[GRASS-SVN] r31312 - grass/branches/develbranch_6/lib/ogsf
Sun May 11 05:41:11 EDT 2008
Author: martinl
Date: 2008-05-11 05:41:11 -0400 (Sun, 11 May 2008)
New Revision: 31312
   grass/branches/develbranch_6/lib/ogsf/GS2.c
   grass/branches/develbranch_6/lib/ogsf/GS_util.c
   grass/branches/develbranch_6/lib/ogsf/GV2.c
   grass/branches/develbranch_6/lib/ogsf/GVL2.c
   grass/branches/develbranch_6/lib/ogsf/Gs3.c
   grass/branches/develbranch_6/lib/ogsf/gs.c
   grass/branches/develbranch_6/lib/ogsf/gsds.c
   grass/branches/develbranch_6/lib/ogsf/gv.c
ogsf: Doxygenization in progress
TRACE_FUNC macro removed, use G_debug() instead of Gs_status()
Modified: grass/branches/develbranch_6/lib/ogsf/GS2.c
--- grass/branches/develbranch_6/lib/ogsf/GS2.c	2008-05-11 06:36:08 UTC (rev 31311)
+++ grass/branches/develbranch_6/lib/ogsf/GS2.c	2008-05-11 09:41:11 UTC (rev 31312)
@@ -50,10 +50,6 @@
 #include "rowcol.h"
 #include "rgbpack.h"
-#ifdef TRACE_FUNCS
-#define TRACE_GS_FUNCS
-#endif
 /* Hack to make NVIZ2.2 query functions.("What's Here" and "Look at")
  * to work.
  * Uses gs_los_intersect1() instead of gs_los_intersect().
@@ -165,11 +161,7 @@
     int i;
-#ifdef TRACE_GS_FUNCS
-	Gs_status("GS_set_att_defaults");
-#endif
+    G_debug (3, "GS_set_att_defaults");
     for (i = 0; i < MAX_ATTS; i++) {
 	Default_const[i] = defs[i];
@@ -191,12 +183,9 @@
     int i, found = 0;
-	Gs_status("GS_surf_exists");
-#endif
+    G_debug(3, "GS_surf_exists");
     if (NULL == gs_get_surf(id)) {
 	return (0);
@@ -224,11 +213,7 @@
     geosurf *ns;
-	Gs_status("GS_new_surface");
-#endif
+    G_debug(3, "GS_new_surface");
     if (Next_surf < MAX_SURFS) {
 	ns = gs_get_new_surface();
@@ -1160,7 +1145,7 @@
   \param id surface id
   \param att
-  \param catstr
+  \param catstr cat string (must be allocated, dim?)
   \param x,y real coordinates
   \return -1 if no category info or point outside of window
@@ -1173,7 +1158,7 @@
     typbuff *buff;
     geosurf *gs;
-    sprintf(catstr, "");
+    catstr[0] = '\0';
     gs = gs_get_surf(id);
     if (NULL == gs) {
@@ -1303,7 +1288,7 @@
     typbuff *buff;
     geosurf *gs;
-    sprintf(valstr, "");
+    valstr = '\0';
     if (NULL == gs) {
@@ -1556,11 +1541,7 @@
     int i, j, found = 0;
-	Gs_status("GS_delete_surface");
-#endif
+    G_debug(3, "GS_delete_surface");
     if (GS_surf_exists(id)) {
 	gs_delete_surf(id);
@@ -1607,12 +1588,6 @@
     int reuse = 0, begin, hdata, ret, neg = 0, has_null = 0;
     typbuff *tbuff;
-	Gs_status("GS_load_att_map");
-#endif
     G_debug (3, "GS_load_att_map(): att_map: %s", filename);
@@ -1882,11 +1857,7 @@
     geosurf *gs;
-	Gs_status("GS_draw_surf");
-#endif
+    G_debug(3, "GS_draw_surf");
     if (gs) {
@@ -1921,11 +1892,7 @@
     geosurf *gs;
-	Gs_status("GS_draw_wire");
-#endif
+    G_debug(3, "GS_draw_wire");
@@ -1979,11 +1946,7 @@
     geosurf *gs;
-	Gs_status("GS_set_exag");
-#endif
+    G_debug(3, "GS_set_exag");
@@ -2006,11 +1969,7 @@
 void GS_set_global_exag(float exag)
-	Gs_status("GS_set_global_exag");
-#endif
+    G_debug(3, "GS_set_global_exag");
     Gv.vert_exag = exag;
     /* GL_NORMALIZE */
@@ -2031,11 +1990,7 @@
 float GS_global_exag(void)
-	Gs_status("GS_global_exag");
-#endif
+    G_debug(3, "GS_global_exag");
     return (Gv.vert_exag);
@@ -2052,11 +2007,7 @@
     geosurf *gs;
-	Gs_status("GS_set_wire_color");
-#endif
+    G_debug(3, "GS_set_wire_color");
@@ -2125,11 +2076,7 @@
     geosurf *gs;
-	Gs_status("GS_set_drawmode");
-#endif
+    G_debug(3, "GS_set_drawmode");
@@ -2177,11 +2124,7 @@
     geosurf *gs;
-	Gs_status("GS_set_nozero");
-#endif
+    G_debug(3, "GS_set_nozero");
@@ -2214,11 +2157,7 @@
     geosurf *gs;
-#endif
@@ -2275,11 +2214,7 @@
     geosurf *gs;
-	Gs_status("GS_set_drawres");
-#endif
+    G_debug(3, "GS_set_drawres");
     if (xres < 1 || yres < 1 || xwire < 1 || ywire < 1) {
 	return (-1);
@@ -2312,11 +2247,7 @@
     geosurf *gs;
-	Gs_status("GS_get_drawres");
-#endif
+    G_debug(3, "GS_get_drawres");
@@ -2340,11 +2271,7 @@
     geosurf *gs;
-	Gs_status("GS_get_dims");
-#endif
+    G_debug(3, "GS_get_dims");
@@ -2459,11 +2386,7 @@
     geosurf *gs;
-	Gs_status("GS_set_trans");
-#endif
+    G_debug(3, "GS_set_trans");
@@ -2486,11 +2409,7 @@
     geosurf *gs;
-	Gs_status("GS_get_trans");
-#endif
+    G_debug(3, "GS_get_trans");
@@ -2512,11 +2431,7 @@
 unsigned int GS_default_draw_color(void)
-	Gs_status("GS_default_draw_color");
