[GRASS-SVN] r31329 - grass/branches/develbranch_6/scripts/r.in.wms
svn_grass at osgeo.org
Tue May 13 08:03:33 EDT 2008
Author: hamish
Date: 2008-05-13 08:03:32 -0400 (Tue, 13 May 2008)
New Revision: 31329
grass/branches/develbranch_6/scripts/r.in.wms/r.in.gdalwarp
grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
grass/branches/develbranch_6/scripts/r.in.wms/wms.download
grass/branches/develbranch_6/scripts/r.in.wms/wms.request
* add -g flag for braindead servers which can't handle POST data
* check to see if RGB image has an alpha layer before using it (jpeg)
* parse Channel list properly
* mention better method: gdal_merge.py
* add some more debug msgs
Modified: grass/branches/develbranch_6/scripts/r.in.wms/r.in.gdalwarp
--- grass/branches/develbranch_6/scripts/r.in.wms/r.in.gdalwarp 2008-05-13 07:06:24 UTC (rev 31328)
+++ grass/branches/develbranch_6/scripts/r.in.wms/r.in.gdalwarp 2008-05-13 12:03:32 UTC (rev 31329)
@@ -80,6 +80,8 @@
exec g.parser "$0" "$@"
fi
+g.message -d "[r.in.gdalwarp]"
#### setup temporary file
TMP="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
@@ -171,6 +173,11 @@
else
ALPHALAYER=${TMPMAPNAME}.alpha
fi
+ # test to see if the alpha map exists
+ g.findfile element=cell file="$ALPHALAYER" > /dev/null
+ if [ $? -ne 0 ] ; then
+ ALPHALAYER=""
+ fi
# Calculate the new maps:
for SUFFIX in $CHANNEL_SUFFIXES ; do
@@ -185,9 +192,16 @@
continue
fi
- # Use alpha channel for nulls:
- GRASS_VERBOSE=1 \
- r.mapcalc "${MAP}${sfx} = if( $ALPHALAYER, ${TMPMAPNAME}${sfx}, null() )"
+ g.message -d message="alpha=[$ALPHALAYER] MAPsfx=[${MAP}${sfx}] tmpname=[${TMPMAPNAME}${sfx}]"
+ if [ -n "$ALPHALAYER" ] ; then
+ # Use alpha channel for nulls:
+# problem: I've seen a map where alpha was 1-255; 1 being transparent. what to do?
+# (Geosci Australia Gold layer, format=tiff)
+ GRASS_VERBOSE=1 \
+ r.mapcalc "${MAP}${sfx} = if( $ALPHALAYER, ${TMPMAPNAME}${sfx}, null() )"
+ else
+ g.copy rast="${TMPMAPNAME}${sfx}","${MAP}${sfx}" --quiet
+ fi
# Copy the color tables:
r.colors map=${MAP}${sfx} rast=${TMPMAPNAME}${sfx} --quiet
@@ -210,8 +224,10 @@
fi
# Remove the old channels:
- CHANNEL_LIST_COMMA=`echo "$CHANNEL_LIST" | sed "s/ /,/g"`
+ CHANNEL_LIST_COMMA=`echo "$CHANNEL_LIST" | tr '\n' ',' | sed -e 's/ /,/g' -e 's/,$//'`
+ g.message -d message="CHANNEL_LIST_COMMA=[$CHANNEL_LIST_COMMA]"
g.remove rast="$CHANNEL_LIST_COMMA" --quiet
nowarpimport () {
@@ -357,6 +373,8 @@
# different color tables so patches output end up all freaky.
# r.mapcalc r#,g#,b# manual patching + r.composite?
# or d.out.file + r.in.png + r.region?
+ # *** there is a GDAL utility to do this: gdal_merge.py
+ # http://www.gdal.org/gdal_merge.html
#r.patch input="$MAPLIST" output="${GIS_OPT_OUTPUT}"
IFS=" "
Modified: grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
--- grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms 2008-05-13 07:06:24 UTC (rev 31328)
+++ grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms 2008-05-13 12:03:32 UTC (rev 31329)
@@ -29,24 +29,30 @@
#%end
#%flag
#% key: o
-#% description: Don't request transparent data.
+#% description: Don't request transparent data
#% guisection: Request
#%end
#%flag
#% key: c
-#% description: Clean existing data out of download directory.
+#% description: Clean existing data out of download directory
#% guisection: Download
#%end
#%flag
#% key: k
-#% description: Keep band numbers instead of using band color names.
+#% description: Keep band numbers instead of using band color names
#% guisection: Import
#%end
#%flag
#% key: p
-#% description: Don't reproject the data, just patch it.
