402 ../gui/tcltk/d.m/menu.tcl:358
@@ -2630,68 +2645,68 @@
msgid "Clean vector"
msgstr "×ÅËÔÏÒ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:426
+#: ../gui/tcltk/gis.m/gmmenu.tcl:425
+msgid "Generalization"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:427
#, fuzzy
msgid "Convert object types"
msgstr "×ÅËÔÏÒ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:428
+#: ../gui/tcltk/gis.m/gmmenu.tcl:429
msgid "Add centroids"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:430
+#: ../gui/tcltk/gis.m/gmmenu.tcl:431
msgid "Build polylines"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:431
+#: ../gui/tcltk/gis.m/gmmenu.tcl:432
msgid "Split polylines"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:432
+#: ../gui/tcltk/gis.m/gmmenu.tcl:433
msgid "Parallel lines"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:434
+#: ../gui/tcltk/gis.m/gmmenu.tcl:435
msgid "Dissolve boundaries"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:436
+#: ../gui/tcltk/gis.m/gmmenu.tcl:437
#, fuzzy
msgid "Create 3D vector over raster"
msgstr "×ÅËÔÏÒ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:437
+#: ../gui/tcltk/gis.m/gmmenu.tcl:438
#, fuzzy
msgid "Extrude 3D vector"
msgstr "×ÅËÔÏÒ ×ÅËÔÏÒ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:439
+#: ../gui/tcltk/gis.m/gmmenu.tcl:440
msgid "Link to OGR"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:441
+#: ../gui/tcltk/gis.m/gmmenu.tcl:442
#, fuzzy
msgid "Create labels"
msgstr "óÏÚÄÁÔØ..."
-#: ../gui/tcltk/gis.m/gmmenu.tcl:443
+#: ../gui/tcltk/gis.m/gmmenu.tcl:444
#, fuzzy
msgid "Reposition vector"
msgstr "×ÅËÔÏÒ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:444
+#: ../gui/tcltk/gis.m/gmmenu.tcl:445
#, fuzzy
msgid "Reproject vector"
msgstr "×ÅËÔÏÒ"
-#: ../gui/tcltk/gis.m/gmmenu.tcl:446
+#: ../gui/tcltk/gis.m/gmmenu.tcl:447
msgid "Metadata support"
msgstr ""
-#: ../gui/tcltk/gis.m/gmmenu.tcl:448
-msgid "Generalization"
-msgstr ""
#: ../gui/tcltk/gis.m/gmmenu.tcl:451
#, fuzzy
msgid "Query with attributes"
@@ -3508,115 +3523,115 @@
msgstr ""
msgstr ""
#, fuzzy
msgstr "×ÅËÔÏÒ"
#, tcl-format
msgstr ""
#, tcl-format
msgstr ""
msgstr ""
msgstr ""
#, tcl-format
msgstr ""
msgid "% width"
msgstr ""
#, tcl-format
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
#, fuzzy
msgstr "×ÅËÔÏÒ"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgid "lines"
msgstr ""
msgstr ""
msgstr ""
msgstr ""
msgstr ""
@@ -3717,6 +3732,10 @@
msgid " color"
msgstr ""
+msgstr ""
#, fuzzy
@@ -4086,8 +4105,8 @@
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1189 ../gui/tcltk/gis.m/georect.tcl:1576
msgstr ""
@@ -4095,11 +4114,11 @@
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:760 ../gui/tcltk/gis.m/mapcanvas.tcl:1783
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:761 ../gui/tcltk/gis.m/mapcanvas.tcl:1784
msgstr ""
@@ -4122,59 +4141,52 @@
"Do you want to overwrite it?"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1061
-#, tcl-format
-msgid "Display: rows=%d columns=%d resolution=%g %s"
-msgstr ""
#: ../gui/tcltk/gis.m/mapcanvas.tcl:1064
#, tcl-format
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1214 ../gui/tcltk/gis.m/georect.tcl:2018
+msgstr ""
+msgid "Error reading current resolution with g.region"
+msgstr ""
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1216 ../gui/tcltk/gis.m/georect.tcl:2020
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1451 ../gui/tcltk/gis.m/georect.tcl:2218
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1578
msgid "Measurement"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1597
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1687
-#, tcl-format
-msgid " --segment length = %s\n"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1689
-#, tcl-format
-msgid "cumulative length = %s\n"
-msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1754
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1822
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1823
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1830
msgstr ""
@@ -4656,19 +4668,19 @@
msgid "r.info error"
msgstr ""
-#: ../gui/tcltk/gis.m/gmlib.tcl:79 ../gui/tcltk/gis.m/gmlib.tcl:108
+#: ../gui/tcltk/gis.m/gmlib.tcl:85 ../gui/tcltk/gis.m/gmlib.tcl:114
msgid "Map Resource File"
msgstr ""
-#: ../gui/tcltk/gis.m/gmlib.tcl:80 ../gui/tcltk/gis.m/gmlib.tcl:110
+#: ../gui/tcltk/gis.m/gmlib.tcl:86 ../gui/tcltk/gis.m/gmlib.tcl:116
msgid "All Files"
msgstr ""
-#: ../gui/tcltk/gis.m/gmlib.tcl:84
+#: ../gui/tcltk/gis.m/gmlib.tcl:90
msgid "Open File"
msgstr ""
-#: ../gui/tcltk/gis.m/gmlib.tcl:109
+#: ../gui/tcltk/gis.m/gmlib.tcl:115
msgid "DM Resource File"
msgstr ""
@@ -5487,7 +5499,7 @@
msgstr "ëÒÉ×ÉÚÎÁ ÓÐÌÁÊÎÁ"
#: ../gui/tcltk/d.m/menu.tcl:356
-msgid "Report category labels and values"
+msgid "Manage category labels and values"
msgstr ""
#: ../gui/tcltk/d.m/menu.tcl:359
@@ -6171,6 +6183,10 @@
msgstr ""
#, fuzzy
+#~ msgid "WARNING: Error creating new location"
+#~ msgstr "ðòåäõðòåöäåîéå"
+#, fuzzy
#~ msgid "Convert vector lines to points"
#~ msgstr "×ÅËÔÏÒ"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_es.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_es.po 2008-05-06 19:11:33 UTC (rev 31269)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_es.po 2008-05-06 20:47:18 UTC (rev 31270)
@@ -3,11 +3,12 @@
# This file is distributed under the same license as the PACKAGE package.
# Carlos Davila <carluti at users.sourceforge.net>, 2008.
+#: ../gui/wxpython/icons/icon.py:303
msgid ""
msgstr ""
"Project-Id-Version: grasswxpy_es\n"
-"POT-Creation-Date: 2008-04-11 20:52+0200\n"
+"POT-Creation-Date: 2008-05-05 17:48+0200\n"
"PO-Revision-Date: 2008-04-13 00:21+0200\n"
@@ -17,16 +18,460 @@
"X-Generator: KBabel 1.11.4\n"
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
-#: ../gui/wxpython/icons/icon.py:153
+#: ../gui/wxpython/icons/icon.py:159
msgid "Unable to load icon theme, using default icon theme..."
msgstr "No se puede cargar el tema de iconos, se usa el predeterminado..."
+#: ../gui/wxpython/icons/icon.py:225
+#, fuzzy
+msgid "Display map"
+msgstr "Mostrar"
+#: ../gui/wxpython/icons/icon.py:227
+#, fuzzy
+msgid "Re-render map"
+msgstr "ráster:"
+#: ../gui/wxpython/icons/icon.py:228
+msgid "Force re-rendering of all layers"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:230
+#, fuzzy
+msgid "Erase display"
+msgstr "Mostrar"
+#: ../gui/wxpython/icons/icon.py:232
+msgid "Pointer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:234
+msgid "Zoom in"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:235
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:237
+msgid "Zoom out"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:238
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:240
+#, fuzzy
+msgid "Pan"
+msgstr "Plano"
+#: ../gui/wxpython/icons/icon.py:241
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:243
+msgid "Query raster/vector map(s) (display mode)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:244
+#, fuzzy
+msgid "Query selected raster/vector map(s)"
+msgstr "Consulta vectorial"
+#: ../gui/wxpython/icons/icon.py:246
+#, fuzzy
+msgid "Query vector map (editable mode)"
+msgstr "Consultar datos de vectorial"
+#: ../gui/wxpython/icons/icon.py:247
+msgid "Query selected vector map in editable mode"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:249
+msgid "Return to previous zoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:251
+#, fuzzy
+msgid "Zoom options"
+msgstr "Establecer opciones"
+#: ../gui/wxpython/icons/icon.py:252
+msgid "Display zoom management"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:254
+#, fuzzy
+msgid "Add overlay"
+msgstr "Añadir capa de texto"
+#: ../gui/wxpython/icons/icon.py:255
+msgid "Add graphic overlays to map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:257
+msgid "Add scalebar and north arrow"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:259
+#, fuzzy
+msgid "Add legend"
+msgstr "Añadir centroides"
+#: ../gui/wxpython/icons/icon.py:261
+msgid "Save display to PNG file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:263
+#, fuzzy
+msgid "Print display"
+msgstr "Mostrar"
+#: ../gui/wxpython/icons/icon.py:266
+msgid "Start new display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:268
+#, fuzzy
+msgid "Create new workspace file"
+msgstr "Cerrar archivo de entorno de trabajo actual"
+#: ../gui/wxpython/icons/icon.py:270
+msgid "Load map layers into workspace"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/gui_modules/menudata.py:35
+msgid "Open existing workspace file"
+msgstr "Abrir archivo de entorno de trabajo existente"
+#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/gui_modules/menudata.py:50
+msgid "Save current workspace to file"
+msgstr "Guardar entorno de trabajo actual a archivo"
+#: ../gui/wxpython/icons/icon.py:277
+#, fuzzy
+msgid "Add raster map layer"
+#: ../gui/wxpython/icons/icon.py:279
+#, fuzzy
+msgid "Add vector map layer"
+#: ../gui/wxpython/icons/icon.py:281
+#, fuzzy
+msgid "Add command layer"
+#: ../gui/wxpython/icons/icon.py:283
+#, fuzzy
+msgid "Add layer group"
+msgstr "Capa:"
+#: ../gui/wxpython/icons/icon.py:285
+msgid "Add grid or vector labels overlay"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:287 ../gui/wxpython/gui_modules/dbm.py:2213
+#, fuzzy
+msgid "Delete selected layer"
+msgstr "Borrar"
+#: ../gui/wxpython/icons/icon.py:289
+msgid "Quit"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:291
+#, fuzzy
+msgid "Show attribute table"
+msgstr "datos"
+#: ../gui/wxpython/icons/icon.py:293
+#, fuzzy
+msgid "Add RGB layer"
+#: ../gui/wxpython/icons/icon.py:295
+#, fuzzy
+msgid "Add HIS layer"
+#: ../gui/wxpython/icons/icon.py:297
+#, fuzzy
+msgid "Add shaded relief map layer"
+msgstr "Relieve sombreado"
+#: ../gui/wxpython/icons/icon.py:299
+#, fuzzy
+msgid "Add raster flow arrows"
+msgstr "ráster"
+#: ../gui/wxpython/icons/icon.py:301
+#, fuzzy
+msgid "Add raster cell numbers"
+msgstr "ráster"
+#: ../gui/wxpython/icons/icon.py:305
+#, fuzzy
+msgid "Add thematic layer"
+#: ../gui/wxpython/icons/icon.py:307
+#, fuzzy
+msgid "Add thematic chart layer"
+#: ../gui/wxpython/icons/icon.py:309
+#, fuzzy
+msgid "Add grid layer"
+#: ../gui/wxpython/icons/icon.py:311
+msgid "Add geodesic line layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:313
+#, fuzzy
+msgid "Add rhumbline layer"
+#: ../gui/wxpython/icons/icon.py:315
+#, fuzzy
+msgid "Add labels"
+msgstr "Crear etiquetas"
+#: ../gui/wxpython/icons/icon.py:317
+#: ../gui/wxpython/gui_modules/mapdisp.py:3353
+msgid "Add text layer"
+#: ../gui/wxpython/icons/icon.py:320
+#, fuzzy
+msgid "Digitize new point"
+msgstr "Digitalizar"
+#: ../gui/wxpython/icons/icon.py:321 ../gui/wxpython/icons/icon.py:330
+#, fuzzy
+msgid "Left: new point"
+msgstr "Generar puntos"
+#: ../gui/wxpython/icons/icon.py:323
+#, fuzzy
+msgid "Digitize new line"
+#: ../gui/wxpython/icons/icon.py:324 ../gui/wxpython/icons/icon.py:327
+#: ../gui/wxpython/icons/icon.py:348
+msgid "Left: new point; Middle: undo last point; Right: close line"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:326
+#, fuzzy
+msgid "Digitize new boundary"
+#: ../gui/wxpython/icons/icon.py:329
+#, fuzzy
+msgid "Digitize new centroid"
+#: ../gui/wxpython/icons/icon.py:332
+#, fuzzy
+msgid "Add new vertex"
+msgstr "Añadir categorÃa nueva"
+#: ../gui/wxpython/icons/icon.py:333 ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/icons/icon.py:339 ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:354 ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:363 ../gui/wxpython/icons/icon.py:369
+msgid "Left: Select; Middle: Unselect; Right: Confirm"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:335
+#, fuzzy
+msgid "Copy categories"
+msgstr "Actualizar categorÃas"
+#: ../gui/wxpython/icons/icon.py:338
+#, fuzzy
+msgid "Delete feature(s)"
+msgstr "Borrar"
+#: ../gui/wxpython/icons/icon.py:341
+#, fuzzy
+msgid "Display/update attributes"
+msgstr "Visualizar atributos"
+#: ../gui/wxpython/icons/icon.py:342 ../gui/wxpython/icons/icon.py:345
+msgid "Left: Select"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:344
+#, fuzzy
+msgid "Display/update categories"
+#: ../gui/wxpython/icons/icon.py:347
+msgid "Edit line/boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:350
+#, fuzzy
+msgid "Move feature(s)"
+msgstr "Elementos más próximos"
+#: ../gui/wxpython/icons/icon.py:353
+msgid "Move vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:356
+#, fuzzy
+msgid "Remove vertex"
+msgstr "Eliminar tabla"
+#: ../gui/wxpython/icons/icon.py:359 ../gui/wxpython/icons/icon.py:419
+#, fuzzy
+msgid "Settings"
+msgstr "Mostrar configuración"
+#: ../gui/wxpython/icons/icon.py:360
+#, fuzzy
+msgid "Settings dialog for digitization tool"
+msgstr "Error"
+#: ../gui/wxpython/icons/icon.py:362
+msgid "Split line/boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:365
+#, fuzzy
+msgid "Quit digitization tool"
+msgstr "Error"
+#: ../gui/wxpython/icons/icon.py:367
+msgid "Additional tools (copy, flip, connect, etc.)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:371
+msgid "Undo"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:372
+msgid "Undo previous changes"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:375
+#, fuzzy
+msgid "Analyze map"
+msgstr "Analizar paisaje"
+#: ../gui/wxpython/icons/icon.py:377
+msgid "Measure distance"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:379
+msgid "Draw transect in map display window to profile"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:381
+#, fuzzy
+msgid "Profile surface map"
+msgstr "Interpolar superficies"
+#: ../gui/wxpython/icons/icon.py:383
+msgid "Draw/re-draw profile"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:385
+#, fuzzy
+msgid "Profile options"
+#: ../gui/wxpython/icons/icon.py:387
+#, fuzzy
+msgid "Create histogram of image or raster file"
+msgstr "ráster"
+#: ../gui/wxpython/icons/icon.py:389
+#, fuzzy
+msgid "Select font"
+msgstr "Establecer tipo de letra"
+#: ../gui/wxpython/icons/icon.py:391
+#, fuzzy
+msgid "Select color"
+msgstr "Color"
+#: ../gui/wxpython/icons/icon.py:393
+#, fuzzy
+msgid "Set histogram options"
+#: ../gui/wxpython/icons/icon.py:395
+#, fuzzy
+msgid "Analyze"
+msgstr "Analizar parcelas"
+#: ../gui/wxpython/icons/icon.py:398
+msgid "Set GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:399
+msgid "Define GCP (Ground Control Points)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/gui_modules/menudata.py:417
+msgid "Georectify"
+msgstr "Georrectificar"
+#: ../gui/wxpython/icons/icon.py:403
+msgid "Recalculate RMS error"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:405
+msgid "Redraw GCP markers in map displays"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:407
+msgid "Save GCPs to POINTS file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:409
+msgid "Add new GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:411
+#, fuzzy
+msgid "Delete selected GCP"
+msgstr "Borrar lo seleccionado"
+#: ../gui/wxpython/icons/icon.py:413
+#, fuzzy
+msgid "Clear selected GCP"
+#: ../gui/wxpython/icons/icon.py:415
+msgid "Reload GCPs from selected POINTS file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:417
+msgid "Quit georectification module"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:420
+msgid "Settings dialog for georectification tool"
+msgstr ""
#: ../gui/wxpython/gui_modules/gdialogs.py:50
msgid "Name for new vector map:"
msgstr "Nombre para el nuevo mapa vectorial:"
#: ../gui/wxpython/gui_modules/gdialogs.py:58
-#: ../gui/wxpython/gui_modules/preferences.py:593
+#: ../gui/wxpython/gui_modules/preferences.py:707
msgid "Allow output files to overwrite existing files"
msgstr "Permitir que los archivos de salida sobrescriban archivos existente"
@@ -43,35 +488,40 @@
#: ../gui/wxpython/gui_modules/gdialogs.py:119
#: ../gui/wxpython/gui_modules/location_wizard.py:215
#: ../gui/wxpython/gui_modules/location_wizard.py:528
-#: ../gui/wxpython/gui_modules/location_wizard.py:1323
-#: ../gui/wxpython/gui_modules/location_wizard.py:1633
-#: ../gui/wxpython/gui_modules/location_wizard.py:1734
-#: ../gui/wxpython/gui_modules/location_wizard.py:1808
-#: ../gui/wxpython/gui_modules/location_wizard.py:1909
-#: ../gui/wxpython/gui_modules/location_wizard.py:2076
-#: ../gui/wxpython/gui_modules/location_wizard.py:2095
-#: ../gui/wxpython/gui_modules/location_wizard.py:2402
-#: ../gui/wxpython/gui_modules/menuform.py:1299
-#: ../gui/wxpython/gui_modules/mapdisp.py:967
-#: ../gui/wxpython/gui_modules/mapdisp.py:1554
-#: ../gui/wxpython/gui_modules/digit.py:2227
-#: ../gui/wxpython/gui_modules/digit.py:2375
-#: ../gui/wxpython/gui_modules/digit.py:2402
-#: ../gui/wxpython/gui_modules/dbm.py:1059
-#: ../gui/wxpython/gui_modules/dbm.py:1158
-#: ../gui/wxpython/gui_modules/dbm.py:1240
-#: ../gui/wxpython/gui_modules/dbm.py:1252
-#: ../gui/wxpython/gui_modules/dbm.py:1266
-#: ../gui/wxpython/gui_modules/dbm.py:1359
-#: ../gui/wxpython/gui_modules/dbm.py:1381
-#: ../gui/wxpython/gui_modules/dbm.py:2447
-#: ../gui/wxpython/gui_modules/dbm.py:2485
+#: ../gui/wxpython/gui_modules/location_wizard.py:1330
+#: ../gui/wxpython/gui_modules/location_wizard.py:1641
+#: ../gui/wxpython/gui_modules/location_wizard.py:1742
+#: ../gui/wxpython/gui_modules/location_wizard.py:1816
+#: ../gui/wxpython/gui_modules/location_wizard.py:1917
+#: ../gui/wxpython/gui_modules/location_wizard.py:2084
+#: ../gui/wxpython/gui_modules/location_wizard.py:2103
+#: ../gui/wxpython/gui_modules/location_wizard.py:2410
+#: ../gui/wxpython/gui_modules/georect.py:882
+#: ../gui/wxpython/gui_modules/georect.py:919
+#: ../gui/wxpython/gui_modules/menuform.py:1304
+#: ../gui/wxpython/gui_modules/mapdisp.py:999
+#: ../gui/wxpython/gui_modules/mapdisp.py:1587
+#: ../gui/wxpython/gui_modules/vdigit.py:2271
+#: ../gui/wxpython/gui_modules/vdigit.py:2419
+#: ../gui/wxpython/gui_modules/vdigit.py:2446
+#: ../gui/wxpython/gui_modules/dbm.py:1063
+#: ../gui/wxpython/gui_modules/dbm.py:1162
+#: ../gui/wxpython/gui_modules/dbm.py:1244
+#: ../gui/wxpython/gui_modules/dbm.py:1256
+#: ../gui/wxpython/gui_modules/dbm.py:1270
+#: ../gui/wxpython/gui_modules/dbm.py:1363
+#: ../gui/wxpython/gui_modules/dbm.py:1385
+#: ../gui/wxpython/gui_modules/dbm.py:1506
+#: ../gui/wxpython/gui_modules/dbm.py:1529
+#: ../gui/wxpython/gui_modules/dbm.py:2475
+#: ../gui/wxpython/gui_modules/dbm.py:2513
#: ../gui/wxpython/gui_modules/gcmd.py:54
-#: ../gui/wxpython/gui_modules/gcmd.py:70
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:316
-#: ../gui/wxpython/gui_modules/workspace.py:181 ../gui/wxpython/gis_set.py:668
-#: ../gui/wxpython/wxgui.py:627 ../gui/wxpython/wxgui.py:813
-#: ../gui/wxpython/wxgui.py:837
+#: ../gui/wxpython/gui_modules/gcmd.py:71
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:336
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:361
+#: ../gui/wxpython/gui_modules/workspace.py:230 ../gui/wxpython/gis_set.py:661
+#: ../gui/wxpython/wxgui.py:677 ../gui/wxpython/wxgui.py:867
+#: ../gui/wxpython/wxgui.py:921
msgid "Error"
msgstr "Error"
@@ -119,7 +569,7 @@
msgstr "Rotación:"
#: ../gui/wxpython/gui_modules/gdialogs.py:428
-#: ../gui/wxpython/gui_modules/preferences.py:497
+#: ../gui/wxpython/gui_modules/preferences.py:611
msgid "Set font"
@@ -152,12 +602,12 @@
msgstr "Lista de mapas:"
#: ../gui/wxpython/gui_modules/gdialogs.py:654
-#: ../gui/wxpython/gui_modules/dbm.py:913
+#: ../gui/wxpython/gui_modules/dbm.py:917
msgid "Select all"
msgstr "Seleccionar todo"
#: ../gui/wxpython/gui_modules/gdialogs.py:655
-#: ../gui/wxpython/gui_modules/dbm.py:914
+#: ../gui/wxpython/gui_modules/dbm.py:918
msgid "Deselect all"
msgstr "Deseleccionar todo"
@@ -168,7 +618,7 @@
#: ../gui/wxpython/gui_modules/location_wizard.py:135
#: ../gui/wxpython/gui_modules/location_wizard.py:1064
#: ../gui/wxpython/gui_modules/location_wizard.py:1156
-#: ../gui/wxpython/gui_modules/menuform.py:1130 ../gui/wxpython/gis_set.py:122
+#: ../gui/wxpython/gui_modules/menuform.py:1135 ../gui/wxpython/gis_set.py:122
msgid "Browse"
msgstr "Explorar"
@@ -186,7 +636,7 @@
msgstr "Seleccionar directorio de datos de GRASS:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1733
+#: ../gui/wxpython/gui_modules/location_wizard.py:1741
msgid "Location already exists in GRASS Database."
msgstr "La localización ya existe en la base de datos de GRASS."