-#endif
+    G_debug(3, "GS_default_draw_color");
     return ((unsigned int) Gd.bgcol);
@@ -2568,11 +2483,7 @@
 void GS_ready_draw(void)
-	Gs_status("GS_ready_draw");
-#endif
+    G_debug(3, "GS_ready_draw");
     gsd_set_view(&Gv, &Gd);
@@ -2585,11 +2496,7 @@
 void GS_done_draw(void)
-	Gs_status("GS_done_draw");
-#endif
+    G_debug(3, "GS_done_draw");
     if (GSD_BACK == Buffermode) {
 	gsd_swapbuffers();
@@ -2608,11 +2515,8 @@
 void GS_set_focus(float *realto)
-	Gs_status("GS_set_focus");
-#endif
+    G_debug(3, "GS_set_focus");
     Gv.infocus = 1;
     GS_v3eq(Gv.real_to, realto);
@@ -2654,11 +2558,7 @@
 int GS_get_focus(float *realto)
-	Gs_status("GS_get_focus");
-#endif
+    G_debug(3, "GS_get_focus");
     if (Gv.infocus) {
 	if (realto) {
@@ -2679,11 +2579,7 @@
     float center[3];
     geosurf *gs;
-	Gs_status("GS_set_focus_center_map");
-#endif
+    G_debug(3, "GS_set_focus_center_map");
@@ -2717,13 +2613,8 @@
     float ft[3];
+    G_debug(3, "GS_moveto");
-	Gs_status("GS_moveto");
-#endif
     if (Gv.infocus) {
 	GS_v3eq(Gv.from_to[FROM], pt);
@@ -2771,11 +2662,7 @@
     geosurf *gs;
-	Gs_status("GS_get_zextents");
-#endif
+    G_debug(3, "GS_get_zextents");
     if (NULL == (gs = gs_get_surf(id))) {
 	return (-1);
@@ -2800,11 +2687,7 @@
     float surf_min, surf_max;
     float vol_min, vol_max;
-	Gs_status("GS_get_zrange");
-#endif
+    G_debug(3, "GS_get_zrange");
     ret_surf = gs_get_zrange(&surf_min, &surf_max);
     ret_vol = gvl_get_zrange(&vol_min, &vol_max);
@@ -2835,13 +2718,8 @@
 void GS_get_from(float *fr)
+    G_debug(3, "GS_get_from");
-	Gs_status("GS_get_from");
-#endif
     GS_v3eq(fr, Gv.from_to[FROM]);
     return;
@@ -2909,13 +2787,8 @@
 void GS_get_to(float *to)
+    G_debug(3, "GS_get_to");
-	Gs_status("GS_get_to");
-#endif
     GS_v3eq(to, Gv.from_to[TO]);
     return;
@@ -3006,13 +2879,8 @@
 void GS_set_nofocus(void)
+    G_debug(3, "GS_set_nofocus");
-	Gs_status("GS_set_nofocus");
-#endif
     Gv.infocus = 0;
     return;
@@ -3025,13 +2893,8 @@
 void GS_set_infocus(void)
+    G_debug(3, "GS_set_infocus");
-        Gs_status("GS_set_infocus");
-#endif
     Gv.infocus = 1;
     return;
@@ -3046,13 +2909,8 @@
 void GS_set_viewport(int left, int right, int bottom, int top)
+    G_debug(3, "GS_set_viewport");
-	Gs_status("GS_set_viewport");
-#endif
     gsd_viewport(left, right, bottom, top);
     return;
@@ -3414,11 +3272,7 @@
     static int first = 1;
-	Gs_status("GS_init_view");
-#endif
+    G_debug(3, "GS_init_view");
     if (first) {
 	first = 0;
@@ -3484,13 +3338,8 @@
 void GS_clear(int col)
+    G_debug(3, "GS_clear");
-	Gs_status("GS_clear");
-#endif
     col = col | 0xFF000000;
     /* OGLXXX
@@ -3524,11 +3373,7 @@
     int left, right, bottom, top;
     GLint tmp[4];
-	Gs_status("GS_get_aspect");
-#endif
+    G_debug(3, "GS_get_aspect");
     /* OGLXXX
      * get GL_VIEWPORT:
Modified: grass/branches/develbranch_6/lib/ogsf/GS_util.c
--- grass/branches/develbranch_6/lib/ogsf/GS_util.c	2008-05-11 06:36:08 UTC (rev 31311)
+++ grass/branches/develbranch_6/lib/ogsf/GS_util.c	2008-05-11 09:41:11 UTC (rev 31312)
@@ -129,7 +129,14 @@
     return (meters);
+  \brief Calculate distance
+  \param from 'from' point (X,Y,Z)
+  \param to 'to' point (X,Y,Z)
+  \return distance
 float GS_distance(float *from, float *to)
     float x, y, z;
@@ -141,7 +148,14 @@
     return (float) sqrt(x * x + y * y + z * z);
+  \brief Calculate distance in plane
+  \param from 'from' point (X,Y)
+  \param to 'to' point (X,Y)
+  \return distance
 float GS_P2distance(float *from, float *to)
     float x, y;
@@ -152,8 +166,14 @@
     return (float) sqrt(x * x + y * y);
-/* v1 = v2 */
+  \brief Copy vector values
+  v1 = v2
+  \param[out] v1 first vector
+  \param v2 second vector
 void GS_v3eq(float *v1, float *v2)
     v1[X] = v2[X];
@@ -163,8 +183,14 @@
     return;
-/* v1 += v2 */
+  \brief Sum vectors
+  v1 += v2
+  \param[in,out] v1 first vector
 void GS_v3add(float *v1, float *v2)
     v1[X] += v2[X];
@@ -174,8 +200,14 @@
     return;
-/* v1 -= v2 */
+  \brief Subtract vectors
+  v1 -= v2
 void GS_v3sub(float *v1, float *v2)
     v1[X] -= v2[X];
@@ -185,8 +217,14 @@
     return;
-/* v1 *= k */
+  \brief Multiple vectors
+  v1 *= k
+  \param[in,out] v1 vector
+  \param k multiplicator
 void GS_v3mult(float *v1, float k)
     v1[X] *= k;
@@ -197,9 +235,12 @@
-  \brief Change v1 so that it is a unit vector
