[GRASS-SVN] r31322 - grass/branches/develbranch_6/lib/ogsf
svn_grass at osgeo.org
Mon May 12 11:52:14 EDT 2008
Author: martinl
Date: 2008-05-12 11:52:14 -0400 (Mon, 12 May 2008)
New Revision: 31322
grass/branches/develbranch_6/lib/ogsf/GS2.c
grass/branches/develbranch_6/lib/ogsf/GSX.c
grass/branches/develbranch_6/lib/ogsf/Gp3.c
grass/branches/develbranch_6/lib/ogsf/Gs3.c
grass/branches/develbranch_6/lib/ogsf/Gv3.c
grass/branches/develbranch_6/lib/ogsf/Gvl3.c
grass/branches/develbranch_6/lib/ogsf/gk.c
grass/branches/develbranch_6/lib/ogsf/gsd_legend.c
grass/branches/develbranch_6/lib/ogsf/gvl_file.c
ogsflib: doxygenization in progress
better error-handling
Modified: grass/branches/develbranch_6/lib/ogsf/GS2.c
--- grass/branches/develbranch_6/lib/ogsf/GS2.c 2008-05-12 12:36:51 UTC (rev 31321)
+++ grass/branches/develbranch_6/lib/ogsf/GS2.c 2008-05-12 15:52:14 UTC (rev 31322)
@@ -1613,8 +1613,9 @@
mapset = G_find_cell2(filename, "");
if (mapset == NULL) {
/* Check for valid filename */
- G_fatal_error ("Raster map <%s> not found",
- G_fully_qualified_name(filename, mapset));
+ G_warning ("Raster map <%s> not found",
+ filename);
+ return -1;
filename = G_fully_qualified_name(filename, mapset);
Modified: grass/branches/develbranch_6/lib/ogsf/GSX.c
--- grass/branches/develbranch_6/lib/ogsf/GSX.c 2008-05-12 12:36:51 UTC (rev 31321)
+++ grass/branches/develbranch_6/lib/ogsf/GSX.c 2008-05-12 15:52:14 UTC (rev 31322)
@@ -22,6 +22,11 @@
static int Cxl = 0;
+ \brief Check cancel
+ \return code
int GS_check_cancel(void)
Cxl_func();
@@ -29,6 +34,9 @@
return (Cxl);
+ \brief Set cancel
void GS_set_cancel(int c)
Cxl = c;
@@ -36,6 +44,11 @@
return;
+ \brief Set cxl function
+ \param pointer to function
void GS_set_cxl_func(void (*f) (void))
Cxl_func = f;
@@ -43,7 +56,11 @@
return;
+ \brief Set swap function
void GS_set_swap_func(void (*f) (void))
Swap_func = f;
Modified: grass/branches/develbranch_6/lib/ogsf/Gp3.c
--- grass/branches/develbranch_6/lib/ogsf/Gp3.c 2008-05-12 12:36:51 UTC (rev 31321)
+++ grass/branches/develbranch_6/lib/ogsf/Gp3.c 2008-05-12 15:52:14 UTC (rev 31322)
@@ -1,7 +1,7 @@
\file Gp3.c
- \brief OGSF library - loading and manipulating point sets
+ \brief OGSF library - loading point sets (lower level functions)
GRASS OpenGL gsurf OGSF Library
@@ -13,18 +13,31 @@
for details.
\author Bill Brown USACERL, GMSL/University of Illinois (January 1994)
+ \author Doxygenized by Martin Landa <landa.martin gmail.com> (May 2008)
#include <stdlib.h>
#include <grass/gis.h>
#include <grass/site.h>
#include <grass/Vect.h>
+#include <grass/glocale.h>
#include <grass/gstypes.h>
-/* used when site attribute mode is ST_ATT_COLOR */
-/* Gets color structure for grass file, goes through points and
- uses fattr as CAT, putting rgb color in iattr. */
+ \brief Set color for point set
+ used when site attribute mode is ST_ATT_COLOR
+ Gets color structure for grass file, goes through points and
+ uses fattr as CAT, putting rgb color in iattr.