@@ -212,7 +662,9 @@
#: ../gui/wxpython/gui_modules/location_wizard.py:252
msgid "Create custom PROJ.4 parameters string for coordinate system"
-msgstr "Crear cadena de parámetros PROJ.4 personalizada para el sistema de coordenadas"
+msgstr ""
+"Crear cadena de parámetros PROJ.4 personalizada para el sistema de "
+"coordenadas"
#: ../gui/wxpython/gui_modules/location_wizard.py:255
#, fuzzy
@@ -256,9 +708,10 @@
msgstr "No se puede leer la lista: %s"
#: ../gui/wxpython/gui_modules/location_wizard.py:627
-#: ../gui/wxpython/gui_modules/location_wizard.py:1333
+#: ../gui/wxpython/gui_modules/location_wizard.py:1341
msgid "Choose method of specifying georeferencing parameters"
-msgstr "Seleccionar método para especificar los parámetros de georreferenciación"
+msgstr ""
+"Seleccionar método para especificar los parámetros de georreferenciación"
#: ../gui/wxpython/gui_modules/location_wizard.py:635
msgid "Select datum with associated ellipsoid"
@@ -337,191 +790,464 @@
msgid "Parameters"
msgstr "Parámetros"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1274
-msgid "Choose EPSG codes file:"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1278
+#, fuzzy
+msgid "Choose EPSG codes file"
msgstr "Seleccionar archivo de códigos EPSG:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1322
+#: ../gui/wxpython/gui_modules/location_wizard.py:1329
#, python-format
msgid "Unable to read EPGS codes: %s"
msgstr "No se pueden leer los códigos EPSG: %s"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1341
+#: ../gui/wxpython/gui_modules/location_wizard.py:1349
msgid "Enter PROJ.4 parameters string:"
msgstr "Introducir cadena de parámetros PROJ.4:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1392
+#: ../gui/wxpython/gui_modules/location_wizard.py:1400
msgid "Summary"
msgstr "Resumen"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1414
+#: ../gui/wxpython/gui_modules/location_wizard.py:1422
msgid "GRASS Database:"
msgstr "Base de datos de GRASS:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1420
+#: ../gui/wxpython/gui_modules/location_wizard.py:1428
msgid "Location Name:"
msgstr "Nombre de la localización:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1426
+#: ../gui/wxpython/gui_modules/location_wizard.py:1434
msgid "Projection:"
msgstr "Proyección:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1465
+#: ../gui/wxpython/gui_modules/location_wizard.py:1473
msgid "PROJ.4 definition:"
msgstr "Definición PROJ.4:"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1507
+#: ../gui/wxpython/gui_modules/location_wizard.py:1515
#, python-format
msgid "Do you want to create GRASS location <%s>?"
msgstr "¿Quiere crear la localización de GRASS <%s>?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1508
+#: ../gui/wxpython/gui_modules/location_wizard.py:1516
msgid "Create new location?"
msgstr "¿Crear nueva localización?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1544
+#: ../gui/wxpython/gui_modules/location_wizard.py:1552
msgid "Define new GRASS Location"
msgstr "Definir nueva localización de GRASS"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1617
+#: ../gui/wxpython/gui_modules/location_wizard.py:1625
msgid "Do you want to set the default region extents and resolution now?"
-msgstr "¿Quiere establecer la extensión y resolución de la región predeterminada ahora?"
+msgstr ""
+"¿Quiere establecer la extensión y resolución de la región predeterminada "
+"ahora?"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1619
+#: ../gui/wxpython/gui_modules/location_wizard.py:1627
#, python-format
msgid "Location <%s> created"
msgstr "Localización <%s> creada"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1632
-#: ../gui/wxpython/gui_modules/location_wizard.py:1731
-#: ../gui/wxpython/gui_modules/location_wizard.py:1807
-#: ../gui/wxpython/gui_modules/location_wizard.py:1908
-#: ../gui/wxpython/gui_modules/location_wizard.py:1973
+#: ../gui/wxpython/gui_modules/location_wizard.py:1640
+#: ../gui/wxpython/gui_modules/location_wizard.py:1739
+#: ../gui/wxpython/gui_modules/location_wizard.py:1815
+#: ../gui/wxpython/gui_modules/location_wizard.py:1916
+#: ../gui/wxpython/gui_modules/location_wizard.py:1981
msgid "Unable to create new location"
msgstr "No se puede crear la nueva localización"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1641
+#: ../gui/wxpython/gui_modules/location_wizard.py:1649
msgid "Location wizard canceled. Location not created."
-msgstr "Se ha cancelado el asistente de localizaciones. La localización no se ha creado."
+msgstr ""
+"Se ha cancelado el asistente de localizaciones. La localización no se ha "
+"creado."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1643
+#: ../gui/wxpython/gui_modules/location_wizard.py:1651
#: ../gui/wxpython/gis_set.py:126
msgid "Location wizard"
msgstr "Asistente de localizaciones"
msgid "EPSG code missing."
msgstr "Falta el código EPSG."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1927
+#: ../gui/wxpython/gui_modules/location_wizard.py:1935
msgid "Select datum transformation"
msgstr "Seleccionar transformación del datum"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1941
+#: ../gui/wxpython/gui_modules/location_wizard.py:1949
msgid "Datum transform is required."
msgstr "Se requiere una transformación del datum."
-#: ../gui/wxpython/gui_modules/location_wizard.py:1974
+#: ../gui/wxpython/gui_modules/location_wizard.py:1982
msgid "file not found"
msgstr "no se ha encontrado el archivo"
-#: ../gui/wxpython/gui_modules/location_wizard.py:1995
+#: ../gui/wxpython/gui_modules/location_wizard.py:2003
msgid "Set default region extent and resolution"
msgstr "Establecer la extensión y resolución de la región predeterminada"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2039
+#: ../gui/wxpython/gui_modules/location_wizard.py:2047
msgid "&Set region"
msgstr "E&stablecer región"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2075
+#: ../gui/wxpython/gui_modules/location_wizard.py:2083
msgid "Invalid location selected."
msgstr "Seleccionada una localizacióŠno válida."
-#: ../gui/wxpython/gui_modules/location_wizard.py:2094
+#: ../gui/wxpython/gui_modules/location_wizard.py:2102
msgid "Invalid region"
msgstr "Región no válida"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2124
+#: ../gui/wxpython/gui_modules/location_wizard.py:2132
msgid "Click here to show 3D settings"
msgstr "Pulse aquà para mostrar configuración 3D"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2125
+#: ../gui/wxpython/gui_modules/location_wizard.py:2133
msgid "Click here to hide 3D settings"
msgstr "Pulse aquà para ocultar configuración 3D"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2148
-#: ../gui/wxpython/gui_modules/location_wizard.py:2429
+#: ../gui/wxpython/gui_modules/location_wizard.py:2156
+#: ../gui/wxpython/gui_modules/location_wizard.py:2437
#, python-format
msgid "Rows: %d"
msgstr "Filas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2149
-#: ../gui/wxpython/gui_modules/location_wizard.py:2430
+#: ../gui/wxpython/gui_modules/location_wizard.py:2157
+#: ../gui/wxpython/gui_modules/location_wizard.py:2438
#, python-format
msgid "Cols: %d"
msgstr "Columnas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2150
-#: ../gui/wxpython/gui_modules/location_wizard.py:2431
+#: ../gui/wxpython/gui_modules/location_wizard.py:2158
+#: ../gui/wxpython/gui_modules/location_wizard.py:2439
#, python-format
msgid "Cells: %d"
msgstr "Celdas: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2191
-#: ../gui/wxpython/gui_modules/location_wizard.py:2433
+#: ../gui/wxpython/gui_modules/location_wizard.py:2199
+#: ../gui/wxpython/gui_modules/location_wizard.py:2441
#, python-format
msgid "Depth: %d"
msgstr "Profundida: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2192
-#: ../gui/wxpython/gui_modules/location_wizard.py:2434
+#: ../gui/wxpython/gui_modules/location_wizard.py:2200
+#: ../gui/wxpython/gui_modules/location_wizard.py:2442
#, python-format
msgid "3D Cells: %d"
msgstr "Celdas 3D: %d"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2195
+#: ../gui/wxpython/gui_modules/location_wizard.py:2203
msgid "Top"
msgstr "Superior"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2203
+#: ../gui/wxpython/gui_modules/location_wizard.py:2211
msgid "Bottom"
msgstr "Inferior"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2211
+#: ../gui/wxpython/gui_modules/location_wizard.py:2219
msgid "T-B resolution"
msgstr "Resolución Sup-Inf"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2274
+#: ../gui/wxpython/gui_modules/location_wizard.py:2282
msgid "North"
msgstr "Norte"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2282
+#: ../gui/wxpython/gui_modules/location_wizard.py:2290
msgid "West"
msgstr "Oeste"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2302
+#: ../gui/wxpython/gui_modules/location_wizard.py:2310
msgid "East"
msgstr "Este"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2311
+#: ../gui/wxpython/gui_modules/location_wizard.py:2319
msgid "South"
msgstr "Sur"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2315
+#: ../gui/wxpython/gui_modules/location_wizard.py:2323
msgid "N-S resolution"
msgstr "Resolución N-S"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2323
+#: ../gui/wxpython/gui_modules/location_wizard.py:2331
msgid "E-W resolution"
msgstr "Resolución E-W"
-#: ../gui/wxpython/gui_modules/location_wizard.py:2401
+#: ../gui/wxpython/gui_modules/location_wizard.py:2409
#, python-format
msgid "Invalid value: %s"
msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:107
+msgid "Setup for georectification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:137
+#: ../gui/wxpython/gui_modules/georect.py:140
+msgid "Georectifying setup canceled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:175
+msgid "Set ground control points (GCPs)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:274
+#, fuzzy
+msgid "Select map type and location/mapset"
+msgstr "ráster"
+#: ../gui/wxpython/gui_modules/georect.py:301
+#, fuzzy
+msgid "Map type to georectify"
+msgstr "Conversiones de tipos de mapa"
+#: ../gui/wxpython/gui_modules/georect.py:302
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:531
+msgid "raster"
+msgstr "ráster"
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:549
+msgid "vector"
+msgstr "vectorial"
+#: ../gui/wxpython/gui_modules/georect.py:308
+#, fuzzy
+msgid "Select source location:"
+msgstr "Borrar localización seleccionada"
+#: ../gui/wxpython/gui_modules/georect.py:319
+#, fuzzy
+msgid "Select source mapset:"
+msgstr "Borrar directorio de mapas seleccionado"
+#: ../gui/wxpython/gui_modules/georect.py:373
+msgid "You must select a valid location before selecting a mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:384
+msgid "You must select a valid location and mapset in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:401
+msgid "Select image/map group to georectify"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:420
+#, fuzzy
+msgid "Select group:"
+msgstr "Color"
+#: ../gui/wxpython/gui_modules/georect.py:431
+msgid "Create group if none exists"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:434
+#, fuzzy
+msgid "Create/edit group..."
+msgstr "Crear/editar grupo"
+#: ../gui/wxpython/gui_modules/georect.py:440
+msgid "Extension for output maps:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:491
+msgid "You must select a valid image/map group in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:496
+msgid "You must enter an map name extension in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:541
+msgid "Select image/map to display for ground control point (GCP) creation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:549
+msgid "Select display image/map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:581
+msgid "You must select a valid image/map in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:605
+msgid "Create & manage ground control points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:696
+#, fuzzy
+msgid "Select rectification method for rasters"
+msgstr "Estimación del área para rásters."
+#: ../gui/wxpython/gui_modules/georect.py:697
+#, fuzzy
+msgid "1st order"
+msgstr "Fast Fourier"
+msgid "2nd order"
+msgstr ""
+msgid "3rd order"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:703
+msgid "Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:774
+#, python-format
+msgid "At least %d GCPs required. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:775
+#, fuzzy
+msgid "Delete GCP"
+msgstr "Borrar"
+#: ../gui/wxpython/gui_modules/georect.py:876
+#, python-format
+msgid "POINTS file <%s> saved"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:877
+msgid "POINTS file saved"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:880
+msgid "Writing POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:917
+msgid "Reading POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:961
+#, fuzzy
+msgid "RMS Error"
+msgstr "Error"
+#: ../gui/wxpython/gui_modules/georect.py:962
+msgid ""
+"Insufficient points defined and active (checked) for selected rectification "
+"method.\n"
+"3+ points needed for 1st order,\n"
+"6+ points for 2nd order, and\n"
+"10+ points for 3rd order."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1033
+#, fuzzy
+msgid "Georectifier settings"
+msgstr "ráster"
+#: ../gui/wxpython/gui_modules/georect.py:1123
+#, python-format
+msgid "RMS error for selected points forward: %s backward: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1156
+msgid "use| X coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1157
+msgid "Y coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1158
+msgid "E coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1159
+msgid "N coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1160
+msgid "Forward error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1161
+msgid "Backward error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1261
+#: ../gui/wxpython/gui_modules/georect.py:1369
+#, fuzzy
+msgid "Edit GCP"
+msgstr "Salir de la GUI"
+#: ../gui/wxpython/gui_modules/georect.py:1262
+msgid "Invalid coordinate value. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1380
+msgid "Ground Control Point"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1394
+msgid "X:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1395
+msgid "Y:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1396
+msgid "E:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1397
+msgid "N:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1483
+#, fuzzy
+msgid "Symbol settings"
+#: ../gui/wxpython/gui_modules/georect.py:1492
+msgid "Color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1509
+msgid "Width:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1537
+#: ../gui/wxpython/gui_modules/preferences.py:464
+#: ../gui/wxpython/gui_modules/profile.py:976
+#: ../gui/wxpython/gui_modules/profile.py:1321
+#, fuzzy
+msgid "Apply changes for the current session"
+msgstr "Aplicar"
+#: ../gui/wxpython/gui_modules/georect.py:1539
+#: ../gui/wxpython/gui_modules/preferences.py:466
+#: ../gui/wxpython/gui_modules/profile.py:978
+#: ../gui/wxpython/gui_modules/profile.py:1323
+#, fuzzy
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
+msgstr "Cerrar guardar"
+#: ../gui/wxpython/gui_modules/georect.py:1542
+#: ../gui/wxpython/gui_modules/preferences.py:469
+#: ../gui/wxpython/gui_modules/vdigit.py:1533
+#: ../gui/wxpython/gui_modules/profile.py:981
+#: ../gui/wxpython/gui_modules/profile.py:1326
+#, fuzzy
+msgid "Close dialog and ignore changes"
+msgstr "Cerrar"
+#: ../gui/wxpython/gui_modules/georect.py:1569
+#, fuzzy, python-format
+msgid "Georectifier settings saved to file '%s'."
+msgstr "Configuraciones."
#: ../gui/wxpython/gui_modules/menuform.py:139
-#: ../gui/wxpython/gui_modules/menuform.py:1092
+#: ../gui/wxpython/gui_modules/menuform.py:1097
#, fuzzy
msgid "Select Color"
msgstr "Color"
@@ -545,8 +1271,7 @@
msgstr ""
#: ../gui/wxpython/gui_modules/menuform.py:253
-#, python-format
-#, fuzzy
msgid "Parameter %(name)s (%(desc)s) is missing.\n"
msgstr "nombre"
@@ -582,17 +1307,17 @@
msgstr "Copiar"
#: ../gui/wxpython/gui_modules/menuform.py:673
-#: ../gui/wxpython/gui_modules/preferences.py:603
+#: ../gui/wxpython/gui_modules/preferences.py:717
#, fuzzy
msgid "Close dialog on finish"
msgstr "Cerrar"
-#: ../gui/wxpython/gui_modules/menuform.py:780
+#: ../gui/wxpython/gui_modules/menuform.py:784
#, python-format
msgid "'%s' copied to clipboard"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:798
+#: ../gui/wxpython/gui_modules/menuform.py:802
#, python-format
msgid ""
"This is a sample program for\n"
@@ -601,63 +1326,63 @@
"%s"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:801
+#: ../gui/wxpython/gui_modules/menuform.py:805
msgid "About wxPython GRASS GUI"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:837
-#: ../gui/wxpython/gui_modules/menuform.py:850
-#: ../gui/wxpython/gui_modules/menuform.py:1184
+#: ../gui/wxpython/gui_modules/menuform.py:841
+#: ../gui/wxpython/gui_modules/menuform.py:854
+#: ../gui/wxpython/gui_modules/menuform.py:1189
#, fuzzy
msgid "Required"
msgstr "Requerido"
-#: ../gui/wxpython/gui_modules/menuform.py:840
+#: ../gui/wxpython/gui_modules/menuform.py:844
msgid "Optional"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:876 ../gui/wxpython/wxgui.py:287
+#: ../gui/wxpython/gui_modules/menuform.py:881 ../gui/wxpython/wxgui.py:297
msgid "Command output"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:883
+#: ../gui/wxpython/gui_modules/menuform.py:887
msgid "Manual"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:951
+#: ../gui/wxpython/gui_modules/menuform.py:956
msgid "[multiple]"
msgstr "[múltiple]"
-#: ../gui/wxpython/gui_modules/menuform.py:988
+#: ../gui/wxpython/gui_modules/menuform.py:993
msgid "Valid range"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1111
+#: ../gui/wxpython/gui_modules/menuform.py:1116
msgid "Transparent"
msgstr "Transparente"
-#: ../gui/wxpython/gui_modules/menuform.py:1128
+#: ../gui/wxpython/gui_modules/menuform.py:1133
#, python-format
msgid "Choose %s"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1129
+#: ../gui/wxpython/gui_modules/menuform.py:1134
#: ../gui/wxpython/gui_modules/menudata.py:26
msgid "File"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1318
+#: ../gui/wxpython/gui_modules/menuform.py:1323
#, python-format
msgid "Unable to fetch interface description for command '%s'."
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1402
+#: ../gui/wxpython/gui_modules/menuform.py:1407
#, python-format
msgid "Unable to parse command %s"
msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1463
+#: ../gui/wxpython/gui_modules/menuform.py:1468
#, python-format
msgid "usage: %s <grass command>"
msgstr ""
@@ -739,56 +1464,87 @@
msgid "overwrite existing file"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:966
-#: ../gui/wxpython/gui_modules/mapdisp.py:1553
+#: ../gui/wxpython/gui_modules/mapdisp.py:998
+#: ../gui/wxpython/gui_modules/mapdisp.py:1586
#, fuzzy
msgid "No vector map selected for editing."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1101
-#: ../gui/wxpython/gui_modules/mapdisp.py:1110
+#: ../gui/wxpython/gui_modules/mapdisp.py:1133
+#: ../gui/wxpython/gui_modules/mapdisp.py:1142
msgid "Update categories"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1646
+#: ../gui/wxpython/gui_modules/mapdisp.py:1679
msgid "Z bulk-labeling dialog"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2087
+#: ../gui/wxpython/gui_modules/mapdisp.py:2120
#, fuzzy
msgid "Zoom to saved region extents"
msgstr "Zum"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2138
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/mapdisp.py:2171
msgid "Region file <%s> already exists. Do you want to overwrite it?"
msgstr "Región?"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2140
-#: ../gui/wxpython/gui_modules/workspace.py:197 ../gui/wxpython/wxgui.py:721
-#: ../gui/wxpython/wxgui.py:739
+#: ../gui/wxpython/gui_modules/mapdisp.py:2173
+#: ../gui/wxpython/gui_modules/workspace.py:246
msgid "Warning"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2186
+#: ../gui/wxpython/gui_modules/mapdisp.py:2219
#, fuzzy
msgid "GRASS GIS - Map display"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2276
+#: ../gui/wxpython/gui_modules/mapdisp.py:2287
+#, fuzzy
+msgid "Coordinates"
+msgstr "Convertir coordenadas"
+#: ../gui/wxpython/gui_modules/mapdisp.py:2288
+msgid "Extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2289
+#, fuzzy
+msgid "Comp. region"
+msgstr "Cargar región:"
+#: ../gui/wxpython/gui_modules/mapdisp.py:2290
+msgid "Show comp. extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2291
+#, fuzzy
+msgid "Display mode"
+msgstr "Mostrar:"
+#: ../gui/wxpython/gui_modules/mapdisp.py:2292
+#, fuzzy
+msgid "Display geometry"
+msgstr "Mostrar lo seleccionado"
+#: ../gui/wxpython/gui_modules/mapdisp.py:2293
+#, fuzzy
+msgid "Map scale"
+msgstr "Directorio de mapas:"
+#: ../gui/wxpython/gui_modules/mapdisp.py:2298
msgid "Render"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2279
+#: ../gui/wxpython/gui_modules/mapdisp.py:2301
msgid "Enable/disable auto-rendering"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2282
+#: ../gui/wxpython/gui_modules/mapdisp.py:2304
msgid "Show computational extent"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2287
+#: ../gui/wxpython/gui_modules/mapdisp.py:2309
#, fuzzy
msgid ""
"Show/hide computational region extent (set with g.region). Display region "
@@ -796,106 +1552,114 @@
"inside a display region as a red box)."
msgstr "Mostrar mostrar."
-#: ../gui/wxpython/gui_modules/mapdisp.py:2295
-#: ../gui/wxpython/gui_modules/preferences.py:544
+#: ../gui/wxpython/gui_modules/mapdisp.py:2317
+#: ../gui/wxpython/gui_modules/preferences.py:658
#, fuzzy
msgid "Constrain display resolution to computational settings"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2299
+#: ../gui/wxpython/gui_modules/mapdisp.py:2321
#, fuzzy
msgid ""
"Constrain display resolution to computational region settings. Default value "
"for new map displays can be set up in 'User GUI settings' dialog."
msgstr "mostrar."
-#: ../gui/wxpython/gui_modules/mapdisp.py:2903
+#: ../gui/wxpython/gui_modules/mapdisp.py:2415
+msgid "Map Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2427
+msgid "Digit Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2444
+msgid "Georectification Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2914
msgid "No map layer selected for querying."
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2904
-#: ../gui/wxpython/gui_modules/mapdisp.py:2963
-#: ../gui/wxpython/gui_modules/digit.py:747
-#: ../gui/wxpython/gui_modules/dbm.py:2669 ../gui/wxpython/wxgui.py:1038
-#: ../gui/wxpython/wxgui.py:1368
+#: ../gui/wxpython/gui_modules/mapdisp.py:2915
+#: ../gui/wxpython/gui_modules/mapdisp.py:2974
+#: ../gui/wxpython/gui_modules/vdigit.py:758
+#: ../gui/wxpython/gui_modules/dbm.py:2697 ../gui/wxpython/wxgui.py:1132
+#: ../gui/wxpython/wxgui.py:1478
msgid "Message"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2962
+#: ../gui/wxpython/gui_modules/mapdisp.py:2973
#, fuzzy
msgid "No vector map selected for querying."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/mapdisp.py:3115
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/mapdisp.py:3126
msgid ""
"Click and drag with left mouse button to measure.%sDouble click with left "
"button to clear."
msgstr "limpiar."