+  \brief Change v1 so that it is a unit vector (2D)
-  \param v1 vector
+  \return 0 if magnitude of v1 is zero
+  \return 1 if magnitude of v1 > 0
 int GS_v3norm(float *v1)
@@ -218,8 +259,14 @@
     return (1);
-/* Changes v1 so that it is a unit vector */
+  \brief Change v1 so that it is a unit vector (3D)
 int GS_v2norm(float *v1)
     float n;
@@ -241,8 +288,8 @@
   \param dv1 vector
-  \return 0
-  \return 1
+  \return 0 if magnitude of dv1 is zero
+  \return 1 if magnitude of dv1 > 0
 int GS_dv3norm(double *dv1)
@@ -266,9 +313,10 @@
   \brief Change v2 so that v1v2 is a unit vector
   \param v1 first vector
-  \param v2 second vector
+  \param v2[in,out] second vector
-  \return ADD
+  \return 0 if magnitude of dx is zero
+  \return 1 if magnitude of dx > 0
 int GS_v3normalize(float *v1, float *v2)
@@ -291,8 +339,16 @@
-/* get a normalized direction from v1 to v2, store in v3 */
+  \brief Get a normalized direction from v1 to v2, store in v3
+  \param v1 first vector
+  \param[out] v3 output vector
 int GS_v3dir(float *v1, float *v2, float *v3)
     float n, dx, dy, dz;
@@ -315,8 +371,16 @@
+  \brief Get a normalized direction from v1 to v2, store in v3 (2D)
 void GS_v2dir(float *v1, float *v2, float *v3)
     float n, dx, dy;
@@ -331,8 +395,13 @@
     return;
-/* return the cross product v3 = v1 cross v2 */
+  \brief Get the cross product v3 = v1 cross v2
 void GS_v3cross(float *v1, float *v2, float *v3)
     v3[X] = (v1[Y] * v2[Z]) - (v1[Z] * v2[Y]);
@@ -342,8 +411,12 @@
     return;
-/* magnitude of vector */
+  \brief Magnitude of vector
+  \param v1 vector
+  \param[out] mag magnitude value
 void GS_v3mag(float *v1, float *mag)
     *mag = sqrt(v1[X] * v1[X] + v1[Y] * v1[Y] + v1[Z] * v1[Z]);
@@ -351,9 +424,20 @@
     return;
-/* initialize by calling with a number nhist to represent number of
- * previous entrys to check, then call with zero as nhist
+  \brief ADD
+  Initialize by calling with a number nhist to represent number of
+  previous entrys to check, then call with zero as nhist
+  \param p1 first point
+  \param p2 second point
+  \param nhist ?
+  \return -1 on error
+  \return -2
+  \return 1
+  \return 9
 int GS_coordpair_repeats(float *p1, float *p2, int nhist)
@@ -364,13 +448,14 @@
     if (nhist) {
 	if (entrys) {
-	    free(entrys);
+	    G_free(entrys);
-	if (NULL == (entrys = (float *) malloc(4 * nhist * sizeof(float)))) {
-	    return (-1);
+	entrys = (float *) G_malloc(4 * nhist * sizeof(float));
+	if (!entrys)
+	  return (-1);
 	len = nhist;
 	next = 0;
Modified: grass/branches/develbranch_6/lib/ogsf/GV2.c
--- grass/branches/develbranch_6/lib/ogsf/GV2.c	2008-05-11 06:36:08 UTC (rev 31311)
+++ grass/branches/develbranch_6/lib/ogsf/GV2.c	2008-05-11 09:41:11 UTC (rev 31312)
@@ -23,10 +23,6 @@
 #include <grass/gstypes.h>
 #include "gsget.h"
-#ifdef TRACE_FUNCS
-#define TRACE_GV_FUNCS
-#endif
 static int Vect_ID[MAX_VECTS];
 static int Next_vect = 0;
@@ -42,11 +38,7 @@
     int i, found = 0;
-#ifdef TRACE_GV_FUNCS
-	Gs_status("GV_vect_exists");
-#endif
+    G_debug(3, "GV_vect_exists");
     if (NULL == gv_get_vect(id)) {
 	return (0);
@@ -71,11 +63,7 @@
     geovect *nv;
-	Gs_status("GV_new_vector");
-#endif
+    G_debug(3, "GV_new_vector");
     if (Next_vect < MAX_VECTS) {
 	nv = gv_get_new_vect();
@@ -143,11 +131,7 @@
-	Gs_status("GV_delete_vect");
-#endif
+    G_debug(3, "GV_delete_vect");
     if (GV_vect_exists(id)) {
 	gv_delete_vect(id);
@@ -297,11 +281,7 @@
     geovect *gv;
-	Gs_status("GV_set_trans");
-#endif
+    G_debug(3, "GV_set_trans");
     gv = gv_get_vect(id);
Modified: grass/branches/develbranch_6/lib/ogsf/GVL2.c
--- grass/branches/develbranch_6/lib/ogsf/GVL2.c	2008-05-11 06:36:08 UTC (rev 31311)
+++ grass/branches/develbranch_6/lib/ogsf/GVL2.c	2008-05-11 09:41:11 UTC (rev 31312)
@@ -21,17 +21,17 @@
 #include "gsget.h"
-#ifdef TRACE_FUNCS
-#define TRACE_GVL_FUNCS
-#endif
 static int Vol_ID[MAX_VOLS];
 static int Next_vol = 0;
 static G3D_Region wind3;
 static double Region[6];
+  \brief Library intialization for volumes
+  Set region extent (N,S,W,E,T,B)
 void GVL_libinit(void)
     G3d_initDefaults();
@@ -47,7 +47,14 @@
     return;
+  \brief Get region extent settings
+  \param[out] n,s,w,e north, south, west, east
+  \param[out] t,b top, bottom
+  \return 1
 int GVL_get_region(float *n, float *s, float *w, float *e, float *t, float *b)
