[GRASS-SVN] r31373 - grass/branches/develbranch_6/raster/r.in.ascii
svn_grass at osgeo.org
Fri May 16 13:53:06 EDT 2008
Author: epatton
Date: 2008-05-16 13:53:06 -0400 (Fri, 16 May 2008)
New Revision: 31373
grass/branches/develbranch_6/raster/r.in.ascii/description.html
Backported html updates from TRUNK: r31372
Modified: grass/branches/develbranch_6/raster/r.in.ascii/description.html
--- grass/branches/develbranch_6/raster/r.in.ascii/description.html 2008-05-16 17:52:13 UTC (rev 31372)
+++ grass/branches/develbranch_6/raster/r.in.ascii/description.html 2008-05-16 17:53:06 UTC (rev 31373)
@@ -1,14 +1,15 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-<EM>r.in.ascii</EM> allows a user to create a (binary) GRASS raster map
+<em>r.in.ascii</em> allows a user to create a (binary) GRASS raster map
layer from an ASCII raster input file with (optional) TITLE.
-<P>
-The GRASS ASCII <B>input</B> file has a header section which describes
+<p>
+The GRASS ASCII <b>input</b> file has a header section which describes
the location and size of the data, followed by the data itself.
-<P>
+<p>
The header has 6 lines:
<div class="code"><pre>
@@ -24,8 +25,10 @@
are the coordinates of the edges of the geographic region.
The rows and cols field values entered describe the dimensions
of the matrix of data to follow.
-The data which follows is <EM>r</EM> rows of <EM>c</EM> integers.
+The data which follows is <em>r</em> rows of <em>c</em> integers.
<p>
Optionally the following parameters can be defined in the header section:
@@ -35,15 +38,48 @@
</pre></div>
<p>
"null" defines a string or number to be converted to NULL value (no
data).<br>
"type" defines the data type (int, float double) and is not required.<br>
"multiplier" is an optional parameter to multiply each cell value.
-<H2>EXAMPLE</H2>
+<h2>NOTES</h2>
-The following is a sample <b>input</b> file to <EM>r.in.ascii</EM>:
+The geographic coordinates north, south, east, and west
+describe the outer edges of the geographic region. They
+run along the edges of the cells at the edge of the
+geographic region and <em>not</em> through the center of the cells
+at the edges.
+The NW value occurs at the beginning of the first line of data, and the
+SW value occurs at the beginning of the last line of data.
+<p>
+The data (which follows the header section) must contain
+<tt>r</tt> <em>x</em> <tt>c</tt> values, but it is not necessary
+that all the data for a row be on one line. A row may be
+split over many lines.
+<p>
+<em>r.in.ascii</em> may import <i>integer</i>, <i>floating point</i>, or <i>double</i> cell
+types using the <b>-i</b>, <b>-f</b>, and <b>-d</b> flags, respectively.
+<p>
+The header information in ESRI Raster ASCII files differs from GRASS.
+To convert an Arc/Info (ArcView) ASCII grid file into GRASS, see
+<em><a href="r.in.arc.html">r.in.arc</a></em>.
+<p>
+SURFER (Golden Software) ASCII files may be imported by passing the <b>-s</b> flag.
+<h2>EXAMPLE</h2>
+The following is a sample <b>input</b> file to <em>r.in.ascii</em>:
north: 4299000.00
south: 4247000.00
@@ -65,46 +101,20 @@
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
</pre></div>
-<H2>NOTES</H2>
+<h2>SEE ALSO</h2>
-The geographic coordinates north, south, east, and west
-describe the outer edges of the geographic region. They
-run along the edges of the cells at the edge of the
-geographic region and <EM>not</EM> through the center of the cells
-at the edges.
-The NW value occurs at the beginning of the first line of data, and the
-SW value occurs at the beginning of the last line of data.
-<P>
-The data (which follows the header section) must contain
-<tt>r</tt> <em>x</em> <tt>c</tt> values, but it is not necessary
-that all the data for a row be on one line. A row may be
-split over many lines.
+<em>
+<a href="r.out.ascii.html">r.out.ascii</a>,
+<a href="r.in.arc.html">r.in.arc</a>,
+<a href="r.in.gdal.html">r.in.gdal</a>,
+<a href="r.out.arc.html">r.out.arc</a>,
+<a href="r.in.bin.html">r.in.bin</a>,
+<a href="r3.in.ascii.html">r3.in.ascii</a></em>,
+<a href="http://grass.itc.it/gdp/html_grass5/ascii_formats.html">GRASS ASCII formats</a>
+</em>
-<P>
+<h2>AUTHOR</h2>
-<EM>r.in.ascii</EM> handles floating point cell values.
-<P>
-The header information in ESRI Raster ASCII files differs from GRASS.
-To convert an Arc/Info (ArcView) ASCII grid file into GRASS, click
-<A HREF="http://grass.itc.it/faq/arcgrid.header.html">here</A>.
-Also, see <EM><A HREF="r.in.arc.html">r.in.arc</A></EM> to import
-ESRI Raster ASCII files.
-<H2>SEE ALSO</H2>
-<EM>
-<A HREF="r.out.ascii.html">r.out.ascii</A>,
-<A HREF="r.in.arc.html">r.in.arc</A>,
-<A HREF="r.in.gdal.html">r.in.gdal</A>,
-<A HREF="r.out.arc.html">r.out.arc</A>,
-<A HREF="r.in.bin.html">r.in.bin</A>,
-<A HREF="r3.in.ascii.html">r3.in.ascii</A></em>,
-<A HREF="http://grass.itc.it/gdp/html_grass5/ascii_formats.html">GRASS ASCII formats</A>
-</EM>
-<H2>AUTHOR</H2>
Michael Shapiro, U.S. Army Construction Engineering Research Laboratory<br>
Surfer support by Roger Miller