-#: ../gui/wxpython/gui_modules/mapdisp.py:3122
-msgid "Measuring distance ("
+#: ../gui/wxpython/gui_modules/mapdisp.py:3133
+msgid "Measuring distance"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3126
+#: ../gui/wxpython/gui_modules/mapdisp.py:3137
msgid "Measuring distance:"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3279
+#: ../gui/wxpython/gui_modules/mapdisp.py:3295
msgid "Scale and North arrow"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3285
+#: ../gui/wxpython/gui_modules/mapdisp.py:3301
msgid "Show/hide scale and North arrow"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3286
+#: ../gui/wxpython/gui_modules/mapdisp.py:3302
msgid "scale object"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3312
+#: ../gui/wxpython/gui_modules/mapdisp.py:3328
msgid "Show/hide legend"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3313
+#: ../gui/wxpython/gui_modules/mapdisp.py:3329
msgid "legend object"
msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:3337
-msgid "Add text layer"
-msgstr "Añadir capa de texto"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3385
+#: ../gui/wxpython/gui_modules/mapdisp.py:3401
#: ../gui/wxpython/gui_modules/wxgui_utils.py:240
#, fuzzy
msgstr "Zum"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3389
+#: ../gui/wxpython/gui_modules/mapdisp.py:3405
#, fuzzy
msgid "Zoom to computational region (set with g.region)"
msgstr "Zum"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3393
+#: ../gui/wxpython/gui_modules/mapdisp.py:3409
msgstr "Zum a la región predeterminada"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3397
+#: ../gui/wxpython/gui_modules/mapdisp.py:3413
msgstr "Zum a una región guardada"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3401
+#: ../gui/wxpython/gui_modules/mapdisp.py:3417
#, fuzzy
msgid "Set computational region from display"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:3405
+#: ../gui/wxpython/gui_modules/mapdisp.py:3421
#, fuzzy
msgstr "mostrar"
#: ../gui/wxpython/gui_modules/menudata.py:27
+#: ../gui/wxpython/gui_modules/preferences.py:852
msgid "Workspace"
msgstr "Entorno de trabajo"
@@ -906,22 +1670,18 @@
#: ../gui/wxpython/gui_modules/menudata.py:30
msgid "Create new workspace file (erase current workspace settings first)"
msgstr ""
-"Crear un nuevo archivo de entorno de trabajo (borrar la configuración del entorno "
-"actual antes)"
+"Crear un nuevo archivo de entorno de trabajo (borrar la configuración del "
+"entorno actual antes)"
#: ../gui/wxpython/gui_modules/menudata.py:34
msgid "Open existing workspace"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:35
-msgid "Open existing workspace file"
-msgstr "Abrir archivo de entorno de trabajo existente"
#: ../gui/wxpython/gui_modules/menudata.py:39
msgid "Load map layers"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:40 ../gui/wxpython/wxgui.py:637
+#: ../gui/wxpython/gui_modules/menudata.py:40 ../gui/wxpython/wxgui.py:687
msgid "Load map layers into layer tree"
msgstr ""
@@ -933,14 +1693,11 @@
msgid "Load map layers from GRC file to layer tree (not fully implemented)"
msgstr ""
-#: ../gui/wxpython/gui_modules/menudata.py:49
+#: ../gui/wxpython/gui_modules/menudata.py:49 ../gui/wxpython/wxgui.py:771
+#: ../gui/wxpython/wxgui.py:789
msgid "Save workspace"
msgstr "Guardar entorno de trabajo"
-#: ../gui/wxpython/gui_modules/menudata.py:50
-msgid "Save current workspace to file"
-msgstr "Guardar entorno de trabajo actual a archivo"
#: ../gui/wxpython/gui_modules/menudata.py:54
msgid "Save workspace as"
msgstr "Guardar entorno de trabajo como"
@@ -967,7 +1724,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:69
msgid "Import GDAL supported raster file into a binary raster map layer."
-msgstr "Importar archivo ráster soportado por GDAL a una capa de mapa ráster binario."
+msgstr ""
+"Importar archivo ráster soportado por GDAL a una capa de mapa ráster binario."
#: ../gui/wxpython/gui_modules/menudata.py:74
msgid "Aggregate ASCII xyz import"
@@ -1113,7 +1871,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:152
msgid "Converts files in DXF format to GRASS vector map format."
-msgstr "Convierte archivos en formato DXF a formato de mapa vectorial de GRASS."
+msgstr ""
+"Convierte archivos en formato DXF a formato de mapa vectorial de GRASS."
#: ../gui/wxpython/gui_modules/menudata.py:156
msgid "ESRI e00 import"
@@ -1228,7 +1987,8 @@
msgstr ""
#: ../gui/wxpython/gui_modules/menudata.py:218
-msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+msgid ""
+"Export a raster map to a text file as x,y,z values based on cell centers."
msgstr ""
"Exportar un mapa ráster a un archivo de texto como valores X, Y, Z basados "
"en los centros de las celdas."
@@ -1317,7 +2077,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:266
msgid "Converts a raster map layer into a height-field file for POVRAY."
-msgstr "Convierte una capa de mapa ráster en un archivo de campo altura para POVRAY."
+msgstr ""
+"Convierte una capa de mapa ráster en un archivo de campo altura para POVRAY."
#: ../gui/wxpython/gui_modules/menudata.py:270
#, fuzzy
@@ -1339,7 +2100,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:276
msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-msgstr "Exportar un mapa ráster al Lenguaje de Modelado de Realidad Virtual (VRML)"
+msgstr ""
+"Exportar un mapa ráster al Lenguaje de Modelado de Realidad Virtual (VRML)"
#: ../gui/wxpython/gui_modules/menudata.py:280
#: ../gui/wxpython/gui_modules/menudata.py:314
@@ -1473,8 +2235,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:359
msgid "Renames data base element files in the user's current mapset."
msgstr ""
-"Cambia el nombre archivos de elementos de base de datos en el directorio de mapas "
-"actual del usuario."
+"Cambia el nombre archivos de elementos de base de datos en el directorio de "
+"mapas actual del usuario."
#: ../gui/wxpython/gui_modules/menudata.py:364
msgid "Delete"
@@ -1520,7 +2282,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:388
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr "Crea un mapa de volumen 3D basado en mapas ráster de elevación y valor 2D."
+msgstr ""
+"Crea un mapa de volumen 3D basado en mapas ráster de elevación y valor 2D."
#: ../gui/wxpython/gui_modules/menudata.py:393
msgid "Vector to raster"
@@ -1561,10 +2324,6 @@
msgid "Converts 3D raster maps to 2D raster maps"
msgstr "Convierte mapas ráster 3D en mapas ráster 2D"
-#: ../gui/wxpython/gui_modules/menudata.py:417
-msgid "Georectify"
-msgstr "Georrectificar"
#: ../gui/wxpython/gui_modules/menudata.py:418
msgid "Georectify raster and vector maps"
msgstr "Georrectifica mapas ráster y vectoriales"
@@ -1617,7 +2376,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:451
#: ../gui/wxpython/gui_modules/menudata.py:456
msgid "Manages the boundary definitions for the geographic region."
-msgstr "Administra las definiciones de los contornos para la región geográfica."
+msgstr ""
+"Administra las definiciones de los contornos para la región geográfica."
#: ../gui/wxpython/gui_modules/menudata.py:455
msgid "Set region"
@@ -1660,7 +2420,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:479
#: ../gui/wxpython/gui_modules/menudata.py:484
msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr "Saca y modifica la configuración actual de variables de GRASS del usuario."
+msgstr ""
+"Saca y modifica la configuración actual de variables de GRASS del usuario."
#: ../gui/wxpython/gui_modules/menudata.py:483
msgid "Change settings"
@@ -1695,7 +2456,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:502
msgid "Create/edit projection information for current location"
-msgstr "Crear/editar la información de la proyección para la localización activa"
+msgstr ""
+"Crear/editar la información de la proyección para la localización activa"
#: ../gui/wxpython/gui_modules/menudata.py:507
msgid "Convert coordinates"
@@ -1834,7 +2596,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:589
msgid "Re-projects a raster map from one location to the current location."
-msgstr "Reproyecta un mapa ráster desde una localización a la localización actual."
+msgstr ""
+"Reproyecta un mapa ráster desde una localización a la localización actual."
#: ../gui/wxpython/gui_modules/menudata.py:593
msgid "Tiling"
@@ -1876,15 +2639,18 @@
#: ../gui/wxpython/gui_modules/menudata.py:613
msgid "Blends color components of two raster maps by a given ratio."
-msgstr "Mezcla los componentes de color de dos mapas ráster en la proporción indicada"
+msgstr ""
+"Mezcla los componentes de color de dos mapas ráster en la proporción indicada"
#: ../gui/wxpython/gui_modules/menudata.py:617
msgid "Create RGB"
msgstr "Crear RGB"
#: ../gui/wxpython/gui_modules/menudata.py:618
-msgid "Combines red, green and blue map layers into a single composite map layer."
-msgstr "Combina capas de mapa roja, verde y azul en una sola capa de mapa compuesto."
+msgid ""
+"Combines red, green and blue map layers into a single composite map layer."
+msgstr ""
+"Combina capas de mapa roja, verde y azul en una sola capa de mapa compuesto."
#: ../gui/wxpython/gui_modules/menudata.py:622
#: ../gui/wxpython/gui_modules/menudata.py:1576
@@ -2108,16 +2874,18 @@
#: ../gui/wxpython/gui_modules/menudata.py:717
msgid "Traces a flow through an elevation model on a raster map layer."
-msgstr "Traza un flujo mediante un modelo de elevación sobre una capa de mapa ráster."
+msgstr ""
+"Traza un flujo mediante un modelo de elevación sobre una capa de mapa ráster."
#: ../gui/wxpython/gui_modules/menudata.py:722
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:496
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:540
msgid "Shaded relief"
#: ../gui/wxpython/gui_modules/menudata.py:723
msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr "Crea un mapa compartido de relieve a partir de un mapa de elevaciones (DEM)."
+msgstr ""
+"Crea un mapa compartido de relieve a partir de un mapa de elevaciones (DEM)."
#: ../gui/wxpython/gui_modules/menudata.py:728
msgid "Slope and aspect"
@@ -2381,7 +3149,8 @@
msgstr "Densidad de borde"
#: ../gui/wxpython/gui_modules/menudata.py:869
-msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
"Calcula el Ãndice de densidad de borde en un mapa ráster usando un algoritmo "
"de 4 vecinos"
@@ -2429,14 +3198,16 @@
#: ../gui/wxpython/gui_modules/menudata.py:895
msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr "Calcula el coeficiente de varianza del área de parche en un mapa ráster"
+msgstr ""
+"Calcula el coeficiente de varianza del área de parche en un mapa ráster"
#: ../gui/wxpython/gui_modules/menudata.py:899
msgid "Patch density"
msgstr "Densidad de parcela"
#: ../gui/wxpython/gui_modules/menudata.py:900
-msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
"Calcula el Ãndice de densidad de parche sobre un mapa ráster usando un "
"algoritmo de 4 vecinos"
@@ -2446,7 +3217,8 @@
msgstr "Número de parcelas"
#: ../gui/wxpython/gui_modules/menudata.py:905
-msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
msgstr ""
"Calcula el Ãndice de número de parche en un mapa ráster usando un algoritmo "
"de 4 vecinos."
@@ -2593,7 +3365,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:986
#, fuzzy
-msgid "r.recode.rules - Use ascii rules file to recode categories in raster map"
+msgid ""
+"r.recode.rules - Use ascii rules file to recode categories in raster map"
msgstr "ráster"
#: ../gui/wxpython/gui_modules/menudata.py:991
@@ -2727,7 +3500,8 @@
msgstr "lÃneas"
#: ../gui/wxpython/gui_modules/menudata.py:1059
-msgid "Produces a vector map layer of specified contours from a raster map layer."
+msgid ""
+"Produces a vector map layer of specified contours from a raster map layer."
msgstr ""
"Produce una capa de mapa vectorial de contornos especificados a partir de "
"una capa de mapa ráster."
@@ -2778,7 +3552,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1087
msgid "Surface generation program from rasterized contours."
-msgstr "Programa de generación de superficies a partir de contornos rasterizados."
+msgstr ""
+"Programa de generación de superficies a partir de contornos rasterizados."
#: ../gui/wxpython/gui_modules/menudata.py:1091
msgid "Regularized spline tension"
@@ -2800,7 +3575,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1098
#, fuzzy
-msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+msgid ""
+"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
msgstr ""
"Rellenar áreas sin datos de los mapas ráster usando la interpolación splines "
"de v.sufr.rst"
@@ -2845,7 +3621,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1123
msgid "Prints terse list of category values found in a raster map layer."
-msgstr "Imprime una lista concisa de valores de categorÃa en una capa de mapa ráster."
+msgstr ""
+"Imprime una lista concisa de valores de categorÃa en una capa de mapa ráster."
#: ../gui/wxpython/gui_modules/menudata.py:1127
msgid "Sum category values"
@@ -2873,7 +3650,8 @@
msgid ""
"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
"vector points map containing the calculated centroids of these clumps."
-msgstr "Calcula el volumen de datos \"clumps\" GRASS vectorial puntos centroides."
+msgstr ""
+"Calcula el volumen de datos \"clumps\" GRASS vectorial puntos centroides."
#: ../gui/wxpython/gui_modules/menudata.py:1142
msgid "Total corrected area"
@@ -2889,7 +3667,8 @@
msgstr "ráster"
#: ../gui/wxpython/gui_modules/menudata.py:1148
-msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
"Calcula estadÃsticas univariantes a partir de celdas no nulas de un mapa "
"ráster."
@@ -2909,7 +3688,8 @@
msgstr "Muestrear transectos (rumbo/distancia)"
#: ../gui/wxpython/gui_modules/menudata.py:1159
-msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
msgstr ""
"Produce valores de capa de mapa ráster que caen a lo largo de lÃnea(s) de "
"transecto definidas por el usuario."
@@ -3123,14 +3903,16 @@
#: ../gui/wxpython/gui_modules/menudata.py:1288
msgid "Select features from ainput by features from binput"
-msgstr "Seleccionar elementos de la entrada A mediante elementos de la entrada B"
+msgstr ""
+"Seleccionar elementos de la entrada A mediante elementos de la entrada B"
#: ../gui/wxpython/gui_modules/menudata.py:1293
msgid "Buffer vectors"
msgstr "Crear áreas de influencia de vectoriales"
#: ../gui/wxpython/gui_modules/menudata.py:1294
-msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgid ""
+"Creates a buffer around features of given type (areas must contain centroid)."
msgstr ""
"Crear un buffer alrededor de los elementos de tipo dado (las áreas deben "
"contener centroide)."
@@ -3145,7 +3927,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1300
msgid "Detects the object's edges from a LIDAR data set."
-msgstr "Detecta los bordes de un objeto a partir de un conjunto de datos LIDAR."
+msgstr ""
+"Detecta los bordes de un objeto a partir de un conjunto de datos LIDAR."
#: ../gui/wxpython/gui_modules/menudata.py:1304
msgid "Detect interiors"
@@ -3343,7 +4126,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1403
msgid "Attach, delete or report vector categories to map geometry."
-msgstr "Adjuntar, borrar o informar categorÃas del vectorial a la geometrÃa del mapa."
+msgstr ""
+"Adjuntar, borrar o informar categorÃas del vectorial a la geometrÃa del mapa."
#: ../gui/wxpython/gui_modules/menudata.py:1407
msgid "Reclassify objects interactively"
@@ -3383,7 +4167,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1427
msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-msgstr "Usa un mapa vectorial de puntos de GRASS para producir un mapa vectorial ."
+msgstr ""
+"Usa un mapa vectorial de puntos de GRASS para producir un mapa vectorial ."
#: ../gui/wxpython/gui_modules/menudata.py:1431
msgid "Delaunay triangles"
@@ -3415,7 +4200,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1444
msgid "Creates a GRASS vector map of a user-defined grid."
-msgstr "Crea un mapa vectorial de GRASS de una cuadrÃcula definida por el usuario."
+msgstr ""
+"Crea un mapa vectorial de GRASS de una cuadrÃcula definida por el usuario."
#: ../gui/wxpython/gui_modules/menudata.py:1447
msgid "Generate points"
@@ -3426,7 +4212,8 @@
msgstr ""
#: ../gui/wxpython/gui_modules/menudata.py:1450
-msgid "Creates new vector (points) map from database table containing coordinates."
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
msgstr ""
"Crea un nuevo mapa vectorial (de puntos) a partir de una tabla de base de "
"datos que contiene coordenadas."
@@ -3455,7 +4242,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1465
msgid "Random location perturbations of GRASS vector points"
-msgstr "Perturbaciones de localizaciones aleatorias de puntos vectoriales de GRASS"
+msgstr ""
+"Perturbaciones de localizaciones aleatorias de puntos vectoriales de GRASS"
#: ../gui/wxpython/gui_modules/menudata.py:1472
#, fuzzy
@@ -3496,7 +4284,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1489
msgid "Uploads vector values at positions of vector points to the table."
-msgstr "Carga valores vectoriales en las posiciones de puntos vectoriales a la tabla."
+msgstr ""
+"Carga valores vectoriales en las posiciones de puntos vectoriales a la tabla."
#: ../gui/wxpython/gui_modules/menudata.py:1492
msgid "Update point attributes from raster"
@@ -3509,7 +4298,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1495
msgid "Uploads raster values at positions of vector points to the table."
-msgstr "Carga valores ráster en las posiciones de puntos vectoriales a la tabla."
+msgstr ""
+"Carga valores ráster en las posiciones de puntos vectoriales a la tabla."
#: ../gui/wxpython/gui_modules/menudata.py:1499
msgid "Sample raster neighborhood around points"
@@ -3601,7 +4391,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1553
msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr "Destina un grupo de imagen a una localización GRASS y un conjunto de mapas"
+msgstr ""
+"Destina un grupo de imagen a una localización GRASS y un conjunto de mapas"
#: ../gui/wxpython/gui_modules/menudata.py:1558
msgid "Mosaic images"
@@ -3609,7 +4400,8 @@
#: ../gui/wxpython/gui_modules/menudata.py:1559
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr "Hace mosaicos de hasta 4 imágenes y extiende colormap; crea mapas *.mosaico"
+msgstr ""
+"Hace mosaicos de hasta 4 imágenes y extiende colormap; crea mapas *.mosaico"
#: ../gui/wxpython/gui_modules/menudata.py:1564
msgid "Manage image colors"
@@ -3669,7 +4461,8 @@
msgstr ""
#: ../gui/wxpython/gui_modules/menudata.py:1595
-msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+msgid ""
+"Brovey transform to merge multispectral and high-res panchromatic channels"
msgstr ""
"Transformación de Brovey para fundir canales multiespectrales y "
"pancromáticos de alta resolución"
@@ -3763,7 +4556,7 @@
msgstr "Filtro de matrices de mapas ráster."
#: ../gui/wxpython/gui_modules/menudata.py:1647
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:283
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:285
msgid "Histogram"
msgstr ""
@@ -3776,7 +4569,8 @@
msgstr "Respuesta espectral"
#: ../gui/wxpython/gui_modules/menudata.py:1653
-msgid "displays spectral response at user specified locations in group or images"
+msgid ""
+"displays spectral response at user specified locations in group or images"
msgstr ""
"muestra la respuesta espectral en localizaciones especificadas por el "
"usuario en grupo o imágenes"
@@ -3937,9 +4731,9 @@
"usuario."
#: ../gui/wxpython/gui_modules/menudata.py:1751
-#: ../gui/wxpython/gui_modules/dbm.py:1922
-#: ../gui/wxpython/gui_modules/dbm.py:2036
-#: ../gui/wxpython/gui_modules/dbm.py:2274
+#: ../gui/wxpython/gui_modules/dbm.py:1950
+#: ../gui/wxpython/gui_modules/dbm.py:2064
+#: ../gui/wxpython/gui_modules/dbm.py:2302
msgid "Database"
msgstr ""
@@ -4047,18 +4841,20 @@
msgstr "Cambiar valores"
#: ../gui/wxpython/gui_modules/menudata.py:1811
-msgid "Allows to update a column in the attribute table connected to a vector map."
+msgid ""
+"Allows to update a column in the attribute table connected to a vector map."
msgstr ""
"Permite actualizar una columna en la tabla de atributos conectada a un mapa "
"vectorial."
#: ../gui/wxpython/gui_modules/menudata.py:1815
-#: ../gui/wxpython/gui_modules/dbm.py:724
+#: ../gui/wxpython/gui_modules/dbm.py:728
msgid "Rename column"
msgstr "Cambiar nombre de columna"
#: ../gui/wxpython/gui_modules/menudata.py:1816
-msgid "Renames a column in the attribute table connected to a given vector map."
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
msgstr ""
"Cambia el nombre de una columna en la tabla de atributos conectada a un mapa "
"vectorial dado."