     *n = Region[0];
@@ -60,47 +67,56 @@
     return (1);
-/* TODO: gvl_file.c use this - change*/
+  \brief Get window
+  \todo gvl_file.c use this - change
+  \return pointer to G3D_Region struct (static)
 void *GVL_get_window()
     return &wind3;
+  \brief Check if volume set exists
+  \param id volume set id
+  \return 1 found
+  \return 0 not found
 int GVL_vol_exists(int id)
     int i, found = 0;
-#ifdef TRACE_GVL_FUNCS
-    Gs_status("GVL_vol_exists");
-#endif
+    G_debug(3, "GVL_vol_exists");
     if (NULL == gvl_get_vol(id)) {
     return (0);
     for (i = 0; i < Next_vol && !found; i++) {
-    if (Vol_ID[i] == id) {
-        found = 1;
+	if (Vol_ID[i] == id) {
+	    found = 1;
     return (found);
+  \brief Add new volume set
+  \return volume set id
 int GVL_new_vol(void)
     geovol *nvl;
-    Gs_status("GVL_new_vol");
-#endif
+    G_debug(3, "GVL_new_vol");
     if (Next_vol < MAX_VOLS) {
         nvl = gvl_get_new_vol();
@@ -118,14 +134,26 @@
     return (-1);
+  \brief Get number of available volume sets
+  \return number of volume sets
 int GVL_num_vols(void)
     return (gvl_num_vols());
-/* USER must free!! */
+  \brief Get list volume sets
+  Must be freed if not needed!
+  \param[out] numvols number of volume sets
+  \return pointer to list of volume sets
+  \return NULL on error
 int *GVL_get_vol_list(int *numvols)
     int i, *ret;
@@ -133,162 +161,194 @@
     *numvols = Next_vol;
     if (Next_vol) {
-    if (NULL == (ret = (int *) G_malloc(Next_vol * sizeof(int)))) {
-        fprintf(stderr, "can't malloc\n");
+	ret = (int *) G_malloc(Next_vol * sizeof(int));
+	if (!ret)
+	    return (NULL);
-        return (NULL);
+	for (i = 0; i < Next_vol; i++) {
+	    ret[i] = Vol_ID[i];
+	return (ret);
-    for (i = 0; i < Next_vol; i++) {
-        ret[i] = Vol_ID[i];
-    return (ret);
     return (NULL);
+  \brief Delete volume set from list
+  \return 1 on success
+  \return -1 on error (invalid volume set id)
 int GVL_delete_vol(int id)
-    Gs_status("GVL_delete_vol");
-#endif
+    G_debug(3, "GVL_delete_vol");
     if (GVL_vol_exists(id)) {
-    for (i = 0; i < GVL_isosurf_num_isosurfs(id); i++) {
-        GVL_isosurf_del(id, 0);
+	for (i = 0; i < GVL_isosurf_num_isosurfs(id); i++) {
+	    GVL_isosurf_del(id, 0);
 	for (i = 0; i < GVL_slice_num_slices(id); i++) {
-        GVL_slice_del(id, 0);
+	    GVL_slice_del(id, 0);
+	gvl_delete_vol(id);
+	for (i = 0; i < Next_vol && !found; i++) {
+		found = 1;
+		for (j = i; j < Next_vol; j++) {
+		    Vol_ID[j] = Vol_ID[j + 1];
+	if (found) {
+	    --Next_vol;
+	    return (1);
-    gvl_delete_vol(id);
-    for (i = 0; i < Next_vol && !found; i++) {
-        found = 1;
-        for (j = i; j < Next_vol; j++) {
-            Vol_ID[j] = Vol_ID[j + 1];
-    if (found) {
-        --Next_vol;
-        return (1);
     return (-1);
+  \brief Load volume
+  \param filename filename
+  \return 0 on success
 int GVL_load_vol(int id, char *filename)
-	geovol *gvl;
+    geovol *gvl;
     int handle;
     if (NULL == (gvl = gvl_get_vol(id))) {
         return (-1);
     if (0 > (handle = gvl_file_newh(filename, VOL_FTYPE_G3D)))
         return (-1);
     gvl->hfile = handle;
-	return (0);
+    return (0);
+  \brief Get volume set name
+  \param[out] filename name (must be allocated)
 int GVL_get_volname(int id, char *filename)
     geovol *gvl;
-    return (-1);
+	return (-1);
     if (0 > gvl->hfile) {
-    return (-1);
+	return (-1);
     G_strcpy(filename, gvl_file_get_name(gvl->hfile));
     return (1);
+  \brief Get dimension
+  \param[out] rows,cols,depths number of rows, cols, depth
 void GVL_get_dims(int id, int *rows, int *cols, int *depths)
     geovol *gvl;
-    Gs_status("GVL_get_dims");
-#endif
+    G_debug(3, "GVL_get_dims");
     gvl = gvl_get_vol(id);
     if (gvl) {
-    *rows = gvl->rows;
-    *cols = gvl->cols;
-    *depths = gvl->depths;
+	*rows = gvl->rows;
+	*cols = gvl->cols;
+	*depths = gvl->depths;
     return;
+  \brief Set trans ?
+  \param xtrans,ytrans,ztrans x/y/z trans values
 void GVL_set_trans(int id, float xtrans, float ytrans, float ztrans)
     geovol *gvl;
-    Gs_status("GVL_set_trans");
-#endif
+    G_debug(3, "GVL_set_trans");
     if (gvl) {
-    gvl->x_trans = xtrans;
-    gvl->y_trans = ytrans;
-    gvl->z_trans = ztrans;
+	gvl->x_trans = xtrans;
+	gvl->y_trans = ytrans;
+	gvl->z_trans = ztrans;
     return;
+  \brief Get trans ?
