[GRASS-SVN] r31339 - grass/trunk/lib/ogsf
    svn_grass at osgeo.org
    Tue May 13 18:02:52 EDT 2008
Author: martinl
Date: 2008-05-13 18:02:52 -0400 (Tue, 13 May 2008)
New Revision: 31339
   grass/trunk/lib/ogsf/gsd_cplane.c
   grass/trunk/lib/ogsf/gsd_fonts.c
   grass/trunk/lib/ogsf/gsd_fringe.c
   grass/trunk/lib/ogsf/gsd_img_mpeg.c
   grass/trunk/lib/ogsf/gsd_img_ppm.c
   grass/trunk/lib/ogsf/gsd_img_tif.c
   grass/trunk/lib/ogsf/gsd_label.c
   grass/trunk/lib/ogsf/gsd_legend.c
   grass/trunk/lib/ogsf/gsdiff.c
ogsf: Initial doxygenization
fprintf -> G_m/w/e
Modified: grass/trunk/lib/ogsf/gsd_cplane.c
--- grass/trunk/lib/ogsf/gsd_cplane.c	2008-05-13 21:57:45 UTC (rev 31338)
+++ grass/trunk/lib/ogsf/gsd_cplane.c	2008-05-13 22:02:52 UTC (rev 31339)
@@ -1,7 +1,7 @@
   \file gsd_cplane.c
-  \brief OGSF library - loading and manipulating surfaces
+  \brief OGSF library - manipulating surfaces (lower level functions)
   GRASS OpenGL gsurf OGSF Library
@@ -13,6 +13,7 @@
   for details.
   \author Bill Brown USACERL, GMSL/University of Illinois (January 1993)
+  \author Doxygenized by Martin Landa <landa.martin gmail.com> (May 2008)
 /* DEBUG */
@@ -47,7 +48,13 @@
     return;
+  \brief Define cplace
+  \param num
+  \param pt
+  \param norm
 void gsd_def_cplane(int num, float *pt, float *norm)
     float sx, sy, sz, ppt[3];
@@ -74,8 +81,11 @@
     return;
-/* called when viewing matrix changes */
+  \brief Update cplaces
+  Called when viewing matrix changes
 void gsd_update_cplanes(void)
     int i;
@@ -89,7 +99,11 @@
     return;
+  \brief ADD
+  \param num
 void gsd_cplane_on(int num)
     static int first = 1;
@@ -107,7 +121,11 @@
     return;
+  \brief ADD
+  \param num
 void gsd_cplane_off(int num)
@@ -117,8 +135,13 @@
     return;
-/* onstate MUST be big enough to hold MAX_CPLANES ints */
+  \brief Get cplane state
+  <i>onstate</i> MUST be big enough to hold MAX_CPLANES ints
+  \param onstate
 void gsd_get_cplanes_state(int *onstate)
     int i;
@@ -130,9 +153,15 @@
     return;
-/* planes MUST be big enough to hold MAX_CPLANES Point4s */
-/* returns surface coordinates, normal pointing away from visible side */
+  \brief Get cplaces
+  Planes MUST be big enough to hold MAX_CPLANES Point4s
+  \param places surface coordinates, normal pointing away from visible side
+  \return ADD
 int gsd_get_cplanes(Point4 * planes)
     int i, ons;
@@ -154,7 +183,11 @@
     return (ons);
+  \brief ADD
+  \param num
 void gsd_update_cpnorm(int num)
     float v[1][4];
@@ -172,7 +205,12 @@
     return;
+  \brief ADD
+  \param num
+  \param rx,ry,rz
 void gsd_cplane_setrot(int num, float rx, float ry, float rz)
     Cp_rot[num][X] = rx;
@@ -185,7 +223,12 @@
     return;
+  \brief ADD
+  \param num
+  \param tx,ty,tz
 void gsd_cplane_settrans(int num, float tx, float ty, float tz)
     Cp_trans[num][X] = tx;
@@ -197,7 +240,13 @@
     return;
+  \brief ADD
+  \param surf1 first surface (geosurf)
+  \param surf2 second surface (geosurf) [unused]
+  \param cpnum
 void gsd_draw_cplane_fence(geosurf * surf1, geosurf * surf2, int cpnum)
     int was_on;
@@ -242,7 +291,11 @@
     return;
+  \brief Draw cplane
+  \param num
 void gsd_draw_cplane(int num)
     float size, cpv[3];
Modified: grass/trunk/lib/ogsf/gsd_fonts.c
--- grass/trunk/lib/ogsf/gsd_fonts.c	2008-05-13 21:57:45 UTC (rev 31338)
+++ grass/trunk/lib/ogsf/gsd_fonts.c	2008-05-13 22:02:52 UTC (rev 31339)
@@ -15,17 +15,24 @@
   for details.