+ \param grassname raster map name
+ \param gp pointer to geopoint struct
+ \return 1 on success
+ \return 0 on failure
int Gp_set_color(char *grassname, geopoint * gp)
char *col_map;
@@ -36,16 +49,14 @@
/* TODO: handle error messages */
if (grassname) {
- col_map = G_find_file2("cell", grassname, "");
- if (col_map == NULL) {
- fprintf(stderr, "Could not find file '%s'", grassname);
- return (0);
+ col_map = G_find_cell2(grassname, "");
+ if (!col_map) {
+ G_warning (_("Raster map <%s> not found"), grassname);
+ return 0;
- else {
- G_read_colors(grassname, col_map, &sc);
+ G_read_colors(grassname, col_map, &sc);
for (tp = gp; tp; tp = tp->next) {
cat = (int) tp->fattr;
color = NULL_COLOR;
@@ -63,9 +74,19 @@
return (0);
-/* This loads to memory.
-The other alternative may be to load to a tmp file. */
+ \brief Load to points to memory
+ The other alternative may be to load to a tmp file.
+ \param grassname vector point map
+ \param nsites
+ \param has_z 2D or 3D points?
+ \param has_att attributes included
+ \return pointer to geopoint struct
+ \return NULL on failure
geopoint *Gp_load_sites(char *grassname, int *nsites, int *has_z,
int *has_att)
@@ -77,22 +98,30 @@
struct Cell_head wind;
RASTER_MAP_TYPE rtype;
int ndim;
+ char *mapset;
- /* TODO: handle error messages */
np = 0;
eof = 0;
*has_z = *has_att = 0;
+ mapset = G_find_vector2((const char *) grassname, "");
+ if (!mapset) {
+ G_warning (_("Vector map <%s> not found"),
+ grassname);
+ return NULL;
Vect_set_open_level (2);
- Vect_open_old (&map, grassname, "");
+ if (Vect_open_old (&map, grassname, "") == -1) {
+ G_fatal_error (_("Unable to open vector map <%s>"),
+ grassname);
Points = Vect_new_line_struct ();
Cats = Vect_new_cats_struct ();
- if (NULL == (top = gpt = (geopoint *) malloc(sizeof(geopoint)))) {
- fprintf(stderr, "Can't malloc.\n");
+ top = gpt = (geopoint *) G_malloc(sizeof(geopoint));
+ if (!top) {
return (NULL);
@@ -112,75 +141,77 @@
ltype = Vect_read_next_line (&map, Points, Cats);
switch (ltype)
- case -1:
- fprintf(stderr, "Can't read vector file");
- return (NULL);
- case -2: /* EOF */
- eof = 1;
- continue;
+ case -1:
+ G_warning(_("Unable to read vector map <%s>"),
+ grassname);
+ return (NULL);
+ case -2: /* EOF */
+ eof = 1;
+ continue;
if ( (ltype & GV_POINTS))
- np++;
- gpt->p3[X] = Points->x[0];
- gpt->p3[Y] = Points->y[0];
- if (ndim > 2) {
- *has_z = 1;
+ np++;
+ gpt->p3[X] = Points->x[0];
+ gpt->p3[Y] = Points->y[0];
+ if (ndim > 2) {
+ *has_z = 1;
gpt->dims = 3;
gpt->p3[Z] = Points->z[0];
- } else {
- gpt->dims = 2;
- *has_z = 0;
- if (Cats->n_cats > 0) {
- *has_att = 1;
- gpt->fattr = Cats->field[0]; /* Is this correct? */
- /* gpt->cat = ; ??***/
- gpt->highlight_color = gpt->highlight_size = gpt->highlight_marker = FALSE;
- } else {
- gpt->fattr = 0;
+ } else {
+ gpt->dims = 2;
+ *has_z = 0;
+ if (Cats->n_cats > 0) {
+ *has_att = 1;
+ gpt->fattr = Cats->field[0]; /* Is this correct? */
+ /* gpt->cat = ; ??***/
+ gpt->highlight_color = gpt->highlight_size = gpt->highlight_marker = FALSE;
+ } else {
+ gpt->fattr = 0;
*has_att = 0;
- gpt->iattr = gpt->fattr;
- gpt->cattr = NULL;
- G_debug(3, "loading vector point %d %f %f -- %d",
- np, Points->x[0], Points->y[0], Cats->n_cats);
- if (NULL ==
- (gpt->next = (geopoint *) malloc(sizeof(geopoint)))) {
- fprintf(stderr, "Can't malloc.\n");/*CLEAN UP*/
- return (NULL);
- prev = gpt;
- gpt = gpt->next;
+ gpt->iattr = gpt->fattr;
+ gpt->cattr = NULL;
+ G_debug(3, "loading vector point %d %f %f -- %d",
+ np, Points->x[0], Points->y[0], Cats->n_cats);
+ gpt->next = (geopoint *) G_malloc(sizeof(geopoint));/* G_fatal_error */
+ if (!gpt->next) {
+ return (NULL);
