[GRASS-SVN] r31289 - grass-addons/raster/r.inund.fluv
svn_grass at osgeo.org
Wed May 7 10:18:01 EDT 2008
Author: robertomarzocchi
Date: 2008-05-07 10:18:01 -0400 (Wed, 07 May 2008)
New Revision: 31289
grass-addons/raster/r.inund.fluv/Makefile
grass-addons/raster/r.inund.fluv/r.inund.fluv
grass-addons/raster/r.inund.fluv/r.inund.fluv_62
Modified: grass-addons/raster/r.inund.fluv/Makefile
--- grass-addons/raster/r.inund.fluv/Makefile 2008-05-07 11:53:45 UTC (rev 31288)
+++ grass-addons/raster/r.inund.fluv/Makefile 2008-05-07 14:18:01 UTC (rev 31289)
@@ -1,4 +1,4 @@
-MODULE_TOPDIR = ../..
+MODULE_TOPDIR = /usr/local/grass-6.3.0RC4
PGM = r.inund.fluv
@@ -28,5 +28,4 @@
$(INSTALL_DATA) $(PGM).html $(MODULE_TOPDIR)/docs/html/
clean:
- -rm -f find_main_channel$(EXE) clean_inundation$(EXE) 2d_path$(EXE) correction_from_path$(EXE) dati.mod dd.mod
\ No newline at end of file
+ -rm -f find_main_channel$(EXE) clean_inundation$(EXE) 2d_path$(EXE) correction_from_path$(EXE) dati.mod dd.mod
Modified: grass-addons/raster/r.inund.fluv/r.inund.fluv
--- grass-addons/raster/r.inund.fluv/r.inund.fluv 2008-05-07 11:53:45 UTC (rev 31288)
+++ grass-addons/raster/r.inund.fluv/r.inund.fluv 2008-05-07 14:18:01 UTC (rev 31289)
@@ -226,20 +226,26 @@
fi
g.remove rast=MASK --quiet
-cartella_nascosta="temp_grass_script"
-# do not use any space in name of cartella_nascosta
-rm -r -f ~/$cartella_nascosta
-mkdir ~/$cartella_nascosta
-cp "$GISBASE/etc/fortran_code"/find_main_channel ~/$cartella_nascosta
-cp "$GISBASE/etc/fortran_code"/clean_inundation ~/$cartella_nascosta
-cp "$GISBASE/etc/fortran_code"/2d_path ~/$cartella_nascosta
-cp "$GISBASE/etc/fortran_code"/correction_from_path ~/$cartella_nascosta
+#make a temporary directory
+TMPDIR="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMPDIR" ] ; then
+ g.message "Unable to create temporary files"
+ exit 1
+fi
+rm -r -f "$TMPDIR"
+mkdir "$TMPDIR"
+cp "$GISBASE/etc/fortran_code"/find_main_channel "$TMPDIR"
+cp "$GISBASE/etc/fortran_code"/clean_inundation "$TMPDIR"
+cp "$GISBASE/etc/fortran_code"/2d_path "$TMPDIR"
+cp "$GISBASE/etc/fortran_code"/correction_from_path "$TMPDIR"
#variables
dtm="$GIS_OPT_DTM"
-cp "$GIS_OPT_W_S_PROFILE" ~/$cartella_nascosta/profilo
+cp "$GIS_OPT_W_S_PROFILE" "$TMPDIR"/profilo
v.in.ascii -z input="$GIS_OPT_W_S_PROFILE" output=profilo format=point fs=" " skip=0 x=1 y=2 z=3 cat=0 --overwrite --quiet
centerline="$GIS_OPT_RIVER"
inondazione="$GIS_OPT_FLOODING_MAP"
@@ -247,13 +253,13 @@
#calculation of the "boundaries" of the main channel
g.region nsres=$res ewres=$res save=dtm_res2 --overwrite
-g.region -p >> ~/$cartella_nascosta/"region2.txt"
-r.out.ascii -h input=$dtm output=$cartella_nascosta/"dtm2x2" null=0 --quiet
+g.region -p >> "$TMPDIR"/"region2.txt"
+r.out.ascii -h input=$dtm output="$TMPDIR"/"dtm2x2" null=0 --quiet
#fortran code run
cd
-cp "$quote100" ~/$cartella_nascosta/quote_100
-cd $cartella_nascosta
+cp "$quote100" "$TMPDIR"/quote_100
+cd "$TMPDIR"
echo $res $deltax $deltay > parameter.txt
echo "'"region2.txt"'" "'"dtm2x2"'" "'"limiti_alveo_vect"'" "'"quote_100"'" > nomefile.txt
g.message "Fortran code that automatically find bed river"
@@ -267,15 +273,15 @@