 #include <string.h>
 #include <assert.h>
 #include <grass/gstypes.h>
 #include <grass/ogsf_proto.h>
 #include "rgbpack.h"
+  \brief Get text width
+  \param s text string
+  \param size size
+  \return text width
 int gsd_get_txtwidth(char *s, int size)
     int width, len;
@@ -36,8 +43,13 @@
     return (width);
+  \brief Get text  height
+  \param size size
+  \return text height
 int gsd_get_txtheight(int size)
     unsigned long height;
@@ -48,30 +60,41 @@
+  \brief Get text descender
+  yorig ??
+  Is this defined somewhere ?
+  \return 2
 int get_txtdescender()
-/* yorig ??
- * Is this defined somewhere ?
     return (2);
+  \brief Get text offset
+  xorig ??
+  \return 0
 int get_txtxoffset()
-/* xorig ??
     return (0);
+  \brief Display label
+  \param fontbase font-base
+  \param lab_pos label position
+  \param txt text string
 void do_label_display(GLuint fontbase, float *lab_pos, char *txt)
     glRasterPos2f(lab_pos[X], lab_pos[Y]);
Modified: grass/trunk/lib/ogsf/gsd_fringe.c
--- grass/trunk/lib/ogsf/gsd_fringe.c	2008-05-13 21:57:45 UTC (rev 31338)
+++ grass/trunk/lib/ogsf/gsd_fringe.c	2008-05-13 22:02:52 UTC (rev 31339)
@@ -1,7 +1,7 @@
   \file gsd_fonts.c
+  \brief OGSF library - manipulating surfaces/fridge (lower level function)
@@ -15,6 +15,7 @@
   for details.
 #include <stdio.h>
@@ -23,11 +24,12 @@
 #include "gsget.h"
 #include "rowcol.h"
 #define FRINGE_FORE 0x000000
 #define FRINGE_WIDTH 2
-/* Normals */
+  \brief Normals
 float Nnorth[] = { 0.0, 0.8, 0.6 };
 float Nsouth[] = { 0.0, -0.8, 0.6 };
 float Neast[] = { 0.8, 0.0, 0.6 };
@@ -35,17 +37,20 @@
 float Ntop[] = { 0.0, 0.0, 1.0 };
 float Nbottom[] = { 0.0, 0.0, -1.0 };
-void
-gsd_display_fringe (geosurf * surf, unsigned long clr, float elev, int where[4])
+  \brief Display fridge
-    /* TODO -- add elevation for bottom
-     *      -- add color option
-     *      -- add ruler grid lines
+  \todo add elevation for bottom
+  add color option
+  add ruler grid lines
+  \param surf surface (geosurf)
+  \param clr
+  \param elev
+  \param where
+void gsd_display_fringe (geosurf * surf, unsigned long clr, float elev, int where[4])
     float bot, xres, yres;   /* world size of view cell */
     int ycnt, xcnt;    /* number of view cells across */
     float xmax, ymax;
@@ -58,10 +63,10 @@
     xmax = surf->xmax;
     ymax = surf->ymax;
-   bot = surf->zmin - ((surf->zrange/4.) * surf->z_exag);
+       bot = surf->zmin - ((surf->zrange/4.) * surf->z_exag);