+ prev = gpt;
+ gpt = gpt->next;
if (np > 0)
prev->next = NULL;
- free(gpt);
+ G_free(gpt);
Vect_close (&map);
if (!np) {
- fprintf(stderr, "Error: No points from %s fall within current region\n", grassname);
- return(NULL);
+ G_warning (_("No points from %s fall within current region"),
+ grassname);
+ return(NULL);
} else {
- fprintf(stderr, "Vector file %s loaded with %d points.\n",
- grassname, np);
+ G_verbose_message(_("Vector file <%s> loaded with %d points"),
+ grassname, np);
*nsites = np;
return (top);
Modified: grass/branches/develbranch_6/lib/ogsf/Gs3.c
--- grass/branches/develbranch_6/lib/ogsf/Gs3.c 2008-05-12 12:36:51 UTC (rev 31321)
+++ grass/branches/develbranch_6/lib/ogsf/Gs3.c 2008-05-12 15:52:14 UTC (rev 31322)
@@ -1,7 +1,7 @@
\file Gs3.c
- \brief OGSF library - loading and manipulating surfaces
+ \brief OGSF library - loading surfaces (lower level functions)
@@ -121,7 +121,8 @@
\param[out] nullmap null map buffer
\param[out] has_null indicates if raster map contains null-data
- \return 1
int Gs_loadmap_as_float(struct Cell_head *wind, char *map_name, float *buff,
struct BM *nullmap, int *has_null)
@@ -132,9 +133,11 @@
G_debug(3, "Gs_loadmap_as_float");
- map_set = G_find_file2("cell", map_name, "");
+ map_set = G_find_cell2(map_name, "");
if (!map_set) {
- G_fatal_error(_("Raster map <%s> not found"), map_name);
+ G_warning(_("Raster map <%s> not found"),
+ map_name);
+ return 0;
*has_null = 0;
@@ -191,7 +194,8 @@
- \return 1
int Gs_loadmap_as_int(struct Cell_head *wind, char *map_name, int *buff,
@@ -202,9 +206,11 @@
G_debug(3, "Gs_loadmap_as_int");
if (!map_set) {
+ map_name);
+ return 0;
*has_null = 0;
@@ -284,9 +290,11 @@
first = 0;
- mapset = G_find_file2("cell", filename, "");
+ mapset = G_find_cell2(filename, "");
if (!mapset) {
- G_fatal_error(_("Raster map <%s> not found"), filename);
+ filename);
+ return -1;
if (G_raster_map_is_fp(filename, mapset)) {
@@ -355,9 +363,11 @@
max_short -= 1;
if (!map_set) {
+ map_name);
+ return -1;
*has_null = 0;
@@ -467,9 +477,11 @@
max_char -= 1;
if (!map_set) {
+ map_name);
+ return -1;
*has_null = 0;
@@ -560,9 +572,11 @@
G_debug(3, "Gs_loadmap_as_bitmap");
if (!map_set) {
+ map_name);
+ return -1;
if ((cellfile = G_open_cell_old(map_name, map_set)) == -1) {
@@ -612,7 +626,8 @@
\param filename raster map name
\param[out] buff data buffer
- \return 1
int Gs_build_256lookup(char *filename, int *buff)
@@ -624,9 +639,11 @@
G_debug(3, "building color table");
- map = G_find_file2("cell", filename, "");
+ map = G_find_cell2(filename, "");
if (!map) {
+ filename);
+ return 0;
G_read_colors(filename, map, &colrules);
@@ -679,9 +696,11 @@
unsigned char *r, *g, *b, *set;
int *cur, i, j;
if (!map) {
+ filename);
+ return;
r = (unsigned char *) G_malloc(cols);
@@ -747,9 +766,11 @@
int i, j, *icur;
FCELL *fcur;
if (!map) {
+ filename);
+ return;
@@ -803,7 +824,8 @@
\param dcol
\param catstr category string
- \return 1
int Gs_get_cat_label(char *filename, int drow, int dcol, char *catstr)
@@ -814,8 +836,10 @@
RASTER_MAP_TYPE map_type;
int fd;
- if ((mapset = G_find_cell(filename, "")) == NULL) {
+ if ((mapset = G_find_cell2(filename, "")) == NULL) {
+ filename);
+ return 0;
if (-1 != G_read_cats(filename, mapset, &cats)) {
Modified: grass/branches/develbranch_6/lib/ogsf/Gv3.c
--- grass/branches/develbranch_6/lib/ogsf/Gv3.c 2008-05-12 12:36:51 UTC (rev 31321)
+++ grass/branches/develbranch_6/lib/ogsf/Gv3.c 2008-05-12 15:52:14 UTC (rev 31322)
@@ -1,7 +1,7 @@
\file Gv3.c
- \brief OGSF library - loading and manipulating vector sets
+ \brief OGSF library - loading vector sets (lower level functions)
@@ -13,12 +13,13 @@
for details.