@@ -4147,185 +4943,199 @@
msgid "About GRASS GIS"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:159
+#: ../gui/wxpython/gui_modules/preferences.py:172
+msgid "Segment break"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:218
msgid "Mapset search path"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:160
+#: ../gui/wxpython/gui_modules/preferences.py:219
msgid "All available mapsets"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:161
-#: ../gui/wxpython/gui_modules/dbm.py:905
+#: ../gui/wxpython/gui_modules/preferences.py:220
+#: ../gui/wxpython/gui_modules/dbm.py:909
msgid "Edit selected record"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:162
-#: ../gui/wxpython/gui_modules/dbm.py:916
+#: ../gui/wxpython/gui_modules/preferences.py:221
+#: ../gui/wxpython/gui_modules/dbm.py:920
msgid "Display selected"
-#: ../gui/wxpython/gui_modules/preferences.py:272
+#: ../gui/wxpython/gui_modules/preferences.py:330
msgid "Uknown settings file location."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:317
+#: ../gui/wxpython/gui_modules/preferences.py:378
msgid "Unable to get value"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:340
+#: ../gui/wxpython/gui_modules/preferences.py:401
msgid "Unable to set "
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:346
+#: ../gui/wxpython/gui_modules/preferences.py:430
msgid "User GUI settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:369
+#: ../gui/wxpython/gui_modules/preferences.py:454
msgid "Set to default"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:377
+#: ../gui/wxpython/gui_modules/preferences.py:462
msgid "Revert settings to default and apply changes"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:379
-#: ../gui/wxpython/gui_modules/digit.py:1508
-#, fuzzy
-msgid "Apply changes for this session"
-msgstr "Aplicar"
-#: ../gui/wxpython/gui_modules/preferences.py:381
-#: ../gui/wxpython/gui_modules/digit.py:1511
-#, fuzzy
-msgid "Close dialog and save changes to user settings file"
-msgstr "Cerrar guardar"
-#: ../gui/wxpython/gui_modules/preferences.py:384
-#: ../gui/wxpython/gui_modules/digit.py:1513
-#, fuzzy
-msgid "Close dialog and ignore changes"
-msgstr "Cerrar"
-#: ../gui/wxpython/gui_modules/preferences.py:412
-#: ../gui/wxpython/gui_modules/digit.py:1569
+#: ../gui/wxpython/gui_modules/preferences.py:497
+#: ../gui/wxpython/gui_modules/vdigit.py:1589
msgid "General"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:415
+#: ../gui/wxpython/gui_modules/preferences.py:500
msgid "General settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:426
+#: ../gui/wxpython/gui_modules/preferences.py:511
msgid "Mapsets path:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:448
+#: ../gui/wxpython/gui_modules/preferences.py:533
#, fuzzy
+msgid "Save current window layout as default"
+msgstr "Guardar entorno de trabajo actual como archivo"
+#: ../gui/wxpython/gui_modules/preferences.py:536
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:549
+#, fuzzy
msgid "Layer Manager settings"
msgstr "Capa"
-#: ../gui/wxpython/gui_modules/preferences.py:459
+#: ../gui/wxpython/gui_modules/preferences.py:560
msgid "Opacity level editable"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:477
-#: ../gui/wxpython/gui_modules/digit.py:1576
+#: ../gui/wxpython/gui_modules/preferences.py:573
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:591
+#: ../gui/wxpython/gui_modules/vdigit.py:1596
msgid "Display"
msgstr "Mostrar"
-#: ../gui/wxpython/gui_modules/preferences.py:481
+#: ../gui/wxpython/gui_modules/preferences.py:595
+#: ../gui/wxpython/gui_modules/profile.py:911
msgid "Font settings"
msgstr "Configuración de tipo de letra"
-#: ../gui/wxpython/gui_modules/preferences.py:492
+#: ../gui/wxpython/gui_modules/preferences.py:606
msgid "Default font for GRASS displays:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:506
+#: ../gui/wxpython/gui_modules/preferences.py:620
#, fuzzy
msgid "Default display settings"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/preferences.py:517
+#: ../gui/wxpython/gui_modules/preferences.py:631
#, fuzzy
msgid "Display driver:"
msgstr "Mostrar:"
-#: ../gui/wxpython/gui_modules/preferences.py:557
+#: ../gui/wxpython/gui_modules/preferences.py:671
msgid "Enable auto-rendering"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:578
+#: ../gui/wxpython/gui_modules/preferences.py:692
msgid "Command"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:581
+#: ../gui/wxpython/gui_modules/preferences.py:695
msgid "Command dialog settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:613
+#: ../gui/wxpython/gui_modules/preferences.py:727
msgid "Verbosity level:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:632
+#: ../gui/wxpython/gui_modules/preferences.py:746
#, fuzzy
msgid "Raster settings"
msgstr "ráster"
-#: ../gui/wxpython/gui_modules/preferences.py:643
+#: ../gui/wxpython/gui_modules/preferences.py:757
msgid "Overlay raster maps"
msgstr "Superponer mapas ráster"
-#: ../gui/wxpython/gui_modules/preferences.py:661
-#: ../gui/wxpython/gui_modules/dbm.py:406
-#, fuzzy
-msgid "Attribute Table Manager"
-msgstr "Tabla"
+#: ../gui/wxpython/gui_modules/preferences.py:775
+#: ../gui/wxpython/gui_modules/vdigit.py:1800
+msgid "Attributes"
+msgstr "Atributos"
-#: ../gui/wxpython/gui_modules/preferences.py:669
+#: ../gui/wxpython/gui_modules/preferences.py:783
msgid "Highlighting"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:683
+#: ../gui/wxpython/gui_modules/preferences.py:797
#, fuzzy
msgid "Line width (in pixels)"
msgstr "LÃnea"
-#: ../gui/wxpython/gui_modules/preferences.py:706
+#: ../gui/wxpython/gui_modules/preferences.py:820
msgid "Data browser"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:711
+#: ../gui/wxpython/gui_modules/preferences.py:825
msgid "Left mouse double click"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:738
-#: ../gui/wxpython/gui_modules/dbm.py:558
+#: ../gui/wxpython/gui_modules/preferences.py:855
+#, fuzzy
+msgid "Loading workspace"
+msgstr "Guardar entorno de trabajo"
+#: ../gui/wxpython/gui_modules/preferences.py:867
+msgid "Suppress positioning Map Display Window(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:878
+msgid "Suppress positioning Layer Manager window"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:896
+#: ../gui/wxpython/gui_modules/dbm.py:562
msgid "Advanced"
msgstr "Avanzado"
-#: ../gui/wxpython/gui_modules/preferences.py:741
+#: ../gui/wxpython/gui_modules/preferences.py:899
msgid "Advanced settings"
msgstr "Configuración avanzada"
-#: ../gui/wxpython/gui_modules/preferences.py:753
+#: ../gui/wxpython/gui_modules/preferences.py:911
msgid "Place where to store settings:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:774
+#: ../gui/wxpython/gui_modules/preferences.py:932
msgid "Icon theme:"
msgstr "Tema de iconos:"
-#: ../gui/wxpython/gui_modules/preferences.py:791
+#: ../gui/wxpython/gui_modules/preferences.py:949
msgid "Note: Requires GUI restart."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:805
+#: ../gui/wxpython/gui_modules/preferences.py:963
msgid "Digitization interface:"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:823
+#: ../gui/wxpython/gui_modules/preferences.py:981
#, fuzzy
msgid ""
"Note: User can choose from two interfaces for digitization. The simple one "
@@ -4335,232 +5145,285 @@
"itself."
msgstr "topologÃa."
-#: ../gui/wxpython/gui_modules/preferences.py:847
+#: ../gui/wxpython/gui_modules/preferences.py:1005
#, fuzzy
msgid "Select default display font"
msgstr "mostrar"
-#: ../gui/wxpython/gui_modules/preferences.py:874
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/preferences.py:1032
msgid "Settings saved to file '%s'."
-#: ../gui/wxpython/gui_modules/preferences.py:1027
+#: ../gui/wxpython/gui_modules/preferences.py:1205
msgid "Set/unset access to mapsets in current location"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1040
+#: ../gui/wxpython/gui_modules/preferences.py:1218
#, python-format
msgid ""
"Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT "
"and current mapset are always accessible."
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1112
+#: ../gui/wxpython/gui_modules/preferences.py:1290
msgid "Mapset"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1113
+#: ../gui/wxpython/gui_modules/preferences.py:1291
msgid "Owner"
msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1114
+#: ../gui/wxpython/gui_modules/preferences.py:1292
msgid "Group"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:149
-#: ../gui/wxpython/gui_modules/digit.py:153
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/vdigit.py:147
+#: ../gui/wxpython/gui_modules/vdigit.py:151
msgid ""
"Unable to open vector map <%s> for editing. Data are probably corrupted, try "
"to run v.build for rebuilding the topology."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/digit.py:745
+#: ../gui/wxpython/gui_modules/vdigit.py:756
#, fuzzy
msgid "Undondo is not implemented in vedit component. Use vdigit instead."
msgstr "Usar."
-#: ../gui/wxpython/gui_modules/digit.py:798
-#: ../gui/wxpython/gui_modules/digit.py:831
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/vdigit.py:813
+#: ../gui/wxpython/gui_modules/vdigit.py:850
msgid "Adding new feature to vector map <%s> failed."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/digit.py:1151
+#: ../gui/wxpython/gui_modules/vdigit.py:1171
#, fuzzy
msgid "Undo failed, data corrupted."
msgstr "datos."
-#: ../gui/wxpython/gui_modules/digit.py:1534
+#: ../gui/wxpython/gui_modules/vdigit.py:1528
+#, fuzzy
+msgid "Apply changes for this session"
+msgstr "Aplicar"
+#: ../gui/wxpython/gui_modules/vdigit.py:1531
+#, fuzzy
+msgid "Close dialog and save changes to user settings file"
+#: ../gui/wxpython/gui_modules/vdigit.py:1554
msgid "Symbology"
msgstr "SimbologÃa"
-#: ../gui/wxpython/gui_modules/digit.py:1581
+#: ../gui/wxpython/gui_modules/vdigit.py:1601
+#: ../gui/wxpython/gui_modules/profile.py:1107
msgid "Line width"
msgstr "Anchura de lÃnea"
-#: ../gui/wxpython/gui_modules/digit.py:1599
+#: ../gui/wxpython/gui_modules/vdigit.py:1619
msgid "Snapping"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1606
+#: ../gui/wxpython/gui_modules/vdigit.py:1626
msgid "Snapping threshold"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1619
+#: ../gui/wxpython/gui_modules/vdigit.py:1639
#, fuzzy
msgid "Backgroud vector map"
msgstr "vectorial"
-#: ../gui/wxpython/gui_modules/digit.py:1630
+#: ../gui/wxpython/gui_modules/vdigit.py:1650
msgid "Snap also to vertex"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1635
-#: ../gui/wxpython/gui_modules/digit.py:1919
-#: ../gui/wxpython/gui_modules/digit.py:1932
-#: ../gui/wxpython/gui_modules/digit.py:1936
+#: ../gui/wxpython/gui_modules/vdigit.py:1655
+#: ../gui/wxpython/gui_modules/vdigit.py:1940
+#: ../gui/wxpython/gui_modules/vdigit.py:1953
+#: ../gui/wxpython/gui_modules/vdigit.py:1957
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1649
+#: ../gui/wxpython/gui_modules/vdigit.py:1669
#, fuzzy
msgid "Select vector features"
msgstr "vectorial"
-#: ../gui/wxpython/gui_modules/digit.py:1665
+#: ../gui/wxpython/gui_modules/vdigit.py:1685
msgid "Select threshold"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1682
+#: ../gui/wxpython/gui_modules/vdigit.py:1702
msgid "Save changes"
msgstr "Guardar cambios"
-#: ../gui/wxpython/gui_modules/digit.py:1685
+#: ../gui/wxpython/gui_modules/vdigit.py:1705
#, fuzzy
msgid "Save changes on exit automatically"
msgstr "Guardar"
-#: ../gui/wxpython/gui_modules/digit.py:1698
+#: ../gui/wxpython/gui_modules/vdigit.py:1718
msgid "Query tool"
msgstr "Herramienta de consultas"
-#: ../gui/wxpython/gui_modules/digit.py:1705
+#: ../gui/wxpython/gui_modules/vdigit.py:1725
msgid "Choose query tool"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1710
+#: ../gui/wxpython/gui_modules/vdigit.py:1730
msgid "Select by box"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1719
+#: ../gui/wxpython/gui_modules/vdigit.py:1739
msgid "length"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1724
+#: ../gui/wxpython/gui_modules/vdigit.py:1744
msgid "Select lines"
msgstr "Seleccionar lÃneas"
-#: ../gui/wxpython/gui_modules/digit.py:1726
-#: ../gui/wxpython/gui_modules/digit.py:1749
+#: ../gui/wxpython/gui_modules/vdigit.py:1746
+#: ../gui/wxpython/gui_modules/vdigit.py:1769
msgid "shorter than"
msgstr ""
msgid "longer than"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1742
+#: ../gui/wxpython/gui_modules/vdigit.py:1762
msgid "dangle"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1747
+#: ../gui/wxpython/gui_modules/vdigit.py:1767
msgid "Select dangles"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1780
-msgid "Attributes"
-msgstr "Atributos"
-#: ../gui/wxpython/gui_modules/digit.py:1787
+#: ../gui/wxpython/gui_modules/vdigit.py:1807
#, fuzzy
msgid "Digitize new feature"
msgstr "Digitalizar"
-#: ../gui/wxpython/gui_modules/digit.py:1792
+#: ../gui/wxpython/gui_modules/vdigit.py:1812
msgid "Add new record into table"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1798
-#: ../gui/wxpython/gui_modules/digit.py:1800
-#: ../gui/wxpython/gui_modules/digit.py:2114
-#: ../gui/wxpython/gui_modules/digit.py:2488
-#: ../gui/wxpython/gui_modules/dbm.py:2025
-#: ../gui/wxpython/gui_modules/dbm.py:2260
-#: ../gui/wxpython/gui_modules/dbm.py:2905
+#: ../gui/wxpython/gui_modules/vdigit.py:1818
+#: ../gui/wxpython/gui_modules/vdigit.py:1820
+#: ../gui/wxpython/gui_modules/vdigit.py:2158
+#: ../gui/wxpython/gui_modules/vdigit.py:2532
+#: ../gui/wxpython/gui_modules/dbm.py:2053
+#: ../gui/wxpython/gui_modules/dbm.py:2288
+#: ../gui/wxpython/gui_modules/dbm.py:2933
msgid "Layer"
msgstr "Capa"
-#: ../gui/wxpython/gui_modules/digit.py:2118
-#: ../gui/wxpython/gui_modules/digit.py:2489
-#: ../gui/wxpython/gui_modules/dbm.py:2938
-#: ../gui/wxpython/gui_modules/dbm.py:3227
+#: ../gui/wxpython/gui_modules/vdigit.py:2162
+#: ../gui/wxpython/gui_modules/vdigit.py:2533
+#: ../gui/wxpython/gui_modules/dbm.py:2966
+#: ../gui/wxpython/gui_modules/dbm.py:3261
msgid "Category"
msgstr ""
msgid "Mode"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1827
+#: ../gui/wxpython/gui_modules/vdigit.py:1847
msgid "Next to use"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1815
+#: ../gui/wxpython/gui_modules/vdigit.py:1835
msgid "Category number"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1825
+#: ../gui/wxpython/gui_modules/vdigit.py:1845
msgid "Category mode"
msgstr ""
msgid "Manual entry"
msgstr ""
msgid "No category"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:1840
+#: ../gui/wxpython/gui_modules/vdigit.py:1860
#, fuzzy
msgid "Delete existing feature(s)"
msgstr "Borrar"
-#: ../gui/wxpython/gui_modules/digit.py:1845
+#: ../gui/wxpython/gui_modules/vdigit.py:1865
#, fuzzy
msgid "Delete record from table"
msgstr "Borrar"
-#: ../gui/wxpython/gui_modules/digit.py:2092
+#: ../gui/wxpython/gui_modules/vdigit.py:1889
+msgid "Highlight"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1890
+msgid "Point"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1891
+msgid "Line"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1892
+msgid "Boundary (no area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1893
+msgid "Boundary (one area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1894
+msgid "Boundary (two areas)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1895
+msgid "Centroid (in area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1896
+msgid "Centroid (outside area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1897
+msgid "Centroid (duplicate in area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1898
+msgid "Node (one line)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1899
+#, fuzzy
+msgid "Node (two lines)"
+msgstr "LÃneas de flujo"
+#: ../gui/wxpython/gui_modules/vdigit.py:1900
+msgid "Vertex"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2136
msgid "List of categories"
msgstr "Lista de categorÃas"
-#: ../gui/wxpython/gui_modules/digit.py:2108
+#: ../gui/wxpython/gui_modules/vdigit.py:2152
msgid "Add new category"
msgstr "Añadir categorÃa nueva"
-#: ../gui/wxpython/gui_modules/digit.py:2222
-#: ../gui/wxpython/gui_modules/digit.py:2397
+#: ../gui/wxpython/gui_modules/vdigit.py:2266
+#: ../gui/wxpython/gui_modules/vdigit.py:2441
#, python-format
msgid ""
"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
@@ -4568,379 +5431,587 @@
"Layer number must be greater then zero."
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2256
+#: ../gui/wxpython/gui_modules/vdigit.py:2300
msgid "Delete selected"
msgstr "Borrar lo seleccionado"
-#: ../gui/wxpython/gui_modules/digit.py:2260
+#: ../gui/wxpython/gui_modules/vdigit.py:2304
msgid "Delete all"
msgstr "Borrar todo"
-#: ../gui/wxpython/gui_modules/digit.py:2262
-#: ../gui/wxpython/gui_modules/dbm.py:924
-#: ../gui/wxpython/gui_modules/dbm.py:1297
+#: ../gui/wxpython/gui_modules/vdigit.py:2306
+#: ../gui/wxpython/gui_modules/dbm.py:928
+#: ../gui/wxpython/gui_modules/dbm.py:1301
msgid "Reload"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2374
+#: ../gui/wxpython/gui_modules/vdigit.py:2418
#, fuzzy
msgid "Unable to update vector map."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/digit.py:2526
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/vdigit.py:2570
msgid "%d lines selected for z bulk-labeling"
msgstr "lÃneas"
-#: ../gui/wxpython/gui_modules/digit.py:2529
+#: ../gui/wxpython/gui_modules/vdigit.py:2573
msgid "Set value"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2536
+#: ../gui/wxpython/gui_modules/vdigit.py:2580
msgid "Starting value"
msgstr ""
-#: ../gui/wxpython/gui_modules/digit.py:2545
+#: ../gui/wxpython/gui_modules/vdigit.py:2589
msgid "Step"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:186
+#: ../gui/wxpython/gui_modules/profile.py:64
#, fuzzy
+msgid "Profile Analysis"
+msgstr "Análisis del terreno"
+#: ../gui/wxpython/gui_modules/profile.py:152
+#: ../gui/wxpython/gui_modules/profile.py:258
+msgid "Profile of"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:156
+#, python-format
+msgid "Distance (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:158
+msgid "Distance along transect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:159
+#, fuzzy
+msgid "Cell values"
+msgstr "Cambiar valores"
+#: ../gui/wxpython/gui_modules/profile.py:267
+#, python-format
+msgid "Profile of %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:293
+#, fuzzy
+msgid "Raster values"
+msgstr "ráster"
+#: ../gui/wxpython/gui_modules/profile.py:416
+msgid "You must draw a transect to profile in the map display window."
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:417
+msgid "Nothing to profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:627
+#, fuzzy
+msgid "Profile text settings"
+msgstr "Configuración de tipo de letra"
+#: ../gui/wxpython/gui_modules/profile.py:654
+#, fuzzy
+msgid "Profile settings"
+msgstr "Mostrar configuración"
+#: ../gui/wxpython/gui_modules/profile.py:717
+#, fuzzy
+msgid "Select raster map to profile"
+msgstr "ráster:"
+#: ../gui/wxpython/gui_modules/profile.py:752
+#, fuzzy
+msgid "Select raster map 1 (required):"
+msgstr "ráster"
+#: ../gui/wxpython/gui_modules/profile.py:753
+#, fuzzy
+msgid "Select raster map 2 (optional):"
+msgstr "ráster"
+#: ../gui/wxpython/gui_modules/profile.py:754
+#, fuzzy
+msgid "Select raster map 3 (optional):"
+msgstr "ráster"
+#: ../gui/wxpython/gui_modules/profile.py:848
+#, fuzzy
+msgid "Text settings"
+#: ../gui/wxpython/gui_modules/profile.py:855
+msgid "Profile title:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:865
+msgid "Title font size (pts):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:886
+msgid "Y-axis label:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:896
+msgid "Label font size (pts):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:919
+msgid "Font family:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:933
+msgid "Style:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:947
+msgid "Weight:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1029
+#: ../gui/wxpython/gui_modules/profile.py:1374
+msgid "Profile settings saved to file '%s'."
+#: ../gui/wxpython/gui_modules/profile.py:1085
+#, fuzzy
+msgid "Profile line settings"
+#: ../gui/wxpython/gui_modules/profile.py:1095
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:287
+msgid "Profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1100
+msgid "Line color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1117
+#, fuzzy
+msgid "Line style"
+msgstr "Anchura de lÃnea"
+#: ../gui/wxpython/gui_modules/profile.py:1126
+#: ../gui/wxpython/gui_modules/profile.py:1178
+msgid "Legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1150
+msgid "Transect segment marker settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1155
+#, fuzzy
+msgid "Color"
+msgstr "Reglas de color"
+#: ../gui/wxpython/gui_modules/profile.py:1161
+msgid "Size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1170
+#: ../gui/wxpython/gui_modules/profile.py:1216
+msgid "Style"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1185
+msgid "Type"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1200
+#, fuzzy
+msgid "Axis settings"
+msgstr "ráster"
+#: ../gui/wxpython/gui_modules/profile.py:1206
+msgid "X-Axis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1207
+msgid "Y-Axis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1225
+msgid "Custom min"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1233
+msgid "Custom max"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1241
+#, fuzzy
+msgid "Log scale"
+msgstr "Rescalar"
+#: ../gui/wxpython/gui_modules/profile.py:1265
+#, fuzzy
+msgid "Grid and Legend settings"
+msgstr "Configuración avanzada"
+#: ../gui/wxpython/gui_modules/profile.py:1270
+msgid "Grid color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1277
+msgid "Show grid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1283
+msgid "Legend font size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1293
+msgid "Show legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:193
+#, fuzzy
msgid "Can display only 256 columns."
msgstr "mostrar."
-#: ../gui/wxpython/gui_modules/dbm.py:240
+#: ../gui/wxpython/gui_modules/dbm.py:242
msgid "Limit 100000 records."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:402
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:406
msgid ""
"Database connection for vector map <%s> is not defined in DB file. You can "
"define new connection in 'Manage layers' tab."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/dbm.py:437
+#: ../gui/wxpython/gui_modules/dbm.py:410
+#, fuzzy
+msgid "Attribute Table Manager"
+msgstr "Tabla"
+#: ../gui/wxpython/gui_modules/dbm.py:441
msgid "Browse data"
msgstr "Explorar datos"
-#: ../gui/wxpython/gui_modules/dbm.py:443
+#: ../gui/wxpython/gui_modules/dbm.py:447
msgid "Manage tables"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:449
+#: ../gui/wxpython/gui_modules/dbm.py:453
msgid "Manage layers"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:452
+#: ../gui/wxpython/gui_modules/dbm.py:456
msgid "Click here to show database connection information"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:453
+#: ../gui/wxpython/gui_modules/dbm.py:457
msgid "Click here to hide database connection information"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:490
-#: ../gui/wxpython/gui_modules/dbm.py:640
-#: ../gui/wxpython/gui_modules/dbm.py:2042
-#: ../gui/wxpython/gui_modules/dbm.py:2280
+#: ../gui/wxpython/gui_modules/dbm.py:494
+#: ../gui/wxpython/gui_modules/dbm.py:644
+#: ../gui/wxpython/gui_modules/dbm.py:2070
+#: ../gui/wxpython/gui_modules/dbm.py:2308
msgid "Table"
msgstr "Tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:496
+#: ../gui/wxpython/gui_modules/dbm.py:500
#, fuzzy
msgid "Attribute data - right-click to edit/manage records"
msgstr "datos"
-#: ../gui/wxpython/gui_modules/dbm.py:522
+#: ../gui/wxpython/gui_modules/dbm.py:526
msgid "SQL Query"
msgstr "Consulta SQL"
-#: ../gui/wxpython/gui_modules/dbm.py:551
-#: ../gui/wxpython/gui_modules/dbm.py:1620
+#: ../gui/wxpython/gui_modules/dbm.py:555
+#: ../gui/wxpython/gui_modules/dbm.py:1648
msgid "SQL Builder"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:555
+#: ../gui/wxpython/gui_modules/dbm.py:559
msgid "Simple"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:626
-#: ../gui/wxpython/gui_modules/dbm.py:930
-#: ../gui/wxpython/gui_modules/dbm.py:1409
-#: ../gui/wxpython/gui_modules/dbm.py:1513
+#: ../gui/wxpython/gui_modules/dbm.py:630
+#: ../gui/wxpython/gui_modules/dbm.py:934
+#: ../gui/wxpython/gui_modules/dbm.py:1413
+#: ../gui/wxpython/gui_modules/dbm.py:1541
#, python-format
msgid "Number of loaded records: %d"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:656
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:660
msgid "Table %s - right-click to delete records"
msgstr "Tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:669
-#: ../gui/wxpython/gui_modules/dbm.py:1869
+#: ../gui/wxpython/gui_modules/dbm.py:673
+#: ../gui/wxpython/gui_modules/dbm.py:1897
msgid "Column name"
msgstr "Nombre de columna"
-#: ../gui/wxpython/gui_modules/dbm.py:680
+#: ../gui/wxpython/gui_modules/dbm.py:684
msgid "Data type"
msgstr "Tipo de datos"
-#: ../gui/wxpython/gui_modules/dbm.py:697
+#: ../gui/wxpython/gui_modules/dbm.py:701
msgid "Data length"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:734
+#: ../gui/wxpython/gui_modules/dbm.py:738
msgid "To"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:744
+#: ../gui/wxpython/gui_modules/dbm.py:748
msgid "&Rename"
msgstr "Cambia&r nombre"
-#: ../gui/wxpython/gui_modules/dbm.py:800
+#: ../gui/wxpython/gui_modules/dbm.py:804
msgid "Layers of vector map"
msgstr "Capas de mapa vectorial"
-#: ../gui/wxpython/gui_modules/dbm.py:809
+#: ../gui/wxpython/gui_modules/dbm.py:813
msgid "List of layers"
msgstr "Lista de capas"
-#: ../gui/wxpython/gui_modules/dbm.py:909
-#: ../gui/wxpython/gui_modules/dbm.py:1017
+#: ../gui/wxpython/gui_modules/dbm.py:913
+#: ../gui/wxpython/gui_modules/dbm.py:1021
msgid "Insert new record"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:910
+#: ../gui/wxpython/gui_modules/dbm.py:914
msgid "Delete selected record(s)"
msgstr "Borrar registro(s) seleccionado(s)"
-#: ../gui/wxpython/gui_modules/dbm.py:911
+#: ../gui/wxpython/gui_modules/dbm.py:915
msgid "Delete all records"
msgstr "Borrar todos los registros"
-#: ../gui/wxpython/gui_modules/dbm.py:919
-#: ../gui/wxpython/gui_modules/dbm.py:1646
-#: ../gui/wxpython/gui_modules/dbm.py:1650
+#: ../gui/wxpython/gui_modules/dbm.py:923
+#: ../gui/wxpython/gui_modules/dbm.py:1674
+#: ../gui/wxpython/gui_modules/dbm.py:1678
msgid "Extract selected"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1028
+#: ../gui/wxpython/gui_modules/dbm.py:1032
#, python-format
msgid "Record with category number %d already exists in the table."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1038
+#: ../gui/wxpython/gui_modules/dbm.py:1042
#, python-format
msgid "Category number (column %s) is missing."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1046
-#: ../gui/wxpython/gui_modules/dbm.py:1143
+#: ../gui/wxpython/gui_modules/dbm.py:1050
+#: ../gui/wxpython/gui_modules/dbm.py:1147
#, python-format
msgid "Casting value '%(value)s' to %(type)s failed."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1057
+#: ../gui/wxpython/gui_modules/dbm.py:1061
msgid "Unable to insert new record."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1122
+#: ../gui/wxpython/gui_modules/dbm.py:1126
msgid "Update existing record"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1156
+#: ../gui/wxpython/gui_modules/dbm.py:1160
msgid "Unable to update existing record."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1238
+#: ../gui/wxpython/gui_modules/dbm.py:1242
#, fuzzy
msgid "Unable to rename column. No column name defined."
msgstr "nombre."