+  \param[out] xtrans,ytrans,ztrans x/y/z trans values
 int GVL_get_trans(int id, float *xtrans, float *ytrans, float *ztrans)
     geovol *gvl;
     if (gvl) {
-    *xtrans = gvl->x_trans;
-    *ytrans = gvl->y_trans;
-    *ztrans = gvl->z_trans;
-    return (1);
+	*xtrans = gvl->x_trans;
+	*ytrans = gvl->y_trans;
+	*ztrans = gvl->z_trans;
+	return (1);
     return (-1);
+  \brief Draw volume set
+  \param vid volume set id
 void GVL_draw_vol(int vid)
     geovol *gvl;
@@ -302,16 +362,16 @@
     return;
+  \brief Draw volume wire mode
 void GVL_draw_wire(int id)
     geovol *gvl;
-	Gs_status("GVL_draw_wire");
-#endif
+    G_debug(3, "GVL_draw_wire");
@@ -322,47 +382,66 @@
     return;
+  \brief Draw all volume sets
 void GVL_alldraw_vol(void)
     int id;
     for (id = 0; id < Next_vol; id++) {
-    GVL_draw_vol(Vol_ID[id]);
+	GVL_draw_vol(Vol_ID[id]);
     return;
+  \brief Draw all volume sets in wire mode
 void GVL_alldraw_wire(void)
     int id;
-    GVL_draw_wire(Vol_ID[id]);
+	GVL_draw_wire(Vol_ID[id]);
     return;
+  \brief Set client data for volume set
+  \param clientd pointer to client data
 int GVL_Set_ClientData(int id, void *clientd)
     geovol *gvl;
     if (gvl) {
-    gvl->clientdata = clientd;
-    return (1);
+	gvl->clientdata = clientd;
+	return (1);
     return (-1);
+  \brief Get client data
+  \return pointer to client data
 void *GVL_Get_ClientData(int id)
     geovol *gvl;
@@ -370,23 +449,23 @@
     if (gvl) {
-    return (gvl->clientdata);
+	return (gvl->clientdata);
     return (NULL);
+  \brief Set focus on map center
 void GVL_set_focus_center_map(int id)
     float center[3];
     geovol *gvl;
-#endif
@@ -397,22 +476,27 @@
 	GS_set_focus(center);
+    return;
 /* ISOSURFACES */
+  \brief Get draw resolution for isosurface
+  \todo error handling
+  \param[out] xres,yres,zres x/y/z resolution value
 void GVL_isosurf_get_drawres(int id, int *xres, int *yres, int *zres)
     geovol *gvl;
-    Gs_status("GVL_isosurf_get_drawres");
-#endif
+    G_debug(3, "GVL_isosurf_get_drawres");
@@ -425,17 +509,21 @@
     return;
+  \brief Set draw resolution of isosurface
+  \param xres,yres,zres x/y/z resolution value
+  \return -1 on error (invalid values/volume set id)
 int GVL_isosurf_set_drawres(int id, int xres, int yres, int zres)
     geovol *gvl;
     int i;
-    Gs_status("GVL_isosurf_set_drawres");
-#endif
+    G_debug(3, "GVL_isosurf_set_drawres");
     if (xres < 1 || yres < 1 || zres < 1) {
         return (-1);
@@ -448,63 +536,80 @@
         gvl->isosurf_y_mod = yres;
         gvl->isosurf_z_mod = zres;
-		for (i = 0; i < gvl->n_isosurfs; i++) {
-			gvl_isosurf_set_att_changed(gvl->isosurf[i], ATT_TOPO);
+	for (i = 0; i < gvl->n_isosurfs; i++) {
+	    gvl_isosurf_set_att_changed(gvl->isosurf[i], ATT_TOPO);
+	return (0);
-    return (0);
+    return (-1);
+  \brief Get draw-mode of isosurface
+  \param[out] mode draw-mode
 int GVL_isosurf_get_drawmode(int id, int *mode)
     geovol *gvl;
     if (gvl) {
-    *mode = gvl->isosurf_draw_mode;
-    return (1);
+	*mode = gvl->isosurf_draw_mode;
+	return (1);
     return (-1);
+  \brief Set draw-mode of isosurface
+  \param mode draw-mode
 int GVL_isosurf_set_drawmode(int id, int mode)
     geovol *gvl;
-    Gs_status("GVL_isosurf_set_drawmode");
-#endif
+    G_debug(3, "GVL_isosurf_set_drawmode");
     if (gvl) {
-    gvl->isosurf_draw_mode = mode;
-    return (0);
+	gvl->isosurf_draw_mode = mode;
+	return (0);
     return (-1);
+  \brief Add isosurface
 int GVL_isosurf_add(int id)
     geovol *gvl;
     geovol_isosurf *isosurf;
-    Gs_status("GVL_isosurf_add");
-#endif
+    G_debug(3, "GVL_isosurf_add");
@@ -522,22 +627,26 @@
     gvl->n_isosurfs++;
     gvl->isosurf[gvl->n_isosurfs - 1] = (geovol_isosurf *) isosurf;
     return (1);
+  \brief Delete isosurface
+  \param isosurf_id isosurface id
 int GVL_isosurf_del(int id, int isosurf_id)
     geovol *gvl;
     int i;
-    Gs_status("GVL_isosurf_del");
-#endif
+    G_debug(3, "GVL_isosurf_del");
     isosurf = gvl_isosurf_get_isosurf(id, isosurf_id);
@@ -561,84 +670,101 @@
     return (1);
+  \brief Move up isosurface in list
 int GVL_isosurf_move_up(int id, int isosurf_id)
-	geovol *gvl;
-	geovol_isosurf *tmp;
+    geovol *gvl;
+    geovol_isosurf *tmp;
+    G_debug(3, "GVL_isosurf_move_up");
-    Gs_status("GVL_isosurf_move_up");
-#endif
-	gvl = gvl_get_vol(id);
-	if (!gvl)
-		return (-1);
-	if (isosurf_id < 0 || isosurf_id > (gvl->n_isosurfs - 1))
-		return (-1);
-	if (isosurf_id == 0)
-		return (1);
-	tmp = gvl->isosurf[isosurf_id - 1];
-	gvl->isosurf[isosurf_id - 1] = gvl->isosurf[isosurf_id];