\author Bill Brown USACERL (December 1993)
#include <stdlib.h>
#define TRAK_MEM
@@ -27,8 +28,17 @@
static int Tot_mem = 0;
#endif
+ \brief Load vector map to memory
+ \param grassname vector map name
+ \param[out] number of loaded features
+ \return pointer to geoline struct
geoline *Gv_load_vect(char *grassname, int *nlines)
struct Map_info map;
@@ -37,28 +47,39 @@
int np, i, n, nareas, nl=0, area, type, is3d;
float vect[2][3];
+ char *mapset;
+ if (!mapset) {
+ G_warning(_("Vector map <%s> not found"),
+ grassname);
+ return NULL;
+ G_warning (_("Unable to open vector map <%s>"),
+ grassname);
+ return NULL;
- if (NULL == (top=gln=(geoline *)malloc(sizeof(geoline)))) {
- fprintf(stderr,"Can't malloc.\n");
- return(NULL);
+ top = gln = (geoline *) G_malloc(sizeof(geoline)); /* G_fatal_error */
+ if (!top) {
+ return NULL;
prev = top;
- #ifdef TRAK_MEM
- Tot_mem+=sizeof(geoline);
- #endif
+#ifdef TRAK_MEM
+ Tot_mem+=sizeof(geoline);
+#endif
points = Vect_new_line_struct ();
G_get_set_window (&wind) ;
Vect_set_constraint_region(&map,wind.north,wind.south,wind.east,wind.west,
PORT_DOUBLE_MAX, -PORT_DOUBLE_MAX);
is3d = Vect_is_3d ( &map );
/* Read areas */
@@ -67,33 +88,33 @@
G_debug(3, "Reading vector areas (nareas = %d)", n);
for ( area = 1; area <= n ; area++ ) {
G_debug(3, " area %d", area);
Vect_get_area_points ( &map, area, points );
if ( points->n_points < 3 ) continue;
gln->type = OGSF_POLYGON;
gln->npts = np = points->n_points;
G_debug(3, " np = %d", np);
if ( is3d ) {
gln->dims = 3;
- if (NULL == (gln->p3=(Point3 *)calloc(np, sizeof(Point3)))) {
- fprintf(stderr,"Can't calloc.\n"); /* CLEAN UP */
+ gln->p3 = (Point3 *) G_calloc(np, sizeof(Point3)); /* G_fatal_error */
+ if (!gln->p3) {
return(NULL);
- #ifdef TRAK_MEM
- Tot_mem+=(np*sizeof(Point3));
- #endif
+#ifdef TRAK_MEM
+ Tot_mem+=(np*sizeof(Point3));
+#endif
} else {
gln->dims = 2;
- if (NULL == (gln->p2=(Point2 *)calloc(np, sizeof(Point2)))) {
+ gln->p2=(Point2 *) G_calloc(np, sizeof(Point2)); /* G_fatal_error */
+ if (!gln->p2) {
return(NULL);
- #ifdef TRAK_MEM
- Tot_mem+=(np*sizeof(Point2));
- #endif
+#ifdef TRAK_MEM
+ Tot_mem+=(np*sizeof(Point2));
+#endif
for (i=0; i < np; i++) {
if ( is3d ) {
gln->p3[i][X] = points->x[i];
@@ -116,21 +137,21 @@
- if (NULL == (gln->next=(geoline *)malloc (sizeof(geoline)))) {
- fprintf(stderr,"Can't malloc.\n"); /* CLEAN UP */
+ gln->next = (geoline *) G_malloc (sizeof(geoline)); /* G_fatal_error */
+ if (!gln->next) {
return(NULL);
- #ifdef TRAK_MEM
- #endif
+#ifdef TRAK_MEM
+#endif
prev = gln;
gln = gln->next;