-#: ../gui/wxpython/gui_modules/dbm.py:1247
+#: ../gui/wxpython/gui_modules/dbm.py:1251
#, python-format
msgid ""
"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
"exists in the table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1263
+#: ../gui/wxpython/gui_modules/dbm.py:1267
#, python-format
msgid ""
"Unable to rename column. Column <%(column)s> doesn't exist in the table <%"
"(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1292
+#: ../gui/wxpython/gui_modules/dbm.py:1296
msgid "Drop selected column"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1295
+#: ../gui/wxpython/gui_modules/dbm.py:1299
#, fuzzy
msgid "Drop all columns"
msgstr "columnas"
-#: ../gui/wxpython/gui_modules/dbm.py:1357
+#: ../gui/wxpython/gui_modules/dbm.py:1361
#, fuzzy
msgid "Unable to add column to the table. No column name defined."
msgstr "nombre."
-#: ../gui/wxpython/gui_modules/dbm.py:1379
+#: ../gui/wxpython/gui_modules/dbm.py:1383
#, python-format
msgid "Column <%(column)s> already exists in table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1574
+#: ../gui/wxpython/gui_modules/dbm.py:1503
+#: ../gui/wxpython/gui_modules/dbm.py:1526
+#, python-format
+msgid ""
+"Loading attribute data failed. Invalid SQL 'select' statement.\n"
+"\n"
+"'%s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1602
msgid "Database connection"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1645
+#: ../gui/wxpython/gui_modules/dbm.py:1673
msgid "Nothing to extract."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1737
-#: ../gui/wxpython/gui_modules/dbm.py:2202
-#: ../gui/wxpython/gui_modules/dbm.py:2573
+#: ../gui/wxpython/gui_modules/dbm.py:1765
+#: ../gui/wxpython/gui_modules/dbm.py:2230
+#: ../gui/wxpython/gui_modules/dbm.py:2601
#, python-format
msgid "Drop also linked attribute table (%s)"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2031
-#: ../gui/wxpython/gui_modules/dbm.py:2268
+#: ../gui/wxpython/gui_modules/dbm.py:2059
+#: ../gui/wxpython/gui_modules/dbm.py:2296
msgid "Driver"
msgstr ""
msgid "Key"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:1997
+#: ../gui/wxpython/gui_modules/dbm.py:2025
msgid ""
"Unable to determine default DB connection settings. Please define DB "
"connection using db.connect module."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2014
+#: ../gui/wxpython/gui_modules/dbm.py:2042
msgid "Add layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2047
-#: ../gui/wxpython/gui_modules/dbm.py:2070
-#: ../gui/wxpython/gui_modules/dbm.py:2286
+#: ../gui/wxpython/gui_modules/dbm.py:2075
+#: ../gui/wxpython/gui_modules/dbm.py:2098
+#: ../gui/wxpython/gui_modules/dbm.py:2314
msgid "Key column"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2065
+#: ../gui/wxpython/gui_modules/dbm.py:2093
msgid "Table name"
msgstr "Nombre de tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:2078
+#: ../gui/wxpython/gui_modules/dbm.py:2106
msgid "&Create table"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2082
+#: ../gui/wxpython/gui_modules/dbm.py:2110
msgid "&Add layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2086
+#: ../gui/wxpython/gui_modules/dbm.py:2114
msgid "&Set default"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2099
+#: ../gui/wxpython/gui_modules/dbm.py:2127
#, fuzzy
msgid "Layer description"
msgstr "Capa"
-#: ../gui/wxpython/gui_modules/dbm.py:2146
+#: ../gui/wxpython/gui_modules/dbm.py:2174
msgid "Table description"
msgstr "Descripción de tabla"
-#: ../gui/wxpython/gui_modules/dbm.py:2185
-#, fuzzy
-msgid "Delete selected layer"
-msgstr "Borrar"
-#: ../gui/wxpython/gui_modules/dbm.py:2188
+#: ../gui/wxpython/gui_modules/dbm.py:2216
msgid "Layer to detele"
msgstr "Capa a borrar"
-#: ../gui/wxpython/gui_modules/dbm.py:2209
+#: ../gui/wxpython/gui_modules/dbm.py:2237
msgid "&Delete layer"
msgstr "&Borrar capa"
-#: ../gui/wxpython/gui_modules/dbm.py:2253
+#: ../gui/wxpython/gui_modules/dbm.py:2281
msgid "Modify selected layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2317
+#: ../gui/wxpython/gui_modules/dbm.py:2345
msgid "&Modify layer"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2445
+#: ../gui/wxpython/gui_modules/dbm.py:2473
#, fuzzy
msgid "Unable to create new table. Table name or key column name is missing."
msgstr "nombre nombre."
-#: ../gui/wxpython/gui_modules/dbm.py:2482
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:2510
+#, fuzzy, python-format
msgid ""
"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
"exists."
msgstr "vectorial vectorial Capa."
-#: ../gui/wxpython/gui_modules/dbm.py:2659
+#: ../gui/wxpython/gui_modules/dbm.py:2687
msgid "Database connection is not defined in DB file."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2663
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/dbm.py:2691
msgid ""
"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
"You can disable this message from digitization settings. Or you can create "
"and link attribute table to the vector map using Attribute Table Manager."
msgstr "vectorial vectorial vectorial."
-#: ../gui/wxpython/gui_modules/dbm.py:2683
+#: ../gui/wxpython/gui_modules/dbm.py:2711
#, fuzzy
msgid "Close dialog on submit"
msgstr "Cerrar"
-#: ../gui/wxpython/gui_modules/dbm.py:2690
+#: ../gui/wxpython/gui_modules/dbm.py:2718
msgid "Update attributes"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2692
+#: ../gui/wxpython/gui_modules/dbm.py:2720
msgid "Add attributes"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2694
+#: ../gui/wxpython/gui_modules/dbm.py:2722
msgid "Display attributes"
msgstr "Visualizar atributos"
-#: ../gui/wxpython/gui_modules/dbm.py:2698
+#: ../gui/wxpython/gui_modules/dbm.py:2726
msgid "&Reload"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2699
+#: ../gui/wxpython/gui_modules/dbm.py:2727
msgid "&Submit"
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:2917
+#: ../gui/wxpython/gui_modules/dbm.py:2945
msgid "No database record available."
msgstr ""
-#: ../gui/wxpython/gui_modules/dbm.py:3324 ../gui/wxpython/wxgui.py:1060
+#: ../gui/wxpython/gui_modules/dbm.py:3358 ../gui/wxpython/wxgui.py:1154
#, fuzzy
msgid "GRASS GIS Attribute Table Manager"
msgstr "Tabla"
@@ -4950,31 +6021,30 @@
msgid "GRASS SQL Builder: %s"
msgstr ""
-#: ../gui/wxpython/gui_modules/gcmd.py:81
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/gcmd.py:82
msgid "Error in command execution %s"
msgstr "Error"
-#: ../gui/wxpython/gui_modules/gcmd.py:89
+#: ../gui/wxpython/gui_modules/gcmd.py:90
msgid "Preferences error"
msgstr ""
-#: ../gui/wxpython/gui_modules/gcmd.py:96
+#: ../gui/wxpython/gui_modules/gcmd.py:97
#, fuzzy
msgid "Error in digitization tool"
msgstr "Error"
-#: ../gui/wxpython/gui_modules/gcmd.py:103
+#: ../gui/wxpython/gui_modules/gcmd.py:104
#, fuzzy
msgid "Error in Attribute Table Manager"
msgstr "Error Tabla"
-#: ../gui/wxpython/gui_modules/gcmd.py:356
+#: ../gui/wxpython/gui_modules/gcmd.py:360
msgid "Execution failed:"
msgstr ""
-#: ../gui/wxpython/gui_modules/gcmd.py:359
+#: ../gui/wxpython/gui_modules/gcmd.py:363
msgid "Details:"
msgstr ""
@@ -4984,54 +6054,51 @@
msgid "GRASS %s Map Calculator"
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:124
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/render.py:123
msgid "<%(name)s>: layer type <%(type)s> is not supported yet."
msgstr "nombre."
-#: ../gui/wxpython/gui_modules/render.py:335
+#: ../gui/wxpython/gui_modules/render.py:337
msgid "GISBASE not set. You must be in GRASS GIS to run this program."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:357
+#: ../gui/wxpython/gui_modules/render.py:368
msgid "Unable to open file"
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:511
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/render.py:527
msgid "Unable to zoom to raster map <%s>."
msgstr "ráster."
-#: ../gui/wxpython/gui_modules/render.py:514
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/render.py:530
msgid "Unable to zoom to vector map <%s>."
msgstr "vectorial."
-#: ../gui/wxpython/gui_modules/render.py:828
-#: ../gui/wxpython/gui_modules/render.py:910
+#: ../gui/wxpython/gui_modules/render.py:853
+#: ../gui/wxpython/gui_modules/render.py:935
#, python-format
msgid "Unable to render map layer <%s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1026
+#: ../gui/wxpython/gui_modules/render.py:1051
#, python-format
msgid "Unable render overlay <%s>."
msgstr ""
-#: ../gui/wxpython/gui_modules/render.py:1060
+#: ../gui/wxpython/gui_modules/render.py:1085
#, python-format
msgid "Unable render overlay <%s>"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:98
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:97
#, fuzzy
msgid "GRASS GIS Map Display: "
msgstr "Mostrar "
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:108
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:107
msgid "Map Layers"
msgstr ""
@@ -5047,133 +6114,133 @@
msgid "Properties"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:251
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:242
#, fuzzy
+msgid "Set computational region from selected map"
+msgstr "mostrar"
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:253
+#, fuzzy
msgid "Show attribute data"
msgstr "datos"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:254
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:256
msgid "Start editing"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:255
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:257
msgid "Stop editing"
msgstr ""
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:276
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:285
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:278
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:289
msgid "Metadata"
msgstr "Metadatos"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:314
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:334
#, fuzzy
+msgid "Unable to create profile of raster map."
+msgstr "No se puede crear el mapa vectorial <%s>."
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:359
+#, fuzzy
msgid "Unable to display histogram of raster map."
msgstr "mostrar ráster."
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:436
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:480
#, fuzzy
msgid "Layer group:"
msgstr "Capa:"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:487
-msgid "raster"
-msgstr "ráster"
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:490
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:493
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:499
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:502
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:505
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:508
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:511
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:514
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:517
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:520
-#: ../gui/wxpython/gui_modules/wxgui_utils.py:523
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:531
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:534
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:537
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:543
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:546
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:549
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:552
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:555
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:558
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:561
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:564
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:567
msgid "(double click to set properties)"
msgstr ""
msgid "RGB"
msgstr ""
msgid "HIS"
msgstr ""
#, fuzzy
msgid "raster cell numbers"
msgstr "ráster"
#, fuzzy
msgid "raster flow arrows"
msgstr "ráster"
-msgid "vector"
-msgstr "vectorial"
msgid "thematic map"
msgstr ""
msgid "thematic charts"
msgstr ""
msgid "grid"
msgstr ""
msgid "geodesic line"
msgstr ""
msgid "rhumbline"
msgstr ""
msgid "vector labels"
msgstr "etiquetas vectoriales"
-#: ../gui/wxpython/gui_modules/toolbars.py:541
+#: ../gui/wxpython/gui_modules/toolbars.py:604
msgid "Digitization settings"
msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:679
-#: ../gui/wxpython/gui_modules/toolbars.py:756
-#: ../gui/wxpython/gui_modules/toolbars.py:817
+#: ../gui/wxpython/gui_modules/toolbars.py:743
+#: ../gui/wxpython/gui_modules/toolbars.py:820
+#: ../gui/wxpython/gui_modules/toolbars.py:881
msgid "Select vector map"
msgstr "Seleccionar mapa vectorial"
-#: ../gui/wxpython/gui_modules/toolbars.py:761
-#, python-format
-#, fuzzy
-msgid "Do you want to save changes to vector map <%s>?"
+#: ../gui/wxpython/gui_modules/toolbars.py:825
+msgid "Do you want to save changes in vector map <%s>?"
msgstr "vectorial?"
-#: ../gui/wxpython/gui_modules/toolbars.py:763
+#: ../gui/wxpython/gui_modules/toolbars.py:827
msgid "Save changes?"
msgstr "¿Guardar cambios?"
-#: ../gui/wxpython/gui_modules/toolbars.py:823
-#: ../gui/wxpython/gui_modules/toolbars.py:828
+#: ../gui/wxpython/gui_modules/toolbars.py:887
+#: ../gui/wxpython/gui_modules/toolbars.py:892
msgid "New vector map"
msgstr "Nuevo mapa vectorial"
-#: ../gui/wxpython/gui_modules/workspace.py:180
+#: ../gui/wxpython/gui_modules/workspace.py:229
#, python-format
msgid "Unable to open file <%s> for reading."
msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:193
-#, python-format
-#, fuzzy
+#: ../gui/wxpython/gui_modules/workspace.py:242
msgid ""
"Some lines were skipped when reading settings from file <%s>.\n"
"See 'Command output' window for details.\n"
@@ -5181,29 +6248,34 @@
"Number of skipped lines: %d"
msgstr "lÃneas lÃneas"
-#: ../gui/wxpython/gui_modules/workspace.py:351
+#: ../gui/wxpython/gui_modules/workspace.py:400
#, python-format
msgid " row %d:"
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:156
+#: ../gui/wxpython/gui_modules/goutput.py:159
msgid "Unable to run the command, another command is running..."
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:189
+#: ../gui/wxpython/gui_modules/goutput.py:195
#, python-format
msgid "Command '%s' not yet implemented."
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:260
+#: ../gui/wxpython/gui_modules/goutput.py:269
msgid "Save file as..."
msgstr "Guardar archivo como..."
-#: ../gui/wxpython/gui_modules/goutput.py:292
+#: ../gui/wxpython/gui_modules/goutput.py:301
+msgid ""
+"Please note that the data are left in incosistent stage and can be corrupted"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:303
msgid "Command aborted"
msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:296
+#: ../gui/wxpython/gui_modules/goutput.py:308
#, python-format
msgid "Command finished (%d sec)"
msgstr ""
@@ -5266,6 +6338,26 @@
msgid "Create mapset"
msgstr ""
+#: ../gui/wxpython/gis_set.py:128
+#, fuzzy
+msgid "Rename mapset"
+msgstr "Cambiar nombre del directorio de mapas seleccionado"
+#, fuzzy
+msgid "Rename location"
+msgstr "Cambiar nombre de la localización seleccionada"
+#: ../gui/wxpython/gis_set.py:129
+#, fuzzy
+msgid "Delete mapset"
+msgstr "Borrar directorio de mapas seleccionado"
+#, fuzzy
+msgid "Delete location"
+msgstr "Borrar localización seleccionada"
#: ../gui/wxpython/gis_set.py:168
msgid "Welcome to GRASS GIS"
msgstr "Bienvenido a GRASS GIS"
@@ -5285,8 +6377,7 @@
msgstr ""
#: ../gui/wxpython/gis_set.py:419 ../gui/wxpython/gis_set.py:443
-#, python-format
-#, fuzzy
msgid ""
"Current name: %s\n"
"Enter new name:"
@@ -5341,17 +6432,27 @@
msgid "Unable to delete location"
msgstr ""
-#: ../gui/wxpython/gis_set.py:653
+#: ../gui/wxpython/gis_set.py:631
#, fuzzy
+msgid "Choose GIS Data Directory:"
+msgstr "Seleccionar directorio de datos de GRASS:"
+#: ../gui/wxpython/gis_set.py:646
+#, fuzzy
msgid "Enter name for new mapset:"
msgstr "nombre:"
-#: ../gui/wxpython/gis_set.py:667
+#: ../gui/wxpython/gis_set.py:647
+#, fuzzy
+msgid "Create new mapset"
+msgstr "Crear nuevo mapa vectorial"
+#: ../gui/wxpython/gis_set.py:660
#, python-format
msgid "Unable to create new mapset: %s"
msgstr ""
-#: ../gui/wxpython/gis_set.py:698
+#: ../gui/wxpython/gis_set.py:691
msgid "GRASS Quickstart"
msgstr ""
@@ -5360,90 +6461,90 @@
msgid "GRASS GIS Layer Manager (Experimental Prototype)"
msgstr "Capa"
-#: ../gui/wxpython/wxgui.py:283
+#: ../gui/wxpython/wxgui.py:293
#, fuzzy
msgid "Map layers for each display"
msgstr "mostrar"
-#: ../gui/wxpython/wxgui.py:400
+#: ../gui/wxpython/wxgui.py:409
msgid "Type GRASS command and run by pressing ENTER"
msgstr ""
-#: ../gui/wxpython/wxgui.py:505
+#: ../gui/wxpython/wxgui.py:514
#, fuzzy
msgid ""
"Workspace is not empty. Do you want to store current settings to workspace "
"file?"
msgstr "Entorno de trabajo?"
-#: ../gui/wxpython/wxgui.py:508
+#: ../gui/wxpython/wxgui.py:517
#, fuzzy
msgid "Save current settings?"
msgstr "Guardar?"
-#: ../gui/wxpython/wxgui.py:523
+#: ../gui/wxpython/wxgui.py:532
msgid "Choose workspace file"
msgstr ""
-#: ../gui/wxpython/wxgui.py:588 ../gui/wxpython/wxgui.py:593
+#: ../gui/wxpython/wxgui.py:596 ../gui/wxpython/wxgui.py:601
#, python-format
msgid ""
"Reading workspace file <%s> failed. Invalid file, unable to parse XML "
"document."
msgstr ""
-#: ../gui/wxpython/wxgui.py:598 ../gui/wxpython/wxgui.py:645
-#: ../gui/wxpython/wxgui.py:681
+#: ../gui/wxpython/wxgui.py:606 ../gui/wxpython/wxgui.py:695
+#: ../gui/wxpython/wxgui.py:731
msgid "Please wait, loading map layers into layer tree..."
msgstr ""
-#: ../gui/wxpython/wxgui.py:625
+#: ../gui/wxpython/wxgui.py:675
msgid "Unable to read workspace file"
msgstr ""
-#: ../gui/wxpython/wxgui.py:665
+#: ../gui/wxpython/wxgui.py:715
msgid "Choose GRC file to load"
msgstr ""
-#: ../gui/wxpython/wxgui.py:704
+#: ../gui/wxpython/wxgui.py:754
#, fuzzy
msgid "Choose file to save current workspace"
msgstr "guardar"
-#: ../gui/wxpython/wxgui.py:719 ../gui/wxpython/wxgui.py:736
+#: ../gui/wxpython/wxgui.py:769 ../gui/wxpython/wxgui.py:786
#, python-format
msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
-msgstr "El archivo de entorno de trabajo <%s> ya existe. ¿Quiere sobrescribirlo?"
+msgstr ""
+"El archivo de entorno de trabajo <%s> ya existe. ¿Quiere sobrescribirlo?"
-#: ../gui/wxpython/wxgui.py:812
+#: ../gui/wxpython/wxgui.py:866
#, python-format
msgid "Unable to open workspace file <%s> for writing."
msgstr ""
-#: ../gui/wxpython/wxgui.py:836
+#: ../gui/wxpython/wxgui.py:920
#, python-format
msgid "Writing current settings to workspace file failed (%s)."
msgstr ""
-#: ../gui/wxpython/wxgui.py:1036
+#: ../gui/wxpython/wxgui.py:1130
#, fuzzy
msgid "Attribute management is available only for vector maps."
msgstr "vectorial."
-#: ../gui/wxpython/wxgui.py:1330
+#: ../gui/wxpython/wxgui.py:1440
#, python-format
msgid "Do you want to remove map layer <%s> from layer tree?"
msgstr ""
-#: ../gui/wxpython/wxgui.py:1333
+#: ../gui/wxpython/wxgui.py:1443
msgid "Do you want to remove selected map layer from layer tree?"
msgstr ""
-#: ../gui/wxpython/wxgui.py:1337
+#: ../gui/wxpython/wxgui.py:1447
msgid "Remove map layer"
msgstr ""
-#: ../gui/wxpython/wxgui.py:1367
+#: ../gui/wxpython/wxgui.py:1477
msgid "No map layer selected. Operation cancelled."
msgstr ""
Added: grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ru.po (rev 0)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ru.po 2008-05-06 20:47:18 UTC (rev 31270)
@@ -0,0 +1,6005 @@
+# translation of grasswxpy_ru.po to Russian
+# This file is distributed under the same license as the GRASS package.
+# Copyright (C) 2006, GRASS Development Team
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+#: ../gui/wxpython/icons/icon.py:303
+#, fuzzy
+msgid ""
+msgstr ""
+"Project-Id-Version: grasswxpy_ru\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2008-05-06 20:32+0200\n"
+"PO-Revision-Date: 2006-07-07 11:53+0200\n"
+"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
+"Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+"X-Generator: KBabel 1.9.1\n"
+#: ../gui/wxpython/icons/icon.py:159
+msgid "Unable to load icon theme, using default icon theme..."