-	gvl->isosurf[isosurf_id] = tmp;
+    gvl = gvl_get_vol(id);
+    if (!gvl)
+	return (-1);
+    if (isosurf_id < 0 || isosurf_id > (gvl->n_isosurfs - 1))
+	return (-1);
+    if (isosurf_id == 0)
 	return (1);
+    tmp = gvl->isosurf[isosurf_id - 1];
+    gvl->isosurf[isosurf_id - 1] = gvl->isosurf[isosurf_id];
+    gvl->isosurf[isosurf_id] = tmp;
+    return (1);
+  \brief Move down isosurface in list
 int GVL_isosurf_move_down(int id, int isosurf_id)
-	geovol *gvl;
+    geovol *gvl;
-#endif
+    if (!gvl)
+	return (-1);
+	return (-1);
+    if (isosurf_id == (gvl->n_isosurfs - 1))
+	return (1);
+    tmp = gvl->isosurf[isosurf_id + 1];
+    gvl->isosurf[isosurf_id + 1] = gvl->isosurf[isosurf_id];
+    return (1);
+  \brief Get isosurface attributes
-	if (!gvl)
-		return (-1);
+  \param isosurf_id surface id
+  \param att attribute id
+  \param[out] set
+  \param[out] constant
+  \param[out] mapname
-		return (-1);
-	if (isosurf_id == (gvl->n_isosurfs - 1))
-		return (1);
-	tmp = gvl->isosurf[isosurf_id + 1];
-	gvl->isosurf[isosurf_id + 1] = gvl->isosurf[isosurf_id];
-	return (1);
-int GVL_isosurf_get_att(int id, int isosurf_id, int att, int *set, float *constant, char *mapname)
+int GVL_isosurf_get_att(int id, int isosurf_id,
+			int att, int *set, float *constant, char *mapname)
     int src;
-    Gs_status("GVL_isosurf_get_att");
-#endif
+    G_debug(3, "GVL_isosurf_get_att");
     if (isosurf) {
         if (-1 != (src = gvl_isosurf_get_att_src(isosurf, att))) {
             *set = src;
             if (src == CONST_ATT) {
                 *constant = isosurf->att[att].constant;
@@ -655,16 +781,21 @@
     return (-1);
+  \brief Unset isosurface attributes
+  \param isosurface_id isosurface id
+  \return ?
 int GVL_isosurf_unset_att(int id, int isosurf_id, int att)
-    Gs_status("GVL_isosurf_unset_att");
-#endif
+    G_debug(3, "GVL_isosurf_unset_att");
@@ -675,16 +806,22 @@
     return (-1);
+  \brief Set constant isosurface attribute
+  \param constant constant value
+  \return ?
 int GVL_isosurf_set_att_const(int id, int isosurf_id, int att, float constant)
-    Gs_status("GVL_isosurf_set_att_const");
-#endif
+    G_debug(3, "GVL_isosurf_set_att_const");
@@ -695,16 +832,22 @@
     return (-1);
+  \brief Set isosurface map attribute
+  \param filename map name
+  \return ?
 int GVL_isosurf_set_att_map(int id, int isosurf_id, int att, char *filename)
-    Gs_status("GVL_isosurf_set_att_map");
-#endif
+    G_debug(3, "GVL_isosurf_set_att_map");
@@ -715,16 +858,21 @@
     return (-1);
+  \brief Get isosurface flags
+  \param[out] inout map name
 int GVL_isosurf_get_flags(int id, int isosurf_id, int *inout)
-    Gs_status("GVL_isosurf_get_flags");
-#endif
+    G_debug(3, "GVL_isosurf_get_flags");
@@ -736,38 +884,46 @@
     return (-1);
+  \brief Set isosurface flags
+  \param inout map name
 int GVL_isosurf_set_flags(int id, int isosurf_id, int inout)
-#endif
     if (isosurf) {
         isosurf->inout_mode = inout;
-		return (1);
+	return (1);
     return (-1);
+  \brief Get number of available isosurfaces
+  \return number of isosurfaces
 int GVL_isosurf_num_isosurfs(int id)
     geovol *gvl;
-    Gs_status("GVL_isosurf_num_isosurfs");
-#endif
+    G_debug(3, "GVL_isosurf_num_isosurfs");
@@ -778,17 +934,23 @@
     return (-1);
-/* mask attribute special: constant is set to indicate invert or no */
+  \brief Set mask attribute mode
+  Mask attribute special: constant is set to indicate invert or no
+  \param mode attribute mode
+  \return mode id
 int GVL_isosurf_set_maskmode(int id, int isosurf_id, int mode)
-#endif
@@ -801,7 +963,16 @@
     return (-1);
+  \brief Get isosurface mask mode
 int GVL_isosurf_get_maskmode(int id, int isosurf_id, int *mode)
@@ -809,9 +980,9 @@
     if (isosurf) {
-    *mode = isosurf->att[ATT_MASK].constant;
-    return (1);
+	*mode = isosurf->att[ATT_MASK].constant;
+	return (1);
     return (-1);
@@ -821,16 +992,17 @@
 /* SLICES */
+  \brief Get draw resolution of slice
 void GVL_slice_get_drawres(int id, int *xres, int *yres, int *zres)
     geovol *gvl;
-    Gs_status("GVL_slice_get_drawres");
-#endif
+    G_debug(3, "GVL_slice_get_drawres");
@@ -843,17 +1015,21 @@
     return;
+  \brief Set draw resolution of slice
+  \return -1 on error (invalid value or id)
 int GVL_slice_set_drawres(int id, int xres, int yres, int zres)
     geovol *gvl;
     int i;
-    Gs_status("GVL_slice_set_drawres");
-#endif
+    G_debug(3, "GVL_slice_set_drawres");
         return (-1);
@@ -866,15 +1042,25 @@
         gvl->slice_y_mod = yres;
         gvl->slice_z_mod = zres;
-		for (i = 0; i < gvl->n_slices; i++) {