nareas++;
G_debug(3, "%d areas loaded", nareas);
/* Read all lines */
G_debug(3, "Reading vector lines ...");
while (-1 < (type = Vect_read_next_line(&map, points, NULL))) {
@@ -143,31 +164,30 @@
/* Vect_append_point ( points, points->x[0], points->y[0], points->z[0] ); */
if ( is3d ) {
gln->dims = 3;
+ gln->p3=(Point3 *) G_calloc(np, sizeof(Point3)); /* G_fatal_error */
+ if (!gln->p3) {
return(NULL);
- #ifdef TRAK_MEM
- #endif
+#ifdef TRAK_MEM
+#endif
} else {
gln->dims = 2;
+ gln->p2 = (Point2 *) G_calloc(np, sizeof(Point2)); /* G_fatal_error */
+ if (!gln->p2) {
return(NULL);
- #ifdef TRAK_MEM
- #endif
+#ifdef TRAK_MEM
+#endif
if ( is3d ) {
@@ -189,16 +209,15 @@
GS_v3cross( vect[1], vect[0], gln->norm );
G_debug ( 3, "norm %f %f %f", gln->norm[0], gln->norm[1], gln->norm[2] );
+ if (!gln->next) {
return(NULL);
- #ifdef TRAK_MEM
- #endif
+#ifdef TRAK_MEM
+#endif
prev = gln;
gln = gln->next;
nl++;
@@ -209,59 +228,74 @@
nl += nareas;
prev->next = NULL;
- free(gln);
+ G_free(gln);
- #ifdef TRAK_MEM
- Tot_mem-=sizeof(geoline);
- #endif
+#ifdef TRAK_MEM
+ Tot_mem-=sizeof(geoline);
+#endif
Vect_close (&map);
- fprintf(stderr,"Vector file %s loaded.\n",grassname);
if (!nl) {
- fprintf(stderr, "Error: No lines from %s fall within current region\n", grassname);
- return (NULL);
+ G_warning (_("No features from vector map <%s> fall within current region"),
+ grassname);
+ return (NULL);
+ G_verbose_message (_("Vector map <%s> loaded (%d features)"),
+ grassname, nl);
*nlines = nl;
- #ifdef TRAK_MEM
- fprintf(stderr,"Total vect memory = %d Kbytes\n", Tot_mem/1000);
- #endif
+#ifdef TRAK_MEM
+ G_debug (3, "Total vect memory = %d Kbytes", Tot_mem/1000);
+#endif
return(top);
+ \brief Tracking memory
+ \param plus plus number
void add_Vectmem(int plus)
- #ifdef TRAK_MEM
+#ifdef TRAK_MEM
Tot_mem+=plus;
- #endif
+#endif
return;
+ \param minus mimus number
void sub_Vectmem(int minus)
- #ifdef TRAK_MEM
+#ifdef TRAK_MEM
Tot_mem-=minus;
- #endif
+#endif
return;
+ \brief Tracking memory (print)
void show_Vectmem(void)
- #ifdef TRAK_MEM
+#ifdef TRAK_MEM
+ G_message("Total vect memory = %d Kbytes", Tot_mem/1000);
- #endif
+#endif
return;
Modified: grass/branches/develbranch_6/lib/ogsf/Gvl3.c
--- grass/branches/develbranch_6/lib/ogsf/Gvl3.c 2008-05-12 12:36:51 UTC (rev 31321)
+++ grass/branches/develbranch_6/lib/ogsf/Gvl3.c 2008-05-12 15:52:14 UTC (rev 31322)
@@ -1,7 +1,7 @@
\file Gvl3.c
- \brief OGSF library - loading and manipulating volumes
+ \brief OGSF library - loading volumes (lower level functions)
@@ -13,19 +13,30 @@
for details.