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:225
+msgid "Display map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:227
+msgid "Re-render map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:228
+msgid "Force re-rendering of all layers"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:230
+msgid "Erase display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:232
+msgid "Pointer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:234
+msgid "Zoom in"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:235
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:237
+msgid "Zoom out"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:238
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:240
+msgid "Pan"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:241
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:243
+msgid "Query raster/vector map(s) (display mode)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:244
+msgid "Query selected raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:246
+msgid "Query vector map (editable mode)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:247
+msgid "Query selected vector map in editable mode"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:249
+msgid "Return to previous zoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:251
+msgid "Zoom options"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:252
+msgid "Display zoom management"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:254
+msgid "Add overlay"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:255
+msgid "Add graphic overlays to map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:257
+msgid "Add scalebar and north arrow"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:259
+msgid "Add legend"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:261
+msgid "Save display to PNG file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:263
+msgid "Print display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:266
+msgid "Start new display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:268
+msgid "Create new workspace file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:270
+msgid "Load map layers into workspace"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/gui_modules/menudata.py:35
+msgid "Open existing workspace file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/gui_modules/menudata.py:50
+msgid "Save current workspace to file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:277
+msgid "Add raster map layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:279
+msgid "Add vector map layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:281
+msgid "Add command layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:283
+msgid "Add layer group"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:285
+msgid "Add grid or vector labels overlay"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:287 ../gui/wxpython/gui_modules/dbm.py:2213
+msgid "Delete selected layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:289
+msgid "Quit"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:291
+msgid "Show attribute table"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:293
+msgid "Add RGB layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:295
+msgid "Add HIS layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:297
+msgid "Add shaded relief map layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:299
+msgid "Add raster flow arrows"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:301
+msgid "Add raster cell numbers"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:305
+msgid "Add thematic layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:307
+msgid "Add thematic chart layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:309
+msgid "Add grid layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:311
+msgid "Add geodesic line layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:313
+msgid "Add rhumbline layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:315
+msgid "Add labels"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:317
+#: ../gui/wxpython/gui_modules/mapdisp.py:3353
+msgid "Add text layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:320
+msgid "Digitize new point"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:321 ../gui/wxpython/icons/icon.py:330
+msgid "Left: new point"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:323
+msgid "Digitize new line"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:324 ../gui/wxpython/icons/icon.py:327
+#: ../gui/wxpython/icons/icon.py:348
+msgid "Left: new point; Middle: undo last point; Right: close line"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:326
+msgid "Digitize new boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:329
+msgid "Digitize new centroid"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:332
+msgid "Add new vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:333 ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/icons/icon.py:339 ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:354 ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:363 ../gui/wxpython/icons/icon.py:369
+msgid "Left: Select; Middle: Unselect; Right: Confirm"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:335
+msgid "Copy categories"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:338
+msgid "Delete feature(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:341
+msgid "Display/update attributes"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:342 ../gui/wxpython/icons/icon.py:345
+msgid "Left: Select"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:344
+msgid "Display/update categories"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:347
+msgid "Edit line/boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:350
+msgid "Move feature(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:353
+msgid "Move vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:356
+msgid "Remove vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:359 ../gui/wxpython/icons/icon.py:419
+msgid "Settings"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:360
+msgid "Settings dialog for digitization tool"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:362
+msgid "Split line/boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:365
+msgid "Quit digitization tool"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:367
+msgid "Additional tools (copy, flip, connect, etc.)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:371
+msgid "Undo"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:372
+msgid "Undo previous changes"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:375
+msgid "Analyze map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:377
+msgid "Measure distance"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:379
+msgid "Draw transect in map display window to profile"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:381
+msgid "Profile surface map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:383
+msgid "Draw/re-draw profile"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:385
+msgid "Profile options"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:387
+msgid "Create histogram of image or raster file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:389
+msgid "Select font"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:391
+msgid "Select color"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:393
+msgid "Set histogram options"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:395
+msgid "Analyze"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:398
+msgid "Set GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:399
+msgid "Define GCP (Ground Control Points)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/gui_modules/menudata.py:417
+msgid "Georectify"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:403
+msgid "Recalculate RMS error"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:405
+msgid "Redraw GCP markers in map displays"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:407
+msgid "Save GCPs to POINTS file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:409
+msgid "Add new GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:411
+msgid "Delete selected GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:413
+msgid "Clear selected GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:415
+msgid "Reload GCPs from selected POINTS file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:417
+msgid "Quit georectification module"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:420
+msgid "Settings dialog for georectification tool"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:50
+msgid "Name for new vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:58
+#: ../gui/wxpython/gui_modules/preferences.py:707
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:106
+#: ../gui/wxpython/gui_modules/menudata.py:1185
+msgid "Create new vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:118
+#, python-format
+msgid "Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:119
+#: ../gui/wxpython/gui_modules/location_wizard.py:215
+#: ../gui/wxpython/gui_modules/location_wizard.py:528
+#: ../gui/wxpython/gui_modules/location_wizard.py:1330
+#: ../gui/wxpython/gui_modules/location_wizard.py:1641
+#: ../gui/wxpython/gui_modules/location_wizard.py:1742
+#: ../gui/wxpython/gui_modules/location_wizard.py:1816
+#: ../gui/wxpython/gui_modules/location_wizard.py:1917
+#: ../gui/wxpython/gui_modules/location_wizard.py:2084
+#: ../gui/wxpython/gui_modules/location_wizard.py:2103
+#: ../gui/wxpython/gui_modules/location_wizard.py:2410
+#: ../gui/wxpython/gui_modules/georect.py:882
+#: ../gui/wxpython/gui_modules/georect.py:919
+#: ../gui/wxpython/gui_modules/menuform.py:1304
+#: ../gui/wxpython/gui_modules/mapdisp.py:999
+#: ../gui/wxpython/gui_modules/mapdisp.py:1587
+#: ../gui/wxpython/gui_modules/vdigit.py:2271
+#: ../gui/wxpython/gui_modules/vdigit.py:2419
+#: ../gui/wxpython/gui_modules/vdigit.py:2446
+#: ../gui/wxpython/gui_modules/dbm.py:1063
+#: ../gui/wxpython/gui_modules/dbm.py:1162
+#: ../gui/wxpython/gui_modules/dbm.py:1244
+#: ../gui/wxpython/gui_modules/dbm.py:1256
+#: ../gui/wxpython/gui_modules/dbm.py:1270
+#: ../gui/wxpython/gui_modules/dbm.py:1363
+#: ../gui/wxpython/gui_modules/dbm.py:1385
+#: ../gui/wxpython/gui_modules/dbm.py:1506
+#: ../gui/wxpython/gui_modules/dbm.py:1529
+#: ../gui/wxpython/gui_modules/dbm.py:2475
+#: ../gui/wxpython/gui_modules/dbm.py:2513
+#: ../gui/wxpython/gui_modules/gcmd.py:54
+#: ../gui/wxpython/gui_modules/gcmd.py:71
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:336
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:361
+#: ../gui/wxpython/gui_modules/workspace.py:230 ../gui/wxpython/gis_set.py:661
+#: ../gui/wxpython/wxgui.py:677 ../gui/wxpython/wxgui.py:867
+#: ../gui/wxpython/wxgui.py:922
+msgid "Error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:161
+msgid "Load region:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:169
+msgid "Save region:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:233
+msgid "Set options"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:240
+#, python-format
+msgid ""
+"Drag %s with mouse in pointer mode to position.\n"
+"Double-click to change options."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:243
+msgid ""
+"\n"
+"Define raster map name for legend in properties dialog."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:294
+#: ../gui/wxpython/gui_modules/gdialogs.py:374
+#, python-format
+msgid "Legend of raster map <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:402
+msgid "Enter text:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:415
+msgid "Rotation:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:428
+#: ../gui/wxpython/gui_modules/preferences.py:611
+msgid "Set font"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:439
+msgid ""
+"Drag text with mouse in pointer mode to position.\n"
+"Double-click to change options"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:527
+msgid "Load"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:562
+msgid "Map layer type:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:573
+msgid "Mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:586
+msgid "Filter:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:598
+msgid "List of maps:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:654
+#: ../gui/wxpython/gui_modules/dbm.py:917
+msgid "Select all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:655
+#: ../gui/wxpython/gui_modules/dbm.py:918
+msgid "Deselect all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:129
+msgid "Define GRASS Database and Location Name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:135
+#: ../gui/wxpython/gui_modules/location_wizard.py:1064
+#: ../gui/wxpython/gui_modules/location_wizard.py:1156
+#: ../gui/wxpython/gui_modules/menuform.py:1135 ../gui/wxpython/gis_set.py:122
+msgid "Browse"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:143
+#: ../gui/wxpython/gis_set.py:98
+msgid "GIS Data Directory:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:159
+msgid "Project Location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:197
+msgid "Choose GRASS data directory:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1741
+msgid "Location already exists in GRASS Database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:211
+msgid "Unable to create location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:237
+msgid "Choose method for creating a new location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:244
+msgid "Select coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:247
+msgid "Select EPSG code of coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:249
+msgid "Use coordinate system of selected georeferenced file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:252
+msgid "Create custom PROJ.4 parameters string for coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:255
+msgid "Use arbitrary non-earth coordinate system (XY)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:320
+msgid "Choose projection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:335
+#: ../gui/wxpython/gui_modules/location_wizard.py:759
+#: ../gui/wxpython/gui_modules/location_wizard.py:767
+#: ../gui/wxpython/gui_modules/location_wizard.py:952
+#: ../gui/wxpython/gui_modules/location_wizard.py:1164
+msgid "Code"
+msgstr ""
+msgid "Description"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:338
+msgid "Projection code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:346
+#: ../gui/wxpython/gui_modules/location_wizard.py:781
+#: ../gui/wxpython/gui_modules/location_wizard.py:964
+#: ../gui/wxpython/gui_modules/location_wizard.py:1147
+msgid "Search in description:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:527
+#, python-format
+msgid "Unable to read list: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:627
+#: ../gui/wxpython/gui_modules/location_wizard.py:1341
+msgid "Choose method of specifying georeferencing parameters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:635
+msgid "Select datum with associated ellipsoid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:638
+msgid "Select ellipsoid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:639
+msgid "Set zone for UTM projection:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:641
+msgid "Zone:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:644
+msgid "Hemisphere for zone:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:732
+msgid "Specify geodetic datum"
+msgstr ""
+msgid "Ellipsoid"
+msgstr ""
+msgid "Datum"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:772
+msgid "Datum code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:796
+msgid "Transformation parameters:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:929
+msgid "Specify ellipsoid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:956
+msgid "Ellipsoid code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1057
+#: ../gui/wxpython/gui_modules/location_wizard.py:1116
+msgid "Select georeferenced file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1062
+msgid "Georeferenced file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1135
+msgid "Choose EPSG Code"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1143
+msgid "Path to the EPSG-codes file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1145
+msgid "EPSG code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1157
+msgid "Browse EPSG Codes"
+msgstr ""
+msgid "Parameters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1278
+msgid "Choose EPSG codes file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1329
+#, python-format
+msgid "Unable to read EPGS codes: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1349
+msgid "Enter PROJ.4 parameters string:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1400
+msgid "Summary"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1422
+msgid "GRASS Database:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1428
+msgid "Location Name:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1434
+msgid "Projection:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1473
+msgid "PROJ.4 definition:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1515
+#, python-format
+msgid "Do you want to create GRASS location <%s>?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1516
+msgid "Create new location?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1552
+msgid "Define new GRASS Location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1625
+msgid "Do you want to set the default region extents and resolution now?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1627
+#, python-format
+msgid "Location <%s> created"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1640
+#: ../gui/wxpython/gui_modules/location_wizard.py:1739
+#: ../gui/wxpython/gui_modules/location_wizard.py:1815
+#: ../gui/wxpython/gui_modules/location_wizard.py:1916
+#: ../gui/wxpython/gui_modules/location_wizard.py:1981
+msgid "Unable to create new location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1649
+msgid "Location wizard canceled. Location not created."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1651
+#: ../gui/wxpython/gis_set.py:126
+msgid "Location wizard"
+msgstr ""
+msgid "EPSG code missing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1935
+msgid "Select datum transformation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1949
+msgid "Datum transform is required."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1982
+msgid "file not found"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2003
+msgid "Set default region extent and resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2047
+msgid "&Set region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2083
+msgid "Invalid location selected."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2102
+msgid "Invalid region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2132
+msgid "Click here to show 3D settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2133
+msgid "Click here to hide 3D settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2156
+#: ../gui/wxpython/gui_modules/location_wizard.py:2437
+#, python-format
+msgid "Rows: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2157
+#: ../gui/wxpython/gui_modules/location_wizard.py:2438
+#, python-format
+msgid "Cols: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2158
+#: ../gui/wxpython/gui_modules/location_wizard.py:2439
+#, python-format
+msgid "Cells: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2199
+#: ../gui/wxpython/gui_modules/location_wizard.py:2441
+#, python-format
+msgid "Depth: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2200
+#: ../gui/wxpython/gui_modules/location_wizard.py:2442
+#, python-format
+msgid "3D Cells: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2203
+msgid "Top"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2211
+msgid "Bottom"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2219
+msgid "T-B resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2282
+msgid "North"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2290
+msgid "West"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2310
+msgid "East"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2319
+msgid "South"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2323
+msgid "N-S resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2331
+msgid "E-W resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2409
+#, python-format
+msgid "Invalid value: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:107
+msgid "Setup for georectification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:137
+#: ../gui/wxpython/gui_modules/georect.py:140
+msgid "Georectifying setup canceled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:175
+msgid "Set ground control points (GCPs)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:274
+msgid "Select map type and location/mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:301
+msgid "Map type to georectify"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:302
+msgid "raster"
+msgstr ""
+msgid "vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:308
+msgid "Select source location:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:319
+msgid "Select source mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:373
+msgid "You must select a valid location before selecting a mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:384
+msgid "You must select a valid location and mapset in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:401
+msgid "Select image/map group to georectify"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:420
+msgid "Select group:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:431
+msgid "Create group if none exists"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:434
+msgid "Create/edit group..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:440
+msgid "Extension for output maps:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:491
+msgid "You must select a valid image/map group in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:496
+msgid "You must enter an map name extension in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:541
+msgid "Select image/map to display for ground control point (GCP) creation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:549
+msgid "Select display image/map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:581
+msgid "You must select a valid image/map in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:605
+msgid "Create & manage ground control points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:696
+msgid "Select rectification method for rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:697
+msgid "1st order"
+msgstr ""
+msgid "2nd order"
+msgstr ""
+msgid "3rd order"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:703
+msgid "Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:774
+#, python-format
+msgid "At least %d GCPs required. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:775
+msgid "Delete GCP"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:876
+#, python-format
+msgid "POINTS file <%s> saved"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:877
+msgid "POINTS file saved"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:880
+msgid "Writing POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:917
+msgid "Reading POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:961
+msgid "RMS Error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:962
+msgid ""
+"Insufficient points defined and active (checked) for selected rectification "
+"method.\n"
+"3+ points needed for 1st order,\n"
+"6+ points for 2nd order, and\n"
+"10+ points for 3rd order."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1033
+msgid "Georectifier settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1123
+#, python-format
+msgid "RMS error for selected points forward: %s backward: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1156
+msgid "use| X coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1157
+msgid "Y coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1158
+msgid "E coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1159
+msgid "N coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1160
+msgid "Forward error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1161
+msgid "Backward error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1261
+#: ../gui/wxpython/gui_modules/georect.py:1369
+msgid "Edit GCP"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1262
+msgid "Invalid coordinate value. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1380
+msgid "Ground Control Point"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1394
+msgid "X:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1395
+msgid "Y:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1396
+msgid "E:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1397
+msgid "N:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1483
+msgid "Symbol settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1492
+msgid "Color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1509
+msgid "Width:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1537
+#: ../gui/wxpython/gui_modules/preferences.py:464
+#: ../gui/wxpython/gui_modules/profile.py:976
+#: ../gui/wxpython/gui_modules/profile.py:1321
+msgid "Apply changes for the current session"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1539
+#: ../gui/wxpython/gui_modules/preferences.py:466
+#: ../gui/wxpython/gui_modules/profile.py:978
+#: ../gui/wxpython/gui_modules/profile.py:1323
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1542
+#: ../gui/wxpython/gui_modules/preferences.py:469
+#: ../gui/wxpython/gui_modules/vdigit.py:1533
+#: ../gui/wxpython/gui_modules/profile.py:981
+#: ../gui/wxpython/gui_modules/profile.py:1326
+msgid "Close dialog and ignore changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1569
+#, python-format
+msgid "Georectifier settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:139
+#: ../gui/wxpython/gui_modules/menuform.py:1097
+msgid "Select Color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:186
+msgid "unknown"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:202
+#, python-format
+msgid "Parameter not found: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:218
+#, python-format
+msgid "Flag not found: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:252
+msgid "<required>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:253
+#, python-format
+msgid "Parameter %(name)s (%(desc)s) is missing.\n"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:608
+msgid "Enter parameters for "
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:612
+msgid " (those in bold typeface are required)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:623
+msgid "Cancel the command settings and ignore changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:642
+msgid "&Run"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:643
+msgid "Run the command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:647
+msgid "Abort the running command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:650
+msgid "Copy the current command string to the clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:673
+#: ../gui/wxpython/gui_modules/preferences.py:717
+msgid "Close dialog on finish"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:784
+#, python-format
+msgid "'%s' copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:802
+#, python-format
+msgid ""
+"This is a sample program for\n"
+"GRASS command interface parsing\n"
+"and automatic GUI building.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:805
+msgid "About wxPython GRASS GUI"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:841
+#: ../gui/wxpython/gui_modules/menuform.py:854
+#: ../gui/wxpython/gui_modules/menuform.py:1189
+msgid "Required"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:844
+msgid "Optional"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:881 ../gui/wxpython/wxgui.py:297
+msgid "Command output"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:887
+msgid "Manual"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:956
+msgid "[multiple]"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:993
+msgid "Valid range"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1116
+msgid "Transparent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1133
+#, python-format
+msgid "Choose %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1134
+#: ../gui/wxpython/gui_modules/menudata.py:26
+msgid "File"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1323
+#, python-format
+msgid "Unable to fetch interface description for command '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1407
+#, python-format
+msgid "Unable to parse command %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1468
+#, python-format
+msgid "usage: %s <grass command>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:29
+msgid "Enter rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:49
+msgid "Create new color table using color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:50
+msgid "Raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:52
+msgid "Enter color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:55
+msgid "Reclassify raster map using rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:56
+msgid "Raster map to reclassify:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:57
+msgid "Reclassified raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:58
+#: ../gui/wxpython/gui_modules/rules.py:70
+msgid "Enter reclassification rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:61
+msgid "Recode raster map using rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:62
+msgid "Raster map to recode:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:63
+msgid "Recoded raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:64
+msgid "Enter recoding rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:67
+msgid "Reclassify vector map using SQL rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:68
+msgid "Vector map to reclassify:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:69
+msgid "Reclassified vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:102
+msgid "overwrite existing file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:998
+#: ../gui/wxpython/gui_modules/mapdisp.py:1586
+msgid "No vector map selected for editing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1133
+#: ../gui/wxpython/gui_modules/mapdisp.py:1142
+msgid "Update categories"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1679
+msgid "Z bulk-labeling dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2120
+msgid "Zoom to saved region extents"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2171
+#, python-format
+msgid "Region file <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2173
+#: ../gui/wxpython/gui_modules/workspace.py:246
+msgid "Warning"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2219
+msgid "GRASS GIS - Map display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2287
+msgid "Coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2288
+msgid "Extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2289
+msgid "Comp. region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2290
+msgid "Show comp. extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2291
+msgid "Display mode"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2292
+msgid "Display geometry"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2293
+msgid "Map scale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2298
+msgid "Render"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2301
+msgid "Enable/disable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2304
+msgid "Show computational extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2309
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2317
+#: ../gui/wxpython/gui_modules/preferences.py:658
+msgid "Constrain display resolution to computational settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2321
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2415
+msgid "Map Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2427
+msgid "Digit Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2444
+msgid "Georectification Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2914
+msgid "No map layer selected for querying."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2915
+#: ../gui/wxpython/gui_modules/mapdisp.py:2974
+#: ../gui/wxpython/gui_modules/vdigit.py:758
+#: ../gui/wxpython/gui_modules/dbm.py:2697 ../gui/wxpython/wxgui.py:1134
+#: ../gui/wxpython/wxgui.py:1480
+msgid "Message"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2973
+msgid "No vector map selected for querying."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3126
+#, python-format
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3133
+msgid "Measuring distance"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3137
+msgid "Measuring distance:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3295
+msgid "Scale and North arrow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3301
+msgid "Show/hide scale and North arrow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3302
+msgid "scale object"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3328
+msgid "Show/hide legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3329
+msgid "legend object"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3401
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:240
+msgid "Zoom to selected map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3405
+msgid "Zoom to computational region (set with g.region)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3409
+msgid "Zoom to default region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3413
+msgid "Zoom to saved region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3417
+msgid "Set computational region from display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3421
+msgid "Save display geometry to named region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:27
+#: ../gui/wxpython/gui_modules/preferences.py:852
+msgid "Workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:29
+msgid "New workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:30
+msgid "Create new workspace file (erase current workspace settings first)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:34
+msgid "Open existing workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:39
+msgid "Load map layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:40 ../gui/wxpython/wxgui.py:687
+msgid "Load map layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:44
+msgid "Load GRC file (Tcl/Tk GUI)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:45
+msgid "Load map layers from GRC file to layer tree (not fully implemented)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:49 ../gui/wxpython/wxgui.py:771
+#: ../gui/wxpython/wxgui.py:789
+msgid "Save workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:54
+msgid "Save workspace as"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:55
+msgid "Save current workspace as file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:59
+msgid "Close current workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:60
+msgid "Close current workspace file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:66
+msgid "Import raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:68
+msgid "Multiple import formats using GDAL"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:69
+msgid "Import GDAL supported raster file into a binary raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:74
+msgid "Aggregate ASCII xyz import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:75
+msgid ""
+"Create a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:79
+msgid "ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:80
+msgid "Converts ASCII raster file to binary raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:84
+msgid "ASCII polygons and lines import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:85
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:90
+msgid "Binary file import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:91
+msgid "Import a binary raster file into a GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:95
+msgid "ESRI ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:96
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+"map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:100
+msgid "GRIDATB.FOR import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:101
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:105
+msgid "MAT-File (v.4) import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:106
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:110
+msgid "SPOT NDVI import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:111
+msgid "Import of SPOT VGT NDVI file into a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:115
+msgid "SRTM HGT import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:116
+msgid "Import SRTM HGT files into GRASS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:120
+msgid "Terra ASTER HDF import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:121
+msgid ""
+"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+"using gdalwarp."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:126
+msgid "WMS import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:127
+msgid "Downloads and imports data from WMS servers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:132
+msgid "Import vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:134
+#: ../gui/wxpython/gui_modules/menudata.py:197
+msgid "Multiple import formats using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:135
+msgid "Convert OGR vector layers to GRASS vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:140
+msgid "ASCII points/GRASS ASCII vector import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:141
+msgid "Creates a vector map from ASCII points file or ASCII vector file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:145
+msgid "Old GRASS vector import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:146
+msgid "Imports older versions of GRASS vector maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:151
+msgid "DXF import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:152
+msgid "Converts files in DXF format to GRASS vector map format."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:156
+msgid "ESRI e00 import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:157
+msgid "Import E00 file into a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:161
+msgid "Garmin GPS import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:162
+msgid ""
+"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:166
+msgid "GPSBabel GPS import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:167
+msgid ""
+"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+"file into a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:171
+msgid "GEOnet import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:172
+msgid ""
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:176
+msgid "Matlab and MapGen import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:177
+msgid "Import Mapgen or Matlab vector maps into GRASS."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:182
+msgid "Import grid 3D volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:184
+msgid "ASCII 3D import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:185
+msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:189
+msgid "Vis5D import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:190
+msgid ""
+"import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable and 1 "
+"time step)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:195
+msgid "Import database table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:198
+msgid "Imports attribute tables in various formats."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:204
+msgid "Export raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:206
+msgid "Multiple export formats using GDAL"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:207
+msgid "Exports GRASS raster map into GDAL supported formats."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:212
+msgid "ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:213
+msgid "Converts a raster map layer into an ASCII text file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:217
+msgid "ASCII x,y,z export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:218
+msgid ""
+"Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:223
+msgid "ESRI ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:224
+msgid "Converts a raster map layer into an ESRI ARCGRID file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:228
+msgid "GRIDATB.FOR export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:229
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:233
+msgid "MAT-File (v.4) export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:234
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:239
+msgid "Binary export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:240
+msgid "Exports a GRASS raster to a binary array."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:245
+msgid "MPEG-1 export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:246
+msgid "Raster File Series to MPEG Conversion Program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:250
+msgid "PNG export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:251
+msgid "Export GRASS raster as non-georeferenced PNG image format."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:255
+msgid "PPM export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:256
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the currently defined region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:260
+msgid "PPM from RGB export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:261
+msgid ""
+"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+"resolution of the CURRENTLY DEFINED REGION."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:265
+#: ../gui/wxpython/gui_modules/menudata.py:304
+msgid "POV-Ray export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:266
+msgid "Converts a raster map layer into a height-field file for POVRAY."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:270
+msgid "TIFF export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:271
+msgid ""
+"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+"resolution of the currently defined region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:275
+msgid "VRML export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:276
+msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:280
+#: ../gui/wxpython/gui_modules/menudata.py:314
+#: ../gui/wxpython/gui_modules/menudata.py:332
+msgid "VTK export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:281
+msgid "Converts raster maps into the VTK-Ascii format"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:286