     bot = elev - ((surf->zrange/4.) * surf->z_exag);
@@ -125,11 +130,16 @@
     return;
+  \brief ADD
-void
-gsd_fringe_horiz_poly (float bot, geosurf * surf, int row, int side)
+  \param bot
+  \param row
+  \param side
+void gsd_fringe_horiz_poly (float bot, geosurf * surf, int row, int side)
     int col;
     int cnt;
     float pt[4];
@@ -148,7 +158,7 @@
     gsd_bgnpolygon();
     col = 0;
-/* floor left */
+    /* floor left */
     pt[X] = col * (surf->x_mod *  surf->xres) ;
     pt[Y] = ((surf->rows - 1) * surf->yres) - ((row+side)*(surf->y_mod*surf->yres));
     pt[Z] = bot;
@@ -187,9 +197,15 @@
     return;
+  \brief ADD
-void
-gsd_fringe_horiz_line (float bot, geosurf * surf, int row, int side)
+  \param bot
+  \param row
+  \param side
+void gsd_fringe_horiz_line (float bot, geosurf * surf, int row, int side)
     int col;
     int cnt;
@@ -210,13 +226,12 @@
     gsd_bgnline();
     col = 0;
-/* floor left */
+    /* floor left */
     pt[Z] = bot;
     gsd_vert_func(pt);
     offset = (row*surf->y_mod*surf->cols) + (col*surf->x_mod) ;
     GET_MAPATT(buff, offset, pt[Z]);
     pt[Z] = pt[Z] * surf->z_exag;
@@ -234,7 +249,7 @@
 	gsd_vert_func(pt);
 	cnt++;
     col--;
@@ -256,9 +271,15 @@
     return;
+  \brief ADD
-void
-gsd_fringe_vert_poly (float bot, geosurf * surf, int col, int side)
+  \param bot
+  \param col
+  \param side [unused]
+void gsd_fringe_vert_poly (float bot, geosurf * surf, int col, int side)
     int row;
@@ -318,9 +339,15 @@
     return;
-void
-gsd_fringe_vert_line (float bot, geosurf * surf, int col, int side)
+  \brief ADD
+  \param bot
+  \param col
+void gsd_fringe_vert_line (float bot, geosurf * surf, int col, int side)
     int row;
     int cnt;
@@ -385,8 +412,15 @@
     return;
-void
-gsd_fringe_horiz_line2 (float bot, geosurf * surf, int row, int side)
+  \brief ADD
+  \param bot
+  \param row
+  \param side
+void gsd_fringe_horiz_line2 (float bot, geosurf * surf, int row, int side)
     int col;
     int cnt;
@@ -400,7 +434,6 @@
     gsd_do_scale(1);
     gsd_translate(surf->x_trans, surf->y_trans, surf->z_trans);
     buff = gs_get_att_typbuff(surf, ATT_TOPO, 0);
     xcnt = VCOLS(surf);
     gsd_bgnline();
@@ -444,5 +477,3 @@
     return;
Modified: grass/trunk/lib/ogsf/gsd_img_mpeg.c
--- grass/trunk/lib/ogsf/gsd_img_mpeg.c	2008-05-13 21:57:45 UTC (rev 31338)
+++ grass/trunk/lib/ogsf/gsd_img_mpeg.c	2008-05-13 22:02:52 UTC (rev 31339)
@@ -13,12 +13,15 @@
   for details.