\author Tomas Paudits (December 2003)
#include <grass/G3d.h>
+ \brief Load color table
+ \param[out] color_data color data buffer
+ \param name 3D raster map name
+ \return -1 on failure
int Gvl_load_colors_data(void **color_data, char *name)
char *mapset;
struct Colors *colors;
if (NULL == (mapset = G_find_grid3(name,""))) {
+ G_warning(_("3D raster map <%s> not found"), name);
return (-1);
@@ -42,7 +53,14 @@
return (1);
+ \brief Unload color table
+ \param color_data color data buffer
int Gvl_unload_colors_data(void *color_data)
if (!G_free_colors(color_data))
@@ -53,7 +71,14 @@
return (1);
+ \brief Get color for value
+ \param color_data color data value
+ \param value data value
+ \return color value
int Gvl_get_color_for_value(void *color_data, float *value)
int r, g, b;
Modified: grass/branches/develbranch_6/lib/ogsf/gk.c
--- grass/branches/develbranch_6/lib/ogsf/gk.c 2008-05-12 12:36:51 UTC (rev 31321)
+++ grass/branches/develbranch_6/lib/ogsf/gk.c 2008-05-12 15:52:14 UTC (rev 31322)
@@ -1,7 +1,7 @@
\file gk.c
- \brief OGSF library - setting and manipulating keyframes animation
+ \brief OGSF library - setting and manipulating keyframes animation (lower level functions)
@@ -13,6 +13,7 @@
for details.
#include <stdlib.h>
@@ -35,13 +36,20 @@
(double) tension * rderiv * (x3 - x2)));
+ \brief Copy keyframes
+ \param k source keyframes
+ \return pointer to Keylist struct (target)
Keylist *gk_copy_key(Keylist * k)
Keylist *newk;
int i;
- if (NULL == (newk = (Keylist *) malloc(sizeof(Keylist)))) {
- fprintf(stderr, "Out of memory\n");
+ newk = (Keylist *) G_malloc(sizeof(Keylist)); /* G_fatal_error */
+ if (!newk) {
return (NULL);
@@ -57,8 +65,18 @@
return (newk);
-/* get begin & end pos, AND all masks in keys <= pos */
-/* time must be between 0.0 & 1.0 */
+ \brief Get mask value
+ Get begin & end pos, AND all masks in keys <= pos
+ Time must be between 0.0 & 1.0
+ \param time timestamp
+ \param keys list of keyframes
+ \return mask value
unsigned long gk_get_mask_sofar(float time, Keylist * keys)
Keylist *k;
@@ -83,6 +101,15 @@
return (mask);
+ \brief ADD
+ \param mask mask value
+ \param[out] keyret output list of keyframes
+ \return number of output keyframes
int gk_viable_keys_for_mask(unsigned long mask, Keylist * keys,
Keylist ** keyret)
@@ -98,8 +125,20 @@
return (cnt);
-/* checks key masks because if they're masked up until the current position,
- pre-existing (or current) field should be used. */
+ \brief Checks key masks
+ Because if they're masked up until the current position,
+ pre-existing (or current) field should be used.