exit 1
fi
cd
-v.in.ascii --o input=$cartella_nascosta/limiti_alveo_vect output=limiti_alveo format=point fs=' ' skip=0 x=1 y=2 cat=0 --quiet
+v.in.ascii --o input="$TMPDIR"/limiti_alveo_vect output=limiti_alveo format=point fs=' ' skip=0 x=1 y=2 cat=0 --quiet
#export of 20x20 dtm, region20.txt and region10.txt
g.region nsres=$res20 ewres=$res20 save=dtm_res20 --overwrite
-g.region -p >> ~/$cartella_nascosta/region20.txt
-r.out.ascii -h input=$dtm output=$cartella_nascosta/dtm20x20 null=0 --quiet
+g.region -p >> "$TMPDIR"/region20.txt
+r.out.ascii -h input=$dtm output="$TMPDIR"/dtm20x20 null=0 --quiet
g.region nsres=$res10 ewres=$res10 save=dtm_res10 --overwrite
-g.region -p >> ~/$cartella_nascosta/region10.txt
+g.region -p >> "$TMPDIR"/region10.txt
g.message "STEP 1"
@@ -308,13 +314,13 @@
# export data
#20x20
g.region region=dtm_res20
-r.out.ascii -h input=inondazione_step2 output=$cartella_nascosta/inondazione_step2 null=0 --quiet
-r.out.ascii -h input=quote_punti_adiacenti output=$cartella_nascosta/quote_punti_adiacenti dp=2 null=0 --quiet
+r.out.ascii -h input=inondazione_step2 output="$TMPDIR"/inondazione_step2 null=0 --quiet
+r.out.ascii -h input=quote_punti_adiacenti output="$TMPDIR"/quote_punti_adiacenti dp=2 null=0 --quiet
# FORTRAN code
g.message "CODE FORTRAN OF STEP 3"
cd
+cd "$TMPDIR"
echo "'"inondazione_step2"'" "'"profilo"'" "'"inondazione_nuova.txt"'" "'"quote_punti_adiacenti"'" "'"region20.txt"'" "'"region2.txt"'" "'"dtm2x2"'" > nomefile.txt
./clean_inundation
rm nomefile.txt
@@ -328,18 +334,18 @@
cd
# output file
-r.in.ascii input=$cartella_nascosta/inondazione_nuova.txt output=inondazione_step3 'mult=1.0 or read from header' nv=0 --overwrite --quiet
+r.in.ascii input="$TMPDIR"/inondazione_nuova.txt output=inondazione_step3 'mult=1.0 or read from header' nv=0 --overwrite --quiet
g.message "STEP 4"
# STEP 4 - calcolation of the 2d_path outside the main channel
-r.out.ascii -h input=inondazione_step3 output=$cartella_nascosta/inondazione_step3 null=0 --quiet
+r.out.ascii -h input=inondazione_step3 output="$TMPDIR"/inondazione_step3 null=0 --quiet
g.message "2D MODEL OF DIFFUSION OF FLOODING INONDATION OUTSIDE THE MAIN CHANEL"
cd
+cd "$TMPDIR"
echo "'"profilo"'" "'"inondazione_step3"'" "'"reticolo"'" "'"region20.txt"'" "'"dtm20x20"'" "'"limiti_alveo_vect"'" "'"region2.txt"'" "'"dtm2x2"'" "'"bordi_alveo"'" > nomefile.txt
./2d_path
rm nomefile.txt
@@ -353,11 +359,11 @@
cd
-#r.in.ascii input=$cartella_nascosta/bordi_alveo output=bordi_alveo 'mult=1.0 or read from header' nv=0 --overwrite
+#r.in.ascii input="$TMPDIR"/bordi_alveo output=bordi_alveo 'mult=1.0 or read from header' nv=0 --overwrite
#r.thin input=bordi_alveo output=bordi_alveo_thin iterations=200 --overwrite
#r.to.vect input=bordi_alveo_thin output=bordi_alveo feature=line --overwrite
-v.in.ascii -n input=$cartella_nascosta/bordi_alveo output=bordi_alveo format=standard fs=' ' skip=0 x=1 y=2 z=0 cat=0 --quiet
-r.in.ascii input=$cartella_nascosta/reticolo output=reticolo 'mult=1.0 or read from header' nv=* --overwrite --quiet
+v.in.ascii -n input="$TMPDIR"/bordi_alveo output=bordi_alveo format=standard fs=' ' skip=0 x=1 y=2 z=0 cat=0 --quiet