 #include <stdlib.h>
 #include <stdio.h>
 #include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
@@ -43,8 +46,16 @@
 AVFormatContext *oc;
 AVStream *video_st;
+  \brief Add a video output stream
-/* add a video output stream */
+  \param oc
+  \param codec_id
+  \param w
+  \param h
+  \return
 static AVStream *add_video_stream(AVFormatContext *oc, int codec_id, int w, int h)
     AVCodecContext *c;
@@ -52,7 +63,7 @@
     st = av_new_stream(oc, 0);
     if (!st) {
-        fprintf(stderr, "Could not alloc stream\n");
+	G_warning (_("Unable to allocate stream"));
 	return NULL;
@@ -86,13 +97,23 @@
     /* some formats want stream headers to be separate */
     if(!strcmp(oc->oformat->name, "mp4") || !strcmp(oc->oformat->name, "mov") || !strcmp(oc->oformat->name, "3gp"))
         c->flags |= CODEC_FLAG_GLOBAL_HEADER;
     c->flags |= CODEC_FLAG_QSCALE;
     c->global_quality = st->quality = FF_QP2LAMBDA * 10;
     return st;
+  \brief Allocate picture
+  \param pix_fmt
+  \param width picture width
+  \param height picture height
+  \return pointer to AVFrame struct
+  \return NULL on failure
 static AVFrame *alloc_picture(int pix_fmt, int width, int height)
     AVFrame *picture;
@@ -100,19 +121,30 @@
     int size;
     picture = avcodec_alloc_frame();
     if (!picture)
         return NULL;
     size = avpicture_get_size(pix_fmt, width, height);
     picture_buf = av_malloc(size);
     if (!picture_buf) {
         av_free(picture);
         return NULL;
     avpicture_fill((AVPicture *)picture, picture_buf,
     return picture;
+  \brief Open video
+  \param oc
+  \param st
 static void open_video(AVFormatContext *oc, AVStream *st)
     AVCodec *codec;
@@ -123,13 +155,13 @@
     /* find the video encoder */
     codec = avcodec_find_encoder(c->codec_id);
     if (!codec) {
-        fprintf(stderr, "video codec not found\n");
+        G_warning (_("Video codec not found"));
         return;
     /* open the codec */
     if (avcodec_open(c, codec) < 0) {
-        fprintf(stderr, "could not open codec\n");
+        G_warning (_("Unable to open codec"));
         return;
@@ -148,7 +180,7 @@
     /* allocate the encoded raw picture */
     picture = alloc_picture(c->pix_fmt, c->width, c->height);
     if (!picture) {
-        fprintf(stderr, "Could not allocate picture\n");
+        G_warning (_("Unable to allocate picture"));
         return;
@@ -159,12 +191,18 @@
     if (c->pix_fmt != PIX_FMT_YUV420P) {
         tmp_picture = alloc_picture(PIX_FMT_YUV420P, c->width, c->height);
         if (!tmp_picture) {
-            fprintf(stderr, "Could not allocate temporary picture\n");
+            G_warning (_("Unable to allocate temporary picture"));
             return;
+  \brief Write video frame
+  \param oc
+  \param st
 static void write_video_frame(AVFormatContext *oc, AVStream *st)
     int out_size, ret;
@@ -207,12 +245,18 @@
     if (ret != 0) {
-        fprintf(stderr, "Error while writing video frame\n");
+        G_warning (_("Error while writing video frame"));
         return;
     frame_count++;
+  \brief Close video
+  \param oc [unused]
+  \param st
 static void close_video(AVFormatContext *oc, AVStream *st)
     avcodec_close(st->codec);
@@ -227,10 +271,14 @@
 #endif
- * initialize FAME setup mpeg defaults and
- * open file for writing
+ \brief Initialize FAME setup mpeg defaults and open file for writing
+ \param filename file name
+ \return -1 on failure
+ \return 0 on success
 int gsd_init_mpeg(char *filename)
 #ifdef HAVE_FFMPEG
@@ -243,7 +291,8 @@
         b = tmp[1];
         t = tmp[1] + tmp[3] - 1;
-	fprintf(stderr, "Opening MPEG stream <%s> ...\n", filename);
+	G_verbose_message (_("Opening MPEG stream <%s>..."),
+			   filename);
 	/* initialize libavcodec, and register all codecs and formats */
     	av_register_all();
@@ -251,18 +300,18 @@
 	/* auto detect the output format from the name. default is mpeg. */
     fmt = guess_format(NULL, filename, NULL);
     if (!fmt) {
-        printf("Could not deduce output format from file extension: using MPEG.\n");
+        G_warning (_("Unable to deduce output format from file extension: using MPEG"));
         fmt = guess_format("mpeg", NULL, NULL);