+#% description: Don't reproject the data, just patch it
#%end
+#%flag
+#% key: g
+#% label: Use GET method instead of POST data method
+#% description: This may be needed to connect to servers which lack POST capability
+#% guisection: Request
+#%end
#%option
#% key: output
#% type: string
@@ -317,37 +323,49 @@
listLayers() {
CAPABILITIES_FILE="${TMP}capabilities.xml"
STRING="service=WMS&request=GetCapabilities&${GIS_OPT_WMSQUERY}";
g.message -d message="POST-data: [$STRING]"
### wget or curl the XML and grep the lines with layer names
g.message message="List of layers for server <$GIS_OPT_MAPSERVER>:"
g.message -v message=""
- if [ "$USE_WGET" ] ; then
- wget $GIS_OPT_WGETOPTIONS --post-data="${STRING}" "$GIS_OPT_MAPSERVER" -O "$CAPABILITIES_FILE";
- message 1 "wget $GIS_OPT_WGETOPTIONS --post-data=\"${STRING}\" \"$GIS_OPT_MAPSERVER\" -O \"$CAPABILITIES_FILE\";"
- else
- curl $GIS_OPT_CURLOPTIONS -o "$CAPABILITIES_FILE" -d "${STRING}" "$GIS_OPT_MAPSERVER"
- message 1 "curl $GIS_OPT_CURLOPTIONS -o \"$CAPABILITIES_FILE\" -d \"${STRING}\" \"$GIS_OPT_MAPSERVER\""
- fi
- g.message -v message=""
- if [ ! -e "$CAPABILITIES_FILE" ] ; then
- g.message -e "Downloading XML file"
- \rm "$TMP"
- exit 1
+ if [ "$GIS_FLAG_G" -eq 0 ] ; then
+ if [ "$USE_WGET" ] ; then
+ wget $GIS_OPT_WGETOPTIONS --post-data="${STRING}" \
+ "$GIS_OPT_MAPSERVER" -O "$CAPABILITIES_FILE";
+ message 1 "wget $GIS_OPT_WGETOPTIONS --post-data=\"${STRING}\" \"$GIS_OPT_MAPSERVER\" -O \"$CAPABILITIES_FILE\";"
+ else
+ curl $GIS_OPT_CURLOPTIONS -o "$CAPABILITIES_FILE" \
+ -d "${STRING}" "$GIS_OPT_MAPSERVER"
+ message 1 "curl $GIS_OPT_CURLOPTIONS -o \"$CAPABILITIES_FILE\" -d \"${STRING}\" \"$GIS_OPT_MAPSERVER\""
+ fi
+ g.message -v message=""
+ if [ ! -e "$CAPABILITIES_FILE" ] ; then
+ g.message -e "Downloading XML file"
+ \rm "$TMP"
+ exit 1
+ fi
+ # work-around for brain-dead WMSs which want POST-data as part of the GET URL
+ # (allowed by OGC WMS def S6.3.4)
+ if [ `wc -c < "$CAPABILITIES_FILE"` -eq 0 ] ; then
+ g.message -w "Downloaded XML file was empty -- trying another method"
+ GIS_FLAG_G=1
+ fi
fi
- # work-around for brain-dead WMSs which want POST-data as part of the GET URL (allowed by OGC WMS def S6.3.4)
- if [ `wc -c < "$CAPABILITIES_FILE"` -eq 0 ] ; then
- g.message -w "Downloaded XML file was empty -- trying another method"
+ if [ "$GIS_FLAG_G" -eq 1 ] ; then
- wget $GIS_OPT_WGETOPTIONS "${GIS_OPT_MAPSERVER}${STRING}" -O "$CAPABILITIES_FILE";
+ wget $GIS_OPT_WGETOPTIONS "${GIS_OPT_MAPSERVER}${STRING}" \
+ -O "$CAPABILITIES_FILE";
message 1 "wget $GIS_OPT_WGETOPTIONS \"${GIS_OPT_MAPSERVER}${STRING}\" -O \"$CAPABILITIES_FILE\";"
else
- curl $GIS_OPT_CURLOPTIONS -o "$CAPABILITIES_FILE" "${GIS_OPT_MAPSERVER}${STRING}"
+ "${GIS_OPT_MAPSERVER}${STRING}"
message 1 "curl $GIS_OPT_CURLOPTIONS -o \"$CAPABILITIES_FILE\" \"${GIS_OPT_MAPSERVER}${STRING}\""
fi
@@ -484,6 +502,7 @@
fi
fi
+addflag DOWNLOAD g ${GIS_FLAG_G}
addargument DOWNLOAD requestfile "${REQUESTFILE}"
addargument DOWNLOAD wgetoptions "${GIS_OPT_WGETOPTIONS}"
addargument DOWNLOAD curloptions "${GIS_OPT_CURLOPTIONS}"
Modified: grass/branches/develbranch_6/scripts/r.in.wms/wms.download
--- grass/branches/develbranch_6/scripts/r.in.wms/wms.download 2008-05-13 07:06:24 UTC (rev 31328)
+++ grass/branches/develbranch_6/scripts/r.in.wms/wms.download 2008-05-13 12:03:32 UTC (rev 31329)
@@ -19,6 +19,11 @@
#% description: Downloads data from servers.
#% keywords: wms
#%End
+#%flag
+#% key: g
+#%end
#%option
#% key: requestfile
#% type: string
@@ -56,6 +61,8 @@
fi
+g.message -d "[wms.download]"
@@ -110,13 +117,17 @@
g.message "Downloading tiles"
# init POST-data vs. GET URL method variable
- POST_DATA_OK=1
+ POST_DATA_OK=1
+ else
+ POST_DATA_OK=0
+ fi
CONTENTS=`cat "${REQUESTFILE}"`
NUMBER_OF_TILES=0
for line in $CONTENTS ; do
- g.message -d message="wget command: [$line]"
+ g.message -d message="wget command: [$line]" debug=2
eval "$line"
emptyness=`file "$OUTPUT_FILE" | grep empty$`
@@ -144,7 +155,7 @@
#Get the data from the WMS server
GetData() {
g.message "Downloading data"
- g.message -v message="Requesting Data from ${SERVER}:"
+ g.message -v message="Requesting Data from <${SERVER}:>"
g.message -v message="$STRING"
if [ "$POST_DATA_OK" -eq 1 ] ; then
Modified: grass/branches/develbranch_6/scripts/r.in.wms/wms.request
--- grass/branches/develbranch_6/scripts/r.in.wms/wms.request 2008-05-13 07:06:24 UTC (rev 31328)
+++ grass/branches/develbranch_6/scripts/r.in.wms/wms.request 2008-05-13 12:03:32 UTC (rev 31329)
@@ -130,6 +130,8 @@
fi
+g.message -d "[wms.request]"
SED="sed"
GREP="grep"
# check if we have sed
