[GRASS-SVN] r31325 - grass/trunk/lib/ogsf
svn_grass at osgeo.org
Mon May 12 18:11:03 EDT 2008
Author: glynn
Date: 2008-05-12 18:11:03 -0400 (Mon, 12 May 2008)
New Revision: 31325
grass/trunk/lib/ogsf/gk.c
grass/trunk/lib/ogsf/gsd_img_mpeg.c
Fix int/long mismatch in gk_follow_frames()
Fix void return from non-void function add_video_stream()
Modified: grass/trunk/lib/ogsf/gk.c
--- grass/trunk/lib/ogsf/gk.c 2008-05-12 22:08:19 UTC (rev 31324)
+++ grass/trunk/lib/ogsf/gk.c 2008-05-12 22:11:03 UTC (rev 31325)
@@ -174,7 +174,7 @@
GS_get_from(tmp);
G_debug(3, "gk_follow_frames():");
- G_debug(3, " MASK: %x", mask);
+ G_debug(3, " MASK: %lx", mask);
G_debug(3, " FROM: %f %f %f", tmp[X], tmp[Y], tmp[Z]);
/* ACS 1 line: was GS_get_focus(tmp);
Modified: grass/trunk/lib/ogsf/gsd_img_mpeg.c
--- grass/trunk/lib/ogsf/gsd_img_mpeg.c 2008-05-12 22:08:19 UTC (rev 31324)
+++ grass/trunk/lib/ogsf/gsd_img_mpeg.c 2008-05-12 22:11:03 UTC (rev 31325)
@@ -53,7 +53,7 @@
st = av_new_stream(oc, 0);
if (!st) {
fprintf(stderr, "Could not alloc stream\n");
- return;
+ return NULL;
c = st->codec;