     if (!fmt) {
-        fprintf(stderr, "Could not find suitable output format\n");
+        G_warning (_("Unable to find suitable output format"));
         return (-1);
     /* allocate the output media context */
     oc = av_alloc_format_context();
     if (!oc) {
-        fprintf(stderr, "Memory error\n");
+        G_warning (_("Out of memory"));
         return(-1);
     oc->oformat = fmt;
@@ -273,7 +322,7 @@
 #ifdef USE_XVID
     fmt->video_codec = CODEC_ID_XVID;
 #endif
     video_st = NULL;
     if (fmt->video_codec != CODEC_ID_NONE) {
         video_st = add_video_stream(oc, fmt->video_codec, (r - l + 1), (t - b + 1) );
@@ -281,7 +330,7 @@
     /* set the output parameters (must be done even if no parameters). */
     if (av_set_parameters(oc, NULL) < 0) {
-        fprintf(stderr, "Invalid output format parameters\n");
+        G_warning (_("Invalid output format parameters"));
         return (-1);
@@ -295,7 +344,8 @@
         /* open the output file, if needed */
     if (!(fmt->flags & AVFMT_NOFILE)) {
         if (url_fopen(&oc->pb, filename, URL_WRONLY) < 0) {
-            fprintf(stderr, "Could not open '%s'\n", filename);
+            G_warning (_("Unable to open <%s>"),
+			 filename);
             return (-1);
@@ -305,34 +355,35 @@
 #else
-	fprintf(stderr, "NVIZ has not been built with MPEG output support\n");
-	return(-1);
+    G_warning (_("NVIZ has not been built with MPEG output support"));
+    return(-1);
 #endif
+    return (0);
-        return (0);
+  \brief Get RGB pixbuf and convert to YUV 4:2:0
+  Image and write to mpeg stream
- * get RGB pixbuf and convert to YUV 4:2:0
- * image and write to mpeg stream
+  \return 0
 int gsd_write_mpegframe(void)
 #ifdef HAVE_FFMPEG
-        unsigned int xsize, ysize;
-        int x, y, xy, xy_uv;
-        int yy, uu, vv;
-        unsigned char *pixbuf;
-        gsd_getimage(&pixbuf, &xsize, &ysize);
-        xy = xy_uv = 0;
-        for (y = ysize - 1; y >= 0; y--) {
-          for (x = 0; x < xsize; x++) {
+    unsigned int xsize, ysize;
+    int x, y, xy, xy_uv;
+    int yy, uu, vv;
+    unsigned char *pixbuf;
+    gsd_getimage(&pixbuf, &xsize, &ysize);
+    xy = xy_uv = 0;
+    for (y = ysize - 1; y >= 0; y--) {
+	for (x = 0; x < xsize; x++) {
 	    unsigned char r = pixbuf[(y * xsize + x) * 4 + 0];
 	    unsigned char g = pixbuf[(y * xsize + x) * 4 + 1];
 	    unsigned char b = pixbuf[(y * xsize + x) * 4 + 2];
             yy = (0.257 * r) + (0.504 * g) + (0.098 * b) + 16;;
             vv = (0.439 * r) - (0.368 * g) - (0.071 * b) + 128;
             uu = -(0.148 * r) - (0.291 * g) + (0.439 * b) + 128;
@@ -341,57 +392,58 @@
             if( (x % 2) && (y % 2) )
-                    picture->data[1][xy_uv] = uu;
-                    picture->data[2][xy_uv] = vv;
-                    xy_uv++;
+		picture->data[1][xy_uv] = uu;
+		picture->data[2][xy_uv] = vv;
+		xy_uv++;
             xy++;
-        free(pixbuf);
-	write_video_frame(oc, video_st);
+    G_free(pixbuf);
+    write_video_frame(oc, video_st);
 #endif
+    return (0);
-        return (0);
+ \brief Close the mpeg, free buffer, and close file
- * close the mpeg, free buffer, and close file
+ \return 0
 int gsd_close_mpeg(void)
 #ifdef HAVE_FFMPEG
-int i;
-	close_video(oc, video_st);
-	/* write the trailer, if any */
-    	av_write_trailer(oc);
-	/* free the streams */
-    	for(i = 0; i < oc->nb_streams; i++) {
-        	av_freep(&oc->streams[i]->codec);
-        	av_freep(&oc->streams[i]);
+    int i;
+    close_video(oc, video_st);
+    /* write the trailer, if any */
+    av_write_trailer(oc);
+    /* free the streams */
+    for(i = 0; i < oc->nb_streams; i++) {
+	av_freep(&oc->streams[i]->codec);
+	av_freep(&oc->streams[i]);
         /* close the output file */
         url_fclose(&oc->pb);
     /* free the stream */
     av_free(oc);
-	fprintf(stderr, "Closed MPEG stream.\n");
+    G_debug (3, "Closed MPEG stream");
 #endif
-        return (0);
+    return (0);
Modified: grass/trunk/lib/ogsf/gsd_img_ppm.c
--- grass/trunk/lib/ogsf/gsd_img_ppm.c	2008-05-13 21:57:45 UTC (rev 31338)
+++ grass/trunk/lib/ogsf/gsd_img_ppm.c	2008-05-13 22:02:52 UTC (rev 31339)
@@ -18,20 +18,32 @@
   for details.