+ \param view pointer to Viewmode struct
+ \param numsteps number of steps
+ \param step step value
+ \param onestep
+ \param render
+ \param mode
void gk_follow_frames(Viewnode * view, int numsteps, Keylist * keys, int step,
int onestep, int render, unsigned long mode)
@@ -132,17 +171,15 @@
GS_moveto(tmp);
-#ifdef KDEBUG
- GS_get_from(tmp);
- fprintf(stderr, "MASK: %x\n", mask);
- fprintf(stderr, "FROM: %f %f %f\n", tmp[X], tmp[Y], tmp[Z]);
-#endif
-/* ACS 1 line: was GS_get_focus(tmp);
- with this kanimator works also for flythrough navigation
- also changed in GK2.c
+ GS_get_from(tmp);
+ G_debug(3, "gk_follow_frames():");
+ G_debug(3, " MASK: %x", mask);
+ G_debug(3, " FROM: %f %f %f", tmp[X], tmp[Y], tmp[Z]);
+ /* ACS 1 line: was GS_get_focus(tmp);
+ with this kanimator works also for flythrough navigation
+ also changed in GK2.c
GS_get_viewdir(tmp);
if ((mask & KF_DIRX_MASK)) {
tmp[X] = v->fields[KF_DIRX];
@@ -153,20 +190,16 @@
if ((mask & KF_DIRZ_MASK)) {
tmp[Z] = v->fields[KF_DIRZ];
-/* ACS 1 line: was GS_set_focus(tmp);
+ /* ACS 1 line: was GS_set_focus(tmp);
GS_set_viewdir(tmp);
+ GS_get_viewdir(tmp);
+ G_debug(3, " DIR: %f %f %f\n", tmp[X], tmp[Y], tmp[Z]);
-#ifdef KDEBUG
- GS_get_viewdir(tmp);
- fprintf(stderr, "DIR: %f %f %f\n", tmp[X], tmp[Y], tmp[Z]);
-#endif
if ((mask & KF_TWIST_MASK)) {
GS_set_twist((int) v->fields[KF_TWIST]);
@@ -231,6 +264,11 @@
return;
+ \brief Free keyframe list
+ \param ok pointer to Keylist struct
void gk_free_key(Keylist * ok)
Keylist *k, *prev;
@@ -240,14 +278,27 @@
while (k) {
prev = k;
k = k->next;
- free(prev);
+ G_free(prev);
return;
-/* here we use a cardinal cubic spline */
+ \brief Generate viewnode from keyframes
+ Here we use a cardinal cubic spline
+ \param keysteps keyframe step
+ \param newsteps new step value
+ \param loop loop indicator
+ \param t
+ \return pointer to Viewnode
Viewnode *gk_make_framesfromkeys(Keylist * keys, int keysteps, int newsteps,
int loop, float t)
@@ -258,8 +309,8 @@
double dt1, dt2, x, x2, x3, range, time, time_step, len, rderiv, lderiv;
/* allocate tmp keys to hold valid keys for fields */
- if (NULL == (tkeys = (Keylist **) malloc(keysteps * sizeof(Keylist *)))) {
- fprintf(stderr, "Unable to allocate memory\n");
+ tkeys = (Keylist **) G_malloc(keysteps * sizeof(Keylist *)); /* G_fatal_error */
+ if (!tkeys) {
return (NULL);
@@ -267,8 +318,8 @@
if (keys && keysteps) {
if (keysteps < 3) {
- fprintf(stderr, "Need at least 3 keyframes for spline\n");
- free(tkeys);
+ G_warning (_("Need at least 3 keyframes for spline"));
+ G_free(tkeys);
return (NULL);
@@ -280,10 +331,9 @@
range = endpos - startpos;
time_step = range / (newsteps - 1);
- if (NULL ==
- (newview = (Viewnode *) malloc(newsteps * sizeof(Viewnode)))) {
- free(tkeys);
+ newview = (Viewnode *) G_malloc(newsteps * sizeof(Viewnode)); /* G_fatal_error */
+ if(!newview) { /* not used */
+ G_free(tkeys);
return (NULL);
@@ -310,9 +360,9 @@
loop, tkeys, &k, &kp1, &kp2, &km1,
&dt1, &dt2);
/* ACS 1 line: was if (len == 0.0) {
- when disabling a channel no calculation must be made at all (otherwise core dump)
+ when disabling a channel no calculation must be made at all (otherwise core dump)
if (len == 0.0 || nvk == 0) {
if (!k) {
@@ -368,23 +418,40 @@
- free(tkeys);
+ G_free(tkeys);
return (newview);
else {
- free(tkeys);
+ G_free(tkeys);
return (NULL);
-/* finds interval containing time, putting left (or equal) key
- at km1, right at kp1, 2nd to right at kp2, and second to left at km2.
- dt1 is given the length of the current + left intervals
- dt2 is given the length of the current + right intervals
- returns the length of the current interval (0 on error)
+ \brief Find interval containing time
+ Changed June 94 to handle masks - now need to have called get_viable_keys
+ for appropriate mask first to build the ARRAY of viable keyframes.
+ Putting left (or equal) key
+ at km1, right at kp1, 2nd to right at kp2, and second to left at km2.
+ dt1 is given the length of the current + left intervals
+ dt2 is given the length of the current + right intervals
+ \param nvk
+ \param time
+ \param range
+ \param loop
+ \param karray
+ \param km1
+ \param kp1
+ \param kp2
+ \param km2
+ \param dt1
+ \param dt2
- Changed June 94 to handle masks - now need to have called get_viable_keys
- for appropriate mask first to build the ARRAY of viable keyframes.