+msgid "Export vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:288
+msgid "Multiple export formats using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:289
+msgid "Converts to one of the supported OGR vector formats."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:294
+msgid "ASCII points/GRASS ASCII vector export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:295
+msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:299
+msgid "DXF export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:300
+msgid "Exports GRASS vector map layers to DXF file format."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:305
+msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:309
+msgid "SVG export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:310
+msgid "Exports a GRASS vector map to SVG."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:315
+msgid "Converts a GRASS binary vector map to VTK ASCII output."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:320
+msgid "Export grid 3D volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:322
+msgid "ASCII 3D export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:323
+msgid "Converts a 3D raster map layer into an ASCII text file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:327
+msgid "Vis5D export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:328
+msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:333
+msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:339
+msgid "Manage maps and volumes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:341
+msgid "Copy"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:342
+msgid ""
+"Copies available data files in the user's current mapset search path and "
+"location to the appropriate element directories under the user's current "
+"mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:347
+msgid "List"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:348
+msgid ""
+"Lists available GRASS data base files of the user-specified data type to "
+"standard output."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:352
+msgid "List filtered"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:353
+msgid "Apply regular expressions and wildcards to g.list"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:358
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:224
+msgid "Rename"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:359
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:364
+msgid "Delete"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:365
+msgid "Removes data base element files from the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:369
+msgid "Delete filtered"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:370
+msgid "Apply regular expressions and wildcards to g.remove"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:375
+msgid "Map type conversions"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:377
+msgid "Raster to vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:378
+msgid "Converts a raster map into a vector map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:382
+msgid "Raster series to volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:383
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:387
+msgid "Raster 2.5D to volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:388
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:393
+msgid "Vector to raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:394
+msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:398
+msgid "Vector to volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:399
+msgid ""
+"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+"raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:403
+msgid "Sites to vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:404
+msgid "Converts a GRASS site_lists file into a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:409
+msgid "Volume to raster series"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:410
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:418
+msgid "Georectify raster and vector maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:423
+msgid "NVIZ (requires Tcl/Tk)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:424
+msgid "nviz - Visualization and animation tool for GRASS data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:429
+msgid "Bearing/distance to coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:430
+msgid "It assumes a cartesian coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:435
+msgid "Postscript plot"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:436
+msgid "Hardcopy PostScript map output utility."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:441
+msgid "E&xit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:442
+msgid "Exit GUI"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:447
+msgid "Config"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:448
+msgid "Region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:450
+msgid "Display region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:451
+#: ../gui/wxpython/gui_modules/menudata.py:456
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:455
+msgid "Set region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:461
+msgid "GRASS working environment"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:463
+msgid "Mapset access"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:464
+msgid "Set/unset access to other mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:468
+msgid "Change working environment"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:469
+msgid "Change current mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:473
+msgid "User access"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:474
+msgid "Controls access to the current mapset for other users on the system."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:478
+msgid "Show settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:479
+#: ../gui/wxpython/gui_modules/menudata.py:484
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:483
+msgid "Change settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:488
+msgid "Version"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:489
+msgid "Displays version and copyright information."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:494
+#: ../gui/wxpython/gui_modules/menudata.py:496
+msgid "Manage projections"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:497
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format). Can also be used to create "
+"GRASS locations."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:501
+msgid "Projection for current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:502
+msgid "Create/edit projection information for current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:507
+msgid "Convert coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:508
+msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:514
+msgid "Preferences"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:515
+msgid "User GUI preferences (display font, commands, digitizer, etc.)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:520
+msgid "Raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:521
+msgid "Develop raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:523
+msgid "Digitize raster (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:524
+msgid "Digitize raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:529
+msgid "Compress/decompress"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:530
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:535
+msgid "Region boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:536
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:540
+msgid "Manage NULL values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:541
+msgid "Creates explicitly the NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:545
+msgid "Quantization"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:546
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:550
+msgid "Timestamp"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:551
+msgid "Print/add/remove a timestamp for a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:556
+msgid "Resample using aggregate statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:557
+msgid "Resamples raster map layers using aggregation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:561
+msgid "Resample using multiple methods"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:562
+msgid "Resamples raster map layers using interpolation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:566
+msgid "Resample using nearest neighbor"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:567
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:571
+msgid "Resample using spline tension"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:572
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:577
+msgid "Support file maintenance"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:578
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:582
+msgid "Update map statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:583
+msgid "Update raster map statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:588
+msgid "Reproject raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:589
+msgid "Re-projects a raster map from one location to the current location."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:593
+msgid "Tiling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:594
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:599
+msgid "Manage colors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:601
+msgid "Color tables"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:602
+msgid "Creates/modifies the color table associated with a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:606
+msgid "Color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:607
+msgid "Set colors interactively by entering color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:612
+msgid "Blend 2 color rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:613
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:617
+msgid "Create RGB"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:618
+msgid ""
+"Combines red, green and blue map layers into a single composite map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:622
+#: ../gui/wxpython/gui_modules/menudata.py:1576
+msgid "RGB to HIS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:623
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:629
+msgid "Query by coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:630
+msgid "Queries raster map layers on their category values and category labels."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:635
+msgid "Buffer rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:636
+msgid ""
+"Creates a raster map layer showing buffer zones surrounding cells that "
+"contain non-NULL category values."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:640
+msgid "Closest points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:641
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:645
+msgid "Mask"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:646
+msgid "Create a MASK for limiting raster operation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:650
+msgid "Map calculator"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:651
+msgid "Map calculator for raster map algebra"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:654
+msgid "Neighborhood analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:656
+msgid "Moving window"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:657
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:661
+msgid "Neighborhood points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:662
+msgid ""
+"Makes each cell value a function of the attribute values assigned to the "
+"vector points or centroids around it, and stores new cell values in an "
+"output raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:667
+msgid "Overlay rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:669
+msgid "Cross product"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:670
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:674
+msgid "Raster series"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:675
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:679
+msgid "Patch raster maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:680
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:685
+msgid "Statistical overlay"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:686
+msgid "Calculates category or object oriented statistics."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:691
+msgid "Solar radiance and shadows"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:693
+msgid "Solar irradiance and irradiation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:694
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:698
+msgid "Shadows map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:699
+msgid ""
+"Calculates cast shadow areas from sun position and DEM. Either A: exact sun "
+"position is specified, or B: date/time to calculate the sun position by r."
+"sunmask itself."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:704
+msgid "Terrain analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:706
+msgid "Cumulative movement costs"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:707
+msgid ""
+"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input elevation raster map "
+"layer whose cell category values represent elevation combined with an input "
+"raster map layer whose cell values represent friction cost."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:711
+msgid "Cost surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:712
+msgid ""
+"Outputs a raster map layer showing the cumulative cost of moving between "
+"different geographic locations on an input raster map layer whose cell "
+"category values represent cost."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:716
+msgid "Least cost route or flow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:717
+msgid "Traces a flow through an elevation model on a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:722
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:540
+msgid "Shaded relief"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:723
+msgid "Creates shaded relief map from an elevation map (DEM)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:728
+msgid "Slope and aspect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:729
+msgid ""
+"Generates raster map layers of slope, aspect, curvatures and partial "
+"derivatives from a raster map layer of true elevation values. Aspect is "
+"calculated counterclockwise from east."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:733
+msgid "Terrain parameters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:734
+msgid ""
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:738
+msgid "Textural features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:739
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:744
+msgid "Visibility"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:745
+msgid "Line-of-sight raster analysis program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:750
+msgid "Transform features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:752
+msgid "Clump"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:753
+msgid ""
+"Recategorizes data in a raster map layer by grouping cells that form "
+"physically discrete areas into unique categories."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:757
+msgid "Grow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:758
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:762
+msgid "Thin"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:763
+msgid "Thins non-zero cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:769
+msgid "Hydrologic modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:771
+msgid "Carve stream channels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:772
+msgid ""
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:776
+msgid "Fill lake"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:777
+msgid "Fills lake from seed at given level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:782
+msgid "Depressionless map and flowlines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:783
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:787
+msgid "Flow accumulation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:788
+msgid "Flow computation for massive grids (Float version)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:792
+msgid "Flow lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:793
+msgid ""
+"Construction of slope curves (flowlines), flowpath lengths, and flowline "
+"densities (upslope areas) from a raster digital elevation model (DEM)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:798
+msgid "SIMWE Overland flow modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:799
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:803
+msgid "SIMWE Sediment flux modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:804
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:809
+msgid "Topographic index map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:810
+msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:814
+msgid "TOPMODEL simulation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:815
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:820
+msgid "Watershed subbasins"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:821
+msgid "Generates a raster map layer showing watershed subbasins."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:825
+msgid "Watershed analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:826
+msgid "Watershed basin analysis program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:830
+msgid "Watershed basin creation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:831
+msgid "Watershed basin creation program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:836
+msgid "Landscape structure modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:838
+msgid "Set up (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:839
+#: ../gui/wxpython/gui_modules/menudata.py:862
+msgid "Set up sampling and analysis framework"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:844
+msgid "Analyze landscape"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:845
+msgid ""
+"Contains a set of measures for attributes, diversity, texture, "
+"juxtaposition, and edge."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:849
+msgid "Analyze patches"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:850
+msgid ""
+"Calculates attribute, patch size, core (interior) size, shape, fractal "
+"dimension, and perimeter measures for sets of patches in a landscape."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:854
+msgid "Output"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:855
+msgid ""
+"Displays the boundary of each r.le patch and shows how the boundary is "
+"traced, displays the attribute, size, perimeter and shape indices for each "
+"patch and saves the data in an output file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:860
+msgid "Landscape patch analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:863
+msgid "Configuration editor for r.li.'index'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:868
+msgid "Edge density"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:869
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:873
+msgid "Contrast weighted edge density"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:874
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:879
+msgid "Patch area mean"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:880
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:884
+msgid "Patch area range"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:885
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:889
+msgid "Patch area Std Dev"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:890
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:894
+msgid "Patch area Coeff Var"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:895
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:899
+msgid "Patch density"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:900
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:904
+msgid "Patch number"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:905
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:910
+msgid "Dominance's diversity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:911
+#: ../gui/wxpython/gui_modules/menudata.py:927
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:915
+msgid "Shannon's diversity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:916
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:920
+msgid "Simpson's diversity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:921
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:926
+msgid "Richness"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:931
+msgid "Shape index"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:932
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:937
+msgid "Wildfire modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:939
+msgid "Rate of spread"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:940
+msgid ""
+"Generates three, or four raster map layers showing 1) the base "
+"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
+"direction of the maximum ROS, and optionally 4) the maximum potential "
+"spotting distance."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:944
+msgid "Least-cost spread paths"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:945
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:949
+msgid "Anisotropic spread simulation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:950
+msgid ""
+"It optionally produces raster maps to contain backlink UTM coordinates for "
+"tracing spread paths."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:956
+msgid "Change category values and labels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:958
+msgid "Interactively edit category values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:959
+msgid "Interactively edit cell values in a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:964
+msgid "Reclassify by size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:965
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:969
+msgid "Reclassify interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:970
+msgid "Reclassify raster categories interactively by entering reclass rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:974
+msgid "Reclassify using rules file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:975
+msgid ""
+"Creates a new map layer whose category values are based upon a "
+"reclassification of the categories in an existing raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:980
+msgid "Recode interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:981
+msgid ""
+"Recode raster categories interactively by entering recode rules (create new "
+"raster map)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:985
+msgid "Recode using rules file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:986
+msgid ""
+"r.recode.rules - Use ascii rules file to recode categories in raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:991
+msgid "Rescale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:992
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:996
+msgid "Rescale with histogram"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:997
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1004
+msgid "Concentric circles"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1005
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1008
+msgid "Generate random cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1010
+msgid "Random cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1011
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1015
+msgid "Random cells and vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1016
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"sites."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1021
+msgid "Generate surfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1023
+msgid "Fractal surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1024
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1029
+msgid "Gaussian kernel density surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1030
+msgid ""
+"Generates a raster density map from vector points data using a moving 2D "
+"isotropic Gaussian kernel or optionally generates a vector density map on "
+"vector network with a 1D kernel."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1034
+msgid "Gaussian deviates surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1035
+msgid ""
+"GRASS module to produce a raster map layer of gaussian deviates whose mean "
+"and standard deviation can be expressed by the user. It uses a gaussian "
+"random number generator."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1040
+msgid "Plane"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1041
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1046
+msgid "Random deviates surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1047
+msgid ""
+"Produces a raster map layer of uniform random deviates whose range can be "
+"expressed by the user."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1051
+msgid "Random surface with spatial dependence"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1052
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1058
+msgid "Generate contour lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1059
+msgid ""
+"Produces a vector map layer of specified contours from a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1062
+msgid "Interpolate surfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1064
+msgid "Bilinear from raster points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1065
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1069
+msgid "Bilinear and bicubic from vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1070
+msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1075
+msgid "IDW from raster points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1076
+msgid "Surface interpolation utility for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1080
+msgid "IDW from vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1081
+msgid ""
+"Surface interpolation from vector point data by Inverse Distance Squared "
+"Weighting."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1086
+msgid "Raster contours"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1087
+msgid "Surface generation program from rasterized contours."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1091
+msgid "Regularized spline tension"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1092
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1097
+msgid "Fill NULL cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1098
+msgid ""
+"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1104
+#: ../gui/wxpython/gui_modules/menudata.py:1685
+msgid "Report and statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1106
+msgid "Basic raster metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1107
+msgid "Output basic information about a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1111
+msgid "Manage category information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1112
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1117
+msgid "General statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1118
+msgid "Generates area statistics for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1122
+msgid "Range of category values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1123
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1127
+msgid "Sum category values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1128
+msgid "Sums up the raster cell values."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1132
+msgid "Sum area by raster map and category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1133
+msgid "Reports statistics for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1137
+msgid "Statistics for clumped cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1138
+msgid ""
+"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
+"vector points map containing the calculated centroids of these clumps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1142
+msgid "Total corrected area"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1143
+msgid "Surface area estimation for rasters."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1147
+msgid "Univariate raster statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1148
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1153
+msgid "Sample transects"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1154
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1158
+msgid "Sample transects (bearing/distance)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1159
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1164
+msgid "Covariance/correlation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1165
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map layer"
+"(s)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1169
+msgid "Linear regression"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1170
+msgid "Calculates linear regression from two raster maps: y = a + b*x"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1174
+msgid "Mutual category occurrences"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1175
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1182
+msgid "Vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1183
+msgid "Develop vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1186
+msgid "Create new empty vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1191
+msgid "Create/rebuild topology"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1192
+msgid "Creates topology for GRASS vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1196
+msgid "Clean vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1197
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1201
+msgid "Generalization"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1202
+msgid "Vector based generalization."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1207
+msgid "Convert object types"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1208
+msgid "Change the type of geometry elements."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1213
+msgid "Add centroids"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1214
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1219
+msgid "Build polylines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1220
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1224
+msgid "Split polylines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1225
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1229
+msgid "Parallel lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1230
+msgid "Create parallel line to input lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1235
+msgid "Dissolve boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1236
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1241
+msgid "Create 3D vector over raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1242
+msgid "Converts vector map to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1246
+msgid "Extrude 3D vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1247
+msgid "Extrudes flat vector object to 3D with defined height."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1252
+msgid "Link to OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1253
+msgid ""
+"Available drivers: ESRI Shapefile,MapInfo File,UK .NTF,SDTS,TIGER,S57,DGN,"
+"VRT,REC,Memory,BNA,CSV,GML,GPX,KML,GeoJSON,GMT,SQLite,ODBC,PGeo,PostgreSQL,"
+"AVCBin"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1258
+msgid "Create labels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1259
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1264
+msgid "Reposition vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1265
+msgid ""
+"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1269
+msgid "Reproject vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1270
+msgid "Allows projection conversion of vector maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1277
+msgid "Query with attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1278
+msgid ""
+"Selects vector objects from an existing vector map and creates a new map "
+"containing only the selected objects."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1282
+msgid "Query with coordinate(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1283
+msgid "Queries a vector map layer at given locations."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1287
+msgid "Query with another vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1288
+msgid "Select features from ainput by features from binput"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1293
+msgid "Buffer vectors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1294
+msgid ""
+"Creates a buffer around features of given type (areas must contain centroid)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1297
+msgid "Lidar analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1299
+msgid "Detect edges"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1300
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1304
+msgid "Detect interiors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1305
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1309
+msgid "Correct and reclassify objects"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1310
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1315
+msgid "Linear referencing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1317
+msgid "Create LRS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1318
+msgid "Create Linear Reference System"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1322
+msgid "Create stationing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1323
+msgid "Create stationing from input lines, and linear reference system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1327
+msgid "Create points/segments"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1328
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1332
+msgid "Find line id and offset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1333
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1339
+msgid "Nearest features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1340
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1343
+msgid "Network analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1345
+msgid "Allocate subnets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1346
+msgid ""
+"Centre node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1350
+msgid "Network maintenance"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1351
+msgid "Network maintenance."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1355
+msgid "Visibility network"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1356
+msgid "Visibility graph construction."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1360
+msgid "Shortest path"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1361
+msgid "Finds shortest path on vector network."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1365
+msgid "Display shortest route (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1366
+msgid ""
+"Display shortest route along network between 2 nodes (visualization only, "
+"requires XTerm))"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1370
+msgid "Split net"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1371
+msgid ""
+"Splits net to bands between cost isolines (direction from centre). Centre "
+"node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1375
+msgid "Steiner tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1376
+msgid ""
+"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
+"is used in this module so the result may be sub optimal"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1380
+msgid "Traveling salesman analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1381
+msgid ""
+"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
+"created cycle may be sub optimal"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1386
+#: ../gui/wxpython/gui_modules/menudata.py:1388
+msgid "Overlay vector maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1389
+msgid "Overlays two vector maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1393
+msgid "Patch vector maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1394
+msgid "Create a new vector map layer by combining other vector map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1400
+msgid "Change attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1402
+msgid "Manage or report categories"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1403
+msgid "Attach, delete or report vector categories to map geometry."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1407
+msgid "Reclassify objects interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1408
+msgid "Reclassify vector objects interactively by entering SQL rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1412
+msgid "Reclassify objects using rules file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1413
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1420
+msgid "Generate area for current region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1421
+msgid "Create a new vector from the current region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1424
+msgid "Generate areas from points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1426
+msgid "Convex hull"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1427
+msgid "Uses a GRASS vector points map to produce a convex hull vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1431
+msgid "Delaunay triangles"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1432
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1436
+msgid "Voronoi diagram/Thiessen polygons"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1437
+msgid ""
+"Creates a Voronoi diagram from an input vector map containing points or "
+"centroids."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1443
+msgid "Generate grid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1444
+msgid "Creates a GRASS vector map of a user-defined grid."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1447
+msgid "Generate points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1449
+msgid "Generate from database"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1450
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1454
+msgid "Generate points along lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1455
+msgid "Create points along input lines in new vector with 2 layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1459
+msgid "Generate random points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1460
+msgid "Randomly generate a 2D/3D vector points map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1464
+msgid "Perturb points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1465
+msgid "Random location perturbations of GRASS vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1472
+msgid "Remove outliers in point sets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1473
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1477
+msgid "Test/training point sets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1478
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1483
+msgid "Update area attributes from raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1484
+msgid ""
+"Calculates univariate statistics from a GRASS raster map based on vector "
+"polygons and uploads statistics to new attribute columns."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1488
+msgid "Update point attributes from areas"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1489
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1492
+msgid "Update point attributes from raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1494
+msgid "Sample raster maps at point locations"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1495
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1499
+msgid "Sample raster neighborhood around points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1500
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1506
+msgid "Reports and statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1508
+msgid "Basic vector metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1509
+msgid "Outputs basic information about a user-specified vector map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1514
+msgid "Report topology by category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1515
+msgid "Reports geometry statistics for vectors."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1519
+msgid "Upload or report topology"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1520
+msgid "Populate database values from vector features."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1525
+msgid "Univariate attribute statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1526
+msgid ""
+"Calculates univariate statistics for attribute. Variance and standard "
+"deviation is calculated only for points if specified."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1531
+msgid "Quadrat indices"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1532
+msgid "Indices for quadrat counts of sites lists."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1536
+msgid "Test normality"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1537
+msgid "Tests for normality for points."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1544
+msgid "Imagery"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1545
+msgid "Develop images and groups"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1547
+msgid "Create/edit group"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1548
+msgid "Creates, edits, and lists groups and subgroups of imagery files."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1552
+msgid "Target group"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1553
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1558
+msgid "Mosaic images"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1559
+msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1564
+msgid "Manage image colors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1566
+msgid "Color balance for RGB"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1567
+msgid "Auto-balancing of colors for LANDSAT images"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1571
+msgid "HIS to RGB"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1572
+msgid ""