-  Markus Neteler
-  Bob Covill
-  Jaro Hofierka
+  \author Markus Neteler
+  \author Bob Covill
+  \author Jaro Hofierka
 #include <stdlib.h>
 #include <stdio.h>
+  \brief Write ppm file
+  \param name file name
+  \return 1 on failure
 int GS_write_ppm(char *name)
-    int y, x;
+    unsigned int x;
+    int y;
     FILE *fp;
@@ -40,7 +52,8 @@
     if (NULL == (fp = fopen(name, "w"))) {
-	fprintf(stderr, "Cannot open file for output.\n");
+	G_warning (_("Unable to open file <%s> for writing"),
+		   name);
 	return(1);
@@ -58,22 +71,33 @@
-    free(pixbuf);
+    G_free(pixbuf);
     fclose(fp);
     return (0);
+  \brief Write zoom to file
+  \param xsize,ysize
 int GS_write_zoom(char *name, unsigned int xsize, unsigned int ysize)
-    int y, x;
+    unsigned int x;
+    int y;
     FILE *fp;
     gsd_writeView(&pixbuf, xsize, ysize);
+		   name);
 	return(1);
@@ -96,4 +120,3 @@
     return (0);
Modified: grass/trunk/lib/ogsf/gsd_img_tif.c
--- grass/trunk/lib/ogsf/gsd_img_tif.c	2008-05-13 21:57:45 UTC (rev 31338)
+++ grass/trunk/lib/ogsf/gsd_img_tif.c	2008-05-13 22:02:52 UTC (rev 31339)
@@ -18,8 +18,9 @@
   for details.
-  Markus Neteler
-  Jaro Hofierka
 #include <grass/config.h>
@@ -29,9 +30,11 @@
 #include <stdlib.h>
 #include <stdio.h>
 #include <sys/types.h>
 #include "tiffio.h"
 unsigned short config = PLANARCONFIG_CONTIG;
Modified: grass/trunk/lib/ogsf/gsd_label.c
--- grass/trunk/lib/ogsf/gsd_label.c	2008-05-13 21:57:45 UTC (rev 31338)
+++ grass/trunk/lib/ogsf/gsd_label.c	2008-05-13 22:02:52 UTC (rev 31339)
@@ -1,7 +1,7 @@
   \file gsd_label.c
-  \brief OGSF library - label management
+  \brief OGSF library - label management (lower level functions)
@@ -13,19 +13,32 @@
   for details.
   \author Bill Brown USACERL (1991-1992)
 #define MAX_LIST 20
 static int first = 0;
 GLuint label_base;
 GLuint label_id;
-void
-gs_put_label(char *text, GLuint fontbase, int size, unsigned long color,
-	     int*pt)
+  \brief Put label
+  \todo Allocate label dynamicaly
+  \param fontbase fontbase settings
+  \param size font size
+  \param color font color
+  \param pt
+void gs_put_label(char *text, GLuint fontbase, int size, unsigned long color,
+		  int*pt)
     int txt_width;
     GLint tmp[4];
@@ -41,17 +54,17 @@
     if (label_id > (label_base + MAX_LIST)) {
-	fprintf(stderr, "Max. number of labels reached!\n");
+	G_warning (_("Max. number of labels reached!"));
 	return;
     glNewList(label_id, GL_COMPILE_AND_EXECUTE);
     txt_width = gsd_get_txtwidth(text, size);
 /* adjust to center text string */
     labpt[X] = (float) (pt[X] - txt_width / 2.);
     labpt[Y] = (float) pt[Y];
     glGetIntegerv(GL_VIEWPORT, tmp);
     l = tmp[0];
     r = tmp[0] + tmp[2];
@@ -77,37 +90,34 @@
- * Remove current label
+  \brief Remove current label
 void gsd_remove_curr(void)
     if (label_id) {
 	glDeleteLists(label_id - 1, 1);
 	label_id--;
     return;
- * Remove all labels from display list
+  \brief Remove all labels from display list
 void gsd_remove_all(void)
     glDeleteLists(label_base, MAX_LIST);
     label_id = label_base;
     return;
- * Call display list and draw defined labels -- called from gsd_prim (gsd_call_lists)
+  \brief Call display list and draw defined labels -- called from gsd_prim (gsd_call_lists)
 void gsd_call_label(void)
     int i;
Modified: grass/trunk/lib/ogsf/gsd_legend.c
--- grass/trunk/lib/ogsf/gsd_legend.c	2008-05-13 21:57:45 UTC (rev 31338)
+++ grass/trunk/lib/ogsf/gsd_legend.c	2008-05-13 22:02:52 UTC (rev 31339)
@@ -16,6 +16,7 @@
   for details.