-			gvl->slice[i]->changed = 1;
+	for (i = 0; i < gvl->n_slices; i++) {
+	    gvl->slice[i]->changed = 1;
+	return (0);
-    return (0);
+    return (-1);
+  \brief Get slice draw mode
+  \param[out] mode draw mode
+  \return -1 on error (invalid id)
 int GVL_slice_get_drawmode(int id, int *mode)
     geovol *gvl;
@@ -882,47 +1068,54 @@
     if (gvl) {
-    *mode = gvl->slice_draw_mode;
-    return (1);
+	*mode = gvl->slice_draw_mode;
+	return (1);
     return (-1);
+  \brief Set slice draw mode
+  \param mode draw mode
 int GVL_slice_set_drawmode(int id, int mode)
     geovol *gvl;
-    Gs_status("GVL_slice_set_drawmode");
-#endif
+    G_debug(3, "GVL_slice_set_drawmode");
     if (gvl) {
-    gvl->slice_draw_mode = mode;
-    return (0);
+	gvl->slice_draw_mode = mode;
+	return (0);
     return (-1);
+  \brief Add slice
 int GVL_slice_add(int id)
     geovol *gvl;
     geovol_slice *slice;
-    Gs_status("GVL_slice_add");
-#endif
+    G_debug(3, "GVL_slice_add");
@@ -944,18 +1137,22 @@
     return (1);
+  \brief Delete slice
+  \param slice_id slice id
 int GVL_slice_del(int id, int slice_id)
     geovol *gvl;
     int i;
-    Gs_status("GVL_slice_del");
-#endif
+    G_debug(3, "GVL_slice_del");
     slice = gvl_slice_get_slice(id, slice_id);
@@ -979,76 +1176,87 @@
     return (1);
+  \brief Move up slice
 int GVL_slice_move_up(int id, int slice_id)
-	geovol *gvl;
-	geovol_slice *tmp;
+    geovol *gvl;
+    geovol_slice *tmp;
-    Gs_status("GVL_slice_move_up");
-#endif
+    G_debug(3, "GVL_slice_move_up");
+    if (!gvl)
+	return (-1);
+    if (slice_id < 0 || slice_id > (gvl->n_slices - 1))
+	return (-1);
+    if (slice_id == 0)
+	return (1);
+    tmp = gvl->slice[slice_id - 1];
+    gvl->slice[slice_id - 1] = gvl->slice[slice_id];
+    gvl->slice[slice_id] = tmp;
+    return (1);
-	if (!gvl)
-		return (-1);
+  \brief Move down slice
-	if (slice_id < 0 || slice_id > (gvl->n_slices - 1))
-		return (-1);
-	if (slice_id == 0)
-		return (1);
+int GVL_slice_move_down(int id, int slice_id)
+    geovol *gvl;
-	tmp = gvl->slice[slice_id - 1];
-	gvl->slice[slice_id - 1] = gvl->slice[slice_id];
-	gvl->slice[slice_id] = tmp;
+    if (!gvl)
+	return (-1);
+	return (-1);
+    if (slice_id == (gvl->n_slices - 1))
 	return (1);
+    tmp = gvl->slice[slice_id + 1];
+    gvl->slice[slice_id + 1] = gvl->slice[slice_id];
+    return (1);
-int GVL_slice_move_down(int id, int slice_id)
-	geovol *gvl;
+  \brief Get number or slices
-#endif
-	if (!gvl)
-		return (-1);
-		return (-1);
-	if (slice_id == (gvl->n_slices - 1))
-		return (1);
-	tmp = gvl->slice[slice_id + 1];
-	gvl->slice[slice_id + 1] = gvl->slice[slice_id];
-	return (1);
+  \return number of slices
 int GVL_slice_num_slices(int id)
     geovol *gvl;
-#endif
@@ -1059,108 +1267,137 @@
     return (-1);
-int GVL_slice_get_pos(int id, int slice_id, float *x1, float *x2, float *y1, float *y2, float *z1, float *z2, int *dir)
+  \brief Get slice position
+  \param[out] x1,y1,z1 coordinates ?
+  \param[out] x2,y2,z2 coordinates ?
+  \param[out] dir direction
+int GVL_slice_get_pos(int id, int slice_id,
+		      float *x1, float *x2, float *y1, float *y2, float *z1, float *z2, int *dir)
     geovol *gvl;
-	geovol_slice *slice;
-	int cols, rows, depths;
+    geovol_slice *slice;
+    int cols, rows, depths;
-	if (!gvl)
-		return (-1);
+    if (!gvl)
+	return (-1);
-	if (!slice)
-		return (-1);
-	if (slice->dir == X) {
+    if (!slice)
+	return (-1);
+    if (slice->dir == X) {
     	cols = gvl->rows;
-		rows = gvl->depths;
-		depths = gvl->cols;
-	} else if (slice->dir == Y) {
-		cols = gvl->cols;
-		depths = gvl->rows;
-	}  else if (slice->dir == Z) {
-		cols = gvl->cols;
-		rows = gvl->rows;
-		depths = gvl->depths;
-	} else {
-		return (-1);
-	*x1 = slice->x1 / (cols - 1);
-	*x2 = slice->x2 / (cols - 1);
-	*y1 = slice->y1 / (rows - 1);
-	*y2 = slice->y2 / (rows - 1);
-	*z1 = slice->z1 / (depths - 1);
-	*z2 = slice->z2 / (depths - 1);
-	*dir = slice->dir;
+	rows = gvl->depths;
+	depths = gvl->cols;
+    } else if (slice->dir == Y) {
+	cols = gvl->cols;
+	depths = gvl->rows;
+    }  else if (slice->dir == Z) {
+	cols = gvl->cols;
+	rows = gvl->rows;
+	depths = gvl->depths;
+    } else {
+	return (-1);
+    *x1 = slice->x1 / (cols - 1);
+    *x2 = slice->x2 / (cols - 1);
+    *y1 = slice->y1 / (rows - 1);
+    *y2 = slice->y2 / (rows - 1);
+    *z1 = slice->z1 / (depths - 1);
+    *z2 = slice->z2 / (depths - 1);
+    *dir = slice->dir;
     return (1);
-int GVL_slice_set_pos(int id, int slice_id, float x1, float x2, float y1, float y2, float z1, float z2, int dir)
-	geovol *gvl;
+  \param x1,y1,z1 coordinates ?