+"Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
+"transformation function."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1577
+msgid ""
+"Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
+"transformation function"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1583
+msgid "Rectify image or raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1584
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1588
+msgid "Ortho photo rectification (requires Xterm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1589
+msgid "Ortho Photo rectification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1594
+msgid "Brovey sharpening"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1595
+msgid ""
+"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1598
+msgid "Classify image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1600
+msgid "Clustering input for unsupervised classification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1601
+msgid ""
+"The resulting signature file is used as input for i.maxlik, to generate an "
+"unsupervised image classification."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1606
+msgid "Maximum likelihood classification (MLC)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1607
+msgid ""
+"Classification is based on the spectral signature information generated by "
+"either i.cluster, i.class, or i.gensig."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1611
+msgid "Sequential maximum a posteriori classification (SMAP)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1612
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1617
+msgid "Interactive input for supervised classification (requires Xterm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1618
+msgid "Interactive input for supervised classification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1622
+msgid "Input for supervised MLC"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1623
+msgid "Generates statistics for i.maxlik from raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1627
+msgid "Input for supervised SMAP"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1628
+msgid "Generate statistics for i.smap from raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1633
+msgid "Filter image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1635
+msgid "Edge detection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1636
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1640
+msgid "Matrix/convolving filter"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1641
+msgid "Raster map matrix filter."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1647
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:285
+msgid "Histogram"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1648
+msgid "Generate histogram of image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1652
+msgid "Spectral response"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1653
+msgid ""
+"displays spectral response at user specified locations in group or images"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1657
+msgid "Tasseled cap vegetation index"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1658
+msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1661
+msgid "Transform image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1663
+msgid "Canonical correlation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1664
+msgid "Canonical components analysis (cca) program for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1668
+msgid "Principal components"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1669
+msgid "Principal components analysis (pca) program for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1673
+msgid "Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1674
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1678
+msgid "Inverse Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1679
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1687
+msgid "Bit pattern comparison "
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1688
+msgid "Compares bit patterns with a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1692
+msgid "Kappa analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1693
+msgid ""
+"Calculate error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1697
+msgid "OIF for LandSat TM"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1698
+msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1705
+msgid "Volumes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1706
+msgid "Develop volumes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1708
+msgid "Manage 3D NULL values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1709
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1713
+msgid "Manage timestamp"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1714
+msgid "Print/add/remove a timestamp for a 3D raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1721
+msgid "3D Mask"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1722
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1726
+msgid "3D raster map calculator"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1727
+msgid "Map calculator for volumetric map algebra"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1731
+msgid "Cross section"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1732
+msgid ""
+"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
+"map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1736
+msgid "Interpolate volume from points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1737
+msgid ""
+"Interpolates point data to a G3D grid volume using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1741
+msgid "Report and Statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1743
+msgid "Basic volume metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1744
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1751
+#: ../gui/wxpython/gui_modules/dbm.py:1950
+#: ../gui/wxpython/gui_modules/dbm.py:2064
+#: ../gui/wxpython/gui_modules/dbm.py:2302
+msgid "Database"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1752
+msgid "Database information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1754
+msgid "Describe table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1755
+msgid "Describes a table in detail."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1759
+msgid "List columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1760
+msgid "List all columns for a given table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1764
+msgid "List drivers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1765
+msgid "List all database drivers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1769
+msgid "List tables"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1770
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1776
+msgid "Manage databases"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1778
+msgid "Connect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1779
+msgid "Prints/sets general DB connection for current mapset and exits."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1783
+msgid "Login"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1784
+#: ../gui/wxpython/gui_modules/menudata.py:1800
+msgid "Sets user/password for driver/database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1789
+msgid "Copy table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1790
+msgid ""
+"Copy a table. Either 'from_table' (optionaly with 'where') can be used or "
+"'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1794
+msgid "New table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1795
+msgid ""
+"Creates and adds a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1799
+msgid "Remove table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1805
+msgid "Add columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1806
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1810
+msgid "Change values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1811
+msgid ""
+"Allows to update a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1815
+#: ../gui/wxpython/gui_modules/dbm.py:728
+msgid "Rename column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1816
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1821
+msgid "Test"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1822
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1827
+msgid "Query"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1829
+msgid "Query any table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1830
+msgid "Selects data from table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1834
+msgid "Query vector attribute data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1835
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1839
+msgid "SQL statement"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1840
+msgid "Executes any SQL statement."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1846
+msgid "Vector database connections"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1848
+msgid "Reconnect vector to database"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1849
+msgid "Reconnects vectors to a new database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1853
+msgid "Set vector map - database connection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1854
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1861
+msgid "Help"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1863
+msgid "GRASS GIS help"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1864
+#: ../gui/wxpython/gui_modules/menudata.py:1869
+msgid "Display the HTML man pages of GRASS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1868
+msgid "GRASS GIS GUI help"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1873
+#: ../gui/wxpython/gui_modules/menudata.py:1874
+msgid "About GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:172
+msgid "Segment break"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:218
+msgid "Mapset search path"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:219
+msgid "All available mapsets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:220
+#: ../gui/wxpython/gui_modules/dbm.py:909
+msgid "Edit selected record"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:221
+#: ../gui/wxpython/gui_modules/dbm.py:920
+msgid "Display selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:330
+msgid "Uknown settings file location."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:378
+msgid "Unable to get value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:401
+msgid "Unable to set "
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:430
+msgid "User GUI settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:454
+msgid "Set to default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:462
+msgid "Revert settings to default and apply changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:497
+#: ../gui/wxpython/gui_modules/vdigit.py:1589
+msgid "General"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:500
+msgid "General settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:511
+msgid "Mapsets path:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:533
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:536
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:549
+msgid "Layer Manager settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:560
+msgid "Opacity level editable"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:573
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:591
+#: ../gui/wxpython/gui_modules/vdigit.py:1596
+msgid "Display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:595
+#: ../gui/wxpython/gui_modules/profile.py:911
+msgid "Font settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:606
+msgid "Default font for GRASS displays:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:620
+msgid "Default display settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:631
+msgid "Display driver:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:671
+msgid "Enable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:692
+msgid "Command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:695
+msgid "Command dialog settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:727
+msgid "Verbosity level:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:746
+msgid "Raster settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:757
+msgid "Overlay raster maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:775
+#: ../gui/wxpython/gui_modules/vdigit.py:1800
+msgid "Attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:783
+msgid "Highlighting"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:797
+msgid "Line width (in pixels)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:820
+msgid "Data browser"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:825
+msgid "Left mouse double click"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:855
+msgid "Loading workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:867
+msgid "Suppress positioning Map Display Window(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:878
+msgid "Suppress positioning Layer Manager window"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:896
+#: ../gui/wxpython/gui_modules/dbm.py:562
+msgid "Advanced"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:899
+msgid "Advanced settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:911
+msgid "Place where to store settings:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:932
+msgid "Icon theme:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:949
+msgid "Note: Requires GUI restart."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:963
+msgid "Digitization interface:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:981
+msgid ""
+"Note: User can choose from two interfaces for digitization. The simple one "
+"uses v.edit command on the background. Map topology is rebuild on each "
+"operation which can significantly slow-down response. The vdigit is a native "
+"interface which uses v.edit functionality, but doesn't call the module "
+"itself."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1005
+msgid "Select default display font"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1032
+#, python-format
+msgid "Settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1205
+msgid "Set/unset access to mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1218
+#, python-format
+msgid ""
+"Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT "
+"and current mapset are always accessible."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1290
+msgid "Mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1291
+msgid "Owner"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1292
+msgid "Group"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:147
+#: ../gui/wxpython/gui_modules/vdigit.py:151
+#, python-format
+msgid ""
+"Unable to open vector map <%s> for editing. Data are probably corrupted, try "
+"to run v.build for rebuilding the topology."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:756
+msgid "Undondo is not implemented in vedit component. Use vdigit instead."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:813
+#: ../gui/wxpython/gui_modules/vdigit.py:850
+#, python-format
+msgid "Adding new feature to vector map <%s> failed."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1171
+msgid "Undo failed, data corrupted."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1528
+msgid "Apply changes for this session"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1531
+msgid "Close dialog and save changes to user settings file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1554
+msgid "Symbology"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1601
+#: ../gui/wxpython/gui_modules/profile.py:1107
+msgid "Line width"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1619
+msgid "Snapping"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1626
+msgid "Snapping threshold"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1639
+msgid "Backgroud vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1650
+msgid "Snap also to vertex"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1655
+#: ../gui/wxpython/gui_modules/vdigit.py:1940
+#: ../gui/wxpython/gui_modules/vdigit.py:1953
+#: ../gui/wxpython/gui_modules/vdigit.py:1957
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1669
+msgid "Select vector features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1685
+msgid "Select threshold"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1702
+msgid "Save changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1705
+msgid "Save changes on exit automatically"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1718
+msgid "Query tool"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1725
+msgid "Choose query tool"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1730
+msgid "Select by box"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1739
+msgid "length"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1744
+msgid "Select lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1746
+#: ../gui/wxpython/gui_modules/vdigit.py:1769
+msgid "shorter than"
+msgstr ""
+msgid "longer than"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1762
+msgid "dangle"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1767
+msgid "Select dangles"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1807
+msgid "Digitize new feature"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1812
+msgid "Add new record into table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1818
+#: ../gui/wxpython/gui_modules/vdigit.py:1820
+#: ../gui/wxpython/gui_modules/vdigit.py:2158
+#: ../gui/wxpython/gui_modules/vdigit.py:2532
+#: ../gui/wxpython/gui_modules/dbm.py:2053
+#: ../gui/wxpython/gui_modules/dbm.py:2288
+#: ../gui/wxpython/gui_modules/dbm.py:2933
+msgid "Layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2162
+#: ../gui/wxpython/gui_modules/vdigit.py:2533
+#: ../gui/wxpython/gui_modules/dbm.py:2966
+#: ../gui/wxpython/gui_modules/dbm.py:3261
+msgid "Category"
+msgstr ""
+msgid "Mode"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1847
+msgid "Next to use"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1835
+msgid "Category number"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1845
+msgid "Category mode"
+msgstr ""
+msgid "Manual entry"
+msgstr ""
+msgid "No category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1860
+msgid "Delete existing feature(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1865
+msgid "Delete record from table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1889
+msgid "Highlight"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1890
+msgid "Point"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1891
+msgid "Line"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1892
+msgid "Boundary (no area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1893
+msgid "Boundary (one area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1894
+msgid "Boundary (two areas)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1895
+msgid "Centroid (in area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1896
+msgid "Centroid (outside area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1897
+msgid "Centroid (duplicate in area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1898
+msgid "Node (one line)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1899
+msgid "Node (two lines)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1900
+msgid "Vertex"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2136
+msgid "List of categories"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2152
+msgid "Add new category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2266
+#: ../gui/wxpython/gui_modules/vdigit.py:2441
+#, python-format
+msgid ""
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater then zero."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2300
+msgid "Delete selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2304
+msgid "Delete all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2306
+#: ../gui/wxpython/gui_modules/dbm.py:928
+#: ../gui/wxpython/gui_modules/dbm.py:1301
+msgid "Reload"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2418
+msgid "Unable to update vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2570
+#, python-format
+msgid "%d lines selected for z bulk-labeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2573
+msgid "Set value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2580
+msgid "Starting value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2589
+msgid "Step"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:64
+msgid "Profile Analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:152
+#: ../gui/wxpython/gui_modules/profile.py:258
+msgid "Profile of"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:156
+#, python-format
+msgid "Distance (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:158
+msgid "Distance along transect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:159
+msgid "Cell values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:267
+#, python-format
+msgid "Profile of %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:293
+msgid "Raster values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:416
+msgid "You must draw a transect to profile in the map display window."
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:417
+msgid "Nothing to profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:627
+msgid "Profile text settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:654
+msgid "Profile settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:717
+msgid "Select raster map to profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:752
+msgid "Select raster map 1 (required):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:753
+msgid "Select raster map 2 (optional):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:754
+msgid "Select raster map 3 (optional):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:848
+msgid "Text settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:855
+msgid "Profile title:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:865
+msgid "Title font size (pts):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:886
+msgid "Y-axis label:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:896
+msgid "Label font size (pts):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:919
+msgid "Font family:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:933
+msgid "Style:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:947
+msgid "Weight:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1029
+#: ../gui/wxpython/gui_modules/profile.py:1374
+#, python-format
+msgid "Profile settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1085
+msgid "Profile line settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1095
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:287
+msgid "Profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1100
+msgid "Line color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1117
+msgid "Line style"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1126
+#: ../gui/wxpython/gui_modules/profile.py:1178
+msgid "Legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1150
+msgid "Transect segment marker settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1155
+msgid "Color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1161
+msgid "Size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1170
+#: ../gui/wxpython/gui_modules/profile.py:1216
+msgid "Style"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1185
+msgid "Type"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1200
+msgid "Axis settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1206
+msgid "X-Axis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1207
+msgid "Y-Axis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1225
+msgid "Custom min"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1233
+msgid "Custom max"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1241
+msgid "Log scale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1265
+msgid "Grid and Legend settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1270
+msgid "Grid color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1277
+msgid "Show grid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1283
+msgid "Legend font size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1293
+msgid "Show legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:193
+msgid "Can display only 256 columns."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:242
+msgid "Limit 100000 records."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:406
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:410
+msgid "Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:441
+msgid "Browse data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:447
+msgid "Manage tables"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:453
+msgid "Manage layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:456
+msgid "Click here to show database connection information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:457
+msgid "Click here to hide database connection information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:494
+#: ../gui/wxpython/gui_modules/dbm.py:644
+#: ../gui/wxpython/gui_modules/dbm.py:2070
+#: ../gui/wxpython/gui_modules/dbm.py:2308
+msgid "Table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:500
+msgid "Attribute data - right-click to edit/manage records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:526
+msgid "SQL Query"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:555
+#: ../gui/wxpython/gui_modules/dbm.py:1648
+msgid "SQL Builder"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:559
+msgid "Simple"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:630
+#: ../gui/wxpython/gui_modules/dbm.py:934
+#: ../gui/wxpython/gui_modules/dbm.py:1413
+#: ../gui/wxpython/gui_modules/dbm.py:1541
+#, python-format
+msgid "Number of loaded records: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:660
+#, python-format
+msgid "Table %s - right-click to delete records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:673
+#: ../gui/wxpython/gui_modules/dbm.py:1897
+msgid "Column name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:684
+msgid "Data type"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:701
+msgid "Data length"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:738
+msgid "To"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:748
+msgid "&Rename"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:804
+msgid "Layers of vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:813
+msgid "List of layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:913
+#: ../gui/wxpython/gui_modules/dbm.py:1021
+msgid "Insert new record"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:914
+msgid "Delete selected record(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:915
+msgid "Delete all records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:923
+#: ../gui/wxpython/gui_modules/dbm.py:1674
+#: ../gui/wxpython/gui_modules/dbm.py:1678
+msgid "Extract selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1032
+#, python-format
+msgid "Record with category number %d already exists in the table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1042
+#, python-format
+msgid "Category number (column %s) is missing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1050
+#: ../gui/wxpython/gui_modules/dbm.py:1147
+#, python-format
+msgid "Casting value '%(value)s' to %(type)s failed."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1061
+msgid "Unable to insert new record."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1126
+msgid "Update existing record"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1160
+msgid "Unable to update existing record."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1242
+msgid "Unable to rename column. No column name defined."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1251
+#, python-format
+msgid ""
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1267
+#, python-format
+msgid ""
+"Unable to rename column. Column <%(column)s> doesn't exist in the table <%"
+"(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1296
+msgid "Drop selected column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1299
+msgid "Drop all columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1361
+msgid "Unable to add column to the table. No column name defined."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1383
+#, python-format
+msgid "Column <%(column)s> already exists in table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1503
+#: ../gui/wxpython/gui_modules/dbm.py:1526
+#, python-format
+msgid ""
+"Loading attribute data failed. Invalid SQL 'select' statement.\n"
+"\n"
+"'%s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1602
+msgid "Database connection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1673
+msgid "Nothing to extract."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1765
+#: ../gui/wxpython/gui_modules/dbm.py:2230
+#: ../gui/wxpython/gui_modules/dbm.py:2601
+#, python-format
+msgid "Drop also linked attribute table (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2059
+#: ../gui/wxpython/gui_modules/dbm.py:2296
+msgid "Driver"
+msgstr ""
+msgid "Key"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2025
+msgid ""
+"Unable to determine default DB connection settings. Please define DB "
+"connection using db.connect module."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2042
+msgid "Add layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2075
+#: ../gui/wxpython/gui_modules/dbm.py:2098
+#: ../gui/wxpython/gui_modules/dbm.py:2314
+msgid "Key column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2093
+msgid "Table name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2106
+msgid "&Create table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2110
+msgid "&Add layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2114
+msgid "&Set default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2127
+msgid "Layer description"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2174
+msgid "Table description"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2216
+msgid "Layer to detele"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2237
+msgid "&Delete layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2281
+msgid "Modify selected layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2345
+msgid "&Modify layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2473
+msgid "Unable to create new table. Table name or key column name is missing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2510
+#, python-format
+msgid ""
+"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
+"exists."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2687
+msgid "Database connection is not defined in DB file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2691
+#, python-format
+msgid ""
+"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
+"You can disable this message from digitization settings. Or you can create "
+"and link attribute table to the vector map using Attribute Table Manager."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2711
+msgid "Close dialog on submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2718
+msgid "Update attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2720
+msgid "Add attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2722
+msgid "Display attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2726
+msgid "&Reload"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2727
+msgid "&Submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2945
+msgid "No database record available."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:3358 ../gui/wxpython/wxgui.py:1156
+msgid "GRASS GIS Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:43
+#, python-format
+msgid "GRASS SQL Builder: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:82
+#, python-format
+msgid "Error in command execution %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:90
+msgid "Preferences error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:97
+msgid "Error in digitization tool"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:104
+msgid "Error in Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:360
+msgid "Execution failed:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:363
+msgid "Details:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:52
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:54
+#, python-format
+msgid "GRASS %s Map Calculator"
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:123
+#, python-format
+msgid "<%(name)s>: layer type <%(type)s> is not supported yet."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:337
+msgid "GISBASE not set. You must be in GRASS GIS to run this program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:368
+msgid "Unable to open file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:527
+#, python-format
+msgid "Unable to zoom to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:530
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:853
+#: ../gui/wxpython/gui_modules/render.py:935
+#, python-format
+msgid "Unable to render map layer <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:1051
+#, python-format
+msgid "Unable render overlay <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:1085
+#, python-format
+msgid "Unable render overlay <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:97
+msgid "GRASS GIS Map Display: "
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:107
+msgid "Map Layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:220
+msgid "Remove"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:231
+msgid "Change opacity level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:238
+msgid "Properties"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:242
+msgid "Set computational region from selected map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:253
+msgid "Show attribute data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:256
+msgid "Start editing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:257
+msgid "Stop editing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:278
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:289
+msgid "Metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:334
+msgid "Unable to create profile of raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:359
+msgid "Unable to display histogram of raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:480
+msgid "Layer group:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:531
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:534
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:537
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:540
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:543
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:546
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:549
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:552
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:555
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:558
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:561
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:564
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:567
+msgid "(double click to set properties)"
+msgstr ""
+msgid "RGB"
+msgstr ""
+msgid "HIS"
+msgstr ""
+msgid "raster cell numbers"
+msgstr ""
+msgid "raster flow arrows"
+msgstr ""
+msgid "thematic map"
+msgstr ""
+msgid "thematic charts"
+msgstr ""
+msgid "grid"
+msgstr ""
+msgid "geodesic line"
+msgstr ""
+msgid "rhumbline"
+msgstr ""
+msgid "vector labels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:604
+msgid "Digitization settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:743
+#: ../gui/wxpython/gui_modules/toolbars.py:820
+#: ../gui/wxpython/gui_modules/toolbars.py:881
+msgid "Select vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:825
+#, python-format
+msgid "Do you want to save changes in vector map <%s>?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:827
+msgid "Save changes?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:887
+#: ../gui/wxpython/gui_modules/toolbars.py:892
+msgid "New vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/workspace.py:229
+#, python-format
+msgid "Unable to open file <%s> for reading."
+msgstr ""
+#: ../gui/wxpython/gui_modules/workspace.py:242
+#, python-format
+msgid ""
+"Some lines were skipped when reading settings from file <%s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/workspace.py:400
+#, python-format
+msgid " row %d:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:159
+msgid "Unable to run the command, another command is running..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:195
+#, python-format
+msgid "Command '%s' not yet implemented."
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:269
+msgid "Save file as..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:301
+msgid ""
+"Please note that the data are left in incosistent stage and can be corrupted"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:303
+msgid "Command aborted"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:308
+#, python-format
+msgid "Command finished (%d sec)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:83
+msgid "Choose project location and mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:86
+msgid "Manage"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:88
+#, python-format
+msgid ""
+"Welcome to GRASS GIS %s\n"
+"The world's leading open source GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:94
+msgid ""
+"Select an existing project location and mapset\n"
+"or define a new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:100
+msgid ""
+"Project location\n"
+"(projection/coordinate system)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:103
+msgid ""
+"Accessible mapsets\n"
+"(directories of GIS files)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:106
+msgid ""
+"Create new mapset\n"
+"in selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:109
+msgid "Define new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:112
+msgid ""
+"Rename/delete selected\n"
+"mapset or location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:117
+msgid "Start GRASS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:124
+msgid "Create mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:128
+msgid "Rename mapset"
+msgstr ""
+msgid "Rename location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:129
+msgid "Delete mapset"
+msgstr ""
+msgid "Delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:168
+msgid "Welcome to GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:176
+msgid "Enter GRASS session"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:200
+#, python-format
+msgid "ERROR: Location <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:211
+#, python-format
+msgid "ERROR: Mapset <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:419 ../gui/wxpython/gis_set.py:443
+#, python-format
+msgid ""
+"Current name: %s\n"
+"Enter new name:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:420
+msgid "Rename selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:431
+msgid "Unable to rename mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:444
+msgid "Rename selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:457
+msgid "Unable to rename location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:469
+#, python-format
+msgid ""
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%"
+"(location)s>?\n"
+"\n"
+"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:474
+msgid "Delete selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:483
+msgid "Unable to delete mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:494
+#, python-format
+msgid ""
+"Do you want to continue with deleting location <%s>?\n"
+"\n"
+"ALL MAPS included in this location will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:498
+msgid "Delete selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:509
+msgid "Unable to delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:631
+msgid "Choose GIS Data Directory:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:646
+msgid "Enter name for new mapset:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:647
+msgid "Create new mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:660
+#, python-format
+msgid "Unable to create new mapset: %s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:691
+msgid "GRASS Quickstart"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:99
+msgid "GRASS GIS Layer Manager (Experimental Prototype)"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:293
+msgid "Map layers for each display"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:409
+msgid "Type GRASS command and run by pressing ENTER"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:514
+msgid ""
+"Workspace is not empty. Do you want to store current settings to workspace "
+"file?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:517
+msgid "Save current settings?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:532
+msgid "Choose workspace file"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:596 ../gui/wxpython/wxgui.py:601
+#, python-format
+msgid ""
+"Reading workspace file <%s> failed. Invalid file, unable to parse XML "
+"document."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:606 ../gui/wxpython/wxgui.py:695
+#: ../gui/wxpython/wxgui.py:731
+msgid "Please wait, loading map layers into layer tree..."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:675
+msgid "Unable to read workspace file"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:715
+msgid "Choose GRC file to load"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:754
+msgid "Choose file to save current workspace"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:769 ../gui/wxpython/wxgui.py:786
+#, python-format
+msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:866
+#, python-format
+msgid "Unable to open workspace file <%s> for writing."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:921
+#, python-format
+msgid "Writing current settings to workspace file failed (%s)."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1132
+msgid "Attribute management is available only for vector maps."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1442
+#, python-format
+msgid "Do you want to remove map layer <%s> from layer tree?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1445
+msgid "Do you want to remove selected map layer from layer tree?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1449
+msgid "Remove map layer"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1479
+msgid "No map layer selected. Operation cancelled."
+msgstr ""
Property changes on: grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
___________________________________________________________________
+ text/plain
+ Author Date Id
+ native
