[GRASS-SVN] r31347 - grass-addons/raster/r.inund.fluv
svn_grass at osgeo.org
Wed May 14 15:29:17 EDT 2008
Author: robertomarzocchi
Date: 2008-05-14 15:29:17 -0400 (Wed, 14 May 2008)
New Revision: 31347
grass-addons/raster/r.inund.fluv/Makefile
grass-addons/raster/r.inund.fluv/README.txt
Modified: grass-addons/raster/r.inund.fluv/Makefile
--- grass-addons/raster/r.inund.fluv/Makefile 2008-05-14 16:09:44 UTC (rev 31346)
+++ grass-addons/raster/r.inund.fluv/Makefile 2008-05-14 19:29:17 UTC (rev 31347)
@@ -1,31 +1,32 @@
-MODULE_TOPDIR = /usr/local/grass-6.3.0RC4
+MODULE_TOPDIR = ../..
PGM = r.inund.fluv
include $(MODULE_TOPDIR)/include/Make/Script.make
include $(MODULE_TOPDIR)/include/Make/Module.make
-default: $(ETC)/fortran_code/fortran_code/$(PGM) html
+default: DIR $(ETC)/fortran_code/$(PGM) html
DIR:
- mkdir -p $(ETC)/fortran_code/fortran_code/
+ mkdir -p $(ETC)/fortran_code/
-$(ETC)/fortran_code/fortran_code/$(PGM): $(OBJ)
+$(ETC)/fortran_code/$(PGM): $(OBJ)
gfortran -O1 -o find_main_channel find_main_channel.f90
gfortran -O1 -o clean_inundation clean_inundation.f90
gfortran -O1 -o 2d_path 2d_path.f90
gfortran -O1 -o correction_from_path correction_from_path.f90
- $(INSTALL) find_main_channel$(EXE) $(ETC)/fortran_code/fortran_code
- $(INSTALL) clean_inundation$(EXE) $(ETC)/fortran_code/fortran_code
- $(INSTALL) 2d_path$(EXE) $(ETC)/fortran_code/fortran_code
- $(INSTALL) correction_from_path$(EXE) $(ETC)/fortran_code/fortran_code
- $(INSTALL) dati.mod $(ETC)/fortran_code/fortran_code
- $(INSTALL) dd.mod $(ETC)/fortran_code/fortran_code
+ $(INSTALL) find_main_channel$(EXE) $(ETC)/fortran_code/
+ $(INSTALL) clean_inundation$(EXE) $(ETC)/fortran_code/
+ $(INSTALL) 2d_path$(EXE) $(ETC)/fortran_code/
+ $(INSTALL) correction_from_path$(EXE) $(ETC)/fortran_code/
+ $(INSTALL) dati.mod $(ETC)/fortran_code/
+ $(INSTALL) dd.mod $(ETC)/fortran_code/
$(INSTALL) $(PGM) $(GISBASE)/scripts/
html:
$(MKDIR) $(GISBASE)/docs/html
- $(INSTALL_DATA) $(PGM).html $(MODULE_TOPDIR)/docs/html/
+ $(INSTALL_DATA) $(PGM).html $(GISBASE)/docs/html/
clean:
- -rm -f find_main_channel$(EXE) clean_inundation$(EXE) 2d_path$(EXE) correction_from_path$(EXE) dati.mod dd.mod
\ No newline at end of file
+ -rm -f find_main_channel$(EXE) clean_inundation$(EXE) 2d_path$(EXE) correction_from_path$(EXE) dati.mod dd.mod
Modified: grass-addons/raster/r.inund.fluv/README.txt
--- grass-addons/raster/r.inund.fluv/README.txt 2008-05-14 16:09:44 UTC (rev 31346)
+++ grass-addons/raster/r.inund.fluv/README.txt 2008-05-14 19:29:17 UTC (rev 31347)
@@ -9,35 +9,18 @@
***************************REQUEST ********************************
The installation of this code requests a fortran compiler installed on your computer.
-The installation script (install.sh) is written for gnu fortran compiler with optimization.
-(http://www.gnu.org/software/gcc/fortran/)
-If you have an other compiler you may change the install script (install.sh)
-e.g.
-gfortran -O1 -o ***.exe ***.f90
-where
-*) `gfortran´ is the name of your compiler
-*) `-O1´ is the optimization option
-*) `-o ***.exe´ is the name of output executable (DO NOT CHANGE!)
-*) `***.f90´ is the name of code (DO NOT CHANGE!)
For any other informations contact the autors of the script
(see description.html)
-Now we're adjusting the Makefile and a simple installation is wi
**************** Users of GRASS 6.3 ******************************
-1)
+1) open the Makefile with a text editor
+2) change the relative path MODULE_TOPDIR = ../.. with the GISBASE directory
+3) make
+4) go in the source grass directory
+5) make install
-**************** Users of GRASS 6.2 ******************************
-1) Change the name of the script for GRASS 6.3.x releases
-mv r.inund.fluv r.inund.fluv_63
-2) Change the name of script for grass 6.2.x releases
-mv r.inund.fluv_62 r.inund.fluv
-3)
+**************** Users of GRASS 6.3 ******************************
+Rename the grass scripts:
+ r.inund.fluv --> r.inund.fluv_63
+ r.inund.fluv_62 --> r.inund.fluv