+r.in.ascii input="$TMPDIR"/reticolo output=reticolo 'mult=1.0 or read from header' nv=* --overwrite --quiet
r.thin input=reticolo output=reticolo_thin iterations=200 --overwrite --quiet
r.to.vect input=reticolo_thin output=reticolo feature=line --overwrite --quiet
g.remove rast=reticolo_thin --quiet
@@ -375,8 +381,8 @@
r.null map=diff_inond setnull=0 --quiet
r.to.vect input=diff_inond output=diff_inond1 feature=area --overwrite --quiet
#to use the v.select command the line must have a layer associated ==> export of vector map in dxf format and then import the dxf file
-v.out.dxf input=reticolo output=$cartella_nascosta/reticolo.dxf --quiet
-v.in.dxf -1 input=$cartella_nascosta/reticolo.dxf output=reticolo --overwrite --quiet
+v.out.dxf input=reticolo output="$TMPDIR"/reticolo.dxf --quiet
+v.in.dxf -1 input="$TMPDIR"/reticolo.dxf output=reticolo --overwrite --quiet
#only 2d_path overlapped the surfaces to look
v.select ainput=reticolo atype=line alayer=1 binput=diff_inond1 btype=area blayer=1 output=reticolo_interno operator=overlap --overwrite --quiet
@@ -393,14 +399,14 @@
g.region region=dtm_res10
#export of 3d points
-v.out.ascii input=punti3d_reticolo output=$cartella_nascosta/punti3d_reticolo format=point dp=2 --quiet
-r.out.ascii -h input=diff_inond output=$cartella_nascosta/diff_inond null=0 --quiet
+v.out.ascii input=punti3d_reticolo output="$TMPDIR"/punti3d_reticolo format=point dp=2 --quiet
+r.out.ascii -h input=diff_inond output="$TMPDIR"/diff_inond null=0 --quiet
g.message "FORTRAN CODE OF STEP 4"
cd
+cd "$TMPDIR"
echo "'"diff_inond"'" "'"punti3d_reticolo"'" "'"correzione"'" "'"region10.txt"'" "'"dtm2x2"'" "'"region2.txt"'" > nomefile.txt
./correction_from_path
rm nomefile.txt
@@ -414,7 +420,7 @@
cd
-r.in.ascii input=$cartella_nascosta/correzione output=inondazione_step5 'mult=1.0 or read from header' nv=0 --overwrite --quiet
+r.in.ascii input="$TMPDIR"/correzione output=inondazione_step5 'mult=1.0 or read from header' nv=0 --overwrite --quiet
# replace null cells with 0 cells
@@ -500,7 +506,7 @@
g.remove vect=bordi_alveo,limiti_alveo --quiet
fi
-rm -r ~/$cartella_nascosta
+rm -r "$TMPDIR"
Modified: grass-addons/raster/r.inund.fluv/r.inund.fluv_62
--- grass-addons/raster/r.inund.fluv/r.inund.fluv_62 2008-05-07 11:53:45 UTC (rev 31288)
+++ grass-addons/raster/r.inund.fluv/r.inund.fluv_62 2008-05-07 14:18:01 UTC (rev 31289)
@@ -217,20 +217,24 @@
fi
g.remove rast=MASK
+ exit 1
+fi
+rm -r -f "$TMPDIR"
+mkdir "$TMPDIR"
#variables
dtm="$GIS_OPT_DTM"
@@ -238,13 +242,13 @@
#fortran code run
cd
+cd "$TMPDIR"
echo "Fortran code that automatically find bed river"
@@ -258,15 +262,15 @@
exit 1
fi
cd
echo "STEP 1"
@@ -299,13 +303,13 @@
# export data
#20x20
# FORTRAN code
echo "CODE FORTRAN OF STEP 3"
cd
+cd "$TMPDIR"
./clean_inundation
rm nomefile.txt
@@ -319,18 +323,18 @@
cd
# output file
echo "STEP 4"
echo "2D MODEL OF DIFFUSION OF FLOODING INONDATION OUTSIDE THE MAIN CHANEL"
cd
+cd "$TMPDIR"
./2d_path
rm nomefile.txt
@@ -344,11 +348,11 @@
cd
@@ -366,8 +370,8 @@
@@ -384,14 +388,14 @@
echo "FORTRAN CODE OF STEP 4"
cd
+cd "$TMPDIR"
rm nomefile.txt
@@ -405,7 +409,7 @@
cd
@@ -490,7 +494,7 @@
fi
+rm -r "$TMPDIR"