 #include <stdlib.h>
@@ -49,7 +50,14 @@
 #define MAX_LEGEND 256
+  \brief ADD
+  \param wl
+  \param wb
+  \param wr
+  \param wt
 void gsd_bgn_legend_viewport(GLint wl, GLint wb, GLint wr, GLint wt)
 /* sets the viewport for the legend and the model matrix */
@@ -77,11 +85,12 @@
     return;
+  \brief ADD
 void gsd_end_legend_viewport(void)
-/* closes the legend viewport and resets matrix and buffers */
+    /* closes the legend viewport and resets matrix and buffers */
     gsd_popmatrix();
     glMatrixMode(GL_PROJECTION);
@@ -97,15 +106,24 @@
     return;
+  \brief ADD
+  \param lownum
+  \param highnum
+  \param numvals
+  \param vals
+  \return 0 on failure
+  \return range value
 int gsd_get_nice_range(float lownum, float highnum, int numvals, float *vals)
 /* get a nice range for displaying legend */
     int num = 0;
     float curnum, step, start;
     if (!numvals)
 	return (0);
@@ -116,7 +134,7 @@
     start = step * (int) (1 + lownum / step);
     if (start - lownum < .65 * step)
 	start += step;
     for (curnum = start; curnum < (highnum - .65 * step); curnum += step) {
 	vals[num++] = curnum;
@@ -125,8 +143,14 @@
+  \brief ADD
+  \param num
+  \return 0 on error
+  \return 1 on success
 int gsd_make_nice_number(float *num)
     float newnum, nextnum;
@@ -163,11 +187,20 @@
     return (1);
+  \brief Put legend
-GLuint
-gsd_put_legend(char *name, GLuint fontbase, int size, int *flags,
-	       float *rangef, int *pt)
+  \param name
+  \param size
+  \param flags
+  \param rangef
+  \param pt
+  \return
+GLuint gsd_put_legend(char *name, GLuint fontbase, int size, int *flags,
+		      float *rangef, int *pt)
     GLint sl, sr, sb, st;
     GLuint legend_list;
@@ -211,13 +244,15 @@
     is_fp = G_raster_map_is_fp(name, mapset);
     if (G_read_colors(name, mapset, &colors) == -1) {
-	fprintf(stderr, "Color file for [%s] not available\n", name);
+	G_warning (_("Unable to read color file of raster map <%s>"),
+		   name);
 	return (-1);
     if (cat_labs)
 	if (G_read_cats(name, mapset, &cats) == -1) {
-	    fprintf(stderr, "Category file for [%s] not available\n", name);
+	    G_warning (_("Unable to read category file of raster map <%s>"),
+		       name);
 	    cat_labs = 0;
@@ -233,7 +268,8 @@
     else {
 	if (is_fp) {
 	    if (G_read_fp_range(name, mapset, &fp_range) != 1) {
-		fprintf(stderr, "Range info for [%s] not available\n", name);
+		G_warning (_("Unable to read fp range of raster map <%s>"),
+			   name);
 		return(-1);
 	    G_get_fp_range_min_max(&fp_range, &fmin, &fmax);
@@ -244,7 +280,8 @@
 	else {
 	    if (G_read_range(name, mapset, &range) == -1) {
+		G_warning (_("Unable to read range of raster map <%s>"),
+			   name);
 		return (-1);
 	    G_get_range_min_max(&range, &min, &max);
@@ -306,18 +343,21 @@
 /* how many labels? */
-numlabs can't be = max - min + 1 any more because of floating point
-maybe shouldn't allow discrete legend for floating point maps (unless list)
-or else check number of different values in floating point map
-and use each if "reasonable"
-gs_get_values_in_range(gs, att, low, high, values, &nvals)
-the nvals sent has a max number to return, nvals returned is the actual