+  \param x2,y2,z2 coordinates ?
+  \param dir direction
-	if (!gvl)
-		return (-1);
+int GVL_slice_set_pos(int id, int slice_id,
+		      float x1, float x2, float y1, float y2, float z1, float z2, int dir)
+    geovol *gvl;
+    if (!gvl)
+	return (-1);
-	if (!slice)
-		return (-1);
-	if (dir == X) {
+    if (!slice)
+	return (-1);
+    if (dir == X) {
     	cols = gvl->rows;
-	} else if (dir == Y) {
-		cols = gvl->cols;
-	}  else if (dir == Z) {
-		cols = gvl->cols;
-		rows = gvl->rows;
-	} else {
-		return (-1);
+    } else if (dir == Y) {
+	cols = gvl->cols;
+    }  else if (dir == Z) {
+	cols = gvl->cols;
+	rows = gvl->rows;
+    } else {
+	return (-1);
+    slice->x1 = ((x1 < 0.) ? 0. : ((x1 > 1.) ? 1. : x1)) * (cols - 1);
+    slice->x2 = ((x2 < 0.) ? 0. : ((x2 > 1.) ? 1. : x2)) * (cols - 1);
+    slice->y1 = ((y1 < 0.) ? 0. : ((y1 > 1.) ? 1. : y1)) * (rows - 1);
+    slice->y2 = ((y2 < 0.) ? 0. : ((y2 > 1.) ? 1. : y2)) * (rows - 1);
+    slice->z1 = ((z1 < 0.) ? 0. : ((z1 > 1.) ? 1. : z1)) * (depths - 1);
+    slice->z2 = ((z2 < 0.) ? 0. : ((z2 > 1.) ? 1. : z2)) * (depths - 1);
+    slice->dir = dir;
+    slice->changed = 1;
+    return (1);
-	slice->x1 = ((x1 < 0.) ? 0. : ((x1 > 1.) ? 1. : x1)) * (cols - 1);
-	slice->x2 = ((x2 < 0.) ? 0. : ((x2 > 1.) ? 1. : x2)) * (cols - 1);
-	slice->y1 = ((y1 < 0.) ? 0. : ((y1 > 1.) ? 1. : y1)) * (rows - 1);
-	slice->y2 = ((y2 < 0.) ? 0. : ((y2 > 1.) ? 1. : y2)) * (rows - 1);
-	slice->z1 = ((z1 < 0.) ? 0. : ((z1 > 1.) ? 1. : z1)) * (depths - 1);
-	slice->z2 = ((z2 < 0.) ? 0. : ((z2 > 1.) ? 1. : z2)) * (depths - 1);
+  \brief Get slice trans ?
-	slice->dir = dir;
+  \param[out] transp transp value
-	slice->changed = 1;
-    return (1);
 int GVL_slice_get_transp(int id, int slice_id, int *transp)
-    Gs_status("GVL_get_transp");
-#endif
+    G_debug(3, "GVL_get_transp");
@@ -1172,16 +1409,21 @@
     return (1);
+  \brief Set slice trans ?
+  \param transp transp value
 int GVL_slice_set_transp(int id, int slice_id, int transp)
-    Gs_status("GVL_set_transp");
-#endif
+    G_debug(3, "GVL_set_transp");
Modified: grass/branches/develbranch_6/lib/ogsf/Gs3.c
--- grass/branches/develbranch_6/lib/ogsf/Gs3.c	2008-05-11 06:36:08 UTC (rev 31311)
+++ grass/branches/develbranch_6/lib/ogsf/Gs3.c	2008-05-11 09:41:11 UTC (rev 31312)
@@ -64,10 +64,6 @@
 typedef int FILEDESC;
-#define TRACE_FUNCS
 #define NO_DATA_COL 0xffffff
Modified: grass/branches/develbranch_6/lib/ogsf/gs.c
--- grass/branches/develbranch_6/lib/ogsf/gs.c	2008-05-11 06:36:08 UTC (rev 31311)
+++ grass/branches/develbranch_6/lib/ogsf/gs.c	2008-05-11 09:41:11 UTC (rev 31312)
@@ -24,10 +24,6 @@
 #define FIRST_SURF_ID 110658
 static geosurf *Surf_top;
 static int Invertmask;
Modified: grass/branches/develbranch_6/lib/ogsf/gsds.c
--- grass/branches/develbranch_6/lib/ogsf/gsds.c	2008-05-11 06:36:08 UTC (rev 31311)
+++ grass/branches/develbranch_6/lib/ogsf/gsds.c	2008-05-11 09:41:11 UTC (rev 31312)
@@ -58,10 +58,6 @@
 #define LUCKY 33
 #define BLOC 20
 #define MAX_DS 100
Modified: grass/branches/develbranch_6/lib/ogsf/gv.c
--- grass/branches/develbranch_6/lib/ogsf/gv.c	2008-05-11 06:36:08 UTC (rev 31311)
+++ grass/branches/develbranch_6/lib/ogsf/gv.c	2008-05-11 09:41:11 UTC (rev 31312)
@@ -23,10 +23,6 @@
 #define FIRST_VECT_ID 20656
 static geovect *Vect_top = NULL;