+ \return the length of the current interval
+ \return 0 on error
double get_key_neighbors(int nvk, double time, double range, int loop,
Keylist * karray[], Keylist ** km1, Keylist ** kp1,
@@ -461,13 +528,33 @@
return (len);
+ \brief Linear interpolation
+ \param dt coeficient
+ \param val2 value 2
+ \param val1 value 1
+ \return val1 + dt * (val2 - val1)
double lin_interp(float dt, float val1, float val2)
return ((double) (val1 + dt * (val2 - val1)));
+ \brief Finds interval containing time, putting left (or equal) key
+ \param nvk
+ \param time
+ \param range
+ \param loop
+ \param karray
+ \param km1
+ \param km2
+ \return interval value
double get_2key_neighbors(int nvk, float time, float range, int loop,
Keylist * karray[], Keylist ** km1, Keylist ** kp1)
@@ -501,8 +588,20 @@
return (len);
-/* Here we use linear interpolation. Loop variable isn't used, but left */
-/* in for use in possible "linear interp with smoothing" version. */
+ \brief Generate viewnode from keyframe list (linear interpolation)
+ Here we use linear interpolation. Loop variable isn't used, but left
+ in for use in possible "linear interp with smoothing" version.
+ \param kesy keyframe list
+ \param keysteps step value
+ \param pointer to viewnode struct
+ \param NULL on failure
Viewnode *gk_make_linear_framesfromkeys(Keylist * keys, int keysteps,
int newsteps, int loop)
@@ -512,8 +611,8 @@
float startpos, endpos, dt, range, time, time_step, len;
+ if(!tkeys) {
return (NULL);
@@ -521,8 +620,8 @@
if (keysteps < 2) {
- fprintf(stderr, "Need at least 2 keyframes for interpolation\n");
- free(tkeys);
+ G_warning (_("Need at least 2 keyframes for interpolation"));
+ G_free(tkeys);
return (NULL);
@@ -534,10 +633,9 @@
- if (NULL ==
- free(tkeys);
+ G_free(tkeys);
return (NULL);
@@ -564,7 +662,7 @@
if (!k1) {
@@ -583,19 +681,23 @@
k1->fields[field],
k2->fields[field]);
- free(tkeys);
+ G_free(tkeys);
return (newview);
else {
- free(tkeys);
+ G_free(tkeys);
return (NULL);
+ \brief Correct twist value
+ \param k keyframe list
void correct_twist(Keylist * k)
Keylist *c, *p, *t;
@@ -624,6 +726,16 @@
return;
+ \brief Draw path
+ \param views Viewnode struct
+ \param steps step value
+ \param keys keyframe list
int gk_draw_path(Viewnode * views, int steps, Keylist * keys)
Viewnode *v;
Modified: grass/branches/develbranch_6/lib/ogsf/gsd_legend.c
--- grass/branches/develbranch_6/lib/ogsf/gsd_legend.c 2008-05-12 12:36:51 UTC (rev 31321)
+++ grass/branches/develbranch_6/lib/ogsf/gsd_legend.c 2008-05-12 15:52:14 UTC (rev 31322)
@@ -201,9 +201,10 @@
if (flags[2])
do_invert = 1;
- mapset = G_find_cell(name, "");
+ mapset = G_find_cell2(name, "");
- fprintf(stderr, "Unable to locate raster %s\n", name);
+ name);
return (-1);
Modified: grass/branches/develbranch_6/lib/ogsf/gvl_file.c
--- grass/branches/develbranch_6/lib/ogsf/gvl_file.c 2008-05-12 12:36:51 UTC (rev 31321)
+++ grass/branches/develbranch_6/lib/ogsf/gvl_file.c 2008-05-12 15:52:14 UTC (rev 31322)
@@ -20,6 +20,7 @@
#include <grass/gsurf.h>
#define LUCKY 33
@@ -335,9 +336,8 @@
/* search for g3d file a return his mapset */
if (NULL == (mapset = G_find_grid3(filename,""))) {
-#ifdef DEBUG_MSG
- fprintf(stderr, "can't find grid3 file : %s\n", filename);
-#endif
+ G_warning (_("3D raster map <%s> not found"),
+ filename);
return (NULL);