-number set in values, return val is 1 on success, -1 if > max vals found
+  numlabs can't be = max - min + 1 any more because of floating point
+  maybe shouldn't allow discrete legend for floating point maps (unless list)
+  or else check number of different values in floating point map
+  and use each if "reasonable"
+  gs_get_values_in_range(gs, att, low, high, values, &nvals)
+  the nvals sent has a max number to return, nvals returned is the actual
+  number set in values, return val is 1 on success, -1 if > max vals found
+  might need to think about doing histograms first & use same routines here
+  could also have a LT_MOST that would limit # to some N most frequent
-might need to think about doing histograms first & use same routines here
-could also have a LT_MOST that would limit # to some N most frequent
 	int i, k, lleg, horiz;
 	int red, green, blue;
@@ -344,12 +384,11 @@
 	    /* watch out for trying to display mega cats */
 	    if (is_fp && !Listnum) {
 		discrete = 0;	/* maybe later do stats & allow if few #s */
-		fprintf(stderr,
-			"Unable to show discrete FP range (use list)\n");
+		G_warning (_("Unable to show discrete FP range (use list"));
 		return (-1);
 	    if (numlabs < MAX_LEGEND)
-		dividers = (float *) malloc(numlabs * sizeof(float));
+		dividers = (float *) G_malloc(numlabs * sizeof(float));
 	else {
 	    numlabs = gsd_get_nice_range(fmin, fmax, 4, labvals + 1);
@@ -461,9 +500,9 @@
 	if (discrete) {
 	    if (numlabs > lleg / 5)
-		G_warning("Too many categories to show as discrete!");
+		G_warning(_("Too many categories to show as discrete!"));
 	    else if (numlabs > 1.2 * lleg / gsd_get_txtheight(size))
-		G_warning("Try using smaller font!");
+		G_warning(_("Try using smaller font!"));
 	incr = do_invert ? -1 : 1;
@@ -647,22 +686,22 @@
 	if (discrete)
-	    free(dividers);
+	    G_free(dividers);
     if (cat_labs)
 	G_free_cats(&cats);
     G_free_colors(&colors);
     gsd_end_legend_viewport();
-    gsd_unset_font(fontbase);
+  gsd_unset_font(fontbase);
     gsd_endlist();
     return (legend_list);
Modified: grass/trunk/lib/ogsf/gsdiff.c
--- grass/trunk/lib/ogsf/gsdiff.c	2008-05-13 21:57:45 UTC (rev 31338)
+++ grass/trunk/lib/ogsf/gsdiff.c	2008-05-13 22:02:52 UTC (rev 31339)
@@ -1,7 +1,7 @@
   \file gsdiff.c
@@ -24,6 +24,7 @@
   for details.
   \author Bill Brown USACERL, GMSL/University of Illinois (November 1994)
 #include <stdio.h>
@@ -35,7 +36,11 @@
 static typbuff *Refbuff = NULL;
 static float Refscale = 1.0;
+  \brief Set scale
+  \param scale value
 void gsdiff_set_SDscale(float scale)
     Refscale = scale;
@@ -43,13 +48,21 @@
     return;
+  \brief Get scale
+  \return scale value
 float gsdiff_get_SDscale(void)
     return (Refscale);
+  \brief ADD
+  \param gsref
 void gsdiff_set_SDref(geosurf * gsref)
     Refsurf = gsref;
@@ -58,7 +71,11 @@
     return;
+  \brief ADD
+  \return pointer to geosurf struct
 geosurf *gsdiff_get_SDref(void)
     if (Refsurf && Refbuff) {
@@ -68,7 +85,14 @@
     return (NULL);
+  \brief ADD
+  \param val
+  \param offset
+  \return value
 float gsdiff_do_SD(float val, int offset)
     float ref;
